[PATCH 1/3] aristainetos2: Rename CONFIG_EXTRA_ENV_BOARD_SETTINGS
Rename CONFIG_EXTRA_ENV_BOARD_SETTINGS to EXTRA_ENV_BOARD_SETTINGS in order to not further add to the CONFIG namespace.
Cc: Heiko Schocher hs@denx.de Signed-off-by: Tom Rini trini@konsulko.com --- include/configs/aristainetos2.h | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/include/configs/aristainetos2.h b/include/configs/aristainetos2.h index 78fa1a969e7f..69398787d9e7 100644 --- a/include/configs/aristainetos2.h +++ b/include/configs/aristainetos2.h @@ -93,13 +93,13 @@ #endif
#if (CONFIG_SYS_BOARD_VERSION == 5) -#define CONFIG_EXTRA_ENV_BOARD_SETTINGS \ +#define EXTRA_ENV_BOARD_SETTINGS \ "dead=while true; do; " \ "led led_red on; sleep 1;" \ "led led_red off; sleep 1;" \ "done\0" #elif (CONFIG_SYS_BOARD_VERSION == 6) -#define CONFIG_EXTRA_ENV_BOARD_SETTINGS \ +#define EXTRA_ENV_BOARD_SETTINGS \ "dead=while true; do; " \ "led led_red on; led led_red2 on; sleep 1;" \ "led led_red off; led led_red2 off;; sleep 1;" \ @@ -414,7 +414,7 @@ "run main_rescue_boot;" \ "fi; \0"\ HAB_EXTRA_SETTINGS \ - CONFIG_EXTRA_ENV_BOARD_SETTINGS + EXTRA_ENV_BOARD_SETTINGS
#define CONFIG_ARP_TIMEOUT 200UL
Rename CONFIG_ENV_KS2_BOARD_SETTINGS to ENV_KS2_BOARD_SETTINGS so that it better fits with the rest of the environment addition macros.
Cc: Vitaly Andrianov vitalya@ti.com Signed-off-by: Tom Rini trini@konsulko.com --- include/configs/k2e_evm.h | 2 +- include/configs/k2g_evm.h | 2 +- include/configs/k2hk_evm.h | 2 +- include/configs/k2l_evm.h | 2 +- include/configs/ti_armv7_keystone2.h | 2 +- 5 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/include/configs/k2e_evm.h b/include/configs/k2e_evm.h index 716ae3b0d4aa..65bf646f3fb2 100644 --- a/include/configs/k2e_evm.h +++ b/include/configs/k2e_evm.h @@ -23,7 +23,7 @@ #endif
/* U-Boot general configuration */ -#define CONFIG_EXTRA_ENV_KS2_BOARD_SETTINGS \ +#define ENV_KS2_BOARD_SETTINGS \ DEFAULT_FW_INITRAMFS_BOOT_ENV \ DEFAULT_SEC_BOOT_ENV \ "boot=ubi\0" \ diff --git a/include/configs/k2g_evm.h b/include/configs/k2g_evm.h index 4471eb4f6a84..17245ab15861 100644 --- a/include/configs/k2g_evm.h +++ b/include/configs/k2g_evm.h @@ -16,7 +16,7 @@ #define CONFIG_SOC_K2G
/* U-Boot general configuration */ -#define CONFIG_EXTRA_ENV_KS2_BOARD_SETTINGS \ +#define ENV_KS2_BOARD_SETTINGS \ DEFAULT_MMC_TI_ARGS \ DEFAULT_PMMC_BOOT_ENV \ DEFAULT_FW_INITRAMFS_BOOT_ENV \ diff --git a/include/configs/k2hk_evm.h b/include/configs/k2hk_evm.h index d90b2648185a..1fdecd60e769 100644 --- a/include/configs/k2hk_evm.h +++ b/include/configs/k2hk_evm.h @@ -23,7 +23,7 @@ #endif
/* U-Boot general configuration */ -#define CONFIG_EXTRA_ENV_KS2_BOARD_SETTINGS \ +#define ENV_KS2_BOARD_SETTINGS \ DEFAULT_FW_INITRAMFS_BOOT_ENV \ DEFAULT_SEC_BOOT_ENV \ "boot=ubi\0" \ diff --git a/include/configs/k2l_evm.h b/include/configs/k2l_evm.h index 152cea01b55b..97512c9903de 100644 --- a/include/configs/k2l_evm.h +++ b/include/configs/k2l_evm.h @@ -23,7 +23,7 @@ #endif
/* U-Boot general configuration */ -#define CONFIG_EXTRA_ENV_KS2_BOARD_SETTINGS \ +#define ENV_KS2_BOARD_SETTINGS \ DEFAULT_FW_INITRAMFS_BOOT_ENV \ DEFAULT_SEC_BOOT_ENV \ "boot=ubi\0" \ diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index cfc2be7b9f07..fc2b3431ddba 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -187,7 +187,7 @@
#define CONFIG_EXTRA_ENV_SETTINGS \ DEFAULT_LINUX_BOOT_ENV \ - CONFIG_EXTRA_ENV_KS2_BOARD_SETTINGS \ + ENV_KS2_BOARD_SETTINGS \ DFUARGS \ "bootdir=/boot\0" \ "tftp_root=/\0" \
Rework the default environment a bit to not use non-standard CONFIG_ENV_... names and similar one-off CONFIG names.
