[U-Boot] [PATCH 0/4] add support for loading ACPI tables from QEMU
Currently, if CONFIG_GENERATE_ACPI_TABLE is defined, U-Boot will generate ACPI tables itlself, this patchset adds the ability to load the ACPI tables generated by QEMU.
Miao Yan (4): x86: qemu: re-structure qemu_fwcfg_list_firmware() x86: qemu: setup PM IO base for ACPI in southbridge x86: qemu: add the ability to load and link ACPI tables from QEMU x86: qemu: loading ACPI table from QEMU
arch/x86/cpu/qemu/fw_cfg.c | 274 ++++++++++++++++++++++++++++++-- arch/x86/cpu/qemu/qemu.c | 39 +++++ arch/x86/include/asm/arch-qemu/device.h | 8 + arch/x86/include/asm/fw_cfg.h | 78 +++++++++ arch/x86/lib/tables.c | 5 +- 5 files changed, 389 insertions(+), 15 deletions(-)
Re-write the logic in qemu_fwcfg_list_firmware(), add a function qemu_cfg_read_firmware_list() to handle reading firmware list.
Signed-off-by: Miao Yan yanmiaobest@gmail.com --- arch/x86/cpu/qemu/fw_cfg.c | 60 +++++++++++++++++++++++++++++++++---------- arch/x86/include/asm/fw_cfg.h | 8 ++++++ 2 files changed, 54 insertions(+), 14 deletions(-)
diff --git a/arch/x86/cpu/qemu/fw_cfg.c b/arch/x86/cpu/qemu/fw_cfg.c index 0599214..b22026c 100644 --- a/arch/x86/cpu/qemu/fw_cfg.c +++ b/arch/x86/cpu/qemu/fw_cfg.c @@ -10,10 +10,13 @@ #include <malloc.h> #include <asm/io.h> #include <asm/fw_cfg.h> +#include <linux/list.h>
static bool fwcfg_present; static bool fwcfg_dma_present;
+static LIST_HEAD(fw_list); + /* Read configuration item using fw_cfg PIO interface */ static void qemu_fwcfg_read_entry_pio(uint16_t entry, uint32_t size, void *address) @@ -162,29 +165,58 @@ static int qemu_fwcfg_setup_kernel(void *load_addr, void *initrd_addr) return 0; }
-static int qemu_fwcfg_list_firmware(void) +static int qemu_fwcfg_read_firmware_list(void) { int i; uint32_t count; - struct fw_cfg_files *files; + struct fw_file *file; + struct list_head *entry; + + /* don't read it twice */ + if (!list_empty(&fw_list)) + return 0;
qemu_fwcfg_read_entry(FW_CFG_FILE_DIR, 4, &count); if (!count) return 0;
count = be32_to_cpu(count); - files = malloc(count * sizeof(struct fw_cfg_file)); - if (!files) - return -ENOMEM; - - files->count = count; - qemu_fwcfg_read_entry(FW_CFG_INVALID, - count * sizeof(struct fw_cfg_file), - files->files); - - for (i = 0; i < files->count; i++) - printf("%-56s\n", files->files[i].name); - free(files); + for (i = 0; i < count; i++) { + file = malloc(sizeof(*file)); + if (!file) { + printf("error: allocating resource\n"); + goto err; + } + qemu_fwcfg_read_entry(FW_CFG_INVALID, + sizeof(struct fw_cfg_file), &file->cfg); + file->addr = 0; + list_add_tail(&file->list, &fw_list); + } + return 0; + +err: + list_for_each(entry, &fw_list) { + file = list_entry(entry, struct fw_file, list); + free(file); + } + return -ENOMEM; +} + +static int qemu_fwcfg_list_firmware(void) +{ + int ret; + struct list_head *entry; + struct fw_file *file; + + /* make sure fw_list is loaded */ + ret = qemu_fwcfg_read_firmware_list(); + if (ret) + return ret; + + list_for_each(entry, &fw_list) { + file = list_entry(entry, struct fw_file, list); + printf("%-56s\n", file->cfg.name); + } return 0; }
diff --git a/arch/x86/include/asm/fw_cfg.h b/arch/x86/include/asm/fw_cfg.h index fb110fa..285d805 100644 --- a/arch/x86/include/asm/fw_cfg.h +++ b/arch/x86/include/asm/fw_cfg.h @@ -12,6 +12,8 @@ #define FW_DMA_PORT_LOW 0x514 #define FW_DMA_PORT_HIGH 0x518
+#include <linux/list.h> + enum qemu_fwcfg_items { FW_CFG_SIGNATURE = 0x00, FW_CFG_ID = 0x01, @@ -67,6 +69,12 @@ struct fw_cfg_file { char name[FW_CFG_MAX_FILE_PATH]; };
+struct fw_file { + struct fw_cfg_file cfg; + unsigned long addr; + struct list_head list; +}; + struct fw_cfg_files { __be32 count; struct fw_cfg_file files[];
Hi Miao,
return 0; qemu_fwcfg_read_entry(FW_CFG_FILE_DIR, 4, &count); if (!count) return 0; count = be32_to_cpu(count);
if (!files)
return -ENOMEM;
files->files);
free(files);
if (!file) {
goto err;
file->addr = 0;
nits: leave one blank line before return
+err:
free(file);
return -ENOMEM;
int ret;
if (ret)
return ret;
+struct fw_file {
unsigned long addr;
Can you please put a comment block above to describe what is each member for?
