[PATCH v2 00/45] dm: core: Support multiple device trees in ofnode
At present the ofnode interface is somewhat limited, in that it cannot access the device tree provided by the OS, only the one used by U-Boot itself (assuming these are separate). This prevents using ofnode functions to handle device tree fixups, i.e. ft_board_setup() and the like.
The ofnode interface was introduced to allow a consistent API to access the device tree, whether a flat tree or a live tree (OF_LIVE) is in use.
With the flat tree, adding nodes and properties at the start of the tree (as often happens when writing to the /chosen node) requires copying a lot of data for each operation. With live tree, such operations are quite a bit faster, since there is no memory copying required. This has to be weighed against the required memory allocation with OF_LIVE, as well as the cost of unflattening and flattening the device tree which U-Boot is running.
This series enables support for access to multiple device trees with the ofnode interface. This is already available to some extent with OF_LIVE, but some of the ofnode functions need changes to allow the tree to be specified.
The mechanism works by using the top 1-4 bits of the device tree offset. The sign bit is not affected, since negative values must be supported.
With this implemented, it becomes possible to use the ofnode interface to do device tree fixups. The only current user is the EVT_FT_FIXUP event.
This has two main benefits:
- ofnode can now be used everywhere, in preference to the libfdt calls - live tree can eventually be used everywhere, with potential speed improvements when larger number of fixups are used
This series is only a step along the way. Firstly, while it is possible to access the 'fix-up' tree using OF_LIVE, most of the fixup functions use flat tree directly, rather than the ofnode interface. These need to be updated. Also the tree must be flattened again before it is passed to the OS. This is not currently implemented.
With OFNODE_MULTI_TREE disabled this has almost no effect on code size: around 4 bytes if EVENT is enabled, 0 if not. With the feature enabled, the increase is around 700 bytes, e.g. on venice2:
$ buildman -b ofn2a venice2 -sS --step 0 Summary of 2 commits for 1 boards (1 thread, 64 jobs per thread) 01: image: Drop some other #ifdefs in image-board.c arm: w+ venice2 48: wip arm: (for 1/1 boards) all +668.0 text +668.0
This size increase is not too bad, considering the extra functionality, but is too large to enable everywhere. So for now this features needs to be opt-in only, based on EVENT.
Changes in v2: - Return the existing node with -EEXIST - Allow len to be passed in as -1 - Add a comment as to why strncmp() is not enough - Add a comment why the len parameter is needed - Add a comment why the new_name variable is used - Add tests for the memory checks in of_add_subnode() - Fix memory checks - Fix 'property' comment - Add lots more tests and a few other fixes - Gosh that code was a mess - Add new patch to rename ofnode_get_property_by_prop() - Substantially expanded to improve the ofnode implementation/interface - Added more ofnode tests - Minor reworks of the ofnode internals, using oftree - Added testing of memory-allocation failures
Simon Glass (45): image: Fix BOOTM_STATE values treewide: Drop bootm_headers_t typedef treewide: Drop image_info_t typedef treewide: Drop image_header_t typedef log: update the comment for log_msg_ret() sandbox: power: Update PMIC driver to use log event: Fix a typo in the EVENT help event: Allow multiple spy declarations for each event dm: core: Pass a root node to of_find_node_by_phandle() event: Pass the images to EVT_FT_FIXUP test: Fix missing livetree test runs test: Support testing malloc() failures dm: core: Document the livetree structures properly dm: core: Allow adding ofnode subnodes dm: core: Support writing a property to an empty node dm: core: Drop the const from ofnode test: Make a copy of the device tree before running a test test: Detect a change in the device tree test: Drop the UT_TESTF_LIVE_OR_FLAT flag sandbox: Add a function to load a relative file path sandbox: Support loading the other FDT sandbox: Support setting up the other FDT for testing sandbox: test: Provide an easy way to use the other FDT dm: core: Reduce code size with dev_of_offset() dm: core: Rename ofnode_get_first/next_property() dm: core: Rename ofnode_get_property_by_prop() dm: core: Avoid creating a name property when unflattening dm: core: Add a macro to iterate through properties dm: core: Drop ofnode_is_available() dm: core: Expand integer-reading tests dm: core: Provide a way to reset the device tree dm: core: Add an ofnode function to obtain the flat tree dm: core: Add ofnode functions to obtain an oftree dm: core: Add a way to look up a phandle in an oftree dm: core: Allow obtaining a node offset in the same tree dm: core: Split ofnode_path_root() into two functions dm: core: Add definitions for multiple ofnode trees dm: core: Add the ofnode multi-tree implementation dm: core: Complete phandle implementation using the other FDT dm: core: Update comments for default-FDT ofnode functions dm: core: Create a function to get a live tree in a test dm: core: Expand ofnode tests vbe: Allow test to run with live/flat tree dm: core: Allow copying ofnode property data when writing dm: core: Support copying properties with ofnode
