[U-Boot] [PATCH 1/1] efi_loader: move efi_guid_t typedef to efi.h
efi_guid_t is used both in efi_api.h and in part_efi.h. Both include efi.h. So we should move the typedef to the common include. This saves us from including part_efi.h in places where we don't need it.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- download.suse.org seems to be down. So I was no able to test on Travis CI. I just built for vexpress and x86. --- include/efi.h | 3 +++ include/part_efi.h | 4 ---- 2 files changed, 3 insertions(+), 4 deletions(-)
diff --git a/include/efi.h b/include/efi.h index 02b78b31b1..6cb7db1ea5 100644 --- a/include/efi.h +++ b/include/efi.h @@ -81,6 +81,9 @@ typedef unsigned long efi_status_t; typedef u64 efi_physical_addr_t; typedef u64 efi_virtual_addr_t; typedef void *efi_handle_t; +typedef struct { + u8 b[16]; +} efi_guid_t;
#define EFI_GUID(a, b, c, d0, d1, d2, d3, d4, d5, d6, d7) \ ((efi_guid_t) \ diff --git a/include/part_efi.h b/include/part_efi.h index 317c044795..31e6bc6e14 100644 --- a/include/part_efi.h +++ b/include/part_efi.h @@ -58,10 +58,6 @@ /* linux/include/efi.h */ typedef u16 efi_char16_t;
-typedef struct { - u8 b[16]; -} efi_guid_t; - /* based on linux/include/genhd.h */ struct partition { u8 boot_ind; /* 0x80 - active */
Won't that break the case where GUID partition table support is enabled, but efi is not?
Alex
- u8 b[16];
+} efi_guid_t;
-typedef struct {
- u8 b[16];
-} efi_guid_t;
Alex
I moved the definition of efi_guid_t from part_efi.h to efi.h. The definition is placed in a part of efi.h that is not enclosed in any #if*. include/part_efi.h has this line: #include <efi.h> So any program including part_efi.h will still see the definition.
Best regards
Heinrich
- u8 b[16];
+} efi_guid_t; #define EFI_GUID(a, b, c, d0, d1, d2, d3, d4, d5, d6, d7) \ ((efi_guid_t) \ diff --git a/include/part_efi.h b/include/part_efi.h index 317c044795..31e6bc6e14 100644 --- a/include/part_efi.h +++ b/include/part_efi.h @@ -58,10 +58,6 @@ /* linux/include/efi.h */ typedef u16 efi_char16_t; -typedef struct {
- u8 b[16];
-} efi_guid_t;
Alexander Graf
