[U-Boot] [PATCH v4 00/11] mtd/sf: Various fixes
Hello,
This is the 4th version of the mtd / sf fixes patchset. This v4 just adds a new check in del_mtd_device() (and a debug() when del_mtd_partitions() fails).
Regards,
Boris
P.S.: travis-ci results => https://travis-ci.org/bbrezillon/u-boot/builds/461943011
Boris Brezillon (11): mtd: Add a function to report when the MTD dev list has been updated mtd: Parse mtdparts/mtdids again when the MTD list has been updated mtd: Delete partitions attached to the device when a device is deleted mtd: sf: Make sure we don't register the same device twice mtd: Use get_mtdids() instead of env_get("mtdids") in mtd_search_alternate_name() mtd: Be more strict on the "mtdparts=" prefix check mtd: Make sure the name passed in mtdparts fits in mtd_name[] mtd: Make sure we don't parse MTD partitions belonging to another dev mtd: Don't stop MTD partition creation when it fails on one device mtd: sf: Unregister the MTD device prior to removing the spi_flash obj mtd: sf: Make sf_mtd.c more robust
drivers/mtd/mtd_uboot.c | 185 +++++++++++++++++++++++++------------ drivers/mtd/mtdcore.c | 23 ++++- drivers/mtd/mtdpart.c | 12 +++ drivers/mtd/spi/sf_mtd.c | 48 +++++++++- drivers/mtd/spi/sf_probe.c | 9 ++ include/linux/mtd/mtd.h | 18 ++++ 6 files changed, 233 insertions(+), 62 deletions(-)
We need to parse mtdparts/mtids again everytime a device has been added/removed from the MTD list, but there's currently no way to know when such an update has been done.
Add an ->updated field to the idr struct that we set to true every time a device is added/removed and expose a function returning the value of this field and resetting it to false.
Signed-off-by: Boris Brezillon boris.brezillon@bootlin.com Tested-by: Heiko Schocher hs@denx.de --- Changes in v4: - Add T-b tag
Changes in v2: - None
Changes in v2: - None --- drivers/mtd/mtdcore.c | 16 +++++++++++++++- include/linux/mtd/mtd.h | 1 + 2 files changed, 16 insertions(+), 1 deletion(-)
diff --git a/drivers/mtd/mtdcore.c b/drivers/mtd/mtdcore.c index fb6c779abbfe..7a15ded8c883 100644 --- a/drivers/mtd/mtdcore.c +++ b/drivers/mtd/mtdcore.c @@ -87,14 +87,17 @@ struct idr_layer {
struct idr { struct idr_layer id[MAX_IDR_ID]; + bool updated; };
#define DEFINE_IDR(name) struct idr name;
void idr_remove(struct idr *idp, int id) { - if (idp->id[id].used) + if (idp->id[id].used) { idp->id[id].used = 0; + idp->updated = true; + }
return; } @@ -134,6 +137,7 @@ int idr_alloc(struct idr *idp, void *ptr, int start, int end, gfp_t gfp_mask) if (idl->used == 0) { idl->used = 1; idl->ptr = ptr; + idp->updated = true; return i; } i++; @@ -155,6 +159,16 @@ struct mtd_info *__mtd_next_device(int i) } EXPORT_SYMBOL_GPL(__mtd_next_device);
+bool mtd_dev_list_updated(void) +{ + if (mtd_idr.updated) { + mtd_idr.updated = false; + return true; + } + + return false; +} + #ifndef __UBOOT__ static LIST_HEAD(mtd_notifiers);
diff --git a/include/linux/mtd/mtd.h b/include/linux/mtd/mtd.h index 68e591532492..d20ebd820289 100644 --- a/include/linux/mtd/mtd.h +++ b/include/linux/mtd/mtd.h @@ -581,6 +581,7 @@ int mtd_arg_off_size(int argc, char *const argv[], int *idx, loff_t *off, void mtd_get_len_incl_bad(struct mtd_info *mtd, uint64_t offset, const uint64_t length, uint64_t *len_incl_bad, int *truncated); +bool mtd_dev_list_updated(void);
/* drivers/mtd/mtd_uboot.c */ int mtd_search_alternate_name(const char *mtdname, char *altname,
Hi Boris,
This series fixed a but on Vybrid, when I run several times "mtdpart default" after calling sf probe for two SPI-NOR memories.
