[U-Boot] [PATCH] powerpc/mpc83xx: Cleanup usage of LBC and DDR constants
Attempt to make 83xx use constants consistently. In the course of switching from numerics to field constants, a number of reserved fields being assigned were found. Those places that seemed broken I marked with [RFC]... please provide guidance if you are familiar with that target.
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- arch/powerpc/cpu/mpc83xx/spd_sdram.c | 9 ++ arch/powerpc/include/asm/fsl_lbc.h | 8 +- include/configs/MERGERBOX.h | 28 +++-- include/configs/MPC8308RDB.h | 50 +++++--- include/configs/MPC8313ERDB.h | 80 +++++++++---- include/configs/MPC8315ERDB.h | 49 ++++---- include/configs/MPC8323ERDB.h | 114 ++++++------------- include/configs/MPC832XEMDS.h | 213 +++++++++++++++++++--------------- include/configs/MPC8349EMDS.h | 107 ++++++++++------- include/configs/MPC8349ITX.h | 35 +++--- include/configs/MPC8360EMDS.h | 146 ++++++++++++++++-------- include/configs/MPC8360ERDK.h | 74 +++++++----- include/configs/MPC837XEMDS.h | 111 ++++++++++-------- include/configs/MPC837XERDB.h | 118 +++++++++++-------- include/configs/MVBLM7.h | 28 +++-- include/configs/SIMPC8313.h | 26 ++-- include/configs/TQM834x.h | 20 ++-- include/configs/km/km83xx-common.h | 28 +++-- include/configs/kmeter1.h | 20 ++-- include/configs/kmsupx5.h | 8 +- include/configs/mpc8308_p1m.h | 47 ++++---- include/configs/sbc8349.h | 65 +++++++---- include/configs/suvd3.h | 10 +- include/configs/tuda1.h | 21 ++-- include/configs/tuxa1.h | 23 ++-- include/configs/ve8313.h | 80 +++++++------ include/configs/vme8349.h | 75 ++++++++---- include/mpc83xx.h | 32 +++++- 28 files changed, 942 insertions(+), 683 deletions(-)
diff --git a/arch/powerpc/cpu/mpc83xx/spd_sdram.c b/arch/powerpc/cpu/mpc83xx/spd_sdram.c index 9b01f0d..3855bfd 100644 --- a/arch/powerpc/cpu/mpc83xx/spd_sdram.c +++ b/arch/powerpc/cpu/mpc83xx/spd_sdram.c @@ -46,10 +46,19 @@ void board_add_ram_info(int use_default) printf(" (DDR%d", ((ddr->sdram_cfg & SDRAM_CFG_SDRAM_TYPE_MASK) >> SDRAM_CFG_SDRAM_TYPE_SHIFT) - 1);
+#if defined(CONFIG_MPC8308) || defined(CONFIG_MPC831x) + if ((ddr->sdram_cfg & SDRAM_CFG_DBW_MASK) == SDRAM_CFG_DBW_16) + puts(", 16-bit"); + else if ((ddr->sdram_cfg & SDRAM_CFG_DBW_MASK) == SDRAM_CFG_DBW_32) + puts(", 32-bit"); + else + puts(", unknown width"); +#else if (ddr->sdram_cfg & SDRAM_CFG_32_BE) puts(", 32-bit"); else puts(", 64-bit"); +#endif
if (ddr->sdram_cfg & SDRAM_CFG_ECC_EN) puts(", ECC on"); diff --git a/arch/powerpc/include/asm/fsl_lbc.h b/arch/powerpc/include/asm/fsl_lbc.h index 8695a62..bf572b7 100644 --- a/arch/powerpc/include/asm/fsl_lbc.h +++ b/arch/powerpc/include/asm/fsl_lbc.h @@ -50,8 +50,10 @@ void lbc_sdram_init(void); #define BR_MSEL 0x000000E0 #define BR_MSEL_SHIFT 5 #define BR_MS_GPCM 0x00000000 /* GPCM */ +#if !defined(CONFIG_MPC834x) && !defined(CONFIG_MPC8360) #define BR_MS_FCM 0x00000020 /* FCM */ -#ifdef CONFIG_MPC83xx +#endif +#if defined(CONFIG_MPC834x) || defined(CONFIG_MPC8360) #define BR_MS_SDRAM 0x00000060 /* SDRAM */ #elif defined(CONFIG_MPC85xx) #define BR_MS_SDRAM 0x00000000 /* SDRAM */ @@ -138,8 +140,10 @@ void lbc_sdram_init(void); #define OR_GPCM_EHTR_SHIFT 1 #define OR_GPCM_EHTR_CLEAR 0x00000000 #define OR_GPCM_EHTR_SET 0x00000002 +#if !defined(CONFIG_MPC8308) #define OR_GPCM_EAD 0x00000001 #define OR_GPCM_EAD_SHIFT 0 +#endif
/* helpers to convert values into an OR address mask (GPCM mode) */ #define P2SZ_TO_AM(s) ((~((s) - 1)) & 0xffff8000) /* must be pow of 2 */ @@ -196,8 +200,10 @@ void lbc_sdram_init(void); #define OR_SDRAM_XAM_SHIFT 13 #define OR_SDRAM_COLS 0x00001C00 #define OR_SDRAM_COLS_SHIFT 10 +#define OR_SDRAM_MIN_COLS 7 #define OR_SDRAM_ROWS 0x000001C0 #define OR_SDRAM_ROWS_SHIFT 6 +#define OR_SDRAM_MIN_ROWS 9 #define OR_SDRAM_PMSEL 0x00000020 #define OR_SDRAM_PMSEL_SHIFT 5 #define OR_SDRAM_EAD 0x00000001 diff --git a/include/configs/MERGERBOX.h b/include/configs/MERGERBOX.h index f9681cd..8a1c4f0 100644 --- a/include/configs/MERGERBOX.h +++ b/include/configs/MERGERBOX.h @@ -159,11 +159,13 @@ #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_64MB)
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | BR_PS_16 | BR_V) +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | BR_PS_16 |\ + BR_MS_GPCM | BR_V) #define CONFIG_SYS_OR0_PRELIM (CONFIG_SYS_FLASH_BASE | OR_UPM_XAM |\ OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 |\ - OR_GPCM_XACS | OR_GPCM_SCY_15 | OR_GPCM_TRLX |\ - OR_GPCM_EHTR | OR_GPCM_EAD) + OR_GPCM_XACS | OR_GPCM_SCY_15 |\ + OR_GPCM_TRLX_SET | OR_GPCM_EHTR_SET |\ + OR_GPCM_EAD)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 512 @@ -180,14 +182,14 @@ #define CONFIG_NAND_FSL_ELBC 1
#define CONFIG_SYS_NAND_BASE 0xE0600000 -#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_NAND_BASE | (2<<BR_DECC_SHIFT) |\ +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_NAND_BASE | BR_DECC_CHK_GEN |\ BR_PS_8 | BR_MS_FCM | BR_V) -#define CONFIG_SYS_OR1_PRELIM (0xFFFF8000 | OR_FCM_BCTLD | OR_FCM_CST |\ +#define CONFIG_SYS_OR1_PRELIM (OR_AM_32KB | OR_FCM_BCTLD | OR_FCM_CST |\ OR_FCM_CHT | OR_FCM_SCY_1 | OR_FCM_RST |\ OR_FCM_TRLX | OR_FCM_EHTR)
#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_NAND_BASE -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000E +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_32KB)
/* * Serial Port @@ -409,7 +411,7 @@ /* DDR: cache cacheable */ #define CONFIG_SYS_SDRAM CONFIG_SYS_SDRAM_BASE
-#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM | BATL_PP_10 |\ +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM | BATL_PP_RW |\ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM | BATU_BL_256M | BATU_VS |\ BATU_VP) @@ -423,7 +425,7 @@ #define CONFIG_SYS_DBAT1U CONFIG_SYS_IBAT1U
/* IMMRBAR, PCI IO and NAND: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_IMMR | BATL_PP_10 |\ +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_IMMR | BATL_PP_RW |\ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_IMMR | BATU_BL_8M | BATU_VS |\ BATU_VP) @@ -437,23 +439,23 @@ #define CONFIG_SYS_DBAT3U CONFIG_SYS_IBAT3U
/* FLASH: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 |\ +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW |\ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_FLASH_BASE | BATU_BL_64M |\ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT4L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT4L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT4U CONFIG_SYS_IBAT4U
/* Stack in dcache: cacheable, no memory coherence */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10) +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_RW) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_INIT_RAM_ADDR | BATU_BL_128K |\ BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT5L CONFIG_SYS_IBAT5L #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U
/* PCI MEM space: cacheable */ -#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI_MEM_PHYS | BATL_PP_10 |\ +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI_MEM_PHYS | BATL_PP_RW |\ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI_MEM_PHYS | BATU_BL_256M |\ BATU_VS | BATU_VP) @@ -461,7 +463,7 @@ #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U
/* PCI MMIO space: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI_MMIO_PHYS | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI_MMIO_PHYS | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT7U (CONFIG_SYS_PCI_MMIO_PHYS | BATU_BL_256M |\ BATU_VS | BATU_VP) diff --git a/include/configs/MPC8308RDB.h b/include/configs/MPC8308RDB.h index 3ff175c..1e50194 100644 --- a/include/configs/MPC8308RDB.h +++ b/include/configs/MPC8308RDB.h @@ -149,7 +149,8 @@
#define CONFIG_SYS_DDR_CS0_BNDS 0x00000007 #define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN \ - | 0x00010000 /* ODT_WR to CSn */ \ + | CSCONFIG_ODT_RD_NEVER \ + | CSCONFIG_ODT_WR_ONLY_CURRENT \ | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10) /* 0x80010102 */ #define CONFIG_SYS_DDR_TIMING_3 0x00000000 @@ -184,7 +185,7 @@ /* 0x03600100 */ #define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SREN \ | SDRAM_CFG_SDRAM_TYPE_DDR2 \ - | SDRAM_CFG_32_BE) + | SDRAM_CFG_DBW_32) /* 0x43080000 */
#define CONFIG_SYS_DDR_SDRAM_CFG2 0x00401000 /* 1 posted refresh */ @@ -240,17 +241,18 @@
#define CONFIG_SYS_BR0_PRELIM (\ CONFIG_SYS_FLASH_BASE /* Flash Base address */ |\ - (2 << BR_PS_SHIFT) /* 16 bit port size */ |\ + BR_PS_16 /* 16 bit port size */ |\ + BR_MS_GPCM /* MSEL = GPCM */ |\ BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) \ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ | OR_UPM_XAM \ | OR_GPCM_CSNT \ | OR_GPCM_ACS_DIV2 \ | OR_GPCM_XACS \ | OR_GPCM_SCY_15 \ - | OR_GPCM_TRLX \ - | OR_GPCM_EHTR \ - | OR_GPCM_EAD) + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + /* [RFC]EAD is reserved on MPC8308: | OR_GPCM_EAD */)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ /* 127 64KB sectors and 8 8KB top sectors per device */ @@ -263,12 +265,13 @@ * NAND Flash on the Local Bus */ #define CONFIG_SYS_NAND_BASE 0xE0600000 /* 0xE0600000 */ +#define CONFIG_SYS_NAND_WINDOW_SIZE (32 * 1024) /* 0x00008000 */ #define CONFIG_SYS_BR1_PRELIM ( CONFIG_SYS_NAND_BASE \ - | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ + | BR_DECC_CHK_GEN /* Use HW ECC */ \ | BR_PS_8 /* Port Size = 8 bit */ \ | BR_MS_FCM /* MSEL = FCM */ \ | BR_V ) /* valid */ -#define CONFIG_SYS_OR1_PRELIM ( 0xFFFF8000 /* length 32K */ \ +#define CONFIG_SYS_OR1_PRELIM ( P2SZ_TO_AM(CONFIG_SYS_NAND_WINDOW_SIZE) \ | OR_FCM_CSCT \ | OR_FCM_CST \ | OR_FCM_CHT \ @@ -282,9 +285,22 @@
#ifdef CONFIG_VSC7385_ENET #define CONFIG_TSEC2 -#define CONFIG_SYS_VSC7385_BASE 0xF0000000 -#define CONFIG_SYS_BR2_PRELIM 0xf0000801 /* VSC7385 Base address */ -#define CONFIG_SYS_OR2_PRELIM 0xfffe09ff /* VSC7385, 128K bytes*/ +#define CONFIG_SYS_VSC7385_BASE 0xF0000000 /* VSC7385 Base address */ +#define CONFIG_SYS_VSC7385_SIZE (128 * 1024) /* 0x00020000 */ +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_VSC7385_BASE /* VSC7385 Base address on CS2 */ \ + | BR_PS_8 /* Port Size = 8 bit */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ + /* 0xF0000801 */ +#define CONFIG_SYS_OR2_PRELIM (P2SZ_TO_AM(CONFIG_SYS_VSC7385_SIZE) \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_SETA \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + /* [RFC]EAD is reserved on MPC8308: | OR_GPCM_EAD */) + /* 0xFFFE09FF */ /* Access window base at VSC7385 base */ #define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_VSC7385_BASE /* Access window size 128K */ @@ -464,7 +480,7 @@ */
/* DDR: cache cacheable */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_128M | \ BATU_VS | BATU_VP) @@ -472,7 +488,7 @@ #define CONFIG_SYS_DBAT0U CONFIG_SYS_IBAT0U
/* IMMRBAR, PCI IO and NAND: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_IMMR | BATU_BL_8M | BATU_VS | \ BATU_VP) @@ -480,17 +496,17 @@ #define CONFIG_SYS_DBAT1U CONFIG_SYS_IBAT1U
/* FLASH: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_FLASH_BASE | BATU_BL_8M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | \ BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT2U CONFIG_SYS_IBAT2U
/* Stack in dcache: cacheable, no memory coherence */ -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_RW) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_INIT_RAM_ADDR | BATU_BL_128K | \ BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT3L CONFIG_SYS_IBAT3L diff --git a/include/configs/MPC8313ERDB.h b/include/configs/MPC8313ERDB.h index 92c54d0..046fe0a 100644 --- a/include/configs/MPC8313ERDB.h +++ b/include/configs/MPC8313ERDB.h @@ -131,7 +131,8 @@ */ #define CONFIG_SYS_DDR_SIZE 128 /* MB */ #define CONFIG_SYS_DDR_CONFIG ( CSCONFIG_EN \ - | 0x00010000 /* TODO */ \ + | CSCONFIG_ODT_RD_NEVER \ + | CSCONFIG_ODT_WR_ONLY_CURRENT \ | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10 ) /* 0x80010102 */
@@ -168,12 +169,13 @@ #if defined(CONFIG_DDR_2T_TIMING) #define CONFIG_SYS_SDRAM_CFG ( SDRAM_CFG_SREN \ | SDRAM_CFG_SDRAM_TYPE_DDR2 \ - | SDRAM_CFG_2T_EN \ - | SDRAM_CFG_DBW_32 ) + | SDRAM_CFG_DBW_32 \ + | SDRAM_CFG_2T_EN ) + /* 0x43088000 */ #else #define CONFIG_SYS_SDRAM_CFG ( SDRAM_CFG_SREN \ | SDRAM_CFG_SDRAM_TYPE_DDR2 \ - | SDRAM_CFG_32_BE ) + | SDRAM_CFG_DBW_32 ) /* 0x43080000 */ #endif #define CONFIG_SYS_SDRAM_CFG2 0x00401000 @@ -202,16 +204,17 @@ #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE /* buffer up multiple bytes */
#define CONFIG_SYS_NOR_BR_PRELIM (CONFIG_SYS_FLASH_BASE | /* flash Base address */ \ - (2 << BR_PS_SHIFT) | /* 16 bit port size */ \ + BR_PS_16 | /* 16 bit port size */ \ + BR_MS_GPCM | /* MSEL = GPCM */ \ BR_V) /* valid */ -#define CONFIG_SYS_NOR_OR_PRELIM ( 0xFF800000 /* 8 MByte */ \ +#define CONFIG_SYS_NOR_OR_PRELIM ( MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) /* 8 MByte */ \ | OR_GPCM_XACS \ | OR_GPCM_SCY_9 \ | OR_GPCM_EHTR \ | OR_GPCM_EAD ) /* 0xFF006FF7 TODO SLOW 16 MB flash size */ #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE /* window base at flash base */ -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000017 /* 16 MB window size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_16MB) /* 16 MB window size */
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 135 /* sectors per device */ @@ -264,14 +267,15 @@ #define CONFIG_CMD_NAND 1 #define CONFIG_NAND_FSL_ELBC 1 #define CONFIG_SYS_NAND_BLOCK_SIZE 16384 +#define CONFIG_SYS_NAND_WINDOW_SIZE (32 * 1024)
#define CONFIG_SYS_NAND_BR_PRELIM ( CONFIG_SYS_NAND_BASE \ - | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ + | BR_DECC_CHK_GEN /* Use HW ECC */ \ | BR_PS_8 /* Port Size = 8 bit */ \ | BR_MS_FCM /* MSEL = FCM */ \ | BR_V ) /* valid */ -#define CONFIG_SYS_NAND_OR_PRELIM ( 0xFFFF8000 /* length 32K */ \ +#define CONFIG_SYS_NAND_OR_PRELIM ( P2SZ_TO_AM(CONFIG_SYS_NAND_WINDOW_SIZE) \ | OR_FCM_CSCT \ | OR_FCM_CST \ | OR_FCM_CHT \ @@ -293,27 +297,53 @@ #endif
#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_NAND_BASE -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000E /* 32KB */ +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_32KB)
#define CONFIG_SYS_NAND_LBLAWBAR_PRELIM CONFIG_SYS_LBLAWBAR1_PRELIM #define CONFIG_SYS_NAND_LBLAWAR_PRELIM CONFIG_SYS_LBLAWAR1_PRELIM
-/* local bus read write buffer mapping */ -#define CONFIG_SYS_BR3_PRELIM 0xFA000801 /* map at 0xFA000000 */ -#define CONFIG_SYS_OR3_PRELIM 0xFFFF8FF7 /* 32kB */ -#define CONFIG_SYS_LBLAWBAR3_PRELIM 0xFA000000 -#define CONFIG_SYS_LBLAWAR3_PRELIM 0x8000000E /* 32KB */ +/* local bus write LED / read status buffer (BCSR) mapping */ +#define CONFIG_SYS_BCSR_ADDR 0xFA000000 +#define CONFIG_SYS_BCSR_SIZE (32 * 1024) /* 0x00008000 */ +#define CONFIG_SYS_BR3_PRELIM (CONFIG_SYS_BCSR_ADDR /* map at 0xFA000000 on LCS3 */ \ + | BR_PS_8 /* Port Size = 8 bit */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ + /* 0xFA000801 */ +#define CONFIG_SYS_OR3_PRELIM (P2SZ_TO_AM(CONFIG_SYS_BCSR_SIZE) \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xFFFF8FF7 */ +#define CONFIG_SYS_LBLAWBAR3_PRELIM CONFIG_SYS_BCSR_ADDR +#define CONFIG_SYS_LBLAWAR3_PRELIM (LBLAWAR_EN | LBLAWAR_32KB)
/* Vitesse 7385 */
-#define CONFIG_SYS_VSC7385_BASE 0xF0000000 - #ifdef CONFIG_VSC7385_ENET
-#define CONFIG_SYS_BR2_PRELIM 0xf0000801 /* VSC7385 Base address */ -#define CONFIG_SYS_OR2_PRELIM 0xfffe09ff /* VSC7385, 128K bytes*/ +#define CONFIG_SYS_VSC7385_BASE 0xF0000000 /* VSC7385 Base address */ +#define CONFIG_SYS_VSC7385_SIZE (128 * 1024) /* 0x00020000 */ + +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_VSC7385_BASE/* VSC7385 Base address on LCS2 */ \ + | BR_PS_8 /* Port Size = 8 bit */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR2_PRELIM (P2SZ_TO_AM(CONFIG_SYS_VSC7385_SIZE) \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_SETA \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xFFFE09FF */ #define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_VSC7385_BASE/* Access window base at VSC7385 base */ -#define CONFIG_SYS_LBLAWAR2_PRELIM 0x80000010 /* Access window size 128K */ +#define CONFIG_SYS_LBLAWAR2_PRELIM (LBLAWAR_EN | LBLAWAR_128KB)
#endif
@@ -547,13 +577,13 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR @ 0x00000000 */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | BATU_VS | BATU_VP)
/* PCI @ 0x80000000 */ -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10) +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_RW) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_RW | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP)
/* PCI2 not supported on 8313 */ @@ -563,11 +593,11 @@ #define CONFIG_SYS_IBAT4U (0)
/* IMMRBAR @ 0xE0000000, PCI IO @ 0xE2000000 & BCSR @ 0xE2400000 */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR | BATL_PP_RW | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_IMMR | BATU_BL_256M | BATU_VS | BATU_VP)
/* SDRAM @ 0xF0000000, stack in DCACHE 0xFDF00000 & FLASH @ 0xFE000000 */ -#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_10 | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_RW | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT6U (0xF0000000 | BATU_BL_256M | BATU_VS | BATU_VP)
#define CONFIG_SYS_IBAT7L (0) diff --git a/include/configs/MPC8315ERDB.h b/include/configs/MPC8315ERDB.h index a0cfd00..c2a38d0 100644 --- a/include/configs/MPC8315ERDB.h +++ b/include/configs/MPC8315ERDB.h @@ -141,7 +141,8 @@ #define CONFIG_SYS_DDR_SIZE 128 /* MB */ #define CONFIG_SYS_DDR_CS0_BNDS 0x00000007 #define CONFIG_SYS_DDR_CS0_CONFIG ( CSCONFIG_EN \ - | 0x00010000 /* ODT_WR to CSn */ \ + | CSCONFIG_ODT_RD_NEVER \ + | CSCONFIG_ODT_WR_ONLY_CURRENT \ | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10 ) /* 0x80010102 */ #define CONFIG_SYS_DDR_TIMING_3 0x00000000 @@ -176,7 +177,7 @@ /* 0x03600100 */ #define CONFIG_SYS_DDR_SDRAM_CFG ( SDRAM_CFG_SREN \ | SDRAM_CFG_SDRAM_TYPE_DDR2 \ - | SDRAM_CFG_32_BE ) + | SDRAM_CFG_DBW_32 ) /* 0x43080000 */ #define CONFIG_SYS_DDR_SDRAM_CFG2 0x00401000 /* 1 posted refresh */ #define CONFIG_SYS_DDR_MODE ( ( 0x0448 << SDRAM_MODE_ESD_SHIFT ) \ @@ -225,19 +226,20 @@ #define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */
#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE /* Window base at flash base */ -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000016 /* 8MB window size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_8MB)
#define CONFIG_SYS_NOR_BR_PRELIM (CONFIG_SYS_FLASH_BASE \ - | (2 << BR_PS_SHIFT) /* 16 bit port size */ \ + | BR_PS_16 /* 16 bit port size */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ | BR_V ) /* valid */ -#define CONFIG_SYS_NOR_OR_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) \ +#define CONFIG_SYS_NOR_OR_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ | OR_UPM_XAM \ | OR_GPCM_CSNT \ | OR_GPCM_ACS_DIV2 \ | OR_GPCM_XACS \ | OR_GPCM_SCY_15 \ - | OR_GPCM_TRLX \ - | OR_GPCM_EHTR \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ | OR_GPCM_EAD )
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ @@ -268,20 +270,21 @@ #define CONFIG_MTD_NAND_VERIFY_WRITE 1 #define CONFIG_CMD_NAND 1 #define CONFIG_NAND_FSL_ELBC 1 -#define CONFIG_SYS_NAND_BLOCK_SIZE 16384 +#define CONFIG_SYS_NAND_BLOCK_SIZE 16384 +#define CONFIG_SYS_NAND_WINDOW_SIZE (32 * 1024)
-#define CONFIG_SYS_NAND_U_BOOT_SIZE (512 << 10) -#define CONFIG_SYS_NAND_U_BOOT_DST 0x00100000 -#define CONFIG_SYS_NAND_U_BOOT_START 0x00100100 -#define CONFIG_SYS_NAND_U_BOOT_OFFS 16384 -#define CONFIG_SYS_NAND_U_BOOT_RELOC 0x00010000 +#define CONFIG_SYS_NAND_U_BOOT_SIZE (512 << 10) +#define CONFIG_SYS_NAND_U_BOOT_DST 0x00100000 +#define CONFIG_SYS_NAND_U_BOOT_START 0x00100100 +#define CONFIG_SYS_NAND_U_BOOT_OFFS 16384 +#define CONFIG_SYS_NAND_U_BOOT_RELOC 0x00010000
#define CONFIG_SYS_NAND_BR_PRELIM (CONFIG_SYS_NAND_BASE \ - | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ + | BR_DECC_CHK_GEN /* Use HW ECC */ \ | BR_PS_8 /* Port Size = 8 bit */ \ | BR_MS_FCM /* MSEL = FCM */ \ | BR_V ) /* valid */ -#define CONFIG_SYS_NAND_OR_PRELIM (0xFFFF8000 /* length 32K */ \ +#define CONFIG_SYS_NAND_OR_PRELIM (P2SZ_TO_AM(CONFIG_SYS_NAND_WINDOW_SIZE) \ | OR_FCM_CSCT \ | OR_FCM_CST \ | OR_FCM_CHT \ @@ -303,7 +306,7 @@ #endif
#define CONFIG_SYS_NAND_LBLAWBAR_PRELIM CONFIG_SYS_LBLAWBAR1_PRELIM #define CONFIG_SYS_NAND_LBLAWAR_PRELIM CONFIG_SYS_LBLAWAR1_PRELIM @@ -569,40 +572,40 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR: cache cacheable */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_128M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT0L CONFIG_SYS_IBAT0L #define CONFIG_SYS_DBAT0U CONFIG_SYS_IBAT0U
/* IMMRBAR, PCI IO and NAND: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_IMMR | BATU_BL_8M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT1L CONFIG_SYS_IBAT1L #define CONFIG_SYS_DBAT1U CONFIG_SYS_IBAT1U
/* FLASH: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_FLASH_BASE | BATU_BL_32M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT2U CONFIG_SYS_IBAT2U
/* Stack in dcache: cacheable, no memory coherence */ -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_RW) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_INIT_RAM_ADDR | BATU_BL_128K | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT3L CONFIG_SYS_IBAT3L #define CONFIG_SYS_DBAT3U CONFIG_SYS_IBAT3U
/* PCI MEM space: cacheable */ -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI_MEM_PHYS | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI_MEM_PHYS | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_PCI_MEM_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT4L CONFIG_SYS_IBAT4L #define CONFIG_SYS_DBAT4U CONFIG_SYS_IBAT4U
/* PCI MMIO space: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_PCI_MMIO_PHYS | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_PCI_MMIO_PHYS | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_PCI_MMIO_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT5L CONFIG_SYS_IBAT5L diff --git a/include/configs/MPC8323ERDB.h b/include/configs/MPC8323ERDB.h index 4d4c758..c77ed61 100644 --- a/include/configs/MPC8323ERDB.h +++ b/include/configs/MPC8323ERDB.h @@ -62,7 +62,7 @@ /* * IMMR new address */ -#define CONFIG_SYS_IMMR 0xE0000000 +#define CONFIG_SYS_IMMR 0xE0000000
/* * System performance @@ -77,7 +77,13 @@ #define CONFIG_SYS_DDR_BASE 0x00000000 /* DDR is system memory */ #define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_BASE #define CONFIG_SYS_DDR_SDRAM_BASE CONFIG_SYS_DDR_BASE -#define CONFIG_SYS_DDRCDR 0x73000002 /* DDR II voltage is 1.8V */ +/* [RFC]This is not defined on the MPC8323: +#define CONFIG_SYS_DDRCDR ( DDRCDR_EN \ + | DDRCDR_PZ_NOMZ \ + | DDRCDR_NZ_NOMZ \ + | DDRCDR_M_ODR ) +*/ + /* 0x73000002 */ /* DDR II voltage is 1.8V */
#undef CONFIG_SPD_EEPROM #if defined(CONFIG_SPD_EEPROM) @@ -89,7 +95,7 @@ */ #define CONFIG_SYS_DDR_SIZE 64 /* MB */ #define CONFIG_SYS_DDR_CS0_CONFIG ( CSCONFIG_EN \ - | CSCONFIG_ODT_WR_ACS \ + /* [RFC]Reserved on MPC832x: | 0x00010000 */ \ | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_9 ) /* 0x80010101 */ #define CONFIG_SYS_DDR_TIMING_0 ( ( 0 << TIMING_CFG0_RWT_SHIFT ) \ @@ -177,18 +183,28 @@ * FLASH on the Local Bus */ #define CONFIG_SYS_FLASH_CFI /* use the Common Flash Interface */ -#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ +#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ #define CONFIG_SYS_FLASH_BASE 0xFE000000 /* FLASH base address */ -#define CONFIG_SYS_FLASH_SIZE 16 /* FLASH size is 16M */ +#define CONFIG_SYS_FLASH_SIZE 16 /* FLASH size is 16M */ #define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */
#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE /* Window base at flash base */ -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000018 /* 32MB window size */ - -#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | /* Flash Base address */ \ - (2 << BR_PS_SHIFT) | /* 16 bit port size */ \ - BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM 0xfe006ff7 /* 16MB Flash size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_32MB) + +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE /* Flash Base address */ \ + | BR_PS_16 /* 16 bit port size */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xFE006FF7 */
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 128 /* sectors per device */ @@ -196,68 +212,6 @@ #undef CONFIG_SYS_FLASH_CHECKSUM
/* - * SDRAM on the Local Bus - */ -#undef CONFIG_SYS_LB_SDRAM /* The board has not SRDAM on local bus */ - -#ifdef CONFIG_SYS_LB_SDRAM -#define CONFIG_SYS_LBC_SDRAM_BASE 0xF0000000 /* SDRAM base address */ -#define CONFIG_SYS_LBC_SDRAM_SIZE 64 /* LBC SDRAM is 64MB */ - -#define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_LBC_SDRAM_BASE -#define CONFIG_SYS_LBLAWAR2_PRELIM 0x80000019 /* 64MB */ - -/*local bus BR2, OR2 definition for SDRAM if soldered on the EPB board */ -/* - * Base Register 2 and Option Register 2 configure SDRAM. - * The SDRAM base address, CONFIG_SYS_LBC_SDRAM_BASE, is 0xf0000000. - * - * For BR2, need: - * Base address of 0xf0000000 = BR[0:16] = 1111 0000 0000 0000 0 - * port size = 32-bits = BR2[19:20] = 11 - * no parity checking = BR2[21:22] = 00 - * SDRAM for MSEL = BR2[24:26] = 011 - * Valid = BR[31] = 1 - * - * 0 4 8 12 16 20 24 28 - * 1111 0000 0000 0000 0001 1000 0110 0001 = f0001861 - * - * CONFIG_SYS_LBC_SDRAM_BASE should be masked and OR'ed into - * the top 17 bits of BR2. - */ - -#define CONFIG_SYS_BR2_PRELIM 0xf0001861 /*Port size=32bit, MSEL=SDRAM */ - -/* - * The SDRAM size in MB, CONFIG_SYS_LBC_SDRAM_SIZE, is 64. - * - * For OR2, need: - * 64MB mask for AM, OR2[0:7] = 1111 1100 - * XAM, OR2[17:18] = 11 - * 9 columns OR2[19-21] = 010 - * 13 rows OR2[23-25] = 100 - * EAD set for extra time OR[31] = 1 - * - * 0 4 8 12 16 20 24 28 - * 1111 1100 0000 0000 0110 1001 0000 0001 = fc006901 - */ - -#define CONFIG_SYS_OR2_PRELIM 0xfc006901 - -#define CONFIG_SYS_LBC_LSRT 0x32000000 /* LB sdram refresh timer, about 6us */ -#define CONFIG_SYS_LBC_MRTPR 0x20000000 /* LB refresh timer prescal, 266MHz/32 */ - -#define CONFIG_SYS_LBC_LSDMR_COMMON 0x0063b723 - -#endif - -/* - * Windows to access PIB via local bus - */ -#define CONFIG_SYS_LBLAWBAR3_PRELIM 0xf8008000 /* windows base 0xf8008000 */ -#define CONFIG_SYS_LBLAWAR3_PRELIM 0x8000000f /* windows size 64KB */ - -/* * Serial Port */ #define CONFIG_CONS_INDEX 1 @@ -447,22 +401,22 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR: cache cacheable */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT0L CONFIG_SYS_IBAT0L #define CONFIG_SYS_DBAT0U CONFIG_SYS_IBAT0U
/* IMMRBAR & PCI IO: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_IMMR | BATU_BL_4M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT1L CONFIG_SYS_IBAT1L #define CONFIG_SYS_DBAT1U CONFIG_SYS_IBAT1U
/* FLASH: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_FLASH_BASE | BATU_BL_32M | BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT2U CONFIG_SYS_IBAT2U
@@ -472,19 +426,19 @@ #define CONFIG_SYS_DBAT3U CONFIG_SYS_IBAT3U
/* Stack in dcache: cacheable, no memory coherence */ -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10) +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_RW) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_INIT_RAM_ADDR | BATU_BL_128K | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT4L CONFIG_SYS_IBAT4L #define CONFIG_SYS_DBAT4U CONFIG_SYS_IBAT4U
