[U-Boot] [PATCH 3/3] mpc83xx: Add PCI-E support for MPC837XEMDS boards
MPC837XEMDS boards can support PCI-E via "PCI-E riser card". The card provides two PCI-E (x2) ports. Though, only one port can be used in x2 mode. Two ports can function simultaneously in x1 mode.
PCI-E x1/x2 modes can be switched via "pex_x2" environment variable.
Signed-off-by: Anton Vorontsov avorontsov@ru.mvista.com --- board/freescale/mpc837xemds/mpc837xemds.c | 6 +- board/freescale/mpc837xemds/pci.c | 89 ++++++++++++++++++++++++++++- board/freescale/mpc837xemds/pci.h | 6 ++ include/configs/MPC837XEMDS.h | 21 +++++++ 4 files changed, 117 insertions(+), 5 deletions(-) create mode 100644 board/freescale/mpc837xemds/pci.h
diff --git a/board/freescale/mpc837xemds/mpc837xemds.c b/board/freescale/mpc837xemds/mpc837xemds.c index acf8ada..156d808 100644 --- a/board/freescale/mpc837xemds/mpc837xemds.c +++ b/board/freescale/mpc837xemds/mpc837xemds.c @@ -18,6 +18,7 @@ #include <tsec.h> #include <libfdt.h> #include <fdt_support.h> +#include "pci.h" #include "../common/pq-mds-pib.h"
int board_early_init_f(void) @@ -38,14 +39,10 @@ int board_early_init_f(void) case SPR_8377: fsl_setup_serdes(CONFIG_FSL_SERDES1, FSL_SERDES_PROTO_SATA, FSL_SERDES_CLK_100, FSL_SERDES_VDD_1V); - fsl_setup_serdes(CONFIG_FSL_SERDES2, FSL_SERDES_PROTO_PEX, - FSL_SERDES_CLK_100, FSL_SERDES_VDD_1V); break; case SPR_8378: fsl_setup_serdes(CONFIG_FSL_SERDES1, FSL_SERDES_PROTO_SGMII, FSL_SERDES_CLK_125, FSL_SERDES_VDD_1V); - fsl_setup_serdes(CONFIG_FSL_SERDES2, FSL_SERDES_PROTO_PEX, - FSL_SERDES_CLK_100, FSL_SERDES_VDD_1V); break; case SPR_8379: fsl_setup_serdes(CONFIG_FSL_SERDES1, FSL_SERDES_PROTO_SATA, @@ -316,6 +313,7 @@ void ft_board_setup(void *blob, bd_t *bd) ft_pci_setup(blob, bd); if (board_pci_host_broken()) ft_pci_fixup(blob, bd); + ft_pcie_fixup(blob, bd); #endif } #endif /* CONFIG_OF_BOARD_SETUP */ diff --git a/board/freescale/mpc837xemds/pci.c b/board/freescale/mpc837xemds/pci.c index df4e748..31116b3 100644 --- a/board/freescale/mpc837xemds/pci.c +++ b/board/freescale/mpc837xemds/pci.c @@ -16,7 +16,9 @@ #include <mpc83xx.h> #include <pci.h> #include <i2c.h> +#include <fdt_support.h> #include <asm/fsl_i2c.h> +#include <asm/fsl_serdes.h>
#if defined(CONFIG_PCI) static struct pci_region pci_regions[] = { @@ -40,15 +42,59 @@ static struct pci_region pci_regions[] = { } };
+static struct pci_region pcie_regions_0[] = { + { + .bus_start = CONFIG_SYS_PCIE1_MEM_BASE, + .phys_start = CONFIG_SYS_PCIE1_MEM_PHYS, + .size = CONFIG_SYS_PCIE1_MEM_SIZE, + .flags = PCI_REGION_MEM, + }, + { + .bus_start = CONFIG_SYS_PCIE1_IO_BASE, + .phys_start = CONFIG_SYS_PCIE1_IO_PHYS, + .size = CONFIG_SYS_PCIE1_IO_SIZE, + .flags = PCI_REGION_IO, + }, +}; + +static struct pci_region pcie_regions_1[] = { + { + .bus_start = CONFIG_SYS_PCIE2_MEM_BASE, + .phys_start = CONFIG_SYS_PCIE2_MEM_PHYS, + .size = CONFIG_SYS_PCIE2_MEM_SIZE, + .flags = PCI_REGION_MEM, + }, + { + .bus_start = CONFIG_SYS_PCIE2_IO_BASE, + .phys_start = CONFIG_SYS_PCIE2_IO_PHYS, + .size = CONFIG_SYS_PCIE2_IO_SIZE, + .flags = PCI_REGION_IO, + }, +}; + +static int is_pex_x2(void) +{ + const char *pex_x2 = getenv("pex_x2"); + + if (pex_x2 && !strcmp(pex_x2, "yes")) + return 1; + return 0; +} + void pci_init_board(void) { volatile immap_t *immr = (volatile immap_t *)CONFIG_SYS_IMMR; + volatile sysconf83xx_t *sysconf = &immr->sysconf; volatile clk83xx_t *clk = (volatile clk83xx_t *)&immr->clk; volatile law83xx_t *pci_law = immr->sysconf.pcilaw; + volatile law83xx_t *pcie_law = sysconf->pcielaw; struct pci_region *reg[] = { pci_regions }; + struct pci_region *pcie_reg[] = { pcie_regions_0, pcie_regions_1, }; + u32 spridr = in_be32(&immr->sysconf.spridr); + int pex2 = is_pex_x2();
if (board_pci_host_broken()) - return; + goto skip_pci;
/* Enable all 5 PCI_CLK_OUTPUTS */ clk->occr |= 0xf8000000; @@ -64,5 +110,46 @@ void pci_init_board(void) udelay(2000);
mpc83xx_pci_init(1, reg, 0); +skip_pci: + /* There is no PEX in MPC8379 parts. */ + if (PARTID_NO_E(spridr) == SPR_8379) + return; + + /* Configure the clock for PCIE controller */ + clrsetbits_be32(&clk->sccr, SCCR_PCIEXP1CM | SCCR_PCIEXP2CM, + SCCR_PCIEXP1CM_1 | SCCR_PCIEXP2CM_1); + + /* Deassert the resets in the control register */ + out_be32(&sysconf->pecr1, 0xE0008000); + if (!pex2) + out_be32(&sysconf->pecr2, 0xE0008000); + udelay(2000); + + /* Configure PCI Express Local Access Windows */ + out_be32(&pcie_law[0].bar, CONFIG_SYS_PCIE1_BASE & LAWBAR_BAR); + out_be32(&pcie_law[0].ar, LBLAWAR_EN | LBLAWAR_512MB); + + out_be32(&pcie_law[1].bar, CONFIG_SYS_PCIE2_BASE & LAWBAR_BAR); + out_be32(&pcie_law[1].ar, LBLAWAR_EN | LBLAWAR_512MB); + + if (pex2) + fsl_setup_serdes(CONFIG_FSL_SERDES2, FSL_SERDES_PROTO_PEX_X2, + FSL_SERDES_CLK_100, FSL_SERDES_VDD_1V); + else + fsl_setup_serdes(CONFIG_FSL_SERDES2, FSL_SERDES_PROTO_PEX, + FSL_SERDES_CLK_100, FSL_SERDES_VDD_1V); + + mpc83xx_pcie_init(pex2 ? 1 : 2, pcie_reg, 0); +} + +void ft_pcie_fixup(void *blob, bd_t *bd) +{ + const char *status = "disabled (PCIE1 is x2)"; + + if (!is_pex_x2()) + return; + + do_fixup_by_path(blob, "pci2", "status", status, + strlen(status) + 1, 1); } #endif /* CONFIG_PCI */ diff --git a/board/freescale/mpc837xemds/pci.h b/board/freescale/mpc837xemds/pci.h new file mode 100644 index 0000000..fd7a916 --- /dev/null +++ b/board/freescale/mpc837xemds/pci.h @@ -0,0 +1,6 @@ +#ifndef __BOARD_MPC837XEMDS_PCI_H +#define __BOARD_MPC837XEMDS_PCI_H + +extern void ft_pcie_fixup(void *blob, bd_t *bd); + +#endif /* __BOARD_MPC837XEMDS_PCI_H */ diff --git a/include/configs/MPC837XEMDS.h b/include/configs/MPC837XEMDS.h index d49155f..28d442b 100644 --- a/include/configs/MPC837XEMDS.h +++ b/include/configs/MPC837XEMDS.h @@ -354,11 +354,32 @@ #define CONFIG_SYS_PCI_SLV_MEM_BUS 0x00000000 #define CONFIG_SYS_PCI_SLV_MEM_SIZE 0x80000000
