[U-Boot] [PATCH v2] Remove deprecated 'autoscr' command/variables
The more standard 'source' command provides identical functionality to the autoscr command.
Environment variable names/values on the MVBC_P, MVBML7, kmeter1, mgcoge, and km8xx boards are updated to no longer refernce 'autoscr'.
The 'autoscript' and 'autoscript_uname' environment variables are also removed.
Signed-off-by: Peter Tyser ptyser@xes-inc.com --- Changes since v1: - Removed all references to autoscript and autoscript_uname, previously just the autoscr command was removed.
README | 8 -------- board/LEOX/elpt860/README.LEOX | 2 +- board/matrix_vision/mvbc_p/mvbc_p_autoscript | 4 ++-- board/matrix_vision/mvblm7/mvblm7_autoscript | 4 ++-- board/musenki/README | 2 +- board/pn62/cmd_pn62.c | 18 ------------------ common/cmd_load.c | 18 ------------------ common/cmd_net.c | 15 --------------- common/cmd_source.c | 18 ------------------ doc/README.IPHASE4539 | 2 +- doc/README.m52277evb | 2 +- doc/README.m5373evb | 2 +- doc/README.m54455evb | 2 +- doc/README.m5475evb | 2 +- doc/feature-removal-schedule.txt | 19 ------------------- include/configs/MVBC_P.h | 14 +++++++------- include/configs/MVBLM7.h | 14 +++++++------- include/configs/keymile-common.h | 6 +++--- 18 files changed, 28 insertions(+), 124 deletions(-)
diff --git a/README b/README index ff4ed8b..67b8eb0 100644 --- a/README +++ b/README @@ -3008,14 +3008,6 @@ Some configuration options can be set using Environment Variables: configuration from the BOOTP server, but not try to load any image using TFTP
- autoscript - if set to "yes" commands like "loadb", "loady", - "bootp", "tftpb", "rarpboot" and "nfs" will attempt - to automatically run script images (by internally - calling "source"). - - autoscript_uname - if script image is in a format (FIT) this - variable is used to get script subimage unit name. - autostart - if set to "yes", an image loaded using the "bootp", "rarpboot", "tftpboot" or "diskboot" commands will be automatically started (by internally calling diff --git a/board/LEOX/elpt860/README.LEOX b/board/LEOX/elpt860/README.LEOX index 25524af..e8ab867 100644 --- a/board/LEOX/elpt860/README.LEOX +++ b/board/LEOX/elpt860/README.LEOX @@ -68,7 +68,6 @@ Type "run nfsboot" to mount root filesystem over NFS Hit any key to stop autoboot: 0 LEOX_elpt860: help askenv - get environment variables from stdin -autoscr - run script from memory base - print or set address offset bdinfo - print Board Info structure bootm - boot application image from memory @@ -100,6 +99,7 @@ run - run commands in an environment variable saveenv - save environment variables to persistent storage setenv - set environment variables sleep - delay execution for some time +source - run script from memory tftpboot- boot image via network using TFTP protocol and env variables ipaddr and serverip version - print monitor version diff --git a/board/matrix_vision/mvbc_p/mvbc_p_autoscript b/board/matrix_vision/mvbc_p/mvbc_p_autoscript index 1102354..9b21f30 100644 --- a/board/matrix_vision/mvbc_p/mvbc_p_autoscript +++ b/board/matrix_vision/mvbc_p/mvbc_p_autoscript @@ -26,7 +26,7 @@ if test ${oprofile} = yes; then setenv