[U-Boot] [PATCH] ubi: reset relevant globals in ubi_exit()
Before calling ubi_init() the U-Boot wrapper calls ubi_mtd_param_parse() to have the UBI driver add it to its mtd_dev_param[] array and increment mtd_devs. The first time ubi_init() is called, mtd_devs would be 1.
Before ubi_init() is called again (another partition is attached), ubi_mtd_param_parse() is called again, incrementing mtd_devs again (now 2). This results in ubi_init() now trying to attach the first partition and the second partition.
Fix this by adding a section at the end of ubi_exit() where we reset any globals that would need to be reset (in this case, just mtd_devs).
Test case: $ ubi part <mtdname> ; ubi part <mtdname>
Before patch:
$ ubi part data UBI: attaching mtd1 to ubi0 UBI: scanning is finished UBI: attached mtd1 (name "mtd=4", size 4 MiB) to ubi0 [...] UBI: available PEBs: 0, total reserved PEBs: 32, [...] $ ubi part data UBI: detaching mtd1 from ubi0 UBI: mtd1 is detached from ubi0 UBI: attaching mtd1 to ubi0 [...] UBI: available PEBs: 0, total reserved PEBs: 32, [...] ** Note that this is where it tries to attach mtd1 again, fails, and ** then detaches everything as it errors out of ubi_init() UBI: detaching mtd1 from ubi0 UBI: mtd1 is detached from ubi0 UBI init error 17 $
After patch:
$ ubi part data UBI: attaching mtd1 to ubi0 UBI: scanning is finished UBI: attached mtd1 (name "mtd=4", size 4 MiB) to ubi0 [...] UBI: available PEBs: 0, total reserved PEBs: 32, [...] $ ubi part data UBI: detaching mtd1 from ubi0 UBI: mtd1 is detached from ubi0 UBI: attaching mtd1 to ubi0 UBI: scanning is finished UBI: attached mtd1 (name "mtd=4", size 4 MiB) to ubi0 [...] UBI: available PEBs: 0, total reserved PEBs: 32, [...] $
Signed-off-by: Andrew Ruder andrew.ruder@elecsyscorp.com Cc: Heiko Schocher hs@denx.de Cc: Kyungmin Park kmpark@infradead.org --- drivers/mtd/ubi/build.c | 4 ++++ 1 file changed, 4 insertions(+)
Not sure this is the best place to make the change, but it is one of the least obtrusive, IMO. Please Cc: me on any responses as it will go directly to my inbox!
diff --git a/drivers/mtd/ubi/build.c b/drivers/mtd/ubi/build.c index 584cf5f..fc5cbce 100644 --- a/drivers/mtd/ubi/build.c +++ b/drivers/mtd/ubi/build.c @@ -1384,6 +1384,10 @@ void ubi_exit(void) misc_deregister(&ubi_ctrl_cdev); class_remove_file(ubi_class, &ubi_version); class_destroy(ubi_class); +#ifdef __UBOOT__ + /* Reset any globals that the driver depends on being zeroed */ + mtd_devs = 0; +#endif } module_exit(ubi_exit);
Hello Andrew,
Am 13.11.2014 18:05, schrieb Andrew Ruder:
Before patch:
After patch:
- /* Reset any globals that the driver depends on being zeroed */
- mtd_devs = 0;
Good catch, but wondering, why this not poped up in my tests, as I did such a test ... Hmm... trying currently on the tqm5200s board on a cfi nor flash [1] shows no error for me. But I just activated ubi errormessages and broke the board ... so I must wait for a debugger :-(
Beside of this, your patch seems feasible, I test it soon.