#ifdef CONFIG_PCI /* PCI MEM space: cacheable */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_PCI1_MEM_PHYS | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_PCI1_MEM_PHYS | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_PCI1_MEM_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT5L CONFIG_SYS_IBAT5L #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U /* PCI MMIO space: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI1_MMIO_PHYS | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI1_MMIO_PHYS | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI1_MMIO_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT6L CONFIG_SYS_IBAT6L diff --git a/include/configs/MPC832XEMDS.h b/include/configs/MPC832XEMDS.h index f136a8e..785d51e 100644 --- a/include/configs/MPC832XEMDS.h +++ b/include/configs/MPC832XEMDS.h @@ -111,17 +111,53 @@ /* Manually set up DDR parameters */ #define CONFIG_SYS_DDR_SIZE 128 /* MB */ -#define CONFIG_SYS_DDR_CS0_CONFIG 0x80840102 -#define CONFIG_SYS_DDR_TIMING_0 0x00220802 -#define CONFIG_SYS_DDR_TIMING_1 0x3935d322 -#define CONFIG_SYS_DDR_TIMING_2 0x0f9048ca -#define CONFIG_SYS_DDR_TIMING_3 0x00000000 -#define CONFIG_SYS_DDR_CLK_CNTL 0x02000000 -#define CONFIG_SYS_DDR_MODE 0x44400232 +#define CONFIG_SYS_DDR_CS0_CONFIG ( CSCONFIG_EN \ + | CSCONFIG_AP \ + | CSCONFIG_ODT_WR_CFG \ + | CSCONFIG_ROW_BIT_13 \ + | CSCONFIG_COL_BIT_10) + /* 0x80840102 */ +#define CONFIG_SYS_DDR_TIMING_0 ( (0 << TIMING_CFG0_RWT_SHIFT) \ + | (0 << TIMING_CFG0_WRT_SHIFT) \ + | (0 << TIMING_CFG0_RRT_SHIFT) \ + | (0 << TIMING_CFG0_WWT_SHIFT) \ + | (2 << TIMING_CFG0_ACT_PD_EXIT_SHIFT) \ + | (2 << TIMING_CFG0_PRE_PD_EXIT_SHIFT) \ + | (8 << TIMING_CFG0_ODT_PD_EXIT_SHIFT) \ + | (2 << TIMING_CFG0_MRS_CYC_SHIFT) ) + /* 0x00220802 */ +#define CONFIG_SYS_DDR_TIMING_1 ( (3 << TIMING_CFG1_PRETOACT_SHIFT) \ + | (9 << TIMING_CFG1_ACTTOPRE_SHIFT) \ + | (3 << TIMING_CFG1_ACTTORW_SHIFT) \ + | (5 << TIMING_CFG1_CASLAT_SHIFT) \ + | (13 << TIMING_CFG1_REFREC_SHIFT) \ + | (3 << TIMING_CFG1_WRREC_SHIFT) \ + | (2 << TIMING_CFG1_ACTTOACT_SHIFT) \ + | (2 << TIMING_CFG1_WRTORD_SHIFT)) + /* 0x3935D322 */ +#define CONFIG_SYS_DDR_TIMING_2 ( (0 << TIMING_CFG2_ADD_LAT_SHIFT) \ + | (31 << TIMING_CFG2_CPO_SHIFT) \ + | (2 << TIMING_CFG2_WR_LAT_DELAY_SHIFT) \ + | (2 << TIMING_CFG2_RD_TO_PRE_SHIFT) \ + | (2 << TIMING_CFG2_WR_DATA_DELAY_SHIFT) \ + | (3 << TIMING_CFG2_CKE_PLS_SHIFT) \ + | (10 << TIMING_CFG2_FOUR_ACT_SHIFT)) + /* 0x0F9048CA */ +#define CONFIG_SYS_DDR_TIMING_3 0x00000000 +#define CONFIG_SYS_DDR_CLK_CNTL DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05 + /* 0x02000000 */ +#define CONFIG_SYS_DDR_MODE ((0x4440 << SDRAM_MODE_ESD_SHIFT) \ + | (0x0232 << SDRAM_MODE_SD_SHIFT)) + /* 0x44400232 */ #define CONFIG_SYS_DDR_MODE2 0x8000c000 -#define CONFIG_SYS_DDR_INTERVAL 0x03200064 -#define CONFIG_SYS_DDR_CS0_BNDS 0x00000007 -#define CONFIG_SYS_DDR_SDRAM_CFG 0x43080000 +#define CONFIG_SYS_DDR_INTERVAL ((800 << SDRAM_INTERVAL_REFINT_SHIFT) \ + | (100 << SDRAM_INTERVAL_BSTOPRE_SHIFT)) + /* 0x03200064 */ +#define CONFIG_SYS_DDR_CS0_BNDS 0x00000007 +#define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SREN \ + | SDRAM_CFG_SDRAM_TYPE_DDR2 \ + | SDRAM_CFG_32_BE) + /* 0x43080000 */ #define CONFIG_SYS_DDR_SDRAM_CFG2 0x00401000 #endif
@@ -172,12 +208,22 @@ #define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */
#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE /* Window base at flash base */ -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000018 /* 32MB window size */ - -#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | /* Flash Base address */ \ - (2 << BR_PS_SHIFT) | /* 16 bit port size */ \ - BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM 0xfe006ff7 /* 16MB Flash size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_32MB) + +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE /* Flash Base address */ \ + | BR_PS_16 /* 16 bit port size */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xfe006ff7 */
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 128 /* sectors per device */ @@ -185,88 +231,69 @@ #undef CONFIG_SYS_FLASH_CHECKSUM
/* - * BCSR on the Local Bus + * Status buffer (BCSR) on the Local Bus */ -#define CONFIG_SYS_BCSR 0xF8000000 +#define CONFIG_SYS_BCSR 0xF8000000 #define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_BCSR /* Access window base at BCSR base */ -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000E /* Access window size 32K */ - -#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR|0x00000801) /* Port size=8bit, MSEL=GPCM */ -#define CONFIG_SYS_OR1_PRELIM 0xFFFFE9f7 /* length 32K */ - -/* - * SDRAM on the Local Bus - */ -#undef CONFIG_SYS_LB_SDRAM /* The board has not SRDAM on local bus */ - -#ifdef CONFIG_SYS_LB_SDRAM -#define CONFIG_SYS_LBC_SDRAM_BASE 0xF0000000 /* SDRAM base address */ -#define CONFIG_SYS_LBC_SDRAM_SIZE 64 /* LBC SDRAM is 64MB */ - -#define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_LBC_SDRAM_BASE -#define CONFIG_SYS_LBLAWAR2_PRELIM 0x80000019 /* 64MB */ - -/*local bus BR2, OR2 definition for SDRAM if soldered on the EPB board */ -/* - * Base Register 2 and Option Register 2 configure SDRAM. - * The SDRAM base address, CONFIG_SYS_LBC_SDRAM_BASE, is 0xf0000000. - * - * For BR2, need: - * Base address of 0xf0000000 = BR[0:16] = 1111 0000 0000 0000 0 - * port size = 32-bits = BR2[19:20] = 11 - * no parity checking = BR2[21:22] = 00 - * SDRAM for MSEL = BR2[24:26] = 011 - * Valid = BR[31] = 1 - * - * 0 4 8 12 16 20 24 28 - * 1111 0000 0000 0000 0001 1000 0110 0001 = f0001861 - * - * CONFIG_SYS_LBC_SDRAM_BASE should be masked and OR'ed into - * the top 17 bits of BR2. - */ - -#define CONFIG_SYS_BR2_PRELIM 0xf0001861 /*Port size=32bit, MSEL=SDRAM */ - -/* - * The SDRAM size in MB, CONFIG_SYS_LBC_SDRAM_SIZE, is 64. - * - * For OR2, need: - * 64MB mask for AM, OR2[0:7] = 1111 1100 - * XAM, OR2[17:18] = 11 - * 9 columns OR2[19-21] = 010 - * 13 rows OR2[23-25] = 100 - * EAD set for extra time OR[31] = 1 - * - * 0 4 8 12 16 20 24 28 - * 1111 1100 0000 0000 0110 1001 0000 0001 = fc006901 - */ - -#define CONFIG_SYS_OR2_PRELIM 0xfc006901 - -#define CONFIG_SYS_LBC_LSRT 0x32000000 /* LB sdram refresh timer, about 6us */ -#define CONFIG_SYS_LBC_MRTPR 0x20000000 /* LB refresh timer prescal, 266MHz/32 */ - -#define CONFIG_SYS_LBC_LSDMR_COMMON 0x0063b723 - -#endif +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_32KB) + +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR \ + | BR_PS_8 \ + | BR_MS_GPCM \ + | BR_V) +#define CONFIG_SYS_OR1_PRELIM (OR_AM_32KB \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xFFFFE9F7 */
/* - * Windows to access PIB via local bus + * Windows to access Platform I/O Boards (PIB) via local bus */ -#define CONFIG_SYS_LBLAWBAR3_PRELIM 0xf8008000 /* windows base 0xf8008000 */ -#define CONFIG_SYS_LBLAWAR3_PRELIM 0x8000000f /* windows size 64KB */ +#define CONFIG_SYS_PIB_BASE 0xF8008000 /* PIB window base 0xF8008000 */ +#define CONFIG_SYS_PIB_WINDOW_SIZE (32 * 1024) +#define CONFIG_SYS_LBLAWBAR3_PRELIM CONFIG_SYS_PIB_BASE +#define CONFIG_SYS_LBLAWAR3_PRELIM (LBLAWAR_EN | LBLAWAR_64KB)
/* * CS2 on Local Bus, to PIB */ -#define CONFIG_SYS_BR2_PRELIM 0xf8008801 /* CS2 base address at 0xf8008000 */ -#define CONFIG_SYS_OR2_PRELIM 0xffffe9f7 /* size 32KB, port size 8bit, GPCM */ +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_PIB_BASE \ + | BR_PS_8 \ + | BR_MS_GPCM \ + | BR_V) + /* 0xF8008801 */ +#define CONFIG_SYS_OR2_PRELIM (P2SZ_TO_AM(CONFIG_SYS_PIB_WINDOW_SIZE) \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xffffe9f7 */
/* * CS3 on Local Bus, to PIB */ -#define CONFIG_SYS_BR3_PRELIM 0xf8010801 /* CS3 base address at 0xf8010000 */ -#define CONFIG_SYS_OR3_PRELIM 0xffffe9f7 /* size 32KB, port size 8bit, GPCM */ +#define CONFIG_SYS_BR3_PRELIM ((CONFIG_SYS_PIB_BASE + CONFIG_SYS_PIB_WINDOW_SIZE) \ + | BR_PS_8 \ + | BR_MS_GPCM \ + | BR_V) + /* 0xF8010801 */ +#define CONFIG_SYS_OR3_PRELIM (P2SZ_TO_AM(CONFIG_SYS_PIB_WINDOW_SIZE) \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xffffe9f7 */
/* * Serial Port @@ -465,29 +492,29 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* BCSR: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_BCSR | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_BCSR | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_BCSR | BATU_BL_128K | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT2L CONFIG_SYS_IBAT2L #define CONFIG_SYS_DBAT2U CONFIG_SYS_IBAT2U
/* FLASH: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_FLASH_BASE | BATU_BL_32M | BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT3L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT3L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT3U CONFIG_SYS_IBAT3U
@@ -497,19 +524,19 @@ #define CONFIG_SYS_DBAT4U CONFIG_SYS_IBAT4U
/* Stack in dcache: cacheable, no memory coherence */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10) +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_RW) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_INIT_RAM_ADDR | BATU_BL_128K | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT5L CONFIG_SYS_IBAT5L #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U
#ifdef CONFIG_PCI /* PCI MEM space: cacheable */ -#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI1_MEM_PHYS | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI1_MEM_PHYS | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI1_MEM_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT6L CONFIG_SYS_IBAT6L #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U /* PCI MMIO space: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI1_MMIO_PHYS | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI1_MMIO_PHYS | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT7U (CONFIG_SYS_PCI1_MMIO_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT7L CONFIG_SYS_IBAT7L diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index 45b6b5f..7dcb55a 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -113,24 +113,24 @@ #define CONFIG_SYS_DDR_SIZE 256 /* MB */ #if defined(CONFIG_DDR_II) #define CONFIG_SYS_DDRCDR 0x80080001 -#define CONFIG_SYS_DDR_CS2_BNDS 0x0000000f +#define CONFIG_SYS_DDR_CS2_BNDS 0x0000000f #define CONFIG_SYS_DDR_CS2_CONFIG 0x80330102 -#define CONFIG_SYS_DDR_TIMING_0 0x00220802 -#define CONFIG_SYS_DDR_TIMING_1 0x38357322 -#define CONFIG_SYS_DDR_TIMING_2 0x2f9048c8 -#define CONFIG_SYS_DDR_TIMING_3 0x00000000 -#define CONFIG_SYS_DDR_CLK_CNTL 0x02000000 +#define CONFIG_SYS_DDR_TIMING_0 0x00220802 +#define CONFIG_SYS_DDR_TIMING_1 0x38357322 +#define CONFIG_SYS_DDR_TIMING_2 0x2f9048c8 +#define CONFIG_SYS_DDR_TIMING_3 0x00000000 +#define CONFIG_SYS_DDR_CLK_CNTL 0x02000000 #define CONFIG_SYS_DDR_MODE 0x47d00432 #define CONFIG_SYS_DDR_MODE2 0x8000c000 -#define CONFIG_SYS_DDR_INTERVAL 0x03cf0080 +#define CONFIG_SYS_DDR_INTERVAL 0x03cf0080 #define CONFIG_SYS_DDR_SDRAM_CFG 0x43000000 #define CONFIG_SYS_DDR_SDRAM_CFG2 0x00401000 #else #define CONFIG_SYS_DDR_CONFIG (CSCONFIG_EN | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10) -#define CONFIG_SYS_DDR_TIMING_1 0x36332321 -#define CONFIG_SYS_DDR_TIMING_2 0x00000800 /* P9-45,may need tuning */ +#define CONFIG_SYS_DDR_TIMING_1 0x36332321 +#define CONFIG_SYS_DDR_TIMING_2 0x00000800 /* P9-45,may need tuning */ #define CONFIG_SYS_DDR_CONTROL 0xc2000000 /* unbuffered,no DYN_PWR */ -#define CONFIG_SYS_DDR_INTERVAL 0x04060100 /* autocharge,no open page */ +#define CONFIG_SYS_DDR_INTERVAL 0x04060100 /* autocharge,no open page */
#if defined(CONFIG_DDR_32BIT) /* set burst length to 8 for 32-bit data path */ @@ -143,12 +143,6 @@ #endif
/* - * SDRAM on the Local Bus - */ -#define CONFIG_SYS_LBC_SDRAM_BASE 0xF0000000 /* Localbus SDRAM */ -#define CONFIG_SYS_LBC_SDRAM_SIZE 64 /* LBC SDRAM is 64MB */ - -/* * FLASH on the Local Bus */ #define CONFIG_SYS_FLASH_CFI /* use the Common Flash Interface */ @@ -158,14 +152,21 @@ #define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */ /* #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE */
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | /* flash Base address */ \ - (2 << BR_PS_SHIFT) | /* 16 bit port size */ \ - BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) | OR_UPM_XAM | \ - OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | OR_GPCM_XACS | OR_GPCM_SCY_15 | \ - OR_GPCM_TRLX | OR_GPCM_EHTR | OR_GPCM_EAD) +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE /* flash base address */\ + | BR_PS_16 /* 16 bit port size */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ + | OR_UPM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE /* window base at flash base */ -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000018 /* 32 MB window size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_32MB)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 256 /* max sectors per device */ @@ -185,11 +186,21 @@ /* * BCSR register on local bus 32KB, 8-bit wide for MDS config reg */ -#define CONFIG_SYS_BCSR 0xE2400000 +#define CONFIG_SYS_BCSR 0xE2400000 #define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_BCSR /* Access window base at BCSR base */ -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000E /* Access window size 32K */ -#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR|0x00000801) /* Port-size=8bit, MSEL=GPCM */ -#define CONFIG_SYS_OR1_PRELIM 0xFFFFE8F0 /* length 32K */ +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_32KB)/* Access window size 32K */ +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR \ + | BR_PS_8 \ + | BR_MS_GPCM \ + | BR_V) + /* 0x00000801 */ +#define CONFIG_SYS_OR1_PRELIM (OR_AM_32KB \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_CLEAR \ + | OR_GPCM_EHTR_CLEAR) + /* 0xFFFFE8F0 */
#define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xFD000000 /* Initial RAM address */ @@ -209,7 +220,7 @@ */ #define CONFIG_SYS_LCRR_DBYP LCRR_DBYP #define CONFIG_SYS_LCRR_CLKDIV LCRR_CLKDIV_4 -#define CONFIG_SYS_LBC_LBCR 0x00000000 +#define CONFIG_SYS_LBC_LBCR 0x00000000
/* * The MPC834xEA MDS for 834xE rev3.1 may not be assembled SDRAM memory. @@ -217,6 +228,12 @@ */ #undef CONFIG_SYS_LB_SDRAM
+/* + * SDRAM on the Local Bus + */ +#define CONFIG_SYS_LBC_SDRAM_BASE 0xF0000000 /* Localbus SDRAM */ +#define CONFIG_SYS_LBC_SDRAM_SIZE 64 /* LBC SDRAM is 64MB */ + #ifdef CONFIG_SYS_LB_SDRAM /* Local bus BR2, OR2 definition for SDRAM if soldered on the MDS board */ /* @@ -232,14 +249,15 @@ * * 0 4 8 12 16 20 24 28 * 1111 0000 0000 0000 0001 1000 0110 0001 = F0001861 - * - * FIXME: CONFIG_SYS_LBC_SDRAM_BASE should be masked and OR'ed into - * FIXME: the top 17 bits of BR2. */
-#define CONFIG_SYS_BR2_PRELIM 0xF0001861 /* Port-size=32bit, MSEL=SDRAM */ -#define CONFIG_SYS_LBLAWBAR2_PRELIM 0xF0000000 -#define CONFIG_SYS_LBLAWAR2_PRELIM 0x80000019 /* 64M */ +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_LBC_SDRAM_BASE \ + | BR_PS_32 /* Port-size = 32bit */ \ + | BR_MS_SDRAM /* MSEL = SDRAM */ \ + | BR_V) /* Valid */ + /* 0xF0001861 */ +#define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_LBC_SDRAM_BASE +#define CONFIG_SYS_LBLAWAR2_PRELIM (LBLAWAR_EN | LBLAWAR_64MB)
/* * The SDRAM size in MB, CONFIG_SYS_LBC_SDRAM_SIZE, is 64. @@ -255,7 +273,12 @@ * 1111 1100 0000 0000 0110 1001 0000 0001 = FC006901 */
-#define CONFIG_SYS_OR2_PRELIM 0xFC006901 +#define CONFIG_SYS_OR2_PRELIM (OR_AM_64MB \ + | OR_SDRAM_XAM \ + | ((9 - OR_SDRAM_MIN_COLS) << OR_SDRAM_COLS_SHIFT) \ + | ((13 - OR_SDRAM_MIN_ROWS) << OR_SDRAM_ROWS_SHIFT) \ + | OR_SDRAM_EAD) + /* 0xFC006901 */
#define CONFIG_SYS_LBC_LSRT 0x32000000 /* LB sdram refresh timer, about 6us */ #define CONFIG_SYS_LBC_MRTPR 0x20000000 /* LB refresh timer prescal, 266MHz/32 */ @@ -611,14 +634,14 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR @ 0x00000000 */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | BATU_VS | BATU_VP)
/* PCI @ 0x80000000 */ #ifdef CONFIG_PCI -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_RW | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP) #else #define CONFIG_SYS_IBAT1L (0) @@ -628,9 +651,9 @@ #endif
#ifdef CONFIG_MPC83XX_PCI2 -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI2_MEM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI2_MEM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_PCI2_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI2_MMIO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI2_MMIO_BASE | BATL_PP_RW | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_PCI2_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP) #else #define CONFIG_SYS_IBAT3L (0) @@ -640,11 +663,11 @@ #endif
/* SDRAM @ 0xF0000000, stack in DCACHE 0xFDF00000 & FLASH @ 0xFE000000 */ -#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_10 | BATL_MEMCOHERENCE | \ +#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_RW | BATL_MEMCOHERENCE | \ BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT6U (0xF0000000 | BATU_BL_256M | BATU_VS | BATU_VP)
diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index de233ff..e32ab1c 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -227,7 +227,6 @@ boards, we say we have two, but don't display a message if we find only one. */ #define CONFIG_SYS_MAX_FLASH_BANKS 2 /* number of banks */ #define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE + 0x800000} #define CONFIG_SYS_FLASH_SIZE 16 /* FLASH size in MB */ -#define CONFIG_SYS_FLASH_SIZE_SHIFT 4 /* log2 of the above value */ #define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */
/* Vitesse 7385 */ @@ -248,12 +247,12 @@ boards, we say we have two, but don't display a message if we find only one. */
/* Flash */
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | BR_PS_16 | BR_V) -#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) | OR_UPM_XAM | \ +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | BR_PS_16 | BR_MS_GPCM | BR_V) +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) | OR_UPM_XAM | \ OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | OR_GPCM_XACS | OR_GPCM_SCY_15 | \ - OR_GPCM_TRLX | OR_GPCM_EHTR | OR_GPCM_EAD) + OR_GPCM_TRLX_SET | OR_GPCM_EHTR_SET | OR_GPCM_EAD) #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | (0x13 + CONFIG_SYS_FLASH_SIZE_SHIFT)) +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_16MB)
/* Vitesse 7385 */
@@ -261,10 +260,10 @@ boards, we say we have two, but don't display a message if we find only one. */
-#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_VSC7385_BASE | BR_PS_8 | BR_V) +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_VSC7385_BASE | BR_PS_8 | BR_MS_GPCM | BR_V) #define CONFIG_SYS_OR1_PRELIM (OR_AM_128KB | OR_GPCM_CSNT | OR_GPCM_XACS | \ - OR_GPCM_SCY_15 | OR_GPCM_SETA | OR_GPCM_TRLX | \ - OR_GPCM_EHTR | OR_GPCM_EAD) + OR_GPCM_SCY_15 | OR_GPCM_SETA | OR_GPCM_TRLX_SET | \ + OR_GPCM_EHTR_SET | OR_GPCM_EAD)
#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_VSC7385_BASE #define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_128KB) @@ -274,10 +273,10 @@ boards, we say we have two, but don't display a message if we find only one. */ /* LED */
#define CONFIG_SYS_LED_BASE 0xF9000000 -#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_LED_BASE | BR_PS_8 | BR_V) +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_LED_BASE | BR_PS_8 | BR_MS_GPCM | BR_V) #define CONFIG_SYS_OR2_PRELIM (OR_AM_2MB | OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | \ - OR_GPCM_XACS | OR_GPCM_SCY_9 | OR_GPCM_TRLX | \ - OR_GPCM_EHTR | OR_GPCM_EAD) + OR_GPCM_XACS | OR_GPCM_SCY_9 | OR_GPCM_TRLX_SET | \ + OR_GPCM_EHTR_SET | OR_GPCM_EAD)
/* Compact Flash */
@@ -606,14 +605,14 @@ boards, we say we have two, but don't display a message if we find only one. */ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | BATU_VS | BATU_VP)
/* PCI */ #ifdef CONFIG_PCI -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_RW | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP) #else #define CONFIG_SYS_IBAT1L 0 @@ -623,9 +622,9 @@ boards, we say we have two, but don't display a message if we find only one. */ #endif
#ifdef CONFIG_MPC83XX_PCI2 -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI2_MEM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI2_MEM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_PCI2_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI2_MMIO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI2_MMIO_BASE | BATL_PP_RW | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_PCI2_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP) #else #define CONFIG_SYS_IBAT3L 0 @@ -635,11 +634,11 @@ boards, we say we have two, but don't display a message if we find only one. */ #endif
diff --git a/include/configs/MPC8360EMDS.h b/include/configs/MPC8360EMDS.h index 49d64a5..b275486 100644 --- a/include/configs/MPC8360EMDS.h +++ b/include/configs/MPC8360EMDS.h @@ -106,7 +106,7 @@ #define CONFIG_SYS_SDRAM_BASE2 (CONFIG_SYS_SDRAM_BASE + 0x10000000) /* + 256M */ #define CONFIG_SYS_DDR_SDRAM_BASE CONFIG_SYS_DDR_BASE #define CONFIG_SYS_DDR_SDRAM_CLK_CNTL (DDR_SDRAM_CLK_CNTL_SS_EN | \ - DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05) + DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05)
#define CONFIG_SYS_83XX_DDR_USES_CS0
@@ -131,25 +131,25 @@ #define CONFIG_SYS_DDR_SIZE 256 /* MB */ #if defined(CONFIG_DDR_II) #define CONFIG_SYS_DDRCDR 0x80080001 -#define CONFIG_SYS_DDR_CS0_BNDS 0x0000000f +#define CONFIG_SYS_DDR_CS0_BNDS 0x0000000f #define CONFIG_SYS_DDR_CS0_CONFIG 0x80330102 -#define CONFIG_SYS_DDR_TIMING_0 0x00220802 -#define CONFIG_SYS_DDR_TIMING_1 0x38357322 -#define CONFIG_SYS_DDR_TIMING_2 0x2f9048c8 -#define CONFIG_SYS_DDR_TIMING_3 0x00000000 -#define CONFIG_SYS_DDR_CLK_CNTL 0x02000000 +#define CONFIG_SYS_DDR_TIMING_0 0x00220802 +#define CONFIG_SYS_DDR_TIMING_1 0x38357322 +#define CONFIG_SYS_DDR_TIMING_2 0x2f9048c8 +#define CONFIG_SYS_DDR_TIMING_3 0x00000000 +#define CONFIG_SYS_DDR_CLK_CNTL 0x02000000 #define CONFIG_SYS_DDR_MODE 0x47d00432 #define CONFIG_SYS_DDR_MODE2 0x8000c000 -#define CONFIG_SYS_DDR_INTERVAL 0x03cf0080 +#define CONFIG_SYS_DDR_INTERVAL 0x03cf0080 #define CONFIG_SYS_DDR_SDRAM_CFG 0x43000000 #define CONFIG_SYS_DDR_SDRAM_CFG2 0x00401000 #else -#define CONFIG_SYS_DDR_CONFIG (CSCONFIG_EN | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_9) -#define CONFIG_SYS_DDR_TIMING_1 0x37344321 /* tCL-tRCD-tRP-tRAS=2.5-3-3-7 */ -#define CONFIG_SYS_DDR_TIMING_2 0x00000800 /* may need tuning */ +#define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_9) +#define CONFIG_SYS_DDR_TIMING_1 0x37344321 /* tCL-tRCD-tRP-tRAS=2.5-3-3-7 */ +#define CONFIG_SYS_DDR_TIMING_2 0x00000800 /* may need tuning */ #define CONFIG_SYS_DDR_CONTROL 0x42008000 /* Self refresh,2T timing */ #define CONFIG_SYS_DDR_MODE 0x20000162 /* DLL,normal,seq,4/2.5 */ -#define CONFIG_SYS_DDR_INTERVAL 0x045b0100 /* page mode */ +#define CONFIG_SYS_DDR_INTERVAL 0x045b0100 /* page mode */ #endif #endif
@@ -195,21 +195,22 @@ * FLASH on the Local Bus */ #define CONFIG_SYS_FLASH_CFI /* use the Common Flash Interface */ -#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ +#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ #define CONFIG_SYS_FLASH_BASE 0xFE000000 /* FLASH base address */ #define CONFIG_SYS_FLASH_SIZE 32 /* max FLASH size is 32M */ -#define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */ -#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ +#define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */ +#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE /* Window base at flash base */ -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000018 /* 32MB window size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_32MB)
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | /* Flash Base address */ \ - (2 << BR_PS_SHIFT) | /* 16 bit port size */ \ - BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) | OR_UPM_XAM | \ +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE /* Flash Base address */ \ + | BR_PS_16 /* 16 bit port size */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) | OR_GPCM_XAM | \ OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | OR_GPCM_XACS | OR_GPCM_SCY_15 | \ - OR_GPCM_TRLX | OR_GPCM_EHTR | OR_GPCM_EAD) + OR_GPCM_TRLX_SET | OR_GPCM_EHTR_SET | OR_GPCM_EAD)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 256 /* max sectors per device */ @@ -219,24 +220,38 @@ /* * BCSR on the Local Bus */ -#define CONFIG_SYS_BCSR 0xF8000000 +#define CONFIG_SYS_BCSR 0xF8000000 #define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_BCSR /* Access window base at BCSR base */ -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000F /* Access window size 64K */ - -#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR|0x00000801) /* Port size=8bit, MSEL=GPCM */ -#define CONFIG_SYS_OR1_PRELIM 0xFFFFE9f7 /* length 32K */ +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_64KB) + +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR \ + | BR_PS_8 \ + | BR_MS_GPCM \ + | BR_V) +#define CONFIG_SYS_OR1_PRELIM (OR_AM_32KB \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xFFFFE9F7 */
/* * SDRAM on the Local Bus */ +/* [RFC]Given this base address, there is no BAT covering LBC_SDRAM */ #define CONFIG_SYS_LBC_SDRAM_BASE 0xF0000000 /* SDRAM base address */ #define CONFIG_SYS_LBC_SDRAM_SIZE 64 /* LBC SDRAM is 64MB */
#define CONFIG_SYS_LB_SDRAM /* if board has SRDAM on local bus */
#ifdef CONFIG_SYS_LB_SDRAM -#define CONFIG_SYS_LBLAWBAR2 0 -#define CONFIG_SYS_LBLAWAR2 0x80000019 /* 64MB */ +/* [RFC]This used to be CONFIG_SYS_LBLAWBAR2 */ +#define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_LBC_SDRAM_BASE /* [RFC]This was 0 before, overlapping DDR */ +/* [RFC]This used to be CONFIG_SYS_LBLAWAR2 */ +#define CONFIG_SYS_LBLAWAR2_PRELIM (LBLAWAR_EN | LBLAWAR_64MB)
/*local bus BR2, OR2 definition for SDRAM if soldered on the EPB board */ /* @@ -253,7 +268,12 @@ * xxxx xxxx xxxx xxxx x001 1000 0110 0001 = 00001861 */
-#define CONFIG_SYS_BR2 0x00001861 /*Port size=32bit, MSEL=SDRAM */ +/* [RFC]This used to be CONFIG_SYS_BR2 */ +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_LBC_SDRAM_BASE /* [RFC]This was 0 before, overlapping DDR */ \ + | BR_PS_32 \ + | BR_MS_SDRAM \ + | BR_V) + /* 0xF0001861 */
/* * The SDRAM size in MB, CONFIG_SYS_LBC_SDRAM_SIZE, is 64. @@ -269,7 +289,13 @@ * 1111 1100 0000 0000 0110 1001 0000 0001 = fc006901 */
-#define CONFIG_SYS_OR2 0xfc006901 +/* [RFC]This used to be CONFIG_SYS_OR2 */ +#define CONFIG_SYS_OR2_PRELIM (MEG_TO_AM(CONFIG_SYS_LBC_SDRAM_SIZE) \ + | OR_SDRAM_XAM \ + | ((9 - OR_SDRAM_MIN_COLS) << OR_SDRAM_COLS_SHIFT) \ + | ((13 - OR_SDRAM_MIN_ROWS) << OR_SDRAM_ROWS_SHIFT) \ + | OR_SDRAM_EAD) + /* 0xFC006901 */
#define CONFIG_SYS_LBC_LSRT 0x32000000 /* LB sdram refresh timer, about 6us */ #define CONFIG_SYS_LBC_MRTPR 0x20000000 /* LB refresh timer prescal, 266MHz/32 */ @@ -288,22 +314,50 @@ #endif
/* - * Windows to access PIB via local bus + * Windows to access Platform I/O Boards (PIB) via local bus */ -#define CONFIG_SYS_LBLAWBAR3_PRELIM 0xf8010000 /* windows base 0xf8010000 */ -#define CONFIG_SYS_LBLAWAR3_PRELIM 0x8000000e /* windows size 32KB */ +#define CONFIG_SYS_PIB_BASE 0xF8008000 +#define CONFIG_SYS_PIB_WINDOW_SIZE (32 * 1024) + +/* [RFC]Previously, this LBLAW only covered the 2nd window (CS5) */ +#define CONFIG_SYS_LBLAWBAR3_PRELIM CONFIG_SYS_PIB_BASE /* windows base */ +#define CONFIG_SYS_LBLAWAR3_PRELIM (LBLAWAR_EN | LBLAWAR_64KB)
/* * CS4 on Local Bus, to PIB */ -#define CONFIG_SYS_BR4_PRELIM 0xf8008801 /* CS4 base address at 0xf8008000 */ -#define CONFIG_SYS_OR4_PRELIM 0xffffe9f7 /* size 32KB, port size 8bit, GPCM */ +#define CONFIG_SYS_BR4_PRELIM (CONFIG_SYS_PIB_BASE \ + | BR_PS_8 \ + | BR_MS_GPCM \ + | BR_V) + /* 0xF8008801 */ /* CS4 base address at 0xf8008000 */ +#define CONFIG_SYS_OR4_PRELIM (OR_AM_32KB \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xffffe9f7 */
/* * CS5 on Local Bus, to PIB */ -#define CONFIG_SYS_BR5_PRELIM 0xf8010801 /* CS5 base address at 0xf8010000 */ -#define CONFIG_SYS_OR5_PRELIM 0xffffe9f7 /* size 32KB, port size 8bit, GPCM */ +#define CONFIG_SYS_BR5_PRELIM ((CONFIG_SYS_PIB_BASE + CONFIG_SYS_PIB_WINDOW_SIZE) \ + | BR_PS_8 \ + | BR_MS_GPCM \ + | BR_V) + /* 0xF8010801 */ /* CS5 base address at 0xf8010000 */ +#define CONFIG_SYS_OR5_PRELIM (CONFIG_SYS_PIB_BASE \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xffffe9f7 */
/* * Serial Port @@ -508,52 +562,52 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR/LBC SDRAM: cacheable */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT0L CONFIG_SYS_IBAT0L #define CONFIG_SYS_DBAT0U CONFIG_SYS_IBAT0U
/* DDR/LBC SDRAM next 256M: cacheable */ -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_SDRAM_BASE2 | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_SDRAM_BASE2 | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_SDRAM_BASE2 | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT4L CONFIG_SYS_IBAT4L #define CONFIG_SYS_DBAT4U CONFIG_SYS_IBAT4U
