[U-Boot] [PATCH 0/2] dm: mmc: dwmmc: fix the minor things
It's working on converting from legacy to DM. It's also in progessing. There are some minor wrongs. These patches are fixed wrong explanations and removing unnecessary defined.
These patchese are based on u-boot-dm. (blk-working branch)
Jaehoon Chung (2): dm: mmc: dwmmc: fix the wrong explanation for clock values dm: mmc: dwmmc: use the callback functions as static
drivers/mmc/dw_mmc.c | 4 ++-- include/dwmmc.h | 11 ++++------- 2 files changed, 6 insertions(+), 9 deletions(-)
This e,g is wrong. Maximum/minimum e.g values are swapped each other.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- include/dwmmc.h | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/include/dwmmc.h b/include/dwmmc.h index 6aebe96..164d1dc 100644 --- a/include/dwmmc.h +++ b/include/dwmmc.h @@ -256,8 +256,8 @@ static inline u8 dwmci_readb(struct dwmci_host *host, int reg) * @name: Device name (normally dev->name) * @buswidth: Bus width (in bits, such as 4 or 8) * @caps: Host capabilities (MMC_MODE_...) - * @max_clk: Maximum supported clock speed in HZ (e.g. 400000) - * @min_clk: Minimum supported clock speed in HZ (e.g. 150000000) + * @max_clk: Maximum supported clock speed in HZ (e.g. 150000000) + * @min_clk: Minimum supported clock speed in HZ (e.g. 400000) */ void dwmci_setup_cfg(struct mmc_config *cfg, const char *name, int buswidth, uint caps, u32 max_clk, u32 min_clk); @@ -286,8 +286,8 @@ int dwmci_bind(struct udevice *dev, struct mmc *mmc, struct mmc_config *cfg); * This is used when you are not using CONFIG_BLK. Convert your driver over! * * @host: DWMMC host structure - * @max_clk: Maximum supported clock speed in HZ (e.g. 400000) - * @min_clk: Minimum supported clock speed in HZ (e.g. 150000000) + * @max_clk: Maximum supported clock speed in HZ (e.g. 150000000) + * @min_clk: Minimum supported clock speed in HZ (e.g. 400000) * @return 0 if OK, -ve on error */ int add_dwmci(struct dwmci_host *host, u32 max_clk, u32 min_clk);
There are no places to call these functions. It should be used the callback function. Then it can be used as static functions.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- drivers/mmc/dw_mmc.c | 4 ++-- include/dwmmc.h | 3 --- 2 files changed, 2 insertions(+), 5 deletions(-)
diff --git a/drivers/mmc/dw_mmc.c b/drivers/mmc/dw_mmc.c index 3411f95..f83a6bc 100644 --- a/drivers/mmc/dw_mmc.c +++ b/drivers/mmc/dw_mmc.c @@ -182,7 +182,7 @@ static int dwmci_set_transfer_mode(struct dwmci_host *host, }
#ifdef CONFIG_DM_MMC_OPS -int dwmci_send_cmd(struct udevice *dev, struct mmc_cmd *cmd, +static int dwmci_send_cmd(struct udevice *dev, struct mmc_cmd *cmd, struct mmc_data *data) { struct mmc *mmc = mmc_get_mmc_dev(dev); @@ -381,7 +381,7 @@ static int dwmci_setup_bus(struct dwmci_host *host, u32 freq) }
#ifdef CONFIG_DM_MMC_OPS -int dwmci_set_ios(struct udevice *dev) +static int dwmci_set_ios(struct udevice *dev) { struct mmc *mmc = mmc_get_mmc_dev(dev); #else diff --git a/include/dwmmc.h b/include/dwmmc.h index 164d1dc..d18ec84 100644 --- a/include/dwmmc.h +++ b/include/dwmmc.h @@ -295,9 +295,6 @@ int add_dwmci(struct dwmci_host *host, u32 max_clk, u32 min_clk);
#ifdef CONFIG_DM_MMC_OPS /* Export the operations to drivers */ -int dwmci_send_cmd(struct udevice *dev, struct mmc_cmd *cmd, - struct mmc_data *data); -int dwmci_set_ios(struct udevice *dev); int dwmci_probe(struct udevice *dev); extern const struct dm_mmc_ops dm_dwmci_ops; #endif
Hi Jaehoon,
From what I can see this is already static. Which commit are you basing off?
#endif
1.9.1
Hi Simon,
On 06/29/2016 12:28 PM, Simon Glass wrote:
Hi Jaehoon,
I'm checking with your 'blk-working' branch. I'm not sure what's correct.
commit dee390a1250c17a4e71e359d6e461319a7cdea54 Author: Simon Glass sjg@chromium.org Date: Sat Jun 11 19:01:49 2016 -0600
dm: blk: Enable CONFIG_BLK if DM_MMC is enabled
If i need to work with other branch, let me know,plz. I have tested the DM with dw_mmc_exynos.c. (It's working fine.)
I will send the patch-set for exynos dwmmc and sdhci controller. So i need to know which repository and branch are correct. :)
Then it's helpful to me for working dm. I think that i can help you for checking on mmc side with DM.
Best Regards, Jaehoon Chung
#endif
1.9.1
Hi Jaehoon,
On 28 June 2016 at 20:47, Jaehoon Chung jh80.chung@samsung.com wrote:
Hi Simon,
Hi Jaehoon,
OK I see, thanks.
[snip
On 01/07/16 04:53, Simon Glass wrote:
Hi Jaehoon,
Hi Simon,
Hi Jaehoon,
OK I see, thanks.
This patch has been delegated to me, but cannot apply to u-boot-samsung. should go to dm tree?
Thanks, Minkyu Kang.
Hi Minkyu,
Hi Jaehoon,
Hi Simon,
Hi Jaehoon,
OK I see, thanks.
Yes, it depends on dm/next. I'll assign those to patches to myself.
Jaehoon Chung
Minkyu Kang
