[PATCH 0/3] arm: dts: am625/am62a7: Switch over to OF_UPSTREAM
Cleanup am625 on by switching over the last two platforms (SK and beagleplay) over to OF_UPSTREAM, and while at it, switch over am62a7 (last of the am62* family) over as well.
This superscedes the previous version of beagleplay only patch[1]
Test logs: https://gist.github.com/nmenon/ba310d3750a80789aca6a4fd90190135
Nishanth Menon (3): arm: dts: am625_beagleplay: Switch to OF_UPSTREAM arm: dts: am625_sk: Switch to OF_UPSTREAM arm: dts: am62a7_sk: Switch to OF_UPSTREAM
arch/arm/dts/Makefile | 7 +- arch/arm/dts/k3-am62-main.dtsi | 1058 ------------------ arch/arm/dts/k3-am62-mcu.dtsi | 176 --- arch/arm/dts/k3-am62-thermal.dtsi | 36 - arch/arm/dts/k3-am62-wakeup.dtsi | 96 -- arch/arm/dts/k3-am62.dtsi | 122 -- arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi | 4 +- arch/arm/dts/k3-am625-beagleplay.dts | 932 --------------- arch/arm/dts/k3-am625-sk-binman.dtsi | 2 +- arch/arm/dts/k3-am625-sk.dts | 299 ----- arch/arm/dts/k3-am625.dtsi | 155 --- arch/arm/dts/k3-am62a-main.dtsi | 1054 ----------------- arch/arm/dts/k3-am62a-mcu.dtsi | 170 --- arch/arm/dts/k3-am62a-sk-binman.dtsi | 2 +- arch/arm/dts/k3-am62a-thermal.dtsi | 50 - arch/arm/dts/k3-am62a-wakeup.dtsi | 73 -- arch/arm/dts/k3-am62a.dtsi | 125 --- arch/arm/dts/k3-am62a7-sk.dts | 702 ------------ arch/arm/dts/k3-am62x-sk-common.dtsi | 535 --------- configs/am62ax_evm_a53_defconfig | 3 +- configs/am62x_beagleplay_a53_defconfig | 3 +- configs/am62x_evm_a53_defconfig | 3 +- 22 files changed, 12 insertions(+), 5595 deletions(-) delete mode 100644 arch/arm/dts/k3-am62-main.dtsi delete mode 100644 arch/arm/dts/k3-am62-mcu.dtsi delete mode 100644 arch/arm/dts/k3-am62-thermal.dtsi delete mode 100644 arch/arm/dts/k3-am62-wakeup.dtsi delete mode 100644 arch/arm/dts/k3-am62.dtsi delete mode 100644 arch/arm/dts/k3-am625-beagleplay.dts delete mode 100644 arch/arm/dts/k3-am625-sk.dts delete mode 100644 arch/arm/dts/k3-am625.dtsi delete mode 100644 arch/arm/dts/k3-am62a-main.dtsi delete mode 100644 arch/arm/dts/k3-am62a-mcu.dtsi delete mode 100644 arch/arm/dts/k3-am62a-thermal.dtsi delete mode 100644 arch/arm/dts/k3-am62a-wakeup.dtsi delete mode 100644 arch/arm/dts/k3-am62a.dtsi delete mode 100644 arch/arm/dts/k3-am62a7-sk.dts delete mode 100644 arch/arm/dts/k3-am62x-sk-common.dtsi
[1] https://lore.kernel.org/u-boot/20240604134751.249048-1-nm@ti.com/
base-commit: 227be29df37545f74243a98c12a4a33c4160e3cd
Enable OF_UPSTREAM for AM625-beagleplay board. Remove DT files that are now available in dts/upstream. Update the appended files based on version of latest OF_UPSTREAM sync point (v6.10-rc1).
Signed-off-by: Nishanth Menon nm@ti.com --- arch/arm/dts/Makefile | 1 - arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi | 4 +- arch/arm/dts/k3-am625-beagleplay.dts | 932 ------------------- configs/am62x_beagleplay_a53_defconfig | 3 +- 4 files changed, 4 insertions(+), 936 deletions(-) delete mode 100644 arch/arm/dts/k3-am625-beagleplay.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 624dadf8ece2..813426a3e519 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1200,7 +1200,6 @@ dtb-$(CONFIG_SOC_K3_AM642) += k3-am642-r5-evm.dtb \
dtb-$(CONFIG_SOC_K3_AM625) += k3-am625-sk.dtb \ k3-am625-r5-sk.dtb \ - k3-am625-beagleplay.dtb \ k3-am625-r5-beagleplay.dtb \ k3-am625-verdin-r5.dtb \ k3-am625-r5-phycore-som-2gb.dtb diff --git a/arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi b/arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi index 9ac4a825f841..dd5b335ed2ee 100644 --- a/arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi +++ b/arch/arm/dts/k3-am625-beagleplay-u-boot.dtsi @@ -66,9 +66,9 @@ #ifdef CONFIG_TARGET_AM625_A53_BEAGLEPLAY
#define SPL_NODTB "spl/u-boot-spl-nodtb.bin" -#define SPL_AM625_BEAGLEPLAY_DTB "spl/dts/k3-am625-beagleplay.dtb" +#define SPL_AM625_BEAGLEPLAY_DTB "spl/dts/ti/k3-am625-beagleplay.dtb" #define UBOOT_NODTB "u-boot-nodtb.bin" -#define AM625_BEAGLEPLAY_DTB "arch/arm/dts/k3-am625-beagleplay.dtb" +#define AM625_BEAGLEPLAY_DTB "dts/upstream/src/arm64/ti/k3-am625-beagleplay.dtb"
&binman { ti-dm { diff --git a/arch/arm/dts/k3-am625-beagleplay.dts b/arch/arm/dts/k3-am625-beagleplay.dts deleted file mode 100644 index 8ab838f1697c..000000000000 --- a/arch/arm/dts/k3-am625-beagleplay.dts +++ /dev/null @@ -1,932 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only OR MIT -/* - * https://beagleplay.org/ - * - * Copyright (C) 2022-2024 Texas Instruments Incorporated - https://www.ti.com/ - * Copyright (C) 2022-2024 Robert Nelson, BeagleBoard.org Foundation - */ - -/dts-v1/; - -#include <dt-bindings/leds/common.h> -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h> -#include "k3-am625.dtsi" - -/ { - compatible = "beagle,am625-beagleplay", "ti,am625"; - model = "BeagleBoard.org BeaglePlay"; - - aliases { - ethernet0 = &cpsw_port1; - ethernet1 = &cpsw_port2; - gpio0 = &main_gpio0; - gpio1 = &main_gpio1; - gpio2 = &mcu_gpio0; - i2c0 = &main_i2c0; - i2c1 = &main_i2c1; - i2c2 = &main_i2c2; - i2c3 = &main_i2c3; - i2c4 = &wkup_i2c0; - i2c5 = &mcu_i2c0; - mmc0 = &sdhci0; - mmc1 = &sdhci1; - mmc2 = &sdhci2; - rtc0 = &rtc; - serial0 = &main_uart5; - serial1 = &main_uart6; - serial2 = &main_uart0; - usb0 = &usb0; - usb1 = &usb1; - }; - - chosen { - stdout-path = "serial2:115200n8"; - }; - - memory@80000000 { - bootph-pre-ram; - device_type = "memory"; - /* 2G RAM */ - reg = <0x00000000 0x80000000 0x00000000 0x80000000>; - }; - - reserved-memory { - #address-cells = <2>; - #size-cells = <2>; - ranges; - - ramoops: ramoops@9ca00000 { - compatible = "ramoops"; - reg = <0x00 0x9ca00000 0x00 0x00100000>; - record-size = <0x8000>; - console-size = <0x8000>; - ftrace-size = <0x00>; - pmsg-size = <0x8000>; - }; - - secure_tfa_ddr: tfa@9e780000 { - reg = <0x00 0x9e780000 0x00 0x80000>; - no-map; - }; - - secure_ddr: optee@9e800000 { - reg = <0x00 0x9e800000 0x00 0x01800000>; - no-map; - }; - - wkup_r5fss0_core0_dma_memory_region: r5f-dma-memory@9db00000 { - compatible = "shared-dma-pool"; - reg = <0x00 0x9db00000 0x00 0xc00000>; - no-map; - }; - }; - - vsys_5v0: regulator-1 { - bootph-all; - compatible = "regulator-fixed"; - regulator-name = "vsys_5v0"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - regulator-boot-on; - }; - - vdd_3v3: regulator-2 { - /* output of TLV62595DMQR-U12 */ - bootph-all; - compatible = "regulator-fixed"; - regulator-name = "vdd_3v3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vsys_5v0>; - regulator-always-on; - regulator-boot-on; - }; - - wlan_en: regulator-3 { - /* OUTPUT of SN74AVC2T244DQMR */ - compatible = "regulator-fixed"; - regulator-name = "wlan_en"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - enable-active-high; - regulator-always-on; - vin-supply = <&vdd_3v3>; - gpio = <&main_gpio0 38 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_en_pins_default>; - }; - - vdd_3v3_sd: regulator-4 { - /* output of TPS22918DBVR-U21 */ - bootph-all; - pinctrl-names = "default"; - pinctrl-0 = <&vdd_3v3_sd_pins_default>; - - compatible = "regulator-fixed"; - regulator-name = "vdd_3v3_sd"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - enable-active-high; - regulator-always-on; - vin-supply = <&vdd_3v3>; - gpio = <&main_gpio1 19 GPIO_ACTIVE_HIGH>; - }; - - vdd_sd_dv: regulator-5 { - bootph-all; - compatible = "regulator-gpio"; - regulator-name = "sd_hs200_switch"; - pinctrl-names = "default"; - pinctrl-0 = <&vdd_sd_dv_pins_default>; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - vin-supply = <&ldo1_reg>; - gpios = <&main_gpio1 49 GPIO_ACTIVE_HIGH>; - states = <1800000 0x0>, - <3300000 0x1>; - }; - - leds { - bootph-all; - compatible = "gpio-leds"; - - led-0 { - bootph-all; - gpios = <&main_gpio0 3 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "heartbeat"; - function = LED_FUNCTION_HEARTBEAT; - default-state = "off"; - }; - - led-1 { - bootph-all; - gpios = <&main_gpio0 4 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "disk-activity"; - function = LED_FUNCTION_DISK_ACTIVITY; - default-state = "keep"; - }; - - led-2 { - bootph-all; - gpios = <&main_gpio0 5 GPIO_ACTIVE_HIGH>; - function = LED_FUNCTION_CPU; - }; - - led-3 { - bootph-all; - gpios = <&main_gpio0 6 GPIO_ACTIVE_HIGH>; - function = LED_FUNCTION_LAN; - }; - - led-4 { - bootph-all; - gpios = <&main_gpio0 9 GPIO_ACTIVE_HIGH>; - function = LED_FUNCTION_WLAN; - }; - }; - - gpio_keys: gpio-keys { - compatible = "gpio-keys"; - autorepeat; - pinctrl-names = "default"; - pinctrl-0 = <&usr_button_pins_default>; - - usr: button-usr { - label = "User Key"; - linux,code = <BTN_0>; - gpios = <&main_gpio0 18 GPIO_ACTIVE_LOW>; - }; - - }; - - hdmi0: connector-hdmi { - compatible = "hdmi-connector"; - label = "hdmi"; - type = "a"; - port { - hdmi_connector_in: endpoint { - remote-endpoint = <&it66121_out>; - }; - }; - }; - - sound { - compatible = "simple-audio-card"; - simple-audio-card,name = "it66121 HDMI"; - simple-audio-card,format = "i2s"; - simple-audio-card,bitclock-master = <&hdmi_dailink_master>; - simple-audio-card,frame-master = <&hdmi_dailink_master>; - - hdmi_dailink_master: simple-audio-card,cpu { - sound-dai = <&mcasp1>; - system-clock-direction-out; - }; - - simple-audio-card,codec { - sound-dai = <&it66121>; - }; - }; - -}; - -&main_pmx0 { - gpio0_pins_default: gpio0-default-pins { - bootph-all; - pinctrl-single,pins = < - AM62X_IOPAD(0x0004, PIN_INPUT, 7) /* (G25) OSPI0_LBCLKO.GPIO0_1 */ - AM62X_IOPAD(0x0008, PIN_INPUT, 7) /* (J24) OSPI0_DQS.GPIO0_2 */ - AM62X_IOPAD(0x000c, PIN_INPUT, 7) /* (E25) OSPI0_D0.GPIO0_3 */ - AM62X_IOPAD(0x0010, PIN_INPUT, 7) /* (G24) OSPI0_D1.GPIO0_4 */ - AM62X_IOPAD(0x0014, PIN_INPUT, 7) /* (F25) OSPI0_D2.GPIO0_5 */ - AM62X_IOPAD(0x0018, PIN_INPUT, 7) /* (F24) OSPI0_D3.GPIO0_6 */ - AM62X_IOPAD(0x0024, PIN_INPUT, 7) /* (H25) OSPI0_D6.GPIO0_9 */ - AM62X_IOPAD(0x0028, PIN_INPUT, 7) /* (J22) OSPI0_D7.GPIO0_10 */ - AM62X_IOPAD(0x002c, PIN_INPUT, 7) /* (F23) OSPI0_CSn0.GPIO0_11 */ - AM62X_IOPAD(0x0030, PIN_INPUT, 7) /* (G21) OSPI0_CSn1.GPIO0_12 */ - AM62X_IOPAD(0x0034, PIN_INPUT, 7) /* (H21) OSPI0_CSn2.GPIO0_13 */ - AM62X_IOPAD(0x0038, PIN_INPUT, 7) /* (E24) OSPI0_CSn3.GPIO0_14 */ - AM62X_IOPAD(0x00a4, PIN_INPUT, 7) /* (M22) GPMC0_DIR.GPIO0_40 */ - AM62X_IOPAD(0x00ac, PIN_INPUT, 7) /* (L21) GPMC0_CSn1.GPIO0_42 */ - >; - }; - - vdd_sd_dv_pins_default: vdd-sd-default-pins { - bootph-all; - pinctrl-single,pins = < - AM62X_IOPAD(0x0244, PIN_OUTPUT, 7) /* (C17) MMC1_SDWP.GPIO1_49 */ - >; - }; - - usr_button_pins_default: usr-button-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x0048, PIN_INPUT, 7) /* (N25) GPMC0_AD3.GPIO0_18 */ - >; - }; - - grove_pins_default: grove-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x01e8, PIN_INPUT_PULLUP, 0) /* (B17) I2C1_SCL */ - AM62X_IOPAD(0x01ec, PIN_INPUT_PULLUP, 0) /* (A17) I2C1_SDA */ - >; - }; - - local_i2c_pins_default: local-i2c-default-pins { - bootph-all; - pinctrl-single,pins = < - AM62X_IOPAD(0x01e0, PIN_INPUT_PULLUP, 0) /* (B16) I2C0_SCL */ - AM62X_IOPAD(0x01e4, PIN_INPUT_PULLUP, 0) /* (A16) I2C0_SDA */ - >; - }; - - i2c2_1v8_pins_default: i2c2-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x00b0, PIN_INPUT_PULLUP, 1) /* (K22) GPMC0_CSn2.I2C2_SCL */ - AM62X_IOPAD(0x00b4, PIN_INPUT_PULLUP, 1) /* (K24) GPMC0_CSn3.I2C2_SDA */ - >; - }; - - mdio0_pins_default: mdio0-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x0160, PIN_OUTPUT, 0) /* (AD24) MDIO0_MDC */ - AM62X_IOPAD(0x015c, PIN_INPUT, 0) /* (AB22) MDIO0_MDIO */ - AM62X_IOPAD(0x003c, PIN_INPUT, 7) /* (M25) GPMC0_AD0.GPIO0_15 */ - AM62X_IOPAD(0x018c, PIN_INPUT, 7) /* (AC21) RGMII2_RD2.GPIO1_5 */ - >; - }; - - rgmii1_pins_default: rgmii1-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x014c, PIN_INPUT, 0) /* (AB17) RGMII1_RD0 */ - AM62X_IOPAD(0x0150, PIN_INPUT, 0) /* (AC17) RGMII1_RD1 */ - AM62X_IOPAD(0x0154, PIN_INPUT, 0) /* (AB16) RGMII1_RD2 */ - AM62X_IOPAD(0x0158, PIN_INPUT, 0) /* (AA15) RGMII1_RD3 */ - AM62X_IOPAD(0x0148, PIN_INPUT, 0) /* (AD17) RGMII1_RXC */ - AM62X_IOPAD(0x0144, PIN_INPUT, 0) /* (AE17) RGMII1_RX_CTL */ - AM62X_IOPAD(0x0134, PIN_OUTPUT, 0) /* (AE20) RGMII1_TD0 */ - AM62X_IOPAD(0x0138, PIN_OUTPUT, 0) /* (AD20) RGMII1_TD1 */ - AM62X_IOPAD(0x013c, PIN_OUTPUT, 0) /* (AE18) RGMII1_TD2 */ - AM62X_IOPAD(0x0140, PIN_OUTPUT, 0) /* (AD18) RGMII1_TD3 */ - AM62X_IOPAD(0x0130, PIN_OUTPUT, 0) /* (AE19) RGMII1_TXC */ - AM62X_IOPAD(0x012c, PIN_OUTPUT, 0) /* (AD19) RGMII1_TX_CTL */ - >; - }; - - emmc_pins_default: emmc-default-pins { - bootph-all; - pinctrl-single,pins = < - AM62X_IOPAD(0x0220, PIN_INPUT, 0) /* (Y3) MMC0_CMD */ - AM62X_IOPAD(0x0218, PIN_INPUT, 0) /* (AB1) MMC0_CLK */ - AM62X_IOPAD(0x0214, PIN_INPUT, 0) /* (AA2) MMC0_DAT0 */ - AM62X_IOPAD(0x0210, PIN_INPUT, 0) /* (AA1) MMC0_DAT1 */ - AM62X_IOPAD(0x020c, PIN_INPUT, 0) /* (AA3) MMC0_DAT2 */ - AM62X_IOPAD(0x0208, PIN_INPUT, 0) /* (Y4) MMC0_DAT3 */ - AM62X_IOPAD(0x0204, PIN_INPUT, 0) /* (AB2) MMC0_DAT4 */ - AM62X_IOPAD(0x0200, PIN_INPUT, 0) /* (AC1) MMC0_DAT5 */ - AM62X_IOPAD(0x01fc, PIN_INPUT, 0) /* (AD2) MMC0_DAT6 */ - AM62X_IOPAD(0x01f8, PIN_INPUT, 0) /* (AC2) MMC0_DAT7 */ - >; - }; - - vdd_3v3_sd_pins_default: vdd-3v3-sd-default-pins { - bootph-all; - pinctrl-single,pins = < - AM62X_IOPAD(0x01c4, PIN_INPUT, 7) /* (B14) SPI0_D1_GPIO1_19 */ - >; - }; - - sd_pins_default: sd-default-pins { - bootph-all; - pinctrl-single,pins = < - AM62X_IOPAD(0x023c, PIN_INPUT, 0) /* (A21) MMC1_CMD */ - AM62X_IOPAD(0x0234, PIN_INPUT, 0) /* (B22) MMC1_CLK */ - AM62X_IOPAD(0x0230, PIN_INPUT, 0) /* (A22) MMC1_DAT0 */ - AM62X_IOPAD(0x022c, PIN_INPUT, 0) /* (B21) MMC1_DAT1 */ - AM62X_IOPAD(0x0228, PIN_INPUT, 0) /* (C21) MMC1_DAT2 */ - AM62X_IOPAD(0x0224, PIN_INPUT, 0) /* (D22) MMC1_DAT3 */ - AM62X_IOPAD(0x0240, PIN_INPUT, 7) /* (D17) MMC1_SDCD.GPIO1_48 */ - >; - }; - - wifi_pins_default: wifi-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x0120, PIN_INPUT, 0) /* (C24) MMC2_CMD */ - AM62X_IOPAD(0x0118, PIN_INPUT, 0) /* (D25) MMC2_CLK */ - AM62X_IOPAD(0x0114, PIN_INPUT, 0) /* (B24) MMC2_DAT0 */ - AM62X_IOPAD(0x0110, PIN_INPUT, 0) /* (C25) MMC2_DAT1 */ - AM62X_IOPAD(0x010c, PIN_INPUT, 0) /* (E23) MMC2_DAT2 */ - AM62X_IOPAD(0x0108, PIN_INPUT, 0) /* (D24) MMC2_DAT3 */ - AM62X_IOPAD(0x0124, PIN_INPUT, 0) /* (A23) MMC2_SDCD */ - AM62X_IOPAD(0x11c, PIN_INPUT, 0) /* (#N/A) MMC2_CLKB */ - >; - }; - - wifi_en_pins_default: wifi-en-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x009c, PIN_OUTPUT, 7) /* (V25) GPMC0_WAIT1.GPIO0_38 */ - >; - }; - - wifi_wlirq_pins_default: wifi-wlirq-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x00a8, PIN_INPUT, 7) /* (M21) GPMC0_CSn0.GPIO0_41 */ - >; - }; - - spe_pins_default: spe-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x0168, PIN_INPUT, 1) /* (AE21) RGMII2_TXC.RMII2_CRS_DV */ - AM62X_IOPAD(0x0180, PIN_INPUT, 1) /* (AD23) RGMII2_RXC.RMII2_REF_CLK */ - AM62X_IOPAD(0x0184, PIN_INPUT, 1) /* (AE23) RGMII2_RD0.RMII2_RXD0 */ - AM62X_IOPAD(0x0188, PIN_INPUT, 1) /* (AB20) RGMII2_RD1.RMII2_RXD1 */ - AM62X_IOPAD(0x017c, PIN_INPUT, 1) /* (AD22) RGMII2_RX_CTL.RMII2_RX_ER */ - AM62X_IOPAD(0x016c, PIN_INPUT, 1) /* (Y18) RGMII2_TD0.RMII2_TXD0 */ - AM62X_IOPAD(0x0170, PIN_INPUT, 1) /* (AA18) RGMII2_TD1.RMII2_TXD1 */ - AM62X_IOPAD(0x0164, PIN_INPUT, 1) /* (AA19) RGMII2_TX_CTL.RMII2_TX_EN */ - AM62X_IOPAD(0x0190, PIN_INPUT, 7) /* (AE22) RGMII2_RD3.GPIO1_6 */ - AM62X_IOPAD(0x01f0, PIN_OUTPUT, 5) /* (A18) EXT_REFCLK1.CLKOUT0 */ - >; - }; - - mikrobus_i2c_pins_default: mikrobus-i2c-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x01d0, PIN_INPUT_PULLUP, 2) /* (A15) UART0_CTSn.I2C3_SCL */ - AM62X_IOPAD(0x01d4, PIN_INPUT_PULLUP, 2) /* (B15) UART0_RTSn.I2C3_SDA */ - >; - }; - - mikrobus_uart_pins_default: mikrobus-uart-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x01d8, PIN_INPUT, 1) /* (C15) MCAN0_TX.UART5_RXD */ - AM62X_IOPAD(0x01dc, PIN_OUTPUT, 1) /* (E15) MCAN0_RX.UART5_TXD */ - >; - }; - - mikrobus_spi_pins_default: mikrobus-spi-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x01b0, PIN_INPUT, 1) /* (A20) MCASP0_ACLKR.SPI2_CLK */ - AM62X_IOPAD(0x01ac, PIN_INPUT, 1) /* (E19) MCASP0_AFSR.SPI2_CS0 */ - AM62X_IOPAD(0x0194, PIN_INPUT, 1) /* (B19) MCASP0_AXR3.SPI2_D0 */ - AM62X_IOPAD(0x0198, PIN_INPUT, 1) /* (A19) MCASP0_AXR2.SPI2_D1 */ - >; - }; - - mikrobus_gpio_pins_default: mikrobus-gpio-default-pins { - bootph-all; - pinctrl-single,pins = < - AM62X_IOPAD(0x019c, PIN_INPUT, 7) /* (B18) MCASP0_AXR1.GPIO1_9 */ - AM62X_IOPAD(0x01a0, PIN_INPUT, 7) /* (E18) MCASP0_AXR0.GPIO1_10 */ - AM62X_IOPAD(0x01a8, PIN_INPUT, 7) /* (D20) MCASP0_AFSX.GPIO1_12 */ - >; - }; - - main_uart0_pins_default: main-uart0-default-pins { - bootph-all; - pinctrl-single,pins = < - AM62X_IOPAD(0x01c8, PIN_INPUT, 0) /* (D14) UART0_RXD */ - AM62X_IOPAD(0x01cc, PIN_OUTPUT, 0) /* (E14) UART0_TXD */ - >; - }; - - wifi_debug_uart_pins_default: wifi-debug-uart-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x001c, PIN_INPUT, 3) /* (J23) OSPI0_D4.UART6_RXD */ - AM62X_IOPAD(0x0020, PIN_OUTPUT, 3) /* (J25) OSPI0_D5.UART6_TXD */ - >; - }; - - usb1_pins_default: usb1-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x0258, PIN_INPUT, 0) /* (F18) USB1_DRVVBUS */ - >; - }; - - pmic_irq_pins_default: pmic-irq-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x01f4, PIN_INPUT_PULLUP, 0) /* (D16) EXTINTn */ - >; - }; - - hdmi_gpio_pins_default: hdmi-gpio-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x0094, PIN_INPUT_PULLUP | PIN_DEBOUNCE_CONF6, 7) /* (N20) GPMC0_BE1n.GPIO0_36 */ - AM62X_IOPAD(0x0054, PIN_OUTPUT_PULLUP, 7) /* (P21) GPMC0_AD6.GPIO0_21 */ - >; - }; - - mcasp_hdmi_pins_default: mcasp-hdmi-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x0090, PIN_INPUT, 2) /* (M24) GPMC0_BE0n_CLE.MCASP1_ACLKX */ - AM62X_IOPAD(0x0098, PIN_INPUT, 2) /* (U23) GPMC0_WAIT0.MCASP1_AFSX */ - AM62X_IOPAD(0x008c, PIN_OUTPUT, 2) /* (L25) GPMC0_WEn.MCASP1_AXR0 */ - AM62X_IOPAD(0x0088, PIN_INPUT, 2) /* (L24) GPMC0_OEn_REn.MCASP1_AXR1 */ - AM62X_IOPAD(0x0084, PIN_INPUT, 2) /* (L23) GPMC0_ADVn_ALE.MCASP1_AXR2 */ - AM62X_IOPAD(0x007c, PIN_INPUT, 2) /* (P25) GPMC0_CLK.MCASP1_AXR3 */ - >; - }; - - dss0_pins_default: dss0-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x0100, PIN_OUTPUT, 0) /* (AC25) VOUT0_VSYNC */ - AM62X_IOPAD(0x00f8, PIN_OUTPUT, 0) /* (AB24) VOUT0_HSYNC */ - AM62X_IOPAD(0x0104, PIN_OUTPUT, 0) /* (AC24) VOUT0_PCLK */ - AM62X_IOPAD(0x00fc, PIN_OUTPUT, 0) /* (Y20) VOUT0_DE */ - AM62X_IOPAD(0x00b8, PIN_OUTPUT, 0) /* (U22) VOUT0_DATA0 */ - AM62X_IOPAD(0x00bc, PIN_OUTPUT, 0) /* (V24) VOUT0_DATA1 */ - AM62X_IOPAD(0x00c0, PIN_OUTPUT, 0) /* (W25) VOUT0_DATA2 */ - AM62X_IOPAD(0x00c4, PIN_OUTPUT, 0) /* (W24) VOUT0_DATA3 */ - AM62X_IOPAD(0x00c8, PIN_OUTPUT, 0) /* (Y25) VOUT0_DATA4 */ - AM62X_IOPAD(0x00cc, PIN_OUTPUT, 0) /* (Y24) VOUT0_DATA5 */ - AM62X_IOPAD(0x00d0, PIN_OUTPUT, 0) /* (Y23) VOUT0_DATA6 */ - AM62X_IOPAD(0x00d4, PIN_OUTPUT, 0) /* (AA25) VOUT0_DATA7 */ - AM62X_IOPAD(0x00d8, PIN_OUTPUT, 0) /* (V21) VOUT0_DATA8 */ - AM62X_IOPAD(0x00dc, PIN_OUTPUT, 0) /* (W21) VOUT0_DATA9 */ - AM62X_IOPAD(0x00e0, PIN_OUTPUT, 0) /* (V20) VOUT0_DATA10 */ - AM62X_IOPAD(0x00e4, PIN_OUTPUT, 0) /* (AA23) VOUT0_DATA11 */ - AM62X_IOPAD(0x00e8, PIN_OUTPUT, 0) /* (AB25) VOUT0_DATA12 */ - AM62X_IOPAD(0x00ec, PIN_OUTPUT, 0) /* (AA24) VOUT0_DATA13 */ - AM62X_IOPAD(0x00f0, PIN_OUTPUT, 0) /* (Y22) VOUT0_DATA14 */ - AM62X_IOPAD(0x00f4, PIN_OUTPUT, 0) /* (AA21) VOUT0_DATA15 */ - AM62X_IOPAD(0x005c, PIN_OUTPUT, 1) /* (R24) GPMC0_AD8.VOUT0_DATA16 */ - AM62X_IOPAD(0x0060, PIN_OUTPUT, 1) /* (R25) GPMC0_AD9.VOUT0_DATA17 */ - AM62X_IOPAD(0x0064, PIN_OUTPUT, 1) /* (T25) GPMC0_AD10.VOUT0_DATA18 */ - AM62X_IOPAD(0x0068, PIN_OUTPUT, 1) /* (R21) GPMC0_AD11.VOUT0_DATA19 */ - AM62X_IOPAD(0x006c, PIN_OUTPUT, 1) /* (T22) GPMC0_AD12.VOUT0_DATA20 */ - AM62X_IOPAD(0x0070, PIN_OUTPUT, 1) /* (T24) GPMC0_AD13.VOUT0_DATA21 */ - AM62X_IOPAD(0x0074, PIN_OUTPUT, 1) /* (U25) GPMC0_AD14.VOUT0_DATA22 */ - AM62X_IOPAD(0x0078, PIN_OUTPUT, 1) /* (U24) GPMC0_AD15.VOUT0_DATA23 */ - >; - }; -}; - -&mcu_pmx0 { - i2c_qwiic_pins_default: i2c-qwiic-default-pins { - pinctrl-single,pins = < - AM62X_MCU_IOPAD(0x0044, PIN_INPUT, 0) /* (A8) MCU_I2C0_SCL */ - AM62X_MCU_IOPAD(0x0048, PIN_INPUT, 0) /* (D10) MCU_I2C0_SDA */ - >; - }; - - gbe_pmx_obsclk: gbe-pmx-obsclk-default-pins { - pinctrl-single,pins = < - AM62X_MCU_IOPAD(0x0004, PIN_OUTPUT, 1) /* (B8) MCU_SPI0_CS1.MCU_OBSCLK0 */ - >; - }; - - i2c_csi_pins_default: i2c-csi-default-pins { - pinctrl-single,pins = < - AM62X_MCU_IOPAD(0x004c, PIN_INPUT_PULLUP, 0) /* (B9) WKUP_I2C0_SCL */ - AM62X_MCU_IOPAD(0x0050, PIN_INPUT_PULLUP, 0) /* (A9) WKUP_I2C0_SDA */ - >; - }; - - wifi_32k_clk: mcu-clk-out-default-pins { - pinctrl-single,pins = < - AM62X_MCU_IOPAD(0x0084, PIN_OUTPUT, 0) /* (A12) WKUP_CLKOUT0 */ - >; - }; -}; - -&a53_opp_table { - /* Requires VDD_CORE to be at 0.85V */ - opp-1400000000 { - opp-hz = /bits/ 64 <1400000000>; - opp-supported-hw = <0x01 0x0004>; - }; -}; - -&wkup_i2c0 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c_csi_pins_default>; - clock-frequency = <400000>; - /* Enable with overlay for camera sensor */ -}; - -&mcu_i2c0 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c_qwiic_pins_default>; - clock-frequency = <100000>; - status = "okay"; -}; - -&usbss0 { - bootph-all; - ti,vbus-divider; - status = "okay"; -}; - -&usb0 { - bootph-all; - dr_mode = "peripheral"; -}; - -&usbss1 { - ti,vbus-divider; - status = "okay"; -}; - -&usb1 { - dr_mode = "host"; - pinctrl-names = "default"; - pinctrl-0 = <&usb1_pins_default>; -}; - -&cpsw3g { - pinctrl-names = "default"; - pinctrl-0 = <&rgmii1_pins_default>, <&spe_pins_default>, - <&gbe_pmx_obsclk>; - assigned-clocks = <&k3_clks 157 70>, <&k3_clks 157 20>; - assigned-clock-parents = <&k3_clks 157 72>, <&k3_clks 157 22>; -}; - -&cpsw_port1 { - phy-mode = "rgmii-rxid"; - phy-handle = <&cpsw3g_phy0>; -}; - -&cpsw_port2 { - phy-mode = "rmii"; - phy-handle = <&cpsw3g_phy1>; -}; - -&cpsw3g_mdio { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&mdio0_pins_default>; - - cpsw3g_phy0: ethernet-phy@0 { - reg = <0>; - reset-gpios = <&main_gpio0 15 GPIO_ACTIVE_LOW>; - reset-assert-us = <10000>; - reset-deassert-us = <50000>; - }; - - cpsw3g_phy1: ethernet-phy@1 { - reg = <1>; - reset-gpios = <&main_gpio1 5 GPIO_ACTIVE_LOW>; - reset-assert-us = <25>; - reset-deassert-us = <60000>; /* T2 */ - }; -}; - -&main_gpio0 { - bootph-all; - pinctrl-names = "default"; - pinctrl-0 = <&gpio0_pins_default>; - gpio-line-names = "BL_EN_3V3", "SPE_PO_EN", "RTC_INT", /* 0-2 */ - "USR0", "USR1", "USR2", "USR3", "", "", "USR4", /* 3-9 */ - "EEPROM_WP", /* 10 */ - "CSI2_CAMERA_GPIO1", "CSI2_CAMERA_GPIO2", /* 11-12 */ - "CC1352P7_BOOT", "CC1352P7_RSTN", "GBE_RSTN", "", "", /* 13-17 */ - "USR_BUTTON", "", "", "", "", "", "", "", "", /* 18-26 */ - "", "", "", "", "", "", "", "", "", "HDMI_INT", /* 27-36 */ - "", "VDD_WLAN_EN", "", "", "WL_IRQ", "GBE_INTN",/* 37-42 */ - "", "", "", "", "", "", "", "", "", "", "", "", /* 43-54 */ - "", "", "", "", "", "", "", "", "", "", "", "", /* 55-66 */ - "", "", "", "", "", "", "", "", "", "", "", "", /* 67-78 */ - "", "", "", "", "", "", /* 79-84 */ - "BITBANG_MDIO_DATA", "BITBANG_MDIO_CLK", /* 85-86 */ - "", "", "", "", ""; /* 87-91 */ -}; - -&main_gpio1 { - bootph-all; - pinctrl-names = "default"; - pinctrl-0 = <&mikrobus_gpio_pins_default>; - gpio-line-names = "", "", "", "", "", /* 0-4 */ - "SPE_RSTN", "SPE_INTN", "MIKROBUS_GPIO1_7", /* 5-7 */ - "MIKROBUS_GPIO1_8", "MIKROBUS_GPIO1_9", /* 8-9 */ - "MIKROBUS_GPIO1_10", "MIKROBUS_GPIO1_11", /* 10-11 */ - "MIKROBUS_GPIO1_12", "MIKROBUS_W1_GPIO0", /* 12-13 */ - "MIKROBUS_GPIO1_14", /* 14 */ - "", "", "", "", "VDD_3V3_SD", "", "", /* 15-21 */ - "MIKROBUS_GPIO1_22", "MIKROBUS_GPIO1_23", /* 22-23 */ - "MIKROBUS_GPIO1_24", "MIKROBUS_GPIO1_25", /* 24-25 */ - "", "", "", "", "", "", "", "", "", "", "", "", /* 26-37 */ - "", "", "", "", "", "", "", "", "", "", /* 38-47 */ - "SD_CD", "SD_VOLT_SEL", "", ""; /* 48-51 */ -}; - -&main_i2c0 { - bootph-all; - pinctrl-names = "default"; - pinctrl-0 = <&local_i2c_pins_default>; - clock-frequency = <400000>; - status = "okay"; - - eeprom@50 { - compatible = "atmel,24c32"; - reg = <0x50>; - }; - - rtc: rtc@68 { - compatible = "ti,bq32000"; - reg = <0x68>; - interrupt-parent = <&main_gpio0>; - interrupts = <2 IRQ_TYPE_EDGE_FALLING>; - }; - - tps65219: pmic@30 { - bootph-all; - compatible = "ti,tps65219"; - reg = <0x30>; - buck1-supply = <&vsys_5v0>; - buck2-supply = <&vsys_5v0>; - buck3-supply = <&vsys_5v0>; - ldo1-supply = <&vdd_3v3>; - ldo2-supply = <&buck2_reg>; - ldo3-supply = <&vdd_3v3>; - ldo4-supply = <&vdd_3v3>; - - pinctrl-names = "default"; - pinctrl-0 = <&pmic_irq_pins_default>; - interrupt-parent = <&gic500>; - interrupts = <GIC_SPI 224 IRQ_TYPE_LEVEL_HIGH>; - interrupt-controller; - #interrupt-cells = <1>; - - system-power-controller; - ti,power-button; - - regulators { - buck1_reg: buck1 { - regulator-name = "VDD_CORE"; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <850000>; - regulator-boot-on; - regulator-always-on; - }; - - buck2_reg: buck2 { - regulator-name = "VDD_1V8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-boot-on; - regulator-always-on; - }; - - buck3_reg: buck3 { - regulator-name = "VDD_1V2"; - regulator-min-microvolt = <1200000>; - regulator-max-microvolt = <1200000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo1_reg: ldo1 { - /* - * Regulator is left as is unused, vdd_sd - * is controlled via GPIO with bypass config - * as per the NVM configuration - */ - regulator-name = "VDD_SD_3V3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-allow-bypass; - regulator-boot-on; - regulator-always-on; - }; - - ldo2_reg: ldo2 { - regulator-name = "VDDA_0V85"; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <850000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo3_reg: ldo3 { - regulator-name = "VDDA_1V8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo4_reg: ldo4 { - regulator-name = "VDD_2V5"; - regulator-min-microvolt = <2500000>; - regulator-max-microvolt = <2500000>; - regulator-boot-on; - regulator-always-on; - }; - }; - }; -}; - -&main_i2c1 { - pinctrl-names = "default"; - pinctrl-0 = <&grove_pins_default>; - clock-frequency = <100000>; - status = "okay"; -}; - -&main_i2c2 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c2_1v8_pins_default>; - clock-frequency = <100000>; - status = "okay"; - - it66121: bridge-hdmi@4c { - compatible = "ite,it66121"; - reg = <0x4c>; - pinctrl-names = "default"; - pinctrl-0 = <&hdmi_gpio_pins_default>; - vcn33-supply = <&vdd_3v3>; - vcn18-supply = <&buck2_reg>; - vrf12-supply = <&buck3_reg>; - reset-gpios = <&main_gpio0 21 GPIO_ACTIVE_LOW>; - interrupt-parent = <&main_gpio0>; - interrupts = <36 IRQ_TYPE_EDGE_FALLING>; - #sound-dai-cells = <0>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - - it66121_in: endpoint { - bus-width = <24>; - remote-endpoint = <&dpi1_out>; - }; - }; - - port@1 { - reg = <1>; - - it66121_out: endpoint { - remote-endpoint = <&hdmi_connector_in>; - }; - }; - }; - }; -}; - -&main_i2c3 { - pinctrl-names = "default"; - pinctrl-0 = <&mikrobus_i2c_pins_default>; - clock-frequency = <400000>; - status = "okay"; -}; - -&main_spi2 { - pinctrl-names = "default"; - pinctrl-0 = <&mikrobus_spi_pins_default>; - status = "okay"; -}; - -&sdhci0 { - bootph-all; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_pins_default>; - disable-wp; - status = "okay"; -}; - -&sdhci1 { - /* SD/MMC */ - bootph-all; - pinctrl-names = "default"; - pinctrl-0 = <&sd_pins_default>; - - vmmc-supply = <&vdd_3v3_sd>; - vqmmc-supply = <&vdd_sd_dv>; - disable-wp; - cd-gpios = <&main_gpio1 48 GPIO_ACTIVE_LOW>; - cd-debounce-delay-ms = <100>; - ti,fails-without-test-cd; - status = "okay"; -}; - -&sdhci2 { - vmmc-supply = <&wlan_en>; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_pins_default>, <&wifi_32k_clk>; - non-removable; - ti,fails-without-test-cd; - cap-power-off-card; - keep-power-in-suspend; - assigned-clocks = <&k3_clks 157 158>; - assigned-clock-parents = <&k3_clks 157 160>; - #address-cells = <1>; - #size-cells = <0>; - status = "okay"; - - wlcore: wlcore@2 { - compatible = "ti,wl1807"; - reg = <2>; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_wlirq_pins_default>; - interrupt-parent = <&main_gpio0>; - interrupts = <41 IRQ_TYPE_EDGE_FALLING>; - }; -}; - -&main_uart0 { - bootph-all; - pinctrl-names = "default"; - pinctrl-0 = <&main_uart0_pins_default>; - status = "okay"; -}; - -&main_uart1 { - /* Main UART1 is used by TIFS firmware */ - status = "reserved"; -}; - -&main_uart5 { - pinctrl-names = "default"; - pinctrl-0 = <&mikrobus_uart_pins_default>; - status = "okay"; -}; - -&main_uart6 { - pinctrl-names = "default"; - pinctrl-0 = <&wifi_debug_uart_pins_default>; - status = "okay"; - - mcu { - compatible = "ti,cc1352p7"; - reset-gpios = <&main_gpio0 72 GPIO_ACTIVE_LOW>; - vdds-supply = <&vdd_3v3>; - }; -}; - -&dss { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&dss0_pins_default>; -}; - -&dss_ports { - /* VP2: DPI Output */ - port@1 { - reg = <1>; - - dpi1_out: endpoint { - remote-endpoint = <&it66121_in>; - }; - }; -}; - -&mcasp1 { - status = "okay"; - #sound-dai-cells = <0>; - pinctrl-names = "default"; - pinctrl-0 = <&mcasp_hdmi_pins_default>; - auxclk-fs-ratio = <2177>; - op-mode = <0>; /* MCASP_IIS_MODE */ - tdm-slots = <2>; - serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */ - 1 0 0 0 - 0 0 0 0 - 0 0 0 0 - 0 0 0 0 - >; - tx-num-evt = <32>; - rx-num-evt = <32>; -}; diff --git a/configs/am62x_beagleplay_a53_defconfig b/configs/am62x_beagleplay_a53_defconfig index ec62670d55d6..455dd86b2fc3 100644 --- a/configs/am62x_beagleplay_a53_defconfig +++ b/configs/am62x_beagleplay_a53_defconfig @@ -10,7 +10,7 @@ CONFIG_TARGET_AM625_A53_BEAGLEPLAY=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80b80000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="k3-am625-beagleplay" +CONFIG_DEFAULT_DEVICE_TREE="ti/k3-am625-beagleplay" CONFIG_SPL_TEXT_BASE=0x80080000 CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y @@ -58,6 +58,7 @@ CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_UPSTREAM=y CONFIG_MULTI_DTB_FIT=y CONFIG_SPL_MULTI_DTB_FIT=y CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y
Hi Nishanth,
Thank you for the patch.
