[RESEND PATCH v1] colibri_imx6: fix broken fsl_esdhc_imx conversion
Not all CONFIG_FSL_ESDHC defines were properly replaced with CONFIG_FSL_ESDHC_IMX, which broke U-boot proper booting on Colibri iMX6 SoMs.
U-boot is stuck after this message: Commercial temperature grade DDR3 timings, 64bit bus width. Trying to boot from MMC1
Fixes: e37ac717d7("Convert to use fsl_esdhc_imx for i.MX platforms") Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com ---
board/toradex/colibri_imx6/colibri_imx6.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/toradex/colibri_imx6/colibri_imx6.c b/board/toradex/colibri_imx6/colibri_imx6.c index ad40b589c1..44173dde1f 100644 --- a/board/toradex/colibri_imx6/colibri_imx6.c +++ b/board/toradex/colibri_imx6/colibri_imx6.c @@ -83,7 +83,7 @@ iomux_v3_cfg_t const uart1_pads[] = { MX6_PAD_CSI0_DAT11__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL), };
-#if defined(CONFIG_FSL_ESDHC) && defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_FSL_ESDHC_IMX) && defined(CONFIG_SPL_BUILD) /* Colibri MMC */ iomux_v3_cfg_t const usdhc1_pads[] = { MX6_PAD_SD1_CLK__SD1_CLK | MUX_PAD_CTRL(USDHC_PAD_CTRL), @@ -304,7 +304,7 @@ int board_ehci_hcd_init(int port) } #endif
-#if defined(CONFIG_FSL_ESDHC) && defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_FSL_ESDHC_IMX) && defined(CONFIG_SPL_BUILD) /* use the following sequence: eMMC, MMC */ struct fsl_esdhc_cfg usdhc_cfg[CONFIG_SYS_FSL_USDHC_NUM] = { {USDHC3_BASE_ADDR},
Hi Stefano
-#if defined(CONFIG_FSL_ESDHC) && defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_FSL_ESDHC_IMX) && defined(CONFIG_SPL_BUILD) /* use the following sequence: eMMC, MMC */ struct fsl_esdhc_cfg usdhc_cfg[CONFIG_SYS_FSL_USDHC_NUM] = { {USDHC3_BASE_ADDR}, -- 2.17.1
I've just found the same fix [1] but from Ricardo with Awaiting upstream status in patchwork (I thought that he has fixed just Apalis iMX6), but seems the patch was lost somewhere, as I can not find it nor in u-boot-imx/next neither in u-boot-imx/master branches.
[1] https://patchwork.ozlabs.org/patch/1157059/
Hi Igor,
Hi Stefano
Thanks for providing the fix (at least for the Toradex boards)
And I do guess that more i.MX6 boards are affected ...
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
On Fri, Dec 06, 2019 at 06:23:09PM +0100, Lukasz Majewski wrote:
Hi Igor,
Hi Stefano
I think there's just one other. The imx8qm_rom7720_a1 references CONFIG_FSL_ESDHC still, but I don't see any other i.MX8 platforms doing anything with the symbol to compare with.
Hi Igor,
Hi Stefano
thx for that hint, so I must replace CONFIG_FSL_ESDHC with CONFIG_FSL_ESDHC_IMX in board/advantech/imx8qm_rom7720_a1/spl.c ?
Oliver
Hi Igor,
Hi Stefano
Yes, and confirm that everything works as expected for the appropriate use cases. Thanks!
From: Igor Opaniuk igor.opaniuk@toradex.com Not all CONFIG_FSL_ESDHC defines were properly replaced with CONFIG_FSL_ESDHC_IMX, which broke U-boot proper booting on Colibri iMX6 SoMs. U-boot is stuck after this message: Commercial temperature grade DDR3 timings, 64bit bus width. Trying to boot from MMC1 Fixes: e37ac717d7("Convert to use fsl_esdhc_imx for i.MX platforms") Signed-off-by: Igor Opaniuk igor.opaniuk@toradex.com
Best regards, Stefano Babic
participants (6)
Igor Opaniuk
Igor Opaniuk
Lukasz Majewski
Oliver Graute
sbabic@denx.de
