[U-Boot] [PATCH 1/5] ARM: mxs: Sort the mx23evk and mx23_olinuxino
These boards were not sortes in the boards.cfg, fix this.
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com Cc: Stefano Babic sbabic@denx.de Cc: Otavio Salvador otavio@ossystems.com.br --- boards.cfg | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/boards.cfg b/boards.cfg index 79d6cd8..5f961da 100644 --- a/boards.cfg +++ b/boards.cfg @@ -197,10 +197,10 @@ tx25 arm arm926ejs tx25 karo zmx25 arm arm926ejs zmx25 syteco mx25 imx27lite arm arm926ejs imx27lite logicpd mx27 magnesium arm arm926ejs imx27lite logicpd mx27 -mx23_olinuxino arm arm926ejs mx23_olinuxino olimex mxs mx23_olinuxino apx4devkit arm arm926ejs apx4devkit bluegiga mxs apx4devkit -mx23evk arm arm926ejs mx23evk freescale mxs mx23evk m28evk arm arm926ejs m28evk denx mxs m28evk +mx23_olinuxino arm arm926ejs mx23_olinuxino olimex mxs mx23_olinuxino +mx23evk arm arm926ejs mx23evk freescale mxs mx23evk mx28evk arm arm926ejs mx28evk freescale mxs mx28evk:ENV_IS_IN_MMC mx28evk_nand arm arm926ejs mx28evk freescale mxs mx28evk:ENV_IS_IN_NAND mx28evk_auart_console arm arm926ejs mx28evk freescale mxs mx28evk:MXS_AUART,MXS_AUART_BASE=MXS_UARTAPP3_BASE,ENV_IS_IN_MMC
This patch adds documentation for the functions used during the initialization of MXS power block.
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/cpu/arm926ejs/mxs/spl_power_init.c | 208 +++++++++++++++++++++++++++ 1 file changed, 208 insertions(+)
diff --git a/arch/arm/cpu/arm926ejs/mxs/spl_power_init.c b/arch/arm/cpu/arm926ejs/mxs/spl_power_init.c index e3b6cd9..32f6e53 100644 --- a/arch/arm/cpu/arm926ejs/mxs/spl_power_init.c +++ b/arch/arm/cpu/arm926ejs/mxs/spl_power_init.c @@ -14,6 +14,13 @@
#include "mxs_init.h"
+/** + * mxs_power_clock2xtal() - Switch CPU core clock source to 24MHz XTAL + * + * This function switches the CPU core clock from PLL to 24MHz XTAL + * oscilator. This is necessary if the PLL is being reconfigured to + * prevent crash of the CPU core. + */ static void mxs_power_clock2xtal(void) { struct mxs_clkctrl_regs *clkctrl_regs = @@ -24,6 +31,13 @@ static void mxs_power_clock2xtal(void) &clkctrl_regs->hw_clkctrl_clkseq_set); }
+/** + * mxs_power_clock2pll() - Switch CPU core clock source to PLL + * + * This function switches the CPU core clock from 24MHz XTAL oscilator + * to PLL. This can only be called once the PLL has re-locked and once + * the PLL is stable after reconfiguration. + */ static void mxs_power_clock2pll(void) { struct mxs_clkctrl_regs *clkctrl_regs = @@ -36,6 +50,12 @@ static void mxs_power_clock2pll(void) CLKCTRL_CLKSEQ_BYPASS_CPU); }
+/** + * mxs_power_clear_auto_restart() - Set the auto-restart bit + * + * This function ungates the RTC block and sets the AUTO_RESTART + * bit to work around a design bug on MX28EVK Rev. A . + */ static void mxs_power_clear_auto_restart(void) { struct mxs_rtc_regs *rtc_regs = @@ -69,6 +89,14 @@ static void mxs_power_clear_auto_restart(void) ; }
+/** + * mxs_power_set_linreg() - Set linear regulators 25mV below DC-DC converter + * + * This function configures the VDDIO, VDDA and VDDD linear regulators output + * to be 25mV below the VDDIO, VDDA and VDDD output from the DC-DC switching + * converter. This is the recommended setting for the case where we use both + * linear regulators and DC-DC converter to power the VDDIO rail. + */ static void mxs_power_set_linreg(void) { struct mxs_power_regs *power_regs = @@ -88,6 +116,11 @@ static void mxs_power_set_linreg(void) POWER_VDDIOCTRL_LINREG_OFFSET_1STEPS_BELOW); }
+/** + * mxs_get_batt_volt() - Measure battery input voltage + * + * This function retrieves the battery input voltage and returns it. + */ static int mxs_get_batt_volt(void) { struct mxs_power_regs *power_regs = @@ -99,11 +132,24 @@ static int mxs_get_batt_volt(void) return volt; }
+/** + * mxs_is_batt_ready() - Test if the battery provides enough voltage to boot + * + * This function checks if the battery input voltage is higher than 3.6V and + * therefore allows the system to successfully boot using this power source. + */ static int mxs_is_batt_ready(void) { return (mxs_get_batt_volt() >= 3600); }
+/** + * mxs_is_batt_good() - Test if battery is operational at all + * + * This function starts recharging the battery and tests if the input current + * provided by the 5V input recharging the battery is also sufficient to power + * the DC-DC converter. + */ static int mxs_is_batt_good(void) { struct mxs_power_regs *power_regs = @@ -144,6 +190,15 @@ static int mxs_is_batt_good(void) return 0; }
+/** + * mxs_power_setup_5v_detect() - Start the 5V input detection comparator + * + * This function enables the 5V detection comparator and sets the 5V valid + * threshold to 4.4V . We use 4.4V threshold here to make sure that even + * under high load, the voltage drop on the 5V input won't be so critical + * to cause undervolt on the 4P2 linear regulator supplying the DC-DC + * converter and thus making the system crash. + */ static void mxs_power_setup_5v_detect(void) { struct mxs_power_regs *power_regs = @@ -156,6 +211,12 @@ static void mxs_power_setup_5v_detect(void) POWER_5VCTRL_PWRUP_VBUS_CMPS); }
+/** + * mxs_src_power_init() - Preconfigure the power block + * + * This function configures reasonable values for the DC-DC control loop + * and battery monitor. + */ static void mxs_src_power_init(void) { struct mxs_power_regs *power_regs = @@ -187,6 +248,12 @@ static void mxs_src_power_init(void) clrbits_le32(&power_regs->hw_power_5vctrl, POWER_5VCTRL_DCDC_XFER); }
+/** + * mxs_power_init_4p2_params() - Configure the parameters of the 4P2 regulator + * + * This function configures the necessary parameters for the 4P2 linear + * regulator to supply the DC-DC converter from 5V input. + */ static void mxs_power_init_4p2_params(void) { struct mxs_power_regs *power_regs = @@ -211,6 +278,12 @@ static void mxs_power_init_4p2_params(void) 0x3f << POWER_5VCTRL_CHARGE_4P2_ILIMIT_OFFSET); }
+/** + * mxs_enable_4p2_dcdc_input() - Enable or disable the DCDC input from 4P2 + * @xfer: Select if the input shall be enabled or disabled + * + * This function enables or disables the 4P2 input into the DC-DC converter. + */ static void mxs_enable_4p2_dcdc_input(int xfer) { struct mxs_power_regs *power_regs = @@ -307,6 +380,12 @@ static void mxs_enable_4p2_dcdc_input(int xfer) POWER_CTRL_ENIRQ_VDD5V_DROOP); }
+/** + * mxs_power_init_4p2_regulator() - Start the 4P2 regulator + * + * This function enables the 4P2 regulator and switches the DC-DC converter + * to use the 4P2 input. + */ static void mxs_power_init_4p2_regulator(void) { struct mxs_power_regs *power_regs = @@ -391,6 +470,12 @@ static void mxs_power_init_4p2_regulator(void) writel(POWER_CTRL_DCDC4P2_BO_IRQ, &power_regs->hw_power_ctrl_clr); }
+/** + * mxs_power_init_dcdc_4p2_source() - Switch DC-DC converter to 4P2 source + * + * This function configures the DC-DC converter to be supplied from the 4P2 + * linear regulator. + */ static void mxs_power_init_dcdc_4p2_source(void) { struct mxs_power_regs *power_regs = @@ -413,6 +498,12 @@ static void mxs_power_init_dcdc_4p2_source(void) } }
+/** + * mxs_power_enable_4p2() - Power up the 4P2 regulator + * + * This function drives the process of powering up the 4P2 linear regulator + * and switching the DC-DC converter input over to the 4P2 linear regulator. + */ static void mxs_power_enable_4p2(void) { struct mxs_power_regs *power_regs = @@ -472,6 +563,14 @@ static void mxs_power_enable_4p2(void) &power_regs->hw_power_charge_clr); }