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com
- Copyright (C) 2022-2024 Texas Instruments Incorporated - https://www.ti.com/
- Copyright (C) 2022-2024 Robert Nelson, BeagleBoard.org Foundation
-/dts-v1/;
- aliases {
gpio2 = &mcu_gpio0;
i2c0 = &main_i2c0;
i2c1 = &main_i2c1;
i2c2 = &main_i2c2;
i2c3 = &main_i2c3;
i2c4 = &wkup_i2c0;
i2c5 = &mcu_i2c0;
mmc0 = &sdhci0;
mmc1 = &sdhci1;
mmc2 = &sdhci2;
rtc0 = &rtc;
usb0 = &usb0;
usb1 = &usb1;
- chosen {
- memory@80000000 {
bootph-pre-ram;
/* 2G RAM */
- reserved-memory {
#size-cells = <2>;
ranges;
no-map;
no-map;
no-map;
bootph-all;
regulator-boot-on;
bootph-all;
regulator-boot-on;
enable-active-high;
bootph-all;
enable-active-high;
bootph-all;
regulator-boot-on;
<3300000 0x1>;
- leds {
bootph-all;
led-0 {
bootph-all;
led-1 {
bootph-all;
led-2 {
bootph-all;
led-3 {
bootph-all;
led-4 {
bootph-all;
autorepeat;
usr: button-usr {
label = "User Key";
label = "hdmi";
type = "a";
port {
- sound {
-&main_pmx0 {
bootph-all;
bootph-all;
bootph-all;
bootph-all;
bootph-all;
bootph-all;
bootph-all;
bootph-all;
-&mcu_pmx0 {
-&a53_opp_table {
- opp-1400000000 {
-&wkup_i2c0 {
-&mcu_i2c0 {
- status = "okay";
-&usbss0 {
- bootph-all;
- ti,vbus-divider;
- status = "okay";
-&usb0 {
- bootph-all;
-&usbss1 {
- ti,vbus-divider;
- status = "okay";
-&usb1 {
- dr_mode = "host";
-&cpsw3g {
<&gbe_pmx_obsclk>;
-&cpsw_port1 {
-&cpsw_port2 {
-&cpsw3g_mdio {
- status = "okay";
reg = <0>;
reg = <1>;
-&main_gpio0 {
- bootph-all;
-&main_gpio1 {
- bootph-all;
-&main_i2c0 {
- bootph-all;
- status = "okay";
- eeprom@50 {
reg = <0x50>;
- rtc: rtc@68 {
reg = <0x68>;
bootph-all;
reg = <0x30>;
ti,power-button;
regulators {
buck1_reg: buck1 {
regulator-boot-on;
buck2_reg: buck2 {
regulator-boot-on;
buck3_reg: buck3 {
regulator-boot-on;
ldo1_reg: ldo1 {
regulator-boot-on;
ldo2_reg: ldo2 {
regulator-boot-on;
ldo3_reg: ldo3 {
regulator-boot-on;
ldo4_reg: ldo4 {
regulator-boot-on;
-&main_i2c1 {
- status = "okay";
-&main_i2c2 {
- status = "okay";
reg = <0x4c>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
bus-width = <24>;
port@1 {
reg = <1>;
-&main_i2c3 {
- status = "okay";
-&main_spi2 {
- status = "okay";
-&sdhci0 {
- bootph-all;
- disable-wp;
- status = "okay";
-&sdhci1 {
- /* SD/MMC */
- bootph-all;
- disable-wp;
- status = "okay";
-&sdhci2 {
- non-removable;
- status = "okay";
reg = <2>;
-&main_uart0 {
- bootph-all;
- status = "okay";
-&main_uart1 {
-&main_uart5 {
- status = "okay";
-&main_uart6 {
- status = "okay";
- mcu {
-&dss {
- status = "okay";
-&dss_ports {
- port@1 {
reg = <1>;
-&mcasp1 {
- status = "okay";
- tdm-slots = <2>;
1 0 0 0
0 0 0 0
0 0 0 0
0 0 0 0
;- tx-num-evt = <32>;
-}; diff --git a/configs/am62x_beagleplay_a53_defconfig b/configs/am62x_beagleplay_a53_defconfig index ec62670d55d6..455dd86b2fc3 100644 --- a/configs/am62x_beagleplay_a53_defconfig +++ b/configs/am62x_beagleplay_a53_defconfig @@ -10,7 +10,7 @@ CONFIG_TARGET_AM625_A53_BEAGLEPLAY=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80b80000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="k3-am625-beagleplay" +CONFIG_DEFAULT_DEVICE_TREE="ti/k3-am625-beagleplay" CONFIG_SPL_TEXT_BASE=0x80080000 CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y @@ -58,6 +58,7 @@ CONFIG_CMD_PMIC=y CONFIG_CMD_REGULATOR=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_UPSTREAM=y CONFIG_MULTI_DTB_FIT=y CONFIG_SPL_MULTI_DTB_FIT=y CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y -- 2.43.0
Enable OF_UPSTREAM for am625-sk board. Remove DT files that are now available in dts/upstream. Update the appended files based on version of latest OF_UPSTREAM sync point (v6.10-rc1).
Signed-off-by: Nishanth Menon nm@ti.com --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/k3-am62-main.dtsi | 1058 -------------------------- arch/arm/dts/k3-am62-mcu.dtsi | 176 ----- arch/arm/dts/k3-am62-thermal.dtsi | 36 - arch/arm/dts/k3-am62-wakeup.dtsi | 96 --- arch/arm/dts/k3-am62.dtsi | 122 --- arch/arm/dts/k3-am625-sk-binman.dtsi | 2 +- arch/arm/dts/k3-am625-sk.dts | 299 -------- arch/arm/dts/k3-am625.dtsi | 155 ---- arch/arm/dts/k3-am62x-sk-common.dtsi | 535 ------------- configs/am62x_evm_a53_defconfig | 3 +- 11 files changed, 4 insertions(+), 2481 deletions(-) delete mode 100644 arch/arm/dts/k3-am62-main.dtsi delete mode 100644 arch/arm/dts/k3-am62-mcu.dtsi delete mode 100644 arch/arm/dts/k3-am62-thermal.dtsi delete mode 100644 arch/arm/dts/k3-am62-wakeup.dtsi delete mode 100644 arch/arm/dts/k3-am62.dtsi delete mode 100644 arch/arm/dts/k3-am625-sk.dts delete mode 100644 arch/arm/dts/k3-am625.dtsi delete mode 100644 arch/arm/dts/k3-am62x-sk-common.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 813426a3e519..5b0bcf336924 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1198,8 +1198,7 @@ dtb-$(CONFIG_SOC_K3_AM642) += k3-am642-r5-evm.dtb \ k3-am642-r5-sk.dtb \ k3-am642-r5-phycore-som-2gb.dtb
-dtb-$(CONFIG_SOC_K3_AM625) += k3-am625-sk.dtb \ - k3-am625-r5-sk.dtb \ +dtb-$(CONFIG_SOC_K3_AM625) += k3-am625-r5-sk.dtb \ k3-am625-r5-beagleplay.dtb \ k3-am625-verdin-r5.dtb \ k3-am625-r5-phycore-som-2gb.dtb diff --git a/arch/arm/dts/k3-am62-main.dtsi b/arch/arm/dts/k3-am62-main.dtsi deleted file mode 100644 index e9cffca073ef..000000000000 --- a/arch/arm/dts/k3-am62-main.dtsi +++ /dev/null @@ -1,1058 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only OR MIT -/* - * Device Tree Source for AM625 SoC Family Main Domain peripherals - * - * Copyright (C) 2020-2024 Texas Instruments Incorporated - https://www.ti.com/ - */ - -&cbass_main { - oc_sram: sram@70000000 { - compatible = "mmio-sram"; - reg = <0x00 0x70000000 0x00 0x10000>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x0 0x00 0x70000000 0x10000>; - }; - - gic500: interrupt-controller@1800000 { - compatible = "arm,gic-v3"; - #address-cells = <2>; - #size-cells = <2>; - ranges; - #interrupt-cells = <3>; - interrupt-controller; - reg = <0x00 0x01800000 0x00 0x10000>, /* GICD */ - <0x00 0x01880000 0x00 0xc0000>, /* GICR */ - <0x00 0x01880000 0x00 0xc0000>, /* GICR */ - <0x01 0x00000000 0x00 0x2000>, /* GICC */ - <0x01 0x00010000 0x00 0x1000>, /* GICH */ - <0x01 0x00020000 0x00 0x2000>; /* GICV */ - /* - * vcpumntirq: - * virtual CPU interface maintenance interrupt - */ - interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; - - gic_its: msi-controller@1820000 { - compatible = "arm,gic-v3-its"; - reg = <0x00 0x01820000 0x00 0x10000>; - socionext,synquacer-pre-its = <0x1000000 0x400000>; - msi-controller; - #msi-cells = <1>; - }; - }; - - main_conf: bus@100000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x0 0x00 0x00100000 0x20000>; - - phy_gmii_sel: phy@4044 { - compatible = "ti,am654-phy-gmii-sel"; - reg = <0x4044 0x8>; - #phy-cells = <1>; - }; - - epwm_tbclk: clock-controller@4130 { - compatible = "ti,am62-epwm-tbclk"; - reg = <0x4130 0x4>; - #clock-cells = <1>; - }; - - audio_refclk0: clock-controller@82e0 { - compatible = "ti,am62-audio-refclk"; - reg = <0x82e0 0x4>; - clocks = <&k3_clks 157 0>; - assigned-clocks = <&k3_clks 157 0>; - assigned-clock-parents = <&k3_clks 157 8>; - #clock-cells = <0>; - }; - - audio_refclk1: clock-controller@82e4 { - compatible = "ti,am62-audio-refclk"; - reg = <0x82e4 0x4>; - clocks = <&k3_clks 157 10>; - assigned-clocks = <&k3_clks 157 10>; - assigned-clock-parents = <&k3_clks 157 18>; - #clock-cells = <0>; - }; - }; - - dmss: bus@48000000 { - bootph-all; - compatible = "simple-bus"; - #address-cells = <2>; - #size-cells = <2>; - dma-ranges; - ranges = <0x00 0x48000000 0x00 0x48000000 0x00 0x06400000>; - - ti,sci-dev-id = <25>; - - secure_proxy_main: mailbox@4d000000 { - bootph-all; - compatible = "ti,am654-secure-proxy"; - #mbox-cells = <1>; - reg-names = "target_data", "rt", "scfg"; - reg = <0x00 0x4d000000 0x00 0x80000>, - <0x00 0x4a600000 0x00 0x80000>, - <0x00 0x4a400000 0x00 0x80000>; - interrupt-names = "rx_012"; - interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; - }; - - inta_main_dmss: interrupt-controller@48000000 { - compatible = "ti,sci-inta"; - reg = <0x00 0x48000000 0x00 0x100000>; - #interrupt-cells = <0>; - interrupt-controller; - interrupt-parent = <&gic500>; - msi-controller; - ti,sci = <&dmsc>; - ti,sci-dev-id = <28>; - ti,interrupt-ranges = <4 68 36>; - ti,unmapped-event-sources = <&main_bcdma>, <&main_pktdma>; - }; - - main_bcdma: dma-controller@485c0100 { - compatible = "ti,am64-dmss-bcdma"; - reg = <0x00 0x485c0100 0x00 0x100>, - <0x00 0x4c000000 0x00 0x20000>, - <0x00 0x4a820000 0x00 0x20000>, - <0x00 0x4aa40000 0x00 0x20000>, - <0x00 0x4bc00000 0x00 0x100000>, - <0x00 0x48600000 0x00 0x8000>, - <0x00 0x484a4000 0x00 0x2000>, - <0x00 0x484c2000 0x00 0x2000>, - <0x00 0x48420000 0x00 0x2000>; - reg-names = "gcfg", "bchanrt", "rchanrt", "tchanrt", "ringrt", - "ring", "tchan", "rchan", "bchan"; - msi-parent = <&inta_main_dmss>; - #dma-cells = <3>; - - ti,sci = <&dmsc>; - ti,sci-dev-id = <26>; - ti,sci-rm-range-bchan = <0x20>; /* BLOCK_COPY_CHAN */ - ti,sci-rm-range-rchan = <0x21>; /* SPLIT_TR_RX_CHAN */ - ti,sci-rm-range-tchan = <0x22>; /* SPLIT_TR_TX_CHAN */ - }; - - main_pktdma: dma-controller@485c0000 { - compatible = "ti,am64-dmss-pktdma"; - reg = <0x00 0x485c0000 0x00 0x100>, - <0x00 0x4a800000 0x00 0x20000>, - <0x00 0x4aa00000 0x00 0x40000>, - <0x00 0x4b800000 0x00 0x400000>, - <0x00 0x485e0000 0x00 0x10000>, - <0x00 0x484a0000 0x00 0x2000>, - <0x00 0x484c0000 0x00 0x2000>, - <0x00 0x48430000 0x00 0x1000>; - reg-names = "gcfg", "rchanrt", "tchanrt", "ringrt", - "ring", "tchan", "rchan", "rflow"; - msi-parent = <&inta_main_dmss>; - #dma-cells = <2>; - - ti,sci = <&dmsc>; - ti,sci-dev-id = <30>; - ti,sci-rm-range-tchan = <0x23>, /* UNMAPPED_TX_CHAN */ - <0x24>, /* CPSW_TX_CHAN */ - <0x25>, /* SAUL_TX_0_CHAN */ - <0x26>; /* SAUL_TX_1_CHAN */ - ti,sci-rm-range-tflow = <0x10>, /* RING_UNMAPPED_TX_CHAN */ - <0x11>, /* RING_CPSW_TX_CHAN */ - <0x12>, /* RING_SAUL_TX_0_CHAN */ - <0x13>; /* RING_SAUL_TX_1_CHAN */ - ti,sci-rm-range-rchan = <0x29>, /* UNMAPPED_RX_CHAN */ - <0x2b>, /* CPSW_RX_CHAN */ - <0x2d>, /* SAUL_RX_0_CHAN */ - <0x2f>, /* SAUL_RX_1_CHAN */ - <0x31>, /* SAUL_RX_2_CHAN */ - <0x33>; /* SAUL_RX_3_CHAN */ - ti,sci-rm-range-rflow = <0x2a>, /* FLOW_UNMAPPED_RX_CHAN */ - <0x2c>, /* FLOW_CPSW_RX_CHAN */ - <0x2e>, /* FLOW_SAUL_RX_0/1_CHAN */ - <0x32>; /* FLOW_SAUL_RX_2/3_CHAN */ - }; - }; - - dmsc: system-controller@44043000 { - bootph-all; - compatible = "ti,k2g-sci"; - ti,host-id = <12>; - mbox-names = "rx", "tx"; - mboxes = <&secure_proxy_main 12>, - <&secure_proxy_main 13>; - reg-names = "debug_messages"; - reg = <0x00 0x44043000 0x00 0xfe0>; - - k3_pds: power-controller { - bootph-all; - compatible = "ti,sci-pm-domain"; - #power-domain-cells = <2>; - }; - - k3_clks: clock-controller { - bootph-all; - compatible = "ti,k2g-sci-clk"; - #clock-cells = <2>; - }; - - k3_reset: reset-controller { - bootph-all; - compatible = "ti,sci-reset"; - #reset-cells = <2>; - }; - }; - - crypto: crypto@40900000 { - compatible = "ti,am62-sa3ul"; - reg = <0x00 0x40900000 0x00 0x1200>; - #address-cells = <2>; - #size-cells = <2>; - ranges = <0x00 0x40900000 0x00 0x40900000 0x00 0x30000>; - - dmas = <&main_pktdma 0xf501 0>, <&main_pktdma 0x7506 0>, - <&main_pktdma 0x7507 0>; - dma-names = "tx", "rx1", "rx2"; - }; - - secure_proxy_sa3: mailbox@43600000 { - bootph-pre-ram; - compatible = "ti,am654-secure-proxy"; - #mbox-cells = <1>; - reg-names = "target_data", "rt", "scfg"; - reg = <0x00 0x43600000 0x00 0x10000>, - <0x00 0x44880000 0x00 0x20000>, - <0x00 0x44860000 0x00 0x20000>; - /* - * Marked Disabled: - * Node is incomplete as it is meant for bootloaders and - * firmware on non-MPU processors - */ - status = "disabled"; - }; - - main_pmx0: pinctrl@f4000 { - bootph-all; - compatible = "pinctrl-single"; - reg = <0x00 0xf4000 0x00 0x2ac>; - #pinctrl-cells = <1>; - pinctrl-single,register-width = <32>; - pinctrl-single,function-mask = <0xffffffff>; - }; - - main_esm: esm@420000 { - bootph-pre-ram; - compatible = "ti,j721e-esm"; - reg = <0x00 0x420000 0x00 0x1000>; - ti,esm-pins = <160>, <161>, <162>, <163>, <177>, <178>; - }; - - main_timer0: timer@2400000 { - bootph-all; - compatible = "ti,am654-timer"; - reg = <0x00 0x2400000 0x00 0x400>; - interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 36 2>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 36 2>; - assigned-clock-parents = <&k3_clks 36 3>; - power-domains = <&k3_pds 36 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer1: timer@2410000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x2410000 0x00 0x400>; - interrupts = <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 37 2>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 37 2>; - assigned-clock-parents = <&k3_clks 37 3>; - power-domains = <&k3_pds 37 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer2: timer@2420000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x2420000 0x00 0x400>; - interrupts = <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 38 2>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 38 2>; - assigned-clock-parents = <&k3_clks 38 3>; - power-domains = <&k3_pds 38 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer3: timer@2430000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x2430000 0x00 0x400>; - interrupts = <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 39 2>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 39 2>; - assigned-clock-parents = <&k3_clks 39 3>; - power-domains = <&k3_pds 39 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer4: timer@2440000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x2440000 0x00 0x400>; - interrupts = <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 40 2>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 40 2>; - assigned-clock-parents = <&k3_clks 40 3>; - power-domains = <&k3_pds 40 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer5: timer@2450000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x2450000 0x00 0x400>; - interrupts = <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 41 2>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 41 2>; - assigned-clock-parents = <&k3_clks 41 3>; - power-domains = <&k3_pds 41 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer6: timer@2460000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x2460000 0x00 0x400>; - interrupts = <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 42 2>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 42 2>; - assigned-clock-parents = <&k3_clks 42 3>; - power-domains = <&k3_pds 42 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer7: timer@2470000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x2470000 0x00 0x400>; - interrupts = <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 43 2>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 43 2>; - assigned-clock-parents = <&k3_clks 43 3>; - power-domains = <&k3_pds 43 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_uart0: serial@2800000 { - compatible = "ti,am64-uart", "ti,am654-uart"; - reg = <0x00 0x02800000 0x00 0x100>; - interrupts = <GIC_SPI 178 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&k3_pds 146 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 146 0>; - clock-names = "fclk"; - status = "disabled"; - }; - - main_uart1: serial@2810000 { - compatible = "ti,am64-uart", "ti,am654-uart"; - reg = <0x00 0x02810000 0x00 0x100>; - interrupts = <GIC_SPI 179 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&k3_pds 152 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 152 0>; - clock-names = "fclk"; - status = "disabled"; - }; - - main_uart2: serial@2820000 { - compatible = "ti,am64-uart", "ti,am654-uart"; - reg = <0x00 0x02820000 0x00 0x100>; - interrupts = <GIC_SPI 180 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&k3_pds 153 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 153 0>; - clock-names = "fclk"; - status = "disabled"; - }; - - main_uart3: serial@2830000 { - compatible = "ti,am64-uart", "ti,am654-uart"; - reg = <0x00 0x02830000 0x00 0x100>; - interrupts = <GIC_SPI 181 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&k3_pds 154 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 154 0>; - clock-names = "fclk"; - status = "disabled"; - }; - - main_uart4: serial@2840000 { - compatible = "ti,am64-uart", "ti,am654-uart"; - reg = <0x00 0x02840000 0x00 0x100>; - interrupts = <GIC_SPI 182 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&k3_pds 155 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 155 0>; - clock-names = "fclk"; - status = "disabled"; - }; - - main_uart5: serial@2850000 { - compatible = "ti,am64-uart", "ti,am654-uart"; - reg = <0x00 0x02850000 0x00 0x100>; - interrupts = <GIC_SPI 183 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&k3_pds 156 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 156 0>; - clock-names = "fclk"; - status = "disabled"; - }; - - main_uart6: serial@2860000 { - compatible = "ti,am64-uart", "ti,am654-uart"; - reg = <0x00 0x02860000 0x00 0x100>; - interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&k3_pds 158 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 158 0>; - clock-names = "fclk"; - status = "disabled"; - }; - - main_i2c0: i2c@20000000 { - compatible = "ti,am64-i2c", "ti,omap4-i2c"; - reg = <0x00 0x20000000 0x00 0x100>; - interrupts = <GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 102 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 102 2>; - clock-names = "fck"; - status = "disabled"; - }; - - main_i2c1: i2c@20010000 { - compatible = "ti,am64-i2c", "ti,omap4-i2c"; - reg = <0x00 0x20010000 0x00 0x100>; - interrupts = <GIC_SPI 162 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 103 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 103 2>; - clock-names = "fck"; - status = "disabled"; - }; - - main_i2c2: i2c@20020000 { - compatible = "ti,am64-i2c", "ti,omap4-i2c"; - reg = <0x00 0x20020000 0x00 0x100>; - interrupts = <GIC_SPI 163 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 104 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 104 2>; - clock-names = "fck"; - status = "disabled"; - }; - - main_i2c3: i2c@20030000 { - compatible = "ti,am64-i2c", "ti,omap4-i2c"; - reg = <0x00 0x20030000 0x00 0x100>; - interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 105 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 105 2>; - clock-names = "fck"; - status = "disabled"; - }; - - main_spi0: spi@20100000 { - compatible = "ti,am654-mcspi", "ti,omap4-mcspi"; - reg = <0x00 0x20100000 0x00 0x400>; - interrupts = <GIC_SPI 172 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 141 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 141 0>; - status = "disabled"; - }; - - main_spi1: spi@20110000 { - compatible = "ti,am654-mcspi","ti,omap4-mcspi"; - reg = <0x00 0x20110000 0x00 0x400>; - interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 142 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 142 0>; - status = "disabled"; - }; - - main_spi2: spi@20120000 { - compatible = "ti,am654-mcspi","ti,omap4-mcspi"; - reg = <0x00 0x20120000 0x00 0x400>; - interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 143 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 143 0>; - status = "disabled"; - }; - - main_gpio_intr: interrupt-controller@a00000 { - compatible = "ti,sci-intr"; - reg = <0x00 0x00a00000 0x00 0x800>; - ti,intr-trigger-type = <1>; - interrupt-controller; - interrupt-parent = <&gic500>; - #interrupt-cells = <1>; - ti,sci = <&dmsc>; - ti,sci-dev-id = <3>; - ti,interrupt-ranges = <0 32 16>; - }; - - main_gpio0: gpio@600000 { - compatible = "ti,am64-gpio", "ti,keystone-gpio"; - reg = <0x0 0x00600000 0x0 0x100>; - gpio-ranges = <&main_pmx0 0 0 32>, - <&main_pmx0 32 33 38>, - <&main_pmx0 70 72 22>; - gpio-controller; - #gpio-cells = <2>; - interrupt-parent = <&main_gpio_intr>; - interrupts = <190>, <191>, <192>, - <193>, <194>, <195>; - interrupt-controller; - #interrupt-cells = <2>; - ti,ngpio = <92>; - ti,davinci-gpio-unbanked = <0>; - power-domains = <&k3_pds 77 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 77 0>; - clock-names = "gpio"; - }; - - main_gpio1: gpio@601000 { - compatible = "ti,am64-gpio", "ti,keystone-gpio"; - reg = <0x0 0x00601000 0x0 0x100>; - gpio-controller; - gpio-ranges = <&main_pmx0 0 94 41>, - <&main_pmx0 41 136 6>, - <&main_pmx0 47 143 3>, - <&main_pmx0 50 149 2>; - #gpio-cells = <2>; - interrupt-parent = <&main_gpio_intr>; - interrupts = <180>, <181>, <182>, - <183>, <184>, <185>; - interrupt-controller; - #interrupt-cells = <2>; - ti,ngpio = <52>; - ti,davinci-gpio-unbanked = <0>; - power-domains = <&k3_pds 78 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 78 0>; - clock-names = "gpio"; - }; - - sdhci0: mmc@fa10000 { - compatible = "ti,am62-sdhci"; - reg = <0x00 0x0fa10000 0x00 0x1000>, <0x00 0x0fa18000 0x00 0x400>; - interrupts = <GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&k3_pds 57 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 57 5>, <&k3_clks 57 6>; - clock-names = "clk_ahb", "clk_xin"; - assigned-clocks = <&k3_clks 57 6>; - assigned-clock-parents = <&k3_clks 57 8>; - bus-width = <8>; - mmc-ddr-1_8v; - mmc-hs200-1_8v; - ti,clkbuf-sel = <0x7>; - ti,otap-del-sel-legacy = <0x0>; - ti,otap-del-sel-mmc-hs = <0x0>; - ti,otap-del-sel-ddr52 = <0x5>; - ti,otap-del-sel-hs200 = <0x5>; - ti,itap-del-sel-legacy = <0xa>; - ti,itap-del-sel-mmc-hs = <0x1>; - status = "disabled"; - }; - - sdhci1: mmc@fa00000 { - compatible = "ti,am62-sdhci"; - reg = <0x00 0x0fa00000 0x00 0x1000>, <0x00 0x0fa08000 0x00 0x400>; - interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&k3_pds 58 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 58 5>, <&k3_clks 58 6>; - clock-names = "clk_ahb", "clk_xin"; - bus-width = <4>; - ti,clkbuf-sel = <0x7>; - ti,otap-del-sel-legacy = <0x8>; - ti,otap-del-sel-sd-hs = <0x0>; - ti,otap-del-sel-sdr12 = <0x0>; - ti,otap-del-sel-sdr25 = <0x0>; - ti,otap-del-sel-sdr50 = <0x8>; - ti,otap-del-sel-sdr104 = <0x7>; - ti,otap-del-sel-ddr50 = <0x4>; - ti,itap-del-sel-legacy = <0xa>; - ti,itap-del-sel-sd-hs = <0x1>; - ti,itap-del-sel-sdr12 = <0xa>; - ti,itap-del-sel-sdr25 = <0x1>; - status = "disabled"; - }; - - sdhci2: mmc@fa20000 { - compatible = "ti,am62-sdhci"; - reg = <0x00 0x0fa20000 0x00 0x1000>, <0x00 0x0fa28000 0x00 0x400>; - interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&k3_pds 184 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 184 5>, <&k3_clks 184 6>; - clock-names = "clk_ahb", "clk_xin"; - bus-width = <4>; - ti,clkbuf-sel = <0x7>; - ti,otap-del-sel-legacy = <0x8>; - ti,otap-del-sel-sd-hs = <0x0>; - ti,otap-del-sel-sdr12 = <0x0>; - ti,otap-del-sel-sdr25 = <0x0>; - ti,otap-del-sel-sdr50 = <0x8>; - ti,otap-del-sel-sdr104 = <0x7>; - ti,otap-del-sel-ddr50 = <0x8>; - ti,itap-del-sel-legacy = <0xa>; - ti,itap-del-sel-sd-hs = <0xa>; - ti,itap-del-sel-sdr12 = <0xa>; - ti,itap-del-sel-sdr25 = <0x1>; - status = "disabled"; - }; - - usbss0: dwc3-usb@f900000 { - compatible = "ti,am62-usb"; - reg = <0x00 0x0f900000 0x00 0x800>; - clocks = <&k3_clks 161 3>; - clock-names = "ref"; - ti,syscon-phy-pll-refclk = <&wkup_conf 0x4008>; - #address-cells = <2>; - #size-cells = <2>; - power-domains = <&k3_pds 178 TI_SCI_PD_EXCLUSIVE>; - ranges; - status = "disabled"; - - usb0: usb@31000000 { - compatible = "snps,dwc3"; - reg = <0x00 0x31000000 0x00 0x50000>; - interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>, /* irq.0 */ - <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; /* irq.0 */ - interrupt-names = "host", "peripheral"; - maximum-speed = "high-speed"; - dr_mode = "otg"; - snps,usb2-gadget-lpm-disable; - snps,usb2-lpm-disable; - }; - }; - - usbss1: dwc3-usb@f910000 { - compatible = "ti,am62-usb"; - reg = <0x00 0x0f910000 0x00 0x800>; - clocks = <&k3_clks 162 3>; - clock-names = "ref"; - ti,syscon-phy-pll-refclk = <&wkup_conf 0x4018>; - #address-cells = <2>; - #size-cells = <2>; - power-domains = <&k3_pds 179 TI_SCI_PD_EXCLUSIVE>; - ranges; - status = "disabled"; - - usb1: usb@31100000 { - compatible = "snps,dwc3"; - reg = <0x00 0x31100000 0x00 0x50000>; - interrupts = <GIC_SPI 226 IRQ_TYPE_LEVEL_HIGH>, /* irq.0 */ - <GIC_SPI 226 IRQ_TYPE_LEVEL_HIGH>; /* irq.0 */ - interrupt-names = "host", "peripheral"; - maximum-speed = "high-speed"; - dr_mode = "otg"; - snps,usb2-gadget-lpm-disable; - snps,usb2-lpm-disable; - }; - }; - - fss: bus@fc00000 { - compatible = "simple-bus"; - reg = <0x00 0x0fc00000 0x00 0x70000>; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - ospi0: spi@fc40000 { - compatible = "ti,am654-ospi", "cdns,qspi-nor"; - reg = <0x00 0x0fc40000 0x00 0x100>, - <0x05 0x00000000 0x01 0x00000000>; - interrupts = <GIC_SPI 139 IRQ_TYPE_LEVEL_HIGH>; - cdns,fifo-depth = <256>; - cdns,fifo-width = <4>; - cdns,trigger-address = <0x0>; - clocks = <&k3_clks 75 7>; - assigned-clocks = <&k3_clks 75 7>; - assigned-clock-parents = <&k3_clks 75 8>; - assigned-clock-rates = <166666666>; - power-domains = <&k3_pds 75 TI_SCI_PD_EXCLUSIVE>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - }; - - gpu: gpu@fd00000 { - compatible = "ti,am62-gpu", "img,img-axe"; - reg = <0x00 0x0fd00000 0x00 0x20000>; - clocks = <&k3_clks 187 0>; - clock-names = "core"; - interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&k3_pds 187 TI_SCI_PD_EXCLUSIVE>; - }; - - cpsw3g: ethernet@8000000 { - compatible = "ti,am642-cpsw-nuss"; - #address-cells = <2>; - #size-cells = <2>; - reg = <0x00 0x08000000 0x00 0x200000>; - reg-names = "cpsw_nuss"; - ranges = <0x00 0x00 0x00 0x08000000 0x00 0x200000>; - clocks = <&k3_clks 13 0>; - assigned-clocks = <&k3_clks 13 3>; - assigned-clock-parents = <&k3_clks 13 11>; - clock-names = "fck"; - power-domains = <&k3_pds 13 TI_SCI_PD_EXCLUSIVE>; - - dmas = <&main_pktdma 0xc600 15>, - <&main_pktdma 0xc601 15>, - <&main_pktdma 0xc602 15>, - <&main_pktdma 0xc603 15>, - <&main_pktdma 0xc604 15>, - <&main_pktdma 0xc605 15>, - <&main_pktdma 0xc606 15>, - <&main_pktdma 0xc607 15>, - <&main_pktdma 0x4600 15>; - dma-names = "tx0", "tx1", "tx2", "tx3", "tx4", "tx5", "tx6", - "tx7", "rx"; - - ethernet-ports { - #address-cells = <1>; - #size-cells = <0>; - - cpsw_port1: port@1 { - reg = <1>; - ti,mac-only; - label = "port1"; - phys = <&phy_gmii_sel 1>; - mac-address = [00 00 00 00 00 00]; - ti,syscon-efuse = <&wkup_conf 0x200>; - }; - - cpsw_port2: port@2 { - reg = <2>; - ti,mac-only; - label = "port2"; - phys = <&phy_gmii_sel 2>; - mac-address = [00 00 00 00 00 00]; - }; - }; - - cpsw3g_mdio: mdio@f00 { - compatible = "ti,cpsw-mdio","ti,davinci_mdio"; - reg = <0x00 0xf00 0x00 0x100>; - #address-cells = <1>; - #size-cells = <0>; - clocks = <&k3_clks 13 0>; - clock-names = "fck"; - bus_freq = <1000000>; - status = "disabled"; - }; - - cpts@3d000 { - compatible = "ti,j721e-cpts"; - reg = <0x00 0x3d000 0x00 0x400>; - clocks = <&k3_clks 13 3>; - clock-names = "cpts"; - interrupts-extended = <&gic500 GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "cpts"; - ti,cpts-ext-ts-inputs = <4>; - ti,cpts-periodic-outputs = <2>; - }; - }; - - dss: dss@30200000 { - compatible = "ti,am625-dss"; - reg = <0x00 0x30200000 0x00 0x1000>, /* common */ - <0x00 0x30202000 0x00 0x1000>, /* vidl1 */ - <0x00 0x30206000 0x00 0x1000>, /* vid */ - <0x00 0x30207000 0x00 0x1000>, /* ovr1 */ - <0x00 0x30208000 0x00 0x1000>, /* ovr2 */ - <0x00 0x3020a000 0x00 0x1000>, /* vp1: Used for OLDI */ - <0x00 0x3020b000 0x00 0x1000>, /* vp2: Used as DPI Out */ - <0x00 0x30201000 0x00 0x1000>; /* common1 */ - reg-names = "common", "vidl1", "vid", - "ovr1", "ovr2", "vp1", "vp2", "common1"; - power-domains = <&k3_pds 186 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 186 6>, - <&dss_vp1_clk>, - <&k3_clks 186 2>; - clock-names = "fck", "vp1", "vp2"; - interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>; - status = "disabled"; - - dss_ports: ports { - #address-cells = <1>; - #size-cells = <0>; - }; - }; - - hwspinlock: spinlock@2a000000 { - compatible = "ti,am64-hwspinlock"; - reg = <0x00 0x2a000000 0x00 0x1000>; - #hwlock-cells = <1>; - }; - - mailbox0_cluster0: mailbox@29000000 { - compatible = "ti,am64-mailbox"; - reg = <0x00 0x29000000 0x00 0x200>; - interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 77 IRQ_TYPE_LEVEL_HIGH>; - #mbox-cells = <1>; - ti,mbox-num-users = <4>; - ti,mbox-num-fifos = <16>; - }; - - ecap0: pwm@23100000 { - compatible = "ti,am3352-ecap"; - #pwm-cells = <3>; - reg = <0x00 0x23100000 0x00 0x100>; - power-domains = <&k3_pds 51 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 51 0>; - clock-names = "fck"; - status = "disabled"; - }; - - ecap1: pwm@23110000 { - compatible = "ti,am3352-ecap"; - #pwm-cells = <3>; - reg = <0x00 0x23110000 0x00 0x100>; - power-domains = <&k3_pds 52 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 52 0>; - clock-names = "fck"; - status = "disabled"; - }; - - ecap2: pwm@23120000 { - compatible = "ti,am3352-ecap"; - #pwm-cells = <3>; - reg = <0x00 0x23120000 0x00 0x100>; - power-domains = <&k3_pds 53 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 53 0>; - clock-names = "fck"; - status = "disabled"; - }; - - main_mcan0: can@20701000 { - compatible = "bosch,m_can"; - reg = <0x00 0x20701000 0x00 0x200>, - <0x00 0x20708000 0x00 0x8000>; - reg-names = "m_can", "message_ram"; - power-domains = <&k3_pds 98 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 98 6>, <&k3_clks 98 1>; - clock-names = "hclk", "cclk"; - interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "int0", "int1"; - bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>; - status = "disabled"; - }; - - main_rti0: watchdog@e000000 { - compatible = "ti,j7-rti-wdt"; - reg = <0x00 0x0e000000 0x00 0x100>; - clocks = <&k3_clks 125 0>; - power-domains = <&k3_pds 125 TI_SCI_PD_EXCLUSIVE>; - assigned-clocks = <&k3_clks 125 0>; - assigned-clock-parents = <&k3_clks 125 2>; - }; - - main_rti1: watchdog@e010000 { - compatible = "ti,j7-rti-wdt"; - reg = <0x00 0x0e010000 0x00 0x100>; - clocks = <&k3_clks 126 0>; - power-domains = <&k3_pds 126 TI_SCI_PD_EXCLUSIVE>; - assigned-clocks = <&k3_clks 126 0>; - assigned-clock-parents = <&k3_clks 126 2>; - }; - - main_rti2: watchdog@e020000 { - compatible = "ti,j7-rti-wdt"; - reg = <0x00 0x0e020000 0x00 0x100>; - clocks = <&k3_clks 127 0>; - power-domains = <&k3_pds 127 TI_SCI_PD_EXCLUSIVE>; - assigned-clocks = <&k3_clks 127 0>; - assigned-clock-parents = <&k3_clks 127 2>; - }; - - main_rti3: watchdog@e030000 { - compatible = "ti,j7-rti-wdt"; - reg = <0x00 0x0e030000 0x00 0x100>; - clocks = <&k3_clks 128 0>; - power-domains = <&k3_pds 128 TI_SCI_PD_EXCLUSIVE>; - assigned-clocks = <&k3_clks 128 0>; - assigned-clock-parents = <&k3_clks 128 2>; - }; - - main_rti15: watchdog@e0f0000 { - compatible = "ti,j7-rti-wdt"; - reg = <0x00 0x0e0f0000 0x00 0x100>; - clocks = <&k3_clks 130 0>; - power-domains = <&k3_pds 130 TI_SCI_PD_EXCLUSIVE>; - assigned-clocks = <&k3_clks 130 0>; - assigned-clock-parents = <&k3_clks 130 2>; - }; - - epwm0: pwm@23000000 { - compatible = "ti,am64-epwm", "ti,am3352-ehrpwm"; - #pwm-cells = <3>; - reg = <0x00 0x23000000 0x00 0x100>; - power-domains = <&k3_pds 86 TI_SCI_PD_EXCLUSIVE>; - clocks = <&epwm_tbclk 0>, <&k3_clks 86 0>; - clock-names = "tbclk", "fck"; - status = "disabled"; - }; - - epwm1: pwm@23010000 { - compatible = "ti,am64-epwm", "ti,am3352-ehrpwm"; - #pwm-cells = <3>; - reg = <0x00 0x23010000 0x00 0x100>; - power-domains = <&k3_pds 87 TI_SCI_PD_EXCLUSIVE>; - clocks = <&epwm_tbclk 1>, <&k3_clks 87 0>; - clock-names = "tbclk", "fck"; - status = "disabled"; - }; - - epwm2: pwm@23020000 { - compatible = "ti,am64-epwm", "ti,am3352-ehrpwm"; - #pwm-cells = <3>; - reg = <0x00 0x23020000 0x00 0x100>; - power-domains = <&k3_pds 88 TI_SCI_PD_EXCLUSIVE>; - clocks = <&epwm_tbclk 2>, <&k3_clks 88 0>; - clock-names = "tbclk", "fck"; - status = "disabled"; - }; - - mcasp0: audio-controller@2b00000 { - compatible = "ti,am33xx-mcasp-audio"; - reg = <0x00 0x02b00000 0x00 0x2000>, - <0x00 0x02b08000 0x00 0x400>; - reg-names = "mpu", "dat"; - interrupts = <GIC_SPI 236 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 235 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "tx", "rx"; - - dmas = <&main_bcdma 0 0xc500 0>, <&main_bcdma 0 0x4500 0>; - dma-names = "tx", "rx"; - - clocks = <&k3_clks 190 0>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 190 0>; - assigned-clock-parents = <&k3_clks 190 2>; - power-domains = <&k3_pds 190 TI_SCI_PD_EXCLUSIVE>; - status = "disabled"; - }; - - mcasp1: audio-controller@2b10000 { - compatible = "ti,am33xx-mcasp-audio"; - reg = <0x00 0x02b10000 0x00 0x2000>, - <0x00 0x02b18000 0x00 0x400>; - reg-names = "mpu", "dat"; - interrupts = <GIC_SPI 238 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 237 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "tx", "rx"; - - dmas = <&main_bcdma 0 0xc501 0>, <&main_bcdma 0 0x4501 0>; - dma-names = "tx", "rx"; - - clocks = <&k3_clks 191 0>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 191 0>; - assigned-clock-parents = <&k3_clks 191 2>; - power-domains = <&k3_pds 191 TI_SCI_PD_EXCLUSIVE>; - status = "disabled"; - }; - - mcasp2: audio-controller@2b20000 { - compatible = "ti,am33xx-mcasp-audio"; - reg = <0x00 0x02b20000 0x00 0x2000>, - <0x00 0x02b28000 0x00 0x400>; - reg-names = "mpu", "dat"; - interrupts = <GIC_SPI 240 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 239 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "tx", "rx"; - - dmas = <&main_bcdma 0 0xc502 0>, <&main_bcdma 0 0x4502 0>; - dma-names = "tx", "rx"; - - clocks = <&k3_clks 192 0>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 192 0>; - assigned-clock-parents = <&k3_clks 192 2>; - power-domains = <&k3_pds 192 TI_SCI_PD_EXCLUSIVE>; - status = "disabled"; - }; - - ti_csi2rx0: ticsi2rx@30102000 { - compatible = "ti,j721e-csi2rx-shim"; - dmas = <&main_bcdma 0 0x4700 0>; - dma-names = "rx0"; - reg = <0x00 0x30102000 0x00 0x1000>; - power-domains = <&k3_pds 182 TI_SCI_PD_EXCLUSIVE>; - #address-cells = <2>; - #size-cells = <2>; - ranges; - status = "disabled"; - - cdns_csi2rx0: csi-bridge@30101000 { - compatible = "ti,j721e-csi2rx", "cdns,csi2rx"; - reg = <0x00 0x30101000 0x00 0x1000>; - clocks = <&k3_clks 182 0>, <&k3_clks 182 3>, <&k3_clks 182 0>, - <&k3_clks 182 0>, <&k3_clks 182 4>, <&k3_clks 182 4>; - clock-names = "sys_clk", "p_clk", "pixel_if0_clk", - "pixel_if1_clk", "pixel_if2_clk", "pixel_if3_clk"; - phys = <&dphy0>; - phy-names = "dphy"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - csi0_port0: port@0 { - reg = <0>; - status = "disabled"; - }; - - csi0_port1: port@1 { - reg = <1>; - status = "disabled"; - }; - - csi0_port2: port@2 { - reg = <2>; - status = "disabled"; - }; - - csi0_port3: port@3 { - reg = <3>; - status = "disabled"; - }; - - csi0_port4: port@4 { - reg = <4>; - status = "disabled"; - }; - }; - }; - }; - - dphy0: phy@30110000 { - compatible = "cdns,dphy-rx"; - reg = <0x00 0x30110000 0x00 0x1100>; - #phy-cells = <0>; - power-domains = <&k3_pds 185 TI_SCI_PD_EXCLUSIVE>; - status = "disabled"; - }; - -}; diff --git a/arch/arm/dts/k3-am62-mcu.dtsi b/arch/arm/dts/k3-am62-mcu.dtsi deleted file mode 100644 index e66d486ef1f2..000000000000 --- a/arch/arm/dts/k3-am62-mcu.dtsi +++ /dev/null @@ -1,176 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only OR MIT -/* - * Device Tree Source for AM625 SoC Family MCU Domain peripherals - * - * Copyright (C) 2020-2024 Texas Instruments Incorporated - https://www.ti.com/ - */ - -&cbass_mcu { - mcu_pmx0: pinctrl@4084000 { - bootph-all; - compatible = "pinctrl-single"; - reg = <0x00 0x04084000 0x00 0x88>; - #pinctrl-cells = <1>; - pinctrl-single,register-width = <32>; - pinctrl-single,function-mask = <0xffffffff>; - }; - - mcu_esm: esm@4100000 { - bootph-pre-ram; - compatible = "ti,j721e-esm"; - reg = <0x00 0x4100000 0x00 0x1000>; - ti,esm-pins = <0>, <1>, <2>, <85>; - }; - - /* - * The MCU domain timer interrupts are routed only to the ESM module, - * and not currently available for Linux. The MCU domain timers are - * of limited use without interrupts, and likely reserved by the ESM. - */ - mcu_timer0: timer@4800000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x4800000 0x00 0x400>; - clocks = <&k3_clks 35 2>; - clock-names = "fck"; - power-domains = <&k3_pds 35 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - status = "reserved"; - }; - - mcu_timer1: timer@4810000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x4810000 0x00 0x400>; - clocks = <&k3_clks 48 2>; - clock-names = "fck"; - power-domains = <&k3_pds 48 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - status = "reserved"; - }; - - mcu_timer2: timer@4820000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x4820000 0x00 0x400>; - clocks = <&k3_clks 49 2>; - clock-names = "fck"; - power-domains = <&k3_pds 49 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - status = "reserved"; - }; - - mcu_timer3: timer@4830000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x4830000 0x00 0x400>; - clocks = <&k3_clks 50 2>; - clock-names = "fck"; - power-domains = <&k3_pds 50 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - status = "reserved"; - }; - - mcu_uart0: serial@4a00000 { - compatible = "ti,am64-uart", "ti,am654-uart"; - reg = <0x00 0x04a00000 0x00 0x100>; - interrupts = <GIC_SPI 185 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&k3_pds 149 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 149 0>; - clock-names = "fclk"; - status = "disabled"; - }; - - mcu_i2c0: i2c@4900000 { - compatible = "ti,am64-i2c", "ti,omap4-i2c"; - reg = <0x00 0x04900000 0x00 0x100>; - interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 106 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 106 2>; - clock-names = "fck"; - status = "disabled"; - }; - - mcu_spi0: spi@4b00000 { - compatible = "ti,am654-mcspi", "ti,omap4-mcspi"; - reg = <0x00 0x04b00000 0x00 0x400>; - interrupts = <GIC_SPI 176 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 147 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 147 0>; - status = "disabled"; - }; - - mcu_spi1: spi@4b10000 { - compatible = "ti,am654-mcspi","ti,omap4-mcspi"; - reg = <0x00 0x04b10000 0x00 0x400>; - interrupts = <GIC_SPI 177 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 148 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 148 0>; - status = "disabled"; - }; - - mcu_gpio_intr: interrupt-controller@4210000 { - compatible = "ti,sci-intr"; - reg = <0x00 0x04210000 0x00 0x200>; - ti,intr-trigger-type = <1>; - interrupt-controller; - interrupt-parent = <&gic500>; - #interrupt-cells = <1>; - ti,sci = <&dmsc>; - ti,sci-dev-id = <5>; - ti,interrupt-ranges = <0 104 4>; - }; - - mcu_gpio0: gpio@4201000 { - compatible = "ti,am64-gpio", "ti,keystone-gpio"; - reg = <0x00 0x4201000 0x00 0x100>; - gpio-controller; - #gpio-cells = <2>; - interrupt-parent = <&mcu_gpio_intr>; - interrupts = <30>, <31>; - interrupt-controller; - #interrupt-cells = <2>; - ti,ngpio = <24>; - ti,davinci-gpio-unbanked = <0>; - power-domains = <&k3_pds 79 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 79 0>; - clock-names = "gpio"; - }; - - mcu_rti0: watchdog@4880000 { - compatible = "ti,j7-rti-wdt"; - reg = <0x00 0x04880000 0x00 0x100>; - clocks = <&k3_clks 131 0>; - power-domains = <&k3_pds 131 TI_SCI_PD_EXCLUSIVE>; - assigned-clocks = <&k3_clks 131 0>; - assigned-clock-parents = <&k3_clks 131 2>; - /* Tightly coupled to M4F */ - status = "reserved"; - }; - - mcu_mcan0: can@4e08000 { - compatible = "bosch,m_can"; - reg = <0x00 0x4e08000 0x00 0x200>, - <0x00 0x4e00000 0x00 0x8000>; - reg-names = "m_can", "message_ram"; - power-domains = <&k3_pds 188 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 188 6>, <&k3_clks 188 1>; - clock-names = "hclk", "cclk"; - bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>; - status = "disabled"; - }; - - mcu_mcan1: can@4e18000 { - compatible = "bosch,m_can"; - reg = <0x00 0x4e18000 0x00 0x200>, - <0x00 0x4e10000 0x00 0x8000>; - reg-names = "m_can", "message_ram"; - power-domains = <&k3_pds 189 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 189 6>, <&k3_clks 189 1>; - clock-names = "hclk", "cclk"; - bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>; - status = "disabled"; - }; -}; diff --git a/arch/arm/dts/k3-am62-thermal.dtsi b/arch/arm/dts/k3-am62-thermal.dtsi deleted file mode 100644 index 12ba833002a1..000000000000 --- a/arch/arm/dts/k3-am62-thermal.dtsi +++ /dev/null @@ -1,36 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only OR MIT -/* - * Copyright (C) 2023-2024 Texas Instruments Incorporated - https://www.ti.com/ - */ - -#include <dt-bindings/thermal/thermal.h> - -thermal_zones: thermal-zones { - main0_thermal: main0-thermal { - polling-delay-passive = <250>; /* milliSeconds */ - polling-delay = <500>; /* milliSeconds */ - thermal-sensors = <&wkup_vtm0 0>; - - trips { - main0_crit: main0-crit { - temperature = <105000>; /* milliCelsius */ - hysteresis = <2000>; /* milliCelsius */ - type = "critical"; - }; - }; - }; - - main1_thermal: main1-thermal { - polling-delay-passive = <250>; /* milliSeconds */ - polling-delay = <500>; /* milliSeconds */ - thermal-sensors = <&wkup_vtm0 1>; - - trips { - main1_crit: main1-crit { - temperature = <105000>; /* milliCelsius */ - hysteresis = <2000>; /* milliCelsius */ - type = "critical"; - }; - }; - }; -}; diff --git a/arch/arm/dts/k3-am62-wakeup.dtsi b/arch/arm/dts/k3-am62-wakeup.dtsi deleted file mode 100644 index 23ce1bfda8d6..000000000000 --- a/arch/arm/dts/k3-am62-wakeup.dtsi +++ /dev/null @@ -1,96 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only OR MIT -/* - * Device Tree Source for AM625 SoC Family Wakeup Domain peripherals - * - * Copyright (C) 2020-2024 Texas Instruments Incorporated - https://www.ti.com/ - */ - -#include <dt-bindings/bus/ti-sysc.h> - -&cbass_wakeup { - wkup_conf: syscon@43000000 { - bootph-all; - compatible = "syscon", "simple-mfd"; - reg = <0x00 0x43000000 0x00 0x20000>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x0 0x00 0x43000000 0x20000>; - - chipid: chipid@14 { - bootph-all; - compatible = "ti,am654-chipid"; - reg = <0x14 0x4>; - }; - }; - - target-module@2b300050 { - compatible = "ti,sysc-omap2", "ti,sysc"; - reg = <0x00 0x2b300050 0x00 0x4>, - <0x00 0x2b300054 0x00 0x4>, - <0x00 0x2b300058 0x00 0x4>; - reg-names = "rev", "sysc", "syss"; - ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | - SYSC_OMAP2_SOFTRESET | - SYSC_OMAP2_AUTOIDLE)>; - ti,sysc-sidle = <SYSC_IDLE_FORCE>, - <SYSC_IDLE_NO>, - <SYSC_IDLE_SMART>, - <SYSC_IDLE_SMART_WKUP>; - ti,syss-mask = <1>; - ti,no-reset-on-init; - power-domains = <&k3_pds 114 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 114 0>; - clock-names = "fck"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x0 0x00 0x2b300000 0x100000>; - - wkup_uart0: serial@0 { - compatible = "ti,am64-uart", "ti,am654-uart"; - reg = <0x0 0x100>; - interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; - status = "disabled"; - }; - }; - - wkup_i2c0: i2c@2b200000 { - compatible = "ti,am64-i2c", "ti,omap4-i2c"; - reg = <0x00 0x2b200000 0x00 0x100>; - interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 107 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 107 4>; - clock-names = "fck"; - status = "disabled"; - }; - - wkup_rtc0: rtc@2b1f0000 { - compatible = "ti,am62-rtc"; - reg = <0x00 0x2b1f0000 0x00 0x100>; - interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 117 6> , <&k3_clks 117 0>; - clock-names = "vbus", "osc32k"; - power-domains = <&k3_pds 117 TI_SCI_PD_EXCLUSIVE>; - wakeup-source; - }; - - wkup_rti0: watchdog@2b000000 { - compatible = "ti,j7-rti-wdt"; - reg = <0x00 0x2b000000 0x00 0x100>; - clocks = <&k3_clks 132 0>; - power-domains = <&k3_pds 132 TI_SCI_PD_EXCLUSIVE>; - assigned-clocks = <&k3_clks 132 0>; - assigned-clock-parents = <&k3_clks 132 2>; - /* Used by DM firmware */ - status = "reserved"; - }; - - wkup_vtm0: temperature-sensor@b00000 { - compatible = "ti,j7200-vtm"; - reg = <0x00 0xb00000 0x00 0x400>, - <0x00 0xb01000 0x00 0x400>; - power-domains = <&k3_pds 95 TI_SCI_PD_EXCLUSIVE>; - #thermal-sensor-cells = <1>; - }; -}; diff --git a/arch/arm/dts/k3-am62.dtsi b/arch/arm/dts/k3-am62.dtsi deleted file mode 100644 index f0781f2bea29..000000000000 --- a/arch/arm/dts/k3-am62.dtsi +++ /dev/null @@ -1,122 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only OR MIT -/* - * Device Tree Source for AM62 SoC Family - * - * Copyright (C) 2020-2024 Texas Instruments Incorporated - https://www.ti.com/ - */ - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/soc/ti,sci_pm_domain.h> - -#include "k3-pinctrl.h" - -/ { - model = "Texas Instruments K3 AM625 SoC"; - compatible = "ti,am625"; - interrupt-parent = <&gic500>; - #address-cells = <2>; - #size-cells = <2>; - - chosen { }; - - firmware { - optee { - compatible = "linaro,optee-tz"; - method = "smc"; - }; - - psci: psci { - compatible = "arm,psci-1.0"; - method = "smc"; - }; - }; - - a53_timer0: timer-cl0-cpu0 { - compatible = "arm,armv8-timer"; - interrupts = <GIC_PPI 13 IRQ_TYPE_LEVEL_LOW>, /* cntpsirq */ - <GIC_PPI 14 IRQ_TYPE_LEVEL_LOW>, /* cntpnsirq */ - <GIC_PPI 11 IRQ_TYPE_LEVEL_LOW>, /* cntvirq */ - <GIC_PPI 10 IRQ_TYPE_LEVEL_LOW>; /* cnthpirq */ - }; - - pmu: pmu { - compatible = "arm,cortex-a53-pmu"; - interrupts = <GIC_PPI 7 IRQ_TYPE_LEVEL_HIGH>; - }; - - cbass_main: bus@f0000 { - bootph-all; - compatible = "simple-bus"; - #address-cells = <2>; - #size-cells = <2>; - - ranges = <0x00 0x000f0000 0x00 0x000f0000 0x00 0x00030000>, /* Main MMRs */ - <0x00 0x00420000 0x00 0x00420000 0x00 0x00001000>, /* ESM0 */ - <0x00 0x00600000 0x00 0x00600000 0x00 0x00001100>, /* GPIO */ - <0x00 0x00703000 0x00 0x00703000 0x00 0x00000200>, /* USB0 debug trace */ - <0x00 0x0070c000 0x00 0x0070c000 0x00 0x00000200>, /* USB1 debug trace */ - <0x00 0x00a40000 0x00 0x00a40000 0x00 0x00000800>, /* Timesync router */ - <0x00 0x01000000 0x00 0x01000000 0x00 0x01b28400>, /* First peripheral window */ - <0x00 0x08000000 0x00 0x08000000 0x00 0x00200000>, /* Main CPSW */ - <0x00 0x0e000000 0x00 0x0e000000 0x00 0x01d20000>, /* Second peripheral window */ - <0x00 0x0fd00000 0x00 0x0fd00000 0x00 0x00020000>, /* GPU */ - <0x00 0x20000000 0x00 0x20000000 0x00 0x0a008000>, /* Third peripheral window */ - <0x00 0x30040000 0x00 0x30040000 0x00 0x00080000>, /* PRUSS-M */ - <0x00 0x30101000 0x00 0x30101000 0x00 0x00010100>, /* CSI window */ - <0x00 0x30200000 0x00 0x30200000 0x00 0x00010000>, /* DSS */ - <0x00 0x31000000 0x00 0x31000000 0x00 0x00050000>, /* USB0 DWC3 Core window */ - <0x00 0x31100000 0x00 0x31100000 0x00 0x00050000>, /* USB1 DWC3 Core window */ - <0x00 0x40900000 0x00 0x40900000 0x00 0x00030000>, /* SA3UL */ - <0x00 0x43600000 0x00 0x43600000 0x00 0x00010000>, /* SA3 sproxy data */ - <0x00 0x44043000 0x00 0x44043000 0x00 0x00000fe0>, /* TI SCI DEBUG */ - <0x00 0x44860000 0x00 0x44860000 0x00 0x00040000>, /* SA3 sproxy config */ - <0x00 0x48000000 0x00 0x48000000 0x00 0x06400000>, /* DMSS */ - <0x00 0x60000000 0x00 0x60000000 0x00 0x08000000>, /* FSS0 DAT1 */ - <0x00 0x70000000 0x00 0x70000000 0x00 0x00010000>, /* OCSRAM */ - <0x01 0x00000000 0x01 0x00000000 0x00 0x00310000>, /* A53 PERIPHBASE */ - <0x05 0x00000000 0x05 0x00000000 0x01 0x00000000>, /* FSS0 DAT3 */ - - /* MCU Domain Range */ - <0x00 0x04000000 0x00 0x04000000 0x00 0x01ff1400>, - - /* Wakeup Domain Range */ - <0x00 0x00b00000 0x00 0x00b00000 0x00 0x00002400>, /* VTM */ - <0x00 0x2b000000 0x00 0x2b000000 0x00 0x00300400>, - <0x00 0x43000000 0x00 0x43000000 0x00 0x00020000>; - - cbass_mcu: bus@4000000 { - bootph-all; - compatible = "simple-bus"; - #address-cells = <2>; - #size-cells = <2>; - ranges = <0x00 0x04000000 0x00 0x04000000 0x00 0x01ff1400>; /* Peripheral window */ - }; - - cbass_wakeup: bus@b00000 { - bootph-all; - compatible = "simple-bus"; - #address-cells = <2>; - #size-cells = <2>; - ranges = <0x00 0x00b00000 0x00 0x00b00000 0x00 0x00002400>, /* VTM */ - <0x00 0x2b000000 0x00 0x2b000000 0x00 0x00300400>, /* Peripheral Window */ - <0x00 0x43000000 0x00 0x43000000 0x00 0x00020000>; - }; - }; - - dss_vp1_clk: clock-divider-oldi { - compatible = "fixed-factor-clock"; - clocks = <&k3_clks 186 0>; - #clock-cells = <0>; - clock-div = <7>; - clock-mult = <1>; - }; - - #include "k3-am62-thermal.dtsi" -}; - -/* Now include the peripherals for each bus segments */ -#include "k3-am62-main.dtsi" -#include "k3-am62-mcu.dtsi" -#include "k3-am62-wakeup.dtsi" diff --git a/arch/arm/dts/k3-am625-sk-binman.dtsi b/arch/arm/dts/k3-am625-sk-binman.dtsi index dfd38d64f638..db3a3e91b08f 100644 --- a/arch/arm/dts/k3-am625-sk-binman.dtsi +++ b/arch/arm/dts/k3-am625-sk-binman.dtsi @@ -141,7 +141,7 @@
#ifdef CONFIG_TARGET_AM625_A53_EVM
-#define SPL_AM625_SK_DTB "spl/dts/k3-am625-sk.dtb" +#define SPL_AM625_SK_DTB "spl/dts/ti/k3-am625-sk.dtb" #define AM625_SK_DTB "u-boot.dtb"
