[U-Boot] [PATCH] mtd: nand: arasan_nfc: Correct nand ecc initialization
Correct the nand ecc initialization code This fixes the issue of incorrect nand ecc init if no device is found in ecc_matrix then it endsup ecc init with junk initialization instead of the most suited one.
Signed-off-by: Siva Durga Prasad Paladugu sivadur@xilinx.com --- drivers/mtd/nand/arasan_nfc.c | 18 +++++++++--------- 1 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/drivers/mtd/nand/arasan_nfc.c b/drivers/mtd/nand/arasan_nfc.c index 2d73a05..caa7982 100644 --- a/drivers/mtd/nand/arasan_nfc.c +++ b/drivers/mtd/nand/arasan_nfc.c @@ -1058,20 +1058,20 @@ static int arasan_nand_ecc_init(struct mtd_info *mtd) if (found < 0) return 1;
- regval = ecc_matrix[i].eccaddr | - (ecc_matrix[i].eccsize << ARASAN_NAND_ECC_SIZE_SHIFT) | - (ecc_matrix[i].bch << ARASAN_NAND_ECC_BCH_SHIFT); + regval = ecc_matrix[found].eccaddr | + (ecc_matrix[found].eccsize << ARASAN_NAND_ECC_SIZE_SHIFT) | + (ecc_matrix[found].bch << ARASAN_NAND_ECC_BCH_SHIFT); writel(regval, &arasan_nand_base->ecc_reg);
- if (ecc_matrix[i].bch) { + if (ecc_matrix[found].bch) { regval = readl(&arasan_nand_base->memadr_reg2); regval &= ~ARASAN_NAND_MEM_ADDR2_BCH_MASK; - regval |= (ecc_matrix[i].bchval << + regval |= (ecc_matrix[found].bchval << ARASAN_NAND_MEM_ADDR2_BCH_SHIFT); writel(regval, &arasan_nand_base->memadr_reg2); }
- nand_oob.eccbytes = ecc_matrix[i].eccsize; + nand_oob.eccbytes = ecc_matrix[found].eccsize; eccpos_start = mtd->oobsize - nand_oob.eccbytes;
for (i = 0; i < nand_oob.eccbytes; i++) @@ -1080,9 +1080,9 @@ static int arasan_nand_ecc_init(struct mtd_info *mtd) nand_oob.oobfree[0].offset = 2; nand_oob.oobfree[0].length = eccpos_start - 2;
- nand_chip->ecc.size = ecc_matrix[i].ecc_codeword_size; - nand_chip->ecc.strength = ecc_matrix[i].eccbits; - nand_chip->ecc.bytes = ecc_matrix[i].eccsize; + nand_chip->ecc.size = ecc_matrix[found].ecc_codeword_size; + nand_chip->ecc.strength = ecc_matrix[found].eccbits; + nand_chip->ecc.bytes = ecc_matrix[found].eccsize; nand_chip->ecc.layout = &nand_oob;
- regval = ecc_matrix[found].eccaddr |
writel(regval, &arasan_nand_base->ecc_reg);(ecc_matrix[found].bch << ARASAN_NAND_ECC_BCH_SHIFT);
- if (ecc_matrix[found].bch) { regval = readl(&arasan_nand_base->memadr_reg2); regval &= ~ARASAN_NAND_MEM_ADDR2_BCH_MASK;
writel(regval, &arasan_nand_base->memadr_reg2); }regval |= (ecc_matrix[found].bchval << ARASAN_NAND_MEM_ADDR2_BCH_SHIFT);
Tested-by: Michal Simek michal.simek@xilinx.com
Thanks, Michal
Michal Simek
