[U-Boot] [PATCH v6] Add support for the DevKit8000 board
This patch adds support for the DevKit8000 board.
Signed-off-by: Frederik Kriewitz frederik@kriewitz.eu --- mach-types.h needs to be synced (MACH_TYPE_DEVKIT8000)
Changelog: v6: added changelog
v5: moved files from board/timll/devkit8000 to board/devkit8000 added omap3_ config file prefix renamed README.timll to README.devkit8000
v4: moved files from board/omap3/devkit8000 to board/timll/devkit8000 (vendor dir) renamed README.devkit8000 to README.timll fixed LIST_ARM_CORTEX_A8 order (MAKEALL) fixed MAINTAINERS ordered comment style changes fixed potential alignment issue (enetaddr assignment)
v3 moved files from board/omap3/devkit8000 to board/devkit8000 removed omap3_ config file prefix moved doc from README.omap3 to README.devkit8000 added MAKEALL entry added warning in case a Die ID based MAC is used removed reset_phy() (Ethernet is only initiated if it's needed) moved CONFIG_SYS_NO_FLASH up (before #include <config_cmd_default.h>) command list cleanup minor define cleanups moved some common kernel args to commonargs variable
v2: added MAINTAINERS entry code style fixes copyright added removed mach-types.h patch command list reordered boot command was moved to own variable (autoboot) fixed memtest config removed useless NOR flash settings
MAINTAINERS | 4 + MAKEALL | 1 + Makefile | 3 + board/devkit8000/Makefile | 52 +++++ board/devkit8000/config.mk | 35 ++++ board/devkit8000/devkit8000.c | 131 +++++++++++++ board/devkit8000/devkit8000.h | 373 ++++++++++++++++++++++++++++++++++++ doc/README.devkit8000 | 15 ++ include/configs/devkit8000.h | 307 +++++++++++++++++++++++++++++ include/configs/omap3_devkit8000.h | 307 +++++++++++++++++++++++++++++ 10 files changed, 1228 insertions(+), 0 deletions(-) create mode 100644 board/devkit8000/Makefile create mode 100644 board/devkit8000/config.mk create mode 100644 board/devkit8000/devkit8000.c create mode 100644 board/devkit8000/devkit8000.h create mode 100644 doc/README.devkit8000 create mode 100644 include/configs/devkit8000.h create mode 100644 include/configs/omap3_devkit8000.h
diff --git a/MAINTAINERS b/MAINTAINERS index 620604c..1919505 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -587,6 +587,10 @@ Nishant Kamat nskamat@ti.com
omap1610h2 ARM926EJS
+Frederik Kriewitz frederik@kriewitz.eu + + omap3_devkit8000 ARM CORTEX-A8 (OMAP3530 SoC) + Sergey Kubushyn ksi@koi8.net
DV-EVM ARM926EJS diff --git a/MAKEALL b/MAKEALL index edebaea..ac46ddc 100755 --- a/MAKEALL +++ b/MAKEALL @@ -576,6 +576,7 @@ LIST_ARM11=" \ ######################################################################### LIST_ARM_CORTEX_A8=" \ omap3_beagle \ + omap3_devkit8000 \ omap3_overo \ omap3_evm \ omap3_pandora \ diff --git a/Makefile b/Makefile index 96cca23..a671bfc 100644 --- a/Makefile +++ b/Makefile @@ -3089,6 +3089,9 @@ SMN42_config : unconfig omap3_beagle_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm_cortexa8 beagle omap3 omap3
+omap3_devkit8000_config : unconfig + @$(MKCONFIG) $(@:_config=) arm arm_cortexa8 devkit8000 NULL omap3 + omap3_overo_config : unconfig @$(MKCONFIG) $(@:_config=) arm arm_cortexa8 overo omap3 omap3
diff --git a/board/devkit8000/Makefile b/board/devkit8000/Makefile new file mode 100644 index 0000000..38600c4 --- /dev/null +++ b/board/devkit8000/Makefile @@ -0,0 +1,52 @@ +# +# (C) Copyright 2000, 2001, 2002 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2009 +# Frederik Kriewitz frederik@kriewitz.eu +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := devkit8000.o + +SRCS := $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) + +$(LIB): $(obj).depend $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +clean: + rm -f $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak $(obj).depend + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/devkit8000/config.mk b/board/devkit8000/config.mk new file mode 100644 index 0000000..6bfcef7 --- /dev/null +++ b/board/devkit8000/config.mk @@ -0,0 +1,35 @@ +# +# (C) Copyright 2006 +# Texas Instruments, <www.ti.com> +# +# (C) Copyright 2009 +# Frederik Kriewitz frederik@kriewitz.eu +# +# DevKit8000 uses OMAP3 (ARM-CortexA8) cpu +# see http://www.ti.com/ for more information on Texas Instruments +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# +# Physical Address: +# 8000'0000 (bank0) +# Linux-Kernel is expected to be at 8000'8000, entry 8000'8000 +# (mem base + reserved) + +# For use with external or internal boots. +TEXT_BASE = 0x80e80000 diff --git a/board/devkit8000/devkit8000.c b/board/devkit8000/devkit8000.c new file mode 100644 index 0000000..db7d2e2 --- /dev/null +++ b/board/devkit8000/devkit8000.c @@ -0,0 +1,131 @@ +/* + * (C) Copyright 2004-2008 + * Texas Instruments, <www.ti.com> + * + * Author : + * Sunil Kumar sunilsaini05@gmail.com + * Shashi Ranjan shashiranjanmca05@gmail.com + * + * (C) Copyright 2009 + * Frederik Kriewitz frederik@kriewitz.eu + * + * Derived from Beagle Board and 3430 SDP code by + * Richard Woodruff r-woodruff2@ti.com + * Syed Mohammed Khasim khasim@ti.com + * + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#include <common.h> +#include <twl4030.h> +#include <asm/io.h> +#include <asm/arch/mux.h> +#include <asm/arch/sys_proto.h> +#include <asm/arch/mem.h> +#include <asm/mach-types.h> +#include "devkit8000.h" +#ifdef CONFIG_DRIVER_DM9000 +#include <net.h> +#include <netdev.h> +#endif + +DECLARE_GLOBAL_DATA_PTR; + +/* + * Routine: board_init + * Description: Early hardware init. + */ +int board_init(void) +{ + gpmc_init(); /* in SRAM or SDRAM, finish GPMC */ + /* board id for Linux */ + gd->bd->bi_arch_number = MACH_TYPE_DEVKIT8000; + /* boot param addr */ + gd->bd->bi_boot_params = (OMAP34XX_SDRC_CS0 + 0x100); + + return 0; +} + +/* + * Routine: misc_init_r + * Description: Configure board specific parts + */ +int misc_init_r(void) +{ + struct ctrl_id *id_base = (struct ctrl_id *)OMAP34XX_ID_L4_IO_BASE; +#ifdef CONFIG_DRIVER_DM9000 + uchar enetaddr[6]; + u32 die_id_0; +#endif + + twl4030_power_init(); +#ifdef CONFIG_TWL4030_LED + twl4030_led_init(); +#endif + +#ifdef CONFIG_DRIVER_DM9000 + /* Configure GPMC registers for DM9000 */ + writel(NET_GPMC_CONFIG1, &gpmc_cfg->cs[6].config1); + writel(NET_GPMC_CONFIG2, &gpmc_cfg->cs[6].config2); + writel(NET_GPMC_CONFIG3, &gpmc_cfg->cs[6].config3); + writel(NET_GPMC_CONFIG4, &gpmc_cfg->cs[6].config4); + writel(NET_GPMC_CONFIG5, &gpmc_cfg->cs[6].config5); + writel(NET_GPMC_CONFIG6, &gpmc_cfg->cs[6].config6); + writel(NET_GPMC_CONFIG7, &gpmc_cfg->cs[6].config7); + + /* Use OMAP DIE_ID as MAC address */ + if (!eth_getenv_enetaddr("ethaddr", enetaddr)) { + printf("ethaddr not set, using Die ID\n"); + die_id_0 = readl(&id_base->die_id_0); + enetaddr[0] = 0x02; /* locally administered */ + enetaddr[1] = readl(&id_base->die_id_1) & 0xff; + enetaddr[2] = (die_id_0 & 0xff000000) >> 24; + enetaddr[3] = (die_id_0 & 0x00ff0000) >> 16; + enetaddr[4] = (die_id_0 & 0x0000ff00) >> 8; + enetaddr[5] = (die_id_0 & 0x000000ff); + eth_setenv_enetaddr("ethaddr", enetaddr); + } +#endif + + dieid_num_r(); + + return 0; +} + +/* + * Routine: set_muxconf_regs + * Description: Setting up the configuration Mux registers specific to the + * hardware. Many pins need to be moved from protect to primary + * mode. + */ +void set_muxconf_regs(void) +{ + MUX_DEVKIT8000(); +} + +#ifdef CONFIG_DRIVER_DM9000 +/* + * Routine: board_eth_init + * Description: Setting up the Ethernet hardware. + */ +int board_eth_init(bd_t *bis) +{ + return dm9000_initialize(bis); +} +#endif diff --git a/board/devkit8000/devkit8000.h b/board/devkit8000/devkit8000.h new file mode 100644 index 0000000..6fcc75a --- /dev/null +++ b/board/devkit8000/devkit8000.h @@ -0,0 +1,373 @@ +/* + * (C) Copyright 2008 + * Dirk Behme dirk.behme@gmail.com + * + * (C) Copyright 2009 + * Frederik Kriewitz frederik@kriewitz.eu + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ +#ifndef _DEVKIT8000_H_ +#define _DEVKIT8000_H_ + +const omap3_sysinfo sysinfo = { + DDR_STACKED, + "OMAP3 DevKit8000", + "NAND", +}; + +/* + * IEN - Input Enable + * IDIS - Input Disable + * PTD - Pull type Down + * PTU - Pull type Up + * DIS - Pull type selection is inactive + * EN - Pull type selection is active + * M0 - Mode 0 + * The commented string gives the final mux configuration for that pin + */ + +#define MUX_DEVKIT8000() \ + /* SDRC */\ + MUX_VAL(CP(SDRC_D0), (IEN | PTD | DIS | M0)) /*SDRC_D0*/\ + MUX_VAL(CP(SDRC_D1), (IEN | PTD | DIS | M0)) /*SDRC_D1*/\ + MUX_VAL(CP(SDRC_D2), (IEN | PTD | DIS | M0)) /*SDRC_D2*/\ + MUX_VAL(CP(SDRC_D3), (IEN | PTD | DIS | M0)) /*SDRC_D3*/\ + MUX_VAL(CP(SDRC_D4), (IEN | PTD | DIS | M0)) /*SDRC_D4*/\ + MUX_VAL(CP(SDRC_D5), (IEN | PTD | DIS | M0)) /*SDRC_D5*/\ + MUX_VAL(CP(SDRC_D6), (IEN | PTD | DIS | M0)) /*SDRC_D6*/\ + MUX_VAL(CP(SDRC_D7), (IEN | PTD | DIS | M0)) /*SDRC_D7*/\ + MUX_VAL(CP(SDRC_D8), (IEN | PTD | DIS | M0)) /*SDRC_D8*/\ + MUX_VAL(CP(SDRC_D9), (IEN | PTD | DIS | M0)) /*SDRC_D9*/\ + MUX_VAL(CP(SDRC_D10), (IEN | PTD | DIS | M0)) /*SDRC_D10*/\ + MUX_VAL(CP(SDRC_D11), (IEN | PTD | DIS | M0)) /*SDRC_D11*/\ + MUX_VAL(CP(SDRC_D12), (IEN | PTD | DIS | M0)) /*SDRC_D12*/\ + MUX_VAL(CP(SDRC_D13), (IEN | PTD | DIS | M0)) /*SDRC_D13*/\ + MUX_VAL(CP(SDRC_D14), (IEN | PTD | DIS | M0)) /*SDRC_D14*/\ + MUX_VAL(CP(SDRC_D15), (IEN | PTD | DIS | M0)) /*SDRC_D15*/\ + MUX_VAL(CP(SDRC_D16), (IEN | PTD | DIS | M0)) /*SDRC_D16*/\ + MUX_VAL(CP(SDRC_D17), (IEN | PTD | DIS | M0)) /*SDRC_D17*/\ + MUX_VAL(CP(SDRC_D18), (IEN | PTD | DIS | M0)) /*SDRC_D18*/\ + MUX_VAL(CP(SDRC_D19), (IEN | PTD | DIS | M0)) /*SDRC_D19*/\ + MUX_VAL(CP(SDRC_D20), (IEN | PTD | DIS | M0)) /*SDRC_D20*/\ + MUX_VAL(CP(SDRC_D21), (IEN | PTD | DIS | M0)) /*SDRC_D21*/\ + MUX_VAL(CP(SDRC_D22), (IEN | PTD | DIS | M0)) /*SDRC_D22*/\ + MUX_VAL(CP(SDRC_D23), (IEN | PTD | DIS | M0)) /*SDRC_D23*/\ + MUX_VAL(CP(SDRC_D24), (IEN | PTD | DIS | M0)) /*SDRC_D24*/\ + MUX_VAL(CP(SDRC_D25), (IEN | PTD | DIS | M0)) /*SDRC_D25*/\ + MUX_VAL(CP(SDRC_D26), (IEN | PTD | DIS | M0)) /*SDRC_D26*/\ + MUX_VAL(CP(SDRC_D27), (IEN | PTD | DIS | M0)) /*SDRC_D27*/\ + MUX_VAL(CP(SDRC_D28), (IEN | PTD | DIS | M0)) /*SDRC_D28*/\ + MUX_VAL(CP(SDRC_D29), (IEN | PTD | DIS | M0)) /*SDRC_D29*/\ + MUX_VAL(CP(SDRC_D30), (IEN | PTD | DIS | M0)) /*SDRC_D30*/\ + MUX_VAL(CP(SDRC_D31), (IEN | PTD | DIS | M0)) /*SDRC_D31*/\ + MUX_VAL(CP(SDRC_CLK), (IEN | PTD | DIS | M0)) /*SDRC_CLK*/\ + MUX_VAL(CP(SDRC_DQS0), (IEN | PTD | DIS | M0)) /*SDRC_DQS0*/\ + MUX_VAL(CP(SDRC_DQS1), (IEN | PTD | DIS | M0)) /*SDRC_DQS1*/\ + MUX_VAL(CP(SDRC_DQS2), (IEN | PTD | DIS | M0)) /*SDRC_DQS2*/\ + MUX_VAL(CP(SDRC_DQS3), (IEN | PTD | DIS | M0)) /*SDRC_DQS3*/\ + /* GPMC */\ + MUX_VAL(CP(GPMC_A1), (IDIS | PTD | DIS | M0)) /*GPMC_A1*/\ + MUX_VAL(CP(GPMC_A2), (IDIS | PTD | DIS | M0)) /*GPMC_A2*/\ + MUX_VAL(CP(GPMC_A3), (IDIS | PTD | DIS | M0)) /*GPMC_A3*/\ + MUX_VAL(CP(GPMC_A4), (IDIS | PTD | DIS | M0)) /*GPMC_A4*/\ + MUX_VAL(CP(GPMC_A5), (IDIS | PTD | DIS | M0)) /*GPMC_A5*/\ + MUX_VAL(CP(GPMC_A6), (IDIS | PTD | DIS | M0)) /*GPMC_A6*/\ + MUX_VAL(CP(GPMC_A7), (IDIS | PTD | DIS | M0)) /*GPMC_A7*/\ + MUX_VAL(CP(GPMC_A8), (IDIS | PTD | DIS | M0)) /*GPMC_A8*/\ + MUX_VAL(CP(GPMC_A9), (IDIS | PTD | DIS | M0)) /*GPMC_A9*/\ + MUX_VAL(CP(GPMC_A10), (IDIS | PTD | DIS | M0)) /*GPMC_A10*/\ + MUX_VAL(CP(GPMC_D0), (IEN | PTD | DIS | M0)) /*GPMC_D0*/\ + MUX_VAL(CP(GPMC_D1), (IEN | PTD | DIS | M0)) /*GPMC_D1*/\ + MUX_VAL(CP(GPMC_D2), (IEN | PTD | DIS | M0)) /*GPMC_D2*/\ + MUX_VAL(CP(GPMC_D3), (IEN | PTD | DIS | M0)) /*GPMC_D3*/\ + MUX_VAL(CP(GPMC_D4), (IEN | PTD | DIS | M0)) /*GPMC_D4*/\ + MUX_VAL(CP(GPMC_D5), (IEN | PTD | DIS | M0)) /*GPMC_D5*/\ + MUX_VAL(CP(GPMC_D6), (IEN | PTD | DIS | M0)) /*GPMC_D6*/\ + MUX_VAL(CP(GPMC_D7), (IEN | PTD | DIS | M0)) /*GPMC_D7*/\ + MUX_VAL(CP(GPMC_D8), (IEN | PTD | DIS | M0)) /*GPMC_D8*/\ + MUX_VAL(CP(GPMC_D9), (IEN | PTD | DIS | M0)) /*GPMC_D9*/\ + MUX_VAL(CP(GPMC_D10), (IEN | PTD | DIS | M0)) /*GPMC_D10*/\ + MUX_VAL(CP(GPMC_D11), (IEN | PTD | DIS | M0)) /*GPMC_D11*/\ + MUX_VAL(CP(GPMC_D12), (IEN | PTD | DIS | M0)) /*GPMC_D12*/\ + MUX_VAL(CP(GPMC_D13), (IEN | PTD | DIS | M0)) /*GPMC_D13*/\ + MUX_VAL(CP(GPMC_D14), (IEN | PTD | DIS | M0)) /*GPMC_D14*/\ + MUX_VAL(CP(GPMC_D15), (IEN | PTD | DIS | M0)) /*GPMC_D15*/\ + MUX_VAL(CP(GPMC_NCS0), (IDIS | PTU | EN | M0)) /*GPMC_nCS0 NAND*/\ + MUX_VAL(CP(GPMC_NCS1), (IDIS | PTU | EN | M0)) /*GPMC_nCS1*/\ + MUX_VAL(CP(GPMC_NCS2), (IDIS | PTU | EN | M0)) /*GPMC_nCS2*/\ + MUX_VAL(CP(GPMC_NCS3), (IDIS | PTU | EN | M0)) /*GPMC_nCS3*/\ + MUX_VAL(CP(GPMC_NCS4), (IDIS | PTU | EN | M0)) /*GPMC_nCS4*/\ + MUX_VAL(CP(GPMC_NCS5), (IDIS | PTU | EN | M0)) /*GPMC_nCS5*/\ + MUX_VAL(CP(GPMC_NCS6), (IDIS | PTU | EN | M0)) /*GPMC_nCS6 DM9000*/\ + MUX_VAL(CP(GPMC_NCS7), (IDIS | PTU | EN | M0)) /*GPMC_nCS7*/\ + MUX_VAL(CP(GPMC_NBE1), (IEN | PTD | DIS | M0)) /*GPMC_nBE1*/\ + MUX_VAL(CP(GPMC_WAIT2), (IEN | PTU | EN | M0)) /*GPMC_WAIT2*/\ + MUX_VAL(CP(GPMC_WAIT3), (IEN | PTU | EN | M0)) /*GPMC_WAIT3*/\ + MUX_VAL(CP(GPMC_CLK), (IDIS | PTD | DIS | M0)) /*GPMC_CLK*/\ + MUX_VAL(CP(GPMC_NADV_ALE), (IDIS | PTD | DIS | M0)) /*GPMC_nADV_ALE*/\ + MUX_VAL(CP(GPMC_NOE), (IDIS | PTD | DIS | M0)) /*GPMC_nOE*/\ + MUX_VAL(CP(GPMC_NWE), (IDIS | PTD | DIS | M0)) /*GPMC_nWE*/\ + MUX_VAL(CP(GPMC_NBE0_CLE), (IDIS | PTD | DIS | M0)) /*GPMC_nBE0_CLE*/\ + MUX_VAL(CP(GPMC_NWP), (IEN | PTD | DIS | M0)) /*GPMC_nWP*/\ + MUX_VAL(CP(GPMC_WAIT0), (IEN | PTU | EN | M0)) /*GPMC_WAIT0*/\ + MUX_VAL(CP(GPMC_WAIT1), (IEN | PTU | EN | M0)) /*GPMC_WAIT1*/\ + /* DSS */\ + MUX_VAL(CP(DSS_PCLK), (IDIS | PTD | DIS | M0)) /*DSS_PCLK*/\ + MUX_VAL(CP(DSS_HSYNC), (IDIS | PTD | DIS | M0)) /*DSS_HSYNC*/\ + MUX_VAL(CP(DSS_VSYNC), (IDIS | PTD | DIS | M0)) /*DSS_VSYNC*/\ + MUX_VAL(CP(DSS_ACBIAS), (IDIS | PTD | DIS | M0)) /*DSS_ACBIAS*/\ + MUX_VAL(CP(DSS_DATA0), (IDIS | PTD | DIS | M0)) /*DSS_DATA0*/\ + MUX_VAL(CP(DSS_DATA1), (IDIS | PTD | DIS | M0)) /*DSS_DATA1*/\ + MUX_VAL(CP(DSS_DATA2), (IDIS | PTD | DIS | M0)) /*DSS_DATA2*/\ + MUX_VAL(CP(DSS_DATA3), (IDIS | PTD | DIS | M0)) /*DSS_DATA3*/\ + MUX_VAL(CP(DSS_DATA4), (IDIS | PTD | DIS | M0)) /*DSS_DATA4*/\ + MUX_VAL(CP(DSS_DATA5), (IDIS | PTD | DIS | M0)) /*DSS_DATA5*/\ + MUX_VAL(CP(DSS_DATA6), (IDIS | PTD | DIS | M0)) /*DSS_DATA6*/\ + MUX_VAL(CP(DSS_DATA7), (IDIS | PTD | DIS | M0)) /*DSS_DATA7*/\ + MUX_VAL(CP(DSS_DATA8), (IDIS | PTD | DIS | M0)) /*DSS_DATA8*/\ + MUX_VAL(CP(DSS_DATA9), (IDIS | PTD | DIS | M0)) /*DSS_DATA9*/\ + MUX_VAL(CP(DSS_DATA10), (IDIS | PTD | DIS | M0)) /*DSS_DATA10*/\ + MUX_VAL(CP(DSS_DATA11), (IDIS | PTD | DIS | M0)) /*DSS_DATA11*/\ + MUX_VAL(CP(DSS_DATA12), (IDIS | PTD | DIS | M0)) /*DSS_DATA12*/\ + MUX_VAL(CP(DSS_DATA13), (IDIS | PTD | DIS | M0)) /*DSS_DATA13*/\ + MUX_VAL(CP(DSS_DATA14), (IDIS | PTD | DIS | M0)) /*DSS_DATA14*/\ + MUX_VAL(CP(DSS_DATA15), (IDIS | PTD | DIS | M0)) /*DSS_DATA15*/\ + MUX_VAL(CP(DSS_DATA16), (IDIS | PTD | DIS | M0)) /*DSS_DATA16*/\ + MUX_VAL(CP(DSS_DATA17), (IDIS | PTD | DIS | M0)) /*DSS_DATA17*/\ + MUX_VAL(CP(DSS_DATA18), (IDIS | PTD | DIS | M0)) /*DSS_DATA18*/\ + MUX_VAL(CP(DSS_DATA19), (IDIS | PTD | DIS | M0)) /*DSS_DATA19*/\ + MUX_VAL(CP(DSS_DATA20), (IDIS | PTD | DIS | M0)) /*DSS_DATA20*/\ + MUX_VAL(CP(DSS_DATA21), (IDIS | PTD | DIS | M0)) /*DSS_DATA21*/\ + MUX_VAL(CP(DSS_DATA22), (IDIS | PTD | DIS | M0)) /*DSS_DATA22*/\ + MUX_VAL(CP(DSS_DATA23), (IDIS | PTD | DIS | M0)) /*DSS_DATA23*/\ + /* CAMERA */\ + MUX_VAL(CP(CAM_HS), (IEN | PTU | EN | M0)) /*CAM_HS */\ + MUX_VAL(CP(CAM_VS), (IEN | PTU | EN | M0)) /*CAM_VS */\ + MUX_VAL(CP(CAM_XCLKA), (IDIS | PTD | DIS | M0)) /*CAM_XCLKA*/\ + MUX_VAL(CP(CAM_PCLK), (IEN | PTU | EN | M0)) /*CAM_PCLK*/\ + MUX_VAL(CP(CAM_FLD), (IDIS | PTD | DIS | M4)) /*GPIO_98*/\ + MUX_VAL(CP(CAM_D0), (IEN | PTD | DIS | M0)) /*CAM_D0*/\ + MUX_VAL(CP(CAM_D1), (IEN | PTD | DIS | M0)) /*CAM_D1*/\ + MUX_VAL(CP(CAM_D2), (IEN | PTD | DIS | M0)) /*CAM_D2*/\ + MUX_VAL(CP(CAM_D3), (IEN | PTD | DIS | M0)) /*CAM_D3*/\ + MUX_VAL(CP(CAM_D4), (IEN | PTD | DIS | M0)) /*CAM_D4*/\ + MUX_VAL(CP(CAM_D5), (IEN | PTD | DIS | M0)) /*CAM_D5*/\ + MUX_VAL(CP(CAM_D6), (IEN | PTD | DIS | M0)) /*CAM_D6*/\ + MUX_VAL(CP(CAM_D7), (IEN | PTD | DIS | M0)) /*CAM_D7*/\ + MUX_VAL(CP(CAM_D8), (IEN | PTD | DIS | M0)) /*CAM_D8*/\ + MUX_VAL(CP(CAM_D9), (IEN | PTD | DIS | M0)) /*CAM_D9*/\ + MUX_VAL(CP(CAM_D10), (IEN | PTD | DIS | M0)) /*CAM_D10*/\ + MUX_VAL(CP(CAM_D11), (IEN | PTD | DIS | M0)) /*CAM_D11*/\ + MUX_VAL(CP(CAM_XCLKB), (IDIS | PTD | DIS | M0)) /*CAM_XCLKB*/\ + MUX_VAL(CP(CAM_WEN), (IEN | PTD | DIS | M4)) /*GPIO_167*/\ + MUX_VAL(CP(CAM_STROBE), (IDIS | PTD | DIS | M0)) /*CAM_STROBE*/\ + MUX_VAL(CP(CSI2_DX0), (IEN | PTD | DIS | M0)) /*CSI2_DX0*/\ + MUX_VAL(CP(CSI2_DY0), (IEN | PTD | DIS | M0)) /*CSI2_DY0*/\ + MUX_VAL(CP(CSI2_DX1), (IEN | PTD | DIS | M0)) /*CSI2_DX1*/\ + MUX_VAL(CP(CSI2_DY1), (IEN | PTD | DIS | M0)) /*CSI2_DY1*/\ + /* Audio Interface */\ + MUX_VAL(CP(MCBSP2_FSX), (IEN | PTD | DIS | M0)) /*McBSP2_FSX*/\ + MUX_VAL(CP(MCBSP2_CLKX), (IEN | PTD | DIS | M0)) /*McBSP2_CLKX*/\ + MUX_VAL(CP(MCBSP2_DR), (IEN | PTD | DIS | M0)) /*McBSP2_DR*/\ + MUX_VAL(CP(MCBSP2_DX), (IDIS | PTD | DIS | M0)) /*McBSP2_DX*/\ + /* MMC Slot */\ + MUX_VAL(CP(MMC1_CLK), (IDIS | PTU | EN | M0)) /*MMC1_CLK*/\ + MUX_VAL(CP(MMC1_CMD), (IEN | PTU | EN | M0)) /*MMC1_CMD*/\ + MUX_VAL(CP(MMC1_DAT0), (IEN | PTU | EN | M0)) /*MMC1_DAT0*/\ + MUX_VAL(CP(MMC1_DAT1), (IEN | PTU | EN | M0)) /*MMC1_DAT1*/\ + MUX_VAL(CP(MMC1_DAT2), (IEN | PTU | EN | M0)) /*MMC1_DAT2*/\ + MUX_VAL(CP(MMC1_DAT3), (IEN | PTU | EN | M0)) /*MMC1_DAT3*/\ + MUX_VAL(CP(MMC1_DAT4), (IEN | PTU | EN | M0)) /*MMC1_DAT4*/\ + MUX_VAL(CP(MMC1_DAT5), (IEN | PTU | EN | M0)) /*MMC1_DAT5*/\ + MUX_VAL(CP(MMC1_DAT6), (IEN | PTU | EN | M0)) /*MMC1_DAT6*/\ + MUX_VAL(CP(MMC1_DAT7), (IEN | PTU | EN | M0)) /*MMC1_DAT7*/\ + /* Expansion Header */\ + MUX_VAL(CP(MMC2_CLK), (IEN | PTU | EN | M4)) /*GPIO_130*/\ + MUX_VAL(CP(MMC2_CMD), (IEN | PTU | EN | M4)) /*GPIO_131*/\ + MUX_VAL(CP(MMC2_DAT0), (IEN | PTU | EN | M4)) /*GPIO_132*/\ + MUX_VAL(CP(MMC2_DAT1), (IEN | PTU | EN | M4)) /*GPIO_133*/\ + MUX_VAL(CP(MMC2_DAT2), (IEN | PTU | EN | M4)) /*GPIO_134*/\ + MUX_VAL(CP(MMC2_DAT3), (IEN | PTU | EN | M4)) /*GPIO_135*/\ + MUX_VAL(CP(MMC2_DAT4), (IEN | PTU | EN | M4)) /*GPIO_136*/\ + MUX_VAL(CP(MMC2_DAT5), (IEN | PTU | EN | M4)) /*GPIO_137*/\ + MUX_VAL(CP(MMC2_DAT6), (IEN | PTU | EN | M4)) /*GPIO_138*/\ + MUX_VAL(CP(MMC2_DAT7), (IEN | PTU | EN | M4)) /*GPIO_139*/\ + MUX_VAL(CP(MCBSP3_DX), (IDIS | PTD | DIS | M4)) /*GPIO_140*/\ + MUX_VAL(CP(MCBSP3_DR), (IDIS | PTD | DIS | M4)) /*GPIO_141*/\ + MUX_VAL(CP(MCBSP3_CLKX), (IDIS | PTD | DIS | M4)) /*GPIO_142*/\ + MUX_VAL(CP(MCBSP3_FSX), (IDIS | PTD | DIS | M4)) /*GPIO_143*/\ + MUX_VAL(CP(UART2_CTS), (IDIS | PTD | DIS | M4)) /*GPIO_144*/\ + MUX_VAL(CP(UART2_RTS), (IDIS | PTD | DIS | M4)) /*GPIO_145*/\ + MUX_VAL(CP(UART2_TX), (IDIS | PTD | DIS | M4)) /*GPIO_146*/\ + MUX_VAL(CP(UART2_RX), (IDIS | PTD | DIS | M4)) /*GPIO_147*/\ + MUX_VAL(CP(UART1_TX), (IDIS | PTD | DIS | M0)) /*GPIO_148*/\ + MUX_VAL(CP(UART1_RTS), (IDIS | PTD | DIS | M4)) /*GPIO_149*/ \ + MUX_VAL(CP(UART1_CTS), (IDIS | PTD | DIS | M4)) /*GPIO_150*/ \ + MUX_VAL(CP(UART1_RX), (IEN | PTD | DIS | M0)) /*GPIO_151*/\ + MUX_VAL(CP(MCBSP4_CLKX), (IEN | PTD | DIS | M1)) /*GPIO_152*/\ + MUX_VAL(CP(MCBSP4_DR), (IEN | PTD | DIS | M1)) /*GPIO_153*/\ + MUX_VAL(CP(MCBSP4_DX), (IEN | PTD | DIS | M1)) /*GPIO_154*/\ + MUX_VAL(CP(MCBSP4_FSX), (IEN | PTD | DIS | M1)) /*GPIO_155*/\ + MUX_VAL(CP(MCBSP1_CLKR), (IDIS | PTD | DIS | M4)) /*GPIO_156*/\ + MUX_VAL(CP(MCBSP1_FSR), (IDIS | PTU | EN | M4)) /*GPIO_157*/\ + MUX_VAL(CP(MCBSP1_DX), (IDIS | PTD | DIS | M4)) /*GPIO_158*/\ + MUX_VAL(CP(MCBSP1_DR), (IDIS | PTD | DIS | M4)) /*GPIO_159*/\ + MUX_VAL(CP(MCBSP_CLKS), (IEN | PTU | DIS | M0)) /*GPIO_160*/\ + MUX_VAL(CP(MCBSP1_FSX), (IDIS | PTD | DIS | M4)) /*GPIO_161*/\ + MUX_VAL(CP(MCBSP1_CLKX), (IDIS | PTD | DIS | M4)) /*GPIO_162*/\ + /* Serial Interface */\ + MUX_VAL(CP(UART3_CTS_RCTX), (IDIS | PTD | EN | M4)) /*GPIO_163 - LED2*/\ + MUX_VAL(CP(UART3_RTS_SD), (IDIS | PTU | EN | M4)) /*GPIO_164 - LED3*/\ + MUX_VAL(CP(UART3_RX_IRRX), (IEN | PTD | DIS | M0)) /*UART3_RX_IRRX*/\ + MUX_VAL(CP(UART3_TX_IRTX), (IDIS | PTD | DIS | M0)) /*UART3_TX_IRTX*/\ + /* Host USB0 */\ + MUX_VAL(CP(HSUSB0_CLK), (IEN | PTD | DIS | M0)) /*HSUSB0_CLK*/\ + MUX_VAL(CP(HSUSB0_STP), (IDIS | PTU | EN | M0)) /*HSUSB0_STP*/\ + MUX_VAL(CP(HSUSB0_DIR), (IEN | PTD | DIS | M0)) /*HSUSB0_DIR*/\ + MUX_VAL(CP(HSUSB0_NXT), (IEN | PTD | DIS | M0)) /*HSUSB0_NXT*/\ + MUX_VAL(CP(HSUSB0_DATA0), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA0*/\ + MUX_VAL(CP(HSUSB0_DATA1), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA1*/\ + MUX_VAL(CP(HSUSB0_DATA2), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA2*/\ + MUX_VAL(CP(HSUSB0_DATA3), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA3*/\ + MUX_VAL(CP(HSUSB0_DATA4), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA4*/\ + MUX_VAL(CP(HSUSB0_DATA5), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA5*/\ + MUX_VAL(CP(HSUSB0_DATA6), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA6*/\ + MUX_VAL(CP(HSUSB0_DATA7), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA7*/\ + MUX_VAL(CP(I2C1_SCL), (IEN | PTU | EN | M0)) /*I2C1_SCL*/\ + MUX_VAL(CP(I2C1_SDA), (IEN | PTU | EN | M0)) /*I2C1_SDA*/\ + MUX_VAL(CP(I2C2_SCL), (IDIS | PTU | DIS | M4)) /*GPIO_168*/\ + MUX_VAL(CP(I2C2_SDA), (IEN | PTU | EN | M4)) /*GPIO_183*/\ + MUX_VAL(CP(I2C3_SCL), (IEN | PTU | EN | M0)) /*I2C3_SCL*/\ + MUX_VAL(CP(I2C3_SDA), (IEN | PTU | EN | M0)) /*I2C3_SDA*/\ + MUX_VAL(CP(I2C4_SCL), (IEN | PTU | EN | M0)) /*I2C4_SCL*/\ + MUX_VAL(CP(I2C4_SDA), (IEN | PTU | DIS | M0)) /*I2C4_SDA*/\ + MUX_VAL(CP(HDQ_SIO), (IDIS | PTD | DIS | M4)) /*GPIO_170*/\ + MUX_VAL(CP(MCSPI1_CLK), (IEN | PTD | DIS | M4)) /*GPIO_171*/\ + MUX_VAL(CP(MCSPI1_SIMO), (IEN | PTD | DIS | M4)) /*GPIO_172*/\ + MUX_VAL(CP(MCSPI1_SOMI), (IEN | PTD | DIS | M0)) /*MCSPI1_SOMI*/\ + MUX_VAL(CP(MCSPI1_CS0), (IEN | PTD | DIS | M0)) /*MCSPI1_CS0*/\ + MUX_VAL(CP(MCSPI1_CS1), (IDIS | PTD | DIS | M0)) /*MCSPI1_CS1*/\ + MUX_VAL(CP(MCSPI1_CS2), (IDIS | PTD | DIS | M4)) /*GPIO_176*/\ + /* USB EHCI (port 2) */\ + MUX_VAL(CP(MCSPI1_CS3), (IEN | PTD | EN | M0)) /*HSUSB2_DATA2*/\ + MUX_VAL(CP(MCSPI2_CLK), (IEN | PTD | DIS | M0)) /*HSUSB2_DATA7*/\ + MUX_VAL(CP(MCSPI2_SIMO), (IEN | PTD | DIS | M0)) /*HSUSB2_DATA4*/\ + MUX_VAL(CP(MCSPI2_SOMI), (IEN | PTD | DIS | M0)) /*HSUSB2_DATA5*/\ + MUX_VAL(CP(MCSPI2_CS0), (IEN | PTD | EN | M0)) /*HSUSB2_DATA6*/\ + MUX_VAL(CP(MCSPI2_CS1), (IEN | PTD | EN | M0)) /*HSUSB2_DATA3*/\ + /*Control and debug */\ + MUX_VAL(CP(SYS_32K), (IEN | PTD | DIS | M0)) /*SYS_32K*/\ + MUX_VAL(CP(SYS_CLKREQ), (IEN | PTD | DIS | M0)) /*SYS_CLKREQ*/\ + MUX_VAL(CP(SYS_NIRQ), (IEN | PTU | EN | M0)) /*SYS_nIRQ*/\ + MUX_VAL(CP(SYS_BOOT0), (IEN | PTD | DIS | M4)) /*GPIO_2*/\ + MUX_VAL(CP(SYS_BOOT1), (IEN | PTD | DIS | M4)) /*GPIO_3*/\ + MUX_VAL(CP(SYS_BOOT2), (IEN | PTD | DIS | M4)) /*GPIO_4 - MMC1_WP*/\ + MUX_VAL(CP(SYS_BOOT3), (IEN | PTD | DIS | M4)) /*GPIO_5*/\ + MUX_VAL(CP(SYS_BOOT4), (IEN | PTD | DIS | M4)) /*GPIO_6*/\ + MUX_VAL(CP(SYS_BOOT5), (IEN | PTD | DIS | M4)) /*GPIO_7*/\ + MUX_VAL(CP(SYS_BOOT6), (IDIS | PTD | DIS | M4)) /*GPIO_8*/ \ + MUX_VAL(CP(SYS_OFF_MODE), (IEN | PTD | DIS | M0)) /*SYS_OFF_MODE*/\ + MUX_VAL(CP(SYS_CLKOUT1), (IDIS | PTD | EN | M0)) /*SYS_CLKOUT1*/\ + MUX_VAL(CP(SYS_CLKOUT2), (IDIS | PTU | EN | M4)) /*GPIO_186 - LED1*/\ + MUX_VAL(CP(ETK_CLK_ES2), (IDIS | PTD | DIS | M3)) /*HSUSB1_STP*/\ + MUX_VAL(CP(ETK_CTL_ES2), (IDIS | PTD | EN | M3)) /*HSUSB1_CLK*/\ + MUX_VAL(CP(ETK_D0_ES2), (IDIS | PTU | EN | M3)) /*HSUSB1_DATA0*/\ + MUX_VAL(CP(ETK_D1_ES2), (IDIS | PTU | EN | M3)) /*HSUSB1_DATA1*/\ + MUX_VAL(CP(ETK_D2_ES2), (IDIS | PTU | EN | M3)) /*HSUSB1_DATA2*/\ + MUX_VAL(CP(ETK_D3_ES2), (IDIS | PTU | EN | M3)) /*HSUSB1_DATA7*/\ + MUX_VAL(CP(ETK_D4_ES2), (IDIS | PTU | EN | M3)) /*HSUSB1_DATA4*/\ + MUX_VAL(CP(ETK_D5_ES2), (IDIS | PTU | EN | M3)) /*HSUSB1_DATA5*/\ + MUX_VAL(CP(ETK_D6_ES2), (IDIS | PTU | EN | M3)) /*HSUSB1_DATA6*/\ + MUX_VAL(CP(ETK_D7_ES2), (IDIS | PTU | EN | M3)) /*HSUSB1_DATA3*/\ + MUX_VAL(CP(ETK_D8_ES2), (IEN | PTD | DIS | M3)) /*HSUSB1_DIR*/\ + MUX_VAL(CP(ETK_D9_ES2), (IEN | PTD | DIS | M3)) /*HSUSB1_NXT*/\ + MUX_VAL(CP(ETK_D10_ES2), (IDIS | PTU | EN | M4)) /*GPIO_24*/\ + MUX_VAL(CP(ETK_D11_ES2), (IEN | PTU | EN | M4)) /*GPIO_25*/\ + MUX_VAL(CP(ETK_D12_ES2), (IEN | PTU | EN | M4)) /*GPIO_26*/\ + MUX_VAL(CP(ETK_D13_ES2), (IEN | PTU | EN | M4)) /*GPIO_27*/\ + MUX_VAL(CP(ETK_D14_ES2), (IEN | PTU | EN | M4)) /*GPIO_28*/\ + MUX_VAL(CP(ETK_D15_ES2), (IEN | PTU | EN | M4)) /*GPIO_29*/\ + MUX_VAL(CP(D2D_MCAD1), (IEN | PTD | EN | M0)) /*D2D_MCAD1*/\ + MUX_VAL(CP(D2D_MCAD2), (IEN | PTD | EN | M0)) /*D2D_MCAD2*/\ + MUX_VAL(CP(D2D_MCAD3), (IEN | PTD | EN | M0)) /*D2D_MCAD3*/\ + MUX_VAL(CP(D2D_MCAD4), (IEN | PTD | EN | M0)) /*D2D_MCAD4*/\ + MUX_VAL(CP(D2D_MCAD5), (IEN | PTD | EN | M0)) /*D2D_MCAD5*/\ + MUX_VAL(CP(D2D_MCAD6), (IEN | PTD | EN | M0)) /*D2D_MCAD6*/\ + MUX_VAL(CP(D2D_MCAD7), (IEN | PTD | EN | M0)) /*D2D_MCAD7*/\ + MUX_VAL(CP(D2D_MCAD8), (IEN | PTD | EN | M0)) /*D2D_MCAD8*/\ + MUX_VAL(CP(D2D_MCAD9), (IEN | PTD | EN | M0)) /*D2D_MCAD9*/\ + MUX_VAL(CP(D2D_MCAD10), (IEN | PTD | EN | M0)) /*D2D_MCAD10*/\ + MUX_VAL(CP(D2D_MCAD11), (IEN | PTD | EN | M0)) /*D2D_MCAD11*/\ + MUX_VAL(CP(D2D_MCAD12), (IEN | PTD | EN | M0)) /*D2D_MCAD12*/\ + MUX_VAL(CP(D2D_MCAD13), (IEN | PTD | EN | M0)) /*D2D_MCAD13*/\ + MUX_VAL(CP(D2D_MCAD14), (IEN | PTD | EN | M0)) /*D2D_MCAD14*/\ + MUX_VAL(CP(D2D_MCAD15), (IEN | PTD | EN | M0)) /*D2D_MCAD15*/\ + MUX_VAL(CP(D2D_MCAD16), (IEN | PTD | EN | M0)) /*D2D_MCAD16*/\ + MUX_VAL(CP(D2D_MCAD17), (IEN | PTD | EN | M0)) /*D2D_MCAD17*/\ + MUX_VAL(CP(D2D_MCAD18), (IEN | PTD | EN | M0)) /*D2D_MCAD18*/\ + MUX_VAL(CP(D2D_MCAD19), (IEN | PTD | EN | M0)) /*D2D_MCAD19*/\ + MUX_VAL(CP(D2D_MCAD20), (IEN | PTD | EN | M0)) /*D2D_MCAD20*/\ + MUX_VAL(CP(D2D_MCAD21), (IEN | PTD | EN | M0)) /*D2D_MCAD21*/\ + MUX_VAL(CP(D2D_MCAD22), (IEN | PTD | EN | M0)) /*D2D_MCAD22*/\ + MUX_VAL(CP(D2D_MCAD23), (IEN | PTD | EN | M0)) /*D2D_MCAD23*/\ + MUX_VAL(CP(D2D_MCAD24), (IEN | PTD | EN | M0)) /*D2D_MCAD24*/\ + MUX_VAL(CP(D2D_MCAD25), (IEN | PTD | EN | M0)) /*D2D_MCAD25*/\ + MUX_VAL(CP(D2D_MCAD26), (IEN | PTD | EN | M0)) /*D2D_MCAD26*/\ + MUX_VAL(CP(D2D_MCAD27), (IEN | PTD | EN | M0)) /*D2D_MCAD27*/\ + MUX_VAL(CP(D2D_MCAD28), (IEN | PTD | EN | M0)) /*D2D_MCAD28*/\ + MUX_VAL(CP(D2D_MCAD29), (IEN | PTD | EN | M0)) /*D2D_MCAD29*/\ + MUX_VAL(CP(D2D_MCAD30), (IEN | PTD | EN | M0)) /*D2D_MCAD30*/\ + MUX_VAL(CP(D2D_MCAD31), (IEN | PTD | EN | M0)) /*D2D_MCAD31*/\ + MUX_VAL(CP(D2D_MCAD32), (IEN | PTD | EN | M0)) /*D2D_MCAD32*/\ + MUX_VAL(CP(D2D_MCAD33), (IEN | PTD | EN | M0)) /*D2D_MCAD33*/\ + MUX_VAL(CP(D2D_MCAD34), (IEN | PTD | EN | M0)) /*D2D_MCAD34*/\ + MUX_VAL(CP(D2D_MCAD35), (IEN | PTD | EN | M0)) /*D2D_MCAD35*/\ + MUX_VAL(CP(D2D_MCAD36), (IEN | PTD | EN | M0)) /*D2D_MCAD36*/\ + MUX_VAL(CP(D2D_CLK26MI), (IEN | PTD | DIS | M0)) /*D2D_clk26mi*/\ + MUX_VAL(CP(D2D_NRESPWRON), (IEN | PTD | EN | M0)) /*D2D_nrespwron*/\ + MUX_VAL(CP(D2D_NRESWARM), (IEN | PTU | EN | M0)) /*D2D_nreswarm */\ + MUX_VAL(CP(D2D_ARM9NIRQ), (IEN | PTD | DIS | M0)) /*D2D_arm9nirq */\ + MUX_VAL(CP(D2D_UMA2P6FIQ), (IEN | PTD | DIS | M0)) /*D2D_uma2p6fiq*/\ + MUX_VAL(CP(D2D_SPINT), (IEN | PTD | EN | M0)) /*D2D_spint*/\ + MUX_VAL(CP(D2D_FRINT), (IEN | PTD | EN | M0)) /*D2D_frint*/\ + MUX_VAL(CP(D2D_DMAREQ0), (IEN | PTD | DIS | M0)) /*D2D_dmareq0*/\ + MUX_VAL(CP(D2D_DMAREQ1), (IEN | PTD | DIS | M0)) /*D2D_dmareq1*/\ + MUX_VAL(CP(D2D_DMAREQ2), (IEN | PTD | DIS | M0)) /*D2D_dmareq2*/\ + MUX_VAL(CP(D2D_DMAREQ3), (IEN | PTD | DIS | M0)) /*D2D_dmareq3*/\ + MUX_VAL(CP(D2D_N3GTRST), (IEN | PTD | DIS | M0)) /*D2D_n3gtrst*/\ + MUX_VAL(CP(D2D_N3GTDI), (IEN | PTD | DIS | M0)) /*D2D_n3gtdi*/\ + MUX_VAL(CP(D2D_N3GTDO), (IEN | PTD | DIS | M0)) /*D2D_n3gtdo*/\ + MUX_VAL(CP(D2D_N3GTMS), (IEN | PTD | DIS | M0)) /*D2D_n3gtms*/\ + MUX_VAL(CP(D2D_N3GTCK), (IEN | PTD | DIS | M0)) /*D2D_n3gtck*/\ + MUX_VAL(CP(D2D_N3GRTCK), (IEN | PTD | DIS | M0)) /*D2D_n3grtck*/\ + MUX_VAL(CP(D2D_MSTDBY), (IEN | PTU | EN | M0)) /*D2D_mstdby*/\ + MUX_VAL(CP(D2D_SWAKEUP), (IEN | PTD | EN | M0)) /*D2D_swakeup*/\ + MUX_VAL(CP(D2D_IDLEREQ), (IEN | PTD | DIS | M0)) /*D2D_idlereq*/\ + MUX_VAL(CP(D2D_IDLEACK), (IEN | PTU | EN | M0)) /*D2D_idleack*/\ + MUX_VAL(CP(D2D_MWRITE), (IEN | PTD | DIS | M0)) /*D2D_mwrite*/\ + MUX_VAL(CP(D2D_SWRITE), (IEN | PTD | DIS | M0)) /*D2D_swrite*/\ + MUX_VAL(CP(D2D_MREAD), (IEN | PTD | DIS | M0)) /*D2D_mread*/\ + MUX_VAL(CP(D2D_SREAD), (IEN | PTD | DIS | M0)) /*D2D_sread*/\ + MUX_VAL(CP(D2D_MBUSFLAG), (IEN | PTD | DIS | M0)) /*D2D_mbusflag*/\ + MUX_VAL(CP(D2D_SBUSFLAG), (IEN | PTD | DIS | M0)) /*D2D_sbusflag*/\ + MUX_VAL(CP(SDRC_CKE0), (IDIS | PTU | EN | M0)) /*sdrc_cke0*/\ + MUX_VAL(CP(SDRC_CKE1), (IDIS | PTD | DIS | M7)) /*sdrc_cke1*/ + +#endif diff --git a/doc/README.devkit8000 b/doc/README.devkit8000 new file mode 100644 index 0000000..28e2fdf --- /dev/null +++ b/doc/README.devkit8000 @@ -0,0 +1,15 @@ +DevKit8000 +========== + +The OMAP3 DevKit8000 from Embest/Timll is a clone of the OMAP3 beagle board +with Ethernet and Touch Screen controller on board. + +For more information go to: +http://www.embedinfo.com/English/Product/devkit8000.asp + +There's no real MAC address available. +If ethaddr is not set, 5 Bytes of the OMAP Die ID will be used. + +Build: +make omap3_devkit8000_config +make diff --git a/include/configs/devkit8000.h b/include/configs/devkit8000.h new file mode 100644 index 0000000..cd40da6 --- /dev/null +++ b/include/configs/devkit8000.h @@ -0,0 +1,307 @@ +/* + * (C) Copyright 2006-2008 + * Texas Instruments. + * Richard Woodruff r-woodruff2@ti.com + * Syed Mohammed Khasim x0khasim@ti.com + * + * (C) Copyright 2009 + * Frederik Kriewitz frederik@kriewitz.eu + * + * Configuration settings for the DevKit8000 board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H +#include <asm/sizes.h> + +/* High Level Configuration Options */ +#define CONFIG_ARMCORTEXA8 1 /* This is an ARM V7 CPU core */ +#define CONFIG_OMAP 1 /* in a TI OMAP core */ +#define CONFIG_OMAP34XX 1 /* which is a 34XX */ +#define CONFIG_OMAP3430 1 /* which is in a 3430 */ +#define CONFIG_OMAP3_DEVKIT8000 1 /* working with DevKit8000 */ + +#include <asm/arch/cpu.h> /* get chip and board defs */ +#include <asm/arch/omap3.h> + +/* Display CPU and Board information */ +#define CONFIG_DISPLAY_CPUINFO 1 +#define CONFIG_DISPLAY_BOARDINFO 1 + +/* Clock Defines */ +#define V_OSCK 26000000 /* Clock output from T2 */ +#define V_SCLK (V_OSCK >> 1) + +#undef CONFIG_USE_IRQ /* no support for IRQs */ +#define CONFIG_MISC_INIT_R + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 +#define CONFIG_REVISION_TAG 1 + +/* Size of malloc() pool */ +#define CONFIG_ENV_SIZE SZ_128K /* Total Size Environment */ + /* Sector */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + SZ_128K) +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for */ + /* initial data */ + +/* Hardware drivers */ + +/* DM9000 */ +#define CONFIG_NET_MULTI 1 +#define CONFIG_NET_RETRY_COUNT 20 +#define CONFIG_DRIVER_DM9000 1 +#define CONFIG_DM9000_BASE 0x2c000000 +#define DM9000_IO CONFIG_DM9000_BASE +#define DM9000_DATA (CONFIG_DM9000_BASE + 0x400) +#define CONFIG_DM9000_USE_16BIT 1 +#define CONFIG_DM9000_NO_SROM 1 +#undef CONFIG_DM9000_DEBUG + +/* NS16550 Configuration */ +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE (-4) +#define CONFIG_SYS_NS16550_CLK 48000000 /* 48MHz (APLL96/2) */ + +/* select serial console configuration */ +#define CONFIG_CONS_INDEX 3 +#define CONFIG_SYS_NS16550_COM3 OMAP34XX_UART3 +#define CONFIG_SERIAL3 3 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600,\ + 115200} + +/* MMC */ +#define CONFIG_MMC 1 +#define CONFIG_OMAP3_MMC 1 +#define CONFIG_DOS_PARTITION 1 + +/* I2C */ +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C_SLAVE 1 +#define CONFIG_SYS_I2C_BUS 0 +#define CONFIG_SYS_I2C_BUS_SELECT 1 +#define CONFIG_DRIVER_OMAP34XX_I2C 1 + +/* TWL4030 */ +#define CONFIG_TWL4030_POWER 1 +#define CONFIG_TWL4030_LED 1 + +/* Board NAND Info */ +#define CONFIG_SYS_NO_FLASH /* no NOR flash */ +#define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ +#define MTDIDS_DEFAULT "nand0=nand" +#define MTDPARTS_DEFAULT "mtdparts=nand:" \ + "512k(x-loader)," \ + "1920k(u-boot)," \ + "128k(u-boot-env)," \ + "4m(kernel)," \ + "-(fs)" + +#define CONFIG_NAND_OMAP_GPMC +#define CONFIG_SYS_NAND_ADDR NAND_BASE /* physical address */ + /* to access nand */ +#define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ + /* to access nand at */ + /* CS0 */ +#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 + +#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND */ + /* devices */ +#define CONFIG_SYS_64BIT_VSPRINTF /* needed for nand_util.c */ + +#define CONFIG_JFFS2_NAND +/* nand device jffs2 lives on */ +#define CONFIG_JFFS2_DEV "nand0" +/* start of jffs2 partition */ +#define CONFIG_JFFS2_PART_OFFSET 0x680000 +#define CONFIG_JFFS2_PART_SIZE 0xf980000 /* size of jffs2 */ + /* partition */ + +/* commands to include */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DHCP /* DHCP support */ +#define CONFIG_CMD_EXT2 /* EXT2 Support */ +#define CONFIG_CMD_FAT /* FAT support */ +#define CONFIG_CMD_I2C /* I2C serial bus support */ +#define CONFIG_CMD_JFFS2 /* JFFS2 Support */ +#define CONFIG_CMD_MMC /* MMC support */ +#define CONFIG_CMD_MTDPARTS /* Enable MTD parts commands */ +#define CONFIG_CMD_NAND /* NAND support */ +#define CONFIG_CMD_NAND_LOCK_UNLOCK /* nand (un)lock commands */ + +#undef CONFIG_CMD_FPGA /* FPGA configuration Support */ +#undef CONFIG_CMD_IMI /* iminfo */ + +/* BOOTP/DHCP options */ +#define CONFIG_BOOTP_SUBNETMASK +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME +#define CONFIG_BOOTP_NISDOMAIN +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_DNS +#define CONFIG_BOOTP_DNS2 +#define CONFIG_BOOTP_SEND_HOSTNAME +#define CONFIG_BOOTP_NTPSERVER +#define CONFIG_BOOTP_TIMEOFFSET +#undef CONFIG_BOOTP_VENDOREX + +/* Environment information */ +#define CONFIG_ENV_OVERWRITE /* allow to overwrite serial and ethaddr */ + +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loadaddr=0x82000000\0" \ + "console=ttyS2,115200n8\0" \ + "vram=12M\0" \ + "dvimode=1024x768MR-16@60\0" \ + "defaultdisplay=dvi\0" \ + "nfsopts=hard,tcp,rsize=65536,wsize=65536\0" \ + "kernelopts=rw\0" \ + "commonargs=" \ + "setenv bootargs console=${console} " \ + "vram=${vram} " \ + "omapfb.mode=dvi:${dvimode} " \ + "omapdss.def_disp=${defaultdisplay}\0" \ + "mmcargs=" \ + "run commonargs; " \ + "setenv bootargs ${bootargs} " \ + "root=/dev/mmcblk0p2 " \ + "${kernelopts}\0" \ + "nandargs=" \ + "run commonargs; " \ + "setenv bootargs ${bootargs} " \ + "omapfb.mode=dvi:${dvimode} " \ + "omapdss.def_disp=${defaultdisplay} " \ + "root=/dev/mtdblock4 " \ + "rootfstype=jffs2 " \ + "${kernelopts}\0" \ + "netargs=" \ + "run commonargs; " \ + "setenv bootargs ${bootargs} " \ + "root=/dev/nfs " \ + "nfsroot=${serverip}:${rootpath},${nfsopts} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off " \ + "${kernelopts} " \ + "dnsip1=${dnsip} " \ + "dnsip2=${dnsip2}\0" \ + "loadbootscript=fatload mmc 0 ${loadaddr} boot.scr\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source ${loadaddr}\0" \ + "loaduimage=fatload mmc 0 ${loadaddr} uImage\0" \ + "eraseenv=nand unlock 0x260000 0x20000; nand erase 0x260000 0x20000\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "bootm ${loadaddr}\0" \ + "nandboot=echo Booting from nand ...; " \ + "run nandargs; " \ + "nand read ${loadaddr} 280000 400000; " \ + "bootm ${loadaddr}\0" \ + "netboot=echo Booting from network ...; " \ + "dhcp ${loadaddr}; " \ + "run netargs; " \ + "bootm ${loadaddr}\0" \ + "autoboot=if mmc init 0; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loaduimage; then " \ + "run mmcboot; " \ + "else run nandboot; " \ + "fi; " \ + "fi; " \ + "else run nandboot; fi\0" + + +#define CONFIG_BOOTCOMMAND "run autoboot" + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_AUTO_COMPLETE 