&binman { diff --git a/arch/arm/dts/k3-am625-sk.dts b/arch/arm/dts/k3-am625-sk.dts deleted file mode 100644 index ae81ebb39d02..000000000000 --- a/arch/arm/dts/k3-am625-sk.dts +++ /dev/null @@ -1,299 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only OR MIT -/* - * AM625 SK: https://www.ti.com/lit/zip/sprr448 - * - * Copyright (C) 2021-2024 Texas Instruments Incorporated - https://www.ti.com/ - */ - -/dts-v1/; - -#include "k3-am62x-sk-common.dtsi" - -/ { - compatible = "ti,am625-sk", "ti,am625"; - model = "Texas Instruments AM625 SK"; - - opp-table { - /* Add 1.4GHz OPP for am625-sk board. Requires VDD_CORE to be at 0.85V */ - opp-1400000000 { - opp-hz = /bits/ 64 <1400000000>; - opp-supported-hw = <0x01 0x0004>; - clock-latency-ns = <6000000>; - }; - }; - - memory@80000000 { - device_type = "memory"; - /* 2G RAM */ - reg = <0x00000000 0x80000000 0x00000000 0x80000000>; - - }; - - vmain_pd: regulator-0 { - /* TPS65988 PD CONTROLLER OUTPUT */ - bootph-all; - compatible = "regulator-fixed"; - regulator-name = "vmain_pd"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - regulator-boot-on; - }; - - vcc_5v0: regulator-1 { - /* Output of LM34936 */ - bootph-all; - compatible = "regulator-fixed"; - regulator-name = "vcc_5v0"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vmain_pd>; - regulator-always-on; - regulator-boot-on; - }; - - vcc_3v3_sys: regulator-2 { - /* output of LM61460-Q1 */ - bootph-all; - compatible = "regulator-fixed"; - regulator-name = "vcc_3v3_sys"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vmain_pd>; - regulator-always-on; - regulator-boot-on; - }; - - vdd_mmc1: regulator-3 { - /* TPS22918DBVR */ - bootph-all; - compatible = "regulator-fixed"; - regulator-name = "vdd_mmc1"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - enable-active-high; - vin-supply = <&vcc_3v3_sys>; - gpio = <&exp1 3 GPIO_ACTIVE_HIGH>; - }; - - vdd_sd_dv: regulator-4 { - /* Output of TLV71033 */ - bootph-all; - compatible = "regulator-gpio"; - regulator-name = "tlv71033"; - pinctrl-names = "default"; - pinctrl-0 = <&vdd_sd_dv_pins_default>; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - vin-supply = <&vcc_5v0>; - gpios = <&main_gpio0 31 GPIO_ACTIVE_HIGH>; - states = <1800000 0x0>, - <3300000 0x1>; - }; - - vcc_1v8: regulator-5 { - /* output of TPS6282518DMQ */ - compatible = "regulator-fixed"; - regulator-name = "vcc_1v8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc_3v3_sys>; - regulator-always-on; - regulator-boot-on; - }; -}; - -&main_pmx0 { - main_rgmii2_pins_default: main-rgmii2-default-pins { - bootph-all; - pinctrl-single,pins = < - AM62X_IOPAD(0x184, PIN_INPUT, 0) /* (AE23) RGMII2_RD0 */ - AM62X_IOPAD(0x188, PIN_INPUT, 0) /* (AB20) RGMII2_RD1 */ - AM62X_IOPAD(0x18c, PIN_INPUT, 0) /* (AC21) RGMII2_RD2 */ - AM62X_IOPAD(0x190, PIN_INPUT, 0) /* (AE22) RGMII2_RD3 */ - AM62X_IOPAD(0x180, PIN_INPUT, 0) /* (AD23) RGMII2_RXC */ - AM62X_IOPAD(0x17c, PIN_INPUT, 0) /* (AD22) RGMII2_RX_CTL */ - AM62X_IOPAD(0x16c, PIN_OUTPUT, 0) /* (Y18) RGMII2_TD0 */ - AM62X_IOPAD(0x170, PIN_OUTPUT, 0) /* (AA18) RGMII2_TD1 */ - AM62X_IOPAD(0x174, PIN_OUTPUT, 0) /* (AD21) RGMII2_TD2 */ - AM62X_IOPAD(0x178, PIN_OUTPUT, 0) /* (AC20) RGMII2_TD3 */ - AM62X_IOPAD(0x168, PIN_OUTPUT, 0) /* (AE21) RGMII2_TXC */ - AM62X_IOPAD(0x164, PIN_OUTPUT, 0) /* (AA19) RGMII2_TX_CTL */ - >; - }; - - ospi0_pins_default: ospi0-default-pins { - bootph-all; - pinctrl-single,pins = < - AM62X_IOPAD(0x000, PIN_OUTPUT, 0) /* (H24) OSPI0_CLK */ - AM62X_IOPAD(0x02c, PIN_OUTPUT, 0) /* (F23) OSPI0_CSn0 */ - AM62X_IOPAD(0x00c, PIN_INPUT, 0) /* (E25) OSPI0_D0 */ - AM62X_IOPAD(0x010, PIN_INPUT, 0) /* (G24) OSPI0_D1 */ - AM62X_IOPAD(0x014, PIN_INPUT, 0) /* (F25) OSPI0_D2 */ - AM62X_IOPAD(0x018, PIN_INPUT, 0) /* (F24) OSPI0_D3 */ - AM62X_IOPAD(0x01c, PIN_INPUT, 0) /* (J23) OSPI0_D4 */ - AM62X_IOPAD(0x020, PIN_INPUT, 0) /* (J25) OSPI0_D5 */ - AM62X_IOPAD(0x024, PIN_INPUT, 0) /* (H25) OSPI0_D6 */ - AM62X_IOPAD(0x028, PIN_INPUT, 0) /* (J22) OSPI0_D7 */ - AM62X_IOPAD(0x008, PIN_INPUT, 0) /* (J24) OSPI0_DQS */ - >; - }; - - vdd_sd_dv_pins_default: vdd-sd-dv-default-pins { - bootph-all; - pinctrl-single,pins = < - AM62X_IOPAD(0x07c, PIN_OUTPUT, 7) /* (P25) GPMC0_CLK.GPIO0_31 */ - >; - }; - - main_gpio1_ioexp_intr_pins_default: main-gpio1-ioexp-intr-default-pins { - bootph-all; - pinctrl-single,pins = < - AM62X_IOPAD(0x01d4, PIN_INPUT, 7) /* (B15) UART0_RTSn.GPIO1_23 */ - >; - }; -}; - -&main_gpio0 { - bootph-all; -}; - -&main_gpio1 { - bootph-all; -}; - -&main_i2c1 { - bootph-all; - exp1: gpio@22 { - bootph-all; - compatible = "ti,tca6424"; - reg = <0x22>; - gpio-controller; - #gpio-cells = <2>; - gpio-line-names = "GPIO_CPSW2_RST", "GPIO_CPSW1_RST", - "PRU_DETECT", "MMC1_SD_EN", - "VPP_LDO_EN", "EXP_PS_3V3_En", - "EXP_PS_5V0_En", "EXP_HAT_DETECT", - "GPIO_AUD_RSTn", "GPIO_eMMC_RSTn", - "UART1_FET_BUF_EN", "WL_LT_EN", - "GPIO_HDMI_RSTn", "CSI_GPIO1", - "CSI_GPIO2", "PRU_3V3_EN", - "HDMI_INTn", "PD_I2C_IRQ", - "MCASP1_FET_EN", "MCASP1_BUF_BT_EN", - "MCASP1_FET_SEL", "UART1_FET_SEL", - "TSINT#", "IO_EXP_TEST_LED"; - - interrupt-parent = <&main_gpio1>; - interrupts = <23 IRQ_TYPE_EDGE_FALLING>; - interrupt-controller; - #interrupt-cells = <2>; - - pinctrl-names = "default"; - pinctrl-0 = <&main_gpio1_ioexp_intr_pins_default>; - }; -}; - -&sdhci1 { - vmmc-supply = <&vdd_mmc1>; - vqmmc-supply = <&vdd_sd_dv>; -}; - -&cpsw3g { - pinctrl-names = "default"; - pinctrl-0 = <&main_rgmii1_pins_default>, <&main_rgmii2_pins_default>; -}; - -&cpsw_port2 { - phy-mode = "rgmii-rxid"; - phy-handle = <&cpsw3g_phy1>; -}; - -&cpsw3g_mdio { - cpsw3g_phy1: ethernet-phy@1 { - reg = <1>; - ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; - ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; - ti,min-output-impedance; - }; -}; - -&mailbox0_cluster0 { - mbox_m4_0: mbox-m4-0 { - ti,mbox-rx = <0 0 0>; - ti,mbox-tx = <1 0 0>; - }; -}; - -&fss { - bootph-all; -}; - -&ospi0 { - bootph-all; - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&ospi0_pins_default>; - - flash@0 { - bootph-all; - compatible = "jedec,spi-nor"; - reg = <0x0>; - spi-tx-bus-width = <8>; - spi-rx-bus-width = <8>; - spi-max-frequency = <25000000>; - cdns,tshsl-ns = <60>; - cdns,tsd2d-ns = <60>; - cdns,tchsh-ns = <60>; - cdns,tslch-ns = <60>; - cdns,read-delay = <4>; - - partitions { - bootph-all; - compatible = "fixed-partitions"; - #address-cells = <1>; - #size-cells = <1>; - - partition@0 { - label = "ospi.tiboot3"; - reg = <0x0 0x80000>; - }; - - partition@80000 { - label = "ospi.tispl"; - reg = <0x80000 0x200000>; - }; - - partition@280000 { - label = "ospi.u-boot"; - reg = <0x280000 0x400000>; - }; - - partition@680000 { - label = "ospi.env"; - reg = <0x680000 0x40000>; - }; - - partition@6c0000 { - label = "ospi.env.backup"; - reg = <0x6c0000 0x40000>; - }; - - partition@800000 { - label = "ospi.rootfs"; - reg = <0x800000 0x37c0000>; - }; - - partition@3fc0000 { - bootph-pre-ram; - label = "ospi.phypattern"; - reg = <0x3fc0000 0x40000>; - }; - }; - }; -}; - -&tlv320aic3106 { - DVDD-supply = <&vcc_1v8>; -}; diff --git a/arch/arm/dts/k3-am625.dtsi b/arch/arm/dts/k3-am625.dtsi deleted file mode 100644 index 4014add6320d..000000000000 --- a/arch/arm/dts/k3-am625.dtsi +++ /dev/null @@ -1,155 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only OR MIT -/* - * Device Tree Source for AM625 SoC family in Quad core configuration - * - * TRM: https://www.ti.com/lit/pdf/spruiv7 - * - * Copyright (C) 2020-2024 Texas Instruments Incorporated - https://www.ti.com/ - */ - -/dts-v1/; - -#include "k3-am62.dtsi" - -/ { - cpus { - #address-cells = <1>; - #size-cells = <0>; - - cpu-map { - cluster0: cluster0 { - core0 { - cpu = <&cpu0>; - }; - - core1 { - cpu = <&cpu1>; - }; - - core2 { - cpu = <&cpu2>; - }; - - core3 { - cpu = <&cpu3>; - }; - }; - }; - - cpu0: cpu@0 { - compatible = "arm,cortex-a53"; - reg = <0x000>; - device_type = "cpu"; - enable-method = "psci"; - i-cache-size = <0x8000>; - i-cache-line-size = <64>; - i-cache-sets = <256>; - d-cache-size = <0x8000>; - d-cache-line-size = <64>; - d-cache-sets = <128>; - next-level-cache = <&L2_0>; - operating-points-v2 = <&a53_opp_table>; - clocks = <&k3_clks 135 0>; - }; - - cpu1: cpu@1 { - compatible = "arm,cortex-a53"; - reg = <0x001>; - device_type = "cpu"; - enable-method = "psci"; - i-cache-size = <0x8000>; - i-cache-line-size = <64>; - i-cache-sets = <256>; - d-cache-size = <0x8000>; - d-cache-line-size = <64>; - d-cache-sets = <128>; - next-level-cache = <&L2_0>; - operating-points-v2 = <&a53_opp_table>; - clocks = <&k3_clks 136 0>; - }; - - cpu2: cpu@2 { - compatible = "arm,cortex-a53"; - reg = <0x002>; - device_type = "cpu"; - enable-method = "psci"; - i-cache-size = <0x8000>; - i-cache-line-size = <64>; - i-cache-sets = <256>; - d-cache-size = <0x8000>; - d-cache-line-size = <64>; - d-cache-sets = <128>; - next-level-cache = <&L2_0>; - operating-points-v2 = <&a53_opp_table>; - clocks = <&k3_clks 137 0>; - }; - - cpu3: cpu@3 { - compatible = "arm,cortex-a53"; - reg = <0x003>; - device_type = "cpu"; - enable-method = "psci"; - i-cache-size = <0x8000>; - i-cache-line-size = <64>; - i-cache-sets = <256>; - d-cache-size = <0x8000>; - d-cache-line-size = <64>; - d-cache-sets = <128>; - next-level-cache = <&L2_0>; - operating-points-v2 = <&a53_opp_table>; - clocks = <&k3_clks 138 0>; - }; - }; - - a53_opp_table: opp-table { - compatible = "operating-points-v2-ti-cpu"; - opp-shared; - syscon = <&wkup_conf>; - - opp-200000000 { - opp-hz = /bits/ 64 <200000000>; - opp-supported-hw = <0x01 0x0007>; - clock-latency-ns = <6000000>; - }; - - opp-400000000 { - opp-hz = /bits/ 64 <400000000>; - opp-supported-hw = <0x01 0x0007>; - clock-latency-ns = <6000000>; - }; - - opp-600000000 { - opp-hz = /bits/ 64 <600000000>; - opp-supported-hw = <0x01 0x0007>; - clock-latency-ns = <6000000>; - }; - - opp-800000000 { - opp-hz = /bits/ 64 <800000000>; - opp-supported-hw = <0x01 0x0007>; - clock-latency-ns = <6000000>; - }; - - opp-1000000000 { - opp-hz = /bits/ 64 <1000000000>; - opp-supported-hw = <0x01 0x0006>; - clock-latency-ns = <6000000>; - }; - - opp-1250000000 { - opp-hz = /bits/ 64 <1250000000>; - opp-supported-hw = <0x01 0x0004>; - clock-latency-ns = <6000000>; - opp-suspend; - }; - }; - - L2_0: l2-cache0 { - compatible = "cache"; - cache-unified; - cache-level = <2>; - cache-size = <0x80000>; - cache-line-size = <64>; - cache-sets = <512>; - }; -}; diff --git a/arch/arm/dts/k3-am62x-sk-common.dtsi b/arch/arm/dts/k3-am62x-sk-common.dtsi deleted file mode 100644 index 3c45782ab2b7..000000000000 --- a/arch/arm/dts/k3-am62x-sk-common.dtsi +++ /dev/null @@ -1,535 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only OR MIT -/* - * Common dtsi for AM62x SK and derivatives - * - * Copyright (C) 2021-2024 Texas Instruments Incorporated - https://www.ti.com/ - */ - -#include <dt-bindings/leds/common.h> -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/net/ti-dp83867.h> -#include "k3-am625.dtsi" - -/ { - aliases { - serial2 = &main_uart0; - mmc0 = &sdhci0; - mmc1 = &sdhci1; - mmc2 = &sdhci2; - spi0 = &ospi0; - ethernet0 = &cpsw_port1; - ethernet1 = &cpsw_port2; - usb0 = &usb0; - usb1 = &usb1; - }; - - chosen { - stdout-path = "serial2:115200n8"; - }; - - memory@80000000 { - bootph-pre-ram; - device_type = "memory"; - /* 2G RAM */ - reg = <0x00000000 0x80000000 0x00000000 0x80000000>; - }; - - reserved-memory { - #address-cells = <2>; - #size-cells = <2>; - ranges; - - ramoops@9ca00000 { - compatible = "ramoops"; - reg = <0x00 0x9ca00000 0x00 0x00100000>; - record-size = <0x8000>; - console-size = <0x8000>; - ftrace-size = <0x00>; - pmsg-size = <0x8000>; - }; - - secure_tfa_ddr: tfa@9e780000 { - reg = <0x00 0x9e780000 0x00 0x80000>; - alignment = <0x1000>; - no-map; - }; - - secure_ddr: optee@9e800000 { - reg = <0x00 0x9e800000 0x00 0x01800000>; /* for OP-TEE */ - alignment = <0x1000>; - no-map; - }; - - wkup_r5fss0_core0_dma_memory_region: r5f-dma-memory@9db00000 { - compatible = "shared-dma-pool"; - reg = <0x00 0x9db00000 0x00 0xc00000>; - no-map; - }; - }; - - leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&usr_led_pins_default>; - - led-0 { - label = "am62-sk:green:heartbeat"; - gpios = <&main_gpio1 49 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "heartbeat"; - function = LED_FUNCTION_HEARTBEAT; - default-state = "off"; - }; - }; - - tlv320_mclk: clk-0 { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <12288000>; - }; - - codec_audio: sound { - compatible = "simple-audio-card"; - simple-audio-card,name = "AM62x-SKEVM"; - simple-audio-card,widgets = - "Headphone", "Headphone Jack", - "Line", "Line In", - "Microphone", "Microphone Jack"; - simple-audio-card,routing = - "Headphone Jack", "HPLOUT", - "Headphone Jack", "HPROUT", - "LINE1L", "Line In", - "LINE1R", "Line In", - "MIC3R", "Microphone Jack", - "Microphone Jack", "Mic Bias"; - simple-audio-card,format = "dsp_b"; - simple-audio-card,bitclock-master = <&sound_master>; - simple-audio-card,frame-master = <&sound_master>; - simple-audio-card,bitclock-inversion; - - simple-audio-card,cpu { - sound-dai = <&mcasp1>; - }; - - sound_master: simple-audio-card,codec { - sound-dai = <&tlv320aic3106>; - clocks = <&tlv320_mclk>; - }; - }; - - hdmi0: connector-hdmi { - compatible = "hdmi-connector"; - label = "hdmi"; - type = "a"; - port { - hdmi_connector_in: endpoint { - remote-endpoint = <&sii9022_out>; - }; - }; - }; -}; - -&main_pmx0 { - /* First pad number is ALW package and second is AMC package */ - main_uart0_pins_default: main-uart0-default-pins { - bootph-all; - pinctrl-single,pins = < - AM62X_IOPAD(0x1c8, PIN_INPUT, 0) /* (D14/A13) UART0_RXD */ - AM62X_IOPAD(0x1cc, PIN_OUTPUT, 0) /* (E14/E11) UART0_TXD */ - >; - }; - - main_uart1_pins_default: main-uart1-default-pins { - bootph-pre-ram; - pinctrl-single,pins = < - AM62X_IOPAD(0x194, PIN_INPUT, 2) /* (B19/B18) MCASP0_AXR3.UART1_CTSn */ - AM62X_IOPAD(0x198, PIN_OUTPUT, 2) /* (A19/B17) MCASP0_AXR2.UART1_RTSn */ - AM62X_IOPAD(0x1ac, PIN_INPUT, 2) /* (E19/D15) MCASP0_AFSR.UART1_RXD */ - AM62X_IOPAD(0x1b0, PIN_OUTPUT, 2) /* (A20/D16) MCASP0_ACLKR.UART1_TXD */ - >; - }; - - main_i2c0_pins_default: main-i2c0-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x1e0, PIN_INPUT_PULLUP, 0) /* (B16/E12) I2C0_SCL */ - AM62X_IOPAD(0x1e4, PIN_INPUT_PULLUP, 0) /* (A16/D14) I2C0_SDA */ - >; - }; - - main_i2c1_pins_default: main-i2c1-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x1e8, PIN_INPUT_PULLUP, 0) /* (B17/A17) I2C1_SCL */ - AM62X_IOPAD(0x1ec, PIN_INPUT_PULLUP, 0) /* (A17/A16) I2C1_SDA */ - >; - }; - - main_i2c2_pins_default: main-i2c2-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x0b0, PIN_INPUT_PULLUP, 1) /* (K22/H18) GPMC0_CSn2.I2C2_SCL */ - AM62X_IOPAD(0x0b4, PIN_INPUT_PULLUP, 1) /* (K24/H19) GPMC0_CSn3.I2C2_SDA */ - >; - }; - - main_mmc0_pins_default: main-mmc0-default-pins { - bootph-all; - pinctrl-single,pins = < - AM62X_IOPAD(0x220, PIN_INPUT, 0) /* (Y3/V3) MMC0_CMD */ - AM62X_IOPAD(0x218, PIN_INPUT, 0) /* (AB1/Y1) MMC0_CLK */ - AM62X_IOPAD(0x214, PIN_INPUT, 0) /* (AA2/V2) MMC0_DAT0 */ - AM62X_IOPAD(0x210, PIN_INPUT, 0) /* (AA1/V1) MMC0_DAT1 */ - AM62X_IOPAD(0x20c, PIN_INPUT, 0) /* (AA3/W2) MMC0_DAT2 */ - AM62X_IOPAD(0x208, PIN_INPUT, 0) /* (Y4/W1) MMC0_DAT3 */ - AM62X_IOPAD(0x204, PIN_INPUT, 0) /* (AB2/Y2) MMC0_DAT4 */ - AM62X_IOPAD(0x200, PIN_INPUT, 0) /* (AC1/W3) MMC0_DAT5 */ - AM62X_IOPAD(0x1fc, PIN_INPUT, 0) /* (AD2/W4) MMC0_DAT6 */ - AM62X_IOPAD(0x1f8, PIN_INPUT, 0) /* (AC2/V4) MMC0_DAT7 */ - >; - }; - - main_mmc1_pins_default: main-mmc1-default-pins { - bootph-all; - pinctrl-single,pins = < - AM62X_IOPAD(0x23c, PIN_INPUT, 0) /* (A21/C18) MMC1_CMD */ - AM62X_IOPAD(0x234, PIN_INPUT, 0) /* (B22/A20) MMC1_CLK */ - AM62X_IOPAD(0x230, PIN_INPUT, 0) /* (A22/A19) MMC1_DAT0 */ - AM62X_IOPAD(0x22c, PIN_INPUT, 0) /* (B21/B19) MMC1_DAT1 */ - AM62X_IOPAD(0x228, PIN_INPUT, 0) /* (C21/B20) MMC1_DAT2 */ - AM62X_IOPAD(0x224, PIN_INPUT, 0) /* (D22/C19) MMC1_DAT3 */ - AM62X_IOPAD(0x240, PIN_INPUT, 0) /* (D17/C15) MMC1_SDCD */ - >; - }; - - usr_led_pins_default: usr-led-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x244, PIN_OUTPUT, 7) /* (C17/B15) MMC1_SDWP.GPIO1_49 */ - >; - }; - - main_mdio1_pins_default: main-mdio1-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x160, PIN_OUTPUT, 0) /* (AD24/V17) MDIO0_MDC */ - AM62X_IOPAD(0x15c, PIN_INPUT, 0) /* (AB22/U16) MDIO0_MDIO */ - >; - }; - - main_rgmii1_pins_default: main-rgmii1-default-pins { - bootph-all; - pinctrl-single,pins = < - AM62X_IOPAD(0x14c, PIN_INPUT, 0) /* (AB17/W15) RGMII1_RD0 */ - AM62X_IOPAD(0x150, PIN_INPUT, 0) /* (AC17/Y16) RGMII1_RD1 */ - AM62X_IOPAD(0x154, PIN_INPUT, 0) /* (AB16/AA17) RGMII1_RD2 */ - AM62X_IOPAD(0x158, PIN_INPUT, 0) /* (AA15/Y15) RGMII1_RD3 */ - AM62X_IOPAD(0x148, PIN_INPUT, 0) /* (AD17/AA16) RGMII1_RXC */ - AM62X_IOPAD(0x144, PIN_INPUT, 0) /* (AE17/W14) RGMII1_RX_CTL */ - AM62X_IOPAD(0x134, PIN_OUTPUT, 0) /* (AE20/U14) RGMII1_TD0 */ - AM62X_IOPAD(0x138, PIN_OUTPUT, 0) /* (AD20/AA19) RGMII1_TD1 */ - AM62X_IOPAD(0x13c, PIN_OUTPUT, 0) /* (AE18/Y17) RGMII1_TD2 */ - AM62X_IOPAD(0x140, PIN_OUTPUT, 0) /* (AD18/AA18) RGMII1_TD3 */ - AM62X_IOPAD(0x130, PIN_OUTPUT, 0) /* (AE19/W16) RGMII1_TXC */ - AM62X_IOPAD(0x12c, PIN_OUTPUT, 0) /* (AD19/V15) RGMII1_TX_CTL */ - >; - }; - - main_usb1_pins_default: main-usb1-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x0258, PIN_OUTPUT, 0) /* (F18/E16) USB1_DRVVBUS */ - >; - }; - - main_mcasp1_pins_default: main-mcasp1-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x090, PIN_INPUT, 2) /* (M24/K17) GPMC0_BE0N_CLE.MCASP1_ACLKX */ - AM62X_IOPAD(0x098, PIN_INPUT, 2) /* (U23/P21) GPMC0_WAIT0.MCASP1_AFSX */ - AM62X_IOPAD(0x08c, PIN_OUTPUT, 2) /* (L25/J17) GPMC0_WEN.MCASP1_AXR0 */ - AM62X_IOPAD(0x084, PIN_INPUT, 2) /* (L23/K20) GPMC0_ADVN_ALE.MCASP1_AXR2 */ - >; - }; - - main_dss0_pins_default: main-dss0-default-pins { - pinctrl-single,pins = < - AM62X_IOPAD(0x100, PIN_OUTPUT, 0) /* (AC25) VOUT0_VSYNC */ - AM62X_IOPAD(0x0f8, PIN_OUTPUT, 0) /* (AB24) VOUT0_HSYNC */ - AM62X_IOPAD(0x104, PIN_OUTPUT, 0) /* (AC24) VOUT0_PCLK */ - AM62X_IOPAD(0x0fc, PIN_OUTPUT, 0) /* (Y20) VOUT0_DE */ - AM62X_IOPAD(0x0b8, PIN_OUTPUT, 0) /* (U22) VOUT0_DATA0 */ - AM62X_IOPAD(0x0bc, PIN_OUTPUT, 0) /* (V24) VOUT0_DATA1 */ - AM62X_IOPAD(0x0c0, PIN_OUTPUT, 0) /* (W25) VOUT0_DATA2 */ - AM62X_IOPAD(0x0c4, PIN_OUTPUT, 0) /* (W24) VOUT0_DATA3 */ - AM62X_IOPAD(0x0c8, PIN_OUTPUT, 0) /* (Y25) VOUT0_DATA4 */ - AM62X_IOPAD(0x0cc, PIN_OUTPUT, 0) /* (Y24) VOUT0_DATA5 */ - AM62X_IOPAD(0x0d0, PIN_OUTPUT, 0) /* (Y23) VOUT0_DATA6 */ - AM62X_IOPAD(0x0d4, PIN_OUTPUT, 0) /* (AA25) VOUT0_DATA7 */ - AM62X_IOPAD(0x0d8, PIN_OUTPUT, 0) /* (V21) VOUT0_DATA8 */ - AM62X_IOPAD(0x0dc, PIN_OUTPUT, 0) /* (W21) VOUT0_DATA9 */ - AM62X_IOPAD(0x0e0, PIN_OUTPUT, 0) /* (V20) VOUT0_DATA10 */ - AM62X_IOPAD(0x0e4, PIN_OUTPUT, 0) /* (AA23) VOUT0_DATA11 */ - AM62X_IOPAD(0x0e8, PIN_OUTPUT, 0) /* (AB25) VOUT0_DATA12 */ - AM62X_IOPAD(0x0ec, PIN_OUTPUT, 0) /* (AA24) VOUT0_DATA13 */ - AM62X_IOPAD(0x0f0, PIN_OUTPUT, 0) /* (Y22) VOUT0_DATA14 */ - AM62X_IOPAD(0x0f4, PIN_OUTPUT, 0) /* (AA21) VOUT0_DATA15 */ - AM62X_IOPAD(0x05c, PIN_OUTPUT, 1) /* (R24) GPMC0_AD8.VOUT0_DATA16 */ - AM62X_IOPAD(0x060, PIN_OUTPUT, 1) /* (R25) GPMC0_AD9.VOUT0_DATA17 */ - AM62X_IOPAD(0x064, PIN_OUTPUT, 1) /* (T25) GPMC0_AD10.VOUT0_DATA18 */ - AM62X_IOPAD(0x068, PIN_OUTPUT, 1) /* (R21) GPMC0_AD11.VOUT0_DATA19 */ - AM62X_IOPAD(0x06c, PIN_OUTPUT, 1) /* (T22) GPMC0_AD12.VOUT0_DATA20 */ - AM62X_IOPAD(0x070, PIN_OUTPUT, 1) /* (T24) GPMC0_AD13.VOUT0_DATA21 */ - AM62X_IOPAD(0x074, PIN_OUTPUT, 1) /* (U25) GPMC0_AD14.VOUT0_DATA22 */ - AM62X_IOPAD(0x078, PIN_OUTPUT, 1) /* (U24) GPMC0_AD15.VOUT0_DATA23 */ - >; - }; -}; - -&mcu_pmx0 { - wkup_uart0_pins_default: wkup-uart0-default-pins { - bootph-pre-ram; - pinctrl-single,pins = < - AM62X_MCU_IOPAD(0x02c, PIN_INPUT, 0) /* (C6/A7) WKUP_UART0_CTSn */ - AM62X_MCU_IOPAD(0x030, PIN_OUTPUT, 0) /* (A4/B4) WKUP_UART0_RTSn */ - AM62X_MCU_IOPAD(0x024, PIN_INPUT, 0) /* (B4/B5) WKUP_UART0_RXD */ - AM62X_MCU_IOPAD(0x028, PIN_OUTPUT, 0) /* (C5/C6) WKUP_UART0_TXD */ - >; - }; -}; - -&wkup_uart0 { - /* WKUP UART0 is used by DM firmware */ - bootph-pre-ram; - status = "reserved"; - pinctrl-names = "default"; - pinctrl-0 = <&wkup_uart0_pins_default>; -}; - -&main_uart0 { - bootph-all; - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&main_uart0_pins_default>; -}; - -&main_uart1 { - /* Main UART1 is used by TIFS firmware */ - bootph-pre-ram; - status = "reserved"; - pinctrl-names = "default"; - pinctrl-0 = <&main_uart1_pins_default>; -}; - -&main_i2c0 { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&main_i2c0_pins_default>; - clock-frequency = <400000>; - - eeprom@51 { - /* AT24C512C-MAHM-T or M24512-DFMC6TG */ - compatible = "atmel,24c512"; - reg = <0x51>; - }; - - typec_pd0: tps6598x@3f { - compatible = "ti,tps6598x"; - reg = <0x3f>; - - connector { - compatible = "usb-c-connector"; - label = "USB-C"; - self-powered; - data-role = "dual"; - power-role = "sink"; - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - usb_con_hs: endpoint { - remote-endpoint = <&usb0_hs_ep>; - }; - }; - }; - }; - }; -}; - -&main_i2c1 { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&main_i2c1_pins_default>; - clock-frequency = <100000>; - - tlv320aic3106: audio-codec@1b { - #sound-dai-cells = <0>; - compatible = "ti,tlv320aic3106"; - reg = <0x1b>; - ai3x-micbias-vg = <1>; /* 2.0V */ - - /* Regulators */ - AVDD-supply = <&vcc_3v3_sys>; - IOVDD-supply = <&vcc_3v3_sys>; - DRVDD-supply = <&vcc_3v3_sys>; - }; - - sii9022: bridge-hdmi@3b { - compatible = "sil,sii9022"; - reg = <0x3b>; - interrupt-parent = <&exp1>; - interrupts = <16 IRQ_TYPE_EDGE_FALLING>; - #sound-dai-cells = <0>; - sil,i2s-data-lanes = < 0 >; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - - sii9022_in: endpoint { - remote-endpoint = <&dpi1_out>; - }; - }; - - port@1 { - reg = <1>; - - sii9022_out: endpoint { - remote-endpoint = <&hdmi_connector_in>; - }; - }; - }; - }; -}; - -&main_i2c2 { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&main_i2c2_pins_default>; - clock-frequency = <400000>; -}; - -&sdhci0 { - bootph-all; - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&main_mmc0_pins_default>; - disable-wp; -}; - -&sdhci1 { - /* SD/MMC */ - bootph-all; - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&main_mmc1_pins_default>; - disable-wp; -}; - -&cpsw3g { - bootph-all; - pinctrl-names = "default"; - pinctrl-0 = <&main_rgmii1_pins_default>; -}; - -&cpsw_port1 { - bootph-all; - phy-mode = "rgmii-rxid"; - phy-handle = <&cpsw3g_phy0>; -}; - -&cpsw3g_mdio { - bootph-all; - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&main_mdio1_pins_default>; - - cpsw3g_phy0: ethernet-phy@0 { - bootph-all; - reg = <0>; - ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; - ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; - ti,min-output-impedance; - }; -}; - -&mailbox0_cluster0 { - mbox_m4_0: mbox-m4-0 { - ti,mbox-rx = <0 0 0>; - ti,mbox-tx = <1 0 0>; - }; -}; - -&usbss0 { - bootph-all; - status = "okay"; - ti,vbus-divider; -}; - -&usbss1 { - status = "okay"; - ti,vbus-divider; -}; - -&usb0 { - bootph-all; - #address-cells = <1>; - #size-cells = <0>; - usb-role-switch; - - port@0 { - reg = <0>; - usb0_hs_ep: endpoint { - remote-endpoint = <&usb_con_hs>; - }; - }; -}; - -&usb1 { - dr_mode = "host"; - pinctrl-names = "default"; - pinctrl-0 = <&main_usb1_pins_default>; -}; - -&mcasp1 { - status = "okay"; - #sound-dai-cells = <0>; - - pinctrl-names = "default"; - pinctrl-0 = <&main_mcasp1_pins_default>; - - op-mode = <0>; /* MCASP_IIS_MODE */ - tdm-slots = <2>; - - serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */ - 1 0 2 0 - 0 0 0 0 - 0 0 0 0 - 0 0 0 0 - >; - tx-num-evt = <32>; - rx-num-evt = <32>; -}; - -&dss { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&main_dss0_pins_default>; -}; - -&dss_ports { - /* VP2: DPI Output */ - port@1 { - reg = <1>; - - dpi1_out: endpoint { - remote-endpoint = <&sii9022_in>; - }; - }; -}; - -/* mcu_gpio0 and mcu_gpio_intr are reserved for mcu firmware usage */ -&mcu_gpio0 { - status = "reserved"; -}; - -&mcu_gpio_intr { - status = "reserved"; -}; diff --git a/configs/am62x_evm_a53_defconfig b/configs/am62x_evm_a53_defconfig index 16294a6a7940..9bfe1560275c 100644 --- a/configs/am62x_evm_a53_defconfig +++ b/configs/am62x_evm_a53_defconfig @@ -10,7 +10,7 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80b80000 CONFIG_SF_DEFAULT_SPEED=25000000 CONFIG_SPL_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="k3-am625-sk" +CONFIG_DEFAULT_DEVICE_TREE="ti/k3-am625-sk" CONFIG_SPL_TEXT_BASE=0x80080000 CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y @@ -56,6 +56,7 @@ CONFIG_CMD_EFIDEBUG=y CONFIG_MMC_SPEED_MODE_SET=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_UPSTREAM=y CONFIG_MULTI_DTB_FIT=y CONFIG_SPL_MULTI_DTB_FIT=y CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y
Hi Nishanth,
Thank you for the patch.
On mer., juin 05, 2024 at 10:27, Nishanth Menon nm@ti.com wrote:
Enable OF_UPSTREAM for am625-sk board. Remove DT files that are now available in dts/upstream. Update the appended files based on version of latest OF_UPSTREAM sync point (v6.10-rc1).
Signed-off-by: Nishanth Menon nm@ti.com
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com
Boot tested to main U-Boot via DFU on AM62X SK EVM.
