[U-Boot] [PATCH v4] cmd_sf: let "sf update" preserve the final part of the last sector
From: Gerlando Falauto gerlando.falauto@keymile.com
Since "sf update" erases the last block as a whole, but only rewrites the meaningful initial part of it, the rest would be left erased, potentially erasing meaningful information. So, as a safety measure, have it rewrite the original content.
Signed-off-by: Gerlando Falauto gerlando.falauto@keymile.com Cc: Valentin Longchamp valentin.longchamp@keymile.com Cc: Holger Brunck holger.brunck@keymile.com Acked-by: Simon Glass sjg@chromium.org Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- Changes for v4: - Rebase to current tree - Fix one checkpatch warning
common/cmd_sf.c | 13 ++++++++++++- 1 file changed, 12 insertions(+), 1 deletion(-)
diff --git a/common/cmd_sf.c b/common/cmd_sf.c index 4af0f0a..3f60979 100644 --- a/common/cmd_sf.c +++ b/common/cmd_sf.c @@ -152,8 +152,10 @@ static const char *spi_flash_update_block(struct spi_flash *flash, u32 offset, { debug("offset=%#x, sector_size=%#x, len=%#zx\n", offset, flash->sector_size, len); - if (spi_flash_read(flash, offset, len, cmp_buf)) + /* Read the entire sector so to allow for rewriting */ + if (spi_flash_read(flash, offset, flash->sector_size, cmp_buf)) return "read"; + /* Compare only what is meaningful (len) */ if (memcmp(cmp_buf, buf, len) == 0) { debug("Skip region %x size %zx: no change\n", offset, len); @@ -163,8 +165,17 @@ static const char *spi_flash_update_block(struct spi_flash *flash, u32 offset, /* Erase the entire sector */ if (spi_flash_erase(flash, offset, flash->sector_size)) return "erase"; + /* Write the initial part of the block from the source */ if (spi_flash_write(flash, offset, len, buf)) return "write"; + /* If it's a partial sector, rewrite the existing part */ + if (len != flash->sector_size) { + /* Rewrite the original data to the end of the sector */ + if (spi_flash_write(flash, offset + len, + flash->sector_size - len, &cmp_buf[len])) + return "write"; + } + return NULL; }
Changes for v4:
- /* Read the entire sector so to allow for rewriting */
- if (spi_flash_read(flash, offset, flash->sector_size, cmp_buf)) return "read";
- /* Compare only what is meaningful (len) */ if (memcmp(cmp_buf, buf, len) == 0) { debug("Skip region %x size %zx: no change\n", offset, len);
- /* Write the initial part of the block from the source */ if (spi_flash_write(flash, offset, len, buf)) return "write";
- /* If it's a partial sector, rewrite the existing part */
- if (len != flash->sector_size) {
return "write";
- return NULL; }
Applied to u-boot-spi/master
-- Thanks, Jagan.
Jagan Teki