When I called "mtdpart default" for the second time, the mtd partitions were gone despite being visible with "mtdparts" command.
Hence,
Tested-by: Lukasz Majewski lukma@denx.de
Changes in v4:
- Add T-b tag
Changes in v2:
- None
Changes in v2:
- None
- bool updated;
return;
} i++;idp->updated = true; return i;
- if (mtd_idr.updated) {
return true;
- return false;
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-59 Fax: (+49)-8142-66989-80 Email: lukma@denx.de
Updates to the MTD device list should trigger a new parsing of the mtdids/mtdparts vars even if those vars haven't changed.
Fixes: 5db66b3aee6f ("cmd: mtd: add 'mtd' command") Signed-off-by: Boris Brezillon boris.brezillon@bootlin.com Tested-by: Heiko Schocher hs@denx.de --- Changes in v4: - Add T-b tag
Changes in v3: - None
Changes in v2: - None --- drivers/mtd/mtd_uboot.c | 18 +++++++++++++++++- 1 file changed, 17 insertions(+), 1 deletion(-)
diff --git a/drivers/mtd/mtd_uboot.c b/drivers/mtd/mtd_uboot.c index 5ca560c96879..6a3e64395de2 100644 --- a/drivers/mtd/mtd_uboot.c +++ b/drivers/mtd/mtd_uboot.c @@ -161,9 +161,13 @@ int mtd_probe_devices(void)
mtd_probe_uclass_mtd_devs();
- /* Check if mtdparts/mtdids changed since last call, otherwise: exit */ + /* + * Check if mtdparts/mtdids changed or if the MTD dev list was updated + * since last call, otherwise: exit + */ if ((!mtdparts && !old_mtdparts && !mtdids && !old_mtdids) || (mtdparts && old_mtdparts && mtdids && old_mtdids && + !mtd_dev_list_updated() && !strcmp(mtdparts, old_mtdparts) && !strcmp(mtdids, old_mtdids))) return 0; @@ -201,6 +205,12 @@ int mtd_probe_devices(void) } }
+ /* + * Call mtd_dev_list_updated() to clear updates generated by our own + * parts removal loop. + */ + mtd_dev_list_updated(); + /* If either mtdparts or mtdids is empty, then exit */ if (!mtdparts || !mtdids) return 0; @@ -281,6 +291,12 @@ int mtd_probe_devices(void) put_mtd_device(mtd); }
+ /* + * Call mtd_dev_list_updated() to clear updates generated by our own + * parts registration loop. + */ + mtd_dev_list_updated(); + return 0; } #else
If we don't do that, partitions might still be exposed while the underlying device is gone.
