[PATCH] fixdep: fix U-Boot own code to handle only valid symbol characters
Currently, fixdep skips parsing include/linux/kconfig.h, but if it parsed it, it would translate the following code in kconfig.h
config_enabled(CONFIG_VAL(option##_MODULE)
into:
$(wildcard include/config/option##/module.h)
When Kbuild includes .*.cmd, it would emit the following error:
*** unterminated call to function 'wildcard': missing ')'. Stop.
This issue prevents us from importing the upstream Linux commit 638e69cf2230 ("fixdep: do not ignore kconfig.h").
Fix this by handling only alphanumerical characters and underscores. This makes sense because they match to the valid character sets in Kconfig symbols.
As a side-note, you can reproduce this issue only on GNU Make <= 4.2.1
For GNU Make <= 4.2.1, the '#' always means the start of a comment. Hence, GNU Make thinks the closing ')' is missing.
The following commit in GNU Make changed how it handles '#' in function invocations. So, this does not happen for GNU Make 4.3
| commit c6966b323811c37acedff05b576b907b06aea5f4 | Author: Paul Smith psmith@gnu.org | Date: Thu Dec 22 18:47:26 2016 -0500 | | [SV 20513] Un-escaped # are not comments in function invocations
Signed-off-by: Masahiro Yamada masahiroy@kernel.org ---
This patch is applicable to the current upstream code.
scripts/basic/fixdep.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/scripts/basic/fixdep.c b/scripts/basic/fixdep.c index da7fb2cd4dde..6a668f114096 100644 --- a/scripts/basic/fixdep.c +++ b/scripts/basic/fixdep.c @@ -262,7 +262,7 @@ static void parse_config_file(const char *map, size_t len) (q - p == 3 && !memcmp(p, "VAL(", 4))) { p = q + 1; for (q = p; q < map + len; q++) - if (*q == ')') + if (!(isalnum(*q) || *q == '_')) goto found2; continue;
into:
Maybe, this can have this tag.
Fixes: 8be60f06c258 ("linux/kconfig.h: add CPP macros useful for per-image config options")
if (*q == ')')
-- 2.17.1
into:
Ah, OK, thanks. Yes, I'll go this route to keep bisectability and fully re-sync the program.
into:
One more tag:
Reported-by: Tom Rini trini@konsulko.com
into:
Signed-off-by: Masahiro Yamada masahiroy@kernel.org Reported-by: Tom Rini trini@konsulko.com
Masahiro Yamada