+/** + * mxs_boot_valid_5v() - Boot from 5V supply + * + * This function configures the power block to boot from valid 5V input. + * This is called only if the 5V is reliable and can properly supply the + * CPU. This function proceeds to configure the 4P2 converter to be supplied + * from the 5V input. + */ static void mxs_boot_valid_5v(void) { struct mxs_power_regs *power_regs = @@ -495,6 +594,11 @@ static void mxs_boot_valid_5v(void) mxs_power_enable_4p2(); }
+/** + * mxs_powerdown() - Shut down the system + * + * This function powers down the CPU completely. + */ static void mxs_powerdown(void) { struct mxs_power_regs *power_regs = @@ -504,6 +608,12 @@ static void mxs_powerdown(void) &power_regs->hw_power_reset); }
+/** + * mxs_batt_boot() - Configure the power block to boot from battery input + * + * This function configures the power block to boot from the battery voltage + * supply. + */ static void mxs_batt_boot(void) { struct mxs_power_regs *power_regs = @@ -548,6 +658,14 @@ static void mxs_batt_boot(void) 0x8 << POWER_5VCTRL_CHARGE_4P2_ILIMIT_OFFSET); }
+/** + * mxs_handle_5v_conflict() - Test if the 5V input is reliable + * + * This function tests if the 5V input can reliably supply the system. If it + * can, then proceed to configuring the system to boot from 5V source, otherwise + * try booting from battery supply. If we can not boot from battery supply + * either, shut down the system. + */ static void mxs_handle_5v_conflict(void) { struct mxs_power_regs *power_regs = @@ -584,6 +702,12 @@ static void mxs_handle_5v_conflict(void) } }
+/** + * mxs_5v_boot() - Configure the power block to boot from 5V input + * + * This function handles configuration of the power block when supplied by + * a 5V input. + */ static void mxs_5v_boot(void) { struct mxs_power_regs *power_regs = @@ -607,6 +731,12 @@ static void mxs_5v_boot(void) mxs_handle_5v_conflict(); }
+/** + * mxs_init_batt_bo() - Configure battery brownout threshold + * + * This function configures the battery input brownout threshold. The value + * at which the battery brownout happens is configured to 3.0V in the code. + */ static void mxs_init_batt_bo(void) { struct mxs_power_regs *power_regs = @@ -621,6 +751,12 @@ static void mxs_init_batt_bo(void) writel(POWER_CTRL_ENIRQ_BATT_BO, &power_regs->hw_power_ctrl_clr); }
+/** + * mxs_switch_vddd_to_dcdc_source() - Switch VDDD rail to DC-DC converter + * + * This function turns off the VDDD linear regulator and therefore makes + * the VDDD rail be supplied only by the DC-DC converter. + */ static void mxs_switch_vddd_to_dcdc_source(void) { struct mxs_power_regs *power_regs = @@ -635,6 +771,15 @@ static void mxs_switch_vddd_to_dcdc_source(void) POWER_VDDDCTRL_DISABLE_STEPPING); }
+/** + * mxs_power_configure_power_source() - Configure power block source + * + * This function is the core of the power configuration logic. The function + * selects the power block input source and configures the whole power block + * accordingly. After the configuration is complete and the system is stable + * again, the function switches the CPU clock source back to PLL. Finally, + * the function switches the voltage rails to DC-DC converter. + */ static void mxs_power_configure_power_source(void) { int batt_ready, batt_good; @@ -679,6 +824,15 @@ static void mxs_power_configure_power_source(void) #endif }
+/** + * mxs_enable_output_rail_protection() - Enable power rail protection + * + * This function enables overload protection on the power rails. This is + * triggered if the power rails' voltage drops rapidly due to overload and + * in such case, the supply to the powerrail is cut-off, protecting the + * CPU from damage. Note that under such condition, the system will likely + * crash or misbehave. + */ static void mxs_enable_output_rail_protection(void) { struct mxs_power_regs *power_regs = @@ -697,6 +851,13 @@ static void mxs_enable_output_rail_protection(void) POWER_VDDIOCTRL_PWDN_BRNOUT); }
+/** + * mxs_get_vddio_power_source_off() - Get VDDIO rail power source + * + * This function tests if the VDDIO rail is supplied by linear regulator + * or by the DC-DC converter. Returns 1 if powered by linear regulator, + * returns 0 if powered by the DC-DC converter. + */ static int mxs_get_vddio_power_source_off(void) { struct mxs_power_regs *power_regs = @@ -725,6 +886,13 @@ static int mxs_get_vddio_power_source_off(void)
+/** + * mxs_get_vddd_power_source_off() - Get VDDD rail power source + * + * This function tests if the VDDD rail is supplied by linear regulator + * or by the DC-DC converter. Returns 1 if powered by linear regulator, + * returns 0 if powered by the DC-DC converter. + */ static int mxs_get_vddd_power_source_off(void) { struct mxs_power_regs *power_regs = @@ -813,6 +981,18 @@ static const struct mxs_vddx_cfg mxs_vddmem_cfg = { }; #endif
+/** + * mxs_power_set_vddx() - Configure voltage on DC-DC converter rail + * @cfg: Configuration data of the DC-DC converter rail + * @new_target: New target voltage of the DC-DC converter rail + * @new_brownout: New brownout trigger voltage + * + * This function configures the output voltage on the DC-DC converter rail. + * The rail is selected by the @cfg argument. The new voltage target is + * selected by the @new_target and the voltage is specified in mV. The + * new brownout value is selected by the @new_brownout argument and the + * value is also in mV. + */ static void mxs_power_set_vddx(const struct mxs_vddx_cfg *cfg, uint32_t new_target, uint32_t new_brownout) { @@ -886,6 +1066,14 @@ static void mxs_power_set_vddx(const struct mxs_vddx_cfg *cfg, } }
+/** + * mxs_setup_batt_detect() - Start the battery voltage measurement logic + * + * This function starts and configures the LRADC block. This allows the + * power initialization code to measure battery voltage and based on this + * knowledge, decide whether to boot at all, boot from battery or boot + * from 5V input. + */ static void mxs_setup_batt_detect(void) { mxs_lradc_init(); @@ -893,6 +1081,14 @@ static void mxs_setup_batt_detect(void) early_delay(10); }
+/** + * mxs_ungate_power() - Ungate the POWER block + * + * This function ungates clock to the power block. In case the power block + * was still gated at this point, it will not be possible to configure the + * block and therefore the power initialization would fail. This function + * is only needed on i.MX233, on i.MX28 the power block is always ungated. + */ static void mxs_ungate_power(void) { #ifdef CONFIG_MX23 @@ -903,6 +1099,12 @@ static void mxs_ungate_power(void) #endif }
+/** + * mxs_power_init() - The power block init main function + * + * This function calls all the power block initialization functions in + * proper sequence to start the power block. + */ void mxs_power_init(void) { struct mxs_power_regs *power_regs = @@ -936,6 +1138,12 @@ void mxs_power_init(void) }
#ifdef CONFIG_SPL_MXS_PSWITCH_WAIT +/** + * mxs_power_wait_pswitch() - Wait for power switch to be pressed + * + * This function waits until the power-switch was pressed to start booting + * the board. + */ void mxs_power_wait_pswitch(void) { struct mxs_power_regs *power_regs =
We have already changed the name of mxs_power_clear_auto_restart() into mxs_power_set_auto_restart()
Applied after changing the name of the function to u-boot-imx, thanks !
Best regards, Stefano Babic
Make sure value in register r0 and r1 is preserved and passed to the board_init_ll() and mxs_common_spl_init() where it can be processed further. The value in r0 can be configured during the BootStream generation to arbitary value, r1 contains pointer to return value from CALL'd function.
