[U-Boot] Unable to boot the new FIT image
Hi ,
I am trying to make a eval board from TI to boot it with the new FIT image format.
I have followed the below procedure but iam getting the "No valid FDT found - please append one to U-Boot binary, use u-boot-dtb.bin or define CONFIG_OF_EMBED." error message. Cannot find out what is the exact problem.
U-Boot Source:
The latest source code from denx.
patman: Suppress duplicate signoffs only for real patches on 05/17/2014
Procedure:
Followed the exact same process mentioned in
http://www.denx.de/wiki/pub/U-Boot/MiniSummitELCE2013/U-Boot_verified_RSA_bo...
I created a device tree and was able to generate a u-boot-dtb.bin file.
SD CARD:
1) copied the MLO in /boot
2) copied the u-boot-dtb.bin in /boot
3) coped the kernel_fdt.itb file
4) uEnv has
console=ttyO0,115200n8 fitfdt=/boot/kernel_fdt.itb setenv loadaddr 0x82000000; run mmcargs; ext2load mmc ${mmcdev}:2 ${loadaddr} ${fitfdt};
I loaded the u-boot-dtb.bin file but it still complains ! Not much help form the forums/internet
Please let me know if i missed anything here.
Thanks,
Harsha
On Mon, May 19, 2014 at 10:06 AM, KJ H. Kiran kj.h.kiran@us.abb.com wrote:
Hi ,
This shouldn't be an issue with FIT - issue with booting u-boot fdt bin
Just for FIT work usage - try to boot with u-boot.bin (fdt less u-boot bin) So-that you can end up with normal u-boot booting.
On u-boot prompt and load u-boot-fdt.bin with TEXTBASE then load u-boot> fatload mmc 0 ${TEXTBASE} u-boot-fdt.bin u-boot> go ${TEXTBASE}
------ fdt u-boot boot prompt> u-boot> fatload mmc 0 ${LOADADDR} kernel_fdt.itb u-boot> bootm ${LOADADDR} .....
Please send output log for this.
U-Boot Source:
Procedure:
SD CARD:
uEnv has
thanks!
+Tom
Hi ,
I hit this problem myself and posted this patch and the following series:
http://patchwork.ozlabs.org/patch/339609/
I heard from one person that it didn't work for them, but I haven't got back to it yet. Still, it might help you. There was a problem with the hash pushing out the end of the image.
U-Boot Source:
Procedure:
SD CARD:
uEnv has
thanks!
Jagan.
Jagan Teki
KJ H. Kiran
