[U-Boot] [PATCH v2] powerpc/p2040rdb: Add p2040rdb board support
P2040RDB Specification: ----------------------- Memory subsystem: * 4Gbyte unbuffered DDR3 SDRAM SO-DIMM(64bit bus) * 128 Mbyte NOR flash single-chip memory * 256 Kbit M24256 I2C EEPROM * 16 Mbyte SPI memory * SD connector to interface with the SD memory card
Ethernet: * dTSEC1: connected to the Vitesse SGMII PHY (VSC8221) * dTSEC2: connected to the Vitesse SGMII PHY (VSC8221) * dTSEC3: connected to the Vitesse SGMII PHY (VSC8221) * dTSEC4: connected to the Vitesse RGMII PHY (VSC8641) * dTSEC5: connected to the Vitesse RGMII PHY (VSC8641)
PCIe: * Lanes E, F, G and H of Bank1 are connected to one x4 PCIe SLOT1 * Lanes C and Land D of Bank2 are connected to one x4 PCIe SLOT2
SATA: Lanes C and Land D of Bank2 are connected to two SATA connectors
USB 2.0: connected via a internal UTMI PHY to two TYPE-A interfaces
I2C: * I2C1: Real time clock, Temperature sensor, Memory module * I2C2: Vcore Regulator, 256Kbit I2C Bus EEPROM, PCIe slot1/2
UART: supports two UARTs up to 115200 bps for console
Signed-off-by: Mingkai Hu Mingkai.hu@freescale.com --- v2: - Fix some warning of checkpatch.pl, such as "line over 80 characters".
board/freescale/p2040rdb/Makefile | 56 ++++ board/freescale/p2040rdb/cpld.c | 171 ++++++++++ board/freescale/p2040rdb/cpld.h | 53 +++ board/freescale/p2040rdb/ddr.c | 115 +++++++ board/freescale/p2040rdb/law.c | 37 ++ board/freescale/p2040rdb/p2040rdb.c | 205 ++++++++++++ board/freescale/p2040rdb/pci.c | 39 +++ board/freescale/p2040rdb/tlb.c | 119 +++++++ boards.cfg | 3 + doc/README.p2040rdb | 123 +++++++ include/configs/P2040RDB.h | 624 +++++++++++++++++++++++++++++++++++ 11 files changed, 1545 insertions(+), 0 deletions(-) create mode 100644 board/freescale/p2040rdb/Makefile create mode 100644 board/freescale/p2040rdb/cpld.c create mode 100644 board/freescale/p2040rdb/cpld.h create mode 100644 board/freescale/p2040rdb/ddr.c create mode 100644 board/freescale/p2040rdb/law.c create mode 100644 board/freescale/p2040rdb/p2040rdb.c create mode 100644 board/freescale/p2040rdb/pci.c create mode 100644 board/freescale/p2040rdb/tlb.c create mode 100644 doc/README.p2040rdb create mode 100644 include/configs/P2040RDB.h
diff --git a/board/freescale/p2040rdb/Makefile b/board/freescale/p2040rdb/Makefile new file mode 100644 index 0000000..65f348f --- /dev/null +++ b/board/freescale/p2040rdb/Makefile @@ -0,0 +1,56 @@ +# +# Copyright 2011 Freescale Semiconductor, Inc. +# (C) Copyright 2001-2006 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +COBJS-y += $(BOARD).o +COBJS-y += cpld.o +COBJS-y += ddr.o +COBJS-y += law.o +COBJS-y += tlb.o +COBJS-$(CONFIG_PCI) += pci.o + +SRCS := $(SOBJS:.o=.S) $(COBJS-y:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS-y)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(call cmd_link_o_target, $(OBJS)) + +clean: + rm -f $(OBJS) $(SOBJS) + +distclean: clean + rm -f $(LIB) core *.bak .depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/freescale/p2040rdb/cpld.c b/board/freescale/p2040rdb/cpld.c new file mode 100644 index 0000000..8e1f46e --- /dev/null +++ b/board/freescale/p2040rdb/cpld.c @@ -0,0 +1,171 @@ +/** + * Copyright 2011 Freescale Semiconductor + * Author: Mingkai Hu Mingkai.hu@freescale.com + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the Free + * Software Foundation; either version 2 of the License, or (at your option) + * any later version. + * + * This file provides support for the board-specific CPLD used on some Freescale + * reference boards. + * + * The following macros need to be defined: + * + * CPLD_BASE - The virtual address of the base of the CPLD register map + * + */ + +#include <common.h> +#include <command.h> +#include <asm/io.h> + +#include "cpld.h" + +static u8 __cpld_read(unsigned int reg) +{ + void *p = (void *)CPLD_BASE; + + return in_8(p + reg); +} +u8 cpld_read(unsigned int reg) __attribute__((weak, alias("__cpld_read"))); + +static void __cpld_write(unsigned int reg, u8 value) +{ + void *p = (void *)CPLD_BASE; + + out_8(p + reg, value); +} +void cpld_write(unsigned int reg, u8 value) + __attribute__((weak, alias("__cpld_write"))); + +/* + * Reset the board. This honors the por_cfg registers. + */ +void __cpld_reset(void) +{ + CPLD_WRITE(system_rst, 1); +} +void cpld_reset(void) __attribute__((weak, alias("__cpld_reset"))); + +/** + * Set the boot bank to the alternate bank + */ +void __cpld_set_altbank(void) +{ + CPLD_WRITE(fbank_sel, 1); +} +void cpld_set_altbank(void) + __attribute__((weak, alias("__cpld_set_altbank"))); + +/** + * Set the boot bank to the default bank + */ +void __cpld_clear_altbank(void) +{ + CPLD_WRITE(fbank_sel, 0); +} +void cpld_clear_altbank(void) + __attribute__((weak, alias("__cpld_clear_altbank"))); + +#ifdef DEBUG +static void cpld_dump_regs(void) +{ + printf("cpld_ver = 0x%02x\n", CPLD_READ(cpld_ver)); + printf("cpld_ver_sub = 0x%02x\n", CPLD_READ(cpld_ver_sub)); + printf("pcba_ver = 0x%02x\n", CPLD_READ(pcba_ver)); + printf("system_rst = 0x%02x\n", CPLD_READ(system_rst)); + printf("wd_cfg = 0x%02x\n", CPLD_READ(wd_cfg)); + printf("sw_ctl_on = 0x%02x\n", CPLD_READ(sw_ctl_on)); + printf("por_cfg = 0x%02x\n", CPLD_READ(por_cfg)); + printf("switch_strobe = 0x%02x\n", CPLD_READ(switch_strobe)); + printf("jtag_sel = 0x%02x\n", CPLD_READ(jtag_sel)); + printf("sdbank1_clk = 0x%02x\n", CPLD_READ(sdbank1_clk)); + printf("sdbank2_clk = 0x%02x\n", CPLD_READ(sdbank2_clk)); + printf("fbank_sel = 0x%02x\n", CPLD_READ(fbank_sel)); + printf("serdes_mux = 0x%02x\n", CPLD_READ(serdes_mux)); + printf("SW[2] = 0x%02x\n", in_8(&CPLD_SW(2))); + putc('\n'); +} +#endif + +int cpld_cmd(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + int rc = 0; + unsigned int