#ifdef CONFIG_PCI /* PCI MEM space: cacheable */ -#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI1_MEM_PHYS | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI1_MEM_PHYS | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI1_MEM_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT6L CONFIG_SYS_IBAT6L #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U /* PCI MMIO space: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI1_MMIO_PHYS | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI1_MMIO_PHYS | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT7U (CONFIG_SYS_PCI1_MMIO_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT7L CONFIG_SYS_IBAT7L diff --git a/include/configs/MPC8360ERDK.h b/include/configs/MPC8360ERDK.h index 851872a..9eea9c0 100644 --- a/include/configs/MPC8360ERDK.h +++ b/include/configs/MPC8360ERDK.h @@ -96,7 +96,10 @@ /* * DDRCDR - DDR Control Driver Register */ -#define CONFIG_SYS_DDRCDR_VALUE 0x80080001 +#define CONFIG_SYS_DDRCDR_VALUE (DDRCDR_DHC_EN \ + | DDRCDR_ODT \ + | DDRCDR_Q_DRN) + /* 0x80080001 */
#undef CONFIG_SPD_EEPROM /* Do not use SPD EEPROM for DDR setup */
@@ -105,14 +108,15 @@ */ #define CONFIG_DDR_II #define CONFIG_SYS_DDR_SIZE 256 /* MB */ -#define CONFIG_SYS_DDR_CS0_BNDS 0x0000000f +#define CONFIG_SYS_DDR_CS0_BNDS 0x0000000f #define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN | CSCONFIG_ROW_BIT_13 | \ - CSCONFIG_COL_BIT_10 | CSCONFIG_ODT_WR_ACS) + CSCONFIG_COL_BIT_10 | \ + CSCONFIG_ODT_WR_ONLY_CURRENT) #define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SDRAM_TYPE_DDR2 | SDRAM_CFG_ECC_EN) #define CONFIG_SYS_DDR_SDRAM_CFG2 0x00001000 -#define CONFIG_SYS_DDR_CLK_CNTL (DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05) -#define CONFIG_SYS_DDR_INTERVAL ((256 << SDRAM_INTERVAL_BSTOPRE_SHIFT) | \ - (1115 << SDRAM_INTERVAL_REFINT_SHIFT)) +#define CONFIG_SYS_DDR_CLK_CNTL (DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05) +#define CONFIG_SYS_DDR_INTERVAL ((256 << SDRAM_INTERVAL_BSTOPRE_SHIFT) | \ + (1115 << SDRAM_INTERVAL_REFINT_SHIFT)) #define CONFIG_SYS_DDR_MODE 0x47800432 #define CONFIG_SYS_DDR_MODE2 0x8000c000
@@ -190,15 +194,16 @@ #define CONFIG_SYS_FLASH_PROTECTION 1 /* Use intel Flash protection. */
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | /* Flash Base address */ \ - (2 << BR_PS_SHIFT) | /* 16 bit port size */ \ - BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) | OR_UPM_XAM | \ - OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | \ - OR_GPCM_XACS | OR_GPCM_SCY_15 | \ - OR_GPCM_TRLX | OR_GPCM_EHTR | OR_GPCM_EAD) +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE /* Flash Base address */ \ + | BR_PS_16 /* 16 bit port size */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) | OR_UPM_XAM | \ + OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | \ + OR_GPCM_XACS | OR_GPCM_SCY_15 | \ + OR_GPCM_TRLX_SET | OR_GPCM_EHTR_SET | OR_GPCM_EAD)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 256 /* max sectors per device */ @@ -215,11 +220,17 @@ #define CONFIG_MTD_NAND_VERIFY_WRITE
#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_NAND_BASE -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000001b /* Access window size 4K */ +/* [RFC]Comment said 4KB window; code said 256MB window; OR1 says 64MB... what's correct? */ +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_256MB)
/* Port size 8 bit, UPMA */ -#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_NAND_BASE | 0x00000881) -#define CONFIG_SYS_OR1_PRELIM 0xfc000001 +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_NAND_BASE \ + | BR_PS_8 \ + | BR_MS_UPMA \ + | BR_V) + /* 0x60000881 */ +#define CONFIG_SYS_OR1_PRELIM (OR_AM_64MB | OR_UPM_EAD) + /* 0xFC000001 */
/* * Fujitsu MB86277 (MINT) graphics controller @@ -227,11 +238,16 @@ #define CONFIG_SYS_VIDEO_BASE 0x70000000
#define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_VIDEO_BASE -#define CONFIG_SYS_LBLAWAR2_PRELIM 0x80000019 /* Access window size 64MB */ +#define CONFIG_SYS_LBLAWAR2_PRELIM (LBLAWAR_EN | LBLAWAR_64MB)
/* Port size 32 bit, UPMB */ -#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_VIDEO_BASE | 0x000018a1) /* PS=11, UPMB */ -#define CONFIG_SYS_OR2_PRELIM 0xfc000001 /* (64MB, EAD=1) */ +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_VIDEO_BASE \ + | BR_PS_32 \ + | BR_MS_UPMB \ + | BR_V) + /* 0x000018a1 */ +#define CONFIG_SYS_OR2_PRELIM (OR_AM_64MB | OR_UPM_EAD) + /* 0xFC000001 */
/* * Serial Port @@ -423,39 +439,39 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* NAND: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_NAND_BASE | BATL_PP_10 | BATL_CACHEINHIBIT |\ +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_NAND_BASE | BATL_PP_RW | BATL_CACHEINHIBIT |\ BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_NAND_BASE | BATU_BL_64M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT2L CONFIG_SYS_IBAT2L #define CONFIG_SYS_DBAT2U CONFIG_SYS_IBAT2U
-#define CONFIG_SYS_IBAT5L (CONFIG_SYS_VIDEO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | \ +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_VIDEO_BASE | BATL_PP_RW | BATL_CACHEINHIBIT | \ BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_VIDEO_BASE | BATU_BL_64M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT5L CONFIG_SYS_IBAT5L @@ -463,12 +479,12 @@
#ifdef CONFIG_PCI /* PCI MEM space: cacheable */ -#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI1_MEM_PHYS | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI1_MEM_PHYS | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI1_MEM_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT6L CONFIG_SYS_IBAT6L #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U /* PCI MMIO space: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI1_MMIO_PHYS | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI1_MMIO_PHYS | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT7U (CONFIG_SYS_PCI1_MMIO_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT7L CONFIG_SYS_IBAT7L diff --git a/include/configs/MPC837XEMDS.h b/include/configs/MPC837XEMDS.h index abccfd6..9529ccd 100644 --- a/include/configs/MPC837XEMDS.h +++ b/include/configs/MPC837XEMDS.h @@ -128,7 +128,8 @@ #define CONFIG_SYS_DDR_SDRAM_BASE CONFIG_SYS_DDR_BASE #define CONFIG_SYS_DDR_SDRAM_CLK_CNTL DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05 #define CONFIG_SYS_83XX_DDR_USES_CS0 -#define CONFIG_SYS_DDRCDR_VALUE 0x80080001 /* ODT 150ohm on SoC */ +#define CONFIG_SYS_DDRCDR_VALUE (DDRCDR_DHC_EN | DDRCDR_ODT | DDRCDR_Q_DRN) + /* 0x80080001 */ /* ODT 150ohm on SoC */
#undef CONFIG_DDR_ECC /* support DDR ECC function */ #undef CONFIG_DDR_ECC_CMD /* Use DDR ECC user commands */ @@ -147,7 +148,8 @@ #define CONFIG_SYS_DDR_SIZE 512 /* MB */ #define CONFIG_SYS_DDR_CS0_BNDS 0x0000001f #define CONFIG_SYS_DDR_CS0_CONFIG ( CSCONFIG_EN \ - | 0x00010000 /* ODT_WR to CSn */ \ + | CSCONFIG_ODT_RD_NEVER /* ODT_RD to none */ \ + | CSCONFIG_ODT_WR_ONLY_CURRENT /* ODT_WR to CSn */ \ | CSCONFIG_ROW_BIT_14 | CSCONFIG_COL_BIT_10 ) /* 0x80010202 */ #define CONFIG_SYS_DDR_TIMING_3 0x00000000 @@ -223,34 +225,35 @@ */ #define CONFIG_SYS_LCRR_DBYP LCRR_DBYP #define CONFIG_SYS_LCRR_CLKDIV LCRR_CLKDIV_8 -#define CONFIG_SYS_LBC_LBCR 0x00000000 +#define CONFIG_SYS_LBC_LBCR 0x00000000 #define CONFIG_FSL_ELBC 1
/* * FLASH on the Local Bus */ #define CONFIG_SYS_FLASH_CFI /* use the Common Flash Interface */ -#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ +#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ #define CONFIG_SYS_FLASH_BASE 0xFE000000 /* FLASH base address */ #define CONFIG_SYS_FLASH_SIZE 32 /* max FLASH size is 32M */ -#define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */ +#define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */
#define CONFIG_SYS_BR0_PRELIM ( CONFIG_SYS_FLASH_BASE /* Flash Base address */ \ - | (2 << BR_PS_SHIFT) /* 16 bit port size */ \ - | BR_V ) /* valid */ -#define CONFIG_SYS_OR0_PRELIM ( (~(CONFIG_SYS_FLASH_SIZE - 1) << 20) \ - | OR_UPM_XAM \ - | OR_GPCM_CSNT \ - | OR_GPCM_ACS_DIV2 \ - | OR_GPCM_XACS \ - | OR_GPCM_SCY_15 \ - | OR_GPCM_TRLX \ - | OR_GPCM_EHTR \ - | OR_GPCM_EAD ) - /* 0xFE000FF7 */ + | BR_PS_16 /* 16 bit port size */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V ) /* valid */ +#define CONFIG_SYS_OR0_PRELIM ( MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ + | OR_UPM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD ) + /* 0xFE000FF7 */
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 256 /* max sectors per device */ @@ -262,39 +265,51 @@ /* * BCSR on the Local Bus */ -#define CONFIG_SYS_BCSR 0xF8000000 +#define CONFIG_SYS_BCSR 0xF8000000 #define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_BCSR /* Access window base at BCSR base */ -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000E /* Access window size 32K */ - -#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR | 0x00000801) /* Port size=8bit, MSEL=GPCM */ -#define CONFIG_SYS_OR1_PRELIM 0xFFFFE9f7 /* length 32K */ +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_32KB) + +#define CONFIG_SYS_BR1_PRELIM ( CONFIG_SYS_BCSR \ + | BR_PS_8 \ + | BR_MS_GPCM \ + | BR_V ) + /* 0xF8000801 */ +#define CONFIG_SYS_OR1_PRELIM ( OR_AM_32KB \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD ) + /* 0xFFFFE9F7 */
/* * NAND Flash on the Local Bus */ -#define CONFIG_CMD_NAND 1 +#define CONFIG_CMD_NAND 1 #define CONFIG_MTD_NAND_VERIFY_WRITE 1 #define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_NAND_FSL_ELBC 1 +#define CONFIG_NAND_FSL_ELBC 1
#define CONFIG_SYS_NAND_BASE 0xE0600000 /* 0xE0600000 */ #define CONFIG_SYS_BR3_PRELIM ( CONFIG_SYS_NAND_BASE \ - | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ - | BR_PS_8 /* Port Size = 8 bit */ \ - | BR_MS_FCM /* MSEL = FCM */ \ - | BR_V ) /* valid */ -#define CONFIG_SYS_OR3_PRELIM ( 0xFFFF8000 /* length 32K */ \ - | OR_FCM_BCTLD \ - | OR_FCM_CST \ - | OR_FCM_CHT \ - | OR_FCM_SCY_1 \ - | OR_FCM_RST \ - | OR_FCM_TRLX \ - | OR_FCM_EHTR ) - /* 0xFFFF919E */ + | BR_DECC_CHK_GEN /* Use HW ECC */ \ + | BR_PS_8 /* Port Size = 8 bit */ \ + | BR_MS_FCM /* MSEL = FCM */ \ + | BR_V ) /* valid */ +#define CONFIG_SYS_OR3_PRELIM ( OR_AM_32KB \ + | OR_FCM_BCTLD \ + | OR_FCM_CST \ + | OR_FCM_CHT \ + | OR_FCM_SCY_1 \ + | OR_FCM_RST \ + | OR_FCM_TRLX \ + | OR_FCM_EHTR ) + /* 0xFFFF919E */
#define CONFIG_SYS_LBLAWBAR3_PRELIM CONFIG_SYS_NAND_BASE -#define CONFIG_SYS_LBLAWAR3_PRELIM 0x8000000E /* 32KB */ +#define CONFIG_SYS_LBLAWAR3_PRELIM (LBLAWAR_EN | LBLAWAR_32KB)
/* * Serial Port @@ -560,51 +575,51 @@ extern int board_pci_host_broken(void); #define CONFIG_SYS_SDRAM_LOWER CONFIG_SYS_SDRAM_BASE #define CONFIG_SYS_SDRAM_UPPER (CONFIG_SYS_SDRAM_BASE + 0x10000000)
-#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_LOWER | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_LOWER | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_LOWER | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT0L CONFIG_SYS_IBAT0L #define CONFIG_SYS_DBAT0U CONFIG_SYS_IBAT0U
-#define CONFIG_SYS_IBAT1L (CONFIG_SYS_SDRAM_UPPER | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_SDRAM_UPPER | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_SDRAM_UPPER | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT1L CONFIG_SYS_IBAT1L #define CONFIG_SYS_DBAT1U CONFIG_SYS_IBAT1U
/* IMMRBAR, PCI IO and NAND: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_IMMR | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_IMMR | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_IMMR | BATU_BL_8M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT2L CONFIG_SYS_IBAT2L #define CONFIG_SYS_DBAT2U CONFIG_SYS_IBAT2U
/* BCSR: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_BCSR | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_BCSR | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_BCSR | BATU_BL_128K | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT3L CONFIG_SYS_IBAT3L #define CONFIG_SYS_DBAT3U CONFIG_SYS_IBAT3U
/* FLASH: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_FLASH_BASE | BATU_BL_32M | BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT4L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT4L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT4U CONFIG_SYS_IBAT4U
#ifdef CONFIG_PCI /* PCI MEM space: cacheable */ -#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI_MEM_PHYS | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI_MEM_PHYS | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI_MEM_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT6L CONFIG_SYS_IBAT6L #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U /* PCI MMIO space: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI_MMIO_PHYS | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI_MMIO_PHYS | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT7U (CONFIG_SYS_PCI_MMIO_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT7L CONFIG_SYS_IBAT7L diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index ea3056b..3da60e7 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -165,9 +165,9 @@ * Manually set up DDR parameters */ #define CONFIG_SYS_DDR_SIZE 256 /* MB */ -#define CONFIG_SYS_DDR_CS0_BNDS 0x0000000f -#define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN | CSCONFIG_ODT_WR_ACS \ - | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10) +#define CONFIG_SYS_DDR_CS0_BNDS 0x0000000f +#define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN | CSCONFIG_ODT_WR_ONLY_CURRENT \ + | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10)
#define CONFIG_SYS_DDR_TIMING_3 0x00000000 #define CONFIG_SYS_DDR_TIMING_0 ((0 << TIMING_CFG0_RWT_SHIFT) \ @@ -178,7 +178,6 @@ | (6 << TIMING_CFG0_PRE_PD_EXIT_SHIFT) \ | (8 << TIMING_CFG0_ODT_PD_EXIT_SHIFT) \ | (2 << TIMING_CFG0_MRS_CYC_SHIFT)) - /* 0x00220802 */ /* 0x00260802 */ /* DDR400 */ #define CONFIG_SYS_DDR_TIMING_1 ((3 << TIMING_CFG1_PRETOACT_SHIFT) \ | (9 << TIMING_CFG1_ACTTOPRE_SHIFT) \ @@ -188,28 +187,35 @@ | (3 << TIMING_CFG1_WRREC_SHIFT) \ | (2 << TIMING_CFG1_ACTTOACT_SHIFT) \ | (2 << TIMING_CFG1_WRTORD_SHIFT)) - /* 0x3935d322 */ /* 0x3937d322 */ -#define CONFIG_SYS_DDR_TIMING_2 0x02984cc8 +#define CONFIG_SYS_DDR_TIMING_2 ((0 << TIMING_CFG2_ADD_LAT_SHIFT) \ + | (5 << TIMING_CFG2_CPO_SHIFT) \ + | (3 << TIMING_CFG2_WR_LAT_DELAY_SHIFT) \ + | (2 << TIMING_CFG2_RD_TO_PRE_SHIFT) \ + | (3 << TIMING_CFG2_WR_DATA_DELAY_SHIFT) \ + | (3 << TIMING_CFG2_CKE_PLS_SHIFT) \ + | (8 << TIMING_CFG2_FOUR_ACT_SHIFT)) + /* 0x02984cc8 */
#define CONFIG_SYS_DDR_INTERVAL ((1024 << SDRAM_INTERVAL_REFINT_SHIFT) \ | (0 << SDRAM_INTERVAL_BSTOPRE_SHIFT)) /* 0x06090100 */
#if defined(CONFIG_DDR_2T_TIMING) -#define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SREN \ - | 3 << SDRAM_CFG_SDRAM_TYPE_SHIFT \ - | SDRAM_CFG_2T_EN \ - | SDRAM_CFG_DBW_32) +#define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SREN \ + | SDRAM_CFG_SDRAM_TYPE_DDR2 \ + | SDRAM_CFG_32_BE \ + | SDRAM_CFG_2T_EN) + /* 0x43088000 */ #else -#define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SREN \ - | 3 << SDRAM_CFG_SDRAM_TYPE_SHIFT) - /* 0x43000000 */ +#define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SREN \ + | SDRAM_CFG_SDRAM_TYPE_DDR2) + /* 0x43000000 */ #endif #define CONFIG_SYS_DDR_SDRAM_CFG2 0x00001000 /* 1 posted refresh */ #define CONFIG_SYS_DDR_MODE ((0x0406 << SDRAM_MODE_ESD_SHIFT) \ - | (0x0442 << SDRAM_MODE_SD_SHIFT)) - /* 0x04400442 */ /* DDR400 */ + | (0x0442 << SDRAM_MODE_SD_SHIFT)) + /* 0x04400442 */ /* DDR400 */ #define CONFIG_SYS_DDR_MODE2 0x00000000
/* @@ -264,15 +270,17 @@ #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE /* Window base at flash base */ #define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000016 /* 8 MB window size */
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | /* Flash Base address */ \ - (2 << BR_PS_SHIFT) | /* 16 bit port size */ \ - BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM (0xFF800000 /* 8 MByte */ \ - | OR_GPCM_XACS \ - | OR_GPCM_SCY_9 \ - | OR_GPCM_EHTR \ - | OR_GPCM_EAD) - /* 0xFF806FF7 TODO SLOW 8 MB flash size */ +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE /* Flash Base address */ \ + | BR_PS_16 /* 16 bit port size */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_9 \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xFF800191 */ +/* [RFC]Old comment: 0xFF806FF7 TODO SLOW 8 MB flash size */
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 256 /* max sectors per device */ @@ -285,20 +293,20 @@ * NAND Flash on the Local Bus */ #define CONFIG_SYS_NAND_BASE 0xE0600000 /* 0xE0600000 */ -#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_NAND_BASE | \ - (2 << BR_DECC_SHIFT) | /* Use HW ECC */ \ - BR_PS_8 | /* Port Size = 8 bit */ \ - BR_MS_FCM | /* MSEL = FCM */ \ - BR_V) /* valid */ -#define CONFIG_SYS_OR1_PRELIM (0xFFFF8000 | /* length 32K */ \ - OR_FCM_CSCT | \ - OR_FCM_CST | \ - OR_FCM_CHT | \ - OR_FCM_SCY_1 | \ - OR_FCM_TRLX | \ - OR_FCM_EHTR) +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_NAND_BASE \ + | BR_DECC_CHK_GEN /* Use HW ECC */ \ + | BR_PS_8 /* Port Size = 8 bit */ \ + | BR_MS_FCM /* MSEL = FCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR1_PRELIM (OR_AM_32KB \ + | OR_FCM_CSCT \ + | OR_FCM_CST \ + | OR_FCM_CHT \ + | OR_FCM_SCY_1 \ + | OR_FCM_TRLX \ + | OR_FCM_EHTR) #define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_NAND_BASE -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000E /* 32KB */ +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_32KB)
/* Vitesse 7385 */
@@ -306,10 +314,22 @@
#ifdef CONFIG_VSC7385_ENET
-#define CONFIG_SYS_BR2_PRELIM 0xf0000801 /* Base address */ -#define CONFIG_SYS_OR2_PRELIM 0xfffe09ff /* 128K bytes*/ +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_VSC7385_BASE \ + | BR_PS_8 \ + | BR_MS_GPCM \ + | BR_V) + /* 0xF0000801 */ +#define CONFIG_SYS_OR2_PRELIM (OR_AM_128KB \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_SETA \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xfffe09ff */ /* 128K bytes*/ #define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_VSC7385_BASE /* Access Base */ -#define CONFIG_SYS_LBLAWAR2_PRELIM 0x80000010 /* Access Size 128K */ +#define CONFIG_SYS_LBLAWAR2_PRELIM (LBLAWAR_EN | LBLAWAR_128KB)
#endif
@@ -569,51 +589,51 @@ #define CONFIG_SYS_SDRAM_LOWER CONFIG_SYS_SDRAM_BASE #define CONFIG_SYS_SDRAM_UPPER (CONFIG_SYS_SDRAM_BASE + 0x10000000)
/* L2 Switch: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_VSC7385_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_VSC7385_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_VSC7385_BASE | BATU_BL_128K | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT3L CONFIG_SYS_IBAT3L #define CONFIG_SYS_DBAT3U CONFIG_SYS_IBAT3U
#ifdef CONFIG_PCI /* PCI MEM space: cacheable */ -#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI_MEM_PHYS | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI_MEM_PHYS | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI_MEM_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT6L CONFIG_SYS_IBAT6L #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U /* PCI MMIO space: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI_MMIO_PHYS | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI_MMIO_PHYS | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT7U (CONFIG_SYS_PCI_MMIO_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT7L CONFIG_SYS_IBAT7L diff --git a/include/configs/MVBLM7.h b/include/configs/MVBLM7.h index c201310..6c1d6e3 100644 --- a/include/configs/MVBLM7.h +++ b/include/configs/MVBLM7.h @@ -72,7 +72,10 @@ #define CONFIG_SYS_MEMTEST_END (70<<20) #define CONFIG_VERY_BIG_RAM
-#define CONFIG_SYS_DDRCDR 0x22000001 +#define CONFIG_SYS_DDRCDR (DDRCDR_PZ_HIZ \ + | DDRCDR_NZ_HIZ \ + | DDRCDR_Q_DRN) + /* 0x22000001 */ #define CONFIG_SYS_DDR_SDRAM_CLK_CNTL DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05
#define CONFIG_SYS_DDR_SIZE 512 @@ -100,20 +103,19 @@
#define CONFIG_SYS_FLASH_BASE 0xFF800000 #define CONFIG_SYS_FLASH_SIZE 8 -#define CONFIG_SYS_FLASH_SIZE_SHIFT 3 #define CONFIG_SYS_FLASH_EMPTY_INFO #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 #define CONFIG_SYS_FLASH_WRITE_TOUT 500 #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 256
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | BR_PS_16 | BR_V) -#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) | OR_UPM_XAM | \ - OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | OR_GPCM_XACS|\ - OR_GPCM_SCY_15 | OR_GPCM_TRLX | OR_GPCM_EHTR | \ - OR_GPCM_EAD) +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | BR_PS_16 | BR_MS_GPCM | BR_V) +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) | OR_UPM_XAM | \ + OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | OR_GPCM_XACS | \ + OR_GPCM_SCY_15 | OR_GPCM_TRLX_SET | OR_GPCM_EHTR_SET | \ + OR_GPCM_EAD) #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | (0x13 + CONFIG_SYS_FLASH_SIZE_SHIFT)) +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_8MB)
/* * U-Boot memory configuration @@ -334,13 +336,13 @@ #define CONFIG_HIGH_BATS 1
/* PCI */ -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT |\ +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_RW | BATL_CACHEINHIBIT |\ BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP)
@@ -351,12 +353,12 @@ #define CONFIG_SYS_IBAT4U 0
/* IMMRBAR @ 0xE0000000, PCI IO @ 0xE2000000 & BCSR @ 0xE2400000 */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR | BATL_PP_10 | BATL_CACHEINHIBIT | \ +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR | BATL_PP_RW | BATL_CACHEINHIBIT | \ BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_IMMR | BATU_BL_256M | BATU_VS | BATU_VP)
/* stack in DCACHE 0xFDF00000 & FLASH @ 0xFF800000 */ -#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_10 | BATL_MEMCOHERENCE | \ +#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_RW | BATL_MEMCOHERENCE | \ BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT6U (0xF0000000 | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_IBAT7L 0 diff --git a/include/configs/SIMPC8313.h b/include/configs/SIMPC8313.h index 339e02b..e731574 100644 --- a/include/configs/SIMPC8313.h +++ b/include/configs/SIMPC8313.h @@ -148,25 +148,25 @@ #define CONFIG_NAND_FSL_ELBC 1
#define CONFIG_SYS_NAND_BR_PRELIM ( CONFIG_SYS_NAND_BASE \ - | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ + | BR_DECC_CHK_GEN /* Use HW ECC */ \ | BR_PS_8 /* Port Size = 8 bit */ \ | BR_MS_FCM /* MSEL = FCM */ \ | BR_V ) /* valid */
#ifdef CONFIG_NAND_SP -#define CONFIG_SYS_NAND_OR_PRELIM ( 0xFFFF8000 /* length 32K */ \ +#define CONFIG_SYS_NAND_OR_PRELIM ( OR_AM_32KB \ | OR_FCM_CSCT \ | OR_FCM_CST \ | OR_FCM_CHT \ | OR_FCM_SCY_1 \ | OR_FCM_TRLX \ | OR_FCM_EHTR ) -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x8000000E /* 32KB */ -#define CONFIG_SYS_NAND_PAGE_SIZE (512) /* NAND chip page size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_32KB) +#define CONFIG_SYS_NAND_PAGE_SIZE 512 /* NAND chip page size */ #define CONFIG_SYS_NAND_BLOCK_SIZE (16 << 10) /* NAND chip block size */ #define NAND_CACHE_PAGES 32 #elif defined(CONFIG_NAND_LP) -#define CONFIG_SYS_NAND_OR_PRELIM ( 0xFFFC0000 /* length 256K */ \ +#define CONFIG_SYS_NAND_OR_PRELIM ( OR_AM_256KB \ | OR_FCM_PGS \ | OR_FCM_CSCT \ | OR_FCM_CST \ @@ -174,8 +174,8 @@ | OR_FCM_SCY_1 \ | OR_FCM_TRLX \ | OR_FCM_EHTR ) -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000011 /* 256KB */ -#define CONFIG_SYS_NAND_PAGE_SIZE (2048) /* NAND chip page size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_256KB) +#define CONFIG_SYS_NAND_PAGE_SIZE 2048 /* NAND chip page size */ #define CONFIG_SYS_NAND_BLOCK_SIZE (128 << 10) /* NAND chip block size */ #define NAND_CACHE_PAGES 64 #else @@ -439,15 +439,15 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR @ 0x00000000 */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT1L ((CONFIG_SYS_SDRAM_BASE + 0x10000000) | BATL_PP_10) +#define CONFIG_SYS_IBAT1L ((CONFIG_SYS_SDRAM_BASE + 0x10000000) | BATL_PP_RW) #define CONFIG_SYS_IBAT1U ((CONFIG_SYS_SDRAM_BASE + 0x10000000) | BATU_BL_256M | BATU_VS | BATU_VP)
/* PCI @ 0x80000000 */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10) +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_RW) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_RW | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_PCI1_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP)
/* PCI2 not supported on 8313 */ @@ -455,11 +455,11 @@ #define CONFIG_SYS_IBAT4U (0)
/* IMMRBAR @ 0xE0000000, PCI IO @ 0xE2000000 */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR | BATL_PP_RW | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_IMMR | BATU_BL_256M | BATU_VS | BATU_VP)
/* SDRAM @ 0xF0000000, stack in DCACHE 0xFDF00000 & FLASH @ 0xFE000000 */ -#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_10 | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_RW | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT6U (0xF0000000 | BATU_BL_256M | BATU_VS | BATU_VP)
#define CONFIG_SYS_IBAT7L (0) diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index 5cd517d..dd2b50e 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -114,11 +114,11 @@ #define CONFIG_SYS_OR_TIMING_FLASH (OR_GPCM_CSNT | OR_GPCM_ACS_DIV4 | \ OR_GPCM_SCY_5 | OR_GPCM_TRLX)
-#define CONFIG_SYS_PRELIM_OR_AM 0xc0000000 /* OR addr mask: 1 GiB */ +#define CONFIG_SYS_PRELIM_OR_AM OR_AM_1GB /* OR addr mask: 1 GiB */
#define CONFIG_SYS_OR0_PRELIM (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_FLASH)
-#define CONFIG_SYS_LBLAWAR0_PRELIM 0x8000001D /* 1 GiB window size (2^(size + 1)) */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_1GB )
@@ -408,22 +408,22 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR 0 - 512M */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_SDRAM_BASE + 0x10000000 | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_SDRAM_BASE + 0x10000000 | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_SDRAM_BASE + 0x10000000 | BATU_BL_256M | BATU_VS | BATU_VP)
/* stack in DCACHE @ 512M (no backing mem) */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_INIT_RAM_ADDR | BATU_BL_128K | BATU_VS | BATU_VP)
/* PCI */ #ifdef CONFIG_PCI -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_PCI1_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_10 | BATL_MEMCOHERENCE | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_RW | BATL_MEMCOHERENCE | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_PCI1_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_PCI1_IO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_PCI1_IO_BASE | BATL_PP_RW | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_PCI1_IO_BASE | BATU_BL_16M | BATU_VS | BATU_VP) #else #define CONFIG_SYS_IBAT3L (0) @@ -435,11 +435,11 @@ #endif
/* IMMRBAR */ -#define CONFIG_SYS_IBAT6L (CONFIG_SYS_IMMR | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_IMMR | BATL_PP_RW | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_IMMR | BATU_BL_1M | BATU_VS | BATU_VP)
/* FLASH */ -#define CONFIG_SYS_IBAT7L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT7L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT7U (CONFIG_SYS_FLASH_BASE | BATU_BL_256M | BATU_VS | BATU_VP)
#define CONFIG_SYS_DBAT0L CONFIG_SYS_IBAT0L diff --git a/include/configs/km/km83xx-common.h b/include/configs/km/km83xx-common.h index 2b1a84a..0a4e4a4 100644 --- a/include/configs/km/km83xx-common.h +++ b/include/configs/km/km83xx-common.h @@ -103,16 +103,17 @@ #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE
#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x8000001b /* 256MB window size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_256MB)
#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | \ - (2 << BR_PS_SHIFT) | /* 16 bit port size */ \ + BR_PS_16 | /* 16 bit port size */ \ + BR_MS_GPCM | /* MSEL = GPCM */ \ BR_V)
#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) | \ OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | \ OR_GPCM_SCY_5 | \ - OR_GPCM_TRLX | OR_GPCM_EAD) + OR_GPCM_TRLX_SET | OR_GPCM_EAD)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max num of flash banks */ #define CONFIG_SYS_MAX_FLASH_SECT 512 /* max num of sects on one chip */ @@ -123,15 +124,16 @@ */ /* Window base at flash base */ #define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_KMBEC_FPGA_BASE -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000001A /* 128MB window size */ +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_128MB)