Fixes: 2a74930da57f ("mtd: mtdpart: implement proper partition handling") Signed-off-by: Boris Brezillon boris.brezillon@bootlin.com Tested-by: Heiko Schocher hs@denx.de --- Changes in v4: - Test the del_mtd_partitions() ret code and propagate errors - Add a debug() message when del_mtd_partitions() returns an error - Add Heiko's T-b
Changes in v2: - Fix build failures when CONFIG_MTD_PARTITIONS is not enabled --- drivers/mtd/mtdcore.c | 7 +++++++ include/linux/mtd/mtd.h | 15 +++++++++++++++ 2 files changed, 22 insertions(+)
diff --git a/drivers/mtd/mtdcore.c b/drivers/mtd/mtdcore.c index 7a15ded8c883..cb7ca38d0744 100644 --- a/drivers/mtd/mtdcore.c +++ b/drivers/mtd/mtdcore.c @@ -528,6 +528,13 @@ int del_mtd_device(struct mtd_info *mtd) struct mtd_notifier *not; #endif
+ ret = del_mtd_partitions(mtd); + if (ret) { + debug("Failed to delete MTD partitions attached to %s (err %d)\n", + mtd->name, ret); + return ret; + } + mutex_lock(&mtd_table_mutex);
if (idr_find(&mtd_idr, mtd->index) != mtd) { diff --git a/include/linux/mtd/mtd.h b/include/linux/mtd/mtd.h index d20ebd820289..4d0096d9f1d8 100644 --- a/include/linux/mtd/mtd.h +++ b/include/linux/mtd/mtd.h @@ -562,8 +562,23 @@ unsigned mtd_mmap_capabilities(struct mtd_info *mtd); /* drivers/mtd/mtdcore.h */ int add_mtd_device(struct mtd_info *mtd); int del_mtd_device(struct mtd_info *mtd); + +#ifdef CONFIG_MTD_PARTITIONS int add_mtd_partitions(struct mtd_info *, const struct mtd_partition *, int); int del_mtd_partitions(struct mtd_info *); +#else +static inline int add_mtd_partitions(struct mtd_info *mtd, + const struct mtd_partition *parts, + int nparts) +{ + return 0; +} + +static inline int del_mtd_partitions(struct mtd_info *mtd) +{ + return 0; +} +#endif
struct mtd_info *__mtd_next_device(int i); #define mtd_for_each_device(mtd) \
spi_flash_mtd_register() can be called several times and each time it will register the same mtd_info instance like if it was a new one. The MTD ID allocation gets crazy when that happens, so let's track the status of the sf_mtd_info object to avoid that.
Fixes: 9fe6d8716e09 ("mtd, spi: Add MTD layer driver") Signed-off-by: Boris Brezillon boris.brezillon@bootlin.com Tested-by: Heiko Schocher hs@denx.de Reviewed-by: Jagan Teki jagan@openedev.com --- Changes in v4: - Add T-b/R-b tags
Changes in v2 - None --- drivers/mtd/spi/sf_mtd.c | 13 ++++++++++++- 1 file changed, 12 insertions(+), 1 deletion(-)
diff --git a/drivers/mtd/spi/sf_mtd.c b/drivers/mtd/spi/sf_mtd.c index 58d7e4439903..aabbc3589435 100644 --- a/drivers/mtd/spi/sf_mtd.c +++ b/drivers/mtd/spi/sf_mtd.c @@ -10,6 +10,7 @@ #include <spi_flash.h>
static struct mtd_info sf_mtd_info; +static bool sf_mtd_registered; static char sf_mtd_name[8];
static int spi_flash_mtd_erase(struct mtd_info *mtd, struct erase_info *instr) @@ -73,6 +74,12 @@ static int spi_flash_mtd_number(void)
int spi_flash_mtd_register(struct spi_flash *flash) { + int ret; + + if (sf_mtd_registered) + del_mtd_device(&sf_mtd_info); + + sf_mtd_registered = false; memset(&sf_mtd_info, 0, sizeof(sf_mtd_info)); sprintf(sf_mtd_name, "nor%d", spi_flash_mtd_number());
@@ -94,7 +101,11 @@ int spi_flash_mtd_register(struct spi_flash *flash) sf_mtd_info.numeraseregions = 0; sf_mtd_info.erasesize = flash->sector_size;
- return add_mtd_device(&sf_mtd_info); + ret = add_mtd_device(&sf_mtd_info); + if (!ret) + sf_mtd_registered = true; + + return ret; }
void spi_flash_mtd_unregister(void)
The environment is not guaranteed to contain a valid mtdids variable when called from mtd_search_alternate_name(). Call get_mtdids() instead of env_get("mtdids").
