[PATCH 1/5] arm: mvebu: Espressobin: Move env load addresses
According to Marvell's U-Boot description [1] current env load addresses overlaps with ATF RT services region and TEE. Because the ATF RT service and TEE region is going to be marked as secure and can't be overwritten, use different different addresses for envs.
[1] - https://github.com/MarvellEmbeddedProcessors/u-boot-marvell/commit/0a5b15980...
Signed-off-by: Pali Rohár pali@kernel.org --- include/configs/mvebu_armada-37xx.h | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/include/configs/mvebu_armada-37xx.h b/include/configs/mvebu_armada-37xx.h index ca662b0ce7..ac0998a2d4 100644 --- a/include/configs/mvebu_armada-37xx.h +++ b/include/configs/mvebu_armada-37xx.h @@ -91,10 +91,10 @@ #include <config_distro_bootcmd.h>
#define CONFIG_EXTRA_ENV_SETTINGS \ - "scriptaddr=0x4d00000\0" \ - "pxefile_addr_r=0x4e00000\0" \ - "fdt_addr_r=0x4f00000\0" \ - "kernel_addr_r=0x5000000\0" \ + "scriptaddr=0x6d00000\0" \ + "pxefile_addr_r=0x6e00000\0" \ + "fdt_addr_r=0x6f00000\0" \ + "kernel_addr_r=0x7000000\0" \ "ramdisk_addr_r=0x8000000\0" \ BOOTENV
Current loadaddr is not writable on Espressobin and 'loadb' command cause rebooting board. Marvell's U-Boot already set default loadaddr to value 0x06000000 [1] and after this change 'loadb' is working fine.
Signed-off-by: Pali Rohár pali@kernel.org --- include/configs/mvebu_armada-37xx.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/mvebu_armada-37xx.h b/include/configs/mvebu_armada-37xx.h index ac0998a2d4..c6b0e2573a 100644 --- a/include/configs/mvebu_armada-37xx.h +++ b/include/configs/mvebu_armada-37xx.h @@ -37,7 +37,7 @@ /* * Other required minimal configurations */ -#define CONFIG_SYS_LOAD_ADDR 0x00800000 /* default load adr- 8M */ +#define CONFIG_SYS_LOAD_ADDR 0x06000000 /* default load adr */ #define CONFIG_SYS_RESET_ADDRESS 0xffff0000 /* Rst Vector Adr */ #define CONFIG_SYS_MAXARGS 32 /* max number of command args */
Thanks, Stefan
Boot scripts for existing Espressobin Linux distributions, like OpenWRT, expect that U-Boot set fdt_addr and kernel_addr envs. So add env aliases from fdt_addr_r and kernel_addr_r values.
Signed-off-by: Pali Rohár pali@kernel.org --- include/configs/mvebu_armada-37xx.h | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/include/configs/mvebu_armada-37xx.h b/include/configs/mvebu_armada-37xx.h index c6b0e2573a..6feceda757 100644 --- a/include/configs/mvebu_armada-37xx.h +++ b/include/configs/mvebu_armada-37xx.h @@ -90,10 +90,13 @@
+/* fdt_addr and kernel_addr are needed for existing distribution boot scripts */ #define CONFIG_EXTRA_ENV_SETTINGS \ "scriptaddr=0x6d00000\0" \ "pxefile_addr_r=0x6e00000\0" \ + "fdt_addr=0x6f00000\0" \ "fdt_addr_r=0x6f00000\0" \ + "kernel_addr=0x7000000\0" \ "kernel_addr_r=0x7000000\0" \ "ramdisk_addr_r=0x8000000\0" \ BOOTENV
Thanks, Stefan
Some distribution bootscripts append console env into boot cmdline. So define console env correctly to have early console access.
Signed-off-by: Pali Rohár pali@kernel.org --- include/configs/mvebu_armada-37xx.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/include/configs/mvebu_armada-37xx.h b/include/configs/mvebu_armada-37xx.h index 6feceda757..b473072976 100644 --- a/include/configs/mvebu_armada-37xx.h +++ b/include/configs/mvebu_armada-37xx.h @@ -17,6 +17,7 @@
#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, \ 115200, 230400, 460800, 921600 } +#define CONFIG_DEFAULT_CONSOLE "console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000"
/* * For booting Linux, the board info and command line data @@ -99,6 +100,7 @@ "kernel_addr=0x7000000\0" \ "kernel_addr_r=0x7000000\0" \ "ramdisk_addr_r=0x8000000\0" \ + "console=" CONFIG_DEFAULT_CONSOLE "\0" \ BOOTENV
#endif /* _CONFIG_MVEBU_ARMADA_37XX_H */
Thanks, Stefan
- For booting Linux, the board info and command line data
this breaks booting debian with systemd for me: [ 4.632197] systemd-udevd[90]: Starting version 241 [ 4.639324] systemd-udevd[91]: Failed to create udev control event source: Operation not permitted
"env delete console" and it works again.
The device tree already has 'stdout-path = "serial0:115200n8";' btw.
Regards, Andre
diff --git a/include/configs/mvebu_armada-37xx.h b/include/configs/mvebu_armada-37xx.h index 6feceda757..b473072976 100644 --- a/include/configs/mvebu_armada-37xx.h +++ b/include/configs/mvebu_armada-37xx.h @@ -17,6 +17,7 @@ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, \ 115200, 230400, 460800, 921600 } +#define CONFIG_DEFAULT_CONSOLE "console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000" /*
- "console=" CONFIG_DEFAULT_CONSOLE "\0" \ BOOTENV #endif /* _CONFIG_MVEBU_ARMADA_37XX_H */
This is really suspicious. Why systemd has problems with control socket when console= parameter is specified on boot command line? And if console= parameter is problematic on command line, why console output is working fine? For me it looks like this variable controls something different, not (only) console output. Maybe some bootscript sets something more when it see u-boot env ${console} non-empty?
