[U-Boot-Users] [PATCH 3/3 (v2)] Remove the deprecated CONFIG_OF_FLAT_TREE
Use CONFIG_OF_LIBFDT instead to support flattened device trees. It is cleaner, has better functionality, and is better supported.
Signed-off-by: Gerald Van Baren vanbaren@cideas.com --- README | 9 +- board/freescale/mpc7448hpc2/mpc7448hpc2.c | 22 +-- board/tqm8272/tqm8272.c | 4 - common/Makefile | 1 - common/ft_build.c | 471 ----------------------------- cpu/74xx_7xx/cpu.c | 4 - include/configs/mpc7448hpc2.h | 1 + include/ft_build.h | 71 ----- 8 files changed, 3 insertions(+), 580 deletions(-) delete mode 100644 common/ft_build.c delete mode 100644 include/ft_build.h
diff --git a/README b/README index f14fb7b..21f4470 100644 --- a/README +++ b/README @@ -350,7 +350,7 @@ The following options need to be configured: expect it to be in bytes, others in MB. Define CONFIG_MEMSIZE_IN_BYTES to make it in bytes.
- CONFIG_OF_LIBFDT / CONFIG_OF_FLAT_TREE + CONFIG_OF_LIBFDT
New kernel versions are expecting firmware settings to be passed using flattened device trees (based on open firmware @@ -361,13 +361,6 @@ The following options need to be configured: * Adds the "fdt" command * The bootm command automatically updates the fdt
- CONFIG_OF_FLAT_TREE - * Deprecated, see CONFIG_OF_LIBFDT - * Original ft_build.c-based support - * Automatically modifies the dft as part of the bootm command - * The environment variable "disable_of", when set, - disables this functionality. - OF_CPU - The proper name of the cpus node. OF_SOC - The proper name of the soc node. OF_TBCLK - The timebase frequency. diff --git a/board/freescale/mpc7448hpc2/mpc7448hpc2.c b/board/freescale/mpc7448hpc2/mpc7448hpc2.c index fcbebc0..f6cd192 100644 --- a/board/freescale/mpc7448hpc2/mpc7448hpc2.c +++ b/board/freescale/mpc7448hpc2/mpc7448hpc2.c @@ -31,10 +31,7 @@
#include <common.h> #include <74xx_7xx.h> -#if defined(CONFIG_OF_FLAT_TREE) -#include <ft_build.h> -extern void ft_cpu_setup (void *blob, bd_t *bd); -#endif +#include <fdt_support.h>
#undef DEBUG
@@ -89,23 +86,6 @@ long int initdram (int board_type) return dram_size (board_type); }
-#if defined(CONFIG_OF_FLAT_TREE) && defined(CONFIG_OF_BOARD_SETUP) -void -ft_board_setup (void *blob, bd_t *bd) -{ - u32 *p; - int len; - - ft_cpu_setup (blob, bd); - - p = ft_get_prop (blob, "/memory/reg", &len); - if (p != NULL) { - *p++ = cpu_to_be32 (bd->bi_memstart); - *p = cpu_to_be32 (bd->bi_memsize); - } -} -#endif - #if defined(CONFIG_OF_BOARD_SETUP) void ft_board_setup(void *blob, bd_t *bd) diff --git a/board/tqm8272/tqm8272.c b/board/tqm8272/tqm8272.c index 7bd6401..ec1a37c 100644 --- a/board/tqm8272/tqm8272.c +++ b/board/tqm8272/tqm8272.c @@ -30,10 +30,6 @@ #include <pci.h> #include <asm/m8260_pci.h> #endif -#if CONFIG_OF_FLAT_TREE -#include <ft_build.h> -#include <image.h> -#endif
#if 0 #define deb_printf(fmt,arg...) \ diff --git a/common/Makefile b/common/Makefile index 9678799..b829373 100644 --- a/common/Makefile +++ b/common/Makefile @@ -118,7 +118,6 @@ COBJS-y += env_nowhere.o COBJS-y += exports.o COBJS-y += flash.o COBJS-y += fpga.o -COBJS-y += ft_build.o COBJS-y += hush.o COBJS-y += kgdb.o COBJS-y += lcd.o diff --git a/common/ft_build.c b/common/ft_build.c deleted file mode 100644 index b951178..0000000 --- a/common/ft_build.c +++ /dev/null @@ -1,471 +0,0 @@ -/* - * OF flat tree builder - * Written by: Pantelis Antoniou