Looks that this struct fw_cfg_files is no longer used by any codes. Please remove this.
Regards, Bin
Enable ACPI IO space for piix4 (for pc board) and ich9 (for q35 board)
Signed-off-by: Miao Yan yanmiaobest@gmail.com --- arch/x86/cpu/qemu/qemu.c | 39 +++++++++++++++++++++++++++++++++ arch/x86/include/asm/arch-qemu/device.h | 8 +++++++ 2 files changed, 47 insertions(+)
diff --git a/arch/x86/cpu/qemu/qemu.c b/arch/x86/cpu/qemu/qemu.c index 46111c9..e7d8a6c 100644 --- a/arch/x86/cpu/qemu/qemu.c +++ b/arch/x86/cpu/qemu/qemu.c @@ -15,6 +15,41 @@
static bool i440fx;
+static void enable_pm_piix(void) +{ + u8 en; + u16 device, cmd; + + device = x86_pci_read_config16(PIIX_PM, PCI_DEVICE_ID); + if (device != PCI_DEVICE_ID_INTEL_82371AB_3) + return; + + /* Set the PM I/O base. */ + x86_pci_write_config32(PIIX_PM, PMBA, DEFAULT_PMBASE | 1); + + /* Enable access to the PM I/O space. */ + cmd = x86_pci_read_config16(PIIX_PM, PCI_COMMAND); + cmd |= PCI_COMMAND_IO; + x86_pci_write_config16(PIIX_PM, PCI_COMMAND, cmd); + + /* PM I/O Space Enable (PMIOSE). */ + en = x86_pci_read_config8(PIIX_PM, PMREGMISC); + en |= PMIOSE; + x86_pci_write_config8(PIIX_PM, PMREGMISC, en); +} + +static void enable_pm_ich9(void) +{ + u16 device; + + device = x86_pci_read_config16(ICH9_PM, PCI_DEVICE_ID); + if (device != PCI_DEVICE_ID_INTEL_ICH9_8) + return; + + /* Set the PM I/O base. */ + x86_pci_write_config32(ICH9_PM, PMBA, DEFAULT_PMBASE | 1); +} + static void qemu_chipset_init(void) { u16 device, xbcs; @@ -53,10 +88,14 @@ static void qemu_chipset_init(void) xbcs = x86_pci_read_config16(PIIX_ISA, XBCS); xbcs |= APIC_EN; x86_pci_write_config16(PIIX_ISA, XBCS, xbcs); + + enable_pm_piix(); } else { /* Configure PCIe ECAM base address */ x86_pci_write_config32(PCI_BDF(0, 0, 0), PCIEX_BAR, CONFIG_PCIE_ECAM_BASE | BAR_EN); + + enable_pm_ich9(); }
qemu_fwcfg_init(); diff --git a/arch/x86/include/asm/arch-qemu/device.h b/arch/x86/include/asm/arch-qemu/device.h index 75a435e..2e11100 100644 --- a/arch/x86/include/asm/arch-qemu/device.h +++ b/arch/x86/include/asm/arch-qemu/device.h @@ -13,9 +13,17 @@ #define PIIX_ISA PCI_BDF(0, 1, 0) #define PIIX_IDE PCI_BDF(0, 1, 1) #define PIIX_USB PCI_BDF(0, 1, 2) +#define PIIX_PM PCI_BDF(0, 1, 3) +#define ICH9_PM PCI_BDF(0, 0x1f, 0) #define I440FX_VGA PCI_BDF(0, 2, 0)
#define QEMU_Q35 PCI_BDF(0, 0, 0) #define Q35_VGA PCI_BDF(0, 1, 0)
+#define PMBA 0x40 +#define DEFAULT_PMBASE 0xe400 +#define PM_IO_BASE DEFAULT_PMBASE +#define PMREGMISC 0x80 +#define PMIOSE (1 << 0) + #endif /* _QEMU_DEVICE_H_ */
Hi Miao,
static bool i440fx;
u8 en;
u16 device, cmd;
return;
Guess the check is already covered in qemu_chipset_init().
