[U-Boot] [PATCH 0/6] arm: socfpga: Add Designware SPI support
Hi!
This patchset adds the driver for the Designware master SPI controller. This IP core is integrated on the Altera SoCFPGA. This implementation is a driver model (DM) implementation. So multiple SPI drivers can be used. Thats necessary, since SoCFPGA also integrates the Cadence QSPI controller used to connect the SPI NOR flashes. Without DM, using multiple SPI driver is not possible.
As mentioned above, this patchset depends on the SoCFPGA DT support. And its also done on-top of the Cadence QSPI support I posted a short while ago. But it doesn't depend on it. Its just that the patch series will most likely generate merge conflicts if not applied in this sequence.
This is tested on the SoCrates SoCFPGA board using the SPI pins on the P14 header.
Thanks, Stefan
Cc: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@altera.com Cc: Vince Bridgers vbridger@altera.com Cc: Marek Vasut marex@denx.de Cc: Pavel Machek pavel@denx.de Cc: Simon Glass sjg@chromium.org Cc: Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com
This function will be needed by the upcoming Designware master SPI driver.
Signed-off-by: Stefan Roese sr@denx.de Cc: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@altera.com Cc: Vince Bridgers vbridger@altera.com Cc: Marek Vasut marex@denx.de Cc: Pavel Machek pavel@denx.de --- arch/arm/cpu/armv7/socfpga/clock_manager.c | 14 ++++++++++++++ 1 file changed, 14 insertions(+)
diff --git a/arch/arm/cpu/armv7/socfpga/clock_manager.c b/arch/arm/cpu/armv7/socfpga/clock_manager.c index d869f47..fa3b93a 100644 --- a/arch/arm/cpu/armv7/socfpga/clock_manager.c +++ b/arch/arm/cpu/armv7/socfpga/clock_manager.c @@ -507,6 +507,19 @@ unsigned int cm_get_qspi_controller_clk_hz(void) return clock; }
+unsigned int cm_get_spi_controller_clk_hz(void) +{ + uint32_t reg, clock = 0; + + clock = cm_get_per_vco_clk_hz(); + + /* get the clock prior L4 SP divider (periph_base_clk) */ + reg = readl(&clock_manager_base->per_pll.perbaseclk); + clock /= (reg + 1); + + return clock; +} + static void cm_print_clock_quick_summary(void) { printf("MPU %10ld kHz\n", cm_get_mpu_clk_hz() / 1000); @@ -518,6 +531,7 @@ static void cm_print_clock_quick_summary(void) printf("MMC %8d kHz\n", cm_get_mmc_controller_clk_hz() / 1000); printf("QSPI %8d kHz\n", cm_get_qspi_controller_clk_hz() / 1000); printf("UART %8d kHz\n", cm_get_l4_sp_clk_hz() / 1000); + printf("SPI %8d kHz\n", cm_get_spi_controller_clk_hz() / 1000); }
int set_cpu_clk_info(void)
Awww, was this missing ? Thanks!
Best regards, Marek Vasut
Acked-by: Pavel Machek pavel@denx.de
This function will be needed by the upcoming Designware master SPI driver. As the SPI master controller is held in reset by the current Preloader implementation. So we need to release the reset for the driver to communicate with the controller.
This function is called from arch_early_init_r() if the SPI driver is enabled.
