[PATCH v2 15/21] mips: add an option to enable u_boot_list section for SPL loaders in u-boot-spl.lds
u_boot_list is not only used by DM, but also by some SPL image load methods such as spl_nor.c.
This patch adds an option CONFIG_SPL_LOADER_SUPPORT in conjunction with CONFIG_SPL_DM surrounding the u_boot_list section to make sure SPL image loaders can be correctly built into u-boot SPL without DM enabled.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- Changes since v1: uses a new config instead of removing CONFIG_SPL_DM --- arch/mips/cpu/u-boot-spl.lds | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/mips/cpu/u-boot-spl.lds b/arch/mips/cpu/u-boot-spl.lds index e467491639..28ea4f2a48 100644 --- a/arch/mips/cpu/u-boot-spl.lds +++ b/arch/mips/cpu/u-boot-spl.lds @@ -27,7 +27,7 @@ SECTIONS *(SORT_BY_ALIGNMENT(.sdata*)) } > .spl_mem
-#ifdef CONFIG_SPL_DM +#if defined(CONFIG_SPL_DM) || defined(CONFIG_SPL_LOADER_SUPPORT) . = ALIGN(4); .u_boot_list : { KEEP(*(SORT(.u_boot_list*)));
Am 17.01.20 um 08:46 schrieb Weijie Gao:
Reviewed-by: Daniel Schwierzeck daniel.schwierzeck@gmail.com
Daniel Schwierzeck
Weijie Gao