This patch also clears the value in r0 before returning to BootROM to make sure the BootROM is not confused by this value.
Finally, this patch cleans up some comments in the start.S file.
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com Cc: Stefano Babic sbabic@denx.de --- arch/arm/cpu/arm926ejs/mxs/spl_boot.c | 5 +-- arch/arm/cpu/arm926ejs/mxs/start.S | 50 +++++++++++++++++------------ arch/arm/include/asm/arch-mxs/sys_proto.h | 5 +-- board/bluegiga/apx4devkit/spl_boot.c | 4 +-- board/denx/m28evk/spl_boot.c | 4 +-- board/freescale/mx23evk/spl_boot.c | 4 +-- board/freescale/mx28evk/iomux.c | 4 +-- board/olimex/mx23_olinuxino/spl_boot.c | 4 +-- board/schulercontrol/sc_sps_1/spl_boot.c | 4 +-- 9 files changed, 48 insertions(+), 36 deletions(-)
diff --git a/arch/arm/cpu/arm926ejs/mxs/spl_boot.c b/arch/arm/cpu/arm926ejs/mxs/spl_boot.c index 0392afd..68c30af 100644 --- a/arch/arm/cpu/arm926ejs/mxs/spl_boot.c +++ b/arch/arm/cpu/arm926ejs/mxs/spl_boot.c @@ -102,8 +102,9 @@ static uint8_t mxs_get_bootmode_index(void) return i; }
-void mxs_common_spl_init(const iomux_cfg_t *iomux_setup, - const unsigned int iomux_size) +void mxs_common_spl_init(const uint32_t arg, const uint32_t *resptr, + const iomux_cfg_t *iomux_setup, + const unsigned int iomux_size) { struct mxs_spl_data *data = (struct mxs_spl_data *) ((CONFIG_SYS_TEXT_BASE - sizeof(struct mxs_spl_data)) & ~0xf); diff --git a/arch/arm/cpu/arm926ejs/mxs/start.S b/arch/arm/cpu/arm926ejs/mxs/start.S index 94b2b3f..3e454ae 100644 --- a/arch/arm/cpu/arm926ejs/mxs/start.S +++ b/arch/arm/cpu/arm926ejs/mxs/start.S @@ -152,39 +152,49 @@ _reset: /* * Store all registers on old stack pointer, this will allow us later to * return to the BootROM and let the BootROM load U-Boot into RAM. + * + * WARNING: Register r0 and r1 are used by the BootROM to pass data + * to the called code. Register r0 will contain arbitrary + * data that are set in the BootStream. In case this code + * was started with CALL instruction, register r1 will contain + * pointer to the return value this function can then set. + * The code below MUST NOT CHANGE register r0 and r1 ! */ push {r0-r12,r14}
- /* save control register c1 */ - mrc p15, 0, r0, c1, c0, 0 - push {r0} + /* Save control register c1 */ + mrc p15, 0, r2, c1, c0, 0 + push {r2}
- /* - * set the cpu to SVC32 mode and store old CPSR register content - */ - mrs r0,cpsr - push {r0} - bic r0,r0,#0x1f - orr r0,r0,#0xd3 - msr cpsr,r0 + /* Set the cpu to SVC32 mode and store old CPSR register content. */ + mrs r2, cpsr + push {r2} + bic r2, r2, #0x1f + orr r2, r2, #0xd3 + msr cpsr, r2
bl board_init_ll
+ /* Restore BootROM's CPU mode (especially FIQ). */ + pop {r2} + msr cpsr,r2 + /* - * restore bootrom's cpu mode (especially FIQ) + * Restore c1 register. Especially set exception vector location + * back to BootROM space which is required by bootrom for USB boot. */ - pop {r0} - msr cpsr,r0 + pop {r2} + mcr p15, 0, r2, c1, c0, 0 + + pop {r0-r12,r14}
/* - * restore c1 register - * (especially set exception vector location back to - * bootrom space which is required by bootrom for USB boot) + * In case this code was started by the CALL instruction, the register + * r0 is examined by the BootROM after this code returns. The value in + * r0 must be set to 0 to indicate successful return. */ - pop {r0} - mcr p15, 0, r0, c1, c0, 0 + mov r0, #0
- pop {r0-r12,r14} bx lr
_hang: diff --git a/arch/arm/include/asm/arch-mxs/sys_proto.h b/arch/arm/include/asm/arch-mxs/sys_proto.h index 1038592..43c7dd6 100644 --- a/arch/arm/include/asm/arch-mxs/sys_proto.h +++ b/arch/arm/include/asm/arch-mxs/sys_proto.h @@ -28,8 +28,9 @@ int mxsmmc_initialize(bd_t *bis, int id, int (*wp)(int), int (*cd)(int)); #include <asm/arch/iomux-mx28.h> #endif
-void mxs_common_spl_init(const iomux_cfg_t *iomux_setup, - const unsigned int iomux_size); +void mxs_common_spl_init(const uint32_t arg, const uint32_t *resptr, + const iomux_cfg_t *iomux_setup, + const unsigned int iomux_size); #endif
struct mxs_pair { diff --git a/board/bluegiga/apx4devkit/spl_boot.c b/board/bluegiga/apx4devkit/spl_boot.c index 3b05baa..81419f9 100644 --- a/board/bluegiga/apx4devkit/spl_boot.c +++ b/board/bluegiga/apx4devkit/spl_boot.c @@ -132,9 +132,9 @@ const iomux_cfg_t iomux_setup[] = { MX28_PAD_EMI_CKE__EMI_CKE | MUX_CONFIG_EMI, };
-void board_init_ll(void) +void board_init_ll(const uint32_t arg, const uint32_t *resptr) { - mxs_common_spl_init(iomux_setup, ARRAY_SIZE(iomux_setup)); + mxs_common_spl_init(arg, resptr, iomux_setup, ARRAY_SIZE(iomux_setup));
/* switch LED on */ gpio_direction_output(MX28_PAD_PWM3__GPIO_3_28, 0); diff --git a/board/denx/m28evk/spl_boot.c b/board/denx/m28evk/spl_boot.c index 525ba6a..5a1010e 100644 --- a/board/denx/m28evk/spl_boot.c +++ b/board/denx/m28evk/spl_boot.c @@ -200,7 +200,7 @@ const iomux_cfg_t iomux_setup[] = { (MXS_PAD_3V3 | MXS_PAD_8MA | MXS_PAD_PULLUP), };
-void board_init_ll(void) +void board_init_ll(const uint32_t arg, const uint32_t *resptr) { - mxs_common_spl_init(iomux_setup, ARRAY_SIZE(iomux_setup)); + mxs_common_spl_init(arg, resptr, iomux_setup, ARRAY_SIZE(iomux_setup)); } diff --git a/board/freescale/mx23evk/spl_boot.c b/board/freescale/mx23evk/spl_boot.c index 054ca0a..603f4dc 100644 --- a/board/freescale/mx23evk/spl_boot.c +++ b/board/freescale/mx23evk/spl_boot.c @@ -129,7 +129,7 @@ void mxs_adjust_memory_params(uint32_t *dram_vals) dram_vals[HW_DRAM_CTL14] = HW_DRAM_CTL14_CONFIG; }
-void board_init_ll(void) +void board_init_ll(const uint32_t arg, const uint32_t *resptr) { - mxs_common_spl_init(iomux_setup, ARRAY_SIZE(iomux_setup)); + mxs_common_spl_init(arg, resptr, iomux_setup, ARRAY_SIZE(iomux_setup)); } diff --git a/board/freescale/mx28evk/iomux.c b/board/freescale/mx28evk/iomux.c index 6ca842b..97c2376 100644 --- a/board/freescale/mx28evk/iomux.c +++ b/board/freescale/mx28evk/iomux.c @@ -200,7 +200,7 @@ void mxs_adjust_memory_params(uint32_t *dram_vals) dram_vals[HW_DRAM_CTL29] = HW_DRAM_CTL29_CONFIG; }
-void board_init_ll(void) +void board_init_ll(const uint32_t arg, const uint32_t *resptr) { - mxs_common_spl_init(iomux_setup, ARRAY_SIZE(iomux_setup)); + mxs_common_spl_init(arg, resptr, iomux_setup, ARRAY_SIZE(iomux_setup)); } diff --git a/board/olimex/mx23_olinuxino/spl_boot.c b/board/olimex/mx23_olinuxino/spl_boot.c index 0a66303..5272dfa 100644 --- a/board/olimex/mx23_olinuxino/spl_boot.c +++ b/board/olimex/mx23_olinuxino/spl_boot.c @@ -85,7 +85,7 @@ const iomux_cfg_t iomux_setup[] = { (MXS_PAD_3V3 | MXS_PAD_12MA | MXS_PAD_NOPULL), };
-void board_init_ll(void) +void board_init_ll(const uint32_t arg, const uint32_t *resptr) { - mxs_common_spl_init(iomux_setup, ARRAY_SIZE(iomux_setup)); + mxs_common_spl_init(arg, resptr, iomux_setup, ARRAY_SIZE(iomux_setup)); } diff --git a/board/schulercontrol/sc_sps_1/spl_boot.c b/board/schulercontrol/sc_sps_1/spl_boot.c index 1fe9224..60195c3 100644 --- a/board/schulercontrol/sc_sps_1/spl_boot.c +++ b/board/schulercontrol/sc_sps_1/spl_boot.c @@ -138,9 +138,9 @@ const iomux_cfg_t iomux_setup[] = { MX28_PAD_GPMI_D06__GPIO_0_6 | MUX_CONFIG_LED, };
Add STMP3780-based XFi3 board. This board is a small PMP device sporting a CPU which was later rebranded to i.MX233 . Currently supported is USB gadget mode and both external SD and internal Phison SD-NAND bridge .