Tested-by: Mattijs Korpershoek mkorpershoek@baylibre.com
arch/arm/dts/Makefile | 3 +- arch/arm/dts/k3-am62-main.dtsi | 1058 -------------------------- arch/arm/dts/k3-am62-mcu.dtsi | 176 ----- arch/arm/dts/k3-am62-thermal.dtsi | 36 - arch/arm/dts/k3-am62-wakeup.dtsi | 96 --- arch/arm/dts/k3-am62.dtsi | 122 --- arch/arm/dts/k3-am625-sk-binman.dtsi | 2 +- arch/arm/dts/k3-am625-sk.dts | 299 -------- arch/arm/dts/k3-am625.dtsi | 155 ---- arch/arm/dts/k3-am62x-sk-common.dtsi | 535 ------------- configs/am62x_evm_a53_defconfig | 3 +- 11 files changed, 4 insertions(+), 2481 deletions(-) delete mode 100644 arch/arm/dts/k3-am62-main.dtsi delete mode 100644 arch/arm/dts/k3-am62-mcu.dtsi delete mode 100644 arch/arm/dts/k3-am62-thermal.dtsi delete mode 100644 arch/arm/dts/k3-am62-wakeup.dtsi delete mode 100644 arch/arm/dts/k3-am62.dtsi delete mode 100644 arch/arm/dts/k3-am625-sk.dts delete mode 100644 arch/arm/dts/k3-am625.dtsi delete mode 100644 arch/arm/dts/k3-am62x-sk-common.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 813426a3e519..5b0bcf336924 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1198,8 +1198,7 @@ dtb-$(CONFIG_SOC_K3_AM642) += k3-am642-r5-evm.dtb \ k3-am642-r5-sk.dtb \ k3-am642-r5-phycore-som-2gb.dtb
-dtb-$(CONFIG_SOC_K3_AM625) += k3-am625-sk.dtb \
k3-am625-r5-sk.dtb \
+dtb-$(CONFIG_SOC_K3_AM625) += k3-am625-r5-sk.dtb \ k3-am625-r5-beagleplay.dtb \ k3-am625-verdin-r5.dtb \ k3-am625-r5-phycore-som-2gb.dtb diff --git a/arch/arm/dts/k3-am62-main.dtsi b/arch/arm/dts/k3-am62-main.dtsi deleted file mode 100644 index e9cffca073ef..000000000000 --- a/arch/arm/dts/k3-am62-main.dtsi +++ /dev/null @@ -1,1058 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only OR MIT -/*
- Device Tree Source for AM625 SoC Family Main Domain peripherals
- Copyright (C) 2020-2024 Texas Instruments Incorporated - https://www.ti.com/
-&cbass_main {
- oc_sram: sram@70000000 {
compatible = "mmio-sram";
reg = <0x00 0x70000000 0x00 0x10000>;
#size-cells = <1>;
ranges = <0x0 0x00 0x70000000 0x10000>;
- gic500: interrupt-controller@1800000 {
compatible = "arm,gic-v3";
#size-cells = <2>;
ranges;
#interrupt-cells = <3>;
reg = <0x00 0x01800000 0x00 0x10000>, /* GICD */
<0x00 0x01880000 0x00 0xc0000>, /* GICR */
<0x01 0x00000000 0x00 0x2000>, /* GICC */
<0x01 0x00010000 0x00 0x1000>, /* GICH */
<0x01 0x00020000 0x00 0x2000>; /* GICV */
* vcpumntirq:
* virtual CPU interface maintenance interrupt
interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>;
gic_its: msi-controller@1820000 {
compatible = "arm,gic-v3-its";
reg = <0x00 0x01820000 0x00 0x10000>;
socionext,synquacer-pre-its = <0x1000000 0x400000>;
msi-controller;
#msi-cells = <1>;
- main_conf: bus@100000 {
#size-cells = <1>;
ranges = <0x0 0x00 0x00100000 0x20000>;
phy_gmii_sel: phy@4044 {
compatible = "ti,am654-phy-gmii-sel";
reg = <0x4044 0x8>;
#phy-cells = <1>;
epwm_tbclk: clock-controller@4130 {
compatible = "ti,am62-epwm-tbclk";
reg = <0x4130 0x4>;
#clock-cells = <1>;
audio_refclk0: clock-controller@82e0 {
compatible = "ti,am62-audio-refclk";
reg = <0x82e0 0x4>;
clocks = <&k3_clks 157 0>;
assigned-clocks = <&k3_clks 157 0>;
assigned-clock-parents = <&k3_clks 157 8>;
#clock-cells = <0>;
audio_refclk1: clock-controller@82e4 {
reg = <0x82e4 0x4>;
clocks = <&k3_clks 157 10>;
assigned-clocks = <&k3_clks 157 10>;
assigned-clock-parents = <&k3_clks 157 18>;
#clock-cells = <0>;
- dmss: bus@48000000 {
bootph-all;
#size-cells = <2>;
dma-ranges;
ranges = <0x00 0x48000000 0x00 0x48000000 0x00 0x06400000>;
ti,sci-dev-id = <25>;
secure_proxy_main: mailbox@4d000000 {
bootph-all;
compatible = "ti,am654-secure-proxy";
#mbox-cells = <1>;
reg-names = "target_data", "rt", "scfg";
reg = <0x00 0x4d000000 0x00 0x80000>,
<0x00 0x4a600000 0x00 0x80000>,
<0x00 0x4a400000 0x00 0x80000>;
interrupt-names = "rx_012";
interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>;
inta_main_dmss: interrupt-controller@48000000 {
compatible = "ti,sci-inta";
reg = <0x00 0x48000000 0x00 0x100000>;
#interrupt-cells = <0>;
msi-controller;
ti,sci = <&dmsc>;
ti,sci-dev-id = <28>;
ti,interrupt-ranges = <4 68 36>;
ti,unmapped-event-sources = <&main_bcdma>, <&main_pktdma>;
main_bcdma: dma-controller@485c0100 {
compatible = "ti,am64-dmss-bcdma";
reg = <0x00 0x485c0100 0x00 0x100>,
<0x00 0x4c000000 0x00 0x20000>,
<0x00 0x4a820000 0x00 0x20000>,
<0x00 0x4aa40000 0x00 0x20000>,
<0x00 0x4bc00000 0x00 0x100000>,
<0x00 0x48600000 0x00 0x8000>,
<0x00 0x484a4000 0x00 0x2000>,
<0x00 0x484c2000 0x00 0x2000>,
<0x00 0x48420000 0x00 0x2000>;
reg-names = "gcfg", "bchanrt", "rchanrt", "tchanrt", "ringrt",
"ring", "tchan", "rchan", "bchan";
msi-parent = <&inta_main_dmss>;
#dma-cells = <3>;
ti,sci = <&dmsc>;
ti,sci-dev-id = <26>;
ti,sci-rm-range-bchan = <0x20>; /* BLOCK_COPY_CHAN */
ti,sci-rm-range-rchan = <0x21>; /* SPLIT_TR_RX_CHAN */
ti,sci-rm-range-tchan = <0x22>; /* SPLIT_TR_TX_CHAN */
main_pktdma: dma-controller@485c0000 {
compatible = "ti,am64-dmss-pktdma";
reg = <0x00 0x485c0000 0x00 0x100>,
<0x00 0x4a800000 0x00 0x20000>,
<0x00 0x4aa00000 0x00 0x40000>,
<0x00 0x4b800000 0x00 0x400000>,
<0x00 0x485e0000 0x00 0x10000>,
<0x00 0x484a0000 0x00 0x2000>,
<0x00 0x484c0000 0x00 0x2000>,
<0x00 0x48430000 0x00 0x1000>;
reg-names = "gcfg", "rchanrt", "tchanrt", "ringrt",
"ring", "tchan", "rchan", "rflow";
#dma-cells = <2>;
ti,sci = <&dmsc>;
ti,sci-dev-id = <30>;
ti,sci-rm-range-tchan = <0x23>, /* UNMAPPED_TX_CHAN */
<0x24>, /* CPSW_TX_CHAN */
<0x25>, /* SAUL_TX_0_CHAN */
<0x26>; /* SAUL_TX_1_CHAN */
ti,sci-rm-range-tflow = <0x10>, /* RING_UNMAPPED_TX_CHAN */
<0x11>, /* RING_CPSW_TX_CHAN */
<0x12>, /* RING_SAUL_TX_0_CHAN */
<0x13>; /* RING_SAUL_TX_1_CHAN */
ti,sci-rm-range-rchan = <0x29>, /* UNMAPPED_RX_CHAN */
<0x2b>, /* CPSW_RX_CHAN */
<0x2d>, /* SAUL_RX_0_CHAN */
<0x2f>, /* SAUL_RX_1_CHAN */
<0x31>, /* SAUL_RX_2_CHAN */
<0x33>; /* SAUL_RX_3_CHAN */
ti,sci-rm-range-rflow = <0x2a>, /* FLOW_UNMAPPED_RX_CHAN */
<0x2c>, /* FLOW_CPSW_RX_CHAN */
<0x2e>, /* FLOW_SAUL_RX_0/1_CHAN */
<0x32>; /* FLOW_SAUL_RX_2/3_CHAN */
- dmsc: system-controller@44043000 {
bootph-all;
compatible = "ti,k2g-sci";
ti,host-id = <12>;
mbox-names = "rx", "tx";
mboxes = <&secure_proxy_main 12>,
<&secure_proxy_main 13>;
reg-names = "debug_messages";
reg = <0x00 0x44043000 0x00 0xfe0>;
k3_pds: power-controller {
bootph-all;
compatible = "ti,sci-pm-domain";
#power-domain-cells = <2>;
k3_clks: clock-controller {
bootph-all;
compatible = "ti,k2g-sci-clk";
#clock-cells = <2>;
k3_reset: reset-controller {
bootph-all;
compatible = "ti,sci-reset";
#reset-cells = <2>;
- crypto: crypto@40900000 {
compatible = "ti,am62-sa3ul";
reg = <0x00 0x40900000 0x00 0x1200>;
#size-cells = <2>;
ranges = <0x00 0x40900000 0x00 0x40900000 0x00 0x30000>;
dmas = <&main_pktdma 0xf501 0>, <&main_pktdma 0x7506 0>,
<&main_pktdma 0x7507 0>;
dma-names = "tx", "rx1", "rx2";
- secure_proxy_sa3: mailbox@43600000 {
bootph-pre-ram;
#mbox-cells = <1>;
reg = <0x00 0x43600000 0x00 0x10000>,
<0x00 0x44880000 0x00 0x20000>,
<0x00 0x44860000 0x00 0x20000>;
* Marked Disabled:
* Node is incomplete as it is meant for bootloaders and
* firmware on non-MPU processors
- main_pmx0: pinctrl@f4000 {
bootph-all;
reg = <0x00 0xf4000 0x00 0x2ac>;
- main_esm: esm@420000 {
bootph-pre-ram;
reg = <0x00 0x420000 0x00 0x1000>;
ti,esm-pins = <160>, <161>, <162>, <163>, <177>, <178>;
- main_timer0: timer@2400000 {
bootph-all;
reg = <0x00 0x2400000 0x00 0x400>;
interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 36 2>;
assigned-clocks = <&k3_clks 36 2>;
assigned-clock-parents = <&k3_clks 36 3>;
power-domains = <&k3_pds 36 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
- main_timer1: timer@2410000 {
reg = <0x00 0x2410000 0x00 0x400>;
interrupts = <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 37 2>;
assigned-clocks = <&k3_clks 37 2>;
assigned-clock-parents = <&k3_clks 37 3>;
power-domains = <&k3_pds 37 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
- main_timer2: timer@2420000 {
reg = <0x00 0x2420000 0x00 0x400>;
interrupts = <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 38 2>;
assigned-clocks = <&k3_clks 38 2>;
assigned-clock-parents = <&k3_clks 38 3>;
power-domains = <&k3_pds 38 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
- main_timer3: timer@2430000 {
reg = <0x00 0x2430000 0x00 0x400>;
interrupts = <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 39 2>;
assigned-clocks = <&k3_clks 39 2>;
assigned-clock-parents = <&k3_clks 39 3>;
power-domains = <&k3_pds 39 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
- main_timer4: timer@2440000 {
reg = <0x00 0x2440000 0x00 0x400>;
interrupts = <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 40 2>;
assigned-clocks = <&k3_clks 40 2>;
assigned-clock-parents = <&k3_clks 40 3>;
power-domains = <&k3_pds 40 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
- main_timer5: timer@2450000 {
reg = <0x00 0x2450000 0x00 0x400>;
interrupts = <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 41 2>;
assigned-clocks = <&k3_clks 41 2>;
assigned-clock-parents = <&k3_clks 41 3>;
power-domains = <&k3_pds 41 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
- main_timer6: timer@2460000 {
reg = <0x00 0x2460000 0x00 0x400>;
interrupts = <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 42 2>;
assigned-clocks = <&k3_clks 42 2>;
assigned-clock-parents = <&k3_clks 42 3>;
power-domains = <&k3_pds 42 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
- main_timer7: timer@2470000 {
reg = <0x00 0x2470000 0x00 0x400>;
interrupts = <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 43 2>;
assigned-clocks = <&k3_clks 43 2>;
assigned-clock-parents = <&k3_clks 43 3>;
power-domains = <&k3_pds 43 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
- main_uart0: serial@2800000 {
reg = <0x00 0x02800000 0x00 0x100>;
interrupts = <GIC_SPI 178 IRQ_TYPE_LEVEL_HIGH>;
power-domains = <&k3_pds 146 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 146 0>;
- main_uart1: serial@2810000 {
reg = <0x00 0x02810000 0x00 0x100>;
interrupts = <GIC_SPI 179 IRQ_TYPE_LEVEL_HIGH>;
power-domains = <&k3_pds 152 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 152 0>;
- main_uart2: serial@2820000 {
reg = <0x00 0x02820000 0x00 0x100>;
interrupts = <GIC_SPI 180 IRQ_TYPE_LEVEL_HIGH>;
power-domains = <&k3_pds 153 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 153 0>;
- main_uart3: serial@2830000 {
reg = <0x00 0x02830000 0x00 0x100>;
interrupts = <GIC_SPI 181 IRQ_TYPE_LEVEL_HIGH>;
power-domains = <&k3_pds 154 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 154 0>;
- main_uart4: serial@2840000 {
reg = <0x00 0x02840000 0x00 0x100>;
interrupts = <GIC_SPI 182 IRQ_TYPE_LEVEL_HIGH>;
power-domains = <&k3_pds 155 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 155 0>;
- main_uart5: serial@2850000 {
reg = <0x00 0x02850000 0x00 0x100>;
interrupts = <GIC_SPI 183 IRQ_TYPE_LEVEL_HIGH>;
power-domains = <&k3_pds 156 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 156 0>;
- main_uart6: serial@2860000 {
reg = <0x00 0x02860000 0x00 0x100>;
interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>;
power-domains = <&k3_pds 158 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 158 0>;
- main_i2c0: i2c@20000000 {
reg = <0x00 0x20000000 0x00 0x100>;
interrupts = <GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
power-domains = <&k3_pds 102 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 102 2>;
- main_i2c1: i2c@20010000 {
reg = <0x00 0x20010000 0x00 0x100>;
interrupts = <GIC_SPI 162 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
power-domains = <&k3_pds 103 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 103 2>;
- main_i2c2: i2c@20020000 {
reg = <0x00 0x20020000 0x00 0x100>;
interrupts = <GIC_SPI 163 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
power-domains = <&k3_pds 104 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 104 2>;
- main_i2c3: i2c@20030000 {
reg = <0x00 0x20030000 0x00 0x100>;
interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
power-domains = <&k3_pds 105 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 105 2>;
- main_spi0: spi@20100000 {
reg = <0x00 0x20100000 0x00 0x400>;
interrupts = <GIC_SPI 172 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
power-domains = <&k3_pds 141 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 141 0>;
- main_spi1: spi@20110000 {
reg = <0x00 0x20110000 0x00 0x400>;
interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
power-domains = <&k3_pds 142 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 142 0>;
- main_spi2: spi@20120000 {
reg = <0x00 0x20120000 0x00 0x400>;
interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
power-domains = <&k3_pds 143 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 143 0>;
- main_gpio_intr: interrupt-controller@a00000 {
reg = <0x00 0x00a00000 0x00 0x800>;
ti,sci = <&dmsc>;
ti,sci-dev-id = <3>;
ti,interrupt-ranges = <0 32 16>;
- main_gpio0: gpio@600000 {
reg = <0x0 0x00600000 0x0 0x100>;
gpio-ranges = <&main_pmx0 0 0 32>,
<&main_pmx0 32 33 38>,
<&main_pmx0 70 72 22>;
gpio-controller;
#gpio-cells = <2>;
interrupt-parent = <&main_gpio_intr>;
interrupts = <190>, <191>, <192>,
<193>, <194>, <195>;
ti,ngpio = <92>;
power-domains = <&k3_pds 77 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 77 0>;
- main_gpio1: gpio@601000 {
reg = <0x0 0x00601000 0x0 0x100>;
gpio-controller;
gpio-ranges = <&main_pmx0 0 94 41>,
<&main_pmx0 41 136 6>,
<&main_pmx0 47 143 3>,
<&main_pmx0 50 149 2>;
#gpio-cells = <2>;
interrupts = <180>, <181>, <182>,
<183>, <184>, <185>;
ti,ngpio = <52>;
power-domains = <&k3_pds 78 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 78 0>;
- sdhci0: mmc@fa10000 {
compatible = "ti,am62-sdhci";
reg = <0x00 0x0fa10000 0x00 0x1000>, <0x00 0x0fa18000 0x00 0x400>;
interrupts = <GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>;
power-domains = <&k3_pds 57 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 57 5>, <&k3_clks 57 6>;
clock-names = "clk_ahb", "clk_xin";
assigned-clocks = <&k3_clks 57 6>;
assigned-clock-parents = <&k3_clks 57 8>;
bus-width = <8>;
mmc-ddr-1_8v;
mmc-hs200-1_8v;
ti,clkbuf-sel = <0x7>;
ti,otap-del-sel-legacy = <0x0>;
ti,otap-del-sel-mmc-hs = <0x0>;
ti,otap-del-sel-ddr52 = <0x5>;
ti,otap-del-sel-hs200 = <0x5>;
ti,itap-del-sel-legacy = <0xa>;
ti,itap-del-sel-mmc-hs = <0x1>;
- sdhci1: mmc@fa00000 {
reg = <0x00 0x0fa00000 0x00 0x1000>, <0x00 0x0fa08000 0x00 0x400>;
interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>;
power-domains = <&k3_pds 58 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 58 5>, <&k3_clks 58 6>;
bus-width = <4>;
ti,otap-del-sel-legacy = <0x8>;
ti,otap-del-sel-sd-hs = <0x0>;
ti,otap-del-sel-sdr12 = <0x0>;
ti,otap-del-sel-sdr25 = <0x0>;
ti,otap-del-sel-sdr50 = <0x8>;
ti,otap-del-sel-sdr104 = <0x7>;
ti,otap-del-sel-ddr50 = <0x4>;
ti,itap-del-sel-sd-hs = <0x1>;
ti,itap-del-sel-sdr12 = <0xa>;
ti,itap-del-sel-sdr25 = <0x1>;
- sdhci2: mmc@fa20000 {
reg = <0x00 0x0fa20000 0x00 0x1000>, <0x00 0x0fa28000 0x00 0x400>;
interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>;
power-domains = <&k3_pds 184 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 184 5>, <&k3_clks 184 6>;
bus-width = <4>;
ti,otap-del-sel-ddr50 = <0x8>;
ti,itap-del-sel-sd-hs = <0xa>;
- usbss0: dwc3-usb@f900000 {
compatible = "ti,am62-usb";
reg = <0x00 0x0f900000 0x00 0x800>;
clocks = <&k3_clks 161 3>;
clock-names = "ref";
ti,syscon-phy-pll-refclk = <&wkup_conf 0x4008>;
#size-cells = <2>;
power-domains = <&k3_pds 178 TI_SCI_PD_EXCLUSIVE>;
ranges;
usb0: usb@31000000 {
compatible = "snps,dwc3";
reg = <0x00 0x31000000 0x00 0x50000>;
interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>, /* irq.0 */
<GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; /* irq.0 */
interrupt-names = "host", "peripheral";
maximum-speed = "high-speed";
dr_mode = "otg";
snps,usb2-gadget-lpm-disable;
snps,usb2-lpm-disable;
- usbss1: dwc3-usb@f910000 {
reg = <0x00 0x0f910000 0x00 0x800>;
clocks = <&k3_clks 162 3>;
ti,syscon-phy-pll-refclk = <&wkup_conf 0x4018>;
#size-cells = <2>;
power-domains = <&k3_pds 179 TI_SCI_PD_EXCLUSIVE>;
ranges;
usb1: usb@31100000 {
reg = <0x00 0x31100000 0x00 0x50000>;
interrupts = <GIC_SPI 226 IRQ_TYPE_LEVEL_HIGH>, /* irq.0 */
<GIC_SPI 226 IRQ_TYPE_LEVEL_HIGH>; /* irq.0 */
dr_mode = "otg";
- fss: bus@fc00000 {
reg = <0x00 0x0fc00000 0x00 0x70000>;
#size-cells = <2>;
ranges;
ospi0: spi@fc40000 {
compatible = "ti,am654-ospi", "cdns,qspi-nor";
reg = <0x00 0x0fc40000 0x00 0x100>,
<0x05 0x00000000 0x01 0x00000000>;
interrupts = <GIC_SPI 139 IRQ_TYPE_LEVEL_HIGH>;
cdns,fifo-depth = <256>;
cdns,fifo-width = <4>;
cdns,trigger-address = <0x0>;
clocks = <&k3_clks 75 7>;
assigned-clocks = <&k3_clks 75 7>;
assigned-clock-parents = <&k3_clks 75 8>;
assigned-clock-rates = <166666666>;
power-domains = <&k3_pds 75 TI_SCI_PD_EXCLUSIVE>;
#size-cells = <0>;
- gpu: gpu@fd00000 {
compatible = "ti,am62-gpu", "img,img-axe";
reg = <0x00 0x0fd00000 0x00 0x20000>;
clocks = <&k3_clks 187 0>;
clock-names = "core";
interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>;
power-domains = <&k3_pds 187 TI_SCI_PD_EXCLUSIVE>;
- cpsw3g: ethernet@8000000 {
compatible = "ti,am642-cpsw-nuss";
#size-cells = <2>;
reg = <0x00 0x08000000 0x00 0x200000>;
reg-names = "cpsw_nuss";
ranges = <0x00 0x00 0x00 0x08000000 0x00 0x200000>;
clocks = <&k3_clks 13 0>;
assigned-clocks = <&k3_clks 13 3>;
assigned-clock-parents = <&k3_clks 13 11>;
power-domains = <&k3_pds 13 TI_SCI_PD_EXCLUSIVE>;
dmas = <&main_pktdma 0xc600 15>,
<&main_pktdma 0xc601 15>,
<&main_pktdma 0xc602 15>,
<&main_pktdma 0xc603 15>,
<&main_pktdma 0xc604 15>,
<&main_pktdma 0xc605 15>,
<&main_pktdma 0xc606 15>,
<&main_pktdma 0xc607 15>,
<&main_pktdma 0x4600 15>;
dma-names = "tx0", "tx1", "tx2", "tx3", "tx4", "tx5", "tx6",
"tx7", "rx";
ethernet-ports {
#size-cells = <0>;
cpsw_port1: port@1 {
reg = <1>;
ti,mac-only;
label = "port1";
phys = <&phy_gmii_sel 1>;
mac-address = [00 00 00 00 00 00];
ti,syscon-efuse = <&wkup_conf 0x200>;
cpsw_port2: port@2 {
reg = <2>;
ti,mac-only;
label = "port2";
phys = <&phy_gmii_sel 2>;
cpsw3g_mdio: mdio@f00 {
compatible = "ti,cpsw-mdio","ti,davinci_mdio";
reg = <0x00 0xf00 0x00 0x100>;
#size-cells = <0>;
bus_freq = <1000000>;
cpts@3d000 {
compatible = "ti,j721e-cpts";
reg = <0x00 0x3d000 0x00 0x400>;
clock-names = "cpts";
interrupts-extended = <&gic500 GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "cpts";
ti,cpts-ext-ts-inputs = <4>;
ti,cpts-periodic-outputs = <2>;
- dss: dss@30200000 {
compatible = "ti,am625-dss";
reg = <0x00 0x30200000 0x00 0x1000>, /* common */
<0x00 0x30202000 0x00 0x1000>, /* vidl1 */
<0x00 0x30206000 0x00 0x1000>, /* vid */
<0x00 0x30207000 0x00 0x1000>, /* ovr1 */
<0x00 0x30208000 0x00 0x1000>, /* ovr2 */
<0x00 0x3020a000 0x00 0x1000>, /* vp1: Used for OLDI */
<0x00 0x3020b000 0x00 0x1000>, /* vp2: Used as DPI Out */
<0x00 0x30201000 0x00 0x1000>; /* common1 */
reg-names = "common", "vidl1", "vid",
"ovr1", "ovr2", "vp1", "vp2", "common1";
power-domains = <&k3_pds 186 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 186 6>,
<&dss_vp1_clk>,
<&k3_clks 186 2>;
clock-names = "fck", "vp1", "vp2";
interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>;
dss_ports: ports {
#size-cells = <0>;
- hwspinlock: spinlock@2a000000 {
compatible = "ti,am64-hwspinlock";
reg = <0x00 0x2a000000 0x00 0x1000>;
#hwlock-cells = <1>;
- mailbox0_cluster0: mailbox@29000000 {
compatible = "ti,am64-mailbox";
reg = <0x00 0x29000000 0x00 0x200>;
interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 77 IRQ_TYPE_LEVEL_HIGH>;
#mbox-cells = <1>;
ti,mbox-num-users = <4>;
ti,mbox-num-fifos = <16>;
- ecap0: pwm@23100000 {
compatible = "ti,am3352-ecap";
#pwm-cells = <3>;
reg = <0x00 0x23100000 0x00 0x100>;
power-domains = <&k3_pds 51 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 51 0>;
- ecap1: pwm@23110000 {
#pwm-cells = <3>;
reg = <0x00 0x23110000 0x00 0x100>;
power-domains = <&k3_pds 52 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 52 0>;
- ecap2: pwm@23120000 {
#pwm-cells = <3>;
reg = <0x00 0x23120000 0x00 0x100>;
power-domains = <&k3_pds 53 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 53 0>;
- main_mcan0: can@20701000 {
reg = <0x00 0x20701000 0x00 0x200>,
<0x00 0x20708000 0x00 0x8000>;
power-domains = <&k3_pds 98 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 98 6>, <&k3_clks 98 1>;
interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "int0", "int1";
- main_rti0: watchdog@e000000 {
reg = <0x00 0x0e000000 0x00 0x100>;
clocks = <&k3_clks 125 0>;
power-domains = <&k3_pds 125 TI_SCI_PD_EXCLUSIVE>;
assigned-clocks = <&k3_clks 125 0>;
assigned-clock-parents = <&k3_clks 125 2>;
- main_rti1: watchdog@e010000 {
reg = <0x00 0x0e010000 0x00 0x100>;
clocks = <&k3_clks 126 0>;
power-domains = <&k3_pds 126 TI_SCI_PD_EXCLUSIVE>;
assigned-clocks = <&k3_clks 126 0>;
assigned-clock-parents = <&k3_clks 126 2>;
- main_rti2: watchdog@e020000 {
reg = <0x00 0x0e020000 0x00 0x100>;
clocks = <&k3_clks 127 0>;
power-domains = <&k3_pds 127 TI_SCI_PD_EXCLUSIVE>;
assigned-clocks = <&k3_clks 127 0>;
assigned-clock-parents = <&k3_clks 127 2>;
- main_rti3: watchdog@e030000 {
reg = <0x00 0x0e030000 0x00 0x100>;
clocks = <&k3_clks 128 0>;
power-domains = <&k3_pds 128 TI_SCI_PD_EXCLUSIVE>;
assigned-clocks = <&k3_clks 128 0>;
assigned-clock-parents = <&k3_clks 128 2>;
- main_rti15: watchdog@e0f0000 {
reg = <0x00 0x0e0f0000 0x00 0x100>;
clocks = <&k3_clks 130 0>;
power-domains = <&k3_pds 130 TI_SCI_PD_EXCLUSIVE>;
assigned-clocks = <&k3_clks 130 0>;
assigned-clock-parents = <&k3_clks 130 2>;
- epwm0: pwm@23000000 {
compatible = "ti,am64-epwm", "ti,am3352-ehrpwm";
#pwm-cells = <3>;
reg = <0x00 0x23000000 0x00 0x100>;
power-domains = <&k3_pds 86 TI_SCI_PD_EXCLUSIVE>;
clocks = <&epwm_tbclk 0>, <&k3_clks 86 0>;
clock-names = "tbclk", "fck";
- epwm1: pwm@23010000 {
#pwm-cells = <3>;
reg = <0x00 0x23010000 0x00 0x100>;
power-domains = <&k3_pds 87 TI_SCI_PD_EXCLUSIVE>;
clocks = <&epwm_tbclk 1>, <&k3_clks 87 0>;
- epwm2: pwm@23020000 {
#pwm-cells = <3>;
reg = <0x00 0x23020000 0x00 0x100>;
power-domains = <&k3_pds 88 TI_SCI_PD_EXCLUSIVE>;
clocks = <&epwm_tbclk 2>, <&k3_clks 88 0>;
- mcasp0: audio-controller@2b00000 {
compatible = "ti,am33xx-mcasp-audio";
reg = <0x00 0x02b00000 0x00 0x2000>,
<0x00 0x02b08000 0x00 0x400>;
reg-names = "mpu", "dat";
interrupts = <GIC_SPI 236 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 235 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "tx", "rx";
dmas = <&main_bcdma 0 0xc500 0>, <&main_bcdma 0 0x4500 0>;
dma-names = "tx", "rx";
clocks = <&k3_clks 190 0>;
assigned-clocks = <&k3_clks 190 0>;
assigned-clock-parents = <&k3_clks 190 2>;
power-domains = <&k3_pds 190 TI_SCI_PD_EXCLUSIVE>;
- mcasp1: audio-controller@2b10000 {
reg = <0x00 0x02b10000 0x00 0x2000>,
<0x00 0x02b18000 0x00 0x400>;
interrupts = <GIC_SPI 238 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 237 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&main_bcdma 0 0xc501 0>, <&main_bcdma 0 0x4501 0>;
clocks = <&k3_clks 191 0>;
assigned-clocks = <&k3_clks 191 0>;
assigned-clock-parents = <&k3_clks 191 2>;
power-domains = <&k3_pds 191 TI_SCI_PD_EXCLUSIVE>;
- mcasp2: audio-controller@2b20000 {
reg = <0x00 0x02b20000 0x00 0x2000>,
<0x00 0x02b28000 0x00 0x400>;
interrupts = <GIC_SPI 240 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 239 IRQ_TYPE_LEVEL_HIGH>;
dmas = <&main_bcdma 0 0xc502 0>, <&main_bcdma 0 0x4502 0>;
clocks = <&k3_clks 192 0>;
assigned-clocks = <&k3_clks 192 0>;
assigned-clock-parents = <&k3_clks 192 2>;
power-domains = <&k3_pds 192 TI_SCI_PD_EXCLUSIVE>;
- ti_csi2rx0: ticsi2rx@30102000 {
compatible = "ti,j721e-csi2rx-shim";
dmas = <&main_bcdma 0 0x4700 0>;
dma-names = "rx0";
reg = <0x00 0x30102000 0x00 0x1000>;
power-domains = <&k3_pds 182 TI_SCI_PD_EXCLUSIVE>;
#size-cells = <2>;
ranges;
cdns_csi2rx0: csi-bridge@30101000 {
compatible = "ti,j721e-csi2rx", "cdns,csi2rx";
reg = <0x00 0x30101000 0x00 0x1000>;
clocks = <&k3_clks 182 0>, <&k3_clks 182 3>, <&k3_clks 182 0>,
<&k3_clks 182 0>, <&k3_clks 182 4>, <&k3_clks 182 4>;
clock-names = "sys_clk", "p_clk", "pixel_if0_clk",
"pixel_if1_clk", "pixel_if2_clk", "pixel_if3_clk";
phys = <&dphy0>;
phy-names = "dphy";
ports {
#size-cells = <0>;
csi0_port0: port@0 {
reg = <0>;
csi0_port1: port@1 {
reg = <1>;
csi0_port2: port@2 {
reg = <2>;
csi0_port3: port@3 {
reg = <3>;
csi0_port4: port@4 {
reg = <4>;
- dphy0: phy@30110000 {
compatible = "cdns,dphy-rx";
reg = <0x00 0x30110000 0x00 0x1100>;
#phy-cells = <0>;
power-domains = <&k3_pds 185 TI_SCI_PD_EXCLUSIVE>;
-}; diff --git a/arch/arm/dts/k3-am62-mcu.dtsi b/arch/arm/dts/k3-am62-mcu.dtsi deleted file mode 100644 index e66d486ef1f2..000000000000 --- a/arch/arm/dts/k3-am62-mcu.dtsi +++ /dev/null @@ -1,176 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only OR MIT -/*
- Device Tree Source for AM625 SoC Family MCU Domain peripherals
-&cbass_mcu {
- mcu_pmx0: pinctrl@4084000 {
bootph-all;
compatible = "pinctrl-single";
reg = <0x00 0x04084000 0x00 0x88>;
#pinctrl-cells = <1>;
pinctrl-single,register-width = <32>;
pinctrl-single,function-mask = <0xffffffff>;
- mcu_esm: esm@4100000 {
bootph-pre-ram;
compatible = "ti,j721e-esm";
reg = <0x00 0x4100000 0x00 0x1000>;
ti,esm-pins = <0>, <1>, <2>, <85>;
* The MCU domain timer interrupts are routed only to the ESM module,
* and not currently available for Linux. The MCU domain timers are
* of limited use without interrupts, and likely reserved by the ESM.
