[U-Boot] [PATCH] cmd/gpt.c: Fix warning over memset args in allocate_disk_part
With clang-3.8 we see: cmd/gpt.c:196:31: warning: 'memset' call operates on objects of type 'struct disk_part' while the size is based on a different type 'struct disk_part *' [-Wsizeof-pointer-memaccess] memset(newpart, '\0', sizeof(newpart)); ~~~~~~~ ^~~~~~~ cmd/gpt.c:196:31: note: did you mean to dereference the argument to 'sizeof' (and multiply it by the number of elements)? memset(newpart, '\0', sizeof(newpart)); ^~~~~~~
As we should have been passing sizeof(*newpart) not sizeof(newpart) here.
Cc: Lothar Waßmann LW@karo-electronics.de Cc: Alison Chaiken alison@peloton-tech.com Fixes: 09a49930e415 ("GPT: read partition table from device into a data structure") Signed-off-by: Tom Rini trini@konsulko.com --- cmd/gpt.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cmd/gpt.c b/cmd/gpt.c index 638aa198267b..701a1c1d6cd1 100644 --- a/cmd/gpt.c +++ b/cmd/gpt.c @@ -193,7 +193,7 @@ static struct disk_part *allocate_disk_part(disk_partition_t *info, int partnum) newpart = malloc(sizeof(*newpart)); if (!newpart) return ERR_PTR(-ENOMEM); - memset(newpart, '\0', sizeof(newpart)); + memset(newpart, '\0', sizeof(*newpart));
newpart->gpt_part_info.start = info->start; newpart->gpt_part_info.size = info->size;
Agreed. I'm happy to have now read how u-boot can be compiled with clang.
-- Alison
memset(newpart, '\0', sizeof(*newpart)); newpart->gpt_part_info.start = info->start; newpart->gpt_part_info.size = info->size;
-- 1.9.1
Alison Chaiken