+#define CONFIG_SYS_PCIE1_BASE 0xA0000000 +#define CONFIG_SYS_PCIE1_CFG_BASE 0xA0000000 +#define CONFIG_SYS_PCIE1_CFG_SIZE 0x08000000 +#define CONFIG_SYS_PCIE1_MEM_BASE 0xA8000000 +#define CONFIG_SYS_PCIE1_MEM_PHYS 0xA8000000 +#define CONFIG_SYS_PCIE1_MEM_SIZE 0x10000000 +#define CONFIG_SYS_PCIE1_IO_BASE 0x00000000 +#define CONFIG_SYS_PCIE1_IO_PHYS 0xB8000000 +#define CONFIG_SYS_PCIE1_IO_SIZE 0x00800000 + +#define CONFIG_SYS_PCIE2_BASE 0xC0000000 +#define CONFIG_SYS_PCIE2_CFG_BASE 0xC0000000 +#define CONFIG_SYS_PCIE2_CFG_SIZE 0x08000000 +#define CONFIG_SYS_PCIE2_MEM_BASE 0xC8000000 +#define CONFIG_SYS_PCIE2_MEM_PHYS 0xC8000000 +#define CONFIG_SYS_PCIE2_MEM_SIZE 0x10000000 +#define CONFIG_SYS_PCIE2_IO_BASE 0x00000000 +#define CONFIG_SYS_PCIE2_IO_PHYS 0xD8000000 +#define CONFIG_SYS_PCIE2_IO_SIZE 0x00800000 + #ifdef CONFIG_PCI #ifndef __ASSEMBLY__ extern int board_pci_host_broken(void); #endif #define CONFIG_83XX_GENERIC_PCI 1 /* Use generic PCI setup */ +#define CONFIG_83XX_GENERIC_PCIE 1 #define CONFIG_PQ_MDS_PIB 1 /* PQ MDS Platform IO Board */
#define CONFIG_HAS_FSL_DR_USB 1 /* fixup device tree for the DR USB */
- /* Deassert the resets in the control register */
- out_be32(&sysconf->pecr1, 0xE0008000);
- if (!pex2)
- udelay(2000);
- /* Configure PCI Express Local Access Windows */
- out_be32(&pcie_law[0].bar, CONFIG_SYS_PCIE1_BASE & LAWBAR_BAR);
- out_be32(&pcie_law[0].ar, LBLAWAR_EN | LBLAWAR_512MB);
- out_be32(&pcie_law[1].bar, CONFIG_SYS_PCIE2_BASE & LAWBAR_BAR);
- out_be32(&pcie_law[1].ar, LBLAWAR_EN | LBLAWAR_512MB);
- if (pex2)
- else
Umm, The serdes initialization should be finished before negated the reset signal according to the UM. So, it is safe to move the serdes initialization before the out_be32(pecr1/2);
Why did you keep the cfg window as 128MB? Did you consider the compitable with FSL BSP?
same
On Thu, 8 Jan 2009 04:26:19 +0300 Anton Vorontsov avorontsov@ru.mvista.com wrote:
applied to u-boot-mpc83xx next.
can you please work together to resolve any issues Dave brought up with this one, and send supplemental patches to u-boot-mpc83xx next? I don't particularly care about BSP compatibility (esp. since you indicated it wasn't worth the effort), but the serdes initialization vs. pecr1 deassertion might need further attention.
Thanks all,
Kim
Thanks Kim.
Sure, I didn't forget about the comments. Just got assigned to other tasks... I'll return to the PCI-E work soon, and will address all the issues.
Thank you all for reviews and comments.
Anton Vorontsov
Kim Phillips
Liu Dave
