[U-Boot] [PATCH v5 5/5] mips: ath79: add AP121 reference board
Signed-off-by: Wills Wang wills.wang@live.com ---
Changes in v5: - Move CONFIG_SYS_TEXT_BASE into ap121.h, and remove config.mk - Remove useless README file - Remove useless checkboard function
Changes in v4: None Changes in v3: - Add support for device tree
Changes in v2: - Add a reference board implemention
arch/mips/dts/Makefile | 2 +- arch/mips/dts/ap121.dts | 37 +++++++++++++++++++ arch/mips/dts/ar933x.dtsi | 64 ++++++++++++++++++++++++++++++++ board/ath79/ap121/Kconfig | 9 +++++ board/ath79/ap121/MAINTAINERS | 6 +++ board/ath79/ap121/Makefile | 8 ++++ board/ath79/ap121/ap121.c | 6 +++ configs/ap121_defconfig | 40 ++++++++++++++++++++ include/configs/ap121.h | 86 +++++++++++++++++++++++++++++++++++++++++++ 9 files changed, 257 insertions(+), 1 deletion(-) create mode 100644 arch/mips/dts/ap121.dts create mode 100644 arch/mips/dts/ar933x.dtsi create mode 100644 board/ath79/ap121/Kconfig create mode 100644 board/ath79/ap121/MAINTAINERS create mode 100644 board/ath79/ap121/Makefile create mode 100644 board/ath79/ap121/ap121.c create mode 100644 configs/ap121_defconfig create mode 100644 include/configs/ap121.h
diff --git a/arch/mips/dts/Makefile b/arch/mips/dts/Makefile index 47b6eb5..3fd49eb 100644 --- a/arch/mips/dts/Makefile +++ b/arch/mips/dts/Makefile @@ -2,7 +2,7 @@ # SPDX-License-Identifier: GPL-2.0+ #
-dtb-y += +dtb-$(CONFIG_BOARD_AP121) += ap121.dtb
targets += $(dtb-y)
diff --git a/arch/mips/dts/ap121.dts b/arch/mips/dts/ap121.dts new file mode 100644 index 0000000..f7c3a1a --- /dev/null +++ b/arch/mips/dts/ap121.dts @@ -0,0 +1,37 @@ +/dts-v1/; +#include "ar933x.dtsi" + +/ { + model = "AP121 Reference Board"; + compatible = "qca,ap121", "qca,ar933x"; + + aliases { + spi0 = &spi0; + serial0 = &uart0; + }; + + chosen { + stdout-path = "serial0:115200n8"; + }; +}; + +&xtal { + clock-frequency = <25000000>; +}; + +&uart0 { + status = "okay"; +}; + +&spi0 { + spi-max-frequency = <25000000>; + status = "okay"; + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + memory-map = <0x9f000000 0x00800000>; + spi-max-frequency = <25000000>; + reg = <0>; + }; +}; diff --git a/arch/mips/dts/ar933x.dtsi b/arch/mips/dts/ar933x.dtsi new file mode 100644 index 0000000..05cc165 --- /dev/null +++ b/arch/mips/dts/ar933x.dtsi @@ -0,0 +1,64 @@ +#include "skeleton.dtsi" + +/ { + compatible = "qca,ar933x"; + + #address-cells = <1>; + #size-cells = <1>; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + device_type = "cpu"; + compatible = "mips,mips24Kc"; + reg = <0>; + }; + }; + + clocks { + #address-cells = <1>; + #size-cells = <1>; + ranges; + + xtal: xtal { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-output-names = "xtal"; + }; + }; + + ahb { + compatible = "simple-bus"; + ranges; + + #address-cells = <1>; + #size-cells = <1>; + + apb { + compatible = "simple-bus"; + ranges; + + #address-cells = <1>; + #size-cells = <1>; + + uart0: uart@18020000 { + compatible = "qca,ar9330-uart"; + reg = <0x18020000 0x20>; + + status = "disabled"; + }; + }; + + spi0: spi@1f000000 { + compatible = "qca,ar7100-spi"; + reg = <0x1f000000 0x10>; + + status = "disabled"; + + #address-cells = <1>; + #size-cells = <0>; + }; + }; +}; diff --git a/board/ath79/ap121/Kconfig b/board/ath79/ap121/Kconfig new file mode 100644 index 0000000..ec72914 --- /dev/null +++ b/board/ath79/ap121/Kconfig @@ -0,0 +1,9 @@ +if BOARD_AP121 + +config SYS_BOARD + default "ap121" + +config SYS_CONFIG_NAME + default "ap121" + +endif diff --git a/board/ath79/ap121/MAINTAINERS b/board/ath79/ap121/MAINTAINERS new file mode 100644 index 0000000..319b521 --- /dev/null +++ b/board/ath79/ap121/MAINTAINERS @@ -0,0 +1,6 @@ +AP121 BOARD +M: Wills Wang wills.wang@live.com +S: Maintained +F: board/ath79/ap121/ +F: include/configs/ap121.h +F: configs/ap121_defconfig diff --git a/board/ath79/ap121/Makefile b/board/ath79/ap121/Makefile new file mode 100644 index 0000000..9132118 --- /dev/null +++ b/board/ath79/ap121/Makefile @@ -0,0 +1,8 @@ +# +# (C) Copyright 2003-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y = ap121.o diff --git a/board/ath79/ap121/ap121.c b/board/ath79/ap121/ap121.c new file mode 100644 index 0000000..4f09768 --- /dev/null +++ b/board/ath79/ap121/ap121.c @@ -0,0 +1,6 @@ +/* + * (C) Copyright 2015 + * Wills Wang, wills.wang@live.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ diff --git a/configs/ap121_defconfig b/configs/ap121_defconfig new file mode 100644 index 0000000..04ef85e --- /dev/null +++ b/configs/ap121_defconfig @@ -0,0 +1,40 @@ +CONFIG_MIPS=y +CONFIG_ARCH_ATH79=y +CONFIG_BOARD_AP121=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_DM_SERIAL=y +CONFIG_DM_SPI=y +CONFIG_DM_SPI_FLASH=y +CONFIG_DEFAULT_DEVICE_TREE="ap121" +CONFIG_SYS_PROMPT="ap121 # " +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_CRC32 is not set +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +# CONFIG_CMD_FPGA is not set +# CONFIG_CMD_NET is not set +# CONFIG_CMD_NFS is not set +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_ATMEL=y +CONFIG_SPI_FLASH_EON=y +CONFIG_SPI_FLASH_GIGADEVICE=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_SPANSION=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_SST=y +CONFIG_SPI_FLASH_WINBOND=y +CONFIG_SPI_FLASH_DATAFLASH=y +CONFIG_SPI_FLASH_MTD=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_AR933X=y +CONFIG_DEBUG_UART_BASE=0x18020000 +CONFIG_DEBUG_UART_CLOCK=25000000 diff --git a/include/configs/ap121.h b/include/configs/ap121.h new file mode 100644 index 0000000..21fb04e --- /dev/null +++ b/include/configs/ap121.h @@ -0,0 +1,86 @@ +#ifndef __CONFIG_H +#define __CONFIG_H + +#include <linux/sizes.h> + +#define CONFIG_SYS_TEXT_BASE 0x9f000000 + +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO +#define CONFIG_BOARD_EARLY_INIT_F + +#define CONFIG_SYS_HZ 1000 +#define CONFIG_SYS_MHZ 200 +#define CONFIG_SYS_MIPS_TIMER_FREQ (CONFIG_SYS_MHZ * 1000000) + +/* Cache Configuration */ +#define CONFIG_SYS_DCACHE_SIZE SZ_32K +#define CONFIG_SYS_ICACHE_SIZE SZ_64K +#define CONFIG_SYS_CACHELINE_SIZE 32 + +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE + +#define CONFIG_SYS_MALLOC_LEN SZ_256K +#define CONFIG_SYS_BOOTPARAMS_LEN SZ_128K + +#define CONFIG_SYS_SDRAM_BASE 0x80000000 +#define CONFIG_SYS_LOAD_ADDR 0x81000000 + +#define CONFIG_SYS_NO_FLASH + +#define CONFIG_SYS_INIT_RAM_ADDR 0xbd000000 +#define CONFIG_SYS_INIT_RAM_SIZE SZ_32K + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE \ + {9600, 19200, 38400, 57600, 115200} + +#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTARGS "console=ttyS0,115200 " \ + "root=/dev/mtdblock2 " \ + "rootfstype=squashfs" +#define CONFIG_BOOTCOMMAND "sf probe;" \ + "mtdparts default;" \ + "bootm 0x9f300000" +#define CONFIG_LZMA +#define CONFIG_OF_LIBFDT + +#define MTDIDS_DEFAULT "nor0=spi-flash.0" +#define MTDPARTS_DEFAULT "mtdparts=spi-flash.0:" \ + "256k(u-boot),64k(u-boot-env)," \ + "2752k(rootfs),896k(uImage)," \ + "64k(NVRAM),64k(ART)" + +#define CONFIG_ENV_SPI_MAX_HZ 25000000 +#define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_OFFSET SZ_256K +#define CONFIG_ENV_SECT_SIZE SZ_64K +#define CONFIG_ENV_SIZE SZ_64K + +/* + * Command + */ +#define CONFIG_CMD_MTDPARTS + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_LONGHELP +#define CONFIG_CMDLINE_EDITING +#define CONFIG_AUTO_COMPLETE + +/* + * Diagnostics + */ +#define CONFIG_SYS_MEMTEST_START 0x80100000 +#define CONFIG_SYS_MEMTEST_END 0x83f00000 +#define CONFIG_CMD_MEMTEST + +#endif /* __CONFIG_H */
Am 29.12.2015 um 12:17 schrieb Wills Wang:
Changes in v5:
Changes in v2:
targets += $(dtb-y)
- model = "AP121 Reference Board";
- compatible = "qca,ap121", "qca,ar933x";
- aliases {
spi0 = &spi0;
serial0 = &uart0;
- chosen {
+&xtal {
- clock-frequency = <25000000>;
+&uart0 {
- status = "okay";
+&spi0 {
- spi-max-frequency = <25000000>;
- status = "okay";
- spi-flash@0 {
#size-cells = <1>;
reg = <0>;
- compatible = "qca,ar933x";
- #address-cells = <1>;
- #size-cells = <1>;
- cpus {
#size-cells = <0>;
cpu@0 {
reg = <0>;
- clocks {
#size-cells = <1>;
ranges;
xtal: xtal {
#clock-cells = <0>;
- ahb {
ranges;
#size-cells = <1>;
apb {
ranges;
#size-cells = <1>;
#size-cells = <0>;
+config SYS_BOARD
- default "ap121"
- default "ap121"
- (C) Copyright 2015
- Wills Wang, wills.wang@live.com
you wrote that without these values, your board will not boot. But it should on a MIPS 24Kc core. The kernel also works with auto-detected values. Please try again with this patch series. I would like to remove the cache code in the future, that depends on manually configured sizes.
please use hexadecimal numbers instead of SZ_* macros. All those options are eventually converted to Kconfig symbols of type hex.
- (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
- (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
you only need
#define CONFIG_SYS_INIT_SP_ADDR \ (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_RAM_SIZE - 1)
The space for global_data is automatically reserved in start.S above the stack pointer
- {9600, 19200, 38400, 57600, 115200}
"bootm 0x9f300000"
- Command
- Diagnostics
+/* Cache Configuration */ +#define CONFIG_SYS_DCACHE_SIZE SZ_32K +#define CONFIG_SYS_ICACHE_SIZE SZ_64K +#define CONFIG_SYS_CACHELINE_SIZE 32 you wrote that without these values, your board will not boot. But it should on a MIPS 24Kc core. The kernel also works with auto-detected values. Please try again with this patch series. I would like to remove the cache code in the future, that depends on manually configured sizes.
I try it again, my board still don't work if remove these three lines.
Ok.
you only need
Ok.
Daniel Schwierzeck
Wills Wang
