Pull request for UEFI sub-system for efi-2020-10-rc1
The following changes since commit bcfe764ee925d0820e82c69ccf75b71d142644c7:
Merge tag 'efi-2020-07-rc6-2' of https://gitlab.denx.de/u-boot/custodians/u-boot-efi (2020-06-30 17:15:39 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-efi.git tags/efi-2020-10-rc1
for you to fetch changes up to 93f6201af71d9a0a521c99212e6066778270a357:
efi_loader: imply FAT, FAT_WRITE (2020-07-03 18:03:56 +0200)
---------------------------------------------------------------- Pull request for UEFI sub-system for efi-2020-10-rc1
This series comprises error corrections for the UEFI subsystem:
* correct consideration of timestamps for variable authentication * correct collection of data regions for code authentication * correct unit tests to test loading dbx * enable FAT_WRITE as required by the UEFI spec
The boot manager uses log functions instead of printf() and debug().
The UEFI intialization state is exported.
---------------------------------------------------------------- AKASHI Takahiro (7): efi_loader: change efi objects initialization order Revert "test: stabilize test_efi_secboot" efi_loader: signature: replace debug to EFI_PRINT efi_loader: variable: replace debug to EFI_PRINT efi_loader: image_loader: replace debug to EFI_PRINT test/py: efi_secboot: remove all "re.search" test/py: efi_secboot: fix test case 1g of test_authvar
Heinrich Schuchardt (9): test: correct time stamps for UEFI authentication efi_loader: fix efi_image_region_add() test: provide tests for efi_image_region_add() efi_loader: add missing validation of timestamp efi_loader: time based authentication efi_loader: use log function in boot manager efi_loader: rtc_mktime() called twice efi_loader: export initialization state efi_loader: imply FAT, FAT_WRITE
MAINTAINERS | 1 + include/efi_loader.h | 3 + lib/efi_loader/Kconfig | 2 + lib/efi_loader/efi_bootmgr.c | 26 ++-- lib/efi_loader/efi_image_loader.c | 64 +++++----- lib/efi_loader/efi_setup.c | 9 +- lib/efi_loader/efi_signature.c | 152 +++++++++++----------- lib/efi_loader/efi_variable.c | 52 +++++--- test/lib/Makefile | 1 + test/lib/efi_image_region.c | 163 ++++++++++++++++++++++++ test/py/tests/test_efi_secboot/conftest.py | 16 +-- test/py/tests/test_efi_secboot/test_authvar.py | 91 +++++++------ test/py/tests/test_efi_secboot/test_signed.py | 38 +++--- test/py/tests/test_efi_secboot/test_unsigned.py | 38 +++--- 14 files changed, 420 insertions(+), 236 deletions(-) create mode 100644 test/lib/efi_image_region.c
- correct consideration of timestamps for variable authentication
- correct collection of data regions for code authentication
- correct unit tests to test loading dbx
- enable FAT_WRITE as required by the UEFI spec
So, FAT_WRITE is required by the UEFI spec, ok. Are we exposing the ability to write files via the UEFI API? What happens if we return failure to write here? I'm asking because the first thing I see reviewing this is thee large number of platforms with: u-boot: add: 30/0, grow: 5/-4 bytes: 139792/-10412 (129380) function old new delta tmpbuf_cluster - 131072 +131072
For FAT write support. Perhaps another way of looking at it is, can we rework the FAT write support to get that buffer dynamically? Thanks!
Yes the UEFI API allows to write files. If the write fails we return an error code conforming to the UEFI specification.
But especially I want to save non-volatile UEFI variables on the EFI system partition in v2020.10. Cf. https://patchwork.ozlabs.org/project/uboot/list/?series=167069 Currently I am reworking that patch series.
I will send a patch to allocate tmpbuf_cluster dynamically.
Best regards
Heinrich
Given that I see you've addressed the size growth from FAT_WRITE, applied to u-boot/next, thanks!