I see. But it does not initialize earlycon.
diff --git a/include/configs/mvebu_armada-37xx.h b/include/configs/mvebu_armada-37xx.h index 6feceda757..b473072976 100644 --- a/include/configs/mvebu_armada-37xx.h +++ b/include/configs/mvebu_armada-37xx.h @@ -17,6 +17,7 @@ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, \ 115200, 230400, 460800, 921600 } +#define CONFIG_DEFAULT_CONSOLE "console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000" /* * For booting Linux, the board info and command line data @@ -99,6 +100,7 @@ "kernel_addr=0x7000000\0" \ "kernel_addr_r=0x7000000\0" \ "ramdisk_addr_r=0x8000000\0" \
It sounds like a bug in systemd, this may be related: https://github.com/systemd/systemd/issues/13332
With ugly workarounds like: https://github.com/openembedded/openembedded-core/commit/dd6ee0b06cd8df6204c...
This is easy for to me to work around, but note that this systemd version is the one shipping with current debian stable.
But this looks like to be related to command line 'console=null'.
Can you check which parameter is causing problem? console=... or earlycon=... ? Also do you have /dev/ttyMV0 in your system?
yup, it's there: crw--w---- 1 root tty 253, 0 Aug 26 15:09 /dev/ttyMV0
But I think it's related to console=null because it ends up as invalid: Your patch sets "console" to "console=...". Debian's boot.scr set "bootargs" to "... console=${console}". So we end up with with kernel args "console=console=..." :)
So we need to strip one "console=", at least for debian's boot scripts: "setenv console ttyMV0,115200 earlycon=ar3700_uart,0xd0012000" and it works again, including earlycon.
Regards, Andre
It is doing same thing as other boards in U-Boot, see:
$ git grep 'define.*CONFIG_DEFAULT_CONSOLE' include/configs/arndale.h:#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" include/configs/espresso7420.h:#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0" include/configs/odroid.h:#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0" include/configs/odroid_xu3.h:#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" include/configs/origen.h:#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0" include/configs/peach-pi.h:#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0" include/configs/peach-pit.h:#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0" include/configs/s5p_goni.h:#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" include/configs/s5pc210_universal.h:#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0" include/configs/smdk5250.h:#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0" include/configs/smdk5420.h:#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0" include/configs/smdk5420.h:#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0" include/configs/smdkv310.h:#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" include/configs/snow.h:#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0" include/configs/spring.h:#define CONFIG_DEFAULT_CONSOLE "console=ttySAC1,115200n8\0" include/configs/trats.h:#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" include/configs/trats2.h:#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0"
and:
$ git grep 'CONFIG_DEFAULT_CONSOLE' | grep -v ':#define' include/configs/odroid.h: "console=" CONFIG_DEFAULT_CONSOLE \ include/configs/odroid_xu3.h: "console=" CONFIG_DEFAULT_CONSOLE \ include/configs/s5p_goni.h: "console=" CONFIG_DEFAULT_CONSOLE \ include/configs/s5pc210_universal.h: "console=" CONFIG_DEFAULT_CONSOLE \ include/configs/trats.h: "console=" CONFIG_DEFAULT_CONSOLE \ include/configs/trats2.h: "console=" CONFIG_DEFAULT_CONSOLE \ scripts/config_whitelist.txt:CONFIG_DEFAULT_CONSOLE
So then also other U-Boot boards are broken in Debian... Where is that Debian's boot.scr file? In which package?
Armbian has 'setenv bootargs "$console ...' https://dl.armbian.com/espressobin/u-boot/bootscript/boot.cmd
OpenWRT has 'setenv bootargs "${bootargs} ${console}"' https://github.com/openwrt/openwrt/blob/master/target/linux/mvebu/image/gene...
So it seems that all expects that ${console} env contains 'console=tty...'
Regards, Andre
On 24/08/2020 16:25, Pali Rohár wrote: > Some distribution bootscripts append console env into boot cmdline. > So define console env correctly to have early console access. > > Signed-off-by: Pali Rohár pali@kernel.org > --- > include/configs/mvebu_armada-37xx.h | 2 ++ > 1 file changed, 2 insertions(+) > > diff --git a/include/configs/mvebu_armada-37xx.h b/include/configs/mvebu_armada-37xx.h > index 6feceda757..b473072976 100644 > --- a/include/configs/mvebu_armada-37xx.h > +++ b/include/configs/mvebu_armada-37xx.h > @@ -17,6 +17,7 @@ > #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, \ > 115200, 230400, 460800, 921600 } > +#define CONFIG_DEFAULT_CONSOLE "console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000" > /* > * For booting Linux, the board info and command line data > @@ -99,6 +100,7 @@ > "kernel_addr=0x7000000\0" \ > "kernel_addr_r=0x7000000\0" \ > "ramdisk_addr_r=0x8000000\0" \ > + "console=" CONFIG_DEFAULT_CONSOLE "\0" \ > BOOTENV > #endif /* _CONFIG_MVEBU_ARMADA_37XX_H */ >
and:
That would be flash-kernel: https://packages.qa.debian.org/f/flash-kernel.html
bootscript/all/bootscr.uboot-generic: setenv bootargs "${bootargs} console=${console}" bootscript/arm64/bootscr.uboot-generic: setenv bootargs "${bootargs} console=${console}" bootscript/armhf/bootscr.cubox:setenv bootargs @@LINUX_KERNEL_CMDLINE_DEFAULTS@@ console=${console} @@LINUX_KERNEL_CMDLINE@@ bootscript/armhf/bootscr.sunxi: setenv bootargs "${bootargs} console=${console}" debian/changelog: - If ${console} is set then add "console=${console}" to the bootargs.
