[U-Boot] Adding support for MB86R01
This patchset adds support for the MB86R01 'Jade' SoC from Fujitsu. It is based on a ARM926EJS core.
Signed-off-by: Matthias Weisser matthias.weisser@graf-syteco.de --- common/serial.c | 3 +- cpu/arm926ejs/jade/Makefile | 47 +++++++++ cpu/arm926ejs/jade/reset.c | 37 ++++++++ cpu/arm926ejs/jade/timer.c | 127 +++++++++++++++++++++++++ include/asm-arm/arch-jade/hardware.h | 31 ++++++ include/asm-arm/arch-jade/jade.h | 170 ++++++++++++++++++++++++++++++++++ include/serial.h | 3 +- 7 files changed, 416 insertions(+), 2 deletions(-) create mode 100644 cpu/arm926ejs/jade/Makefile create mode 100644 cpu/arm926ejs/jade/reset.c create mode 100644 cpu/arm926ejs/jade/timer.c create mode 100644 include/asm-arm/arch-jade/hardware.h create mode 100644 include/asm-arm/arch-jade/jade.h
diff --git a/common/serial.c b/common/serial.c index 5f9ffd7..7397608 100644 --- a/common/serial.c +++ b/common/serial.c @@ -41,7 +41,8 @@ struct serial_device *__default_serial_console (void) #elif defined(CONFIG_405GP) || defined(CONFIG_405CR) || defined(CONFIG_440) \ || defined(CONFIG_405EP) || defined(CONFIG_405EZ) || defined(CONFIG_405EX) \ || defined(CONFIG_MPC5xxx) || defined(CONFIG_MPC83xx) \ - || defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) + || defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) \ + || defined(CONFIG_JADE) #if defined(CONFIG_CONS_INDEX) && defined(CONFIG_SYS_NS16550_SERIAL) #if (CONFIG_CONS_INDEX==1) return &eserial1_device; diff --git a/cpu/arm926ejs/jade/Makefile b/cpu/arm926ejs/jade/Makefile new file mode 100644 index 0000000..360f046 --- /dev/null +++ b/cpu/arm926ejs/jade/Makefile @@ -0,0 +1,47 @@ +# +# (C) Copyright 2000-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(SOC).a + +COBJS = timer.o reset.o +SOBJS = + +SRCS := $(START:.o=.S) $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) +START := $(addprefix $(obj),$(START)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/cpu/arm926ejs/jade/reset.c b/cpu/arm926ejs/jade/reset.c new file mode 100644 index 0000000..820c3a1 --- /dev/null +++ b/cpu/arm926ejs/jade/reset.c @@ -0,0 +1,37 @@ +/* + * (C) Copyright 2009 + * Matthias Weisser matthias.weisser@graf-syteco.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/hardware.h> + +/* + * Reset the cpu by setting software reset request bit + */ +void reset_cpu(ulong ignored) +{ + writel(0x00000002, JADE_CRG_PHYS_BASE + CRG_CRSR); + while (1) + /* NOP */; + /* Never reached */ +} diff --git a/cpu/arm926ejs/jade/timer.c b/cpu/arm926ejs/jade/timer.c new file mode 100644 index 0000000..bc20f37 --- /dev/null +++ b/cpu/arm926ejs/jade/timer.c @@ -0,0 +1,127 @@ +/* + * (C) Copyright 2007-2008 + * Stelian Pop stelian.pop@leadtechdesign.com + * Lead Tech Design <www.leadtechdesign.com> + * Matthias Weisser matthias.weisser@graf-syteco.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <div64.h> +#include <asm/io.h> +#include <asm/arch/hardware.h> + +#define TIMER_LOAD_VAL 0xffffffff +#define TIMER_BASE JADE_TIMER_PHYS_BASE + +#define TIMER_REG_LOAD (TIMER_BASE + 0) +#define TIMER_REG_VALUE (TIMER_BASE + 4) +#define TIMER_REG_CONTROL (TIMER_BASE + 8) + +#define TIMER_FREQ (CONFIG_JADE_IOCLK / 16) + +static ulong timestamp; +static ulong lastdec; + +static inline unsigned long long tick_to_time(unsigned long long tick) +{ + tick *= CONFIG_SYS_HZ; + do_div(tick, TIMER_FREQ); + + return tick; +} + +static inline unsigned long long usec_to_tick(unsigned long long usec) +{ + usec *= TIMER_FREQ; + do_div(usec, 1000000); + + return usec; +} + +/* nothing really to do with interrupts, just starts up a counter. */ +int timer_init(void) +{ + writel(TIMER_LOAD_VAL, TIMER_REG_LOAD); + writel(0x86, TIMER_REG_CONTROL); + + reset_timer_masked(); + + return 0; +} + +/* + * timer without interrupts + */ +unsigned long long get_ticks(void) +{ + ulong now = readl(TIMER_REG_VALUE); + + if (now <= lastdec) /* normal mode (non roll) */ + /* move stamp forward with absolut diff ticks */ + timestamp += (lastdec - now); + else /* we have rollover of incrementer */ + timestamp += lastdec + TIMER_LOAD_VAL - now; + lastdec = now; + return timestamp; +} + +void reset_timer_masked(void) +{ + /* reset time */ + lastdec = readl(TIMER_REG_VALUE); + timestamp = 0; +} + +ulong get_timer_masked(void) +{ + return tick_to_time(get_ticks()); +} + +void __udelay(unsigned long usec) +{ + unsigned long long tmp; + ulong tmo; + + tmo = usec_to_tick(usec); + tmp = get_ticks() + tmo; /* get current timestamp */ + + while (get_ticks() < tmp) /* loop till event */ + /*NOP*/; +} + +void reset_timer(void) +{ + reset_timer_masked(); +} + +ulong get_timer(ulong base) +{ + return get_timer_masked() - base; +} + +/* + * This function is derived from PowerPC code (timebase clock frequency). + * On ARM it returns the number of timer ticks per second. + */ +ulong get_tbclk(void) +{ + return CONFIG_SYS_HZ; +} diff --git a/include/asm-arm/arch-jade/hardware.h b/include/asm-arm/arch-jade/hardware.h new file mode 100644 index 0000000..a26bdca --- /dev/null +++ b/include/asm-arm/arch-jade/hardware.h @@ -0,0 +1,31 @@ +/* + * (C) Copyright 2007 + * + * Author : Carsten Schneider, mycable GmbH + * cs@mycable.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef __ASM_ARCH_HARDWARE_H +#define __ASM_ARCH_HARDWARE_H + +#include <asm/sizes.h> +#include <asm/arch/jade.h> + +#endif diff --git a/include/asm-arm/arch-jade/jade.h b/include/asm-arm/arch-jade/jade.h new file mode 100644 index 0000000..8640a62 --- /dev/null +++ b/include/asm-arm/arch-jade/jade.h @@ -0,0 +1,170 @@ +/* + * (C) Copyright 2007 + * + * jade definitions + * + * Author : Carsten Schneider, mycable GmbH + * cs@mycable.de + * + * (C) Copyright 2009 + * Matthias Weisser matthias.weisser@graf-syteco.