nits: please remove the ending period. Please fix this globally in this file.
en |= PMIOSE;
u16 device;
return;
enable_pm_ich9(); } qemu_fwcfg_init();
See arch/x86/cpu/quark/Kconfig we have ACPI_PM1_BASE already. Maybe we need consolidate this to introduce a similar one for QEMU.
PM_IO_BASE is not referenced anywhere.
Please move these register defines to include/asm/arch-qemu/qemu.h
Regards, Bin
Hi Bin,
2016-01-16 21:23 GMT+08:00 Bin Meng bmeng.cn@gmail.com:
Hi Miao,
static bool i440fx;
u8 en;
u16 device, cmd;
return;
Do you mean this check ?
device = x86_pci_read_config16(PCI_BDF(0, 0, 0), PCI_DEVICE_ID); i440fx = (device == PCI_DEVICE_ID_INTEL_82441);
So is it guaranteed that PIIX_PM is always on that BDF ?
IMO, we are operating on another chipset, and we better make sure it's the one we expect, besides, an extra check won't do any harm.
en |= PMIOSE;
u16 device;
return;
OK, will fix this.
OK, will fix this.
Regards, Bin
Hi Miao,
On Tue, Jan 19, 2016 at 10:46 AM, Miao Yan yanmiaobest@gmail.com wrote:
Hi Bin,
Hi Miao,
static bool i440fx;
u8 en;
u16 device, cmd;
return;
I believe so. If you look at the codes in qemu.c, the variable "static bool i440fx" is used to distinguish QEMU machine pc and q35. It does not check whether the chipset is i440fx, or PIIX which is the chipset connected to i440fx.
Yes, that makes sense. So if we go with your way, maybe we need expand "static bool i440fx" to multiple variables and use correct variable to check? But this looks a bit complex than a single variable.
en |= PMIOSE;
u16 device;
return;
OK, will fix this.
OK, will fix this.
Regards, Bin
Hi Bin,
2016-01-19 17:25 GMT+08:00 Bin Meng bmeng.cn@gmail.com:
Hi Miao,
Hi Bin,
Hi Miao,
static bool i440fx;
u8 en;
u16 device, cmd;
return;
Yes, that's a little bit complex and not necessary if their PCI addresses are fixed . And I don't think we should do it in this patchset.
So how do you suggest we do this ? Either I remove the two checks to make it aligned with the rest or create a separate patch to do the checks ?
en |= PMIOSE;
u16 device;
return;
OK, will fix this.
OK, will fix this.
Regards, Bin
Hi Miao,
On Wed, Jan 20, 2016 at 9:58 AM, Miao Yan yanmiaobest@gmail.com wrote:
Hi Bin,
Hi Miao,
Hi Bin,
Hi Miao,
static bool i440fx;
u8 en;
u16 device, cmd;
return;
I suggest we do it in existing way (single variable).
[snip]
Regards, Bin
This patch adds the ability to load and link ACPI tables provided by QEMU. QEMU tells guests how to load and patch ACPI tables through its fw_cfg interface, by adding a firmware file 'etc/table-loader'. Guests are supposed to parse this file and execute corresponding QEMU commands.