- mcu_timer0: timer@4800000 {
compatible = "ti,am654-timer";
reg = <0x00 0x4800000 0x00 0x400>;
clocks = <&k3_clks 35 2>;
power-domains = <&k3_pds 35 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
- mcu_timer1: timer@4810000 {
reg = <0x00 0x4810000 0x00 0x400>;
clocks = <&k3_clks 48 2>;
power-domains = <&k3_pds 48 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
- mcu_timer2: timer@4820000 {
reg = <0x00 0x4820000 0x00 0x400>;
clocks = <&k3_clks 49 2>;
power-domains = <&k3_pds 49 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
- mcu_timer3: timer@4830000 {
reg = <0x00 0x4830000 0x00 0x400>;
clocks = <&k3_clks 50 2>;
power-domains = <&k3_pds 50 TI_SCI_PD_EXCLUSIVE>;
ti,timer-pwm;
- mcu_uart0: serial@4a00000 {
reg = <0x00 0x04a00000 0x00 0x100>;
interrupts = <GIC_SPI 185 IRQ_TYPE_LEVEL_HIGH>;
power-domains = <&k3_pds 149 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 149 0>;
clock-names = "fclk";
- mcu_i2c0: i2c@4900000 {
reg = <0x00 0x04900000 0x00 0x100>;
interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
power-domains = <&k3_pds 106 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 106 2>;
- mcu_spi0: spi@4b00000 {
compatible = "ti,am654-mcspi", "ti,omap4-mcspi";
reg = <0x00 0x04b00000 0x00 0x400>;
interrupts = <GIC_SPI 176 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
power-domains = <&k3_pds 147 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 147 0>;
- mcu_spi1: spi@4b10000 {
compatible = "ti,am654-mcspi","ti,omap4-mcspi";
reg = <0x00 0x04b10000 0x00 0x400>;
interrupts = <GIC_SPI 177 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
power-domains = <&k3_pds 148 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 148 0>;
- mcu_gpio_intr: interrupt-controller@4210000 {
compatible = "ti,sci-intr";
reg = <0x00 0x04210000 0x00 0x200>;
ti,intr-trigger-type = <1>;
#interrupt-cells = <1>;
ti,sci = <&dmsc>;
ti,sci-dev-id = <5>;
ti,interrupt-ranges = <0 104 4>;
- mcu_gpio0: gpio@4201000 {
compatible = "ti,am64-gpio", "ti,keystone-gpio";
reg = <0x00 0x4201000 0x00 0x100>;
gpio-controller;
#gpio-cells = <2>;
interrupt-parent = <&mcu_gpio_intr>;
interrupts = <30>, <31>;
ti,ngpio = <24>;
ti,davinci-gpio-unbanked = <0>;
power-domains = <&k3_pds 79 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 79 0>;
clock-names = "gpio";
- mcu_rti0: watchdog@4880000 {
reg = <0x00 0x04880000 0x00 0x100>;
clocks = <&k3_clks 131 0>;
power-domains = <&k3_pds 131 TI_SCI_PD_EXCLUSIVE>;
assigned-clocks = <&k3_clks 131 0>;
assigned-clock-parents = <&k3_clks 131 2>;
/* Tightly coupled to M4F */
- mcu_mcan0: can@4e08000 {
compatible = "bosch,m_can";
reg = <0x00 0x4e08000 0x00 0x200>,
<0x00 0x4e00000 0x00 0x8000>;
reg-names = "m_can", "message_ram";
power-domains = <&k3_pds 188 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 188 6>, <&k3_clks 188 1>;
clock-names = "hclk", "cclk";
bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>;
- mcu_mcan1: can@4e18000 {
reg = <0x00 0x4e18000 0x00 0x200>,
<0x00 0x4e10000 0x00 0x8000>;
power-domains = <&k3_pds 189 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 189 6>, <&k3_clks 189 1>;
-}; diff --git a/arch/arm/dts/k3-am62-thermal.dtsi b/arch/arm/dts/k3-am62-thermal.dtsi deleted file mode 100644 index 12ba833002a1..000000000000 --- a/arch/arm/dts/k3-am62-thermal.dtsi +++ /dev/null @@ -1,36 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only OR MIT -/*
- Copyright (C) 2023-2024 Texas Instruments Incorporated - https://www.ti.com/
-#include <dt-bindings/thermal/thermal.h>
-thermal_zones: thermal-zones {
- main0_thermal: main0-thermal {
polling-delay-passive = <250>; /* milliSeconds */
polling-delay = <500>; /* milliSeconds */
thermal-sensors = <&wkup_vtm0 0>;
trips {
main0_crit: main0-crit {
temperature = <105000>; /* milliCelsius */
hysteresis = <2000>; /* milliCelsius */
type = "critical";
- main1_thermal: main1-thermal {
thermal-sensors = <&wkup_vtm0 1>;
trips {
main1_crit: main1-crit {
type = "critical";
-}; diff --git a/arch/arm/dts/k3-am62-wakeup.dtsi b/arch/arm/dts/k3-am62-wakeup.dtsi deleted file mode 100644 index 23ce1bfda8d6..000000000000 --- a/arch/arm/dts/k3-am62-wakeup.dtsi +++ /dev/null @@ -1,96 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only OR MIT -/*
- Device Tree Source for AM625 SoC Family Wakeup Domain peripherals
-#include <dt-bindings/bus/ti-sysc.h>
-&cbass_wakeup {
- wkup_conf: syscon@43000000 {
bootph-all;
compatible = "syscon", "simple-mfd";
reg = <0x00 0x43000000 0x00 0x20000>;
#size-cells = <1>;
ranges = <0x0 0x00 0x43000000 0x20000>;
chipid: chipid@14 {
bootph-all;
compatible = "ti,am654-chipid";
reg = <0x14 0x4>;
- target-module@2b300050 {
compatible = "ti,sysc-omap2", "ti,sysc";
reg = <0x00 0x2b300050 0x00 0x4>,
<0x00 0x2b300054 0x00 0x4>,
<0x00 0x2b300058 0x00 0x4>;
reg-names = "rev", "sysc", "syss";
ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP |
SYSC_OMAP2_SOFTRESET |
SYSC_OMAP2_AUTOIDLE)>;
ti,sysc-sidle = <SYSC_IDLE_FORCE>,
<SYSC_IDLE_NO>,
<SYSC_IDLE_SMART>,
<SYSC_IDLE_SMART_WKUP>;
ti,syss-mask = <1>;
ti,no-reset-on-init;
power-domains = <&k3_pds 114 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 114 0>;
clock-names = "fck";
#size-cells = <1>;
ranges = <0x0 0x00 0x2b300000 0x100000>;
wkup_uart0: serial@0 {
compatible = "ti,am64-uart", "ti,am654-uart";
reg = <0x0 0x100>;
interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>;
status = "disabled";
- wkup_i2c0: i2c@2b200000 {
compatible = "ti,am64-i2c", "ti,omap4-i2c";
reg = <0x00 0x2b200000 0x00 0x100>;
interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
power-domains = <&k3_pds 107 TI_SCI_PD_EXCLUSIVE>;
clocks = <&k3_clks 107 4>;
- wkup_rtc0: rtc@2b1f0000 {
compatible = "ti,am62-rtc";
reg = <0x00 0x2b1f0000 0x00 0x100>;
interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&k3_clks 117 6> , <&k3_clks 117 0>;
clock-names = "vbus", "osc32k";
power-domains = <&k3_pds 117 TI_SCI_PD_EXCLUSIVE>;
wakeup-source;
- wkup_rti0: watchdog@2b000000 {
compatible = "ti,j7-rti-wdt";
reg = <0x00 0x2b000000 0x00 0x100>;
clocks = <&k3_clks 132 0>;
power-domains = <&k3_pds 132 TI_SCI_PD_EXCLUSIVE>;
assigned-clocks = <&k3_clks 132 0>;
assigned-clock-parents = <&k3_clks 132 2>;
/* Used by DM firmware */
- wkup_vtm0: temperature-sensor@b00000 {
compatible = "ti,j7200-vtm";
reg = <0x00 0xb00000 0x00 0x400>,
<0x00 0xb01000 0x00 0x400>;
power-domains = <&k3_pds 95 TI_SCI_PD_EXCLUSIVE>;
#thermal-sensor-cells = <1>;
-}; diff --git a/arch/arm/dts/k3-am62.dtsi b/arch/arm/dts/k3-am62.dtsi deleted file mode 100644 index f0781f2bea29..000000000000 --- a/arch/arm/dts/k3-am62.dtsi +++ /dev/null @@ -1,122 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only OR MIT -/*
- Device Tree Source for AM62 SoC Family
-#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/soc/ti,sci_pm_domain.h>
-#include "k3-pinctrl.h"
- model = "Texas Instruments K3 AM625 SoC";
- compatible = "ti,am625";
- interrupt-parent = <&gic500>;
- chosen { };
- firmware {
optee {
compatible = "linaro,optee-tz";
method = "smc";
psci: psci {
compatible = "arm,psci-1.0";
method = "smc";
- a53_timer0: timer-cl0-cpu0 {
compatible = "arm,armv8-timer";
interrupts = <GIC_PPI 13 IRQ_TYPE_LEVEL_LOW>, /* cntpsirq */
<GIC_PPI 14 IRQ_TYPE_LEVEL_LOW>, /* cntpnsirq */
<GIC_PPI 11 IRQ_TYPE_LEVEL_LOW>, /* cntvirq */
<GIC_PPI 10 IRQ_TYPE_LEVEL_LOW>; /* cnthpirq */
- pmu: pmu {
compatible = "arm,cortex-a53-pmu";
interrupts = <GIC_PPI 7 IRQ_TYPE_LEVEL_HIGH>;
- cbass_main: bus@f0000 {
bootph-all;
#size-cells = <2>;
ranges = <0x00 0x000f0000 0x00 0x000f0000 0x00 0x00030000>, /* Main MMRs */
<0x00 0x00420000 0x00 0x00420000 0x00 0x00001000>, /* ESM0 */
<0x00 0x00600000 0x00 0x00600000 0x00 0x00001100>, /* GPIO */
<0x00 0x00703000 0x00 0x00703000 0x00 0x00000200>, /* USB0 debug trace */
<0x00 0x0070c000 0x00 0x0070c000 0x00 0x00000200>, /* USB1 debug trace */
<0x00 0x00a40000 0x00 0x00a40000 0x00 0x00000800>, /* Timesync router */
<0x00 0x01000000 0x00 0x01000000 0x00 0x01b28400>, /* First peripheral window */
<0x00 0x08000000 0x00 0x08000000 0x00 0x00200000>, /* Main CPSW */
<0x00 0x0e000000 0x00 0x0e000000 0x00 0x01d20000>, /* Second peripheral window */
<0x00 0x0fd00000 0x00 0x0fd00000 0x00 0x00020000>, /* GPU */
<0x00 0x20000000 0x00 0x20000000 0x00 0x0a008000>, /* Third peripheral window */
<0x00 0x30040000 0x00 0x30040000 0x00 0x00080000>, /* PRUSS-M */
<0x00 0x30101000 0x00 0x30101000 0x00 0x00010100>, /* CSI window */
<0x00 0x30200000 0x00 0x30200000 0x00 0x00010000>, /* DSS */
<0x00 0x31000000 0x00 0x31000000 0x00 0x00050000>, /* USB0 DWC3 Core window */
<0x00 0x31100000 0x00 0x31100000 0x00 0x00050000>, /* USB1 DWC3 Core window */
<0x00 0x40900000 0x00 0x40900000 0x00 0x00030000>, /* SA3UL */
<0x00 0x43600000 0x00 0x43600000 0x00 0x00010000>, /* SA3 sproxy data */
<0x00 0x44043000 0x00 0x44043000 0x00 0x00000fe0>, /* TI SCI DEBUG */
<0x00 0x44860000 0x00 0x44860000 0x00 0x00040000>, /* SA3 sproxy config */
<0x00 0x48000000 0x00 0x48000000 0x00 0x06400000>, /* DMSS */
<0x00 0x60000000 0x00 0x60000000 0x00 0x08000000>, /* FSS0 DAT1 */
<0x00 0x70000000 0x00 0x70000000 0x00 0x00010000>, /* OCSRAM */
<0x01 0x00000000 0x01 0x00000000 0x00 0x00310000>, /* A53 PERIPHBASE */
<0x05 0x00000000 0x05 0x00000000 0x01 0x00000000>, /* FSS0 DAT3 */
/* MCU Domain Range */
<0x00 0x04000000 0x00 0x04000000 0x00 0x01ff1400>,
/* Wakeup Domain Range */
<0x00 0x00b00000 0x00 0x00b00000 0x00 0x00002400>, /* VTM */
<0x00 0x2b000000 0x00 0x2b000000 0x00 0x00300400>,
<0x00 0x43000000 0x00 0x43000000 0x00 0x00020000>;
cbass_mcu: bus@4000000 {
bootph-all;
compatible = "simple-bus";
#size-cells = <2>;
ranges = <0x00 0x04000000 0x00 0x04000000 0x00 0x01ff1400>; /* Peripheral window */
cbass_wakeup: bus@b00000 {
bootph-all;
#size-cells = <2>;
ranges = <0x00 0x00b00000 0x00 0x00b00000 0x00 0x00002400>, /* VTM */
<0x00 0x2b000000 0x00 0x2b000000 0x00 0x00300400>, /* Peripheral Window */
- dss_vp1_clk: clock-divider-oldi {
compatible = "fixed-factor-clock";
clocks = <&k3_clks 186 0>;
#clock-cells = <0>;
clock-div = <7>;
clock-mult = <1>;
- #include "k3-am62-thermal.dtsi"
-/* Now include the peripherals for each bus segments */ -#include "k3-am62-main.dtsi" -#include "k3-am62-mcu.dtsi" -#include "k3-am62-wakeup.dtsi" diff --git a/arch/arm/dts/k3-am625-sk-binman.dtsi b/arch/arm/dts/k3-am625-sk-binman.dtsi index dfd38d64f638..db3a3e91b08f 100644 --- a/arch/arm/dts/k3-am625-sk-binman.dtsi +++ b/arch/arm/dts/k3-am625-sk-binman.dtsi @@ -141,7 +141,7 @@
#ifdef CONFIG_TARGET_AM625_A53_EVM
-#define SPL_AM625_SK_DTB "spl/dts/k3-am625-sk.dtb" +#define SPL_AM625_SK_DTB "spl/dts/ti/k3-am625-sk.dtb" #define AM625_SK_DTB "u-boot.dtb"
&binman { diff --git a/arch/arm/dts/k3-am625-sk.dts b/arch/arm/dts/k3-am625-sk.dts deleted file mode 100644 index ae81ebb39d02..000000000000 --- a/arch/arm/dts/k3-am625-sk.dts +++ /dev/null @@ -1,299 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only OR MIT -/*
- AM625 SK: https://www.ti.com/lit/zip/sprr448
- Copyright (C) 2021-2024 Texas Instruments Incorporated - https://www.ti.com/
-/dts-v1/;
-#include "k3-am62x-sk-common.dtsi"
- compatible = "ti,am625-sk", "ti,am625";
- model = "Texas Instruments AM625 SK";
- opp-table {
/* Add 1.4GHz OPP for am625-sk board. Requires VDD_CORE to be at 0.85V */
opp-1400000000 {
opp-hz = /bits/ 64 <1400000000>;
- memory@80000000 {
/* 2G RAM */
- vmain_pd: regulator-0 {
/* TPS65988 PD CONTROLLER OUTPUT */
bootph-all;
regulator-name = "vmain_pd";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
regulator-boot-on;
- vcc_5v0: regulator-1 {
/* Output of LM34936 */
bootph-all;
regulator-name = "vcc_5v0";
vin-supply = <&vmain_pd>;
regulator-boot-on;
- vcc_3v3_sys: regulator-2 {
/* output of LM61460-Q1 */
bootph-all;
regulator-name = "vcc_3v3_sys";
regulator-min-microvolt = <3300000>;
regulator-boot-on;
- vdd_mmc1: regulator-3 {
/* TPS22918DBVR */
bootph-all;
regulator-name = "vdd_mmc1";
regulator-boot-on;
enable-active-high;
gpio = <&exp1 3 GPIO_ACTIVE_HIGH>;
- vdd_sd_dv: regulator-4 {
/* Output of TLV71033 */
bootph-all;
compatible = "regulator-gpio";
regulator-name = "tlv71033";
pinctrl-0 = <&vdd_sd_dv_pins_default>;
regulator-max-microvolt = <3300000>;
regulator-boot-on;
vin-supply = <&vcc_5v0>;
gpios = <&main_gpio0 31 GPIO_ACTIVE_HIGH>;
states = <1800000 0x0>,
<3300000 0x1>;
- vcc_1v8: regulator-5 {
/* output of TPS6282518DMQ */
compatible = "regulator-fixed";
regulator-name = "vcc_1v8";
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
vin-supply = <&vcc_3v3_sys>;
regulator-always-on;
regulator-boot-on;
-&main_pmx0 {
- main_rgmii2_pins_default: main-rgmii2-default-pins {
bootph-all;
AM62X_IOPAD(0x184, PIN_INPUT, 0) /* (AE23) RGMII2_RD0 */
AM62X_IOPAD(0x188, PIN_INPUT, 0) /* (AB20) RGMII2_RD1 */
AM62X_IOPAD(0x18c, PIN_INPUT, 0) /* (AC21) RGMII2_RD2 */
AM62X_IOPAD(0x190, PIN_INPUT, 0) /* (AE22) RGMII2_RD3 */
AM62X_IOPAD(0x180, PIN_INPUT, 0) /* (AD23) RGMII2_RXC */
AM62X_IOPAD(0x17c, PIN_INPUT, 0) /* (AD22) RGMII2_RX_CTL */
AM62X_IOPAD(0x16c, PIN_OUTPUT, 0) /* (Y18) RGMII2_TD0 */
AM62X_IOPAD(0x170, PIN_OUTPUT, 0) /* (AA18) RGMII2_TD1 */
AM62X_IOPAD(0x174, PIN_OUTPUT, 0) /* (AD21) RGMII2_TD2 */
AM62X_IOPAD(0x178, PIN_OUTPUT, 0) /* (AC20) RGMII2_TD3 */
AM62X_IOPAD(0x168, PIN_OUTPUT, 0) /* (AE21) RGMII2_TXC */
AM62X_IOPAD(0x164, PIN_OUTPUT, 0) /* (AA19) RGMII2_TX_CTL */
- ospi0_pins_default: ospi0-default-pins {
bootph-all;
AM62X_IOPAD(0x000, PIN_OUTPUT, 0) /* (H24) OSPI0_CLK */
AM62X_IOPAD(0x02c, PIN_OUTPUT, 0) /* (F23) OSPI0_CSn0 */
AM62X_IOPAD(0x00c, PIN_INPUT, 0) /* (E25) OSPI0_D0 */
AM62X_IOPAD(0x010, PIN_INPUT, 0) /* (G24) OSPI0_D1 */
AM62X_IOPAD(0x014, PIN_INPUT, 0) /* (F25) OSPI0_D2 */
AM62X_IOPAD(0x018, PIN_INPUT, 0) /* (F24) OSPI0_D3 */
AM62X_IOPAD(0x01c, PIN_INPUT, 0) /* (J23) OSPI0_D4 */
AM62X_IOPAD(0x020, PIN_INPUT, 0) /* (J25) OSPI0_D5 */
AM62X_IOPAD(0x024, PIN_INPUT, 0) /* (H25) OSPI0_D6 */
AM62X_IOPAD(0x028, PIN_INPUT, 0) /* (J22) OSPI0_D7 */
AM62X_IOPAD(0x008, PIN_INPUT, 0) /* (J24) OSPI0_DQS */
- vdd_sd_dv_pins_default: vdd-sd-dv-default-pins {
bootph-all;
bootph-all;
-&main_gpio0 {
- bootph-all;
-&main_gpio1 {
- bootph-all;
-&main_i2c1 {
- bootph-all;
- exp1: gpio@22 {
bootph-all;
reg = <0x22>;
gpio-controller;
#gpio-cells = <2>;
-&sdhci1 {
-&cpsw3g {
-&cpsw_port2 {
-&cpsw3g_mdio {
reg = <1>;
-&fss {
- bootph-all;
-&ospi0 {
- bootph-all;
- status = "okay";
- flash@0 {
bootph-all;
reg = <0x0>;
partitions {
bootph-all;
#size-cells = <1>;
partition@0 {
partition@80000 {
partition@280000 {
partition@680000 {
label = "ospi.env";
partition@6c0000 {
partition@800000 {
partition@3fc0000 {
bootph-pre-ram;
-&tlv320aic3106 {
- Device Tree Source for AM625 SoC family in Quad core configuration
-/dts-v1/;
- cpus {
#size-cells = <0>;
cpu-map {
core0 {
cpu = <&cpu0>;
core1 {
cpu = <&cpu1>;
core2 {
cpu = <&cpu2>;
core3 {
cpu = <&cpu3>;
cpu0: cpu@0 {
reg = <0x000>;
cpu1: cpu@1 {
reg = <0x001>;
cpu2: cpu@2 {
reg = <0x002>;
cpu3: cpu@3 {
reg = <0x003>;
opp-shared;
opp-200000000 {
opp-400000000 {
opp-600000000 {
opp-800000000 {
opp-1000000000 {
opp-1250000000 {
opp-suspend;
- L2_0: l2-cache0 {
cache-unified;
cache-level = <2>;
cache-sets = <512>;
- Common dtsi for AM62x SK and derivatives
- aliases {
mmc0 = &sdhci0;
mmc1 = &sdhci1;
mmc2 = &sdhci2;
spi0 = &ospi0;
usb0 = &usb0;
usb1 = &usb1;
- chosen {
- memory@80000000 {
bootph-pre-ram;
/* 2G RAM */
- reserved-memory {
#size-cells = <2>;
ranges;
ramoops@9ca00000 {
no-map;
no-map;
no-map;
- leds {
led-0 {
#clock-cells = <0>;
"Line", "Line In",
label = "hdmi";
type = "a";
port {
-&main_pmx0 {
bootph-all;
bootph-pre-ram;
bootph-all;
bootph-all;
bootph-all;
-&mcu_pmx0 {
bootph-pre-ram;
-&wkup_uart0 {
- bootph-pre-ram;
-&main_uart0 {
- bootph-all;
- status = "okay";
-&main_uart1 {
- bootph-pre-ram;
-&main_i2c0 {
- status = "okay";
- eeprom@51 {
reg = <0x51>;
reg = <0x3f>;
connector {
label = "USB-C";
self-powered;
data-role = "dual";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
-&main_i2c1 {
- status = "okay";
reg = <0x1b>;
/* Regulators */
reg = <0x3b>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
port@1 {
reg = <1>;
-&main_i2c2 {
- status = "okay";
-&sdhci0 {
- bootph-all;
- status = "okay";
- disable-wp;
-&sdhci1 {
- /* SD/MMC */
- bootph-all;
- status = "okay";
- disable-wp;
-&cpsw3g {
- bootph-all;
-&cpsw_port1 {
- bootph-all;
-&cpsw3g_mdio {
- bootph-all;
- status = "okay";
bootph-all;
reg = <0>;
-&usbss0 {
- bootph-all;
- status = "okay";
- ti,vbus-divider;
-&usbss1 {
- status = "okay";
- ti,vbus-divider;
-&usb0 {
- bootph-all;
- usb-role-switch;
- port@0 {
reg = <0>;
-&usb1 {
- dr_mode = "host";
-&mcasp1 {
- status = "okay";
- tdm-slots = <2>;
1 0 2 0
0 0 0 0
0 0 0 0
0 0 0 0
;- tx-num-evt = <32>;
-&dss {
- status = "okay";
-&dss_ports {
- port@1 {
reg = <1>;
-&mcu_gpio_intr {
-}; diff --git a/configs/am62x_evm_a53_defconfig b/configs/am62x_evm_a53_defconfig index 16294a6a7940..9bfe1560275c 100644 --- a/configs/am62x_evm_a53_defconfig +++ b/configs/am62x_evm_a53_defconfig @@ -10,7 +10,7 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80b80000 CONFIG_SF_DEFAULT_SPEED=25000000 CONFIG_SPL_DM_SPI=y -CONFIG_DEFAULT_DEVICE_TREE="k3-am625-sk" +CONFIG_DEFAULT_DEVICE_TREE="ti/k3-am625-sk" CONFIG_SPL_TEXT_BASE=0x80080000 CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y @@ -56,6 +56,7 @@ CONFIG_CMD_EFIDEBUG=y CONFIG_MMC_SPEED_MODE_SET=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_UPSTREAM=y CONFIG_MULTI_DTB_FIT=y CONFIG_SPL_MULTI_DTB_FIT=y CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y -- 2.43.0
Enable OF_UPSTREAM for am62a7-sk board. Remove DT files that are now available in dts/upstream. Update the appended files based on version of latest OF_UPSTREAM sync point (v6.10-rc1).
Signed-off-by: Nishanth Menon nm@ti.com --- arch/arm/dts/Makefile | 3 +- arch/arm/dts/k3-am62a-main.dtsi | 1054 -------------------------- arch/arm/dts/k3-am62a-mcu.dtsi | 170 ----- arch/arm/dts/k3-am62a-sk-binman.dtsi | 2 +- arch/arm/dts/k3-am62a-thermal.dtsi | 50 -- arch/arm/dts/k3-am62a-wakeup.dtsi | 73 -- arch/arm/dts/k3-am62a.dtsi | 125 --- arch/arm/dts/k3-am62a7-sk.dts | 702 ----------------- configs/am62ax_evm_a53_defconfig | 3 +- 9 files changed, 4 insertions(+), 2178 deletions(-) delete mode 100644 arch/arm/dts/k3-am62a-main.dtsi delete mode 100644 arch/arm/dts/k3-am62a-mcu.dtsi delete mode 100644 arch/arm/dts/k3-am62a-thermal.dtsi delete mode 100644 arch/arm/dts/k3-am62a-wakeup.dtsi delete mode 100644 arch/arm/dts/k3-am62a.dtsi delete mode 100644 arch/arm/dts/k3-am62a7-sk.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 5b0bcf336924..27f38908f268 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -1203,8 +1203,7 @@ dtb-$(CONFIG_SOC_K3_AM625) += k3-am625-r5-sk.dtb \ k3-am625-verdin-r5.dtb \ k3-am625-r5-phycore-som-2gb.dtb
-dtb-$(CONFIG_SOC_K3_AM62A7) += k3-am62a7-sk.dtb \ - k3-am62a7-r5-sk.dtb +dtb-$(CONFIG_SOC_K3_AM62A7) += k3-am62a7-r5-sk.dtb
dtb-$(CONFIG_SOC_K3_AM62P5) += k3-am62p5-r5-sk.dtb
diff --git a/arch/arm/dts/k3-am62a-main.dtsi b/arch/arm/dts/k3-am62a-main.dtsi deleted file mode 100644 index aa1e057082f0..000000000000 --- a/arch/arm/dts/k3-am62a-main.dtsi +++ /dev/null @@ -1,1054 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only OR MIT -/* - * Device Tree Source for AM62A SoC Family Main Domain peripherals - * - * Copyright (C) 2022-2024 Texas Instruments Incorporated - https://www.ti.com/ - */ - -&cbass_main { - oc_sram: sram@70000000 { - compatible = "mmio-sram"; - reg = <0x00 0x70000000 0x00 0x10000>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x0 0x00 0x70000000 0x10000>; - }; - - gic500: interrupt-controller@1800000 { - compatible = "arm,gic-v3"; - reg = <0x00 0x01800000 0x00 0x10000>, /* GICD */ - <0x00 0x01880000 0x00 0xc0000>, /* GICR */ - <0x00 0x01880000 0x00 0xc0000>, /* GICR */ - <0x01 0x00000000 0x00 0x2000>, /* GICC */ - <0x01 0x00010000 0x00 0x1000>, /* GICH */ - <0x01 0x00020000 0x00 0x2000>; /* GICV */ - #address-cells = <2>; - #size-cells = <2>; - ranges; - #interrupt-cells = <3>; - interrupt-controller; - /* - * vcpumntirq: - * virtual CPU interface maintenance interrupt - */ - interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; - - gic_its: msi-controller@1820000 { - compatible = "arm,gic-v3-its"; - reg = <0x00 0x01820000 0x00 0x10000>; - socionext,synquacer-pre-its = <0x1000000 0x400000>; - msi-controller; - #msi-cells = <1>; - }; - }; - - main_conf: bus@100000 { - compatible = "simple-bus"; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x00 0x00 0x00100000 0x20000>; - - phy_gmii_sel: phy@4044 { - compatible = "ti,am654-phy-gmii-sel"; - reg = <0x4044 0x8>; - #phy-cells = <1>; - }; - - epwm_tbclk: clock-controller@4130 { - compatible = "ti,am62-epwm-tbclk"; - reg = <0x4130 0x4>; - #clock-cells = <1>; - }; - }; - - dmss: bus@48000000 { - compatible = "simple-bus"; - #address-cells = <2>; - #size-cells = <2>; - dma-ranges; - ranges = <0x00 0x48000000 0x00 0x48000000 0x00 0x06000000>; - - ti,sci-dev-id = <25>; - - secure_proxy_main: mailbox@4d000000 { - compatible = "ti,am654-secure-proxy"; - reg = <0x00 0x4d000000 0x00 0x80000>, - <0x00 0x4a600000 0x00 0x80000>, - <0x00 0x4a400000 0x00 0x80000>; - reg-names = "target_data", "rt", "scfg"; - #mbox-cells = <1>; - interrupt-names = "rx_012"; - interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; - }; - - inta_main_dmss: interrupt-controller@48000000 { - compatible = "ti,sci-inta"; - reg = <0x00 0x48000000 0x00 0x100000>; - #interrupt-cells = <0>; - interrupt-controller; - interrupt-parent = <&gic500>; - msi-controller; - ti,sci = <&dmsc>; - ti,sci-dev-id = <28>; - ti,interrupt-ranges = <6 70 34>; - ti,unmapped-event-sources = <&main_bcdma>, <&main_pktdma>; - }; - - main_bcdma: dma-controller@485c0100 { - compatible = "ti,am64-dmss-bcdma"; - reg = <0x00 0x485c0100 0x00 0x100>, - <0x00 0x4c000000 0x00 0x20000>, - <0x00 0x4a820000 0x00 0x20000>, - <0x00 0x4aa40000 0x00 0x20000>, - <0x00 0x4bc00000 0x00 0x100000>, - <0x00 0x48600000 0x00 0x8000>, - <0x00 0x484a4000 0x00 0x2000>, - <0x00 0x484c2000 0x00 0x2000>, - <0x00 0x48420000 0x00 0x2000>; - reg-names = "gcfg", "bchanrt", "rchanrt", "tchanrt", "ringrt", - "ring", "tchan", "rchan", "bchan"; - msi-parent = <&inta_main_dmss>; - #dma-cells = <3>; - ti,sci = <&dmsc>; - ti,sci-dev-id = <26>; - ti,sci-rm-range-bchan = <0x20>; /* BLOCK_COPY_CHAN */ - ti,sci-rm-range-rchan = <0x21>; /* SPLIT_TR_RX_CHAN */ - ti,sci-rm-range-tchan = <0x22>; /* SPLIT_TR_TX_CHAN */ - }; - - main_pktdma: dma-controller@485c0000 { - compatible = "ti,am64-dmss-pktdma"; - reg = <0x00 0x485c0000 0x00 0x100>, - <0x00 0x4a800000 0x00 0x20000>, - <0x00 0x4aa00000 0x00 0x40000>, - <0x00 0x4b800000 0x00 0x400000>, - <0x00 0x485e0000 0x00 0x10000>, - <0x00 0x484a0000 0x00 0x2000>, - <0x00 0x484c0000 0x00 0x2000>, - <0x00 0x48430000 0x00 0x1000>; - reg-names = "gcfg", "rchanrt", "tchanrt", "ringrt", - "ring", "tchan", "rchan", "rflow"; - msi-parent = <&inta_main_dmss>; - #dma-cells = <2>; - ti,sci = <&dmsc>; - ti,sci-dev-id = <30>; - ti,sci-rm-range-tchan = <0x23>, /* UNMAPPED_TX_CHAN */ - <0x24>, /* CPSW_TX_CHAN */ - <0x25>, /* SAUL_TX_0_CHAN */ - <0x26>; /* SAUL_TX_1_CHAN */ - ti,sci-rm-range-tflow = <0x10>, /* RING_UNMAPPED_TX_CHAN */ - <0x11>, /* RING_CPSW_TX_CHAN */ - <0x12>, /* RING_SAUL_TX_0_CHAN */ - <0x13>; /* RING_SAUL_TX_1_CHAN */ - ti,sci-rm-range-rchan = <0x29>, /* UNMAPPED_RX_CHAN */ - <0x2b>, /* CPSW_RX_CHAN */ - <0x2d>, /* SAUL_RX_0_CHAN */ - <0x2f>, /* SAUL_RX_1_CHAN */ - <0x31>, /* SAUL_RX_2_CHAN */ - <0x33>; /* SAUL_RX_3_CHAN */ - ti,sci-rm-range-rflow = <0x2a>, /* FLOW_UNMAPPED_RX_CHAN */ - <0x2c>, /* FLOW_CPSW_RX_CHAN */ - <0x2e>, /* FLOW_SAUL_RX_0/1_CHAN */ - <0x32>; /* FLOW_SAUL_RX_2/3_CHAN */ - }; - }; - - dmss_csi: bus@4e000000 { - compatible = "simple-bus"; - #address-cells = <2>; - #size-cells = <2>; - dma-ranges; - ranges = <0x00 0x4e000000 0x00 0x4e000000 0x00 0x300000>; - - ti,sci-dev-id = <198>; - - inta_main_dmss_csi: interrupt-controller@4e0a0000 { - compatible = "ti,sci-inta"; - reg = <0x00 0x4e0a0000 0x00 0x8000>; - #interrupt-cells = <0>; - interrupt-controller; - interrupt-parent = <&gic500>; - msi-controller; - ti,sci = <&dmsc>; - ti,sci-dev-id = <200>; - ti,interrupt-ranges = <0 237 8>; - ti,unmapped-event-sources = <&main_bcdma_csi>; - power-domains = <&k3_pds 182 TI_SCI_PD_EXCLUSIVE>; - }; - - main_bcdma_csi: dma-controller@4e230000 { - compatible = "ti,am62a-dmss-bcdma-csirx"; - reg = <0x00 0x4e230000 0x00 0x100>, - <0x00 0x4e180000 0x00 0x8000>, - <0x00 0x4e100000 0x00 0x10000>; - reg-names = "gcfg", "rchanrt", "ringrt"; - msi-parent = <&inta_main_dmss_csi>; - #dma-cells = <3>; - ti,sci = <&dmsc>; - ti,sci-dev-id = <199>; - ti,sci-rm-range-rchan = <0x21>; - power-domains = <&k3_pds 182 TI_SCI_PD_EXCLUSIVE>; - }; - }; - - dmsc: system-controller@44043000 { - compatible = "ti,k2g-sci"; - reg = <0x00 0x44043000 0x00 0xfe0>; - reg-names = "debug_messages"; - ti,host-id = <12>; - mbox-names = "rx", "tx"; - mboxes = <&secure_proxy_main 12>, - <&secure_proxy_main 13>; - - k3_pds: power-controller { - compatible = "ti,sci-pm-domain"; - #power-domain-cells = <2>; - }; - - k3_clks: clock-controller { - compatible = "ti,k2g-sci-clk"; - #clock-cells = <2>; - }; - - k3_reset: reset-controller { - compatible = "ti,sci-reset"; - #reset-cells = <2>; - }; - }; - - secure_proxy_sa3: mailbox@43600000 { - compatible = "ti,am654-secure-proxy"; - #mbox-cells = <1>; - reg-names = "target_data", "rt", "scfg"; - reg = <0x00 0x43600000 0x00 0x10000>, - <0x00 0x44880000 0x00 0x20000>, - <0x00 0x44860000 0x00 0x20000>; - /* - * Marked Disabled: - * Node is incomplete as it is meant for bootloaders and - * firmware on non-MPU processors - */ - status = "disabled"; - }; - - main_pmx0: pinctrl@f4000 { - compatible = "pinctrl-single"; - reg = <0x00 0xf4000 0x00 0x2ac>; - #pinctrl-cells = <1>; - pinctrl-single,register-width = <32>; - pinctrl-single,function-mask = <0xffffffff>; - }; - - main_timer0: timer@2400000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x2400000 0x00 0x400>; - interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 36 2>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 36 2>; - assigned-clock-parents = <&k3_clks 36 3>; - power-domains = <&k3_pds 36 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer1: timer@2410000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x2410000 0x00 0x400>; - interrupts = <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 37 2>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 37 2>; - assigned-clock-parents = <&k3_clks 37 3>; - power-domains = <&k3_pds 37 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer2: timer@2420000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x2420000 0x00 0x400>; - interrupts = <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 38 2>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 38 2>; - assigned-clock-parents = <&k3_clks 38 3>; - power-domains = <&k3_pds 38 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer3: timer@2430000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x2430000 0x00 0x400>; - interrupts = <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 39 2>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 39 2>; - assigned-clock-parents = <&k3_clks 39 3>; - power-domains = <&k3_pds 39 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer4: timer@2440000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x2440000 0x00 0x400>; - interrupts = <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 40 2>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 40 2>; - assigned-clock-parents = <&k3_clks 40 3>; - power-domains = <&k3_pds 40 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer5: timer@2450000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x2450000 0x00 0x400>; - interrupts = <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 41 2>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 41 2>; - assigned-clock-parents = <&k3_clks 41 3>; - power-domains = <&k3_pds 41 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer6: timer@2460000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x2460000 0x00 0x400>; - interrupts = <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 42 2>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 42 2>; - assigned-clock-parents = <&k3_clks 42 3>; - power-domains = <&k3_pds 42 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_timer7: timer@2470000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x2470000 0x00 0x400>; - interrupts = <GIC_SPI 127 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 43 2>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 43 2>; - assigned-clock-parents = <&k3_clks 43 3>; - power-domains = <&k3_pds 43 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - }; - - main_uart0: serial@2800000 { - compatible = "ti,am64-uart", "ti,am654-uart"; - reg = <0x00 0x02800000 0x00 0x100>; - interrupts = <GIC_SPI 178 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&k3_pds 146 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 146 0>; - clock-names = "fclk"; - status = "disabled"; - }; - - main_uart1: serial@2810000 { - compatible = "ti,am64-uart", "ti,am654-uart"; - reg = <0x00 0x02810000 0x00 0x100>; - interrupts = <GIC_SPI 179 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&k3_pds 152 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 152 0>; - clock-names = "fclk"; - status = "disabled"; - }; - - main_uart2: serial@2820000 { - compatible = "ti,am64-uart", "ti,am654-uart"; - reg = <0x00 0x02820000 0x00 0x100>; - interrupts = <GIC_SPI 180 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&k3_pds 153 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 153 0>; - clock-names = "fclk"; - status = "disabled"; - }; - - main_uart3: serial@2830000 { - compatible = "ti,am64-uart", "ti,am654-uart"; - reg = <0x00 0x02830000 0x00 0x100>; - interrupts = <GIC_SPI 181 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&k3_pds 154 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 154 0>; - clock-names = "fclk"; - status = "disabled"; - }; - - main_uart4: serial@2840000 { - compatible = "ti,am64-uart", "ti,am654-uart"; - reg = <0x00 0x02840000 0x00 0x100>; - interrupts = <GIC_SPI 182 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&k3_pds 155 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 155 0>; - clock-names = "fclk"; - status = "disabled"; - }; - - main_uart5: serial@2850000 { - compatible = "ti,am64-uart", "ti,am654-uart"; - reg = <0x00 0x02850000 0x00 0x100>; - interrupts = <GIC_SPI 183 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&k3_pds 156 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 156 0>; - clock-names = "fclk"; - status = "disabled"; - }; - - main_uart6: serial@2860000 { - compatible = "ti,am64-uart", "ti,am654-uart"; - reg = <0x00 0x02860000 0x00 0x100>; - interrupts = <GIC_SPI 184 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&k3_pds 158 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 158 0>; - clock-names = "fclk"; - status = "disabled"; - }; - - main_i2c0: i2c@20000000 { - compatible = "ti,am64-i2c", "ti,omap4-i2c"; - reg = <0x00 0x20000000 0x00 0x100>; - interrupts = <GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 102 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 102 2>; - clock-names = "fck"; - status = "disabled"; - }; - - main_i2c1: i2c@20010000 { - compatible = "ti,am64-i2c", "ti,omap4-i2c"; - reg = <0x00 0x20010000 0x00 0x100>; - interrupts = <GIC_SPI 162 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 103 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 103 2>; - clock-names = "fck"; - status = "disabled"; - }; - - main_i2c2: i2c@20020000 { - compatible = "ti,am64-i2c", "ti,omap4-i2c"; - reg = <0x00 0x20020000 0x00 0x100>; - interrupts = <GIC_SPI 163 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 104 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 104 2>; - clock-names = "fck"; - status = "disabled"; - }; - - main_i2c3: i2c@20030000 { - compatible = "ti,am64-i2c", "ti,omap4-i2c"; - reg = <0x00 0x20030000 0x00 0x100>; - interrupts = <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 105 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 105 2>; - clock-names = "fck"; - status = "disabled"; - }; - - main_spi0: spi@20100000 { - compatible = "ti,am654-mcspi", "ti,omap4-mcspi"; - reg = <0x00 0x20100000 0x00 0x400>; - interrupts = <GIC_SPI 172 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 141 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 141 0>; - status = "disabled"; - }; - - main_spi1: spi@20110000 { - compatible = "ti,am654-mcspi","ti,omap4-mcspi"; - reg = <0x00 0x20110000 0x00 0x400>; - interrupts = <GIC_SPI 173 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 142 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 142 0>; - status = "disabled"; - }; - - main_spi2: spi@20120000 { - compatible = "ti,am654-mcspi","ti,omap4-mcspi"; - reg = <0x00 0x20120000 0x00 0x400>; - interrupts = <GIC_SPI 174 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 143 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 143 0>; - status = "disabled"; - }; - - main_gpio_intr: interrupt-controller@a00000 { - compatible = "ti,sci-intr"; - reg = <0x00 0x00a00000 0x00 0x800>; - ti,intr-trigger-type = <1>; - interrupt-controller; - interrupt-parent = <&gic500>; - #interrupt-cells = <1>; - ti,sci = <&dmsc>; - ti,sci-dev-id = <3>; - ti,interrupt-ranges = <0 32 16>; - status = "disabled"; - }; - - main_gpio0: gpio@600000 { - compatible = "ti,am64-gpio", "ti,keystone-gpio"; - reg = <0x00 0x00600000 0x0 0x100>; - gpio-controller; - #gpio-cells = <2>; - interrupt-parent = <&main_gpio_intr>; - interrupts = <190>, <191>, <192>, - <193>, <194>, <195>; - interrupt-controller; - #interrupt-cells = <2>; - ti,ngpio = <92>; - ti,davinci-gpio-unbanked = <0>; - power-domains = <&k3_pds 77 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 77 0>; - clock-names = "gpio"; - status = "disabled"; - }; - - main_gpio1: gpio@601000 { - compatible = "ti,am64-gpio", "ti,keystone-gpio"; - reg = <0x00 0x00601000 0x0 0x100>; - gpio-controller; - #gpio-cells = <2>; - interrupt-parent = <&main_gpio_intr>; - interrupts = <180>, <181>, <182>, - <183>, <184>, <185>; - interrupt-controller; - #interrupt-cells = <2>; - ti,ngpio = <52>; - ti,davinci-gpio-unbanked = <0>; - power-domains = <&k3_pds 78 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 78 0>; - clock-names = "gpio"; - status = "disabled"; - }; - - sdhci0: mmc@fa10000 { - compatible = "ti,am62-sdhci"; - reg = <0x00 0xfa10000 0x00 0x260>, <0x00 0xfa18000 0x00 0x134>; - interrupts = <GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&k3_pds 57 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 57 5>, <&k3_clks 57 6>; - clock-names = "clk_ahb", "clk_xin"; - assigned-clocks = <&k3_clks 57 6>; - assigned-clock-parents = <&k3_clks 57 8>; - bus-width = <8>; - mmc-hs200-1_8v; - ti,clkbuf-sel = <0x7>; - ti,otap-del-sel-legacy = <0x0>; - ti,otap-del-sel-mmc-hs = <0x0>; - ti,otap-del-sel-hs200 = <0x6>; - status = "disabled"; - }; - - sdhci1: mmc@fa00000 { - compatible = "ti,am62-sdhci"; - reg = <0x00 0xfa00000 0x00 0x260>, <0x00 0xfa08000 0x00 0x134>; - interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&k3_pds 58 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 58 5>, <&k3_clks 58 6>; - clock-names = "clk_ahb", "clk_xin"; - bus-width = <4>; - ti,clkbuf-sel = <0x7>; - ti,otap-del-sel-legacy = <0x0>; - ti,otap-del-sel-sd-hs = <0x0>; - ti,otap-del-sel-sdr12 = <0xf>; - ti,otap-del-sel-sdr25 = <0xf>; - ti,otap-del-sel-sdr50 = <0xc>; - ti,otap-del-sel-sdr104 = <0x6>; - ti,otap-del-sel-ddr50 = <0x9>; - ti,itap-del-sel-legacy = <0x0>; - ti,itap-del-sel-sd-hs = <0x0>; - ti,itap-del-sel-sdr12 = <0x0>; - ti,itap-del-sel-sdr25 = <0x0>; - no-1-8-v; - status = "disabled"; - }; - - sdhci2: mmc@fa20000 { - compatible = "ti,am62-sdhci"; - reg = <0x00 0xfa20000 0x00 0x260>, <0x00 0xfa28000 0x00 0x134>; - interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&k3_pds 184 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 184 5>, <&k3_clks 184 6>; - clock-names = "clk_ahb", "clk_xin"; - bus-width = <4>; - ti,clkbuf-sel = <0x7>; - ti,otap-del-sel-legacy = <0x0>; - ti,otap-del-sel-sd-hs = <0x0>; - ti,otap-del-sel-sdr12 = <0xf>; - ti,otap-del-sel-sdr25 = <0xf>; - ti,otap-del-sel-sdr50 = <0xc>; - ti,otap-del-sel-sdr104 = <0x6>; - ti,otap-del-sel-ddr50 = <0x9>; - ti,itap-del-sel-legacy = <0x0>; - ti,itap-del-sel-sd-hs = <0x0>; - ti,itap-del-sel-sdr12 = <0x0>; - ti,itap-del-sel-sdr25 = <0x0>; - no-1-8-v; - status = "disabled"; - }; - - usbss0: dwc3-usb@f900000 { - compatible = "ti,am62-usb"; - reg = <0x00 0x0f900000 0x00 0x800>; - clocks = <&k3_clks 161 3>; - clock-names = "ref"; - ti,syscon-phy-pll-refclk = <&wkup_conf 0x4008>; - #address-cells = <2>; - #size-cells = <2>; - power-domains = <&k3_pds 178 TI_SCI_PD_EXCLUSIVE>; - ranges; - status = "disabled"; - - usb0: usb@31000000 { - compatible = "snps,dwc3"; - reg = <0x00 0x31000000 0x00 0x50000>; - interrupts = <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>, /* irq.0 */ - <GIC_SPI 188 IRQ_TYPE_LEVEL_HIGH>; /* irq.0 */ - interrupt-names = "host", "peripheral"; - maximum-speed = "high-speed"; - dr_mode = "otg"; - }; - }; - - usbss1: dwc3-usb@f910000 { - compatible = "ti,am62-usb"; - reg = <0x00 0x0f910000 0x00 0x800>; - clocks = <&k3_clks 162 3>; - clock-names = "ref"; - ti,syscon-phy-pll-refclk = <&wkup_conf 0x4018>; - #address-cells = <2>; - #size-cells = <2>; - power-domains = <&k3_pds 179 TI_SCI_PD_EXCLUSIVE>; - ranges; - status = "disabled"; - - usb1: usb@31100000 { - compatible = "snps,dwc3"; - reg = <0x00 0x31100000 0x00 0x50000>; - interrupts = <GIC_SPI 226 IRQ_TYPE_LEVEL_HIGH>, /* irq.0 */ - <GIC_SPI 226 IRQ_TYPE_LEVEL_HIGH>; /* irq.0 */ - interrupt-names = "host", "peripheral"; - maximum-speed = "high-speed"; - dr_mode = "otg"; - }; - }; - - fss: bus@fc00000 { - compatible = "simple-bus"; - reg = <0x00 0x0fc00000 0x00 0x70000>; - #address-cells = <2>; - #size-cells = <2>; - ranges; - status = "disabled"; - - ospi0: spi@fc40000 { - compatible = "ti,am654-ospi", "cdns,qspi-nor"; - reg = <0x00 0x0fc40000 0x00 0x100>, - <0x05 0x00000000 0x01 0x00000000>; - interrupts = <GIC_SPI 139 IRQ_TYPE_LEVEL_HIGH>; - cdns,fifo-depth = <256>; - cdns,fifo-width = <4>; - cdns,trigger-address = <0x0>; - clocks = <&k3_clks 75 7>; - assigned-clocks = <&k3_clks 75 7>; - assigned-clock-parents = <&k3_clks 75 8>; - assigned-clock-rates = <166666666>; - power-domains = <&k3_pds 75 TI_SCI_PD_EXCLUSIVE>; - #address-cells = <1>; - #size-cells = <0>; - }; - }; - - cpsw3g: ethernet@8000000 { - compatible = "ti,am642-cpsw-nuss"; - #address-cells = <2>; - #size-cells = <2>; - reg = <0x0 0x8000000 0x0 0x200000>; - reg-names = "cpsw_nuss"; - ranges = <0x0 0x0 0x0 0x8000000 0x0 0x200000>; - clocks = <&k3_clks 13 0>; - assigned-clocks = <&k3_clks 13 3>; - assigned-clock-parents = <&k3_clks 13 11>; - clock-names = "fck"; - power-domains = <&k3_pds 13 TI_SCI_PD_EXCLUSIVE>; - status = "disabled"; - - dmas = <&main_pktdma 0xc600 15>, - <&main_pktdma 0xc601 15>, - <&main_pktdma 0xc602 15>, - <&main_pktdma 0xc603 15>, - <&main_pktdma 0xc604 15>, - <&main_pktdma 0xc605 15>, - <&main_pktdma 0xc606 15>, - <&main_pktdma 0xc607 15>, - <&main_pktdma 0x4600 15>; - dma-names = "tx0", "tx1", "tx2", "tx3", "tx4", "tx5", "tx6", - "tx7", "rx"; - - ethernet-ports { - #address-cells = <1>; - #size-cells = <0>; - - cpsw_port1: port@1 { - reg = <1>; - ti,mac-only; - label = "port1"; - phys = <&phy_gmii_sel 1>; - mac-address = [00 00 00 00 00 00]; - ti,syscon-efuse = <&wkup_conf 0x200>; - }; - - cpsw_port2: port@2 { - reg = <2>; - ti,mac-only; - label = "port2"; - phys = <&phy_gmii_sel 2>; - mac-address = [00 00 00 00 00 00]; - }; - }; - - cpsw3g_mdio: mdio@f00 { - compatible = "ti,cpsw-mdio","ti,davinci_mdio"; - reg = <0x0 0xf00 0x0 0x100>; - #address-cells = <1>; - #size-cells = <0>; - clocks = <&k3_clks 13 0>; - clock-names = "fck"; - bus_freq = <1000000>; - }; - - cpts@3d000 { - compatible = "ti,j721e-cpts"; - reg = <0x0 0x3d000 0x0 0x400>; - clocks = <&k3_clks 13 3>; - clock-names = "cpts"; - interrupts-extended = <&gic500 GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "cpts"; - ti,cpts-ext-ts-inputs = <4>; - ti,cpts-periodic-outputs = <2>; - }; - }; - - hwspinlock: spinlock@2a000000 { - compatible = "ti,am64-hwspinlock"; - reg = <0x00 0x2a000000 0x00 0x1000>; - #hwlock-cells = <1>; - }; - - mailbox0_cluster0: mailbox@29000000 { - compatible = "ti,am64-mailbox"; - reg = <0x00 0x29000000 0x00 0x200>; - interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>; - #mbox-cells = <1>; - ti,mbox-num-users = <4>; - ti,mbox-num-fifos = <16>; - }; - - mailbox0_cluster1: mailbox@29010000 { - compatible = "ti,am64-mailbox"; - reg = <0x00 0x29010000 0x00 0x200>; - interrupts = <GIC_SPI 77 IRQ_TYPE_LEVEL_HIGH>; - #mbox-cells = <1>; - ti,mbox-num-users = <4>; - ti,mbox-num-fifos = <16>; - }; - - mailbox0_cluster2: mailbox@29020000 { - compatible = "ti,am64-mailbox"; - reg = <0x00 0x29020000 0x00 0x200>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH>; - #mbox-cells = <1>; - ti,mbox-num-users = <4>; - ti,mbox-num-fifos = <16>; - }; - - mailbox0_cluster3: mailbox@29030000 { - compatible = "ti,am64-mailbox"; - reg = <0x00 0x29030000 0x00 0x200>; - interrupts = <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH>; - #mbox-cells = <1>; - ti,mbox-num-users = <4>; - ti,mbox-num-fifos = <16>; - }; - - main_mcan0: can@20701000 { - compatible = "bosch,m_can"; - reg = <0x00 0x20701000 0x00 0x200>, - <0x00 0x20708000 0x00 0x8000>; - reg-names = "m_can", "message_ram"; - power-domains = <&k3_pds 98 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 98 6>, <&k3_clks 98 1>; - clock-names = "hclk", "cclk"; - interrupts = <GIC_SPI 155 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "int0", "int1"; - bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>; - status = "disabled"; - }; - - main_rti0: watchdog@e000000 { - compatible = "ti,j7-rti-wdt"; - reg = <0x00 0x0e000000 0x00 0x100>; - clocks = <&k3_clks 125 0>; - power-domains = <&k3_pds 125 TI_SCI_PD_EXCLUSIVE>; - assigned-clocks = <&k3_clks 125 0>; - assigned-clock-parents = <&k3_clks 125 2>; - }; - - main_rti1: watchdog@e010000 { - compatible = "ti,j7-rti-wdt"; - reg = <0x00 0x0e010000 0x00 0x100>; - clocks = <&k3_clks 126 0>; - power-domains = <&k3_pds 126 TI_SCI_PD_EXCLUSIVE>; - assigned-clocks = <&k3_clks 126 0>; - assigned-clock-parents = <&k3_clks 126 2>; - }; - - main_rti2: watchdog@e020000 { - compatible = "ti,j7-rti-wdt"; - reg = <0x00 0x0e020000 0x00 0x100>; - clocks = <&k3_clks 127 0>; - power-domains = <&k3_pds 127 TI_SCI_PD_EXCLUSIVE>; - assigned-clocks = <&k3_clks 127 0>; - assigned-clock-parents = <&k3_clks 127 2>; - }; - - main_rti3: watchdog@e030000 { - compatible = "ti,j7-rti-wdt"; - reg = <0x00 0x0e030000 0x00 0x100>; - clocks = <&k3_clks 128 0>; - power-domains = <&k3_pds 128 TI_SCI_PD_EXCLUSIVE>; - assigned-clocks = <&k3_clks 128 0>; - assigned-clock-parents = <&k3_clks 128 2>; - }; - - main_rti4: watchdog@e040000 { - compatible = "ti,j7-rti-wdt"; - reg = <0x00 0x0e040000 0x00 0x100>; - clocks = <&k3_clks 205 0>; - power-domains = <&k3_pds 205 TI_SCI_PD_EXCLUSIVE>; - assigned-clocks = <&k3_clks 205 0>; - assigned-clock-parents = <&k3_clks 205 2>; - }; - - epwm0: pwm@23000000 { - compatible = "ti,am64-epwm", "ti,am3352-ehrpwm"; - #pwm-cells = <3>; - reg = <0x00 0x23000000 0x00 0x100>; - power-domains = <&k3_pds 86 TI_SCI_PD_EXCLUSIVE>; - clocks = <&epwm_tbclk 0>, <&k3_clks 86 0>; - clock-names = "tbclk", "fck"; - status = "disabled"; - }; - - epwm1: pwm@23010000 { - compatible = "ti,am64-epwm", "ti,am3352-ehrpwm"; - #pwm-cells = <3>; - reg = <0x00 0x23010000 0x00 0x100>; - power-domains = <&k3_pds 87 TI_SCI_PD_EXCLUSIVE>; - clocks = <&epwm_tbclk 1>, <&k3_clks 87 0>; - clock-names = "tbclk", "fck"; - status = "disabled"; - }; - - epwm2: pwm@23020000 { - compatible = "ti,am64-epwm", "ti,am3352-ehrpwm"; - #pwm-cells = <3>; - reg = <0x00 0x23020000 0x00 0x100>; - power-domains = <&k3_pds 88 TI_SCI_PD_EXCLUSIVE>; - clocks = <&epwm_tbclk 2>, <&k3_clks 88 0>; - clock-names = "tbclk", "fck"; - status = "disabled"; - }; - - ecap0: pwm@23100000 { - compatible = "ti,am3352-ecap"; - #pwm-cells = <3>; - reg = <0x00 0x23100000 0x00 0x100>; - power-domains = <&k3_pds 51 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 51 0>; - clock-names = "fck"; - status = "disabled"; - }; - - ecap1: pwm@23110000 { - compatible = "ti,am3352-ecap"; - #pwm-cells = <3>; - reg = <0x00 0x23110000 0x00 0x100>; - power-domains = <&k3_pds 52 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 52 0>; - clock-names = "fck"; - status = "disabled"; - }; - - ecap2: pwm@23120000 { - compatible = "ti,am3352-ecap"; - #pwm-cells = <3>; - reg = <0x00 0x23120000 0x00 0x100>; - power-domains = <&k3_pds 53 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 53 0>; - clock-names = "fck"; - status = "disabled"; - }; - - mcasp0: audio-controller@2b00000 { - compatible = "ti,am33xx-mcasp-audio"; - reg = <0x00 0x02b00000 0x00 0x2000>, - <0x00 0x02b08000 0x00 0x400>; - reg-names = "mpu", "dat"; - interrupts = <GIC_SPI 236 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 235 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "tx", "rx"; - - dmas = <&main_bcdma 0 0xc500 0>, <&main_bcdma 0 0x4500 0>; - dma-names = "tx", "rx"; - - clocks = <&k3_clks 190 0>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 190 0>; - assigned-clock-parents = <&k3_clks 190 2>; - power-domains = <&k3_pds 190 TI_SCI_PD_EXCLUSIVE>; - status = "disabled"; - }; - - mcasp1: audio-controller@2b10000 { - compatible = "ti,am33xx-mcasp-audio"; - reg = <0x00 0x02b10000 0x00 0x2000>, - <0x00 0x02b18000 0x00 0x400>; - reg-names = "mpu", "dat"; - interrupts = <GIC_SPI 238 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 237 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "tx", "rx"; - - dmas = <&main_bcdma 0 0xc501 0>, <&main_bcdma 0 0x4501 0>; - dma-names = "tx", "rx"; - - clocks = <&k3_clks 191 0>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 191 0>; - assigned-clock-parents = <&k3_clks 191 2>; - power-domains = <&k3_pds 191 TI_SCI_PD_EXCLUSIVE>; - status = "disabled"; - }; - - mcasp2: audio-controller@2b20000 { - compatible = "ti,am33xx-mcasp-audio"; - reg = <0x00 0x02b20000 0x00 0x2000>, - <0x00 0x02b28000 0x00 0x400>; - reg-names = "mpu", "dat"; - interrupts = <GIC_SPI 240 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 239 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "tx", "rx"; - - dmas = <&main_bcdma 0 0xc502 0>, <&main_bcdma 0 0x4502 0>; - dma-names = "tx", "rx"; - - clocks = <&k3_clks 192 0>; - clock-names = "fck"; - assigned-clocks = <&k3_clks 192 0>; - assigned-clock-parents = <&k3_clks 192 2>; - power-domains = <&k3_pds 192 TI_SCI_PD_EXCLUSIVE>; - status = "disabled"; - }; - - ti_csi2rx0: ticsi2rx@30102000 { - compatible = "ti,j721e-csi2rx-shim"; - dmas = <&main_bcdma_csi 0 0x5000 0>; - dma-names = "rx0"; - reg = <0x00 0x30102000 0x00 0x1000>; - power-domains = <&k3_pds 182 TI_SCI_PD_EXCLUSIVE>; - #address-cells = <2>; - #size-cells = <2>; - ranges; - status = "disabled"; - - cdns_csi2rx0: csi-bridge@30101000 { - compatible = "ti,j721e-csi2rx", "cdns,csi2rx"; - reg = <0x00 0x30101000 0x00 0x1000>; - clocks = <&k3_clks 182 0>, <&k3_clks 182 3>, <&k3_clks 182 0>, - <&k3_clks 182 0>, <&k3_clks 182 4>, <&k3_clks 182 4>; - clock-names = "sys_clk", "p_clk", "pixel_if0_clk", - "pixel_if1_clk", "pixel_if2_clk", "pixel_if3_clk"; - phys = <&dphy0>; - phy-names = "dphy"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - csi0_port0: port@0 { - reg = <0>; - status = "disabled"; - }; - - csi0_port1: port@1 { - reg = <1>; - status = "disabled"; - }; - - csi0_port2: port@2 { - reg = <2>; - status = "disabled"; - }; - - csi0_port3: port@3 { - reg = <3>; - status = "disabled"; - }; - - csi0_port4: port@4 { - reg = <4>; - status = "disabled"; - }; - }; - }; - }; - - dphy0: phy@30110000 { - compatible = "cdns,dphy-rx"; - reg = <0x00 0x30110000 0x00 0x1100>; - #phy-cells = <0>; - power-domains = <&k3_pds 185 TI_SCI_PD_EXCLUSIVE>; - status = "disabled"; - }; - - dss: dss@30200000 { - compatible = "ti,am62a7-dss"; - reg = <0x00 0x30200000 0x00 0x1000>, /* common */ - <0x00 0x30202000 0x00 0x1000>, /* vidl1 */ - <0x00 0x30206000 0x00 0x1000>, /* vid */ - <0x00 0x30207000 0x00 0x1000>, /* ovr1 */ - <0x00 0x30208000 0x00 0x1000>, /* ovr2 */ - <0x00 0x3020a000 0x00 0x1000>, /* vp1: Tied OFF in the SoC */ - <0x00 0x3020b000 0x00 0x1000>, /* vp2: Used as DPI Out */ - <0x00 0x30201000 0x00 0x1000>; /* common1 */ - reg-names = "common", "vidl1", "vid", - "ovr1", "ovr2", "vp1", "vp2", "common1"; - power-domains = <&k3_pds 186 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 186 6>, - <&k3_clks 186 0>, - <&k3_clks 186 2>; - clock-names = "fck", "vp1", "vp2"; - interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>; - status = "disabled"; - - dss_ports: ports { - #address-cells = <1>; - #size-cells = <0>; - }; - }; -}; diff --git a/arch/arm/dts/k3-am62a-mcu.dtsi b/arch/arm/dts/k3-am62a-mcu.dtsi deleted file mode 100644 index 8c36e56f4138..000000000000 --- a/arch/arm/dts/k3-am62a-mcu.dtsi +++ /dev/null @@ -1,170 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only OR MIT -/* - * Device Tree Source for AM625 SoC Family MCU Domain peripherals - * - * Copyright (C) 2020-2024 Texas Instruments Incorporated - https://www.ti.com/ - */ - -&cbass_mcu { - mcu_pmx0: pinctrl@4084000 { - compatible = "pinctrl-single"; - reg = <0x00 0x04084000 0x00 0x88>; - #pinctrl-cells = <1>; - pinctrl-single,register-width = <32>; - pinctrl-single,function-mask = <0xffffffff>; - status = "disabled"; - }; - - /* - * The MCU domain timer interrupts are routed only to the ESM module, - * and not currently available for Linux. The MCU domain timers are - * of limited use without interrupts, and likely reserved by the ESM. - */ - mcu_timer0: timer@4800000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x4800000 0x00 0x400>; - clocks = <&k3_clks 35 2>; - clock-names = "fck"; - power-domains = <&k3_pds 35 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - status = "reserved"; - }; - - mcu_timer1: timer@4810000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x4810000 0x00 0x400>; - clocks = <&k3_clks 48 2>; - clock-names = "fck"; - power-domains = <&k3_pds 48 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - status = "reserved"; - }; - - mcu_timer2: timer@4820000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x4820000 0x00 0x400>; - clocks = <&k3_clks 49 2>; - clock-names = "fck"; - power-domains = <&k3_pds 49 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - status = "reserved"; - }; - - mcu_timer3: timer@4830000 { - compatible = "ti,am654-timer"; - reg = <0x00 0x4830000 0x00 0x400>; - clocks = <&k3_clks 50 2>; - clock-names = "fck"; - power-domains = <&k3_pds 50 TI_SCI_PD_EXCLUSIVE>; - ti,timer-pwm; - status = "reserved"; - }; - - mcu_uart0: serial@4a00000 { - compatible = "ti,am64-uart", "ti,am654-uart"; - reg = <0x00 0x04a00000 0x00 0x100>; - interrupts = <GIC_SPI 185 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&k3_pds 149 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 149 0>; - clock-names = "fclk"; - status = "disabled"; - }; - - mcu_i2c0: i2c@4900000 { - compatible = "ti,am64-i2c", "ti,omap4-i2c"; - reg = <0x00 0x04900000 0x00 0x100>; - interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 106 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 106 2>; - clock-names = "fck"; - status = "disabled"; - }; - - mcu_spi0: spi@4b00000 { - compatible = "ti,am654-mcspi", "ti,omap4-mcspi"; - reg = <0x00 0x04b00000 0x00 0x400>; - interrupts = <GIC_SPI 176 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 147 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 147 0>; - status = "disabled"; - }; - - mcu_spi1: spi@4b10000 { - compatible = "ti,am654-mcspi","ti,omap4-mcspi"; - reg = <0x00 0x04b10000 0x00 0x400>; - interrupts = <GIC_SPI 177 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 148 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 148 0>; - status = "disabled"; - }; - - mcu_gpio_intr: interrupt-controller@4210000 { - compatible = "ti,sci-intr"; - reg = <0x00 0x04210000 0x00 0x200>; - ti,intr-trigger-type = <1>; - interrupt-controller; - interrupt-parent = <&gic500>; - #interrupt-cells = <1>; - ti,sci = <&dmsc>; - ti,sci-dev-id = <5>; - ti,interrupt-ranges = <0 104 4>; - }; - - mcu_gpio0: gpio@4201000 { - compatible = "ti,am64-gpio", "ti,keystone-gpio"; - reg = <0x00 0x04201000 0x00 0x100>; - gpio-controller; - #gpio-cells = <2>; - interrupt-parent = <&mcu_gpio_intr>; - interrupts = <30>, <31>; - interrupt-controller; - #interrupt-cells = <2>; - ti,ngpio = <24>; - ti,davinci-gpio-unbanked = <0>; - power-domains = <&k3_pds 79 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 79 0>; - clock-names = "gpio"; - status = "disabled"; - }; - - mcu_rti0: watchdog@4880000 { - compatible = "ti,j7-rti-wdt"; - reg = <0x00 0x04880000 0x00 0x100>; - clocks = <&k3_clks 131 0>; - power-domains = <&k3_pds 131 TI_SCI_PD_EXCLUSIVE>; - assigned-clocks = <&k3_clks 131 0>; - assigned-clock-parents = <&k3_clks 131 2>; - /* Tightly coupled to M4F */ - status = "reserved"; - }; - - mcu_mcan0: can@4e08000 { - compatible = "bosch,m_can"; - reg = <0x00 0x4e08000 0x00 0x200>, - <0x00 0x4e00000 0x00 0x8000>; - reg-names = "m_can", "message_ram"; - power-domains = <&k3_pds 188 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 188 6>, <&k3_clks 188 1>; - clock-names = "hclk", "cclk"; - bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>; - status = "disabled"; - }; - - mcu_mcan1: can@4e18000 { - compatible = "bosch,m_can"; - reg = <0x00 0x4e18000 0x00 0x200>, - <0x00 0x4e10000 0x00 0x8000>; - reg-names = "m_can", "message_ram"; - power-domains = <&k3_pds 189 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 189 6>, <&k3_clks 189 1>; - clock-names = "hclk", "cclk"; - bosch,mram-cfg = <0x0 128 64 64 64 64 32 32>; - status = "disabled"; - }; -}; diff --git a/arch/arm/dts/k3-am62a-sk-binman.dtsi b/arch/arm/dts/k3-am62a-sk-binman.dtsi index ec3bf7ce913b..6ccc8b5834cb 100644 --- a/arch/arm/dts/k3-am62a-sk-binman.dtsi +++ b/arch/arm/dts/k3-am62a-sk-binman.dtsi @@ -144,7 +144,7 @@
#ifdef CONFIG_TARGET_AM62A7_A53_EVM
-#define SPL_AM62A7_SK_DTB "spl/dts/k3-am62a7-sk.dtb" +#define SPL_AM62A7_SK_DTB "spl/dts/ti/k3-am62a7-sk.dtb" #define AM62A7_SK_DTB "u-boot.dtb"