#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_KMBEC_FPGA_BASE | \ - (1 << BR_PS_SHIFT) | /* 8 bit port size */ \ + BR_PS_8 | /* 8 bit port size */ \ + BR_MS_GPCM | /* MSEL = GPCM */ \ BR_V) #define CONFIG_SYS_OR1_PRELIM (MEG_TO_AM(CONFIG_SYS_KMBEC_FPGA_SIZE) | \ OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | \ OR_GPCM_SCY_2 | \ - OR_GPCM_TRLX | OR_GPCM_EAD) + OR_GPCM_TRLX_SET | OR_GPCM_EAD)
/* * Serial Port @@ -242,7 +244,7 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR: cache cacheable */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) @@ -250,7 +252,7 @@ #define CONFIG_SYS_DBAT0U CONFIG_SYS_IBAT0U
/* IMMRBAR & PCI IO: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_IMMR | BATU_BL_4M | BATU_VS \ | BATU_VP) @@ -258,25 +260,25 @@ #define CONFIG_SYS_DBAT1U CONFIG_SYS_IBAT1U
/* PRIO1, PIGGY: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_KMBEC_FPGA_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_KMBEC_FPGA_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_KMBEC_FPGA_BASE | BATU_BL_128M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT2L (CONFIG_SYS_KMBEC_FPGA_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT2L (CONFIG_SYS_KMBEC_FPGA_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT2U CONFIG_SYS_IBAT2U
/* FLASH: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_FLASH_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT3L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT3L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT3U CONFIG_SYS_IBAT3U
/* Stack in dcache: cacheable, no memory coherence */ -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10) +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_RW) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_INIT_RAM_ADDR | BATU_BL_128K | \ BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT4L CONFIG_SYS_IBAT4L diff --git a/include/configs/kmeter1.h b/include/configs/kmeter1.h index 8639ddd..c44258e 100644 --- a/include/configs/kmeter1.h +++ b/include/configs/kmeter1.h @@ -72,9 +72,10 @@ #define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN | CSCONFIG_AP | \ CSCONFIG_ROW_BIT_13 | \ CSCONFIG_COL_BIT_10 | \ - CSCONFIG_ODT_WR_ACS) + CSCONFIG_ODT_WR_ONLY_CURRENT)
-#define CONFIG_SYS_DDRCDR 0x40000001 +#define CONFIG_SYS_DDRCDR (DDRCDR_EN | DDRCDR_Q_DRN) + /* 0x40000001 */ #define CONFIG_SYS_DDR_MODE 0x47860452 #define CONFIG_SYS_DDR_MODE2 0x8080c000
@@ -136,37 +137,38 @@ * PAXE on the local bus CS3 */ #define CONFIG_SYS_LBLAWBAR3_PRELIM CONFIG_SYS_PAXE_BASE -#define CONFIG_SYS_LBLAWAR3_PRELIM 0x8000001C /* 512MB window size */ +#define CONFIG_SYS_LBLAWAR3_PRELIM (LBLAWAR_EN | LBLAWAR_512MB)
#define CONFIG_SYS_BR3_PRELIM (CONFIG_SYS_PAXE_BASE | \ - (1 << BR_PS_SHIFT) | /* 8 bit port size */ \ + BR_PS_8 | /* 8 bit port size */ \ + BR_MS_GPCM | /* MSEL = GPCM */ \ BR_V) #define CONFIG_SYS_OR3_PRELIM (MEG_TO_AM(CONFIG_SYS_PAXE_SIZE) | \ OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | \ OR_GPCM_SCY_2 | \ - OR_GPCM_TRLX | OR_GPCM_EAD) + OR_GPCM_TRLX_SET | OR_GPCM_EAD)
/* * MMU Setup */
/* PAXE: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_PAXE_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_PAXE_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_PAXE_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT5L (CONFIG_SYS_PAXE_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT5L (CONFIG_SYS_PAXE_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U
#ifdef CONFIG_PCI /* PCI MEM space: cacheable */ -#define CFG_IBAT6L (CFG_PCI1_MEM_PHYS | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CFG_IBAT6L (CFG_PCI1_MEM_PHYS | BATL_PP_RW | BATL_MEMCOHERENCE) #define CFG_IBAT6U (CFG_PCI1_MEM_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CFG_DBAT6L CFG_IBAT6L #define CFG_DBAT6U CFG_IBAT6U /* PCI MMIO space: cache-inhibit and guarded */ -#define CFG_IBAT7L (CFG_PCI1_MMIO_PHYS | BATL_PP_10 | \ +#define CFG_IBAT7L (CFG_PCI1_MMIO_PHYS | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CFG_IBAT7U (CFG_PCI1_MMIO_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CFG_DBAT7L CFG_IBAT7L diff --git a/include/configs/kmsupx5.h b/include/configs/kmsupx5.h index f8cd8e0..b0dd88c 100644 --- a/include/configs/kmsupx5.h +++ b/include/configs/kmsupx5.h @@ -69,16 +69,16 @@ OR_GPCM_CSNT | \ OR_GPCM_ACS_DIV4 | \ OR_GPCM_SCY_2 | \ - (OR_GPCM_TRLX & \ - (~OR_GPCM_EHTR)) | /* EHTR = 0 */ \ + OR_GPCM_TRLX_SET | \ + OR_GPCM_EHTR_CLEAR | \ OR_GPCM_EAD)
/* LPXF: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_LPXF_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_LPXF_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_LPXF_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT5L (CONFIG_SYS_LPXF_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT5L (CONFIG_SYS_LPXF_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U
diff --git a/include/configs/mpc8308_p1m.h b/include/configs/mpc8308_p1m.h index d7a3a96..c3d49fa 100644 --- a/include/configs/mpc8308_p1m.h +++ b/include/configs/mpc8308_p1m.h @@ -155,11 +155,13 @@
#define CONFIG_SYS_DDR_SIZE 128 /* MB */
-#define CONFIG_SYS_DDR_CS0_BNDS 0x00000007 +#define CONFIG_SYS_DDR_CS0_BNDS 0x00000007 #define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN \ - | 0x00010000 /* ODT_WR to CSn */ \ - | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10) - /* 0x80010102 */ + | CSCONFIG_ODT_RD_NEVER \ + | CSCONFIG_ODT_WR_ONLY_CURRENT \ + | CSCONFIG_ROW_BIT_13 \ + | CSCONFIG_COL_BIT_10) + /* 0x80010102 */ #define CONFIG_SYS_DDR_TIMING_3 0x00000000 #define CONFIG_SYS_DDR_TIMING_0 ((0 << TIMING_CFG0_RWT_SHIFT) \ | (0 << TIMING_CFG0_WRT_SHIFT) \ @@ -192,7 +194,7 @@ /* 0x03600100 */ #define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SREN \ | SDRAM_CFG_SDRAM_TYPE_DDR2 \ - | SDRAM_CFG_32_BE) + | SDRAM_CFG_DBW_32) /* 0x43080000 */
#define CONFIG_SYS_DDR_SDRAM_CFG2 0x00401000 /* 1 posted refresh */ @@ -248,17 +250,18 @@
#define CONFIG_SYS_BR0_PRELIM (\ CONFIG_SYS_FLASH_BASE /* Flash Base address */ |\ - (2 << BR_PS_SHIFT) /* 16 bit port size */ |\ + BR_PS_16 /* 16 bit port size */ |\ + BR_MS_GPCM /* MSEL = GPCM */ |\ BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) \ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ | OR_UPM_XAM \ | OR_GPCM_CSNT \ | OR_GPCM_ACS_DIV2 \ | OR_GPCM_XACS \ | OR_GPCM_SCY_4 \ - | OR_GPCM_TRLX \ - | OR_GPCM_EHTR \ - | OR_GPCM_EAD) + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + /* [RFC]Reserved on mpc8308: | OR_GPCM_EAD */)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 512 @@ -273,11 +276,12 @@ */ #define CONFIG_SYS_SJA1000_BASE 0xFBFF0000 #define CONFIG_SYS_BR1_PRELIM ( CONFIG_SYS_SJA1000_BASE \ - | (1 << BR_PS_SHIFT) /* 8 bit port size */ \ + | BR_PS_8 /* 8 bit port size */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ | BR_V ) /* valid */ -#define CONFIG_SYS_OR1_PRELIM ( 0xFFFF8000 /* length 32K */ \ +#define CONFIG_SYS_OR1_PRELIM ( OR_AM_32KB \ | OR_GPCM_SCY_5 \ - | OR_GPCM_EHTR) + | OR_GPCM_EHTR_SET) /* 0xFFFF8052 */
#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_SJA1000_BASE @@ -288,11 +292,12 @@ */ #define CONFIG_SYS_CPLD_BASE 0xFBFF8000 #define CONFIG_SYS_BR2_PRELIM ( CONFIG_SYS_CPLD_BASE \ - | (1 << BR_PS_SHIFT) /* 8 bit port size */ \ + | BR_PS_8 /* 8 bit port size */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ | BR_V ) /* valid */ -#define CONFIG_SYS_OR2_PRELIM ( 0xFFFF8000 /* length 32K */ \ +#define CONFIG_SYS_OR2_PRELIM ( OR_AM_32KB \ | OR_GPCM_SCY_4 \ - | OR_GPCM_EHTR) + | OR_GPCM_EHTR_SET) /* 0xFFFF8042 */
#define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_CPLD_BASE @@ -456,7 +461,7 @@ */
/* DDR: cache cacheable */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_128M | \ BATU_VS | BATU_VP) @@ -464,7 +469,7 @@ #define CONFIG_SYS_DBAT0U CONFIG_SYS_IBAT0U
/* IMMRBAR, PCI IO and NAND: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_IMMR | BATU_BL_8M | BATU_VS | \ BATU_VP) @@ -472,17 +477,17 @@ #define CONFIG_SYS_DBAT1U CONFIG_SYS_IBAT1U
/* FLASH: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_FLASH_BASE | BATU_BL_8M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | \ BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT2U CONFIG_SYS_IBAT2U
/* Stack in dcache: cacheable, no memory coherence */ -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_RW) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_INIT_RAM_ADDR | BATU_BL_128K | \ BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT3L CONFIG_SYS_IBAT3L diff --git a/include/configs/sbc8349.h b/include/configs/sbc8349.h index b418cf2..db9340f 100644 --- a/include/configs/sbc8349.h +++ b/include/configs/sbc8349.h @@ -132,8 +132,9 @@ /* * SDRAM on the Local Bus */ -#define CONFIG_SYS_LBC_SDRAM_BASE 0x10000000 /* Localbus SDRAM */ -#define CONFIG_SYS_LBC_SDRAM_SIZE 128 /* LBC SDRAM is 128MB */ +/* [RFC]Changed to match code */ +#define CONFIG_SYS_LBC_SDRAM_BASE 0xF0000000 /* Localbus SDRAM */ +#define CONFIG_SYS_LBC_SDRAM_SIZE 64 /* LBC SDRAM is 64MB */
/* * FLASH on the Local Bus @@ -144,13 +145,23 @@ #define CONFIG_SYS_FLASH_SIZE 8 /* flash size in MB */ /* #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE */
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | /* flash Base address */ \ - (2 << BR_PS_SHIFT) | /* 16 bit port size */ \ - BR_V) /* valid */ - -#define CONFIG_SYS_OR0_PRELIM 0xFF806FF7 /* 8 MB flash size */ +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | \ + BR_PS_16 | /* 16 bit port size */ \ + BR_MS_GPCM | /* MSEL = GPCM */ \ + BR_V) /* valid */ + +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xFF806FF7 */ #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE /* window base at flash base */ -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000016 /* 8 MB window size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_8MB)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 64 /* sectors per device */ @@ -204,14 +215,15 @@ * * 0 4 8 12 16 20 24 28 * 1111 0000 0000 0000 0001 1000 0110 0001 = F0001861 - * - * FIXME: CONFIG_SYS_LBC_SDRAM_BASE should be masked and OR'ed into - * FIXME: the top 17 bits of BR2. */
-#define CONFIG_SYS_BR2_PRELIM 0xF0001861 /* Port-size=32bit, MSEL=SDRAM */ -#define CONFIG_SYS_LBLAWBAR2_PRELIM 0xF0000000 -#define CONFIG_SYS_LBLAWAR2_PRELIM 0x80000019 /* 64M */ +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_LBC_SDRAM_BASE \ + | BR_PS_32 \ + | BR_MS_SDRAM \ + | BR_V) + /* 0xF0001861 */ +#define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_LBC_SDRAM_BASE +#define CONFIG_SYS_LBLAWAR2_PRELIM (LBLAWAR_EN | LBLAWAR_64MB)
/* * The SDRAM size in MB, CONFIG_SYS_LBC_SDRAM_SIZE, is 64. @@ -227,7 +239,12 @@ * 1111 1100 0000 0000 0110 1001 0000 0001 = FC006901 */
-#define CONFIG_SYS_OR2_PRELIM 0xFC006901 +#define CONFIG_SYS_OR2_PRELIM (MEG_TO_AM(CONFIG_SYS_LBC_SDRAM_SIZE) \ + | OR_SDRAM_XAM \ + | ((9 - OR_SDRAM_MIN_COLS) << OR_SDRAM_COLS_SHIFT) \ + | ((13 - OR_SDRAM_MIN_ROWS) << OR_SDRAM_ROWS_SHIFT) \ + | OR_SDRAM_EAD) + /* 0xFC006901 */
#define CONFIG_SYS_LBC_LSRT 0x32000000 /* LB sdram refresh timer, about 6us */ #define CONFIG_SYS_LBC_MRTPR 0x20000000 /* LB refresh timer prescal, 266MHz/32 */ @@ -541,14 +558,14 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* PCI @ 0x80000000 */ #ifdef CONFIG_PCI -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_RW | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP) #else #define CONFIG_SYS_IBAT1L (0) @@ -558,9 +575,9 @@ #endif
#ifdef CONFIG_MPC83XX_PCI2 -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI2_MEM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI2_MEM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_PCI2_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI2_MMIO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI2_MMIO_BASE | BATL_PP_RW | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_PCI2_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP) #else #define CONFIG_SYS_IBAT3L (0) @@ -570,13 +587,13 @@ #endif
-/* SDRAM @ 0xF0000000, stack in DCACHE 0xFDF00000 & FLASH @ 0xFE000000 */ -#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_10 | BATL_MEMCOHERENCE | \ +/* LBC SDRAM @ 0xF0000000, stack in DCACHE 0xFDF00000 & FLASH @ 0xFE000000 */ +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_LBC_SDRAM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE | \ BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT6U (0xF0000000 | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT6U (CONFIG_SYS_LBC_SDRAM_BASE | BATU_BL_256M | BATU_VS | BATU_VP)
#define CONFIG_SYS_IBAT7L (0) #define CONFIG_SYS_IBAT7U (0) diff --git a/include/configs/suvd3.h b/include/configs/suvd3.h index 0b59d51..ae19701 100644 --- a/include/configs/suvd3.h +++ b/include/configs/suvd3.h @@ -70,7 +70,7 @@ OR_GPCM_CSNT | \ OR_GPCM_ACS_DIV4 | \ OR_GPCM_SCY_3 | \ - OR_GPCM_TRLX) + OR_GPCM_TRLX_SET)
#define CONFIG_SYS_MAMR (MxMR_GPL_x4DIS | \ 0x0000c000 | \ @@ -85,19 +85,19 @@
/* APP1: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_APP1_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_APP1_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_APP1_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT5L (CONFIG_SYS_APP1_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT5L (CONFIG_SYS_APP1_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U
-#define CONFIG_SYS_IBAT6L (CONFIG_SYS_APP2_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_APP2_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_APP2_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT6L (CONFIG_SYS_APP2_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT6L (CONFIG_SYS_APP2_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U
diff --git a/include/configs/tuda1.h b/include/configs/tuda1.h index 853c00a..577bbd0 100644 --- a/include/configs/tuda1.h +++ b/include/configs/tuda1.h @@ -73,8 +73,8 @@ OR_GPCM_CSNT | \ OR_GPCM_ACS_DIV4 | \ OR_GPCM_SCY_2 | \ - (OR_GPCM_TRLX & \ - (~OR_GPCM_EHTR)) | /* EHTR = 0 */ \ + OR_GPCM_TRLX_SET | \ + OR_GPCM_EHTR_CLEAR | \ OR_GPCM_EAD) /* * PINC3 on the local bus CS3 @@ -91,11 +91,10 @@
#define CONFIG_SYS_OR3_PRELIM (MEG_TO_AM(CONFIG_SYS_APP2_SIZE) | \ OR_GPCM_CSNT | \ - (OR_GPCM_ACS_DIV2 & /* ACS = 11 */\ - (~OR_GPCM_XACS)) | /* XACS = 0 */\ - (OR_GPCM_SCY_2 & \ - (~OR_GPCM_EHTR)) | /* EHTR = 0 */ \ - OR_GPCM_TRLX) + OR_GPCM_ACS_DIV2 | \ + OR_GPCM_SCY_2 | \ + OR_GPCM_TRLX_SET | \ + OR_GPCM_EHTR_CLEAR)
#define CONFIG_SYS_MAMR (MxMR_GPL_x4DIS | \ 0x0000c000 | \ @@ -106,7 +105,7 @@ */ /* PAXG: icache cacheable, but dcache-inhibit and guarded */ #define CONFIG_SYS_IBAT5L (CONFIG_SYS_APP1_BASE | \ - BATL_PP_10 | \ + BATL_PP_RW | \ BATL_MEMCOHERENCE) /* 512M should also include APP2... */ #define CONFIG_SYS_IBAT5U (CONFIG_SYS_APP1_BASE | \ @@ -114,21 +113,21 @@ BATU_VS | \ BATU_VP) #define CONFIG_SYS_DBAT5L (CONFIG_SYS_APP1_BASE | \ - BATL_PP_10 | \ + BATL_PP_RW | \ BATL_CACHEINHIBIT | \ BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U
/* PINC3: icache cacheable, but dcache-inhibit and guarded */ #define CONFIG_SYS_IBAT6L (CONFIG_SYS_APP2_BASE | \ - BATL_PP_10 | \ + BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_APP2_BASE | \ BATU_BL_256M | \ BATU_VS | \ BATU_VP) #define CONFIG_SYS_DBAT6L (CONFIG_SYS_APP2_BASE | \ - BATL_PP_10 | \ + BATL_PP_RW | \ BATL_CACHEINHIBIT | \ BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U diff --git a/include/configs/tuxa1.h b/include/configs/tuxa1.h index ceeb5a3..36eaf4e 100644 --- a/include/configs/tuxa1.h +++ b/include/configs/tuxa1.h @@ -58,7 +58,7 @@ #define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_LPXF_BASE #define CONFIG_SYS_LBLAWAR2_PRELIM (LBLAWAR_EN | LBLAWAR_256MB)
-#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_LPXF_BASE | \ +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_LPXF_BASE | \ BR_PS_8 | \ BR_MS_GPCM | \ BR_V) @@ -67,8 +67,8 @@ OR_GPCM_CSNT | \ OR_GPCM_ACS_DIV4 | \ OR_GPCM_SCY_2 | \ - (OR_GPCM_TRLX & \ - (~OR_GPCM_EHTR)) | /* EHTR = 0 */ \ + OR_GPCM_TRLX_SET | \ + OR_GPCM_EHTR_CLEAR | \ OR_GPCM_EAD) /* * PINC2 on the local bus CS3 @@ -85,11 +85,10 @@
#define CONFIG_SYS_OR3_PRELIM (MEG_TO_AM(CONFIG_SYS_PINC2_SIZE) | \ OR_GPCM_CSNT | \ - (OR_GPCM_ACS_DIV2 & /* ACS = 11 */ \ - (~OR_GPCM_XACS)) | /* XACS = 0 */ \ - (OR_GPCM_SCY_2 & \ - (~OR_GPCM_EHTR)) | /* EHTR = 0 */ \ - OR_GPCM_TRLX) + OR_GPCM_ACS_DIV2 | \ + OR_GPCM_SCY_2 | \ + OR_GPCM_TRLX_SET | \ + OR_GPCM_EHTR_CLEAR)
#define CONFIG_SYS_MAMR (MxMR_GPL_x4DIS | \ 0x0000c000 | \ @@ -99,20 +98,20 @@ * MMU Setup */ /* LPXF: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_LPXF_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_LPXF_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_LPXF_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT5L (CONFIG_SYS_LPXF_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT5L (CONFIG_SYS_LPXF_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U
/* PINC2: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PINC2_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PINC2_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_PINC2_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT6L (CONFIG_SYS_PINC2_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT6L (CONFIG_SYS_PINC2_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U
diff --git a/include/configs/ve8313.h b/include/configs/ve8313.h index abb57fe..23e811a 100644 --- a/include/configs/ve8313.h +++ b/include/configs/ve8313.h @@ -80,10 +80,11 @@ */ #define CONFIG_SYS_DDR_SIZE 128 /* MB */ #define CONFIG_SYS_DDR_CONFIG ( CSCONFIG_EN \ - | CSCONFIG_AP \ - | 0x00040000 /* TODO */ \ - | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10 ) - /* 0x80840102 */ + | CSCONFIG_AP \ + | CSCONFIG_ODT_RD_NEVER \ + | CSCONFIG_ODT_WR_ALL \ + | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10 ) + /* 0x80840102 */
#define CONFIG_SYS_DDR_TIMING_3 0x00000000 #define CONFIG_SYS_DDR_TIMING_0 ( ( 0 << TIMING_CFG0_RWT_SHIFT ) \ @@ -117,7 +118,7 @@ /* 0x03202000 */ #define CONFIG_SYS_SDRAM_CFG ( SDRAM_CFG_SREN \ | SDRAM_CFG_SDRAM_TYPE_DDR2 \ - | SDRAM_CFG_32_BE ) + | SDRAM_CFG_DBW_32 ) /* 0x43080000 */ #define CONFIG_SYS_SDRAM_CFG2 0x00401000 #define CONFIG_SYS_DDR_MODE ( ( 0x4440 << SDRAM_MODE_ESD_SHIFT ) \ @@ -144,18 +145,19 @@ #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE /* buffer up multiple bytes */
#define CONFIG_SYS_NOR_BR_PRELIM (CONFIG_SYS_FLASH_BASE | \ - (2 << BR_PS_SHIFT) | /* 16 bit */ \ - BR_V) /* valid */ + BR_PS_16 | /* 16 bit */ \ + BR_MS_GPCM | /* MSEL = GPCM */ \ + BR_V) /* valid */ #define CONFIG_SYS_NOR_OR_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ - | OR_GPCM_CSNT \ - | OR_GPCM_ACS_DIV4 \ - | OR_GPCM_SCY_5 \ - | OR_GPCM_TRLX \ - | OR_GPCM_EAD) - /* 0xfe000c55 */ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV4 \ + | OR_GPCM_SCY_5 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EAD) + /* 0xfe000c55 */
#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000018 /* 32 MB window size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_32MB)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 256 /* sectors per dev */ @@ -202,18 +204,18 @@ #define CONFIG_SYS_NAND_BLOCK_SIZE 16384
#define CONFIG_SYS_NAND_BR_PRELIM ( CONFIG_SYS_NAND_BASE \ - | BR_PS_8 \ - | BR_DECC_CHK_GEN \ - | BR_MS_FCM \ - | BR_V ) /* valid */ - /* 0x61000c21 */ -#define CONFIG_SYS_NAND_OR_PRELIM (0xffff8000 \ - | OR_FCM_BCTLD \ - | OR_FCM_CHT \ - | OR_FCM_SCY_2 \ - | OR_FCM_RST \ - | OR_FCM_TRLX) - /* 0xffff90ac */ + | BR_PS_8 \ + | BR_DECC_CHK_GEN \ + | BR_MS_FCM \ + | BR_V ) /* valid */ + /* 0x61000c21 */ +#define CONFIG_SYS_NAND_OR_PRELIM ( OR_AM_32KB \ + | OR_FCM_BCTLD \ + | OR_FCM_CHT \ + | OR_FCM_SCY_2 \ + | OR_FCM_RST \ + | OR_FCM_TRLX) + /* 0xffff90ac */
#define CONFIG_SYS_BR0_PRELIM CONFIG_SYS_NOR_BR_PRELIM #define CONFIG_SYS_OR0_PRELIM CONFIG_SYS_NOR_OR_PRELIM @@ -221,7 +223,7 @@ #define CONFIG_SYS_OR1_PRELIM CONFIG_SYS_NAND_OR_PRELIM
#define CONFIG_SYS_NAND_LBLAWBAR_PRELIM CONFIG_SYS_LBLAWBAR1_PRELIM #define CONFIG_SYS_NAND_LBLAWAR_PRELIM CONFIG_SYS_LBLAWAR1_PRELIM @@ -231,12 +233,12 @@ | BR_PS_8 \ | BR_V) /* 0x60000801 */ -#define CONFIG_SYS_OR2_PRELIM (0xfffe0000 \ +#define CONFIG_SYS_OR2_PRELIM ( OR_AM_128KB \ | OR_GPCM_CSNT \ | OR_GPCM_XACS \ | OR_GPCM_SCY_3 \ - | OR_GPCM_TRLX \ - | OR_GPCM_EHTR \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ | OR_GPCM_EAD) /* 0xfffe0937 */ /* local bus read write buffer mapping SRAM@0x64000000 */ @@ -245,12 +247,12 @@ | BR_V) /* 0x62001001 */
-#define CONFIG_SYS_OR3_PRELIM (0xfe000000 \ +#define CONFIG_SYS_OR3_PRELIM ( OR_AM_32MB \ | OR_GPCM_CSNT \ | OR_GPCM_XACS \ | OR_GPCM_SCY_15 \ - | OR_GPCM_TRLX \ - | OR_GPCM_EHTR \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ | OR_GPCM_EAD) /* 0xfe0009f7 */
@@ -421,16 +423,16 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR @ 0x00000000 */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP)
#if defined(CONFIG_PCI) /* PCI @ 0x80000000 */ -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10) +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_RW) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) @@ -448,17 +450,17 @@ #define CONFIG_SYS_IBAT4U (0)
/* IMMRBAR @ 0xE0000000, PCI IO @ 0xE2000000 & BCSR @ 0xE2400000 */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_IMMR | BATU_BL_256M | BATU_VS | \ BATU_VP)
/* stack in DCACHE 0xFDF00000 & FLASH @ 0xFE000000 */ -#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_10 | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_RW | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT6U (0xF0000000 | BATU_BL_256M | BATU_VS | BATU_VP)
/* FPGA, SRAM, NAND @ 0x60000000 */ -#define CONFIG_SYS_IBAT7L (0x60000000 | BATL_PP_10 | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT7L (0x60000000 | BATL_PP_RW | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT7U (0x60000000 | BATU_BL_256M | BATU_VS | BATU_VP)
#define CONFIG_SYS_DBAT0L CONFIG_SYS_IBAT0L diff --git a/include/configs/vme8349.h b/include/configs/vme8349.h index d153762..f6a47f3 100644 --- a/include/configs/vme8349.h +++ b/include/configs/vme8349.h @@ -109,7 +109,8 @@ #define CONFIG_SYS_DDR_SDRAM_CLK_CNTL (DDR_SDRAM_CLK_CNTL_SS_EN | \ DDR_SDRAM_CLK_CNTL_CLK_ADJUST_075) #define CONFIG_DDR_2T_TIMING -#define CONFIG_SYS_DDRCDR 0x80080001 +#define CONFIG_SYS_DDRCDR (DDRCDR_DHC_EN | DDRCDR_ODT | DDRCDR_Q_DRN) + /* 0x80080001 */
/* * FLASH on the Local Bus @@ -120,29 +121,57 @@ #define CONFIG_SYS_FLASH_BASE 0xffc00000 /* start of FLASH */ #define CONFIG_SYS_FLASH_SIZE 4 /* flash size in MB */ #define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | \ - (2 << BR_PS_SHIFT) | /* 16bit */ \ - BR_V) /* valid */ - -#define CONFIG_SYS_OR0_PRELIM 0xffc06ff7 /* 4 MB flash size */ + BR_PS_16 | /* 16bit */ \ + BR_MS_GPCM | /* MSEL = GPCM */ \ + BR_V) /* valid */ + +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xffc06ff7 */ #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000015 /* 4 MB window size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_4MB) #else #define CONFIG_SYS_FLASH_BASE 0xf8000000 /* start of FLASH */ #define CONFIG_SYS_FLASH_SIZE 128 /* flash size in MB */ #define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | \ - (2 << BR_PS_SHIFT) | /* 16bit */ \ - BR_V) /* valid */ - -#define CONFIG_SYS_OR0_PRELIM 0xf8006ff7 /* 128 MB flash size */ + BR_PS_16 | /* 16bit */ \ + BR_MS_GPCM | /* MSEL = GPCM */ \ + BR_V) /* valid */ + +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xf8006ff7 */ #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x8000001a /* 128 MB window size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_128MB) #endif /* #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE */
-#define CONFIG_SYS_BR1_PRELIM (0xf0000000 | 0x00001801) -#define CONFIG_SYS_OR1_PRELIM (0xfffc0008 | 0x00000200) -#define CONFIG_SYS_LBLAWBAR1_PRELIM 0xf0000000 -#define CONFIG_SYS_LBLAWAR1_PRELIM (0x80000000 | 0x00000011) +#define CONFIG_SYS_WINDOW1_BASE 0xf0000000 +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_WINDOW1_BASE \ + | BR_PS_32 \ + | BR_MS_GPCM \ + | BR_V) + /* 0xF0001801 */ +#define CONFIG_SYS_OR1_PRELIM (OR_AM_256KB \ + | 0x00000200 /* [RFC]Reserved ACS value on MPC8349 */ \ + | OR_GPCM_SETA) + /* 0xfffc0208 */ +#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_WINDOW1_BASE +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_256KB)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device*/ @@ -465,18 +494,18 @@ #define CONFIG_HIGH_BATS /* High BATs supported */
/* DDR @ 0x00000000 */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP)
/* PCI @ 0x80000000 */ #ifdef CONFIG_PCI -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) @@ -488,11 +517,11 @@ #endif
#ifdef CONFIG_MPC83XX_PCI2 -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI2_MEM_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI2_MEM_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_PCI2_MEM_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI2_MMIO_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI2_MMIO_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_PCI2_MMIO_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) @@ -504,17 +533,17 @@ #endif
/* IMMRBAR @ 0xE0000000, PCI IO @ 0xE2000000 */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_IMMR | BATU_BL_256M | \ BATU_VS | BATU_VP)
-#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (0xF0000000 | BATU_BL_256M | BATU_VS | BATU_VP)
#if (CONFIG_SYS_DDR_SIZE == 512) #define CONFIG_SYS_IBAT7L (CONFIG_SYS_SDRAM_BASE+0x10000000 | \ - BATL_PP_10 | BATL_MEMCOHERENCE) + BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT7U (CONFIG_SYS_SDRAM_BASE+0x10000000 | \ BATU_BL_256M | BATU_VS | BATU_VP) #else diff --git a/include/mpc83xx.h b/include/mpc83xx.h index 8292018..15ef487 100644 --- a/include/mpc83xx.h +++ b/include/mpc83xx.h @@ -905,9 +905,29 @@ */ #define CSCONFIG_EN 0x80000000 #define CSCONFIG_AP 0x00800000 -#define CSCONFIG_ODT_WR_ACS 0x00010000 -#if defined(CONFIG_MPC832x) +#if defined(CONFIG_MPC8308) || defined(CONFIG_MPC831x) +#define CSCONFIG_ODT_RD_NEVER 0x00000000 +#define CSCONFIG_ODT_RD_ONLY_CURRENT 0x00100000 +#define CSCONFIG_ODT_RD_ONLY_OTHER_CS 0x00200000 +#define CSCONFIG_ODT_RD_ALL 0x00400000 +#define CSCONFIG_ODT_WR_NEVER 0x00000000 +#define CSCONFIG_ODT_WR_ONLY_CURRENT 0x00010000 +#define CSCONFIG_ODT_WR_ONLY_OTHER_CS 0x00020000 +#define CSCONFIG_ODT_WR_ALL 0x00040000 +#elif defined(CONFIG_MPC832x) +#define CSCONFIG_ODT_RD_CFG 0x00400000 #define CSCONFIG_ODT_WR_CFG 0x00040000 +#elif defined(CONFIG_MPC8360) || defined(CONFIG_MPC837x) +#define CSCONFIG_ODT_RD_NEVER 0x00000000 +#define CSCONFIG_ODT_RD_ONLY_CURRENT 0x00100000 +#define CSCONFIG_ODT_RD_ONLY_OTHER_CS 0x00200000 +#define CSCONFIG_ODT_RD_ONLY_OTHER_DIMM 0x00300000 +#define CSCONFIG_ODT_RD_ALL 0x00400000 +#define CSCONFIG_ODT_WR_NEVER 0x00000000 +#define CSCONFIG_ODT_WR_ONLY_CURRENT 0x00010000 +#define CSCONFIG_ODT_WR_ONLY_OTHER_CS 0x00020000 +#define CSCONFIG_ODT_WR_ONLY_OTHER_DIMM 0x00030000 +#define CSCONFIG_ODT_WR_ALL 0x00040000 #endif #define CSCONFIG_BANK_BIT_3 0x00004000 #define CSCONFIG_ROW_BIT 0x00000700 @@ -996,8 +1016,16 @@ #define SDRAM_CFG_SDRAM_TYPE_MASK 0x07000000 #define SDRAM_CFG_SDRAM_TYPE_SHIFT 24 #define SDRAM_CFG_DYN_PWR 0x00200000 +#if defined(CONFIG_MPC8308) || defined(CONFIG_MPC831x) +#define SDRAM_CFG_DBW_MASK 0x00180000 +#define SDRAM_CFG_DBW_16 0x00100000 +#define SDRAM_CFG_DBW_32 0x00080000 +#else #define SDRAM_CFG_32_BE 0x00080000 +#endif +#if !defined(CONFIG_MPC8308) #define SDRAM_CFG_8_BE 0x00040000 +#endif #define SDRAM_CFG_NCAP 0x00020000 #define SDRAM_CFG_2T_EN 0x00008000 #define SDRAM_CFG_HSE 0x00000008
On Fri, Aug 12, 2011 at 1:38 AM, Joe Hershberger joe.hershberger@ni.com wrote:
Attempt to make 83xx use constants consistently. In the course of switching from numerics to field constants, a number of reserved fields being assigned were found. Those places that seemed broken I marked with [RFC]... please provide guidance if you are familiar with that target.