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef JADE_H +#define JADE_H + +#ifndef __ASSEMBLY__ + +/* GPIO registers */ +struct jade_gpio{ + uint32_t gpdr0; + uint32_t gpdr1; + uint32_t gpdr2; + uint32_t res; + uint32_t gpddr0; + uint32_t gpddr1; + uint32_t gpddr2; +}; + +/* PWM registers */ +struct jade_pwm{ + uint32_t bcr; + uint32_t tpr; + uint32_t pr; + uint32_t dr; + uint32_t cr; + uint32_t sr; + uint32_t ccr; + uint32_t ir; +}; + +/* The jade chip control (CCNT) register set. */ +struct jade_ccnt{ + uint32_t ccid; + uint32_t csrst; + uint32_t pad0[2]; + uint32_t cist; + uint32_t cistm; + uint32_t cgpio_ist; + uint32_t cgpio_istm; + uint32_t cgpio_ip; + uint32_t cgpio_im; + uint32_t caxi_bw; + uint32_t caxi_ps; + uint32_t cmux_md; + uint32_t cex_pin_st; + uint32_t cmlb; + uint32_t pad1[1]; + uint32_t cusb; + uint32_t pad2[41]; + uint32_t cbsc; + uint32_t cdcrc; + uint32_t cmsr0; + uint32_t cmsr1; + uint32_t pad3[2]; +}; + +#endif /* __ASSEMBLY__ */ + +/* + * Physical Address Defines + */ +#define JADE_DDR2C_PHYS_BASE 0xf3000000 +#define JADE_GDC_PHYS_BASE 0xf1fc0000 +#define JADE_GDC_DISP0_PHYS_BASE 0xf1fd0000 +#define JADE_GDC_DISP1_PHYS_BASE 0xf1fd2000 +#define JADE_CCNT_PHYS_BASE 0xfff42000 +#define JADE_CAN0_PHYS_BASE 0xfff54000 +#define JADE_CAN1_PHYS_BASE 0xfff55000 +#define JADE_I2C0_PHYS_BASE 0xfff56000 +#define JADE_I2C1_PHYS_BASE 0xfff57000 +#define JADE_EHCI_PHYS_BASE 0xfff80000 +#define JADE_OHCI_PHYS_BASE 0xfff81000 +#define JADE_IRC1_PHYS_BASE 0xfffb0000 +#define JADE_MEMC_PHYS_BASE 0xfffc0000 +#define JADE_TIMER_PHYS_BASE 0xfffe0000 +#define JADE_UART0_PHYS_BASE 0xfffe1000 +#define JADE_UART1_PHYS_BASE 0xfffe2000 +#define JADE_IRCE_PHYS_BASE 0xfffe4000 +#define JADE_CRG_PHYS_BASE 0xfffe7000 +#define JADE_IRC0_PHYS_BASE 0xfffe8000 +#define JADE_GPIO_PHYS_BASE 0xfffe9000 +#define JADE_PWM0_PHYS_BASE 0xfff41000 +#define JADE_PWM1_PHYS_BASE 0xfff41100 + +/* + * Offset definitions for DRAM controller + */ +#define DDR2C_DRIC 0x00 +#define DDR2C_DRIC1 0x02 +#define DDR2C_DRIC2 0x04 +#define DDR2C_DRCA 0x06 +#define DDR2C_DRCM 0x08 +#define DDR2C_DRCST1 0x0a +#define DDR2C_DRCST2 0x0c +#define DDR2C_DRCR 0x0e +#define DDR2C_DRCF 0x20 +#define DDR2C_DRASR 0x30 +#define DDR2C_DRIMS 0x50 +#define DDR2C_DROS 0x60 +#define DDR2C_DRIBSLI 0x62 +#define DDR2C_DRIBSODT1 0x64 +#define DDR2C_DRIBSOCD 0x66 +#define DDR2C_DRIBSOCD2 0x68 +#define DDR2C_DROABA 0x70 +#define DDR2C_DROBV 0x80 +#define DDR2C_DROBS 0x84 +#define DDR2C_DROBSR1 0x86 +#define DDR2C_DROBSR2 0x88 +#define DDR2C_DROBSR3 0x8a +#define DDR2C_DROBSR4 0x8c +#define DDR2C_DRIMR1 0x90 +#define DDR2C_DRIMR2 0x92 +#define DDR2C_DRIMR3 0x94 +#define DDR2C_DRIMR4 0x96 +#define DDR2C_DROISR1 0x98 +#define DDR2C_DROISR2 0x9a + +/* + * Offset definitions Chip Control Module + */ +#define CCNT_CCID 0x00 +#define CCNT_CSRST 0x1c +#define CCNT_CIST 0x20 +#define CCNT_CISTM 0x24 +#define CCNT_CMUX_MD 0x30 +#define CCNT_CDCRC 0xec + +/* + * Offset definitions clock reset generator + */ +#define CRG_CRPR 0x00 +#define CRG_CRWR 0x08 +#define CRG_CRSR 0x0c +#define CRG_CRDA 0x10 +#define CRG_CRDB 0x14 +#define CRG_CRHA 0x18 +#define CRG_CRPA 0x1c +#define CRG_CRPB 0x20 +#define CRG_CRHB 0x24 +#define CRG_CRAM 0x28 + +#endif /* jade_H */ diff --git a/include/serial.h b/include/serial.h index f2638ec..a560c71 100644 --- a/include/serial.h +++ b/include/serial.h @@ -25,7 +25,8 @@ extern struct serial_device * default_serial_console (void); #if defined(CONFIG_405GP) || defined(CONFIG_405CR) || defined(CONFIG_440) || \ defined(CONFIG_405EP) || defined(CONFIG_405EZ) || defined(CONFIG_405EX) || \ defined(CONFIG_MPC5xxx) || defined(CONFIG_MPC83xx) || \ - defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) + defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) || \ + defined(CONFIG_JADE) extern struct serial_device serial0_device; extern struct serial_device serial1_device; #if defined(CONFIG_SYS_NS16550_SERIAL)
Signed-off-by: Matthias Weisser matthias.weisser@graf-syteco.de --- drivers/video/Makefile | 1 + drivers/video/cfb_console.c | 2 +- drivers/video/jadegdc.c | 193 +++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 195 insertions(+), 1 deletions(-) create mode 100644 drivers/video/jadegdc.c
diff --git a/drivers/video/Makefile b/drivers/video/Makefile index bb6b5a0..aadc149 100644 --- a/drivers/video/Makefile +++ b/drivers/video/Makefile @@ -30,6 +30,7 @@ COBJS-$(CONFIG_ATMEL_LCD) += atmel_lcdfb.o COBJS-$(CONFIG_CFB_CONSOLE) += cfb_console.o COBJS-$(CONFIG_S6E63D6) += s6e63d6.o COBJS-$(CONFIG_VIDEO_CT69000) += ct69000.o +COBJS-$(CONFIG_VIDEO_JADEGDC) += jadegdc.o COBJS-$(CONFIG_VIDEO_MB862xx) += mb862xx.o COBJS-$(CONFIG_VIDEO_MX3) += mx3fb.o COBJS-$(CONFIG_VIDEO_SED13806) += sed13806.o diff --git a/drivers/video/cfb_console.c b/drivers/video/cfb_console.c index c07a26e..506337b 100644 --- a/drivers/video/cfb_console.c +++ b/drivers/video/cfb_console.c @@ -321,7 +321,7 @@ void console_cursor (int state); #else #define SWAP16(x) (x) #define SWAP32(x) (x) -#if defined(VIDEO_FB_16BPP_WORD_SWAP) +#if defined(VIDEO_FB_16BPP_WORD_SWAP) || defined(CONFIG_VIDEO_JADEGDC) #define SHORTSWAP32(x) ( ((x) >> 16) | ((x) << 16) ) #else #define SHORTSWAP32(x) (x) diff --git a/drivers/video/jadegdc.c b/drivers/video/jadegdc.c new file mode 100644 index 0000000..354de11 --- /dev/null +++ b/drivers/video/jadegdc.c @@ -0,0 +1,193 @@ +/* + * (C) Copyright 2007-2009 + * Matthias Weisser matthias.weisser@graf-syteco.