The last entry points to: https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=783074
Which has:
I suppose hush doesn't have sufficient power to check for an existing console= in bootargs?
Not that I'm aware of.
So yeah...
Regards, Andre
Regards, Andre
and:
Looking at this again, CONFIG_DEFAULT_CONSOLE with "console=" doesn't look like a de facto standard to me:
$ ll include/configs/|wc -l 712
$ git grep CONFIG_DEFAULT_CONSOLE|grep define|wc -l 18
Only 18 out of +700 boards use it, and all of them ttySAC*, so probably just copy pasta. CONFIG_DEFAULT_CONSOLE looks like a leftover, it's not used anywhere except in those config headers. Some boards even define it, but don't use it, making it effectively dead.
On the other hand, check "git grep 'console='". So why not just add the earlycon to bootargs directly so it works everywhere?
Regards, Andre
The only useful thing about CONFIG_DEFAULT_CONSOLE and ${console} env is to propagate earlycon argument to kernel. As console kernel argument is already set via chosen/stdout in DTS.
Setting earlycon directly to ${bootargs} env does not work as basically all distribution scripts set/overwrite ${bootargs} on their own.
So we need to store earlycon argument into some other uboot env and then teach these distribution scripts to append that new uboot env into their bootargs...
Or is there any other way?
I don't know the answer to that, but as we've seen with $console, it's hard to get everyone on the same page.
But maybe it's not worth the hassle, since console works, and earlycon may only be interesting to ppl who know how to enable it anyway.
Regards, Andre
fyi: I opened a bug for this: https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=969070
Regards, Andre
Include information about permanent ethernet MAC address and add link how to build ATF as U-Boot on Espressobin cannot be flashed without ATF.
Signed-off-by: Pali Rohár pali@kernel.org --- doc/README.marvell | 40 +++++++++++++++++++++++++++++++++++++--- 1 file changed, 37 insertions(+), 3 deletions(-)
diff --git a/doc/README.marvell b/doc/README.marvell index 336461745c..da16316407 100644 --- a/doc/README.marvell +++ b/doc/README.marvell @@ -13,7 +13,8 @@ Build Procedure
2. Set the cross compiler:
- # export CROSS_COMPILE=/path/to/toolchain/aarch64-marvell-linux-gnu- + # sudo apt-get install gcc-aarch64-linux-gnu + # export CROSS_COMPILE=aarch64-linux-gnu-
3. Clean-up old residuals:
@@ -30,7 +31,7 @@ Build Procedure
5. Configure the device-tree and build the U-Boot image:
- Compile u-boot and set the required device-tree using: + For the Armada-70x0/80x0 DB board compile u-boot and set the required device-tree using:
# make DEVICE_TREE=<name>
@@ -42,12 +43,45 @@ Build Procedure In order to prevent this, the required device-tree MUST be set during compilation. All device-tree files are located in ./arch/arm/dts/ folder.
+ For other DB boards (MacchiatoBin, EsspressoBin and 3700 DB board) compile u-boot with + just default device-tree from defconfig using: + + # make + NOTE: The u-boot.bin should not be used as a stand-alone image. The ARM Trusted Firmware (ATF) build process uses this image to generate the - flash image. + flash image. See TF-A Build Instructions for Marvell Platforms for more details at: + https://trustedfirmware-a.readthedocs.io/en/latest/plat/marvell/armada/build...
Configuration update --------------------- To update the U-Boot configuration, please refer to doc/README.kconfig
+ +Permanent ethernet MAC address +------------------------------- + Prior flashing new U-Boot version (as part of ATF image) it is suggested to backup + permanent ethernet MAC address as it is stored only in U-Boot env storage (SPI or eMMC). + Some boards like EspressoBin have MAC address printed on sticker. To print current MAC + address run: + + # echo $ethaddr + + MAC addresses 00:51:82:11:22:00, 00:51:82:11:22:01, 00:51:82:11:22:02, 00:51:82:11:22:03 + and F0:AD:4E:03:64:7F are default hardcoded values found in Marvell's and Armbian U-Boot + forks and therefore *not* unique. Usage of static hardcoded MAC addresses should be avoided. + When original address is lost (e.g. erased by Armbian boot scripts for EspressoBin) it is + suggested to generate new random one. + + After flashing new U-Boot version it is suggested to reset U-Boot env variables to default + and then set correct permanent ethernet MAC address. + + # env default -a + # setenv ethaddr XX:XX:XX:XX:XX:XX + # saveenv + + Where XX:XX:XX:XX:XX:XX is permanent ethernet MAC address. + + Recent Linux kernel versions use correct permanent ethernet MAC address from U-Boot env as + U-Boot will inject it into kernel's device-tree.
Thanks, Stefan
Thanks, Stefan
Pali,
thank you for all these espressobin fixes, much appreciated!
This isn't directly related to the patch I'm replying to, but since you seem to be syncing down- with upstream:
Upstream u-boot doesn't detect my sata ssd ("SATA link 0 timeout"), nor is it able to run debian's kernel (hangs after "Starting kernel"). Both work with armbian's downstream flash-image.bin.