arch/arc/lib/bootm.c | 8 +- arch/arm/lib/bootm.c | 13 +- arch/arm/mach-aspeed/ast2600/spl.c | 4 +- arch/arm/mach-imx/hab.c | 2 +- arch/arm/mach-imx/spl_imx_romapi.c | 6 +- arch/arm/mach-k3/common.c | 2 +- arch/arm/mach-k3/sysfw-loader.c | 6 +- arch/arm/mach-keystone/cmd_mon.c | 6 +- arch/arm/mach-socfpga/board.c | 2 +- arch/arm/mach-sunxi/spl_spi_sunxi.c | 4 +- arch/arm/mach-tegra/xusb-padctl-common.c | 2 +- arch/m68k/lib/bootm.c | 2 +- arch/microblaze/lib/bootm.c | 6 +- arch/mips/lib/bootm.c | 16 +- arch/mips/mach-jz47xx/jz4780/jz4780.c | 6 +- arch/mips/mach-mtmips/mt7621/spl/spl.c | 4 +- arch/mips/mach-mtmips/mt7621/tpl/tpl.c | 4 +- arch/nios2/lib/bootm.c | 2 +- arch/powerpc/lib/bootm.c | 16 +- arch/riscv/lib/andes_plic.c | 2 +- arch/riscv/lib/bootm.c | 8 +- arch/riscv/lib/smp.c | 2 +- arch/sandbox/cpu/cpu.c | 34 +- arch/sandbox/cpu/start.c | 16 +- arch/sandbox/cpu/state.c | 48 ++ arch/sandbox/dts/Makefile | 2 +- arch/sandbox/dts/other.dts | 35 ++ arch/sandbox/include/asm/malloc.h | 1 + arch/sandbox/include/asm/state.h | 30 + arch/sandbox/include/asm/test.h | 19 + arch/sandbox/lib/bootm.c | 2 +- arch/sh/lib/bootm.c | 2 +- arch/x86/lib/bootm.c | 8 +- arch/xtensa/lib/bootm.c | 2 +- board/synopsys/hsdk/hsdk.c | 2 +- board/ti/ks2_evm/board.c | 4 +- boot/boot_fit.c | 4 +- boot/bootm.c | 26 +- boot/bootm_os.c | 35 +- boot/image-android.c | 6 +- boot/image-board.c | 26 +- boot/image-fdt.c | 13 +- boot/image-fit.c | 16 +- boot/image.c | 14 +- boot/vbe_simple.c | 2 +- cmd/bootefi.c | 2 +- cmd/booti.c | 2 +- cmd/bootm.c | 4 +- cmd/bootz.c | 2 +- cmd/disk.c | 4 +- cmd/fpga.c | 2 +- cmd/nand.c | 4 +- cmd/source.c | 2 +- cmd/ximg.c | 4 +- common/Kconfig | 2 +- common/board_r.c | 2 + common/dlmalloc.c | 19 + common/spl/spl.c | 10 +- common/spl/spl_ext.c | 4 +- common/spl/spl_fat.c | 6 +- common/spl/spl_legacy.c | 8 +- common/spl/spl_mmc.c | 4 +- common/spl/spl_nand.c | 4 +- common/spl/spl_net.c | 2 +- common/spl/spl_nor.c | 8 +- common/spl/spl_onenand.c | 2 +- common/spl/spl_ram.c | 8 +- common/spl/spl_sata.c | 2 +- common/spl/spl_semihosting.c | 4 +- common/spl/spl_spi.c | 6 +- common/spl/spl_ubi.c | 4 +- common/spl/spl_xip.c | 2 +- common/spl/spl_ymodem.c | 14 +- common/splash_source.c | 6 +- doc/develop/driver-model/livetree.rst | 37 +- doc/uImage.FIT/source_file_format.txt | 2 +- drivers/core/Kconfig | 24 + drivers/core/fdtaddr.c | 18 +- drivers/core/of_access.c | 83 ++- drivers/core/ofnode.c | 442 +++++++++++--- drivers/core/read.c | 6 +- drivers/cpu/imx8_cpu.c | 2 +- drivers/cpu/riscv_cpu.c | 2 +- drivers/crypto/fsl/jr.c | 2 +- drivers/firmware/scmi/scmi_agent-uclass.c | 2 +- drivers/fpga/socfpga_arria10.c | 4 +- drivers/mtd/mtdpart.c | 4 +- drivers/mtd/nand/raw/zynq_nand.c | 2 +- drivers/net/fec_mxc.c | 2 +- drivers/net/fsl_enetc.c | 2 +- drivers/net/mscc_eswitch/felix_switch.c | 2 +- drivers/net/sja1105.c | 2 +- drivers/net/ti/am65-cpsw-nuss.c | 2 +- drivers/pci/pci-uclass.c | 2 +- drivers/pci/pci_mvebu.c | 2 +- drivers/pci/pci_tegra.c | 2 +- drivers/pci/pcie_mediatek.c | 4 +- drivers/power/pmic/sandbox.c | 10 +- drivers/usb/gadget/f_sdp.c | 2 +- env/common.c | 6 +- include/asm-generic/global_data.h | 4 + include/bootm.h | 6 +- include/configs/uniphier.h | 2 +- include/dm/device.h | 6 +- include/dm/of.h | 15 +- include/dm/of_access.h | 29 +- include/dm/ofnode.h | 345 +++++++++-- include/dm/ofnode_decl.h | 37 +- include/dm/read.h | 8 +- include/event.h | 6 +- include/image.h | 118 ++-- include/log.h | 5 +- include/malloc.h | 12 + include/spl.h | 8 +- include/tee/optee.h | 4 +- include/test/test.h | 30 +- include/test/ut.h | 5 + lib/efi_loader/efi_dt_fixup.c | 2 +- lib/fdtdec.c | 7 +- lib/of_live.c | 7 +- net/dsa-uclass.c | 2 +- scripts/event_dump.py | 4 +- test/boot/vbe_simple.c | 25 +- test/dm/ofnode.c | 696 +++++++++++++++++++++- test/dm/ofread.c | 11 +- test/image/spl_load.c | 4 +- test/test-main.c | 136 ++++- tools/binman/ftest.py | 4 +- tools/default_image.c | 31 +- tools/fit_image.c | 4 +- tools/imx8mimage.c | 8 +- tools/mkimage.c | 2 +- tools/mtk_image.c | 10 +- 133 files changed, 2253 insertions(+), 621 deletions(-) create mode 100644 arch/sandbox/dts/other.dts