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com Cc: Otavio Salvador otavio@ossystems.com.br Cc: Stefano Babic sbabic@denx.de --- MAINTAINERS | 1 + board/creative/xfi3/Makefile | 31 ++++++ board/creative/xfi3/spl_boot.c | 134 ++++++++++++++++++++++++ board/creative/xfi3/xfi3.c | 224 ++++++++++++++++++++++++++++++++++++++++ boards.cfg | 1 + include/configs/xfi3.h | 69 +++++++++++++ 6 files changed, 460 insertions(+) create mode 100644 board/creative/xfi3/Makefile create mode 100644 board/creative/xfi3/spl_boot.c create mode 100644 board/creative/xfi3/xfi3.c create mode 100644 include/configs/xfi3.h
diff --git a/MAINTAINERS b/MAINTAINERS index 0a900dc..84c1f61 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -968,6 +968,7 @@ Marek Vasut marek.vasut@gmail.com vpac270 xscale/pxa zipitz2 xscale/pxa mx23_olinuxino i.MX23 + xfi3 i.MX23 m28evk i.MX28 sc_sps_1 i.MX28 m53evk i.MX53 diff --git a/board/creative/xfi3/Makefile b/board/creative/xfi3/Makefile new file mode 100644 index 0000000..4dc2b48 --- /dev/null +++ b/board/creative/xfi3/Makefile @@ -0,0 +1,31 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +ifndef CONFIG_SPL_BUILD +COBJS := xfi3.o +else +COBJS := spl_boot.o +endif + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/creative/xfi3/spl_boot.c b/board/creative/xfi3/spl_boot.c new file mode 100644 index 0000000..af7aa0e --- /dev/null +++ b/board/creative/xfi3/spl_boot.c @@ -0,0 +1,134 @@ +/* + * Creative ZEN X-Fi3 setup + * + * Copyright (C) 2013 Marek Vasut marex@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <config.h> +#include <asm/io.h> +#include <asm/arch/iomux-mx23.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/sys_proto.h> + +#define MUX_CONFIG_EMI (MXS_PAD_1V8 | MXS_PAD_12MA | MXS_PAD_PULLUP) +#define MUX_CONFIG_SSP (MXS_PAD_3V3 | MXS_PAD_8MA | MXS_PAD_PULLUP) +#define MUX_CONFIG_LCD (MXS_PAD_3V3 | MXS_PAD_4MA | MXS_PAD_NOPULL) + +const iomux_cfg_t iomux_setup[] = { + /* EMI */ + MX23_PAD_EMI_D00__EMI_D00 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D01__EMI_D01 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D02__EMI_D02 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D03__EMI_D03 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D04__EMI_D04 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D05__EMI_D05 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D06__EMI_D06 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D07__EMI_D07 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D08__EMI_D08 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D09__EMI_D09 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D10__EMI_D10 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D11__EMI_D11 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D12__EMI_D12 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D13__EMI_D13 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D14__EMI_D14 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D15__EMI_D15 | MUX_CONFIG_EMI, + MX23_PAD_EMI_DQM0__EMI_DQM0 | MUX_CONFIG_EMI, + MX23_PAD_EMI_DQM1__EMI_DQM1 | MUX_CONFIG_EMI, + MX23_PAD_EMI_DQS0__EMI_DQS0 | MUX_CONFIG_EMI, + MX23_PAD_EMI_DQS1__EMI_DQS1 | MUX_CONFIG_EMI, + MX23_PAD_EMI_CLK__EMI_CLK | MUX_CONFIG_EMI, + MX23_PAD_EMI_CLKN__EMI_CLKN | MUX_CONFIG_EMI, + + MX23_PAD_EMI_A00__EMI_A00 | MUX_CONFIG_EMI, + MX23_PAD_EMI_A01__EMI_A01 | MUX_CONFIG_EMI, + MX23_PAD_EMI_A02__EMI_A02 | MUX_CONFIG_EMI, + MX23_PAD_EMI_A03__EMI_A03 | MUX_CONFIG_EMI, + MX23_PAD_EMI_A04__EMI_A04 | MUX_CONFIG_EMI, + MX23_PAD_EMI_A05__EMI_A05 | MUX_CONFIG_EMI, + MX23_PAD_EMI_A06__EMI_A06 | MUX_CONFIG_EMI, + MX23_PAD_EMI_A07__EMI_A07 | MUX_CONFIG_EMI, + MX23_PAD_EMI_A08__EMI_A08 | MUX_CONFIG_EMI, + MX23_PAD_EMI_A09__EMI_A09 | MUX_CONFIG_EMI, + MX23_PAD_EMI_A10__EMI_A10 | MUX_CONFIG_EMI, + MX23_PAD_EMI_A11__EMI_A11 | MUX_CONFIG_EMI, + MX23_PAD_EMI_A12__EMI_A12 | MUX_CONFIG_EMI, + MX23_PAD_EMI_BA0__EMI_BA0 | MUX_CONFIG_EMI, + MX23_PAD_EMI_BA1__EMI_BA1 | MUX_CONFIG_EMI, + + MX23_PAD_EMI_CASN__EMI_CASN | MUX_CONFIG_EMI, + MX23_PAD_EMI_CE0N__EMI_CE0N | MUX_CONFIG_EMI, + MX23_PAD_EMI_CE1N__EMI_CE1N | MUX_CONFIG_EMI, + MX23_PAD_EMI_CKE__EMI_CKE | MUX_CONFIG_EMI, + MX23_PAD_EMI_RASN__EMI_RASN | MUX_CONFIG_EMI, + MX23_PAD_EMI_WEN__EMI_WEN | MUX_CONFIG_EMI, + + MX23_PAD_LCD_D00__LCD_D00 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D01__LCD_D01 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D02__LCD_D02 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D03__LCD_D03 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D04__LCD_D04 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D05__LCD_D05 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D06__LCD_D06 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D07__LCD_D07 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D08__LCD_D08 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D09__LCD_D09 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D10__LCD_D10 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D11__LCD_D11 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D12__LCD_D12 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D13__LCD_D13 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D14__LCD_D14 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D15__LCD_D15 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D16__LCD_D16 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D17__LCD_D17 | MUX_CONFIG_LCD, + MX23_PAD_LCD_RESET__LCD_RESET | MUX_CONFIG_LCD, + MX23_PAD_LCD_RS__LCD_RS | MUX_CONFIG_LCD, + MX23_PAD_LCD_WR__LCD_WR | MUX_CONFIG_LCD, + MX23_PAD_LCD_CS__LCD_CS | MUX_CONFIG_LCD, + MX23_PAD_LCD_ENABLE__LCD_ENABLE | MUX_CONFIG_LCD, + MX23_PAD_LCD_VSYNC__LCD_VSYNC | MUX_CONFIG_LCD, + + MX23_PAD_SSP1_CMD__SSP1_CMD | MUX_CONFIG_SSP, + MX23_PAD_SSP1_DETECT__GPIO_2_1 | MUX_CONFIG_SSP, + MX23_PAD_SSP1_DATA0__SSP1_DATA0 | MUX_CONFIG_SSP, + MX23_PAD_SSP1_DATA1__SSP1_DATA1 | MUX_CONFIG_SSP, + MX23_PAD_SSP1_DATA2__SSP1_DATA2 | MUX_CONFIG_SSP, + MX23_PAD_SSP1_DATA3__SSP1_DATA3 | MUX_CONFIG_SSP, + MX23_PAD_SSP1_SCK__SSP1_SCK | MUX_CONFIG_SSP, + MX23_PAD_GPMI_D07__GPIO_0_7 | MUX_CONFIG_SSP, + + MX23_PAD_GPMI_D00__SSP2_DATA0 | MUX_CONFIG_SSP, + MX23_PAD_GPMI_D01__SSP2_DATA1 | MUX_CONFIG_SSP, + MX23_PAD_GPMI_D02__SSP2_DATA2 | MUX_CONFIG_SSP, + MX23_PAD_GPMI_D03__SSP2_DATA3 | MUX_CONFIG_SSP, + MX23_PAD_GPMI_RDY1__SSP2_CMD | MUX_CONFIG_SSP, + MX23_PAD_GPMI_WRN__SSP2_SCK | MUX_CONFIG_SSP, + + /* PWM -- FIXME */ + MX23_PAD_PWM2__GPIO_1_28 | MXS_PAD_3V3 | MXS_PAD_12MA | MXS_PAD_PULLUP, +}; + +void mxs_adjust_memory_params(uint32_t *dram_vals) +{ + /* mDDR configuration values */ + const uint32_t regs[] = { + 0x01010001, 0x00010000, 0x01000000, 0x00000001, + 0x00010101, 0x00000001, 0x00010000, 0x01000001, + 0x01010000, 0x00000001, 0x07000200, 0x04070203, + 0x02020002, 0x06070a02, 0x0d000201, 0x0305000d, + 0x02080800, 0x19330f0a, 0x1f1f1c00, 0x020a1313, + 0x03061323, 0x0000000a, 0x00080008, 0x00200020, + 0x00200020, 0x00200020, 0x000003f7, 0x00000000, + 0x00000000, 0x00000000, 0x00000020, 0x00000000, + 0x001023cd, 0x20410010, 0x00006665, 0x00000000, + 0x00000101, 0x00000001, 0x00000000, 0x00000000, + }; + memcpy(dram_vals, regs, sizeof(regs)); +} + +void board_init_ll(const uint32_t arg, const uint32_t *resptr) +{ + mxs_common_spl_init(arg, resptr, iomux_setup, ARRAY_SIZE(iomux_setup)); +} diff --git a/board/creative/xfi3/xfi3.c b/board/creative/xfi3/xfi3.c new file mode 100644 index 0000000..d90dfae --- /dev/null +++ b/board/creative/xfi3/xfi3.c @@ -0,0 +1,224 @@ +/* + * Creative ZEN X-Fi3 board + * + * Copyright (C) 2013 Marek Vasut marex@denx.de + * + * Hardware investigation done by: + * + * Amaury Pouly amaury.pouly@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <errno.