[PATCH] spi: zynq_qspi: Use clk subsystem to get reference qspi clk
Remove fixed reference clk used by plat->frequency and use clk subsystem to get reference clk. As per spi dt bindings "spi-max-frequency" property should be used by the slave devices. This property is read by spi-uclass driver for the slave device. So avoid reading above property from the platform driver.
Signed-off-by: T Karthik Reddy t.karthik.reddy@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
drivers/spi/zynq_qspi.c | 35 +++++++++++++++++++++++++++-------- 1 file changed, 27 insertions(+), 8 deletions(-)
diff --git a/drivers/spi/zynq_qspi.c b/drivers/spi/zynq_qspi.c index 3f39ef05f2d6..7591164ea986 100644 --- a/drivers/spi/zynq_qspi.c +++ b/drivers/spi/zynq_qspi.c @@ -6,6 +6,7 @@ * Xilinx Zynq Quad-SPI(QSPI) controller driver (master mode only) */
+#include <clk.h> #include <common.h> #include <dm.h> #include <log.h> @@ -105,14 +106,6 @@ static int zynq_qspi_ofdata_to_platdata(struct udevice *bus) plat->regs = (struct zynq_qspi_regs *)fdtdec_get_addr(blob, node, "reg");
- /* FIXME: Use 166MHz as a suitable default */ - plat->frequency = fdtdec_get_int(blob, node, "spi-max-frequency", - 166666666); - plat->speed_hz = plat->frequency / 2; - - debug("%s: regs=%p max-frequency=%d\n", __func__, - plat->regs, plat->frequency); - return 0; }
@@ -159,13 +152,39 @@ static int zynq_qspi_probe(struct udevice *bus) { struct zynq_qspi_platdata *plat = dev_get_platdata(bus); struct zynq_qspi_priv *priv = dev_get_priv(bus); + struct clk clk; + unsigned long clock; + int ret;
priv->regs = plat->regs; priv->fifo_depth = ZYNQ_QSPI_FIFO_DEPTH;
+ ret = clk_get_by_name(bus, "ref_clk", &clk); + if (ret < 0) { + dev_err(dev, "failed to get clock\n"); + return ret; + } + + clock = clk_get_rate(&clk); + if (IS_ERR_VALUE(clock)) { + dev_err(dev, "failed to get rate\n"); + return clock; + } + + ret = clk_enable(&clk); + if (ret && ret != -ENOSYS) { + dev_err(dev, "failed to enable clock\n"); + return ret; + } + /* init the zynq spi hw */ zynq_qspi_init_hw(priv);
+ plat->frequency = clock; + plat->speed_hz = plat->frequency / 2; + + debug("%s: max-frequency=%d\n", __func__, plat->speed_hz); + return 0; }
Michal Simek