I'm using the espressobin v1 with these patches from the list on top of 2020.07: arm64: a37xx: pci: Depends on DM_GPIO arm: mvebu: Espressobin: Update README.marvell file arm: mvebu: Espressobin: Define console env arm: mvebu: Espressobin: Define fdt_addr and kernel_addr env aliases arm: mvebu: Espressobin: Change default loadaddr arm: mvebu: Espressobin: Move env load addresses arm: mvebu: Espressobin: Setup MTD partitions when booting kernel arm: mvebu: Espressobin: Make SPI env offset compatible with Marvell's U-Boot arm: dts: a37x0: enable sd card support on espressobin mmc: xenon: set signal voltage and max base clock arm64: a37xx: pci: Assert PERST# signal when unloading driver arm64: a37xx: pci: Make PCIe Reset GPIO DT compatible with Linux kernel DT arm64: dts: armada-3720-espressobin: fix COMPHY nodes arm: mvebu: Espressobin: Enable CONFIG_MVNETA arm: mvebu: Espressobin: Disallow forwarding packets between wan and lan ports
Bootlog:
TIM-1.0 WTMI-devel-18.12.1- WTMI: system early-init CPU VDD voltage default value: 1.108V NOTICE: Booting Trusted Firmware NOTICE: BL1: v2.3(): (Marvell-devel-18.12.0) NOTICE: BL1: Built : 06:12:46, Aug 26 2020 NOTICE: BL1: Booting BL2 NOTICE: BL2: v2.3(): (Marvell-devel-18.12.0) NOTICE: BL2: Built : 06:12:46, Aug 26 2020 NOTICE: BL1: Booting BL31 NOTICE: BL31: v2.3(): (Marvell-devel-18.12.0) NOTICE: BL31: Built : 06:12:46
U-Boot 2020.07 (Aug 26 2020 - 06:12:46 +0000)
DRAM: 1 GiB Comphy-0: USB3_HOST0 5 Gbps Comphy-1: PEX0 2.5 Gbps Comphy-2: SATA0 5 Gbps SATA link 0 timeout. AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode flags: ncq led only pmp fbss pio slum part sxs PCIE-0: Link up MMC: sdhci@d0000: 0 Loading Environment from SPI Flash... SF: Detected w25q32dw with page size 256 Bytes, erase size 4 KiB, total 4 MiB OK Model: Marvell Armada 3720 Community Board ESPRESSOBin Net: eth0: neta@30000 Hit any key to stop autoboot: 0 MMC Device 1 not found no mmc device at slot 1 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot.scr 2250 bytes read in 12 ms (182.6 KiB/s) ## Executing script at 06d00000 22079344 bytes read in 1219 ms (17.3 MiB/s) 10671 bytes read in 24 ms (433.6 KiB/s) 27689238 bytes read in 1555 ms (17 MiB/s) Booting Debian 5.7.0-0.bpo.2-arm64 from mmc 0:1... ## Flattened Device Tree blob at 06f00000 Booting using the fdt blob at 0x6f00000 Loading Ramdisk to 3e0be000, end 3fb26116 ... OK Loading Device Tree to 000000003e0b8000, end 000000003e0bd9ae ... OK
Starting kernel ... <hangs here>
Bootlog with armbian's flash-image-ddr3-1g-2cs-800_800.bin: TIM-1.0 WTMI-devel-18.12.1-e6bb176 WTMI: system early-init CPU VDD voltage default value: 1.108V NOTICE: Booting Trusted Firmware NOTICE: BL1: v1.5(release):1f8ca7e (Marvell-devel-18.12.2) NOTICE: BL1: Built : 16:22:53, May 21 2019 NOTICE: BL1: Booting BL2 NOTICE: BL2: v1.5(release):1f8ca7e (Marvell-devel-18.12.2) NOTICE: BL2: Built : 16:22:55, May 21 2019 NOTICE: BL1: Booting BL31 NOTICE: BL31: v1.5(release):1f8ca7e (Marvell-devel-18.12.2) NOTICE: BL31: Built : 16:22:58
U-Boot 2018.03-devel-18.12.3-gc9aa92c-armbian (Feb 20 2019 - 09:45:04 +0100)
Model: Marvell Armada 3720 Community Board ESPRESSOBin CPU 800 [MHz] L2 800 [MHz] TClock 200 [MHz] DDR 800 [MHz] DRAM: 1 GiB Comphy chip #0: Comphy-0: USB3 5 Gbps Comphy-1: PEX0 2.5 Gbps Comphy-2: SATA0 6 Gbps Target spinup took 0 ms. AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode flags: ncq led only pmp fbss pio slum part sxs PCIE-0: Link up MMC: sdhci@d0000: 0, sdhci@d8000: 1 Loading Environment from SPI Flash... SF: Detected w25q32dw with page size 256 Bytes, erase size 4 KiB, total 4 MiB OK Model: Marvell Armada 3720 Community Board ESPRESSOBin Net: eth0: neta@30000 [PRIME] Hit any key to stop autoboot: 0 / 2250 bytes read in 10 ms (219.7 KiB/s) ## Executing script at 06d00000 22079344 bytes read in 1231 ms (17.1 MiB/s) 10671 bytes read in 20 ms (520.5 KiB/s) 27689238 bytes read in 1570 ms (16.8 MiB/s) Booting Debian 5.7.0-0.bpo.2-arm64 from mmc 0:... ## Flattened Device Tree blob at 06000000 Booting using the fdt blob at 0x6000000 Loading Ramdisk to 3dbc2000, end 3f62a116 ... OK Using Device Tree in place at 0000000006000000, end 00000000060059ae
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 5.7.0-0.bpo.2-arm64 (debian-kernel@lists.debian.org) (gcc version 8.3.0 (Debian 8.3.0-6), GNU ld (GNU Binutils for Debian) 2.31.1) #1 SMP Debian 5.7.10-1~bpo10+1 (2020-07-30) [ 0.000000] Machine model: Globalscale Marvell ESPRESSOBin Board Any idea?
Thanks in advance! Andre
Hello!
