[PATCH] arm64: zynqmp: Add support for u-boot.itb generation with ATF.
Follow i.MX, Sunxi, RISC-V and Rockchip to generate u-boot.itb which includes U-Boot proper, ATF and DTBs in FIT format. ZynqMP supports FIT for quite a long time but with using out of tree solution. The patch is filling this gap.
Tested on zcu102, zcu104 and zcu100/Ultra96.
Kconfig | 3 +- arch/arm/mach-zynqmp/mkimage_fit_atf.sh | 99 +++++++++++++++++++++++++ include/configs/xilinx_zynqmp.h | 6 +- 3 files changed, 106 insertions(+), 2 deletions(-) create mode 100755 arch/arm/mach-zynqmp/mkimage_fit_atf.sh
diff --git a/Kconfig b/Kconfig index e22417ec4471..7efafffec0a4 100644 --- a/Kconfig +++ b/Kconfig @@ -253,7 +253,7 @@ config BUILD_TARGET default "u-boot-spl.kwb" if ARCH_MVEBU && SPL default "u-boot-elf.srec" if RCAR_GEN3 default "u-boot.itb" if SPL_LOAD_FIT && (ARCH_ROCKCHIP || \ - ARCH_SUNXI || RISCV) + ARCH_SUNXI || RISCV || ARCH_ZYNQMP) default "u-boot.kwb" if KIRKWOOD default "u-boot-with-spl.bin" if ARCH_AT91 && SPL_NAND_SUPPORT default "u-boot-with-spl.imx" if ARCH_MX6 && SPL @@ -481,6 +481,7 @@ config SPL_FIT_GENERATOR depends on SPL_FIT default "board/sunxi/mksunxi_fit_atf.sh" if SPL_LOAD_FIT && ARCH_SUNXI default "arch/arm/mach-rockchip/make_fit_atf.py" if SPL_LOAD_FIT && ARCH_ROCKCHIP + default "arch/arm/mach-zynqmp/mkimage_fit_atf.sh" if SPL_LOAD_FIT && ARCH_ZYNQMP default "arch/riscv/lib/mkimage_fit_opensbi.sh" if SPL_LOAD_FIT && RISCV help Specifies a (platform specific) script file to generate the FIT diff --git a/arch/arm/mach-zynqmp/mkimage_fit_atf.sh b/arch/arm/mach-zynqmp/mkimage_fit_atf.sh new file mode 100755 index 000000000000..1a4f396d1c3a --- /dev/null +++ b/arch/arm/mach-zynqmp/mkimage_fit_atf.sh @@ -0,0 +1,99 @@ +#!/bin/sh +# SPDX-License-Identifier: GPL-2.0+ +# +# script to generate FIT image source for Xilinx ZynqMP boards with +# ARM Trusted Firmware and multiple device trees (given on the command line) +# +# usage: $0 <dt_name> [<dt_name> [<dt_name] ...] + +BL33="u-boot-nodtb.bin" +[ -z "$BL31" ] && BL31="bl31.bin" +[ -z "$ATF_LOAD_ADDR" ] && ATF_LOAD_ADDR="0xfffe0000" +[ -z "$BL33_LOAD_ADDR" ] && BL33_LOAD_ADDR="0x8000000" + +if [ ! -f $BL31 ]; then + echo "ERROR: BL31 file $BL31 NOT found" >&2 +else + echo "$BL31 size: " >&2 + ls -lct $BL31 | awk '{print $5}' >&2 +fi + + + +cat << __HEADER_EOF +/dts-v1/; + +/ { + description = "Configuration to load ATF before U-Boot"; + + images { + uboot { + description = "U-Boot (64-bit)"; + data = /incbin/("$BL33"); + type = "firmware"; + os = "u-boot"; + arch = "arm64"; + compression = "none"; + load = <$BL33_LOAD_ADDR>; + hash { + algo = "md5"; + }; + }; + atf { + description = "ARM Trusted Firmware"; + data = /incbin/("$BL31"); + type = "firmware"; + os = "arm-trusted-firmware"; + arch = "arm64"; + compression = "none"; + load = <$ATF_LOAD_ADDR>; + entry = <$ATF_LOAD_ADDR>; + hash { + algo = "md5"; + }; + }; +__HEADER_EOF + +cnt=1 +for dtname in $* +do + cat << __FDT_IMAGE_EOF + fdt_$cnt { + description = "$(basename $dtname .dtb)"; + data = /incbin/("$dtname"); + type = "flat_dt"; + arch = "arm64"; + compression = "none"; + hash { + algo = "md5"; + }; + }; +__FDT_IMAGE_EOF +cnt=$((cnt+1)) +done + +cat << __CONF_HEADER_EOF + }; + configurations { + default = "config_1"; + +__CONF_HEADER_EOF + +cnt=1 +for dtname in $* +do +cat << __CONF_SECTION1_EOF + config_$cnt { + description = "$(basename $dtname .dtb)"; + firmware = "uboot"; + loadables = "atf"; + fdt = "fdt_$cnt"; + }; +__CONF_SECTION1_EOF +cnt=$((cnt+1)) +done + +cat << __ITS_EOF + }; +}; +__ITS_EOF diff --git a/include/configs/xilinx_zynqmp.h b/include/configs/xilinx_zynqmp.h index ee1ceebf1291..e7eb8dbfcb45 100644 --- a/include/configs/xilinx_zynqmp.h +++ b/include/configs/xilinx_zynqmp.h @@ -243,7 +243,11 @@ # define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTOR 0 /* unused */ # define CONFIG_SYS_MMCSD_RAW_MODE_ARGS_SECTORS 0 /* unused */ # define CONFIG_SYS_MMCSD_RAW_MODE_KERNEL_SECTOR 0 /* unused */ -# define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" +# if defined(CONFIG_SPL_LOAD_FIT) +# define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.itb" +# else +# define CONFIG_SPL_FS_LOAD_PAYLOAD_NAME "u-boot.img" +# endif #endif
#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_DFU)
Michal Simek