&binman { diff --git a/arch/arm/dts/k3-am62a-thermal.dtsi b/arch/arm/dts/k3-am62a-thermal.dtsi deleted file mode 100644 index c7486fb2a5b4..000000000000 --- a/arch/arm/dts/k3-am62a-thermal.dtsi +++ /dev/null @@ -1,50 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only OR MIT -/* - * Copyright (C) 2023-2024 Texas Instruments Incorporated - https://www.ti.com/ - */ - -#include <dt-bindings/thermal/thermal.h> - -thermal_zones: thermal-zones { - main0_thermal: main0-thermal { - polling-delay-passive = <250>; /* milliSeconds */ - polling-delay = <500>; /* milliSeconds */ - thermal-sensors = <&wkup_vtm0 0>; - - trips { - main0_crit: main0-crit { - temperature = <125000>; /* milliCelsius */ - hysteresis = <2000>; /* milliCelsius */ - type = "critical"; - }; - }; - }; - - main1_thermal: main1-thermal { - polling-delay-passive = <250>; /* milliSeconds */ - polling-delay = <500>; /* milliSeconds */ - thermal-sensors = <&wkup_vtm0 1>; - - trips { - main1_crit: main1-crit { - temperature = <125000>; /* milliCelsius */ - hysteresis = <2000>; /* milliCelsius */ - type = "critical"; - }; - }; - }; - - main2_thermal: main2-thermal { - polling-delay-passive = <250>; /* milliSeconds */ - polling-delay = <500>; /* milliSeconds */ - thermal-sensors = <&wkup_vtm0 2>; - - trips { - main2_crit: main2-crit { - temperature = <125000>; /* milliCelsius */ - hysteresis = <2000>; /* milliCelsius */ - type = "critical"; - }; - }; - }; -}; diff --git a/arch/arm/dts/k3-am62a-wakeup.dtsi b/arch/arm/dts/k3-am62a-wakeup.dtsi deleted file mode 100644 index f7bec484705a..000000000000 --- a/arch/arm/dts/k3-am62a-wakeup.dtsi +++ /dev/null @@ -1,73 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only OR MIT -/* - * Device Tree Source for AM62A SoC Family Wakeup Domain peripherals - * - * Copyright (C) 2022-2024 Texas Instruments Incorporated - https://www.ti.com/ - */ - -&cbass_wakeup { - wkup_conf: syscon@43000000 { - compatible = "ti,j721e-system-controller", "syscon", "simple-mfd"; - reg = <0x00 0x43000000 0x00 0x20000>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0x00 0x00 0x43000000 0x20000>; - - chipid: chipid@14 { - compatible = "ti,am654-chipid"; - reg = <0x14 0x4>; - }; - }; - - wkup_uart0: serial@2b300000 { - compatible = "ti,am64-uart", "ti,am654-uart"; - reg = <0x00 0x2b300000 0x00 0x100>; - interrupts = <GIC_SPI 186 IRQ_TYPE_LEVEL_HIGH>; - power-domains = <&k3_pds 114 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 114 0>; - clock-names = "fclk"; - status = "disabled"; - }; - - wkup_i2c0: i2c@2b200000 { - compatible = "ti,am64-i2c", "ti,omap4-i2c"; - reg = <0x00 0x2b200000 0x00 0x100>; - interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - power-domains = <&k3_pds 107 TI_SCI_PD_EXCLUSIVE>; - clocks = <&k3_clks 107 4>; - clock-names = "fck"; - status = "disabled"; - }; - - wkup_rtc0: rtc@2b1f0000 { - compatible = "ti,am62-rtc"; - reg = <0x00 0x2b1f0000 0x00 0x100>; - interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&k3_clks 117 6> , <&k3_clks 117 0>; - clock-names = "vbus", "osc32k"; - power-domains = <&k3_pds 117 TI_SCI_PD_EXCLUSIVE>; - wakeup-source; - status = "disabled"; - }; - - wkup_rti0: watchdog@2b000000 { - compatible = "ti,j7-rti-wdt"; - reg = <0x00 0x2b000000 0x00 0x100>; - clocks = <&k3_clks 132 0>; - power-domains = <&k3_pds 132 TI_SCI_PD_EXCLUSIVE>; - assigned-clocks = <&k3_clks 132 0>; - assigned-clock-parents = <&k3_clks 132 2>; - /* Used by DM firmware */ - status = "reserved"; - }; - - wkup_vtm0: temperature-sensor@b00000 { - compatible = "ti,j7200-vtm"; - reg = <0x00 0xb00000 0x00 0x400>, - <0x00 0xb01000 0x00 0x400>; - power-domains = <&k3_pds 95 TI_SCI_PD_EXCLUSIVE>; - #thermal-sensor-cells = <1>; - }; -}; diff --git a/arch/arm/dts/k3-am62a.dtsi b/arch/arm/dts/k3-am62a.dtsi deleted file mode 100644 index b1b884600293..000000000000 --- a/arch/arm/dts/k3-am62a.dtsi +++ /dev/null @@ -1,125 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only OR MIT -/* - * Device Tree Source for AM62A SoC Family - * - * Copyright (C) 2022-2024 Texas Instruments Incorporated - https://www.ti.com/ - */ - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/soc/ti,sci_pm_domain.h> - -#include "k3-pinctrl.h" - -/ { - model = "Texas Instruments K3 AM62A SoC"; - compatible = "ti,am62a7"; - interrupt-parent = <&gic500>; - #address-cells = <2>; - #size-cells = <2>; - - chosen { }; - - firmware { - optee { - compatible = "linaro,optee-tz"; - method = "smc"; - }; - - psci: psci { - compatible = "arm,psci-1.0"; - method = "smc"; - }; - }; - - a53_timer0: timer-cl0-cpu0 { - compatible = "arm,armv8-timer"; - interrupts = <GIC_PPI 13 IRQ_TYPE_LEVEL_LOW>, /* cntpsirq */ - <GIC_PPI 14 IRQ_TYPE_LEVEL_LOW>, /* cntpnsirq */ - <GIC_PPI 11 IRQ_TYPE_LEVEL_LOW>, /* cntvirq */ - <GIC_PPI 10 IRQ_TYPE_LEVEL_LOW>; /* cnthpirq */ - }; - - pmu: pmu { - compatible = "arm,cortex-a53-pmu"; - interrupts = <GIC_PPI 7 IRQ_TYPE_LEVEL_HIGH>; - }; - - cbass_main: bus@f0000 { - compatible = "simple-bus"; - #address-cells = <2>; - #size-cells = <2>; - - ranges = <0x00 0x000f0000 0x00 0x000f0000 0x00 0x00030000>, /* Main MMRs */ - <0x00 0x00420000 0x00 0x00420000 0x00 0x00001000>, /* ESM0 */ - <0x00 0x00600000 0x00 0x00600000 0x00 0x00001100>, /* GPIO */ - <0x00 0x00703000 0x00 0x00703000 0x00 0x00000200>, /* USB0 debug trace */ - <0x00 0x0070c000 0x00 0x0070c000 0x00 0x00000200>, /* USB1 debug trace */ - <0x00 0x00a40000 0x00 0x00a40000 0x00 0x00000800>, /* Timesync router */ - <0x00 0x01000000 0x00 0x01000000 0x00 0x01b28400>, /* First peripheral window */ - <0x00 0x08000000 0x00 0x08000000 0x00 0x00200000>, /* Main CPSW */ - <0x00 0x0e000000 0x00 0x0e000000 0x00 0x01d20000>, /* Second peripheral window */ - <0x00 0x0fd00000 0x00 0x0fd00000 0x00 0x00020000>, /* GPU */ - <0x00 0x20000000 0x00 0x20000000 0x00 0x0a008000>, /* Third peripheral window */ - <0x00 0x30040000 0x00 0x30040000 0x00 0x00080000>, /* PRUSS-M */ - <0x00 0x30101000 0x00 0x30101000 0x00 0x00010100>, /* CSI window */ - <0x00 0x30200000 0x00 0x30200000 0x00 0x00010000>, /* DSS */ - <0x00 0x30210000 0x00 0x30210000 0x00 0x00010000>, /* VPU */ - <0x00 0x31000000 0x00 0x31000000 0x00 0x00050000>, /* USB0 DWC3 Core window */ - <0x00 0x31100000 0x00 0x31100000 0x00 0x00050000>, /* USB1 DWC3 Core window */ - <0x00 0x40900000 0x00 0x40900000 0x00 0x00030000>, /* SA3UL */ - <0x00 0x43600000 0x00 0x43600000 0x00 0x00010000>, /* SA3 sproxy data */ - <0x00 0x44043000 0x00 0x44043000 0x00 0x00000fe0>, /* TI SCI DEBUG */ - <0x00 0x44860000 0x00 0x44860000 0x00 0x00040000>, /* SA3 sproxy config */ - <0x00 0x48000000 0x00 0x48000000 0x00 0x06400000>, /* DMSS */ - <0x00 0x60000000 0x00 0x60000000 0x00 0x08000000>, /* FSS0 DAT1 */ - <0x00 0x70000000 0x00 0x70000000 0x00 0x00010000>, /* OCSRAM */ - <0x00 0x7e000000 0x00 0x7e000000 0x00 0x00100000>, /* C7x_0 */ - <0x01 0x00000000 0x01 0x00000000 0x00 0x00310000>, /* A53 PERIPHBASE */ - <0x05 0x00000000 0x05 0x00000000 0x01 0x00000000>, /* FSS0 DAT3 */ - - /* MCU Domain Range */ - <0x00 0x04000000 0x00 0x04000000 0x00 0x01ff1400>, - <0x00 0x79000000 0x00 0x79000000 0x00 0x00008000>, /* MCU R5 ATCM */ - <0x00 0x79020000 0x00 0x79020000 0x00 0x00008000>, /* MCU R5 BTCM */ - <0x00 0x79100000 0x00 0x79100000 0x00 0x00040000>, /* MCU R5 IRAM0 */ - <0x00 0x79140000 0x00 0x79140000 0x00 0x00040000>, /* MCU R5 IRAM1 */ - - /* Wakeup Domain Range */ - <0x00 0x00b00000 0x00 0x00b00000 0x00 0x00002400>, - <0x00 0x2b000000 0x00 0x2b000000 0x00 0x00300400>, - <0x00 0x43000000 0x00 0x43000000 0x00 0x00020000>, - <0x00 0x78000000 0x00 0x78000000 0x00 0x00008000>, /* DM R5 ATCM */ - <0x00 0x78100000 0x00 0x78100000 0x00 0x00008000>; /* DM R5 BTCM */ - - cbass_mcu: bus@4000000 { - compatible = "simple-bus"; - #address-cells = <2>; - #size-cells = <2>; - ranges = <0x00 0x04000000 0x00 0x04000000 0x00 0x01ff1400>, /* Peripheral window */ - <0x00 0x79000000 0x00 0x79000000 0x00 0x00008000>, /* MCU R5 ATCM */ - <0x00 0x79020000 0x00 0x79020000 0x00 0x00008000>, /* MCU R5 BTCM */ - <0x00 0x79100000 0x00 0x79100000 0x00 0x00040000>, /* MCU IRAM0 */ - <0x00 0x79140000 0x00 0x79140000 0x00 0x00040000>; /* MCU IRAM1 */ - }; - - cbass_wakeup: bus@b00000 { - compatible = "simple-bus"; - #address-cells = <2>; - #size-cells = <2>; - ranges = <0x00 0x00b00000 0x00 0x00b00000 0x00 0x00002400>, /* VTM */ - <0x00 0x2b000000 0x00 0x2b000000 0x00 0x00300400>, /* Peripheral Window */ - <0x00 0x43000000 0x00 0x43000000 0x00 0x00020000>, /* WKUP CTRL MMR */ - <0x00 0x78000000 0x00 0x78000000 0x00 0x00008000>, /* DM R5 ATCM*/ - <0x00 0x78100000 0x00 0x78100000 0x00 0x00008000>; /* DM R5 BTCM*/ - }; - }; - - #include "k3-am62a-thermal.dtsi" -}; - -/* Now include the peripherals for each bus segments */ -#include "k3-am62a-main.dtsi" -#include "k3-am62a-mcu.dtsi" -#include "k3-am62a-wakeup.dtsi" diff --git a/arch/arm/dts/k3-am62a7-sk.dts b/arch/arm/dts/k3-am62a7-sk.dts deleted file mode 100644 index f241637a5642..000000000000 --- a/arch/arm/dts/k3-am62a7-sk.dts +++ /dev/null @@ -1,702 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only OR MIT -/* - * AM62A SK: https://www.ti.com/lit/zip/sprr459 - * - * Copyright (C) 2022-2024 Texas Instruments Incorporated - https://www.ti.com/ - */ - -/dts-v1/; - -#include <dt-bindings/leds/common.h> -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/net/ti-dp83867.h> -#include "k3-am62a7.dtsi" - -/ { - compatible = "ti,am62a7-sk", "ti,am62a7"; - model = "Texas Instruments AM62A7 SK"; - - aliases { - serial0 = &wkup_uart0; - serial2 = &main_uart0; - serial3 = &main_uart1; - mmc0 = &sdhci0; - mmc1 = &sdhci1; - }; - - chosen { - stdout-path = "serial2:115200n8"; - }; - - memory@80000000 { - device_type = "memory"; - /* 4G RAM */ - reg = <0x00000000 0x80000000 0x00000000 0x80000000>, - <0x00000008 0x80000000 0x00000000 0x80000000>; - }; - - reserved-memory { - #address-cells = <2>; - #size-cells = <2>; - ranges; - - secure_tfa_ddr: tfa@9e780000 { - reg = <0x00 0x9e780000 0x00 0x80000>; - alignment = <0x1000>; - no-map; - }; - - secure_ddr: optee@9e800000 { - reg = <0x00 0x9e800000 0x00 0x01800000>; /* for OP-TEE */ - alignment = <0x1000>; - no-map; - }; - - wkup_r5fss0_core0_memory_region: r5f-dma-memory@9c900000 { - compatible = "shared-dma-pool"; - reg = <0x00 0x9c900000 0x00 0x01e00000>; - no-map; - }; - }; - - vmain_pd: regulator-0 { - /* TPS25750 PD CONTROLLER OUTPUT */ - compatible = "regulator-fixed"; - regulator-name = "vmain_pd"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - regulator-boot-on; - }; - - vcc_5v0: regulator-1 { - /* Output of TPS63070 */ - compatible = "regulator-fixed"; - regulator-name = "vcc_5v0"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vmain_pd>; - regulator-always-on; - regulator-boot-on; - }; - - vcc_3v3_main: regulator-2 { - /* output of LM5141-Q1 */ - compatible = "regulator-fixed"; - regulator-name = "vcc_3v3_main"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vmain_pd>; - regulator-always-on; - regulator-boot-on; - }; - - vdd_mmc1: regulator-3 { - /* TPS22918DBVR */ - compatible = "regulator-fixed"; - regulator-name = "vdd_mmc1"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - enable-active-high; - gpio = <&exp1 3 GPIO_ACTIVE_HIGH>; - }; - - vcc_3v3_sys: regulator-4 { - /* output of TPS222965DSGT */ - compatible = "regulator-fixed"; - regulator-name = "vcc_3v3_sys"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc_3v3_main>; - regulator-always-on; - regulator-boot-on; - }; - - leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&usr_led_pins_default>; - - led-0 { - label = "am62a-sk:green:heartbeat"; - gpios = <&main_gpio1 49 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "heartbeat"; - function = LED_FUNCTION_HEARTBEAT; - default-state = "off"; - }; - }; - - tlv320_mclk: clk-0 { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <12288000>; - }; - - hdmi0: connector-hdmi { - compatible = "hdmi-connector"; - label = "hdmi"; - type = "a"; - - port { - hdmi_connector_in: endpoint { - remote-endpoint = <&sii9022_out>; - }; - }; - }; - - codec_audio: sound { - compatible = "simple-audio-card"; - simple-audio-card,name = "AM62Ax-SKEVM"; - simple-audio-card,widgets = - "Headphone", "Headphone Jack", - "Line", "Line In", - "Microphone", "Microphone Jack"; - simple-audio-card,routing = - "Headphone Jack", "HPLOUT", - "Headphone Jack", "HPROUT", - "LINE1L", "Line In", - "LINE1R", "Line In", - "MIC3R", "Microphone Jack", - "Microphone Jack", "Mic Bias"; - simple-audio-card,format = "dsp_b"; - simple-audio-card,bitclock-master = <&sound_master>; - simple-audio-card,frame-master = <&sound_master>; - simple-audio-card,bitclock-inversion; - - simple-audio-card,cpu { - sound-dai = <&mcasp1>; - }; - - sound_master: simple-audio-card,codec { - sound-dai = <&tlv320aic3106>; - clocks = <&tlv320_mclk>; - }; - }; -}; - -&mcu_pmx0 { - wkup_uart0_pins_default: wkup-uart0-default-pins { - pinctrl-single,pins = < - AM62AX_MCU_IOPAD(0x0024, PIN_INPUT, 0) /* (C9) WKUP_UART0_RXD */ - AM62AX_MCU_IOPAD(0x0028, PIN_OUTPUT, 0) /* (E9) WKUP_UART0_TXD */ - AM62AX_MCU_IOPAD(0x002c, PIN_INPUT, 0) /* (C10) WKUP_UART0_CTSn */ - AM62AX_MCU_IOPAD(0x0030, PIN_OUTPUT, 0) /* (C8) WKUP_UART0_RTSn */ - >; - }; -}; - -/* WKUP UART0 is used for DM firmware logs */ -&wkup_uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&wkup_uart0_pins_default>; - status = "reserved"; -}; - -&main_pmx0 { - main_dss0_pins_default: main-dss0-default-pins { - pinctrl-single,pins = < - AM62AX_IOPAD(0x100, PIN_OUTPUT, 0) /* (V17) VOUT0_VSYNC */ - AM62AX_IOPAD(0x0f8, PIN_OUTPUT, 0) /* (T18) VOUT0_HSYNC */ - AM62AX_IOPAD(0x104, PIN_OUTPUT, 0) /* (AA22) VOUT0_PCLK */ - AM62AX_IOPAD(0x0fc, PIN_OUTPUT, 0) /* (U17) VOUT0_DE */ - AM62AX_IOPAD(0x0b8, PIN_OUTPUT, 0) /* (U22) VOUT0_DATA0 */ - AM62AX_IOPAD(0x0bc, PIN_OUTPUT, 0) /* (U21) VOUT0_DATA1 */ - AM62AX_IOPAD(0x0c0, PIN_OUTPUT, 0) /* (U20) VOUT0_DATA2 */ - AM62AX_IOPAD(0x0c4, PIN_OUTPUT, 0) /* (U19) VOUT0_DATA3 */ - AM62AX_IOPAD(0x0c8, PIN_OUTPUT, 0) /* (T19) VOUT0_DATA4 */ - AM62AX_IOPAD(0x0cc, PIN_OUTPUT, 0) /* (U18) VOUT0_DATA5 */ - AM62AX_IOPAD(0x0d0, PIN_OUTPUT, 0) /* (V22) VOUT0_DATA6 */ - AM62AX_IOPAD(0x0d4, PIN_OUTPUT, 0) /* (V21) VOUT0_DATA7 */ - AM62AX_IOPAD(0x0d8, PIN_OUTPUT, 0) /* (V19) VOUT0_DATA8 */ - AM62AX_IOPAD(0x0dc, PIN_OUTPUT, 0) /* (V18) VOUT0_DATA9 */ - AM62AX_IOPAD(0x0e0, PIN_OUTPUT, 0) /* (W22) VOUT0_DATA10 */ - AM62AX_IOPAD(0x0e4, PIN_OUTPUT, 0) /* (W21) VOUT0_DATA11 */ - AM62AX_IOPAD(0x0e8, PIN_OUTPUT, 0) /* (W20) VOUT0_DATA12 */ - AM62AX_IOPAD(0x0ec, PIN_OUTPUT, 0) /* (W19) VOUT0_DATA13 */ - AM62AX_IOPAD(0x0f0, PIN_OUTPUT, 0) /* (Y21) VOUT0_DATA14 */ - AM62AX_IOPAD(0x0f4, PIN_OUTPUT, 0) /* (Y22) VOUT0_DATA15 */ - AM62AX_IOPAD(0x05c, PIN_OUTPUT, 1) /* (P22) GPMC0_AD8.VOUT0_DATA16 */ - AM62AX_IOPAD(0x060, PIN_OUTPUT, 1) /* (R19) GPMC0_AD9.VOUT0_DATA17 */ - AM62AX_IOPAD(0x064, PIN_OUTPUT, 1) /* (R20) GPMC0_AD10.VOUT0_DATA18 */ - AM62AX_IOPAD(0x068, PIN_OUTPUT, 1) /* (R22) GPMC0_AD11.VOUT0_DATA19 */ - AM62AX_IOPAD(0x06c, PIN_OUTPUT, 1) /* (T22) GPMC0_AD12.VOUT0_DATA20 */ - AM62AX_IOPAD(0x070, PIN_OUTPUT, 1) /* (R21) GPMC0_AD13.VOUT0_DATA21 */ - AM62AX_IOPAD(0x074, PIN_OUTPUT, 1) /* (T20) GPMC0_AD14.VOUT0_DATA22 */ - AM62AX_IOPAD(0x078, PIN_OUTPUT, 1) /* (T21) GPMC0_AD15.VOUT0_DATA23 */ - >; - }; - - main_uart0_pins_default: main-uart0-default-pins { - pinctrl-single,pins = < - AM62AX_IOPAD(0x1c8, PIN_INPUT, 0) /* (E14) UART0_RXD */ - AM62AX_IOPAD(0x1cc, PIN_OUTPUT, 0) /* (D15) UART0_TXD */ - >; - }; - - main_uart1_pins_default: main-uart1-default-pins { - pinctrl-single,pins = < - AM62AX_IOPAD(0x01e8, PIN_INPUT, 1) /* (C17) I2C1_SCL.UART1_RXD */ - AM62AX_IOPAD(0x01ec, PIN_OUTPUT, 1) /* (E17) I2C1_SDA.UART1_TXD */ - AM62AX_IOPAD(0x0194, PIN_INPUT, 2) /* (C19) MCASP0_AXR3.UART1_CTSn */ - AM62AX_IOPAD(0x0198, PIN_OUTPUT, 2) /* (B19) MCASP0_AXR2.UART1_RTSn */ - >; - }; - - main_i2c0_pins_default: main-i2c0-default-pins { - pinctrl-single,pins = < - AM62AX_IOPAD(0x1e0, PIN_INPUT_PULLUP, 0) /* (B16) I2C0_SCL */ - AM62AX_IOPAD(0x1e4, PIN_INPUT_PULLUP, 0) /* (A16) I2C0_SDA */ - >; - }; - - main_i2c1_pins_default: main-i2c1-default-pins { - pinctrl-single,pins = < - AM62AX_IOPAD(0x1e8, PIN_INPUT_PULLUP, 0) /* (B17) I2C1_SCL */ - AM62AX_IOPAD(0x1ec, PIN_INPUT_PULLUP, 0) /* (A17) I2C1_SDA */ - >; - }; - - main_i2c2_pins_default: main-i2c2-default-pins { - pinctrl-single,pins = < - AM62AX_IOPAD(0x0b0, PIN_INPUT_PULLUP, 1) /* (K22) GPMC0_CSn2.I2C2_SCL */ - AM62AX_IOPAD(0x0b4, PIN_INPUT_PULLUP, 1) /* (K24) GPMC0_CSn3.I2C2_SDA */ - >; - }; - - main_mmc0_pins_default: main-mmc0-default-pins { - pinctrl-single,pins = < - AM62AX_IOPAD(0x220, PIN_INPUT, 0) /* (Y3) MMC0_CMD */ - AM62AX_IOPAD(0x218, PIN_INPUT, 0) /* (AB1) MMC0_CLKLB */ - AM62AX_IOPAD(0x21c, PIN_INPUT, 0) /* (AB1) MMC0_CLK */ - AM62AX_IOPAD(0x214, PIN_INPUT, 0) /* (AA2) MMC0_DAT0 */ - AM62AX_IOPAD(0x210, PIN_INPUT_PULLUP, 0) /* (AA1) MMC0_DAT1 */ - AM62AX_IOPAD(0x20c, PIN_INPUT_PULLUP, 0) /* (AA3) MMC0_DAT2 */ - AM62AX_IOPAD(0x208, PIN_INPUT_PULLUP, 0) /* (Y4) MMC0_DAT3 */ - AM62AX_IOPAD(0x204, PIN_INPUT_PULLUP, 0) /* (AB2) MMC0_DAT4 */ - AM62AX_IOPAD(0x200, PIN_INPUT_PULLUP, 0) /* (AC1) MMC0_DAT5 */ - AM62AX_IOPAD(0x1fc, PIN_INPUT_PULLUP, 0) /* (AD2) MMC0_DAT6 */ - AM62AX_IOPAD(0x1f8, PIN_INPUT_PULLUP, 0) /* (AC2) MMC0_DAT7 */ - >; - }; - - main_mmc1_pins_default: main-mmc1-default-pins { - pinctrl-single,pins = < - AM62AX_IOPAD(0x23c, PIN_INPUT, 0) /* (A21) MMC1_CMD */ - AM62AX_IOPAD(0x234, PIN_INPUT, 0) /* (B22) MMC1_CLK */ - AM62AX_IOPAD(0x230, PIN_INPUT, 0) /* (A22) MMC1_DAT0 */ - AM62AX_IOPAD(0x22c, PIN_INPUT, 0) /* (B21) MMC1_DAT1 */ - AM62AX_IOPAD(0x228, PIN_INPUT, 0) /* (C21) MMC1_DAT2 */ - AM62AX_IOPAD(0x224, PIN_INPUT, 0) /* (D22) MMC1_DAT3 */ - AM62AX_IOPAD(0x240, PIN_INPUT, 0) /* (D17) MMC1_SDCD */ - >; - }; - - usr_led_pins_default: usr-led-default-pins { - pinctrl-single,pins = < - AM62AX_IOPAD(0x244, PIN_OUTPUT, 7) /* (D18) MMC1_SDWP.GPIO1_49 */ - >; - }; - - main_usb1_pins_default: main-usb1-default-pins { - pinctrl-single,pins = < - AM62AX_IOPAD(0x0258, PIN_OUTPUT, 0) /* (F18) USB1_DRVVBUS */ - >; - }; - - main_mdio1_pins_default: main-mdio1-default-pins { - pinctrl-single,pins = < - AM62AX_IOPAD(0x160, PIN_OUTPUT, 0) /* (V12) MDIO0_MDC */ - AM62AX_IOPAD(0x15c, PIN_INPUT, 0) /* (V13) MDIO0_MDIO */ - >; - }; - - main_rgmii1_pins_default: main-rgmii1-default-pins { - pinctrl-single,pins = < - AM62AX_IOPAD(0x14c, PIN_INPUT, 0) /* (AB16) RGMII1_RD0 */ - AM62AX_IOPAD(0x150, PIN_INPUT, 0) /* (V15) RGMII1_RD1 */ - AM62AX_IOPAD(0x154, PIN_INPUT, 0) /* (W15) RGMII1_RD2 */ - AM62AX_IOPAD(0x158, PIN_INPUT, 0) /* (V14) RGMII1_RD3 */ - AM62AX_IOPAD(0x148, PIN_INPUT, 0) /* (AA16) RGMII1_RXC */ - AM62AX_IOPAD(0x144, PIN_INPUT, 0) /* (AA15) RGMII1_RX_CTL */ - AM62AX_IOPAD(0x134, PIN_INPUT, 0) /* (Y17) RGMII1_TD0 */ - AM62AX_IOPAD(0x138, PIN_INPUT, 0) /* (V16) RGMII1_TD1 */ - AM62AX_IOPAD(0x13c, PIN_INPUT, 0) /* (Y16) RGMII1_TD2 */ - AM62AX_IOPAD(0x140, PIN_INPUT, 0) /* (AA17) RGMII1_TD3 */ - AM62AX_IOPAD(0x130, PIN_INPUT, 0) /* (AB17) RGMII1_TXC */ - AM62AX_IOPAD(0x12c, PIN_INPUT, 0) /* (W16) RGMII1_TX_CTL */ - >; - }; - - main_mcasp1_pins_default: main-mcasp1-default-pins { - pinctrl-single,pins = < - AM62AX_IOPAD(0x090, PIN_INPUT, 2) /* (L19) GPMC0_BE0n_CLE.MCASP1_ACLKX */ - AM62AX_IOPAD(0x098, PIN_INPUT, 2) /* (R18) GPMC0_WAIT0.MCASP1_AFSX */ - AM62AX_IOPAD(0x08c, PIN_OUTPUT, 2) /* (K19) GPMC0_WEn.MCASP1_AXR0 */ - AM62AX_IOPAD(0x084, PIN_INPUT, 2) /* (L18) GPMC0_ADVn_ALE.MCASP1_AXR2 */ - >; - }; - - main_gpio1_ioexp_intr_pins_default: main-gpio1-ioexp-intr-default-pins { - pinctrl-single,pins = < - AM62AX_IOPAD(0x01d4, PIN_INPUT, 7) /* (C15) UART0_RTSn.GPIO1_23 */ - >; - }; -}; - -&mcu_pmx0 { - status = "okay"; - - pmic_irq_pins_default: pmic-irq-default-pins { - pinctrl-single,pins = < - AM62AX_MCU_IOPAD(0x000, PIN_INPUT, 7) /* (E11) MCU_GPIO0_0 */ - >; - }; -}; - -&mcu_gpio0 { - status = "okay"; -}; - -&main_i2c0 { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&main_i2c0_pins_default>; - clock-frequency = <400000>; - - typec_pd0: usb-power-controller@3f { - compatible = "ti,tps6598x"; - reg = <0x3f>; - - connector { - compatible = "usb-c-connector"; - label = "USB-C"; - self-powered; - data-role = "dual"; - power-role = "sink"; - port { - usb_con_hs: endpoint { - remote-endpoint = <&usb0_hs_ep>; - }; - }; - }; - }; - - tps659312: pmic@48 { - compatible = "ti,tps6593-q1"; - reg = <0x48>; - ti,primary-pmic; - system-power-controller; - - gpio-controller; - #gpio-cells = <2>; - - pinctrl-names = "default"; - pinctrl-0 = <&pmic_irq_pins_default>; - interrupt-parent = <&mcu_gpio0>; - interrupts = <0 IRQ_TYPE_EDGE_FALLING>; - - buck123-supply = <&vcc_3v3_sys>; - buck4-supply = <&vcc_3v3_sys>; - buck5-supply = <&vcc_3v3_sys>; - ldo1-supply = <&vcc_3v3_sys>; - ldo2-supply = <&vcc_3v3_sys>; - ldo3-supply = <&buck5>; - ldo4-supply = <&vcc_3v3_sys>; - - regulators { - buck123: buck123 { - regulator-name = "vcc_core"; - regulator-min-microvolt = <715000>; - regulator-max-microvolt = <895000>; - regulator-boot-on; - regulator-always-on; - }; - - buck4: buck4 { - regulator-name = "vcc_1v1"; - regulator-min-microvolt = <1100000>; - regulator-max-microvolt = <1100000>; - regulator-boot-on; - regulator-always-on; - }; - - buck5: buck5 { - regulator-name = "vcc_1v8_sys"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo1: ldo1 { - regulator-name = "vddshv5_sdio"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo2: ldo2 { - regulator-name = "vpp_1v8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo3: ldo3 { - regulator-name = "vcc_0v85"; - regulator-min-microvolt = <850000>; - regulator-max-microvolt = <850000>; - regulator-boot-on; - regulator-always-on; - }; - - ldo4: ldo4 { - regulator-name = "vdda_1v8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-boot-on; - regulator-always-on; - }; - }; - }; -}; - -&main_i2c1 { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&main_i2c1_pins_default>; - clock-frequency = <100000>; - - exp1: gpio@22 { - compatible = "ti,tca6424"; - reg = <0x22>; - gpio-controller; - #gpio-cells = <2>; - interrupt-parent = <&main_gpio1>; - interrupts = <23 IRQ_TYPE_EDGE_FALLING>; - interrupt-controller; - #interrupt-cells = <2>; - pinctrl-names = "default"; - pinctrl-0 = <&main_gpio1_ioexp_intr_pins_default>; - - gpio-line-names = "GPIO_CPSW2_RST", "GPIO_CPSW1_RST", - "BT_EN_SOC", "MMC1_SD_EN", - "VPP_EN", "EXP_PS_3V3_En", - "EXP_PS_5V0_En", "EXP_HAT_DETECT", - "GPIO_AUD_RSTn", "GPIO_eMMC_RSTn", - "UART1_FET_BUF_EN", "BT_UART_WAKE_SOC", - "GPIO_HDMI_RSTn", "CSI_GPIO0", - "CSI_GPIO1", "WLAN_ALERTn", - "HDMI_INTn", "TEST_GPIO2", - "MCASP1_FET_EN", "MCASP1_BUF_BT_EN", - "MCASP1_FET_SEL", "UART1_FET_SEL", - "PD_I2C_IRQ", "IO_EXP_TEST_LED"; - }; - - tlv320aic3106: audio-codec@1b { - #sound-dai-cells = <0>; - compatible = "ti,tlv320aic3106"; - reg = <0x1b>; - ai3x-micbias-vg = <1>; /* 2.0V */ - - /* Regulators */ - AVDD-supply = <&vcc_3v3_sys>; - IOVDD-supply = <&vcc_3v3_sys>; - DRVDD-supply = <&vcc_3v3_sys>; - DVDD-supply = <&buck5>; - }; - - exp2: gpio@23 { - compatible = "ti,tca6424"; - reg = <0x23>; - gpio-controller; - #gpio-cells = <2>; - - gpio-line-names = "", "", - "", "", - "", "", - "", "", - "WL_LT_EN", "CSI_RSTz", - "", "", - "", "", - "", "", - "SPI0_FET_SEL", "SPI0_FET_OE", - "RGMII2_BRD_CONN_DET", "CSI_SEL2", - "CSI_EN", "AUTO_100M_1000M_CONFIG", - "CSI_VLDO_SEL", "SoC_WLAN_SDIO_RST"; - }; - - sii9022: bridge-hdmi@3b { - compatible = "sil,sii9022"; - reg = <0x3b>; - interrupt-parent = <&exp1>; - interrupts = <16 IRQ_TYPE_EDGE_FALLING>; - #sound-dai-cells = <0>; - sil,i2s-data-lanes = < 0 >; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - - sii9022_in: endpoint { - remote-endpoint = <&dpi1_out>; - }; - }; - - port@1 { - reg = <1>; - - sii9022_out: endpoint { - remote-endpoint = <&hdmi_connector_in>; - }; - }; - }; - }; -}; - -&main_i2c2 { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&main_i2c2_pins_default>; - clock-frequency = <400000>; -}; - -&sdhci0 { - /* eMMC */ - status = "okay"; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&main_mmc0_pins_default>; - disable-wp; -}; - -&sdhci1 { - /* SD/MMC */ - status = "okay"; - vmmc-supply = <&vdd_mmc1>; - pinctrl-names = "default"; - pinctrl-0 = <&main_mmc1_pins_default>; - disable-wp; -}; - -&main_gpio0 { - status = "okay"; -}; - -&main_gpio1 { - status = "okay"; -}; - -&main_gpio_intr { - status = "okay"; -}; - -&main_uart0 { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&main_uart0_pins_default>; -}; - -/* Main UART1 is used for TIFS firmware logs */ -&main_uart1 { - pinctrl-names = "default"; - pinctrl-0 = <&main_uart1_pins_default>; - status = "reserved"; -}; - -&usbss0 { - status = "okay"; - ti,vbus-divider; -}; - -&usb0 { - usb-role-switch; - - port { - usb0_hs_ep: endpoint { - remote-endpoint = <&usb_con_hs>; - }; - }; -}; - -&usbss1 { - status = "okay"; -}; - -&usb1 { - dr_mode = "host"; - pinctrl-names = "default"; - pinctrl-0 = <&main_usb1_pins_default>; -}; - -&cpsw3g { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&main_rgmii1_pins_default>; -}; - -&cpsw_port1 { - status = "okay"; - phy-mode = "rgmii-rxid"; - phy-handle = <&cpsw3g_phy0>; -}; - -&cpsw_port2 { - status = "disabled"; -}; - -&cpsw3g_mdio { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&main_mdio1_pins_default>; - - cpsw3g_phy0: ethernet-phy@0 { - reg = <0>; - ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; - ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; - ti,min-output-impedance; - }; -}; - -&mcasp1 { - status = "okay"; - #sound-dai-cells = <0>; - - pinctrl-names = "default"; - pinctrl-0 = <&main_mcasp1_pins_default>; - - op-mode = <0>; /* MCASP_IIS_MODE */ - tdm-slots = <2>; - - serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */ - 1 0 2 0 - 0 0 0 0 - 0 0 0 0 - 0 0 0 0 - >; - tx-num-evt = <32>; - rx-num-evt = <32>; -}; - -&dss { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&main_dss0_pins_default>; -}; - -&dss_ports { - /* VP2: DPI Output */ - port@1 { - reg = <1>; - - dpi1_out: endpoint { - remote-endpoint = <&sii9022_in>; - }; - }; -}; diff --git a/configs/am62ax_evm_a53_defconfig b/configs/am62ax_evm_a53_defconfig index 6b29a4b9cff5..2a71b06310f1 100644 --- a/configs/am62ax_evm_a53_defconfig +++ b/configs/am62ax_evm_a53_defconfig @@ -8,7 +8,7 @@ CONFIG_SOC_K3_AM62A7=y CONFIG_TARGET_AM62A7_A53_EVM=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x80480000 -CONFIG_DEFAULT_DEVICE_TREE="k3-am62a7-sk" +CONFIG_DEFAULT_DEVICE_TREE="ti/k3-am62a7-sk" CONFIG_SPL_TEXT_BASE=0x80080000 CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y @@ -39,6 +39,7 @@ CONFIG_SPL_YMODEM_SUPPORT=y CONFIG_CMD_MMC=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_UPSTREAM=y CONFIG_MULTI_DTB_FIT=y CONFIG_SPL_MULTI_DTB_FIT=y CONFIG_SPL_MULTI_DTB_FIT_NO_COMPRESSION=y
On Jun 05, 2024 at 10:27:49 -0500, Nishanth Menon wrote:
Cleanup am625 on by switching over the last two platforms (SK and beagleplay) over to OF_UPSTREAM, and while at it, switch over am62a7 (last of the am62* family) over as well.
Thanks for the cleanup.
This superscedes the previous version of beagleplay only patch[1]
Test logs: https://gist.github.com/nmenon/ba310d3750a80789aca6a4fd90190135
Nishanth Menon (3): arm: dts: am625_beagleplay: Switch to OF_UPSTREAM arm: dts: am625_sk: Switch to OF_UPSTREAM arm: dts: am62a7_sk: Switch to OF_UPSTREAM
For the series, Reviewed-by: Dhruva Gole d-gole@ti.com
On June 5, 2024 thus sayeth Nishanth Menon:
Looks great to me
Reviewed-by: Bryan Brattlof bb@ti.com
~Bryan
participants (5)
Bryan Brattlof
Dhruva Gole
Mattijs Korpershoek
Nishanth Menon