On Wednesday 26 August 2020 09:30:11 Andre Heider wrote:
Pali,
Could you try following Marvell SATA/AHCI patch? https://github.com/MarvellEmbeddedProcessors/u-boot-marvell/commit/2c1571432...
Do you really have espressobin v1? I saw hw schemas and diagrams only for V3, V4, V5 and V7. And I tested only V5 as I do not have any other revisions.
Bootlog:
Starting kernel ...
<hangs here>
Can you write which commands you have run to load & boot kernel? What are command line arguments for kernel?
Also have you reset env variables to default?
On 26/08/2020 10:31, Pali Rohár wrote:
Hello!
Pali,
will do that later and report my findings, thanks!
Oh sorry, I meant the first public version, the one with ddr3 memory. Which would be the V5 schematics iirc.
Bootlog:
Starting kernel ...
<hangs here>
Yeah, I do reset the full env when switching between the flash images.
For the upstream version: env default -a setenv ethaddr f0:ad:4e:03:86:cd setenv eth1addr f0:ad:4e:03:86:cd setenv eth2addr f0:ad:4e:03:86:cd setenv serverip 192.168.0.40 setenv ipaddr 192.168.0.2 saveenv
For the downstream version: env default -a env delete console setenv fdt_addr_r 0x6000000 setenv kernel_addr_r 0x7000000 setenv ramdisk_addr_r 0x1100000 setenv ethaddr f0:ad:4e:03:86:cd setenv eth1addr f0:ad:4e:03:86:cd setenv eth2addr f0:ad:4e:03:86:cd setenv serverip 192.168.0.40 setenv ipaddr 192.168.0.2 setenv fdt_addr 0x6000000 setenv kernel_addr 0x7000000 setenv loadaddr 0x8000000 setenv initrd_size 0x2000000 setenv initrd_addr 0x1100000 setenv scriptaddr 0x6d00000 setenv initrd_image uInitrd setenv image_name Image setenv boot_targets 'mmc0 usb sata mmc1' setenv boot_prefixes '/ /boot/' setenv bootcmd_mmc0 'setenv devnum 0; setenv devtype mmc; run scan_dev_for_boot;' setenv bootcmd_mmc1 'setenv devnum 1; setenv devtype mmc; run scan_dev_for_boot;' setenv bootcmd_sata 'setenv devnum 0; scsi scan; scsi dev 0; setenv devtype scsi; run scan_dev_for_boot;' setenv bootcmd_usb 'setenv devnum 0; usb start;setenv devtype usb; run scan_dev_for_boot;' setenv bootcmd 'for target in ${boot_targets}; do run bootcmd_${target}; done' setenv scan_dev_for_boot 'for prefix in ${boot_prefixes}; do echo ${prefix};run boot_a_script; done' setenv boot_a_script 'ext4load ${devtype} ${devnum}:1 ${scriptaddr} ${prefix}boot.scr;source ${scriptaddr};' saveenv
Debian's boot.scr relies on u-boot's distro boot. Downstream still fails to enable it (even managed to break my patch to enable it...), so most of my env is to make it compatible again so I can use an unmodified userland.
Debian's script is rather boring then:
$ strings /boot/boot.scr boot script # flash-kernel: bootscr.uboot-generic # Bootscript using the new unified bootcmd handling # Expects to be called with the following environment variables set: # devtype e.g. mmc/scsi etc # devnum The device number of the given type # bootpart The partition containing the boot files # distro_bootpart The partition containing the boot files # (introduced in u-boot mainline 2016.01) # prefix Prefix within the boot partiion to the boot files # kernel_addr_r Address to load the kernel to # fdt_addr_r Address to load the FDT to # ramdisk_addr_r Address to load the initrd to. # The uboot must support the booti and generic filesystem load commands. if test -n "${console}"; then setenv bootargs "${bootargs} console=${console}" setenv bootargs ${bootargs} root=LABEL=espresso-root if test -z "${fk_kvers}"; then setenv fk_kvers '5.7.0-0.bpo.2-arm64' # These two blocks should be the same apart from the use of # ${fk_kvers} in the first, the syntax supported by u-boot does not # lend itself to removing this duplication. if test -n "${fdtfile}"; then setenv fdtpath dtbs/${fk_kvers}/${fdtfile} else setenv fdtpath dtb-${fk_kvers} if test -z "${distro_bootpart}"; then setenv partition ${bootpart} else setenv partition ${distro_bootpart} load ${devtype} ${devnum}:${partition} ${kernel_addr_r} ${prefix}vmlinuz-${fk_kvers} \ && load ${devtype} ${devnum}:${partition} ${fdt_addr_r} ${prefix}${fdtpath} \ && load ${devtype} ${devnum}:${partition} ${ramdisk_addr_r} ${prefix}initrd.img-${fk_kvers} \ && echo "Booting Debian ${fk_kvers} from ${devtype} ${devnum}:${partition}..." \ && booti ${kernel_addr_r} ${ramdisk_addr_r}:${filesize} ${fdt_addr_r} load ${devtype} ${devnum}:${partition} ${kernel_addr_r} ${prefix}vmlinuz \ && load ${devtype} ${devnum}:${partition} ${fdt_addr_r} ${prefix}dtb \ && load ${devtype} ${devnum}:${partition} ${ramdisk_addr_r} ${prefix}initrd.img \ && echo "Booting Debian from ${devtype} ${devnum}:${partition}..." \ && booti ${kernel_addr_r} ${ramdisk_addr_r}:${filesize} ${fdt_addr_r}
Regards, Andre
Hello!
Pali,
Bootlog:
Starting kernel ...
<hangs here>
Now I tried to boot openwrt kernel image and it is working fine on tested espressobin v5 unit. I compiled u-boot with all those a37xx patches.
