[U-Boot] Problem with v2018-09-rc2 to boot EFI on Arndale board
While trying to boot Grub2/EFI on Arndale board, I got the following error: ********************************************************************** fdt_fixup_memory_banks: num banks 8 exceeds hardcoded limit 4. Recompile with higher MEMORY_BANKS_MAX? ERROR: arch-specific fdt fixup failed - must RESET the board to recover.
ERROR: failed to process device tree ERROR: failed to install device tree 812544 bytes read in 77 ms (10.1 MiB/s) fdt_fixup_memory_banks: num banks 8 exceeds hardcoded limit 4. Recompile with higher MEMORY_BANKS_MAX? ERROR: arch-specific fdt fixup failed - must RESET the board to recover.
ERROR: failed to process device tree ERROR: failed to install device tree EFI LOAD FAILED: continuing... **********************************************************************
If I set MEMORY_BANKS_MAX to 8 in common/fdt_support.c , then it boots fine. Is there any reason to stick this to 4, or could I send a patch to rise it to 8?
Would be great to get it fixed for v2018.09.
Guillaume
On Thu, Aug 16, 2018 at 10:40 AM, Guillaume GARDET guillaume.gardet@free.fr wrote:
There's already a couple of threads on this list about this problem, see the Aug [1] and search, you can likely get it working by setting the value you need in the arndale config file too while that thread comes to agreement.
Guillaume GARDET
Peter Robinson