bye, Heiko
[1] log on the tqm5200s board: => mtdparts
device nor0 <fc000000.flash>, # parts = 7 #: name size offset mask_flags 0: firmware 0x00100000 0x00000000 0 1: dtb 0x00040000 0x00100000 0 2: kernel 0x00240000 0x00140000 0 3: small-fs 0x00280000 0x00380000 0 4: initrd 0x00200000 0x00600000 0 5: misc 0x00800000 0x00800000 0 6: big-fs 0x01000000 0x01000000 0
active partition: nor0,0 - (firmware) 0x00100000 @ 0x00000000
defaults: mtdids : nor0=fc000000.flash mtdparts: mtdparts=fc000000.flash:1m(firmware),256k(dtb),2304k(kernel),2560k(small-fs),2m(initrd),8m(misc),16m(big-fs) => ubi part misc UBI: default fastmap pool size: 8 UBI: default fastmap WL pool size: 25 UBI: attaching mtd1 to ubi0 UBI: scanning is finished UBI: empty MTD device detected UBI: attached mtd1 (name "mtd=5", size 8 MiB) to ubi0 UBI: PEB size: 262144 bytes (256 KiB), LEB size: 262016 bytes UBI: min./max. I/O unit sizes: 1/1, sub-page size 1 UBI: VID header offset: 64 (aligned 64), data offset: 128 UBI: good PEBs: 32, bad PEBs: 0, corrupted PEBs: 0 UBI: user volume: 0, internal volumes: 1, max. volumes count: 128 UBI: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 0 UBI: available PEBs: 26, total reserved PEBs: 6, PEBs reserved for bad PEB handling: 0 => ubi info l Volume information dump: vol_id 2147479551 reserved_pebs 2 alignment 1 data_pad 0 vol_type 3 name_len 13 usable_leb_size 262016 used_ebs 2 used_bytes 524032 last_eb_bytes 2 corrupted 0 upd_marker 0 name layout volume => ubi info UBI: MTD device name: "mtd=5" UBI: MTD device size: 8 MiB UBI: physical eraseblock size: 262144 bytes (256 KiB) UBI: logical eraseblock size: 262016 bytes UBI: number of good PEBs: 32 UBI: number of bad PEBs: 0 UBI: smallest flash I/O unit: 1 UBI: VID header offset: 64 (aligned 64) UBI: data offset: 128 UBI: max. allowed volumes: 128 UBI: wear-leveling threshold: 4096 UBI: number of internal volumes: 1 UBI: number of user volumes: 0 UBI: available PEBs: 26 UBI: total number of reserved PEBs: 6 UBI: number of PEBs reserved for bad PEB handling: 0 UBI: max/mean erase counter: 1/0 => ubi create test 400000 Creating dynamic volume test of size 4194304 => ubi info l Volume information dump: vol_id 0 reserved_pebs 17 alignment 1 data_pad 0 vol_type 3 name_len 4 usable_leb_size 262016 used_ebs 17 used_bytes 4454272 last_eb_bytes 262016 corrupted 0 upd_marker 0 name test Volume information dump: vol_id 2147479551 reserved_pebs 2 alignment 1 data_pad 0 vol_type 3 name_len 13 usable_leb_size 262016 used_ebs 2 used_bytes 524032 last_eb_bytes 2 corrupted 0 upd_marker 0 name layout volume => ubi part misc UBI: detaching mtd1 from ubi0 UBI: mtd1 is detached from ubi0 UBI: default fastmap pool size: 8 UBI: default fastmap WL pool size: 25 UBI: attaching mtd1 to ubi0 UBI: scanning is finished UBI: attached mtd1 (name "mtd=5", size 8 MiB) to ubi0 UBI: PEB size: 262144 bytes (256 KiB), LEB size: 262016 bytes UBI: min./max. I/O unit sizes: 1/1, sub-page size 1 UBI: VID header offset: 64 (aligned 64), data offset: 128 UBI: good PEBs: 32, bad PEBs: 0, corrupted PEBs: 0 UBI: user volume: 1, internal volumes: 1, max. volumes count: 128 UBI: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0 UBI: available PEBs: 9, total reserved PEBs: 23, PEBs reserved for bad PEB handling: 0 => ubi part misc UBI: detaching mtd1 from ubi0 UBI: mtd1 is detached from ubi0 UBI: default fastmap pool size: 8 UBI: default fastmap WL pool size: 25 UBI: attaching mtd1 to ubi0 UBI: scanning is finished UBI: attached mtd1 (name "mtd=5", size 8 MiB) to ubi0 UBI: PEB size: 262144 bytes (256 KiB), LEB size: 262016 bytes UBI: min./max. I/O unit sizes: 1/1, sub-page size 1 UBI: VID header offset: 64 (aligned 64), data offset: 128 UBI: good PEBs: 32, bad PEBs: 0, corrupted PEBs: 0 UBI: user volume: 1, internal volumes: 1, max. volumes count: 128 UBI: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0 UBI: available PEBs: 9, total reserved PEBs: 23, PEBs reserved for bad PEB handling: 0 => ubi part misc UBI: detaching mtd1 from ubi0 UBI: mtd1 is detached from ubi0 UBI: default fastmap pool size: 8 UBI: default fastmap WL pool size: 25 UBI: attaching mtd1 to ubi0 UBI: scanning is finished UBI: attached mtd1 (name "mtd=5", size 8 MiB) to ubi0 UBI: PEB size: 262144 bytes (256 KiB), LEB size: 262016 bytes UBI: min./max. I/O unit sizes: 1/1, sub-page size 1 UBI: VID header offset: 64 (aligned 64), data offset: 128 UBI: good PEBs: 32, bad PEBs: 0, corrupted PEBs: 0 UBI: user volume: 1, internal volumes: 1, max. volumes count: 128 UBI: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0 UBI: available PEBs: 9, total reserved PEBs: 23, PEBs reserved for bad PEB handling: 0 =>
bye, Heiko
Hello Andrew,
Am 14.11.2014 14:31, schrieb Andrew Ruder:
Are you on 2014.10? I don't think this issue existed on the 2014.07-rc3 I was using earlier.
Yes, I tested currently with current mainline ...
bye, Heiko
Hello Andrew,
Am 17.11.2014 07:21, schrieb Heiko Schocher:
Hello Andrew,
Could you please test on your hw with current ML? I could not see this problem, but maybe I have another setup ... thanks!
bye, Heiko
Andrew Ruder
Heiko Schocher