DRAM: 512 MiB Comphy-0: USB3_HOST0 5 Gbps Comphy-1: PEX0 2.5 Gbps Comphy-2: SATA0 5 Gbps SATA link 0 timeout. AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode flags: ncq led only pmp fbss pio slum part sxs PCIE-0: Link up MMC: sdhci@d0000: 0 Loading Environment from SPIFlash... SF: Detected w25q32dw with page size 256 Bytes, erase size 4 KiB, total 4 MiB OK Model: Marvell Armada 3720 Community Board ESPRESSOBin Net: eth0: neta@30000 [PRIME] Hit any key to stop autoboot: 0 => env default -a ## Resetting to default environment => setenv bootargs "root=PARTUUID=aefd80c5-02 rw rootwait" => setenv bootargs "${bootargs} ${console}" => mmc dev 0 switch to partitions #0, OK mmc0 is current device => load mmc 0:1 ${fdt_addr} armada-3720-espressobin.dtb 10630 bytes read in 11 ms (943.4 KiB/s) => load mmc 0:1 ${kernel_addr} Image 10197000 bytes read in 436 ms (22.3 MiB/s) => booti ${kernel_addr} - ${fdt_addr} Moving Image from 0x7000000 to 0x7080000, end=7a82000 ## Flattened Device Tree blob at 06f00000 Booting using the fdt blob at 0x6f00000 Loading Device Tree to 000000001fb20000, end 000000001fb25985 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 5.4.59 (builder@buildhost) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 r14241-ba2ddba56b)) #0 SMP Mon Aug 24 00:09:30 2020 [ 0.000000] Machine model: Globalscale Marvell ESPRESSOBin Board [ 0.000000] earlycon: ar3700_uart0 at MMIO 0x00000000d0012000 (options '') [ 0.000000] printk: bootconsole [ar3700_uart0] enabled [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.1 [ 0.000000] percpu: Embedded 16 pages/cpu s26520 r8192 d30824 u65536 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: GIC system register CPU interface [ 0.000000] Speculative Store Bypass Disable mitigation not required [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 128512 [ 0.000000] Kernel command line: root=PARTUUID=aefd80c5-02 rw rootwait console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000 ...
Hello!
Pali,
Bootlog:
Starting kernel ...
<hangs here>
I looked at Debian and booting Debian kernel with Debian initrd failed:
=> booti ${kernel_addr_r} ${ramdisk_addr_r}:{filesize} ${fdt_addr_r} Moving Image from 0x7000000 to 0x7080000, end=82f2000 ERROR: RD image overlaps OS image (OS=0x7080000..0x82f2000)
Debian's kernel is big, so it is needed to move also ramdisk_addr_r env variable. Following patch helped:
diff --git a/include/configs/mvebu_armada-37xx.h b/include/configs/mvebu_armada-37xx.h index 6f72a13301..8929fcf390 100644 --- a/include/configs/mvebu_armada-37xx.h +++ b/include/configs/mvebu_armada-37xx.h @@ -99,7 +99,7 @@ "fdt_addr_r=0x6f00000\0" \ "kernel_addr=0x7000000\0" \ "kernel_addr_r=0x7000000\0" \ - "ramdisk_addr_r=0x8000000\0" \ + "ramdisk_addr_r=0xa000000\0" \ "console=" CONFIG_DEFAULT_CONSOLE "\0" \ BOOTENV
And after that Debian kernel with Debian initrd and FDT was booted:
DRAM: 512 MiB Comphy-0: USB3_HOST0 5 Gbps Comphy-1: PEX0 2.5 Gbps Comphy-2: SATA0 5 Gbps SATA link 0 timeout. AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode flags: ncq led only pmp fbss pio slum part sxs PCIE-0: Link up MMC: sdhci@d0000: 0 Loading Environment from SPIFlash... SF: Detected w25q32dw with page size 256 Bytes, erase size 4 KiB, total 4 MiB OK Model: Marvell Armada 3720 Community Board ESPRESSOBin Net: eth0: neta@30000 [PRIME] Hit any key to stop autoboot: 0 => env default -a ## Resetting to default environment => mmc dev 0 switch to partitions #0, OK mmc0 is current device => load mmc 0:2 ${fdt_addr_r} debian/armada-3720-espressobin.dtb 10553 bytes read in 17 ms (605.5 KiB/s) => load mmc 0:2 ${kernel_addr_r} debian/vmlinuz-4.19.0-10-arm64 18759536 bytes read in 804 ms (22.3 MiB/s) => load mmc 0:2 ${ramdisk_addr_r} debian/initrd.img-4.19.0-10-arm64 23890636 bytes read in 1013 ms (22.5 MiB/s) => setenv bootargs "$console root=/dev/mmcblk0p2 ro rootwait net.ifnames=0 biosdevname=0" => echo $bootargs console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000 root=/dev/mmcblk0p2 ro rootwait net.ifnames=0 biosdevname=0 => echo ${filesize} 16c8acc => booti ${kernel_addr_r} ${ramdisk_addr_r}:{filesize} ${fdt_addr_r} Moving Image from 0x7000000 to 0x7080000, end=82f2000 ## Flattened Device Tree blob at 06f00000 Booting using the fdt blob at 0x6f00000 Loading Ramdisk to 20000000, end 20000000 ... OK Loading Device Tree to 000000001f620000, end 000000001f625938 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 4.19.0-10-arm64 (debian-kernel@lists.debian.org) (gcc version 8.3.0 (Debian 8.3.0-6)) #1 SMP Debian 4.19.132-1 (2020-07-24) [ 0.000000] Machine model: Globalscale Marvell ESPRESSOBin Board [ 0.000000] earlycon: ar3700_uart0 at MMIO 0x00000000d0012000 (options '') [ 0.000000] bootconsole [ar3700_uart0] enabled [ 0.000000] efi: Getting EFI parameters from FDT: [ 0.000000] efi: UEFI not found. [ 0.000000] cma: Reserved 64 MiB at 0x000000001b400000 [ 0.000000] NUMA: No NUMA configuration found [ 0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x000000001fffffff] [ 0.000000] NUMA: NODE_DATA [mem 0x1ffe6600-0x1ffe7dbf] [ 0.000000] Zone ranges: [ 0.000000] DMA32 [mem 0x0000000000000000-0x000000001fffffff] [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000000000000-0x0000000003ffffff] [ 0.000000] node 0: [mem 0x0000000004200000-0x000000001fffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000001fffffff] [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.1 [ 0.000000] random: get_random_bytes called from start_kernel+0x9c/0x4c0 with crng_init=0 [ 0.000000] percpu: Embedded 25 pages/cpu s61976 r8192 d32232 u102400 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: enabling workaround for ARM erratum 845719 [ 0.000000] Speculative Store Bypass Disable mitigation not required [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 128512 [ 0.000000] Policy zone: DMA32 [ 0.000000] Kernel command line: console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000 root=/dev/mmcblk0p2 ro rootwait net.ifnames=0 biosdevname=0 ...
