[U-Boot] [PATCH][v3] FDT: remove obsolete OF_CPU and OF_SOC macros.
Signed-off-by: Marcel Ziswiler marcel.ziswiler@noser.com Acked-by: Guennadi Liakhovetski g.liakhovetski@gmx.de --- Changes since v1: - CC all respective board maintainers Changes since v2: - Added Guennadi Liakhovetski's ack
README | 6 ++++-- include/configs/IDS8247.h | 2 -- include/configs/MPC8260ADS.h | 1 - include/configs/linkstation.h | 2 -- include/configs/mgcoge.h | 2 -- include/configs/mpc7448hpc2.h | 1 - include/configs/muas3001.h | 2 -- include/configs/stxxtc.h | 1 - 8 files changed, 4 insertions(+), 13 deletions(-)
diff --git a/README b/README index ff4ed8b..3cb7786 100644 --- a/README +++ b/README @@ -368,8 +368,10 @@ The following options need to be configured: * Adds the "fdt" command * The bootm command automatically updates the fdt
- OF_CPU - The proper name of the cpus node. - OF_SOC - The proper name of the soc node. + OF_CPU - The proper name of the cpus node (only required for + MPC512X and MPC5xxx based boards). + OF_SOC - The proper name of the soc node (only required for + MPC512X and MPC5xxx based boards). OF_TBCLK - The timebase frequency. OF_STDOUT_PATH - The path to the console device
diff --git a/include/configs/IDS8247.h b/include/configs/IDS8247.h index 4c4af05..147a8b2 100644 --- a/include/configs/IDS8247.h +++ b/include/configs/IDS8247.h @@ -125,8 +125,6 @@ #define CONFIG_OF_LIBFDT 1 #define CONFIG_OF_BOARD_SETUP 1
-#define OF_CPU "PowerPC,8247@0" -#define OF_SOC "soc@f0000000" #define OF_TBCLK (bd->bi_busfreq / 4) #define OF_STDOUT_PATH "/soc@f0000000/serial8250@e0008000"
diff --git a/include/configs/MPC8260ADS.h b/include/configs/MPC8260ADS.h index 942a4cc..677a143 100644 --- a/include/configs/MPC8260ADS.h +++ b/include/configs/MPC8260ADS.h @@ -209,7 +209,6 @@ #define CONFIG_OF_LIBFDT 1 #define CONFIG_OF_BOARD_SETUP 1 #if defined(CONFIG_OF_LIBFDT) -#define OF_CPU "cpu@0" #define OF_TBCLK (bd->bi_busfreq / 4) #endif
diff --git a/include/configs/linkstation.h b/include/configs/linkstation.h index 2feb3ae..16b464c 100644 --- a/include/configs/linkstation.h +++ b/include/configs/linkstation.h @@ -96,8 +96,6 @@
-#define OF_CPU "PowerPC,603e" -#define OF_SOC "soc10x@80000000" #define OF_STDOUT_PATH "/soc10x/serial@80004600"
/* this must be included AFTER the definition of CONFIG_COMMANDS (if any) */ diff --git a/include/configs/mgcoge.h b/include/configs/mgcoge.h index b955749..55d1fc9 100644 --- a/include/configs/mgcoge.h +++ b/include/configs/mgcoge.h @@ -347,8 +347,6 @@ #define CONFIG_OF_LIBFDT 1 #define CONFIG_OF_BOARD_SETUP 1
-#define OF_CPU "PowerPC,8247@0" -#define OF_SOC "soc@f0000000" #define OF_TBCLK (bd->bi_busfreq / 4) #define OF_STDOUT_PATH "/soc/cpm/serial@11a90"
diff --git a/include/configs/mpc7448hpc2.h b/include/configs/mpc7448hpc2.h index 4f98ba4..be12186 100644 --- a/include/configs/mpc7448hpc2.h +++ b/include/configs/mpc7448hpc2.h @@ -79,7 +79,6 @@ #define CONFIG_OF_LIBFDT 1 #define CONFIG_OF_BOARD_SETUP 1
-#define OF_CPU "PowerPC,7448@0" #define OF_TSI "tsi108@c0000000" #define OF_TBCLK (bd->bi_busfreq / 8) #define OF_STDOUT_PATH "/tsi108@c0000000/serial@7808" diff --git a/include/configs/muas3001.h b/include/configs/muas3001.h index ae033b2..c94daa3 100644 --- a/include/configs/muas3001.h +++ b/include/configs/muas3001.h @@ -405,8 +405,6 @@ #define CONFIG_OF_LIBFDT 1 #define CONFIG_OF_BOARD_SETUP 1
-#define OF_CPU "PowerPC,8270@0" -#define OF_SOC "soc@f0000000" #define OF_TBCLK (bd->bi_busfreq / 4) #if defined(CONFIG_MUAS_DEV_BOARD) #define OF_STDOUT_PATH "/soc/cpm/serial@11a90" diff --git a/include/configs/stxxtc.h b/include/configs/stxxtc.h index d16262b..5854366 100644 --- a/include/configs/stxxtc.h +++ b/include/configs/stxxtc.h @@ -509,7 +509,6 @@ typedef unsigned int led_id_t; /* pass open firmware flattened device tree */ #define CONFIG_OF_LIBFDT 1
-#define OF_CPU "PowerPC,MPC870@0" #define OF_TBCLK (MPC8XX_HZ / 16)
#endif /* __CONFIG_H */
Hello Marcel,
Changes since v1:
Changes since v2:
for the IDS8247, muas3001 and mgcoge board you get an
Acked-by: Heiko Schocher hs@denx.de
Thanks!
bye Heiko
Heiko Schocher
Marcel Ziswiler