Fixes: ff4afa8a981e ("mtd: uboot: search for an equivalent MTD name with the mtdids") Signed-off-by: Boris Brezillon boris.brezillon@bootlin.com Reviewed-by: Miquel Raynal miquel.raynal@bootlin.com Tested-by: Heiko Schocher hs@denx.de --- Changes in v4: - Add T-b tag
Changes in v2: - Add Miquel's R-b - Move board_mtdparts_default() prototype def to fix a build failure --- drivers/mtd/mtd_uboot.c | 49 ++++++++++++++++++++--------------------- 1 file changed, 24 insertions(+), 25 deletions(-)
diff --git a/drivers/mtd/mtd_uboot.c b/drivers/mtd/mtd_uboot.c index 6a3e64395de2..c4434d70520d 100644 --- a/drivers/mtd/mtd_uboot.c +++ b/drivers/mtd/mtd_uboot.c @@ -13,6 +13,29 @@
#define MTD_NAME_MAX_LEN 20
+void board_mtdparts_default(const char **mtdids, const char **mtdparts); + +static const char *get_mtdids(void) +{ + __maybe_unused const char *mtdparts = NULL; + const char *mtdids = env_get("mtdids"); + + if (mtdids) + return mtdids; + +#if defined(CONFIG_SYS_MTDPARTS_RUNTIME) + board_mtdparts_default(&mtdids, &mtdparts); +#elif defined(MTDIDS_DEFAULT) + mtdids = MTDIDS_DEFAULT; +#elif defined(CONFIG_MTDIDS_DEFAULT) + mtdids = CONFIG_MTDIDS_DEFAULT; +#endif + + if (mtdids) + env_set("mtdids", mtdids); + + return mtdids; +}
/** * mtd_search_alternate_name - Search an alternate name for @mtdname thanks to @@ -34,7 +57,7 @@ int mtd_search_alternate_name(const char *mtdname, char *altname, const char *mtdids, *equal, *comma, *dev_id, *mtd_id; int dev_id_len, mtd_id_len;
- mtdids = env_get("mtdids"); + mtdids = get_mtdids(); if (!mtdids) return -EINVAL;
@@ -92,30 +115,6 @@ static void mtd_probe_uclass_mtd_devs(void) { } #endif
#if defined(CONFIG_MTD_PARTITIONS) -extern void board_mtdparts_default(const char **mtdids, - const char **mtdparts); - -static const char *get_mtdids(void) -{ - __maybe_unused const char *mtdparts = NULL; - const char *mtdids = env_get("mtdids"); - - if (mtdids) - return mtdids; - -#if defined(CONFIG_SYS_MTDPARTS_RUNTIME) - board_mtdparts_default(&mtdids, &mtdparts); -#elif defined(MTDIDS_DEFAULT) - mtdids = MTDIDS_DEFAULT; -#elif defined(CONFIG_MTDIDS_DEFAULT) - mtdids = CONFIG_MTDIDS_DEFAULT; -#endif - - if (mtdids) - env_set("mtdids", mtdids); - - return mtdids; -}
#define MTDPARTS_MAXLEN 512
strstr() does not guarantee that the string we're searching for is placed at the beginning. Use strncmp() instead.
Changes in v2: - New patch --- drivers/mtd/mtd_uboot.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/mtd_uboot.c b/drivers/mtd/mtd_uboot.c index c4434d70520d..d551aee20203 100644 --- a/drivers/mtd/mtd_uboot.c +++ b/drivers/mtd/mtd_uboot.c @@ -215,7 +215,7 @@ int mtd_probe_devices(void) return 0;
/* Start the parsing by ignoring the extra 'mtdparts=' prefix, if any */ - if (strstr(mtdparts, "mtdparts=")) + if (!strncmp(mtdparts, "mtdparts=", sizeof("mtdparts=") - 1)) mtdparts += 9;
/* For each MTD device in mtdparts */
The local mtd_name[] variable is limited in size. Return an error if the name passed in mtdparts does not fit in this local var.