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * jade.c - Graphic interface for Fujitsu Jade integrated graphic + * controller. Derived from mb862xx.c + */ + +#include <common.h> + +#include <malloc.h> +#include <mb862xx.h> +#include <asm/io.h> +#include <asm/arch/hardware.h> +#include <video_fb.h> +#include "videomodes.h" + +/* + * 4MB (at the end of system RAM) + */ +#define VIDEO_MEM_SIZE 0x400000 + +/* + * Graphic Device + */ +GraphicDevice jadegdc; + +void *video_hw_init(void) +{ + GraphicDevice *pGD = &jadegdc; + struct ctfb_res_modes var_mode[2]; + unsigned long *vid; + unsigned long div; + unsigned long dspBase[2]; + char *penv; + int bpp; + int i, j; + + memset(pGD, 0, sizeof(GraphicDevice)); + + dspBase[0] = JADE_GDC_DISP0_PHYS_BASE; + dspBase[1] = JADE_GDC_DISP1_PHYS_BASE; + + pGD->gdfIndex = GDF_15BIT_555RGB; + pGD->gdfBytesPP = 2; + + pGD->memSize = VIDEO_MEM_SIZE; + pGD->frameAdrs = PHYS_SDRAM + PHYS_SDRAM_SIZE - VIDEO_MEM_SIZE; + vid = (unsigned long *)pGD->frameAdrs; + + for (i = 0; i < 2; i++) { + char varName[32]; + u32 dcm1, dcm2, dcm3; + u16 htp, hdp, hdb, hsp, vtr, vsp, vdp; + u8 hsw, vsw; + u32 l2m, l2em, l2oa0, l2da0, l2oa1, l2da1; + u16 l2dx, l2dy, l2wx, l2wy, l2ww, l2wh; + + sprintf(varName, "gs_dsp_%d_param", i); + + penv = getenv(varName); + if (penv == NULL) { + penv = getenv("videomode"); + if ((i == 1) || (penv == NULL)) + continue; + } + + bpp = 0; + bpp = video_get_params(&var_mode[i], penv); + + if (bpp == 0) { + var_mode[i].xres = 640; + var_mode[i].yres = 480; + var_mode[i].pixclock = 39721; /* 25MHz */ + var_mode[i].left_margin = 48; + var_mode[i].right_margin = 16; + var_mode[i].upper_margin = 33; + var_mode[i].lower_margin = 10; + var_mode[i].hsync_len = 96; + var_mode[i].vsync_len = 2; + var_mode[i].sync = 0; + var_mode[i].vmode = 0; + } + + for (j = 0; j < var_mode[i].xres * var_mode[i].yres / 2; j++) + *vid++ = 0xFFFFFFFF; + + pGD->winSizeX = var_mode[i].xres; + pGD->winSizeY = var_mode[i].yres; + + /* LCD base clock is ~ 660MHZ. We do calculations in kHz */ + div = 660000 / (1000000000L / var_mode[i].pixclock); + if (div > 64) + div = 64; + if (0 == div) + div = 1; + + dcm1 = (div - 1) << 8; + dcm2 = 0x00000000; + dcm3 = 0x00000000; + + htp = var_mode[i].left_margin + var_mode[i].xres + + var_mode[i].hsync_len + var_mode[i].right_margin; + hdp = var_mode[i].xres; + hdb = var_mode[i].xres; + hsp = var_mode[i].xres + var_mode[i].right_margin; + hsw = var_mode[i].hsync_len; + + vsw = var_mode[i].vsync_len; + vtr = var_mode[i].upper_margin + var_mode[i].yres + + var_mode[i].vsync_len + var_mode[i].lower_margin; + vsp = var_mode[i].yres + var_mode[i].lower_margin; + vdp = var_mode[i].yres; + + l2m = ((var_mode[i].yres - 1) << (0)) | + (((var_mode[i].xres * 2) / 64) << (16)) | + ((1) << (31)); + + l2em = (1 << 0) | (1 << 1); + + l2oa0 = pGD->frameAdrs; + l2da0 = pGD->frameAdrs; + l2oa1 = pGD->frameAdrs; + l2da1 = pGD->frameAdrs; + l2dx = 0; + l2dy = 0; + l2wx = 0; + l2wy = 0; + l2ww = var_mode[i].xres; + l2wh = var_mode[i].yres - 1; + + writel(dcm1, dspBase[i] + GC_DCM1); + writel(dcm2, dspBase[i] + GC_DCM2); + writel(dcm3, dspBase[i] + GC_DCM3); + + writew(htp, dspBase[i] + GC_HTP); + writew(hdp, dspBase[i] + GC_HDP); + writew(hdb, dspBase[i] + GC_HDB); + writew(hsp, dspBase[i] + GC_HSP); + writeb(hsw, dspBase[i] + GC_HSW); + + writeb(vsw, dspBase[i] + GC_VSW); + writew(vtr, dspBase[i] + GC_VTR); + writew(vsp, dspBase[i] + GC_VSP); + writew(vdp, dspBase[i] + GC_VDP); + + writel(l2m, dspBase[i] + GC_L2M); + writel(l2em, dspBase[i] + GC_L2EM); + writel(l2oa0, dspBase[i] + GC_L2OA0); + writel(l2da0, dspBase[i] + GC_L2DA0); + writel(l2oa1, dspBase[i] + GC_L2OA1); + writel(l2da1, dspBase[i] + GC_L2DA1); + writew(l2dx, dspBase[i] + GC_L2DX); + writew(l2dy, dspBase[i] + GC_L2DY); + writew(l2wx, dspBase[i] + GC_L2WX); + writew(l2wy, dspBase[i] + GC_L2WY); + writew(l2ww, dspBase[i] + GC_L2WW); + writew(l2wh, dspBase[i] + GC_L2WH); + + writel(dcm1 | (1 << 18) | (1 << 31), dspBase[i] + GC_DCM1); + } + + return pGD; +} + +/* + * Set a RGB color in the LUT + */ +void video_set_lut(unsigned int index, unsigned char r, + unsigned char g, unsigned char b) +{ + +}
Signed-off-by: Matthias Weisser matthias.weisser@graf-syteco.de --- tools/Makefile | 3 +++ tools/logos/syteco.bmp | Bin 0 -> 12278 bytes 2 files changed, 3 insertions(+), 0 deletions(-) create mode 100644 tools/logos/syteco.bmp
diff --git a/tools/Makefile b/tools/Makefile index 5b8c3c3..702bb83 100644 --- a/tools/Makefile +++ b/tools/Makefile @@ -105,6 +105,9 @@ endif ifeq ($(VENDOR),ronetix) LOGO_BMP= logos/ronetix.bmp endif +ifeq ($(VENDOR),syteco) +LOGO_BMP= logos/syteco.bmp +endif
# now $(obj) is defined HOSTSRCS += $(addprefix $(SRCTREE)/,$(EXT_OBJ_FILES-y:.o=.c)) diff --git a/tools/logos/syteco.bmp b/tools/logos/syteco.bmp new file mode 100644 index 0000000000000000000000000000000000000000..141ee8e10edd85caa52b9501e3a4381b81fe772d GIT binary patch literal 12278 zcmeI0TdvbE5Qg2PNJwmiH{MtP??`Ncopb>#s;lC)jN^<mx5VSvEtQTf72hWQzx=+$ zhaW%xehW+behuL(l>Wf)7yK^a^U@yw`TZsRu;KA|g!}yt)yLX&3%A>CEstzCFdP^T zd`t(f&J=<Se1cz6Vz2%xn8}kC7#8>(XPCrZWxxz)aQVUR*)s#%*H9UWBXrEA1QO&t zYstvm(XSvSGDIqb%bIEx@j1x-j~>EAlo=D;a@~oAc7b6ib0rJDLd@MXyUuWw7M5lh zfih3b_~Yq<Q0mM4sm&RQGEdX7KJAq(ZPTPs8d(~qNu#u~oQ5$_npsY+84IPE<=mPv zQ97`kn5KBBu^pKzRr@FeV}ujV0E-%key8+JPwjR%PSg-fL+v?Zuuzm~N*8k07B$EL zgOci{u%n!(&w*xPvQV*M3>M{ZnIT6kFp5Q@?7&zo5+*A-3K2%KXp{&O|B7Qh)*L|? zpC$*w76J<5c_x@E8fJ%u!)!vHl9NR{v&%xA@eq(0pD%ivp1}fG^iANr-ANEg*UW!q z5!3Wi7BY`!(b&_ei5$V^gNKdw934IaoiAk}Vud1NtB)*p`12iK3IL=Vr3MQz1&YHL z?g!T5(G$}<te52r@ir{UnfLG|IrA<o(V5;X`SwN+d0eDBdHS-))l0rbu^5}`5<7SE zRg$sjdj!8hEd8L`mjx~<>uXXIGz-iLz0M#^oeMge`4T14zy+4)zzCKVrZ7jqYdS;U zK)-geMY1HAGK&er_EJ$=1t^vU#=&C1z*A)XDyd=veR|!7ux30g3PzkUMQIhlSTc-@ zMZgG@*7F4qsH=~K!AO*L798Qkj$n(W{oIW!FU?{FOAaOLb{j}7ih~CEHp_s~Z*R(> z0tFpD&{ka*OeKq?NOh&;XfR-ESl~bKOcsZ-5uyjHVwp@9L&w#mVCq;V!xxvX86;tv zS@1$`sudaqOe;&gcN7#4x;acE%W?(k1=GfoP<lDj#DXX-Fy!*w!m^>X!E6i4`vtgM zK%4GqiqZ>a!!mBRTo7yU$TR*rpd^+A%JbZc6eD%0s`up(SQ{|tgv^IC(h;nGKxaB^ J$T5U;;2&8xIXwUX
literal 0 HcmV?d00001
Signed-off-by: Matthias Weisser matthias.weisser@graf-syteco.de --- MAINTAINERS | 4 + MAKEALL | 1 + Makefile | 7 + board/syteco/jadecpu/Makefile | 55 +++++++ board/syteco/jadecpu/config.mk | 1 + board/syteco/jadecpu/jadecpu.c | 188 +++++++++++++++++++++++ board/syteco/jadecpu/lowlevel_init.S | 279 ++++++++++++++++++++++++++++++++++ include/configs/jadecpu.h | 187 +++++++++++++++++++++++ 8 files changed, 722 insertions(+), 0 deletions(-) create mode 100644 board/syteco/jadecpu/Makefile create mode 100644 board/syteco/jadecpu/config.mk create mode 100644 board/syteco/jadecpu/jadecpu.c create mode 100644 board/syteco/jadecpu/lowlevel_init.S create mode 100644 include/configs/jadecpu.h