pantelis.antoniou@gmail.com - * Updated by: Matthew McClintock msm@freescale.com - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#include <common.h> -#include <malloc.h> -#include <environment.h> - -#ifdef CONFIG_OF_FLAT_TREE - -#include <asm/errno.h> -#include <stddef.h> - -#include <ft_build.h> -#include <linux/ctype.h> - -#undef DEBUG - -/* align addr on a size boundary - adjust address up if needed -- Cort */ -#define _ALIGN(addr,size) (((addr)+(size)-1)&(~((size)-1))) -#ifndef CONFIG_OF_BOOT_CPU -#define CONFIG_OF_BOOT_CPU 0 -#endif -#define SIZE_OF_RSVMAP_ENTRY (2*sizeof(u64)) - -static void ft_put_word(struct ft_cxt *cxt, u32 v) -{ - memmove(cxt->p + sizeof(u32), cxt->p, cxt->p_end - cxt->p); - - *(u32 *) cxt->p = cpu_to_be32(v); - cxt->p += sizeof(u32); - cxt->p_end += sizeof(u32); -} - -static inline void ft_put_bin(struct ft_cxt *cxt, const void *data, int sz) -{ - int aligned_size = ((u8 *)_ALIGN((unsigned long)cxt->p + sz, - sizeof(u32))) - cxt->p; - - memmove(cxt->p + aligned_size, cxt->p, cxt->p_end - cxt->p); - - /* make sure the last bytes are zeroed */ - memset(cxt->p + aligned_size - (aligned_size % sizeof(u32)), 0, - (aligned_size % sizeof(u32))); - - memcpy(cxt->p, data, sz); - - cxt->p += aligned_size; - cxt->p_end += aligned_size; -} - -void ft_begin_node(struct ft_cxt *cxt, const char *name) -{ - ft_put_word(cxt, OF_DT_BEGIN_NODE); - ft_put_bin(cxt, name, strlen(name) + 1); -} - -void ft_end_node(struct ft_cxt *cxt) -{ - ft_put_word(cxt, OF_DT_END_NODE); -} - -void ft_nop(struct ft_cxt *cxt) -{ - ft_put_word(cxt, OF_DT_NOP); -} - -static int lookup_string(struct ft_cxt *cxt, const char *name) -{ - u8 *p; - - p = cxt->p; - while (p < cxt->p_end) { - if (strcmp((char *)p, name) == 0) - return p - cxt->p; - p += strlen((char *)p) + 1; - } - - return -1; -} - -void ft_prop(struct ft_cxt *cxt, const char *name, const void *data, int sz) -{ - int off = 0; - - off = lookup_string(cxt, name); - if (off == -1) { - memcpy(cxt->p_end, name, strlen(name) + 1); - off = cxt->p_end - cxt->p; - cxt->p_end += strlen(name) + 1; - } - - /* now put offset from beginning of *STRUCTURE* */ - /* will be fixed up at the end */ - ft_put_word(cxt, OF_DT_PROP); - ft_put_word(cxt, sz); - ft_put_word(cxt, off); - ft_put_bin(cxt, data, sz); -} - -void ft_prop_str(struct ft_cxt *cxt, const char *name, const char *str) -{ - ft_prop(cxt, name, str, strlen(str) + 1); -} - -void ft_prop_int(struct ft_cxt *cxt, const char *name, int val) -{ - u32 v = cpu_to_be32((u32) val); - - ft_prop(cxt, name, &v, sizeof(u32)); -} - -/* pick up and start working on a tree in place */ -void ft_init_cxt(struct ft_cxt *cxt, void *blob) -{ - struct boot_param_header *bph = blob; - - memset(cxt, 0, sizeof(*cxt)); - - cxt->bph = bph; - bph->boot_cpuid_phys = CONFIG_OF_BOOT_CPU; - - /* find beginning and end of reserve map table (zeros in last entry) */ - cxt->p_rsvmap = (u8 *)bph + bph->off_mem_rsvmap; - while ( ((uint64_t *)cxt->p_rsvmap)[0] != 0 && - ((uint64_t *)cxt->p_rsvmap)[1] != 0 ) { - cxt->p_rsvmap += SIZE_OF_RSVMAP_ENTRY; - } - - cxt->p_start = (u8 *)bph + bph->off_dt_struct; - cxt->p_end = (u8 *)bph + bph->totalsize; - cxt->p = (u8 *)bph + bph->off_dt_strings; -} - -/* add a reserver physical area to the rsvmap */ -void ft_add_rsvmap(struct ft_cxt *cxt, u64 physstart, u64 physend) -{ - memmove(cxt->p_rsvmap + SIZE_OF_RSVMAP_ENTRY, cxt->p_rsvmap, - cxt->p_end - cxt->p_rsvmap); - - ((u64 *)cxt->p_rsvmap)[0] = cpu_to_be64(physstart); - ((u64 *)cxt->p_rsvmap)[1] = cpu_to_be64(physend); - ((u64 *)cxt->p_rsvmap)[2] = 0; - ((u64 *)cxt->p_rsvmap)[3] = 0; - - cxt->p_rsvmap += SIZE_OF_RSVMAP_ENTRY; - cxt->p_start += SIZE_OF_RSVMAP_ENTRY; - cxt->p += SIZE_OF_RSVMAP_ENTRY; - cxt->p_end += SIZE_OF_RSVMAP_ENTRY; -} - -void ft_end_tree(struct ft_cxt *cxt) -{ - ft_put_word(cxt, OF_DT_END); -} - -/* update the boot param header with correct values */ -void ft_finalize_tree(struct ft_cxt *cxt) { - struct boot_param_header *bph = cxt->bph; - - bph->totalsize = cxt->p_end - (u8 *)bph; - bph->off_dt_struct = cxt->p_start - (u8 *)bph; - bph->off_dt_strings = cxt->p - (u8 *)bph; - bph->dt_strings_size = cxt->p_end - cxt->p; -} - -static int is_printable_string(const void *data, int len) -{ - const char *s = data; - const char *ss; - - /* zero length is not */ - if (len == 0) - return 0; - - /* must terminate with zero */ - if (s[len - 1] != '\0') - return 0; - - ss = s; - while (*s && isprint(*s)) - s++; - - /* not zero, or not done yet */ - if (*s != '\0' || (s + 1 - ss) < len) - return 0; - - return 1; -} - -static void print_data(const void *data, int len) -{ - int i; - const u8 *s; - - /* no data, don't print */ - if (len == 0) - return; - - if (is_printable_string(data, len)) { - puts(" = ""); - puts(data); - puts("""); - return; - } - - switch (len) { - case 1: /* byte */ - printf(" = <%02x>", (*(u8 *) data) & 0xff); - break; - case 2: /* half-word */ - printf(" = <%04x>", be16_to_cpu(*(u16 *) data) & 0xffff); - break; - case 4: /* word */ - printf(" = <%x>", be32_to_cpu(*(u32 *) data) & 0xffffffffU); - break; - case 8: /* double-word */ - printf(" = <%qx>", be64_to_cpu(*(uint64_t *) data)); - break; - default: /* anything else... hexdump */ - printf(" = ["); - for (i = 0, s = data; i < len; i++) - printf("%02x%s", s[i], i < len - 1 ? " " : ""); - printf("]"); - - break; - } -} - -void ft_dump_blob(const void *bphp) -{ - const struct boot_param_header *bph = bphp; - const uint64_t *p_rsvmap = (const uint64_t *) - ((const char *)bph + be32_to_cpu(bph->off_mem_rsvmap)); - const u32 *p_struct = (const u32 *) - ((const char *)bph + be32_to_cpu(bph->off_dt_struct)); - const u32 *p_strings = (const u32 *) - ((const char *)bph + be32_to_cpu(bph->off_dt_strings)); - u32 tag; - const u32 *p; - const char *s, *t; - int depth, sz, shift; - int i; - uint64_t addr, size; - - if (be32_to_cpu(bph->magic) != OF_DT_HEADER) { - /* not valid tree */ - return; - } - - depth = 0; - shift = 4; - - for (i = 0;; i++) { - addr = be64_to_cpu(p_rsvmap[i * 2]); - size = be64_to_cpu(p_rsvmap[i * 2 + 1]); - if (addr == 0 && size == 0) - break; - - printf("/memreserve/ %qx %qx;\n", addr, size); - } - - p = p_struct; - while ((tag = be32_to_cpu(*p++)) != OF_DT_END) { - - /* printf("tag: 0x%08x (%d)\n", tag, p - p_struct); */ - - if (tag == OF_DT_BEGIN_NODE) { - s = (const char *)p; - p = (u32 *) _ALIGN((unsigned long)p + strlen(s) + 1, 4); - - printf("%*s%s {\n", depth * shift, "", s); - - depth++; - continue; - } - - if (tag == OF_DT_END_NODE) { - depth--; - - printf("%*s};\n", depth * shift, ""); - continue; - } - - if (tag == OF_DT_NOP) { - printf("%*s[NOP]\n", depth * shift, ""); - continue; - } - - if (tag != OF_DT_PROP) { - fprintf(stderr, "%*s ** Unknown tag 