i; + + if (argc <= 1) + return cmd_usage(cmdtp); + + if (strcmp(argv[1], "reset") == 0) { + if (strcmp(argv[2], "altbank") == 0) + cpld_set_altbank(); + else + cpld_clear_altbank(); + + cpld_reset(); + } else if (strcmp(argv[1], "watchdog") == 0) { + static char *period[8] = {"1ms", "10ms", "30ms", "disable", + "100ms", "1s", "10s", "60s"}; + for (i = 0; i < ARRAY_SIZE(period); i++) { + if (strcmp(argv[2], period[i]) == 0) + CPLD_WRITE(wd_cfg, i); + } + } else if (strcmp(argv[1], "lane_mux") == 0) { + u32 lane = simple_strtoul(argv[2], NULL, 16); + u8 val = (u8)simple_strtoul(argv[3], NULL, 16); + u8 reg = CPLD_READ(serdes_mux); + + switch (lane) { + case 0x6: + reg &= ~SERDES_MUX_LANE_6_MASK; + reg |= val << SERDES_MUX_LANE_6_SHIFT; + break; + case 0xa: + reg &= ~SERDES_MUX_LANE_A_MASK; + reg |= val << SERDES_MUX_LANE_A_SHIFT; + break; + case 0xc: + reg &= ~SERDES_MUX_LANE_C_MASK; + reg |= val << SERDES_MUX_LANE_C_SHIFT; + break; + case 0xd: + reg &= ~SERDES_MUX_LANE_D_MASK; + reg |= val << SERDES_MUX_LANE_D_SHIFT; + break; + default: + printf("Invalid value\n"); + break; + } + + CPLD_WRITE(serdes_mux, reg); +#ifdef DEBUG + } else if (strcmp(argv[1], "dump") == 0) { + cpld_dump_regs(); +#endif + } else + rc = cmd_usage(cmdtp); + + return rc; +} + +U_BOOT_CMD( + cpld_cmd, CONFIG_SYS_MAXARGS, 1, cpld_cmd, + "Reset the board or pin mulexing selection using the CPLD sequencer", + "reset - hard reset to default bank\n" + "cpld_cmd reset altbank - reset to alternate bank\n" + "cpld_cmd watchdog <watchdog_period> - set the watchdog period\n" + " period: 1ms 10ms 30ms 100ms 1s 10s 60s disable\n" + "cpld_cmd lane_mux <lane> <mux_value> - set multiplexed lane pin\n" + " lane 6: 0 -> slot1 (Default)\n" + " 1 -> SGMII\n" + " lane a: 0 -> slot2 (Default)\n" + " 1 -> AURORA\n" + " lane c: 0 -> slot2 (Default)\n" + " 1 -> SATA0\n" + " lane d: 0 -> slot2 (Default)\n" + " 1 -> SATA1\n" +#ifdef DEBUG + "cpld_cmd dump - display the CPLD registers\n" +#endif + ); diff --git a/board/freescale/p2040rdb/cpld.h b/board/freescale/p2040rdb/cpld.h new file mode 100644 index 0000000..3b24cb0 --- /dev/null +++ b/board/freescale/p2040rdb/cpld.h @@ -0,0 +1,53 @@ +/** + * Copyright 2011 Freescale Semiconductor + * Author: Mingkai Hu Mingkai.hu@freescale.com + * + * This program is free software; you can redistribute it and/or modify it + * under the terms of the GNU General Public License as published by the Free + * Software Foundation; either version 2 of the License, or (at your option) + * any later version. + * + * This file provides support for the ngPIXIS, a board-specific FPGA used on + * some Freescale reference boards. + */ + +/* + * CPLD register set. Feel free to add board-specific #ifdefs where necessary. + */ +typedef struct cpld_data { + u8 cpld_ver; /* 0x0 - CPLD Major Revision Register */ + u8 cpld_ver_sub; /* 0x1 - CPLD Minor Revision Register */ + u8 pcba_ver; /* 0x2 - PCBA Revision Register */ + u8 system_rst; /* 0x3 - system reset register */ + u8 wd_cfg; /* 0x4 - Watchdog Period Setting Register */ + u8 sw_ctl_on; /* 0x5 - Switch Control Enable Register */ + u8 por_cfg; /* 0x6 - POR Control Register */ + u8 switch_strobe; /* 0x7 - Multiplexed pin Select Register */ + u8 jtag_sel; /* 0x8 - JTAG or AURORA Selection */ + u8 sdbank1_clk; /* 0x9 - SerDes Bank1 Reference clock */ + u8 sdbank2_clk; /* 0xa - SerDes Bank2 Reference clock */ + u8 fbank_sel; /* 0xb - Flash bank selection */ + u8 serdes_mux; /* 0xc - Multiplexed pin Select Register */ + u8 sw[1]; /* 0xd - SW2 Status */ +} __attribute__ ((packed)) cpld_data_t; + +#define SERDES_MUX_LANE_6_MASK 0x2 +#define SERDES_MUX_LANE_6_SHIFT 1 +#define SERDES_MUX_LANE_A_MASK 0x1 +#define SERDES_MUX_LANE_A_SHIFT 0 +#define SERDES_MUX_LANE_C_MASK 0x4 +#define SERDES_MUX_LANE_C_SHIFT 2 +#define SERDES_MUX_LANE_D_MASK 0x8 +#define SERDES_MUX_LANE_D_SHIFT 3 + +/* Pointer to the CPLD register set */ +#define cpld ((cpld_data_t *)CPLD_BASE) + +/* The CPLD SW register that corresponds to board switch X, where x >= 1 */ +#define CPLD_SW(x) (cpld->sw[(x) - 2]) + +u8 cpld_read(unsigned int reg); +void cpld_write(unsigned int reg, u8 value); + +#define CPLD_READ(reg) cpld_read(offsetof(cpld_data_t, reg)) +#define CPLD_WRITE(reg, value) cpld_write(offsetof(cpld_data_t, reg), value) diff --git a/board/freescale/p2040rdb/ddr.c b/board/freescale/p2040rdb/ddr.c new file mode 100644 index 0000000..46de910 --- /dev/null +++ b/board/freescale/p2040rdb/ddr.c @@ -0,0 +1,115 @@ +/* + * Copyright 2011 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License + * Version 2 as published by the Free Software Foundation. + */ + +#include <common.h> +#include <i2c.h> +#include <hwconfig.h> +#include <asm/mmu.h> +#include <asm/fsl_ddr_sdram.h> +#include <asm/fsl_ddr_dimm_params.h> +#include <asm/fsl_law.h> + +typedef struct { + u32 datarate_mhz_low; + u32 datarate_mhz_high; + u32 n_ranks; + u32 clk_adjust; + u32 wrlvl_start; + u32 cpo; + u32 write_data_delay; + u32 force_2T; +} board_specific_parameters_t; + +/* + * ranges for parameters: + * wr_data_delay = 0-6 + * clk adjust = 0-8 + * cpo 2-0x1E (30) + */ +const board_specific_parameters_t board_specific_parameters[] = { + /* + * memory controller 0 + * lo| hi| num| clk| wrlvl | cpo |wrdata|2T + * mhz| mhz|ranks|adjst| start | delay| + */ + { 1017, 1116, 2, 4, 6, 0xff, 2, 0}, +}; + +void fsl_ddr_board_options(memctl_options_t *popts, + dimm_params_t *pdimm, + unsigned int ctrl_num) +{ + const board_specific_parameters_t *pbsp = + &board_specific_parameters[0]; + u32 num_params = ARRAY_SIZE(board_specific_parameters); + u32 i; + ulong ddr_freq; + + /* + * Get clk_adjust, cpo, write_data_delay,2T, according to the board ddr + * freqency and n_banks specified in board_specific_parameters table. + */ + ddr_freq = get_ddr_freq(0) / 1000000; + for (i = 0; i < num_params; i++) { + if (ddr_freq >= pbsp->datarate_mhz_low && + ddr_freq <= pbsp->datarate_mhz_high && + pdimm[0].n_ranks == pbsp->n_ranks) { + popts->cpo_override = pbsp->cpo; + popts->write_data_delay = pbsp->write_data_delay; + popts->clk_adjust = pbsp->clk_adjust; + popts->wrlvl_start = pbsp->wrlvl_start; + popts->twoT_en = pbsp->force_2T; + break; + } + pbsp++; + } + + if (i == num_params) { + printf("Warning: board specific timing not found " + "for data rate %lu MT/s!