[U-Boot] [PATCH 00/19] First step towards Kbuild: Use Kbuild style makefiles
Kbuild in U-Boot has been talked for a while and RFC patches were posted by Simon Glass.
(Refer to "RFC: Add Kbuild system to U-Boot" posted by Simon, May 12, 2013)
Simon's effort is a good start point but varous critical features were missing from his patch series.
I have also been eager to introduce Kbuild to U-Boot. So I have been working on this task for a while with a little different migration path from Simon's way. And I succeeded to build a few boards with support of SPL build, Out-of-tree build, correct output file names, which were missing from Simon's patches.
While I were working on my local branch, the build system and makefiles in U-Boot master repository always kept changing, of course.
So, my fruit does not fit with the current master repository anymore. But if someone is interested in my work, I can push my local branch to somewhere in my GitHub space. (RFC quality, but might be helpful for just discussions)
I recognize these patches are so rough that they support only a few ARM boards. Perfectly covering all architectures and all boards without breaking any U-Boot features is a too big task for a sigle indivisual.
Even if I could do that, the patch series would be extremely big size and the adjustment for U-Boot would be complecated. So the review would probably take very long time. Along with the review process, as time goes by, the posted patches would become not appled to the master branch.
So we would need to repeat post, review, fix, rebase on the master and post again, reviwe, ... again and again for a very big patch series.
I began to be wondering it is possible to switch to Kbuild in this way.
So I decided to begin with what I can do, one by one. By stepping little by litte, we can get close to Kbuild and finally we will arrive at our goal. I think this strategy is more realistic rather than adding a big change at one time.
Before adding a real Kbuild, I'd like to adjust our build system in a form suitable for Kbuild.
First of all, this series convert makefiles in sub directories to Kbuild style.
What this series do is quite simple: - Moving common lines in sub makefiles to a new file 'scripts/Makefile.build' - Renaming COBJS-y and SOBJS-y to obj-y in each sub makefile. - A little bit more tweaks
That's all.
0001 creates scripts/Makefile.build and tweaks Makefile and spl/Makefile to use scripts/Makefile.build.
U-Boot conventional makefiles are like this:
include $(TOPDIR)/config.mk
LIB = $(obj)libfoo.o
COBJS := ... COBJS += ... SOBJS := ...
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS))
all: $(obj).depend $(LIB)
$(LIB): $(OBJS) $(call cmd_link_o_target, $(OBJS))
include $(SRCTREE)/rules.mk
sinclude $(obj).depend
Top and bottom parts are common in almost all makefiles. Writing those lines in all makefiles is a big waste. So common lines have been pushed into scripts/Makefile.build. In addition, scripts/Makefile.build includes a glue code for supporting 'obj-y'. Be aware U-Boot conventional makefile sytle is still supported. So we can change sub makefiles little by little in the following patches.
0002-0019 change sub makefiles into a Kbuild suitable form using obj-y. In order to avoid creating a big patch file, they are divided by CPU architectures and categories.
0002-0007: refactor under arch/arm/ 0008-0016: refactor libraries which are common for all architectures 0017 : refactor under arch/powerpc/ 0018 : refactor under board/ti/
Note arch/arm/cpu/s3c44b0/Makefile was kept untouched. It is the remainder of dead board and should be deleted. (See 'ARM: s3c44b0: remove remainders of dead board' posted by me Aug 19)
(I am not a maintainer of TI boards, but I just wanted to demonstrate in 0018 for example how easily board maintainers can do this conversion)
Conversion rule is pretty easy:
(1) Delete common parts at top and bottom. (2) Rename COBJS -> obj-y SOBJS -> obj-y COBJS-$(CONFIG_FOO) -> obj-$(CONFIG_FOO) SOBJS-$(CONFIG_FOO) -> obj-$(CONFIG_FOO) START -> extra-y
We can convert almost automatically althogh in some cases we may need to tweak a little.
I refactored more than 150 makefiles in this series. But we still have more than 600 makefiles. (Most of them reside under board/ directory) We can convert them lator little by little. Your contribution is welcome! :-)
Note1: This series breaks _NO_ features in U-Boot. Beucase it just moves common parts into scripts/Makefile.build
I believe no boards are broken by this refactoring, but it is humans who can make a mistake. So, it is very important to do build check before patches are applied.
I tested for ARM and Sandbox like this:
$ CROSS_COMPILE_ARM=arm-linux-gnueabi- ./MAKEALL -a arm -a sandbox
and I got:
--------------------- SUMMARY ---------------------------- Boards compiled: 336 ----------------------------------------------------------
I could not test other architectures because I don't have suitable compiler. Especially PowerPC boards must be checked since I changed under arch/powerpc/ in 0017. I will be grateful for any custodians' help.
Note2: This series is _NOT_ RFC. I believe what these patches are doing is clear. 0001 changes less than 100 lines. 0002-0019 changes lots of makefiles, but the conversion rule is simple.
So, I expect this series will be reviewed in a few weeks and hopefully applied to master while the next merge window if the review passed.
Note3: obj-y := foo/ (descending into foo sub directory) syntax is not supprted in this series. It is implemented in upcoming patch series. The reason why I postpone this feature is I don't want to add a big change at one time. Adjusting for Kbuild little by litte is my strategy here for easy review.
Note4: Of course, scripts/Makefile.build added by 0001 patch is temporary. It shall be replaced with the one of Linux Kernel in future.
Note5: I confirmed these patches can be apply on v2013.10-rc2 tag.
Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@ti.com
Masahiro Yamada (19): Makefile: prepare for using Kbuild-style Makefile armv7: convert makefiles to Kbuild style arm926ejs: convert makefiles to Kbuild style arm920t: convert makefiles to Kbuild style arm720t: convert makefiles to Kbuild style ARM: convert makefiles to Kbuild style ARM: imx-common: convert makefiles to Kbuild style drivers: net: convert makefiles to Kbuild style drivers: mtd: convert makefiles to Kbuild style drivers: usb: convert makefiles to Kbuild style drivers: convert makefiles to Kbuild style fs: convert makefiles to Kbuild style common: convert makefiles to Kbuild style net: convert a makefile to Kbuild style lib: convert makefiles to Kbuild style disk: convert a makefile to Kbuild style sandbox: convert makefiles to Kbuild style powerpc: convert makefiles to Kbuild style board: ti: convert makefiles to Kbuild style
Makefile | 42 +++- arch/arm/cpu/arm1136/Makefile | 26 +- arch/arm/cpu/arm1136/mx31/Makefile | 27 +- arch/arm/cpu/arm1136/mx35/Makefile | 28 +-- arch/arm/cpu/arm1176/Makefile | 26 +- arch/arm/cpu/arm1176/bcm2835/Makefile | 25 +- arch/arm/cpu/arm1176/tnetv107x/Makefile | 27 +- arch/arm/cpu/arm720t/Makefile | 26 +- arch/arm/cpu/arm720t/tegra-common/Makefile | 25 +- arch/arm/cpu/arm720t/tegra114/Makefile | 25 +- arch/arm/cpu/arm720t/tegra20/Makefile | 23 +- arch/arm/cpu/arm720t/tegra30/Makefile | 23 +- arch/arm/cpu/arm920t/Makefile | 28 +-- arch/arm/cpu/arm920t/a320/Makefile | 25 +- arch/arm/cpu/arm920t/at91/Makefile | 33 +-- arch/arm/cpu/arm920t/ep93xx/Makefile | 24 +- arch/arm/cpu/arm920t/imx/Makefile | 27 +- arch/arm/cpu/arm920t/ks8695/Makefile | 26 +- arch/arm/cpu/arm920t/s3c24x0/Makefile | 29 +-- arch/arm/cpu/arm925t/Makefile | 30 +-- arch/arm/cpu/arm926ejs/Makefile | 28 +-- arch/arm/cpu/arm926ejs/armada100/Makefile | 23 +- arch/arm/cpu/arm926ejs/at91/Makefile | 59 ++--- arch/arm/cpu/arm926ejs/davinci/Makefile | 48 +--- arch/arm/cpu/arm926ejs/kirkwood/Makefile | 31 +-- arch/arm/cpu/arm926ejs/lpc32xx/Makefile | 23 +- arch/arm/cpu/arm926ejs/mb86r0x/Makefile | 25 +- arch/arm/cpu/arm926ejs/mx25/Makefile | 23 +- arch/arm/cpu/arm926ejs/mx27/Makefile | 23 +- arch/arm/cpu/arm926ejs/mxs/Makefile | 26 +- arch/arm/cpu/arm926ejs/nomadik/Makefile | 25 +- arch/arm/cpu/arm926ejs/omap/Makefile | 26 +- arch/arm/cpu/arm926ejs/orion5x/Makefile | 29 +-- arch/arm/cpu/arm926ejs/pantheon/Makefile | 23 +- arch/arm/cpu/arm926ejs/spear/Makefile | 36 +-- arch/arm/cpu/arm926ejs/versatile/Makefile | 26 +- arch/arm/cpu/arm946es/Makefile | 26 +- arch/arm/cpu/arm_intcm/Makefile | 26 +- arch/arm/cpu/armv7/Makefile | 32 +-- arch/arm/cpu/armv7/am33xx/Makefile | 51 +--- arch/arm/cpu/armv7/at91/Makefile | 31 +-- arch/arm/cpu/armv7/exynos/Makefile | 34 +-- arch/arm/cpu/armv7/highbank/Makefile | 24 +- arch/arm/cpu/armv7/mx5/Makefile | 25 +- arch/arm/cpu/armv7/mx6/Makefile | 23 +- arch/arm/cpu/armv7/omap-common/Makefile | 43 +--- arch/arm/cpu/armv7/omap3/Makefile | 41 +-- arch/arm/cpu/armv7/omap4/Makefile | 31 +-- arch/arm/cpu/armv7/omap5/Makefile | 33 +-- arch/arm/cpu/armv7/rmobile/Makefile | 51 +--- arch/arm/cpu/armv7/s5p-common/Makefile | 29 +-- arch/arm/cpu/armv7/s5pc1xx/Makefile | 27 +- arch/arm/cpu/armv7/socfpga/Makefile | 29 +-- arch/arm/cpu/armv7/tegra-common/Makefile | 24 +- arch/arm/cpu/armv7/tegra114/Makefile | 22 +- arch/arm/cpu/armv7/tegra20/Makefile | 26 +- arch/arm/cpu/armv7/tegra30/Makefile | 22 +- arch/arm/cpu/armv7/u8500/Makefile | 25 +- arch/arm/cpu/armv7/vf610/Makefile | 25 +- arch/arm/cpu/armv7/zynq/Makefile | 29 +-- arch/arm/cpu/ixp/Makefile | 30 +-- arch/arm/cpu/pxa/Makefile | 36 +-- arch/arm/cpu/sa1100/Makefile | 28 +-- arch/arm/cpu/tegra-common/Makefile | 25 +- arch/arm/cpu/tegra114-common/Makefile | 23 +- arch/arm/cpu/tegra20-common/Makefile | 29 +-- arch/arm/cpu/tegra30-common/Makefile | 26 +- arch/arm/imx-common/Makefile | 35 +-- arch/arm/lib/Makefile | 86 ++----- arch/powerpc/cpu/74xx_7xx/Makefile | 28 +-- arch/powerpc/cpu/mpc512x/Makefile | 51 ++-- arch/powerpc/cpu/mpc5xx/Makefile | 27 +- arch/powerpc/cpu/mpc5xxx/Makefile | 54 ++-- arch/powerpc/cpu/mpc824x/Makefile | 28 +-- arch/powerpc/cpu/mpc8260/Makefile | 30 +-- arch/powerpc/cpu/mpc83xx/Makefile | 58 ++--- arch/powerpc/cpu/mpc85xx/Makefile | 233 ++++++++--------- arch/powerpc/cpu/mpc86xx/Makefile | 50 ++-- arch/powerpc/cpu/mpc8xx/Makefile | 58 ++--- arch/powerpc/cpu/mpc8xxx/Makefile | 30 +-- arch/powerpc/cpu/mpc8xxx/ddr/Makefile | 30 +-- arch/powerpc/cpu/ppc4xx/Makefile | 90 +++---- arch/powerpc/lib/Makefile | 78 ++---- arch/sandbox/cpu/Makefile | 23 +- arch/sandbox/lib/Makefile | 25 +- board/ti/am335x/Makefile | 29 +-- board/ti/am3517crane/Makefile | 19 +- board/ti/am43xx/Makefile | 29 +-- board/ti/beagle/Makefile | 24 +- board/ti/dra7xx/Makefile | 27 +- board/ti/evm/Makefile | 19 +- board/ti/omap1510inn/Makefile | 24 +- board/ti/omap5912osk/Makefile | 24 +- board/ti/omap5_uevm/Makefile | 27 +- board/ti/omap730p2/Makefile | 24 +- board/ti/panda/Makefile | 21 +- board/ti/sdp3430/Makefile | 21 +- board/ti/sdp4430/Makefile | 23 +- board/ti/ti814x/Makefile | 29 +-- board/ti/ti816x/Makefile | 27 +- board/ti/tnetv107xevm/Makefile | 25 +- common/Makefile | 389 ++++++++++++++--------------- common/spl/Makefile | 36 +-- disk/Makefile | 34 +-- drivers/bios_emulator/Makefile | 23 +- drivers/block/Makefile | 52 ++-- drivers/bootcount/Makefile | 30 +-- drivers/crypto/Makefile | 25 +- drivers/dfu/Makefile | 25 +- drivers/dma/Makefile | 30 +-- drivers/fpga/Makefile | 44 +--- drivers/gpio/Makefile | 73 ++---- drivers/hwmon/Makefile | 40 +-- drivers/i2c/Makefile | 70 ++---- drivers/input/Makefile | 36 +-- drivers/misc/Makefile | 52 ++-- drivers/mmc/Makefile | 69 ++--- drivers/mtd/Makefile | 44 +--- drivers/mtd/nand/Makefile | 102 +++----- drivers/mtd/onenand/Makefile | 27 +- drivers/mtd/spi/Makefile | 48 +--- drivers/mtd/ubi/Makefile | 28 +-- drivers/net/Makefile | 136 +++++----- drivers/net/fm/Makefile | 59 ++--- drivers/net/npe/Makefile | 24 +- drivers/net/phy/Makefile | 60 ++--- drivers/pci/Makefile | 44 +--- drivers/pcmcia/Makefile | 34 +-- drivers/power/Makefile | 47 +--- drivers/power/battery/Makefile | 25 +- drivers/power/fuel_gauge/Makefile | 25 +- drivers/power/pmic/Makefile | 31 +-- drivers/qe/Makefile | 25 +- drivers/rtc/Makefile | 110 ++++---- drivers/serial/Makefile | 82 +++--- drivers/sound/Makefile | 30 +-- drivers/spi/Makefile | 82 +++--- drivers/tpm/Makefile | 29 +-- drivers/twserial/Makefile | 24 +- drivers/usb/eth/Makefile | 28 +-- drivers/usb/gadget/Makefile | 54 ++-- drivers/usb/host/Makefile | 74 ++---- drivers/usb/musb-new/Makefile | 36 +-- drivers/usb/musb/Makefile | 36 +-- drivers/usb/phy/Makefile | 24 +- drivers/usb/ulpi/Makefile | 28 +-- drivers/video/Makefile | 84 +++---- drivers/watchdog/Makefile | 36 +-- fs/Makefile | 24 +- fs/cbfs/Makefile | 24 +- fs/cramfs/Makefile | 29 +-- fs/ext4/Makefile | 27 +- fs/fat/Makefile | 31 +-- fs/fdos/Makefile | 27 +- fs/jffs2/Makefile | 38 +-- fs/reiserfs/Makefile | 26 +- fs/sandbox/Makefile | 23 +- fs/ubifs/Makefile | 29 +-- fs/yaffs2/Makefile | 33 +-- fs/zfs/Makefile | 25 +- lib/Makefile | 114 ++++----- lib/libfdt/Makefile | 27 +- lib/lzma/Makefile | 24 +- lib/lzo/Makefile | 24 +- lib/rsa/Makefile | 22 +- lib/tizen/Makefile | 24 +- lib/zlib/Makefile | 22 +- net/Makefile | 46 +--- scripts/Makefile.build | 48 ++++ spl/Makefile | 24 +- 170 files changed, 1511 insertions(+), 5095 deletions(-) create mode 100644 scripts/Makefile.build
In every sub directory, Makefile is like follows:
Top and bottom parts are common in almost all sub-makefiles. This is a big waste. This commit pushes common parts of makefiles into script/Makefile.build.
Going forward sub-makefiles only need to describe this part:
But, script/Makefile.build includes the glue code to support obj-y, the following style (the same as Kbuild) is preferable:
obj-y := ... obj-$(CONFIG_FOO) += ... obj-$(CONFIG_BAR) += ...
The conventional U-Boot Makefile style is still supported. This is achieved by greping the Makefile before entering into it. U-Boot conventional sub makefiles always include some other makefiles. So the build system searches a line with beginning with "include" keyword in the makefile in order to distinguish which style it is. If the Makefile include a "include" line, we assume it is a conventional U-Boot style. Otherwise, it is treated as a Kbuild-style makefile.
(At first, I tried to grep "rules.mk" keyword instead, but I found it does not work. Almost all sub makefiles include "rules.mk", but there exist three exception: - board/avnet/fx12mm/Makefile - board/avnet/v5fx30teval/Makefile - board/xilinx/ml507/Makefile These three makefiles include "rules.mk" indirectly. Anyway, they look weird, so they should be fixed lator.)
With this tweak, we can switch sub-makefiles from U-Boot style to Kbuild style little by little.
This refactoring of sub makefiles is the first step towards Kbuild, and makes it easy to import a "real" Kbuild from Linux Kernel.
Note that this refactoring breaks nothing because it just moves the common parts into scripts/Makefile.build.
Note one more thing:
obj-y := foo/ # descending into foo sub directory
syntax is not supported yet. (This feature will be implemented in the upcoming commit series.)
Of course, scripts/Makefile.build added by this commit is temporary. It shall be replaced with the one of Linux Kernel in future.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Simon Glass sjg@chromium.org --- Makefile | 34 ++++++++++++++++++++++++++++++---- scripts/Makefile.build | 48 ++++++++++++++++++++++++++++++++++++++++++++++++ spl/Makefile | 20 ++++++++++++++++++-- 3 files changed, 96 insertions(+), 6 deletions(-) create mode 100644 scripts/Makefile.build
diff --git a/Makefile b/Makefile index ed48279..852f80b 100644 --- a/Makefile +++ b/Makefile @@ -592,14 +592,35 @@ ifeq ($(CONFIG_KALLSYMS),y) $(GEN_UBOOT) $(obj)common/system_map.o endif
+# Tentative step for Kbuild-style makefiles coexist with conventional U-Boot style makefiles +# U-Boot conventional sub makefiles always include some other makefiles. +# So, the build system searches a line beginning with "include" before entering into the sub makefile +# in order to distinguish which style it is. +# If the Makefile include a "include" line, we assume it is an U-Boot style makefile. +# Otherwise, it is treated as a Kbuild-style makefile. + +# We do not need to build $(OBJS) explicitly. +# It is built while we are at $(CPUDIR)/lib$(CPU).o build. $(OBJS): depend - $(MAKE) -C $(CPUDIR) $(if $(REMOTE_BUILD),$@,$(notdir $@)) + if grep -q "^include" $(CPUDIR)/Makefile; then \ + $(MAKE) -C $(CPUDIR) $(if $(REMOTE_BUILD),$@,$(notdir $@)); \ + fi
$(LIBS): depend $(SUBDIR_TOOLS) - $(MAKE) -C $(dir $(subst $(obj),,$@)) + if grep -q "^include" $(dir $(subst $(obj),,$@))Makefile; then \ + $(MAKE) -C $(dir $(subst $(obj),,$@)); \ + else \ + $(MAKE) -C $(dir $(subst $(obj),,$@)) -f $(TOPDIR)/scripts/Makefile.build; \ + mv $(dir $@)built-in.o $@; \ + fi
$(LIBBOARD): depend $(LIBS) - $(MAKE) -C $(dir $(subst $(obj),,$@)) + if grep -q "^include" $(dir $(subst $(obj),,$@))/Makefile; then \ + $(MAKE) -C $(dir $(subst $(obj),,$@)); \ + else \ + $(MAKE) -C $(dir $(subst $(obj),,$@)) -f $(TOPDIR)/scripts/Makefile.build; \ + mv $(dir $@)built-in.o $@; \ + fi
$(SUBDIRS): depend $(MAKE) -C $@ all @@ -636,7 +657,12 @@ depend dep: $(TIMESTAMP_FILE) $(VERSION_FILE) \ $(obj)include/generated/generic-asm-offsets.h \ $(obj)include/generated/asm-offsets.h for dir in $(SUBDIRS) $(CPUDIR) $(LDSCRIPT_MAKEFILE_DIR) ; do \ - $(MAKE) -C $$dir _depend ; done + if grep -q "^include" $$dir/Makefile; then \ + $(MAKE) -C $$dir _depend ; \ + else \ + $(MAKE) -C $$dir -f $(TOPDIR)/scripts/Makefile.build _depend; \ + fi; \ + done
TAG_SUBDIRS = $(SUBDIRS) TAG_SUBDIRS += $(dir $(__LIBS)) diff --git a/scripts/Makefile.build b/scripts/Makefile.build new file mode 100644 index 0000000..f969ec5 --- /dev/null +++ b/scripts/Makefile.build @@ -0,0 +1,48 @@ +# our default target +.PHONY: all +all: + +include $(TOPDIR)/config.mk + +LIB := $(obj)built-in.o +LIBGCC = $(obj)libgcc.o +SRCS := + +include Makefile + +# Backward compatible: obj-y is preferable +COBJS := $(sort $(COBJS) $(COBJS-y)) +SOBJS := $(sort $(SOBJS) $(SOBJS-y)) + +# Going forward use the following +obj-y := $(sort $(obj-y)) +extra-y := $(sort $(extra-y)) +lib-y := $(sort $(lib-y)) + +SRCS += $(COBJS:.o=.c) $(SOBJS:.o=.S) \ + $(wildcard $(obj-y:.o=.c) $(obj-y:.o=.S) $(lib-y:.o=.c) $(lib-y:.o=.S) $(extra-y:.o=.c) $(extra-y:.o=.S)) +OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS) $(obj-y)) + +LGOBJS := $(addprefix $(obj),$(sort $(GLSOBJS) $(GLCOBJS)) $(lib-y)) + +all: $(LIB) $(addprefix $(obj),$(extra-y)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +ifneq ($(strip $(lib-y)),) +all: $(LIBGCC) + +$(LIBGCC): $(obj).depend $(LGOBJS) + $(call cmd_link_o_target, $(LGOBJS)) +endif + +######################################################################### + +# defines $(obj).depend target + +include $(TOPDIR)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/spl/Makefile b/spl/Makefile index 339e5e8..7497b5f 100644 --- a/spl/Makefile +++ b/spl/Makefile @@ -198,11 +198,27 @@ GEN_UBOOT = \ $(obj)$(SPL_BIN): depend $(START) $(LIBS) $(obj)u-boot-spl.lds $(GEN_UBOOT)
+# Tentative step for Kbuild-style makefiles coexist with conventional U-Boot style makefiles +# U-Boot conventional sub makefiles always include some other makefiles. +# So, the build system searches a line beginning with "include" before entering into the sub makefile +# in order to distinguish which style it is. +# If the Makefile include a "include" line, we assume it is an U-Boot style makefile. +# Otherwise, it is treated as a Kbuild-style makefile. + +# We do not need to build $(START) explicitly. +# It is built while we are at $(CPUDIR)/lib$(CPU).o build. $(START): depend - $(MAKE) -C $(SRCTREE)/$(START_PATH) $@ + if grep -q "^include" $(SRCTREE)$(dir $(subst $(SPLTREE),,$@))Makefile; then \ + $(MAKE) -C $(SRCTREE)/$(START_PATH) $@; \ + fi
$(LIBS): depend - $(MAKE) -C $(SRCTREE)$(dir $(subst $(SPLTREE),,$@)) + if grep -q "^include" $(SRCTREE)$(dir $(subst $(SPLTREE),,$@))Makefile; then \ + $(MAKE) -C $(SRCTREE)$(dir $(subst $(SPLTREE),,$@)); \ + else \ + $(MAKE) -C $(SRCTREE)$(dir $(subst $(SPLTREE),,$@)) -f $(TOPDIR)/scripts/Makefile.build; \ + mv $(dir $@)built-in.o $@; \ + fi
$(obj)u-boot-spl.lds: $(LDSCRIPT) depend $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -I$(obj). -ansi -D__ASSEMBLY__ -P - < $< > $@
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com --- arch/arm/cpu/armv7/Makefile | 32 ++++---------------- arch/arm/cpu/armv7/am33xx/Makefile | 51 ++++++++------------------------ arch/arm/cpu/armv7/at91/Makefile | 31 ++++--------------- arch/arm/cpu/armv7/exynos/Makefile | 34 ++++----------------- arch/arm/cpu/armv7/highbank/Makefile | 24 +-------------- arch/arm/cpu/armv7/mx5/Makefile | 25 ++-------------- arch/arm/cpu/armv7/mx6/Makefile | 23 +------------- arch/arm/cpu/armv7/omap-common/Makefile | 43 +++++++-------------------- arch/arm/cpu/armv7/omap3/Makefile | 41 +++++++------------------ arch/arm/cpu/armv7/omap4/Makefile | 31 ++++--------------- arch/arm/cpu/armv7/omap5/Makefile | 33 ++++----------------- arch/arm/cpu/armv7/rmobile/Makefile | 51 ++++++++------------------------ arch/arm/cpu/armv7/s5p-common/Makefile | 29 +++--------------- arch/arm/cpu/armv7/s5pc1xx/Makefile | 27 ++--------------- arch/arm/cpu/armv7/socfpga/Makefile | 29 ++---------------- arch/arm/cpu/armv7/tegra-common/Makefile | 24 +-------------- arch/arm/cpu/armv7/tegra114/Makefile | 22 +------------- arch/arm/cpu/armv7/tegra20/Makefile | 26 ++-------------- arch/arm/cpu/armv7/tegra30/Makefile | 22 +------------- arch/arm/cpu/armv7/u8500/Makefile | 25 ++-------------- arch/arm/cpu/armv7/vf610/Makefile | 25 ++-------------- arch/arm/cpu/armv7/zynq/Makefile | 29 ++---------------- 22 files changed, 99 insertions(+), 578 deletions(-)
diff --git a/arch/arm/cpu/armv7/Makefile b/arch/arm/cpu/armv7/Makefile index b723e22..75fac4b 100644 --- a/arch/arm/cpu/armv7/Makefile +++ b/arch/arm/cpu/armv7/Makefile @@ -5,35 +5,13 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk +extra-y := start.o
-LIB = $(obj)lib$(CPU).o +obj-y += cache_v7.o
-START := start.o - -COBJS += cache_v7.o - -COBJS += cpu.o -COBJS += syslib.o +obj-y += cpu.o +obj-y += syslib.o
ifneq ($(CONFIG_AM43XX)$(CONFIG_AM33XX)$(CONFIG_OMAP44XX)$(CONFIG_OMAP54XX)$(CONFIG_TEGRA)$(CONFIG_MX6)$(CONFIG_TI81XX),) -SOBJS += lowlevel_init.o +obj-y += lowlevel_init.o endif - -SRCS := $(START:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/arm/cpu/armv7/am33xx/Makefile b/arch/arm/cpu/armv7/am33xx/Makefile index f6a297c..966fcab 100644 --- a/arch/arm/cpu/armv7/am33xx/Makefile +++ b/arch/arm/cpu/armv7/am33xx/Makefile @@ -4,46 +4,19 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-$(CONFIG_AM33XX) += clock_am33xx.o -COBJS-$(CONFIG_TI814X) += clock_ti814x.o -COBJS-$(CONFIG_AM43XX) += clock_am43xx.o +obj-$(CONFIG_AM33XX) += clock_am33xx.o +obj-$(CONFIG_TI814X) += clock_ti814x.o +obj-$(CONFIG_AM43XX) += clock_am43xx.o
ifneq ($(CONFIG_AM43XX)$(CONFIG_AM33XX),) -COBJS += clock.o +obj-y += clock.o endif
-COBJS-$(CONFIG_TI816X) += clock_ti816x.o -COBJS += sys_info.o -COBJS += mem.o -COBJS += ddr.o -COBJS += emif4.o -COBJS += board.o -COBJS += mux.o -COBJS-$(CONFIG_NAND_OMAP_GPMC) += elm.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(COBJS-y) $(SOBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -clean: - rm -f $(SOBJS) $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak .depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_TI816X) += clock_ti816x.o +obj-y += sys_info.o +obj-y += mem.o +obj-y += ddr.o +obj-y += emif4.o +obj-y += board.o +obj-y += mux.o +obj-$(CONFIG_NAND_OMAP_GPMC) += elm.o diff --git a/arch/arm/cpu/armv7/at91/Makefile b/arch/arm/cpu/armv7/at91/Makefile index 90b9bd6..0a2e48d 100644 --- a/arch/arm/cpu/armv7/at91/Makefile +++ b/arch/arm/cpu/armv7/at91/Makefile @@ -8,29 +8,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-$(CONFIG_SAMA5D3) += sama5d3_devices.o -COBJS-y += clock.o -COBJS-y += cpu.o -COBJS-y += reset.o -COBJS-y += timer.o - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_SAMA5D3) += sama5d3_devices.o +obj-y += clock.o +obj-y += cpu.o +obj-y += reset.o +obj-y += timer.o diff --git a/arch/arm/cpu/armv7/exynos/Makefile b/arch/arm/cpu/armv7/exynos/Makefile index eb1633f..e207bd6 100644 --- a/arch/arm/cpu/armv7/exynos/Makefile +++ b/arch/arm/cpu/armv7/exynos/Makefile @@ -5,34 +5,12 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-y += clock.o power.o soc.o system.o pinmux.o tzpc.o +obj-y += clock.o power.o soc.o system.o pinmux.o tzpc.o
ifdef CONFIG_SPL_BUILD -COBJS-$(CONFIG_EXYNOS5) += clock_init_exynos5.o -COBJS-$(CONFIG_EXYNOS5) += dmc_common.o dmc_init_ddr3.o -COBJS-$(CONFIG_EXYNOS4210)+= dmc_init_exynos4.o clock_init_exynos4.o -COBJS-y += spl_boot.o -COBJS-y += lowlevel_init.o +obj-$(CONFIG_EXYNOS5) += clock_init_exynos5.o +obj-$(CONFIG_EXYNOS5) += dmc_common.o dmc_init_ddr3.o +obj-$(CONFIG_EXYNOS4210)+= dmc_init_exynos4.o clock_init_exynos4.o +obj-y += spl_boot.o +obj-y += lowlevel_init.o endif - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/arm/cpu/armv7/highbank/Makefile b/arch/arm/cpu/armv7/highbank/Makefile index 22e3b72..876099d 100644 --- a/arch/arm/cpu/armv7/highbank/Makefile +++ b/arch/arm/cpu/armv7/highbank/Makefile @@ -5,26 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS := timer.o -SOBJS := - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := timer.o diff --git a/arch/arm/cpu/armv7/mx5/Makefile b/arch/arm/cpu/armv7/mx5/Makefile index 7c86ae3..d021842 100644 --- a/arch/arm/cpu/armv7/mx5/Makefile +++ b/arch/arm/cpu/armv7/mx5/Makefile @@ -7,26 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS = soc.o clock.o -SOBJS = lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := soc.o clock.o +obj-y += lowlevel_init.o diff --git a/arch/arm/cpu/armv7/mx6/Makefile b/arch/arm/cpu/armv7/mx6/Makefile index c5e9858..eba0b86 100644 --- a/arch/arm/cpu/armv7/mx6/Makefile +++ b/arch/arm/cpu/armv7/mx6/Makefile @@ -7,25 +7,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS = soc.o clock.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := soc.o clock.o diff --git a/arch/arm/cpu/armv7/omap-common/Makefile b/arch/arm/cpu/armv7/omap-common/Makefile index 75b3753..4d3a165 100644 --- a/arch/arm/cpu/armv7/omap-common/Makefile +++ b/arch/arm/cpu/armv7/omap-common/Makefile @@ -5,46 +5,25 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libomap-common.o - -COBJS := reset.o -COBJS += timer.o -COBJS += utils.o +obj-y := reset.o +obj-y += timer.o +obj-y += utils.o
ifneq ($(CONFIG_OMAP44XX)$(CONFIG_OMAP54XX),) -COBJS += hwinit-common.o -COBJS += clocks-common.o -COBJS += emif-common.o -COBJS += vc.o -COBJS += abb.o +obj-y += hwinit-common.o +obj-y += clocks-common.o +obj-y += emif-common.o +obj-y += vc.o +obj-y += abb.o endif
ifeq ($(CONFIG_OMAP34XX),) -COBJS += boot-common.o -SOBJS += lowlevel_init.o +obj-y += boot-common.o +obj-y += lowlevel_init.o endif
ifndef CONFIG_SPL_BUILD ifneq ($(CONFIG_OMAP44XX)$(CONFIG_OMAP54XX),) -COBJS += mem-common.o +obj-y += mem-common.o endif endif - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/arm/cpu/armv7/omap3/Makefile b/arch/arm/cpu/armv7/omap3/Makefile index f070c18..39ff257 100644 --- a/arch/arm/cpu/armv7/omap3/Makefile +++ b/arch/arm/cpu/armv7/omap3/Makefile @@ -5,38 +5,17 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk +obj-y := lowlevel_init.o
-LIB = $(obj)lib$(SOC).o - -SOBJS := lowlevel_init.o - -COBJS += board.o -COBJS += clock.o -COBJS += mem.o -COBJS += sys_info.o +obj-y += board.o +obj-y += clock.o +obj-y += mem.o +obj-y += sys_info.o ifdef CONFIG_SPL_BUILD -COBJS-$(CONFIG_SPL_OMAP3_ID_NAND) += spl_id_nand.o +obj-$(CONFIG_SPL_OMAP3_ID_NAND) += spl_id_nand.o endif
-COBJS-$(CONFIG_DRIVER_TI_EMAC) += emac.o -COBJS-$(CONFIG_EMIF4) += emif4.o -COBJS-$(CONFIG_SDRC) += sdrc.o -COBJS-$(CONFIG_USB_MUSB_AM35X) += am35x_musb.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(COBJS-y) $(SOBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_DRIVER_TI_EMAC) += emac.o +obj-$(CONFIG_EMIF4) += emif4.o +obj-$(CONFIG_SDRC) += sdrc.o +obj-$(CONFIG_USB_MUSB_AM35X) += am35x_musb.o diff --git a/arch/arm/cpu/armv7/omap4/Makefile b/arch/arm/cpu/armv7/omap4/Makefile index fc6e2dd..76a032a 100644 --- a/arch/arm/cpu/armv7/omap4/Makefile +++ b/arch/arm/cpu/armv7/omap4/Makefile @@ -5,29 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS += sdram_elpida.o -COBJS += hwinit.o -COBJS += emif.o -COBJS += prcm-regs.o -COBJS += hw_data.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += sdram_elpida.o +obj-y += hwinit.o +obj-y += emif.o +obj-y += prcm-regs.o +obj-y += hw_data.o diff --git a/arch/arm/cpu/armv7/omap5/Makefile b/arch/arm/cpu/armv7/omap5/Makefile index 168302d..64c6879 100644 --- a/arch/arm/cpu/armv7/omap5/Makefile +++ b/arch/arm/cpu/armv7/omap5/Makefile @@ -5,30 +5,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS += hwinit.o -COBJS += emif.o -COBJS += sdram.o -COBJS += prcm-regs.o -COBJS += hw_data.o -COBJS += abb.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += hwinit.o +obj-y += emif.o +obj-y += sdram.o +obj-y += prcm-regs.o +obj-y += hw_data.o +obj-y += abb.o diff --git a/arch/arm/cpu/armv7/rmobile/Makefile b/arch/arm/cpu/armv7/rmobile/Makefile index 3168e97..8f4cf3a 100644 --- a/arch/arm/cpu/armv7/rmobile/Makefile +++ b/arch/arm/cpu/armv7/rmobile/Makefile @@ -5,45 +5,20 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -SOBJS = lowlevel_init.o -COBJS-y += cpu_info.o -COBJS-y += emac.o - -COBJS-$(CONFIG_DISPLAY_BOARDINFO) += board.o -COBJS-$(CONFIG_GLOBAL_TIMER) += timer.o -COBJS-$(CONFIG_R8A7740) += cpu_info-r8a7740.o -COBJS-$(CONFIG_R8A7740) += pfc-r8a7740.o -COBJS-$(CONFIG_SH73A0) += cpu_info-sh73a0.o -COBJS-$(CONFIG_SH73A0) += pfc-sh73a0.o -COBJS_LN-$(CONFIG_TMU_TIMER) += sh_timer.o - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) $(addprefix $(obj),$(COBJS_LN-y:.o=.c)) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS) $(COBJS_LN-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - +obj-y = lowlevel_init.o +obj-y += cpu_info.o +obj-y += emac.o + +obj-$(CONFIG_DISPLAY_BOARDINFO) += board.o +obj-$(CONFIG_GLOBAL_TIMER) += timer.o +obj-$(CONFIG_R8A7740) += cpu_info-r8a7740.o +obj-$(CONFIG_R8A7740) += pfc-r8a7740.o +obj-$(CONFIG_SH73A0) += cpu_info-sh73a0.o +obj-$(CONFIG_SH73A0) += pfc-sh73a0.o +obj-$(CONFIG_TMU_TIMER) += sh_timer.o + +SRCS += $(obj)sh_timer.c # from arch/sh/lib/ directory $(obj)sh_timer.c: @rm -f $(obj)sh_timer.c ln -s $(SRCTREE)/arch/sh/lib/time.c $(obj)sh_timer.c - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### - diff --git a/arch/arm/cpu/armv7/s5p-common/Makefile b/arch/arm/cpu/armv7/s5p-common/Makefile index fd7290c..f571d8a 100644 --- a/arch/arm/cpu/armv7/s5p-common/Makefile +++ b/arch/arm/cpu/armv7/s5p-common/Makefile @@ -5,30 +5,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libs5p-common.o - -COBJS-y += cpu_info.o +obj-y += cpu_info.o ifndef CONFIG_SPL_BUILD -COBJS-y += timer.o -COBJS-y += sromc.o -COBJS-$(CONFIG_PWM) += pwm.o +obj-y += timer.o +obj-y += sromc.o +obj-$(CONFIG_PWM) += pwm.o endif - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y) $(SOBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/arm/cpu/armv7/s5pc1xx/Makefile b/arch/arm/cpu/armv7/s5pc1xx/Makefile index 09fed66..9f43ded 100644 --- a/arch/arm/cpu/armv7/s5pc1xx/Makefile +++ b/arch/arm/cpu/armv7/s5pc1xx/Makefile @@ -8,28 +8,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk +obj-y = cache.o +obj-y += reset.o
-LIB = $(obj)lib$(SOC).o - -SOBJS = cache.o -SOBJS += reset.o - -COBJS += clock.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += clock.o diff --git a/arch/arm/cpu/armv7/socfpga/Makefile b/arch/arm/cpu/armv7/socfpga/Makefile index 3b48ac9..fbfb51e 100644 --- a/arch/arm/cpu/armv7/socfpga/Makefile +++ b/arch/arm/cpu/armv7/socfpga/Makefile @@ -7,29 +7,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
- -include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -SOBJS := lowlevel_init.o -COBJS-y := misc.o timer.o -COBJS-$(CONFIG_SPL_BUILD) += spl.o - -COBJS := $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := lowlevel_init.o +obj-y += misc.o timer.o +obj-$(CONFIG_SPL_BUILD) += spl.o diff --git a/arch/arm/cpu/armv7/tegra-common/Makefile b/arch/arm/cpu/armv7/tegra-common/Makefile index d97542d..463c260 100644 --- a/arch/arm/cpu/armv7/tegra-common/Makefile +++ b/arch/arm/cpu/armv7/tegra-common/Makefile @@ -7,26 +7,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libtegra-common.o - -COBJS-$(CONFIG_CMD_ENTERRCM) += cmd_enterrcm.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_CMD_ENTERRCM) += cmd_enterrcm.o diff --git a/arch/arm/cpu/armv7/tegra114/Makefile b/arch/arm/cpu/armv7/tegra114/Makefile index eb98c8e..886b509 100644 --- a/arch/arm/cpu/armv7/tegra114/Makefile +++ b/arch/arm/cpu/armv7/tegra114/Makefile @@ -17,24 +17,4 @@ # along with this program. If not, see http://www.gnu.org/licenses/. #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj- := diff --git a/arch/arm/cpu/armv7/tegra20/Makefile b/arch/arm/cpu/armv7/tegra20/Makefile index 4ee8e5b..9b4295c 100644 --- a/arch/arm/cpu/armv7/tegra20/Makefile +++ b/arch/arm/cpu/armv7/tegra20/Makefile @@ -7,27 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-$(CONFIG_PWM_TEGRA) += pwm.o -COBJS-$(CONFIG_VIDEO_TEGRA) += display.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_PWM_TEGRA) += pwm.o +obj-$(CONFIG_VIDEO_TEGRA) += display.o diff --git a/arch/arm/cpu/armv7/tegra30/Makefile b/arch/arm/cpu/armv7/tegra30/Makefile index 04adb52..518d6d1 100644 --- a/arch/arm/cpu/armv7/tegra30/Makefile +++ b/arch/arm/cpu/armv7/tegra30/Makefile @@ -17,24 +17,4 @@ # along with this program. If not, see http://www.gnu.org/licenses/. #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj- := diff --git a/arch/arm/cpu/armv7/u8500/Makefile b/arch/arm/cpu/armv7/u8500/Makefile index 3d7a592..fad9d4a 100644 --- a/arch/arm/cpu/armv7/u8500/Makefile +++ b/arch/arm/cpu/armv7/u8500/Makefile @@ -5,26 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS = timer.o clock.o prcmu.o cpu.o -SOBJS = lowlevel.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := timer.o clock.o prcmu.o cpu.o +obj-y += lowlevel.o diff --git a/arch/arm/cpu/armv7/vf610/Makefile b/arch/arm/cpu/armv7/vf610/Makefile index 7d3c454..68cb756 100644 --- a/arch/arm/cpu/armv7/vf610/Makefile +++ b/arch/arm/cpu/armv7/vf610/Makefile @@ -4,26 +4,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS += generic.o -COBJS += timer.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += generic.o +obj-y += timer.o diff --git a/arch/arm/cpu/armv7/zynq/Makefile b/arch/arm/cpu/armv7/zynq/Makefile index e5494f7..b2391a7 100644 --- a/arch/arm/cpu/armv7/zynq/Makefile +++ b/arch/arm/cpu/armv7/zynq/Makefile @@ -8,29 +8,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-y := timer.o -COBJS-y += cpu.o -COBJS-y += slcr.o - -COBJS := $(COBJS-y) - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := timer.o +obj-y += cpu.o +obj-y += slcr.o
Note1: In arch/arm/cpu/arm926ejs/spear/Makefile START := start.o was changed extra-$(CONFIG_SPL_BUILD) := start.o because spear/start.o is only used for SPL.
