[U-Boot] booting the kernel
Hi, Im trying to boot the linux kernel with uboot and it just hangs so I tried the instructions in the Linux PostMortem FAQ entry.
I'd like to know if I could be doing something obviously wrong here:
the kernel I use is for freescale imx31_litekit. I've booted it using the logicpd loader so I know it works.
I use the arch/arm/boot/Image with mkimage like this:
mkimage -A arm -O linux -T kernel -C none -a 86000000 -e 86000000 -d Image image.bin
are the load address and entry point ok? if not how can I determine which value they should have?
I tftp it to 0x81000000 like this:
tftp 0x81000000 /tftpboot/image.bin
that works fine
then I bootm
it loads the kernel and ends up printing:
Starting kernel ...
and hangs there, if I use my jtag I can see that the core is running ie: it doesnt crash. Btw I've also tried with the jtag attached so thats not the problem.
__log_buf in my System.map is at c035c168 and CONFIG_KERNEL_START is c0000000
so am I right to do
md 8635c168 ?
there doesnt seem to be anything interesting around this address...
what else could I try to figure out why the kernel isnt booting?
thanks a lot. -M
Sorry, I don't know.
Starting kernel ...
Do you have a console configured and enabled?
so am I right to do
md 8635c168 ?
Try 0035c168 - I'm not a arm-man, but the linux kernel traditionally relocates itself at location 00000000 and remaps itself to the virtual address c0000000. When you are looking with the debugger, you need to drop the "c" to get the physical address.
thanks a lot. -M
HTH, gvb
Hello Mathieu
2008/10/21 Mathieu Dube mathieu@mobilefusioninc.com:
^^^^ ^^^^ Double check these addresses. The convention is to load the Linux kernel at the base of physical RAM plus an offset of 0x8000 (32K), which allows enough room for the parameters area (typically placed at offset 0x100), page exception vectors and page tables.
Jerry Van Baren
Mathieu Dube
Roman Mashak
