[U-Boot] [PATCH] ARM: fix build error with gcc-4.4.2 about inline function declared weak
From: Abdoulaye Walsimou Gaye walsimou@walsimou.com
This patch fix build error with gcc-4.4.2 about inline function declared weak, see below: board.c:96: error: inline function 'coloured_LED_init' cannot be declared weak board.c:98: error: inline function 'red_LED_on' cannot be declared weak board.c:100: error: inline function 'red_LED_off' cannot be declared weak board.c:102: error: inline function 'green_LED_on' cannot be declared weak board.c:104: error: inline function 'green_LED_off' cannot be declared weak board.c:106: error: inline function 'yellow_LED_on' cannot be declared weak board.c:108: error: inline function 'yellow_LED_off' cannot be declared weak board.c:110: error: inline function 'blue_LED_on' cannot be declared weak board.c:112: error: inline function 'blue_LED_off' cannot be declared weak make[1]: *** [board.o] Error 1
Signed-off-by: Abdoulaye Walsimou Gaye walsimou@walsimou.com --- lib_arm/board.c | 18 +++++++++--------- 1 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/lib_arm/board.c b/lib_arm/board.c index 5e3d7f6..886c74c 100644 --- a/lib_arm/board.c +++ b/lib_arm/board.c @@ -93,23 +93,23 @@ extern void rtl8019_get_enetaddr (uchar * addr); * May be supplied by boards if desired */ void inline __coloured_LED_init (void) {} -void inline coloured_LED_init (void) __attribute__((weak, alias("__coloured_LED_init"))); +void coloured_LED_init(void)__attribute__((weak, alias("__coloured_LED_init"))); void inline __red_LED_on (void) {} -void inline red_LED_on (void) __attribute__((weak, alias("__red_LED_on"))); +void red_LED_on(void) __attribute__((weak, alias("__red_LED_on"))); void inline __red_LED_off(void) {} -void inline red_LED_off(void) __attribute__((weak, alias("__red_LED_off"))); +void red_LED_off(void)__attribute__((weak, alias("__red_LED_off"))); void inline __green_LED_on(void) {} -void inline green_LED_on(void) __attribute__((weak, alias("__green_LED_on"))); +void green_LED_on(void) __attribute__((weak, alias("__green_LED_on"))); void inline __green_LED_off(void) {} -void inline green_LED_off(void)__attribute__((weak, alias("__green_LED_off"))); +void green_LED_off(void)__attribute__((weak, alias("__green_LED_off"))); void inline __yellow_LED_on(void) {} -void inline yellow_LED_on(void)__attribute__((weak, alias("__yellow_LED_on"))); +void yellow_LED_on(void)__attribute__((weak, alias("__yellow_LED_on"))); void inline __yellow_LED_off(void) {} -void inline yellow_LED_off(void)__attribute__((weak, alias("__yellow_LED_off"))); +void yellow_LED_off(void)__attribute__((weak, alias("__yellow_LED_off"))); void inline __blue_LED_on(void) {} -void inline blue_LED_on(void)__attribute__((weak, alias("__blue_LED_on"))); +void blue_LED_on(void)__attribute__((weak, alias("__blue_LED_on"))); void inline __blue_LED_off(void) {} -void inline blue_LED_off(void)__attribute__((weak, alias("__blue_LED_off"))); +void blue_LED_off(void)__attribute__((weak, alias("__blue_LED_off")));
/************************************************************************ * Init Utilities *
What is your $(CROSS_COMPILE)gcc -v ? Tom
- May be supplied by boards if desired
- Init Utilities *
This is a home made toolchain. With same options with gcc-4.3.4, gcc-4.4.1, no build error.
armel-linux-gcc -v Using built-in specs. Target: armel-unknown-linux-gnueabi Configured with: /usr/src/walsimou/embtoolkit-0.1.0-rc5/build/tools_build-armel-linux-arm920t/gcc-4.4.2/configure --prefix=/usr/src/walsimou/embtoolkit-0.1.0-rc5/tools-armel-linux-arm920t --with-sysroot=/usr/src/walsimou/embtoolkit-0.1.0-rc5/sysroot-armel-linux-arm920t --target=armel-unknown-linux-gnueabi --with-cpu=arm920t --with-float=soft --disable-multilib --host=x86_64-unknown-linux-gnu --build=x86_64-unknown-linux-gnu --enable-__cxa_atexit --disable-libssp --disable-libgomp --disable-libmudflap --disable-nls --enable-threads --enable-shared --with-gmp=/usr/src/walsimou/embtoolkit-0.1.0-rc5/host-tools-arm920t/usr/local/gmp-host --with-mpfr=/usr/src/walsimou/embtoolkit-0.1.0-rc5/host-tools-arm920t/usr/local/mpfr-host --enable-languages=c Thread model: posix gcc version 4.4.2 (GCC)
Thanks
Dear Tom,
Tom, please note this issue is old, and in any case a patch,if checked in, should be properly attributed. I think the first to bring this up was Ron Lee; please see the whole thread here: http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/65397
Looks exactly the same as Ron's patch to me...
Wolfgang Denk wrote:
Dear Tom,
Deja vu.. Let try to fix it this time. The hold up issue is non inline, adds some wasted bytes.
Is the linker smart enough to garbage collect them away ? Tom
Gaye Abdoulaye Walsimou
Tom
walsimouï¼ walsimou.com