Changes in v2: - New patch --- drivers/mtd/mtd_uboot.c | 11 ++++++++--- 1 file changed, 8 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/mtd_uboot.c b/drivers/mtd/mtd_uboot.c index d551aee20203..0eda36278309 100644 --- a/drivers/mtd/mtd_uboot.c +++ b/drivers/mtd/mtd_uboot.c @@ -222,8 +222,8 @@ int mtd_probe_devices(void) while (mtdparts[0] != '\0') { char mtd_name[MTD_NAME_MAX_LEN], *colon; struct mtd_partition *parts; - int mtd_name_len, nparts; - int ret; + unsigned int mtd_name_len; + int nparts, ret;
colon = strchr(mtdparts, ':'); if (!colon) { @@ -231,7 +231,12 @@ int mtd_probe_devices(void) return -EINVAL; }
- mtd_name_len = colon - mtdparts; + mtd_name_len = (unsigned int)(colon - mtdparts); + if (mtd_name_len + 1 > sizeof(mtd_name)) { + printf("MTD name too long: %s\n", mtdparts); + return -EINVAL; + } + strncpy(mtd_name, mtdparts, mtd_name_len); mtd_name[mtd_name_len] = '\0'; /* Move the pointer forward (including the ':') */
The mtdparts variable might contain partition definitions for several MTD devices. Each partition layout is separated by a ';', so let's make sure we don't pick a wrong name when mtdparts is malformed.
Changes in v2: - New patch --- drivers/mtd/mtd_uboot.c | 17 ++++++++++++----- 1 file changed, 12 insertions(+), 5 deletions(-)
diff --git a/drivers/mtd/mtd_uboot.c b/drivers/mtd/mtd_uboot.c index 0eda36278309..6a36948b917b 100644 --- a/drivers/mtd/mtd_uboot.c +++ b/drivers/mtd/mtd_uboot.c @@ -155,6 +155,7 @@ int mtd_probe_devices(void) static char *old_mtdids; const char *mtdparts = get_mtdparts(); const char *mtdids = get_mtdids(); + const char *mtdparts_next = mtdparts; bool remaining_partitions = true; struct mtd_info *mtd;
@@ -219,13 +220,22 @@ int mtd_probe_devices(void) mtdparts += 9;
/* For each MTD device in mtdparts */ - while (mtdparts[0] != '\0') { + for (; mtdparts[0] != '\0'; mtdparts = mtdparts_next) { char mtd_name[MTD_NAME_MAX_LEN], *colon; struct mtd_partition *parts; unsigned int mtd_name_len; int nparts, ret;
+ mtdparts_next = strchr(mtdparts, ';'); + if (!mtdparts_next) + mtdparts_next = mtdparts + strlen(mtdparts); + else + mtdparts_next++; + colon = strchr(mtdparts, ':'); + if (colon > mtdparts_next) + colon = NULL; + if (!colon) { printf("Wrong mtdparts: %s\n", mtdparts); return -EINVAL; @@ -263,10 +273,7 @@ int mtd_probe_devices(void) if (ret || IS_ERR_OR_NULL(mtd)) { printf("Could not find a valid device for %s\n", mtd_name); - mtdparts = strchr(mtdparts, ';'); - if (mtdparts) - mtdparts++; - + mtdparts = mtdparts_next; continue; } }
MTD partition creation code is a bit tricky. It tries to figure out when things have changed (either MTD dev list or mtdparts/mtdids vars) and when that happens it first deletes all the partitions that had been previously created and then creates the new ones based on the new mtdparts/mtdids values. But before deleting the old partitions, it ensures that none of the currently registered parts are being used and bails out when that's not the case. So, we end up in a situation where, if at least one MTD dev has one of its partitions used by someone (UBI for instance), the partitions update logic no longer works for other devs.
Rework the code to relax the logic and allow updates of MTD parts on devices that are not being used (we still refuse to updates parts on devices who have at least one of their partitions used by someone).