Signed-off-by: Stefan Roese sr@denx.de Cc: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@altera.com Cc: Vince Bridgers vbridger@altera.com Cc: Marek Vasut marex@denx.de Cc: Pavel Machek pavel@denx.de --- arch/arm/cpu/armv7/socfpga/misc.c | 6 ++++++ arch/arm/cpu/armv7/socfpga/reset_manager.c | 9 +++++++++ arch/arm/include/asm/arch-socfpga/reset_manager.h | 3 +++ 3 files changed, 18 insertions(+)
diff --git a/arch/arm/cpu/armv7/socfpga/misc.c b/arch/arm/cpu/armv7/socfpga/misc.c index 8c3e5f7..73cffd3 100644 --- a/arch/arm/cpu/armv7/socfpga/misc.c +++ b/arch/arm/cpu/armv7/socfpga/misc.c @@ -202,6 +202,12 @@ int arch_early_init_r(void)
/* Add device descriptor to FPGA device table */ socfpga_fpga_add(); + +#ifdef CONFIG_DESIGNWARE_SPI + /* Get Designware SPI controller out of reset */ + socfpga_spim_enable(); +#endif + return 0; }
diff --git a/arch/arm/cpu/armv7/socfpga/reset_manager.c b/arch/arm/cpu/armv7/socfpga/reset_manager.c index 1d3a95d..af9db85 100644 --- a/arch/arm/cpu/armv7/socfpga/reset_manager.c +++ b/arch/arm/cpu/armv7/socfpga/reset_manager.c @@ -104,3 +104,12 @@ void socfpga_emac_reset(int enable) #endif } } + +/* SPI Master enable (its held in reset by the preloader) */ +void socfpga_spim_enable(void) +{ + const void *reset = &reset_manager_base->per_mod_reset; + + clrbits_le32(reset, 1 << RSTMGR_PERMODRST_SPIM0_LSB); + clrbits_le32(reset, 1 << RSTMGR_PERMODRST_SPIM1_LSB); +} diff --git a/arch/arm/include/asm/arch-socfpga/reset_manager.h b/arch/arm/include/asm/arch-socfpga/reset_manager.h index 1857b80..034135b 100644 --- a/arch/arm/include/asm/arch-socfpga/reset_manager.h +++ b/arch/arm/include/asm/arch-socfpga/reset_manager.h @@ -14,6 +14,7 @@ void socfpga_bridges_reset(int enable);
void socfpga_emac_reset(int enable); void socfpga_watchdog_reset(void); +void socfpga_spim_enable(void);
struct socfpga_reset_manager { u32 status; @@ -35,5 +36,7 @@ struct socfpga_reset_manager { #define RSTMGR_PERMODRST_EMAC0_LSB 0 #define RSTMGR_PERMODRST_EMAC1_LSB 1 #define RSTMGR_PERMODRST_L4WD0_LSB 6 +#define RSTMGR_PERMODRST_SPIM0_LSB 18 +#define RSTMGR_PERMODRST_SPIM1_LSB 19
#endif /* _RESET_MANAGER_H_ */
- const void *reset = &reset_manager_base->per_mod_reset;
- clrbits_le32(reset, 1 << RSTMGR_PERMODRST_SPIM0_LSB);
- clrbits_le32(reset, 1 << RSTMGR_PERMODRST_SPIM1_LSB);
Actually, you can do this with one clrbits, right?
Pavel
Yes, will send a follow-up patch for this.
Thanks, Stefan
This patch adds the driver for the Designware master SPI controller. This IP core is integrated on the Altera SoCFPGA. This implementation is a driver model (DM) implementation. So multiple SPI drivers can be used. Thats necessary, since SoCFPGA also integrates the Cadence QSPI controller used to connect the SPI NOR flashes. Without DM, using multiple SPI driver is not possible.
This driver is very loosly based on the Linux driver. Most of the Linux driver is removed. Only the polling loop for the transfer is really used from this driver. As we don't support interrupts and DMA right now.