0x%08x at 0x%x\n", - depth * shift, "", tag, --p); - break; - } - sz = be32_to_cpu(*p++); - s = (const char *)p_strings + be32_to_cpu(*p++); - t = (const char *)p; - p = (const u32 *)_ALIGN((unsigned long)p + sz, 4); - printf("%*s%s", depth * shift, "", s); - print_data(t, sz); - printf(";\n"); - } -} - -void ft_backtrack_node(struct ft_cxt *cxt) -{ - int i = 4; - - while (be32_to_cpu(*(u32 *) (cxt->p - i)) != OF_DT_END_NODE) - i += 4; - - memmove (cxt->p - i, cxt->p, cxt->p_end - cxt->p); - - cxt->p_end -= i; - cxt->p -= i; -} - -void *ft_get_prop(void *bphp, const char *propname, int *szp) -{ - struct boot_param_header *bph = bphp; - uint32_t *p_struct = - (uint32_t *) ((char *)bph + be32_to_cpu(bph->off_dt_struct)); - uint32_t *p_strings = - (uint32_t *) ((char *)bph + be32_to_cpu(bph->off_dt_strings)); - uint32_t version = be32_to_cpu(bph->version); - uint32_t tag; - uint32_t *p; - char *s, *t; - char *ss; - int sz; - static char path[256], prop[256]; - - path[0] = '\0'; - - p = p_struct; - while ((tag = be32_to_cpu(*p++)) != OF_DT_END) { - - if (tag == OF_DT_BEGIN_NODE) { - s = (char *)p; - p = (uint32_t *) _ALIGN((unsigned long)p + strlen(s) + - 1, 4); - strcat(path, s); - strcat(path, "/"); - continue; - } - - if (tag == OF_DT_END_NODE) { - path[strlen(path) - 1] = '\0'; - ss = strrchr(path, '/'); - if (ss != NULL) - ss[1] = '\0'; - continue; - } - - if (tag == OF_DT_NOP) - continue; - - if (tag != OF_DT_PROP) - break; - - sz = be32_to_cpu(*p++); - s = (char *)p_strings + be32_to_cpu(*p++); - if (version < 0x10 && sz >= 8) - p = (uint32_t *) _ALIGN((unsigned long)p, 8); - t = (char *)p; - p = (uint32_t *) _ALIGN((unsigned long)p + sz, 4); - - strcpy(prop, path); - strcat(prop, s); - - if (strcmp(prop, propname) == 0) { - *szp = sz; - return t; - } - } - - return NULL; -} - -/********************************************************************/ - -void ft_setup(void *blob, bd_t * bd, ulong initrd_start, ulong initrd_end) -{ - u32 *p; - int len; - struct ft_cxt cxt; - ulong clock; - - /* disable OF tree; booting old kernel */ - if (getenv("disable_of") != NULL) { - memcpy(blob, bd, sizeof(*bd)); - return; - } - -#ifdef DEBUG - printf ("recieved oftree\n"); - ft_dump_blob(blob); -#endif - - ft_init_cxt(&cxt, blob); - - if (initrd_start && initrd_end) - ft_add_rsvmap(&cxt, initrd_start, initrd_end - initrd_start + 1); - - /* back into root */ - ft_backtrack_node(&cxt); - - ft_begin_node(&cxt, "chosen"); - ft_prop_str(&cxt, "name", "chosen"); - - ft_prop_str(&cxt, "bootargs", getenv("bootargs")); - ft_prop_int(&cxt, "linux,platform", 0x600); /* what is this? */ - if (initrd_start && initrd_end) { - ft_prop_int(&cxt, "linux,initrd-start", initrd_start); - ft_prop_int(&cxt, "linux,initrd-end", initrd_end); - } -#ifdef OF_STDOUT_PATH - ft_prop_str(&cxt, "linux,stdout-path", OF_STDOUT_PATH); -#endif - - ft_end_node(&cxt); - - ft_end_node(&cxt); /* end root */ - - ft_end_tree(&cxt); - ft_finalize_tree(&cxt); - -#ifdef CONFIG_PPC - clock = bd->bi_intfreq; - p = ft_get_prop(blob, "/cpus/" OF_CPU "/clock-frequency", &len); - if (p != NULL) - *p = cpu_to_be32(clock); - -#ifdef OF_TBCLK - clock = OF_TBCLK; - p = ft_get_prop(blob, "/cpus/" OF_CPU "/timebase-frequency", &len); - if (p != NULL) - *p = cpu_to_be32(clock); -#endif -#endif /* __powerpc__ */ - -#ifdef CONFIG_OF_BOARD_SETUP - ft_board_setup(blob, bd); -#endif - - /* in case the size changed in the platform code */ - ft_finalize_tree(&cxt); - -#ifdef DEBUG - printf("final OF-tree\n"); - ft_dump_blob(blob); -#endif -} -#endif diff --git a/cpu/74xx_7xx/cpu.c b/cpu/74xx_7xx/cpu.c index a6e3426..ea43c9a 100644 --- a/cpu/74xx_7xx/cpu.c +++ b/cpu/74xx_7xx/cpu.c @@ -49,10 +49,6 @@ #include <fdt_support.h> #endif
