[U-Boot] [PATCH] AT91: Small fix on AT91 USART initialization code
Before reset dbgu transmitter, we just wait TXEMPTY to drain the transmitter register. If not doing this, we may sometimes see several weird characters from DBGU.
A short delay is also added to make sure the new serial settings are settled.
Signed-off-by: Hong Xu hong.xu@atmel.com --- drivers/serial/atmel_usart.c | 8 +++++++- 1 files changed, 7 insertions(+), 1 deletions(-)
diff --git a/drivers/serial/atmel_usart.c b/drivers/serial/atmel_usart.c index e326b2b..0d5d254 100644 --- a/drivers/serial/atmel_usart.c +++ b/drivers/serial/atmel_usart.c @@ -49,17 +49,23 @@ int serial_init(void) { atmel_usart3_t *usart = (atmel_usart3_t *)CONFIG_USART_BASE;
+ /* Just in case: drain transmitter register */ + while (!(readl(&usart->csr) & USART3_BIT(TXEMPTY))) + ; + writel(USART3_BIT(RSTRX) | USART3_BIT(RSTTX), &usart->cr);
serial_setbrg();
- writel(USART3_BIT(RXEN) | USART3_BIT(TXEN), &usart->cr); writel((USART3_BF(USART_MODE, USART3_USART_MODE_NORMAL) | USART3_BF(USCLKS, USART3_USCLKS_MCK) | USART3_BF(CHRL, USART3_CHRL_8) | USART3_BF(PAR, USART3_PAR_NONE) | USART3_BF(NBSTOP, USART3_NBSTOP_1)), &usart->mr); + writel(USART3_BIT(RXEN) | USART3_BIT(TXEN), &usart->cr); + /* __udelay(100) is enough for the new settings to be settled */ + __udelay(100);
return 0; }
Dear Hong Xu,
Signed-off-by: Hong Xuhong.xu@atmel.com
- /* Just in case: drain transmitter register */
- while (!(readl(&usart->csr)& USART3_BIT(TXEMPTY)))
Are you sure-sure that can never hang, for example if the USART was never initialized or when the baudrate generator is not running? Can you rule out situations where TXREMPTY might not set because of previous states? Imagine NOR boot (or the 9XE) where not at91bootstrap might have run before?
writel(USART3_BIT(RSTRX) | USART3_BIT(RSTTX),&usart->cr);
serial_setbrg();
- writel(USART3_BIT(RXEN) | USART3_BIT(TXEN),&usart->cr); writel((USART3_BF(USART_MODE, USART3_USART_MODE_NORMAL) | USART3_BF(USCLKS, USART3_USCLKS_MCK) | USART3_BF(CHRL, USART3_CHRL_8) | USART3_BF(PAR, USART3_PAR_NONE) | USART3_BF(NBSTOP, USART3_NBSTOP_1)), &usart->mr);
- /* __udelay(100) is enough for the new settings to be settled */
- __udelay(100);
Not to be picky here, but "100us is enough for ..." reads nicer in the commentary:)
Best Regards, Reinhard
Hong Xu
Reinhard Meyer