Signed-off-by: Stefan Roese sr@denx.de Cc: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@altera.com Cc: Vince Bridgers vbridger@altera.com Cc: Marek Vasut marex@denx.de Cc: Pavel Machek pavel@denx.de Cc: Simon Glass sjg@chromium.org Cc: Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com --- drivers/spi/Makefile | 1 + drivers/spi/designware_spi.c | 425 +++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 426 insertions(+) create mode 100644 drivers/spi/designware_spi.c
diff --git a/drivers/spi/Makefile b/drivers/spi/Makefile index 964fdc1..edbd520 100644 --- a/drivers/spi/Makefile +++ b/drivers/spi/Makefile @@ -27,6 +27,7 @@ obj-$(CONFIG_CADENCE_QSPI) += cadence_qspi.o cadence_qspi_apb.o obj-$(CONFIG_CF_SPI) += cf_spi.o obj-$(CONFIG_CF_QSPI) += cf_qspi.o obj-$(CONFIG_DAVINCI_SPI) += davinci_spi.o +obj-$(CONFIG_DESIGNWARE_SPI) += designware_spi.o obj-$(CONFIG_EXYNOS_SPI) += exynos_spi.o obj-$(CONFIG_FTSSP010_SPI) += ftssp010_spi.o obj-$(CONFIG_ICH_SPI) += ich.o diff --git a/drivers/spi/designware_spi.c b/drivers/spi/designware_spi.c new file mode 100644 index 0000000..1bc0d04 --- /dev/null +++ b/drivers/spi/designware_spi.c @@ -0,0 +1,425 @@ +/* + * Designware master SPI core controller driver + * + * Copyright (C) 2014 Stefan Roese sr@denx.de + * + * Very loosly based on the Linux driver version which is: + * Copyright (c) 2009, Intel Corporation. + * + * SPDX-License-Identifier: GPL-2.0 + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <malloc.h> +#include <spi.h> +#include <fdtdec.h> +#include <linux/compat.h> +#include <asm/io.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* Register offsets */ +#define DW_SPI_CTRL0 0x00 +#define DW_SPI_CTRL1 0x04 +#define DW_SPI_SSIENR 0x08 +#define DW_SPI_MWCR 0x0c +#define DW_SPI_SER 0x10 +#define DW_SPI_BAUDR 0x14 +#define DW_SPI_TXFLTR 0x18 +#define DW_SPI_RXFLTR 0x1c +#define DW_SPI_TXFLR 0x20 +#define DW_SPI_RXFLR 0x24 +#define DW_SPI_SR 0x28 +#define DW_SPI_IMR 0x2c +#define DW_SPI_ISR 0x30 +#define DW_SPI_RISR 0x34 +#define DW_SPI_TXOICR 0x38 +#define DW_SPI_RXOICR 0x3c +#define DW_SPI_RXUICR 0x40 +#define DW_SPI_MSTICR 0x44 +#define DW_SPI_ICR 0x48 +#define DW_SPI_DMACR 0x4c +#define DW_SPI_DMATDLR 0x50 +#define DW_SPI_DMARDLR 0x54 +#define DW_SPI_IDR 0x58 +#define DW_SPI_VERSION 0x5c +#define DW_SPI_DR 0x60 + +/* Bit fields in CTRLR0 */ +#define SPI_DFS_OFFSET 0 + +#define SPI_FRF_OFFSET 4 +#define SPI_FRF_SPI 0x0 +#define SPI_FRF_SSP 0x1 +#define SPI_FRF_MICROWIRE 0x2 +#define SPI_FRF_RESV 0x3 + +#define SPI_MODE_OFFSET 6 +#define SPI_SCPH_OFFSET 6 +#define SPI_SCOL_OFFSET 7 + +#define SPI_TMOD_OFFSET 8 +#define SPI_TMOD_MASK (0x3 << SPI_TMOD_OFFSET) +#define SPI_TMOD_TR 0x0 /* xmit & recv */ +#define SPI_TMOD_TO 0x1 /* xmit only */ +#define SPI_TMOD_RO 0x2 /* recv only */ +#define SPI_TMOD_EPROMREAD 0x3 /* eeprom read mode */ + +#define SPI_SLVOE_OFFSET 10 +#define SPI_SRL_OFFSET 11 +#define SPI_CFS_OFFSET 12 + +/* Bit fields in SR, 7 bits */ +#define SR_MASK 0x7f /* cover 7 bits */ +#define SR_BUSY (1 << 0) +#define SR_TF_NOT_FULL (1 << 1) +#define SR_TF_EMPT (1 << 2) +#define SR_RF_NOT_EMPT (1 << 3) +#define SR_RF_FULL (1 << 4) +#define SR_TX_ERR (1 << 5) +#define SR_DCOL (1 << 6) + +#define RX_TIMEOUT 1000 + +struct dw_spi_platdata { + s32 frequency; /* Default clock frequency, -1 for none */ + void __iomem *regs; +}; + +struct dw_spi_priv { + void __iomem *regs; + unsigned