Cc: Jaehoon Chung jh80.chung@samsung.com Signed-off-by: Tom Rini trini@konsulko.com --- include/configs/exynos4-common.h | 2 +- include/configs/s5pc210_universal.h | 26 +++++++++----------------- include/configs/trats.h | 9 +++------ include/configs/trats2.h | 2 +- 4 files changed, 14 insertions(+), 25 deletions(-)
diff --git a/include/configs/exynos4-common.h b/include/configs/exynos4-common.h index 5e2aca371e7e..2ca14d0b86e3 100644 --- a/include/configs/exynos4-common.h +++ b/include/configs/exynos4-common.h @@ -32,7 +32,7 @@ #define CONFIG_USB_GADGET_DWC2_OTG_PHY
/* Common environment variables */ -#define CONFIG_EXTRA_ENV_ITB \ +#define ENV_ITB \ "loadkernel=load mmc ${mmcbootdev}:${mmcbootpart} ${kerneladdr} " \ "${kernelname}\0" \ "loadinitrd=load mmc ${mmcbootdev}:${mmcbootpart} ${initrdaddr} " \ diff --git a/include/configs/s5pc210_universal.h b/include/configs/s5pc210_universal.h index 0b679f437482..8ee667e69306 100644 --- a/include/configs/s5pc210_universal.h +++ b/include/configs/s5pc210_universal.h @@ -44,16 +44,6 @@ ",100M(swap)"\ ",-(UMS)\0"
-#define CONFIG_ENV_UBI_MTD " ubi.mtd=${ubiblock} ubi.mtd=4 ubi.mtd=7" -#define CONFIG_BOOTBLOCK "10" -#define CONFIG_UBIBLOCK "9" - -#define CONFIG_ENV_UBIFS_OPTION " rootflags=bulk_read,no_chk_data_crc " -#define CONFIG_ENV_FLASHBOOT CONFIG_ENV_UBI_MTD CONFIG_ENV_UBIFS_OPTION \ - "${mtdparts}" - -#define CONFIG_ENV_COMMON_BOOT "${console} ${meminfo}" - #define CONFIG_EXTRA_ENV_SETTINGS \ "updateb=" \ "onenand erase 0x0 0x100000;" \ @@ -71,18 +61,20 @@ "lpj=lpj=3981312\0" \ "ubifsboot=" \ "set bootargs root=ubi0!rootfs rootfstype=ubifs ${lpj} " \ - CONFIG_ENV_FLASHBOOT " ${opts} ${lcdinfo} " \ - CONFIG_ENV_COMMON_BOOT "; run bootk\0" \ + "ubi.mtd=${ubiblock} ubi.mtd=4 ubi.mtd=7 " \ + "rootflags=bulk_read,no_chk_data_crc ${mtdparts} ${opts} " \ + "${lcdinfo} ${console} ${meminfo}; run bootk\0" \ "tftpboot=" \ "set bootargs root=ubi0!rootfs rootfstype=ubifs " \ - CONFIG_ENV_FLASHBOOT " ${opts} ${lcdinfo} " \ - CONFIG_ENV_COMMON_BOOT \ + "ubi.mtd=${ubiblock} ubi.mtd=4 ubi.mtd=7 " \ + "rootflags=bulk_read,no_chk_data_crc ${mtdparts} ${opts} " \ + "${lcdinfo} ${console} ${meminfo}" \ "; tftp 0x40007FC0 uImage; bootm 0x40007FC0\0" \ "nfsboot=" \ "set bootargs root=/dev/nfs rw " \ "nfsroot=${nfsroot},nolock,tcp " \ "ip=${ipaddr}:${serverip}:${gatewayip}:" \ - "${netmask}:generic:usb0:off " CONFIG_ENV_COMMON_BOOT \ + "${netmask}:generic:usb0:off ${console} ${meminfo}" \ "; run bootk\0" \ "ramfsboot=" \ "set bootargs root=/dev/ram0 rw rootfstype=ext2 " \ @@ -102,8 +94,8 @@ "mbrparts=" MBRPARTS_DEFAULT \ "meminfo=crashkernel=32M@0x50000000\0" \ "nfsroot=/nfsroot/arm\0" \ - "bootblock=" CONFIG_BOOTBLOCK "\0" \ - "ubiblock=" CONFIG_UBIBLOCK" \0" \ + "bootblock=10\0" \ + "ubiblock=9\0" \ "ubi=enabled\0" \ "loaduimage=fatload mmc ${mmcdev}:${mmcbootpart} 0x40007FC0 uImage\0" \ "mmcdev=0\0" \ diff --git a/include/configs/trats.h b/include/configs/trats.h index a44792d85764..c3f891ae53d8 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -40,9 +40,6 @@