Signed-off-by: Miao Yan yanmiaobest@gmail.com --- arch/x86/cpu/qemu/fw_cfg.c | 214 ++++++++++++++++++++++++++++++++++++++++++ arch/x86/include/asm/fw_cfg.h | 70 ++++++++++++++ 2 files changed, 284 insertions(+)
diff --git a/arch/x86/cpu/qemu/fw_cfg.c b/arch/x86/cpu/qemu/fw_cfg.c index b22026c..755676c 100644 --- a/arch/x86/cpu/qemu/fw_cfg.c +++ b/arch/x86/cpu/qemu/fw_cfg.c @@ -10,7 +10,10 @@ #include <malloc.h> #include <asm/io.h> #include <asm/fw_cfg.h> +#include <asm/tables.h> +#include <asm/e820.h> #include <linux/list.h> +#include <memalign.h>
static bool fwcfg_present; static bool fwcfg_dma_present; @@ -202,6 +205,217 @@ err: return -ENOMEM; }
+static struct fw_file *qemu_fwcfg_find_file(const char *name) +{ + struct list_head *entry; + struct fw_file *file; + + list_for_each(entry, &fw_list) { + file = list_entry(entry, struct fw_file, list); + if (!strcmp(file->cfg.name, name)) + return file; + } + + return NULL; +} + +static int bios_linker_allocate(struct bios_linker_entry *entry, + unsigned long *addr) +{ + uint32_t size, align; + struct fw_file *file; + unsigned long aligned_addr; + + align = le32_to_cpu(entry->alloc.align); + /* align must be power of 2 */ + if (align & (align - 1)) { + printf("error: wrong alignment %u\n", align); + return -EINVAL; + } + + file = qemu_fwcfg_find_file(entry->alloc.file); + if (!file) { + printf("error: can't find file %s\n", entry->alloc.file); + return -ENOENT; + } + + size = be32_to_cpu(file->cfg.size); + + /* + * ZONE_HIGH means we need to allocate from high memory, since + * malloc space is already at the end of RAM, so we directly use it. + * If allocation zone is ZONE_FSEG, then we use the 'addr' passed + * in which is low memory + */ + if (entry->alloc.zone == BIOS_LINKER_LOADER_ALLOC_ZONE_HIGH) { + aligned_addr = (unsigned long)memalign(align, size); + } else if (entry->alloc.zone == BIOS_LINKER_LOADER_ALLOC_ZONE_FSEG) { + aligned_addr = ALIGN(*addr, align); + } else { + printf("error: invalid allocation zone\n"); + return -EINVAL; + } + + debug("bios_linker_allocate: allocate file %s, size %u, zone %d, align %u, addr 0x%lx\n", + file->cfg.name, size, entry->alloc.zone, align, aligned_addr); + + qemu_fwcfg_read_entry(be16_to_cpu(file->cfg.select), + size, (void *)aligned_addr); + file->addr = aligned_addr; + + /* adjust address for low memory allocation */ + if (entry->alloc.zone == BIOS_LINKER_LOADER_ALLOC_ZONE_FSEG) + *addr = (aligned_addr + size); + + return 0; +} + +static int bios_linker_add_pointer(struct bios_linker_entry *entry) +{ + struct fw_file *dest, *src; + uint32_t offset = le32_to_cpu(entry->pointer.offset); + uint64_t pointer = 0; + + dest = qemu_fwcfg_find_file(entry->pointer.dest_file); + if (!dest || !dest->addr) + return -ENOENT; + src = qemu_fwcfg_find_file(entry->pointer.src_file); + if (!src || !src->addr) + return -ENOENT; + + + memcpy(&pointer, (char *)dest->addr + offset, entry->pointer.size); + pointer = le64_to_cpu(pointer); + + + debug("bios_linker_add_pointer: dest->addr 0x%lx, src->addr 0x%lx, offset 0x%x size %u, 0x%llx\n", + dest->addr, src->addr, offset, entry->pointer.size, pointer); + + pointer += (unsigned long)src->addr; + pointer = cpu_to_le64(pointer); + memcpy((char *)dest->addr + offset, &pointer, entry->pointer.size); + + return 0; +} + +static int bios_linker_add_checksum(struct bios_linker_entry *entry) +{ + struct fw_file *file; + uint8_t *data, cksum = 0; + uint8_t *cksum_start; + + file = qemu_fwcfg_find_file(entry->cksum.file); + if (!file || !file->addr) + return -ENOENT; + + data = (uint8_t *)(file->addr + le32_to_cpu(entry->cksum.offset)); + cksum_start = (uint8_t *)(file->addr + le32_to_cpu(entry->cksum.start)); + cksum = table_compute_checksum(cksum_start, + le32_to_cpu(entry->cksum.length)); + *data = cksum; + + return 0; +} + +unsigned install_e820_map(unsigned max_entries, struct e820entry *entries) +{ + entries[0].addr = 0; + entries[0].size = ISA_START_ADDRESS; + entries[0].type = E820_RAM; + + entries[1].addr = ISA_START_ADDRESS; + entries[1].size = ISA_END_ADDRESS - ISA_START_ADDRESS; + entries[1].type = E820_RESERVED; + + /* + * since we use memalign(malloc) to allocate high memory for + * storing ACPI tables, we need to reserve them in e820 tables, + * otherwise kernel will reclaim them and data will be corrupted + */ + entries[2].addr = ISA_END_ADDRESS; + entries[2].size = gd->relocaddr - TOTAL_MALLOC_LEN - ISA_END_ADDRESS; + entries[2].type = E820_RAM; + + /* for simplicity, reserve entire malloc space */ + entries[3].addr = gd->relocaddr - TOTAL_MALLOC_LEN; + entries[3].size = TOTAL_MALLOC_LEN; + entries[3].type = E820_RESERVED; + + entries[4].addr = gd->relocaddr; + entries[4].size = gd->ram_size - gd->relocaddr; + entries[4].type = E820_RESERVED; + + entries[5].addr = CONFIG_PCIE_ECAM_BASE; + entries[5].size = CONFIG_PCIE_ECAM_SIZE; + entries[5].type = E820_RESERVED; + + return 6; +} + +/* This function loads and patches ACPI tables provided by QEMU */ +unsigned long qemu_fwcfg_write_acpi_tables(unsigned long addr) +{ + int i, ret = 0; + struct fw_file *file; + struct bios_linker_entry *table_loader; + struct bios_linker_entry *entry; + uint32_t size; + + /* make sure fw_list is loaded */ + ret = qemu_fwcfg_read_firmware_list(); + if (ret) { + printf("error: can't read firmware file list\n"); + return addr; + } + + file = qemu_fwcfg_find_file("etc/table-loader"); + if (!file) { + printf("error: can't find etc/table-loader\n"); + return addr; + } + + size = be32_to_cpu(file->cfg.size); + if ((size % sizeof(*entry)) != 0) { + printf("error: table loader maybe corrupted\n"); + return addr; + } + + table_loader = malloc(size); + if (!table_loader) { + printf("error: no memory for table-loader\n"); + return addr; + } + + qemu_fwcfg_read_entry(be16_to_cpu(file->cfg.select), + size, table_loader); + + for (i = 0; i < (size / sizeof(*entry)); i++) { + entry = table_loader + i; + switch (le32_to_cpu(entry->command)) { + case BIOS_LINKER_LOADER_COMMAND_ALLOCATE: + ret = bios_linker_allocate(entry, &addr); + if (ret) + goto err; + break; + case BIOS_LINKER_LOADER_COMMAND_ADD_POINTER: + ret = bios_linker_add_pointer(entry); + if (ret) + goto err; + break; + case BIOS_LINKER_LOADER_COMMAND_ADD_CHECKSUM: + ret = bios_linker_add_checksum(entry); + if (ret) + goto err; + break; + default: + break; + } + } +err: + free(table_loader); + return addr; +} + static int qemu_fwcfg_list_firmware(void) { int ret; diff --git a/arch/x86/include/asm/fw_cfg.h b/arch/x86/include/asm/fw_cfg.h index 285d805..ad58205 100644 --- a/arch/x86/include/asm/fw_cfg.h +++ b/arch/x86/include/asm/fw_cfg.h @@ -47,11 +47,23 @@ enum qemu_fwcfg_items { FW_CFG_INVALID = 0xffff, };