int freq; /* Default frequency */ + unsigned int mode; + + int bits_per_word; + u8 cs; /* chip select pin */ + u8 n_bytes; /* current is a 1/2/4 byte op */ + u8 tmode; /* TR/TO/RO/EEPROM */ + u8 type; /* SPI/SSP/MicroWire */ + int len; + + u32 fifo_len; /* depth of the FIFO buffer */ + void *tx; + void *tx_end; + void *rx; + void *rx_end; +}; + +static inline u32 dw_readl(struct dw_spi_priv *priv, u32 offset) +{ + return __raw_readl(priv->regs + offset); +} + +static inline void dw_writel(struct dw_spi_priv *priv, u32 offset, u32 val) +{ + __raw_writel(val, priv->regs + offset); +} + +static inline u16 dw_readw(struct dw_spi_priv *priv, u32 offset) +{ + return __raw_readw(priv->regs + offset); +} + +static inline void dw_writew(struct dw_spi_priv *priv, u32 offset, u16 val) +{ + __raw_writew(val, priv->regs + offset); +} + +static int dw_spi_ofdata_to_platdata(struct udevice *bus) +{ + struct dw_spi_platdata *plat = bus->platdata; + const void *blob = gd->fdt_blob; + int node = bus->of_offset; + + plat->regs = (struct dw_spi *)fdtdec_get_addr(blob, node, "reg"); + + /* Use 500KHz as a suitable default */ + plat->frequency = fdtdec_get_int(blob, node, "spi-max-frequency", + 500000); + debug("%s: regs=%p max-frequency=%d\n", __func__, plat->regs, + plat->frequency); + + return 0; +} + +static inline void spi_enable_chip(struct dw_spi_priv *priv, int enable) +{ + dw_writel(priv, DW_SPI_SSIENR, (enable ? 1 : 0)); +} + +/* Restart the controller, disable all interrupts, clean rx fifo */ +static void spi_hw_init(struct dw_spi_priv *priv) +{ + spi_enable_chip(priv, 0); + dw_writel(priv, DW_SPI_IMR, 0xff); + spi_enable_chip(priv, 1); + + /* + * Try to detect the FIFO depth if not set by interface driver, + * the depth could be from 2 to 256 from HW spec + */ + if (!priv->fifo_len) { + u32 fifo; + + for (fifo = 2; fifo <= 257; fifo++) { + dw_writew(priv, DW_SPI_TXFLTR, fifo); + if (fifo != dw_readw(priv, DW_SPI_TXFLTR)) + break; + } + + priv->fifo_len = (fifo == 257) ? 0 : fifo; + dw_writew(priv, DW_SPI_TXFLTR, 0); + } + debug("%s: fifo_len=%d\n", __func__, priv->fifo_len); +} + +static int dw_spi_probe(struct udevice *bus) +{ + struct dw_spi_platdata *plat = dev_get_platdata(bus); + struct dw_spi_priv *priv = dev_get_priv(bus); + + priv->regs = plat->regs; + priv->freq = plat->frequency; + + /* Currently only bits_per_word == 8 supported */ + priv->bits_per_word = 8; + priv->n_bytes = 1; + + priv->tmode = 0; /* Tx & Rx */ + + /* Basic HW init */ + spi_hw_init(priv); + + return 0; +} + +/* Return the max entries we can fill into tx fifo */ +static inline u32 tx_max(struct dw_spi_priv *priv) +{ + u32 tx_left, tx_room, rxtx_gap; + + tx_left = (priv->tx_end - priv->tx) / priv->n_bytes; + tx_room = priv->fifo_len - dw_readw(priv, DW_SPI_TXFLR); + + /* + * Another concern is about the tx/rx mismatch, we + * though to use (priv->fifo_len - rxflr - txflr) as + * one maximum value for tx, but it doesn't cover the + * data which is out of tx/rx fifo and inside the + * shift registers. So a control from sw point of + * view is taken. + */ + rxtx_gap = ((priv->rx_end - priv->rx) - (priv->tx_end - priv->tx)) / + priv->n_bytes; + + return min3(tx_left, tx_room, (u32)(priv->fifo_len - rxtx_gap)); +} + +/* Return the max entries we should read out of rx fifo */ +static inline u32 rx_max(struct dw_spi_priv *priv) +{ + u32 rx_left = (priv->rx_end - priv->rx) / priv->n_bytes; + + return min_t(u32, rx_left, dw_readw(priv, DW_SPI_RXFLR)); +} + +static void dw_writer(struct dw_spi_priv *priv) +{ + u32 max = tx_max(priv); + u16 txw = 0; + + while (max--) { + /* Set the tx word if the transfer's original "tx" is not null */ + if (priv->tx_end - priv->len) { + if (priv->n_bytes == 1) + txw = *(u8 *)(priv->tx); + else + txw = *(u16 *)(priv->tx); + } + dw_writew(priv, DW_SPI_DR, txw); + debug("%s: tx=0x%02x\n", __func__, txw); + priv->tx += priv->n_bytes; + } +} + +static int dw_reader(struct dw_spi_priv *priv) +{ + unsigned start = get_timer(0); + u32 max; + u16 rxw; + + /* Wait for rx data to be ready */ + while (rx_max(priv) == 0) { + if (get_timer(start) > RX_TIMEOUT) + return -ETIMEDOUT; + } + + max = rx_max(priv); + + while (max--) { + rxw = dw_readw(priv, DW_SPI_DR); + debug("%s: rx=0x%02x\n", __func__, rxw); + /* Care rx only if the transfer's original "rx" is not null */ + if (priv->rx_end - priv->len) { + if (priv->n_bytes == 1) + *(u8 *)(priv->rx) = rxw; + else + *(u16 *)(priv->rx) = rxw; + } + priv->rx += priv->n_bytes; + } + + return 0; +} + +static int poll_transfer(struct dw_spi_priv *priv) +{ + int ret; + + do { + dw_writer(priv); + ret = dw_reader(priv); + if (ret < 0) + return ret; + } while (priv->rx_end > priv->rx); + + return 0; +} + +static int dw_spi_xfer(struct udevice *dev, unsigned int bitlen, + const void *dout, void *din, unsigned long flags) +{ + struct udevice *bus = dev->parent; + struct dw_spi_priv *priv = dev_get_priv(bus); + const u8 *tx = dout; + u8 *rx = din; + int ret = 0; + u32 cr0 = 0; + u8 bits = 0; + u32 cs; + + /* spi core configured to do 8 bit transfers */ + if (bitlen % 8) { + debug("Non byte aligned SPI transfer.\n"); + return -1; + } + + bits = priv->bits_per_word; + priv->n_bytes = bits >> 3; + cr0 = (bits - 1) | (priv->type << SPI_FRF_OFFSET) | + (priv->mode << SPI_MODE_OFFSET) | + (priv->tmode << SPI_TMOD_OFFSET); + + if (rx && tx) + priv->tmode = SPI_TMOD_TR; + else if (rx) + priv->tmode = SPI_TMOD_RO; + else + priv->tmode = SPI_TMOD_TO; + + cr0 &= ~SPI_TMOD_MASK; + cr0 |= (priv->tmode << SPI_TMOD_OFFSET); + + priv->len = bitlen / 8; + debug("%s: rx=%p tx=%p len=%d [bytes]\n", __func__, rx, tx, priv->len); + + priv->tx = (void *)tx; + priv->tx_end = priv->tx + priv->len; + priv->rx = rx; + priv->rx_end = priv->rx + priv->len; + + /* Disable controller before writing control registers */ + spi_enable_chip(priv, 0); + + debug("%s: cr0=%08x\n", __func__, cr0); + /* Reprogram cr0 only if changed */ + if (dw_readw(priv, DW_SPI_CTRL0) != cr0) + dw_writew(priv, DW_SPI_CTRL0, cr0); + + /* + * Configure the desired SS (slave select 0...3) in the controller + * The DW SPI controller will activate and deactivate this CS + * automatically. So no cs_activate() etc is needed in this driver. + */ + cs = spi_chip_select(dev); + dw_writel(priv, DW_SPI_SER, 1 << cs); + + /* Enable controller after writing control registers */ + spi_enable_chip(priv, 1); + + /* Start transfer in a polling loop */ + ret = poll_transfer(priv); + + return ret; +} + +static int dw_spi_set_speed(struct udevice *bus, uint speed) +{ + struct dw_spi_platdata *plat = bus->platdata; + struct dw_spi_priv *priv = dev_get_priv(bus); + u16 clk_div; + + if (speed > plat->frequency) + speed = plat->frequency; + + /* Disable controller before writing control registers */ + spi_enable_chip(priv, 0); + + /* clk_div