\n", ddr_freq); + } + + /* + * Factors to consider for half-strength driver enable: + * - number of DIMMs installed + */ + popts->half_strength_driver_enable = 0; + /* Write leveling override */ + popts->wrlvl_override = 1; + popts->wrlvl_sample = 0xf; + + /* Rtt and Rtt_WR override */ + popts->rtt_override = 0; + + /* Enable ZQ calibration */ + popts->zq_en = 1; + + /* DHC_EN =1, ODT = 60 Ohm */ + popts->ddr_cdr1 = DDR_CDR1_DHC_EN; +} + +phys_size_t initdram(int board_type) +{ + phys_size_t dram_size = 0; + + puts("Initializing...."); + + if (fsl_use_spd()) { + puts("using SPD\n"); + dram_size = fsl_ddr_sdram(); + } else { + puts("no SPD and fixed parameters\n"); + return dram_size; + } + + dram_size = setup_ddr_tlbs(dram_size / 0x100000); + dram_size *= 0x100000; + + puts(" DDR: "); + return dram_size; +} diff --git a/board/freescale/p2040rdb/law.c b/board/freescale/p2040rdb/law.c new file mode 100644 index 0000000..127a478 --- /dev/null +++ b/board/freescale/p2040rdb/law.c @@ -0,0 +1,37 @@ +/* + * Copyright 2011 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/fsl_law.h> +#include <asm/mmu.h> + +struct law_entry law_table[] = { + SET_LAW(CONFIG_SYS_FLASH_BASE_PHYS, LAW_SIZE_256M, LAW_TRGT_IF_LBC), + SET_LAW(CONFIG_SYS_BMAN_MEM_PHYS, LAW_SIZE_2M, LAW_TRGT_IF_BMAN), + SET_LAW(CONFIG_SYS_QMAN_MEM_PHYS, LAW_SIZE_2M, LAW_TRGT_IF_QMAN), + SET_LAW(CPLD_BASE_PHYS, LAW_SIZE_4K, LAW_TRGT_IF_LBC), +#ifdef CONFIG_SYS_DCSRBAR_PHYS + SET_LAW(CONFIG_SYS_DCSRBAR_PHYS, LAW_SIZE_32M, LAW_TRGT_IF_DCSR), +#endif +}; + +int num_law_entries = ARRAY_SIZE(law_table); diff --git a/board/freescale/p2040rdb/p2040rdb.c b/board/freescale/p2040rdb/p2040rdb.c new file mode 100644 index 0000000..c08a40a --- /dev/null +++ b/board/freescale/p2040rdb/p2040rdb.c @@ -0,0 +1,205 @@ +/* + * Copyright 2011 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <netdev.h> +#include <linux/compiler.h> +#include <asm/mmu.h> +#include <asm/processor.h> +#include <asm/cache.h> +#include <asm/immap_85xx.h> +#include <asm/fsl_law.h> +#include <asm/fsl_serdes.h> +#include <asm/fsl_portals.h> +#include <asm/fsl_liodn.h> + +extern void pci_of_setup(void *blob, bd_t *bd); + +#include "cpld.h" + +DECLARE_GLOBAL_DATA_PTR; + +int checkboard(void) +{ + u8 sw; + struct cpu_type *cpu = gd->cpu; + ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; + unsigned int i; + + printf("Board: %sRDB, ", cpu->name); + printf("CPLD version: %d.%d ", CPLD_READ(cpld_ver), + CPLD_READ(cpld_ver_sub)); + + sw = CPLD_READ(fbank_sel); + printf("vBank: %d\n", sw & 0x1); + +#ifdef CONFIG_PHYS_64BIT + puts("36-bit Addressing\n"); +#endif + + /* + * Display the RCW, so that no one gets confused as to what RCW + * we're actually using for this boot. + */ + puts("Reset Configuration Word (RCW):"); + for (i = 0; i < ARRAY_SIZE(gur->rcwsr); i++) { + u32 rcw = in_be32(&gur->rcwsr[i]); + + if ((i % 4) == 0) + printf("\n %08x:", i * 4); + printf(" %08x", rcw); + } + puts("\n"); + + /* + * Display the actual SERDES reference clocks as configured by the + * dip switches on the board. Note that the SWx registers could + * technically be set to force the reference clocks to match the + * values that the SERDES expects (or vice versa). For now, however, + * we just display both values and hope the user notices when they + * don't match. + */ + puts("SERDES Reference Clocks: "); + sw = in_8(&CPLD_SW(2)) >> 2; + for (i = 0; i < 2; i++) { + static const char * const freq[] = {"0", "100", "125"}; + unsigned int clock = (sw >> (2 * i)) & 3; + + printf("Bank%u=%sMhz ", i+1, freq[clock]); + } + puts("\n"); + + return 0; +} + +int board_early_init_f(void) +{ + ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); + + /* + * P2040 RDB board only uses the DDR_MCK0/1, so disable the DDR_MCK2/3 + */ + setbits_be32(&gur->ddrclkdr, 0x000f000f); + + return 0; +} + +int board_early_init_r(void) +{ + const unsigned int flashbase = CONFIG_SYS_FLASH_BASE; + const u8 flash_esel = find_tlb_idx((void *)flashbase, 1); + + /* + * Remap Boot flash + PROMJET region to caching-inhibited + * so that flash can be erased properly. + */ + + /* Flush d-cache and invalidate i-cache of any FLASH data */ + flush_dcache(); + invalidate_icache(); + + /* invalidate existing TLB entry for flash + promjet */ + disable_tlb(flash_esel); + + set_tlb(1, flashbase, CONFIG_SYS_FLASH_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, flash_esel, BOOKE_PAGESZ_256M, 1); + + set_liodns(); + setup_portals(); + + return 0; +} + +static const char *serdes_clock_to_string(u32 clock) +{ + switch (clock) { + case SRDS_PLLCR0_RFCK_SEL_100: + return "100"; + case SRDS_PLLCR0_RFCK_SEL_125: + return "125"; + case SRDS_PLLCR0_RFCK_SEL_156_25: + return "156.25"; + default: + return "150"; + } +} + +#define NUM_SRDS_BANKS 2 + +int misc_init_r(void) +{ + serdes_corenet_t *regs = (void *)CONFIG_SYS_FSL_CORENET_SERDES_ADDR; + u32 actual[NUM_SRDS_BANKS]; + unsigned int i; + u8 sw; + + sw = in_8(&CPLD_SW(2)) >> 2; + for (i = 0; i < NUM_SRDS_BANKS; i++) { + unsigned int clock = (sw >> (2 * i)) & 3; + switch (clock) { + case 1: + actual[i] = SRDS_PLLCR0_RFCK_SEL_100; + break; + case 2: + actual[i] = SRDS_PLLCR0_RFCK_SEL_125; + break; + default: + printf("Warning: SDREFCLK%u switch setting of '11' is " + "unsupported\n", i + 1); + break; + } + } + + for (i = 0; i < NUM_SRDS_BANKS; i++) { + u32 expected = in_be32(®s->bank[i].pllcr0); + expected &= SRDS_PLLCR0_RFCK_SEL_MASK; + if (expected != actual[i]) { + printf("Warning: SERDES bank %u expects reference clock" + " %sMHz, but actual is %sMHz\n", i + 1, + serdes_clock_to_string(expected), + serdes_clock_to_string(actual[i])); + } + } + + return 0; +} + +void ft_board_setup(void *blob, bd_t *bd) +{ + phys_addr_t base; + phys_size_t size; + + ft_cpu_setup(blob, bd); + + base = getenv_bootm_low(); + size = getenv_bootm_size(); + + fdt_fixup_memory(blob, (u64)base, (u64)size); + +#ifdef CONFIG_PCI + pci_of_setup(blob, bd); +#endif + + fdt_fixup_liodn(blob); +} diff --git a/board/freescale/p2040rdb/pci.c b/board/freescale/p2040rdb/pci.c new file mode 100644 index 0000000..1ab4cdf --- /dev/null +++ b/board/freescale/p2040rdb/pci.c @@ -0,0 +1,39 @@ +/* + * Copyright 2011 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <command.h> +#include <pci.h> +#include <asm/fsl_pci.h> +#include <libfdt.h> +#include <fdt_support.h> +#include <asm/fsl_serdes.h> + +void pci_init_board(void) +{ + fsl_pcie_init_board(0); +} + +void pci_of_setup(void *blob, bd_t *bd) +{ + FT_FSL_PCI_SETUP; +} diff --git a/board/freescale/p2040rdb/tlb.c b/board/freescale/p2040rdb/tlb.c new file mode 100644 index 0000000..43f28ed --- /dev/null +++ b/board/freescale/p2040rdb/tlb.c @@ -0,0 +1,119 @@ +/* + * Copyright 2011 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/mmu.h> + +struct fsl_e_tlb_entry tlb_table[] = { + /* TLB 0 - for temp stack in cache */ + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR, + CONFIG_SYS_INIT_RAM_ADDR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 4 * 1024, + CONFIG_SYS_INIT_RAM_ADDR_PHYS + 4 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 8 * 1024, + CONFIG_SYS_INIT_RAM_ADDR_PHYS + 8 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + SET_TLB_ENTRY(0, CONFIG_SYS_INIT_RAM_ADDR + 12 * 1024, + CONFIG_SYS_INIT_RAM_ADDR_PHYS + 12 * 1024, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 0, BOOKE_PAGESZ_4K, 0), + + SET_TLB_ENTRY(0, CPLD_BASE, CPLD_BASE_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 0, BOOKE_PAGESZ_4K, 0), + + /* TLB 1 */ + /* *I*** - Covers boot page */ +#if defined(CONFIG_SYS_RAMBOOT) && defined(CONFIG_SYS_INIT_L3_ADDR) + /* + * *I*G - L3SRAM. When L3 is used as 1M SRAM, the address of the + * SRAM is at 0xfff00000, it covered the 0xfffff000. + */ + SET_TLB_ENTRY(1, CONFIG_SYS_INIT_L3_ADDR, CONFIG_SYS_INIT_L3_ADDR, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 0, BOOKE_PAGESZ_1M, 1), +#else + SET_TLB_ENTRY(1, 0xfffff000, 0xfffff000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 0, BOOKE_PAGESZ_4K, 1), +#endif + + /* *I*G* - CCSRBAR */ + SET_TLB_ENTRY(1, CONFIG_SYS_CCSRBAR, CONFIG_SYS_CCSRBAR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 1, BOOKE_PAGESZ_16M, 1), + + /* *I*G* - Flash, localbus */ + /* This will be changed to *I*G* after relocation to RAM. */ + SET_TLB_ENTRY(1, CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE_PHYS, + MAS3_SX|MAS3_SR, MAS2_W|MAS2_G, + 0, 2, BOOKE_PAGESZ_256M, 1), + + /* *I*G* - PCI */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE1_MEM_VIRT, CONFIG_SYS_PCIE1_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 3, BOOKE_PAGESZ_1G, 1), + + /* *I*G* - PCI */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE1_MEM_VIRT + 0x40000000, + CONFIG_SYS_PCIE1_MEM_PHYS + 0x40000000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 4, BOOKE_PAGESZ_256M, 1), + + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE1_MEM_VIRT + 0x50000000, + CONFIG_SYS_PCIE1_MEM_PHYS + 0x50000000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 5, BOOKE_PAGESZ_256M, 1), + + /* *I*G* - PCI I/O */ + SET_TLB_ENTRY(1, CONFIG_SYS_PCIE1_IO_VIRT, CONFIG_SYS_PCIE1_IO_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 6, BOOKE_PAGESZ_256K, 1), + + /* Bman/Qman */ + SET_TLB_ENTRY(1, CONFIG_SYS_BMAN_MEM_BASE, CONFIG_SYS_BMAN_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 9, BOOKE_PAGESZ_1M, 1), + SET_TLB_ENTRY(1, CONFIG_SYS_BMAN_MEM_BASE + 0x00100000, + CONFIG_SYS_BMAN_MEM_PHYS + 0x00100000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 10, BOOKE_PAGESZ_1M, 1), + SET_TLB_ENTRY(1, CONFIG_SYS_QMAN_MEM_BASE, CONFIG_SYS_QMAN_MEM_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 11, BOOKE_PAGESZ_1M, 1), + SET_TLB_ENTRY(1, CONFIG_SYS_QMAN_MEM_BASE + 0x00100000, + CONFIG_SYS_QMAN_MEM_PHYS + 0x00100000, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 12, BOOKE_PAGESZ_1M, 1), +#ifdef CONFIG_SYS_DCSRBAR_PHYS + SET_TLB_ENTRY(1, CONFIG_SYS_DCSRBAR, CONFIG_SYS_DCSRBAR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, + 0, 13, BOOKE_PAGESZ_4M, 1), +#endif +}; + +int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/boards.cfg b/boards.cfg index e1bb9e0..903c65b 100644 --- a/boards.cfg +++ b/boards.cfg @@ -575,6 +575,9 @@ P2020RDB_36BIT_SPIFLASH powerpc mpc85xx p1_p2_rdb freesca P2020RDB_NAND powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020RDB,NAND P2020RDB_SDCARD powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020RDB,SDCARD P2020RDB_SPIFLASH powerpc mpc85xx p1_p2_rdb freescale - P1_P2_RDB:P2020RDB,SPIFLASH +P2040RDB powerpc mpc85xx p2040rdb freescale +P2040RDB_SDCARD powerpc mpc85xx p2040rdb freescale - P2040RDB:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 +P2040RDB_SPIFLASH powerpc mpc85xx p2040rdb freescale - P2040RDB:RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF80000 P3041DS powerpc mpc85xx corenet_ds freescale P3041DS_NAND powerpc