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com
arch/powerpc/cpu/mpc83xx/spd_sdram.c |   9 ++  arch/powerpc/include/asm/fsl_lbc.h  |   8 +-  include/configs/MERGERBOX.h      |  28 +++--  include/configs/MPC8308RDB.h     |  50 +++++---  include/configs/MPC8313ERDB.h     |  80 +++++++++----  include/configs/MPC8315ERDB.h     |  49 ++++----  include/configs/MPC8323ERDB.h     |  114 ++++++-------------  include/configs/MPC832XEMDS.h     |  213 +++++++++++++++++++---------------  include/configs/MPC8349EMDS.h     |  107 ++++++++++-------  include/configs/MPC8349ITX.h     |  35 +++---  include/configs/MPC8360EMDS.h     |  146 ++++++++++++++++--------  include/configs/MPC8360ERDK.h     |  74 +++++++-----  include/configs/MPC837XEMDS.h     |  111 ++++++++++--------  include/configs/MPC837XERDB.h     |  118 +++++++++++--------  include/configs/MVBLM7.h       |  28 +++--  include/configs/SIMPC8313.h      |  26 ++--  include/configs/TQM834x.h       |  20 ++--  include/configs/km/km83xx-common.h  |  28 +++--  include/configs/kmeter1.h       |  20 ++--  include/configs/kmsupx5.h       |   8 +-  include/configs/mpc8308_p1m.h     |  47 ++++----  include/configs/sbc8349.h       |  65 +++++++----  include/configs/suvd3.h        |  10 +-  include/configs/tuda1.h        |  21 ++--  include/configs/tuxa1.h        |  23 ++--  include/configs/ve8313.h       |  80 +++++++------  include/configs/vme8349.h       |  75 ++++++++----  include/mpc83xx.h           |  32 +++++-  28 files changed, 942 insertions(+), 683 deletions(-)
Didn't realize this was so big (147kB)... splitting it up...
-Joe
Joe Hershberger (4): powerpc/mpc83xx: Whitespace changes powerpc/mpx83xx: Cleanup usage of BAT constants powerpc/mpc83xx: Cleanup usage of DDR constants powerpc/mpc83xx: Cleanup usage of LBC constants
Changes for v3: - Left out [RFC] changes that Kim removed - Broke the whitespace changes patch up - Make all mpc83xx config files checkpatch.pl compliant (with exceptions) - COMPLEX_MACRO and MULTISTATEMENT_MACRO_USE_DO_WHILE need to be ignored - Moved the "Rename CONFIG_SYS_DDR_CONFIG..." patch into this series
Joe Hershberger (24): mpc83xx: cosmetic: MERGERBOX.h checkpatch compliance mpc83xx: cosmetic: MPC8308RDB.h checkpatch compliance mpc83xx: cosmetic: MPC8313ERDB.h checkpatch compliance mpc83xx: cosmetic: MPC8315ERDB.h checkpatch compliance mpc83xx: cosmetic: MPC8323ERDB.h checkpatch compliance mpc83xx: cosmetic: MPC832XEMDS.h checkpatch compliance mpc83xx: cosmetic: MPC8349EMDS.h checkpatch compliance mpc83xx: cosmetic: MPC8349ITX.h checkpatch compliance mpc83xx: cosmetic: MPC8360EMDS.h checkpatch compliance mpc83xx: cosmetic: MPC8360ERDK.h checkpatch compliance mpc83xx: cosmetic: MPC837XEMDS.h checkpatch compliance mpc83xx: cosmetic: MPC837XERDB.h checkpatch compliance mpc83xx: cosmetic: MVBLM7.h checkpatch compliance mpc83xx: cosmetic: SIMPC8313.h checkpatch compliance mpc83xx: cosmetic: TQM834x.h checkpatch compliance mpc83xx: cosmetic: kmeter1.h checkpatch compliance mpc83xx: cosmetic: mpc8308_p1m.h checkpatch compliance mpc83xx: cosmetic: sbc8349.h checkpatch compliance mpc83xx: cosmetic: ve8313.h checkpatch compliance mpc83xx: cosmetic: vme8349.h checkpatch compliance mpc83xx: Cleanup usage of BAT constants mpc83xx: Cleanup usage of DDR constants mpc83xx: Cleanup usage of LBC constants mpc83xx: Rename CONFIG_SYS_DDR_CONFIG and cleanup DDR csbnds code
arch/powerpc/cpu/mpc83xx/spd_sdram.c | 9 + arch/powerpc/include/asm/fsl_lbc.h | 8 +- board/freescale/mpc8313erdb/sdram.c | 10 +- board/freescale/mpc8349emds/mpc8349emds.c | 27 +- board/freescale/mpc8349itx/mpc8349itx.c | 28 ++- board/freescale/mpc8360emds/mpc8360emds.c | 42 ++-- board/sbc8349/sbc8349.c | 27 +- board/ve8313/ve8313.c | 10 +- include/configs/MERGERBOX.h | 40 ++-- include/configs/MPC8308RDB.h | 66 +++-- include/configs/MPC8313ERDB.h | 308 +++++++++++++++--------- include/configs/MPC8315ERDB.h | 287 +++++++++++++---------- include/configs/MPC8323ERDB.h | 319 ++++++++++++------------- include/configs/MPC832XEMDS.h | 374 +++++++++++++++++------------ include/configs/MPC8349EMDS.h | 327 ++++++++++++++++---------- include/configs/MPC8349ITX.h | 335 ++++++++++++++++---------- include/configs/MPC8360EMDS.h | 307 ++++++++++++++++-------- include/configs/MPC8360ERDK.h | 315 +++++++++++++++---------- include/configs/MPC837XEMDS.h | 325 +++++++++++++++---------- include/configs/MPC837XERDB.h | 291 ++++++++++++++--------- include/configs/MVBLM7.h | 125 +++++++---- include/configs/SIMPC8313.h | 296 +++++++++++++---------- include/configs/TQM834x.h | 278 +++++++++++++--------- include/configs/km/km83xx-common.h | 28 ++- include/configs/kmeter1.h | 24 +- include/configs/kmsupx5.h | 8 +- include/configs/mpc8308_p1m.h | 63 +++--- include/configs/sbc8349.h | 287 ++++++++++++++--------- include/configs/suvd3.h | 10 +- include/configs/tuda1.h | 21 +- include/configs/tuxa1.h | 21 +- include/configs/ve8313.h | 230 ++++++++++-------- include/configs/vme8349.h | 115 ++++++---- include/mpc83xx.h | 32 +++- 34 files changed, 2993 insertions(+), 2000 deletions(-)
On Tue, 11 Oct 2011 23:57:07 -0500 Joe Hershberger joe.hershberger@ni.com wrote:
Changes for v3:
all 24 patches applied to u-boot-mpc83xx/master.
Thanks,
Kim
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- include/configs/MERGERBOX.h | 12 ++++++------ 1 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/include/configs/MERGERBOX.h b/include/configs/MERGERBOX.h index f9681cd..105a45a 100644 --- a/include/configs/MERGERBOX.h +++ b/include/configs/MERGERBOX.h @@ -177,7 +177,7 @@ */ #define CONFIG_MTD_NAND_VERIFY_WRITE 1 #define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_NAND_FSL_ELBC 1 +#define CONFIG_NAND_FSL_ELBC 1
#define CONFIG_SYS_NAND_BASE 0xE0600000 #define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_NAND_BASE | (2<<BR_DECC_SHIFT) |\ @@ -474,7 +474,7 @@ #define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 #define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 6 #define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 10 -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 #define CONFIG_SYS_EEPROM_SIZE 0x4000
/* @@ -531,8 +531,8 @@ #define CONFIG_ZERO_BOOTDELAY_CHECK #define CONFIG_RESET_TO_RETRY 1000
-#define MV_CI MergerBox -#define MV_VCI MergerBox +#define MV_CI "MergerBox" +#define MV_VCI "MergerBox" #define MV_FPGA_DATA 0xfc100000 #define MV_FPGA_SIZE 0x00200000
@@ -571,8 +571,8 @@ "mv_version=" U_BOOT_VERSION "\0"\ "mtdids=" MTDIDS_DEFAULT "\0"\ "mtdparts=" MTDPARTS_DEFAULT "\0"\ - "dhcp_client_id=" MK_STR(MV_CI) "\0"\ - "dhcp_vendor-class-identifier=" MK_STR(MV_VCI) "\0"\ + "dhcp_client_id=" MV_CI "\0"\ + "dhcp_vendor-class-identifier=" MV_VCI "\0"\ "upd_uboot=dhcp;tftp bdi2000/u-boot-mergerbox-xp.bin;"\ "protect off all;erase $uboota +0xC0000;"\ "cp.b $loadaddr $uboota $filesize\0"\
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- include/configs/MPC8308RDB.h | 16 ++++++++-------- 1 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/include/configs/MPC8308RDB.h b/include/configs/MPC8308RDB.h index 3ff175c..e6b83c8 100644 --- a/include/configs/MPC8308RDB.h +++ b/include/configs/MPC8308RDB.h @@ -212,7 +212,7 @@ */ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_OFFSET \ (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
@@ -262,19 +262,19 @@ /* * NAND Flash on the Local Bus */ -#define CONFIG_SYS_NAND_BASE 0xE0600000 /* 0xE0600000 */ -#define CONFIG_SYS_BR1_PRELIM ( CONFIG_SYS_NAND_BASE \ +#define CONFIG_SYS_NAND_BASE 0xE0600000 /* 0xE0600000 */ +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_NAND_BASE \ | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ - | BR_PS_8 /* Port Size = 8 bit */ \ + | BR_PS_8 /* 8 bit port */ \ | BR_MS_FCM /* MSEL = FCM */ \ - | BR_V ) /* valid */ -#define CONFIG_SYS_OR1_PRELIM ( 0xFFFF8000 /* length 32K */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR1_PRELIM (0xFFFF8000 /* length 32K */ \ | OR_FCM_CSCT \ | OR_FCM_CST \ | OR_FCM_CHT \ | OR_FCM_SCY_1 \ | OR_FCM_TRLX \ - | OR_FCM_EHTR ) + | OR_FCM_EHTR) /* 0xFFFF8396 */
#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_NAND_BASE @@ -323,7 +323,7 @@ #define CONFIG_I2C_MULTI_BUS #define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ #define CONFIG_SYS_I2C_SLAVE 0x7F -#define CONFIG_SYS_I2C_NOPROBES {{0x51}} /* Don't probe these addrs */ +#define CONFIG_SYS_I2C_NOPROBES { {0, 0x51} } /* Don't probe these addrs */ #define CONFIG_SYS_I2C_OFFSET 0x3000 #define CONFIG_SYS_I2C2_OFFSET 0x3100
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- include/configs/MPC8313ERDB.h | 248 +++++++++++++++++++++++------------------ 1 files changed, 142 insertions(+), 106 deletions(-)
diff --git a/include/configs/MPC8313ERDB.h b/include/configs/MPC8313ERDB.h index 92c54d0..edcd085 100644 --- a/include/configs/MPC8313ERDB.h +++ b/include/configs/MPC8313ERDB.h @@ -121,7 +121,7 @@ /* * DDR Setup */ -#define CONFIG_SYS_DDR_BASE 0x00000000 /* DDR is system memory*/ +#define CONFIG_SYS_DDR_BASE 0x00000000 /* DDR is system memory*/ #define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_BASE #define CONFIG_SYS_DDR_SDRAM_BASE CONFIG_SYS_DDR_BASE
@@ -129,121 +129,126 @@ * Manually set up DDR parameters, as this board does not * seem to have the SPD connected to I2C. */ -#define CONFIG_SYS_DDR_SIZE 128 /* MB */ -#define CONFIG_SYS_DDR_CONFIG ( CSCONFIG_EN \ - | 0x00010000 /* TODO */ \ - | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10 ) +#define CONFIG_SYS_DDR_SIZE 128 /* MB */ +#define CONFIG_SYS_DDR_CONFIG (CSCONFIG_EN \ + | 0x00010000 /* TODO */ \ + | CSCONFIG_ROW_BIT_13 \ + | CSCONFIG_COL_BIT_10) /* 0x80010102 */
#define CONFIG_SYS_DDR_TIMING_3 0x00000000 -#define CONFIG_SYS_DDR_TIMING_0 ( ( 0 << TIMING_CFG0_RWT_SHIFT ) \ - | ( 0 << TIMING_CFG0_WRT_SHIFT ) \ - | ( 0 << TIMING_CFG0_RRT_SHIFT ) \ - | ( 0 << TIMING_CFG0_WWT_SHIFT ) \ - | ( 2 << TIMING_CFG0_ACT_PD_EXIT_SHIFT ) \ - | ( 2 << TIMING_CFG0_PRE_PD_EXIT_SHIFT ) \ - | ( 8 << TIMING_CFG0_ODT_PD_EXIT_SHIFT ) \ - | ( 2 << TIMING_CFG0_MRS_CYC_SHIFT ) ) +#define CONFIG_SYS_DDR_TIMING_0 ((0 << TIMING_CFG0_RWT_SHIFT) \ + | (0 << TIMING_CFG0_WRT_SHIFT) \ + | (0 << TIMING_CFG0_RRT_SHIFT) \ + | (0 << TIMING_CFG0_WWT_SHIFT) \ + | (2 << TIMING_CFG0_ACT_PD_EXIT_SHIFT) \ + | (2 << TIMING_CFG0_PRE_PD_EXIT_SHIFT) \ + | (8 << TIMING_CFG0_ODT_PD_EXIT_SHIFT) \ + | (2 << TIMING_CFG0_MRS_CYC_SHIFT)) /* 0x00220802 */ -#define CONFIG_SYS_DDR_TIMING_1 ( ( 3 << TIMING_CFG1_PRETOACT_SHIFT ) \ - | ( 8 << TIMING_CFG1_ACTTOPRE_SHIFT ) \ - | ( 3 << TIMING_CFG1_ACTTORW_SHIFT ) \ - | ( 5 << TIMING_CFG1_CASLAT_SHIFT ) \ - | (10 << TIMING_CFG1_REFREC_SHIFT ) \ - | ( 3 << TIMING_CFG1_WRREC_SHIFT ) \ - | ( 2 << TIMING_CFG1_ACTTOACT_SHIFT ) \ - | ( 2 << TIMING_CFG1_WRTORD_SHIFT ) ) +#define CONFIG_SYS_DDR_TIMING_1 ((3 << TIMING_CFG1_PRETOACT_SHIFT) \ + | (8 << TIMING_CFG1_ACTTOPRE_SHIFT) \ + | (3 << TIMING_CFG1_ACTTORW_SHIFT) \ + | (5 << TIMING_CFG1_CASLAT_SHIFT) \ + | (10 << TIMING_CFG1_REFREC_SHIFT) \ + | (3 << TIMING_CFG1_WRREC_SHIFT) \ + | (2 << TIMING_CFG1_ACTTOACT_SHIFT) \ + | (2 << TIMING_CFG1_WRTORD_SHIFT)) /* 0x3835a322 */ -#define CONFIG_SYS_DDR_TIMING_2 ( ( 1 << TIMING_CFG2_ADD_LAT_SHIFT ) \ - | ( 5 << TIMING_CFG2_CPO_SHIFT ) \ - | ( 2 << TIMING_CFG2_WR_LAT_DELAY_SHIFT ) \ - | ( 2 << TIMING_CFG2_RD_TO_PRE_SHIFT ) \ - | ( 2 << TIMING_CFG2_WR_DATA_DELAY_SHIFT ) \ - | ( 3 << TIMING_CFG2_CKE_PLS_SHIFT ) \ - | ( 6 << TIMING_CFG2_FOUR_ACT_SHIFT) ) +#define CONFIG_SYS_DDR_TIMING_2 ((1 << TIMING_CFG2_ADD_LAT_SHIFT) \ + | (5 << TIMING_CFG2_CPO_SHIFT) \ + | (2 << TIMING_CFG2_WR_LAT_DELAY_SHIFT) \ + | (2 << TIMING_CFG2_RD_TO_PRE_SHIFT) \ + | (2 << TIMING_CFG2_WR_DATA_DELAY_SHIFT) \ + | (3 << TIMING_CFG2_CKE_PLS_SHIFT) \ + | (6 << TIMING_CFG2_FOUR_ACT_SHIFT)) /* 0x129048c6 */ /* P9-45,may need tuning */ -#define CONFIG_SYS_DDR_INTERVAL ( ( 1296 << SDRAM_INTERVAL_REFINT_SHIFT ) \ - | ( 1280 << SDRAM_INTERVAL_BSTOPRE_SHIFT ) ) +#define CONFIG_SYS_DDR_INTERVAL ((1296 << SDRAM_INTERVAL_REFINT_SHIFT) \ + | (1280 << SDRAM_INTERVAL_BSTOPRE_SHIFT)) /* 0x05100500 */ #if defined(CONFIG_DDR_2T_TIMING) -#define CONFIG_SYS_SDRAM_CFG ( SDRAM_CFG_SREN \ +#define CONFIG_SYS_SDRAM_CFG (SDRAM_CFG_SREN \ | SDRAM_CFG_SDRAM_TYPE_DDR2 \ | SDRAM_CFG_2T_EN \ - | SDRAM_CFG_DBW_32 ) + | SDRAM_CFG_DBW_32) #else -#define CONFIG_SYS_SDRAM_CFG ( SDRAM_CFG_SREN \ +#define CONFIG_SYS_SDRAM_CFG (SDRAM_CFG_SREN \ | SDRAM_CFG_SDRAM_TYPE_DDR2 \ - | SDRAM_CFG_32_BE ) + | SDRAM_CFG_32_BE) /* 0x43080000 */ #endif #define CONFIG_SYS_SDRAM_CFG2 0x00401000 /* set burst length to 8 for 32-bit data path */ -#define CONFIG_SYS_DDR_MODE ( ( 0x4448 << SDRAM_MODE_ESD_SHIFT ) \ - | ( 0x0632 << SDRAM_MODE_SD_SHIFT ) ) +#define CONFIG_SYS_DDR_MODE ((0x4448 << SDRAM_MODE_ESD_SHIFT) \ + | (0x0632 << SDRAM_MODE_SD_SHIFT)) /* 0x44480632 */ -#define CONFIG_SYS_DDR_MODE_2 0x8000C000 +#define CONFIG_SYS_DDR_MODE_2 0x8000C000
#define CONFIG_SYS_DDR_CLK_CNTL DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05 /*0x02000000*/ -#define CONFIG_SYS_DDRCDR_VALUE ( DDRCDR_EN \ +#define CONFIG_SYS_DDRCDR_VALUE (DDRCDR_EN \ | DDRCDR_PZ_NOMZ \ | DDRCDR_NZ_NOMZ \ - | DDRCDR_M_ODR ) + | DDRCDR_M_ODR)
/* * FLASH on the Local Bus */ -#define CONFIG_SYS_FLASH_CFI /* use the Common Flash Interface */ -#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ +#define CONFIG_SYS_FLASH_CFI /* use the Common Flash Interface */ +#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ #define CONFIG_SYS_FLASH_BASE 0xFE000000 /* start of FLASH */ -#define CONFIG_SYS_FLASH_SIZE 8 /* flash size in MB */ -#define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */ -#define CONFIG_SYS_FLASH_EMPTY_INFO /* display empty sectors */ -#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE /* buffer up multiple bytes */ - -#define CONFIG_SYS_NOR_BR_PRELIM (CONFIG_SYS_FLASH_BASE | /* flash Base address */ \ - (2 << BR_PS_SHIFT) | /* 16 bit port size */ \ - BR_V) /* valid */ -#define CONFIG_SYS_NOR_OR_PRELIM ( 0xFF800000 /* 8 MByte */ \ +#define CONFIG_SYS_FLASH_SIZE 8 /* flash size in MB */ +#define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */ +#define CONFIG_SYS_FLASH_EMPTY_INFO /* display empty sectors */ +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE /* buffer up multiple bytes */ + +#define CONFIG_SYS_NOR_BR_PRELIM (CONFIG_SYS_FLASH_BASE \ + | (2 << BR_PS_SHIFT) /* 16 bit port */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_NOR_OR_PRELIM (0xFF800000 /* 8 MByte */ \ | OR_GPCM_XACS \ | OR_GPCM_SCY_9 \ | OR_GPCM_EHTR \ - | OR_GPCM_EAD ) + | OR_GPCM_EAD) /* 0xFF006FF7 TODO SLOW 16 MB flash size */ -#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE /* window base at flash base */ + /* window base at flash base */ +#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000017 /* 16 MB window size */
-#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 135 /* sectors per device */ +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 135 /* sectors per device */
#define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */
-#if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) && !defined(CONFIG_NAND_SPL) +#if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) && \ + !defined(CONFIG_NAND_SPL) #define CONFIG_SYS_RAMBOOT #endif
#define CONFIG_SYS_INIT_RAM_LOCK 1 -#define CONFIG_SYS_INIT_RAM_ADDR 0xFD000000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM*/ +#define CONFIG_SYS_INIT_RAM_ADDR 0xFD000000 /* Initial RAM addr */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM*/
-#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* CONFIG_SYS_MONITOR_LEN must be a multiple of CONFIG_ENV_SECT_SIZE */ -#define CONFIG_SYS_MONITOR_LEN (384 * 1024) /* Reserve 384 kB for Mon */ -#define CONFIG_SYS_MALLOC_LEN (512 * 1024) /* Reserved for malloc */ +#define CONFIG_SYS_MONITOR_LEN (384 * 1024) /* Reserve 384 kB for Mon */ +#define CONFIG_SYS_MALLOC_LEN (512 * 1024) /* Reserved for malloc */
/* * Local Bus LCRR and LBCR regs */ #define CONFIG_SYS_LCRR_EADC LCRR_EADC_1 #define CONFIG_SYS_LCRR_CLKDIV LCRR_CLKDIV_4 -#define CONFIG_SYS_LBC_LBCR ( 0x00040000 /* TODO */ \ - | (0xFF << LBCR_BMT_SHIFT) \ - | 0xF ) /* 0x0004ff0f */ +#define CONFIG_SYS_LBC_LBCR (0x00040000 /* TODO */ \ + | (0xFF << LBCR_BMT_SHIFT) \ + | 0xF) /* 0x0004ff0f */
-#define CONFIG_SYS_LBC_MRTPR 0x20000000 /*TODO */ /* LB refresh timer prescal, 266MHz/32 */ + /* LB refresh timer prescal, 266MHz/32 */ +#define CONFIG_SYS_LBC_MRTPR 0x20000000 /*TODO */
/* drivers/mtd/nand/nand.c */ #ifdef CONFIG_NAND_SPL @@ -256,7 +261,7 @@ #define CONFIG_MTD_PARTITION #define CONFIG_CMD_MTDPARTS #define MTDIDS_DEFAULT "nand0=e2800000.flash" -#define MTDPARTS_DEFAULT \ +#define MTDPARTS_DEFAULT \ "mtdparts=e0600000.flash:512k(uboot),128k(env),3m@1m(kernel),-(fs)"
#define CONFIG_SYS_MAX_NAND_DEVICE 1 @@ -266,18 +271,18 @@ #define CONFIG_SYS_NAND_BLOCK_SIZE 16384
-#define CONFIG_SYS_NAND_BR_PRELIM ( CONFIG_SYS_NAND_BASE \ +#define CONFIG_SYS_NAND_BR_PRELIM (CONFIG_SYS_NAND_BASE \ | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ - | BR_PS_8 /* Port Size = 8 bit */ \ + | BR_PS_8 /* 8 bit port */ \ | BR_MS_FCM /* MSEL = FCM */ \ - | BR_V ) /* valid */ -#define CONFIG_SYS_NAND_OR_PRELIM ( 0xFFFF8000 /* length 32K */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_NAND_OR_PRELIM (0xFFFF8000 /* length 32K */ \ | OR_FCM_CSCT \ | OR_FCM_CST \ | OR_FCM_CHT \ | OR_FCM_SCY_1 \ | OR_FCM_TRLX \ - | OR_FCM_EHTR ) + | OR_FCM_EHTR) /* 0xFFFF8396 */
#ifdef CONFIG_NAND_U_BOOT @@ -310,10 +315,14 @@
#ifdef CONFIG_VSC7385_ENET
-#define CONFIG_SYS_BR2_PRELIM 0xf0000801 /* VSC7385 Base address */ -#define CONFIG_SYS_OR2_PRELIM 0xfffe09ff /* VSC7385, 128K bytes*/ -#define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_VSC7385_BASE/* Access window base at VSC7385 base */ -#define CONFIG_SYS_LBLAWAR2_PRELIM 0x80000010 /* Access window size 128K */ + /* VSC7385 Base address */ +#define CONFIG_SYS_BR2_PRELIM 0xf0000801 + /* VSC7385, 128K bytes*/ +#define CONFIG_SYS_OR2_PRELIM 0xfffe09ff + /* Access window base at VSC7385 base */ +#define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_VSC7385_BASE + /* Access window size 128K */ +#define CONFIG_SYS_LBLAWAR2_PRELIM 0x80000010
#endif
@@ -344,11 +353,11 @@ #define CONFIG_HARD_I2C /* I2C with hardware support*/ #define CONFIG_FSL_I2C #define CONFIG_I2C_MULTI_BUS -#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ -#define CONFIG_SYS_I2C_SLAVE 0x7F -#define CONFIG_SYS_I2C_NOPROBES {{0,0x69}} /* Don't probe these addrs */ -#define CONFIG_SYS_I2C_OFFSET 0x3000 -#define CONFIG_SYS_I2C2_OFFSET 0x3100 +#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_I2C_SLAVE 0x7F +#define CONFIG_SYS_I2C_NOPROBES { {0, 0x69} } /* Don't probe these addrs */ +#define CONFIG_SYS_I2C_OFFSET 0x3000 +#define CONFIG_SYS_I2C2_OFFSET 0x3100
/* * General PCI @@ -413,10 +422,12 @@ #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE #define CONFIG_ENV_RANGE (CONFIG_ENV_SECT_SIZE * 4) - #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_RANGE) + #define CONFIG_ENV_OFFSET_REDUND \ + (CONFIG_ENV_OFFSET + CONFIG_ENV_RANGE) #elif !defined(CONFIG_SYS_RAMBOOT) #define CONFIG_ENV_IS_IN_FLASH 1 - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) + #define CONFIG_ENV_ADDR \ + (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K(one sector) for env */ #define CONFIG_ENV_SIZE 0x2000
@@ -467,17 +478,21 @@ #define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */
-#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ -#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */ + /* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ + /* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */
/* * For booting Linux, the board info and command line data * have to be in the first 256 MB of memory, since this is * the maximum mapped by the Linux kernel during initialization. */ -#define CONFIG_SYS_BOOTMAPSZ (256 << 20) /* Initial Memory map for Linux*/ + /* Initial Memory map for Linux*/ +#define CONFIG_SYS_BOOTMAPSZ (256 << 20)
#define CONFIG_SYS_RCWH_PCIHOST 0x80000000 /* PCIHOST */
@@ -535,7 +550,7 @@
/* System IO Config */ #define CONFIG_SYS_SICRH (SICRH_TSOBI1 | SICRH_TSOBI2) /* RGMII */ -#define CONFIG_SYS_SICRL SICRL_USBDR_10 /* Enable Internal USB Phy */ +#define CONFIG_SYS_SICRL SICRL_USBDR_10 /* Enable Internal USB Phy */
#define CONFIG_SYS_HID0_INIT 0x000000000 #define CONFIG_SYS_HID0_FINAL (HID0_ENABLE_MACHINE_CHECK | \ @@ -548,13 +563,25 @@
/* DDR @ 0x00000000 */ #define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10) -#define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP)
/* PCI @ 0x80000000 */ #define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10) -#define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP)
/* PCI2 not supported on 8313 */ #define CONFIG_SYS_IBAT3L (0) @@ -563,8 +590,14 @@ #define CONFIG_SYS_IBAT4U (0)
/* IMMRBAR @ 0xE0000000, PCI IO @ 0xE2000000 & BCSR @ 0xE2400000 */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT5U (CONFIG_SYS_IMMR | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT5U (CONFIG_SYS_IMMR \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP)
/* SDRAM @ 0xF0000000, stack in DCACHE 0xFDF00000 & FLASH @ 0xFE000000 */ #define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_10 | BATL_GUARDEDSTORAGE) @@ -595,15 +628,17 @@ */ #define CONFIG_ENV_OVERWRITE
-#define CONFIG_NETDEV eth1 +#define CONFIG_NETDEV "eth1"
#define CONFIG_HOSTNAME mpc8313erdb #define CONFIG_ROOTPATH /nfs/root/path #define CONFIG_BOOTFILE uImage -#define CONFIG_UBOOTPATH u-boot.bin /* U-Boot image on TFTP server */ -#define CONFIG_FDTFILE mpc8313erdb.dtb + /* U-Boot image on TFTP server */ +#define CONFIG_UBOOTPATH "u-boot.bin" +#define CONFIG_FDTFILE "mpc8313erdb.dtb"
-#define CONFIG_LOADADDR 800000 /* default location for tftp and bootm */ + /* default location for tftp and bootm */ +#define CONFIG_LOADADDR 800000 #define CONFIG_BOOTDELAY 6 /* -1 disables auto-boot */ #define CONFIG_BAUDRATE 115200
@@ -611,22 +646,23 @@ #define MK_STR(x) XMK_STR(x)
#define CONFIG_EXTRA_ENV_SETTINGS \ - "netdev=" MK_STR(CONFIG_NETDEV) "\0" \ + "netdev=" CONFIG_NETDEV "\0" \ "ethprime=TSEC1\0" \ - "uboot=" MK_STR(CONFIG_UBOOTPATH) "\0" \ + "uboot=" CONFIG_UBOOTPATH "\0" \ "tftpflash=tftpboot $loadaddr $uboot; " \ - "protect off " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; " \ - "erase " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; " \ - "cp.b $loadaddr " MK_STR(CONFIG_SYS_TEXT_BASE) " $filesize; " \ - "protect on " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; " \ - "cmp.b $loadaddr " MK_STR(CONFIG_SYS_TEXT_BASE) " $filesize\0" \ + "protect off " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; "\ + "erase " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; " \ + "cp.b $loadaddr " MK_STR(CONFIG_SYS_TEXT_BASE) " $filesize; "\ + "protect on " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; "\ + "cmp.b $loadaddr " MK_STR(CONFIG_SYS_TEXT_BASE) " $filesize\0"\ "fdtaddr=780000\0" \ - "fdtfile=" MK_STR(CONFIG_FDTFILE) "\0" \ + "fdtfile=" CONFIG_FDTFILE "\0" \ "console=ttyS0\0" \ "setbootargs=setenv bootargs " \ "root=$rootdev rw console=$console,$baudrate $othbootargs\0" \ "setipargs=setenv bootargs nfsroot=$serverip:$rootpath " \ - "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ + "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:"\ + "$netdev:off " \ "root=$rootdev rw console=$console,$baudrate $othbootargs\0"
#define CONFIG_NFSBOOTCOMMAND \
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- include/configs/MPC8315ERDB.h | 253 +++++++++++++++++++++++----------------- 1 files changed, 145 insertions(+), 108 deletions(-)
diff --git a/include/configs/MPC8315ERDB.h b/include/configs/MPC8315ERDB.h index a0cfd00..62ecfdc 100644 --- a/include/configs/MPC8315ERDB.h +++ b/include/configs/MPC8315ERDB.h @@ -118,8 +118,8 @@ * Arbiter Setup */ #define CONFIG_SYS_ACR_PIPE_DEP 3 /* Arbiter pipeline depth is 4 */ -#define CONFIG_SYS_ACR_RPTCNT 3 /* Arbiter repeat count is 4 */ -#define CONFIG_SYS_SPCR_TSECEP 3 /* eTSEC emergency priority is highest */ +#define CONFIG_SYS_ACR_RPTCNT 3 /* Arbiter repeat count is 4 */ +#define CONFIG_SYS_SPCR_TSECEP 3 /* eTSEC emergency priority is highest */