addprofile setenv bootargs ${bootargs} profile=${profile} fi -if test ${autoscr_boot} != no; +if test ${autoscript_boot} != no; then if test ${netboot} = yes; then @@ -44,5 +44,5 @@ then echo "=== bootfromflash ===" run cpdtb rundtb bootfromflash else - echo "=== boot stopped with autoscr_boot no ===" + echo "=== boot stopped with autoscript_boot no ===" fi diff --git a/board/matrix_vision/mvblm7/mvblm7_autoscript b/board/matrix_vision/mvblm7/mvblm7_autoscript index 6f9357f..dc385fd 100644 --- a/board/matrix_vision/mvblm7/mvblm7_autoscript +++ b/board/matrix_vision/mvblm7/mvblm7_autoscript @@ -21,7 +21,7 @@ setenv set_static_nm setenv netmask ${static_netmask} setenv set_static_gw setenv gatewayip ${static_gateway} setenv set_ip setenv ip ${ipaddr}::${gatewayip}:${netmask} setenv ramparam setenv bootargs root=/dev/ram0 ro rootfstype=squashfs -if test ${autoscr_boot} != no; +if test ${autoscript_boot} != no; then if test ${netboot} = yes; then @@ -39,5 +39,5 @@ then echo "=== bootfromflash ===" run cpdtb rundtb bootfromflash else - echo "=== boot stopped with autoscr_boot no ===" + echo "=== boot stopped with autoscript_boot no ===" fi diff --git a/board/musenki/README b/board/musenki/README index 135a01a..084ab54 100644 --- a/board/musenki/README +++ b/board/musenki/README @@ -34,7 +34,6 @@ Out: serial Err: serial Hit any key to stop autoboot: 0 => help -autoscr - run script from memory base - print or set address offset bdinfo - print Board Info structure bootm - boot application image from memory @@ -67,6 +66,7 @@ reset - Perform RESET of the CPU run - run commands in an environment variable saveenv - save environment variables to persistent storage setenv - set environment variables +source - run script from memory tftpboot- boot image via network using TFTP protocol and env variables ipaddr and serverip version - print monitor version diff --git a/board/pn62/cmd_pn62.c b/board/pn62/cmd_pn62.c index a989351..43295d6 100644 --- a/board/pn62/cmd_pn62.c +++ b/board/pn62/cmd_pn62.c @@ -152,24 +152,6 @@ int do_loadpci (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) rcode = do_bootm (cmdtp, 0, 1, local_args); }
-#ifdef CONFIG_SOURCE - if (load_addr) { - char *s; - - if (((s = getenv("autoscript")) != NULL) && (strcmp(s,"yes") == 0)) { - printf ("Running "source" command at addr 0x%08lX", - load_addr); - - s = getenv ("autoscript_uname"); - if (s) - printf (":%s ...\n", s); - else - puts (" ...\n"); - - rcode = source (load_addr, s); - } - } -#endif return rcode; }
diff --git a/common/cmd_load.c b/common/cmd_load.c index 73fbf74..d6bbb78 100644 --- a/common/cmd_load.c +++ b/common/cmd_load.c @@ -513,24 +513,6 @@ int do_load_serial_bin (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) } }
diff --git a/common/cmd_net.c b/common/cmd_net.c index 88f4e5b..b80a7ad 100644 --- a/common/cmd_net.c +++ b/common/cmd_net.c @@ -222,21 +222,6 @@ netboot_common (proto_t proto, cmd_tbl_t *cmdtp, int argc, char *argv[]) rcode = do_bootm (cmdtp, 0, 1, local_args); }