diff --git a/MAINTAINERS b/MAINTAINERS index 9734b1d..706e847 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -744,6 +744,10 @@ Prafulla Wadaskar prafulla@marvell.com rd6281a ARM926EJS (Kirkwood SoC) sheevaplug ARM926EJS (Kirkwood SoC)
+Matthias Weisser matthias.weisser@graf-syteco.de + + jadecpu ARM926EJS + Richard Woodruff r-woodruff2@ti.com
omap2420h4 ARM1136EJS diff --git a/MAKEALL b/MAKEALL index ab1bb6f..33b1dc6 100755 --- a/MAKEALL +++ b/MAKEALL @@ -553,6 +553,7 @@ LIST_ARM9=" \ cp966 \ da830evm \ imx27lite \ + jadecpu \ lpd7a400 \ mv88f6281gtw_ge \ mx1ads \ diff --git a/Makefile b/Makefile index ed6156f..98c147d 100644 --- a/Makefile +++ b/Makefile @@ -2874,6 +2874,13 @@ TNY_A9260_config : unconfig @echo "#define CONFIG_$(@:_config=) 1" >$(obj)include/config.h @$(MKCONFIG) -a tny_a9260 arm arm926ejs tny_a9260 calao at91
+######################################################################### +## ARM926EJ-S Systems +######################################################################### + +jadecpu_config : unconfig + @$(MKCONFIG) $(@:_config=) arm arm926ejs jadecpu syteco jade + ######################################################################## ## ARM Integrator boards - see doc/README-integrator for more info. integratorap_config \ diff --git a/board/syteco/jadecpu/Makefile b/board/syteco/jadecpu/Makefile new file mode 100644 index 0000000..87d2234 --- /dev/null +++ b/board/syteco/jadecpu/Makefile @@ -0,0 +1,55 @@ +# +# (C) Copyright 2003-2008 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2008 +# Stelian Pop stelian.pop@leadtechdesign.com +# Lead Tech Design <www.leadtechdesign.com> +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS-y += jadecpu.o +SOBJS := lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/syteco/jadecpu/config.mk b/board/syteco/jadecpu/config.mk new file mode 100644 index 0000000..c661f0b --- /dev/null +++ b/board/syteco/jadecpu/config.mk @@ -0,0 +1 @@ +TEXT_BASE = 0x46000000 diff --git a/board/syteco/jadecpu/jadecpu.c b/board/syteco/jadecpu/jadecpu.c new file mode 100644 index 0000000..aba3e54 --- /dev/null +++ b/board/syteco/jadecpu/jadecpu.c @@ -0,0 +1,188 @@ +/* + * (c) 2009 Graf-Syteco, Matthias Weisser + * matthias.weisser@graf-syteco.de + * + * (C) Copyright 2007, mycable GmbH + * Carsten Schneider cs@mycable.de, Alexander Bigga ab@mycable.de + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <netdev.h> +#include <asm/io.h> +#include <asm/arch/jade.h> + +DECLARE_GLOBAL_DATA_PTR; + +#if defined(CONFIG_SHOW_BOOT_PROGRESS) +void show_boot_progress(int progress) +{ + printf("Boot reached stage %d\n", progress); +} +#endif + +/* + * Miscellaneous platform dependent initialisations + */ +int board_init(void) +{ + struct jade_ccnt * ccnt = (struct jade_ccnt *)JADE_CCNT_PHYS_BASE; + + /* We select mode 0 for group 2 and mode 1 for group 4 */ + writel(0x00000010, &ccnt->cmux_md); + + gd->flags = 0; + + icache_enable(); + + return 0; +} + +int board_late_init(void) +{ + struct jade_gpio *gpio = (struct jade_gpio *)JADE_GPIO_PHYS_BASE; + struct jade_pwm *pwm; + uint32_t in_word; + const char *e; + const char *s; + + /* Check if we have valid display settings and turn on power if so*/ + /* Display 0 */ + if (getenv("gs_dsp_0_param")) { + writel(readl(&gpio->gpdr2) | (1 << 3), &gpio->gpdr2); + + e = getenv("gs_dsp_0_pwm"); + if (e != NULL) { + uint32_t freq, init; + + freq = 0; + init = 0; + + s = strchr(e, 'f'); + if (s != NULL) + freq = simple_strtol(s + 2, NULL, 0); + + s = strchr(e, 'i'); + if (s != NULL) + init = simple_strtol(s + 2, NULL, 0); + + if (freq > 0) { + pwm = (struct jade_pwm *)JADE_PWM0_PHYS_BASE; + + writel(CONFIG_JADE_IOCLK / 1000 / freq, + &pwm->bcr); + writel(1002, &pwm->tpr); + writel(1, &pwm->pr); + writel(init * 10 + 1, &pwm->dr); + writel(1, &pwm->cr); + writel(1, &pwm->sr); + } + } + } + writel(readl(&gpio->gpddr2) | (1 << 3), &gpio->gpddr2); + + /* Display 1 */ + if (getenv("gs_dsp_1_param")) { + writel(readl(&gpio->gpdr2) | (1 << 4), &gpio->gpdr2); + + e = getenv("gs_dsp_1_pwm"); + if (e != NULL) { + uint32_t freq, init; + + freq = 0; + init = 0; + + s = strchr(e, 'f'); + if (s != NULL) + freq = simple_strtol(s + 2, NULL, 0); + + s = strchr(e, 'i'); + if (s != NULL) + init = simple_strtol(s + 2, NULL, 0); + + if (freq > 0) { + pwm = (struct jade_pwm *)JADE_PWM1_PHYS_BASE; + + writel(CONFIG_JADE_IOCLK / 1000 / freq, + &pwm->bcr); + writel(1002, &pwm->tpr); + writel(1, &pwm->pr); + writel(init * 10 + 1, &pwm->dr); + writel(1, &pwm->cr); + writel(1, &pwm->sr); + } + } + } + writel(readl(&gpio->gpddr2) | (1 << 4), &gpio->gpddr2); + + /* 5V enable */ + writel(readl(&gpio->gpddr1) | (1 << 5), &gpio->gpddr1); + writel(readl(&gpio->gpdr1) & ~(1 << 5), &gpio->gpdr1); + + /* We have special boot options if told by GPIOs */ + in_word = readl(&gpio->gpdr1); + + if ((in_word & 0xC0) == 0xC0) { + setenv("stdin", "eserial0"); + setenv("stdout", "eserial0"); + setenv("stderr", "eserial0"); + setenv("bootdelay", "10"); + } else if ((in_word & 0xC0) != 0) { + setenv("stdout", "vga"); + setenv("bootcmd", "mw.l 0x40000000 0 1024; usb start;" + "fatls usb 0; fatload usb 0 0x40000000 mcq5resq.bin;" + "bootelf 0x40000000; bootelf 0x10080000"); + setenv("bootdelay", "5"); + } else{ + setenv("stdin", "serial"); + setenv("stdout", "serial"); + setenv("stderr", "serial"); + if (getenv("gs_devel")) + setenv("bootdelay", "5"); + else + setenv("bootdelay", "0"); + } + + return 0; +} + +int misc_init_r(void) +{ + setenv("verify", "n"); + return 0; +} + +/* + * DRAM configuration + */ +int dram_init(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM; + gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE; + + return 0; +} + +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_SMC911X + rc = smc911x_initialize(0, CONFIG_SMC911X_BASE); +#endif + return rc; +} + diff --git a/board/syteco/jadecpu/lowlevel_init.S b/board/syteco/jadecpu/lowlevel_init.S new file mode 100644 index 0000000..73550c9 --- /dev/null +++ b/board/syteco/jadecpu/lowlevel_init.S @@ -0,0 +1,279 @@ +/* + * Board specific setup info + * + * (C) Copyright 2007, mycable GmbH + * Carsten Schneider cs@mycable.de, Alexander Bigga ab@mycable.de + * + * (C) Copyright 2007, mycable GmbH + * Carsten Schneider cs@mycable.de, Alexander Bigga ab@mycable.de + * + * (C) Copyright 2003, ARM Ltd. + * Philippe Robin, philippe.robin@arm.