[U-Boot] [PATCH 2/2] Kirkwood: OpenRD: Initialize MPPs during early init
This patch adds board_early_init_f function for OpenRD boards. The function initializes MPPs so that peripherals can work at early stage.
Signed-off-by: Tanmay Upadhyay tanmay.upadhyay@einfochips.com --- board/Marvell/openrd/openrd.c | 6 +++++- include/configs/openrd.h | 2 ++ 2 files changed, 7 insertions(+), 1 deletions(-)
diff --git a/board/Marvell/openrd/openrd.c b/board/Marvell/openrd/openrd.c index 3953282..2d34a24 100644 --- a/board/Marvell/openrd/openrd.c +++ b/board/Marvell/openrd/openrd.c @@ -41,7 +41,7 @@
DECLARE_GLOBAL_DATA_PTR;
-int board_init(void) +int board_early_init_f(void) { /* * default gpio configuration @@ -108,7 +108,11 @@ int board_init(void) };
kirkwood_mpp_conf(kwmpp_config); + return 0; +}
+int board_init(void) +{ /* * arch number of board */ diff --git a/include/configs/openrd.h b/include/configs/openrd.h index c4dcad6..850dbae 100644 --- a/include/configs/openrd.h +++ b/include/configs/openrd.h @@ -110,4 +110,6 @@ #define CONFIG_SYS_ATA_IDE1_OFFSET MV_SATA_PORT1_OFFSET #endif /*CONFIG_MVSATA_IDE*/
+/* board_early_init_f function in openrd.c initializes all MPP settings */ +#define CONFIG_BOARD_EARLY_INIT_F #endif /* _CONFIG_OPENRD_H */
Tanmay Upadhyay