Note2: START := start.o was missing from arch/arm/cpu/arm926ejs/mxs/Makefile. This commit simply adds extra-$(CONFIG_SPL_BUILD) := start.o
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com --- arch/arm/cpu/arm926ejs/Makefile | 28 ++------------- arch/arm/cpu/arm926ejs/armada100/Makefile | 23 +----------- arch/arm/cpu/arm926ejs/at91/Makefile | 59 ++++++++++--------------------- arch/arm/cpu/arm926ejs/davinci/Makefile | 48 +++++++------------------ arch/arm/cpu/arm926ejs/kirkwood/Makefile | 31 +++------------- arch/arm/cpu/arm926ejs/lpc32xx/Makefile | 23 +----------- arch/arm/cpu/arm926ejs/mb86r0x/Makefile | 25 +------------ arch/arm/cpu/arm926ejs/mx25/Makefile | 23 +----------- arch/arm/cpu/arm926ejs/mx27/Makefile | 23 +----------- arch/arm/cpu/arm926ejs/mxs/Makefile | 26 ++------------ arch/arm/cpu/arm926ejs/nomadik/Makefile | 25 ++----------- arch/arm/cpu/arm926ejs/omap/Makefile | 26 ++------------ arch/arm/cpu/arm926ejs/orion5x/Makefile | 29 +++------------ arch/arm/cpu/arm926ejs/pantheon/Makefile | 23 +----------- arch/arm/cpu/arm926ejs/spear/Makefile | 36 +++++-------------- arch/arm/cpu/arm926ejs/versatile/Makefile | 26 ++------------ 16 files changed, 67 insertions(+), 407 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/Makefile b/arch/arm/cpu/arm926ejs/Makefile index b4c214c..1252995 100644 --- a/arch/arm/cpu/arm926ejs/Makefile +++ b/arch/arm/cpu/arm926ejs/Makefile @@ -5,33 +5,11 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -START = start.o -COBJS = cpu.o cache.o +extra-y = start.o +obj-y = cpu.o cache.o
ifdef CONFIG_SPL_BUILD ifdef CONFIG_SPL_NO_CPU_SUPPORT_CODE -START := +extra-y := endif endif - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/arm/cpu/arm926ejs/armada100/Makefile b/arch/arm/cpu/arm926ejs/armada100/Makefile index a1a6df0..fca98ef 100644 --- a/arch/arm/cpu/arm926ejs/armada100/Makefile +++ b/arch/arm/cpu/arm926ejs/armada100/Makefile @@ -6,25 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-y = cpu.o timer.o dram.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = cpu.o timer.o dram.o diff --git a/arch/arm/cpu/arm926ejs/at91/Makefile b/arch/arm/cpu/arm926ejs/at91/Makefile index 9faec91..698a28d 100644 --- a/arch/arm/cpu/arm926ejs/at91/Makefile +++ b/arch/arm/cpu/arm926ejs/at91/Makefile @@ -5,46 +5,25 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-$(CONFIG_AT91CAP9) += at91cap9_devices.o -COBJS-$(CONFIG_AT91SAM9260) += at91sam9260_devices.o -COBJS-$(CONFIG_AT91SAM9G20) += at91sam9260_devices.o -COBJS-$(CONFIG_AT91SAM9XE) += at91sam9260_devices.o -COBJS-$(CONFIG_AT91SAM9261) += at91sam9261_devices.o -COBJS-$(CONFIG_AT91SAM9G10) += at91sam9261_devices.o -COBJS-$(CONFIG_AT91SAM9263) += at91sam9263_devices.o -COBJS-$(CONFIG_AT91SAM9RL) += at91sam9rl_devices.o -COBJS-$(CONFIG_AT91SAM9M10G45) += at91sam9m10g45_devices.o -COBJS-$(CONFIG_AT91SAM9G45) += at91sam9m10g45_devices.o -COBJS-$(CONFIG_AT91SAM9N12) += at91sam9n12_devices.o -COBJS-$(CONFIG_AT91SAM9X5) += at91sam9x5_devices.o -COBJS-$(CONFIG_AT91_EFLASH) += eflash.o -COBJS-$(CONFIG_AT91_LED) += led.o -COBJS-y += clock.o -COBJS-y += cpu.o -COBJS-y += reset.o -COBJS-y += timer.o +obj-$(CONFIG_AT91CAP9) += at91cap9_devices.o +obj-$(CONFIG_AT91SAM9260) += at91sam9260_devices.o +obj-$(CONFIG_AT91SAM9G20) += at91sam9260_devices.o +obj-$(CONFIG_AT91SAM9XE) += at91sam9260_devices.o +obj-$(CONFIG_AT91SAM9261) += at91sam9261_devices.o +obj-$(CONFIG_AT91SAM9G10) += at91sam9261_devices.o +obj-$(CONFIG_AT91SAM9263) += at91sam9263_devices.o +obj-$(CONFIG_AT91SAM9RL) += at91sam9rl_devices.o +obj-$(CONFIG_AT91SAM9M10G45) += at91sam9m10g45_devices.o +obj-$(CONFIG_AT91SAM9G45) += at91sam9m10g45_devices.o +obj-$(CONFIG_AT91SAM9N12) += at91sam9n12_devices.o +obj-$(CONFIG_AT91SAM9X5) += at91sam9x5_devices.o +obj-$(CONFIG_AT91_EFLASH) += eflash.o +obj-$(CONFIG_AT91_LED) += led.o +obj-y += clock.o +obj-y += cpu.o +obj-y += reset.o +obj-y += timer.o
ifndef CONFIG_SKIP_LOWLEVEL_INIT -SOBJS-y := lowlevel_init.o +obj-y += lowlevel_init.o endif - -SRCS := $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/arm/cpu/arm926ejs/davinci/Makefile b/arch/arm/cpu/arm926ejs/davinci/Makefile index b596818..7d67191 100644 --- a/arch/arm/cpu/arm926ejs/davinci/Makefile +++ b/arch/arm/cpu/arm926ejs/davinci/Makefile @@ -7,44 +7,22 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-y += cpu.o misc.o timer.o psc.o pinmux.o reset.o -COBJS-$(CONFIG_DA850_LOWLEVEL) += da850_lowlevel.o -COBJS-$(CONFIG_SOC_DM355) += dm355.o -COBJS-$(CONFIG_SOC_DM365) += dm365.o -COBJS-$(CONFIG_SOC_DM644X) += dm644x.o -COBJS-$(CONFIG_SOC_DM646X) += dm646x.o -COBJS-$(CONFIG_SOC_DA830) += da830_pinmux.o -COBJS-$(CONFIG_SOC_DA850) += da850_pinmux.o -COBJS-$(CONFIG_DRIVER_TI_EMAC) += lxt972.o dp83848.o et1011c.o ksz8873.o +obj-y += cpu.o misc.o timer.o psc.o pinmux.o reset.o +obj-$(CONFIG_DA850_LOWLEVEL) += da850_lowlevel.o +obj-$(CONFIG_SOC_DM355) += dm355.o +obj-$(CONFIG_SOC_DM365) += dm365.o +obj-$(CONFIG_SOC_DM644X) += dm644x.o +obj-$(CONFIG_SOC_DM646X) += dm646x.o +obj-$(CONFIG_SOC_DA830) += da830_pinmux.o +obj-$(CONFIG_SOC_DA850) += da850_pinmux.o +obj-$(CONFIG_DRIVER_TI_EMAC) += lxt972.o dp83848.o et1011c.o ksz8873.o
ifdef CONFIG_SPL_BUILD -COBJS-$(CONFIG_SPL_FRAMEWORK) += spl.o -COBJS-$(CONFIG_SOC_DM365) += dm365_lowlevel.o -COBJS-$(CONFIG_SOC_DA8XX) += da850_lowlevel.o +obj-$(CONFIG_SPL_FRAMEWORK) += spl.o +obj-$(CONFIG_SOC_DM365) += dm365_lowlevel.o +obj-$(CONFIG_SOC_DA8XX) += da850_lowlevel.o endif
ifndef CONFIG_SKIP_LOWLEVEL_INIT -SOBJS += lowlevel_init.o +obj-y += lowlevel_init.o endif - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y) $(SOBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/arm/cpu/arm926ejs/kirkwood/Makefile b/arch/arm/cpu/arm926ejs/kirkwood/Makefile index 20ccf20..c230ce8 100644 --- a/arch/arm/cpu/arm926ejs/kirkwood/Makefile +++ b/arch/arm/cpu/arm926ejs/kirkwood/Makefile @@ -6,29 +6,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-y = cpu.o -COBJS-y += dram.o -COBJS-y += mpp.o -COBJS-y += timer.o -COBJS-y += cache.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = cpu.o +obj-y += dram.o +obj-y += mpp.o +obj-y += timer.o +obj-y += cache.o diff --git a/arch/arm/cpu/arm926ejs/lpc32xx/Makefile b/arch/arm/cpu/arm926ejs/lpc32xx/Makefile index 603051a..314f004 100644 --- a/arch/arm/cpu/arm926ejs/lpc32xx/Makefile +++ b/arch/arm/cpu/arm926ejs/lpc32xx/Makefile @@ -5,25 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS = cpu.o clk.o devices.o timer.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = cpu.o clk.o devices.o timer.o diff --git a/arch/arm/cpu/arm926ejs/mb86r0x/Makefile b/arch/arm/cpu/arm926ejs/mb86r0x/Makefile index a780dfe..365892c 100644 --- a/arch/arm/cpu/arm926ejs/mb86r0x/Makefile +++ b/arch/arm/cpu/arm926ejs/mb86r0x/Makefile @@ -5,27 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS = clock.o reset.o timer.o -SOBJS = - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = clock.o reset.o timer.o diff --git a/arch/arm/cpu/arm926ejs/mx25/Makefile b/arch/arm/cpu/arm926ejs/mx25/Makefile index 75a09ff..134c69d 100644 --- a/arch/arm/cpu/arm926ejs/mx25/Makefile +++ b/arch/arm/cpu/arm926ejs/mx25/Makefile @@ -4,25 +4,4 @@ # # SPDX-License-Identifier: GPL-2.0+
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS = generic.o timer.o reset.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = generic.o timer.o reset.o diff --git a/arch/arm/cpu/arm926ejs/mx27/Makefile b/arch/arm/cpu/arm926ejs/mx27/Makefile index 53ffaf2..4976bbb 100644 --- a/arch/arm/cpu/arm926ejs/mx27/Makefile +++ b/arch/arm/cpu/arm926ejs/mx27/Makefile @@ -4,25 +4,4 @@ # # SPDX-License-Identifier: GPL-2.0+
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS = generic.o reset.o timer.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = generic.o reset.o timer.o diff --git a/arch/arm/cpu/arm926ejs/mxs/Makefile b/arch/arm/cpu/arm926ejs/mxs/Makefile index 3d66892..13b5a54 100644 --- a/arch/arm/cpu/arm926ejs/mxs/Makefile +++ b/arch/arm/cpu/arm926ejs/mxs/Makefile @@ -5,25 +5,14 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk +extra-$(CONFIG_SPL_BUILD) := start.o
-LIB = $(obj)lib$(SOC).o - -COBJS = clock.o mxs.o iomux.o timer.o +obj-y = clock.o mxs.o iomux.o timer.o
ifdef CONFIG_SPL_BUILD -COBJS += spl_boot.o spl_lradc_init.o spl_mem_init.o spl_power_init.o +obj-y += spl_boot.o spl_lradc_init.o spl_mem_init.o spl_power_init.o endif
-SRCS := $(START:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - # Specify the target for use in elftosb call ELFTOSB_TARGET-$(CONFIG_MX23) = imx23 ELFTOSB_TARGET-$(CONFIG_MX28) = imx28 @@ -33,12 +22,3 @@ $(OBJTREE)/u-boot.bd: $(SRCTREE)/$(CPUDIR)/$(SOC)/u-boot-$(ELFTOSB_TARGET-y).bd
$(OBJTREE)/u-boot.sb: $(OBJTREE)/u-boot.bin $(OBJTREE)/spl/u-boot-spl.bin $(OBJTREE)/u-boot.bd elftosb -zf $(ELFTOSB_TARGET-y) -c $(OBJTREE)/u-boot.bd -o $(OBJTREE)/u-boot.sb - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/arm/cpu/arm926ejs/nomadik/Makefile b/arch/arm/cpu/arm926ejs/nomadik/Makefile index 8896b0b..cdf1345 100644 --- a/arch/arm/cpu/arm926ejs/nomadik/Makefile +++ b/arch/arm/cpu/arm926ejs/nomadik/Makefile @@ -5,26 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS = timer.o gpio.o -SOBJS = reset.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) $(addprefix $(obj),$(SOBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = timer.o gpio.o +obj-y += reset.o diff --git a/arch/arm/cpu/arm926ejs/omap/Makefile b/arch/arm/cpu/arm926ejs/omap/Makefile index b519477..bd0a2fb 100644 --- a/arch/arm/cpu/arm926ejs/omap/Makefile +++ b/arch/arm/cpu/arm926ejs/omap/Makefile @@ -5,27 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS = timer.o cpuinfo.o -SOBJS = reset.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = timer.o cpuinfo.o +obj-y += reset.o diff --git a/arch/arm/cpu/arm926ejs/orion5x/Makefile b/arch/arm/cpu/arm926ejs/orion5x/Makefile index 8f36dc0..546ebcb 100644 --- a/arch/arm/cpu/arm926ejs/orion5x/Makefile +++ b/arch/arm/cpu/arm926ejs/orion5x/Makefile @@ -9,31 +9,10 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-y = cpu.o -COBJS-y += dram.o -COBJS-y += timer.o +obj-y = cpu.o +obj-y += dram.o +obj-y += timer.o
ifndef CONFIG_SKIP_LOWLEVEL_INIT -SOBJS := lowlevel_init.o +obj-y += lowlevel_init.o endif - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/arm/cpu/arm926ejs/pantheon/Makefile b/arch/arm/cpu/arm926ejs/pantheon/Makefile index fb6bf63..988341f 100644 --- a/arch/arm/cpu/arm926ejs/pantheon/Makefile +++ b/arch/arm/cpu/arm926ejs/pantheon/Makefile @@ -6,25 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-y = cpu.o timer.o dram.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = cpu.o timer.o dram.o diff --git a/arch/arm/cpu/arm926ejs/spear/Makefile b/arch/arm/cpu/arm926ejs/spear/Makefile index 3006cd6..3f190bc 100644 --- a/arch/arm/cpu/arm926ejs/spear/Makefile +++ b/arch/arm/cpu/arm926ejs/spear/Makefile @@ -5,37 +5,17 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-y := cpu.o \ +obj-y := cpu.o \ reset.o \ timer.o
ifdef CONFIG_SPL_BUILD -COBJS-y += spl.o spl_boot.o -COBJS-$(CONFIG_SPEAR600) += spear600.o -COBJS-$(CONFIG_DDR_MT47H64M16) += spr600_mt47h64m16_3_333_cl5_psync.o -COBJS-$(CONFIG_DDR_MT47H32M16) += spr600_mt47h32m16_333_cl5_psync.o -COBJS-$(CONFIG_DDR_MT47H32M16) += spr600_mt47h32m16_37e_166_cl4_sync.o -COBJS-$(CONFIG_DDR_MT47H128M8) += spr600_mt47h128m8_3_266_cl5_async.o +obj-y += spl.o spl_boot.o +obj-$(CONFIG_SPEAR600) += spear600.o +obj-$(CONFIG_DDR_MT47H64M16) += spr600_mt47h64m16_3_333_cl5_psync.o +obj-$(CONFIG_DDR_MT47H32M16) += spr600_mt47h32m16_333_cl5_psync.o +obj-$(CONFIG_DDR_MT47H32M16) += spr600_mt47h32m16_37e_166_cl4_sync.o +obj-$(CONFIG_DDR_MT47H128M8) += spr600_mt47h128m8_3_266_cl5_async.o endif
-SRCS := $(START:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-$(CONFIG_SPL_BUILD) := start.o diff --git a/arch/arm/cpu/arm926ejs/versatile/Makefile b/arch/arm/cpu/arm926ejs/versatile/Makefile index d4659f9..907f516 100644 --- a/arch/arm/cpu/arm926ejs/versatile/Makefile +++ b/arch/arm/cpu/arm926ejs/versatile/Makefile @@ -5,27 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS = timer.o -SOBJS = reset.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = timer.o +obj-y += reset.o
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com --- arch/arm/cpu/arm920t/Makefile | 28 +++------------------------- arch/arm/cpu/arm920t/a320/Makefile | 25 ++----------------------- arch/arm/cpu/arm920t/at91/Makefile | 33 ++++++--------------------------- arch/arm/cpu/arm920t/ep93xx/Makefile | 24 ++---------------------- arch/arm/cpu/arm920t/imx/Makefile | 27 +++------------------------ arch/arm/cpu/arm920t/ks8695/Makefile | 26 ++------------------------ arch/arm/cpu/arm920t/s3c24x0/Makefile | 29 ++++------------------------- 7 files changed, 22 insertions(+), 170 deletions(-)
diff --git a/arch/arm/cpu/arm920t/Makefile b/arch/arm/cpu/arm920t/Makefile index 4758f02..aac8043 100644 --- a/arch/arm/cpu/arm920t/Makefile +++ b/arch/arm/cpu/arm920t/Makefile @@ -5,29 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk +extra-y = start.o
-LIB = $(obj)lib$(CPU).o - -START = start.o - -COBJS-y += cpu.o -COBJS-$(CONFIG_USE_IRQ) += interrupts.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y) $(SOBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += cpu.o +obj-$(CONFIG_USE_IRQ) += interrupts.o diff --git a/arch/arm/cpu/arm920t/a320/Makefile b/arch/arm/cpu/arm920t/a320/Makefile index 88c7d9b..bbdab58 100644 --- a/arch/arm/cpu/arm920t/a320/Makefile +++ b/arch/arm/cpu/arm920t/a320/Makefile @@ -5,26 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -SOBJS += reset.o -COBJS += timer.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += reset.o +obj-y += timer.o diff --git a/arch/arm/cpu/arm920t/at91/Makefile b/arch/arm/cpu/arm920t/at91/Makefile index b2b1e56..561b4b4 100644 --- a/arch/arm/cpu/arm920t/at91/Makefile +++ b/arch/arm/cpu/arm920t/at91/Makefile @@ -5,30 +5,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -SOBJS += lowlevel_init.o -COBJS += reset.o -COBJS += timer.o -COBJS += clock.o -COBJS += cpu.o -COBJS += at91rm9200_devices.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += lowlevel_init.o +obj-y += reset.o +obj-y += timer.o +obj-y += clock.o +obj-y += cpu.o +obj-y += at91rm9200_devices.o diff --git a/arch/arm/cpu/arm920t/ep93xx/Makefile b/arch/arm/cpu/arm920t/ep93xx/Makefile index 7a75c86..638333a 100644 --- a/arch/arm/cpu/arm920t/ep93xx/Makefile +++ b/arch/arm/cpu/arm920t/ep93xx/Makefile @@ -16,26 +16,6 @@ # # SPDX-License-Identifier: GPL-2.0+ # -include $(TOPDIR)/config.mk
-LIB = $(obj)lib$(SOC).o - -COBJS = cpu.o led.o speed.o timer.o -SOBJS = lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = cpu.o led.o speed.o timer.o +obj-y += lowlevel_init.o diff --git a/arch/arm/cpu/arm920t/imx/Makefile b/arch/arm/cpu/arm920t/imx/Makefile index c9c85b8..54ce646 100644 --- a/arch/arm/cpu/arm920t/imx/Makefile +++ b/arch/arm/cpu/arm920t/imx/Makefile @@ -5,27 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS += generic.o -COBJS += speed.o -COBJS += timer.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += generic.o +obj-y += speed.o +obj-y += timer.o diff --git a/arch/arm/cpu/arm920t/ks8695/Makefile b/arch/arm/cpu/arm920t/ks8695/Makefile index eef0530..400aa89 100644 --- a/arch/arm/cpu/arm920t/ks8695/Makefile +++ b/arch/arm/cpu/arm920t/ks8695/Makefile @@ -5,27 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -SOBJS = lowlevel_init.o - -COBJS = timer.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = lowlevel_init.o +obj-y += timer.o diff --git a/arch/arm/cpu/arm920t/s3c24x0/Makefile b/arch/arm/cpu/arm920t/s3c24x0/Makefile index 9717533..e44c549 100644 --- a/arch/arm/cpu/arm920t/s3c24x0/Makefile +++ b/arch/arm/cpu/arm920t/s3c24x0/Makefile @@ -5,28 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-$(CONFIG_USE_IRQ) += interrupts.o -COBJS-$(CONFIG_DISPLAY_CPUINFO) += cpu_info.o -COBJS-y += speed.o -COBJS-y += timer.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_USE_IRQ) += interrupts.o +obj-$(CONFIG_DISPLAY_CPUINFO) += cpu_info.o +obj-y += speed.o +obj-y += timer.o
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com --- arch/arm/cpu/arm720t/Makefile | 26 ++------------------------ arch/arm/cpu/arm720t/tegra-common/Makefile | 25 ++----------------------- arch/arm/cpu/arm720t/tegra114/Makefile | 25 ++----------------------- arch/arm/cpu/arm720t/tegra20/Makefile | 23 +---------------------- arch/arm/cpu/arm720t/tegra30/Makefile | 23 +---------------------- 5 files changed, 8 insertions(+), 114 deletions(-)
diff --git a/arch/arm/cpu/arm720t/Makefile b/arch/arm/cpu/arm720t/Makefile index 73e1635..243a123 100644 --- a/arch/arm/cpu/arm720t/Makefile +++ b/arch/arm/cpu/arm720t/Makefile @@ -5,27 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -START = start.o -COBJS = interrupts.o cpu.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y = start.o +obj-y = interrupts.o cpu.o diff --git a/arch/arm/cpu/arm720t/tegra-common/Makefile b/arch/arm/cpu/arm720t/tegra-common/Makefile index 37ec43f..a9c2b67 100644 --- a/arch/arm/cpu/arm720t/tegra-common/Makefile +++ b/arch/arm/cpu/arm720t/tegra-common/Makefile @@ -7,26 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libtegra-common.o - -COBJS-$(CONFIG_SPL_BUILD) += spl.o -COBJS-y += cpu.o - -SRCS := $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_SPL_BUILD) += spl.o +obj-y += cpu.o diff --git a/arch/arm/cpu/arm720t/tegra114/Makefile b/arch/arm/cpu/arm720t/tegra114/Makefile index 6cf7fe9..ea3e55e 100644 --- a/arch/arm/cpu/arm720t/tegra114/Makefile +++ b/arch/arm/cpu/arm720t/tegra114/Makefile @@ -17,26 +17,5 @@ # along with this program. If not, see http://www.gnu.org/licenses/. #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -#COBJS-y += cpu.o t11x.o -COBJS-y += cpu.o - -SRCS := $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +#obj-y += cpu.o t11x.o +obj-y += cpu.o diff --git a/arch/arm/cpu/arm720t/tegra20/Makefile b/arch/arm/cpu/arm720t/tegra20/Makefile index eef5922..12243fa 100644 --- a/arch/arm/cpu/arm720t/tegra20/Makefile +++ b/arch/arm/cpu/arm720t/tegra20/Makefile @@ -7,25 +7,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS-y += cpu.o - -SRCS := $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += cpu.o diff --git a/arch/arm/cpu/arm720t/tegra30/Makefile b/arch/arm/cpu/arm720t/tegra30/Makefile index bd96997..6ff4c55 100644 --- a/arch/arm/cpu/arm720t/tegra30/Makefile +++ b/arch/arm/cpu/arm720t/tegra30/Makefile @@ -17,25 +17,4 @@ # along with this program. If not, see http://www.gnu.org/licenses/. #
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com --- arch/arm/cpu/arm1136/Makefile | 26 +--------- arch/arm/cpu/arm1136/mx31/Makefile | 27 ++--------- arch/arm/cpu/arm1136/mx35/Makefile | 28 ++--------- arch/arm/cpu/arm1176/Makefile | 26 +--------- arch/arm/cpu/arm1176/bcm2835/Makefile | 25 +--------- arch/arm/cpu/arm1176/tnetv107x/Makefile | 27 +---------- arch/arm/cpu/arm925t/Makefile | 30 ++---------- arch/arm/cpu/arm946es/Makefile | 26 +--------- arch/arm/cpu/arm_intcm/Makefile | 26 +--------- arch/arm/cpu/ixp/Makefile | 30 ++---------- arch/arm/cpu/pxa/Makefile | 36 +++----------- arch/arm/cpu/sa1100/Makefile | 28 ++--------- arch/arm/cpu/tegra-common/Makefile | 25 +--------- arch/arm/cpu/tegra114-common/Makefile | 23 +-------- arch/arm/cpu/tegra20-common/Makefile | 29 ++--------- arch/arm/cpu/tegra30-common/Makefile | 26 +--------- arch/arm/lib/Makefile | 86 ++++++++++----------------------- 17 files changed, 69 insertions(+), 455 deletions(-)
diff --git a/arch/arm/cpu/arm1136/Makefile b/arch/arm/cpu/arm1136/Makefile index cc516f7..3279f12 100644 --- a/arch/arm/cpu/arm1136/Makefile +++ b/arch/arm/cpu/arm1136/Makefile @@ -5,27 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -START = start.o -COBJS = cpu.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y = start.o +obj-y = cpu.o diff --git a/arch/arm/cpu/arm1136/mx31/Makefile b/arch/arm/cpu/arm1136/mx31/Makefile index c75adec..9670ed9 100644 --- a/arch/arm/cpu/arm1136/mx31/Makefile +++ b/arch/arm/cpu/arm1136/mx31/Makefile @@ -5,27 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS += generic.o -COBJS += timer.o -COBJS += devices.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += generic.o +obj-y += timer.o +obj-y += devices.o diff --git a/arch/arm/cpu/arm1136/mx35/Makefile b/arch/arm/cpu/arm1136/mx35/Makefile index ee534a9..c533215 100644 --- a/arch/arm/cpu/arm1136/mx35/Makefile +++ b/arch/arm/cpu/arm1136/mx35/Makefile @@ -7,28 +7,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS += generic.o -COBJS += timer.o -COBJS += mx35_sdram.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += generic.o +obj-y += timer.o +obj-y += mx35_sdram.o diff --git a/arch/arm/cpu/arm1176/Makefile b/arch/arm/cpu/arm1176/Makefile index 5d451a7..deec427 100644 --- a/arch/arm/cpu/arm1176/Makefile +++ b/arch/arm/cpu/arm1176/Makefile @@ -8,27 +8,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -START = start.o -COBJS = cpu.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y = start.o +obj-y = cpu.o diff --git a/arch/arm/cpu/arm1176/bcm2835/Makefile b/arch/arm/cpu/arm1176/bcm2835/Makefile index 135de42..0ad3690 100644 --- a/arch/arm/cpu/arm1176/bcm2835/Makefile +++ b/arch/arm/cpu/arm1176/bcm2835/Makefile @@ -12,26 +12,5 @@ # GNU General Public License for more details. #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -SOBJS := lowlevel_init.o -COBJS := init.o reset.o timer.o mbox.o - -SRCS := $(SOBJS:.o=.c) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := lowlevel_init.o +obj-y += init.o reset.o timer.o mbox.o diff --git a/arch/arm/cpu/arm1176/tnetv107x/Makefile b/arch/arm/cpu/arm1176/tnetv107x/Makefile index 1eb27ed..a4c1edf 100644 --- a/arch/arm/cpu/arm1176/tnetv107x/Makefile +++ b/arch/arm/cpu/arm1176/tnetv107x/Makefile @@ -2,28 +2,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC).o - -COBJS += aemif.o clock.o init.o mux.o timer.o -SOBJS += lowlevel_init.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) - -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += aemif.o clock.o init.o mux.o timer.o +obj-y += lowlevel_init.o diff --git a/arch/arm/cpu/arm925t/Makefile b/arch/arm/cpu/arm925t/Makefile index 40d2156..ffe2ff5 100644 --- a/arch/arm/cpu/arm925t/Makefile +++ b/arch/arm/cpu/arm925t/Makefile @@ -5,30 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(CPU).o - -START = start.o - -COBJS += cpu.o -COBJS += omap925.o -COBJS += timer.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += cpu.o +obj-y += omap925.o +obj-y += timer.o diff --git a/arch/arm/cpu/arm946es/Makefile b/arch/arm/cpu/arm946es/Makefile index 87e6c65..a44bddc 100644 --- a/arch/arm/cpu/arm946es/Makefile +++ b/arch/arm/cpu/arm946es/Makefile @@ -5,28 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(CPU).o - -START = start.o - -COBJS = cpu.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y = cpu.o diff --git a/arch/arm/cpu/arm_intcm/Makefile b/arch/arm/cpu/arm_intcm/Makefile index cc516f7..3279f12 100644 --- a/arch/arm/cpu/arm_intcm/Makefile +++ b/arch/arm/cpu/arm_intcm/Makefile @@ -5,27 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -START = start.o -COBJS = cpu.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y = start.o +obj-y = cpu.o diff --git a/arch/arm/cpu/ixp/Makefile b/arch/arm/cpu/ixp/Makefile index 788598e..4e66523 100644 --- a/arch/arm/cpu/ixp/Makefile +++ b/arch/arm/cpu/ixp/Makefile @@ -5,30 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(CPU).o - -START = start.o - -COBJS-y += cpu.o -COBJS-$(CONFIG_USE_IRQ) += interrupts.o -COBJS-y += timer.o - -SRCS := $(START:.o=.S) $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += cpu.o +obj-$(CONFIG_USE_IRQ) += interrupts.o +obj-y += timer.o diff --git a/arch/arm/cpu/pxa/Makefile b/arch/arm/cpu/pxa/Makefile index c84186a..8cd475e 100644 --- a/arch/arm/cpu/pxa/Makefile +++ b/arch/arm/cpu/pxa/Makefile @@ -5,35 +5,11 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(CPU).o +obj-$(CONFIG_CPU_PXA25X) += pxa2xx.o +obj-$(CONFIG_CPU_PXA27X) += pxa2xx.o