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <asm/arch/iomux-mx23.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/clock.h> +#include <asm/arch/sys_proto.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Functions + */ +int board_early_init_f(void) +{ + /* IO0 clock at 480MHz */ + mxs_set_ioclk(MXC_IOCLK0, 480000); + + /* SSP0 clock at 96MHz */ + mxs_set_sspclk(MXC_SSPCLK0, 96000, 0); + + return 0; +} + +int dram_init(void) +{ + return mxs_dram_init(); +} + +#ifdef CONFIG_CMD_MMC +static int xfi3_mmc_cd(int id) +{ + switch (id) { + case 0: + /* The SSP_DETECT is inverted on this board. */ + return gpio_get_value(MX23_PAD_SSP1_DETECT__GPIO_2_1); + case 1: + /* Phison bridge always present */ + return 1; + default: + return 0; + } +} + +int board_mmc_init(bd_t *bis) +{ + int ret; + + /* MicroSD slot */ + gpio_direction_input(MX23_PAD_SSP1_DETECT__GPIO_2_1); + gpio_direction_output(MX23_PAD_GPMI_D07__GPIO_0_7, 0); + ret = mxsmmc_initialize(bis, 0, NULL, xfi3_mmc_cd); + if (ret) + return ret; + + /* Phison SD-NAND bridge */ + ret = mxsmmc_initialize(bis, 1, NULL, xfi3_mmc_cd); + + return ret; +} +#endif + +#ifdef CONFIG_VIDEO_MXS +static int mxsfb_write_byte(uint32_t payload, const unsigned int data) +{ + struct mxs_lcdif_regs *regs = (struct mxs_lcdif_regs *)MXS_LCDIF_BASE; + const unsigned int timeout = 0x10000; + + if (mxs_wait_mask_clr(®s->hw_lcdif_ctrl_reg, LCDIF_CTRL_RUN, + timeout)) + return -ETIMEDOUT; + + writel((1 << LCDIF_TRANSFER_COUNT_V_COUNT_OFFSET) | + (1 << LCDIF_TRANSFER_COUNT_H_COUNT_OFFSET), + ®s->hw_lcdif_transfer_count); + + writel(LCDIF_CTRL_DATA_SELECT | LCDIF_CTRL_RUN, + ®s->hw_lcdif_ctrl_clr); + + if (data) + writel(LCDIF_CTRL_DATA_SELECT, ®s->hw_lcdif_ctrl_set); + + writel(LCDIF_CTRL_RUN, ®s->hw_lcdif_ctrl_set); + + if (mxs_wait_mask_clr(®s->hw_lcdif_lcdif_stat_reg, 1 << 29, + timeout)) + return -ETIMEDOUT; + + writel(payload, ®s->hw_lcdif_data); + return mxs_wait_mask_clr(®s->hw_lcdif_ctrl_reg, LCDIF_CTRL_RUN, + timeout); +} + +static void mxsfb_write_register(uint32_t reg, uint32_t data) +{ + mxsfb_write_byte(reg, 0); + mxsfb_write_byte(data, 1); +} + +static const struct { + uint8_t reg; + uint8_t delay; + uint16_t val; +} lcd_regs[] = { + { 0x01, 0, 0x001c }, + { 0x02, 0, 0x0100 }, + /* Writing 0x30 to reg. 0x03 flips the LCD */ + { 0x03, 0, 0x1038 }, + { 0x08, 0, 0x0808 }, + /* This can contain 0x111 to rotate the LCD. */ + { 0x0c, 0, 0x0000 }, + { 0x0f, 0, 0x0c01 }, + { 0x20, 0, 0x0000 }, + { 0x21, 30, 0x0000 }, + /* Wait 30 mS here */ + { 0x10, 0, 0x0a00 }, + { 0x11, 30, 0x1038 }, + /* Wait 30 mS here */ + { 0x12, 0, 0x1010 }, + { 0x13, 0, 0x0050 }, + { 0x14, 0, 0x4f58 }, + { 0x30, 0, 0x0000 }, + { 0x31, 0, 0x00db }, + { 0x32, 0, 0x0000 }, + { 0x33, 0, 0x0000 }, + { 0x34, 0, 0x00db }, + { 0x35, 0, 0x0000 }, + { 0x36, 0, 0x00af }, + { 0x37, 0, 0x0000 }, + { 0x38, 0, 0x00db }, + { 0x39, 0, 0x0000 }, + { 0x50, 0, 0x0000 }, + { 0x51, 0, 0x0705 }, + { 0x52, 0, 0x0e0a }, + { 0x53, 0, 0x0300 }, + { 0x54, 0, 0x0a0e }, + { 0x55, 0, 0x0507 }, + { 0x56, 0, 0x0000 }, + { 0x57, 0, 0x0003 }, + { 0x58, 0, 0x090a }, + { 0x59, 30, 0x0a09 }, + /* Wait 30 mS here */ + { 0x07, 30, 0x1017 }, + /* Wait 40 mS here */ + { 0x36, 0, 0x00af }, + { 0x37, 0, 0x0000 }, + { 0x38, 0, 0x00db }, + { 0x39, 0, 0x0000 }, + { 0x20, 0, 0x0000 }, + { 0x21, 0, 0x0000 }, +}; + +void board_mxsfb_system_setup(void) +{ + struct mxs_lcdif_regs *regs = (struct mxs_lcdif_regs *)MXS_LCDIF_BASE; + int i; + + /* Switch the LCDIF into System-Mode */ + writel(LCDIF_CTRL_LCDIF_MASTER | LCDIF_CTRL_DOTCLK_MODE | + LCDIF_CTRL_BYPASS_COUNT, ®s->hw_lcdif_ctrl_clr); + + /* Restart the SmartLCD controller */ + mdelay(50); + writel(1, ®s->hw_lcdif_ctrl1_set); + mdelay(50); + writel(1, ®s->hw_lcdif_ctrl1_clr); + mdelay(50); + writel(1, ®s->hw_lcdif_ctrl1_set); + mdelay(50); + + /* Program the SmartLCD controller */ + writel(LCDIF_CTRL1_RECOVER_ON_UNDERFLOW, ®s->hw_lcdif_ctrl1_set); + + writel((0x03 << LCDIF_TIMING_CMD_HOLD_OFFSET) | + (0x03 << LCDIF_TIMING_CMD_SETUP_OFFSET) | + (0x03 << LCDIF_TIMING_DATA_HOLD_OFFSET) | + (0x02 << LCDIF_TIMING_DATA_SETUP_OFFSET), + ®s->hw_lcdif_timing); + + /* + * OTM2201A init and configuration sequence. + */ + for (i = 0; i < ARRAY_SIZE(lcd_regs); i++) { + mxsfb_write_register(lcd_regs[i].reg, lcd_regs[i].val); + if (lcd_regs[i].delay) + mdelay(lcd_regs[i].delay); + } + /* Turn on Framebuffer Upload Mode */ + mxsfb_write_byte(0x22, 0); + + writel(LCDIF_CTRL_LCDIF_MASTER | LCDIF_CTRL_DATA_SELECT, + ®s->hw_lcdif_ctrl_set); +} +#endif + +int board_init(void) +{ + /* Adress of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; + + /* Turn on PWM backlight */ + gpio_direction_output(MX23_PAD_PWM2__GPIO_1_28, 1); + + return 0; +} + +int board_eth_init(bd_t *bis) +{ + usb_eth_initialize(bis); + return 0; +} diff --git a/boards.cfg b/boards.cfg index 5f961da..c951633 100644 --- a/boards.cfg +++ b/boards.cfg @@ -205,6 +205,7 @@ mx28evk arm arm926ejs mx28evk freesca mx28evk_nand arm arm926ejs mx28evk freescale mxs mx28evk:ENV_IS_IN_NAND mx28evk_auart_console arm arm926ejs mx28evk freescale mxs mx28evk:MXS_AUART,MXS_AUART_BASE=MXS_UARTAPP3_BASE,ENV_IS_IN_MMC sc_sps_1 arm arm926ejs sc_sps_1 schulercontrol mxs +xfi3 arm arm926ejs xfi3 creative mxs xfi3 nhk8815 arm arm926ejs nhk8815 st nomadik nhk8815_onenand arm arm926ejs nhk8815 st nomadik nhk8815:BOOT_ONENAND omap5912osk arm arm926ejs - ti omap diff --git a/include/configs/xfi3.h b/include/configs/xfi3.h new file mode 100644 index 0000000..022bc95 --- /dev/null +++ b/include/configs/xfi3.h @@ -0,0 +1,69 @@ +/* + * Copyright (C) 2013 Marek Vasut marex@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef __CONFIGS_XFI3_H__ +#define __CONFIGS_XFI3_H__ + +/* System configurations */ +#define CONFIG_MX23 /* i.MX23 SoC */ + +/* U-Boot Commands */ +#define CONFIG_SYS_NO_FLASH +#include <config_cmd_default.h> +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DOS_PARTITION + +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_CMD_GPIO +#define CONFIG_CMD_MMC +#define CONFIG_CMD_PING +#define CONFIG_CMD_USB +#define CONFIG_VIDEO + +/* Memory configuration */ +#define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ +#define PHYS_SDRAM_1 0x40000000 /* Base address */ +#define PHYS_SDRAM_1_SIZE 0x08000000 /* Max 128 MB RAM */ +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 + +/* Environment */ +#define CONFIG_ENV_SIZE (16 * 1024) +#define CONFIG_ENV_IS_NOWHERE +#define CONFIG_ENV_OVERWRITE + +/* Booting Linux */ +#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTFILE "uImage" +#define CONFIG_BOOTARGS "console=ttyAMA0,115200n8 " +#define CONFIG_LOADADDR 0x42000000 +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +/* LCD */ +#ifdef CONFIG_VIDEO +#define CONFIG_VIDEO_FONT_4X6 +#define CONFIG_VIDEO_MXS_MODE_SYSTEM +#define CONFIG_SYS_BLACK_IN_WRITE +#define LCD_BPP LCD_COLOR16 +#endif + +/* USB */ +#ifdef CONFIG_CMD_USB +#define CONFIG_EHCI_MXS_PORT0 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 + +#define CONFIG_MV_UDC /* ChipIdea CI13xxx UDC */ +#define CONFIG_USB_GADGET_DUALSPEED + +#define CONFIG_USB_ETHER +#define CONFIG_USB_ETH_CDC +#define CONFIG_NETCONSOLE +#endif + +/* The rest of the configuration is shared */ +#include <configs/mxs.h> + +#endif /* __CONFIGS_XFI3_H__ */
Applied after fixing (line too long) checkpatch warning, thanks !
Add STMP3780-based Sansa Fuze+ board. This board is a small PMP device sporting a CPU which was later rebranded to i.MX233 . Currently supported is USB gadget mode and MMC .
