[U-Boot-Users] need PPC asm. help. for 83xx watchdog
Hi.
Attempting to enable&use watchdog in 8343; but run into Assembler (v.2.15) problem in cpu/mpc83xx/start.S:424 .... /* and reset it */ li r4, 0x556C sth r4, SWSRR@l(r3) li r4, 0xAA39 <-------- gas barks here, 0xAA39 > 0x8000 sth r4, SWSRR@l(r3)
which I do not understand, since I thought 'li' was an UNsigned 16bit load. I can work around it in a kludgey way with.
lis r4, 0 ori r4, r4, 0xAA39 sth r4, SWSRR@l(r3)
but wonder if one you PowerPC assembler gurus could offer better suggestion.
Thanx.
-dbu.
David Updegraff wrote:
Hi.
Thanx.
-dbu.
"li" is a simplified mnemonic which is actually "addi" (which sign-extends the immediate value) according to the "PowerPC Microprocessor Family: The Programming Environments" Appendix F (p. F-15).
Why gas barks, I'm not quite sure. Probably because it suspects you wanted it unsigned (which actually is the case - I hate it when tools are smarter than me).
gvb
Hi.
Thanx.
-dbu.
gvb
This SF.net email is sponsored by: Splunk Inc. Do you grep through log files for problems? Stop! Download the new AJAX search engine that makes searching your log files as easy as surfing the web. DOWNLOAD SPLUNK! http://ads.osdn.com/?ad_id=7637&alloc_id=16865&op=click _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Did you tried using li r4, 0xaa39@l ?
Pantelis
David Updegraff
Jerry Van Baren
Pantelis Antoniou
