[U-Boot] [PATCH v3 0/2] Support for TI bandgap temperature sensor
Adding support for TI bandgap temperature sensor. Also add dt support for bandgap sensor in spl.
v3: Missed adding Reviewed-by in v2.
Faiz Abbas (2): thermal: ti-bandgap: Add support for temperature sensor ARM: dts: OMAP5+: Add support for bandgap sensor in SPL
arch/arm/dts/omap5-u-boot.dtsi | 4 + common/spl/Kconfig | 8 + configs/dra7xx_evm_defconfig | 3 + .../thermal/ti_soc_thermal.txt | 35 ++++ drivers/Makefile | 2 +- drivers/thermal/Kconfig | 6 + drivers/thermal/Makefile | 1 + drivers/thermal/ti-bandgap.c | 197 +++++++++++++++++++++ 8 files changed, 255 insertions(+), 1 deletion(-) create mode 100644 doc/device-tree-bindings/thermal/ti_soc_thermal.txt create mode 100644 drivers/thermal/ti-bandgap.c
The dra7xx series of SOCs contain a temperature sensor and an associated analog-to-digital converter (ADC) which produces an output which is proportional to the SOC temperature. Add support for this temperature sensor.
Signed-off-by: Faiz Abbas faiz_abbas@ti.com Reviewed-by: Simon Glass sjg@chromium.org --- v3: Added Reviewed-by comment
v2: 1. Removed extra elements from ti_bandgap 2. Changed base address to ulong 3. Changed to udev to dev to maintain consistency 4. minor format changes
common/spl/Kconfig | 8 + configs/dra7xx_evm_defconfig | 3 + .../thermal/ti_soc_thermal.txt | 35 ++++ drivers/Makefile | 2 +- drivers/thermal/Kconfig | 6 + drivers/thermal/Makefile | 1 + drivers/thermal/ti-bandgap.c | 197 +++++++++++++++++++++ 7 files changed, 251 insertions(+), 1 deletion(-) create mode 100644 doc/device-tree-bindings/thermal/ti_soc_thermal.txt create mode 100644 drivers/thermal/ti-bandgap.c
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 0bd8370..0bf3ee3 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -604,6 +604,14 @@ config SPL_SPI_SUPPORT enable SPI drivers that are needed for other purposes also, such as a SPI PMIC.
+config SPL_THERMAL + bool "Driver support for thermal devices" + help + Enable support for temperature-sensing devices. Some SoCs have on-chip + temperature sensors to permit warnings, speed throttling or even + automatic power-off when the temperature gets too high or low. Other + devices may be discrete but connected on a suitable bus. + config SPL_USB_HOST_SUPPORT bool "Support USB host drivers" help diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 468c288..447fb89 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -90,3 +90,6 @@ CONFIG_USB_GADGET=y CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" CONFIG_USB_GADGET_VENDOR_NUM=0x0451 CONFIG_USB_GADGET_PRODUCT_NUM=0xd022 +CONFIG_SPL_THERMAL=y +CONFIG_DM_THERMAL=y +CONFIG_TI_DRA7_THERMAL=y diff --git a/doc/device-tree-bindings/thermal/ti_soc_thermal.txt b/doc/device-tree-bindings/thermal/ti_soc_thermal.txt new file mode 100644 index 0000000..b4e88c2 --- /dev/null +++ b/doc/device-tree-bindings/thermal/ti_soc_thermal.txt @@ -0,0 +1,35 @@ +* Texas Instrument dra7xx SCM bandgap bindings + +In the System Control Module, SoC supplies a voltage reference +and a temperature sensor feature that are gathered in the band +gap voltage and temperature sensor (VBGAPTS) module. The band +gap provides current and voltage reference for its internal +circuits and other analog IP blocks. The analog-to-digital +converter (ADC) produces an output value that is proportional +to the silicon temperature. + +Required properties: +- compatible : Should be: + - "ti,dra752-bandgap" +- interrupts : this entry should indicate which interrupt line +the talert signal is routed to; +- regs : this is specific to each bandgap version, because +the mapping may change from soc to soc, apart from depending +on available features. + +Optional: +- gpios : this entry should be used to inform which GPIO +line the tshut signal is routed to. The informed GPIO will +be treated as an IRQ; + +Example: +bandgap { + reg = <0x4a0021e0 0xc + 0x4a00232c 0xc + 0x4a002380 0x2c + 0x4a0023C0 0x3c + 0x4a002564 0x8 + 0x4a002574 0x50>; + compatible = "ti,dra752-bandgap"; + interrupts = <0 126 4>; /* talert */ +}; diff --git a/drivers/Makefile b/drivers/Makefile index dab5c18..35510ca 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -50,7 +50,7 @@ obj-$(CONFIG_SPL_SATA_SUPPORT) += ata/ scsi/ obj-$(CONFIG_SPL_USB_HOST_SUPPORT) += block/ obj-$(CONFIG_SPL_MMC_SUPPORT) += block/ obj-$(CONFIG_SPL_FPGA_SUPPORT) += fpga/ - +obj-$(CONFIG_SPL_THERMAL) += thermal/ endif endif
diff --git a/drivers/thermal/Kconfig b/drivers/thermal/Kconfig index 886f5fa..a71b9be 100644 --- a/drivers/thermal/Kconfig +++ b/drivers/thermal/Kconfig @@ -17,4 +17,10 @@ config IMX_THERMAL cpufreq is used as the cooling device to throttle CPUs when the passive trip is crossed.
+config TI_DRA7_THERMAL + bool "Temperature sensor driver for TI dra7xx SOCs" + help + Enable thermal support for for the Texas Instruments DRA752 SoC family. + The driver supports reading CPU temperature. + endif # if DM_THERMAL diff --git a/drivers/thermal/Makefile b/drivers/thermal/Makefile index d768f5e..f6271a5 100644 --- a/drivers/thermal/Makefile +++ b/drivers/thermal/Makefile @@ -7,3 +7,4 @@
obj-$(CONFIG_DM_THERMAL) += thermal-uclass.o obj-$(CONFIG_IMX_THERMAL) += imx_thermal.o +obj-$(CONFIG_TI_DRA7_THERMAL) += ti-bandgap.o diff --git a/drivers/thermal/ti-bandgap.c b/drivers/thermal/ti-bandgap.c new file mode 100644 index 0000000..6db9f54 --- /dev/null +++ b/drivers/thermal/ti-bandgap.c @@ -0,0 +1,197 @@ +/* + * TI Bandgap temperature sensor driver + * + * Copyright (C) 2017 Texas Instruments Incorporated - http://www.ti.com/ + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation version 2. + * + * This program is distributed "as is" WITHOUT ANY WARRANTY of any + * kind, whether express or implied; without even the implied warranty + * of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * Taken from Linux v4.9 (drivers/thermal/ti-soc-thermal/ti-bandgap.c) + * and ported to uboot. + * + */ + +#include <asm/io.h> +#include <dm.h> +#include <thermal.h> + +#define CTRL_CORE_TEMP_SENSOR_MPU 0 +#define DRA752_ADC_START_VALUE 540 + +struct ti_bandgap { + ulong base; + int temperature; /* in mili degree celsius */ +}; + +/* + * DRA752 : Temperature values in milli degree celsius + * ADC code values from 540 to 945 + */ +static int dra752_adc_to_temp[] = { + /* Index 540 - 549 */ + -40000, -40000, -40000, -40000, -39800, -39400, -39000, -38600, -38200, + -37800, + /* Index 550 - 559 */ + -37400, -37000, -36600, -36200, -35800, -35300, -34700, -34200, -33800, + -33400, + /* Index 560 - 569 */ + -33000, -32600, -32200, -31800, -31400, -31000, -30600, -30200, -29800, + -29400, + /* Index 570 - 579 */ + -29000, -28600, -28200, -27700, -27100, -26600, -26200, -25800, -25400, + -25000, + /* Index 580 - 589 */ + -24600, -24200, -23800, -23400, -23000, -22600, -22200, -21800, -21400, + -21000, + /* Index 590 - 599 */ + -20500, -19900, -19400, -19000, -18600, -18200, -17800, -17400, -17000, + -16600, + /* Index 600 - 609 */ + -16200, -15800, -15400, -15000, -14600, -14200, -13800, -13400, -13000, + -12500, + /* Index 610 - 619 */ + -11900, -11400, -11000, -10600, -10200, -9800, -9400, -9000, -8600, + -8200, + /* Index 620 - 629 */ + -7800, -7400, -7000, -6600, -6200, -5800, -5400, -5000, -4500, + -3900, + /* Index 630 - 639 */ + -3400, -3000, -2600, -2200, -1800, -1400, -1000, -600, -200, + 200, + /* Index 640 - 649 */ + 600, 1000, 1400, 1800, 2200, 2600, 3000, 3400, 3900, + 4500, + /* Index 650 - 659 */ + 5000, 5400, 5800, 6200, 6600, 7000, 7400, 7800, 8200, + 8600, + /* Index 660 - 669 */ + 9000, 9400, 9800, 10200, 10600, 11000, 11400, 11800, 12200, + 12700, + /* Index 670 - 679 */ + 13300, 13800, 14200, 14600, 15000, 15400, 15800, 16200, 16600, + 17000, + /* Index 680 - 689 */ + 17400, 17800, 18200, 18600, 19000, 19400, 19800, 20200, 20600, + 21000, + /* Index 690 - 699 */ + 21400, 21900, 22500, 23000, 23400, 23800, 24200, 24600, 25000, + 25400, + /* Index 700 - 709 */ + 25800, 26200, 26600, 27000, 27400, 27800, 28200, 28600, 29000, + 29400, + /* Index 710 - 719 */ + 29800, 30200, 30600, 31000, 31400, 31900, 32500, 33000, 33400, + 33800, + /* Index 720 - 729 */ + 34200, 34600, 35000, 35400, 35800, 36200, 36600, 37000, 37400, + 37800, + /* Index 730 - 739 */ + 38200, 38600, 39000, 39400, 39800, 40200, 40600, 41000, 41400, + 41800, + /* Index 740 - 749 */ + 42200, 42600, 43100, 43700, 44200, 44600, 45000, 45400, 45800, + 46200, + /* Index 750 - 759 */ + 46600, 47000, 47400, 47800, 48200, 48600, 49000, 49400, 49800, + 50200, + /* Index 760 - 769 */ + 50600, 51000, 51400, 51800, 52200, 52600, 53000, 53400, 53800, + 54200, + /* Index 770 - 779 */ + 54600, 55000, 55400, 55900, 56500, 57000, 57400, 57800, 58200, + 58600, + /* Index 780 - 789 */ + 59000, 59400, 59800, 60200, 60600, 61000, 61400, 61800, 62200, + 62600, + /* Index 790 - 799 */ + 63000, 63400, 63800, 64200, 64600, 65000, 65400, 65800, 66200, + 66600, + /* Index 800 - 809 */ + 67000, 67400, 67800, 68200, 68600, 69000, 69400, 69800, 70200, + 70600, + /* Index 810 - 819 */ + 71000, 71500, 72100, 72600, 73000, 73400, 73800, 74200, 74600, + 75000, + /* Index 820 - 829 */ + 75400, 75800, 76200, 76600, 77000, 77400, 77800, 78200, 78600, + 79000, + /* Index 830 - 839 */ + 79400, 79800, 80200, 80600, 81000, 81400, 81800, 82200, 82600, + 83000, + /* Index 840 - 849 */ + 83400, 83800, 84200, 84600, 85000, 85400, 85800, 86200, 86600, + 87000, + /* Index 850 - 859 */ + 87400, 87800, 88200, 88600, 89000, 89400, 89800, 90200, 90600, + 91000, + /* Index 860 - 869 */ + 91400, 91800, 92200, 92600, 93000, 93400, 93800, 94200, 94600, + 95000, + /* Index 870 - 879 */ + 95400, 95800, 96200, 96600, 97000, 97500, 98100, 98600, 99000, + 99400, + /* Index 880 - 889 */ + 99800, 100200, 100600, 101000, 101400, 101800, 102200, 102600, 103000, + 103400, + /* Index 890 - 899 */ + 103800, 104200, 104600, 105000, 105400, 105800, 106200, 106600, 107000, + 