[U-Boot] [PATCH] env_sf: support embedded environments
If both CONFIG_ENV_SECT_SIZE and CONFIG_ENV_SIZE are defined, and the sect size is larger than the env size, then it means the env is embedded in a block. So we have to save/restore the part of the sector which is not the environment. Previously, saving the environment in SPI flash in this setup would probably brick the board as the rest of the sector tends to contain actual U-Boot data/code.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- common/env_sf.c | 41 ++++++++++++++++++++++++++++++++++++----- 1 files changed, 36 insertions(+), 5 deletions(-)
diff --git a/common/env_sf.c b/common/env_sf.c index 1bbf93f..2f52e25 100644 --- a/common/env_sf.c +++ b/common/env_sf.c @@ -27,6 +27,7 @@ */ #include <common.h> #include <environment.h> +#include <malloc.h> #include <spi_flash.h>
#ifndef CONFIG_ENV_SPI_BUS @@ -60,13 +61,30 @@ uchar env_get_char_spec(int index)
int saveenv(void) { + u32 saved_size, saved_offset; + char *saved_buffer = NULL; u32 sector = 1; + int ret;
if (!env_flash) { puts("Environment SPI flash not initialized\n"); return 1; }
+ /* Is the sector larger than the env (i.e. embedded) */ + if (CONFIG_ENV_SECT_SIZE > CONFIG_ENV_SIZE) { + saved_size = CONFIG_ENV_SECT_SIZE - CONFIG_ENV_SIZE; + saved_offset = CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE; + saved_buffer = malloc(saved_size); + if (!saved_buffer) { + ret = 1; + goto done; + } + ret = spi_flash_read(env_flash, saved_offset, saved_size, saved_buffer); + if (ret) + goto done; + } + if (CONFIG_ENV_SIZE > CONFIG_ENV_SECT_SIZE) { sector = CONFIG_ENV_SIZE / CONFIG_ENV_SECT_SIZE; if (CONFIG_ENV_SIZE % CONFIG_ENV_SECT_SIZE) @@ -74,15 +92,28 @@ int saveenv(void) }
puts("Erasing SPI flash..."); - if (spi_flash_erase(env_flash, CONFIG_ENV_OFFSET, sector * CONFIG_ENV_SECT_SIZE)) - return 1; + ret = spi_flash_erase(env_flash, CONFIG_ENV_OFFSET, sector * CONFIG_ENV_SECT_SIZE); + if (ret) + goto done;
puts("Writing to SPI flash..."); - if (spi_flash_write(env_flash, CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, env_ptr)) - return 1; + ret = spi_flash_write(env_flash, CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, env_ptr); + if (ret) + goto done; + + if (CONFIG_ENV_SECT_SIZE > CONFIG_ENV_SIZE) { + ret = spi_flash_write(env_flash, saved_offset, saved_size, saved_buffer); + if (ret) + goto done; + }
+ ret = 0; puts("done\n"); - return 0; + + done: + if (saved_buffer) + free(saved_buffer); + return ret; }
void env_relocate_spec(void)
Makes sense to me. Assuming this is how other types of flash work,
Acked-by: Haavard Skinnemoen haavard.skinnemoen@atmel.com
Dear Mike Frysinger,
Applied, thanks.
Haavard Skinnemoen
Mike Frysinger