1 +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_PROMPT "OMAP3 DevKit8000 # " +#define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 128 /* max number of command args */ + +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE (CONFIG_SYS_CBSIZE) + +#define CONFIG_SYS_MEMTEST_START (OMAP34XX_SDRC_CS0 + 0x07000000) +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ + 0x01000000) /* 16MB */ + +#define CONFIG_SYS_LOAD_ADDR (OMAP34XX_SDRC_CS0 + 0x02000000) + +/* + * OMAP3 has 12 GP timers, they can be driven by the system clock + * (12/13/16.8/19.2/38.4MHz) or by 32KHz clock. We use 13MHz (V_SCLK). + * This rate is divided by a local divisor. + */ +#define CONFIG_SYS_TIMERBASE (OMAP34XX_GPT2) +#define CONFIG_SYS_PTV 2 /* Divisor: 2^(PTV+1) => 8 */ +#define CONFIG_SYS_HZ 1000 + +/* The stack sizes are set up in start.S using the settings below */ +#define CONFIG_STACKSIZE SZ_128K /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ SZ_4K /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ SZ_4K /* FIQ stack */ +#endif + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 2 /* CS1 may or may not be populated */ +#define PHYS_SDRAM_1 OMAP34XX_SDRC_CS0 +#define PHYS_SDRAM_1_SIZE SZ_128M /* at least 128 meg */ +#define PHYS_SDRAM_2 OMAP34XX_SDRC_CS1 + +/* SDRAM Bank Allocation method */ +#define SDRC_R_B_C 1 + +/* NAND and environment organization */ +#define PISMO1_NAND_SIZE GPMC_SIZE_128M + +#define CONFIG_SYS_MONITOR_LEN SZ_256K /* Reserve 2 sectors */ + +#define CONFIG_ENV_IS_IN_NAND 1 +#define SMNAND_ENV_OFFSET 0x260000 /* environment starts here */ + +#define CONFIG_ENV_OFFSET boot_flash_off + +#ifndef __ASSEMBLY__ +extern struct gpmc *gpmc_cfg; +extern unsigned int boot_flash_base; +extern volatile unsigned int boot_flash_env_addr; +extern unsigned int boot_flash_off; +extern unsigned int boot_flash_sec; +extern unsigned int boot_flash_type; +#endif + +#endif /* __CONFIG_H */ diff --git a/include/configs/omap3_devkit8000.h b/include/configs/omap3_devkit8000.h new file mode 100644 index 0000000..cd40da6 --- /dev/null +++ b/include/configs/omap3_devkit8000.h @@ -0,0 +1,307 @@ +/* + * (C) Copyright 2006-2008 + * Texas Instruments. + * Richard Woodruff r-woodruff2@ti.com + * Syed Mohammed Khasim x0khasim@ti.com + * + * (C) Copyright 2009 + * Frederik Kriewitz frederik@kriewitz.eu + * + * Configuration settings for the DevKit8000 board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H +#include <asm/sizes.h> + +/* High Level Configuration Options */ +#define CONFIG_ARMCORTEXA8 1 /* This is an ARM V7 CPU core */ +#define CONFIG_OMAP 1 /* in a TI OMAP core */ +#define CONFIG_OMAP34XX 1 /* which is a 34XX */ +#define CONFIG_OMAP3430 1 /* which is in a 3430 */ +#define CONFIG_OMAP3_DEVKIT8000 1 /* working with DevKit8000 */ + +#include <asm/arch/cpu.h> /* get chip and board defs */ +#include <asm/arch/omap3.h> + +/* Display CPU and Board information */ +#define CONFIG_DISPLAY_CPUINFO 1 +#define CONFIG_DISPLAY_BOARDINFO 1 + +/* Clock Defines */ +#define V_OSCK 26000000 /* Clock output from T2 */ +#define V_SCLK (V_OSCK >> 1) + +#undef CONFIG_USE_IRQ /* no support for IRQs */ +#define CONFIG_MISC_INIT_R + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 +#define CONFIG_REVISION_TAG 1 + +/* Size of malloc() pool */ +#define CONFIG_ENV_SIZE SZ_128K /* Total Size Environment */ + /* Sector */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + SZ_128K) +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for */ + /* initial data */ + +/* Hardware drivers */ + +/* DM9000 */ +#define CONFIG_NET_MULTI 1 +#define CONFIG_NET_RETRY_COUNT 20 +#define CONFIG_DRIVER_DM9000 1 +#define CONFIG_DM9000_BASE 0x2c000000 +#define DM9000_IO CONFIG_DM9000_BASE +#define DM9000_DATA (CONFIG_DM9000_BASE + 0x400) +#define CONFIG_DM9000_USE_16BIT 1 +#define CONFIG_DM9000_NO_SROM 1 +#undef CONFIG_DM9000_DEBUG + +/* NS16550 Configuration */ +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE (-4) +#define CONFIG_SYS_NS16550_CLK 48000000 /* 48MHz (APLL96/2) */ + +/* select serial console configuration */ +#define CONFIG_CONS_INDEX 3 +#define CONFIG_SYS_NS16550_COM3 OMAP34XX_UART3 +#define CONFIG_SERIAL3 3 +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600,\ + 115200} + +/* MMC */ +#define CONFIG_MMC 1 +#define CONFIG_OMAP3_MMC 1 +#define CONFIG_DOS_PARTITION 1 + +/* I2C */ +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C_SLAVE 1 +#define CONFIG_SYS_I2C_BUS 0 +#define CONFIG_SYS_I2C_BUS_SELECT 1 +#define CONFIG_DRIVER_OMAP34XX_I2C 1 + +/* TWL4030 */ +#define CONFIG_TWL4030_POWER 1 +#define CONFIG_TWL4030_LED 1 + +/* Board NAND Info */ +#define CONFIG_SYS_NO_FLASH /* no NOR flash */ +#define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ +#define MTDIDS_DEFAULT "nand0=nand" +#define MTDPARTS_DEFAULT "mtdparts=nand:" \ + "512k(x-loader)," \ + "1920k(u-boot)," \ + "128k(u-boot-env)," \ + "4m(kernel)," \ + "-(fs)" + +#define CONFIG_NAND_OMAP_GPMC +#define CONFIG_SYS_NAND_ADDR NAND_BASE /* physical address */ + /* to access nand */ +#define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address */ + /* to access nand at */ + /* CS0 */ +#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 + +#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND */ + /* devices */ +#define CONFIG_SYS_64BIT_VSPRINTF /* needed for nand_util.c */ + +#define CONFIG_JFFS2_NAND +/* nand device jffs2 lives on */ +#define CONFIG_JFFS2_DEV "nand0" +/* start of jffs2 partition */ +#define CONFIG_JFFS2_PART_OFFSET 0x680000 +#define CONFIG_JFFS2_PART_SIZE 0xf980000 /* size of jffs2 */ + /* partition */ + +/* commands to include */ +#include <config_cmd_default.h> + +#define CONFIG_CMD_DHCP /* DHCP support */ +#define CONFIG_CMD_EXT2 /* EXT2 Support */ +#define CONFIG_CMD_FAT /* FAT support */ +#define CONFIG_CMD_I2C /* I2C serial bus support */ +#define CONFIG_CMD_JFFS2 /* JFFS2 Support */ +#define CONFIG_CMD_MMC /* MMC support */ +#define CONFIG_CMD_MTDPARTS /* Enable