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software/* you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation/* either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY/* without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program/* if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> +#include <asm/macro.h> +#include <asm/arch/jade.h> + +/* Set up the platform, once the cpu has been initialized */ +.globl lowlevel_init +lowlevel_init: +/* + * Initialize Clock Reset Generator (CRG) + */ + + ldr r0, =JADE_CRG_PHYS_BASE + + /* Not change the initial value that is set by external pin.*/ +1: ldr r2, [r0, #CRG_CRPR] /* Wait for PLLREADY */ + tst r2, #0x00000100 + beq 1b + + /* Set clock gate control */ + ldr r1, =0x0000ffff /* Open */ + str r1, [r0, #CRG_CRHA] /* CRHA: AHB clock */ + ldr r1, =0x0000ffff /* Open */ + str r1, [r0, #CRG_CRPA] /* CRPA: APB-A clock */ + ldr r1, =0xfffffffe /* Close */ + str r1, [r0, #CRG_CRPB] /* CRPA: APB-B clock */ + ldr r1, =0x0000ffff /* Open */ + str r1, [r0, #CRG_CRHB] /* CRHB: ExtAHB clock */ + ldr r1, =0xffffffef /* Open ARM926EJ-S only */ + str r1, [r0, #CRG_CRAM] /* CRAM: ARM core clock */ + +/* + * Initialize External Bus Interface + */ + + ldr r0, =JADE_MEMC_PHYS_BASE + + /* + * SRAM/flash _mode_ registers (XCS4 is set by external pin) + * XCS0: Ethernet Controller + * XCS2: not used (?) + * XCS4: Flash + */ + ldr r1, =0x00000001 /* XCS0: 16bit */ + str r1, [r0, #0x00] + ldr r1, =0x00000001 /* XCS2: 16bit */ + str r1, [r0, #0x08] + ldr r1, =0x00000021 /* XCS4: 16bit, */ + str r1, [r0, #0x10] + + /* SRAM/flash _timing_ registers (HCLK=83.3/80MHz) */ + ldr r1, =0x03061008 /* XCS0: FPGA*/ + str r1, [r0, #0x20] + ldr r1, =0x03061008 /* XCS2: Ethernet */ + str r1, [r0, #0x28] + ldr r1, =0x03061804 /* XCS4: FLASH ROM */ + str r1, [r0, #0x30] + + /* SRAM/flash _area_ registers (address of XCS4 is set by hardware) */ + ldr r1, =0x000000c0 /* XCS0: 0x0c000000/1MB */ + str r1, [r0, #0x40] + ldr r1, =0x00000020 /* XCS2: 0x02000000/1MB */ + str r1, [r0, #0x48] + ldr r1, =0x001f0000 /* XCS4: 32 MB */ + str r1, [r0, #0x50] + +/* + * Initialize DDR2 Controller + */ + + /* Wait for PLL LOCK up time or more */ + wait_timer 20 + + /* + * (2) Initialize DDRIF + */ + ldr r0, =JADE_DDR2C_PHYS_BASE + ldr r1, =0x5555 + strh r1, [r0, #DDR2C_DRIMS] + + /* + * (3) Wait for 20MCKPs(120nsec) or more + */ + wait_timer 20 + + /* + * (4) IRESET/IUSRRST release + /* + ldr r0, =JADE_CCNT_PHYS_BASE + ldr r1, =0x00000002 + str r1, [r0, #CCNT_CDCRC] + + /* + * (5) Wait for 20MCKPs(120nsec) or more + */ + wait_timer 20 + + /* + * (6) IDLLRST release + */ + ldr r0, =JADE_CCNT_PHYS_BASE + ldr r1, =0x00000003 + str r1, [r0, #CCNT_CDCRC] + + /* + * (7+8) Wait for 200us(=200000ns) or more (DDR2 Spec) + */ + wait_timer 33536 + + /* + * (9) MCKE ON + */ + ldr r0, =JADE_DDR2C_PHYS_BASE + ldr r1, =0x003f + strh r1, [r0, #DDR2C_DRIC1] + ldr r1, =0x0000 + strh r1, [r0, #DDR2C_DRIC2] + ldr r1, =0xc124 /* 512Mbit DDR2SDRAM x 2 */ + strh r1, [r0, #DDR2C_DRCA] + ldr r1, =0xc000 + strh r1, [r0, #DDR2C_DRIC] + + /* + * (10) Initialize SDRAM + */ + + ldr r1, =0xc001 /* NOP Command */ + strh r1, [r0, #DDR2C_DRIC] + + wait_timer 67 /* 400ns wait */ + + ldr r1, =0x0017 /* PALL Command */ + strh r1, [r0, #DDR2C_DRIC1] + ldr r1, =0x0400 + strh r1, [r0, #DDR2C_DRIC2] + ldr r1, =0xc001 + strh r1, [r0, #DDR2C_DRIC] + + ldr r1, =0x0006 /* EMR(2) command */ + strh r1, [r0, #DDR2C_DRIC1] + ldr r1, =0x0000 + strh r1, [r0, #DDR2C_DRIC2] + ldr r1, =0xc001 + strh r1, [r0, #DDR2C_DRIC] + + ldr r1, =0x0007 /* EMR(3) command */ + strh r1, [r0, #DDR2C_DRIC1] + ldr r1, =0x0000 + strh r1, [r0, #DDR2C_DRIC2] + ldr r1, =0xc001 + strh r1, [r0, #DDR2C_DRIC] + + ldr r1, =0x0005 /* EMR(1) command */ + strh r1, [r0, #DDR2C_DRIC1] + ldr r1, =0x0000 /* Extended Mode Register 1 clear*/ + strh r1, [r0, #DDR2C_DRIC2] + ldr r1, =0xc001 + strh r1, [r0, #DDR2C_DRIC] + + ldr r1, =0x0004 /* MRS command */ + strh r1, [r0, #DDR2C_DRIC1] + ldr r1, =0x0532 /* Mode Register */ + strh r1, [r0, #DDR2C_DRIC2] + ldr r1, =0xc001 + strh r1, [r0, #DDR2C_DRIC] + + wait_timer 200 + + ldr r1, =0x0017 /* PALL command */ + strh r1, [r0, #DDR2C_DRIC1] + ldr r1, =0x0400 + strh r1, [r0, #DDR2C_DRIC2] + ldr r1, =0xc001 + strh r1, [r0, #DDR2C_DRIC] + + ldr r1, =0x000f /* REF command 1 */ + strh r1, [r0, #DDR2C_DRIC1] + ldr r1, =0x0000 /* (changed) */ + strh r1, [r0, #DDR2C_DRIC2] + ldr r1, =0xc001 + strh r1, [r0, #DDR2C_DRIC] + + wait_timer 18 /* 105ns wait */ + + ldr r1, =0x0004 /* MRS command */ + strh r1, [r0, #DDR2C_DRIC1] + ldr r1, =0x0432 + strh r1, [r0, #DDR2C_DRIC2] + ldr r1, =0xc001 + strh r1, [r0, #DDR2C_DRIC] + + wait_timer 200 /* MRS to OCD: 200clock */ + + ldr r1, =0x0005 /* EMR(1) command */ + strh r1, [r0, #DDR2C_DRIC1] + ldr r1, =0x0380 /* Extended Mode Register 1 set OCD */ + strh r1, [r0, #DDR2C_DRIC2] + ldr r1, =0xc001 + strh r1, [r0, #DDR2C_DRIC] + + ldr r1, =0x0005 /* EMR(1) command */ + strh r1, [r0, #DDR2C_DRIC1] + /* ldr r1, =0x0044 */ + ldr r1, =0x0002 /* EMR(1) set reduced strength */ + strh r1, [r0, #DDR2C_DRIC2] + ldr r1, =0xc001 + strh