-START = start.o - -COBJS-$(CONFIG_CPU_PXA25X) = pxa2xx.o -COBJS-$(CONFIG_CPU_PXA27X) = pxa2xx.o - -COBJS-y += cpuinfo.o - -COBJS = $(COBJS-y) -COBJS += timer.o -COBJS += usb.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += cpuinfo.o +obj-y += timer.o +obj-y += usb.o diff --git a/arch/arm/cpu/sa1100/Makefile b/arch/arm/cpu/sa1100/Makefile index c84b7b9..85a0d28 100644 --- a/arch/arm/cpu/sa1100/Makefile +++ b/arch/arm/cpu/sa1100/Makefile @@ -5,29 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(CPU).o - -START = start.o - -COBJS += cpu.o -COBJS += timer.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += cpu.o +obj-y += timer.o diff --git a/arch/arm/cpu/tegra-common/Makefile b/arch/arm/cpu/tegra-common/Makefile index 1b6cdf7..3aac655 100644 --- a/arch/arm/cpu/tegra-common/Makefile +++ b/arch/arm/cpu/tegra-common/Makefile @@ -7,26 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libcputegra-common.o - -SOBJS += lowlevel_init.o -COBJS-y += ap.o board.o sys_info.o timer.o clock.o cache.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += lowlevel_init.o +obj-y += ap.o board.o sys_info.o timer.o clock.o cache.o diff --git a/arch/arm/cpu/tegra114-common/Makefile b/arch/arm/cpu/tegra114-common/Makefile index 5b53a71..d959b57 100644 --- a/arch/arm/cpu/tegra114-common/Makefile +++ b/arch/arm/cpu/tegra114-common/Makefile @@ -17,25 +17,4 @@ # along with this program. If not, see http://www.gnu.org/licenses/. #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(SOC)-common.o - -COBJS-y += clock.o funcmux.o pinmux.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += clock.o funcmux.o pinmux.o diff --git a/arch/arm/cpu/tegra20-common/Makefile b/arch/arm/cpu/tegra20-common/Makefile index 175387f..32ddbda 100644 --- a/arch/arm/cpu/tegra20-common/Makefile +++ b/arch/arm/cpu/tegra20-common/Makefile @@ -7,32 +7,11 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - # The AVP is ARMv4T architecture so we must use special compiler # flags for any startup files it might use. CFLAGS_arch/arm/cpu/tegra20-common/warmboot_avp.o += -march=armv4t
-LIB = $(obj)lib$(SOC)-common.o - -COBJS-y += clock.o funcmux.o pinmux.o -COBJS-$(CONFIG_TEGRA_LP0) += warmboot.o crypto.o warmboot_avp.o -COBJS-$(CONFIG_TEGRA_CLOCK_SCALING) += emc.o -COBJS-$(CONFIG_TEGRA_PMU) += pmu.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += clock.o funcmux.o pinmux.o +obj-$(CONFIG_TEGRA_LP0) += warmboot.o crypto.o warmboot_avp.o +obj-$(CONFIG_TEGRA_CLOCK_SCALING) += emc.o +obj-$(CONFIG_TEGRA_PMU) += pmu.o diff --git a/arch/arm/cpu/tegra30-common/Makefile b/arch/arm/cpu/tegra30-common/Makefile index 75fef32..d2d616e 100644 --- a/arch/arm/cpu/tegra30-common/Makefile +++ b/arch/arm/cpu/tegra30-common/Makefile @@ -17,28 +17,4 @@ # along with this program. If not, see http://www.gnu.org/licenses/. #
-include $(TOPDIR)/config.mk - -# The AVP is ARMv4T architecture so we must use special compiler -# flags for any startup files it might use. - -LIB = $(obj)lib$(SOC)-common.o - -COBJS-y += clock.o funcmux.o pinmux.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += clock.o funcmux.o pinmux.o diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index 4e78723..679f19a 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -5,77 +5,43 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(ARCH).o -LIBGCC = $(obj)libgcc.o - -GLSOBJS += _ashldi3.o -GLSOBJS += _ashrdi3.o -GLSOBJS += _divsi3.o -GLSOBJS += _lshrdi3.o -GLSOBJS += _modsi3.o -GLSOBJS += _udivsi3.o -GLSOBJS += _umodsi3.o - -GLCOBJS += div0.o +# Build private libgcc only when asked for +ifdef USE_PRIVATE_LIBGCC +lib-y += _ashldi3.o +lib-y += _ashrdi3.o +lib-y += _divsi3.o +lib-y += _lshrdi3.o +lib-y += _modsi3.o +lib-y += _udivsi3.o +lib-y += _umodsi3.o +lib-y += div0.o +endif
-SOBJS-y += crt0.o +obj-y += crt0.o
ifndef CONFIG_SPL_BUILD -SOBJS-y += relocate.o +obj-y += relocate.o ifndef CONFIG_SYS_GENERIC_BOARD -COBJS-y += board.o +obj-y += board.o endif -COBJS-y += sections.o +obj-y += sections.o
-COBJS-$(CONFIG_OF_LIBFDT) += bootm-fdt.o -COBJS-$(CONFIG_CMD_BOOTM) += bootm.o -COBJS-$(CONFIG_SYS_L2_PL310) += cache-pl310.o -SOBJS-$(CONFIG_USE_ARCH_MEMSET) += memset.o -SOBJS-$(CONFIG_USE_ARCH_MEMCPY) += memcpy.o +obj-$(CONFIG_OF_LIBFDT) += bootm-fdt.o +obj-$(CONFIG_CMD_BOOTM) += bootm.o +obj-$(CONFIG_SYS_L2_PL310) += cache-pl310.o +obj-$(CONFIG_USE_ARCH_MEMSET) += memset.o +obj-$(CONFIG_USE_ARCH_MEMCPY) += memcpy.o else -COBJS-$(CONFIG_SPL_FRAMEWORK) += spl.o +obj-$(CONFIG_SPL_FRAMEWORK) += spl.o endif
-COBJS-y += interrupts.o -COBJS-y += reset.o - -COBJS-y += cache.o -COBJS-y += cache-cp15.o - -SRCS := $(GLSOBJS:.o=.S) $(GLCOBJS:.o=.c) \ - $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) -LGOBJS := $(addprefix $(obj),$(GLSOBJS)) \ - $(addprefix $(obj),$(GLCOBJS)) +obj-y += interrupts.o +obj-y += reset.o
-# Always build libarm.o -TARGETS := $(LIB) - -# Build private libgcc only when asked for -ifdef USE_PRIVATE_LIBGCC -TARGETS += $(LIBGCC) -endif +obj-y += cache.o +obj-y += cache-cp15.o
# For EABI conformant tool chains, provide eabi_compat() ifneq (,$(findstring -mabi=aapcs-linux,$(PLATFORM_CPPFLAGS))) -TARGETS += $(obj)eabi_compat.o +extra-y += eabi_compat.o endif - -all: $(TARGETS) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -$(LIBGCC): $(obj).depend $(LGOBJS) - $(call cmd_link_o_target, $(LGOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -#########################################################################
Multiple targets are included in arch/arm/imx-common/Makefile In order to refactor it, we need to tweak Makefile and spl/Makefile.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com --- Makefile | 8 +++++--- arch/arm/imx-common/Makefile | 35 ++++++----------------------------- spl/Makefile | 4 +++- 3 files changed, 14 insertions(+), 33 deletions(-)
diff --git a/Makefile b/Makefile index 852f80b..338bf31 100644 --- a/Makefile +++ b/Makefile @@ -413,6 +413,8 @@ ALL-y += $(obj)u-boot-nodtb-tegra.bin endif endif
+build := -f $(TOPDIR)/scripts/Makefile.build -C + all: $(ALL-y) $(SUBDIR_EXAMPLES)
$(obj)u-boot.dtb: checkdtc $(obj)u-boot @@ -460,7 +462,7 @@ $(obj)u-boot.img: $(obj)u-boot.bin -d $< $@
$(obj)u-boot.imx: $(obj)u-boot.bin depend - $(MAKE) -C $(SRCTREE)/arch/arm/imx-common $(OBJTREE)/u-boot.imx + $(MAKE) $(build) $(SRCTREE)/arch/arm/imx-common $(OBJTREE)/u-boot.imx
$(obj)u-boot.kwb: $(obj)u-boot.bin $(obj)tools/mkimage -n $(CONFIG_SYS_KWD_CONFIG) -T kwbimage \ @@ -498,11 +500,11 @@ $(obj)tpl/u-boot-with-tpl.bin: $(obj)tpl/u-boot-tpl.bin $(obj)u-boot.bin $(call SPL_PAD_APPEND,$<,$(obj)u-boot.bin,tpl/u-boot-tpl-pad.bin,$(CONFIG_TPL_PAD_TO))
$(obj)u-boot-with-spl.imx: $(obj)spl/u-boot-spl.bin $(obj)u-boot.bin - $(MAKE) -C $(SRCTREE)/arch/arm/imx-common \ + $(MAKE) $(build) $(SRCTREE)/arch/arm/imx-common \ $(OBJTREE)/u-boot-with-spl.imx
$(obj)u-boot-with-nand-spl.imx: $(obj)spl/u-boot-spl.bin $(obj)u-boot.bin - $(MAKE) -C $(SRCTREE)/arch/arm/imx-common \ + $(MAKE) $(build) $(SRCTREE)/arch/arm/imx-common \ $(OBJTREE)/u-boot-with-nand-spl.imx
$(obj)u-boot.ubl: $(obj)u-boot-with-spl.bin diff --git a/arch/arm/imx-common/Makefile b/arch/arm/imx-common/Makefile index 727a052..50873d8 100644 --- a/arch/arm/imx-common/Makefile +++ b/arch/arm/imx-common/Makefile @@ -7,31 +7,18 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libimx-common.o - ifeq ($(SOC),$(filter $(SOC),mx25 mx35 mx5 mx6 vf610)) -COBJS-y = iomux-v3.o +obj-y = iomux-v3.o endif ifeq ($(SOC),$(filter $(SOC),mx5 mx6)) -COBJS-y += timer.o cpu.o speed.o -COBJS-$(CONFIG_I2C_MXC) += i2c-mxv7.o +obj-y += timer.o cpu.o speed.o +obj-$(CONFIG_I2C_MXC) += i2c-mxv7.o endif ifeq ($(SOC),$(filter $(SOC),mx6 mxs)) -COBJS-y += misc.o +obj-y += misc.o endif -COBJS-$(CONFIG_CMD_BMODE) += cmd_bmode.o -COBJS-$(CONFIG_CMD_HDMIDETECT) += cmd_hdmidet.o -COBJS := $(sort $(COBJS-y)) - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) +obj-$(CONFIG_CMD_BMODE) += cmd_bmode.o +obj-$(CONFIG_CMD_HDMIDETECT) += cmd_hdmidet.o
$(OBJTREE)/$(patsubst "%",%,$(CONFIG_IMX_CONFIG)).cfgtmp: $(OBJTREE)/%.cfgtmp : $(SRCTREE)/% mkdir -p $(dir $@) @@ -67,13 +54,3 @@ $(OBJTREE)/u-boot-with-nand-spl.imx: $(OBJTREE)/SPL $(OBJTREE)/u-boot.bin $(OBJTREE)/u-boot.uim cat $(OBJTREE)/spl/u-boot-nand-spl-pad.imx $(OBJTREE)/u-boot.uim > $@ rm $(OBJTREE)/spl/u-boot-nand-spl-pad.imx $(OBJTREE)/u-boot.uim - - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/spl/Makefile b/spl/Makefile index 7497b5f..5d31a52 100644 --- a/spl/Makefile +++ b/spl/Makefile @@ -152,6 +152,8 @@ ifeq ($(wildcard $(LDSCRIPT)),) $(error could not find linker script) endif
+build := -f $(TOPDIR)/scripts/Makefile.build -C + # Special flags for CPP when processing the linker script. # Pass the version down so we can handle backwards compatibility # on the fly. @@ -171,7 +173,7 @@ $(OBJTREE)/MLO.byteswap: $(obj)u-boot-spl.bin -a $(CONFIG_SPL_TEXT_BASE) -d $< $@
$(OBJTREE)/SPL : $(obj)u-boot-spl.bin depend - $(MAKE) -C $(SRCTREE)/arch/arm/imx-common $@ + $(MAKE) $(build) $(SRCTREE)/arch/arm/imx-common $@
ALL-y += $(obj)$(SPL_BIN).bin
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com --- drivers/net/Makefile | 136 ++++++++++++++++++++--------------------------- drivers/net/fm/Makefile | 59 +++++++------------- drivers/net/npe/Makefile | 24 +-------- drivers/net/phy/Makefile | 60 +++++++-------------- 4 files changed, 96 insertions(+), 183 deletions(-)
diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 18fd54f..7f9ce90 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -5,83 +5,61 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libnet.o - -COBJS-$(CONFIG_PPC4xx_EMAC) += 4xx_enet.o -COBJS-$(CONFIG_ALTERA_TSE) += altera_tse.o -COBJS-$(CONFIG_ARMADA100_FEC) += armada100_fec.o -COBJS-$(CONFIG_DRIVER_AT91EMAC) += at91_emac.o -COBJS-$(CONFIG_DRIVER_AX88180) += ax88180.o -COBJS-$(CONFIG_BFIN_MAC) += bfin_mac.o -COBJS-$(CONFIG_CALXEDA_XGMAC) += calxedaxgmac.o -COBJS-$(CONFIG_CS8900) += cs8900.o -COBJS-$(CONFIG_TULIP) += dc2114x.o -COBJS-$(CONFIG_DESIGNWARE_ETH) += designware.o -COBJS-$(CONFIG_DRIVER_DM9000) += dm9000x.o -COBJS-$(CONFIG_DNET) += dnet.o -COBJS-$(CONFIG_E1000) += e1000.o -COBJS-$(CONFIG_E1000_SPI) += e1000_spi.o -COBJS-$(CONFIG_EEPRO100) += eepro100.o -COBJS-$(CONFIG_ENC28J60) += enc28j60.o -COBJS-$(CONFIG_EP93XX) += ep93xx_eth.o -COBJS-$(CONFIG_ETHOC) += ethoc.o -COBJS-$(CONFIG_FEC_MXC) += fec_mxc.o -COBJS-$(CONFIG_FSLDMAFEC) += fsl_mcdmafec.o mcfmii.o -COBJS-$(CONFIG_FTGMAC100) += ftgmac100.o -COBJS-$(CONFIG_FTMAC110) += ftmac110.o -COBJS-$(CONFIG_FTMAC100) += ftmac100.o -COBJS-$(CONFIG_GRETH) += greth.o -COBJS-$(CONFIG_INCA_IP_SWITCH) += inca-ip_sw.o -COBJS-$(CONFIG_DRIVER_KS8695ETH) += ks8695eth.o -COBJS-$(CONFIG_KS8851_MLL) += ks8851_mll.o -COBJS-$(CONFIG_LAN91C96) += lan91c96.o -COBJS-$(CONFIG_MACB) += macb.o -COBJS-$(CONFIG_MCFFEC) += mcffec.o mcfmii.o -COBJS-$(CONFIG_MPC5xxx_FEC) += mpc5xxx_fec.o -COBJS-$(CONFIG_MPC512x_FEC) += mpc512x_fec.o -COBJS-$(CONFIG_MVGBE) += mvgbe.o -COBJS-$(CONFIG_NATSEMI) += natsemi.o -COBJS-$(CONFIG_DRIVER_NE2000) += ne2000.o ne2000_base.o -COBJS-$(CONFIG_DRIVER_AX88796L) += ax88796.o ne2000_base.o -COBJS-$(CONFIG_NETCONSOLE) += netconsole.o -COBJS-$(CONFIG_NS8382X) += ns8382x.o -COBJS-$(CONFIG_PCNET) += pcnet.o -COBJS-$(CONFIG_PLB2800_ETHER) += plb2800_eth.o -COBJS-$(CONFIG_RTL8139) += rtl8139.o -COBJS-$(CONFIG_RTL8169) += rtl8169.o -COBJS-$(CONFIG_SH_ETHER) += sh_eth.o -COBJS-$(CONFIG_SMC91111) += smc91111.o -COBJS-$(CONFIG_SMC911X) += smc911x.o -COBJS-$(CONFIG_SUNXI_WEMAC) += sunxi_wemac.o -COBJS-$(CONFIG_DRIVER_TI_EMAC) += davinci_emac.o -COBJS-$(CONFIG_TSEC_ENET) += tsec.o fsl_mdio.o -COBJS-$(CONFIG_DRIVER_TI_CPSW) += cpsw.o -COBJS-$(CONFIG_FMAN_ENET) += fsl_mdio.o -COBJS-$(CONFIG_TSI108_ETH) += tsi108_eth.o -COBJS-$(CONFIG_ULI526X) += uli526x.o -COBJS-$(CONFIG_VSC7385_ENET) += vsc7385.o -COBJS-$(CONFIG_XILINX_AXIEMAC) += xilinx_axi_emac.o -COBJS-$(CONFIG_XILINX_EMACLITE) += xilinx_emaclite.o -COBJS-$(CONFIG_XILINX_LL_TEMAC) += xilinx_ll_temac.o xilinx_ll_temac_mdio.o \ +obj-$(CONFIG_PPC4xx_EMAC) += 4xx_enet.o +obj-$(CONFIG_ALTERA_TSE) += altera_tse.o +obj-$(CONFIG_ARMADA100_FEC) += armada100_fec.o +obj-$(CONFIG_DRIVER_AT91EMAC) += at91_emac.o +obj-$(CONFIG_DRIVER_AX88180) += ax88180.o +obj-$(CONFIG_BFIN_MAC) += bfin_mac.o +obj-$(CONFIG_CALXEDA_XGMAC) += calxedaxgmac.o +obj-$(CONFIG_CS8900) += cs8900.o +obj-$(CONFIG_TULIP) += dc2114x.o +obj-$(CONFIG_DESIGNWARE_ETH) += designware.o +obj-$(CONFIG_DRIVER_DM9000) += dm9000x.o +obj-$(CONFIG_DNET) += dnet.o +obj-$(CONFIG_E1000) += e1000.o +obj-$(CONFIG_E1000_SPI) += e1000_spi.o +obj-$(CONFIG_EEPRO100) += eepro100.o +obj-$(CONFIG_ENC28J60) += enc28j60.o +obj-$(CONFIG_EP93XX) += ep93xx_eth.o +obj-$(CONFIG_ETHOC) += ethoc.o +obj-$(CONFIG_FEC_MXC) += fec_mxc.o +obj-$(CONFIG_FSLDMAFEC) += fsl_mcdmafec.o mcfmii.o +obj-$(CONFIG_FTGMAC100) += ftgmac100.o +obj-$(CONFIG_FTMAC110) += ftmac110.o +obj-$(CONFIG_FTMAC100) += ftmac100.o +obj-$(CONFIG_GRETH) += greth.o +obj-$(CONFIG_INCA_IP_SWITCH) += inca-ip_sw.o +obj-$(CONFIG_DRIVER_KS8695ETH) += ks8695eth.o +obj-$(CONFIG_KS8851_MLL) += ks8851_mll.o +obj-$(CONFIG_LAN91C96) += lan91c96.o +obj-$(CONFIG_MACB) += macb.o +obj-$(CONFIG_MCFFEC) += mcffec.o mcfmii.o +obj-$(CONFIG_MPC5xxx_FEC) += mpc5xxx_fec.o +obj-$(CONFIG_MPC512x_FEC) += mpc512x_fec.o +obj-$(CONFIG_MVGBE) += mvgbe.o +obj-$(CONFIG_NATSEMI) += natsemi.o +obj-$(CONFIG_DRIVER_NE2000) += ne2000.o ne2000_base.o +obj-$(CONFIG_DRIVER_AX88796L) += ax88796.o ne2000_base.o +obj-$(CONFIG_NETCONSOLE) += netconsole.o +obj-$(CONFIG_NS8382X) += ns8382x.o +obj-$(CONFIG_PCNET) += pcnet.o +obj-$(CONFIG_PLB2800_ETHER) += plb2800_eth.o +obj-$(CONFIG_RTL8139) += rtl8139.o +obj-$(CONFIG_RTL8169) += rtl8169.o +obj-$(CONFIG_SH_ETHER) += sh_eth.o +obj-$(CONFIG_SMC91111) += smc91111.o +obj-$(CONFIG_SMC911X) += smc911x.o +obj-$(CONFIG_SUNXI_WEMAC) += sunxi_wemac.o +obj-$(CONFIG_DRIVER_TI_EMAC) += davinci_emac.o +obj-$(CONFIG_TSEC_ENET) += tsec.o fsl_mdio.o +obj-$(CONFIG_DRIVER_TI_CPSW) += cpsw.o +obj-$(CONFIG_FMAN_ENET) += fsl_mdio.o +obj-$(CONFIG_TSI108_ETH) += tsi108_eth.o +obj-$(CONFIG_ULI526X) += uli526x.o +obj-$(CONFIG_VSC7385_ENET) += vsc7385.o +obj-$(CONFIG_XILINX_AXIEMAC) += xilinx_axi_emac.o +obj-$(CONFIG_XILINX_EMACLITE) += xilinx_emaclite.o +obj-$(CONFIG_XILINX_LL_TEMAC) += xilinx_ll_temac.o xilinx_ll_temac_mdio.o \ xilinx_ll_temac_fifo.o xilinx_ll_temac_sdma.o -COBJS-$(CONFIG_ZYNQ_GEM) += zynq_gem.o - -COBJS := $(sort $(COBJS-y)) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_ZYNQ_GEM) += zynq_gem.o diff --git a/drivers/net/fm/Makefile b/drivers/net/fm/Makefile index 4edd849..75380a8 100644 --- a/drivers/net/fm/Makefile +++ b/drivers/net/fm/Makefile @@ -4,50 +4,29 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libfm.o - ifdef CONFIG_FMAN_ENET -COBJS-y += dtsec.o -COBJS-y += eth.o -COBJS-y += fm.o -COBJS-y += init.o -COBJS-y += tgec.o -COBJS-y += tgec_phy.o +obj-y += dtsec.o +obj-y += eth.o +obj-y += fm.o +obj-y += init.o +obj-y += tgec.o +obj-y += tgec_phy.o
# Soc have FMAN v3 with mEMAC -COBJS-$(CONFIG_SYS_FMAN_V3) += memac_phy.o -COBJS-$(CONFIG_SYS_FMAN_V3) += memac.o +obj-$(CONFIG_SYS_FMAN_V3) += memac_phy.o +obj-$(CONFIG_SYS_FMAN_V3) += memac.o
# SoC specific SERDES support -COBJS-$(CONFIG_P1017) += p1023.o -COBJS-$(CONFIG_P1023) += p1023.o +obj-$(CONFIG_P1017) += p1023.o +obj-$(CONFIG_P1023) += p1023.o # The P204x, P304x, and P5020 are the same -COBJS-$(CONFIG_PPC_P2041) += p5020.o -COBJS-$(CONFIG_PPC_P3041) += p5020.o -COBJS-$(CONFIG_PPC_P4080) += p4080.o -COBJS-$(CONFIG_PPC_P5020) += p5020.o -COBJS-$(CONFIG_PPC_P5040) += p5040.o -COBJS-$(CONFIG_PPC_T4240) += t4240.o -COBJS-$(CONFIG_PPC_T4160) += t4240.o -COBJS-$(CONFIG_PPC_B4420) += b4860.o -COBJS-$(CONFIG_PPC_B4860) += b4860.o +obj-$(CONFIG_PPC_P2041) += p5020.o +obj-$(CONFIG_PPC_P3041) += p5020.o +obj-$(CONFIG_PPC_P4080) += p4080.o +obj-$(CONFIG_PPC_P5020) += p5020.o +obj-$(CONFIG_PPC_P5040) += p5040.o +obj-$(CONFIG_PPC_T4240) += t4240.o +obj-$(CONFIG_PPC_T4160) += t4240.o +obj-$(CONFIG_PPC_B4420) += b4860.o +obj-$(CONFIG_PPC_B4860) += b4860.o endif - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/drivers/net/npe/Makefile b/drivers/net/npe/Makefile index a982678..7fa5ea6 100644 --- a/drivers/net/npe/Makefile +++ b/drivers/net/npe/Makefile @@ -5,16 +5,12 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libnpe.o - LOCAL_CFLAGS += -I$(TOPDIR)/drivers/net/npe/include -DCONFIG_IXP425_COMPONENT_ETHDB -D__linux CFLAGS += $(LOCAL_CFLAGS) CPPFLAGS += $(LOCAL_CFLAGS) # needed for depend HOSTCFLAGS += $(LOCAL_CFLAGS)
-COBJS-$(CONFIG_IXP4XX_NPE) := npe.o \ +obj-$(CONFIG_IXP4XX_NPE) := npe.o \ miiphy.o \ IxOsalBufferMgt.o \ IxOsalIoMem.o \ @@ -63,21 +59,3 @@ COBJS-$(CONFIG_IXP4XX_NPE) := npe.o \ IxNpeMhSend.o \ IxNpeMhSolicitedCbMgr.o \ IxNpeMhUnsolicitedCbMgr.o - -SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/drivers/net/phy/Makefile b/drivers/net/phy/Makefile index fe762e9..dbf7bf7 100644 --- a/drivers/net/phy/Makefile +++ b/drivers/net/phy/Makefile @@ -5,44 +5,22 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libphy.o - -COBJS-$(CONFIG_BITBANGMII) += miiphybb.o -COBJS-$(CONFIG_MV88E61XX_SWITCH) += mv88e61xx.o -COBJS-$(CONFIG_MV88E6352_SWITCH) += mv88e6352.o - -COBJS-$(CONFIG_PHYLIB) += phy.o -COBJS-$(CONFIG_PHYLIB_10G) += generic_10g.o -COBJS-$(CONFIG_PHY_ATHEROS) += atheros.o -COBJS-$(CONFIG_PHY_BROADCOM) += broadcom.o -COBJS-$(CONFIG_PHY_DAVICOM) += davicom.o -COBJS-$(CONFIG_PHY_ET1011C) += et1011c.o -COBJS-$(CONFIG_PHY_ICPLUS) += icplus.o -COBJS-$(CONFIG_PHY_LXT) += lxt.o -COBJS-$(CONFIG_PHY_MARVELL) += marvell.o -COBJS-$(CONFIG_PHY_MICREL) += micrel.o -COBJS-$(CONFIG_PHY_NATSEMI) += natsemi.o -COBJS-$(CONFIG_PHY_REALTEK) += realtek.o -COBJS-$(CONFIG_PHY_SMSC) += smsc.o -COBJS-$(CONFIG_PHY_TERANETICS) += teranetics.o -COBJS-$(CONFIG_PHY_VITESSE) += vitesse.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_BITBANGMII) += miiphybb.o +obj-$(CONFIG_MV88E61XX_SWITCH) += mv88e61xx.o +obj-$(CONFIG_MV88E6352_SWITCH) += mv88e6352.o + +obj-$(CONFIG_PHYLIB) += phy.o +obj-$(CONFIG_PHYLIB_10G) += generic_10g.o +obj-$(CONFIG_PHY_ATHEROS) += atheros.o +obj-$(CONFIG_PHY_BROADCOM) += broadcom.o +obj-$(CONFIG_PHY_DAVICOM) += davicom.o +obj-$(CONFIG_PHY_ET1011C) += et1011c.o +obj-$(CONFIG_PHY_ICPLUS) += icplus.o +obj-$(CONFIG_PHY_LXT) += lxt.o +obj-$(CONFIG_PHY_MARVELL) += marvell.o +obj-$(CONFIG_PHY_MICREL) += micrel.o +obj-$(CONFIG_PHY_NATSEMI) += natsemi.o +obj-$(CONFIG_PHY_REALTEK) += realtek.o +obj-$(CONFIG_PHY_SMSC) += smsc.o +obj-$(CONFIG_PHY_TERANETICS) += teranetics.o +obj-$(CONFIG_PHY_VITESSE) += vitesse.o
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com --- drivers/mtd/Makefile | 44 +++++-------------- drivers/mtd/nand/Makefile | 102 +++++++++++++++++-------------------------- drivers/mtd/onenand/Makefile | 27 ++---------- drivers/mtd/spi/Makefile | 48 ++++++-------------- drivers/mtd/ubi/Makefile | 28 ++---------- 5 files changed, 70 insertions(+), 179 deletions(-)
diff --git a/drivers/mtd/Makefile b/drivers/mtd/Makefile index d2c3bda..5467a95 100644 --- a/drivers/mtd/Makefile +++ b/drivers/mtd/Makefile @@ -5,38 +5,16 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libmtd.o - ifneq (,$(findstring y,$(CONFIG_MTD_DEVICE)$(CONFIG_CMD_NAND)$(CONFIG_CMD_ONENAND))) -COBJS-y += mtdcore.o +obj-y += mtdcore.o endif -COBJS-$(CONFIG_MTD_PARTITIONS) += mtdpart.o -COBJS-$(CONFIG_MTD_CONCAT) += mtdconcat.o -COBJS-$(CONFIG_HAS_DATAFLASH) += at45.o -COBJS-$(CONFIG_FLASH_CFI_DRIVER) += cfi_flash.o -COBJS-$(CONFIG_FLASH_CFI_MTD) += cfi_mtd.o -COBJS-$(CONFIG_HAS_DATAFLASH) += dataflash.o -COBJS-$(CONFIG_FTSMC020) += ftsmc020.o -COBJS-$(CONFIG_FLASH_CFI_LEGACY) += jedec_flash.o -COBJS-$(CONFIG_MW_EEPROM) += mw_eeprom.o -COBJS-$(CONFIG_ST_SMI) += st_smi.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_MTD_PARTITIONS) += mtdpart.o +obj-$(CONFIG_MTD_CONCAT) += mtdconcat.o +obj-$(CONFIG_HAS_DATAFLASH) += at45.o +obj-$(CONFIG_FLASH_CFI_DRIVER) += cfi_flash.o +obj-$(CONFIG_FLASH_CFI_MTD) += cfi_mtd.o +obj-$(CONFIG_HAS_DATAFLASH) += dataflash.o +obj-$(CONFIG_FTSMC020) += ftsmc020.o +obj-$(CONFIG_FLASH_CFI_LEGACY) += jedec_flash.o +obj-$(CONFIG_MW_EEPROM) += mw_eeprom.o +obj-$(CONFIG_ST_SMI) += st_smi.o diff --git a/drivers/mtd/nand/Makefile b/drivers/mtd/nand/Makefile index 366dee6..eb1eafa 100644 --- a/drivers/mtd/nand/Makefile +++ b/drivers/mtd/nand/Makefile @@ -5,10 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libnand.o - ifdef CONFIG_CMD_NAND
ifdef CONFIG_SPL_BUILD @@ -17,77 +13,59 @@ ifdef CONFIG_SPL_NAND_DRIVERS NORMAL_DRIVERS=y endif
-COBJS-$(CONFIG_SPL_NAND_AM33XX_BCH) += am335x_spl_bch.o -COBJS-$(CONFIG_SPL_NAND_DOCG4) += docg4_spl.o -COBJS-$(CONFIG_SPL_NAND_SIMPLE) += nand_spl_simple.o -COBJS-$(CONFIG_SPL_NAND_LOAD) += nand_spl_load.o -COBJS-$(CONFIG_SPL_NAND_ECC) += nand_ecc.o -COBJS-$(CONFIG_SPL_NAND_BASE) += nand_base.o -COBJS-$(CONFIG_SPL_NAND_INIT) += nand.o +obj-$(CONFIG_SPL_NAND_AM33XX_BCH) += am335x_spl_bch.o +obj-$(CONFIG_SPL_NAND_DOCG4) += docg4_spl.o +obj-$(CONFIG_SPL_NAND_SIMPLE) += nand_spl_simple.o +obj-$(CONFIG_SPL_NAND_LOAD) += nand_spl_load.o +obj-$(CONFIG_SPL_NAND_ECC) += nand_ecc.o +obj-$(CONFIG_SPL_NAND_BASE) += nand_base.o +obj-$(CONFIG_SPL_NAND_INIT) += nand.o
else # not spl
NORMAL_DRIVERS=y
-COBJS-y += nand.o -COBJS-y += nand_bbt.o -COBJS-y += nand_ids.o -COBJS-y += nand_util.o -COBJS-y += nand_ecc.o -COBJS-y += nand_base.o +obj-y += nand.o +obj-y += nand_bbt.o +obj-y += nand_ids.o +obj-y += nand_util.o +obj-y += nand_ecc.o +obj-y += nand_base.o
endif # not spl
ifdef NORMAL_DRIVERS
-COBJS-$(CONFIG_NAND_ECC_BCH) += nand_bch.o - -COBJS-$(CONFIG_NAND_ATMEL) += atmel_nand.o -COBJS-$(CONFIG_DRIVER_NAND_BFIN) += bfin_nand.o -COBJS-$(CONFIG_NAND_DAVINCI) += davinci_nand.o -COBJS-$(CONFIG_NAND_FSL_ELBC) += fsl_elbc_nand.o -COBJS-$(CONFIG_NAND_FSL_IFC) += fsl_ifc_nand.o -COBJS-$(CONFIG_NAND_FSL_UPM) += fsl_upm.o -COBJS-$(CONFIG_NAND_FSMC) += fsmc_nand.o -COBJS-$(CONFIG_NAND_JZ4740) += jz4740_nand.o -COBJS-$(CONFIG_NAND_KB9202) += kb9202_nand.o -COBJS-$(CONFIG_NAND_KIRKWOOD) += kirkwood_nand.o -COBJS-$(CONFIG_NAND_KMETER1) += kmeter1_nand.o -COBJS-$(CONFIG_NAND_MPC5121_NFC) += mpc5121_nfc.o -COBJS-$(CONFIG_NAND_MXC) += mxc_nand.o -COBJS-$(CONFIG_NAND_MXS) += mxs_nand.o -COBJS-$(CONFIG_NAND_NDFC) += ndfc.o -COBJS-$(CONFIG_NAND_NOMADIK) += nomadik.o -COBJS-$(CONFIG_NAND_S3C2410) += s3c2410_nand.o -COBJS-$(CONFIG_NAND_SPEAR) += spr_nand.o -COBJS-$(CONFIG_TEGRA_NAND) += tegra_nand.o -COBJS-$(CONFIG_NAND_OMAP_GPMC) += omap_gpmc.o -COBJS-$(CONFIG_NAND_PLAT) += nand_plat.o -COBJS-$(CONFIG_NAND_DOCG4) += docg4.o +obj-$(CONFIG_NAND_ECC_BCH) += nand_bch.o + +obj-$(CONFIG_NAND_ATMEL) += atmel_nand.o +obj-$(CONFIG_DRIVER_NAND_BFIN) += bfin_nand.o +obj-$(CONFIG_NAND_DAVINCI) += davinci_nand.o +obj-$(CONFIG_NAND_FSL_ELBC) += fsl_elbc_nand.o +obj-$(CONFIG_NAND_FSL_IFC) += fsl_ifc_nand.o +obj-$(CONFIG_NAND_FSL_UPM) += fsl_upm.o +obj-$(CONFIG_NAND_FSMC) += fsmc_nand.o +obj-$(CONFIG_NAND_JZ4740) += jz4740_nand.o +obj-$(CONFIG_NAND_KB9202) += kb9202_nand.o +obj-$(CONFIG_NAND_KIRKWOOD) += kirkwood_nand.o +obj-$(CONFIG_NAND_KMETER1) += kmeter1_nand.o +obj-$(CONFIG_NAND_MPC5121_NFC) += mpc5121_nfc.o +obj-$(CONFIG_NAND_MXC) += mxc_nand.o +obj-$(CONFIG_NAND_MXS) += mxs_nand.o +obj-$(CONFIG_NAND_NDFC) += ndfc.o +obj-$(CONFIG_NAND_NOMADIK) += nomadik.o +obj-$(CONFIG_NAND_S3C2410) += s3c2410_nand.o +obj-$(CONFIG_NAND_SPEAR) += spr_nand.o +obj-$(CONFIG_TEGRA_NAND) += tegra_nand.o +obj-$(CONFIG_NAND_OMAP_GPMC) += omap_gpmc.o +obj-$(CONFIG_NAND_PLAT) += nand_plat.o +obj-$(CONFIG_NAND_DOCG4) += docg4.o
else # minimal SPL drivers
-COBJS-$(CONFIG_NAND_FSL_ELBC) += fsl_elbc_spl.o -COBJS-$(CONFIG_NAND_FSL_IFC) += fsl_ifc_spl.o -COBJS-$(CONFIG_NAND_MXC) += mxc_nand_spl.o +obj-$(CONFIG_NAND_FSL_ELBC) += fsl_elbc_spl.o +obj-$(CONFIG_NAND_FSL_IFC) += fsl_ifc_spl.o +obj-$(CONFIG_NAND_MXC) += mxc_nand_spl.o
endif # drivers endif # nand - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/drivers/mtd/onenand/Makefile b/drivers/mtd/onenand/Makefile index 993d317..b249348 100644 --- a/drivers/mtd/onenand/Makefile +++ b/drivers/mtd/onenand/Makefile @@ -5,30 +5,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libonenand.o - ifndef CONFIG_SPL_BUILD -COBJS-$(CONFIG_CMD_ONENAND) := onenand_uboot.o onenand_base.o onenand_bbt.o -COBJS-$(CONFIG_SAMSUNG_ONENAND) += samsung.o +obj-$(CONFIG_CMD_ONENAND) := onenand_uboot.o onenand_base.o onenand_bbt.o +obj-$(CONFIG_SAMSUNG_ONENAND) += samsung.o else -COBJS-y := onenand_spl.o +obj-y := onenand_spl.o endif - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/drivers/mtd/spi/Makefile b/drivers/mtd/spi/Makefile index 191138a..4173b5f 100644 --- a/drivers/mtd/spi/Makefile +++ b/drivers/mtd/spi/Makefile @@ -5,41 +5,19 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libspi_flash.o - ifdef CONFIG_SPL_BUILD -COBJS-$(CONFIG_SPL_SPI_LOAD) += spi_spl_load.o -COBJS-$(CONFIG_SPL_SPI_BOOT) += fsl_espi_spl.o +obj-$(CONFIG_SPL_SPI_LOAD) += spi_spl_load.o +obj-$(CONFIG_SPL_SPI_BOOT) += fsl_espi_spl.o endif