#define CONFIG_SYS_MONITOR_BASE 0x00000000
-#define CONFIG_BOOTBLOCK "10" -#define CONFIG_ENV_COMMON_BOOT "${console} ${meminfo}" - /* Tizen - partitions definitions */ #define PARTS_CSA "csa-mmc" #define PARTS_BOOT "boot" @@ -94,7 +91,7 @@ "setenv bootargs root=/dev/nfs rw " \ "nfsroot=${nfsroot},nolock,tcp " \ "ip=${ipaddr}:${serverip}:${gatewayip}:" \ - "${netmask}:generic:usb0:off " CONFIG_ENV_COMMON_BOOT \ + "${netmask}:generic:usb0:off ${console} ${meminfo}" \ "; run bootk\0" \ "ramfsboot=" \ "setenv bootargs root=/dev/ram0 rw rootfstype=ext2 " \ @@ -112,7 +109,7 @@ "console=console=ttySAC2,115200n8\0" \ "meminfo=crashkernel=32M@0x50000000\0" \ "nfsroot=/nfsroot/arm\0" \ - "bootblock=" CONFIG_BOOTBLOCK "\0" \ + "bootblock=10\0" \ "loaduimage=ext4load mmc ${mmcdev}:${mmcbootpart} 0x40007FC0 uImage\0" \ "loaddtb=ext4load mmc ${mmcdev}:${mmcbootpart} ${fdtaddr} " \ "${fdtfile}\0" \ @@ -141,7 +138,7 @@ "setenv spl_imgsize;" \ "setenv spl_imgaddr;" \ "setenv spl_addr_tmp;\0" \ - CONFIG_EXTRA_ENV_ITB \ + ENV_ITB \ "fdtaddr=40800000\0" \
/* Falcon mode definitions */ diff --git a/include/configs/trats2.h b/include/configs/trats2.h index 4b1eff08f3b3..e5f2b0cc993a 100644 --- a/include/configs/trats2.h +++ b/include/configs/trats2.h @@ -125,7 +125,7 @@ "setenv spl_imgsize;" \ "setenv spl_imgaddr;" \ "setenv spl_addr_tmp;\0" \ - CONFIG_EXTRA_ENV_ITB \ + ENV_ITB \ "fdtaddr=40800000\0" \
/* GPT */
Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Best Regars, Jaehoon Chung
"${mtdparts}"
"tftpboot=" \ "set bootargs root=ubi0!rootfs rootfstype=ubifs " \"${lcdinfo} ${console} ${meminfo}; run bootk\0" \
"; tftp 0x40007FC0 uImage; bootm 0x40007FC0\0" \ "nfsboot=" \ "set bootargs root=/dev/nfs rw " \ "nfsroot=${nfsroot},nolock,tcp " \ "ip=${ipaddr}:${serverip}:${gatewayip}:" \"${lcdinfo} ${console} ${meminfo}" \
"; run bootk\0" \ "ramfsboot=" \ "set bootargs root=/dev/ram0 rw rootfstype=ext2 " \"${netmask}:generic:usb0:off ${console} ${meminfo}" \
- "bootblock=10\0" \
- "ubiblock=9\0" \ "ubi=enabled\0" \ "loaduimage=fatload mmc ${mmcdev}:${mmcbootpart} 0x40007FC0 uImage\0" \ "mmcdev=0\0" \
"; run bootk\0" \ "ramfsboot=" \ "setenv bootargs root=/dev/ram0 rw rootfstype=ext2 " \"${netmask}:generic:usb0:off ${console} ${meminfo}" \
- "bootblock=10\0" \ "loaduimage=ext4load mmc ${mmcdev}:${mmcbootpart} 0x40007FC0 uImage\0" \ "loaddtb=ext4load mmc ${mmcdev}:${mmcbootpart} ${fdtaddr} " \ "${fdtfile}\0" \
- ENV_ITB \ "fdtaddr=40800000\0" \
/* GPT */
Cc: Jaehoon Chung jh80.chung@samsung.com Signed-off-by: Tom Rini trini@konsulko.com Reviewed-by: Jaehoon Chung jh80.chung@samsung.com
Hello Tom,
Reviewed-by: Heiko Schocher hs@denx.de
Thanks!
bye, Heiko
Cc: Heiko Schocher hs@denx.de Signed-off-by: Tom Rini trini@konsulko.com Reviewed-by: Heiko Schocher hs@denx.de
Heiko Schocher
Jaehoon Chung
