[U-Boot] [PATCH] nios2: add clear and set bits macros
These macros can be used to clear and set multiple bits in a register using a single call.
Signed-off-by: Thomas Chou thomas@wytron.com.tw --- arch/nios2/include/asm/io.h | 57 +++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 57 insertions(+)
diff --git a/arch/nios2/include/asm/io.h b/arch/nios2/include/asm/io.h index b4bd20f..123e885 100644 --- a/arch/nios2/include/asm/io.h +++ b/arch/nios2/include/asm/io.h @@ -116,4 +116,61 @@ static inline void outsl (unsigned long port, const void *src, unsigned long cou while (count--) outl (*p++, port); }
+/* + * Clear and set bits in one shot. These macros can be used to clear and + * set multiple bits in a register using a single call. These macros can + * also be used to set a multiple-bit bit pattern using a mask, by + * specifying the mask in the 'clear' parameter and the new bit pattern + * in the 'set' parameter. + */ + +#define out_arch(type,endian,a,v) __raw_write##type(cpu_to_##endian(v),a) +#define in_arch(type,endian,a) endian##_to_cpu(__raw_read##type(a)) + +#define out_le64(a,v) out_arch(q,le64,a,v) +#define out_le32(a,v) out_arch(l,le32,a,v) +#define out_le16(a,v) out_arch(w,le16,a,v) + +#define in_le64(a) in_arch(q,le64,a) +#define in_le32(a) in_arch(l,le32,a) +#define in_le16(a) in_arch(w,le16,a) + +#define out_be32(a,v) out_arch(l,be32,a,v) +#define out_be16(a,v) out_arch(w,be16,a,v) + +#define in_be32(a) in_arch(l,be32,a) +#define in_be16(a) in_arch(w,be16,a) + +#define out_8(a,v) __raw_writeb(v,a) +#define in_8(a) __raw_readb(a) + +#define clrbits(type, addr, clear) \ + out_##type((addr), in_##type(addr) & ~(clear)) + +#define setbits(type, addr, set) \ + out_##type((addr), in_##type(addr) | (set)) + +#define clrsetbits(type, addr, clear, set) \ + out_##type((addr), (in_##type(addr) & ~(clear)) | (set)) + +#define clrbits_be32(addr, clear) clrbits(be32, addr, clear) +#define setbits_be32(addr, set) setbits(be32, addr, set) +#define clrsetbits_be32(addr, clear, set) clrsetbits(be32, addr, clear, set) + +#define clrbits_le32(addr, clear) clrbits(le32, addr, clear) +#define setbits_le32(addr, set) setbits(le32, addr, set) +#define clrsetbits_le32(addr, clear, set) clrsetbits(le32, addr, clear, set) + +#define clrbits_be16(addr, clear) clrbits(be16, addr, clear) +#define setbits_be16(addr, set) setbits(be16, addr, set) +#define clrsetbits_be16(addr, clear, set) clrsetbits(be16, addr, clear, set) + +#define clrbits_le16(addr, clear) clrbits(le16, addr, clear) +#define setbits_le16(addr, set) setbits(le16, addr, set) +#define clrsetbits_le16(addr, clear, set) clrsetbits(le16, addr, clear, set) + +#define clrbits_8(addr, clear) clrbits(8, addr, clear) +#define setbits_8(addr, set) setbits(8, addr, set) +#define clrsetbits_8(addr, clear, set) clrsetbits(8, addr, clear, set) + #endif /* __ASM_NIOS2_IO_H_ */
Looks pretty standard,
Best regards, Marek Vasut
Hi Thomas,
Thanks for the patch. Sorry for the late comments as noticed all my mail for last few days was stuck in mail server.
- Clear and set bits in one shot. These macros can be used to clear and
- set multiple bits in a register using a single call. These macros can
- also be used to set a multiple-bit bit pattern using a mask, by
- specifying the mask in the 'clear' parameter and the new bit pattern
- in the 'set' parameter.