Changes in v3: - Re-create partitions when our last attempt do delete all existing parts failed. This way we can update parts after ubi detach has been called without having to change mtdparts/mtdids. --- drivers/mtd/mtd_uboot.c | 96 +++++++++++++++++++++++++++++------------ drivers/mtd/mtdpart.c | 12 ++++++ include/linux/mtd/mtd.h | 2 + 3 files changed, 82 insertions(+), 28 deletions(-)
diff --git a/drivers/mtd/mtd_uboot.c b/drivers/mtd/mtd_uboot.c index 6a36948b917b..d638f700d041 100644 --- a/drivers/mtd/mtd_uboot.c +++ b/drivers/mtd/mtd_uboot.c @@ -149,6 +149,54 @@ static const char *get_mtdparts(void) return mtdparts; }
+static int mtd_del_parts(struct mtd_info *mtd, bool quiet) +{ + int ret; + + if (!mtd_has_partitions(mtd)) + return 0; + + /* do not delete partitions if they are in use. */ + if (mtd_partitions_used(mtd)) { + if (!quiet) + printf(""%s" partitions still in use, can't delete them\n", + mtd->name); + return -EACCES; + } + + ret = del_mtd_partitions(mtd); + if (ret) + return ret; + + return 1; +} + +static bool mtd_del_all_parts_failed; + +static void mtd_del_all_parts(void) +{ + struct mtd_info *mtd; + int ret = 0; + + mtd_del_all_parts_failed = false; + + /* + * It is not safe to remove entries from the mtd_for_each_device loop + * as it uses idr indexes and the partitions removal is done in bulk + * (all partitions of one device at the same time), so break and + * iterate from start each time a new partition is found and deleted. + */ + do { + mtd_for_each_device(mtd) { + ret = mtd_del_parts(mtd, false); + if (ret > 0) + break; + else if (ret < 0) + mtd_del_all_parts_failed = true; + } + } while (ret > 0); +} + int mtd_probe_devices(void) { static char *old_mtdparts; @@ -156,18 +204,19 @@ int mtd_probe_devices(void) const char *mtdparts = get_mtdparts(); const char *mtdids = get_mtdids(); const char *mtdparts_next = mtdparts; - bool remaining_partitions = true; struct mtd_info *mtd;
/* - * Check if mtdparts/mtdids changed or if the MTD dev list was updated - * since last call, otherwise: exit + * Check if mtdparts/mtdids changed, if the MTD dev list was updated + * or if our previous attempt to delete existing partititions failed. + * In any of these cases we want to update the partitions, otherwise, + * everything is up-to-date and we can return 0 directly. */ if ((!mtdparts && !old_mtdparts && !mtdids && !old_mtdids) || (mtdparts && old_mtdparts && mtdids && old_mtdids && - !mtd_dev_list_updated() && + !mtd_dev_list_updated() && !mtd_del_all_parts_failed && !strcmp(mtdparts, old_mtdparts) && !strcmp(mtdids, old_mtdids))) return 0; @@ -178,32 +227,12 @@ int mtd_probe_devices(void) old_mtdparts = strdup(mtdparts); old_mtdids = strdup(mtdids);
- /* If at least one partition is still in use, do not delete anything */ - mtd_for_each_device(mtd) { - if (mtd->usecount) { - printf("Partition "%s" already in use, aborting\n", - mtd->name); - return -EACCES; - } - } - /* - * Everything looks clear, remove all partitions. It is not safe to - * remove entries from the mtd_for_each_device loop as it uses idr - * indexes and the partitions removal is done in bulk (all partitions of - * one device at the same time), so break and iterate from start each - * time a new partition is found and deleted. + * Remove all old parts. Note that partition removal can fail in case + * one of the partition is still being used by an MTD user, so this + * does not guarantee that all old partitions are gone. */ - while (remaining_partitions) { - remaining_partitions = false; - mtd_for_each_device(mtd) { - if (!mtd_is_partition(mtd) && mtd_has_partitions(mtd)) { - del_mtd_partitions(mtd); - remaining_partitions = true; - break; - } - } - } + mtd_del_all_parts();