Hello!
Pali,
That one didn't help unfortunately. u-boot still prints "SATA link 0 timeout". Booting kernel 5.7.0-0.bpo.2-arm64 with that and sata works, but booting 4.19.0-10-arm64 and it doesn't: "ata1: SATA link down (SStatus 131 SControl 300)" is printed all over again.
Bootlog:
Starting kernel ...
<hangs here>
- "ramdisk_addr_r=0xa000000\0" \ "console=" CONFIG_DEFAULT_CONSOLE "\0" \ BOOTENV
Heh, nice. That indeed works!
Well minus one thing, see my reply to "arm: mvebu: Espressobin: Define console env".
Thanks, Andre
Hello!
Pali,
I guess it was broken also prior applying all those patches. So for now I do not have any fix for this. Somebody else would need to look at it.
Ok, I have sent a new version V2 of this patch series and updated first patch which fix also ramdisk_addr_r.
For now I have dropped this patch for V2, until it is solved/fixed in some way.
Hello!
Pali,
I found another patch which could maybe help: https://github.com/MarvellEmbeddedProcessors/u-boot-marvell/commit/6c6b2088f...
Or maybe with this patch:
diff --git a/arch/arm/dts/armada-3720-espressobin.dts b/arch/arm/dts/armada-3720-espressobin.dts index 4534f5ff29..c5eea978f6 100644 --- a/arch/arm/dts/armada-3720-espressobin.dts +++ b/arch/arm/dts/armada-3720-espressobin.dts @@ -95,6 +95,7 @@ phy2 { phy-type = <PHY_TYPE_SATA0>; phy-speed = <PHY_SPEED_5G>; + phy-invert = <COMPHY_POLARITY_NO_INVERT>; }; };
Hello!
On Wednesday 26 August 2020 09:30:11 Andre Heider wrote: > Pali, > > thank you for all these espressobin fixes, much appreciated! > > This isn't directly related to the patch I'm replying to, but since you seem > to be syncing down- with upstream: > > Upstream u-boot doesn't detect my sata ssd ("SATA link 0 timeout"), nor is
I think we have a winner:
U-Boot 2020.10-rc3-00020-gbcf6779d94 (Aug 28 2020 - 16:23:44 +0200)
DRAM: 1 GiB Comphy-0: USB3_HOST0 5 Gbps Comphy-1: PEX0 2.5 Gbps Comphy-2: SATA0 5 Gbps Target spinup took 0 ms. AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl SATA mode flags: ncq led only pmp fbss pio slum part sxs PCIE-0: Link up MMC: sdhci@d0000: 0 Loading Environment from SPIFlash... SF: Detected w25q32dw with page size 256 Bytes, erase size 4 KiB, total 4 MiB OK Model: Marvell Armada 3720 Community Board ESPRESSOBin Net: eth0: neta@30000 Hit any key to stop autoboot: 0 => scsi scan scanning bus for devices... Device 0: (0:0) Vendor: ATA Prod.: Crucial_CT250MX2 Rev: MU05 Type: Hard Disk Capacity: 238475.1 MB = 232.8 GB (488397168 x 512)
Nice, thanks! Will send the patch soon, Andre
On 26/08/2020 10:31, Pali Rohár wrote: > Hello! > > On Wednesday 26 August 2020 09:30:11 Andre Heider wrote: > > Pali, > > > > thank you for all these espressobin fixes, much appreciated! > > > > This isn't directly related to the patch I'm replying to, but since you seem > > to be syncing down- with upstream: > > > > Upstream u-boot doesn't detect my sata ssd ("SATA link 0 timeout"), nor is > > Could you try following Marvell SATA/AHCI patch? > https://github.com/MarvellEmbeddedProcessors/u-boot-marvell/commit/2c1571432...
Excellent!