mpc85xx corenet_ds freescale - P3041DS:RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF80000 P3041DS_SDCARD powerpc mpc85xx corenet_ds freescale - P3041DS:RAMBOOT_PBL,SDCARD,SYS_TEXT_BASE=0xFFF80000 diff --git a/doc/README.p2040rdb b/doc/README.p2040rdb new file mode 100644 index 0000000..63cfb7c --- /dev/null +++ b/doc/README.p2040rdb @@ -0,0 +1,123 @@ +Overview +========= +The P2040 Processor combines four Power Architecture processor cores +with high-performance datapath acceleration architecture(DPAA), CoreNet +fabric infrastructure, as well as network and peripheral bus interfaces +required for networking, telecom/datacom, wireless infrastructure, and +military/aerospace applications. + +P2040RDB board is a quad core platform supporting the P2040 processor +of QorIQ DPAA series. + +Boot from NOR flash +=================== +1. Build image + make P2040RDB_config + make all + +2. Program image + => tftp 1000000 u-boot.bin + => protect off all + => erase eff80000 efffffff + => cp.b 1000000 eff80000 80000 + +3. Program RCW + => tftp 1000000 rcw.bin + => protect off all + => erase e8000000 e801ffff + => cp.b 1000000 e8000000 50 + +4. Program FMAN Firmware ucode + => tftp 1000000 ucode.bin + => protect off all + => erase ef000000 ef0fffff + => cp.b 1000000 ef000000 2000 + +5. Change DIP-switch + SW1[1-5] = 10110 + Note: 1 stands for 'on', 0 stands for 'off' + +Boot from SDCard +=================== +1. Build image + make P2040RDB_SDCARD_config + make all + +2. Generate PBL imge + Use PE tool to produce a image used to be programed to + SDCard which contains RCW and U-Boot image. + +3. Program the PBL image to SDCard + => tftp 1000000 pbl_sd.bin + => mmcinfo + => mmc write 1000000 8 441 + +4. Program FMAN Firmware ucode + => tftp 1000000 ucode.bin + => mmc write 1000000 46a 10 + +5. Change DIP-switch + SW1[1-5] = 01100 + Note: 1 stands for 'on', 0 stands for 'off' + +Boot from SPI flash +=================== +1. Build image + make P2040RDB_SPIFLASH_config + make all + +2. Generate PBL imge + Use PE tool to produce a image used to be programed to + SPI flash which contains RCW and U-Boot image. + +3. Program the PBL image to SPI flash + => tftp 1000000 pbl_spi.bin + => spi probe 0 + => sf erase 0 100000 + => sf write 1000000 0 $filesize + +4. Program FMAN Firmware ucode + => tftp 1000000 ucode.bin + => sf erase 110000 10000 + => sf write 1000000 110000 $filesize + +5. Change DIP-switch + SW1[1-5] = 10100 + Note: 1 stands for 'on', 0 stands for 'off' + +CPLD command +============ +The CPLD is used to control the power sequence and some serdes lane +mux function. + +cpld reset - hard reset to default bank +cpld reset altbank - reset to alternate bank +cpld lane_mux <lane> <mux_value> - set multiplexed lane pin + lane 6: 0 -> slot1 (Default) + 1 -> SGMII + lane a: 0 -> slot2 (Default) + 1 -> AURORA + lane c: 0 -> slot2 (Default) + 1 -> SATA0 + lane d: 0 -> slot2 (Default) + 1 -> SATA1 + +Using the Device Tree Source File +================================= +To create the DTB (Device Tree Binary) image file, use a command +similar to this: + dtc -O dtb -b 0 -p 1024 p2040rdb.dts > p2040rdb.dtb + +Or use the following command: + {linux-2.6}/make p2040rdb.dtb ARCH=powerpc + +then the dtb file will be generated under the following directory: + {linux-2.6}/arch/powerpc/boot/p2040rdb.dtb + +Booting Linux +============= +Place a linux uImage in the TFTP disk area. + tftp 1000000 uImage + tftp 2000000 rootfs.ext2.gz.uboot + tftp 3000000 p2040rdb.dtb + bootm 1000000 2000000 3000000 diff --git a/include/configs/P2040RDB.h b/include/configs/P2040RDB.h new file mode 100644 index 0000000..4c09dd9 --- /dev/null +++ b/include/configs/P2040RDB.h @@ -0,0 +1,624 @@ +/* + * Copyright 2011 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +/* + * P2040 RDB board configuration file + * + */ +#ifndef __CONFIG_H +#define __CONFIG_H + +#define CONFIG_P2040RDB +#define CONFIG_PHYS_64BIT +#define CONFIG_PPC_P2040 + +#ifdef CONFIG_RAMBOOT_PBL +#define CONFIG_RAMBOOT_TEXT_BASE CONFIG_SYS_TEXT_BASE +#define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc +#endif + +/* High Level Configuration Options */ +#define CONFIG_BOOKE +#define CONFIG_E500 /* BOOKE e500 family */ +#define CONFIG_E500MC /* BOOKE e500mc family */ +#define CONFIG_SYS_BOOK3E_HV /* Category E.HV supported */ +#define CONFIG_MPC85xx /* MPC85xx/PQ3 platform */ +#define CONFIG_FSL_CORENET /* Freescale CoreNet platform */ +#define CONFIG_MP /* support multiple processors */ + +#ifndef CONFIG_SYS_TEXT_BASE +#define CONFIG_SYS_TEXT_BASE 0xeff80000 +#endif + +#ifndef CONFIG_RESET_VECTOR_ADDRESS +#define CONFIG_RESET_VECTOR_ADDRESS 0xeffffffc +#endif + +#define CONFIG_SYS_FSL_CPC /* Corenet Platform Cache */ +#define CONFIG_SYS_NUM_CPC CONFIG_NUM_DDR_CONTROLLERS +#define CONFIG_FSL_ELBC /* Has Enhanced localbus controller */ +#define CONFIG_PCI /* Enable PCI/PCIE */ +#define CONFIG_PCIE1 /* PCIE controler 1 */ +#define CONFIG_PCIE2 /* PCIE controler 2 */ +#define CONFIG_PCIE3 /* PCIE controler 3 */ +#define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ +#define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */ + +#define CONFIG_SYS_SRIO +#define CONFIG_SRIO1 /* SRIO port 1 */ +#define CONFIG_SRIO2 /* SRIO port 2 */ + +#define CONFIG_FSL_LAW /* Use common FSL init code */ + +#define CONFIG_ENV_OVERWRITE + +#ifdef CONFIG_SYS_NO_FLASH +#define CONFIG_ENV_IS_NOWHERE +#else +#define CONFIG_FLASH_CFI_DRIVER +#define CONFIG_SYS_FLASH_CFI +#endif + +#if defined(CONFIG_SPIFLASH) + #define CONFIG_SYS_EXTRA_ENV_RELOC + #define CONFIG_ENV_IS_IN_SPI_FLASH + #define CONFIG_ENV_SPI_BUS 0 + #define CONFIG_ENV_SPI_CS 0 + #define CONFIG_ENV_SPI_MAX_HZ 10000000 + #define CONFIG_ENV_SPI_MODE 0 + #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ + #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ + #define CONFIG_ENV_SECT_SIZE 0x10000 +#elif defined(CONFIG_SDCARD) + #define CONFIG_SYS_EXTRA_ENV_RELOC + #define CONFIG_ENV_IS_IN_MMC + #define CONFIG_SYS_MMC_ENV_DEV 0 + #define CONFIG_ENV_SIZE 0x2000 + #define CONFIG_ENV_OFFSET (512 * 1097) +#else + #define CONFIG_ENV_IS_IN_FLASH + #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE \ + - CONFIG_ENV_SECT_SIZE) + #define CONFIG_ENV_SIZE 0x2000 + #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) */ +#endif + +#define CONFIG_SYS_CLK_FREQ 66666666 + +/* + * These can be toggled for performance analysis, otherwise use default. + */ +#define CONFIG_SYS_CACHE_STASHING +#define CONFIG_BTB /* toggle branch predition */ + +#define CONFIG_ENABLE_36BIT_PHYS + +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_ADDR_MAP +#define CONFIG_SYS_NUM_ADDR_MAP 64 /* number of TLB1 entries */ +#endif + +#define CONFIG_POST CONFIG_SYS_POST_MEMORY /* test POST memory test */ +#define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END 0x00400000 +#define CONFIG_SYS_ALT_MEMTEST +#define CONFIG_PANIC_HANG /* do not reset board on panic */ + +/* + * Config the L3 Cache as L3 SRAM + */ +#define CONFIG_SYS_INIT_L3_ADDR CONFIG_RAMBOOT_TEXT_BASE +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_INIT_L3_ADDR_PHYS (0xf00000000ull | \ + CONFIG_RAMBOOT_TEXT_BASE) +#else +#define CONFIG_SYS_INIT_L3_ADDR_PHYS CONFIG_SYS_INIT_L3_ADDR +#endif +#define CONFIG_SYS_L3_SIZE (1024 << 10) +#define CONFIG_SYS_INIT_L3_END (CONFIG_SYS_INIT_L3_ADDR + CONFIG_SYS_L3_SIZE) + +/* + * Base addresses -- Note these are effective addresses where the + * actual resources get mapped (not physical addresses) + */ +#define CONFIG_SYS_CCSRBAR_DEFAULT 0xfe000000 /* CCSRBAR Default */ +#define CONFIG_SYS_CCSRBAR 0xfe000000 /* relocated CCSRBAR */ +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_CCSRBAR_PHYS 0xffe000000ull +#else +#define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR +#endif +/* PQII uses CONFIG_SYS_IMMR */ +#define CONFIG_SYS_IMMR CONFIG_SYS_CCSRBAR + +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_DCSRBAR 0xf0000000 +#define CONFIG_SYS_DCSRBAR_PHYS 0xf00000000ull +#endif + +/* EEPROM */ +#define CONFIG_ID_EEPROM +#define CONFIG_SYS_I2C_EEPROM_NXID +#define CONFIG_SYS_EEPROM_BUS_NUM 0 +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 1 + +/* + * DDR Setup + */ +#define CONFIG_VERY_BIG_RAM +#define CONFIG_SYS_DDR_SDRAM_BASE 0x00000000 +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE + +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 +#define CONFIG_CHIP_SELECTS_PER_CTRL (4 * CONFIG_DIMM_SLOTS_PER_CTLR) + +#define CONFIG_DDR_SPD +#define CONFIG_FSL_DDR3 + +#define CONFIG_SYS_SPD_BUS_NUM 0 +#define SPD_EEPROM_ADDRESS 0x52 +#define CONFIG_SYS_SDRAM_SIZE 4096 /* for fixed parameter use */ + +/* + * Local Bus Definitions + */ + +/* Set the local bus clock 1/8 of platform clock */ +#define CONFIG_SYS_LBC_LCRR LCRR_CLKDIV_8 + +#define CONFIG_SYS_FLASH_BASE 0xe8000000 /* Start of PromJet */ +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_FLASH_BASE_PHYS 0xfe8000000ull +#else +#define CONFIG_SYS_FLASH_BASE_PHYS CONFIG_SYS_FLASH_BASE +#endif + +#define CONFIG_SYS_BR0_PRELIM \ + (BR_PHYS_ADDR(CONFIG_SYS_FLASH_BASE_PHYS) | BR_PS_16 | BR_V) +#define CONFIG_SYS_OR0_PRELIM ((0xf8000ff7 & ~OR_GPCM_SCY & ~OR_GPCM_EHTR) \ + | OR_GPCM_SCY_8 | OR_GPCM_EHTR_CLEAR) + +#define CONFIG_FSL_CPLD +#define CPLD_BASE 0xffdf0000 /* CPLD registers */ +#ifdef CONFIG_PHYS_64BIT +#define CPLD_BASE_PHYS 0xfffdf0000ull +#else +#define CPLD_BASE_PHYS CPLD_BASE +#endif + +#define CONFIG_SYS_BR3_PRELIM (BR_PHYS_ADDR(CPLD_BASE_PHYS) | BR_PS_8 | BR_V) +#define CONFIG_SYS_OR3_PRELIM 0xffffeff7 /* 32KB but only 4k mapped */ + +#define PIXIS_LBMAP_SWITCH 7 +#define PIXIS_LBMAP_MASK 0xf0 +#define PIXIS_LBMAP_SHIFT 4 +#define PIXIS_LBMAP_ALTBANK 0x40 + +#define CONFIG_SYS_FLASH_QUIET_TEST +#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ + +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device */ +#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Erase Timeout (ms) */ +#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Write Timeout (ms) */ + +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE + +#if defined(CONFIG_RAMBOOT_PBL) +#define CONFIG_SYS_RAMBOOT +#endif + +#define CONFIG_SYS_FLASH_EMPTY_INFO +#define CONFIG_SYS_FLASH_AMD_CHECK_DQ7 +#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE_PHYS} + +#define CONFIG_BOARD_EARLY_INIT_F +#define CONFIG_BOARD_EARLY_INIT_R /* call board_early_init_r function */ +#define CONFIG_MISC_INIT_R + +#define CONFIG_HWCONFIG + +/* define to use L1 as initial stack */ +#define CONFIG_L1_INIT_RAM +#define CONFIG_SYS_INIT_RAM_LOCK +#define CONFIG_SYS_INIT_RAM_ADDR 0xffd00000 /* Initial L1 address */ +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH 0xf +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW CONFIG_SYS_INIT_RAM_ADDR +/* The assembler doesn't like typecast */ +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS \ + ((CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH * 1ull << 32) | \ + CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW) +#else +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS CONFIG_SYS_INIT_RAM_ADDR +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_HIGH 0 +#define CONFIG_SYS_INIT_RAM_ADDR_PHYS_LOW CONFIG_SYS_INIT_RAM_ADDR_PHYS +#endif +#define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 + +#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ + GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET + +#define CONFIG_SYS_MONITOR_LEN (512 * 