Signed-off-by: Marek Vasut marex@denx.de Cc: Fabio Estevam fabio.estevam@freescale.com Cc: Otavio Salvador otavio@ossystems.com.br Cc: Stefano Babic sbabic@denx.de --- MAINTAINERS | 1 + board/sandisk/sansa_fuze_plus/Makefile | 31 +++ board/sandisk/sansa_fuze_plus/sfp.c | 388 ++++++++++++++++++++++++++++++ board/sandisk/sansa_fuze_plus/spl_boot.c | 139 +++++++++++ boards.cfg | 1 + include/configs/sansa_fuze_plus.h | 70 ++++++ 6 files changed, 630 insertions(+) create mode 100644 board/sandisk/sansa_fuze_plus/Makefile create mode 100644 board/sandisk/sansa_fuze_plus/sfp.c create mode 100644 board/sandisk/sansa_fuze_plus/spl_boot.c create mode 100644 include/configs/sansa_fuze_plus.h
diff --git a/MAINTAINERS b/MAINTAINERS index 84c1f61..750d6ec 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -969,6 +969,7 @@ Marek Vasut marek.vasut@gmail.com zipitz2 xscale/pxa mx23_olinuxino i.MX23 xfi3 i.MX23 + sansa_fuze_plus i.MX23 m28evk i.MX28 sc_sps_1 i.MX28 m53evk i.MX53 diff --git a/board/sandisk/sansa_fuze_plus/Makefile b/board/sandisk/sansa_fuze_plus/Makefile new file mode 100644 index 0000000..571cc07 --- /dev/null +++ b/board/sandisk/sansa_fuze_plus/Makefile @@ -0,0 +1,31 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +ifndef CONFIG_SPL_BUILD +COBJS := sfp.o +else +COBJS := spl_boot.o +endif + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(call cmd_link_o_target, $(OBJS)) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/sandisk/sansa_fuze_plus/sfp.c b/board/sandisk/sansa_fuze_plus/sfp.c new file mode 100644 index 0000000..a3865ad --- /dev/null +++ b/board/sandisk/sansa_fuze_plus/sfp.c @@ -0,0 +1,388 @@ +/* + * SanDisk Sansa Fuze Plus board + * + * Copyright (C) 2013 Marek Vasut marex@denx.de + * + * Hardware investigation done by: + * + * Amaury Pouly amaury.pouly@gmail.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <errno.h> +#include <asm/gpio.h> +#include <asm/io.h> +#include <asm/arch/iomux-mx23.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/clock.h> +#include <asm/arch/sys_proto.h> + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Functions + */ +int board_early_init_f(void) +{ + /* IO0 clock at 480MHz */ + mxs_set_ioclk(MXC_IOCLK0, 480000); + + /* SSP0 clock at 96MHz */ + mxs_set_sspclk(MXC_SSPCLK0, 96000, 0); + + return 0; +} + +int dram_init(void) +{ + return mxs_dram_init(); +} + +#ifdef CONFIG_CMD_MMC +static int xfi3_mmc_cd(int id) +{ + switch (id) { + case 0: + /* The SSP_DETECT is inverted on this board. */ + return gpio_get_value(MX23_PAD_SSP1_DETECT__GPIO_2_1); + case 1: + /* Internal eMMC always present */ + return 1; + default: + return 0; + } +} + +int board_mmc_init(bd_t *bis) +{ + int ret; + + /* MicroSD slot */ + gpio_direction_input(MX23_PAD_SSP1_DETECT__GPIO_2_1); + gpio_direction_output(MX23_PAD_GPMI_D08__GPIO_0_8, 0); + ret = mxsmmc_initialize(bis, 0, NULL, xfi3_mmc_cd); + if (ret) + return ret; + + /* Internal eMMC */ + gpio_direction_output(MX23_PAD_PWM3__GPIO_1_29, 0); + ret = mxsmmc_initialize(bis, 1, NULL, xfi3_mmc_cd); + + return ret; +} +#endif + +#ifdef CONFIG_VIDEO_MXS +#define MUX_CONFIG_LCD (MXS_PAD_3V3 | MXS_PAD_4MA | MXS_PAD_NOPULL) +const iomux_cfg_t iomux_lcd_gpio[] = { + MX23_PAD_LCD_D00__GPIO_1_0 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D01__GPIO_1_1 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D02__GPIO_1_2 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D03__GPIO_1_3 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D04__GPIO_1_4 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D05__GPIO_1_5 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D06__GPIO_1_6 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D07__GPIO_1_7 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D08__GPIO_1_8 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D09__GPIO_1_9 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D10__GPIO_1_10 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D11__GPIO_1_11 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D12__GPIO_1_12 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D13__GPIO_1_13 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D14__GPIO_1_14 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D15__GPIO_1_15 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D16__GPIO_1_16 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D17__GPIO_1_17 | MUX_CONFIG_LCD, + MX23_PAD_LCD_RESET__GPIO_1_18 | MUX_CONFIG_LCD, + MX23_PAD_LCD_RS__GPIO_1_19 | MUX_CONFIG_LCD, + MX23_PAD_LCD_WR__GPIO_1_20 | MUX_CONFIG_LCD, + MX23_PAD_LCD_CS__GPIO_1_21 | MUX_CONFIG_LCD, + MX23_PAD_LCD_ENABLE__GPIO_1_23 | MUX_CONFIG_LCD, +}; + +const iomux_cfg_t iomux_lcd_lcd[] = { + MX23_PAD_LCD_D00__LCD_D00 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D01__LCD_D01 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D02__LCD_D02 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D03__LCD_D03 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D04__LCD_D04 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D05__LCD_D05 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D06__LCD_D06 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D07__LCD_D07 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D08__LCD_D08 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D09__LCD_D09 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D10__LCD_D10 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D11__LCD_D11 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D12__LCD_D12 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D13__LCD_D13 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D14__LCD_D14 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D15__LCD_D15 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D16__LCD_D16 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D17__LCD_D17 | MUX_CONFIG_LCD, + MX23_PAD_LCD_RESET__LCD_RESET | MUX_CONFIG_LCD, + MX23_PAD_LCD_RS__LCD_RS | MUX_CONFIG_LCD, + MX23_PAD_LCD_WR__LCD_WR | MUX_CONFIG_LCD, + MX23_PAD_LCD_CS__LCD_CS | MUX_CONFIG_LCD, + MX23_PAD_LCD_ENABLE__LCD_ENABLE | MUX_CONFIG_LCD, + MX23_PAD_LCD_VSYNC__LCD_VSYNC | MUX_CONFIG_LCD, +}; + +static int mxsfb_read_register(uint32_t reg, uint32_t *value) +{ + iomux_cfg_t mux; + uint32_t val = 0; + int i; + + /* Mangle the register offset. */ + reg = ((reg & 0xff) << 1) | (((reg >> 8) & 0xff) << 10); + + /* + * The SmartLCD interface on MX233 can only do WRITE operation + * via the LCDIF controller. Implement the READ operation by + * fiddling with bits. + */ + mxs_iomux_setup_multiple_pads(iomux_lcd_gpio, + ARRAY_SIZE(iomux_lcd_gpio)); + + gpio_direction_output(MX23_PAD_LCD_RS__GPIO_1_19, 1); + gpio_direction_output(MX23_PAD_LCD_CS__GPIO_1_21, 1); + gpio_direction_output(MX23_PAD_LCD_WR__GPIO_1_20, 1); + gpio_direction_output(MX23_PAD_LCD_ENABLE__GPIO_1_23, 1); + + for (i = 0; i < 18; i++) { + mux = MXS_IOMUX_PAD_NAKED(1, i, PAD_MUXSEL_GPIO); + gpio_direction_output(mux, 0); + } + + udelay(2); + gpio_direction_output(MX23_PAD_LCD_RS__GPIO_1_19, 0); + udelay(1); + gpio_direction_output(MX23_PAD_LCD_CS__GPIO_1_21, 0); + udelay(1); + gpio_direction_output(MX23_PAD_LCD_WR__GPIO_1_20, 0); + udelay(1); + + for (i = 0; i < 18; i++) { + mux = MXS_IOMUX_PAD_NAKED(1, i, PAD_MUXSEL_GPIO); + gpio_direction_output(mux, (reg >> i) & 1); + } + udelay(1); + + gpio_direction_output(MX23_PAD_LCD_WR__GPIO_1_20, 1); + udelay(3); + + for (i = 0; i < 18; i++) { + mux = MXS_IOMUX_PAD_NAKED(1, i, PAD_MUXSEL_GPIO); + gpio_direction_input(mux); + } + udelay(2); + + gpio_direction_output(MX23_PAD_LCD_ENABLE__GPIO_1_23, 0); + udelay(1); + gpio_direction_output(MX23_PAD_LCD_RS__GPIO_1_19, 1); + udelay(1); + gpio_direction_output(MX23_PAD_LCD_ENABLE__GPIO_1_23, 1); + udelay(3); + gpio_direction_output(MX23_PAD_LCD_ENABLE__GPIO_1_23, 