107400, + /* Index 900 - 909 */ + 107800, 108200, 108600, 109000, 109400, 109800, 110200, 110600, 111000, + 111400, + /* Index 910 - 919 */ + 111800, 112200, 112600, 113000, 113400, 113800, 114200, 114600, 115000, + 115400, + /* Index 920 - 929 */ + 115800, 116200, 116600, 117000, 117400, 117800, 118200, 118600, 119000, + 119400, + /* Index 930 - 939 */ + 119800, 120200, 120600, 121000, 121400, 121800, 122200, 122600, 123000, + 123400, + /* Index 940 - 945 */ + 123800, 124200, 124600, 124900, 125000, 125000, +}; + +static int ti_bandgap_get_temp(struct udevice *dev, int *temp) +{ + struct ti_bandgap *bgp = dev_get_priv(dev); + + bgp->temperature = 0x3ff & readl(bgp->base + CTRL_CORE_TEMP_SENSOR_MPU); + *temp = dra752_adc_to_temp[bgp->temperature - DRA752_ADC_START_VALUE]; + + return 0; +} + +static struct dm_thermal_ops ti_thermal_ops = { + .get_temp = ti_bandgap_get_temp, +}; + +static int ti_bandgap_probe(struct udevice *dev) +{ + struct ti_bandgap *bgp = dev_get_priv(dev); + + bgp->base = devfdt_get_addr_index(dev, 1); + + return 0; +} + +static const struct udevice_id of_ti_bandgap_match[] = { + { + .compatible = "ti,dra752-bandgap", + }, +}; + +U_BOOT_DRIVER(ti_bandgap_thermal) = { + .name = "ti_bandgap_thermal", + .id = UCLASS_THERMAL, + .ops = &ti_thermal_ops, + .probe = ti_bandgap_probe, + .of_match = of_ti_bandgap_match, + .priv_auto_alloc_size = sizeof(struct ti_bandgap), +};
and note that in U-Boot, we let patchwork collect Reviewed-by/etc tags, so you don't need to repost with just tags added, in the future. Thanks!
v2:
- Removed extra elements from ti_bandgap
- Changed base address to ulong
- Changed to udev to dev to maintain consistency
- minor format changes
+config SPL_THERMAL
- bool "Driver support for thermal devices"
- help
Tom, Do you want these options to be implied so that it will take effect for HS board as well. Or enable it in defconfig as is?
Thanks and regards, Lokesh
v2:
+config SPL_THERMAL
- help
How important is it that this be enabled? Is this 100% within the SoC? Thanks!
Hi Tom,
v2:
+config SPL_THERMAL
- help
There is an upcoming errata which requires temperature support to workaround. This errata will apply to the HS boards as well. Will send a new patch with imply added to TARGET_DRA7XX_EVM for these configs.
Thanks, Faiz
On Mon, Oct 23, 2017 at 10:50:15AM +0530, Faiz Abbas wrote:
Hi Tom,
v2:
+config SPL_THERMAL
- help
Well, can you _not_ have this support enabled, on the dra7xx family? If it must be always there, please select it. Otherwise imply is OK. Thanks!
Hi Tom,
v2:
+config SPL_THERMAL
- help
Its not enabled in the latest v4. Have added imply in TARGET_DRA7XX_EVM and TARGET_AM57XX_EVM instead.
Thanks, Faiz
Mark bandgap node as uboot,dm-spl so that it can be accessed in spl
Signed-off-by: Faiz Abbas faiz_abbas@ti.com Reviewed-by: Simon Glass sjg@chromium.org --- v3: Added Reviewed-by comment.
arch/arm/dts/omap5-u-boot.dtsi | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/arch/arm/dts/omap5-u-boot.dtsi b/arch/arm/dts/omap5-u-boot.dtsi index fdaa692..bf2684c 100644 --- a/arch/arm/dts/omap5-u-boot.dtsi +++ b/arch/arm/dts/omap5-u-boot.dtsi @@ -18,6 +18,10 @@ ocp2scp@4a090000 { compatible = "ti,omap-ocp2scp", "simple-bus"; }; + + bandgap@4a0021e0 { + u-boot,dm-spl; + }; }; };
Faiz Abbas
Lokesh Vutla