-COBJS-$(CONFIG_SPI_FLASH) += spi_flash.o -COBJS-$(CONFIG_SPI_FLASH_ATMEL) += atmel.o -COBJS-$(CONFIG_SPI_FLASH_EON) += eon.o -COBJS-$(CONFIG_SPI_FLASH_GIGADEVICE) += gigadevice.o -COBJS-$(CONFIG_SPI_FLASH_MACRONIX) += macronix.o -COBJS-$(CONFIG_SPI_FLASH_SPANSION) += spansion.o -COBJS-$(CONFIG_SPI_FLASH_SST) += sst.o -COBJS-$(CONFIG_SPI_FLASH_STMICRO) += stmicro.o -COBJS-$(CONFIG_SPI_FLASH_WINBOND) += winbond.o -COBJS-$(CONFIG_SPI_FRAM_RAMTRON) += ramtron.o -COBJS-$(CONFIG_SPI_M95XXX) += eeprom_m95xxx.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_SPI_FLASH) += spi_flash.o +obj-$(CONFIG_SPI_FLASH_ATMEL) += atmel.o +obj-$(CONFIG_SPI_FLASH_EON) += eon.o +obj-$(CONFIG_SPI_FLASH_GIGADEVICE) += gigadevice.o +obj-$(CONFIG_SPI_FLASH_MACRONIX) += macronix.o +obj-$(CONFIG_SPI_FLASH_SPANSION) += spansion.o +obj-$(CONFIG_SPI_FLASH_SST) += sst.o +obj-$(CONFIG_SPI_FLASH_STMICRO) += stmicro.o +obj-$(CONFIG_SPI_FLASH_WINBOND) += winbond.o +obj-$(CONFIG_SPI_FRAM_RAMTRON) += ramtron.o +obj-$(CONFIG_SPI_M95XXX) += eeprom_m95xxx.o diff --git a/drivers/mtd/ubi/Makefile b/drivers/mtd/ubi/Makefile index 1a88e94..e1f3a24 100644 --- a/drivers/mtd/ubi/Makefile +++ b/drivers/mtd/ubi/Makefile @@ -5,31 +5,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libubi.o - ifdef CONFIG_CMD_UBI -COBJS-y += build.o vtbl.o vmt.o upd.o kapi.o eba.o io.o wl.o scan.o crc32.o +obj-y += build.o vtbl.o vmt.o upd.o kapi.o eba.o io.o wl.o scan.o crc32.o
-COBJS-y += misc.o -COBJS-y += debug.o +obj-y += misc.o +obj-y += debug.o endif - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -#########################################################################
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com --- drivers/usb/eth/Makefile | 28 ++-------------- drivers/usb/gadget/Makefile | 54 ++++++++++--------------------- drivers/usb/host/Makefile | 74 +++++++++++++++---------------------------- drivers/usb/musb-new/Makefile | 36 ++++----------------- drivers/usb/musb/Makefile | 36 ++++----------------- drivers/usb/phy/Makefile | 24 +------------- drivers/usb/ulpi/Makefile | 28 ++-------------- 7 files changed, 62 insertions(+), 218 deletions(-)
diff --git a/drivers/usb/eth/Makefile b/drivers/usb/eth/Makefile index 04a8b58..03f5474 100644 --- a/drivers/usb/eth/Makefile +++ b/drivers/usb/eth/Makefile @@ -3,31 +3,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libusb_eth.o - # new USB host ethernet layer dependencies -COBJS-$(CONFIG_USB_HOST_ETHER) += usb_ether.o +obj-$(CONFIG_USB_HOST_ETHER) += usb_ether.o ifdef CONFIG_USB_ETHER_ASIX -COBJS-y += asix.o +obj-y += asix.o endif -COBJS-$(CONFIG_USB_ETHER_SMSC95XX) += smsc95xx.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_USB_ETHER_SMSC95XX) += smsc95xx.o diff --git a/drivers/usb/gadget/Makefile b/drivers/usb/gadget/Makefile index 4c2a39a..276ad6e 100644 --- a/drivers/usb/gadget/Makefile +++ b/drivers/usb/gadget/Makefile @@ -5,56 +5,34 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libusb_gadget.o - # if defined(CONFIG_USB_GADGET) || defined(CONFIG_USB_ETHER) # Everytime you forget how crufty makefiles can get things like # this remind you... ifneq (,$(CONFIG_USB_GADGET)$(CONFIG_USB_ETHER)) -COBJS-y += epautoconf.o config.o usbstring.o +obj-y += epautoconf.o config.o usbstring.o endif
# new USB gadget layer dependencies ifdef CONFIG_USB_GADGET -COBJS-$(CONFIG_USB_GADGET_S3C_UDC_OTG) += s3c_udc_otg.o -COBJS-$(CONFIG_USB_GADGET_FOTG210) += fotg210.o -COBJS-$(CONFIG_USBDOWNLOAD_GADGET) += g_dnl.o -COBJS-$(CONFIG_DFU_FUNCTION) += f_dfu.o +obj-$(CONFIG_USB_GADGET_S3C_UDC_OTG) += s3c_udc_otg.o +obj-$(CONFIG_USB_GADGET_FOTG210) += fotg210.o +obj-$(CONFIG_USBDOWNLOAD_GADGET) += g_dnl.o +obj-$(CONFIG_DFU_FUNCTION) += f_dfu.o endif ifdef CONFIG_USB_ETHER -COBJS-y += ether.o -COBJS-$(CONFIG_USB_ETH_RNDIS) += rndis.o -COBJS-$(CONFIG_MV_UDC) += mv_udc.o -COBJS-$(CONFIG_CPU_PXA25X) += pxa25x_udc.o +obj-y += ether.o +obj-$(CONFIG_USB_ETH_RNDIS) += rndis.o +obj-$(CONFIG_MV_UDC) += mv_udc.o +obj-$(CONFIG_CPU_PXA25X) += pxa25x_udc.o else # Devices not related to the new gadget layer depend on CONFIG_USB_DEVICE ifdef CONFIG_USB_DEVICE -COBJS-y += core.o -COBJS-y += ep0.o -COBJS-$(CONFIG_DW_UDC) += designware_udc.o -COBJS-$(CONFIG_OMAP1510) += omap1510_udc.o -COBJS-$(CONFIG_OMAP1610) += omap1510_udc.o -COBJS-$(CONFIG_MPC885_FAMILY) += mpc8xx_udc.o -COBJS-$(CONFIG_CPU_PXA27X) += pxa27x_udc.o +obj-y += core.o +obj-y += ep0.o +obj-$(CONFIG_DW_UDC) += designware_udc.o +obj-$(CONFIG_OMAP1510) += omap1510_udc.o +obj-$(CONFIG_OMAP1610) += omap1510_udc.o +obj-$(CONFIG_MPC885_FAMILY) += mpc8xx_udc.o +obj-$(CONFIG_CPU_PXA27X) += pxa27x_udc.o endif endif - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/drivers/usb/host/Makefile b/drivers/usb/host/Makefile index ff6c80e..674508a 100644 --- a/drivers/usb/host/Makefile +++ b/drivers/usb/host/Makefile @@ -5,57 +5,35 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libusb_host.o - # ohci -COBJS-$(CONFIG_USB_OHCI_NEW) += ohci-hcd.o -COBJS-$(CONFIG_USB_ATMEL) += ohci-at91.o -COBJS-$(CONFIG_USB_OHCI_DA8XX) += ohci-da8xx.o -COBJS-$(CONFIG_USB_ISP116X_HCD) += isp116x-hcd.o -COBJS-$(CONFIG_USB_R8A66597_HCD) += r8a66597-hcd.o -COBJS-$(CONFIG_USB_SL811HS) += sl811-hcd.o -COBJS-$(CONFIG_USB_OHCI_S3C24XX) += ohci-s3c24xx.o +obj-$(CONFIG_USB_OHCI_NEW) += ohci-hcd.o +obj-$(CONFIG_USB_ATMEL) += ohci-at91.o +obj-$(CONFIG_USB_OHCI_DA8XX) += ohci-da8xx.o +obj-$(CONFIG_USB_ISP116X_HCD) += isp116x-hcd.o +obj-$(CONFIG_USB_R8A66597_HCD) += r8a66597-hcd.o +obj-$(CONFIG_USB_SL811HS) += sl811-hcd.o +obj-$(CONFIG_USB_OHCI_S3C24XX) += ohci-s3c24xx.o
# echi -COBJS-$(CONFIG_USB_EHCI) += ehci-hcd.o -COBJS-$(CONFIG_USB_EHCI_ARMADA100) += ehci-armada100.o utmi-armada100.o -COBJS-$(CONFIG_USB_EHCI_ATMEL) += ehci-atmel.o +obj-$(CONFIG_USB_EHCI) += ehci-hcd.o +obj-$(CONFIG_USB_EHCI_ARMADA100) += ehci-armada100.o utmi-armada100.o +obj-$(CONFIG_USB_EHCI_ATMEL) += ehci-atmel.o ifdef CONFIG_MPC512X -COBJS-$(CONFIG_USB_EHCI_FSL) += ehci-mpc512x.o +obj-$(CONFIG_USB_EHCI_FSL) += ehci-mpc512x.o else -COBJS-$(CONFIG_USB_EHCI_FSL) += ehci-fsl.o +obj-$(CONFIG_USB_EHCI_FSL) += ehci-fsl.o endif -COBJS-$(CONFIG_USB_EHCI_FARADAY) += ehci-faraday.o -COBJS-$(CONFIG_USB_EHCI_EXYNOS) += ehci-exynos.o -COBJS-$(CONFIG_USB_EHCI_MXC) += ehci-mxc.o -COBJS-$(CONFIG_USB_EHCI_MXS) += ehci-mxs.o -COBJS-$(CONFIG_USB_EHCI_MX5) += ehci-mx5.o -COBJS-$(CONFIG_USB_EHCI_MX6) += ehci-mx6.o -COBJS-$(CONFIG_USB_EHCI_OMAP) += ehci-omap.o -COBJS-$(CONFIG_USB_EHCI_PPC4XX) += ehci-ppc4xx.o -COBJS-$(CONFIG_USB_EHCI_IXP4XX) += ehci-ixp.o -COBJS-$(CONFIG_USB_EHCI_MARVELL) += ehci-marvell.o -COBJS-$(CONFIG_USB_EHCI_PCI) += ehci-pci.o -COBJS-$(CONFIG_USB_EHCI_SPEAR) += ehci-spear.o -COBJS-$(CONFIG_USB_EHCI_TEGRA) += ehci-tegra.o -COBJS-$(CONFIG_USB_EHCI_VCT) += ehci-vct.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_USB_EHCI_FARADAY) += ehci-faraday.o +obj-$(CONFIG_USB_EHCI_EXYNOS) += ehci-exynos.o +obj-$(CONFIG_USB_EHCI_MXC) += ehci-mxc.o +obj-$(CONFIG_USB_EHCI_MXS) += ehci-mxs.o +obj-$(CONFIG_USB_EHCI_MX5) += ehci-mx5.o +obj-$(CONFIG_USB_EHCI_MX6) += ehci-mx6.o +obj-$(CONFIG_USB_EHCI_OMAP) += ehci-omap.o +obj-$(CONFIG_USB_EHCI_PPC4XX) += ehci-ppc4xx.o +obj-$(CONFIG_USB_EHCI_IXP4XX) += ehci-ixp.o +obj-$(CONFIG_USB_EHCI_MARVELL) += ehci-marvell.o +obj-$(CONFIG_USB_EHCI_PCI) += ehci-pci.o +obj-$(CONFIG_USB_EHCI_SPEAR) += ehci-spear.o +obj-$(CONFIG_USB_EHCI_TEGRA) += ehci-tegra.o +obj-$(CONFIG_USB_EHCI_VCT) += ehci-vct.o diff --git a/drivers/usb/musb-new/Makefile b/drivers/usb/musb-new/Makefile index c23bef1..ba72348 100644 --- a/drivers/usb/musb-new/Makefile +++ b/drivers/usb/musb-new/Makefile @@ -2,38 +2,14 @@ # for USB OTG silicon based on Mentor Graphics INVENTRA designs #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libusb_musb-new.o - -COBJS-$(CONFIG_MUSB_GADGET) += musb_gadget.o musb_gadget_ep0.o musb_core.o -COBJS-$(CONFIG_MUSB_GADGET) += musb_uboot.o -COBJS-$(CONFIG_MUSB_HOST) += musb_host.o musb_core.o musb_uboot.o -COBJS-$(CONFIG_USB_MUSB_DSPS) += musb_dsps.o -COBJS-$(CONFIG_USB_MUSB_AM35X) += am35x.o -COBJS-$(CONFIG_USB_MUSB_OMAP2PLUS) += omap2430.o +obj-$(CONFIG_MUSB_GADGET) += musb_gadget.o musb_gadget_ep0.o musb_core.o +obj-$(CONFIG_MUSB_GADGET) += musb_uboot.o +obj-$(CONFIG_MUSB_HOST) += musb_host.o musb_core.o musb_uboot.o +obj-$(CONFIG_USB_MUSB_DSPS) += musb_dsps.o +obj-$(CONFIG_USB_MUSB_AM35X) += am35x.o +obj-$(CONFIG_USB_MUSB_OMAP2PLUS) += omap2430.o
CFLAGS_NO_WARN := $(call cc-option,-Wno-unused-variable) \ $(call cc-option,-Wno-unused-but-set-variable) \ $(call cc-option,-Wno-unused-label) CFLAGS += $(CFLAGS_NO_WARN) - -COBJS := $(sort $(COBJS-y)) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -#$(LIB): $(OBJS) -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### - diff --git a/drivers/usb/musb/Makefile b/drivers/usb/musb/Makefile index aa2126d..3c9ed98 100644 --- a/drivers/usb/musb/Makefile +++ b/drivers/usb/musb/Makefile @@ -5,32 +5,10 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libusb_musb.o - -COBJS-$(CONFIG_MUSB_HCD) += musb_hcd.o musb_core.o -COBJS-$(CONFIG_MUSB_UDC) += musb_udc.o musb_core.o -COBJS-$(CONFIG_USB_BLACKFIN) += blackfin_usb.o -COBJS-$(CONFIG_USB_DAVINCI) += davinci.o -COBJS-$(CONFIG_USB_OMAP3) += omap3.o -COBJS-$(CONFIG_USB_DA8XX) += da8xx.o -COBJS-$(CONFIG_USB_AM35X) += am35x.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_MUSB_HCD) += musb_hcd.o musb_core.o +obj-$(CONFIG_MUSB_UDC) += musb_udc.o musb_core.o +obj-$(CONFIG_USB_BLACKFIN) += blackfin_usb.o +obj-$(CONFIG_USB_DAVINCI) += davinci.o +obj-$(CONFIG_USB_OMAP3) += omap3.o +obj-$(CONFIG_USB_DA8XX) += da8xx.o +obj-$(CONFIG_USB_AM35X) += am35x.o diff --git a/drivers/usb/phy/Makefile b/drivers/usb/phy/Makefile index f93121a..535cf51 100644 --- a/drivers/usb/phy/Makefile +++ b/drivers/usb/phy/Makefile @@ -5,26 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libusb_phy.o - -COBJS-$(CONFIG_TWL4030_USB) += twl4030.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_TWL4030_USB) += twl4030.o diff --git a/drivers/usb/ulpi/Makefile b/drivers/usb/ulpi/Makefile index ba5a1ab..a21fe2c 100644 --- a/drivers/usb/ulpi/Makefile +++ b/drivers/usb/ulpi/Makefile @@ -4,28 +4,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libusb_ulpi.o - -COBJS-$(CONFIG_USB_ULPI) += ulpi.o -COBJS-$(CONFIG_USB_ULPI_VIEWPORT) += ulpi-viewport.o -COBJS-$(CONFIG_USB_ULPI_VIEWPORT_OMAP) += omap-ulpi-viewport.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_USB_ULPI) += ulpi.o +obj-$(CONFIG_USB_ULPI_VIEWPORT) += ulpi-viewport.o +obj-$(CONFIG_USB_ULPI_VIEWPORT_OMAP) += omap-ulpi-viewport.o
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com --- drivers/bios_emulator/Makefile | 23 +------- drivers/block/Makefile | 52 ++++++------------ drivers/bootcount/Makefile | 30 ++--------- drivers/crypto/Makefile | 25 +-------- drivers/dfu/Makefile | 25 ++------- drivers/dma/Makefile | 30 ++--------- drivers/fpga/Makefile | 44 ++++----------- drivers/gpio/Makefile | 73 +++++++++---------------- drivers/hwmon/Makefile | 40 ++++---------- drivers/i2c/Makefile | 70 +++++++++--------------- drivers/input/Makefile | 36 +++---------- drivers/misc/Makefile | 52 ++++++------------ drivers/mmc/Makefile | 69 ++++++++---------------- drivers/pci/Makefile | 44 ++++----------- drivers/pcmcia/Makefile | 34 +++--------- drivers/power/Makefile | 47 +++++----------- drivers/power/battery/Makefile | 25 +-------- drivers/power/fuel_gauge/Makefile | 25 +-------- drivers/power/pmic/Makefile | 31 ++--------- drivers/qe/Makefile | 25 +-------- drivers/rtc/Makefile | 110 +++++++++++++++----------------------- drivers/serial/Makefile | 82 +++++++++++----------------- drivers/sound/Makefile | 30 ++--------- drivers/spi/Makefile | 82 +++++++++++----------------- drivers/tpm/Makefile | 29 ++-------- drivers/twserial/Makefile | 24 +-------- drivers/video/Makefile | 84 +++++++++++------------------ drivers/watchdog/Makefile | 36 +++---------- 28 files changed, 331 insertions(+), 946 deletions(-)
diff --git a/drivers/bios_emulator/Makefile b/drivers/bios_emulator/Makefile index d94a144..dd42e0f 100644 --- a/drivers/bios_emulator/Makefile +++ b/drivers/bios_emulator/Makefile @@ -1,12 +1,8 @@ -include $(TOPDIR)/config.mk - -LIB := $(obj)libatibiosemu.o - X86DIR = x86emu
$(shell mkdir -p $(obj)$(X86DIR))
-COBJS-$(CONFIG_BIOSEMU) = atibios.o biosemu.o besys.o bios.o \ +obj-$(CONFIG_BIOSEMU) = atibios.o biosemu.o besys.o bios.o \ $(X86DIR)/decode.o \ $(X86DIR)/ops2.o \ $(X86DIR)/ops.o \ @@ -14,26 +10,9 @@ COBJS-$(CONFIG_BIOSEMU) = atibios.o biosemu.o besys.o bios.o \ $(X86DIR)/sys.o \ $(X86DIR)/debug.o
-COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - EXTRA_CFLAGS += -I. -I./include -I$(TOPDIR)/include \ -D__PPC__ -D__BIG_ENDIAN__
CFLAGS += $(EXTRA_CFLAGS) HOSTCFLAGS += $(EXTRA_CFLAGS) CPPFLAGS += $(EXTRA_CFLAGS) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/drivers/block/Makefile b/drivers/block/Makefile index 2016e98..4e94378 100644 --- a/drivers/block/Makefile +++ b/drivers/block/Makefile @@ -5,40 +5,18 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libblock.o - -COBJS-$(CONFIG_SCSI_AHCI) += ahci.o -COBJS-$(CONFIG_ATA_PIIX) += ata_piix.o -COBJS-$(CONFIG_DWC_AHSATA) += dwc_ahsata.o -COBJS-$(CONFIG_FSL_SATA) += fsl_sata.o -COBJS-$(CONFIG_IDE_FTIDE020) += ftide020.o -COBJS-$(CONFIG_LIBATA) += libata.o -COBJS-$(CONFIG_MVSATA_IDE) += mvsata_ide.o -COBJS-$(CONFIG_MX51_PATA) += mxc_ata.o -COBJS-$(CONFIG_PATA_BFIN) += pata_bfin.o -COBJS-$(CONFIG_SATA_DWC) += sata_dwc.o -COBJS-$(CONFIG_SATA_SIL3114) += sata_sil3114.o -COBJS-$(CONFIG_SATA_SIL) += sata_sil.o -COBJS-$(CONFIG_IDE_SIL680) += sil680.o -COBJS-$(CONFIG_SCSI_SYM53C8XX) += sym53c8xx.o -COBJS-$(CONFIG_SYSTEMACE) += systemace.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_SCSI_AHCI) += ahci.o +obj-$(CONFIG_ATA_PIIX) += ata_piix.o +obj-$(CONFIG_DWC_AHSATA) += dwc_ahsata.o +obj-$(CONFIG_FSL_SATA) += fsl_sata.o +obj-$(CONFIG_IDE_FTIDE020) += ftide020.o +obj-$(CONFIG_LIBATA) += libata.o +obj-$(CONFIG_MVSATA_IDE) += mvsata_ide.o +obj-$(CONFIG_MX51_PATA) += mxc_ata.o +obj-$(CONFIG_PATA_BFIN) += pata_bfin.o +obj-$(CONFIG_SATA_DWC) += sata_dwc.o +obj-$(CONFIG_SATA_SIL3114) += sata_sil3114.o +obj-$(CONFIG_SATA_SIL) += sata_sil.o +obj-$(CONFIG_IDE_SIL680) += sil680.o +obj-$(CONFIG_SCSI_SYM53C8XX) += sym53c8xx.o +obj-$(CONFIG_SYSTEMACE) += systemace.o diff --git a/drivers/bootcount/Makefile b/drivers/bootcount/Makefile index 2b517b6..012acef 100644 --- a/drivers/bootcount/Makefile +++ b/drivers/bootcount/Makefile @@ -2,28 +2,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libbootcount.o - -COBJS-y += bootcount.o -COBJS-$(CONFIG_AT91SAM9XE) += bootcount_at91.o -COBJS-$(CONFIG_BLACKFIN) += bootcount_blackfin.o -COBJS-$(CONFIG_SOC_DA8XX) += bootcount_davinci.o -COBJS-$(CONFIG_BOOTCOUNT_RAM) += bootcount_ram.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################## +obj-y += bootcount.o +obj-$(CONFIG_AT91SAM9XE) += bootcount_at91.o +obj-$(CONFIG_BLACKFIN) += bootcount_blackfin.o +obj-$(CONFIG_SOC_DA8XX) += bootcount_davinci.o +obj-$(CONFIG_BOOTCOUNT_RAM) += bootcount_ram.o diff --git a/drivers/crypto/Makefile b/drivers/crypto/Makefile index 02c53bf..b807795 100644 --- a/drivers/crypto/Makefile +++ b/drivers/crypto/Makefile @@ -5,27 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libcrypto.o - -COBJS-$(CONFIG_EXYNOS_ACE_SHA) += ace_sha.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################## +obj-$(CONFIG_EXYNOS_ACE_SHA) += ace_sha.o diff --git a/drivers/dfu/Makefile b/drivers/dfu/Makefile index fca370a..f7b7014 100644 --- a/drivers/dfu/Makefile +++ b/drivers/dfu/Makefile @@ -5,25 +5,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libdfu.o - -COBJS-$(CONFIG_DFU_FUNCTION) += dfu.o -COBJS-$(CONFIG_DFU_MMC) += dfu_mmc.o -COBJS-$(CONFIG_DFU_NAND) += dfu_nand.o - -SRCS := $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_DFU_FUNCTION) += dfu.o +obj-$(CONFIG_DFU_MMC) += dfu_mmc.o +obj-$(CONFIG_DFU_NAND) += dfu_nand.o diff --git a/drivers/dma/Makefile b/drivers/dma/Makefile index a6132e2..8b2821b 100644 --- a/drivers/dma/Makefile +++ b/drivers/dma/Makefile @@ -5,29 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libdma.o - -COBJS-$(CONFIG_FSLDMAFEC) += MCD_tasksInit.o MCD_dmaApi.o MCD_tasks.o -COBJS-$(CONFIG_APBH_DMA) += apbh_dma.o -COBJS-$(CONFIG_FSL_DMA) += fsl_dma.o -COBJS-$(CONFIG_OMAP3_DMA) += omap3_dma.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_FSLDMAFEC) += MCD_tasksInit.o MCD_dmaApi.o MCD_tasks.o +obj-$(CONFIG_APBH_DMA) += apbh_dma.o +obj-$(CONFIG_FSL_DMA) += fsl_dma.o +obj-$(CONFIG_OMAP3_DMA) += omap3_dma.o diff --git a/drivers/fpga/Makefile b/drivers/fpga/Makefile index a1a0602..4fcdf40 100644 --- a/drivers/fpga/Makefile +++ b/drivers/fpga/Makefile @@ -5,40 +5,18 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libfpga.o - ifdef CONFIG_FPGA -COBJS-y += fpga.o -COBJS-$(CONFIG_FPGA_SPARTAN2) += spartan2.o -COBJS-$(CONFIG_FPGA_SPARTAN3) += spartan3.o -COBJS-$(CONFIG_FPGA_VIRTEX2) += virtex2.o -COBJS-$(CONFIG_FPGA_ZYNQPL) += zynqpl.o -COBJS-$(CONFIG_FPGA_XILINX) += xilinx.o -COBJS-$(CONFIG_FPGA_LATTICE) += ivm_core.o lattice.o +obj-y += fpga.o +obj-$(CONFIG_FPGA_SPARTAN2) += spartan2.o +obj-$(CONFIG_FPGA_SPARTAN3) += spartan3.o +obj-$(CONFIG_FPGA_VIRTEX2) += virtex2.o +obj-$(CONFIG_FPGA_ZYNQPL) += zynqpl.o +obj-$(CONFIG_FPGA_XILINX) += xilinx.o +obj-$(CONFIG_FPGA_LATTICE) += ivm_core.o lattice.o ifdef CONFIG_FPGA_ALTERA -COBJS-y += altera.o -COBJS-$(CONFIG_FPGA_ACEX1K) += ACEX1K.o -COBJS-$(CONFIG_FPGA_CYCLON2) += cyclon2.o -COBJS-$(CONFIG_FPGA_STRATIX_II) += stratixII.o +obj-y += altera.o +obj-$(CONFIG_FPGA_ACEX1K) += ACEX1K.o +obj-$(CONFIG_FPGA_CYCLON2) += cyclon2.o +obj-$(CONFIG_FPGA_STRATIX_II) += stratixII.o endif endif - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index 71ddb00..1165793 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -5,51 +5,28 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libgpio.o - -COBJS-$(CONFIG_AT91_GPIO) += at91_gpio.o -COBJS-$(CONFIG_INTEL_ICH6_GPIO) += intel_ich6_gpio.o -COBJS-$(CONFIG_KIRKWOOD_GPIO) += kw_gpio.o -COBJS-$(CONFIG_MARVELL_GPIO) += mvgpio.o -COBJS-$(CONFIG_MARVELL_MFP) += mvmfp.o -COBJS-$(CONFIG_MXC_GPIO) += mxc_gpio.o -COBJS-$(CONFIG_MXS_GPIO) += mxs_gpio.o -COBJS-$(CONFIG_PCA953X) += pca953x.o -COBJS-$(CONFIG_PCA9698) += pca9698.o -COBJS-$(CONFIG_S5P) += s5p_gpio.o -COBJS-$(CONFIG_SANDBOX_GPIO) += sandbox.o -COBJS-$(CONFIG_SPEAR_GPIO) += spear_gpio.o -COBJS-$(CONFIG_TEGRA_GPIO) += tegra_gpio.o -COBJS-$(CONFIG_DA8XX_GPIO) += da8xx_gpio.o -COBJS-$(CONFIG_DM644X_GPIO) += da8xx_gpio.o -COBJS-$(CONFIG_ALTERA_PIO) += altera_pio.o -COBJS-$(CONFIG_MPC83XX_GPIO) += mpc83xx_gpio.o -COBJS-$(CONFIG_SH_GPIO_PFC) += sh_pfc.o -COBJS-$(CONFIG_OMAP_GPIO) += omap_gpio.o -COBJS-$(CONFIG_DB8500_GPIO) += db8500_gpio.o -COBJS-$(CONFIG_BCM2835_GPIO) += bcm2835_gpio.o -COBJS-$(CONFIG_S3C2440_GPIO) += s3c2440_gpio.o -COBJS-$(CONFIG_XILINX_GPIO) += xilinx_gpio.o -COBJS-$(CONFIG_ADI_GPIO2) += adi_gpio2.o -COBJS-$(CONFIG_TCA642X) += tca642x.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################## +obj-$(CONFIG_AT91_GPIO) += at91_gpio.o +obj-$(CONFIG_INTEL_ICH6_GPIO) += intel_ich6_gpio.o +obj-$(CONFIG_KIRKWOOD_GPIO) += kw_gpio.o +obj-$(CONFIG_MARVELL_GPIO) += mvgpio.o +obj-$(CONFIG_MARVELL_MFP) += mvmfp.o +obj-$(CONFIG_MXC_GPIO) += mxc_gpio.o +obj-$(CONFIG_MXS_GPIO) += mxs_gpio.o +obj-$(CONFIG_PCA953X) += pca953x.o +obj-$(CONFIG_PCA9698) += pca9698.o +obj-$(CONFIG_S5P) += s5p_gpio.o +obj-$(CONFIG_SANDBOX_GPIO) += sandbox.o +obj-$(CONFIG_SPEAR_GPIO) += spear_gpio.o +obj-$(CONFIG_TEGRA_GPIO) += tegra_gpio.o +obj-$(CONFIG_DA8XX_GPIO) += da8xx_gpio.o +obj-$(CONFIG_DM644X_GPIO) += da8xx_gpio.o +obj-$(CONFIG_ALTERA_PIO) += altera_pio.o +obj-$(CONFIG_MPC83XX_GPIO) += mpc83xx_gpio.o +obj-$(CONFIG_SH_GPIO_PFC) += sh_pfc.o +obj-$(CONFIG_OMAP_GPIO) += omap_gpio.o +obj-$(CONFIG_DB8500_GPIO) += db8500_gpio.o +obj-$(CONFIG_BCM2835_GPIO) += bcm2835_gpio.o +obj-$(CONFIG_S3C2440_GPIO) += s3c2440_gpio.o +obj-$(CONFIG_XILINX_GPIO) += xilinx_gpio.o +obj-$(CONFIG_ADI_GPIO2) += adi_gpio2.o +obj-$(CONFIG_TCA642X) += tca642x.o diff --git a/drivers/hwmon/Makefile b/drivers/hwmon/Makefile index 6e203a3..a78a724 100644 --- a/drivers/hwmon/Makefile +++ b/drivers/hwmon/Makefile @@ -8,36 +8,14 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - #CFLAGS += -DDEBUG