/* * Call mtd_dev_list_updated() to clear updates generated by our own @@ -278,6 +307,17 @@ int mtd_probe_devices(void) } }
+ /* + * Call mtd_del_parts() again, even if it's already been called + * in mtd_del_all_parts(). We need to know if old partitions are + * still around (because they are still being used by someone), + * and if they are, we shouldn't create new partitions, so just + * skip this MTD device and try the next one. + */ + ret = mtd_del_parts(mtd, true); + if (ret < 0) + continue; + /* * Parse the MTD device partitions. It will update the mtdparts * pointer, create an array of parts (that must be freed), and diff --git a/drivers/mtd/mtdpart.c b/drivers/mtd/mtdpart.c index 4d2ac8107f01..fd8d8e5ea729 100644 --- a/drivers/mtd/mtdpart.c +++ b/drivers/mtd/mtdpart.c @@ -63,6 +63,18 @@ char *kstrdup(const char *s, gfp_t gfp) #define MTD_SIZE_REMAINING (~0LLU) #define MTD_OFFSET_NOT_SPECIFIED (~0LLU)
+bool mtd_partitions_used(struct mtd_info *master) +{ + struct mtd_info *slave; + + list_for_each_entry(slave, &master->partitions, node) { + if (slave->usecount) + return true; + } + + return false; +} + /** * mtd_parse_partition - Parse @mtdparts partition definition, fill @partition * with it and update the @mtdparts string pointer. diff --git a/include/linux/mtd/mtd.h b/include/linux/mtd/mtd.h index 4d0096d9f1d8..cd1f557a2f31 100644 --- a/include/linux/mtd/mtd.h +++ b/include/linux/mtd/mtd.h @@ -366,6 +366,8 @@ static inline bool mtd_has_partitions(const struct mtd_info *mtd) return !list_empty(&mtd->partitions); }
+bool mtd_partitions_used(struct mtd_info *master); + int mtd_ooblayout_ecc(struct mtd_info *mtd, int section, struct mtd_oob_region *oobecc); int mtd_ooblayout_find_eccregion(struct mtd_info *mtd, int eccbyte,
The DM implementation of spi_flash_free() does not unregister the MTD device before removing the spi dev object. This leads to a use-after-free bug when the MTD device is later accessed by a MTD user (observed when attaching the device to UBI after env_sf_load() has called spi_flash_free()).
Implement ->remove() and call spi_flash_mtd_unregister() from there.
Changes in v3: - New patch --- drivers/mtd/spi/sf_probe.c | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/drivers/mtd/spi/sf_probe.c b/drivers/mtd/spi/sf_probe.c index 5a2e932de8f8..00f8558e7019 100644 --- a/drivers/mtd/spi/sf_probe.c +++ b/drivers/mtd/spi/sf_probe.c @@ -144,6 +144,14 @@ static int spi_flash_std_probe(struct udevice *dev) return spi_flash_probe_slave(flash); }
+static int spi_flash_std_remove(struct udevice *dev) +{ +#ifdef CONFIG_SPI_FLASH_MTD + spi_flash_mtd_unregister(); +#endif + return 0; +} + static const struct dm_spi_flash_ops spi_flash_std_ops = { .read = spi_flash_std_read, .write = spi_flash_std_write, @@ -161,6 +169,7 @@ U_BOOT_DRIVER(spi_flash_std) = { .id = UCLASS_SPI_FLASH, .of_match = spi_flash_std_ids, .probe = spi_flash_std_probe, + .remove = spi_flash_std_remove, .priv_auto_alloc_size = sizeof(struct spi_flash), .ops = &spi_flash_std_ops, };
SPI flash based MTD devs can be registered/unregistered at any time through the sf probe command or the spi_flash_free() function.
This commit does not try to fix the root cause as it would probably require rewriting most of the code and have an mtd_info object instance per spi_flash object (not to mention that the the spi-flash layer is likely to be replaced by a spi-nor layer ported from Linux).
Instead, we try to be as safe as can be by checking the code returned by del_mtd_device() and complain loudly when there's nothing we can do about the deregistration failure. When that happens we also reset sf_mtd_info.priv to NULL, and check for NULL pointer in the mtd hooks so that -ENODEV is returned instead of hitting a NULL pointer dereference exception when the MTD instance is later accessed by a user.