Signed-off-by: Pali Rohár pali@kernel.org --- Changes in V2: * Move also ramdisk_addr_r, so there is enough space for kernel * Drop patch "Define console env" as it cause problems for Debian bootscript --- include/configs/mvebu_armada-37xx.h | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/include/configs/mvebu_armada-37xx.h b/include/configs/mvebu_armada-37xx.h index ca662b0ce7..a9ed0a838f 100644 --- a/include/configs/mvebu_armada-37xx.h +++ b/include/configs/mvebu_armada-37xx.h @@ -91,11 +91,11 @@ #include <config_distro_bootcmd.h>
#define CONFIG_EXTRA_ENV_SETTINGS \ - "scriptaddr=0x4d00000\0" \ - "pxefile_addr_r=0x4e00000\0" \ - "fdt_addr_r=0x4f00000\0" \ - "kernel_addr_r=0x5000000\0" \ - "ramdisk_addr_r=0x8000000\0" \ + "scriptaddr=0x6d00000\0" \ + "pxefile_addr_r=0x6e00000\0" \ + "fdt_addr_r=0x6f00000\0" \ + "kernel_addr_r=0x7000000\0" \ + "ramdisk_addr_r=0xa000000\0" \ BOOTENV
diff --git a/include/configs/mvebu_armada-37xx.h b/include/configs/mvebu_armada-37xx.h index a9ed0a838f..93c05e30cc 100644 --- a/include/configs/mvebu_armada-37xx.h +++ b/include/configs/mvebu_armada-37xx.h @@ -37,7 +37,7 @@ /* * Other required minimal configurations */ -#define CONFIG_SYS_LOAD_ADDR 0x00800000 /* default load adr- 8M */ +#define CONFIG_SYS_LOAD_ADDR 0x06000000 /* default load adr */ #define CONFIG_SYS_RESET_ADDRESS 0xffff0000 /* Rst Vector Adr */ #define CONFIG_SYS_MAXARGS 32 /* max number of command args */
Thanks, Stefan
- Other required minimal configurations
Viele Grüße, Stefan
Tested-by: Andre Heider a.heider@gmail.com
Applied to u-boot-marvell/master
Thanks, Stefan
Viele Grüße, Stefan
diff --git a/include/configs/mvebu_armada-37xx.h b/include/configs/mvebu_armada-37xx.h index 93c05e30cc..905ce09b7a 100644 --- a/include/configs/mvebu_armada-37xx.h +++ b/include/configs/mvebu_armada-37xx.h @@ -90,10 +90,13 @@
+/* fdt_addr and kernel_addr are needed for existing distribution boot scripts */ #define CONFIG_EXTRA_ENV_SETTINGS \ "scriptaddr=0x6d00000\0" \ "pxefile_addr_r=0x6e00000\0" \ + "fdt_addr=0x6f00000\0" \ "fdt_addr_r=0x6f00000\0" \ + "kernel_addr=0x7000000\0" \ "kernel_addr_r=0x7000000\0" \ "ramdisk_addr_r=0xa000000\0" \ BOOTENV
Thanks, Stefan
- "fdt_addr=0x6f00000\0" \ "fdt_addr_r=0x6f00000\0" \
- "kernel_addr=0x7000000\0" \ "kernel_addr_r=0x7000000\0" \ "ramdisk_addr_r=0xa000000\0" \ BOOTENV
Viele Grüße, Stefan
Thanks, Stefan
Viele Grüße, Stefan
+ For other DB boards (MacchiatoBin, EspressoBin and 3700 DB board) compile u-boot with + just default device-tree from defconfig using: + + # make + NOTE: The u-boot.bin should not be used as a stand-alone image. The ARM Trusted Firmware (ATF) build process uses this image to generate the - flash image. + flash image. See TF-A Build Instructions for Marvell Platforms for more details at: + https://trustedfirmware-a.readthedocs.io/en/latest/plat/marvell/armada/build...
Thanks, Stefan
- Set the cross compiler:
- Clean-up old residuals:
- Configure the device-tree and build the U-Boot image:
- For other DB boards (MacchiatoBin, EspressoBin and 3700 DB board) compile u-boot with
- just default device-tree from defconfig using:
# make
- NOTE: The u-boot.bin should not be used as a stand-alone image. The ARM Trusted Firmware (ATF) build process uses this image to generate the
- flash image.
- Prior flashing new U-Boot version (as part of ATF image) it is suggested to backup
- permanent ethernet MAC address as it is stored only in U-Boot env storage (SPI or eMMC).
- Some boards like EspressoBin have MAC address printed on sticker. To print current MAC
- address run:
# echo $ethaddr
- MAC addresses 00:51:82:11:22:00, 00:51:82:11:22:01, 00:51:82:11:22:02, 00:51:82:11:22:03
- and F0:AD:4E:03:64:7F are default hardcoded values found in Marvell's and Armbian U-Boot
- forks and therefore *not* unique. Usage of static hardcoded MAC addresses should be avoided.
- When original address is lost (e.g. erased by Armbian boot scripts for EspressoBin) it is
- suggested to generate new random one.
- After flashing new U-Boot version it is suggested to reset U-Boot env variables to default
- and then set correct permanent ethernet MAC address.
# env default -a
# saveenv
- Where XX:XX:XX:XX:XX:XX is permanent ethernet MAC address.
- Recent Linux kernel versions use correct permanent ethernet MAC address from U-Boot env as
- U-Boot will inject it into kernel's device-tree.
Viele Grüße, Stefan
Thanks, Stefan
# make
- flash image.
- address run:
# echo $ethaddr
# env default -a
# saveenv
Viele Grüße, Stefan
For the series: Tested-by: Andre Heider a.heider@gmail.com
Thanks again, finally I'm able to boot with an upstream atf/u-boot!
Hi Andre,
Could you please send such a mail with the TB tag for all the 4 out of 4 patches from this series? Reason being, that patchwork automatically collects these tags making it easier for me (and other maintainers) to keep track of these tags.
Thanks, Stefan
Thanks, Stefan
Changes in V2:
- Move also ramdisk_addr_r, so there is enough space for kernel
- Drop patch "Define console env" as it cause problems for Debian bootscript
Viele Grüße, Stefan
Thanks, Stefan
Changes in V2:
Viele Grüße, Stefan
Andre Heider
Pali Rohár
Stefan Roese