/* * DDR Setup @@ -128,11 +128,11 @@ #define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_BASE #define CONFIG_SYS_DDR_SDRAM_BASE CONFIG_SYS_DDR_BASE #define CONFIG_SYS_DDR_SDRAM_CLK_CNTL DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05 -#define CONFIG_SYS_DDRCDR_VALUE ( DDRCDR_EN \ +#define CONFIG_SYS_DDRCDR_VALUE (DDRCDR_EN \ | DDRCDR_PZ_LOZ \ | DDRCDR_NZ_LOZ \ | DDRCDR_ODT \ - | DDRCDR_Q_DRN ) + | DDRCDR_Q_DRN) /* 0x7b880001 */ /* * Manually set up DDR parameters @@ -140,49 +140,50 @@ */ #define CONFIG_SYS_DDR_SIZE 128 /* MB */ #define CONFIG_SYS_DDR_CS0_BNDS 0x00000007 -#define CONFIG_SYS_DDR_CS0_CONFIG ( CSCONFIG_EN \ +#define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN \ | 0x00010000 /* ODT_WR to CSn */ \ - | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10 ) + | CSCONFIG_ROW_BIT_13 \ + | CSCONFIG_COL_BIT_10) /* 0x80010102 */ #define CONFIG_SYS_DDR_TIMING_3 0x00000000 -#define CONFIG_SYS_DDR_TIMING_0 ( ( 0 << TIMING_CFG0_RWT_SHIFT ) \ - | ( 0 << TIMING_CFG0_WRT_SHIFT ) \ - | ( 0 << TIMING_CFG0_RRT_SHIFT ) \ - | ( 0 << TIMING_CFG0_WWT_SHIFT ) \ - | ( 2 << TIMING_CFG0_ACT_PD_EXIT_SHIFT ) \ - | ( 2 << TIMING_CFG0_PRE_PD_EXIT_SHIFT ) \ - | ( 8 << TIMING_CFG0_ODT_PD_EXIT_SHIFT ) \ - | ( 2 << TIMING_CFG0_MRS_CYC_SHIFT ) ) +#define CONFIG_SYS_DDR_TIMING_0 ((0 << TIMING_CFG0_RWT_SHIFT) \ + | (0 << TIMING_CFG0_WRT_SHIFT) \ + | (0 << TIMING_CFG0_RRT_SHIFT) \ + | (0 << TIMING_CFG0_WWT_SHIFT) \ + | (2 << TIMING_CFG0_ACT_PD_EXIT_SHIFT) \ + | (2 << TIMING_CFG0_PRE_PD_EXIT_SHIFT) \ + | (8 << TIMING_CFG0_ODT_PD_EXIT_SHIFT) \ + | (2 << TIMING_CFG0_MRS_CYC_SHIFT)) /* 0x00220802 */ -#define CONFIG_SYS_DDR_TIMING_1 ( ( 2 << TIMING_CFG1_PRETOACT_SHIFT ) \ - | ( 7 << TIMING_CFG1_ACTTOPRE_SHIFT ) \ - | ( 2 << TIMING_CFG1_ACTTORW_SHIFT ) \ - | ( 5 << TIMING_CFG1_CASLAT_SHIFT ) \ - | ( 6 << TIMING_CFG1_REFREC_SHIFT ) \ - | ( 2 << TIMING_CFG1_WRREC_SHIFT ) \ - | ( 2 << TIMING_CFG1_ACTTOACT_SHIFT ) \ - | ( 2 << TIMING_CFG1_WRTORD_SHIFT ) ) +#define CONFIG_SYS_DDR_TIMING_1 ((2 << TIMING_CFG1_PRETOACT_SHIFT) \ + | (7 << TIMING_CFG1_ACTTOPRE_SHIFT) \ + | (2 << TIMING_CFG1_ACTTORW_SHIFT) \ + | (5 << TIMING_CFG1_CASLAT_SHIFT) \ + | (6 << TIMING_CFG1_REFREC_SHIFT) \ + | (2 << TIMING_CFG1_WRREC_SHIFT) \ + | (2 << TIMING_CFG1_ACTTOACT_SHIFT) \ + | (2 << TIMING_CFG1_WRTORD_SHIFT)) /* 0x27256222 */ -#define CONFIG_SYS_DDR_TIMING_2 ( ( 1 << TIMING_CFG2_ADD_LAT_SHIFT ) \ - | ( 4 << TIMING_CFG2_CPO_SHIFT ) \ - | ( 2 << TIMING_CFG2_WR_LAT_DELAY_SHIFT ) \ - | ( 2 << TIMING_CFG2_RD_TO_PRE_SHIFT ) \ - | ( 2 << TIMING_CFG2_WR_DATA_DELAY_SHIFT ) \ - | ( 3 << TIMING_CFG2_CKE_PLS_SHIFT ) \ - | ( 5 << TIMING_CFG2_FOUR_ACT_SHIFT) ) +#define CONFIG_SYS_DDR_TIMING_2 ((1 << TIMING_CFG2_ADD_LAT_SHIFT) \ + | (4 << TIMING_CFG2_CPO_SHIFT) \ + | (2 << TIMING_CFG2_WR_LAT_DELAY_SHIFT) \ + | (2 << TIMING_CFG2_RD_TO_PRE_SHIFT) \ + | (2 << TIMING_CFG2_WR_DATA_DELAY_SHIFT) \ + | (3 << TIMING_CFG2_CKE_PLS_SHIFT) \ + | (5 << TIMING_CFG2_FOUR_ACT_SHIFT)) /* 0x121048c5 */ -#define CONFIG_SYS_DDR_INTERVAL ( ( 0x0360 << SDRAM_INTERVAL_REFINT_SHIFT ) \ - | ( 0x0100 << SDRAM_INTERVAL_BSTOPRE_SHIFT ) ) +#define CONFIG_SYS_DDR_INTERVAL ((0x0360 << SDRAM_INTERVAL_REFINT_SHIFT) \ + | (0x0100 << SDRAM_INTERVAL_BSTOPRE_SHIFT)) /* 0x03600100 */ -#define CONFIG_SYS_DDR_SDRAM_CFG ( SDRAM_CFG_SREN \ +#define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SREN \ | SDRAM_CFG_SDRAM_TYPE_DDR2 \ - | SDRAM_CFG_32_BE ) + | SDRAM_CFG_32_BE) /* 0x43080000 */ #define CONFIG_SYS_DDR_SDRAM_CFG2 0x00401000 /* 1 posted refresh */ -#define CONFIG_SYS_DDR_MODE ( ( 0x0448 << SDRAM_MODE_ESD_SHIFT ) \ - | ( 0x0232 << SDRAM_MODE_SD_SHIFT ) ) +#define CONFIG_SYS_DDR_MODE ((0x0448 << SDRAM_MODE_ESD_SHIFT) \ + | (0x0232 << SDRAM_MODE_SD_SHIFT)) /* ODT 150ohm CL=3, AL=1 on SDRAM */ -#define CONFIG_SYS_DDR_MODE2 0x00000000 +#define CONFIG_SYS_DDR_MODE2 0x00000000
/* * Memory test @@ -194,8 +195,8 @@ /* * The reserved memory */ -#define CONFIG_SYS_MONITOR_LEN (384 * 1024) /* Reserve 384 kB for Mon */ -#define CONFIG_SYS_MALLOC_LEN (512 * 1024) /* Reserved for malloc */ +#define CONFIG_SYS_MONITOR_LEN (384 * 1024) /* Reserve 384 kB for Mon */ +#define CONFIG_SYS_MALLOC_LEN (512 * 1024) /* Reserved for malloc */
/* * Initial RAM Base Address Setup @@ -203,7 +204,8 @@ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
/* * Local Bus Configuration & Clock Setup @@ -221,15 +223,16 @@ #define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT
#define CONFIG_SYS_FLASH_BASE 0xFE000000 /* FLASH base address */ -#define CONFIG_SYS_FLASH_SIZE 8 /* FLASH size is 8M */ -#define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */ +#define CONFIG_SYS_FLASH_SIZE 8 /* FLASH size is 8M */ +#define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */
-#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE /* Window base at flash base */ + /* Window base at flash base */ +#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000016 /* 8MB window size */
#define CONFIG_SYS_NOR_BR_PRELIM (CONFIG_SYS_FLASH_BASE \ - | (2 << BR_PS_SHIFT) /* 16 bit port size */ \ - | BR_V ) /* valid */ + | (2 << BR_PS_SHIFT) /* 16 bit port */ \ + | BR_V) /* valid */ #define CONFIG_SYS_NOR_OR_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) \ | OR_UPM_XAM \ | OR_GPCM_CSNT \ @@ -238,10 +241,11 @@ | OR_GPCM_SCY_15 \ | OR_GPCM_TRLX \ | OR_GPCM_EHTR \ - | OR_GPCM_EAD ) + | OR_GPCM_EAD)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 135 /* 127 64KB sectors and 8 8KB top sectors per device */ +/* 127 64KB sectors and 8 8KB top sectors per device */ +#define CONFIG_SYS_MAX_FLASH_SECT 135
#undef CONFIG_SYS_FLASH_CHECKSUM #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ @@ -261,7 +265,7 @@ #define CONFIG_MTD_PARTITION #define CONFIG_CMD_MTDPARTS #define MTDIDS_DEFAULT "nand0=e0600000.flash" -#define MTDPARTS_DEFAULT \ +#define MTDPARTS_DEFAULT \ "mtdparts=e0600000.flash:512k(uboot),128k(env),3m@1m(kernel),-(fs)"
#define CONFIG_SYS_MAX_NAND_DEVICE 1 @@ -278,16 +282,16 @@
#define CONFIG_SYS_NAND_BR_PRELIM (CONFIG_SYS_NAND_BASE \ | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ - | BR_PS_8 /* Port Size = 8 bit */ \ + | BR_PS_8 /* 8 bit port */ \ | BR_MS_FCM /* MSEL = FCM */ \ - | BR_V ) /* valid */ + | BR_V) /* valid */ #define CONFIG_SYS_NAND_OR_PRELIM (0xFFFF8000 /* length 32K */ \ | OR_FCM_CSCT \ | OR_FCM_CST \ | OR_FCM_CHT \ | OR_FCM_SCY_1 \ | OR_FCM_TRLX \ - | OR_FCM_EHTR ) + | OR_FCM_EHTR) /* 0xFFFF8396 */
#ifdef CONFIG_NAND_U_BOOT @@ -325,7 +329,7 @@ #define CONFIG_SYS_NS16550_CLK (CONFIG_83XX_CLKIN * 2)
#define CONFIG_SYS_BAUDRATE_TABLE \ - {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200} + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200}
#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR+0x4600) @@ -344,9 +348,9 @@ /* I2C */ #define CONFIG_HARD_I2C /* I2C with hardware support */ #define CONFIG_FSL_I2C -#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave addr */ #define CONFIG_SYS_I2C_SLAVE 0x7F -#define CONFIG_SYS_I2C_NOPROBES {0x51} /* Don't probe these addrs */ +#define CONFIG_SYS_I2C_NOPROBES {0x51} /* Don't probe these addrs */ #define CONFIG_SYS_I2C_OFFSET 0x3000 #define CONFIG_SYS_I2C2_OFFSET 0x3100
@@ -365,9 +369,9 @@ * General PCI * Addresses are mapped 1-1. */ -#define CONFIG_SYS_PCI_MEM_BASE 0x80000000 -#define CONFIG_SYS_PCI_MEM_PHYS CONFIG_SYS_PCI_MEM_BASE -#define CONFIG_SYS_PCI_MEM_SIZE 0x10000000 /* 256M */ +#define CONFIG_SYS_PCI_MEM_BASE 0x80000000 +#define CONFIG_SYS_PCI_MEM_PHYS CONFIG_SYS_PCI_MEM_BASE +#define CONFIG_SYS_PCI_MEM_SIZE 0x10000000 /* 256M */ #define CONFIG_SYS_PCI_MMIO_BASE 0x90000000 #define CONFIG_SYS_PCI_MMIO_PHYS CONFIG_SYS_PCI_MMIO_BASE #define CONFIG_SYS_PCI_MMIO_SIZE 0x10000000 /* 256M */ @@ -420,7 +424,7 @@ #define CONFIG_USB_STORAGE #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_FSL -#define CONFIG_USB_PHY_TYPE "utmi" +#define CONFIG_USB_PHY_TYPE "utmi" #define CONFIG_EHCI_HCD_INIT_AFTER_RESET
/* @@ -428,9 +432,9 @@ */ #define CONFIG_TSEC_ENET /* TSEC ethernet support */ #define CONFIG_SYS_TSEC1_OFFSET 0x24000 -#define CONFIG_SYS_TSEC1 (CONFIG_SYS_IMMR+CONFIG_SYS_TSEC1_OFFSET) +#define CONFIG_SYS_TSEC1 (CONFIG_SYS_IMMR+CONFIG_SYS_TSEC1_OFFSET) #define CONFIG_SYS_TSEC2_OFFSET 0x25000 -#define CONFIG_SYS_TSEC2 (CONFIG_SYS_IMMR+CONFIG_SYS_TSEC2_OFFSET) +#define CONFIG_SYS_TSEC2 (CONFIG_SYS_IMMR+CONFIG_SYS_TSEC2_OFFSET)
/* * TSEC ethernet configuration @@ -459,12 +463,12 @@ #define CONFIG_SYS_SATA_MAX_DEVICE 2 #define CONFIG_SATA1 #define CONFIG_SYS_SATA1_OFFSET 0x18000 -#define CONFIG_SYS_SATA1 (CONFIG_SYS_IMMR + CONFIG_SYS_SATA1_OFFSET) -#define CONFIG_SYS_SATA1_FLAGS FLAGS_DMA +#define CONFIG_SYS_SATA1 (CONFIG_SYS_IMMR + CONFIG_SYS_SATA1_OFFSET) +#define CONFIG_SYS_SATA1_FLAGS FLAGS_DMA #define CONFIG_SATA2 #define CONFIG_SYS_SATA2_OFFSET 0x19000 -#define CONFIG_SYS_SATA2 (CONFIG_SYS_IMMR + CONFIG_SYS_SATA2_OFFSET) -#define CONFIG_SYS_SATA2_FLAGS FLAGS_DMA +#define CONFIG_SYS_SATA2 (CONFIG_SYS_IMMR + CONFIG_SYS_SATA2_OFFSET) +#define CONFIG_SYS_SATA2_FLAGS FLAGS_DMA
#ifdef CONFIG_FSL_SATA #define CONFIG_LBA48 @@ -487,11 +491,12 @@ CONFIG_ENV_RANGE) #elif !defined(CONFIG_SYS_RAMBOOT) #define CONFIG_ENV_IS_IN_FLASH 1 - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) + #define CONFIG_ENV_ADDR \ + (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K(one sector) for env */ #define CONFIG_ENV_SIZE 0x2000 #else - #define CONFIG_SYS_NO_FLASH 1 /* Flash is not usable now */ + #define CONFIG_SYS_NO_FLASH 1 /* Flash is not usable now */ #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 @@ -525,7 +530,7 @@ #endif
#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ -#define CONFIG_AUTO_COMPLETE /* add autocompletion support */ +#define CONFIG_AUTO_COMPLETE /* add autocompletion support */
#undef CONFIG_WATCHDOG /* watchdog disabled */
@@ -542,17 +547,19 @@ #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #endif
-#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ -#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */ + /* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ + /* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */
/* * For booting Linux, the board info and command line data * have to be in the first 256 MB of memory, since this is * the maximum mapped by the Linux kernel during initialization. */ -#define CONFIG_SYS_BOOTMAPSZ (256 << 20) /* Initial Memory map for Linux */ +#define CONFIG_SYS_BOOTMAPSZ (256 << 20) /* Initial Memory map for Linux */
/* * Core HID Setup @@ -569,42 +576,71 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR: cache cacheable */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_128M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE \ + | BATU_BL_128M \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT0L CONFIG_SYS_IBAT0L #define CONFIG_SYS_DBAT0U CONFIG_SYS_IBAT0U
/* IMMRBAR, PCI IO and NAND: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_10 | \ - BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT1U (CONFIG_SYS_IMMR | BATU_BL_8M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT1U (CONFIG_SYS_IMMR \ + | BATU_BL_8M \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT1L CONFIG_SYS_IBAT1L #define CONFIG_SYS_DBAT1U CONFIG_SYS_IBAT1U
/* FLASH: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT2U (CONFIG_SYS_FLASH_BASE | BATU_BL_32M | \ - BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ - BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_FLASH_BASE \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT2U (CONFIG_SYS_FLASH_BASE \ + | BATU_BL_32M \ + | BATU_VS \ + | BATU_VP) +#define CONFIG_SYS_DBAT2L (CONFIG_SYS_FLASH_BASE \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT2U CONFIG_SYS_IBAT2U
/* Stack in dcache: cacheable, no memory coherence */ #define CONFIG_SYS_IBAT3L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10) -#define CONFIG_SYS_IBAT3U (CONFIG_SYS_INIT_RAM_ADDR | BATU_BL_128K | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT3U (CONFIG_SYS_INIT_RAM_ADDR \ + | BATU_BL_128K \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT3L CONFIG_SYS_IBAT3L #define CONFIG_SYS_DBAT3U CONFIG_SYS_IBAT3U
/* PCI MEM space: cacheable */ -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI_MEM_PHYS | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT4U (CONFIG_SYS_PCI_MEM_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI_MEM_PHYS \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT4U (CONFIG_SYS_PCI_MEM_PHYS \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT4L CONFIG_SYS_IBAT4L #define CONFIG_SYS_DBAT4U CONFIG_SYS_IBAT4U
/* PCI MMIO space: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_PCI_MMIO_PHYS | BATL_PP_10 | \ - BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT5U (CONFIG_SYS_PCI_MMIO_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_PCI_MMIO_PHYS \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT5U (CONFIG_SYS_PCI_MMIO_PHYS \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT5L CONFIG_SYS_IBAT5L #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U
@@ -642,31 +678,32 @@ #undef CONFIG_BOOTARGS /* the boot command will set bootargs */
#define CONFIG_EXTRA_ENV_SETTINGS \ - "netdev=eth0\0" \ - "consoledev=ttyS0\0" \ - "ramdiskaddr=1000000\0" \ - "ramdiskfile=ramfs.83xx\0" \ - "fdtaddr=780000\0" \ - "fdtfile=mpc8315erdb.dtb\0" \ - "usb_phy_type=utmi\0" \ - "" + "netdev=eth0\0" \ + "consoledev=ttyS0\0" \ + "ramdiskaddr=1000000\0" \ + "ramdiskfile=ramfs.83xx\0" \ + "fdtaddr=780000\0" \ + "fdtfile=mpc8315erdb.dtb\0" \ + "usb_phy_type=utmi\0" \ + ""
#define CONFIG_NFSBOOTCOMMAND \ - "setenv bootargs root=/dev/nfs rw " \ - "nfsroot=$serverip:$rootpath " \ - "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "tftp $loadaddr $bootfile;" \ - "tftp $fdtaddr $fdtfile;" \ - "bootm $loadaddr - $fdtaddr" + "setenv bootargs root=/dev/nfs rw " \ + "nfsroot=$serverip:$rootpath " \ + "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:" \ + "$netdev:off " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr - $fdtaddr"
#define CONFIG_RAMBOOTCOMMAND \ - "setenv bootargs root=/dev/ram rw " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "tftp $ramdiskaddr $ramdiskfile;" \ - "tftp $loadaddr $bootfile;" \ - "tftp $fdtaddr $fdtfile;" \ - "bootm $loadaddr $ramdiskaddr $fdtaddr" + "setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $ramdiskaddr $ramdiskfile;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr"
#define CONFIG_BOOTCOMMAND CONFIG_NFSBOOTCOMMAND
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- include/configs/MPC8323ERDB.h | 253 ++++++++++++++++++++++++----------------- 1 files changed, 150 insertions(+), 103 deletions(-)
diff --git a/include/configs/MPC8323ERDB.h b/include/configs/MPC8323ERDB.h index 4d4c758..957090d 100644 --- a/include/configs/MPC8323ERDB.h +++ b/include/configs/MPC8323ERDB.h @@ -68,16 +68,17 @@ * System performance */ #define CONFIG_SYS_ACR_PIPE_DEP 3 /* Arbiter pipeline depth (0-3) */ -#define CONFIG_SYS_ACR_RPTCNT 3 /* Arbiter repeat count (0-7) */ -#define CONFIG_SYS_SPCR_OPT 1 /* (0-1) Optimize transactions between CSB and the SEC and QUICC Engine block */ +#define CONFIG_SYS_ACR_RPTCNT 3 /* Arbiter repeat count (0-7) */ +/* (0-1) Optimize transactions between CSB and the SEC and QUICC Engine block */ +#define CONFIG_SYS_SPCR_OPT 1
/* * DDR Setup */ -#define CONFIG_SYS_DDR_BASE 0x00000000 /* DDR is system memory */ -#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_BASE +#define CONFIG_SYS_DDR_BASE 0x00000000 /* DDR is system memory */ +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_BASE #define CONFIG_SYS_DDR_SDRAM_BASE CONFIG_SYS_DDR_BASE -#define CONFIG_SYS_DDRCDR 0x73000002 /* DDR II voltage is 1.8V */ +#define CONFIG_SYS_DDRCDR 0x73000002 /* DDR II voltage is 1.8V */
#undef CONFIG_SPD_EEPROM #if defined(CONFIG_SPD_EEPROM) @@ -87,51 +88,52 @@ #else /* Manually set up DDR parameters */ -#define CONFIG_SYS_DDR_SIZE 64 /* MB */ -#define CONFIG_SYS_DDR_CS0_CONFIG ( CSCONFIG_EN \ +#define CONFIG_SYS_DDR_SIZE 64 /* MB */ +#define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN \ | CSCONFIG_ODT_WR_ACS \ - | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_9 ) + | CSCONFIG_ROW_BIT_13 \ + | CSCONFIG_COL_BIT_9) /* 0x80010101 */ -#define CONFIG_SYS_DDR_TIMING_0 ( ( 0 << TIMING_CFG0_RWT_SHIFT ) \ - | ( 0 << TIMING_CFG0_WRT_SHIFT ) \ - | ( 0 << TIMING_CFG0_RRT_SHIFT ) \ - | ( 0 << TIMING_CFG0_WWT_SHIFT ) \ - | ( 2 << TIMING_CFG0_ACT_PD_EXIT_SHIFT ) \ - | ( 2 << TIMING_CFG0_PRE_PD_EXIT_SHIFT ) \ - | ( 8 << TIMING_CFG0_ODT_PD_EXIT_SHIFT ) \ - | ( 2 << TIMING_CFG0_MRS_CYC_SHIFT ) ) +#define CONFIG_SYS_DDR_TIMING_0 ((0 << TIMING_CFG0_RWT_SHIFT) \ + | (0 << TIMING_CFG0_WRT_SHIFT) \ + | (0 << TIMING_CFG0_RRT_SHIFT) \ + | (0 << TIMING_CFG0_WWT_SHIFT) \ + | (2 << TIMING_CFG0_ACT_PD_EXIT_SHIFT) \ + | (2 << TIMING_CFG0_PRE_PD_EXIT_SHIFT) \ + | (8 << TIMING_CFG0_ODT_PD_EXIT_SHIFT) \ + | (2 << TIMING_CFG0_MRS_CYC_SHIFT)) /* 0x00220802 */ -#define CONFIG_SYS_DDR_TIMING_1 ( ( 2 << TIMING_CFG1_PRETOACT_SHIFT ) \ - | ( 6 << TIMING_CFG1_ACTTOPRE_SHIFT ) \ - | ( 2 << TIMING_CFG1_ACTTORW_SHIFT ) \ - | ( 5 << TIMING_CFG1_CASLAT_SHIFT ) \ - | ( 3 << TIMING_CFG1_REFREC_SHIFT ) \ - | ( 2 << TIMING_CFG1_WRREC_SHIFT ) \ - | ( 2 << TIMING_CFG1_ACTTOACT_SHIFT ) \ - | ( 2 << TIMING_CFG1_WRTORD_SHIFT ) ) +#define CONFIG_SYS_DDR_TIMING_1 ((2 << TIMING_CFG1_PRETOACT_SHIFT) \ + | (6 << TIMING_CFG1_ACTTOPRE_SHIFT) \ + | (2 << TIMING_CFG1_ACTTORW_SHIFT) \ + | (5 << TIMING_CFG1_CASLAT_SHIFT) \ + | (3 << TIMING_CFG1_REFREC_SHIFT) \ + | (2 << TIMING_CFG1_WRREC_SHIFT) \ + | (2 << TIMING_CFG1_ACTTOACT_SHIFT) \ + | (2 << TIMING_CFG1_WRTORD_SHIFT)) /* 0x26253222 */ -#define CONFIG_SYS_DDR_TIMING_2 ( ( 1 << TIMING_CFG2_ADD_LAT_SHIFT ) \ - | (31 << TIMING_CFG2_CPO_SHIFT ) \ - | ( 2 << TIMING_CFG2_WR_LAT_DELAY_SHIFT ) \ - | ( 2 << TIMING_CFG2_RD_TO_PRE_SHIFT ) \ - | ( 2 << TIMING_CFG2_WR_DATA_DELAY_SHIFT ) \ - | ( 3 << TIMING_CFG2_CKE_PLS_SHIFT ) \ - | ( 7 << TIMING_CFG2_FOUR_ACT_SHIFT) ) +#define CONFIG_SYS_DDR_TIMING_2 ((1 << TIMING_CFG2_ADD_LAT_SHIFT) \ + | (31 << TIMING_CFG2_CPO_SHIFT) \ + | (2 << TIMING_CFG2_WR_LAT_DELAY_SHIFT) \ + | (2 << TIMING_CFG2_RD_TO_PRE_SHIFT) \ + | (2 << TIMING_CFG2_WR_DATA_DELAY_SHIFT) \ + | (3 << TIMING_CFG2_CKE_PLS_SHIFT) \ + | (7 << TIMING_CFG2_FOUR_ACT_SHIFT)) /* 0x1f9048c7 */ #define CONFIG_SYS_DDR_TIMING_3 0x00000000 #define CONFIG_SYS_DDR_CLK_CNTL DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05 /* 0x02000000 */ -#define CONFIG_SYS_DDR_MODE ( ( 0x4448 << SDRAM_MODE_ESD_SHIFT ) \ - | ( 0x0232 << SDRAM_MODE_SD_SHIFT ) ) +#define CONFIG_SYS_DDR_MODE ((0x4448 << SDRAM_MODE_ESD_SHIFT) \ + | (0x0232 << SDRAM_MODE_SD_SHIFT)) /* 0x44480232 */ -#define CONFIG_SYS_DDR_MODE2 0x8000c000 -#define CONFIG_SYS_DDR_INTERVAL ( ( 800 << SDRAM_INTERVAL_REFINT_SHIFT ) \ - | ( 100 << SDRAM_INTERVAL_BSTOPRE_SHIFT ) ) +#define CONFIG_SYS_DDR_MODE2 0x8000c000 +#define CONFIG_SYS_DDR_INTERVAL ((800 << SDRAM_INTERVAL_REFINT_SHIFT) \ + | (100 << SDRAM_INTERVAL_BSTOPRE_SHIFT)) /* 0x03200064 */ #define CONFIG_SYS_DDR_CS0_BNDS 0x00000003 -#define CONFIG_SYS_DDR_SDRAM_CFG ( SDRAM_CFG_SREN \ +#define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SREN \ | SDRAM_CFG_SDRAM_TYPE_DDR2 \ - | SDRAM_CFG_32_BE ) + | SDRAM_CFG_32_BE) /* 0x43080000 */ #define CONFIG_SYS_DDR_SDRAM_CFG2 0x00401000 #endif @@ -155,16 +157,17 @@ #endif
/* CONFIG_SYS_MONITOR_LEN must be a multiple of CONFIG_ENV_SECT_SIZE */ -#define CONFIG_SYS_MONITOR_LEN (384 * 1024) /* Reserve 384 kB for Mon */ -#define CONFIG_SYS_MALLOC_LEN (128 * 1024) /* Reserved for malloc */ +#define CONFIG_SYS_MONITOR_LEN (384 * 1024) /* Reserve 384 kB for Mon */ +#define CONFIG_SYS_MALLOC_LEN (128 * 1024) /* Reserved for malloc */
/* * Initial RAM Base Address Setup */ #define CONFIG_SYS_INIT_RAM_LOCK 1 -#define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ +#define CONFIG_SYS_GBL_DATA_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
/* * Local Bus Configuration & Clock Setup @@ -178,30 +181,31 @@ */ #define CONFIG_SYS_FLASH_CFI /* use the Common Flash Interface */ #define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ -#define CONFIG_SYS_FLASH_BASE 0xFE000000 /* FLASH base address */ +#define CONFIG_SYS_FLASH_BASE 0xFE000000 /* FLASH base address */ #define CONFIG_SYS_FLASH_SIZE 16 /* FLASH size is 16M */ -#define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */ +#define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */
-#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE /* Window base at flash base */ + /* Window base at flash base */ +#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000018 /* 32MB window size */
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | /* Flash Base address */ \ - (2 << BR_PS_SHIFT) | /* 16 bit port size */ \ - BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM 0xfe006ff7 /* 16MB Flash size */ +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE \ + | (2 << BR_PS_SHIFT) /* 16 bit port */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR0_PRELIM 0xfe006ff7 /* 16MB Flash size */
-#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 128 /* sectors per device */ +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 128 /* sectors per device */
/* * SDRAM on the Local Bus */ -#undef CONFIG_SYS_LB_SDRAM /* The board has not SRDAM on local bus */ +#undef CONFIG_SYS_LB_SDRAM /* The board has not SRDAM on local bus */
#ifdef CONFIG_SYS_LB_SDRAM -#define CONFIG_SYS_LBC_SDRAM_BASE 0xF0000000 /* SDRAM base address */ +#define CONFIG_SYS_LBC_SDRAM_BASE 0xF0000000 /* SDRAM base addr */ #define CONFIG_SYS_LBC_SDRAM_SIZE 64 /* LBC SDRAM is 64MB */
#define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_LBC_SDRAM_BASE @@ -226,7 +230,8 @@ * the top 17 bits of BR2. */
-#define CONFIG_SYS_BR2_PRELIM 0xf0001861 /*Port size=32bit, MSEL=SDRAM */ + /*Port size=32bit, MSEL=SDRAM */ +#define CONFIG_SYS_BR2_PRELIM 0xf0001861
/* * The SDRAM size in MB, CONFIG_SYS_LBC_SDRAM_SIZE, is 64. @@ -244,8 +249,10 @@
#define CONFIG_SYS_OR2_PRELIM 0xfc006901
-#define CONFIG_SYS_LBC_LSRT 0x32000000 /* LB sdram refresh timer, about 6us */ -#define CONFIG_SYS_LBC_MRTPR 0x20000000 /* LB refresh timer prescal, 266MHz/32 */ + /* LB sdram refresh timer, about 6us */ +#define CONFIG_SYS_LBC_LSRT 0x32000000 + /* LB refresh timer prescal, 266MHz/32 */ +#define CONFIG_SYS_LBC_MRTPR 0x20000000
#define CONFIG_SYS_LBC_LSDMR_COMMON 0x0063b723
@@ -254,7 +261,8 @@ /* * Windows to access PIB via local bus */ -#define CONFIG_SYS_LBLAWBAR3_PRELIM 0xf8008000 /* windows base 0xf8008000 */ + /* windows base 0xf8008000 */ +#define CONFIG_SYS_LBLAWBAR3_PRELIM 0xf8008000 #define CONFIG_SYS_LBLAWAR3_PRELIM 0x8000000f /* windows size 64KB */
/* @@ -267,7 +275,7 @@ #define CONFIG_SYS_NS16550_CLK get_bus_freq(0)
#define CONFIG_SYS_BAUDRATE_TABLE \ - {300, 600, 1200, 2400, 4800, 9600, 19200, 38400,115200} + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 115200}
#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR+0x4600) @@ -367,11 +375,12 @@ */ #ifndef CONFIG_SYS_RAMBOOT #define CONFIG_ENV_IS_IN_FLASH 1 - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) + #define CONFIG_ENV_ADDR \ + (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE 0x2000 #else - #define CONFIG_SYS_NO_FLASH 1 /* Flash is not usable now */ + #define CONFIG_SYS_NO_FLASH 1 /* Flash is not usable now */ #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 @@ -411,9 +420,9 @@ /* * Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ -#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ +#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */
#if (CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ @@ -421,17 +430,20 @@ #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #endif
-#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ + /* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ -#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */ + /* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */
/* * For booting Linux, the board info and command line data * have to be in the first 256 MB of memory, since this is * the maximum mapped by the Linux kernel during initialization. */ -#define CONFIG_SYS_BOOTMAPSZ (256 << 20) /* Initial Memory map for Linux */ + /* Initial Memory map for Linux */ +#define CONFIG_SYS_BOOTMAPSZ (256 << 20)
/* * Core HID Setup @@ -447,23 +459,40 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR: cache cacheable */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT0L CONFIG_SYS_IBAT0L #define CONFIG_SYS_DBAT0U CONFIG_SYS_IBAT0U
/* IMMRBAR & PCI IO: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_10 | \ - BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT1U (CONFIG_SYS_IMMR | BATU_BL_4M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT1U (CONFIG_SYS_IMMR \ + | BATU_BL_4M \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT1L CONFIG_SYS_IBAT1L #define CONFIG_SYS_DBAT1U CONFIG_SYS_IBAT1U
/* FLASH: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT2U (CONFIG_SYS_FLASH_BASE | BATU_BL_32M | BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ - BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_FLASH_BASE \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT2U (CONFIG_SYS_FLASH_BASE \ + | BATU_BL_32M \ + | BATU_VS \ + | BATU_VP) +#define CONFIG_SYS_DBAT2L (CONFIG_SYS_FLASH_BASE \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT2U CONFIG_SYS_IBAT2U
#define CONFIG_SYS_IBAT3L (0) @@ -473,20 +502,33 @@
/* Stack in dcache: cacheable, no memory coherence */ #define CONFIG_SYS_IBAT4L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10) -#define CONFIG_SYS_IBAT4U (CONFIG_SYS_INIT_RAM_ADDR | BATU_BL_128K | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT4U (CONFIG_SYS_INIT_RAM_ADDR \ + | BATU_BL_128K \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT4L CONFIG_SYS_IBAT4L #define CONFIG_SYS_DBAT4U CONFIG_SYS_IBAT4U