Signed-off-by: Boris Brezillon boris.brezillon@bootlin.com Tested-by: Heiko Schocher hs@denx.de --- Changes in v4: - Add T-b tags
Changes in v3: - New patch --- drivers/mtd/spi/sf_mtd.c | 39 ++++++++++++++++++++++++++++++++++++--- 1 file changed, 36 insertions(+), 3 deletions(-)
diff --git a/drivers/mtd/spi/sf_mtd.c b/drivers/mtd/spi/sf_mtd.c index aabbc3589435..68c36002bee2 100644 --- a/drivers/mtd/spi/sf_mtd.c +++ b/drivers/mtd/spi/sf_mtd.c @@ -18,6 +18,9 @@ static int spi_flash_mtd_erase(struct mtd_info *mtd, struct erase_info *instr) struct spi_flash *flash = mtd->priv; int err;
+ if (!flash) + return -ENODEV; + instr->state = MTD_ERASING;
err = spi_flash_erase(flash, instr->addr, instr->len); @@ -39,6 +42,9 @@ static int spi_flash_mtd_read(struct mtd_info *mtd, loff_t from, size_t len, struct spi_flash *flash = mtd->priv; int err;
+ if (!flash) + return -ENODEV; + err = spi_flash_read(flash, from, len, buf); if (!err) *retlen = len; @@ -52,6 +58,9 @@ static int spi_flash_mtd_write(struct mtd_info *mtd, loff_t to, size_t len, struct spi_flash *flash = mtd->priv; int err;
+ if (!flash) + return -ENODEV; + err = spi_flash_write(flash, to, len, buf); if (!err) *retlen = len; @@ -76,8 +85,13 @@ int spi_flash_mtd_register(struct spi_flash *flash) { int ret;
- if (sf_mtd_registered) - del_mtd_device(&sf_mtd_info); + if (sf_mtd_registered) { + ret = del_mtd_device(&sf_mtd_info); + if (ret) + return ret; + + sf_mtd_registered = false; + }
sf_mtd_registered = false; memset(&sf_mtd_info, 0, sizeof(sf_mtd_info)); @@ -110,5 +124,24 @@ int spi_flash_mtd_register(struct spi_flash *flash)
void spi_flash_mtd_unregister(void) { - del_mtd_device(&sf_mtd_info); + int ret; + + if (!sf_mtd_registered) + return; + + ret = del_mtd_device(&sf_mtd_info); + if (!ret) { + sf_mtd_registered = false; + return; + } + + /* + * Setting mtd->priv to NULL is the best we can do. Thanks to that, + * the MTD layer can still call mtd hooks without risking a + * use-after-free bug. Still, things should be fixed to prevent the + * spi_flash object from being destroyed when del_mtd_device() fails. + */ + sf_mtd_info.priv = NULL; + printf("Failed to unregister MTD %s and the spi_flash object is going away: you're in deep trouble!", + sf_mtd_info.name); }
Hi Jagan,
On Sun, 2 Dec 2018 10:54:21 +0100 Boris Brezillon boris.brezillon@bootlin.com wrote:
Hello,
Regards,
Boris
Please don't wait too long before queuing this series and sending a fixes PR to Tom. I don't want to end up in the same situation we were for 2018.11.
Thanks,
Boris
On Sun, Dec 2, 2018 at 3:25 PM Boris Brezillon boris.brezillon@bootlin.com wrote:
Hello,
Regards,
Boris
Applied to u-boot-spi/master
+Tom for the question about missing SoBs.
Hi Jagan,
On Thu, 6 Dec 2018 00:48:47 +0530 Jagan Teki jagan@amarulasolutions.com wrote:
Hello,
Regards,
Boris
I see that those patches have been merged in mainline, which is great. Just have one question: looks like your SoB is missing while you're clearly reported as the committer. Since I found the same problem on 2614a208471e ("common: command: tempory buffer should have size of command line buf"), I wanted to know if this is a common practice in u-boot to not add SoBs when maintainers apply patches to their tree?
Regards,
Boris
Hi Jagan,
Hello,
Regards,
Boris
So yes (and I should put this into that wiki sections where we do differ from Linux), if you as a custodian aren't making changes to a patch when applying it then no, you don't add your own SoB line.
Boris Brezillon
Jagan Teki
Lukasz Majewski
