[U-Boot] [PATCH] [v3] powerpc: clean up DIU macro definitions for the MPC8610HPCD and MPC5121ADS
Clean up the macro defintions used to enable DIU (video) support on the MPC8610HPCD and the MPC5121ADS so that they look more like the P1022DS, which is newer.
Signed-off-by: Timur Tabi timur@freescale.com --- doc/README.mpc5121ads | 18 ++++++++++++++++++ doc/README.mpc8610hpcd | 7 +++++++ include/configs/MPC8610HPCD.h | 12 +++--------- include/configs/mpc5121ads.h | 8 +++----- 4 files changed, 31 insertions(+), 14 deletions(-) create mode 100644 doc/README.mpc5121ads
diff --git a/doc/README.mpc5121ads b/doc/README.mpc5121ads new file mode 100644 index 0000000..78fc3c9 --- /dev/null +++ b/doc/README.mpc5121ads @@ -0,0 +1,18 @@ +Freescale MPC5121ADS board +=========================== + + +Building U-Boot +--------------- + + $ make mpc5121ads_config + Configuring for mpc5121ads board... + + $ make + + +Video Support +------------- +To enable DIU video support (console on a video display), define the macro +CONFIG_FSL_DIU_FB in the board header file (mpc5121ads.h) and set the +'monitor' environment variable appropriately. diff --git a/doc/README.mpc8610hpcd b/doc/README.mpc8610hpcd index 31a9af3..8f878c4 100644 --- a/doc/README.mpc8610hpcd +++ b/doc/README.mpc8610hpcd @@ -71,3 +71,10 @@ DIP Switch Settings ------------------- To manually switch the flash banks using the DIP switch settings, toggle both SW6:1 and SW6:2. + + +Video Support +------------- +To enable DIU video support (console on a video display), define the macro +CONFIG_FSL_DIU_FB in the board header file (MPC8610HPCD.h) and set the +'monitor' environment variable appropriately. diff --git a/include/configs/MPC8610HPCD.h b/include/configs/MPC8610HPCD.h index 03ee394..1e321f4 100644 --- a/include/configs/MPC8610HPCD.h +++ b/include/configs/MPC8610HPCD.h @@ -21,12 +21,11 @@
#define CONFIG_SYS_TEXT_BASE 0xfff00000
-#define CONFIG_FSL_DIU_FB 1 /* FSL DIU */
/* video */ -#undef CONFIG_VIDEO - -#ifdef CONFIG_VIDEO +#ifdef CONFIG_FSL_DIU_FB +#define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR + 0x2c000) +#define CONFIG_VIDEO #define CONFIG_CMD_BMP #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE @@ -88,8 +87,6 @@ #define CONFIG_SYS_CCSRBAR_PHYS_HIGH 0x0 #define CONFIG_SYS_CCSRBAR_PHYS CONFIG_SYS_CCSRBAR_PHYS_LOW
-#define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_CCSRBAR+0x2c000) - /* DDR Setup */ #define CONFIG_FSL_DDR2 #undef CONFIG_FSL_DDR_INTERACTIVE @@ -494,9 +491,6 @@ #define CONFIG_WATCHDOG /* watchdog enabled */ #define CONFIG_SYS_WATCHDOG_FREQ 5000 /* Feed interval, 5s */
-/*DIU Configuration*/ -#define DIU_CONNECT_TO_DVI /* DIU controller connects to DVI encoder*/ - /* * Miscellaneous configurable options */ diff --git a/include/configs/mpc5121ads.h b/include/configs/mpc5121ads.h index f966325..33a5b86 100644 --- a/include/configs/mpc5121ads.h +++ b/include/configs/mpc5121ads.h @@ -46,14 +46,13 @@ */ #define CONFIG_E300 1 /* E300 Family */ #define CONFIG_MPC512X 1 /* MPC512X family */ -#define CONFIG_FSL_DIU_FB 1 /* FSL DIU */
#define CONFIG_SYS_TEXT_BASE 0xFFF00000
/* video */ -#undef CONFIG_VIDEO - -#ifdef CONFIG_VIDEO +#ifdef CONFIG_FSL_DIU_FB +#define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_IMMR + 0x2100) +#define CONFIG_VIDEO #define CONFIG_CMD_BMP #define CONFIG_CFB_CONSOLE #define CONFIG_VGA_AS_SINGLE_DEVICE @@ -74,7 +73,6 @@ #define CONFIG_MISC_INIT_R
#define CONFIG_SYS_IMMR 0x80000000 -#define CONFIG_SYS_DIU_ADDR (CONFIG_SYS_IMMR+0x2100)
#define CONFIG_SYS_MEMTEST_START 0x00200000 /* memtest region */ #define CONFIG_SYS_MEMTEST_END 0x00400000
Dear Timur Tabi,
- $ make mpc5121ads_config
- Configuring for mpc5121ads board...
- $ make
Thanks - well meant, but wrong.
It makes little sense to add a README.board file which contains only commonplace like how to configure and build.
And CONFIG_* options must be explained in the top level README, not in some board files, and especially not repeatedly in all that might be affected. Such redundancy is always a Bad Thing.
Please drop these README.board files and move the documentation for CONFIG_FSL_DIU_FB into README.
Timur Tabi