-LIB = $(obj)libhwmon.o - -COBJS-$(CONFIG_DTT_ADM1021) += adm1021.o -COBJS-$(CONFIG_DTT_ADT7460) += adt7460.o -COBJS-$(CONFIG_DTT_DS1621) += ds1621.o -COBJS-$(CONFIG_DTT_DS1722) += ds1722.o -COBJS-$(CONFIG_DTT_DS1775) += ds1775.o -COBJS-$(CONFIG_DTT_LM63) += lm63.o -COBJS-$(CONFIG_DTT_LM73) += lm73.o -COBJS-$(CONFIG_DTT_LM75) += lm75.o -COBJS-$(CONFIG_DTT_LM81) += lm81.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_DTT_ADM1021) += adm1021.o +obj-$(CONFIG_DTT_ADT7460) += adt7460.o +obj-$(CONFIG_DTT_DS1621) += ds1621.o +obj-$(CONFIG_DTT_DS1722) += ds1722.o +obj-$(CONFIG_DTT_DS1775) += ds1775.o +obj-$(CONFIG_DTT_LM63) += lm63.o +obj-$(CONFIG_DTT_LM73) += lm73.o +obj-$(CONFIG_DTT_LM75) += lm75.o +obj-$(CONFIG_DTT_LM81) += lm81.o diff --git a/drivers/i2c/Makefile b/drivers/i2c/Makefile index 37ccbd1..203193f 100644 --- a/drivers/i2c/Makefile +++ b/drivers/i2c/Makefile @@ -5,49 +5,27 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libi2c.o - -COBJS-$(CONFIG_BFIN_TWI_I2C) += bfin-twi_i2c.o -COBJS-$(CONFIG_DRIVER_DAVINCI_I2C) += davinci_i2c.o -COBJS-$(CONFIG_DW_I2C) += designware_i2c.o -COBJS-$(CONFIG_I2C_MVTWSI) += mvtwsi.o -COBJS-$(CONFIG_I2C_MV) += mv_i2c.o -COBJS-$(CONFIG_I2C_MXC) += mxc_i2c.o -COBJS-$(CONFIG_I2C_MXS) += mxs_i2c.o -COBJS-$(CONFIG_DRIVER_OMAP1510_I2C) += omap1510_i2c.o -COBJS-$(CONFIG_DRIVER_OMAP24XX_I2C) += omap24xx_i2c.o -COBJS-$(CONFIG_DRIVER_OMAP34XX_I2C) += omap24xx_i2c.o -COBJS-$(CONFIG_PCA9564_I2C) += pca9564_i2c.o -COBJS-$(CONFIG_DRIVER_S3C24X0_I2C) += s3c24x0_i2c.o -COBJS-$(CONFIG_S3C44B0_I2C) += s3c44b0_i2c.o -COBJS-$(CONFIG_TSI108_I2C) += tsi108_i2c.o -COBJS-$(CONFIG_U8500_I2C) += u8500_i2c.o -COBJS-$(CONFIG_SH_I2C) += sh_i2c.o -COBJS-$(CONFIG_SH_SH7734_I2C) += sh_sh7734_i2c.o -COBJS-$(CONFIG_SYS_I2C) += i2c_core.o -COBJS-$(CONFIG_SYS_I2C_FSL) += fsl_i2c.o -COBJS-$(CONFIG_SYS_I2C_FTI2C010) += fti2c010.o -COBJS-$(CONFIG_SYS_I2C_PPC4XX) += ppc4xx_i2c.o -COBJS-$(CONFIG_SYS_I2C_SOFT) += soft_i2c.o -COBJS-$(CONFIG_SYS_I2C_TEGRA) += tegra_i2c.o -COBJS-$(CONFIG_ZYNQ_I2C) += zynq_i2c.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_BFIN_TWI_I2C) += bfin-twi_i2c.o +obj-$(CONFIG_DRIVER_DAVINCI_I2C) += davinci_i2c.o +obj-$(CONFIG_DW_I2C) += designware_i2c.o +obj-$(CONFIG_I2C_MVTWSI) += mvtwsi.o +obj-$(CONFIG_I2C_MV) += mv_i2c.o +obj-$(CONFIG_I2C_MXC) += mxc_i2c.o +obj-$(CONFIG_I2C_MXS) += mxs_i2c.o +obj-$(CONFIG_DRIVER_OMAP1510_I2C) += omap1510_i2c.o +obj-$(CONFIG_DRIVER_OMAP24XX_I2C) += omap24xx_i2c.o +obj-$(CONFIG_DRIVER_OMAP34XX_I2C) += omap24xx_i2c.o +obj-$(CONFIG_PCA9564_I2C) += pca9564_i2c.o +obj-$(CONFIG_DRIVER_S3C24X0_I2C) += s3c24x0_i2c.o +obj-$(CONFIG_S3C44B0_I2C) += s3c44b0_i2c.o +obj-$(CONFIG_TSI108_I2C) += tsi108_i2c.o +obj-$(CONFIG_U8500_I2C) += u8500_i2c.o +obj-$(CONFIG_SH_I2C) += sh_i2c.o +obj-$(CONFIG_SH_SH7734_I2C) += sh_sh7734_i2c.o +obj-$(CONFIG_SYS_I2C) += i2c_core.o +obj-$(CONFIG_SYS_I2C_FSL) += fsl_i2c.o +obj-$(CONFIG_SYS_I2C_FTI2C010) += fti2c010.o +obj-$(CONFIG_SYS_I2C_PPC4XX) += ppc4xx_i2c.o +obj-$(CONFIG_SYS_I2C_SOFT) += soft_i2c.o +obj-$(CONFIG_SYS_I2C_TEGRA) += tegra_i2c.o +obj-$(CONFIG_ZYNQ_I2C) += zynq_i2c.o diff --git a/drivers/input/Makefile b/drivers/input/Makefile index 7885403..a8e9be2 100644 --- a/drivers/input/Makefile +++ b/drivers/input/Makefile @@ -5,34 +5,12 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libinput.o - -COBJS-$(CONFIG_I8042_KBD) += i8042.o -COBJS-$(CONFIG_TEGRA_KEYBOARD) += tegra-kbc.o -COBJS-$(CONFIG_CROS_EC_KEYB) += cros_ec_keyb.o +obj-$(CONFIG_I8042_KBD) += i8042.o +obj-$(CONFIG_TEGRA_KEYBOARD) += tegra-kbc.o +obj-$(CONFIG_CROS_EC_KEYB) += cros_ec_keyb.o ifdef CONFIG_PS2KBD -COBJS-y += keyboard.o pc_keyb.o -COBJS-$(CONFIG_PS2MULT) += ps2mult.o ps2ser.o +obj-y += keyboard.o pc_keyb.o +obj-$(CONFIG_PS2MULT) += ps2mult.o ps2ser.o endif -COBJS-y += input.o -COBJS-$(CONFIG_OF_CONTROL) += key_matrix.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += input.o +obj-$(CONFIG_OF_CONTROL) += key_matrix.o diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index 08828ee..d8ff9c6 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -5,40 +5,18 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libmisc.o - -COBJS-$(CONFIG_ALI152X) += ali512x.o -COBJS-$(CONFIG_DS4510) += ds4510.o -COBJS-$(CONFIG_CBMEM_CONSOLE) += cbmem_console.o -COBJS-$(CONFIG_CROS_EC) += cros_ec.o -COBJS-$(CONFIG_CROS_EC_LPC) += cros_ec_lpc.o -COBJS-$(CONFIG_CROS_EC_I2C) += cros_ec_i2c.o -COBJS-$(CONFIG_CROS_EC_SPI) += cros_ec_spi.o -COBJS-$(CONFIG_FSL_IIM) += fsl_iim.o -COBJS-$(CONFIG_GPIO_LED) += gpio_led.o -COBJS-$(CONFIG_FSL_MC9SDZ60) += mc9sdz60.o -COBJS-$(CONFIG_MXC_OCOTP) += mxc_ocotp.o -COBJS-$(CONFIG_NS87308) += ns87308.o -COBJS-$(CONFIG_PDSP188x) += pdsp188x.o -COBJS-$(CONFIG_STATUS_LED) += status_led.o -COBJS-$(CONFIG_TWL4030_LED) += twl4030_led.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_ALI152X) += ali512x.o +obj-$(CONFIG_DS4510) += ds4510.o +obj-$(CONFIG_CBMEM_CONSOLE) += cbmem_console.o +obj-$(CONFIG_CROS_EC) += cros_ec.o +obj-$(CONFIG_CROS_EC_LPC) += cros_ec_lpc.o +obj-$(CONFIG_CROS_EC_I2C) += cros_ec_i2c.o +obj-$(CONFIG_CROS_EC_SPI) += cros_ec_spi.o +obj-$(CONFIG_FSL_IIM) += fsl_iim.o +obj-$(CONFIG_GPIO_LED) += gpio_led.o +obj-$(CONFIG_FSL_MC9SDZ60) += mc9sdz60.o +obj-$(CONFIG_MXC_OCOTP) += mxc_ocotp.o +obj-$(CONFIG_NS87308) += ns87308.o +obj-$(CONFIG_PDSP188x) += pdsp188x.o +obj-$(CONFIG_STATUS_LED) += status_led.o +obj-$(CONFIG_TWL4030_LED) += twl4030_led.o diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index bedf833..4daeae4 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -5,51 +5,28 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libmmc.o - - -COBJS-$(CONFIG_BFIN_SDH) += bfin_sdh.o -COBJS-$(CONFIG_DAVINCI_MMC) += davinci_mmc.o -COBJS-$(CONFIG_FSL_ESDHC) += fsl_esdhc.o -COBJS-$(CONFIG_FTSDC010) += ftsdc010_mci.o -COBJS-$(CONFIG_GENERIC_MMC) += mmc.o -COBJS-$(CONFIG_GENERIC_ATMEL_MCI) += gen_atmel_mci.o -COBJS-$(CONFIG_MMC_SPI) += mmc_spi.o -COBJS-$(CONFIG_ARM_PL180_MMCI) += arm_pl180_mmci.o -COBJS-$(CONFIG_MV_SDHCI) += mv_sdhci.o -COBJS-$(CONFIG_MXC_MMC) += mxcmmc.o -COBJS-$(CONFIG_MXS_MMC) += mxsmmc.o -COBJS-$(CONFIG_OMAP_HSMMC) += omap_hsmmc.o -COBJS-$(CONFIG_PXA_MMC_GENERIC) += pxa_mmc_gen.o -COBJS-$(CONFIG_SDHCI) += sdhci.o -COBJS-$(CONFIG_BCM2835_SDHCI) += bcm2835_sdhci.o -COBJS-$(CONFIG_S5P_SDHCI) += s5p_sdhci.o -COBJS-$(CONFIG_SH_MMCIF) += sh_mmcif.o -COBJS-$(CONFIG_SPEAR_SDHCI) += spear_sdhci.o -COBJS-$(CONFIG_TEGRA_MMC) += tegra_mmc.o -COBJS-$(CONFIG_DWMMC) += dw_mmc.o -COBJS-$(CONFIG_EXYNOS_DWMMC) += exynos_dw_mmc.o -COBJS-$(CONFIG_ZYNQ_SDHCI) += zynq_sdhci.o +obj-$(CONFIG_BFIN_SDH) += bfin_sdh.o +obj-$(CONFIG_DAVINCI_MMC) += davinci_mmc.o +obj-$(CONFIG_FSL_ESDHC) += fsl_esdhc.o +obj-$(CONFIG_FTSDC010) += ftsdc010_mci.o +obj-$(CONFIG_GENERIC_MMC) += mmc.o +obj-$(CONFIG_GENERIC_ATMEL_MCI) += gen_atmel_mci.o +obj-$(CONFIG_MMC_SPI) += mmc_spi.o +obj-$(CONFIG_ARM_PL180_MMCI) += arm_pl180_mmci.o +obj-$(CONFIG_MV_SDHCI) += mv_sdhci.o +obj-$(CONFIG_MXC_MMC) += mxcmmc.o +obj-$(CONFIG_MXS_MMC) += mxsmmc.o +obj-$(CONFIG_OMAP_HSMMC) += omap_hsmmc.o +obj-$(CONFIG_PXA_MMC_GENERIC) += pxa_mmc_gen.o +obj-$(CONFIG_SDHCI) += sdhci.o +obj-$(CONFIG_BCM2835_SDHCI) += bcm2835_sdhci.o +obj-$(CONFIG_S5P_SDHCI) += s5p_sdhci.o +obj-$(CONFIG_SH_MMCIF) += sh_mmcif.o +obj-$(CONFIG_SPEAR_SDHCI) += spear_sdhci.o +obj-$(CONFIG_TEGRA_MMC) += tegra_mmc.o +obj-$(CONFIG_DWMMC) += dw_mmc.o +obj-$(CONFIG_EXYNOS_DWMMC) += exynos_dw_mmc.o +obj-$(CONFIG_ZYNQ_SDHCI) += zynq_sdhci.o ifdef CONFIG_SPL_BUILD -COBJS-$(CONFIG_SPL_MMC_BOOT) += fsl_esdhc_spl.o +obj-$(CONFIG_SPL_MMC_BOOT) += fsl_esdhc_spl.o endif - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/drivers/pci/Makefile b/drivers/pci/Makefile index be26b60..99d51a6 100644 --- a/drivers/pci/Makefile +++ b/drivers/pci/Makefile @@ -5,36 +5,14 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libpci.o - -COBJS-$(CONFIG_FSL_PCI_INIT) += fsl_pci_init.o -COBJS-$(CONFIG_PCI) += pci.o pci_auto.o -COBJS-$(CONFIG_PCI_INDIRECT_BRIDGE) += pci_indirect.o -COBJS-$(CONFIG_PCI_GT64120) += pci_gt64120.o -COBJS-$(CONFIG_FTPCI100) += pci_ftpci100.o -COBJS-$(CONFIG_IXP_PCI) += pci_ixp.o -COBJS-$(CONFIG_SH4_PCI) += pci_sh4.o -COBJS-$(CONFIG_SH7751_PCI) +=pci_sh7751.o -COBJS-$(CONFIG_SH7780_PCI) +=pci_sh7780.o -COBJS-$(CONFIG_TSI108_PCI) += tsi108_pci.o -COBJS-$(CONFIG_WINBOND_83C553) += w83c553f.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_FSL_PCI_INIT) += fsl_pci_init.o +obj-$(CONFIG_PCI) += pci.o pci_auto.o +obj-$(CONFIG_PCI_INDIRECT_BRIDGE) += pci_indirect.o +obj-$(CONFIG_PCI_GT64120) += pci_gt64120.o +obj-$(CONFIG_FTPCI100) += pci_ftpci100.o +obj-$(CONFIG_IXP_PCI) += pci_ixp.o +obj-$(CONFIG_SH4_PCI) += pci_sh4.o +obj-$(CONFIG_SH7751_PCI) +=pci_sh7751.o +obj-$(CONFIG_SH7780_PCI) +=pci_sh7780.o +obj-$(CONFIG_TSI108_PCI) += tsi108_pci.o +obj-$(CONFIG_WINBOND_83C553) += w83c553f.o diff --git a/drivers/pcmcia/Makefile b/drivers/pcmcia/Makefile index 80a132e..ae3cafb 100644 --- a/drivers/pcmcia/Makefile +++ b/drivers/pcmcia/Makefile @@ -5,31 +5,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libpcmcia.o - -COBJS-$(CONFIG_I82365) += i82365.o -COBJS-$(CONFIG_8xx) += mpc8xx_pcmcia.o -COBJS-y += rpx_pcmcia.o -COBJS-$(CONFIG_IDE_TI_CARDBUS) += ti_pci1410a.o -COBJS-y += tqm8xx_pcmcia.o -COBJS-$(CONFIG_MARUBUN_PCCARD) += marubun_pcmcia.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_I82365) += i82365.o +obj-$(CONFIG_8xx) += mpc8xx_pcmcia.o +obj-y += rpx_pcmcia.o +obj-$(CONFIG_IDE_TI_CARDBUS) += ti_pci1410a.o +obj-y += tqm8xx_pcmcia.o +obj-$(CONFIG_MARUBUN_PCCARD) += marubun_pcmcia.o diff --git a/drivers/power/Makefile b/drivers/power/Makefile index b2812dc..53ff97d 100644 --- a/drivers/power/Makefile +++ b/drivers/power/Makefile @@ -5,38 +5,15 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libpower.o - -COBJS-$(CONFIG_EXYNOS_TMU) += exynos-tmu.o -COBJS-$(CONFIG_FTPMU010_POWER) += ftpmu010.o -COBJS-$(CONFIG_TPS6586X_POWER) += tps6586x.o -COBJS-$(CONFIG_TWL4030_POWER) += twl4030.o -COBJS-$(CONFIG_TWL6030_POWER) += twl6030.o -COBJS-$(CONFIG_PALMAS_POWER) += palmas.o - -COBJS-$(CONFIG_POWER) += power_core.o -COBJS-$(CONFIG_DIALOG_POWER) += power_dialog.o -COBJS-$(CONFIG_POWER_FSL) += power_fsl.o -COBJS-$(CONFIG_POWER_I2C) += power_i2c.o -COBJS-$(CONFIG_POWER_SPI) += power_spi.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################## +obj-$(CONFIG_EXYNOS_TMU) += exynos-tmu.o +obj-$(CONFIG_FTPMU010_POWER) += ftpmu010.o +obj-$(CONFIG_TPS6586X_POWER) += tps6586x.o +obj-$(CONFIG_TWL4030_POWER) += twl4030.o +obj-$(CONFIG_TWL6030_POWER) += twl6030.o +obj-$(CONFIG_PALMAS_POWER) += palmas.o + +obj-$(CONFIG_POWER) += power_core.o +obj-$(CONFIG_DIALOG_POWER) += power_dialog.o +obj-$(CONFIG_POWER_FSL) += power_fsl.o +obj-$(CONFIG_POWER_I2C) += power_i2c.o +obj-$(CONFIG_POWER_SPI) += power_spi.o diff --git a/drivers/power/battery/Makefile b/drivers/power/battery/Makefile index 637d1ff..a1f6ad9 100644 --- a/drivers/power/battery/Makefile +++ b/drivers/power/battery/Makefile @@ -5,27 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libbattery.o - -COBJS-$(CONFIG_POWER_BATTERY_TRATS) += bat_trats.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################## +obj-$(CONFIG_POWER_BATTERY_TRATS) += bat_trats.o diff --git a/drivers/power/fuel_gauge/Makefile b/drivers/power/fuel_gauge/Makefile index 5166a30..3b349f9 100644 --- a/drivers/power/fuel_gauge/Makefile +++ b/drivers/power/fuel_gauge/Makefile @@ -5,27 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libfuel_gauge.o - -COBJS-$(CONFIG_POWER_FG_MAX17042) += fg_max17042.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################## +obj-$(CONFIG_POWER_FG_MAX17042) += fg_max17042.o diff --git a/drivers/power/pmic/Makefile b/drivers/power/pmic/Makefile index f054470..476cae5 100644 --- a/drivers/power/pmic/Makefile +++ b/drivers/power/pmic/Makefile @@ -5,30 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libpmic.o - -COBJS-$(CONFIG_POWER_MAX8998) += pmic_max8998.o -COBJS-$(CONFIG_POWER_MAX8997) += pmic_max8997.o -COBJS-$(CONFIG_POWER_MUIC_MAX8997) += muic_max8997.o -COBJS-$(CONFIG_POWER_MAX77686) += pmic_max77686.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################## +obj-$(CONFIG_POWER_MAX8998) += pmic_max8998.o +obj-$(CONFIG_POWER_MAX8997) += pmic_max8997.o +obj-$(CONFIG_POWER_MUIC_MAX8997) += muic_max8997.o +obj-$(CONFIG_POWER_MAX77686) += pmic_max77686.o diff --git a/drivers/qe/Makefile b/drivers/qe/Makefile index 3aaf757..b8c15f8 100644 --- a/drivers/qe/Makefile +++ b/drivers/qe/Makefile @@ -4,26 +4,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libqe.o - -COBJS-$(and $(CONFIG_QE),$(CONFIG_OF_LIBFDT)) += fdt.o -COBJS-$(CONFIG_QE) += qe.o uccf.o uec.o uec_phy.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(and $(CONFIG_QE),$(CONFIG_OF_LIBFDT)) += fdt.o +obj-$(CONFIG_QE) += qe.o uccf.o uec.o uec_phy.o diff --git a/drivers/rtc/Makefile b/drivers/rtc/Makefile index b477c23..fdccc48 100644 --- a/drivers/rtc/Makefile +++ b/drivers/rtc/Makefile @@ -5,71 +5,49 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)librtc.o - -COBJS-$(CONFIG_RTC_AT91SAM9_RTT) += at91sam9_rtt.o -COBJS-$(CONFIG_RTC_BFIN) += bfin_rtc.o -COBJS-y += date.o -COBJS-$(CONFIG_RTC_DAVINCI) += davinci.o -COBJS-$(CONFIG_RTC_DS12887) += ds12887.o -COBJS-$(CONFIG_RTC_DS1302) += ds1302.o -COBJS-$(CONFIG_RTC_DS1306) += ds1306.o -COBJS-$(CONFIG_RTC_DS1307) += ds1307.o -COBJS-$(CONFIG_RTC_DS1338) += ds1307.o -COBJS-$(CONFIG_RTC_DS1337) += ds1337.o -COBJS-$(CONFIG_RTC_DS1374) += ds1374.o -COBJS-$(CONFIG_RTC_DS1388) += ds1337.o -COBJS-$(CONFIG_RTC_DS1556) += ds1556.o -COBJS-$(CONFIG_RTC_DS164x) += ds164x.o -COBJS-$(CONFIG_RTC_DS174x) += ds174x.o -COBJS-$(CONFIG_RTC_DS3231) += ds3231.o -COBJS-$(CONFIG_RTC_FTRTC010) += ftrtc010.o -COBJS-$(CONFIG_RTC_IMXDI) += imxdi.o -COBJS-$(CONFIG_RTC_ISL1208) += isl1208.o -COBJS-$(CONFIG_RTC_M41T11) += m41t11.o -COBJS-$(CONFIG_RTC_M41T60) += m41t60.o -COBJS-$(CONFIG_RTC_M41T62) += m41t62.o -COBJS-$(CONFIG_RTC_M41T94) += m41t94.o -COBJS-$(CONFIG_RTC_M48T35A) += m48t35ax.o -COBJS-$(CONFIG_RTC_MAX6900) += max6900.o -COBJS-$(CONFIG_RTC_MC13XXX) += mc13xxx-rtc.o -COBJS-$(CONFIG_RTC_MC146818) += mc146818.o -COBJS-$(CONFIG_MCFRTC) += mcfrtc.o -COBJS-$(CONFIG_RTC_MK48T59) += mk48t59.o -COBJS-$(CONFIG_RTC_MPC5200) += mpc5xxx.o -COBJS-$(CONFIG_RTC_MPC8xx) += mpc8xx.o -COBJS-$(CONFIG_RTC_MV) += mvrtc.o -COBJS-$(CONFIG_RTC_MX27) += mx27rtc.o -COBJS-$(CONFIG_RTC_MXS) += mxsrtc.o -COBJS-$(CONFIG_RTC_PCF8563) += pcf8563.o -COBJS-$(CONFIG_RTC_PL031) += pl031.o -COBJS-$(CONFIG_RTC_PT7C4338) += pt7c4338.o -COBJS-$(CONFIG_RTC_RS5C372A) += rs5c372.o -COBJS-$(CONFIG_RTC_RTC4543) += rtc4543.o -COBJS-$(CONFIG_RTC_RV3029) += rv3029.o -COBJS-$(CONFIG_RTC_RX8025) += rx8025.o -COBJS-$(CONFIG_RTC_S3C24X0) += s3c24x0_rtc.o -COBJS-$(CONFIG_RTC_S3C44B0) += s3c44b0_rtc.o -COBJS-$(CONFIG_RTC_X1205) += x1205.o - -COBJS := $(sort $(COBJS-y)) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_RTC_AT91SAM9_RTT) += at91sam9_rtt.o +obj-$(CONFIG_RTC_BFIN) += bfin_rtc.o +obj-y += date.o +obj-$(CONFIG_RTC_DAVINCI) += davinci.o +obj-$(CONFIG_RTC_DS12887) += ds12887.o +obj-$(CONFIG_RTC_DS1302) += ds1302.o +obj-$(CONFIG_RTC_DS1306) += ds1306.o +obj-$(CONFIG_RTC_DS1307) += ds1307.o +obj-$(CONFIG_RTC_DS1338) += ds1307.o +obj-$(CONFIG_RTC_DS1337) += ds1337.o +obj-$(CONFIG_RTC_DS1374) += ds1374.o +obj-$(CONFIG_RTC_DS1388) += ds1337.o +obj-$(CONFIG_RTC_DS1556) += ds1556.o +obj-$(CONFIG_RTC_DS164x) += ds164x.o +obj-$(CONFIG_RTC_DS174x) += ds174x.o +obj-$(CONFIG_RTC_DS3231) += ds3231.o +obj-$(CONFIG_RTC_FTRTC010) += ftrtc010.o +obj-$(CONFIG_RTC_IMXDI) += imxdi.o +obj-$(CONFIG_RTC_ISL1208) += isl1208.o +obj-$(CONFIG_RTC_M41T11) += m41t11.o +obj-$(CONFIG_RTC_M41T60) += m41t60.o +obj-$(CONFIG_RTC_M41T62) += m41t62.o +obj-$(CONFIG_RTC_M41T94) += m41t94.o +obj-$(CONFIG_RTC_M48T35A) += m48t35ax.o +obj-$(CONFIG_RTC_MAX6900) += max6900.o +obj-$(CONFIG_RTC_MC13XXX) += mc13xxx-rtc.o +obj-$(CONFIG_RTC_MC146818) += mc146818.o +obj-$(CONFIG_MCFRTC) += mcfrtc.o +obj-$(CONFIG_RTC_MK48T59) += mk48t59.o +obj-$(CONFIG_RTC_MPC5200) += mpc5xxx.o +obj-$(CONFIG_RTC_MPC8xx) += mpc8xx.o +obj-$(CONFIG_RTC_MV) += mvrtc.o +obj-$(CONFIG_RTC_MX27) += mx27rtc.o +obj-$(CONFIG_RTC_MXS) += mxsrtc.o +obj-$(CONFIG_RTC_PCF8563) += pcf8563.o +obj-$(CONFIG_RTC_PL031) += pl031.o +obj-$(CONFIG_RTC_PT7C4338) += pt7c4338.o +obj-$(CONFIG_RTC_RS5C372A) += rs5c372.o +obj-$(CONFIG_RTC_RTC4543) += rtc4543.o +obj-$(CONFIG_RTC_RV3029) += rv3029.o +obj-$(CONFIG_RTC_RX8025) += rx8025.o +obj-$(CONFIG_RTC_S3C24X0) += s3c24x0_rtc.o +obj-$(CONFIG_RTC_S3C44B0) += s3c44b0_rtc.o +obj-$(CONFIG_RTC_X1205) += x1205.o diff --git a/drivers/serial/Makefile b/drivers/serial/Makefile index 697f2bb..80623b8 100644 --- a/drivers/serial/Makefile +++ b/drivers/serial/Makefile @@ -5,58 +5,36 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libserial.o - -COBJS-y += serial.o - -COBJS-$(CONFIG_ALTERA_UART) += altera_uart.o -COBJS-$(CONFIG_ALTERA_JTAG_UART) += altera_jtag_uart.o -COBJS-$(CONFIG_ARM_DCC) += arm_dcc.o -COBJS-$(CONFIG_ATMEL_USART) += atmel_usart.o -COBJS-$(CONFIG_LPC32XX_HSUART) += lpc32xx_hsuart.o -COBJS-$(CONFIG_MCFUART) += mcfuart.o -COBJS-$(CONFIG_OPENCORES_YANU) += opencores_yanu.o -COBJS-$(CONFIG_SYS_NS16550) += ns16550.o -COBJS-$(CONFIG_S5P) += serial_s5p.o -COBJS-$(CONFIG_SYS_NS16550_SERIAL) += serial_ns16550.o -COBJS-$(CONFIG_IMX_SERIAL) += serial_imx.o -COBJS-$(CONFIG_IXP_SERIAL) += serial_ixp.o -COBJS-$(CONFIG_KS8695_SERIAL) += serial_ks8695.o -COBJS-$(CONFIG_MAX3100_SERIAL) += serial_max3100.o -COBJS-$(CONFIG_MXC_UART) += serial_mxc.o -COBJS-$(CONFIG_PL010_SERIAL) += serial_pl01x.o -COBJS-$(CONFIG_PL011_SERIAL) += serial_pl01x.o -COBJS-$(CONFIG_PXA_SERIAL) += serial_pxa.o -COBJS-$(CONFIG_SA1100_SERIAL) += serial_sa1100.o -COBJS-$(CONFIG_S3C24X0_SERIAL) += serial_s3c24x0.o -COBJS-$(CONFIG_S3C44B0_SERIAL) += serial_s3c44b0.o -COBJS-$(CONFIG_XILINX_UARTLITE) += serial_xuartlite.o -COBJS-$(CONFIG_SANDBOX_SERIAL) += sandbox.o -COBJS-$(CONFIG_SCIF_CONSOLE) += serial_sh.o -COBJS-$(CONFIG_ZYNQ_SERIAL) += serial_zynq.o -COBJS-$(CONFIG_BFIN_SERIAL) += serial_bfin.o -COBJS-$(CONFIG_FSL_LPUART) += serial_lpuart.o +obj-y += serial.o + +obj-$(CONFIG_ALTERA_UART) += altera_uart.o +obj-$(CONFIG_ALTERA_JTAG_UART) += altera_jtag_uart.o +obj-$(CONFIG_ARM_DCC) += arm_dcc.o +obj-$(CONFIG_ATMEL_USART) += atmel_usart.o +obj-$(CONFIG_LPC32XX_HSUART) += lpc32xx_hsuart.o +obj-$(CONFIG_MCFUART) += mcfuart.o +obj-$(CONFIG_OPENCORES_YANU) += opencores_yanu.o +obj-$(CONFIG_SYS_NS16550) += ns16550.o +obj-$(CONFIG_S5P) += serial_s5p.o +obj-$(CONFIG_SYS_NS16550_SERIAL) += serial_ns16550.o +obj-$(CONFIG_IMX_SERIAL) += serial_imx.o +obj-$(CONFIG_IXP_SERIAL) += serial_ixp.o +obj-$(CONFIG_KS8695_SERIAL) += serial_ks8695.o +obj-$(CONFIG_MAX3100_SERIAL) += serial_max3100.o +obj-$(CONFIG_MXC_UART) += serial_mxc.o +obj-$(CONFIG_PL010_SERIAL) += serial_pl01x.o +obj-$(CONFIG_PL011_SERIAL) += serial_pl01x.o +obj-$(CONFIG_PXA_SERIAL) += serial_pxa.o +obj-$(CONFIG_SA1100_SERIAL) += serial_sa1100.o +obj-$(CONFIG_S3C24X0_SERIAL) += serial_s3c24x0.o +obj-$(CONFIG_S3C44B0_SERIAL) += serial_s3c44b0.o +obj-$(CONFIG_XILINX_UARTLITE) += serial_xuartlite.o +obj-$(CONFIG_SANDBOX_SERIAL) += sandbox.o +obj-$(CONFIG_SCIF_CONSOLE) += serial_sh.o +obj-$(CONFIG_ZYNQ_SERIAL) += serial_zynq.o +obj-$(CONFIG_BFIN_SERIAL) += serial_bfin.o +obj-$(CONFIG_FSL_LPUART) += serial_lpuart.o
ifndef CONFIG_SPL_BUILD -COBJS-$(CONFIG_USB_TTY) += usbtty.o +obj-$(CONFIG_USB_TTY) += usbtty.o endif - -COBJS := $(sort $(COBJS-y)) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/drivers/sound/Makefile b/drivers/sound/Makefile index c50dd15..6d25292 100644 --- a/drivers/sound/Makefile +++ b/drivers/sound/Makefile @@ -5,29 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libsound.o - -COBJS-$(CONFIG_SOUND) += sound.o -COBJS-$(CONFIG_I2S) += samsung-i2s.o -COBJS-$(CONFIG_SOUND_WM8994) += wm8994.o -COBJS-$(CONFIG_SOUND_MAX98095) += max98095.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -# +obj-$(CONFIG_SOUND) += sound.o +obj-$(CONFIG_I2S) += samsung-i2s.o +obj-$(CONFIG_SOUND_WM8994) += wm8994.o +obj-$(CONFIG_SOUND_MAX98095) += max98095.o diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 91d24ce..83a36bc 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -5,56 +5,34 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libspi.o - # There are many options which enable SPI, so make this library available -COBJS-y += spi.o - -COBJS-$(CONFIG_ALTERA_SPI) += altera_spi.o -COBJS-$(CONFIG_ANDES_SPI) += andes_spi.o -COBJS-$(CONFIG_ARMADA100_SPI) += armada100_spi.o -COBJS-$(CONFIG_ATMEL_DATAFLASH_SPI) += atmel_dataflash_spi.o -COBJS-$(CONFIG_ATMEL_SPI) += atmel_spi.o -COBJS-$(CONFIG_BFIN_SPI) += bfin_spi.o -COBJS-$(CONFIG_BFIN_SPI6XX) += bfin_spi6xx.o -COBJS-$(CONFIG_CF_SPI) += cf_spi.o -COBJS-$(CONFIG_CF_QSPI) += cf_qspi.o -COBJS-$(CONFIG_DAVINCI_SPI) += davinci_spi.o -COBJS-$(CONFIG_EXYNOS_SPI) += exynos_spi.o -COBJS-$(CONFIG_ICH_SPI) += ich.o -COBJS-$(CONFIG_KIRKWOOD_SPI) += kirkwood_spi.o -COBJS-$(CONFIG_MPC52XX_SPI) += mpc52xx_spi.o -COBJS-$(CONFIG_MPC8XXX_SPI) += mpc8xxx_spi.o -COBJS-$(CONFIG_MXC_SPI) += mxc_spi.o -COBJS-$(CONFIG_MXS_SPI) += mxs_spi.o -COBJS-$(CONFIG_OC_TINY_SPI) += oc_tiny_spi.o -COBJS-$(CONFIG_OMAP3_SPI) += omap3_spi.o -COBJS-$(CONFIG_SOFT_SPI) += soft_spi.o -COBJS-$(CONFIG_SH_SPI) += sh_spi.o -COBJS-$(CONFIG_FSL_ESPI) += fsl_espi.o -COBJS-$(CONFIG_FDT_SPI) += fdt_spi.o -COBJS-$(CONFIG_TEGRA20_SFLASH) += tegra20_sflash.o -COBJS-$(CONFIG_TEGRA20_SLINK) += tegra20_slink.o -COBJS-$(CONFIG_TEGRA114_SPI) += tegra114_spi.o -COBJS-$(CONFIG_XILINX_SPI) += xilinx_spi.o -COBJS-$(CONFIG_ZYNQ_SPI) += zynq_spi.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += spi.o + +obj-$(CONFIG_ALTERA_SPI) += altera_spi.o +obj-$(CONFIG_ANDES_SPI) += andes_spi.o +obj-$(CONFIG_ARMADA100_SPI) += armada100_spi.o +obj-$(CONFIG_ATMEL_DATAFLASH_SPI) += atmel_dataflash_spi.o +obj-$(CONFIG_ATMEL_SPI) += atmel_spi.o +obj-$(CONFIG_BFIN_SPI) += bfin_spi.o +obj-$(CONFIG_BFIN_SPI6XX) += bfin_spi6xx.o +obj-$(CONFIG_CF_SPI) += cf_spi.o +obj-$(CONFIG_CF_QSPI) += cf_qspi.o +obj-$(CONFIG_DAVINCI_SPI) += davinci_spi.o +obj-$(CONFIG_EXYNOS_SPI) += exynos_spi.o +obj-$(CONFIG_ICH_SPI) += ich.o +obj-$(CONFIG_KIRKWOOD_SPI) += kirkwood_spi.o +obj-$(CONFIG_MPC52XX_SPI) += mpc52xx_spi.o +obj-$(CONFIG_MPC8XXX_SPI) += mpc8xxx_spi.o +obj-$(CONFIG_MXC_SPI) += mxc_spi.o +obj-$(CONFIG_MXS_SPI) += mxs_spi.o +obj-$(CONFIG_OC_TINY_SPI) += oc_tiny_spi.o +obj-$(CONFIG_OMAP3_SPI) += omap3_spi.o +obj-$(CONFIG_SOFT_SPI) += soft_spi.o +obj-$(CONFIG_SH_SPI) += sh_spi.o +obj-$(CONFIG_FSL_ESPI) += fsl_espi.o +obj-$(CONFIG_FDT_SPI) += fdt_spi.o +obj-$(CONFIG_TEGRA20_SFLASH) += tegra20_sflash.o +obj-$(CONFIG_TEGRA20_SLINK) += tegra20_slink.o +obj-$(CONFIG_TEGRA114_SPI) += tegra114_spi.o +obj-$(CONFIG_XILINX_SPI) += xilinx_spi.o +obj-$(CONFIG_ZYNQ_SPI) += zynq_spi.o diff --git a/drivers/tpm/Makefile b/drivers/tpm/Makefile index 4457a78..4b8cbec 100644 --- a/drivers/tpm/Makefile +++ b/drivers/tpm/Makefile @@ -3,31 +3,10 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libtpm.o - $(shell mkdir -p $(obj)slb9635_i2c)
# TODO: Merge tpm_tis_lpc.c with tpm.c -COBJS-$(CONFIG_TPM_ATMEL_TWI) += tpm_atmel_twi.o -COBJS-$(CONFIG_TPM_TIS_I2C) += tpm.o -COBJS-$(CONFIG_TPM_TIS_I2C) += tpm_tis_i2c.o -COBJS-$(CONFIG_TPM_TIS_LPC) += tpm_tis_lpc.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_TPM_ATMEL_TWI) += tpm_atmel_twi.o +obj-$(CONFIG_TPM_TIS_I2C) += tpm.o +obj-$(CONFIG_TPM_TIS_I2C) += tpm_tis_i2c.o +obj-$(CONFIG_TPM_TIS_LPC) += tpm_tis_lpc.o diff --git a/drivers/twserial/Makefile b/drivers/twserial/Makefile index ac22735..7cc7c4d 100644 --- a/drivers/twserial/Makefile +++ b/drivers/twserial/Makefile @@ -5,26 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libtws.o - -COBJS-$(CONFIG_SOFT_TWS) += soft_tws.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_SOFT_TWS) += soft_tws.o diff --git a/drivers/video/Makefile b/drivers/video/Makefile index 6dee1e9..20379c6 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -5,57 +5,35 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libvideo.o - -COBJS-$(CONFIG_ATI_RADEON_FB) += ati_radeon_fb.o videomodes.o -COBJS-$(CONFIG_ATMEL_HLCD) += atmel_hlcdfb.o -COBJS-$(CONFIG_ATMEL_LCD) += atmel_lcdfb.o -COBJS-$(CONFIG_CFB_CONSOLE) += cfb_console.o -COBJS-$(CONFIG_EXYNOS_DP) += exynos_dp.o exynos_dp_lowlevel.o -COBJS-$(CONFIG_EXYNOS_FB) += exynos_fb.o exynos_fimd.o -COBJS-$(CONFIG_EXYNOS_MIPI_DSIM) += exynos_mipi_dsi.o exynos_mipi_dsi_common.o \ +obj-$(CONFIG_ATI_RADEON_FB) += ati_radeon_fb.o videomodes.o +obj-$(CONFIG_ATMEL_HLCD) += atmel_hlcdfb.o +obj-$(CONFIG_ATMEL_LCD) += atmel_lcdfb.o +obj-$(CONFIG_CFB_CONSOLE) += cfb_console.o +obj-$(CONFIG_EXYNOS_DP) += exynos_dp.o exynos_dp_lowlevel.o +obj-$(CONFIG_EXYNOS_FB) += exynos_fb.o exynos_fimd.o +obj-$(CONFIG_EXYNOS_MIPI_DSIM) += exynos_mipi_dsi.o exynos_mipi_dsi_common.o \ exynos_mipi_dsi_lowlevel.o -COBJS-$(CONFIG_EXYNOS_PWM_BL) += exynos_pwm_bl.o -COBJS-$(CONFIG_FSL_DIU_FB) += fsl_diu_fb.o videomodes.o -COBJS-$(CONFIG_L5F31188) += l5f31188.o -COBJS-$(CONFIG_MPC8XX_LCD) += mpc8xx_lcd.o -COBJS-$(CONFIG_PXA_LCD) += pxa_lcd.o -COBJS-$(CONFIG_S6E8AX0) += s6e8ax0.o -COBJS-$(CONFIG_S6E63D6) += s6e63d6.o -COBJS-$(CONFIG_LD9040) += ld9040.o -COBJS-$(CONFIG_SED156X) += sed156x.o -COBJS-$(CONFIG_VIDEO_BCM2835) += bcm2835.o -COBJS-$(CONFIG_VIDEO_COREBOOT) += coreboot_fb.o -COBJS-$(CONFIG_VIDEO_CT69000) += ct69000.o videomodes.o -COBJS-$(CONFIG_VIDEO_DA8XX) += da8xx-fb.o videomodes.o -COBJS-$(CONFIG_VIDEO_MB862xx) += mb862xx.o videomodes.o -COBJS-$(CONFIG_VIDEO_MB86R0xGDC) += mb86r0xgdc.o videomodes.o -COBJS-$(CONFIG_VIDEO_MX3) += mx3fb.o videomodes.o -COBJS-$(CONFIG_VIDEO_IPUV3) += mxc_ipuv3_fb.o ipu_common.o ipu_disp.o -COBJS-$(CONFIG_VIDEO_MXS) += mxsfb.o videomodes.o -COBJS-$(CONFIG_VIDEO_OMAP3) += omap3_dss.o -COBJS-$(CONFIG_VIDEO_SED13806) += sed13806.o -COBJS-$(CONFIG_VIDEO_SM501) += sm501.o -COBJS-$(CONFIG_VIDEO_SMI_LYNXEM) += smiLynxEM.o videomodes.o -COBJS-$(CONFIG_VIDEO_TEGRA) += tegra.o -COBJS-$(CONFIG_VIDEO_VCXK) += bus_vcxk.o - -COBJS := $(sort $(COBJS-y)) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_EXYNOS_PWM_BL) += exynos_pwm_bl.o +obj-$(CONFIG_FSL_DIU_FB) += fsl_diu_fb.o videomodes.o +obj-$(CONFIG_L5F31188) += l5f31188.o +obj-$(CONFIG_MPC8XX_LCD) += mpc8xx_lcd.o +obj-$(CONFIG_PXA_LCD) += pxa_lcd.o +obj-$(CONFIG_S6E8AX0) += s6e8ax0.o +obj-$(CONFIG_S6E63D6) += s6e63d6.o +obj-$(CONFIG_LD9040) += ld9040.o +obj-$(CONFIG_SED156X) += sed156x.o +obj-$(CONFIG_VIDEO_BCM2835) += bcm2835.o +obj-$(CONFIG_VIDEO_COREBOOT) += coreboot_fb.o +obj-$(CONFIG_VIDEO_CT69000) += ct69000.o videomodes.o +obj-$(CONFIG_VIDEO_DA8XX) += da8xx-fb.o videomodes.o +obj-$(CONFIG_VIDEO_MB862xx) += mb862xx.o videomodes.o +obj-$(CONFIG_VIDEO_MB86R0xGDC) += mb86r0xgdc.o videomodes.o +obj-$(CONFIG_VIDEO_MX3) += mx3fb.o videomodes.o +obj-$(CONFIG_VIDEO_IPUV3) += mxc_ipuv3_fb.o ipu_common.o ipu_disp.o +obj-$(CONFIG_VIDEO_MXS) += mxsfb.o videomodes.o +obj-$(CONFIG_VIDEO_OMAP3) += omap3_dss.o +obj-$(CONFIG_VIDEO_SED13806) += sed13806.o +obj-$(CONFIG_VIDEO_SM501) += sm501.o +obj-$(CONFIG_VIDEO_SMI_LYNXEM) += smiLynxEM.o videomodes.o +obj-$(CONFIG_VIDEO_TEGRA) += tegra.o +obj-$(CONFIG_VIDEO_VCXK) += bus_vcxk.o diff --git a/drivers/watchdog/Makefile b/drivers/watchdog/Makefile index 7e255ce..7aa1163 100644 --- a/drivers/watchdog/Makefile +++ b/drivers/watchdog/Makefile @@ -5,34 +5,12 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB := $(obj)libwatchdog.o - -COBJS-$(CONFIG_AT91SAM9_WATCHDOG) += at91sam9_wdt.o -COBJS-$(CONFIG_FTWDT010_WATCHDOG) += ftwdt010_wdt.o +obj-$(CONFIG_AT91SAM9_WATCHDOG) += at91sam9_wdt.o +obj-$(CONFIG_FTWDT010_WATCHDOG) += ftwdt010_wdt.o ifneq (,$(filter $(SOC), mx31 mx35 mx5 mx6 vf610)) -COBJS-y += imx_watchdog.o +obj-y += imx_watchdog.o endif -COBJS-$(CONFIG_TNETV107X_WATCHDOG) += tnetv107x_wdt.o -COBJS-$(CONFIG_S5P) += s5p_wdt.o -COBJS-$(CONFIG_XILINX_TB_WATCHDOG) += xilinx_tb_wdt.o -COBJS-$(CONFIG_BFIN_WATCHDOG) += bfin_wdt.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_TNETV107X_WATCHDOG) += tnetv107x_wdt.o +obj-$(CONFIG_S5P) += s5p_wdt.o +obj-$(CONFIG_XILINX_TB_WATCHDOG) += xilinx_tb_wdt.o +obj-$(CONFIG_BFIN_WATCHDOG) += bfin_wdt.o
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com --- fs/Makefile | 24 +----------------------- fs/cbfs/Makefile | 24 +----------------------- fs/cramfs/Makefile | 29 ++--------------------------- fs/ext4/Makefile | 27 ++------------------------- fs/fat/Makefile | 31 +++---------------------------- fs/fdos/Makefile | 27 +-------------------------- fs/jffs2/Makefile | 38 ++++++-------------------------------- fs/reiserfs/Makefile | 26 +------------------------- fs/sandbox/Makefile | 23 +---------------------- fs/ubifs/Makefile | 29 ++++------------------------- fs/yaffs2/Makefile | 33 +-------------------------------- fs/zfs/Makefile | 25 +------------------------ 12 files changed, 24 insertions(+), 312 deletions(-)