r1, [r0, #DDR2C_DRIC] + + ldr r1, =0x0032 /* Set BT, AL, CL, BL */ + strh r1, [r0, #DDR2C_DRCM] + + ldr r1, =0x3418 /* Set tRCD, tRAS, tRP, tRC */ + strh r1, [r0, #DDR2C_DRCST1] + + /* ldr r1, =0x2e22 */ /* Set tRFC, tRRD, tWR */ + ldr r1, =0x6e32 + strh r1, [r0, #DDR2C_DRCST2] + + /* ldr r1, =0x0051 */ /* Set CNTL, REF_CNT*/ + ldr r1, =0x0141 /* (changed) */ + strh r1, [r0, #DDR2C_DRCR] + + ldr r1, =0x0002 /* Set Address FIFO (8 steps) */ + strh r1, [r0, #DDR2C_DRCF] + + ldr r1, =0x0001 /* Enable AXI Cache */ + strh r1, [r0, #DDR2C_DRASR] + + /* + * (11) ODT setting + */ + ldr r1, =0x0001 + strh r1, [r0, #DDR2C_DROBS] + ldr r1, =0x0103 /* ODT auto adjustment on */ + strh r1, [r0, #DDR2C_DROABA] + ldr r1, =0x003F /* Set ODT to on 50/100 Ohm */ + strh r1, [r0, #DDR2C_DRIBSODT1] + + /* + * (12) Shift to ODTCONT ON (SDRAM side) and DDR2C usual operation mode + */ + ldr r1, =0x0001 + strh r1, [r0, #DDR2C_DROS] + ldr r1, =0x4000 + strh r1, [r0, #DDR2C_DRIC] + + mov pc, lr + diff --git a/include/configs/jadecpu.h b/include/configs/jadecpu.h new file mode 100644 index 0000000..5a19abf --- /dev/null +++ b/include/configs/jadecpu.h @@ -0,0 +1,187 @@ +/* + * (C) Copyright 2007-2008 + * Matthias Weisser matthias.weisser@graf-syteco.de + * + * Configuation settings for the AT91SAM9260EK & AT91SAM9G20EK boards. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_JADE +#define CONFIG_JADE_IOCLK (41164767) +#define CONFIG_SYS_HZ (CONFIG_JADE_IOCLK / 16) +#define CONFIG_SYS_TIMERBASE 0xfffe0000 + +#define CONFIG_ARM926EJS 1 /* This is an ARM926EJS Core */ +#undef CONFIG_USE_IRQ /* we don't need IRQ/FIQ stuff */ + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 +#define BOARD_LATE_INIT 1 + +/* + * Hardware drivers + */ + +/* + * Serial + */ +#define CONFIG_SERIAL_MULTI +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE (-4) +#define CONFIG_SYS_NS16550_CLK CONFIG_JADE_IOCLK +#define CONFIG_SYS_NS16550_COM1 0xfffe1000 /* UART 0 */ +#define CONFIG_SYS_NS16550_COM2 0xfff50000 /* UART 2 (SP) */ +#define CONFIG_SYS_NS16550_COM3 0xfff51000 /* UART 3 */ +#define CONFIG_SYS_NS16550_COM4 0xfff43000 /* UART 4 */ + +#define CONFIG_CONS_INDEX 4 + +/* + * Ethernet + */ +#define CONFIG_NET_MULTI +#define CONFIG_SMC911X +#define CONFIG_SMC911X_BASE 0x02000000 +#define CONFIG_SMC911X_16_BIT + +/* + * Video + */ +#define CONFIG_VIDEO +#define CONFIG_VIDEO_JADEGDC +#define CONFIG_SYS_WHITE_ON_BLACK +#define CONFIG_CFB_CONSOLE +#define CONFIG_SYS_CONSOLE_IS_IN_ENV +#define CONFIG_SYS_CONSOLE_ENV_OVERWRITE +#define CONFIG_VIDEO_LOGO +#define CONFIG_SPLASH_SCREEN +#define CONFIG_SPLASH_SCREEN_ALIGN +#define CONFIG_VIDEO_BMP_LOGO +#define CONFIG_VIDEO_BMP_GZIP +#define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (800*480 + 256*4 + 10*1024) +#define VIDEO_KBD_INIT_FCT 0 +#define VIDEO_TSTC_FCT serial_tstc +#define VIDEO_GETC_FCT serial_getc + +/* + * BOOTP options + */ +#define CONFIG_BOOTP_BOOTFILESIZE 1 +#define CONFIG_BOOTP_BOOTPATH 1 +#define CONFIG_BOOTP_GATEWAY 1 +#define CONFIG_BOOTP_HOSTNAME 1 + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_IMI +#undef CONFIG_CMD_IMLS +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_SOURCE +#undef CONFIG_CMD_NFS +#undef CONFIG_CMD_XIMG + +#define CONFIG_CMD_IMI 1 +#define CONFIG_CMD_ELF 1 +#define CONFIG_CMD_PING 1 +#define CONFIG_CMD_DHCP 1 +#define CONFIG_CMD_BMP 1 +#define CONFIG_CMD_USB 1 +#define CONFIG_CMD_FAT 1 +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +/* USB */ +#define CONFIG_USB_OHCI_NEW +#define CONFIG_SYS_USB_OHCI_REGS_BASE 0xFFF81000 +#define CONFIG_SYS_USB_OHCI_SLOT_NAME "jadeusb" +#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 1 +#define CONFIG_USB_STORAGE +#define CONFIG_DOS_PARTITION + +/* SDRAM */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM 0x40000000 /* Start address of DDRRAM */ +#define PHYS_SDRAM_SIZE 0x08000000 /* 128 megs */ + +/* + * FLASH and environment organization + */ +#define CONFIG_SYS_FLASH_BASE 0x10000000 +#define CONFIG_SYS_MAX_FLASH_BANKS 1 +#define CONFIG_SYS_MAX_FLASH_SECT 256 +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE + +#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x00040000) +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_SECT_SIZE (128 * 1024) +#define CONFIG_ENV_SIZE (128 * 1024) + +/* + * CFI FLASH driver setup + */ +#define CONFIG_SYS_FLASH_CFI 1 +#define CONFIG_FLASH_CFI_DRIVER 1 +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 /* ~10x faster */ + +#define CONFIG_SYS_LOAD_ADDR 0x40000000 /* load address */ + +#define CONFIG_SYS_MEMTEST_START (PHYS_SDRAM + (512*1024)) +#define CONFIG_SYS_MEMTEST_END (PHYS_SDRAM + PHYS_SDRAM_SIZE) + +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {115200, 19200, 38400, 57600, 9600 } + +#define CONFIG_SYS_PROMPT "jade> " +#define CONFIG_SYS_CBSIZE 256 +#define CONFIG_SYS_MAXARGS 16 +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) \ + + 16) +#define CONFIG_SYS_LONGHELP 1 +#define CONFIG_CMDLINE_EDITING 1 + +#define CONFIG_BOOTDELAY 2 +#define CONFIG_AUTOBOOT_KEYED +#define CONFIG_AUTOBOOT_PROMPT "autoboot in %d seconds\n", bootdelay +#define CONFIG_AUTOBOOT_DELAY_STR "delaygs" +#define CONFIG_AUTOBOOT_STOP_STR "stopgs" + +/* + * Size of malloc() pool + */ +#define CONFIG_SYS_MALLOC_LEN (0x400000 - 0x8000) +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* 128 bytes for initial data */ + +#define CONFIG_STACKSIZE (32*1024) /* regular stack */ + +#ifdef CONFIG_USE_IRQ +#error CONFIG_USE_IRQ not supported +#endif + +#endif /* __CONFIG_H */ +
<snip>
Change to 'Syteco ARM926EJ-S Systems'
- @$(MKCONFIG) $(@:_config=) arm arm926ejs jadecpu syteco jade
<snip>
- printf("Boot reached stage %d\n", progress);
+} +#endif
- Miscellaneous platform dependent initialisations
board_init should fill out entries in struct global_data. See other board like lopgicpd/zoom1 as an example. Make sure to include the machine id.
