[U-Boot] [PULL] : Please pull u-boot-imx
Hi Albert,
please pull from u-boot-imx, thanks !
The following changes since commit 326ea986ac150acdc7656d57fca647db80b50158:
Merge git://git.denx.de/u-boot-arm (2013-07-31 11:30:38 +0200)
git://www.denx.de/git/u-boot-imx.git master
for you to fetch changes up to 8467faef7fce8c5faad7224b7737a58e16c52186:
i.MX6: Set and clear the gating bits for Phase Fractional Dividers (2013-08-31 18:09:37 +0200)
---------------------------------------------------------------- Amaury Pouly (1): mmc: mxsmmc: Enable MMC HC support
Andreas Wass (2): ARM: mxs: Added application UART driver ARM: mxs: Add mx28evk_auart_console target
Eric Nelson (6): i.MX6: nitrogen6x: force HDMI onto IPU0/DI0 fec_mxc: set ethaddr if fuses burned and not previously set i.MX6: Add convenience macros cpu_type(rev) and is_cpu_type(cpu) i.MX6: Correct ANATOP_PFD (Phase Fractional Divider) register declarations i.MX6: nitrogen6x: Don't bother setting PLL3(480) PFD1 divisor i.MX6: Set and clear the gating bits for Phase Fractional Dividers
Hector Palacios (1): ARM: mxs: rename function that sets AUTO_RESTART flag
Marek Vasut (3): ARM: mxs: tools: Add mkimage support for MXS bootstream tools: Sort lists of files in Makefile tools: mxsboot: Staticize functions
SARTRE Leo (1): ARM: Congatec: README update
Stefano Babic (7): tools: imx_header should not include flash_offset tools: rename mximage_flash_offset to imximage_ivt_offset tools: dynamically allocate imx_header in imximage tools: add variable padding of data image in mkimage tools: add padding of data image file for imximage tools: add support for setting the CSF into imximage imx: add status reporting for HAB status
arch/arm/cpu/arm926ejs/mxs/mxsimage.mx23.cfg | 6 + arch/arm/cpu/arm926ejs/mxs/mxsimage.mx28.cfg | 8 + arch/arm/cpu/arm926ejs/mxs/spl_power_init.c | 9 +- arch/arm/cpu/armv7/mx6/Makefile | 7 +- arch/arm/cpu/armv7/mx6/hab.c | 104 ++ arch/arm/cpu/armv7/mx6/soc.c | 28 + arch/arm/include/asm/arch-mx6/hab.h | 67 + arch/arm/include/asm/arch-mx6/imx-regs.h | 37 +- arch/arm/include/asm/arch-mx6/sys_proto.h | 7 + arch/arm/include/asm/arch-mxs/regs-uartapp.h | 220 +++ board/boundary/nitrogen6x/nitrogen6x.c | 8 +- board/congatec/cgtqmx6eval/README | 3 +- boards.cfg | 1 + common/image.c | 1 + config.mk | 9 + doc/README.imximage | 30 +- doc/README.mxc_hab | 48 + doc/README.mxsimage | 165 ++ drivers/mmc/mxsmmc.c | 3 +- drivers/net/fec_mxc.c | 2 + drivers/serial/Makefile | 1 + drivers/serial/mxs_auart.c | 151 ++ drivers/serial/serial.c | 2 + include/configs/mxs.h | 7 +- include/image.h | 1 + tools/Makefile | 42 +- tools/imximage.c | 180 +- tools/imximage.h | 20 +- tools/mkimage.c | 26 +- tools/mkimage.h | 6 +- tools/mxsboot.c | 12 +- tools/mxsimage.c | 2347 ++++++++++++++++++++++++++ tools/mxsimage.h | 230 +++ 33 files changed, 3691 insertions(+), 97 deletions(-) create mode 100644 arch/arm/cpu/arm926ejs/mxs/mxsimage.mx23.cfg create mode 100644 arch/arm/cpu/arm926ejs/mxs/mxsimage.mx28.cfg create mode 100644 arch/arm/cpu/armv7/mx6/hab.c create mode 100644 arch/arm/include/asm/arch-mx6/hab.h create mode 100644 arch/arm/include/asm/arch-mxs/regs-uartapp.h create mode 100644 doc/README.mxc_hab create mode 100644 doc/README.mxsimage create mode 100644 drivers/serial/mxs_auart.c create mode 100644 tools/mxsimage.c create mode 100644 tools/mxsimage.h
Hi Stefano,
On Tue, 03 Sep 2013 10:20:44 +0200, Stefano Babic sbabic@denx.de wrote:
Hi Albert,
Applied to u-boot-arm/master, thanks!
Amicalement,
Albert ARIBAUD
Stefano Babic
