[U-Boot] [PATCH 0/4] arm: tegra: colibri_t20: ulpi reset polarity fix & various other patches
This series contains two spelling fixes, some added comments as well as the Toradex Colibri T20 ULPI reset polarity fix.
The whole series is also available here:
http://git.toradex.com/cgit/u-boot-toradex.git/log/?h=for-next
Marcel Ziswiler (4): video: tegra: fix spelling in comment pci: kconfig: fix spelling in description apalis_t30: comment about disabled pcie nodes colibri_t20: fix ulpi reset polarity
arch/arm/dts/tegra20-colibri.dts | 6 ++++-- arch/arm/dts/tegra30-apalis.dts | 2 ++ drivers/pci/Kconfig | 2 +- drivers/video/tegra124/display.c | 2 +- 4 files changed, 8 insertions(+), 4 deletions(-)
Get rid of spurious 'are' in the comment.
Signed-off-by: Marcel Ziswiler marcel.ziswiler@toradex.com ---
drivers/video/tegra124/display.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/video/tegra124/display.c b/drivers/video/tegra124/display.c index d8999c3..28db96c 100644 --- a/drivers/video/tegra124/display.c +++ b/drivers/video/tegra124/display.c @@ -343,7 +343,7 @@ static int display_init(struct udevice *dev, void *lcdbase,
/* * Before we probe the display device (eDP), tell it that this device - * is are the source of the display data. + * is the source of the display data. */ ret = uclass_find_first_device(UCLASS_DISPLAY, &dp_dev); if (ret) {
Fix 'driver model' rather than 'driver mode' in description.
drivers/pci/Kconfig | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/pci/Kconfig b/drivers/pci/Kconfig index ff2c370..275b29b 100644 --- a/drivers/pci/Kconfig +++ b/drivers/pci/Kconfig @@ -9,7 +9,7 @@ menuconfig PCI if PCI
config DM_PCI - bool "Enable driver mode for PCI" + bool "Enable driver model for PCI" depends on DM help Use driver model for PCI. Driver model is the new method for
Add a comment about the disabled PCIe port nodes.
arch/arm/dts/tegra30-apalis.dts | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/dts/tegra30-apalis.dts b/arch/arm/dts/tegra30-apalis.dts index f83f094..9e4ab8c 100644 --- a/arch/arm/dts/tegra30-apalis.dts +++ b/arch/arm/dts/tegra30-apalis.dts @@ -44,10 +44,12 @@ hvdd-pex-supply = <&sys_3v3_reg>;
pci@1,0 { + /* TS_DIFF1/2/3/4 left disabled */ nvidia,num-lanes = <4>; };
pci@2,0 { + /* PCIE1_RX/TX left disabled */ nvidia,num-lanes = <1>; };
Fix ULPI reset polarity which caused a hard hang on Colibri T20 upon attempting to start the USB subsystem:
This fixes my late commit d5a24d8b53d350364bd429b7104ec369b817e4b8 (colibri_t20: fix usb operation and controller order) inadvertently having overwritten Stephen's previous commit 2f6a7e8ce5df8b99d84bfd486c6f99d92322ce04 (ARM: tegra: fix USB ULPI PHY reset signal inversion confusion).
While at it also fix comment about on-module USB port.
arch/arm/dts/tegra20-colibri.dts | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/arch/arm/dts/tegra20-colibri.dts b/arch/arm/dts/tegra20-colibri.dts index 89adfb6..3c10dd6 100644 --- a/arch/arm/dts/tegra20-colibri.dts +++ b/arch/arm/dts/tegra20-colibri.dts @@ -16,7 +16,7 @@ i2c2 = "/i2c@7000c400"; mmc0 = "/sdhci@c8000600"; usb0 = "/usb@c5000000"; - usb1 = "/usb@c5004000"; /* on-module only, for ASIX */ + usb1 = "/usb@c5004000"; /* On-module only, for ASIX */ usb2 = "/usb@c5008000"; };
@@ -92,8 +92,10 @@ /* EHCI instance 1: ULPI -> USB3340 -> AX88772B */ usb@c5004000 { status = "okay"; + /* ULPI_RESET */ + nvidia,phy-reset-gpio = + <&gpio TEGRA_GPIO(V, 1) GPIO_ACTIVE_LOW>; /* VBUS_LAN */ - nvidia,phy-reset-gpio = <&gpio TEGRA_GPIO(V, 1) GPIO_ACTIVE_HIGH>; nvidia,vbus-gpio = <&gpio TEGRA_GPIO(BB, 1) GPIO_ACTIVE_HIGH>; };
Marcel Ziswiler