-#if defined(CONFIG_OF_FLAT_TREE) -#include <ft_build.h> -#endif - #ifdef CONFIG_AMIGAONEG3SE #include "../board/MAI/AmigaOneG3SE/via686.h" #include "../board/MAI/AmigaOneG3SE/memio.h" diff --git a/include/configs/mpc7448hpc2.h b/include/configs/mpc7448hpc2.h index c01d0a5..689b4ad 100644 --- a/include/configs/mpc7448hpc2.h +++ b/include/configs/mpc7448hpc2.h @@ -58,6 +58,7 @@ #define CONFIG_BOARD_EARLY_INIT_R #define CONFIG_MISC_INIT_R
+#define CONFIG_HAS_ETH0 #define CONFIG_HAS_ETH1
#define CONFIG_ENV_OVERWRITE diff --git a/include/ft_build.h b/include/ft_build.h deleted file mode 100644 index 89c689c..0000000 --- a/include/ft_build.h +++ /dev/null @@ -1,71 +0,0 @@ -/* - * OF Flat tree builder - * - */ - -#ifndef FT_BUILD_H -#define FT_BUILD_H - -#include <linux/types.h> -#include <asm/u-boot.h> - -/* Definitions used by the flattened device tree */ -#define OF_DT_HEADER 0xd00dfeed /* marker */ -#define OF_DT_BEGIN_NODE 0x1 /* Start of node, full name */ -#define OF_DT_END_NODE 0x2 /* End node */ -#define OF_DT_PROP 0x3 /* Property: name off, size, - * content */ -#define OF_DT_NOP 0x4 /* nop */ -#define OF_DT_END 0x9 - -#define OF_DT_VERSION 0x10 - -struct boot_param_header { - u32 magic; /* magic word OF_DT_HEADER */ - u32 totalsize; /* total size of DT block */ - u32 off_dt_struct; /* offset to structure */ - u32 off_dt_strings; /* offset to strings */ - u32 off_mem_rsvmap; /* offset to memory reserve map */ - u32 version; /* format version */ - u32 last_comp_version; /* last compatible version */ - /* version 2 fields below */ - u32 boot_cpuid_phys; /* Physical CPU id we're booting on */ - /* version 3 fields below */ - u32 dt_strings_size; /* size of the DT strings block */ -}; - -struct ft_cxt { - struct boot_param_header *bph; - u8 *p_rsvmap; - u8 *p_start; /* pointer to beginning of dt_struct */ - u8 *p_end; /* pointer to end of dt_strings */ - u8 *p; /* pointer to end of dt_struct and beginning of dt_strings */ -}; - -void ft_begin_node(struct ft_cxt *cxt, const char *name); -void ft_init_cxt(struct ft_cxt *cxt, void *blob); -void ft_end_node(struct ft_cxt *cxt); - -void ft_end_tree(struct ft_cxt *cxt); -void ft_finalize_tree(struct ft_cxt *cxt); - -void ft_nop(struct ft_cxt *cxt); -void ft_prop(struct ft_cxt *cxt, const char *name, const void *data, int sz); -void ft_prop_str(struct ft_cxt *cxt, const char *name, const char *str); -void ft_prop_int(struct ft_cxt *cxt, const char *name, int val); -void ft_begin(struct ft_cxt *cxt, void *blob, int max_size); -void ft_add_rsvmap(struct ft_cxt *cxt, u64 physaddr, u64 size); - -void ft_setup(void *blob, bd_t * bd, ulong initrd_start, ulong initrd_end); - -void ft_dump_blob(const void *bphp); -void ft_merge_blob(struct ft_cxt *cxt, void *blob); -void *ft_get_prop(void *bphp, const char *propname, int *szp); - -#ifdef CONFIG_OF_BOARD_SETUP -void ft_board_setup(void *blob, bd_t *bd); -void ft_cpu_setup(void *blob, bd_t *bd); -void ft_pci_setup(void *blob, bd_t *bd); -#endif - -#endif
Jerry Van Baren