doesn't support odd number */ + clk_div = CONFIG_DW_SPI_REF_CLK / speed; + clk_div = (clk_div + 1) & 0xfffe; + dw_writel(priv, DW_SPI_BAUDR, clk_div); + + /* Enable controller after writing control registers */ + spi_enable_chip(priv, 1); + + priv->freq = speed; + debug("%s: regs=%p speed=%d clk_div=%d\n", __func__, priv->regs, + priv->freq, clk_div); + + return 0; +} + +static int dw_spi_set_mode(struct udevice *bus, uint mode) +{ + struct dw_spi_priv *priv = dev_get_priv(bus); + + /* + * Can't set mode yet. Since this depends on if rx, tx, or + * rx & tx is requested. So we have to defer this to the + * real transfer function. + */ + priv->mode = mode; + debug("%s: regs=%p, mode=%d\n", __func__, priv->regs, priv->mode); + + return 0; +} + +static const struct dm_spi_ops dw_spi_ops = { + .xfer = dw_spi_xfer, + .set_speed = dw_spi_set_speed, + .set_mode = dw_spi_set_mode, + /* + * cs_info is not needed, since we require all chip selects to be + * in the device tree explicitly + */ +}; + +static const struct udevice_id dw_spi_ids[] = { + { .compatible = "snps,dw-spi-mmio" }, + { } +}; + +U_BOOT_DRIVER(dw_spi) = { + .name = "dw_spi", + .id = UCLASS_SPI, + .of_match = dw_spi_ids, + .ops = &dw_spi_ops, + .ofdata_to_platdata = dw_spi_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct dw_spi_platdata), + .priv_auto_alloc_size = sizeof(struct dw_spi_priv), + .per_child_auto_alloc_size = sizeof(struct spi_slave), + .probe = dw_spi_probe, +};
- Designware master SPI core controller driver
- Copyright (C) 2014 Stefan Roese sr@denx.de
- Very loosly based on the Linux driver version which is:
- Copyright (c) 2009, Intel Corporation.
- SPDX-License-Identifier: GPL-2.0
What's the agreement about the licensing now, GPL-2.0 or GPL-2.0+ ?
- return __raw_readl(priv->regs + offset);
Do we really need these wrappers ?
Thanks!
Hi Stefan,
For driver model things:
Hi!
You tripped my spell-checker, sorry.
drivers.
loosely?
, as
loosely. (And citing filename here might be useful.)
Any chance to convert this to structure?
comment with units would be welcome.
- s32 frequency; /* Default clock frequency, -1 for none */
- void __iomem *regs;
- unsigned int freq; /* Default frequency */
- unsigned int mode;
- int bits_per_word;
- u8 cs; /* chip select pin */
- u8 n_bytes; /* current is a 1/2/4 byte op */
- u8 tmode; /* TR/TO/RO/EEPROM */
- u8 type; /* SPI/SSP/MicroWire */
- int len;
Having both n_bytes and len is "interesting". Turn n_bytes into "word_size"?
- struct dw_spi_platdata *plat = dev_get_platdata(bus);
- struct dw_spi_priv *priv = dev_get_priv(bus);
- priv->regs = plat->regs;
- priv->freq = plat->frequency;
- /* Currently only bits_per_word == 8 supported */
- priv->bits_per_word = 8;
- priv->n_bytes = 1;
n_bytes -> bytes_per_word? Why we have two variables for same information?
"thought about using"?
- while (max--) {
"Care about"?
- /* spi core configured to do 8 bit transfers */
"core is"?
Thanks, Pavel
On Wednesday, November 12, 2014 at 06:51:42 PM, Pavel Machek wrote:
Hi!
drivers.
loosely?
, as
I fixed the text and I placed this whole driver patchset to
u-boot-socfpga:topic/drivers/spi-20141114
Can you please fix the code so I can replace that one patch ? Or just send me one which I can squash into this patch, either way works.
Thanks!
Hi!
drivers.
loosely?
, as
Yes. I'll take a look at it tomorrow or on Monday.
Thanks, Stefan
Hi!
drivers.
loosely?
