[U-Boot] Please pull fsl-qoriq master
Tom,
The following changes since commit 1fb8d7933924aa5deb7e722d64c1d9fc7f0b2b82:
Merge git://git.denx.de/u-boot-x86 (2015-09-17 17:00:08 -0400)
git://git.denx.de/u-boot-fsl-qoriq.git master
for you to fetch changes up to a857d5f835c53f7b66de61b19120ea1188e94999:
drivers/net/vsc9953: Add GPL-2.0+ SPDX-License-Identifier (2015-09-21 08:29:48 -0700)
---------------------------------------------------------------- Codrin Ciubotariu (16): drivers/net/vsc9953: Remove 'CONFIG_' from macros' name drivers/net/vsc9953: Cleanup patch drivers/net/vsc9953: Fix bug when enabling a port drivers/net/vsc9953: Fix missing reserved register include/bitfield: Add new bitfield operations drivers/net/vsc9953: Add default configuration for VSC9953 L2 Switch common/cmd_ethsw: Add generic commands for Ethernet Switches drivers/net/vsc9953: Use the generic Ethernet Switch parser drivers/net/vsc9953: Add command to show/clear port counters drivers/net/vsc9953: Add commands to enable/disable HW learning common/env_flags.c: Add function to validate a MAC address drivers/net/vsc9953: Add commands to manipulate the FDB for VSC9953 drivers/net/vsc9953: Add VLAN commands for VSC9953 drivers/net/vsc9953: Add command for shared/private VLAN learning drivers/net/vsc9953: Add commands for VLAN ingress filtering drivers/net/vsc9953: Add GPL-2.0+ SPDX-License-Identifier
common/Makefile | 1 + common/cmd_ethsw.c | 1027 ++++++++++++++++++++ common/env_flags.c | 40 +- drivers/net/vsc9953.c | 2246 +++++++++++++++++++++++++++++++++++++++----- include/bitfield.h | 32 + include/configs/T104xRDB.h | 2 +- include/env_flags.h | 7 + include/ethsw.h | 95 ++ include/vsc9953.h | 389 ++++++-- 9 files changed, 3504 insertions(+), 335 deletions(-) create mode 100644 common/cmd_ethsw.c create mode 100644 include/ethsw.h
Thanks.
York
On Tue, Sep 22, 2015 at 08:01:36AM -0700, York Sun wrote:
Tom,
York Sun