diff --git a/fs/Makefile b/fs/Makefile index 7e753e9..ea2eb09 100644 --- a/fs/Makefile +++ b/fs/Makefile @@ -6,26 +6,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libfs.o - -COBJS-y += fs.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += fs.o diff --git a/fs/cbfs/Makefile b/fs/cbfs/Makefile index 190fd8e..6f33d28 100644 --- a/fs/cbfs/Makefile +++ b/fs/cbfs/Makefile @@ -3,26 +3,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libcbfs.o - -COBJS-$(CONFIG_CMD_CBFS) := cbfs.o - -SRCS := $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_CMD_CBFS) := cbfs.o diff --git a/fs/cramfs/Makefile b/fs/cramfs/Makefile index 9b1a3d7..e2b2c73 100644 --- a/fs/cramfs/Makefile +++ b/fs/cramfs/Makefile @@ -5,30 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libcramfs.o - -AOBJS = -COBJS-$(CONFIG_CMD_CRAMFS) := cramfs.o -COBJS-$(CONFIG_CMD_CRAMFS) += uncompress.o - -SRCS := $(AOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS-y)) - -#CPPFLAGS += - -all: $(LIB) $(AOBJS) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_CMD_CRAMFS) := cramfs.o +obj-$(CONFIG_CMD_CRAMFS) += uncompress.o diff --git a/fs/ext4/Makefile b/fs/ext4/Makefile index f45bb32..0f5d399 100644 --- a/fs/ext4/Makefile +++ b/fs/ext4/Makefile @@ -9,28 +9,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libext4fs.o - -AOBJS = -COBJS-$(CONFIG_FS_EXT4) := ext4fs.o ext4_common.o dev.o -COBJS-$(CONFIG_EXT4_WRITE) += ext4_write.o ext4_journal.o crc16.o - -SRCS := $(AOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS-y)) - - -all: $(LIB) $(AOBJS) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_FS_EXT4) := ext4fs.o ext4_common.o dev.o +obj-$(CONFIG_EXT4_WRITE) += ext4_write.o ext4_journal.o crc16.o diff --git a/fs/fat/Makefile b/fs/fat/Makefile index c00681f..b60e848 100644 --- a/fs/fat/Makefile +++ b/fs/fat/Makefile @@ -3,34 +3,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libfat.o - -AOBJS = -COBJS-$(CONFIG_FS_FAT) := fat.o -COBJS-$(CONFIG_FAT_WRITE):= fat_write.o +obj-$(CONFIG_FS_FAT) := fat.o +obj-$(CONFIG_FAT_WRITE):= fat_write.o
ifndef CONFIG_SPL_BUILD -COBJS-$(CONFIG_FS_FAT) += file.o +obj-$(CONFIG_FS_FAT) += file.o endif - -SRCS := $(AOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS-y)) - -all: $(LIB) $(AOBJS) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -# SEE README.arm-unaligned-accesses -$(obj)file.o: CFLAGS += $(PLATFORM_NO_UNALIGNED) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/fs/fdos/Makefile b/fs/fdos/Makefile index 867c5ca..95480af 100644 --- a/fs/fdos/Makefile +++ b/fs/fdos/Makefile @@ -10,29 +10,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libfdos.o - -AOBJS = -COBJS-$(CONFIG_CMD_FDOS) := fat.o vfat.o dev.o fdos.o fs.o subdir.o - -SRCS := $(AOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS-y)) - -#CPPFLAGS += - -all: $(LIB) $(AOBJS) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_CMD_FDOS) := fat.o vfat.o dev.o fdos.o fs.o subdir.o diff --git a/fs/jffs2/Makefile b/fs/jffs2/Makefile index a11ca32..02e481f 100644 --- a/fs/jffs2/Makefile +++ b/fs/jffs2/Makefile @@ -5,37 +5,11 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libjffs2.o - -AOBJS = ifdef CONFIG_CMD_JFFS2 -COBJS-$(CONFIG_JFFS2_LZO) += compr_lzo.o -COBJS-y += compr_rtime.o -COBJS-y += compr_rubin.o -COBJS-y += compr_zlib.o -COBJS-y += jffs2_1pass.o -COBJS-y += mini_inflate.o +obj-$(CONFIG_JFFS2_LZO) += compr_lzo.o +obj-y += compr_rtime.o +obj-y += compr_rubin.o +obj-y += compr_zlib.o +obj-y += jffs2_1pass.o +obj-y += mini_inflate.o endif - -COBJS := $(COBJS-y) -SRCS := $(AOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS)) - -#CPPFLAGS += - -all: $(LIB) $(AOBJS) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/fs/reiserfs/Makefile b/fs/reiserfs/Makefile index d81d71d..55f70b1 100644 --- a/fs/reiserfs/Makefile +++ b/fs/reiserfs/Makefile @@ -9,28 +9,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libreiserfs.o - -AOBJS = -COBJS-$(CONFIG_CMD_REISER) := reiserfs.o dev.o mode_string.o - -SRCS := $(AOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS-y)) - -#CPPFLAGS += - -all: $(LIB) $(AOBJS) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_CMD_REISER) := reiserfs.o dev.o mode_string.o diff --git a/fs/sandbox/Makefile b/fs/sandbox/Makefile index df2fc32..faa7c16 100644 --- a/fs/sandbox/Makefile +++ b/fs/sandbox/Makefile @@ -10,25 +10,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libsandboxfs.o - -COBJS-$(CONFIG_SANDBOX) := sandboxfs.o - -SRCS := $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS-y)) - -all: $(LIB) $(AOBJS) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_SANDBOX) := sandboxfs.o diff --git a/fs/ubifs/Makefile b/fs/ubifs/Makefile index 47949c1..47d5a8f 100644 --- a/fs/ubifs/Makefile +++ b/fs/ubifs/Makefile @@ -9,31 +9,10 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libubifs.o - -COBJS-$(CONFIG_CMD_UBIFS) := ubifs.o io.o super.o sb.o master.o lpt.o -COBJS-$(CONFIG_CMD_UBIFS) += lpt_commit.o scan.o lprops.o -COBJS-$(CONFIG_CMD_UBIFS) += tnc.o tnc_misc.o debug.o crc16.o budget.o -COBJS-$(CONFIG_CMD_UBIFS) += log.o orphan.o recovery.o replay.o - -SRCS := $(AOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS-y)) - -all: $(LIB) $(AOBJS) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) +obj-$(CONFIG_CMD_UBIFS) := ubifs.o io.o super.o sb.o master.o lpt.o +obj-$(CONFIG_CMD_UBIFS) += lpt_commit.o scan.o lprops.o +obj-$(CONFIG_CMD_UBIFS) += tnc.o tnc_misc.o debug.o crc16.o budget.o +obj-$(CONFIG_CMD_UBIFS) += log.o orphan.o recovery.o replay.o
# SEE README.arm-unaligned-accesses $(obj)super.o: CFLAGS += $(PLATFORM_NO_UNALIGNED) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/fs/yaffs2/Makefile b/fs/yaffs2/Makefile index 9b29d22..077af78 100644 --- a/fs/yaffs2/Makefile +++ b/fs/yaffs2/Makefile @@ -16,11 +16,7 @@ # # $Id: Makefile,v 1.15 2007/07/18 19:40:38 charles Exp $
-include $(TOPDIR)/config.mk - -LIB = $(obj)libyaffs2.o - -COBJS-$(CONFIG_YAFFS2) := \ +obj-$(CONFIG_YAFFS2) := \ yaffs_allocator.o yaffs_attribs.o yaffs_bitmap.o yaffs_uboot_glue.o\ yaffs_checkptrw.o yaffs_ecc.o yaffs_error.o \ yaffsfs.o yaffs_guts.o yaffs_nameval.o yaffs_nand.o\ @@ -28,36 +24,9 @@ COBJS-$(CONFIG_YAFFS2) := \ yaffs_summary.o yaffs_tagscompat.o yaffs_verify.o yaffs_yaffs1.o \ yaffs_yaffs2.o yaffs_mtdif.o yaffs_mtdif2.o
-SRCS := $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) - YCFLAGS = -DCONFIG_YAFFS_DIRECT -DCONFIG_YAFFS_SHORT_NAMES_IN_RAM YCFLAGS += -DCONFIG_YAFFS_YAFFS2 -DNO_Y_INLINE YCFLAGS += -DCONFIG_YAFFS_PROVIDE_DEFS -DCONFIG_YAFFSFS_PROVIDE_VALUES
CFLAGS += $(YCFLAGS) CPPFLAGS += $(YCFLAGS) - -all: $(LIB) - -$(obj)libyaffs2.a: $(obj).depend $(OBJS) - $(AR) $(ARFLAGS) $@ $(OBJS) - -$(obj)libyaffs2.o: $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -.PHONY: clean distclean -clean: - rm -f $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak .depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/fs/zfs/Makefile b/fs/zfs/Makefile index 32070de..7090416 100644 --- a/fs/zfs/Makefile +++ b/fs/zfs/Makefile @@ -5,27 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libzfs.o - -AOBJS = -COBJS-$(CONFIG_CMD_ZFS) := dev.o zfs.o zfs_fletcher.o zfs_sha256.o zfs_lzjb.o - -SRCS := $(AOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(AOBJS) $(COBJS-y)) - - -all: $(LIB) $(AOBJS) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_CMD_ZFS) := dev.o zfs.o zfs_fletcher.o zfs_sha256.o zfs_lzjb.o
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com --- common/Makefile | 389 ++++++++++++++++++++++++---------------------------- common/spl/Makefile | 36 +---- 2 files changed, 189 insertions(+), 236 deletions(-)
diff --git a/common/Makefile b/common/Makefile index 288690b..745d447 100644 --- a/common/Makefile +++ b/common/Makefile @@ -5,215 +5,211 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libcommon.o - # core ifndef CONFIG_SPL_BUILD -COBJS-y += main.o -COBJS-y += command.o -COBJS-y += exports.o -COBJS-y += hash.o -COBJS-$(CONFIG_SYS_HUSH_PARSER) += hush.o -COBJS-y += s_record.o -COBJS-y += xyzModem.o -COBJS-y += cmd_disk.o +obj-y += main.o +obj-y += command.o +obj-y += exports.o +obj-y += hash.o +obj-$(CONFIG_SYS_HUSH_PARSER) += hush.o +obj-y += s_record.o +obj-y += xyzModem.o +obj-y += cmd_disk.o
# boards -COBJS-$(CONFIG_SYS_GENERIC_BOARD) += board_f.o -COBJS-$(CONFIG_SYS_GENERIC_BOARD) += board_r.o +obj-$(CONFIG_SYS_GENERIC_BOARD) += board_f.o +obj-$(CONFIG_SYS_GENERIC_BOARD) += board_r.o
# core command -COBJS-y += cmd_boot.o -COBJS-$(CONFIG_CMD_BOOTM) += cmd_bootm.o -COBJS-y += cmd_help.o -COBJS-y += cmd_version.o +obj-y += cmd_boot.o +obj-$(CONFIG_CMD_BOOTM) += cmd_bootm.o +obj-y += cmd_help.o +obj-y += cmd_version.o
# environment -COBJS-y += env_attr.o -COBJS-y += env_callback.o -COBJS-y += env_flags.o -COBJS-$(CONFIG_ENV_IS_IN_DATAFLASH) += env_dataflash.o -COBJS-$(CONFIG_ENV_IS_IN_EEPROM) += env_eeprom.o -XCOBJS-$(CONFIG_ENV_IS_EMBEDDED) += env_embedded.o -COBJS-$(CONFIG_ENV_IS_IN_EEPROM) += env_embedded.o -XCOBJS-$(CONFIG_ENV_IS_IN_FLASH) += env_embedded.o -COBJS-$(CONFIG_ENV_IS_IN_NVRAM) += env_embedded.o -COBJS-$(CONFIG_ENV_IS_IN_FLASH) += env_flash.o -COBJS-$(CONFIG_ENV_IS_IN_MMC) += env_mmc.o -COBJS-$(CONFIG_ENV_IS_IN_FAT) += env_fat.o -COBJS-$(CONFIG_ENV_IS_IN_NAND) += env_nand.o -COBJS-$(CONFIG_ENV_IS_IN_NVRAM) += env_nvram.o -COBJS-$(CONFIG_ENV_IS_IN_ONENAND) += env_onenand.o -COBJS-$(CONFIG_ENV_IS_IN_SPI_FLASH) += env_sf.o -COBJS-$(CONFIG_ENV_IS_IN_REMOTE) += env_remote.o -COBJS-$(CONFIG_ENV_IS_IN_UBI) += env_ubi.o -COBJS-$(CONFIG_ENV_IS_NOWHERE) += env_nowhere.o +obj-y += env_attr.o +obj-y += env_callback.o +obj-y += env_flags.o +obj-$(CONFIG_ENV_IS_IN_DATAFLASH) += env_dataflash.o +obj-$(CONFIG_ENV_IS_IN_EEPROM) += env_eeprom.o +extra-$(CONFIG_ENV_IS_EMBEDDED) += env_embedded.o +obj-$(CONFIG_ENV_IS_IN_EEPROM) += env_embedded.o +extra-$(CONFIG_ENV_IS_IN_FLASH) += env_embedded.o +obj-$(CONFIG_ENV_IS_IN_NVRAM) += env_embedded.o +obj-$(CONFIG_ENV_IS_IN_FLASH) += env_flash.o +obj-$(CONFIG_ENV_IS_IN_MMC) += env_mmc.o +obj-$(CONFIG_ENV_IS_IN_FAT) += env_fat.o +obj-$(CONFIG_ENV_IS_IN_NAND) += env_nand.o +obj-$(CONFIG_ENV_IS_IN_NVRAM) += env_nvram.o +obj-$(CONFIG_ENV_IS_IN_ONENAND) += env_onenand.o +obj-$(CONFIG_ENV_IS_IN_SPI_FLASH) += env_sf.o +obj-$(CONFIG_ENV_IS_IN_REMOTE) += env_remote.o +obj-$(CONFIG_ENV_IS_IN_UBI) += env_ubi.o +obj-$(CONFIG_ENV_IS_NOWHERE) += env_nowhere.o
# command -COBJS-$(CONFIG_CMD_AMBAPP) += cmd_ambapp.o -COBJS-$(CONFIG_SOURCE) += cmd_source.o -COBJS-$(CONFIG_CMD_SOURCE) += cmd_source.o -COBJS-$(CONFIG_CMD_BDI) += cmd_bdinfo.o -COBJS-$(CONFIG_CMD_BEDBUG) += bedbug.o cmd_bedbug.o -COBJS-$(CONFIG_CMD_BMP) += cmd_bmp.o -COBJS-$(CONFIG_CMD_BOOTMENU) += cmd_bootmenu.o -COBJS-$(CONFIG_CMD_BOOTLDR) += cmd_bootldr.o -COBJS-$(CONFIG_CMD_BOOTSTAGE) += cmd_bootstage.o -COBJS-$(CONFIG_CMD_CACHE) += cmd_cache.o -COBJS-$(CONFIG_CMD_CBFS) += cmd_cbfs.o -COBJS-$(CONFIG_CMD_CONSOLE) += cmd_console.o -COBJS-$(CONFIG_CMD_CPLBINFO) += cmd_cplbinfo.o -COBJS-$(CONFIG_DATAFLASH_MMC_SELECT) += cmd_dataflash_mmc_mux.o -COBJS-$(CONFIG_CMD_DATE) += cmd_date.o -COBJS-$(CONFIG_CMD_SOUND) += cmd_sound.o +obj-$(CONFIG_CMD_AMBAPP) += cmd_ambapp.o +obj-$(CONFIG_SOURCE) += cmd_source.o +obj-$(CONFIG_CMD_SOURCE) += cmd_source.o +obj-$(CONFIG_CMD_BDI) += cmd_bdinfo.o +obj-$(CONFIG_CMD_BEDBUG) += bedbug.o cmd_bedbug.o +obj-$(CONFIG_CMD_BMP) += cmd_bmp.o +obj-$(CONFIG_CMD_BOOTMENU) += cmd_bootmenu.o +obj-$(CONFIG_CMD_BOOTLDR) += cmd_bootldr.o +obj-$(CONFIG_CMD_BOOTSTAGE) += cmd_bootstage.o +obj-$(CONFIG_CMD_CACHE) += cmd_cache.o +obj-$(CONFIG_CMD_CBFS) += cmd_cbfs.o +obj-$(CONFIG_CMD_CONSOLE) += cmd_console.o +obj-$(CONFIG_CMD_CPLBINFO) += cmd_cplbinfo.o +obj-$(CONFIG_DATAFLASH_MMC_SELECT) += cmd_dataflash_mmc_mux.o +obj-$(CONFIG_CMD_DATE) += cmd_date.o +obj-$(CONFIG_CMD_SOUND) += cmd_sound.o ifdef CONFIG_4xx -COBJS-$(CONFIG_CMD_SETGETDCR) += cmd_dcr.o +obj-$(CONFIG_CMD_SETGETDCR) += cmd_dcr.o endif ifdef CONFIG_POST -COBJS-$(CONFIG_CMD_DIAG) += cmd_diag.o +obj-$(CONFIG_CMD_DIAG) += cmd_diag.o endif -COBJS-$(CONFIG_CMD_DISPLAY) += cmd_display.o -COBJS-$(CONFIG_CMD_DTT) += cmd_dtt.o -COBJS-$(CONFIG_CMD_ECHO) += cmd_echo.o -COBJS-$(CONFIG_ENV_IS_IN_EEPROM) += cmd_eeprom.o -COBJS-$(CONFIG_CMD_EEPROM) += cmd_eeprom.o -COBJS-$(CONFIG_CMD_ELF) += cmd_elf.o -COBJS-$(CONFIG_SYS_HUSH_PARSER) += cmd_exit.o -COBJS-$(CONFIG_CMD_EXT4) += cmd_ext4.o -COBJS-$(CONFIG_CMD_EXT2) += cmd_ext2.o -COBJS-$(CONFIG_CMD_FAT) += cmd_fat.o -COBJS-$(CONFIG_CMD_FDC)$(CONFIG_CMD_FDOS) += cmd_fdc.o -COBJS-$(CONFIG_OF_LIBFDT) += cmd_fdt.o fdt_support.o -COBJS-$(CONFIG_CMD_FDOS) += cmd_fdos.o -COBJS-$(CONFIG_CMD_FITUPD) += cmd_fitupd.o -COBJS-$(CONFIG_CMD_FLASH) += cmd_flash.o +obj-$(CONFIG_CMD_DISPLAY) += cmd_display.o +obj-$(CONFIG_CMD_DTT) += cmd_dtt.o +obj-$(CONFIG_CMD_ECHO) += cmd_echo.o +obj-$(CONFIG_ENV_IS_IN_EEPROM) += cmd_eeprom.o +obj-$(CONFIG_CMD_EEPROM) += cmd_eeprom.o +obj-$(CONFIG_CMD_ELF) += cmd_elf.o +obj-$(CONFIG_SYS_HUSH_PARSER) += cmd_exit.o +obj-$(CONFIG_CMD_EXT4) += cmd_ext4.o +obj-$(CONFIG_CMD_EXT2) += cmd_ext2.o +obj-$(CONFIG_CMD_FAT) += cmd_fat.o +obj-$(CONFIG_CMD_FDC)$(CONFIG_CMD_FDOS) += cmd_fdc.o +obj-$(CONFIG_OF_LIBFDT) += cmd_fdt.o fdt_support.o +obj-$(CONFIG_CMD_FDOS) += cmd_fdos.o +obj-$(CONFIG_CMD_FITUPD) += cmd_fitupd.o +obj-$(CONFIG_CMD_FLASH) += cmd_flash.o ifdef CONFIG_FPGA -COBJS-$(CONFIG_CMD_FPGA) += cmd_fpga.o +obj-$(CONFIG_CMD_FPGA) += cmd_fpga.o endif -COBJS-$(CONFIG_CMD_FPGAD) += cmd_fpgad.o -COBJS-$(CONFIG_CMD_FS_GENERIC) += cmd_fs.o -COBJS-$(CONFIG_CMD_FUSE) += cmd_fuse.o -COBJS-$(CONFIG_CMD_GETTIME) += cmd_gettime.o -COBJS-$(CONFIG_CMD_GPIO) += cmd_gpio.o -COBJS-$(CONFIG_CMD_I2C) += cmd_i2c.o -COBJS-$(CONFIG_CMD_HASH) += cmd_hash.o -COBJS-$(CONFIG_CMD_IDE) += cmd_ide.o -COBJS-$(CONFIG_CMD_IMMAP) += cmd_immap.o -COBJS-$(CONFIG_CMD_INI) += cmd_ini.o -COBJS-$(CONFIG_CMD_IRQ) += cmd_irq.o -COBJS-$(CONFIG_CMD_ITEST) += cmd_itest.o -COBJS-$(CONFIG_CMD_JFFS2) += cmd_jffs2.o -COBJS-$(CONFIG_CMD_CRAMFS) += cmd_cramfs.o -COBJS-$(CONFIG_CMD_LDRINFO) += cmd_ldrinfo.o -COBJS-$(CONFIG_CMD_LED) += cmd_led.o -COBJS-$(CONFIG_CMD_LICENSE) += cmd_license.o -COBJS-y += cmd_load.o -COBJS-$(CONFIG_LOGBUFFER) += cmd_log.o -COBJS-$(CONFIG_ID_EEPROM) += cmd_mac.o -COBJS-$(CONFIG_CMD_MD5SUM) += cmd_md5sum.o -COBJS-$(CONFIG_CMD_MEMORY) += cmd_mem.o -COBJS-$(CONFIG_CMD_IO) += cmd_io.o -COBJS-$(CONFIG_CMD_MFSL) += cmd_mfsl.o -COBJS-$(CONFIG_MII) += miiphyutil.o -COBJS-$(CONFIG_CMD_MII) += miiphyutil.o -COBJS-$(CONFIG_PHYLIB) += miiphyutil.o -COBJS-$(CONFIG_CMD_MII) += cmd_mii.o +obj-$(CONFIG_CMD_FPGAD) += cmd_fpgad.o +obj-$(CONFIG_CMD_FS_GENERIC) += cmd_fs.o +obj-$(CONFIG_CMD_FUSE) += cmd_fuse.o +obj-$(CONFIG_CMD_GETTIME) += cmd_gettime.o +obj-$(CONFIG_CMD_GPIO) += cmd_gpio.o +obj-$(CONFIG_CMD_I2C) += cmd_i2c.o +obj-$(CONFIG_CMD_HASH) += cmd_hash.o +obj-$(CONFIG_CMD_IDE) += cmd_ide.o +obj-$(CONFIG_CMD_IMMAP) += cmd_immap.o +obj-$(CONFIG_CMD_INI) += cmd_ini.o +obj-$(CONFIG_CMD_IRQ) += cmd_irq.o +obj-$(CONFIG_CMD_ITEST) += cmd_itest.o +obj-$(CONFIG_CMD_JFFS2) += cmd_jffs2.o +obj-$(CONFIG_CMD_CRAMFS) += cmd_cramfs.o +obj-$(CONFIG_CMD_LDRINFO) += cmd_ldrinfo.o +obj-$(CONFIG_CMD_LED) += cmd_led.o +obj-$(CONFIG_CMD_LICENSE) += cmd_license.o +obj-y += cmd_load.o +obj-$(CONFIG_LOGBUFFER) += cmd_log.o +obj-$(CONFIG_ID_EEPROM) += cmd_mac.o +obj-$(CONFIG_CMD_MD5SUM) += cmd_md5sum.o +obj-$(CONFIG_CMD_MEMORY) += cmd_mem.o +obj-$(CONFIG_CMD_IO) += cmd_io.o +obj-$(CONFIG_CMD_MFSL) += cmd_mfsl.o +obj-$(CONFIG_MII) += miiphyutil.o +obj-$(CONFIG_CMD_MII) += miiphyutil.o +obj-$(CONFIG_PHYLIB) += miiphyutil.o +obj-$(CONFIG_CMD_MII) += cmd_mii.o ifdef CONFIG_PHYLIB -COBJS-$(CONFIG_CMD_MII) += cmd_mdio.o +obj-$(CONFIG_CMD_MII) += cmd_mdio.o endif -COBJS-$(CONFIG_CMD_MISC) += cmd_misc.o -COBJS-$(CONFIG_CMD_MMC) += cmd_mmc.o -COBJS-$(CONFIG_CMD_MMC_SPI) += cmd_mmc_spi.o -COBJS-$(CONFIG_MP) += cmd_mp.o -COBJS-$(CONFIG_CMD_MTDPARTS) += cmd_mtdparts.o -COBJS-$(CONFIG_CMD_NAND) += cmd_nand.o -COBJS-$(CONFIG_CMD_NET) += cmd_net.o -COBJS-$(CONFIG_CMD_ONENAND) += cmd_onenand.o -COBJS-$(CONFIG_CMD_OTP) += cmd_otp.o -COBJS-$(CONFIG_CMD_PART) += cmd_part.o +obj-$(CONFIG_CMD_MISC) += cmd_misc.o +obj-$(CONFIG_CMD_MMC) += cmd_mmc.o +obj-$(CONFIG_CMD_MMC_SPI) += cmd_mmc_spi.o +obj-$(CONFIG_MP) += cmd_mp.o +obj-$(CONFIG_CMD_MTDPARTS) += cmd_mtdparts.o +obj-$(CONFIG_CMD_NAND) += cmd_nand.o +obj-$(CONFIG_CMD_NET) += cmd_net.o +obj-$(CONFIG_CMD_ONENAND) += cmd_onenand.o +obj-$(CONFIG_CMD_OTP) += cmd_otp.o +obj-$(CONFIG_CMD_PART) += cmd_part.o ifdef CONFIG_PCI -COBJS-$(CONFIG_CMD_PCI) += cmd_pci.o +obj-$(CONFIG_CMD_PCI) += cmd_pci.o endif -COBJS-y += cmd_pcmcia.o -COBJS-$(CONFIG_CMD_PORTIO) += cmd_portio.o -COBJS-$(CONFIG_CMD_PXE) += cmd_pxe.o -COBJS-$(CONFIG_CMD_READ) += cmd_read.o -COBJS-$(CONFIG_CMD_REGINFO) += cmd_reginfo.o -COBJS-$(CONFIG_CMD_REISER) += cmd_reiser.o -COBJS-$(CONFIG_SANDBOX) += cmd_sandbox.o -COBJS-$(CONFIG_CMD_SATA) += cmd_sata.o -COBJS-$(CONFIG_CMD_SF) += cmd_sf.o -COBJS-$(CONFIG_CMD_SCSI) += cmd_scsi.o -COBJS-$(CONFIG_CMD_SHA1SUM) += cmd_sha1sum.o -COBJS-$(CONFIG_CMD_SETEXPR) += cmd_setexpr.o -COBJS-$(CONFIG_CMD_SOFTSWITCH) += cmd_softswitch.o -COBJS-$(CONFIG_CMD_SPI) += cmd_spi.o -COBJS-$(CONFIG_CMD_SPIBOOTLDR) += cmd_spibootldr.o -COBJS-$(CONFIG_CMD_STRINGS) += cmd_strings.o -COBJS-$(CONFIG_CMD_TERMINAL) += cmd_terminal.o -COBJS-$(CONFIG_CMD_TIME) += cmd_time.o -COBJS-$(CONFIG_CMD_TRACE) += cmd_trace.o -COBJS-$(CONFIG_SYS_HUSH_PARSER) += cmd_test.o -COBJS-$(CONFIG_CMD_TPM) += cmd_tpm.o -COBJS-$(CONFIG_CMD_TSI148) += cmd_tsi148.o -COBJS-$(CONFIG_CMD_UBI) += cmd_ubi.o -COBJS-$(CONFIG_CMD_UBIFS) += cmd_ubifs.o -COBJS-$(CONFIG_CMD_UNIVERSE) += cmd_universe.o -COBJS-$(CONFIG_CMD_UNZIP) += cmd_unzip.o +obj-y += cmd_pcmcia.o +obj-$(CONFIG_CMD_PORTIO) += cmd_portio.o +obj-$(CONFIG_CMD_PXE) += cmd_pxe.o +obj-$(CONFIG_CMD_READ) += cmd_read.o +obj-$(CONFIG_CMD_REGINFO) += cmd_reginfo.o +obj-$(CONFIG_CMD_REISER) += cmd_reiser.o +obj-$(CONFIG_SANDBOX) += cmd_sandbox.o +obj-$(CONFIG_CMD_SATA) += cmd_sata.o +obj-$(CONFIG_CMD_SF) += cmd_sf.o +obj-$(CONFIG_CMD_SCSI) += cmd_scsi.o +obj-$(CONFIG_CMD_SHA1SUM) += cmd_sha1sum.o +obj-$(CONFIG_CMD_SETEXPR) += cmd_setexpr.o +obj-$(CONFIG_CMD_SOFTSWITCH) += cmd_softswitch.o +obj-$(CONFIG_CMD_SPI) += cmd_spi.o +obj-$(CONFIG_CMD_SPIBOOTLDR) += cmd_spibootldr.o +obj-$(CONFIG_CMD_STRINGS) += cmd_strings.o +obj-$(CONFIG_CMD_TERMINAL) += cmd_terminal.o +obj-$(CONFIG_CMD_TIME) += cmd_time.o +obj-$(CONFIG_CMD_TRACE) += cmd_trace.o +obj-$(CONFIG_SYS_HUSH_PARSER) += cmd_test.o +obj-$(CONFIG_CMD_TPM) += cmd_tpm.o +obj-$(CONFIG_CMD_TSI148) += cmd_tsi148.o +obj-$(CONFIG_CMD_UBI) += cmd_ubi.o +obj-$(CONFIG_CMD_UBIFS) += cmd_ubifs.o +obj-$(CONFIG_CMD_UNIVERSE) += cmd_universe.o +obj-$(CONFIG_CMD_UNZIP) += cmd_unzip.o ifdef CONFIG_CMD_USB -COBJS-y += cmd_usb.o -COBJS-y += usb.o usb_hub.o -COBJS-$(CONFIG_USB_STORAGE) += usb_storage.o +obj-y += cmd_usb.o +obj-y += usb.o usb_hub.o +obj-$(CONFIG_USB_STORAGE) += usb_storage.o endif -COBJS-$(CONFIG_CMD_USB_MASS_STORAGE) += cmd_usb_mass_storage.o -COBJS-$(CONFIG_CMD_XIMG) += cmd_ximg.o -COBJS-$(CONFIG_YAFFS2) += cmd_yaffs2.o -COBJS-$(CONFIG_CMD_SPL) += cmd_spl.o -COBJS-$(CONFIG_CMD_ZIP) += cmd_zip.o -COBJS-$(CONFIG_CMD_ZFS) += cmd_zfs.o +obj-$(CONFIG_CMD_USB_MASS_STORAGE) += cmd_usb_mass_storage.o +obj-$(CONFIG_CMD_XIMG) += cmd_ximg.o +obj-$(CONFIG_YAFFS2) += cmd_yaffs2.o +obj-$(CONFIG_CMD_SPL) += cmd_spl.o +obj-$(CONFIG_CMD_ZIP) += cmd_zip.o +obj-$(CONFIG_CMD_ZFS) += cmd_zfs.o
# others -COBJS-$(CONFIG_BOOTSTAGE) += bootstage.o -COBJS-$(CONFIG_CONSOLE_MUX) += iomux.o -COBJS-y += flash.o -COBJS-$(CONFIG_CMD_KGDB) += kgdb.o kgdb_stubs.o -COBJS-$(CONFIG_I2C_EDID) += edid.o -COBJS-$(CONFIG_KALLSYMS) += kallsyms.o -COBJS-y += splash.o -COBJS-$(CONFIG_LCD) += lcd.o -COBJS-$(CONFIG_LYNXKDI) += lynxkdi.o -COBJS-$(CONFIG_MENU) += menu.o -COBJS-$(CONFIG_MODEM_SUPPORT) += modem.o -COBJS-$(CONFIG_UPDATE_TFTP) += update.o -COBJS-$(CONFIG_USB_KEYBOARD) += usb_kbd.o -COBJS-$(CONFIG_CMD_DFU) += cmd_dfu.o -COBJS-$(CONFIG_CMD_GPT) += cmd_gpt.o +obj-$(CONFIG_BOOTSTAGE) += bootstage.o +obj-$(CONFIG_CONSOLE_MUX) += iomux.o +obj-y += flash.o +obj-$(CONFIG_CMD_KGDB) += kgdb.o kgdb_stubs.o +obj-$(CONFIG_I2C_EDID) += edid.o +obj-$(CONFIG_KALLSYMS) += kallsyms.o +obj-y += splash.o +obj-$(CONFIG_LCD) += lcd.o +obj-$(CONFIG_LYNXKDI) += lynxkdi.o +obj-$(CONFIG_MENU) += menu.o +obj-$(CONFIG_MODEM_SUPPORT) += modem.o +obj-$(CONFIG_UPDATE_TFTP) += update.o +obj-$(CONFIG_USB_KEYBOARD) += usb_kbd.o +obj-$(CONFIG_CMD_DFU) += cmd_dfu.o +obj-$(CONFIG_CMD_GPT) += cmd_gpt.o endif
ifdef CONFIG_SPL_BUILD -COBJS-$(CONFIG_ENV_IS_IN_FLASH) += env_flash.o -COBJS-$(CONFIG_SPL_YMODEM_SUPPORT) += xyzModem.o -COBJS-$(CONFIG_SPL_NET_SUPPORT) += miiphyutil.o +obj-$(CONFIG_ENV_IS_IN_FLASH) += env_flash.o +obj-$(CONFIG_SPL_YMODEM_SUPPORT) += xyzModem.o +obj-$(CONFIG_SPL_NET_SUPPORT) += miiphyutil.o # environment -COBJS-$(CONFIG_SPL_ENV_SUPPORT) += env_attr.o -COBJS-$(CONFIG_SPL_ENV_SUPPORT) += env_flags.o -COBJS-$(CONFIG_SPL_ENV_SUPPORT) += env_callback.o +obj-$(CONFIG_SPL_ENV_SUPPORT) += env_attr.o +obj-$(CONFIG_SPL_ENV_SUPPORT) += env_flags.o +obj-$(CONFIG_SPL_ENV_SUPPORT) += env_callback.o ifneq ($(CONFIG_SPL_NET_SUPPORT),y) -COBJS-$(CONFIG_ENV_IS_NOWHERE) += env_nowhere.o -COBJS-$(CONFIG_ENV_IS_IN_MMC) += env_mmc.o -COBJS-$(CONFIG_ENV_IS_IN_NAND) += env_nand.o -COBJS-$(CONFIG_ENV_IS_IN_SPI_FLASH) += env_sf.o -COBJS-$(CONFIG_ENV_IS_IN_FLASH) += env_flash.o +obj-$(CONFIG_ENV_IS_NOWHERE) += env_nowhere.o +obj-$(CONFIG_ENV_IS_IN_MMC) += env_mmc.o +obj-$(CONFIG_ENV_IS_IN_NAND) += env_nand.o +obj-$(CONFIG_ENV_IS_IN_SPI_FLASH) += env_sf.o +obj-$(CONFIG_ENV_IS_IN_FLASH) += env_flash.o else -COBJS-y += env_nowhere.o +obj-y += env_nowhere.o endif endif # core command -COBJS-y += cmd_nvedit.o +obj-y += cmd_nvedit.o #environment -COBJS-y += env_common.o +obj-y += env_common.o #others ifdef CONFIG_DDR_SPD SPD := y @@ -221,32 +217,20 @@ endif ifdef CONFIG_SPD_EEPROM SPD := y endif -COBJS-$(SPD) += ddr_spd.o -COBJS-$(CONFIG_HWCONFIG) += hwconfig.o -COBJS-$(CONFIG_BOUNCE_BUFFER) += bouncebuf.o -COBJS-y += console.o -COBJS-y += dlmalloc.o -COBJS-y += image.o -COBJS-$(CONFIG_OF_LIBFDT) += image-fdt.o -COBJS-$(CONFIG_FIT) += image-fit.o -COBJS-$(CONFIG_FIT_SIGNATURE) += image-sig.o -COBJS-y += memsize.o -COBJS-y += stdio.o - - -COBJS := $(sort $(COBJS-y)) -XCOBJS := $(sort $(XCOBJS-y)) -SRCS := $(COBJS:.o=.c) $(XCOBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -XOBJS := $(addprefix $(obj),$(XCOBJS)) +obj-$(SPD) += ddr_spd.o +obj-$(CONFIG_HWCONFIG) += hwconfig.o +obj-$(CONFIG_BOUNCE_BUFFER) += bouncebuf.o +obj-y += console.o +obj-y += dlmalloc.o +obj-y += image.o +obj-$(CONFIG_OF_LIBFDT) += image-fdt.o +obj-$(CONFIG_FIT) += image-fit.o +obj-$(CONFIG_FIT_SIGNATURE) += image-sig.o +obj-y += memsize.o +obj-y += stdio.o
CPPFLAGS += -I..