#ifdef CONFIG_PCI /* PCI MEM space: cacheable */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_PCI1_MEM_PHYS | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT5U (CONFIG_SYS_PCI1_MEM_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_PCI1_MEM_PHYS \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT5U (CONFIG_SYS_PCI1_MEM_PHYS \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT5L CONFIG_SYS_IBAT5L #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U /* PCI MMIO space: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI1_MMIO_PHYS | BATL_PP_10 | \ - BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI1_MMIO_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI1_MMIO_PHYS \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI1_MMIO_PHYS \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT6L CONFIG_SYS_IBAT6L #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U #else @@ -516,22 +558,26 @@ */ #define CONFIG_ENV_OVERWRITE
-#define CONFIG_HAS_ETH0 /* add support for "ethaddr" */ -#define CONFIG_HAS_ETH1 /* add support for "eth1addr" */ +#define CONFIG_HAS_ETH0 /* add support for "ethaddr" */ +#define CONFIG_HAS_ETH1 /* add support for "eth1addr" */
-/* use mac_read_from_eeprom() to read ethaddr from I2C EEPROM (see CONFIG_SYS_I2C_EEPROM) */ -#define CONFIG_SYS_I2C_MAC_OFFSET 0x7f00 /* MAC address offset in I2C EEPROM */ +/* use mac_read_from_eeprom() to read ethaddr from I2C EEPROM + * (see CONFIG_SYS_I2C_EEPROM) */ + /* MAC address offset in I2C EEPROM */ +#define CONFIG_SYS_I2C_MAC_OFFSET 0x7f00
#define CONFIG_HOSTNAME mpc8323erdb #define CONFIG_ROOTPATH /nfsroot -#define CONFIG_RAMDISKFILE rootfs.ext2.gz.uboot #define CONFIG_BOOTFILE uImage -#define CONFIG_UBOOTPATH u-boot.bin /* U-Boot image on TFTP server */ -#define CONFIG_FDTFILE mpc832x_rdb.dtb + /* U-Boot image on TFTP server */ +#define CONFIG_UBOOTPATH "u-boot.bin" +#define CONFIG_FDTFILE "mpc832x_rdb.dtb" +#define CONFIG_RAMDISKFILE "rootfs.ext2.gz.uboot"
@@ -539,23 +585,24 @@ #define MK_STR(x) XMK_STR(x)
#define CONFIG_EXTRA_ENV_SETTINGS \ - "netdev=" MK_STR(CONFIG_NETDEV) "\0" \ - "uboot=" MK_STR(CONFIG_UBOOTPATH) "\0" \ + "netdev=" CONFIG_NETDEV "\0" \ + "uboot=" CONFIG_UBOOTPATH "\0" \ "tftpflash=tftp $loadaddr $uboot;" \ - "protect off " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; " \ - "erase " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; " \ - "cp.b $loadaddr " MK_STR(CONFIG_SYS_TEXT_BASE) " $filesize; " \ - "protect on " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; " \ - "cmp.b $loadaddr " MK_STR(CONFIG_SYS_TEXT_BASE) " $filesize\0" \ + "protect off " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; "\ + "erase " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; " \ + "cp.b $loadaddr " MK_STR(CONFIG_SYS_TEXT_BASE) " $filesize; "\ + "protect on " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; "\ + "cmp.b $loadaddr " MK_STR(CONFIG_SYS_TEXT_BASE) " $filesize\0"\ "fdtaddr=780000\0" \ - "fdtfile=" MK_STR(CONFIG_FDTFILE) "\0" \ + "fdtfile=" CONFIG_FDTFILE "\0" \ "ramdiskaddr=1000000\0" \ - "ramdiskfile=" MK_STR(CONFIG_RAMDISKFILE) "\0" \ + "ramdiskfile=" CONFIG_RAMDISKFILE "\0" \ "console=ttyS0\0" \ "setbootargs=setenv bootargs " \ - "root=$rootdev rw console=$console,$baudrate $othbootargs\0" \ + "root=$rootdev rw console=$console,$baudrate $othbootargs\0"\ "setipargs=setenv bootargs nfsroot=$serverip:$rootpath " \ - "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ + "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:"\ + "$netdev:off "\ "root=$rootdev rw console=$console,$baudrate $othbootargs\0"
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- include/configs/MPC832XEMDS.h | 229 +++++++++++++++++++++++++---------------- 1 files changed, 141 insertions(+), 88 deletions(-)
diff --git a/include/configs/MPC832XEMDS.h b/include/configs/MPC832XEMDS.h index f136a8e..9e65b00 100644 --- a/include/configs/MPC832XEMDS.h +++ b/include/configs/MPC832XEMDS.h @@ -97,10 +97,10 @@ /* * DDR Setup */ -#define CONFIG_SYS_DDR_BASE 0x00000000 /* DDR is system memory */ -#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_BASE +#define CONFIG_SYS_DDR_BASE 0x00000000 /* DDR is system memory */ +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_BASE #define CONFIG_SYS_DDR_SDRAM_BASE CONFIG_SYS_DDR_BASE -#define CONFIG_SYS_DDRCDR 0x73000002 /* DDR II voltage is 1.8V */ +#define CONFIG_SYS_DDRCDR 0x73000002 /* DDR II voltage is 1.8V */
#undef CONFIG_SPD_EEPROM #if defined(CONFIG_SPD_EEPROM) @@ -112,15 +112,15 @@ */ #define CONFIG_SYS_DDR_SIZE 128 /* MB */ #define CONFIG_SYS_DDR_CS0_CONFIG 0x80840102 -#define CONFIG_SYS_DDR_TIMING_0 0x00220802 -#define CONFIG_SYS_DDR_TIMING_1 0x3935d322 -#define CONFIG_SYS_DDR_TIMING_2 0x0f9048ca -#define CONFIG_SYS_DDR_TIMING_3 0x00000000 -#define CONFIG_SYS_DDR_CLK_CNTL 0x02000000 +#define CONFIG_SYS_DDR_TIMING_0 0x00220802 +#define CONFIG_SYS_DDR_TIMING_1 0x3935d322 +#define CONFIG_SYS_DDR_TIMING_2 0x0f9048ca +#define CONFIG_SYS_DDR_TIMING_3 0x00000000 +#define CONFIG_SYS_DDR_CLK_CNTL 0x02000000 #define CONFIG_SYS_DDR_MODE 0x44400232 #define CONFIG_SYS_DDR_MODE2 0x8000c000 -#define CONFIG_SYS_DDR_INTERVAL 0x03200064 -#define CONFIG_SYS_DDR_CS0_BNDS 0x00000007 +#define CONFIG_SYS_DDR_INTERVAL 0x03200064 +#define CONFIG_SYS_DDR_CS0_BNDS 0x00000007 #define CONFIG_SYS_DDR_SDRAM_CFG 0x43080000 #define CONFIG_SYS_DDR_SDRAM_CFG2 0x00401000 #endif @@ -144,16 +144,17 @@ #endif
/* * Initial RAM Base Address Setup */ #define CONFIG_SYS_INIT_RAM_LOCK 1 -#define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM addr */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ +#define CONFIG_SYS_GBL_DATA_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
/* * Local Bus Configuration & Clock Setup @@ -166,38 +167,42 @@ * FLASH on the Local Bus */ #define CONFIG_SYS_FLASH_CFI /* use the Common Flash Interface */ -#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ -#define CONFIG_SYS_FLASH_BASE 0xFE000000 /* FLASH base address */ -#define CONFIG_SYS_FLASH_SIZE 16 /* FLASH size is 16M */ -#define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */ +#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ +#define CONFIG_SYS_FLASH_BASE 0xFE000000 /* FLASH base address */ +#define CONFIG_SYS_FLASH_SIZE 16 /* FLASH size is 16M */ +#define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */
/* * BCSR on the Local Bus */ -#define CONFIG_SYS_BCSR 0xF8000000 -#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_BCSR /* Access window base at BCSR base */ -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000E /* Access window size 32K */ +#define CONFIG_SYS_BCSR 0xF8000000 + /* Access window base at BCSR base */ +#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_BCSR + /* Access window size 32K */ +#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000E
-#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR|0x00000801) /* Port size=8bit, MSEL=GPCM */ + /* Port size=8bit, MSEL=GPCM */ +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR|0x00000801) #define CONFIG_SYS_OR1_PRELIM 0xFFFFE9f7 /* length 32K */
#ifdef CONFIG_SYS_LB_SDRAM #define CONFIG_SYS_LBC_SDRAM_BASE 0xF0000000 /* SDRAM base address */ @@ -243,8 +248,10 @@
@@ -253,20 +260,26 @@ /* * Windows to access PIB via local bus */ -#define CONFIG_SYS_LBLAWBAR3_PRELIM 0xf8008000 /* windows base 0xf8008000 */ -#define CONFIG_SYS_LBLAWAR3_PRELIM 0x8000000f /* windows size 64KB */ + /* windows base 0xf8008000 */ +#define CONFIG_SYS_LBLAWBAR3_PRELIM 0xf8008000 + /* windows size 64KB */ +#define CONFIG_SYS_LBLAWAR3_PRELIM 0x8000000f
/* * CS2 on Local Bus, to PIB */ -#define CONFIG_SYS_BR2_PRELIM 0xf8008801 /* CS2 base address at 0xf8008000 */ -#define CONFIG_SYS_OR2_PRELIM 0xffffe9f7 /* size 32KB, port size 8bit, GPCM */ + /* CS2 base address at 0xf8008000 */ +#define CONFIG_SYS_BR2_PRELIM 0xf8008801 + /* size 32KB, port size 8bit, GPCM */ +#define CONFIG_SYS_OR2_PRELIM 0xffffe9f7
/* * CS3 on Local Bus, to PIB */ -#define CONFIG_SYS_BR3_PRELIM 0xf8010801 /* CS3 base address at 0xf8010000 */ -#define CONFIG_SYS_OR3_PRELIM 0xffffe9f7 /* size 32KB, port size 8bit, GPCM */ + /* CS3 base address at 0xf8010000 */ +#define CONFIG_SYS_BR3_PRELIM 0xf8010801 + /* size 32KB, port size 8bit, GPCM */ +#define CONFIG_SYS_OR3_PRELIM 0xffffe9f7
/* * Serial Port @@ -278,7 +291,7 @@ #define CONFIG_SYS_NS16550_CLK get_bus_freq(0)
#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR+0x4600) @@ -382,11 +395,12 @@ */ #ifndef CONFIG_SYS_RAMBOOT #define CONFIG_ENV_IS_IN_FLASH 1 - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) + #define CONFIG_ENV_ADDR \ + (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE 0x2000 #else - #define CONFIG_SYS_NO_FLASH 1 /* Flash is not usable now */ + #define CONFIG_SYS_NO_FLASH 1 /* Flash is not usable now */ #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 @@ -428,9 +442,9 @@ /* * Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ -#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ +#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */
#if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ @@ -438,17 +452,20 @@ #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #endif
/* * Core HID Setup @@ -465,30 +482,52 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* BCSR: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_BCSR | BATL_PP_10 | \ - BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT2U (CONFIG_SYS_BCSR | BATU_BL_128K | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_BCSR \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT2U (CONFIG_SYS_BCSR \ + | BATU_BL_128K \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT2L CONFIG_SYS_IBAT2L #define CONFIG_SYS_DBAT2U CONFIG_SYS_IBAT2U
/* FLASH: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT3U (CONFIG_SYS_FLASH_BASE | BATU_BL_32M | BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT3L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ - BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_FLASH_BASE \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT3U (CONFIG_SYS_FLASH_BASE \ + | BATU_BL_32M \ + | BATU_VS \ + | BATU_VP) +#define CONFIG_SYS_DBAT3L (CONFIG_SYS_FLASH_BASE \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT3U CONFIG_SYS_IBAT3U
#define CONFIG_SYS_IBAT4L (0) @@ -498,20 +537,33 @@
/* Stack in dcache: cacheable, no memory coherence */ #define CONFIG_SYS_IBAT5L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10) -#define CONFIG_SYS_IBAT5U (CONFIG_SYS_INIT_RAM_ADDR | BATU_BL_128K | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT5U (CONFIG_SYS_INIT_RAM_ADDR \ + | BATU_BL_128K \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT5L CONFIG_SYS_IBAT5L #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U
#ifdef CONFIG_PCI /* PCI MEM space: cacheable */ -#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI1_MEM_PHYS | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI1_MEM_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI1_MEM_PHYS \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI1_MEM_PHYS \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT6L CONFIG_SYS_IBAT6L #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U /* PCI MMIO space: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI1_MMIO_PHYS | BATL_PP_10 | \ - BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT7U (CONFIG_SYS_PCI1_MMIO_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI1_MMIO_PHYS \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT7U (CONFIG_SYS_PCI1_MMIO_PHYS \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT7L CONFIG_SYS_IBAT7L #define CONFIG_SYS_DBAT7U CONFIG_SYS_IBAT7U #else @@ -547,30 +599,31 @@ #undef CONFIG_BOOTARGS /* the boot command will set bootargs */
#define CONFIG_EXTRA_ENV_SETTINGS \ - "netdev=eth0\0" \ - "consoledev=ttyS0\0" \ - "ramdiskaddr=1000000\0" \ - "ramdiskfile=ramfs.83xx\0" \ - "fdtaddr=780000\0" \ - "fdtfile=mpc832x_mds.dtb\0" \ - "" + "netdev=eth0\0" \ + "consoledev=ttyS0\0" \ + "ramdiskaddr=1000000\0" \ + "ramdiskfile=ramfs.83xx\0" \ + "fdtaddr=780000\0" \ + "fdtfile=mpc832x_mds.dtb\0" \ + ""
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- include/configs/MPC8349EMDS.h | 295 +++++++++++++++++++++++++---------------- 1 files changed, 178 insertions(+), 117 deletions(-)
diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index 45b6b5f..b377650 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -66,7 +66,7 @@
#define CONFIG_SYS_IMMR 0xE0000000
-#undef CONFIG_SYS_DRAM_TEST /* memory test, takes time */ +#undef CONFIG_SYS_DRAM_TEST /* memory test, takes time */ #define CONFIG_SYS_MEMTEST_START 0x00000000 /* memtest region */ #define CONFIG_SYS_MEMTEST_END 0x00100000
@@ -89,11 +89,11 @@ */ #undef CONFIG_DDR_32BIT
-#define CONFIG_SYS_DDR_BASE 0x00000000 /* DDR is system memory*/ -#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_BASE +#define CONFIG_SYS_DDR_BASE 0x00000000 /* DDR is system memory*/ +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_BASE #define CONFIG_SYS_DDR_SDRAM_BASE CONFIG_SYS_DDR_BASE -#define CONFIG_SYS_DDR_SDRAM_CLK_CNTL (DDR_SDRAM_CLK_CNTL_SS_EN | \ - DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05) +#define CONFIG_SYS_DDR_SDRAM_CLK_CNTL (DDR_SDRAM_CLK_CNTL_SS_EN \ + | DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05) #undef CONFIG_DDR_2T_TIMING
/* @@ -113,31 +113,35 @@ #define CONFIG_SYS_DDR_SIZE 256 /* MB */ #if defined(CONFIG_DDR_II) #define CONFIG_SYS_DDRCDR 0x80080001 -#define CONFIG_SYS_DDR_CS2_BNDS 0x0000000f +#define CONFIG_SYS_DDR_CS2_BNDS 0x0000000f #define CONFIG_SYS_DDR_CS2_CONFIG 0x80330102 -#define CONFIG_SYS_DDR_TIMING_0 0x00220802 -#define CONFIG_SYS_DDR_TIMING_1 0x38357322 -#define CONFIG_SYS_DDR_TIMING_2 0x2f9048c8 -#define CONFIG_SYS_DDR_TIMING_3 0x00000000 -#define CONFIG_SYS_DDR_CLK_CNTL 0x02000000 +#define CONFIG_SYS_DDR_TIMING_0 0x00220802 +#define CONFIG_SYS_DDR_TIMING_1 0x38357322 +#define CONFIG_SYS_DDR_TIMING_2 0x2f9048c8 +#define CONFIG_SYS_DDR_TIMING_3 0x00000000 +#define CONFIG_SYS_DDR_CLK_CNTL 0x02000000 #define CONFIG_SYS_DDR_MODE 0x47d00432 #define CONFIG_SYS_DDR_MODE2 0x8000c000 -#define CONFIG_SYS_DDR_INTERVAL 0x03cf0080 +#define CONFIG_SYS_DDR_INTERVAL 0x03cf0080 #define CONFIG_SYS_DDR_SDRAM_CFG 0x43000000 #define CONFIG_SYS_DDR_SDRAM_CFG2 0x00401000 #else -#define CONFIG_SYS_DDR_CONFIG (CSCONFIG_EN | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10) +#define CONFIG_SYS_DDR_CONFIG (CSCONFIG_EN \ + | CSCONFIG_ROW_BIT_13 \ + | CSCONFIG_COL_BIT_10) #define CONFIG_SYS_DDR_TIMING_1 0x36332321 #define CONFIG_SYS_DDR_TIMING_2 0x00000800 /* P9-45,may need tuning */ -#define CONFIG_SYS_DDR_CONTROL 0xc2000000 /* unbuffered,no DYN_PWR */ +#define CONFIG_SYS_DDR_CONTROL 0xc2000000 /* unbuffered,no DYN_PWR */ #define CONFIG_SYS_DDR_INTERVAL 0x04060100 /* autocharge,no open page */
#if defined(CONFIG_DDR_32BIT) /* set burst length to 8 for 32-bit data path */ -#define CONFIG_SYS_DDR_MODE 0x00000023 /* DLL,normal,seq,4/2.5, 8 burst len */ + /* DLL,normal,seq,4/2.5, 8 burst len */ +#define CONFIG_SYS_DDR_MODE 0x00000023 #else /* the default burst length is 4 - for 64-bit data path */ -#define CONFIG_SYS_DDR_MODE 0x00000022 /* DLL,normal,seq,4/2.5, 4 burst len */ + /* DLL,normal,seq,4/2.5, 4 burst len */ +#define CONFIG_SYS_DDR_MODE 0x00000022 #endif #endif #endif @@ -151,24 +155,31 @@ /* * FLASH on the Local Bus */ -#define CONFIG_SYS_FLASH_CFI /* use the Common Flash Interface */ -#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ +#define CONFIG_SYS_FLASH_CFI /* use the Common Flash Interface */ +#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ #define CONFIG_SYS_FLASH_BASE 0xFE000000 /* start of FLASH */ -#define CONFIG_SYS_FLASH_SIZE 32 /* max flash size in MB */ -#define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */ +#define CONFIG_SYS_FLASH_SIZE 32 /* max flash size in MB */ +#define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */ /* #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE */
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | /* flash Base address */ \ - (2 << BR_PS_SHIFT) | /* 16 bit port size */ \ +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | \ + (2 << BR_PS_SHIFT) | /* 16 bit port */ \ BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) | OR_UPM_XAM | \ - OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | OR_GPCM_XACS | OR_GPCM_SCY_15 | \ - OR_GPCM_TRLX | OR_GPCM_EHTR | OR_GPCM_EAD) -#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE /* window base at flash base */ +#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) \ + | OR_UPM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX \ + | OR_GPCM_EHTR \ + | OR_GPCM_EAD) + /* window base at flash base */ +#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000018 /* 32 MB window size */
-#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 256 /* max sectors per device */ +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 256 /* max sectors per device */
#undef CONFIG_SYS_FLASH_CHECKSUM #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ @@ -185,21 +196,25 @@ /* * BCSR register on local bus 32KB, 8-bit wide for MDS config reg */ -#define CONFIG_SYS_BCSR 0xE2400000 -#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_BCSR /* Access window base at BCSR base */ -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000E /* Access window size 32K */ -#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR|0x00000801) /* Port-size=8bit, MSEL=GPCM */ -#define CONFIG_SYS_OR1_PRELIM 0xFFFFE8F0 /* length 32K */ +#define CONFIG_SYS_BCSR 0xE2400000 + /* Access window base at BCSR base */ +#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_BCSR + /* Access window size 32K */ +#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000E + /* Port-size=8bit, MSEL=GPCM */ +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR|0x00000801) +#define CONFIG_SYS_OR1_PRELIM 0xFFFFE8F0 /* length 32K */
/* * Local Bus LCRR and LBCR regs @@ -207,8 +222,8 @@ * External Local Bus rate is * CLKIN * HRCWL_CSB_TO_CLKIN / HRCWL_LCL_BUS_TO_SCB_CLK / LCRR_CLKDIV */ -#define CONFIG_SYS_LCRR_DBYP LCRR_DBYP -#define CONFIG_SYS_LCRR_CLKDIV LCRR_CLKDIV_4 +#define CONFIG_SYS_LCRR_DBYP LCRR_DBYP +#define CONFIG_SYS_LCRR_CLKDIV LCRR_CLKDIV_4 #define CONFIG_SYS_LBC_LBCR 0x00000000
/* @@ -237,9 +252,10 @@ * FIXME: the top 17 bits of BR2. */
-#define CONFIG_SYS_BR2_PRELIM 0xF0001861 /* Port-size=32bit, MSEL=SDRAM */ + /* Port-size=32bit, MSEL=SDRAM */ +#define CONFIG_SYS_BR2_PRELIM 0xF0001861 #define CONFIG_SYS_LBLAWBAR2_PRELIM 0xF0000000 -#define CONFIG_SYS_LBLAWAR2_PRELIM 0x80000019 /* 64M */ +#define CONFIG_SYS_LBLAWAR2_PRELIM 0x80000019 /* 64M */
/* * The SDRAM size in MB, CONFIG_SYS_LBC_SDRAM_SIZE, is 64. @@ -257,18 +273,19 @@
#define CONFIG_SYS_OR2_PRELIM 0xFC006901
-#define CONFIG_SYS_LBC_LSDMR_COMMON ( LSDMR_RFEN \ +#define CONFIG_SYS_LBC_LSDMR_COMMON (LSDMR_RFEN \ | LSDMR_BSMA1516 \ | LSDMR_RFCR8 \ | LSDMR_PRETOACT6 \ | LSDMR_ACTTORW3 \ | LSDMR_BL8 \ | LSDMR_WRC3 \ - | LSDMR_CL3 \ - ) + | LSDMR_CL3)
/* * SDRAM Controller configuration sequence. @@ -290,7 +307,7 @@ #define CONFIG_SYS_NS16550_CLK get_bus_freq(0)
#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR+0x4600) @@ -299,7 +316,7 @@ #define CONFIG_AUTO_COMPLETE /* add autocompletion support */ /* Use the HUSH parser */ #define CONFIG_SYS_HUSH_PARSER -#ifdef CONFIG_SYS_HUSH_PARSER +#ifdef CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #endif
@@ -309,15 +326,15 @@ #define CONFIG_OF_STDOUT_VIA_ALIAS 1
/* I2C */ -#define CONFIG_HARD_I2C /* I2C with hardware support*/ -#undef CONFIG_SOFT_I2C /* I2C bit-banged */ +#define CONFIG_HARD_I2C /* I2C with hardware support*/ +#undef CONFIG_SOFT_I2C /* I2C bit-banged */ #define CONFIG_FSL_I2C #define CONFIG_I2C_MULTI_BUS -#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ -#define CONFIG_SYS_I2C_SLAVE 0x7F -#define CONFIG_SYS_I2C_NOPROBES {{0,0x69}} /* Don't probe these addrs */ -#define CONFIG_SYS_I2C_OFFSET 0x3000 -#define CONFIG_SYS_I2C2_OFFSET 0x3100 +#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_I2C_SLAVE 0x7F +#define CONFIG_SYS_I2C_NOPROBES { {0, 0x69} } /* Don't probe these addrs */ +#define CONFIG_SYS_I2C_OFFSET 0x3000 +#define CONFIG_SYS_I2C2_OFFSET 0x3100
/* SPI */ #define CONFIG_MPC8XXX_SPI @@ -330,9 +347,9 @@
/* TSEC */ #define CONFIG_SYS_TSEC1_OFFSET 0x24000 -#define CONFIG_SYS_TSEC1 (CONFIG_SYS_IMMR+CONFIG_SYS_TSEC1_OFFSET) +#define CONFIG_SYS_TSEC1 (CONFIG_SYS_IMMR+CONFIG_SYS_TSEC1_OFFSET) #define CONFIG_SYS_TSEC2_OFFSET 0x25000 -#define CONFIG_SYS_TSEC2 (CONFIG_SYS_IMMR+CONFIG_SYS_TSEC2_OFFSET) +#define CONFIG_SYS_TSEC2 (CONFIG_SYS_IMMR+CONFIG_SYS_TSEC2_OFFSET)
/* USB */ #define CONFIG_SYS_USE_MPC834XSYS_USB_PHY 1 /* Use SYS board PHY */ @@ -347,9 +364,9 @@ #define CONFIG_SYS_PCI1_MMIO_BASE 0x90000000 #define CONFIG_SYS_PCI1_MMIO_PHYS CONFIG_SYS_PCI1_MMIO_BASE #define CONFIG_SYS_PCI1_MMIO_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCI1_IO_BASE 0x00000000 -#define CONFIG_SYS_PCI1_IO_PHYS 0xE2000000 -#define CONFIG_SYS_PCI1_IO_SIZE 0x00100000 /* 1M */ +#define CONFIG_SYS_PCI1_IO_BASE 0x00000000 +#define CONFIG_SYS_PCI1_IO_PHYS 0xE2000000 +#define CONFIG_SYS_PCI1_IO_SIZE 0x00100000 /* 1M */
#define CONFIG_SYS_PCI2_MEM_BASE 0xA0000000 #define CONFIG_SYS_PCI2_MEM_PHYS CONFIG_SYS_PCI2_MEM_BASE @@ -357,9 +374,9 @@ #define CONFIG_SYS_PCI2_MMIO_BASE 0xB0000000 #define CONFIG_SYS_PCI2_MMIO_PHYS CONFIG_SYS_PCI2_MMIO_BASE #define CONFIG_SYS_PCI2_MMIO_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCI2_IO_BASE 0x00000000 -#define CONFIG_SYS_PCI2_IO_PHYS 0xE2100000 -#define CONFIG_SYS_PCI2_IO_SIZE 0x00100000 /* 1M */ +#define CONFIG_SYS_PCI2_IO_BASE 0x00000000 +#define CONFIG_SYS_PCI2_IO_PHYS 0xE2100000 +#define CONFIG_SYS_PCI2_IO_SIZE 0x00100000 /* 1M */
#if defined(CONFIG_PCI)
@@ -391,7 +408,7 @@ /* * TSEC configuration */ -#define CONFIG_TSEC_ENET /* TSEC ethernet support */ +#define CONFIG_TSEC_ENET /* TSEC ethernet support */
#if defined(CONFIG_TSEC_ENET) #ifndef CONFIG_NET_MULTI @@ -399,9 +416,9 @@ #endif
#define CONFIG_GMII 1 /* MII PHY management */ -#define CONFIG_TSEC1 1 +#define CONFIG_TSEC1 1 #define CONFIG_TSEC1_NAME "TSEC0" -#define CONFIG_TSEC2 1 +#define CONFIG_TSEC2 1 #define CONFIG_TSEC2_NAME "TSEC1" #define TSEC1_PHY_ADDR 0 #define TSEC2_PHY_ADDR 1 @@ -418,15 +435,16 @@ /* * Configure on-board RTC */ -#define CONFIG_RTC_DS1374 /* use ds1374 rtc via i2c */ -#define CONFIG_SYS_I2C_RTC_ADDR 0x68 /* at address 0x68 */ +#define CONFIG_RTC_DS1374 /* use ds1374 rtc via i2c */ +#define CONFIG_SYS_I2C_RTC_ADDR 0x68 /* at address 0x68 */
/* * Environment */ #ifndef CONFIG_SYS_RAMBOOT #define CONFIG_ENV_IS_IN_FLASH 1 - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) + #define CONFIG_ENV_ADDR \ + (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K(one sector) for env */ #define CONFIG_ENV_SIZE 0x2000
@@ -435,7 +453,7 @@ #define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE)
#else - #define CONFIG_SYS_NO_FLASH 1 /* Flash is not usable now */ + #define CONFIG_SYS_NO_FLASH 1 /* Flash is not usable now */ #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 @@ -484,22 +502,25 @@ #define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */
#if defined(CONFIG_CMD_KGDB) - #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ + #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #else - #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ + #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #endif
/* * For booting Linux, the board info and command line data * have to be in the first 256 MB of memory, since this is * the maximum mapped by the Linux kernel during initialization. */ -#define CONFIG_SYS_BOOTMAPSZ (256 << 20) /* Initial Memory map for Linux*/ + /* Initial Memory map for Linux*/ +#define CONFIG_SYS_BOOTMAPSZ (256 << 20)
#define CONFIG_SYS_RCWH_PCIHOST 0x80000000 /* PCIHOST */
@@ -552,7 +573,7 @@ HRCWH_SW_WATCHDOG_DISABLE |\ HRCWH_ROM_LOC_LOCAL_16BIT |\ HRCWH_TSEC1M_IN_GMII |\ - HRCWH_TSEC2M_IN_GMII ) + HRCWH_TSEC2M_IN_GMII) #else #if defined(PCI_64BIT) #define CONFIG_SYS_HRCW_HIGH (\ @@ -566,7 +587,7 @@ HRCWH_SW_WATCHDOG_DISABLE |\ HRCWH_ROM_LOC_LOCAL_16BIT |\ HRCWH_TSEC1M_IN_GMII |\ - HRCWH_TSEC2M_IN_GMII ) + HRCWH_TSEC2M_IN_GMII) #else #define CONFIG_SYS_HRCW_HIGH (\ HRCWH_PCI_HOST |\ @@ -579,7 +600,7 @@ HRCWH_SW_WATCHDOG_DISABLE |\ HRCWH_ROM_LOC_LOCAL_16BIT |\ HRCWH_TSEC1M_IN_GMII |\ - HRCWH_TSEC2M_IN_GMII ) + HRCWH_TSEC2M_IN_GMII) #endif /* PCI_64BIT */ #endif /* CONFIG_PCISLAVE */
@@ -587,7 +608,7 @@ * System performance */ #define CONFIG_SYS_ACR_PIPE_DEP 3 /* Arbiter pipeline depth (0-3) */ -#define CONFIG_SYS_ACR_RPTCNT 3 /* Arbiter repeat count (0-7) */ +#define CONFIG_SYS_ACR_RPTCNT 3 /* Arbiter repeat count (0-7) */ #define CONFIG_SYS_SPCR_TSEC1EP 3 /* TSEC1 emergency priority (0-3) */ #define CONFIG_SYS_SPCR_TSEC2EP 3 /* TSEC2 emergency priority (0-3) */ #define CONFIG_SYS_SCCR_TSEC1CM 1 /* TSEC1 clock mode (0-3) */ @@ -598,28 +619,44 @@ #define CONFIG_SYS_SICRL SICRL_LDP_A
#define CONFIG_SYS_HID0_INIT 0x000000000 -#define CONFIG_SYS_HID0_FINAL (HID0_ENABLE_MACHINE_CHECK | \ - HID0_ENABLE_INSTRUCTION_CACHE) +#define CONFIG_SYS_HID0_FINAL (HID0_ENABLE_MACHINE_CHECK \ + | HID0_ENABLE_INSTRUCTION_CACHE)
-/* #define CONFIG_SYS_HID0_FINAL (\ +/* #define CONFIG_SYS_HID0_FINAL (\ HID0_ENABLE_INSTRUCTION_CACHE |\ HID0_ENABLE_M_BIT |\ - HID0_ENABLE_ADDRESS_BROADCAST ) */ + HID0_ENABLE_ADDRESS_BROADCAST) */