1024) +#define CONFIG_SYS_MALLOC_LEN (1024 * 1024) + +/* Serial Port - controlled on board with jumper J8 + * open - index 2 + * shorted - index 1 + */ +#define CONFIG_CONS_INDEX 1 +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE 1 +#define CONFIG_SYS_NS16550_CLK (get_bus_freq(0)/2) + +#define CONFIG_SYS_BAUDRATE_TABLE \ + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200} + +#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_CCSRBAR+0x11C500) +#define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_CCSRBAR+0x11C600) +#define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) +#define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600) + +/* Use the HUSH parser */ +#define CONFIG_SYS_HUSH_PARSER +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " + +/* pass open firmware flat tree */ +#define CONFIG_OF_LIBFDT +#define CONFIG_OF_BOARD_SETUP +#define CONFIG_OF_STDOUT_VIA_ALIAS + +/* new uImage format support */ +#define CONFIG_FIT +#define CONFIG_FIT_VERBOSE /* enable fit_format_{error,warning}() */ + +/* I2C */ +#define CONFIG_FSL_I2C /* Use FSL common I2C driver */ +#define CONFIG_HARD_I2C /* I2C with hardware support */ +#define CONFIG_I2C_MULTI_BUS +#define CONFIG_I2C_CMD_TREE +#define CONFIG_SYS_I2C_SPEED 400000 +#define CONFIG_SYS_I2C_SLAVE 0x7F +#define CONFIG_SYS_I2C_OFFSET 0x118000 +#define CONFIG_SYS_I2C2_OFFSET 0x118100 + +/* + * RapidIO + */ +#define CONFIG_SYS_SRIO1_MEM_VIRT 0xa0000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_SRIO1_MEM_PHYS 0xc20000000ull +#else +#define CONFIG_SYS_SRIO1_MEM_PHYS 0xa0000000 +#endif +#define CONFIG_SYS_SRIO1_MEM_SIZE 0x10000000 /* 256M */ + +#define CONFIG_SYS_SRIO2_MEM_VIRT 0xb0000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_SRIO2_MEM_PHYS 0xc30000000ull +#else +#define CONFIG_SYS_SRIO2_MEM_PHYS 0xb0000000 +#endif +#define CONFIG_SYS_SRIO2_MEM_SIZE 0x10000000 /* 256M */ + +/* + * eSPI - Enhanced SPI + */ +#define CONFIG_FSL_ESPI +#define CONFIG_SPI_FLASH +#define CONFIG_SPI_FLASH_SPANSION +#define CONFIG_CMD_SF +#define CONFIG_SF_DEFAULT_SPEED 10000000 +#define CONFIG_SF_DEFAULT_MODE 0 + +/* + * General PCI + * Memory space is mapped 1-1, but I/O space must start from 0. + */ + +/* controller 1, direct to uli, tgtid 3, Base address 20000 */ +#define CONFIG_SYS_PCIE1_MEM_VIRT 0x80000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_PCIE1_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE1_MEM_PHYS 0xc00000000ull +#else +#define CONFIG_SYS_PCIE1_MEM_BUS 0x80000000 +#define CONFIG_SYS_PCIE1_MEM_PHYS 0x80000000 +#endif +#define CONFIG_SYS_PCIE1_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE1_IO_VIRT 0xf8000000 +#define CONFIG_SYS_PCIE1_IO_BUS 0x00000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_PCIE1_IO_PHYS 0xff8000000ull +#else +#define CONFIG_SYS_PCIE1_IO_PHYS 0xf8000000 +#endif +#define CONFIG_SYS_PCIE1_IO_SIZE 0x00010000 /* 64k */ + +/* controller 2, Slot 2, tgtid 2, Base address 201000 */ +#define CONFIG_SYS_PCIE2_MEM_VIRT 0xa0000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_PCIE2_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE2_MEM_PHYS 0xc20000000ull +#else +#define CONFIG_SYS_PCIE2_MEM_BUS 0xa0000000 +#define CONFIG_SYS_PCIE2_MEM_PHYS 0xa0000000 +#endif +#define CONFIG_SYS_PCIE2_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE2_IO_VIRT 0xf8010000 +#define CONFIG_SYS_PCIE2_IO_BUS 0x00000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_PCIE2_IO_PHYS 0xff8010000ull +#else +#define CONFIG_SYS_PCIE2_IO_PHYS 0xf8010000 +#endif +#define CONFIG_SYS_PCIE2_IO_SIZE 0x00010000 /* 64k */ + +/* controller 3, Slot 1, tgtid 1, Base address 202000 */ +#define CONFIG_SYS_PCIE3_MEM_VIRT 0xc0000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_PCIE3_MEM_BUS 0xe0000000 +#define CONFIG_SYS_PCIE3_MEM_PHYS 0xc40000000ull +#else +#define CONFIG_SYS_PCIE3_MEM_BUS 0xc0000000 +#define CONFIG_SYS_PCIE3_MEM_PHYS 0xc0000000 +#endif +#define CONFIG_SYS_PCIE3_MEM_SIZE 0x20000000 /* 512M */ +#define CONFIG_SYS_PCIE3_IO_VIRT 0xf8020000 +#define CONFIG_SYS_PCIE3_IO_BUS 0x00000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_PCIE3_IO_PHYS 0xff8020000ull +#else +#define CONFIG_SYS_PCIE3_IO_PHYS 0xf8020000 +#endif +#define CONFIG_SYS_PCIE3_IO_SIZE 0x00010000 /* 64k */ + +/* Qman/Bman */ +#define CONFIG_SYS_DPAA_QBMAN /* Support Q/Bman */ +#define CONFIG_SYS_BMAN_NUM_PORTALS 10 +#define CONFIG_SYS_BMAN_MEM_BASE 0xf4000000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_BMAN_MEM_PHYS 0xff4000000ull +#else +#define CONFIG_SYS_BMAN_MEM_PHYS CONFIG_SYS_BMAN_MEM_BASE +#endif +#define CONFIG_SYS_BMAN_MEM_SIZE 0x00200000 +#define CONFIG_SYS_QMAN_NUM_PORTALS 10 +#define CONFIG_SYS_QMAN_MEM_BASE 0xf4200000 +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SYS_QMAN_MEM_PHYS 0xff4200000ull +#else +#define CONFIG_SYS_QMAN_MEM_PHYS CONFIG_SYS_QMAN_MEM_BASE +#endif +#define CONFIG_SYS_QMAN_MEM_SIZE 0x00200000 + +#define CONFIG_SYS_DPAA_FMAN +#define CONFIG_SYS_DPAA_PME +/* Default address of microcode for the Linux Fman driver */ +#define CONFIG_SYS_FMAN_FW +#if defined(CONFIG_SPIFLASH) +/* + * env is stored at 0x100000, sector size is 0x10000, ucode is stored after + * env, so we got 0x110000. + */ +#define CONFIG_SYS_QE_FW_IN_SPIFLASH 0x110000 +#elif defined(CONFIG_SDCARD) +/* + * PBL SD boot image should stored at 0x1000(8 blocks), the size of the image is + * about 545KB (1089 blocks), Env is stored after the image, and the env size is + * 0x2000 (16 blocks), 8 + 1089 + 16 = 1113, enlarge it to 1130. + */ +#define CONFIG_SYS_QE_FW_IN_MMC (512 * 1130) +#elif defined(CONFIG_NAND) +#define CONFIG_SYS_QE_FW_IN_NAND (6 * CONFIG_SYS_NAND_BLOCK_SIZE) +#else +#define CONFIG_SYS_FMAN_FW_ADDR 0xEF000000 +#endif +#define CONFIG_SYS_FMAN_FW_LENGTH 0x10000 +#define CONFIG_SYS_FDT_PAD (0x3000 + CONFIG_SYS_FMAN_FW_LENGTH) + +#ifdef CONFIG_SYS_DPAA_FMAN +#define CONFIG_FMAN_ENET +#endif + +#ifdef CONFIG_PCI +#define CONFIG_NET_MULTI +#define CONFIG_PCI_PNP /* do pci plug-and-play */ +#define CONFIG_E1000 + +#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ +#define CONFIG_DOS_PARTITION +#endif /* CONFIG_PCI */ + +#ifdef CONFIG_FMAN_ENET +#define CONFIG_SYS_FM1_DTSEC1_PHY_ADDR 0x2 +#define CONFIG_SYS_FM1_DTSEC2_PHY_ADDR 0x3 +#define CONFIG_SYS_FM1_DTSEC3_PHY_ADDR 0x4 +#define CONFIG_SYS_FM1_DTSEC4_PHY_ADDR 0x1 +#define CONFIG_SYS_FM1_DTSEC5_PHY_ADDR 0x0 + +#define CONFIG_SYS_FM1_DTSEC1_RISER_PHY_ADDR 0x1c +#define CONFIG_SYS_FM1_DTSEC2_RISER_PHY_ADDR 0x1d +#define CONFIG_SYS_FM1_DTSEC3_RISER_PHY_ADDR 0x1e +#define CONFIG_SYS_FM1_DTSEC4_RISER_PHY_ADDR 0x1f + +#define CONFIG_SYS_TBIPA_VALUE 8 +#define CONFIG_MII /* MII PHY management */ +#define CONFIG_ETHPRIME "FM1@DTSEC1" +#define CONFIG_PHY_GIGE /* Include GbE speed/duplex detection */ +#endif + +/* + * Environment + */ +#define CONFIG_LOADS_ECHO /* echo on for serial download */ +#define CONFIG_SYS_LOADS_BAUD_CHANGE /* allow baudrate change */ + +/* + * Command line configuration. + */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_ELF +#define CONFIG_CMD_ERRATA +#define CONFIG_CMD_GREPENV +#define CONFIG_CMD_IRQ +#define CONFIG_CMD_I2C +#define CONFIG_CMD_MII +#define CONFIG_CMD_PING +#define CONFIG_CMD_SETEXPR + +#ifdef CONFIG_PCI +#define CONFIG_CMD_PCI +#define CONFIG_CMD_NET +#endif + +/* +* USB +*/ +#define CONFIG_CMD_USB +#define CONFIG_USB_STORAGE +#define CONFIG_USB_EHCI +#define CONFIG_USB_EHCI_FSL +#define CONFIG_EHCI_HCD_INIT_AFTER_RESET +#define CONFIG_CMD_EXT2 + +#define CONFIG_MMC + +#ifdef CONFIG_MMC +#define CONFIG_FSL_ESDHC +#define CONFIG_SYS_FSL_ESDHC_ADDR CONFIG_SYS_MPC85xx_ESDHC_ADDR +#define CONFIG_SYS_FSL_ESDHC_BROKEN_TIMEOUT +#define CONFIG_CMD_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_CMD_EXT2 +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION +#endif + +/* + * Miscellaneous configurable options + */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_CMDLINE_EDITING /* Command-line editing */ +#define CONFIG_AUTO_COMPLETE /* add autocompletion support */ +#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ +#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ +#ifdef CONFIG_CMD_KGDB +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ +#else +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +#endif +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_HZ 1000 /* decrementer freq 1ms ticks */ + +/* + * For booting Linux, the board info and command line data + * have to be in the first 64 MB of memory, since this is + * the maximum mapped by the Linux kernel during initialization. + */ +#define CONFIG_SYS_BOOTMAPSZ (64 << 20) /* Initial Memory for Linux */ +#define CONFIG_SYS_BOOTM_LEN (64 << 20) /* Increase max gunzip size */ + +#ifdef CONFIG_CMD_KGDB +#define CONFIG_KGDB_BAUDRATE 230400 /* speed to run kgdb serial port */ +#define CONFIG_KGDB_SER_INDEX 2 /* which serial port to use */ +#endif + +/* + * Environment Configuration + */ +#define CONFIG_ROOTPATH /opt/nfsroot +#define CONFIG_BOOTFILE uImage +#define CONFIG_UBOOTPATH u-boot.bin + +/* default location for tftp and bootm */ +#define CONFIG_LOADADDR 1000000 + +#define CONFIG_BOOTDELAY 10 /* -1 disables auto-boot */ + +#define CONFIG_BAUDRATE 115200 + +#define __USB_PHY_TYPE utmi + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "hwconfig=fsl_ddr:ctlr_intlv=cacheline," \ + "bank_intlv=cs0_cs1\0" \ + "netdev=eth0\0" \ + "uboot=" MK_STR(CONFIG_UBOOTPATH) "\0" \ + "ubootaddr=" MK_STR(CONFIG_SYS_TEXT_BASE) "\0" \ + "tftpflash=tftpboot $loadaddr $uboot && " \ + "protect off $ubootaddr +$filesize && " \ + "erase $ubootaddr +$filesize && " \ + "cp.b $loadaddr $ubootaddr $filesize && " \ + "protect on $ubootaddr +$filesize && " \ + "cmp.b $loadaddr $ubootaddr $filesize\0" \ + "consoledev=ttyS0\0" \ + "usb_phy_type=" MK_STR(__USB_PHY_TYPE) "\0" \ + "usb_dr_mode=host\0" \ + "ramdiskaddr=2000000\0" \ + "ramdiskfile=p2040rdb/ramdisk.uboot\0" \ + "fdtaddr=c00000\0" \ + "fdtfile=p2040rdb/p2040rdb.dtb\0" \ + "bdev=sda3\0" \ + "c=ffe\0" + +#define CONFIG_HDBOOT \ + "setenv bootargs root=/dev/$bdev rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr - $fdtaddr" + +#define CONFIG_NFSBOOTCOMMAND \ + "setenv bootargs root=/dev/nfs rw " \ + "nfsroot=$serverip:$rootpath " \ + "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr - $fdtaddr" + +#define CONFIG_RAMBOOTCOMMAND \ + "setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $ramdiskaddr $ramdiskfile;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr" + +#define CONFIG_BOOTCOMMAND CONFIG_HDBOOT + +#ifdef CONFIG_SECURE_BOOT +#include <asm/fsl_secure_boot.h> +#endif + +#endif /* __CONFIG_H */
Memory subsystem:
- 4Gbyte unbuffered DDR3 SDRAM SO-DIMM(64bit bus)
- 128 Mbyte NOR flash single-chip memory
- 256 Kbit M24256 I2C EEPROM
- 16 Mbyte SPI memory
- SD connector to interface with the SD memory card
Ethernet:
- dTSEC1: connected to the Vitesse SGMII PHY (VSC8221)
- dTSEC2: connected to the Vitesse SGMII PHY (VSC8221)
- dTSEC3: connected to the Vitesse SGMII PHY (VSC8221)
- dTSEC4: connected to the Vitesse RGMII PHY (VSC8641)
- dTSEC5: connected to the Vitesse RGMII PHY (VSC8641)
PCIe:
- Lanes E, F, G and H of Bank1 are connected to one x4 PCIe SLOT1
- Lanes C and Land D of Bank2 are connected to one x4 PCIe SLOT2
I2C:
- I2C1: Real time clock, Temperature sensor, Memory module
- I2C2: Vcore Regulator, 256Kbit I2C Bus EEPROM, PCIe slot1/2
v2:
renamed everything to P2041, applied to 85xx
- k
Kumar Gala
Mingkai Hu