- struct jade_ccnt * ccnt = (struct jade_ccnt *)JADE_CCNT_PHYS_BASE;
- /* We select mode 0 for group 2 and mode 1 for group 4 */
- writel(0x00000010, &ccnt->cmux_md);
- gd->flags = 0;
- icache_enable();
- struct jade_gpio *gpio = (struct jade_gpio *)JADE_GPIO_PHYS_BASE;
- struct jade_pwm *pwm;
- uint32_t in_word;
- const char *e;
- const char *s;
- /* Check if we have valid display settings and turn on power if so*/
ws Add as space between 'so*'
- /* Display 0 */
This should be conditional included if the video in included
#ifdef CONFIG_VIDEO_JADEGDC ..
- if (getenv("gs_dsp_0_param")) {
if (e != NULL) {
freq = 0;
init = 0;
s = strchr(e, 'f');
if (s != NULL)
s = strchr(e, 'i');
if (s != NULL)
if (freq > 0) {
&pwm->bcr);
The video patch has logic to fall back reading if (penv == NULL) { penv = getenv("videomode"); if ((i == 1) || (penv == NULL)) Should similar logic be added here ?
- writel(readl(&gpio->gpddr2) | (1 << 3), &gpio->gpddr2);
- /* Display 1 */
- if (getenv("gs_dsp_1_param")) {
if (e != NULL) {
freq = 0;
init = 0;
s = strchr(e, 'f');
if (s != NULL)
s = strchr(e, 'i');
if (s != NULL)
if (freq > 0) {
&pwm->bcr);
- writel(readl(&gpio->gpddr2) | (1 << 4), &gpio->gpddr2);
- /* 5V enable */
- writel(readl(&gpio->gpddr1) | (1 << 5), &gpio->gpddr1);
- writel(readl(&gpio->gpdr1) & ~(1 << 5), &gpio->gpdr1);
- /* We have special boot options if told by GPIOs */
- in_word = readl(&gpio->gpdr1);
- if ((in_word & 0xC0) == 0xC0) {
- } else if ((in_word & 0xC0) != 0) {
- } else{
ws space between 'else{'
else
- setenv("verify", "n");
This should be added to the list of #define CONFIG_EXTRA_ENV_SETTINGS set the the board config file.
- DRAM configuration
- gd->bd->bi_dram[0].start = PHYS_SDRAM;
- gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE;
- int rc = 0;
- rc = smc911x_initialize(0, CONFIG_SMC911X_BASE);
- return rc;
- Board specific setup info
- (C) Copyright 2007, mycable GmbH
- Carsten Schneider cs@mycable.de, Alexander Bigga ab@mycable.de
- (C) Copyright 2003, ARM Ltd.
- Philippe Robin, philippe.robin@arm.com
- project.
- This program is free software/* you can redistribute it and/or
ws remove '/*'
- published by the Free Software Foundation/* either version 2 of
ws remove '/*'
- but WITHOUT ANY WARRANTY/* without even the implied warranty of
ws remove '/*'
- along with this program/* if not, write to the Free Software
here too..
- MA 02111-1307 USA
- Initialize Clock Reset Generator (CRG)
- ldr r0, =JADE_CRG_PHYS_BASE
- /* Not change the initial value that is set by external pin.*/
Use a better label that '1:'
- tst r2, #0x00000100
- beq 1b
- /* Set clock gate control */
- ldr r1, =0x0000ffff /* Open */
- str r1, [r0, #CRG_CRHA] /* CRHA: AHB clock */
- str r1, [r0, #CRG_CRPA] /* CRPA: APB-A clock */
- ldr r1, =0xfffffffe /* Close */
- str r1, [r0, #CRG_CRPB] /* CRPA: APB-B clock */
- str r1, [r0, #CRG_CRHB] /* CRHB: ExtAHB clock */
- ldr r1, =0xffffffef /* Open ARM926EJ-S only */
- str r1, [r0, #CRG_CRAM] /* CRAM: ARM core clock */
- Initialize External Bus Interface
- ldr r0, =JADE_MEMC_PHYS_BASE
* XCS4: Flash
- ldr r1, =0x00000001 /* XCS0: 16bit */
- str r1, [r0, #0x00]
- ldr r1, =0x00000001 /* XCS2: 16bit */
- str r1, [r0, #0x08]
- ldr r1, =0x00000021 /* XCS4: 16bit, */
- str r1, [r0, #0x10]
- /* SRAM/flash _timing_ registers (HCLK=83.3/80MHz) */
- ldr r1, =0x03061008 /* XCS0: FPGA*/
- str r1, [r0, #0x20]
- ldr r1, =0x03061008 /* XCS2: Ethernet */
- str r1, [r0, #0x28]
- ldr r1, =0x03061804 /* XCS4: FLASH ROM */
- str r1, [r0, #0x30]
- /* SRAM/flash _area_ registers (address of XCS4 is set by hardware) */
- ldr r1, =0x000000c0 /* XCS0: 0x0c000000/1MB */
- str r1, [r0, #0x40]
- ldr r1, =0x00000020 /* XCS2: 0x02000000/1MB */
- str r1, [r0, #0x48]
- ldr r1, =0x001f0000 /* XCS4: 32 MB */
- str r1, [r0, #0x50]
- Initialize DDR2 Controller
- /* Wait for PLL LOCK up time or more */
- wait_timer 20
- ldr r0, =JADE_DDR2C_PHYS_BASE
- ldr r1, =0x5555
- strh r1, [r0, #DDR2C_DRIMS]
- wait_timer 20
This looks like a programming error /* -> */ ?
- ldr r0, =JADE_CCNT_PHYS_BASE
- ldr r1, =0x00000002
- str r1, [r0, #CCNT_CDCRC]
<snip>
- ldr r1, =0x0005 /* EMR(1) command */
- strh r1, [r0, #DDR2C_DRIC1]
- ldr r1, =0x0380 /* Extended Mode Register 1 set OCD */
- strh r1, [r0, #DDR2C_DRIC2]
- ldr r1, =0xc001
- strh r1, [r0, #DDR2C_DRIC]
- /* ldr r1, =0x0044 */
Do not include commented out code. Remove or add appropriate if-def
- ldr r1, =0x0002 /* EMR(1) set reduced strength */
- ldr r1, =0xc001
- ldr r1, =0x0032 /* Set BT, AL, CL, BL */
- strh r1, [r0, #DDR2C_DRCM]
- ldr r1, =0x3418 /* Set tRCD, tRAS, tRP, tRC */
- strh r1, [r0, #DDR2C_DRCST1]
- /* ldr r1, =0x2e22 */ /* Set tRFC, tRRD, tWR */
Same here..
- ldr r1, =0x6e32
- strh r1, [r0, #DDR2C_DRCST2]
- /* ldr r1, =0x0051 */ /* Set CNTL, REF_CNT*/
and here..