-#ifdef CONFIG_SOURCE - if (((s = getenv("autoscript")) != NULL) && (strcmp(s,"yes") == 0)) { - printf ("Running "source" command at addr 0x%08lX", - load_addr); - - s = getenv ("autoscript_uname"); - if (s) - printf (":%s ...\n", s); - else - puts (" ...\n"); - - show_boot_progress (83); - rcode = source (load_addr, s); - } -#endif if (rcode < 0) show_boot_progress (-83); else diff --git a/common/cmd_source.c b/common/cmd_source.c index 965b8b1..1424d30 100644 --- a/common/cmd_source.c +++ b/common/cmd_source.c @@ -236,22 +236,4 @@ U_BOOT_CMD( "unit name in the form of addr:<subimg_uname>" #endif ); - -/* - * Keep for now for backward compatibility; - * remove later when support for "autoscr" goes away. - */ -static int -do_autoscr (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) -{ - printf ("\n### WARNING ### " - ""autoscr" is deprecated, use "source" instead ###\n\n"); - return do_source (cmdtp, flag, argc, argv); -} - -U_BOOT_CMD( - autoscr, 2, 0, do_autoscr, - "DEPRECATED - use "source" command instead", - "" -); #endif diff --git a/doc/README.IPHASE4539 b/doc/README.IPHASE4539 index defad30..b804e06 100644 --- a/doc/README.IPHASE4539 +++ b/doc/README.IPHASE4539 @@ -54,7 +54,6 @@ connector as follows:
------------------------------------------------------------------------------ => help -autoscr - run script from memory base - print or set address offset bdinfo - print Board Info structure bootm - boot application image from memory @@ -88,6 +87,7 @@ run - run commands in an environment variable saveenv - save environment variables to persistent storage setenv - set environment variables sleep - delay execution for some time +source - run script from memory tftpboot- boot image via network using TFTP protocol and env variables ipaddr and serverip version - print monitor version diff --git a/doc/README.m52277evb b/doc/README.m52277evb index bec77b4..40f9028 100644 --- a/doc/README.m52277evb +++ b/doc/README.m52277evb @@ -184,7 +184,6 @@ baudrate = 115200 bps -> -> help ? - alias for 'help' -autoscr - run script from memory base - print or set address offset bdinfo - print Board Info structure boot - boot default, i.e., run 'bootcmd' @@ -227,5 +226,6 @@ run - run commands in an environment variable saveenv - save environment variables to persistent storage setenv - set environment variables sleep - delay execution for some time +source - run script from memory version - print monitor version -> diff --git a/doc/README.m5373evb b/doc/README.m5373evb index 0bd1101..5591748 100644 --- a/doc/README.m5373evb +++ b/doc/README.m5373evb @@ -195,7 +195,6 @@ baudrate = 115200 bps -> -> help ? - alias for 'help' -autoscr - run script from memory base - print or set address offset bdinfo - print Board Info structure boot - boot default, i.e., run 'bootcmd' @@ -243,6 +242,7 @@ run - run commands in an environment variable saveenv - save environment variables to persistent storage setenv - set environment variables sleep - delay execution for some time +source - run script from memory tftpboot- boot image via network using TFTP protocol version - print monitor version -> tftp 0x40800000 uImage diff --git a/doc/README.m54455evb b/doc/README.m54455evb index b769ff9..1888e16 100644 --- a/doc/README.m54455evb +++ b/doc/README.m54455evb @@ -276,7 +276,6 @@ baudrate = 115200 bps -> -> help ? - alias for 'help' -autoscr - run script from memory base - print or set address offset bdinfo - print Board Info structure boot - boot default, i.e., run 'bootcmd' @@ -332,6 +331,7 @@ run - run commands in an environment variable saveenv - save environment variables to persistent storage setenv - set environment variables sleep - delay execution for some time +source - run script from memory tftpboot- boot image via network using TFTP protocol version - print monitor version ->bootm 4000000 diff --git a/doc/README.m5475evb b/doc/README.m5475evb index 936c018..f3a1d7b 100644 --- a/doc/README.m5475evb +++ b/doc/README.m5475evb @@ -215,7 +215,6 @@ ip_addr = 192.162.1.2 baudrate = 115200 bps -> ? ? - alias for 'help' -autoscr - run script from memory base - print or set address offset bdinfo - print Board Info structure boot - boot default, i.e., run 'bootcmd' @@ -260,6 +259,7 @@ run - run commands in an environment variable saveenv - save environment variables to persistent storage setenv - set environment variables sleep - delay execution for some time +source - run script from memory tftpboot- boot image via network using TFTP protocol usb - USB sub-system usbboot - boot from USB device diff --git a/doc/feature-removal-schedule.txt b/doc/feature-removal-schedule.txt index 0238d97..5fe21e8 100644 --- a/doc/feature-removal-schedule.txt +++ b/doc/feature-removal-schedule.txt @@ -26,25 +26,6 @@ Who: Ben Warren biggerbadderben@gmail.com
-What: "autoscr" command -When: Release 2009-09 - -Why: "autosrc" is an ugly and completely non-standard name. - The "autoscr" command is deprecated and will be replaced by - - the "source" command as used by other shells such as bash. - - Starting with March 2009, both commands will be supported for - a transition period of 6 months after which "autoscr" will be - removed. During the transition period existing scripts and - environment variable names remain untouched for maximum - compatibiltiy; thse will be changed when support for the - "autoscr" command get's finally dropped. - -Who: Peter Tyser ptyser@xes-inc.com - ---------------------------- - What: GPL cleanup When: August 2009 Why: Over time, a couple of files have sneaked in into the U-Boot diff --git a/include/configs/MVBC_P.h b/include/configs/MVBC_P.h index 0c228cb..8f6b16b 100644 --- a/include/configs/MVBC_P.h +++ b/include/configs/MVBC_P.h @@ -73,8 +73,8 @@ #define MV_INITRD_LENGTH 0x00400000 #define MV_SCRATCH_ADDR 0x00000000 #define MV_SCRATCH_LENGTH MV_INITRD_LENGTH -#define MV_SOURCE_ADDR 0xff840000 -#define MV_SOURCE_ADDR2 0xff850000 +#define MV_SCRIPT_ADDR 0xff840000 +#define MV_SCRIPT_ADDR2 0xff850000 #define MV_DTB_ADDR 0xfffc0000
#define CONFIG_SHOW_BOOT_PROGRESS 1 @@ -130,9 +130,9 @@ #define CONFIG_ZERO_BOOTDELAY_CHECK #define CONFIG_RESET_TO_RETRY 1000
-#define CONFIG_BOOTCOMMAND "if imi ${autoscr_addr}; \ - then source ${autoscr_addr}; \ - else source ${autoscr_addr2}; \ +#define CONFIG_BOOTCOMMAND "if imi ${script_addr}; \ + then source ${script_addr}; \ + else source ${script_addr2}; \ fi;"
