[U-Boot] [PATCH] ti: clocks: Fix do_enable_clocks() to accept NULL pointers as input parameters
Up till this commit passing NULL as input parameter was allowed, but not handled properly.
When one passed NULL to one of this function parameters, the code was executed causing data abort.
However, what is more interesting, the abort was not caught because of code execution in HYP mode with masked CPSR A bit ("Imprecise Data Abort mask bit). The TI's AM57xx SoC switch to HYP mode with A bit masked in lowlevel_init.S due to SMC call. Such operation (by default) is performed in SoC ROM code.
The problem would pop up when one: - Switch back to SVC mode after disabling LPAE support - Somebody enables A bit (by executing cpsie a asm instruction)
and then the previously described exception would be caught.
Signed-off-by: Lukasz Majewski lukma@denx.de --- arch/arm/cpu/armv7/omap-common/clocks-common.c | 10 ++++++---- 1 file changed, 6 insertions(+), 4 deletions(-)
diff --git a/arch/arm/cpu/armv7/omap-common/clocks-common.c b/arch/arm/cpu/armv7/omap-common/clocks-common.c index 097b8e3..157155a 100644 --- a/arch/arm/cpu/armv7/omap-common/clocks-common.c +++ b/arch/arm/cpu/armv7/omap-common/clocks-common.c @@ -822,27 +822,29 @@ void do_enable_clocks(u32 const *clk_domains, u32 i, max = 100;
/* Put the clock domains in SW_WKUP mode */ - for (i = 0; (i < max) && clk_domains[i]; i++) { + for (i = 0; (i < max) && clk_domains && clk_domains[i]; i++) { enable_clock_domain(clk_domains[i], CD_CLKCTRL_CLKTRCTRL_SW_WKUP); }
/* Clock modules that need to be put in HW_AUTO */ - for (i = 0; (i < max) && clk_modules_hw_auto[i]; i++) { + for (i = 0; (i < max) && clk_modules_hw_auto && + clk_modules_hw_auto[i]; i++) { enable_clock_module(clk_modules_hw_auto[i], MODULE_CLKCTRL_MODULEMODE_HW_AUTO, wait_for_enable); };
/* Clock modules that need to be put in SW_EXPLICIT_EN mode */ - for (i = 0; (i < max) && clk_modules_explicit_en[i]; i++) { + for (i = 0; (i < max) && clk_modules_explicit_en && + clk_modules_explicit_en[i]; i++) { enable_clock_module(clk_modules_explicit_en[i], MODULE_CLKCTRL_MODULEMODE_SW_EXPLICIT_EN, wait_for_enable); };
/* Put the clock domains in HW_AUTO mode now */ - for (i = 0; (i < max) && clk_domains[i]; i++) { + for (i = 0; (i < max) && clk_domains && clk_domains[i]; i++) { enable_clock_domain(clk_domains[i], CD_CLKCTRL_CLKTRCTRL_HW_AUTO); }
This has been moved to arch/arm/mach-omap2/clocks-common.c Please use the latest U-Boot.
- for (i = 0; (i < max) && clk_domains && clk_domains[i]; i++) {
Instead of checking for clk_domains every time, can we use max as ARRAY_SIZE(clk_domains)? Similarly other places.
Thanks and regards, Lokesh
- for (i = 0; (i < max) && clk_domains && clk_domains[i]; i++) { enable_clock_domain(clk_domains[i], CD_CLKCTRL_CLKTRCTRL_HW_AUTO); }
Hi Lokesh,
Ok. I'm not working on a cutting-edge u-boot.
i++) {
do_enable_clocks() accepts pointer to u32 as an argument (clk_domains). IMHO the ARRAY_SIZE(clk_domains) would be 1 - always.
mode */
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
On Friday 24 March 2017 02:41 PM, Lukasz Majewski wrote:
Hi Lokesh,
i++) {
you are right. Discard my comment.
Signed-off-by: Lukasz Majewski lukma@denx.de --- Changes for v2: - Rebase to the newest "master" branch --- arch/arm/mach-omap2/clocks-common.c | 10 ++++++---- 1 file changed, 6 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-omap2/clocks-common.c b/arch/arm/mach-omap2/clocks-common.c index 84f93e7..93c4c6f 100644 --- a/arch/arm/mach-omap2/clocks-common.c +++ b/arch/arm/mach-omap2/clocks-common.c @@ -828,27 +828,29 @@ void do_enable_clocks(u32 const *clk_domains, u32 i, max = 100;
Signed-off-by: Lukasz Majewski lukma@denx.de Reviewed-by: Tom Rini trini@konsulko.com
Lokesh Vutla
Lukasz Majewski