+enum { + BIOS_LINKER_LOADER_COMMAND_ALLOCATE = 0x1, + BIOS_LINKER_LOADER_COMMAND_ADD_POINTER = 0x2, + BIOS_LINKER_LOADER_COMMAND_ADD_CHECKSUM = 0x3, +}; + +enum { + BIOS_LINKER_LOADER_ALLOC_ZONE_HIGH = 0x1, + BIOS_LINKER_LOADER_ALLOC_ZONE_FSEG = 0x2, +}; + #define FW_CFG_FILE_SLOTS 0x10 #define FW_CFG_MAX_ENTRY (FW_CFG_FILE_FIRST + FW_CFG_FILE_SLOTS) #define FW_CFG_ENTRY_MASK ~(FW_CFG_WRITE_CHANNEL | FW_CFG_ARCH_LOCAL)
#define FW_CFG_MAX_FILE_PATH 56 +#define BIOS_LINKER_LOADER_FILESZ FW_CFG_MAX_FILE_PATH
#define QEMU_FW_CFG_SIGNATURE (('Q' << 24) | ('E' << 16) | ('M' << 8) | 'U')
@@ -69,6 +81,7 @@ struct fw_cfg_file { char name[FW_CFG_MAX_FILE_PATH]; };
+ struct fw_file { struct fw_cfg_file cfg; unsigned long addr; @@ -86,6 +99,55 @@ struct fw_cfg_dma_access { __be64 address; };
+struct bios_linker_entry { + __le32 command; + union { + /* + * COMMAND_ALLOCATE - allocate a table from @alloc.file + * subject to @alloc.align alignment (must be power of 2) + * and @alloc.zone (can be HIGH or FSEG) requirements. + * + * Must appear exactly once for each file, and before + * this file is referenced by any other command. + */ + struct { + char file[BIOS_LINKER_LOADER_FILESZ]; + __le32 align; + uint8_t zone; + } alloc; + + /* + * COMMAND_ADD_POINTER - patch the table (originating from + * @dest_file) at @pointer.offset, by adding a pointer to the + * table originating from @src_file. 1,2,4 or 8 byte unsigned + * addition is used depending on @pointer.size. + */ + struct { + char dest_file[BIOS_LINKER_LOADER_FILESZ]; + char src_file[BIOS_LINKER_LOADER_FILESZ]; + __le32 offset; + uint8_t size; + } pointer; + + /* + * COMMAND_ADD_CHECKSUM - calculate checksum of the range + * specified by @cksum_start and @cksum_length fields, + * and then add the value at @cksum.offset. + * Checksum simply sums -X for each byte X in the range + * using 8-bit math. + */ + struct { + char file[BIOS_LINKER_LOADER_FILESZ]; + __le32 offset; + __le32 start; + __le32 length; + } cksum; + + /* padding */ + char pad[124]; + }; +} __packed; + /** * Initialize QEMU fw_cfg interface */ @@ -98,4 +160,12 @@ void qemu_fwcfg_init(void); */ int qemu_fwcfg_online_cpus(void);
+/** + * Load ACPI tables from QEMU + * + * @addr: address to load + * @return: next address + */ +unsigned long qemu_fwcfg_write_acpi_tables(unsigned long addr); + #endif
Hi Miao,
return file;
return NULL;
Please add a comment block for what this function is doing, its parameters, return value, etc. Please do the same for the other 2 functions below.
return -EINVAL;
if (!file) {
return -ENOENT;
} else {
return -EINVAL;
return -ENOENT;
return -ENOENT;
Remove one blank line here.
return -ENOENT;
*data = cksum;
return 6;
int i, ret = 0;
uint32_t size;
if (ret) {
return addr;
if (!file) {
return addr;
table-loader may be
return addr;
return addr;
if (ret)
goto err;
break;
if (ret)
goto err;
break;
if (ret)
goto err;
break;
default:
break;
+err:
free(table_loader);
return addr;
+enum {
+enum {
Use FW_CFG_MAX_FILE_PATH directly?