0); + udelay(2); + + for (i = 0; i < 18; i++) { + mux = MXS_IOMUX_PAD_NAKED(1, i, PAD_MUXSEL_GPIO); + val |= !!gpio_get_value(mux) << i; + } + udelay(1); + + gpio_direction_output(MX23_PAD_LCD_ENABLE__GPIO_1_23, 1); + udelay(1); + gpio_direction_output(MX23_PAD_LCD_CS__GPIO_1_21, 1); + udelay(1); + + mxs_iomux_setup_multiple_pads(iomux_lcd_lcd, + ARRAY_SIZE(iomux_lcd_lcd)); + + /* Demangle the register value. */ + *value = ((val >> 1) & 0xff) | ((val >> 2) & 0xff00); + + writel(val, 0x2000); + return 0; +} + +static int mxsfb_write_byte(uint32_t payload, const unsigned int data) +{ + struct mxs_lcdif_regs *regs = (struct mxs_lcdif_regs *)MXS_LCDIF_BASE; + const unsigned int timeout = 0x10000; + + /* What is going on here I do not know. FIXME */ + payload = ((payload & 0xff) << 1) | (((payload >> 8) & 0xff) << 10); + + if (mxs_wait_mask_clr(®s->hw_lcdif_ctrl_reg, LCDIF_CTRL_RUN, + timeout)) + return -ETIMEDOUT; + + writel((1 << LCDIF_TRANSFER_COUNT_V_COUNT_OFFSET) | + (1 << LCDIF_TRANSFER_COUNT_H_COUNT_OFFSET), + ®s->hw_lcdif_transfer_count); + + writel(LCDIF_CTRL_DATA_SELECT | LCDIF_CTRL_RUN, + ®s->hw_lcdif_ctrl_clr); + + if (data) + writel(LCDIF_CTRL_DATA_SELECT, ®s->hw_lcdif_ctrl_set); + + writel(LCDIF_CTRL_RUN, ®s->hw_lcdif_ctrl_set); + + if (mxs_wait_mask_clr(®s->hw_lcdif_lcdif_stat_reg, 1 << 29, + timeout)) + return -ETIMEDOUT; + + writel(payload, ®s->hw_lcdif_data); + return mxs_wait_mask_clr(®s->hw_lcdif_ctrl_reg, LCDIF_CTRL_RUN, + timeout); +} + +static void mxsfb_write_register(uint32_t reg, uint32_t data) +{ + mxsfb_write_byte(reg, 0); + mxsfb_write_byte(data, 1); +} + +static const struct { + uint8_t reg; + uint8_t delay; + uint16_t val; +} lcd_regs[] = { + { 0xe5, 0 , 0x78f0 }, + { 0xe3, 0 , 0x3008 }, + { 0xe7, 0 , 0x0012 }, + { 0xef, 0 , 0x1231 }, + { 0x00, 0 , 0x0001 }, + { 0x01, 0 , 0x0100 }, + { 0x02, 0 , 0x0700 }, + { 0x03, 0 , 0x1030 }, + { 0x04, 0 , 0x0000 }, + { 0x08, 0 , 0x0207 }, + { 0x09, 0 , 0x0000 }, + { 0x0a, 0 , 0x0000 }, + { 0x0c, 0 , 0x0000 }, + { 0x0d, 0 , 0x0000 }, + { 0x0f, 0 , 0x0000 }, + { 0x10, 0 , 0x0000 }, + { 0x11, 0 , 0x0007 }, + { 0x12, 0 , 0x0000 }, + { 0x13, 20 , 0x0000 }, + /* Wait 20 mS here. */ + { 0x10, 0 , 0x1290 }, + { 0x11, 50 , 0x0007 }, + /* Wait 50 mS here. */ + { 0x12, 50 , 0x0019 }, + /* Wait 50 mS here. */ + { 0x13, 0 , 0x1700 }, + { 0x29, 50 , 0x0014 }, + /* Wait 50 mS here. */ + { 0x20, 0 , 0x0000 }, + { 0x21, 0 , 0x0000 }, + { 0x30, 0 , 0x0504 }, + { 0x31, 0 , 0x0007 }, + { 0x32, 0 , 0x0006 }, + { 0x35, 0 , 0x0106 }, + { 0x36, 0 , 0x0202 }, + { 0x37, 0 , 0x0504 }, + { 0x38, 0 , 0x0500 }, + { 0x39, 0 , 0x0706 }, + { 0x3c, 0 , 0x0204 }, + { 0x3d, 0 , 0x0202 }, + { 0x50, 0 , 0x0000 }, + { 0x51, 0 , 0x00ef }, + { 0x52, 0 , 0x0000 }, + { 0x53, 0 , 0x013f }, + { 0x60, 0 , 0xa700 }, + { 0x61, 0 , 0x0001 }, + { 0x6a, 0 , 0x0000 }, + { 0x2b, 50 , 0x000d }, + /* Wait 50 mS here. */ + { 0x90, 0 , 0x0011 }, + { 0x92, 0 , 0x0600 }, + { 0x93, 0 , 0x0003 }, + { 0x95, 0 , 0x0110 }, + { 0x97, 0 , 0x0000 }, + { 0x98, 0 , 0x0000 }, + { 0x07, 0 , 0x0173 }, +}; + +void board_mxsfb_system_setup(void) +{ + struct mxs_lcdif_regs *regs = (struct mxs_lcdif_regs *)MXS_LCDIF_BASE; + uint32_t id; + int i; + + /* Switch the LCDIF into System-Mode */ + writel(LCDIF_CTRL_LCDIF_MASTER | LCDIF_CTRL_DOTCLK_MODE | + LCDIF_CTRL_BYPASS_COUNT, ®s->hw_lcdif_ctrl_clr); + + /* To program the LCD, switch to 18bit bus + 18bit data. */ + clrsetbits_le32(®s->hw_lcdif_ctrl, + LCDIF_CTRL_WORD_LENGTH_MASK | LCDIF_CTRL_LCD_DATABUS_WIDTH_MASK, + LCDIF_CTRL_WORD_LENGTH_18BIT | + LCDIF_CTRL_LCD_DATABUS_WIDTH_18BIT); + + mxsfb_read_register(0, &id); + writel(id, 0x2004); + + /* Restart the SmartLCD controller */ + mdelay(50); + writel(1, ®s->hw_lcdif_ctrl1_set); + mdelay(50); + writel(1, ®s->hw_lcdif_ctrl1_clr); + mdelay(50); + writel(1, ®s->hw_lcdif_ctrl1_set); + mdelay(50); + + /* Program the SmartLCD controller */ + writel(LCDIF_CTRL1_RECOVER_ON_UNDERFLOW, ®s->hw_lcdif_ctrl1_set); + + writel((0x02 << LCDIF_TIMING_CMD_HOLD_OFFSET) | + (0x02 << LCDIF_TIMING_CMD_SETUP_OFFSET) | + (0x02 << LCDIF_TIMING_DATA_HOLD_OFFSET) | + (0x01 << LCDIF_TIMING_DATA_SETUP_OFFSET), + ®s->hw_lcdif_timing); + + /* + * ILI9325 init and configuration sequence. + */ + for (i = 0; i < ARRAY_SIZE(lcd_regs); i++) { + mxsfb_write_register(lcd_regs[i].reg, lcd_regs[i].val); + if (lcd_regs[i].delay) + mdelay(lcd_regs[i].delay); + } + /* Turn on Framebuffer Upload Mode */ + mxsfb_write_byte(0x22, 0); + + writel(LCDIF_CTRL_LCDIF_MASTER | LCDIF_CTRL_DATA_SELECT, + ®s->hw_lcdif_ctrl_set); + + /* Operate the framebuffer in 16bit mode. */ + clrsetbits_le32(®s->hw_lcdif_ctrl, + LCDIF_CTRL_WORD_LENGTH_MASK | LCDIF_CTRL_LCD_DATABUS_WIDTH_MASK, + LCDIF_CTRL_WORD_LENGTH_16BIT | + LCDIF_CTRL_LCD_DATABUS_WIDTH_18BIT); +} +#endif + +int board_init(void) +{ + /* Adress of boot parameters */ + gd->bd->bi_boot_params = PHYS_SDRAM_1 + 0x100; + + /* Turn on PWM backlight */ + gpio_direction_output(MX23_PAD_PWM2__GPIO_1_28, 1); + + return 0; +} + +int board_eth_init(bd_t *bis) +{ + usb_eth_initialize(bis); + return 0; +} diff --git a/board/sandisk/sansa_fuze_plus/spl_boot.c b/board/sandisk/sansa_fuze_plus/spl_boot.c new file mode 100644 index 0000000..b763766 --- /dev/null +++ b/board/sandisk/sansa_fuze_plus/spl_boot.c @@ -0,0 +1,139 @@ +/* + * SanDisk Sansa Fuze Plus setup + * + * Copyright (C) 2013 Marek Vasut marex@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <config.h> +#include <asm/io.h> +#include <asm/arch/iomux-mx23.h> +#include <asm/arch/imx-regs.h> +#include <asm/arch/sys_proto.h> + +#define MUX_CONFIG_EMI (MXS_PAD_1V8 | MXS_PAD_12MA | MXS_PAD_PULLUP) +#define MUX_CONFIG_SSP (MXS_PAD_3V3 | MXS_PAD_4MA | MXS_PAD_PULLUP) +#define MUX_CONFIG_LCD (MXS_PAD_3V3 | MXS_PAD_4MA | MXS_PAD_NOPULL) + +const iomux_cfg_t iomux_setup[] = { + /* EMI */ + MX23_PAD_EMI_D00__EMI_D00 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D01__EMI_D01 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D02__EMI_D02 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D03__EMI_D03 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D04__EMI_D04 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D05__EMI_D05 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D06__EMI_D06 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D07__EMI_D07 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D08__EMI_D08 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D09__EMI_D09 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D10__EMI_D10 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D11__EMI_D11 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D12__EMI_D12 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D13__EMI_D13 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D14__EMI_D14 | MUX_CONFIG_EMI, + MX23_PAD_EMI_D15__EMI_D15 | MUX_CONFIG_EMI, + MX23_PAD_EMI_DQM0__EMI_DQM0 | MUX_CONFIG_EMI, + MX23_PAD_EMI_DQM1__EMI_DQM1 | MUX_CONFIG_EMI, + MX23_PAD_EMI_DQS0__EMI_DQS0 | MUX_CONFIG_EMI, + MX23_PAD_EMI_DQS1__EMI_DQS1 | MUX_CONFIG_EMI, + MX23_PAD_EMI_CLK__EMI_CLK | MUX_CONFIG_EMI, + MX23_PAD_EMI_CLKN__EMI_CLKN | MUX_CONFIG_EMI, + + MX23_PAD_EMI_A00__EMI_A00 | MUX_CONFIG_EMI, + MX23_PAD_EMI_A01__EMI_A01 | MUX_CONFIG_EMI, + MX23_PAD_EMI_A02__EMI_A02 | MUX_CONFIG_EMI, + MX23_PAD_EMI_A03__EMI_A03 | MUX_CONFIG_EMI, + MX23_PAD_EMI_A04__EMI_A04 | MUX_CONFIG_EMI, + MX23_PAD_EMI_A05__EMI_A05 | MUX_CONFIG_EMI, + MX23_PAD_EMI_A06__EMI_A06 | MUX_CONFIG_EMI, + MX23_PAD_EMI_A07__EMI_A07 | MUX_CONFIG_EMI, + MX23_PAD_EMI_A08__EMI_A08 | MUX_CONFIG_EMI, + MX23_PAD_EMI_A09__EMI_A09 | MUX_CONFIG_EMI, + MX23_PAD_EMI_A10__EMI_A10 | MUX_CONFIG_EMI, + MX23_PAD_EMI_A11__EMI_A11 | MUX_CONFIG_EMI, + MX23_PAD_EMI_A12__EMI_A12 | MUX_CONFIG_EMI, + MX23_PAD_EMI_BA0__EMI_BA0 | MUX_CONFIG_EMI, + MX23_PAD_EMI_BA1__EMI_BA1 | MUX_CONFIG_EMI, + + MX23_PAD_EMI_CASN__EMI_CASN | MUX_CONFIG_EMI, + MX23_PAD_EMI_CE0N__EMI_CE0N | MUX_CONFIG_EMI, + MX23_PAD_EMI_CE1N__EMI_CE1N | MUX_CONFIG_EMI, + MX23_PAD_EMI_CKE__EMI_CKE | MUX_CONFIG_EMI, + MX23_PAD_EMI_RASN__EMI_RASN | MUX_CONFIG_EMI, + MX23_PAD_EMI_WEN__EMI_WEN | MUX_CONFIG_EMI, + + MX23_PAD_LCD_D00__LCD_D00 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D01__LCD_D01 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D02__LCD_D02 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D03__LCD_D03 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D04__LCD_D04 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D05__LCD_D05 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D06__LCD_D06 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D07__LCD_D07 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D08__LCD_D08 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D09__LCD_D09 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D10__LCD_D10 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D11__LCD_D11 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D12__LCD_D12 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D13__LCD_D13 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D14__LCD_D14 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D15__LCD_D15 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D16__LCD_D16 | MUX_CONFIG_LCD, + MX23_PAD_LCD_D17__LCD_D17 | MUX_CONFIG_LCD, + MX23_PAD_LCD_RESET__LCD_RESET | MUX_CONFIG_LCD, + MX23_PAD_LCD_RS__LCD_RS | MUX_CONFIG_LCD, + MX23_PAD_LCD_WR__LCD_WR | MUX_CONFIG_LCD, + MX23_PAD_LCD_CS__LCD_CS | MUX_CONFIG_LCD, + MX23_PAD_LCD_ENABLE__LCD_ENABLE | MUX_CONFIG_LCD, + MX23_PAD_LCD_VSYNC__LCD_VSYNC | MUX_CONFIG_LCD, + + MX23_PAD_SSP1_CMD__SSP1_CMD | MUX_CONFIG_SSP, + MX23_PAD_SSP1_DETECT__GPIO_2_1 | MUX_CONFIG_SSP, + MX23_PAD_SSP1_DATA0__SSP1_DATA0 | MUX_CONFIG_SSP, + MX23_PAD_SSP1_DATA1__SSP1_DATA1 | MUX_CONFIG_SSP, + MX23_PAD_SSP1_DATA2__SSP1_DATA2 | MUX_CONFIG_SSP, + MX23_PAD_SSP1_DATA3__SSP1_DATA3 | MUX_CONFIG_SSP, + MX23_PAD_SSP1_SCK__SSP1_SCK | MUX_CONFIG_SSP, + MX23_PAD_GPMI_D08__GPIO_0_8 | MUX_CONFIG_SSP, + + MX23_PAD_GPMI_D00__SSP2_DATA0 | MUX_CONFIG_SSP, + MX23_PAD_GPMI_D01__SSP2_DATA1 | MUX_CONFIG_SSP, + MX23_PAD_GPMI_D02__SSP2_DATA2 | MUX_CONFIG_SSP, + MX23_PAD_GPMI_D03__SSP2_DATA3 | MUX_CONFIG_SSP, + MX23_PAD_GPMI_D04__SSP2_DATA4 | MUX_CONFIG_SSP, + MX23_PAD_GPMI_D05__SSP2_DATA5 | MUX_CONFIG_SSP, + MX23_PAD_GPMI_D06__SSP2_DATA6 | MUX_CONFIG_SSP, + MX23_PAD_GPMI_D07__SSP2_DATA7 | MUX_CONFIG_SSP, + MX23_PAD_GPMI_RDY1__SSP2_CMD | MUX_CONFIG_SSP, + MX23_PAD_GPMI_WRN__SSP2_SCK | (MXS_PAD_3V3 | MXS_PAD_4MA | MXS_PAD_NOPULL), + MX23_PAD_PWM3__GPIO_1_29 | MUX_CONFIG_SSP, + + /* PWM -- FIXME */ + MX23_PAD_PWM2__GPIO_1_28 | MXS_PAD_3V3 | MXS_PAD_12MA | MXS_PAD_PULLUP, +}; + +void mxs_adjust_memory_params(uint32_t *dram_vals) +{ + /* mDDR configuration values */ + const uint32_t regs[] = { + 0x01010001, 0x00010000, 0x01000000, 0x00000001, + 0x00010101, 0x00000001, 0x00010000, 0x01000001, + 0x01010000, 0x00000001, 0x07000200, 0x04070203, + 0x02020002, 0x06070a02, 0x0d000201, 0x0305000d, + 0x02080800, 0x19330f0a, 0x1f1f1c00, 0x020a1313, + 0x03061323, 0x0000000a, 0x00080008, 0x00200020, + 0x00200020, 0x00200020, 0x000003f7, 0x00000000, + 0x00000000, 0x00000000, 0x00000020, 0x00000000, + 0x001023cd, 0x20410010, 0x00006665, 0x00000000, + 0x00000101, 0x00000001, 0x00000000, 0x00000000, + }; + memcpy(dram_vals, regs, sizeof(regs)); +} + +void board_init_ll(const uint32_t arg, const uint32_t *resptr) +{ + mxs_common_spl_init(arg, resptr, iomux_setup, ARRAY_SIZE(iomux_setup)); +} diff --git a/boards.cfg b/boards.cfg index c951633..1fbf2cb 100644 --- a/boards.cfg +++ b/boards.cfg @@ -204,6 +204,7 @@ mx23evk arm arm926ejs mx23evk freesca mx28evk arm arm926ejs mx28evk freescale mxs mx28evk:ENV_IS_IN_MMC mx28evk_nand arm arm926ejs mx28evk freescale mxs mx28evk:ENV_IS_IN_NAND mx28evk_auart_console arm arm926ejs mx28evk freescale mxs mx28evk:MXS_AUART,MXS_AUART_BASE=MXS_UARTAPP3_BASE,ENV_IS_IN_MMC +sansa_fuze_plus arm arm926ejs sansa_fuze_plus sandisk mxs sansa_fuze_plus sc_sps_1 arm arm926ejs sc_sps_1 schulercontrol mxs xfi3 arm arm926ejs xfi3 creative mxs xfi3 nhk8815 arm arm926ejs nhk8815 st nomadik diff --git a/include/configs/sansa_fuze_plus.h b/include/configs/sansa_fuze_plus.h new file mode 100644 index 0000000..a85eb1c --- /dev/null +++ b/include/configs/sansa_fuze_plus.h @@ -0,0 +1,70 @@ +/* + * Copyright (C) 2013 Marek Vasut marex@denx.de + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef __CONFIGS_SANSA_FUZE_PLUS_H__ +#define __CONFIGS_SANSA_FUZE_PLUS_H__ + +/* System configurations */ +#define CONFIG_MX23 /* i.MX23 SoC */ + +/* U-Boot Commands */ +#define CONFIG_SYS_NO_FLASH +#include <config_cmd_default.h> +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DOS_PARTITION + +#define CONFIG_CMD_CACHE +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_CMD_GPIO +#define CONFIG_CMD_MMC +#define CONFIG_CMD_PING +#define CONFIG_CMD_USB +#define CONFIG_VIDEO +#define CONFIG_CMD_MEMTEST + +/* Memory configuration */ +#define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ +#define PHYS_SDRAM_1 0x40000000 /* Base address */ +#define PHYS_SDRAM_1_SIZE 0x08000000 /* Max 128 MB RAM */ +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM_1 + +/* Environment */ +#define CONFIG_ENV_SIZE (16 * 1024) +#define CONFIG_ENV_IS_NOWHERE +#define CONFIG_ENV_OVERWRITE + +/* Booting Linux */ +#define CONFIG_BOOTDELAY 3 +#define CONFIG_BOOTFILE "uImage" +#define CONFIG_BOOTARGS "console=ttyAMA0,115200n8 " +#define CONFIG_LOADADDR 0x42000000 +#define CONFIG_SYS_LOAD_ADDR CONFIG_LOADADDR + +/* LCD */ +#ifdef CONFIG_VIDEO +#define CONFIG_VIDEO_FONT_4X6 +#define CONFIG_VIDEO_MXS_MODE_SYSTEM +#define CONFIG_SYS_BLACK_IN_WRITE +#define LCD_BPP LCD_COLOR16 +#endif + +/* USB */ +#ifdef CONFIG_CMD_USB +#define CONFIG_EHCI_MXS_PORT0 +#define CONFIG_USB_MAX_CONTROLLER_COUNT 1 + +#define CONFIG_MV_UDC /* ChipIdea CI13xxx UDC */ +#define CONFIG_USB_GADGET_DUALSPEED + +#define CONFIG_USB_ETHER +#define CONFIG_USB_ETH_CDC +#define CONFIG_NETCONSOLE +#endif + +/* The rest of the configuration is shared */ +#include <configs/mxs.h> + +#endif /* __CONFIGS_SANSA_FUZE_PLUS_H__ */
I think this patch is not need as boards.cfg is being reworked.
Dear Otavio Salvador,
This patch is needed as it fixes inconsistency your previous patch introduced.
Best regards, Marek Vasut
I agree with the patch; I just think we must get the boards file rework merged as soon as possible or we'll keep generating conflicts for it.
What rework are you talking about ?
The maintainers file merge with the boards.
I suppose there will be not much problem with this reorder ... it would be nice if you provided link for a patch or discussion.
Am 31/08/2013 22:03, schrieb Marek Vasut:
http://patchwork.ozlabs.org/patch/266253/
Of course, each change in boards.cfg or MAINTAINER will generate a conflict, as Otavio stated. I hope this patch will be merged soon.
I propose we postpone this single patch until Albert's flow into mainline - if we need then some clean up, we will do at that time.
Dear Stefano Babic,
Either way WFM. But where did the tartlette-devourer disappear anyway ? I haven't seen albert around for a while now ...
I am adding Albert and Tom in Cc.
Anyone knows what is holding the MAINTAINER file rework from merge?
-----BEGIN PGP SIGNED MESSAGE----- Hash: SHA1
I like it, but given the current high conflict rate it has, I'm waiting for Albert to decide he's ready to re-generate things, probably after he gets back and re-syncs all the ARM trees.
- -- Tom
In this case, this patch could be applied to imx tree than.
Agree.
Otavio Salvador
Stefano Babic