-all: $(LIB) $(XOBJS) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - $(obj)env_embedded.o: $(src)env_embedded.c $(obj)../tools/envcrc $(CC) $(AFLAGS) -Wa,--no-warn \ -DENV_CRC=$(shell $(obj)../tools/envcrc) \ @@ -258,12 +242,3 @@ $(obj)../tools/envcrc: # SEE README.arm-unaligned-accesses $(obj)hush.o: CFLAGS += $(PLATFORM_NO_UNALIGNED) $(obj)fdt_support.o: CFLAGS += $(PLATFORM_NO_UNALIGNED) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/common/spl/Makefile b/common/spl/Makefile index e8144f7..5c0637b 100644 --- a/common/spl/Makefile +++ b/common/spl/Makefile @@ -8,34 +8,12 @@ # Based on common/Makefile. #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libspl.o - ifdef CONFIG_SPL_BUILD -COBJS-$(CONFIG_SPL_FRAMEWORK) += spl.o -COBJS-$(CONFIG_SPL_NOR_SUPPORT) += spl_nor.o -COBJS-$(CONFIG_SPL_YMODEM_SUPPORT) += spl_ymodem.o -COBJS-$(CONFIG_SPL_NAND_SUPPORT) += spl_nand.o -COBJS-$(CONFIG_SPL_ONENAND_SUPPORT) += spl_onenand.o -COBJS-$(CONFIG_SPL_NET_SUPPORT) += spl_net.o -COBJS-$(CONFIG_SPL_MMC_SUPPORT) += spl_mmc.o +obj-$(CONFIG_SPL_FRAMEWORK) += spl.o +obj-$(CONFIG_SPL_NOR_SUPPORT) += spl_nor.o +obj-$(CONFIG_SPL_YMODEM_SUPPORT) += spl_ymodem.o +obj-$(CONFIG_SPL_NAND_SUPPORT) += spl_nand.o +obj-$(CONFIG_SPL_ONENAND_SUPPORT) += spl_onenand.o +obj-$(CONFIG_SPL_NET_SUPPORT) += spl_net.o +obj-$(CONFIG_SPL_MMC_SUPPORT) += spl_mmc.o endif - -COBJS := $(sort $(COBJS-y)) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -#########################################################################
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com --- net/Makefile | 46 ++++++++++++---------------------------------- 1 file changed, 12 insertions(+), 34 deletions(-)
diff --git a/net/Makefile b/net/Makefile index 4c9a97f..31aadc2 100644 --- a/net/Makefile +++ b/net/Makefile @@ -5,39 +5,17 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - # CFLAGS += -DDEBUG
-LIB = $(obj)libnet.o - -COBJS-$(CONFIG_CMD_NET) += arp.o -COBJS-$(CONFIG_CMD_NET) += bootp.o -COBJS-$(CONFIG_CMD_CDP) += cdp.o -COBJS-$(CONFIG_CMD_DNS) += dns.o -COBJS-$(CONFIG_CMD_NET) += eth.o -COBJS-$(CONFIG_CMD_LINK_LOCAL) += link_local.o -COBJS-$(CONFIG_CMD_NET) += net.o -COBJS-$(CONFIG_CMD_NFS) += nfs.o -COBJS-$(CONFIG_CMD_PING) += ping.o -COBJS-$(CONFIG_CMD_RARP) += rarp.o -COBJS-$(CONFIG_CMD_SNTP) += sntp.o -COBJS-$(CONFIG_CMD_NET) += tftp.o - -COBJS := $(sort $(COBJS-y)) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_CMD_NET) += arp.o +obj-$(CONFIG_CMD_NET) += bootp.o +obj-$(CONFIG_CMD_CDP) += cdp.o +obj-$(CONFIG_CMD_DNS) += dns.o +obj-$(CONFIG_CMD_NET) += eth.o +obj-$(CONFIG_CMD_LINK_LOCAL) += link_local.o +obj-$(CONFIG_CMD_NET) += net.o +obj-$(CONFIG_CMD_NFS) += nfs.o +obj-$(CONFIG_CMD_PING) += ping.o +obj-$(CONFIG_CMD_RARP) += rarp.o +obj-$(CONFIG_CMD_SNTP) += sntp.o +obj-$(CONFIG_CMD_NET) += tftp.o
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com --- lib/Makefile | 114 ++++++++++++++++++++++------------------------------ lib/libfdt/Makefile | 27 +------------ lib/lzma/Makefile | 24 +---------- lib/lzo/Makefile | 24 +---------- lib/rsa/Makefile | 22 +--------- lib/tizen/Makefile | 24 +---------- lib/zlib/Makefile | 22 +--------- 7 files changed, 54 insertions(+), 203 deletions(-)
diff --git a/lib/Makefile b/lib/Makefile index df0cdd4..4e3b500 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -5,78 +5,58 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libgeneric.o - ifndef CONFIG_SPL_BUILD -COBJS-$(CONFIG_AES) += aes.o -COBJS-$(CONFIG_BZIP2) += bzlib.o -COBJS-$(CONFIG_BZIP2) += bzlib_crctable.o -COBJS-$(CONFIG_BZIP2) += bzlib_decompress.o -COBJS-$(CONFIG_BZIP2) += bzlib_randtable.o -COBJS-$(CONFIG_BZIP2) += bzlib_huffman.o -COBJS-$(CONFIG_USB_TTY) += circbuf.o -COBJS-y += crc7.o -COBJS-y += crc16.o -COBJS-$(CONFIG_OF_CONTROL) += fdtdec.o -COBJS-$(CONFIG_TEST_FDTDEC) += fdtdec_test.o -COBJS-$(CONFIG_GZIP) += gunzip.o -COBJS-$(CONFIG_GZIP_COMPRESSED) += gzip.o -COBJS-y += initcall.o -COBJS-$(CONFIG_LMB) += lmb.o -COBJS-y += ldiv.o -COBJS-$(CONFIG_MD5) += md5.o -COBJS-y += net_utils.o -COBJS-$(CONFIG_PHYSMEM) += physmem.o -COBJS-y += qsort.o -COBJS-$(CONFIG_SHA1) += sha1.o -COBJS-$(CONFIG_SHA256) += sha256.o -COBJS-y += strmhz.o -COBJS-$(CONFIG_TPM) += tpm.o -COBJS-$(CONFIG_RBTREE) += rbtree.o -COBJS-$(CONFIG_BITREVERSE) += bitrev.o +obj-$(CONFIG_AES) += aes.o +obj-$(CONFIG_BZIP2) += bzlib.o +obj-$(CONFIG_BZIP2) += bzlib_crctable.o +obj-$(CONFIG_BZIP2) += bzlib_decompress.o +obj-$(CONFIG_BZIP2) += bzlib_randtable.o +obj-$(CONFIG_BZIP2) += bzlib_huffman.o +obj-$(CONFIG_USB_TTY) += circbuf.o +obj-y += crc7.o +obj-y += crc16.o +obj-$(CONFIG_OF_CONTROL) += fdtdec.o +obj-$(CONFIG_TEST_FDTDEC) += fdtdec_test.o +obj-$(CONFIG_GZIP) += gunzip.o +obj-$(CONFIG_GZIP_COMPRESSED) += gzip.o +obj-y += initcall.o +obj-$(CONFIG_LMB) += lmb.o +obj-y += ldiv.o +obj-$(CONFIG_MD5) += md5.o +obj-y += net_utils.o +obj-$(CONFIG_PHYSMEM) += physmem.o +obj-y += qsort.o +obj-$(CONFIG_SHA1) += sha1.o +obj-$(CONFIG_SHA256) += sha256.o +obj-y += strmhz.o +obj-$(CONFIG_TPM) += tpm.o +obj-$(CONFIG_RBTREE) += rbtree.o +obj-$(CONFIG_BITREVERSE) += bitrev.o endif
ifdef CONFIG_SPL_BUILD -COBJS-$(CONFIG_SPL_YMODEM_SUPPORT) += crc16.o -COBJS-$(CONFIG_SPL_NET_SUPPORT) += net_utils.o +obj-$(CONFIG_SPL_YMODEM_SUPPORT) += crc16.o +obj-$(CONFIG_SPL_NET_SUPPORT) += net_utils.o endif -COBJS-$(CONFIG_ADDR_MAP) += addr_map.o -COBJS-y += hashtable.o -COBJS-y += errno.o -COBJS-y += display_options.o -COBJS-$(CONFIG_BCH) += bch.o -COBJS-y += crc32.o -COBJS-y += ctype.o -COBJS-y += div64.o -COBJS-y += hang.o -COBJS-y += linux_string.o -COBJS-$(CONFIG_REGEX) += slre.o -COBJS-y += string.o -COBJS-y += time.o -COBJS-$(CONFIG_TRACE) += trace.o -COBJS-$(CONFIG_BOOTP_PXE) += uuid.o -COBJS-y += vsprintf.o -COBJS-$(CONFIG_RANDOM_MACADDR) += rand.o -COBJS-$(CONFIG_BOOTP_RANDOM_DELAY) += rand.o -COBJS-$(CONFIG_CMD_LINK_LOCAL) += rand.o - -COBJS := $(sort $(COBJS-y)) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) +obj-$(CONFIG_ADDR_MAP) += addr_map.o +obj-y += hashtable.o +obj-y += errno.o +obj-y += display_options.o +obj-$(CONFIG_BCH) += bch.o +obj-y += crc32.o +obj-y += ctype.o +obj-y += div64.o +obj-y += hang.o +obj-y += linux_string.o +obj-$(CONFIG_REGEX) += slre.o +obj-y += string.o +obj-y += time.o +obj-$(CONFIG_TRACE) += trace.o +obj-$(CONFIG_BOOTP_PXE) += uuid.o +obj-y += vsprintf.o +obj-$(CONFIG_RANDOM_MACADDR) += rand.o +obj-$(CONFIG_BOOTP_RANDOM_DELAY) += rand.o +obj-$(CONFIG_CMD_LINK_LOCAL) += rand.o
# SEE README.arm-unaligned-accesses $(obj)bzlib.o: CFLAGS += $(PLATFORM_NO_UNALIGNED) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/lib/libfdt/Makefile b/lib/libfdt/Makefile index 07373df..a02c9b0 100644 --- a/lib/libfdt/Makefile +++ b/lib/libfdt/Makefile @@ -5,30 +5,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libfdt.o - -SOBJS = - COBJS-libfdt += fdt.o fdt_ro.o fdt_rw.o fdt_strerror.o fdt_sw.o fdt_wip.o fdt_empty_tree.o
-COBJS-$(CONFIG_OF_LIBFDT) += $(COBJS-libfdt) -COBJS-$(CONFIG_FIT) += $(COBJS-libfdt) - - -COBJS := $(sort $(COBJS-y)) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_OF_LIBFDT) += $(COBJS-libfdt) +obj-$(CONFIG_FIT) += $(COBJS-libfdt) diff --git a/lib/lzma/Makefile b/lib/lzma/Makefile index 412e187..25c6797 100644 --- a/lib/lzma/Makefile +++ b/lib/lzma/Makefile @@ -8,28 +8,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)liblzma.o - -SOBJS = - CFLAGS += -D_LZMA_PROB32
-COBJS-$(CONFIG_LZMA) += LzmaDec.o LzmaTools.o - -COBJS = $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_LZMA) += LzmaDec.o LzmaTools.o diff --git a/lib/lzo/Makefile b/lib/lzo/Makefile index 516519a..dd853ea 100644 --- a/lib/lzo/Makefile +++ b/lib/lzo/Makefile @@ -5,26 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)liblzo.o - -SOBJS = - -COBJS-$(CONFIG_LZO) += lzo1x_decompress.o - -COBJS = $(COBJS-y) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_LZO) += lzo1x_decompress.o diff --git a/lib/rsa/Makefile b/lib/rsa/Makefile index decd6e5..693c745 100644 --- a/lib/rsa/Makefile +++ b/lib/rsa/Makefile @@ -7,26 +7,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)librsa.o - ifdef CONFIG_FIT_SIGNATURE -COBJS-$(CONFIG_RSA) += rsa-verify.o +obj-$(CONFIG_RSA) += rsa-verify.o endif - -COBJS := $(sort $(COBJS-y)) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/lib/tizen/Makefile b/lib/tizen/Makefile index 80d76cf..e1a9cf4 100644 --- a/lib/tizen/Makefile +++ b/lib/tizen/Makefile @@ -5,26 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libtizen.o - -SOBJS = - -COBJS-$(CONFIG_TIZEN) += tizen.o - -COBJS := $(sort $(COBJS-y)) -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_TIZEN) += tizen.o diff --git a/lib/zlib/Makefile b/lib/zlib/Makefile index b69e234..1e9e04d 100644 --- a/lib/zlib/Makefile +++ b/lib/zlib/Makefile @@ -5,24 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libz.o - -COBJS-$(CONFIG_ZLIB) += zlib.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_ZLIB) += zlib.o
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com --- disk/Makefile | 34 ++++++---------------------------- 1 file changed, 6 insertions(+), 28 deletions(-)
diff --git a/disk/Makefile b/disk/Makefile index 2b04e03..48abec8 100644 --- a/disk/Makefile +++ b/disk/Makefile @@ -5,33 +5,11 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - #CFLAGS += -DET_DEBUG -DDEBUG
-LIB = $(obj)libdisk.o - -COBJS-$(CONFIG_PARTITIONS) += part.o -COBJS-$(CONFIG_MAC_PARTITION) += part_mac.o -COBJS-$(CONFIG_DOS_PARTITION) += part_dos.o -COBJS-$(CONFIG_ISO_PARTITION) += part_iso.o -COBJS-$(CONFIG_AMIGA_PARTITION) += part_amiga.o -COBJS-$(CONFIG_EFI_PARTITION) += part_efi.o - -COBJS := $(COBJS-y) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_PARTITIONS) += part.o +obj-$(CONFIG_MAC_PARTITION) += part_mac.o +obj-$(CONFIG_DOS_PARTITION) += part_dos.o +obj-$(CONFIG_ISO_PARTITION) += part_iso.o +obj-$(CONFIG_AMIGA_PARTITION) += part_amiga.o +obj-$(CONFIG_EFI_PARTITION) += part_efi.o
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Simon Glass sjg@chromium.org --- arch/sandbox/cpu/Makefile | 23 +---------------------- arch/sandbox/lib/Makefile | 25 +------------------------ 2 files changed, 2 insertions(+), 46 deletions(-)
diff --git a/arch/sandbox/cpu/Makefile b/arch/sandbox/cpu/Makefile index e386867..404ff67 100644 --- a/arch/sandbox/cpu/Makefile +++ b/arch/sandbox/cpu/Makefile @@ -7,29 +7,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -COBJS := cpu.o os.o start.o state.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) +obj-y := cpu.o os.o start.o state.o
# os.c is build in the system environment, so needs standard includes $(obj)os.o: ALL_CFLAGS := $(filter-out -nostdinc,$(ALL_CFLAGS)) $(obj).depend.os: CPPFLAGS := $(filter-out -nostdinc,$(CPPFLAGS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/sandbox/lib/Makefile b/arch/sandbox/lib/Makefile index 993fb4e..4c1a38d 100644 --- a/arch/sandbox/lib/Makefile +++ b/arch/sandbox/lib/Makefile @@ -7,28 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-LIB = $(obj)lib$(ARCH).o - -COBJS-y += interrupts.o - -SRCS := $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS-y)) - -# Always build libsandbox.o -TARGETS := $(LIB) - -all: $(TARGETS) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += interrupts.o
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Wolfgang Denk wd@denx.de Cc: Stefan Roese sr@denx.de --- arch/powerpc/cpu/74xx_7xx/Makefile | 28 +--- arch/powerpc/cpu/mpc512x/Makefile | 51 ++------ arch/powerpc/cpu/mpc5xx/Makefile | 27 +--- arch/powerpc/cpu/mpc5xxx/Makefile | 54 +++----- arch/powerpc/cpu/mpc824x/Makefile | 28 +--- arch/powerpc/cpu/mpc8260/Makefile | 30 +---- arch/powerpc/cpu/mpc83xx/Makefile | 58 +++------ arch/powerpc/cpu/mpc85xx/Makefile | 233 +++++++++++++++------------------- arch/powerpc/cpu/mpc86xx/Makefile | 50 ++------ arch/powerpc/cpu/mpc8xx/Makefile | 58 +++------ arch/powerpc/cpu/mpc8xxx/Makefile | 30 +---- arch/powerpc/cpu/mpc8xxx/ddr/Makefile | 30 +---- arch/powerpc/cpu/ppc4xx/Makefile | 90 +++++-------- arch/powerpc/lib/Makefile | 78 ++++-------- 14 files changed, 266 insertions(+), 579 deletions(-)
diff --git a/arch/powerpc/cpu/74xx_7xx/Makefile b/arch/powerpc/cpu/74xx_7xx/Makefile index de9b4a7..f31fe75 100644 --- a/arch/powerpc/cpu/74xx_7xx/Makefile +++ b/arch/powerpc/cpu/74xx_7xx/Makefile @@ -8,28 +8,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -START = start.o -SOBJS = cache.o kgdb.o io.o -COBJS = traps.o cpu.o cpu_init.o speed.o interrupts.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y = start.o +obj-y = cache.o kgdb.o io.o +obj-y += traps.o cpu.o cpu_init.o speed.o interrupts.o diff --git a/arch/powerpc/cpu/mpc512x/Makefile b/arch/powerpc/cpu/mpc512x/Makefile index 1af9ab1..f770350 100644 --- a/arch/powerpc/cpu/mpc512x/Makefile +++ b/arch/powerpc/cpu/mpc512x/Makefile @@ -4,44 +4,21 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - $(shell mkdir -p $(OBJTREE)/board/freescale/common)
-LIB = $(obj)lib$(CPU).o - -START = start.o -COBJS-y := cpu.o -COBJS-y += traps.o -COBJS-y += cpu_init.o -COBJS-y += fixed_sdram.o -COBJS-y += i2c.o -COBJS-y += interrupts.o -COBJS-y += iopin.o -COBJS-y += serial.o -COBJS-y += speed.o -COBJS-$(CONFIG_FSL_DIU_FB) += diu.o -COBJS-$(CONFIG_CMD_IDE) += ide.o -COBJS-$(CONFIG_PCI) += pci.o +extra-y = start.o +obj-y := cpu.o +obj-y += traps.o +obj-y += cpu_init.o +obj-y += fixed_sdram.o +obj-y += i2c.o +obj-y += interrupts.o +obj-y += iopin.o +obj-y += serial.o +obj-y += speed.o +obj-$(CONFIG_FSL_DIU_FB) += diu.o +obj-$(CONFIG_CMD_IDE) += ide.o +obj-$(CONFIG_PCI) += pci.o
# Stub implementations of cache management functions for USB -COBJS-$(CONFIG_USB_EHCI) += cache.o - -COBJS := $(COBJS-y) -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_USB_EHCI) += cache.o diff --git a/arch/powerpc/cpu/mpc5xx/Makefile b/arch/powerpc/cpu/mpc5xx/Makefile index e3e50af..7b8826a 100644 --- a/arch/powerpc/cpu/mpc5xx/Makefile +++ b/arch/powerpc/cpu/mpc5xx/Makefile @@ -16,28 +16,5 @@ # uses the definitions made in arch/powerpc/cpu/mpc5xx/config.mk #
- -include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -START = start.o -COBJS = serial.o cpu.o cpu_init.o interrupts.o traps.o speed.o spi.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y = start.o +obj-y = serial.o cpu.o cpu_init.o interrupts.o traps.o speed.o spi.o diff --git a/arch/powerpc/cpu/mpc5xxx/Makefile b/arch/powerpc/cpu/mpc5xxx/Makefile index fc0b7a1..5c67e1d 100644 --- a/arch/powerpc/cpu/mpc5xxx/Makefile +++ b/arch/powerpc/cpu/mpc5xxx/Makefile @@ -5,44 +5,22 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -SSTART = start.o -CSTART = traps.o -SOBJS += io.o -SOBJS += firmware_sc_task_bestcomm.impl.o -COBJS-y += i2c.o -COBJS-y += cpu.o -COBJS-y += cpu_init.o -COBJS-y += ide.o -COBJS-y += interrupts.o -COBJS-y += loadtask.o -COBJS-y += pci_mpc5200.o -COBJS-y += serial.o -COBJS-y += speed.o -COBJS-$(CONFIG_CMD_USB) += usb_ohci.o -COBJS-$(CONFIG_CMD_USB) += usb.o +extra-y = start.o +extra-y += traps.o +obj-y += io.o +obj-y += firmware_sc_task_bestcomm.impl.o +obj-y += i2c.o +obj-y += cpu.o +obj-y += cpu_init.o +obj-y += ide.o +obj-y += interrupts.o +obj-y += loadtask.o +obj-y += pci_mpc5200.o +obj-y += serial.o +obj-y += speed.o +obj-$(CONFIG_CMD_USB) += usb_ohci.o +obj-$(CONFIG_CMD_USB) += usb.o
ifdef CONFIG_SPL_BUILD -COBJS-y += spl_boot.o +obj-y += spl_boot.o endif - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS-y)) -START := $(addprefix $(obj),$(SSTART) $(CSTART)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/powerpc/cpu/mpc824x/Makefile b/arch/powerpc/cpu/mpc824x/Makefile index 8f27aac..67b0d17 100644 --- a/arch/powerpc/cpu/mpc824x/Makefile +++ b/arch/powerpc/cpu/mpc824x/Makefile @@ -5,35 +5,15 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk ifneq ($(OBJTREE),$(SRCTREE)) $(shell mkdir -p $(obj)drivers/epic $(obj)drivers/i2c) endif
-LIB = $(obj)lib$(CPU).o - -START = start.o -COBJS = traps.o cpu.o cpu_init.o interrupts.o speed.o \ +extra-y = start.o +obj-y = traps.o cpu.o cpu_init.o interrupts.o speed.o \ drivers/epic/epic1.o drivers/i2c/i2c.o pci.o -COBJS_LN = bedbug_603e.o - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) $(addprefix $(obj),$(COBJS_LN:.o=.c)) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS) $(COBJS_LN)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) +obj-y += bedbug_603e.o
+SRCS += $(obj)bedbug_603e.c $(obj)bedbug_603e.c: ln -sf $(src)../mpc8260/bedbug_603e.c $(obj)bedbug_603e.c - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/powerpc/cpu/mpc8260/Makefile b/arch/powerpc/cpu/mpc8260/Makefile index d87eff6..5f33849 100644 --- a/arch/powerpc/cpu/mpc8260/Makefile +++ b/arch/powerpc/cpu/mpc8260/Makefile @@ -5,33 +5,9 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - -START = start.o kgdb.o -COBJS = traps.o serial_smc.o serial_scc.o cpu.o cpu_init.o speed.o \ +extra-y = start.o kgdb.o +obj-y = traps.o serial_smc.o serial_scc.o cpu.o cpu_init.o speed.o \ interrupts.o ether_fcc.o i2c.o commproc.o \ bedbug_603e.o pci.o spi.o
-COBJS-$(CONFIG_ETHER_ON_SCC) = ether_scc.o - -COBJS += $(COBJS-y) - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS) $(obj)kgdb.o) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_ETHER_ON_SCC) += ether_scc.o diff --git a/arch/powerpc/cpu/mpc83xx/Makefile b/arch/powerpc/cpu/mpc83xx/Makefile index 6341cd4..b7142f0 100644 --- a/arch/powerpc/cpu/mpc83xx/Makefile +++ b/arch/powerpc/cpu/mpc83xx/Makefile @@ -7,10 +7,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(CPU).o - MINIMAL=
ifdef CONFIG_SPL_BUILD @@ -19,48 +15,39 @@ MINIMAL=y endif endif
-START = start.o +extra-y = start.o
ifdef MINIMAL
-COBJS-y += spl_minimal.o +obj-y += spl_minimal.o
else
-COBJS-y += traps.o -COBJS-y += cpu.o -COBJS-y += cpu_init.o -COBJS-y += speed.o -COBJS-y += interrupts.o -COBJS-y += ecc.o -COBJS-$(CONFIG_QE) += qe_io.o -COBJS-$(CONFIG_FSL_SERDES) += serdes.o -COBJS-$(CONFIG_PCI) += pci.o -COBJS-$(CONFIG_PCIE) += pcie.o -COBJS-$(CONFIG_OF_LIBFDT) += fdt.o +obj-y += traps.o +obj-y += cpu.o +obj-y += cpu_init.o +obj-y += speed.o +obj-y += interrupts.o +obj-y += ecc.o +obj-$(CONFIG_QE) += qe_io.o +obj-$(CONFIG_FSL_SERDES) += serdes.o +obj-$(CONFIG_PCI) += pci.o +obj-$(CONFIG_PCIE) += pcie.o +obj-$(CONFIG_OF_LIBFDT) += fdt.o
# Stub implementations of cache management functions for USB -COBJS-y += cache.o +obj-y += cache.o
ifdef CONFIG_FSL_DDR2 -COBJS_LN-$(CONFIG_MPC8349) += ddr-gen2.o +obj-$(CONFIG_MPC8349) += ddr-gen2.o +SRCS += $(obj)ddr-gen2.c else -COBJS-y += spd_sdram.o +obj-y += spd_sdram.o endif -COBJS-$(CONFIG_FSL_DDR2) += law.o +obj-$(CONFIG_FSL_DDR2) += law.o
endif # not minimal
-COBJS := $(COBJS-y) -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) $(addprefix $(obj),$(COBJS_LN-y:.o=.c)) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS) $(COBJS_LN-y)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - $(obj)ddr-gen1.c: ln -sf $(SRCTREE)/arch/powerpc/cpu/mpc85xx/ddr-gen1.c $(obj)ddr-gen1.c
@@ -69,12 +56,3 @@ $(obj)ddr-gen2.c:
$(obj)ddr-gen3.c: ln -sf $(SRCTREE)/arch/powerpc/cpu/mpc85xx/ddr-gen3.c $(obj)ddr-gen3.c - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/powerpc/cpu/mpc85xx/Makefile b/arch/powerpc/cpu/mpc85xx/Makefile index f70f0d7..50ddb50 100644 --- a/arch/powerpc/cpu/mpc85xx/Makefile +++ b/arch/powerpc/cpu/mpc85xx/Makefile @@ -8,10 +8,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
ifdef CONFIG_SPL_BUILD @@ -20,149 +16,128 @@ MINIMAL=y endif endif
-START = start.o resetvec.o +extra-y = start.o resetvec.o
ifdef MINIMAL
-COBJS-y += cpu_init_early.o tlb.o spl_minimal.o +obj-y += cpu_init_early.o tlb.o spl_minimal.o
else
-SOBJS-$(CONFIG_MP) += release.o -SOBJS = $(SOBJS-y) +obj-$(CONFIG_MP) += release.o
-COBJS-$(CONFIG_CMD_ERRATA) += cmd_errata.o -COBJS-$(CONFIG_CPM2) += commproc.o +obj-$(CONFIG_CMD_ERRATA) += cmd_errata.o +obj-$(CONFIG_CPM2) += commproc.o
# supports ddr1 -COBJS-$(CONFIG_MPC8540) += ddr-gen1.o -COBJS-$(CONFIG_MPC8560) += ddr-gen1.o -COBJS-$(CONFIG_MPC8541) += ddr-gen1.o -COBJS-$(CONFIG_MPC8555) += ddr-gen1.o +obj-$(CONFIG_MPC8540) += ddr-gen1.o +obj-$(CONFIG_MPC8560) += ddr-gen1.o +obj-$(CONFIG_MPC8541) += ddr-gen1.o +obj-$(CONFIG_MPC8555) += ddr-gen1.o
# supports ddr1/2 -COBJS-$(CONFIG_MPC8548) += ddr-gen2.o -COBJS-$(CONFIG_MPC8568) += ddr-gen2.o -COBJS-$(CONFIG_MPC8544) += ddr-gen2.o +obj-$(CONFIG_MPC8548) += ddr-gen2.o +obj-$(CONFIG_MPC8568) += ddr-gen2.o +obj-$(CONFIG_MPC8544) += ddr-gen2.o
# supports ddr1/2/3 -COBJS-$(CONFIG_PPC_C29X) += ddr-gen3.o -COBJS-$(CONFIG_MPC8572) += ddr-gen3.o -COBJS-$(CONFIG_MPC8536) += ddr-gen3.o -COBJS-$(CONFIG_MPC8569) += ddr-gen3.o -COBJS-$(CONFIG_P1010) += ddr-gen3.o -COBJS-$(CONFIG_P1011) += ddr-gen3.o -COBJS-$(CONFIG_P1012) += ddr-gen3.o -COBJS-$(CONFIG_P1013) += ddr-gen3.o -COBJS-$(CONFIG_P1014) += ddr-gen3.o -COBJS-$(CONFIG_P1020) += ddr-gen3.o -COBJS-$(CONFIG_P1021) += ddr-gen3.o -COBJS-$(CONFIG_P1022) += ddr-gen3.o -COBJS-$(CONFIG_P1023) += ddr-gen3.o -COBJS-$(CONFIG_P1024) += ddr-gen3.o -COBJS-$(CONFIG_P1025) += ddr-gen3.o -COBJS-$(CONFIG_P2010) += ddr-gen3.o -COBJS-$(CONFIG_P2020) += ddr-gen3.o -COBJS-$(CONFIG_PPC_P2041) += ddr-gen3.o -COBJS-$(CONFIG_PPC_P3041) += ddr-gen3.o -COBJS-$(CONFIG_PPC_P4080) += ddr-gen3.o -COBJS-$(CONFIG_PPC_P5020) += ddr-gen3.o -COBJS-$(CONFIG_PPC_P5040) += ddr-gen3.o -COBJS-$(CONFIG_PPC_T4240) += ddr-gen3.o -COBJS-$(CONFIG_PPC_T4160) += ddr-gen3.o -COBJS-$(CONFIG_PPC_B4420) += ddr-gen3.o -COBJS-$(CONFIG_PPC_B4860) += ddr-gen3.o -COBJS-$(CONFIG_BSC9131) += ddr-gen3.o -COBJS-$(CONFIG_BSC9132) += ddr-gen3.o -COBJS-$(CONFIG_PPC_T1040) += ddr-gen3.o - -COBJS-$(CONFIG_CPM2) += ether_fcc.o -COBJS-$(CONFIG_OF_LIBFDT) += fdt.o -COBJS-$(CONFIG_FSL_CORENET) += liodn.o -COBJS-$(CONFIG_MP) += mp.o -COBJS-$(CONFIG_PCI) += pci.o -COBJS-$(CONFIG_SYS_DPAA_QBMAN) += portals.o +obj-$(CONFIG_PPC_C29X) += ddr-gen3.o +obj-$(CONFIG_MPC8572) += ddr-gen3.o +obj-$(CONFIG_MPC8536) += ddr-gen3.o +obj-$(CONFIG_MPC8569) += ddr-gen3.o +obj-$(CONFIG_P1010) += ddr-gen3.o +obj-$(CONFIG_P1011) += ddr-gen3.o +obj-$(CONFIG_P1012) += ddr-gen3.o +obj-$(CONFIG_P1013) += ddr-gen3.o +obj-$(CONFIG_P1014) += ddr-gen3.o +obj-$(CONFIG_P1020) += ddr-gen3.o +obj-$(CONFIG_P1021) += ddr-gen3.o +obj-$(CONFIG_P1022) += ddr-gen3.o +obj-$(CONFIG_P1023) += ddr-gen3.o +obj-$(CONFIG_P1024) += ddr-gen3.o +obj-$(CONFIG_P1025) += ddr-gen3.o +obj-$(CONFIG_P2010) += ddr-gen3.o +obj-$(CONFIG_P2020) += ddr-gen3.o +obj-$(CONFIG_PPC_P2041) += ddr-gen3.o +obj-$(CONFIG_PPC_P3041) += ddr-gen3.o +obj-$(CONFIG_PPC_P4080) += ddr-gen3.o +obj-$(CONFIG_PPC_P5020) += ddr-gen3.o +obj-$(CONFIG_PPC_P5040) += ddr-gen3.o +obj-$(CONFIG_PPC_T4240) += ddr-gen3.o +obj-$(CONFIG_PPC_T4160) += ddr-gen3.o +obj-$(CONFIG_PPC_B4420) += ddr-gen3.o +obj-$(CONFIG_PPC_B4860) += ddr-gen3.o +obj-$(CONFIG_BSC9131) += ddr-gen3.o +obj-$(CONFIG_BSC9132) += ddr-gen3.o +obj-$(CONFIG_PPC_T1040) += ddr-gen3.o + +obj-$(CONFIG_CPM2) += ether_fcc.o +obj-$(CONFIG_OF_LIBFDT) += fdt.o +obj-$(CONFIG_FSL_CORENET) += liodn.o +obj-$(CONFIG_MP) += mp.o +obj-$(CONFIG_PCI) += pci.o +obj-$(CONFIG_SYS_DPAA_QBMAN) += portals.o
# various SoC specific assignments -COBJS-$(CONFIG_PPC_P2041) += p2041_ids.o -COBJS-$(CONFIG_PPC_P3041) += p3041_ids.o -COBJS-$(CONFIG_PPC_P4080) += p4080_ids.o -COBJS-$(CONFIG_PPC_P5020) += p5020_ids.o -COBJS-$(CONFIG_PPC_P5040) += p5040_ids.o -COBJS-$(CONFIG_PPC_T4240) += t4240_ids.o -COBJS-$(CONFIG_PPC_T4160) += t4240_ids.o -COBJS-$(CONFIG_PPC_B4420) += b4860_ids.o -COBJS-$(CONFIG_PPC_B4860) += b4860_ids.o -COBJS-$(CONFIG_PPC_T1040) += t1040_ids.o - -COBJS-$(CONFIG_QE) += qe_io.o -COBJS-$(CONFIG_CPM2) += serial_scc.o -COBJS-$(CONFIG_SYS_FSL_QORIQ_CHASSIS1) += fsl_corenet_serdes.o -COBJS-$(CONFIG_SYS_FSL_QORIQ_CHASSIS2) += fsl_corenet2_serdes.o +obj-$(CONFIG_PPC_P2041) += p2041_ids.o +obj-$(CONFIG_PPC_P3041) += p3041_ids.o +obj-$(CONFIG_PPC_P4080) += p4080_ids.o +obj-$(CONFIG_PPC_P5020) += p5020_ids.o +obj-$(CONFIG_PPC_P5040) += p5040_ids.o +obj-$(CONFIG_PPC_T4240) += t4240_ids.o +obj-$(CONFIG_PPC_T4160) += t4240_ids.o +obj-$(CONFIG_PPC_B4420) += b4860_ids.o +obj-$(CONFIG_PPC_B4860) += b4860_ids.o +obj-$(CONFIG_PPC_T1040) += t1040_ids.o + +obj-$(CONFIG_QE) += qe_io.o +obj-$(CONFIG_CPM2) += serial_scc.o +obj-$(CONFIG_SYS_FSL_QORIQ_CHASSIS1) += fsl_corenet_serdes.o +obj-$(CONFIG_SYS_FSL_QORIQ_CHASSIS2) += fsl_corenet2_serdes.o
# SoC specific SERDES support -COBJS-$(CONFIG_PPC_C29X) += c29x_serdes.o -COBJS-$(CONFIG_MPC8536) += mpc8536_serdes.o -COBJS-$(CONFIG_MPC8544) += mpc8544_serdes.o -COBJS-$(CONFIG_MPC8548) += mpc8548_serdes.o -COBJS-$(CONFIG_MPC8568) += mpc8568_serdes.o -COBJS-$(CONFIG_MPC8569) += mpc8569_serdes.o -COBJS-$(CONFIG_MPC8572) += mpc8572_serdes.o -COBJS-$(CONFIG_P1010) += p1010_serdes.o -COBJS-$(CONFIG_P1011) += p1021_serdes.o -COBJS-$(CONFIG_P1012) += p1021_serdes.o -COBJS-$(CONFIG_P1013) += p1022_serdes.o -COBJS-$(CONFIG_P1014) += p1010_serdes.o -COBJS-$(CONFIG_P1017) += p1023_serdes.o -COBJS-$(CONFIG_P1020) += p1021_serdes.o -COBJS-$(CONFIG_P1021) += p1021_serdes.o -COBJS-$(CONFIG_P1022) += p1022_serdes.o -COBJS-$(CONFIG_P1023) += p1023_serdes.o -COBJS-$(CONFIG_P1024) += p1021_serdes.o -COBJS-$(CONFIG_P1025) += p1021_serdes.o -COBJS-$(CONFIG_P2010) += p2020_serdes.o -COBJS-$(CONFIG_P2020) += p2020_serdes.o -COBJS-$(CONFIG_PPC_P2041) += p2041_serdes.o -COBJS-$(CONFIG_PPC_P3041) += p3041_serdes.o -COBJS-$(CONFIG_PPC_P4080) += p4080_serdes.o -COBJS-$(CONFIG_PPC_P5020) += p5020_serdes.o -COBJS-$(CONFIG_PPC_P5040) += p5040_serdes.o -COBJS-$(CONFIG_PPC_T4240) += t4240_serdes.o -COBJS-$(CONFIG_PPC_T4160) += t4240_serdes.o -COBJS-$(CONFIG_PPC_B4420) += b4860_serdes.o -COBJS-$(CONFIG_PPC_B4860) += b4860_serdes.o -COBJS-$(CONFIG_BSC9132) += bsc9132_serdes.o -COBJS-$(CONFIG_PPC_T1040) += t1040_serdes.o - -COBJS-y += cpu.o -COBJS-y += cpu_init.o -COBJS-y += cpu_init_early.o -COBJS-y += interrupts.o -COBJS-y += speed.o -COBJS-y += tlb.o -COBJS-y += traps.o +obj-$(CONFIG_PPC_C29X) += c29x_serdes.o +obj-$(CONFIG_MPC8536) += mpc8536_serdes.o +obj-$(CONFIG_MPC8544) += mpc8544_serdes.o +obj-$(CONFIG_MPC8548) += mpc8548_serdes.o +obj-$(CONFIG_MPC8568) += mpc8568_serdes.o +obj-$(CONFIG_MPC8569) += mpc8569_serdes.o +obj-$(CONFIG_MPC8572) += mpc8572_serdes.o +obj-$(CONFIG_P1010) += p1010_serdes.o +obj-$(CONFIG_P1011) += p1021_serdes.o +obj-$(CONFIG_P1012) += p1021_serdes.o +obj-$(CONFIG_P1013) += p1022_serdes.o +obj-$(CONFIG_P1014) += p1010_serdes.o +obj-$(CONFIG_P1017) += p1023_serdes.o +obj-$(CONFIG_P1020) += p1021_serdes.o +obj-$(CONFIG_P1021) += p1021_serdes.o +obj-$(CONFIG_P1022) += p1022_serdes.o +obj-$(CONFIG_P1023) += p1023_serdes.o +obj-$(CONFIG_P1024) += p1021_serdes.o +obj-$(CONFIG_P1025) += p1021_serdes.o +obj-$(CONFIG_P2010) += p2020_serdes.o +obj-$(CONFIG_P2020) += p2020_serdes.o +obj-$(CONFIG_PPC_P2041) += p2041_serdes.o +obj-$(CONFIG_PPC_P3041) += p3041_serdes.o +obj-$(CONFIG_PPC_P4080) += p4080_serdes.o +obj-$(CONFIG_PPC_P5020) += p5020_serdes.o +obj-$(CONFIG_PPC_P5040) += p5040_serdes.o +obj-$(CONFIG_PPC_T4240) += t4240_serdes.o +obj-$(CONFIG_PPC_T4160) += t4240_serdes.o +obj-$(CONFIG_PPC_B4420) += b4860_serdes.o +obj-$(CONFIG_PPC_B4860) += b4860_serdes.o +obj-$(CONFIG_BSC9132) += bsc9132_serdes.o +obj-$(CONFIG_PPC_T1040) += t1040_serdes.o + +obj-y += cpu.o +obj-y += cpu_init.o +obj-y += cpu_init_early.o +obj-y += interrupts.o +obj-y += speed.o +obj-y += tlb.o +obj-y += traps.o
endif # not minimal - -COBJS = $(COBJS-y) - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/powerpc/cpu/mpc86xx/Makefile b/arch/powerpc/cpu/mpc86xx/Makefile index 04271b0..bcb786d 100644 --- a/arch/powerpc/cpu/mpc86xx/Makefile +++ b/arch/powerpc/cpu/mpc86xx/Makefile @@ -8,42 +8,20 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk +extra-y = start.o +extra-y += traps.o
-LIB = $(obj)lib$(CPU).o +obj-y += cache.o +obj-$(CONFIG_MP) += release.o
-SSTART = start.o -CSTART = traps.o - -SOBJS-y += cache.o -SOBJS-$(CONFIG_MP) += release.o - -COBJS-y += cpu.o -COBJS-y += cpu_init.o +obj-y += cpu.o +obj-y += cpu_init.o # 8610 & 8641 are identical w/regards to DDR -COBJS-$(CONFIG_MPC8610) += ddr-8641.o -COBJS-$(CONFIG_MPC8641) += ddr-8641.o -COBJS-$(CONFIG_OF_LIBFDT) += fdt.o -COBJS-y += interrupts.o -COBJS-$(CONFIG_MP) += mp.o -COBJS-$(CONFIG_MPC8610) += mpc8610_serdes.o -COBJS-$(CONFIG_MPC8641) += mpc8641_serdes.o -COBJS-y += speed.o - -SRCS := $(START:.o=.S) $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) -START := $(addprefix $(obj),$(SSTART) $(CSTART)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-$(CONFIG_MPC8610) += ddr-8641.o +obj-$(CONFIG_MPC8641) += ddr-8641.o +obj-$(CONFIG_OF_LIBFDT) += fdt.o +obj-y += interrupts.o +obj-$(CONFIG_MP) += mp.o +obj-$(CONFIG_MPC8610) += mpc8610_serdes.o +obj-$(CONFIG_MPC8641) += mpc8641_serdes.o +obj-y += speed.o diff --git a/arch/powerpc/cpu/mpc8xx/Makefile b/arch/powerpc/cpu/mpc8xx/Makefile index 71d5e30..d40bdab 100644 --- a/arch/powerpc/cpu/mpc8xx/Makefile +++ b/arch/powerpc/cpu/mpc8xx/Makefile @@ -5,45 +5,23 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - # CFLAGS += -DET_DEBUG
-LIB = $(obj)lib$(CPU).o - -SSTART-y += start.o -CSTART-y += traps.o -COBJS-y += bedbug_860.o -COBJS-y += commproc.o -COBJS-y += cpu.o -COBJS-y += cpu_init.o -COBJS-y += fec.o -COBJS-$(CONFIG_OF_LIBFDT) += fdt.o -COBJS-y += i2c.o -COBJS-y += interrupts.o -COBJS-y += scc.o -COBJS-y += serial.o -COBJS-y += speed.o -COBJS-y += spi.o -COBJS-y += upatch.o -COBJS-y += video.o -SOBJS-y += kgdb.o -SOBJS-y += plprcr_write.o - -SRCS := $(SSTART-y:.o=.S) $(CSTART-y:.o=.c) $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) -START := $(addprefix $(obj),$(SSTART-y) $(CSTART-y)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +extra-y += start.o +extra-y += traps.o +obj-y += bedbug_860.o +obj-y += commproc.o +obj-y += cpu.o +obj-y += cpu_init.o +obj-y += fec.o +obj-$(CONFIG_OF_LIBFDT) += fdt.o +obj-y += i2c.o +obj-y += interrupts.o +obj-y += scc.o +obj-y += serial.o +obj-y += speed.o +obj-y += spi.o +obj-y += upatch.o +obj-y += video.o +obj-y += kgdb.o +obj-y += plprcr_write.o diff --git a/arch/powerpc/cpu/mpc8xxx/Makefile b/arch/powerpc/cpu/mpc8xxx/Makefile index 3dc8e05..395fed1 100644 --- a/arch/powerpc/cpu/mpc8xxx/Makefile +++ b/arch/powerpc/cpu/mpc8xxx/Makefile @@ -6,10 +6,6 @@ # Version 2 as published by the Free Software Foundation. #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib8xxx.o - MINIMAL=
ifdef CONFIG_SPL_BUILD @@ -20,30 +16,18 @@ endif
ifdef MINIMAL
-COBJS-$(CONFIG_FSL_LAW) += law.o +obj-$(CONFIG_FSL_LAW) += law.o
else
ifneq ($(CPU),mpc83xx) -COBJS-y += cpu.o +obj-y += cpu.o endif
-COBJS-$(CONFIG_OF_LIBFDT) += fdt.o -COBJS-$(CONFIG_FSL_IFC) += fsl_ifc.o -COBJS-$(CONFIG_FSL_LBC) += fsl_lbc.o -COBJS-$(CONFIG_SYS_SRIO) += srio.o -COBJS-$(CONFIG_FSL_LAW) += law.o +obj-$(CONFIG_OF_LIBFDT) += fdt.o +obj-$(CONFIG_FSL_IFC) += fsl_ifc.o +obj-$(CONFIG_FSL_LBC) += fsl_lbc.o +obj-$(CONFIG_SYS_SRIO) += srio.o +obj-$(CONFIG_FSL_LAW) += law.o
endif - -SRCS := $(START:.o=.S) $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend diff --git a/arch/powerpc/cpu/mpc8xxx/ddr/Makefile b/arch/powerpc/cpu/mpc8xxx/ddr/Makefile index 29523aa..8cbc06c 100644 --- a/arch/powerpc/cpu/mpc8xxx/ddr/Makefile +++ b/arch/powerpc/cpu/mpc8xxx/ddr/Makefile @@ -6,17 +6,13 @@ # Version 2 as published by the Free Software Foundation. #
-include $(TOPDIR)/config.mk - -LIB = $(obj)libddr.o - -COBJS-$(CONFIG_FSL_DDR1) += main.o util.o ctrl_regs.o options.o \ +obj-$(CONFIG_FSL_DDR1) += main.o util.o ctrl_regs.o options.o \ lc_common_dimm_params.o
-COBJS-$(CONFIG_FSL_DDR2) += main.o util.o ctrl_regs.o options.o \ +obj-$(CONFIG_FSL_DDR2) += main.o util.o ctrl_regs.o options.o \ lc_common_dimm_params.o
-COBJS-$(CONFIG_FSL_DDR3) += main.o util.o ctrl_regs.o options.o \ +obj-$(CONFIG_FSL_DDR3) += main.o util.o ctrl_regs.o options.o \ lc_common_dimm_params.o ifdef CONFIG_DDR_SPD SPD := y @@ -25,21 +21,9 @@ ifdef CONFIG_SPD_EEPROM SPD := y endif ifdef SPD -COBJS-$(CONFIG_FSL_DDR1) += ddr1_dimm_params.o -COBJS-$(CONFIG_FSL_DDR2) += ddr2_dimm_params.o -COBJS-$(CONFIG_FSL_DDR3) += ddr3_dimm_params.o +obj-$(CONFIG_FSL_DDR1) += ddr1_dimm_params.o +obj-$(CONFIG_FSL_DDR2) += ddr2_dimm_params.o +obj-$(CONFIG_FSL_DDR3) += ddr3_dimm_params.o endif
-COBJS-$(CONFIG_FSL_DDR_INTERACTIVE) += interactive.o - -SRCS := $(START:.o=.S) $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) - -all: $(obj).depend $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend +obj-$(CONFIG_FSL_DDR_INTERACTIVE) += interactive.o diff --git a/arch/powerpc/cpu/ppc4xx/Makefile b/arch/powerpc/cpu/ppc4xx/Makefile index d38b4aa..14b520f 100644 --- a/arch/powerpc/cpu/ppc4xx/Makefile +++ b/arch/powerpc/cpu/ppc4xx/Makefile @@ -5,71 +5,49 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk +extra-y := resetvec.o +extra-y += start.o
-LIB = $(obj)lib$(CPU).o +obj-y := cache.o +obj-y += dcr.o +obj-y += kgdb.o
-START := resetvec.o -START += start.o - -SOBJS := cache.o -SOBJS += dcr.o -SOBJS += kgdb.o - -COBJS := 40x_spd_sdram.o +obj-y += 40x_spd_sdram.o
ifndef CONFIG_NAND_SPL ifndef CONFIG_NAND_U_BOOT -COBJS += 44x_spd_ddr.o +obj-y += 44x_spd_ddr.o endif endif -COBJS-$(CONFIG_SDRAM_PPC4xx_IBM_DDR2) += 44x_spd_ddr2.o -COBJS-$(CONFIG_PPC4xx_DDR_AUTOCALIBRATION) += 4xx_ibm_ddr2_autocalib.o -COBJS += 4xx_pci.o -COBJS += 4xx_pcie.o -COBJS += bedbug_405.o -COBJS-$(CONFIG_CMD_CHIP_CONFIG) += cmd_chip_config.o -COBJS += cpu.o -COBJS += cpu_init.o -COBJS += denali_data_eye.o -COBJS += denali_spd_ddr2.o -COBJS += ecc.o -COBJS-$(CONFIG_CMD_ECCTEST) += cmd_ecctest.o -COBJS += fdt.o -COBJS += interrupts.o -COBJS-$(CONFIG_CMD_REGINFO) += reginfo.o -COBJS += sdram.o -COBJS += speed.o -COBJS += tlb.o -COBJS += traps.o -COBJS += usb.o -COBJS += usb_ohci.o -COBJS-$(CONFIG_XILINX_440) += xilinx_irq.o +obj-$(CONFIG_SDRAM_PPC4xx_IBM_DDR2) += 44x_spd_ddr2.o +obj-$(CONFIG_PPC4xx_DDR_AUTOCALIBRATION) += 4xx_ibm_ddr2_autocalib.o +obj-y += 4xx_pci.o +obj-y += 4xx_pcie.o +obj-y += bedbug_405.o +obj-$(CONFIG_CMD_CHIP_CONFIG) += cmd_chip_config.o +obj-y += cpu.o +obj-y += cpu_init.o +obj-y += denali_data_eye.o +obj-y += denali_spd_ddr2.o +obj-y += ecc.o +obj-$(CONFIG_CMD_ECCTEST) += cmd_ecctest.o +obj-y += fdt.o +obj-y += interrupts.o +obj-$(CONFIG_CMD_REGINFO) += reginfo.o +obj-y += sdram.o +obj-y += speed.o +obj-y += tlb.o +obj-y += traps.o +obj-y += usb.o +obj-y += usb_ohci.o +obj-$(CONFIG_XILINX_440) += xilinx_irq.o ifndef CONFIG_XILINX_440 -COBJS += 4xx_uart.o -COBJS += gpio.o -COBJS += miiphy.o -COBJS += uic.o +obj-y += 4xx_uart.o +obj-y += gpio.o +obj-y += miiphy.o +obj-y += uic.o endif
ifdef CONFIG_SPL_BUILD -COBJS-y += spl_boot.o +obj-y += spl_boot.o endif - -SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS) $(COBJS-y)) -START := $(addprefix $(obj),$(START)) - -all: $(obj).depend $(START) $(LIB) - -$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/arch/powerpc/lib/Makefile b/arch/powerpc/lib/Makefile index 8815292..a706d3c 100644 --- a/arch/powerpc/lib/Makefile +++ b/arch/powerpc/lib/Makefile @@ -5,23 +5,14 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - ## Build a couple of necessary functions into a private libgcc -LIBGCC = $(obj)libgcc.o -GLSOBJS += _ashldi3.o -GLSOBJS += _ashrdi3.o -GLSOBJS += _lshrdi3.o -LGOBJS := $(addprefix $(obj),$(GLSOBJS)) \ - $(addprefix $(obj),$(GLCOBJS)) - -## But only build it if the user asked for it +## if the user asked for it ifdef USE_PRIVATE_LIBGCC -TARGETS += $(LIBGCC) +lib-y += _ashldi3.o +lib-y += _ashrdi3.o +lib-y += _lshrdi3.o endif
-LIB = $(obj)lib$(ARCH).o - MINIMAL=
ifdef CONFIG_SPL_BUILD @@ -31,29 +22,29 @@ endif endif
ifdef MINIMAL -COBJS-y += cache.o time.o -SOBJS-y += ticks.o +obj-y += cache.o time.o +obj-y += ticks.o else
-SOBJS-y += ppcstring.o +obj-y += ppcstring.o
-SOBJS-y += ppccache.o -SOBJS-y += ticks.o -SOBJS-y += reloc.o +obj-y += ppccache.o +obj-y += ticks.o +obj-y += reloc.o
-COBJS-$(CONFIG_BAT_RW) += bat_rw.o +obj-$(CONFIG_BAT_RW) += bat_rw.o ifndef CONFIG_SPL_BUILD ifndef CONFIG_SYS_GENERIC_BOARD -COBJS-y += board.o +obj-y += board.o endif endif -COBJS-$(CONFIG_CMD_BOOTM) += bootm.o -COBJS-y += cache.o -COBJS-y += extable.o -COBJS-y += interrupts.o -COBJS-$(CONFIG_CMD_KGDB) += kgdb.o -COBJS-${CONFIG_CMD_IDE} += ide.o -COBJS-y += time.o +obj-$(CONFIG_CMD_BOOTM) += bootm.o +obj-y += cache.o +obj-y += extable.o +obj-y += interrupts.o +obj-$(CONFIG_CMD_KGDB) += kgdb.o +obj-$(CONFIG_CMD_IDE) += ide.o +obj-y += time.o
# Don't include the MPC5xxx special memcpy into the # SPL U-Boot image. memcpy is used in the SPL NOR @@ -64,41 +55,16 @@ ifndef CONFIG_SPL_BUILD # on MPC512x and MPC5200 ifdef CONFIG_MPC512X $(obj)ppcstring.o: AFLAGS += -Dmemcpy=__memcpy -COBJS-y += memcpy_mpc5200.o +obj-y += memcpy_mpc5200.o endif ifdef CONFIG_MPC5200 $(obj)ppcstring.o: AFLAGS += -Dmemcpy=__memcpy -COBJS-y += memcpy_mpc5200.o +obj-y += memcpy_mpc5200.o endif endif
endif # not minimal
ifdef CONFIG_SPL_BUILD -COBJS-$(CONFIG_SPL_FRAMEWORK) += spl.o +obj-$(CONFIG_SPL_FRAMEWORK) += spl.o endif - -COBJS += $(sort $(COBJS-y)) - -SRCS := $(GLSOBJS:.o=.S) $(GLCOBJS:.o=.c) \ - $(SOBJS-y:.o=.S) $(COBJS-y:.o=.c) -OBJS := $(addprefix $(obj),$(SOBJS-y) $(COBJS-y)) - -TARGETS += $(LIB) - -all: $(TARGETS) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -$(LIBGCC): $(obj).depend $(LGOBJS) - $(call cmd_link_o_target, $(LGOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -#########################################################################
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Tom Rini trini@ti.com --- board/ti/am335x/Makefile | 29 ++--------------------------- board/ti/am3517crane/Makefile | 19 +------------------ board/ti/am43xx/Makefile | 29 ++--------------------------- board/ti/beagle/Makefile | 24 ++---------------------- board/ti/dra7xx/Makefile | 27 +-------------------------- board/ti/evm/Makefile | 19 +------------------ board/ti/omap1510inn/Makefile | 24 ++---------------------- board/ti/omap5912osk/Makefile | 24 ++---------------------- board/ti/omap5_uevm/Makefile | 27 +-------------------------- board/ti/omap730p2/Makefile | 24 ++---------------------- board/ti/panda/Makefile | 21 +-------------------- board/ti/sdp3430/Makefile | 21 +-------------------- board/ti/sdp4430/Makefile | 23 ++--------------------- board/ti/ti814x/Makefile | 29 ++--------------------------- board/ti/ti816x/Makefile | 27 +-------------------------- board/ti/tnetv107xevm/Makefile | 25 +------------------------ 16 files changed, 24 insertions(+), 368 deletions(-)
diff --git a/board/ti/am335x/Makefile b/board/ti/am335x/Makefile index 3dbeeda..c8b4f9a 100644 --- a/board/ti/am335x/Makefile +++ b/board/ti/am335x/Makefile @@ -6,33 +6,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - ifeq ($(CONFIG_SPL_BUILD)$(CONFIG_NOR_BOOT),y) -COBJS := mux.o +obj-y := mux.o endif
-COBJS += board.o -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -clean: - rm -f $(SOBJS) $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak $(obj).depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += board.o diff --git a/board/ti/am3517crane/Makefile b/board/ti/am3517crane/Makefile index d9ab72a..9da795d 100644 --- a/board/ti/am3517crane/Makefile +++ b/board/ti/am3517crane/Makefile @@ -8,21 +8,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := am3517crane.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend +obj-y := am3517crane.o diff --git a/board/ti/am43xx/Makefile b/board/ti/am43xx/Makefile index 4a1bb7c..cb5fe88 100644 --- a/board/ti/am43xx/Makefile +++ b/board/ti/am43xx/Makefile @@ -6,33 +6,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - ifdef CONFIG_SPL_BUILD -COBJS := mux.o +obj-y := mux.o endif
-COBJS += board.o -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -clean: - rm -f $(SOBJS) $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak $(obj).depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += board.o diff --git a/board/ti/beagle/Makefile b/board/ti/beagle/Makefile index 3018f6c..9f55e8f 100644 --- a/board/ti/beagle/Makefile +++ b/board/ti/beagle/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS-y := $(BOARD).o -COBJS-$(CONFIG_STATUS_LED) += led.o - -COBJS := $(sort $(COBJS-y)) -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := $(BOARD).o +obj-$(CONFIG_STATUS_LED) += led.o diff --git a/board/ti/dra7xx/Makefile b/board/ti/dra7xx/Makefile index e558f4c..434e8d1 100644 --- a/board/ti/dra7xx/Makefile +++ b/board/ti/dra7xx/Makefile @@ -5,29 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := evm.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -clean: - rm -f $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak $(obj).depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := evm.o diff --git a/board/ti/evm/Makefile b/board/ti/evm/Makefile index 0f8cf44..b88ab8f 100644 --- a/board/ti/evm/Makefile +++ b/board/ti/evm/Makefile @@ -5,21 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := evm.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend +obj-y := evm.o diff --git a/board/ti/omap1510inn/Makefile b/board/ti/omap1510inn/Makefile index ad5a7eb..8256e81 100644 --- a/board/ti/omap1510inn/Makefile +++ b/board/ti/omap1510inn/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := omap1510innovator.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := omap1510innovator.o +obj-y += lowlevel_init.o diff --git a/board/ti/omap5912osk/Makefile b/board/ti/omap5912osk/Makefile index b2727de..d7c0ebd 100644 --- a/board/ti/omap5912osk/Makefile +++ b/board/ti/omap5912osk/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := omap5912osk.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := omap5912osk.o +obj-y += lowlevel_init.o diff --git a/board/ti/omap5_uevm/Makefile b/board/ti/omap5_uevm/Makefile index 2ab40e3..b88ab8f 100644 --- a/board/ti/omap5_uevm/Makefile +++ b/board/ti/omap5_uevm/Makefile @@ -5,29 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := evm.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -clean: - rm -f $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak $(obj).depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := evm.o diff --git a/board/ti/omap730p2/Makefile b/board/ti/omap730p2/Makefile index 37a4d34..8242f3d 100644 --- a/board/ti/omap730p2/Makefile +++ b/board/ti/omap730p2/Makefile @@ -5,25 +5,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := omap730p2.o flash.o -SOBJS := lowlevel_init.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := omap730p2.o flash.o +obj-y += lowlevel_init.o diff --git a/board/ti/panda/Makefile b/board/ti/panda/Makefile index 1e489d2..c89f80d 100644 --- a/board/ti/panda/Makefile +++ b/board/ti/panda/Makefile @@ -5,23 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := panda.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := panda.o diff --git a/board/ti/sdp3430/Makefile b/board/ti/sdp3430/Makefile index e72485c..753f099 100644 --- a/board/ti/sdp3430/Makefile +++ b/board/ti/sdp3430/Makefile @@ -5,23 +5,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := sdp.o - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := sdp.o diff --git a/board/ti/sdp4430/Makefile b/board/ti/sdp4430/Makefile index c522a2b..79e67b6 100644 --- a/board/ti/sdp4430/Makefile +++ b/board/ti/sdp4430/Makefile @@ -5,27 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := sdp.o +obj-y := sdp.o
ifndef CONFIG_SPL_BUILD -COBJS += cmd_bat.o +obj-y += cmd_bat.o endif - -SRCS := $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### diff --git a/board/ti/ti814x/Makefile b/board/ti/ti814x/Makefile index 6059e20..93155de 100644 --- a/board/ti/ti814x/Makefile +++ b/board/ti/ti814x/Makefile @@ -6,33 +6,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-COBJS += evm.o -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -clean: - rm -f $(SOBJS) $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak $(obj).depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += evm.o diff --git a/board/ti/ti816x/Makefile b/board/ti/ti816x/Makefile index 17ce72a..f1cc3d5 100644 --- a/board/ti/ti816x/Makefile +++ b/board/ti/ti816x/Makefile @@ -9,29 +9,4 @@ # SPDX-License-Identifier: GPL-2.0 #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS := evm.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) - -$(LIB): $(obj).depend $(OBJS) - $(call cmd_link_o_target, $(OBJS)) - -clean: - rm -f $(OBJS) - -distclean: clean - rm -f $(LIB) core *.bak $(obj).depend - -######################################################################### - -# defines $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y := evm.o diff --git a/board/ti/tnetv107xevm/Makefile b/board/ti/tnetv107xevm/Makefile index 5b82e48..0a6128f 100644 --- a/board/ti/tnetv107xevm/Makefile +++ b/board/ti/tnetv107xevm/Makefile @@ -2,27 +2,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-include $(TOPDIR)/config.mk - -LIB = $(obj)lib$(BOARD).o - -COBJS += sdb_board.o - -SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) -OBJS := $(addprefix $(obj),$(COBJS)) -SOBJS := $(addprefix $(obj),$(SOBJS)) - -.PHONY: all - -all: $(LIB) - -$(LIB): $(obj).depend $(OBJS) $(SOBJS) - $(call cmd_link_o_target, $(OBJS) $(SOBJS)) - -######################################################################### -# This is for $(obj).depend target -include $(SRCTREE)/rules.mk - -sinclude $(obj).depend - -######################################################################### +obj-y += sdb_board.o
0002-0019 change sub makefiles into a Kbuild suitable form using obj-y. In order to avoid creating a big patch file, they are divided by CPU architectures and categories.
