[U-Boot-Users] U-boot Arm kernel (2.4.19-rmk7) booting problem.
Hi ,
i m using 2.4.19-rmk7 kernel with u-boot. while power up my board i can able to see the following .
U-Boot 1.1.1 (May 27 2004 - 12:22:57)
U-Boot code: 00F80000 -> 00F91500 BSS: -> 00F92A10 RAM Configuration: Bank #0: 00000000 16 MB Flash: 32 MB In: serial Out: serial Err: serial Hit any key to stop autoboot: 0 ## Booting image at 50040000 ... Image Name: Linux Kernel Image Image Type: ARM Linux Kernel Image (gzip compressed) Data Size: 707682 Bytes = 691.1 kB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Uncompressing Kernel Image ... OK
Starting Kernel ...
I am very newbie to ARM platform. i dont know what is Load Address, and Entry point, where should i find in my kernle source ?. should i load ramdisk before kernel booting ?. i have set the follwoing Environment variables.
bootargs=root=/dev/mtdblock2 rootfstype=cramfs console=ttyS0,115200 bootcmd=bootm 50040000 bootdelay=3 baudrate=115200 ethaddr=08:00:3e:26:0a:5b ipaddr=192.168.0.21 serverip=192.168.0.250 netmask=255.255.0.0 stdin=serial stdout=serial stderr=serial
Environment size: 249/131068 bytes
Expecting your Help
Thanks Prakash
As mentioned before in private email, these addresses are definitely wrong on ARM.
Search the archive. This has been discussed several times before.
As your root device is on a MTD partition, you should not load a ramdisk at all.
Annamalai Prakash