#define CONFIG_BOOTARGS "root=/dev/ram ro rootfstype=squashfs" @@ -150,8 +150,8 @@ "fpga=0\0" \ "fpgadata=" MK_STR(MV_FPGA_DATA) "\0" \ "fpgadatasize=" MK_STR(MV_FPGA_SIZE) "\0" \ - "autoscr_addr=" MK_STR(MV_SOURCE_ADDR) "\0" \ - "autoscr_addr2=" MK_STR(MV_SOURCE_ADDR2) "\0" \ + "script_addr=" MK_STR(MV_SCRIPT_ADDR) "\0" \ + "script_addr2=" MK_STR(MV_SCRIPT_ADDR2) "\0" \ "mv_kernel_addr=" MK_STR(MV_KERNEL_ADDR) "\0" \ "mv_kernel_addr_ram=" MK_STR(MV_KERNEL_ADDR_RAM) "\0" \ "mv_initrd_addr=" MK_STR(MV_INITRD_ADDR) "\0" \ diff --git a/include/configs/MVBLM7.h b/include/configs/MVBLM7.h index 80334bd..9835567 100644 --- a/include/configs/MVBLM7.h +++ b/include/configs/MVBLM7.h @@ -399,8 +399,8 @@ #define MV_FPGA_SIZE 0 #define MV_KERNEL_ADDR 0xff810000 #define MV_INITRD_ADDR 0xffb00000 -#define MV_SOURCE_ADDR 0xff804000 -#define MV_SOURCE_ADDR2 0xff806000 +#define MV_SCRIPT_ADDR 0xff804000 +#define MV_SCRIPT_ADDR2 0xff806000 #define MV_DTB_ADDR 0xff808000 #define MV_INITRD_LENGTH 0x00400000
@@ -410,9 +410,9 @@ #define MV_DTB_ADDR_RAM 0x00600000 #define MV_INITRD_ADDR_RAM 0x01000000
-#define CONFIG_BOOTCOMMAND "if imi ${autoscr_addr}; \ - then source ${autoscr_addr}; \ - else source ${autoscr_addr2}; \ +#define CONFIG_BOOTCOMMAND "if imi ${script_addr}; \ + then source ${script_addr}; \ + else source ${script_addr2}; \ fi;" #define CONFIG_BOOTARGS "root=/dev/ram ro rootfstype=squashfs"
@@ -425,8 +425,8 @@ "fpga=0\0" \ "fpgadata=" MK_STR(MV_FPGA_DATA) "\0" \ "fpgadatasize=" MK_STR(MV_FPGA_SIZE) "\0" \ - "autoscr_addr=" MK_STR(MV_SOURCE_ADDR) "\0" \ - "autoscr_addr2=" MK_STR(MV_SOURCE_ADDR2) "\0" \ + "script_addr=" MK_STR(MV_SCRIPT_ADDR) "\0" \ + "script_addr2=" MK_STR(MV_SCRIPT_ADDR2) "\0" \ "mv_kernel_addr=" MK_STR(MV_KERNEL_ADDR) "\0" \ "mv_kernel_addr_ram=" MK_STR(MV_KERNEL_ADDR_RAM) "\0" \ "mv_initrd_addr=" MK_STR(MV_INITRD_ADDR) "\0" \ diff --git a/include/configs/keymile-common.h b/include/configs/keymile-common.h index 0cc1b3b..80c41a4 100644 --- a/include/configs/keymile-common.h +++ b/include/configs/keymile-common.h @@ -171,7 +171,7 @@ "kernel_addr_r=200000\0" \ "fdt_addr_r=600000\0" \ "ram_ws=800000 \0" \ - "autoscr_ws=780000 \0" \ + "script_ws=780000 \0" \ "fdt_file=" xstr(CONFIG_HOSTNAME) "/" \ xstr(CONFIG_HOSTNAME) ".dtb\0" \ "u-boot=" xstr(CONFIG_HOSTNAME) "/u-boot.bin \0" \ @@ -253,8 +253,8 @@ "set_new_esw_script=setenv new_esw_script " \ "new_esw_0x${IVM_BoardId}_0x${IVM_HWKey}.scr \0" \ "new_esw=run set_new_esw_script; " \ - "tftp ${autoscr_ws} ${new_esw_script}; " \ - "iminfo ${autoscr_ws}; source ${autoscr_ws} \0" \ + "tftp ${script_ws} ${new_esw_script}; " \ + "iminfo ${script_ws}; source ${script_ws} \0" \ "bootlimit=0 \0" \ CONFIG_KM_DEF_ENV_IOMUX \ CONFIG_KM_DEF_ENV_PRIVATE \
Peter,
Changes since v1:
looks ok for mvBC-P and mvBL-M7.
Acked-by: Andre Schwarz andre.schwarz@matrix-vision.de
Thanks, André
MATRIX VISION GmbH, Talstrasse 16, DE-71570 Oppenweiler Registergericht: Amtsgericht Stuttgart, HRB 271090 Geschaeftsfuehrer: Gerhard Thullner, Werner Armingeon, Uwe Furtner, Hans-Joachim Reich
Hello Peter,
Changes since v1:
Thanks. Looks fine for the keymile boards.
Acked-by: Heiko Schocher hs@denx.de
bye Heiko
Dear Peter Tyser,
Changes since v1:
Applied, thanks.
André Schwarz
Heiko Schocher
Peter Tyser