The 64bit support (q) is not yet available. This will break if someone using this.
same as above
Thanks Chin Liang
- out_##type((addr), in_##type(addr) & ~(clear))
- out_##type((addr), in_##type(addr) | (set))
- out_##type((addr), (in_##type(addr) & ~(clear)) | (set))
Signed-off-by: Thomas Chou thomas@wytron.com.tw Reviewed-by: Marek Vasut marex@denx.de --- v2 remove unsupported 64 btis macros as Chin Liang suggested.
arch/nios2/include/asm/io.h | 55 +++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 55 insertions(+)
diff --git a/arch/nios2/include/asm/io.h b/arch/nios2/include/asm/io.h index b4bd20f..2200dab 100644 --- a/arch/nios2/include/asm/io.h +++ b/arch/nios2/include/asm/io.h @@ -116,4 +116,59 @@ static inline void outsl (unsigned long port, const void *src, unsigned long cou while (count--) outl (*p++, port); }
+/* + * Clear and set bits in one shot. These macros can be used to clear and + * set multiple bits in a register using a single call. These macros can + * also be used to set a multiple-bit bit pattern using a mask, by + * specifying the mask in the 'clear' parameter and the new bit pattern + * in the 'set' parameter. + */ + +#define out_arch(type,endian,a,v) __raw_write##type(cpu_to_##endian(v),a) +#define in_arch(type,endian,a) endian##_to_cpu(__raw_read##type(a)) + +#define out_le32(a,v) out_arch(l,le32,a,v) +#define out_le16(a,v) out_arch(w,le16,a,v) + +#define in_le32(a) in_arch(l,le32,a) +#define in_le16(a) in_arch(w,le16,a) + +#define out_be32(a,v) out_arch(l,be32,a,v) +#define out_be16(a,v) out_arch(w,be16,a,v) + +#define in_be32(a) in_arch(l,be32,a) +#define in_be16(a) in_arch(w,be16,a) + +#define out_8(a,v) __raw_writeb(v,a) +#define in_8(a) __raw_readb(a) + +#define clrbits(type, addr, clear) \ + out_##type((addr), in_##type(addr) & ~(clear)) + +#define setbits(type, addr, set) \ + out_##type((addr), in_##type(addr) | (set)) + +#define clrsetbits(type, addr, clear, set) \ + out_##type((addr), (in_##type(addr) & ~(clear)) | (set)) + +#define clrbits_be32(addr, clear) clrbits(be32, addr, clear) +#define setbits_be32(addr, set) setbits(be32, addr, set) +#define clrsetbits_be32(addr, clear, set) clrsetbits(be32, addr, clear, set) + +#define clrbits_le32(addr, clear) clrbits(le32, addr, clear) +#define setbits_le32(addr, set) setbits(le32, addr, set) +#define clrsetbits_le32(addr, clear, set) clrsetbits(le32, addr, clear, set) + +#define clrbits_be16(addr, clear) clrbits(be16, addr, clear) +#define setbits_be16(addr, set) setbits(be16, addr, set) +#define clrsetbits_be16(addr, clear, set) clrsetbits(be16, addr, clear, set) + +#define clrbits_le16(addr, clear) clrbits(le16, addr, clear) +#define setbits_le16(addr, set) setbits(le16, addr, set) +#define clrsetbits_le16(addr, clear, set) clrsetbits(le16, addr, clear, set) + +#define clrbits_8(addr, clear) clrbits(8, addr, clear) +#define setbits_8(addr, set) setbits(8, addr, set) +#define clrsetbits_8(addr, clear, set) clrsetbits(8, addr, clear, set) + #endif /* __ASM_NIOS2_IO_H_ */
Hi Thomas,
Acked-by: Chin Liang See clsee@altera.com
Thanks Chin Liang
Applied to u-boot-nios.
Chin Liang See
Thomas Chou
