Pull request: u-boot-rockchip-20231110
Hi Tom,
Please pull the fixex for rockchip platform: - Add Board: rk3588 Pine64 QuartzPro64; - fix rk3066 enter download mode; - fix for ringneck-px30 board;
CI: https://source.denx.de/u-boot/custodians/u-boot-rockchip/-/pipelines/18047
Thanks, - Kever
The following changes since commit e17d174773e9ba9447596708e702b7382e47a6cf:
Merge tag 'xilinx-for-v2024.01-rc3' of https://source.denx.de/u-boot/custodians/u-boot-microblaze (2023-11-07 10:36:23 -0500)
https://source.denx.de/u-boot/custodians/u-boot-rockchip.git tags/u-boot-rockchip-20231110
for you to fetch changes up to 4df4aea88fb99f413a0e3a2a96e176c6108939e3:
rockchip: include: asm: fix entering download mode rk3066 (2023-11-09 18:07:21 +0800)
---------------------------------------------------------------- Johan Jonker (1): rockchip: include: asm: fix entering download mode rk3066
Quentin Schulz (3): rockchip: ringneck-px30: enable i2c command rockchip: ringneck-px30: always reset STM32 companion controller on boot rockchip: ringneck-px30: enable SPL_BOARD_INIT
Tim Lunn (3): rockchip: dts: fix bootph tags for rv1126 rockchip: otp: Add support for RV1126 rockchip: rv1126: Read cpuid from otp and set ethaddr
Tom Fitzhenry (1): board: rockchip: add Pine64 QuartzPro64 RK3588 board
arch/arm/dts/Makefile | 1 + arch/arm/dts/rk3588-quartzpro64-u-boot.dtsi | 12 + arch/arm/dts/rk3588-quartzpro64.dts | 1137 ++++++++++++++++++++ arch/arm/dts/rv1126-u-boot.dtsi | 18 +- arch/arm/include/asm/arch-rk3066/boot0.h | 77 +- arch/arm/mach-rockchip/Kconfig | 4 +- arch/arm/mach-rockchip/rk3066/Kconfig | 8 + arch/arm/mach-rockchip/rk3588/Kconfig | 8 + board/pine64/quartzpro64-rk3588/Kconfig | 15 + board/pine64/quartzpro64-rk3588/MAINTAINERS | 8 + board/pine64/quartzpro64-rk3588/Makefile | 3 + .../pine64/quartzpro64-rk3588/quartzpro64-rk3588.c | 39 + .../ringneck_px30/ringneck-px30.c | 53 + configs/quartzpro64-rk3588_defconfig | 72 ++ configs/ringneck-px30_defconfig | 2 + doc/board/rockchip/rockchip.rst | 1 + drivers/misc/rockchip-otp.c | 76 ++ include/configs/quartzpro64-rk3588.h | 14 + 18 files changed, 1543 insertions(+), 5 deletions(-) create mode 100644 arch/arm/dts/rk3588-quartzpro64-u-boot.dtsi create mode 100644 arch/arm/dts/rk3588-quartzpro64.dts create mode 100644 board/pine64/quartzpro64-rk3588/Kconfig create mode 100644 board/pine64/quartzpro64-rk3588/MAINTAINERS create mode 100644 board/pine64/quartzpro64-rk3588/Makefile create mode 100644 board/pine64/quartzpro64-rk3588/quartzpro64-rk3588.c create mode 100644 configs/quartzpro64-rk3588_defconfig create mode 100644 include/configs/quartzpro64-rk3588.h
On Fri, Nov 10, 2023 at 05:09:14PM +0800, Kever Yang wrote:
Hi Tom,
Thanks,
- Kever
Kever Yang