MTD parts commands */ +#define CONFIG_CMD_NAND /* NAND support */ +#define CONFIG_CMD_NAND_LOCK_UNLOCK /* nand (un)lock commands */ + +#undef CONFIG_CMD_FPGA /* FPGA configuration Support */ +#undef CONFIG_CMD_IMI /* iminfo */ + +/* BOOTP/DHCP options */ +#define CONFIG_BOOTP_SUBNETMASK +#define CONFIG_BOOTP_GATEWAY +#define CONFIG_BOOTP_HOSTNAME +#define CONFIG_BOOTP_NISDOMAIN +#define CONFIG_BOOTP_BOOTPATH +#define CONFIG_BOOTP_BOOTFILESIZE +#define CONFIG_BOOTP_DNS +#define CONFIG_BOOTP_DNS2 +#define CONFIG_BOOTP_SEND_HOSTNAME +#define CONFIG_BOOTP_NTPSERVER +#define CONFIG_BOOTP_TIMEOFFSET +#undef CONFIG_BOOTP_VENDOREX + +/* Environment information */ +#define CONFIG_ENV_OVERWRITE /* allow to overwrite serial and ethaddr */ + +#define CONFIG_BOOTDELAY 3 + +#define CONFIG_EXTRA_ENV_SETTINGS \ + "loadaddr=0x82000000\0" \ + "console=ttyS2,115200n8\0" \ + "vram=12M\0" \ + "dvimode=1024x768MR-16@60\0" \ + "defaultdisplay=dvi\0" \ + "nfsopts=hard,tcp,rsize=65536,wsize=65536\0" \ + "kernelopts=rw\0" \ + "commonargs=" \ + "setenv bootargs console=${console} " \ + "vram=${vram} " \ + "omapfb.mode=dvi:${dvimode} " \ + "omapdss.def_disp=${defaultdisplay}\0" \ + "mmcargs=" \ + "run commonargs; " \ + "setenv bootargs ${bootargs} " \ + "root=/dev/mmcblk0p2 " \ + "${kernelopts}\0" \ + "nandargs=" \ + "run commonargs; " \ + "setenv bootargs ${bootargs} " \ + "omapfb.mode=dvi:${dvimode} " \ + "omapdss.def_disp=${defaultdisplay} " \ + "root=/dev/mtdblock4 " \ + "rootfstype=jffs2 " \ + "${kernelopts}\0" \ + "netargs=" \ + "run commonargs; " \ + "setenv bootargs ${bootargs} " \ + "root=/dev/nfs " \ + "nfsroot=${serverip}:${rootpath},${nfsopts} " \ + "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}:${hostname}::off " \ + "${kernelopts} " \ + "dnsip1=${dnsip} " \ + "dnsip2=${dnsip2}\0" \ + "loadbootscript=fatload mmc 0 ${loadaddr} boot.scr\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source ${loadaddr}\0" \ + "loaduimage=fatload mmc 0 ${loadaddr} uImage\0" \ + "eraseenv=nand unlock 0x260000 0x20000; nand erase 0x260000 0x20000\0" \ + "mmcboot=echo Booting from mmc ...; " \ + "run mmcargs; " \ + "bootm ${loadaddr}\0" \ + "nandboot=echo Booting from nand ...; " \ + "run nandargs; " \ + "nand read ${loadaddr} 280000 400000; " \ + "bootm ${loadaddr}\0" \ + "netboot=echo Booting from network ...; " \ + "dhcp ${loadaddr}; " \ + "run netargs; " \ + "bootm ${loadaddr}\0" \ + "autoboot=if mmc init 0; then " \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "if run loaduimage; then " \ + "run mmcboot; " \ + "else run nandboot; " \ + "fi; " \ + "fi; " \ + "else run nandboot; fi\0" + + +#define CONFIG_BOOTCOMMAND "run autoboot" + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_AUTO_COMPLETE 1 +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_PROMPT "OMAP3 DevKit8000 # " +#define CONFIG_SYS_CBSIZE 512 /* Console I/O Buffer Size */ +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + \ + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 128 /* max number of command args */ + +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE (CONFIG_SYS_CBSIZE) + +#define CONFIG_SYS_MEMTEST_START (OMAP34XX_SDRC_CS0 + 0x07000000) +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START + \ + 0x01000000) /* 16MB */ + +#define CONFIG_SYS_LOAD_ADDR (OMAP34XX_SDRC_CS0 + 0x02000000) + +/* + * OMAP3 has 12 GP timers, they can be driven by the system clock + * (12/13/16.8/19.2/38.4MHz) or by 32KHz clock. We use 13MHz (V_SCLK). + * This rate is divided by a local divisor. + */ +#define CONFIG_SYS_TIMERBASE (OMAP34XX_GPT2) +#define CONFIG_SYS_PTV 2 /* Divisor: 2^(PTV+1) => 8 */ +#define CONFIG_SYS_HZ 1000 + +/* The stack sizes are set up in start.S using the settings below */ +#define CONFIG_STACKSIZE SZ_128K /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ SZ_4K /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ SZ_4K /* FIQ stack */ +#endif + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 2 /* CS1 may or may not be populated */ +#define PHYS_SDRAM_1 OMAP34XX_SDRC_CS0 +#define PHYS_SDRAM_1_SIZE SZ_128M /* at least 128 meg */ +#define PHYS_SDRAM_2 OMAP34XX_SDRC_CS1 + +/* SDRAM Bank Allocation method */ +#define SDRC_R_B_C 1 + +/* NAND and environment organization */ +#define PISMO1_NAND_SIZE GPMC_SIZE_128M + +#define CONFIG_SYS_MONITOR_LEN SZ_256K /* Reserve 2 sectors */ + +#define CONFIG_ENV_IS_IN_NAND 1 +#define SMNAND_ENV_OFFSET 0x260000 /* environment starts here */ + +#define CONFIG_ENV_OFFSET boot_flash_off + +#ifndef __ASSEMBLY__ +extern struct gpmc *gpmc_cfg; +extern unsigned int boot_flash_base; +extern volatile unsigned int boot_flash_env_addr; +extern unsigned int boot_flash_off; +extern unsigned int boot_flash_sec; +extern unsigned int boot_flash_type; +#endif + +#endif /* __CONFIG_H */
why do you duplicate it? maybe an miss when updating the patch
Best Regards, J.
On Tue, Aug 25, 2009 at 7:25 AM, Jean-Christophe PLAGNIOL-VILLARDplagnioj@jcrosoft.com wrote:
<snip>
This is a version of the patch Dirk asked for. Without timll vendor directory and with omap3_ config file prefix:
MAINTAINERS | 4 + MAKEALL | 1 + Makefile | 3 + board/timll/devkit8000/Makefile | 52 +++++
I'm not sure what "timll" stands for?
Depending on the result of the board directory rename discussion, I'd like to see board/devkit8000 or board/omap3devkit8000 here.
diff --git a/MAKEALL b/MAKEALL index edebaea..65eb4b7 100755 --- a/MAKEALL +++ b/MAKEALL @@ -575,6 +575,7 @@ LIST_ARM11=" \ ## ARM Cortex-A8 Systems ######################################################################### LIST_ARM_CORTEX_A8=" \
devkit8000 \ omap3_beagle \ omap3_overo \ omap3_evm \
What's about "omap3_devkit8000"?
No, Jean-Christophe referred to the 2 config headers: devkit8000.h *and* omap3_devkit8000.h. You probably forgot to remove one of those files.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Oh yes, do we really need a v7? Or is v4 (with timll vendor directory) ok.
Sorry for the patch spam.
Frederik Kriewitz
Stefan Roese