__le32 command;
union {
struct {
__le32 align;
uint8_t zone;
} alloc;
struct {
__le32 offset;
uint8_t size;
} pointer;
* using 8-bit math.
struct {
__le32 offset;
__le32 start;
__le32 length;
} cksum;
/* padding */
char pad[124];
+} __packed;
- Initialize QEMU fw_cfg interface
- Load ACPI tables from QEMU
- @addr: address to load
- @return: next address
#endif
Regards, Bin
Hi Bin,
2016-01-16 21:24 GMT+08:00 Bin Meng bmeng.cn@gmail.com:
Hi Miao,
return file;
return NULL;
return -EINVAL;
if (!file) {
return -ENOENT;
} else {
return -EINVAL;
return -ENOENT;
return -ENOENT;
return -ENOENT;
*data = cksum;
return 6;
int i, ret = 0;
uint32_t size;
if (ret) {
return addr;
if (!file) {
return addr;
table-loader may be
return addr;
return addr;
if (ret)
goto err;
break;
if (ret)
goto err;
break;
if (ret)
goto err;
break;
default:
break;
+err:
free(table_loader);
return addr;
+enum {
+enum {
Those codes are derived from QEMU, with some modifications to make them compatible with U-Boot source. So I think maybe we should keep it in sync with QEMU.
__le32 command;
union {
struct {
__le32 align;
uint8_t zone;
} alloc;
struct {
__le32 offset;
uint8_t size;
} pointer;
* using 8-bit math.
struct {
__le32 offset;
__le32 start;
__le32 length;
} cksum;
/* padding */
char pad[124];
+} __packed;
#endif
Regards, Bin
Hi Miao,
On Tue, Jan 19, 2016 at 10:39 AM, Miao Yan yanmiaobest@gmail.com wrote:
Hi Bin,
Hi Miao,
return file;
return NULL;
return -EINVAL;
if (!file) {
return -ENOENT;
} else {
return -EINVAL;
return -ENOENT;
return -ENOENT;
return -ENOENT;
*data = cksum;
return 6;
int i, ret = 0;
uint32_t size;
if (ret) {
return addr;
if (!file) {
return addr;
table-loader may be
return addr;
return addr;
if (ret)
goto err;
break;
if (ret)
goto err;
break;
if (ret)
goto err;
break;
default:
break;
+err:
free(table_loader);
return addr;
+enum {
+enum {
OK, makes sense.
__le32 command;
union {
struct {
__le32 align;
uint8_t zone;
} alloc;
struct {
__le32 offset;
uint8_t size;
} pointer;
* using 8-bit math.
struct {
__le32 offset;
__le32 start;
__le32 length;
} cksum;
/* padding */
char pad[124];
+} __packed;
#endif
Regards, Bin
If CONFIG_GENERATE_ACPI_TABLE is not defined, then use ACPI table created by QEMU.
Signed-off-by: Miao Yan yanmiaobest@gmail.com --- arch/x86/lib/tables.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/arch/x86/lib/tables.c b/arch/x86/lib/tables.c index 14b15cf..1671385 100644 --- a/arch/x86/lib/tables.c +++ b/arch/x86/lib/tables.c @@ -10,6 +10,7 @@ #include <asm/smbios.h> #include <asm/tables.h> #include <asm/acpi_table.h> +#include <asm/fw_cfg.h>
u8 table_compute_checksum(void *v, int len) { @@ -55,8 +56,10 @@ void write_tables(void) #endif #ifdef CONFIG_GENERATE_ACPI_TABLE rom_table_end = write_acpi_tables(rom_table_end); - rom_table_end = ALIGN(rom_table_end, 1024); +#else + rom_table_end = qemu_fwcfg_write_acpi_tables(rom_table_end); #endif + rom_table_end = ALIGN(rom_table_end, 1024); #ifdef CONFIG_GENERATE_SMBIOS_TABLE rom_table_end = write_smbios_table(rom_table_end); rom_table_end = ALIGN(rom_table_end, 1024);
Hi Miao,
+#else
This breaks other x86 boards.Can we hide this changes in acpi_table.c with proper #ifdef and some comments?
For QEMU ACPI, how about:
- GENERATE_ACPI_TABLE is the overall switch to turn on ACPI table by U-Boot - Introduce another Kconfig option for QEMU to generate ACPI tables from firmware interface. If this is turned on, the original method provided in acpi_tables.c will not be used.
#endif
#ifdef CONFIG_GENERATE_SMBIOS_TABLE rom_table_end = write_smbios_table(rom_table_end); rom_table_end = ALIGN(rom_table_end, 1024); --
Regards, Bin
Hi Bin,
Hi Miao,
+#else
Sounds OK, I'll drop this one. Thanks.
#endif
Regards, Bin
Bin Meng
Miao Yan