- ldr r1, =0x0141 /* (changed) */
- strh r1, [r0, #DDR2C_DRCR]
- ldr r1, =0x0002 /* Set Address FIFO (8 steps) */
- strh r1, [r0, #DDR2C_DRCF]
- ldr r1, =0x0001 /* Enable AXI Cache */
- strh r1, [r0, #DDR2C_DRASR]
* (11) ODT setting
- ldr r1, =0x0001
- strh r1, [r0, #DDR2C_DROBS]
- ldr r1, =0x0103 /* ODT auto adjustment on */
- strh r1, [r0, #DDR2C_DROABA]
- ldr r1, =0x003F /* Set ODT to on 50/100 Ohm */
- strh r1, [r0, #DDR2C_DRIBSODT1]
- ldr r1, =0x0001
- strh r1, [r0, #DDR2C_DROS]
- ldr r1, =0x4000
- mov pc, lr
- (C) Copyright 2007-2008
- Matthias Weisser matthias.weisser@graf-syteco.de
- Configuation settings for the AT91SAM9260EK & AT91SAM9G20EK boards.
- project.
- MA 02111-1307 USA
The board and cpu defines go first move the device configs to later
This is a strange number. please add a comment.
- Hardware drivers
- Serial
- Ethernet
- Video
This should be conditional on CONFIG_VIDEO_JADEDC
- BOOTP options
- Command line configuration.
ws convert spaces in the last 3 lines to tabs
Tom
Dear Matthias Weisser,
NAK.
Please remove this header completely. We don't add so much comments for a single board.
Also note that lists are sorted, so please move this entry to where it belongs.
Hello Wolfgang
Wolfgang Denk wd@denx.de schrieb am 16.01.2010 um 21:11:
NAK.
it
belongs.
Can you tell me where it belongs to then? In the ARM section of the makefile we have * StrongARM * ARM92xT * two Atmel related sections * ARM integrator boards * ARM supplied versatile development boards * S3C44B0 (Samsung) * ARM720T * ARM Cortex * XScale * ARM1136 * ARM1176
My board doesn't match any of the above categories so I thought introducing a new category for generic ARM926EJS devices would be a good idea.
Regards, Matthias
------------------------------------ Amtsgericht Freiburg HRA 602707 Ust. ID-Nr.: DE232464428
Geschäftsführer: Dipl. Ing. (FH) Martin Graf Dipl. Ing. (FH) David Graf Dipl. Inf. Fabian Graf
Komplementärin: GRAF-SYTECO Verwaltungs-GmbH Amtsgericht Freiburg HRB 602868 ------------------------------------
Dear "Matthias Weisser",
In the "ARM926EJ-S Systems" group?
- StrongARM
- ARM92xT
- two Atmel related sections
- ARM integrator boards
- ARM supplied versatile development boards
- S3C44B0 (Samsung)
- ARM720T
- ARM Cortex
- XScale
- ARM1136
- ARM1176
I also see an entry "Atmel ARM926EJ-S Systems" here, which already lists a numnber of arm926ejs boards.
Why do you think your board does not fit into the "Atmel ARM926EJ-S Systems" group?
Hello Wolfgang
Am 18.01.2010 08:57, schrieb Wolfgang Denk:
Because the MB86R01 'Jade' is not manufactured by Atmel. And therefore I thought that "Atmel ARM926EJ-S Systems" does not match.
Regards, Matthias
Dear =?ISO-8859-1?Q?Matthias_Wei=DFer?=,
In message 4B541A25.7060002@arcor.de you wrote:
Hello Wolfgang
Feel free to submit a patch to remove the "Atmel" part, then. It probably was added when only Atmel had ARM926EJ-S systems in the field.
Hi Tom
thanks for your feedback.
Am 16.01.2010 20:18, schrieb Tom:
As I don't use Linux on this board I don't have such an id. How to deal with such a situation? Should I get a machine id anyway? And if so can you give me a hint on how I can get such an id?
You are right. Thanks for catching this.
Can you please explain what you mean with this comment?
Well, it is the clock frequency of the IO blocks of the SoC. Its 14,31818 MHz * 46 / 16. I added a comment.
I have fixed the other stuff you pointed out.
Regards, Matthias
Yes, you are required to register a machine ID. See http://www.arm.linux.org.uk/developer/machines/?action=new
Am 18.01.2010 09:52, schrieb Wolfgang Denk:
I have registered a machine id now. Should I include the id into my reworked patch set or will that be synced with the linux kernel by one of the u-boot maintainers? I think the latter option has to be done but then my patch will not build until the sync takes place.
Regards, Matthias
You post a request to u-boot list and cc me. I do the sync-ing.
This normally happens once a month or so but I will do it as required. I will take care of this.
Tom
Regards, Matthias
I have updated the mach-types.h You can get this by sync-ing with u-boot-arm/master. Tom
Regards, Matthias
The grey S in the middle looks a bit lighter that what is on the website http://www.graf-syteco.de/html/deutsch/bediengerate.html
How the bmp is included looks fine. Tom
Am 16.01.2010 17:43, schrieb Tom:
Signed-off-by: Matthias Weissermatthias.weisser@graf-syteco.de
Thats OK. We use that bitmap since "ever" as logo in our devices and I think I am going to use it in u-boot also.
Regards, Matthias
Instead of adding CONFIG_VIDEO_JADEGDC, define VIDEO_FB_16BPP_WORD_SWAP in your board config file or a more appropriate file.
<snip>
- 4MB (at the end of system RAM)
- Graphic Device
It does not look like this global is accessed output of this function It should be declared static.
- GraphicDevice *pGD = &jadegdc;
- struct ctfb_res_modes var_mode[2];
- unsigned long *vid;
- unsigned long div;
- unsigned long dspBase[2];
- char *penv;
- int bpp;
- int i, j;
- memset(pGD, 0, sizeof(GraphicDevice));
- dspBase[0] = JADE_GDC_DISP0_PHYS_BASE;
- dspBase[1] = JADE_GDC_DISP1_PHYS_BASE;
- pGD->gdfIndex = GDF_15BIT_555RGB;
- pGD->gdfBytesPP = 2;
- pGD->memSize = VIDEO_MEM_SIZE;
- pGD->frameAdrs = PHYS_SDRAM + PHYS_SDRAM_SIZE - VIDEO_MEM_SIZE;
- vid = (unsigned long *)pGD->frameAdrs;
- for (i = 0; i < 2; i++) {
char varName[32];
u8 hsw, vsw;
if (penv == NULL) {
continue;
This check for (i == 1) should be moved before the getenv
bpp = 0;
<snip>
- return pGD;
- Set a RGB color in the LUT
If leaving this a noop is intentional, add a comment.
Tom
Am 16.01.2010 17:30, schrieb Tom:
Done.
- Graphic Device
Done.
- GraphicDevice *pGD =&jadegdc;
- char *penv;
- int bpp;
- int i, j;
- for (i = 0; i< 2; i++) {
char varName[32];
u8 hsw, vsw;
if (penv == NULL) {
continue;
Done.
Done.
Thanks for checking.
Regards, Matthias
- || defined(CONFIG_MPC85xx) || defined(CONFIG_MPC86xx) \
- || defined(CONFIG_JADE)
Including serial here is premature. I do not see where you set up there serial devices. Please save this for a later serial-only patch.
Otherwise this patch looks fine. Tom
Am 16.01.2010 16:39, schrieb Tom:
- || defined(CONFIG_JADE) #if defined(CONFIG_CONS_INDEX)&& defined(CONFIG_SYS_NS16550_SERIAL) #if (CONFIG_CONS_INDEX==1) return&eserial1_device;
Well, the SoC has UARTs which are fully compatible with the ns16550 driver (drivers/serial/serial.c) and therefore I simply set it up like this. What would be the right way to do it? I don't see a reason to add a serial_mb860x.c driver which is virtually identical to the current stuff in serial.c
Regards, Matthias
Please in the future use git format-patch -n This will number the patch set.
Tom
participants (5)
Matthias Weisser
Matthias Weisser
Matthias Weißer
Tom