, as
Thank you !
Signed-off-by: Stefan Roese sr@denx.de Cc: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@altera.com Cc: Vince Bridgers vbridger@altera.com Cc: Marek Vasut marex@denx.de Cc: Pavel Machek pavel@denx.de --- arch/arm/dts/socfpga.dtsi | 28 ++++++++++++++++++++++++++++ 1 file changed, 28 insertions(+)
diff --git a/arch/arm/dts/socfpga.dtsi b/arch/arm/dts/socfpga.dtsi index 4a789a9..9de7ca9 100644 --- a/arch/arm/dts/socfpga.dtsi +++ b/arch/arm/dts/socfpga.dtsi @@ -654,6 +654,34 @@ status = "disabled"; };
+ spi0: spi@fff00000 { + compatible = "snps,dw-spi-mmio"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0xfff00000 0x1000>; + interrupts = <0 154 4>; + num-chipselect = <4>; + bus-num = <0>; + tx-dma-channel = <&pdma 16>; + rx-dma-channel = <&pdma 17>; + clocks = <&per_base_clk>; + status = "disabled"; + }; + + spi1: spi@fff01000 { + compatible = "snps,dw-spi-mmio"; + #address-cells = <1>; + #size-cells = <0>; + reg = <0xfff01000 0x1000>; + interrupts = <0 156 4>; + num-chipselect = <4>; + bus-num = <1>; + tx-dma-channel = <&pdma 20>; + rx-dma-channel = <&pdma 21>; + clocks = <&per_base_clk>; + status = "disabled"; + }; + /* Local timer */ timer@fffec600 { compatible = "arm,cortex-a9-twd-timer";
Without this alias, DM based probing does not work. So lets add this alias to get the bus numbering correct for the Designware SPI controllers.
Signed-off-by: Stefan Roese sr@denx.de Cc: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@altera.com Cc: Vince Bridgers vbridger@altera.com Cc: Marek Vasut marex@denx.de Cc: Pavel Machek pavel@denx.de --- arch/arm/dts/socfpga_cyclone5_socrates.dts | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/dts/socfpga_cyclone5_socrates.dts b/arch/arm/dts/socfpga_cyclone5_socrates.dts index 02bb8b3..4f0bfab 100644 --- a/arch/arm/dts/socfpga_cyclone5_socrates.dts +++ b/arch/arm/dts/socfpga_cyclone5_socrates.dts @@ -27,6 +27,8 @@
aliases { spi0 = "/spi@ff705000"; /* QSPI */ + spi1 = "/spi@fff00000"; + spi2 = "/spi@fff01000"; };
memory {
Enable support for the DW master SPI controller in the config header for the SoCFPGA. This controller can only be enabled, if DT support is enabled.
Signed-off-by: Stefan Roese sr@denx.de Cc: Chin Liang See clsee@altera.com Cc: Dinh Nguyen dinguyen@altera.com Cc: Vince Bridgers vbridger@altera.com Cc: Marek Vasut marex@denx.de Cc: Pavel Machek pavel@denx.de --- include/configs/socfpga_common.h | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 9fc4212..830b956 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -191,6 +191,18 @@ unsigned int cm_get_qspi_controller_clk_hz(void); #define CONFIG_CMD_SF #endif
+#ifdef CONFIG_OF_CONTROL /* DW SPI is controlled via DT */ +#define CONFIG_CMD_DM +#define CONFIG_DM +#define CONFIG_DM_SPI +#define CONFIG_DESIGNWARE_SPI +#ifndef __ASSEMBLY__ +unsigned int cm_get_spi_controller_clk_hz(void); +#define CONFIG_DW_SPI_REF_CLK cm_get_spi_controller_clk_hz() +#endif +#define CONFIG_CMD_SPI +#endif + /* * Serial Driver */
Putting prototypes into configuration file is ugly. Hiding function call into macro so that it looks like constant is evil. Is there better solution? Pavel
The SPI driver should call this function directly. Or is there a reason why such a macro is used ?
Historically. I'll check it again and will implement it differently in the next version. Tomorrow or on Monday.
Thanks, Stefan
Roger. Thank you!
Pavel Machek
Stefan Roese