0002-0007: refactor under arch/arm/ 0008-0016: refactor libraries which are common for all architectures 0017 : refactor under arch/powerpc/ 0018 : refactor under board/ti/
Please let me correct this part.
0017 : refactor under arch/sandbox 0018 : refactor under arch/powerpc/ 0019 : refactor under board/ti/
Best Regards Masahiro Yamada
On Sun, Sep 08, 2013 at 10:42 +0900, Masahiro Yamada wrote:
First of all, this series convert makefiles in sub directories to Kbuild style.
What this series do is quite simple:
- Moving common lines in sub makefiles to a new file 'scripts/Makefile.build'
- Renaming COBJS-y and SOBJS-y to obj-y in each sub makefile.
- A little bit more tweaks
That's all.
OK, so you claim that nothing changes, except for the build instructions, and that this is done in routine ways following simple rules. Source code need not get touched and is not affected, features aren't broken, migration can be done in several steps, etc ... (this is a good thing, see below)
Note1: This series breaks _NO_ features in U-Boot. Beucase it just moves common parts into scripts/Makefile.build
I believe no boards are broken by this refactoring, but it is humans who can make a mistake. So, it is very important to do build check before patches are applied.
I tested for ARM and Sandbox like this:
$ CROSS_COMPILE_ARM=arm-linux-gnueabi- ./MAKEALL -a arm -a sandbox
and I got:
--------------------- SUMMARY ---------------------------- Boards compiled: 336 ----------------------------------------------------------
This test only proves that the code compiles, nothing else. Even for a single board you may not run-test all features, given the many functions and high interactivity and options that U-Boot provides. This becomes worse when your change affects several more boards or even the whole tree (which is the case here).
I'd suggest a more formal approach to test or verification. Being able to build the code (not having broken the compile phase) is just a prerequisite. But you want to prove that no harm was done, i.e. that the code still is operational (at least that it works as good as it did before the manipulation).
For editor sweep types of changes (for example renaming identifiers while program flow and logic won't change) one may verify that the changed textual representation of the source still results in the same output for the machine. This can be achieved by e.g. md5 summing the object files or executables (there may be differences, but only in the "envelope" which carries timestamps or filenames, not in the generated code itself).
Can you come up with a way to map executables generated by one approach to executables generated by the other approach? If you still output the same set of files in the same locations, this might already be given. Can you then programmatically compare the output files (either objects, or executables, depending on which has less "false positives" or which involves less manual comparison steps)? This dramatically would increase certainty that your modification does no harm, and is desirable.
Verifying that your modification to the build instructions still results in the same binary output -- if done programmatically -- can free you of having to run-test the software (which is complex, or impossible in the absence of hardware), and judge whether you liked the result (which may be non-trivial as well when you don't know what to expect). Identical binary output allows you to claim that the software will work the way it did before your change without doubt. :)
I could not test other architectures because I don't have suitable compiler. Especially PowerPC boards must be checked since I changed under arch/powerpc/ in 0017. I will be grateful for any custodians' help.
Getting cross compilers for other architectures should be easy. There's a prebuilt collection at kernel.org, so that you just need to download any of them as the need arises. See ftp://ftp.kernel.org/pub/tools/crosstool/
virtually yours Gerhard Sittig
Hello Gerhard.
I thought compiling with no errors/warnings means no harm because no source files except makefiles were touched in this patch series.
That's why I believed the only build check is sufficient and I did not try run-test.
But your suggestion sounds interesting. If we could programmatically compare the generated executables in an easy way, that would be worth checking.
So I gave it a try. Finally it turned out to be much harder than I had expected. (Almost nightware)
Anyway, let's see what I did one by one.
(1) Time stamp
Because U-boot executable includes a timestamp, Everytime U-Boot is compiled, include/generated/timestamp_autogenerated.h is updated, which results in different outcome.
So, I tweaked include/timestamp.h not to include it:
#ifndef DO_DEPS_ONLY -#include "generated/timestamp_autogenerated.h" +/* #include "generated/timestamp_autogenerated.h" */ +#define U_BOOT_DATE "DUMMY" +#define U_BOOT_TIME "DUMMY" #endif
(2) Git commit hash
Git commit hash is contained in include/generated/version_autogenerated.h. So, I also modified include/version.h not to include it as follows:
#ifndef DO_DEPS_ONLY -#include "generated/version_autogenerated.h" +/* #include "generated/version_autogenerated.h" */ +#define PLAIN_VERSION "__DUMMY__" +#define U_BOOT_VERSION "__DUMMY__" +#define CC_VERSION_STRING "__DUMMY__" +#define LD_VERSION_STRING "__DUMMY__" #endif
(3) Show md5sum
I added a line to MAKEALL script to show md5sum of u-boot and u-boot-spl.
${CROSS_COMPILE}size ${OBJS} | tee -a ${LOG_DIR}/$target.MAKELOG
+ md5sum ${OBJS} + [ -e "${LOG_DIR}/${target}.ERR" ] && cat "${LOG_DIR}/${target}.ERR"
(4) Make sure to build in the same path
The output executables (ELF) depends on the directory path where it was built. (Of course, the "u-boot.bin" does not carry this information.) So, we need to make sure to build in the same path in order to get indentical ELF files.
(5) Take care of the difference of symbols order
The output file depends on the order of the object files at the link stage. Even if you change the order of the *.o files, you can still get a correct outcome. But now we want to compare md5sum, so we must keep the same order.
Let's closely look some makefiles.
Some of makefiles sort object files before linking, and others do not.
For example, let's see "common/Makefile" first.
COBJS := $(sort $(COBJS-y)) ---< snip >--- OBJS := $(addprefix $(obj),$(COBJS)) ---< snip >--- $(LIB): $(obj).depend $(OBJS) $(call cmd_link_o_target, $(OBJS))
Before linked into common/libcommon.o, the object files are sorted in alphabetical order by $(sort ...) function.
For another example, let's take a look arch/arm/cpu/armv7/am33xx/Makefile.
COBJS-$(CONFIG_AM33XX) += clock_am33xx.o COBJS-$(CONFIG_TI814X) += clock_ti814x.o COBJS-$(CONFIG_AM43XX) += clock_am43xx.o
ifneq ($(CONFIG_AM43XX)$(CONFIG_AM33XX),) COBJS += clock.o endif
COBJS-$(CONFIG_TI816X) += clock_ti816x.o COBJS += sys_info.o COBJS += mem.o COBJS += ddr.o COBJS += emif4.o COBJS += board.o COBJS += mux.o COBJS-$(CONFIG_NAND_OMAP_GPMC) += elm.o
SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(COBJS) $(COBJS-y) $(SOBJS))
Be aware that both "COBJS-y" and "COBJS" are used and $(COBJS) $(COBJS-y) are added in this order to $(OBJS). So the resulting $(OBJS) contains the *.o files in the following order: clock.o sys_info.o mem.o ddr.o emif4.o board.o mux.o clock_am33xx.o clock_ti814.o .....
In this commit series, I converted both COBJS-y and COBJS into obj-y. So, after applying this patch series, the object files are listed in different order.
In the conventional U-Boot Makefiles, the order of object files which are linked together is depending on makefiles.
- Some of them sort objects in alphabetical order with $(sort ...) function. - Some of them keep the order in which they apper. - Other cases (like arch/arm/cpu/armv7/am33xx/Makefile)
This variation makes it very difficult to programatically compare the output files.
So, I standerdized the order of the object files to alphabetical order. I added $(sort ...) function to the linkage rule in each sub makefile like follows:
$(LIB): $(OBJS) - $(call cmd_link_o_target, $(OBJS)) + $(call cmd_link_o_target, $(sort $(OBJS)))
(6) Another timestamp problem
Even after I eliminated a timestamp header problem in (1), I still found a board that produces different output at every compile.
See board/cray/L1/Makefile.
---< snip >--- $(obj)bootscript.c: $(obj)bootscript.image od -t x1 -v -A x $^ | awk -f x2c.awk > $@
$(obj)bootscript.image: $(src)bootscript.hush $(src)Makefile -$(OBJTREE)/tools/mkimage -A ppc -O linux -T script -C none -a 0 -e 0 -n bootscript -d (src)bootscript.hush $@ ---< snip >---
The source code, board/cray/L1/bootscript.c is generated from board/cray/L1/bootscript.image. The timestamp information is embedded in bootscript.image by mkimage tool.
I gave up to solve this problem.
(7) Fix PowerPC code
I am only familiar with ARM architecture, but anyway I needed to compile over all architectures. While working on PowerPC, I noticed lots of PowerPC boards failed in compiling on v2013-10-rc2 tag.
What I did is:
CROSS_COMPILE_POWERPC=powerpc-linux-gnu- ./MAKEALL -a powerpc
The result is:
--------------------- SUMMARY ---------------------------- Boards compiled: 660 Boards with errors: 139 ( HWW1U1A MPC8572DS MPC8572DS_36BIT MPC8572DS_NAND P1020MBG-PC P1020MBG-PC_36BIT P1020MBG-PC_36BIT_SDCARD P1020MBG-PC_SDCARD P1020RDB P1020RDB_36BIT P1020RDB_36BIT_SDCARD P1020RDB_36BIT_SPIFLASH P1020RDB_NAND P1020RDB-PC P1020RDB-PC_36BIT P1020RDB-PC_36BIT_NAND P1020RDB-PC_36BIT_SDCARD P1020RDB-PC_36BIT_SPIFLASH P1020RDB-PC_NAND P1020RDB-PC_SDCARD P1020RDB-PC_SPIFLASH P1020RDB_SDCARD P1020RDB_SPIFLASH P1020RDB-PD P1020RDB-PD_NAND P1020RDB-PD_SDCARD P1020RDB-PD_SPIFLASH P1020UTM-PC P1020UTM-PC_36BIT P1020UTM-PC_36BIT_SDCARD P1020UTM-PC_SDCARD P1021RDB-PC P1021RDB-PC_36BIT P1021RDB-PC_36BIT_NAND P1021RDB-PC_36BIT_SDCARD P1021RDB-PC_36BIT_SPIFLASH P1021RDB-PC_NAND P1021RDB-PC_SDCARD P1021RDB-PC_SPIFLASH P1022DS P1022DS_NAND P1022DS_36BIT_NAND P1022DS_SPIFLASH P1022DS_36BIT_SPIFLASH P1022DS_SDCARD P1022DS_36BIT_SDCARD P1022DS_36BIT P1023RDB P1023RDS P1023RDS_NAND P1024RDB P1024RDB_36BIT P1024RDB_NAND P1024RDB_SDCARD P1024RDB_SPIFLASH P1025RDB P1025RDB_36BIT P1025RDB_NAND P1025RDB_SDCARD P1025RDB_SPIFLASH TWR-P1025 P2020COME_SDCARD P2020COME_SPIFLASH P2020DS P2020DS_36BIT P2020DS_DDR2 P2020DS_SDCARD P2020DS_SPIFLASH P2020RDB P2020RDB_36BIT P2020RDB_36BIT_SDCARD P2020RDB_36BIT_SPIFLASH P2020RDB_NAND P2020RDB-PC P2020RDB-PC_36BIT P2020RDB-PC_36BIT_NAND P2020RDB-PC_36BIT_SDCARD P2020RDB-PC_36BIT_SPIFLASH P2020RDB-PC_NAND P2020RDB-PC_SDCARD P2020RDB-PC_SPIFLASH P2020RDB_SDCARD P2020RDB_SPIFLASH P2041RDB P2041RDB_NAND P2041RDB_SDCARD P2041RDB_SECURE_BOOT P2041RDB_SPIFLASH P2041RDB_SRIO_PCIE_BOOT P3041DS P3041DS_NAND P3041DS_SDCARD P3041DS_SECURE_BOOT P3041DS_SPIFLASH P3041DS_SRIO_PCIE_BOOT P4080DS P4080DS_SDCARD P4080DS_SECURE_BOOT P4080DS_SPIFLASH P4080DS_SRIO_PCIE_BOOT P5020DS P5020DS_NAND P5020DS_SDCARD P5020DS_SECURE_BOOT P5020DS_SPIFLASH P5020DS_SRIO_PCIE_BOOT P5040DS P5040DS_NAND P5040DS_SDCARD P5040DS_SPIFLASH BSC9132QDS_NOR_DDRCLK100 BSC9132QDS_NOR_DDRCLK133 BSC9132QDS_NAND_DDRCLK100 BSC9132QDS_NAND_DDRCLK133 BSC9132QDS_SDCARD_DDRCLK100 BSC9132QDS_SDCARD_DDRCLK133 BSC9132QDS_SPIFLASH_DDRCLK100 BSC9132QDS_SPIFLASH_DDRCLK133 controlcenterd_36BIT_SDCARD controlcenterd_36BIT_SDCARD_DEVELOP controlcenterd_TRAILBLAZER controlcenterd_TRAILBLAZER_DEVELOP T4240QDS T4240EMU T4240QDS_SDCARD T4240QDS_SPIFLASH T4240QDS_SRIO_PCIE_BOOT T4160QDS T4160QDS_SDCARD T4160QDS_SPIFLASH B4860QDS B4860QDS_NAND B4860QDS_SPIFLASH B4860QDS_SRIO_PCIE_BOOT B4420QDS B4420QDS_NAND B4420QDS_SPIFLASH xpedite537x xpedite550x ) Boards with warnings but no errors: 3 ( MPC8572DS_36BIT SPD823TS taishan )
The reason of the error seemed to locate in arch/powerpc/cpu/mpc85xx/release.S
release.S:137: Error: value of 4294963524 too large for field of 2 bytes at 174 release.S:138: Error: operand out of range (0xfffffffffffff144 is not between 0x0000000000000000 and 0x000000000000ffff) release.S:138: Error: value of 4294963524 too large for field of 2 bytes at 178 release.S:281: Error: value of 4294963524 too large for field of 2 bytes at 210 release.S:282: Error: operand out of range (0xfffffffffffff144 is not between 0x0000000000000000 and 0x000000000000ffff) release.S:282: Error: value of 4294963524 too large for field of 2 bytes at 214 release.S:306: Error: value of 4294963520 too large for field of 2 bytes at 282 release.S:307: Error: operand out of range (0xfffffffffffff140 is not between 0x0000000000000000 and 0x000000000000ffff) release.S:307: Error: value of 4294963520 too large for field of 2 bytes at 286
I am not familiar with PowerPC at all and I am not sure my build procedure was correct either, but anyway I could not compile lots of boards even on the u-boot/master. I needed the final output files in order to get md5sum matching.
So I forcibly made the compiling passed by simply commenting out the code which caused the error like follows:
/* get our PIR to figure out our table entry */ - lis r3,toreset(__spin_table_addr)@h - ori r3,r3,toreset(__spin_table_addr)@l +/* lis r3,toreset(__spin_table_addr)@h + ori r3,r3,toreset(__spin_table_addr)@l */ lwz r3,0(r3)
Even after this workaround, I could not compile 3 boards ( MPC8572DS_36BIT SPD823TS taishan ) for PowerPC architecture.
$ cat LOG/MPC8572DS_36BIT.ERR powerpc-linux-gnu-ld.bfd: section .bootpg loaded at [00000000effff000,00000000effff4bb] overlaps section .u_boot_list loaded at [00000000efffeb84,00000000effff41b] powerpc-linux-gnu-ld.bfd: u-boot: section .bootpg lma 0xeffff000 adjusted to 0xeffff41c make: *** [u-boot] Error 1 $ cat LOG/SPD823TS.ERR u-boot.lds:12 cannot move location counter backwards (from 00000000ff008008 to 00000000ff008000) make: *** [u-boot] Error 1 $ cat LOG/taishan.ERR powerpc-linux-gnu-ld.bfd: section .bootpg loaded at [00000000fffff000,00000000fffff24f] overlaps section .u_boot_list loaded at [00000000ffffe7ec,00000000fffff157] powerpc-linux-gnu-ld.bfd: u-boot: section .bootpg lma 0xfffff000 adjusted to 0xfffff158 make: *** [u-boot] Error 1
I gave up these 3 boards.
(8) Other minor architectures
For arm, avr32, sandbox, x86 architectures, I succeeded in compiling all boards, without any errors/warnings. For powerpc, I could compiled most of boards by modifing one file as shown in (7).
I could not find cross compilers for nds32 and nios2 in ftp://ftp.kernel.org/pub/tools/crosstool/. I omitted nds32 (3 boards) and nios2 (3 boards)
For blackfin, m68k, microblaze,mips, openrisc, sh, sparc architecures, I could compile some boards and I could not others. But the "SUMMARY" result was still the same after applying this series, that is, - Boards with errors list - Boards with warnings but no errors list - error / warnings messages were the same.
This means compiling succeeded the same way it did, and compiling failed the same way it did.
Comparison of md5sum was done for only boards which could generate the final ELF file.
(9) How to check the md5sum diffs
The following is my procedure for comparing md5sum.
I got arm-linux-gnueabi-gcc and powerpc-linux-gnu-gcc by Ubuntu apt-get. I downloaded other cross compilers from ftp://ftp.kernel.org/pub/tools/crosstool/. (Gerhard taught me this site, Thanks!)
Assume we have two repositories, "u-boot-org" and "u-boot-kbuild".
u-boot-org is: v2013.10-rc2 tag + Time stamp tweak as shown in (1) + Git hash tweak as shown in (2) + Show md5sum as shown in (3) + Sort *.o files in alphabetical order as shown in (5) + Fix PowerPC code as shown in (7)
u-boot-kbuild is: v2013.10-rc2 tag + This patch series (0001-0019) + Time stamp tweak as shown in (1) + Git hash tweak as shown in (2) + Show md5sum as shown in (3) + Fix PowerPC code as shown in (7)
I took care to build in the same directory path.
mv u-boot-org u-boot cd u-boot CROSS_COMPILE=arm-linux-gnueabi- ./MAKEALL -a arm 2>&1 | tee u-boot-org.log.arm ... (do this for all architectures)
cd .. mv u-boot u-boot-org
mv u-boot-kbuild u-boot cd u-boot
CROSS_COMPILE=arm-linux-gnueabi- ./MAKEALL -a arm 2>&1 | tee u-boot-kbuild.log.arm ... (do this for all architectures)
I got md5sum along with SUMMAY, error/warning messages. I compared log files between u-boot-org and u-boot-kbuild.
(10) Results
- arm
For all 336 boards, compiling succeeded and the md5sum matched.
- avr32
--------------------- SUMMARY ---------------------------- Boards compiled: 10 ----------------------------------------------------------
For all 10 boards, compiling succeeded and the md5sum matched.
- blackfin
--------------------- SUMMARY ---------------------------- Boards compiled: 35 Boards with errors: 5 ( bct-brettl2 bf506f-ezkit bf533-stamp bf609-ezkit cm-bf548 ) Boards with warnings but no errors: 30 ( bf518f-ezbrd bf525-ucr2 bf526-ezbrd bf527-ad7160-eval bf527-ezkit bf527-ezkit-v2 bf527-sdp bf533-ezkit bf537-minotaur bf537-pnav bf537-srv1 bf537-stamp bf538f-ezkit bf548-ezkit bf561-acvilon bf561-ezkit blackstamp blackvme br4 cm-bf527 cm-bf533 cm-bf537e cm-bf537u cm-bf561 dnp5370 ibf-dsp561 ip04 pr1 tcm-bf518 tcm-bf537 ) ----------------------------------------------------------
The result of compiling was the same for both before and after this series. (errors for 5 boards and warnings for 30 boards)
For 21 boards, the u-boot ELF file was produced and the md5sum matched.
- m68k
--------------------- SUMMARY ---------------------------- Boards compiled: 50 Boards with errors: 6 ( M5253DEMO M54455EVB M54455EVB_a66 M54455EVB_i66 M54455EVB_intel M54455EVB_stm33 ) Boards with warnings but no errors: 44 ( M52277EVB M52277EVB_stmicro M5235EVB M5235EVB_Flash32 cobra5272 idmr eb_cpu5282 eb_cpu5282_internal TASREG M5208EVBE M5249EVB M5253EVBE M5271EVB M5272C3 M5275EVB M5282EVB astro_mcf5373l M53017EVB M5329AFEE M5329BFEE M5373EVB M54418TWR M54418TWR_nand_mii M54418TWR_nand_rmii M54418TWR_nand_rmii_lowfreq M54418TWR_serial_mii M54418TWR_serial_rmii M54451EVB M54451EVB_stmicro M5475AFE M5475BFE M5475CFE M5475DFE M5475EFE M5475FFE M5475GFE M5485AFE M5485BFE M5485CFE M5485DFE M5485EFE M5485FFE M5485GFE M5485HFE ) ----------------------------------------------------------
The result of compiling was the same for both before and after this series. (errors for 6 boards and warnings for 44 boards)
For 44 boards, the u-boot ELF file was produced and the md5sum matched.
- microblaze
--------------------- SUMMARY ---------------------------- Boards compiled: 1 Boards with errors: 1 ( microblaze-generic ) ----------------------------------------------------------
I could not compile microblaze at all. Microblaze is a processor custom-designed in Xilinx FPGA. I am not sure, but I may need additional files descripting the hardware.
I could not compare md5sum.
- mips
--------------------- SUMMARY ---------------------------- Boards compiled: 28 Boards with warnings but no errors: 26 ( qemu_mips qemu_mipsel qemu_malta qemu_maltael vct_platinum vct_platinumavc vct_platinumavc_onenand vct_platinumavc_onenand_small vct_platinumavc_small vct_platinum_onenand vct_platinum_onenand_small vct_platinum_small vct_premium vct_premium_onenand vct_premium_onenand_small vct_premium_small dbau1000 dbau1100 dbau1500 dbau1550 dbau1550_el pb1000 incaip incaip_100MHz incaip_133MHz incaip_150MHz ) ----------------------------------------------------------
The result of compiling was the same for both before and after this series. (success for 2 boards and warnings for 26 boards)
For 28 boards, the u-boot ELF file was generated and the md5sum matched.
- nds32
I could not get a suitable cross compiler, so 3 nds32 boards were skipped.
- nios2
I could not get a suitable cross compiler, so 3 nios2 boards were skipped.
- openrisc
--------------------- SUMMARY ---------------------------- Boards compiled: 1 Boards with warnings but no errors: 1 ( openrisc-generic ) ----------------------------------------------------------
The result of compiling was the same for both before and after this series. (warnings for 1 boards)
For 1 board, the u-boot ELF file was generated and md5sum matched.
- powerpc
--------------------- SUMMARY ---------------------------- Boards compiled: 660 Boards with warnings but no errors: 3 ( MPC8572DS_36BIT SPD823TS taishan ) ----------------------------------------------------------
By tweaking arch/powerpc/cpu/mpc85xx/release.S in (7), I could successfully build most of boards, except ( MPC8572DS_36BIT SPD823TS taishan ). I omitted these three boards. As I mentioned in (6), CRAYL1 board produces every time different ELF file because of timestamp. I also omitted this board.
The md5sum checking was done for 656 boards. I found lots of unmatched md5sum for mpc8260 cpu. I think arch/powerpc/cpu/mpc8260/Makefile should be fixed to get the same md5sum. I discuss this item lator. See (11) below.
- sandbox
--------------------- SUMMARY ---------------------------- Boards compiled: 1 ----------------------------------------------------------
sandbox has only one board. The u-boot ELF file was produced and the md5sum matched.
- sh
--------------------- SUMMARY ---------------------------- Boards compiled: 21 Boards with errors: 6 ( rsk7203 rsk7264 rsk7269 mpr2 ms7720se shmin ) ----------------------------------------------------------
The result of compiling was the same for both before and after this series. (success for 15 boards, errors for 6 boards.)
- sparc
--------------------- SUMMARY ---------------------------- Boards compiled: 5 Boards with errors: 4 ( gr_cpci_ax2000 gr_ep2s60 grsim gr_xc3s_1500 ) Boards with warnings but no errors: 1 ( grsim_leon2 ) ----------------------------------------------------------
The result of compiling was the same for both before and after this series. (errors for 4 boards and warnings for 1 board)
No u-boot ELF file was generated, so I could not check md5sum.
- x86
x86 has only one board. The u-boot ELF file was produced and the md5sum matched.
(11) One file turned out to be fixed
md5sum unmatching were found for powerpc mpc8260 cpu.
arch/powerpc/cpu/mpc8260/Makefile is originally like follows:
START = start.o kgdb.o COBJS = traps.o serial_smc.o serial_scc.o cpu.o cpu_init.o speed.o \ interrupts.o ether_fcc.o i2c.o commproc.o \ bedbug_603e.o pci.o spi.o
COBJS += $(COBJS-y)
SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) START := $(addprefix $(obj),$(START))
$(LIB): $(OBJS) $(call cmd_link_o_target, $(OBJS) $(obj)kgdb.o)
See the last line "$(call cmd_link_o_target, $(OBJS) $(obj)kgdb.o)". This is very weird. kgdb.o is not included in $(OBJS) but linked into $(LIB).
So, in the first place
should have been
START = start.o SOBJS = kgdb.o
and
should have been
$(LIB): $(OBJS) $(call cmd_link_o_target, $(OBJS))
My patch series converted arch/powerpc/cpu/mpc8260/Makefile by following the simple rule like this:
extra-y = start.o kgdb.o obj-y = traps.o serial_smc.o serial_scc.o cpu.o cpu_init.o speed.o \ interrupts.o ether_fcc.o i2c.o commproc.o \ bedbug_603e.o pci.o spi.o
Above still should work fine (for both compiling and run testing) because arch/powerpc/cpu/mpc8260/kgdb.S is not used at all.
But, in order to get identical output and the same md5sum, it should be fixed like follows:
extra-y = start.o obj-y = traps.o serial_smc.o serial_scc.o cpu.o cpu_init.o speed.o \ interrupts.o ether_fcc.o i2c.o commproc.o \ bedbug_603e.o pci.o spi.o kdbg.o
After fixing arch/powerpc/cpu/mpc8260/Makefile, md5sum perfectly matched for all boards with mpc8260 cpu.
(12) Conclusion
I made as much effort as I could do now in order to get md5sum matching.
I found one file (arch/powerpc/cpu/mpc8260/Makefile) to be fixed. (Working but better to be fixed.)
I will post version2 with this fix plus rebased on the current master.
In this series, I touched - arch/arm/ - arch/powerpc/ - arch/sandbox/ - and commonly used part (drivers/, fs/, common/, net/, lib/, disk/)
I could not compile lots of minor architecture boards, but the results of md5sum for arm, powerpc, sandbox architectures is sufficient to support my correctness.
But I want to know the reason why the compile failed for such many boards. Of course my procedure might be wrong, but I think at least some of warnings are caused by immature code. I mean more or less boards look to be already broken.
Thanks! But I could not find nds32 and nios2 compilers.
I hope the collection of necessary compilers to build all achitectures supported by U-boot is prepared in U-Boot web site (+ tips to build all boards).
Best Regards, Masahiro Yamada
On Tue, Sep 17, 2013 at 09:35 +0900, Masahiro Yamada wrote:
[ Makefiles rearranged, how to verify the change? ]
[ ... time stamps, version information, symbol order, etc ... ]
(10) Results
[ ... most architectures, matching md5sum ... ]
(12) Conclusion
What a fine display of Lemming control^H^H^H^W^W persistence. :)
Woah, this is awesome! You spent a lot of effort to verify the results, and further improved the series upon detecting a previously unspotted difference. This is very much appreciated.
So you gained even more confidence in the change and have proven that apart from the wanted modification nothing else is affected. This is a very good thing! Especially since the nature of the bootloader's project is rather sensitive to not passing a flag, or passing a wrong flag to architecture specific code.
The essence of your notes (the spots of potential conflict, how to "unify" them to shadow "unwanted diffs", and how to compare results after building most of the targets) are worth keeping around somewhere, I guess. Those who setup build and test farms may want to reference them. For now it's in the ML archive.
That was my other motivation for the "compare binaries" approach in contrast to run-testing the result on the targets.
You want to prove that your modification only has wanted effects and does nothing else, regardless of which state you initially find the source code in. Not being able to build need not mean that you broke it, it might have been in this state before already. And not being able to run software in the absence of hardware may even be the rule instead of an exception.
Getting those targets to build again which currently don't appears to be a separate task, independent from your modification (re-write) of the build instructions.
I posted v2 for this series.
Gerhard Sittig
Masahiro Yamada