#define CONFIG_SYS_HID2 HID2_HBE #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR @ 0x00000000 */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP)
/* PCI @ 0x80000000 */ #ifdef CONFIG_PCI -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) #else #define CONFIG_SYS_IBAT1L (0) #define CONFIG_SYS_IBAT1U (0) @@ -628,10 +665,21 @@ #endif
#ifdef CONFIG_MPC83XX_PCI2 -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI2_MEM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT3U (CONFIG_SYS_PCI2_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI2_MMIO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT4U (CONFIG_SYS_PCI2_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI2_MEM_BASE \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT3U (CONFIG_SYS_PCI2_MEM_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI2_MMIO_BASE \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT4U (CONFIG_SYS_PCI2_MMIO_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) #else #define CONFIG_SYS_IBAT3L (0) #define CONFIG_SYS_IBAT3U (0) @@ -640,13 +688,25 @@ #endif
/* IMMRBAR @ 0xE0000000, PCI IO @ 0xE2000000 & BCSR @ 0xE2400000 */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT5U (CONFIG_SYS_IMMR | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT5U (CONFIG_SYS_IMMR \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP)
/* SDRAM @ 0xF0000000, stack in DCACHE 0xFDF00000 & FLASH @ 0xFE000000 */ -#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_10 | BATL_MEMCOHERENCE | \ +#define CONFIG_SYS_IBAT6L (0xF0000000 \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE |\ + \ BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT6U (0xF0000000 | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT6U (0xF0000000 \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP)
#define CONFIG_SYS_IBAT7L (0) #define CONFIG_SYS_IBAT7U (0) @@ -687,10 +747,10 @@ #define CONFIG_ROOTPATH /nfsroot/rootfs #define CONFIG_BOOTFILE uImage
-#define CONFIG_LOADADDR 800000 /* default location for tftp and bootm */ +#define CONFIG_LOADADDR 800000 /* default location for tftp and bootm */
#define CONFIG_BOOTDELAY 6 /* -1 disables auto-boot */ -#undef CONFIG_BOOTARGS /* the boot command will set bootargs */ +#undef CONFIG_BOOTARGS /* the boot command will set bootargs */
#define CONFIG_BAUDRATE 115200
@@ -716,28 +776,29 @@ "bootm\0" \ "load=tftp 100000 /tftpboot/mpc8349emds/u-boot.bin\0" \ "update=protect off fe000000 fe03ffff; " \ - "era fe000000 fe03ffff; cp.b 100000 fe000000 ${filesize}\0" \ + "era fe000000 fe03ffff; cp.b 100000 fe000000 ${filesize}\0"\ "upd=run load update\0" \ "fdtaddr=780000\0" \ "fdtfile=mpc834x_mds.dtb\0" \ ""
-#define CONFIG_NFSBOOTCOMMAND \ - "setenv bootargs root=/dev/nfs rw " \ - "nfsroot=$serverip:$rootpath " \ - "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "tftp $loadaddr $bootfile;" \ - "tftp $fdtaddr $fdtfile;" \ - "bootm $loadaddr - $fdtaddr" +#define CONFIG_NFSBOOTCOMMAND \ + "setenv bootargs root=/dev/nfs rw " \ + "nfsroot=$serverip:$rootpath " \ + "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:" \ + "$netdev:off " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr - $fdtaddr"
#define CONFIG_BOOTCOMMAND "run flash_self"
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- include/configs/MPC8349ITX.h | 328 ++++++++++++++++++++++++++---------------- 1 files changed, 204 insertions(+), 124 deletions(-)
diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index de233ff..c98c675 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -71,7 +71,7 @@ #define CONFIG_SYS_TEXT_BASE 0xFEF00000 #endif
-#define CONFIG_SYS_IMMR 0xE0000000 /* The IMMR is relocated to here */ +#define CONFIG_SYS_IMMR 0xE0000000 /* The IMMR is relocated to here */
#define CONFIG_MISC_INIT_F #define CONFIG_MISC_INIT_R @@ -81,7 +81,8 @@ */
#ifdef CONFIG_MPC8349ITX -#define CONFIG_COMPACT_FLASH /* The CF card interface on the back of the board */ +/* The CF card interface on the back of the board */ +#define CONFIG_COMPACT_FLASH #define CONFIG_VSC7385_ENET /* VSC7385 ethernet support */ #define CONFIG_SATA_SIL3114 /* SIL3114 SATA controller */ #define CONFIG_SYS_USB_HOST /* use the EHCI USB controller */ @@ -111,19 +112,20 @@ #define CONFIG_SYS_I2C_8574A_ADDR1 0x38 /* I2C1, PCF8574A */ #define CONFIG_SYS_I2C_8574A_ADDR2 0x39 /* I2C1, PCF8574A */ #define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* I2C0, Board EEPROM */ -#define CONFIG_SYS_I2C_RTC_ADDR 0x68 /* I2C1, DS1339 RTC*/ -#define SPD_EEPROM_ADDRESS 0x51 /* I2C1, DDR */ +#define CONFIG_SYS_I2C_RTC_ADDR 0x68 /* I2C1, DS1339 RTC*/ +#define SPD_EEPROM_ADDRESS 0x51 /* I2C1, DDR */
-#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ -#define CONFIG_SYS_I2C_SLAVE 0x7F +#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_I2C_SLAVE 0x7F
/* Don't probe these addresses: */ -#define CONFIG_SYS_I2C_NOPROBES {{1, CONFIG_SYS_I2C_8574_ADDR1}, \ +#define CONFIG_SYS_I2C_NOPROBES { {1, CONFIG_SYS_I2C_8574_ADDR1}, \ {1, CONFIG_SYS_I2C_8574_ADDR2}, \ {1, CONFIG_SYS_I2C_8574A_ADDR1}, \ - {1, CONFIG_SYS_I2C_8574A_ADDR2}} + {1, CONFIG_SYS_I2C_8574A_ADDR2} } /* Bit definitions for the 8574[A] I2C expander */ -#define I2C_8574_REVISION 0x03 /* Board revision, 00=0.0, 01=0.1, 10=1.0 */ + /* Board revision, 00=0.0, 01=0.1, 10=1.0 */ +#define I2C_8574_REVISION 0x03 #define I2C_8574_CF 0x08 /* 1=Compact flash absent, 0=present */ #define I2C_8574_MPCICLKRN 0x10 /* MiniPCI Clk Run */ #define I2C_8574_PCI66 0x20 /* 0=33MHz PCI, 1=66MHz PCI */ @@ -146,7 +148,8 @@ #define CONFIG_SYS_ATA_ALT_OFFSET 0x0200 #define CONFIG_SYS_ATA_STRIDE 2
-#define ATA_RESET_TIME 1 /* If a CF card is not inserted, time out quickly */ +/* If a CF card is not inserted, time out quickly */ +#define ATA_RESET_TIME 1
#endif
@@ -183,15 +186,15 @@ /* * DDR Setup */ -#define CONFIG_SYS_DDR_BASE 0x00000000 /* DDR is system memory*/ +#define CONFIG_SYS_DDR_BASE 0x00000000 /* DDR is system memory*/ #define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_BASE #define CONFIG_SYS_DDR_SDRAM_BASE CONFIG_SYS_DDR_BASE #define CONFIG_SYS_83XX_DDR_USES_CS0 -#define CONFIG_SYS_MEMTEST_START 0x1000 /* memtest region */ +#define CONFIG_SYS_MEMTEST_START 0x1000 /* memtest region */ #define CONFIG_SYS_MEMTEST_END 0x2000
-#define CONFIG_SYS_DDR_SDRAM_CLK_CNTL (DDR_SDRAM_CLK_CNTL_SS_EN | \ - DDR_SDRAM_CLK_CNTL_CLK_ADJUST_075) +#define CONFIG_SYS_DDR_SDRAM_CLK_CNTL (DDR_SDRAM_CLK_CNTL_SS_EN \ + | DDR_SDRAM_CLK_CNTL_CLK_ADJUST_075)
#define CONFIG_VERY_BIG_RAM #define CONFIG_MAX_MEM_MAPPED ((phys_size_t)256 << 20) @@ -200,9 +203,12 @@ #define CONFIG_SPD_EEPROM /* use SPD EEPROM for DDR setup*/ #endif
-#ifndef CONFIG_SPD_EEPROM /* No SPD? Then manually set up DDR parameters */ - #define CONFIG_SYS_DDR_SIZE 256 /* Mb */ - #define CONFIG_SYS_DDR_CONFIG (CSCONFIG_EN | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10) +/* No SPD? Then manually set up DDR parameters */ +#ifndef CONFIG_SPD_EEPROM + #define CONFIG_SYS_DDR_SIZE 256 /* Mb */ + #define CONFIG_SYS_DDR_CONFIG (CSCONFIG_EN \ + | CSCONFIG_ROW_BIT_13 \ + | CSCONFIG_COL_BIT_10)
#define CONFIG_SYS_DDR_TIMING_1 0x26242321 #define CONFIG_SYS_DDR_TIMING_2 0x00000800 /* P9-45, may need tuning */ @@ -212,11 +218,12 @@ *Flash on the Local Bus */
-#define CONFIG_SYS_FLASH_CFI /* use the Common Flash Interface */ -#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ +#define CONFIG_SYS_FLASH_CFI /* use the Common Flash Interface */ +#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ #define CONFIG_SYS_FLASH_BASE 0xFE000000 /* start of FLASH */ #define CONFIG_SYS_FLASH_EMPTY_INFO -#define CONFIG_SYS_MAX_FLASH_SECT 135 /* 127 64KB sectors + 8 8KB sectors per device */ +/* 127 64KB sectors + 8 8KB sectors per device */ +#define CONFIG_SYS_MAX_FLASH_SECT 135 #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (ms) */ #define CONFIG_SYS_FLASH_CFI_WIDTH FLASH_CFI_16BIT @@ -224,11 +231,12 @@ /* The ITX has two flash chips, but the ITX-GP has only one. To support both boards, we say we have two, but don't display a message if we find only one. */ #define CONFIG_SYS_FLASH_QUIET_TEST -#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* number of banks */ -#define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE + 0x800000} -#define CONFIG_SYS_FLASH_SIZE 16 /* FLASH size in MB */ -#define CONFIG_SYS_FLASH_SIZE_SHIFT 4 /* log2 of the above value */ -#define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */ +#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* number of banks */ +#define CONFIG_SYS_FLASH_BANKS_LIST \ + {CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE + 0x800000} +#define CONFIG_SYS_FLASH_SIZE 16 /* FLASH size in MB */ +#define CONFIG_SYS_FLASH_SIZE_SHIFT 4 /* log2 of the above value */ +#define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */
/* Vitesse 7385 */
@@ -248,12 +256,19 @@ boards, we say we have two, but don't display a message if we find only one. */
/* Flash */
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | BR_PS_16 | BR_V) -#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) | OR_UPM_XAM | \ - OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | OR_GPCM_XACS | OR_GPCM_SCY_15 | \ - OR_GPCM_TRLX | OR_GPCM_EHTR | OR_GPCM_EAD) +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | BR_PS_16 | BR_V) +#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) \ + | OR_UPM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX \ + | OR_GPCM_EHTR \ + | OR_GPCM_EAD) #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | (0x13 + CONFIG_SYS_FLASH_SIZE_SHIFT)) +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN \ + | (0x13 + CONFIG_SYS_FLASH_SIZE_SHIFT))
/* Vitesse 7385 */
@@ -261,10 +276,15 @@ boards, we say we have two, but don't display a message if we find only one. */
#ifdef CONFIG_VSC7385_ENET
-#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_VSC7385_BASE | BR_PS_8 | BR_V) -#define CONFIG_SYS_OR1_PRELIM (OR_AM_128KB | OR_GPCM_CSNT | OR_GPCM_XACS | \ - OR_GPCM_SCY_15 | OR_GPCM_SETA | OR_GPCM_TRLX | \ - OR_GPCM_EHTR | OR_GPCM_EAD) +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_VSC7385_BASE | BR_PS_8 | BR_V) +#define CONFIG_SYS_OR1_PRELIM (OR_AM_128KB \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_SETA \ + | OR_GPCM_TRLX \ + | OR_GPCM_EHTR \ + | OR_GPCM_EAD)
#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_VSC7385_BASE #define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_128KB) @@ -273,20 +293,28 @@ boards, we say we have two, but don't display a message if we find only one. */
/* LED */
-#define CONFIG_SYS_LED_BASE 0xF9000000 -#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_LED_BASE | BR_PS_8 | BR_V) -#define CONFIG_SYS_OR2_PRELIM (OR_AM_2MB | OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | \ - OR_GPCM_XACS | OR_GPCM_SCY_9 | OR_GPCM_TRLX | \ - OR_GPCM_EHTR | OR_GPCM_EAD) +#define CONFIG_SYS_LED_BASE 0xF9000000 +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_LED_BASE | BR_PS_8 | BR_V) +#define CONFIG_SYS_OR2_PRELIM (OR_AM_2MB \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_9 \ + | OR_GPCM_TRLX \ + | OR_GPCM_EHTR \ + | OR_GPCM_EAD)
/* Compact Flash */
#ifdef CONFIG_COMPACT_FLASH
-#define CONFIG_SYS_CF_BASE 0xF0000000 +#define CONFIG_SYS_CF_BASE 0xF0000000
-#define CONFIG_SYS_BR3_PRELIM (CONFIG_SYS_CF_BASE | BR_PS_16 | BR_MS_UPMA | BR_V) -#define CONFIG_SYS_OR3_PRELIM (OR_UPM_AM | OR_UPM_BI) +#define CONFIG_SYS_BR3_PRELIM (CONFIG_SYS_CF_BASE \ + | BR_PS_16 \ + | BR_MS_UPMA \ + | BR_V) +#define CONFIG_SYS_OR3_PRELIM (OR_UPM_AM | OR_UPM_BI)
#define CONFIG_SYS_LBLAWBAR3_PRELIM CONFIG_SYS_CF_BASE #define CONFIG_SYS_LBLAWAR3_PRELIM (LBLAWAR_EN | LBLAWAR_64KB) @@ -305,15 +333,16 @@ boards, we say we have two, but don't display a message if we find only one. */ #endif
#define CONFIG_SYS_INIT_RAM_LOCK -#define CONFIG_SYS_INIT_RAM_ADDR 0xFD000000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM*/ +#define CONFIG_SYS_INIT_RAM_ADDR 0xFD000000 /* Initial RAM addr */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM*/
-#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* * Local Bus LCRR and LBCR regs @@ -325,8 +354,10 @@ boards, we say we have two, but don't display a message if we find only one. */ #define CONFIG_SYS_LCRR_CLKDIV LCRR_CLKDIV_4 #define CONFIG_SYS_LBC_LBCR 0x00000000
-#define CONFIG_SYS_LBC_LSRT 0x32000000 /* LB sdram refresh timer, about 6us */ -#define CONFIG_SYS_LBC_MRTPR 0x20000000 /* LB refresh timer prescal, 266MHz/32*/ + /* LB sdram refresh timer, about 6us */ +#define CONFIG_SYS_LBC_LSRT 0x32000000 + /* LB refresh timer prescal, 266MHz/32*/ +#define CONFIG_SYS_LBC_MRTPR 0x20000000
/* * Serial Port @@ -338,7 +369,7 @@ boards, we say we have two, but don't display a message if we find only one. */ #define CONFIG_SYS_NS16550_CLK get_bus_freq(0)
#define CONFIG_SYS_BAUDRATE_TABLE \ - {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 115200} + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 115200}
#define CONFIG_CONSOLE ttyS0 #define CONFIG_BAUDRATE 115200 @@ -365,23 +396,27 @@ boards, we say we have two, but don't display a message if we find only one. */ #define CONFIG_SYS_PCI1_MEM_BASE 0x80000000 #define CONFIG_SYS_PCI1_MEM_PHYS CONFIG_SYS_PCI1_MEM_BASE #define CONFIG_SYS_PCI1_MEM_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCI1_MMIO_BASE (CONFIG_SYS_PCI1_MEM_BASE + CONFIG_SYS_PCI1_MEM_SIZE) +#define CONFIG_SYS_PCI1_MMIO_BASE \ + (CONFIG_SYS_PCI1_MEM_BASE + CONFIG_SYS_PCI1_MEM_SIZE) #define CONFIG_SYS_PCI1_MMIO_PHYS CONFIG_SYS_PCI1_MMIO_BASE #define CONFIG_SYS_PCI1_MMIO_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCI1_IO_BASE 0x00000000 -#define CONFIG_SYS_PCI1_IO_PHYS 0xE2000000 -#define CONFIG_SYS_PCI1_IO_SIZE 0x01000000 /* 16M */ +#define CONFIG_SYS_PCI1_IO_BASE 0x00000000 +#define CONFIG_SYS_PCI1_IO_PHYS 0xE2000000 +#define CONFIG_SYS_PCI1_IO_SIZE 0x01000000 /* 16M */
#ifdef CONFIG_MPC83XX_PCI2 -#define CONFIG_SYS_PCI2_MEM_BASE (CONFIG_SYS_PCI1_MMIO_BASE + CONFIG_SYS_PCI1_MMIO_SIZE) +#define CONFIG_SYS_PCI2_MEM_BASE \ + (CONFIG_SYS_PCI1_MMIO_BASE + CONFIG_SYS_PCI1_MMIO_SIZE) #define CONFIG_SYS_PCI2_MEM_PHYS CONFIG_SYS_PCI2_MEM_BASE #define CONFIG_SYS_PCI2_MEM_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCI2_MMIO_BASE (CONFIG_SYS_PCI2_MEM_BASE + CONFIG_SYS_PCI2_MEM_SIZE) +#define CONFIG_SYS_PCI2_MMIO_BASE \ + (CONFIG_SYS_PCI2_MEM_BASE + CONFIG_SYS_PCI2_MEM_SIZE) #define CONFIG_SYS_PCI2_MMIO_PHYS CONFIG_SYS_PCI2_MMIO_BASE #define CONFIG_SYS_PCI2_MMIO_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCI2_IO_BASE 0x00000000 -#define CONFIG_SYS_PCI2_IO_PHYS (CONFIG_SYS_PCI1_IO_PHYS + CONFIG_SYS_PCI1_IO_SIZE) -#define CONFIG_SYS_PCI2_IO_SIZE 0x01000000 /* 16M */ +#define CONFIG_SYS_PCI2_IO_BASE 0x00000000 +#define CONFIG_SYS_PCI2_IO_PHYS \ + (CONFIG_SYS_PCI1_IO_PHYS + CONFIG_SYS_PCI1_IO_SIZE) +#define CONFIG_SYS_PCI2_IO_SIZE 0x01000000 /* 16M */ #endif
#define CONFIG_NET_MULTI @@ -444,15 +479,16 @@ boards, we say we have two, but don't display a message if we find only one. */
#ifndef CONFIG_SYS_RAMBOOT #define CONFIG_ENV_IS_IN_FLASH - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) + #define CONFIG_ENV_ADDR \ + (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K (one sector) for environment */ - #define CONFIG_ENV_SIZE 0x2000 + #define CONFIG_ENV_SIZE 0x2000 #else - #define CONFIG_SYS_NO_FLASH /* Flash is not usable now */ + #define CONFIG_SYS_NO_FLASH /* Flash is not usable now */ #undef CONFIG_FLASH_CFI_DRIVER #define CONFIG_ENV_IS_NOWHERE /* Store ENV in memory only */ - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) - #define CONFIG_ENV_SIZE 0x2000 + #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) + #define CONFIG_ENV_SIZE 0x2000 #endif
#define CONFIG_LOADS_ECHO /* echo on for serial download */ @@ -481,30 +517,30 @@ boards, we say we have two, but don't display a message if we find only one. */ #define CONFIG_CMD_SDRAM
#if defined(CONFIG_COMPACT_FLASH) || defined(CONFIG_SATA_SIL3114) \ - || defined(CONFIG_USB_STORAGE) - #define CONFIG_DOS_PARTITION - #define CONFIG_CMD_FAT - #define CONFIG_SUPPORT_VFAT + || defined(CONFIG_USB_STORAGE) + #define CONFIG_DOS_PARTITION + #define CONFIG_CMD_FAT + #define CONFIG_SUPPORT_VFAT #endif
#ifdef CONFIG_COMPACT_FLASH - #define CONFIG_CMD_IDE + #define CONFIG_CMD_IDE #endif
#ifdef CONFIG_SATA_SIL3114 - #define CONFIG_CMD_SATA + #define CONFIG_CMD_SATA #endif
#if defined(CONFIG_SATA_SIL3114) || defined(CONFIG_USB_STORAGE) - #define CONFIG_CMD_EXT2 + #define CONFIG_CMD_EXT2 #endif
#ifdef CONFIG_PCI - #define CONFIG_CMD_PCI + #define CONFIG_CMD_PCI #endif
#ifdef CONFIG_HARD_I2C - #define CONFIG_CMD_I2C + #define CONFIG_CMD_I2C #endif
/* Watchdog */ @@ -513,38 +549,41 @@ boards, we say we have two, but don't display a message if we find only one. */ /* * Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_CMDLINE_EDITING /* Command-line editing */ -#define CONFIG_AUTO_COMPLETE /* add autocompletion support */ -#define CONFIG_SYS_HUSH_PARSER /* Use the HUSH parser */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_CMDLINE_EDITING /* Command-line editing */ +#define CONFIG_AUTO_COMPLETE /* add autocompletion support */ +#define CONFIG_SYS_HUSH_PARSER /* Use the HUSH parser */ #define CONFIG_SYS_PROMPT_HUSH_PS2 "> "
#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ #define CONFIG_LOADADDR 800000 /* default location for tftp and bootm */
#ifdef CONFIG_MPC8349ITX -#define CONFIG_SYS_PROMPT "MPC8349E-mITX> " /* Monitor Command Prompt */ +#define CONFIG_SYS_PROMPT "MPC8349E-mITX> " /* Monitor Command Prompt */ #else -#define CONFIG_SYS_PROMPT "MPC8349E-mITX-GP> " /* Monitor Command Prompt */ +#define CONFIG_SYS_PROMPT "MPC8349E-mITX-GP> " /* Monitor Command Prompt */ #endif
-#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ -#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */ + /* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ + /* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */
#define CONFIG_SYS_HRCW_LOW (\ HRCWL_LCL_BUS_TO_SCB_CLK_1X1 |\ @@ -565,7 +604,7 @@ boards, we say we have two, but don't display a message if we find only one. */ HRCWH_SW_WATCHDOG_DISABLE |\ HRCWH_ROM_LOC_LOCAL_16BIT |\ HRCWH_TSEC1M_IN_GMII |\ - HRCWH_TSEC2M_IN_GMII ) + HRCWH_TSEC2M_IN_GMII) #else #define CONFIG_SYS_HRCW_HIGH (\ HRCWH_PCI_HOST |\ @@ -578,14 +617,14 @@ boards, we say we have two, but don't display a message if we find only one. */ HRCWH_SW_WATCHDOG_DISABLE |\ HRCWH_ROM_LOC_LOCAL_16BIT |\ HRCWH_TSEC1M_IN_GMII |\ - HRCWH_TSEC2M_IN_GMII ) + HRCWH_TSEC2M_IN_GMII) #endif
/* * System performance */ #define CONFIG_SYS_ACR_PIPE_DEP 3 /* Arbiter pipeline depth (0-3) */ -#define CONFIG_SYS_ACR_RPTCNT 3 /* Arbiter repeat count (0-7) */ +#define CONFIG_SYS_ACR_RPTCNT 3 /* Arbiter repeat count (0-7) */ #define CONFIG_SYS_SPCR_TSEC1EP 3 /* TSEC1 emergency priority (0-3) */ #define CONFIG_SYS_SPCR_TSEC2EP 3 /* TSEC2 emergency priority (0-3) */ #define CONFIG_SYS_SCCR_TSEC1CM 1 /* TSEC1 clock mode (0-3) */ @@ -596,8 +635,10 @@ boards, we say we have two, but don't display a message if we find only one. */ /* * System IO Config */ -#define CONFIG_SYS_SICRH SICRH_TSOBI1 /* Needed for gigabit to work on TSEC 1 */ -#define CONFIG_SYS_SICRL (SICRL_LDP_A | SICRL_USB1) /* USB DR as device + USB MPH as host */ +/* Needed for gigabit to work on TSEC 1 */ +#define CONFIG_SYS_SICRH SICRH_TSOBI1 + /* USB DR as device + USB MPH as host */ +#define CONFIG_SYS_SICRL (SICRL_LDP_A | SICRL_USB1)
#define CONFIG_SYS_HID0_INIT 0x00000000 #define CONFIG_SYS_HID0_FINAL HID0_ENABLE_INSTRUCTION_CACHE @@ -606,15 +647,31 @@ boards, we say we have two, but don't display a message if we find only one. */ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP)
/* PCI */ #ifdef CONFIG_PCI -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) #else #define CONFIG_SYS_IBAT1L 0 #define CONFIG_SYS_IBAT1U 0 @@ -623,10 +680,21 @@ boards, we say we have two, but don't display a message if we find only one. */ #endif
#ifdef CONFIG_MPC83XX_PCI2 -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI2_MEM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT3U (CONFIG_SYS_PCI2_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI2_MMIO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT4U (CONFIG_SYS_PCI2_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI2_MEM_BASE \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT3U (CONFIG_SYS_PCI2_MEM_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI2_MMIO_BASE \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT4U (CONFIG_SYS_PCI2_MMIO_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) #else #define CONFIG_SYS_IBAT3L 0 #define CONFIG_SYS_IBAT3U 0 @@ -635,13 +703,24 @@ boards, we say we have two, but don't display a message if we find only one. */ #endif
/* SDRAM @ 0xF0000000, stack in DCACHE 0xFDF00000 & FLASH @ 0xFE000000 */ -#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_10 | BATL_MEMCOHERENCE | \ - BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT6U (0xF0000000 | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT6L (0xF0000000 \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT6U (0xF0000000 \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP)
#define CONFIG_SYS_IBAT7L 0 #define CONFIG_SYS_IBAT7U 0 @@ -674,23 +753,24 @@ boards, we say we have two, but don't display a message if we find only one. */ */ #define CONFIG_ENV_OVERWRITE
-#define CONFIG_NETDEV eth0 +#define CONFIG_NETDEV "eth0"
#ifdef CONFIG_MPC8349ITX -#define CONFIG_HOSTNAME mpc8349emitx +#define CONFIG_HOSTNAME "mpc8349emitx" #else -#define CONFIG_HOSTNAME mpc8349emitxgp +#define CONFIG_HOSTNAME "mpc8349emitxgp" #endif
/* Default path and filenames */ #define CONFIG_ROOTPATH /nfsroot/rootfs #define CONFIG_BOOTFILE uImage -#define CONFIG_UBOOTPATH u-boot.bin /* U-Boot image on TFTP server */ + /* U-Boot image on TFTP server */ +#define CONFIG_UBOOTPATH "u-boot.bin"
#ifdef CONFIG_MPC8349ITX -#define CONFIG_FDTFILE mpc8349emitx.dtb +#define CONFIG_FDTFILE "mpc8349emitx.dtb" #else -#define CONFIG_FDTFILE mpc8349emitxgp.dtb +#define CONFIG_FDTFILE "mpc8349emitxgp.dtb" #endif
#define CONFIG_BOOTDELAY 6 @@ -700,28 +780,28 @@ boards, we say we have two, but don't display a message if we find only one. */
#define CONFIG_BOOTARGS \ "root=/dev/nfs rw" \ - " nfsroot=" MK_STR(CONFIG_SERVERIP) ":" MK_STR(CONFIG_ROOTPATH) \ + " nfsroot=" MK_STR(CONFIG_SERVERIP) ":" MK_STR(CONFIG_ROOTPATH) \ " ip=" MK_STR(CONFIG_IPADDR) ":" MK_STR(CONFIG_SERVERIP) ":" \ - MK_STR(CONFIG_GATEWAYIP) ":" MK_STR(CONFIG_NETMASK) ":" \ - MK_STR(CONFIG_HOSTNAME) ":" MK_STR(CONFIG_NETDEV) ":off" \ + MK_STR(CONFIG_GATEWAYIP) ":" MK_STR(CONFIG_NETMASK) ":" \ + CONFIG_HOSTNAME ":" CONFIG_NETDEV ":off" \ " console=" MK_STR(CONFIG_CONSOLE) "," MK_STR(CONFIG_BAUDRATE)
#define CONFIG_EXTRA_ENV_SETTINGS \ "console=" MK_STR(CONFIG_CONSOLE) "\0" \ - "netdev=" MK_STR(CONFIG_NETDEV) "\0" \ - "uboot=" MK_STR(CONFIG_UBOOTPATH) "\0" \ + "netdev=" CONFIG_NETDEV "\0" \ + "uboot=" CONFIG_UBOOTPATH "\0" \ "tftpflash=tftpboot $loadaddr $uboot; " \ - "protect off " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; " \ - "erase " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; " \ - "cp.b $loadaddr " MK_STR(CONFIG_SYS_TEXT_BASE) " $filesize; " \ - "protect on " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; " \ - "cmp.b $loadaddr " MK_STR(CONFIG_SYS_TEXT_BASE) " $filesize\0" \ + "protect off " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; "\ + "erase " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; " \ + "cp.b $loadaddr " MK_STR(CONFIG_SYS_TEXT_BASE) " $filesize; "\ + "protect on " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; "\ + "cmp.b $loadaddr " MK_STR(CONFIG_SYS_TEXT_BASE) " $filesize\0"\ "fdtaddr=780000\0" \ - "fdtfile=" MK_STR(CONFIG_FDTFILE) "\0" + "fdtfile=" CONFIG_FDTFILE "\0"
#define CONFIG_NFSBOOTCOMMAND \ "setenv bootargs root=/dev/nfs rw nfsroot=$serverip:$rootpath" \ - " ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ + " ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off "\ " console=$console,$baudrate $othbootargs; " \ "tftp $loadaddr $bootfile;" \ "tftp $fdtaddr $fdtfile;" \
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- include/configs/MPC8360EMDS.h | 223 ++++++++++++++++++++++++++--------------- 1 files changed, 141 insertions(+), 82 deletions(-)
diff --git a/include/configs/MPC8360EMDS.h b/include/configs/MPC8360EMDS.h index 49d64a5..5c6b1ac 100644 --- a/include/configs/MPC8360EMDS.h +++ b/include/configs/MPC8360EMDS.h @@ -101,12 +101,13 @@ /* * DDR Setup */ -#define CONFIG_SYS_DDR_BASE 0x00000000 /* DDR is system memory */ -#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_BASE -#define CONFIG_SYS_SDRAM_BASE2 (CONFIG_SYS_SDRAM_BASE + 0x10000000) /* + 256M */ +#define CONFIG_SYS_DDR_BASE 0x00000000 /* DDR is system memory */ +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_BASE + /* + 256M */ +#define CONFIG_SYS_SDRAM_BASE2 (CONFIG_SYS_SDRAM_BASE + 0x10000000) #define CONFIG_SYS_DDR_SDRAM_BASE CONFIG_SYS_DDR_BASE -#define CONFIG_SYS_DDR_SDRAM_CLK_CNTL (DDR_SDRAM_CLK_CNTL_SS_EN | \ - DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05) +#define CONFIG_SYS_DDR_SDRAM_CLK_CNTL (DDR_SDRAM_CLK_CNTL_SS_EN \ + | DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05)
@@ -131,24 +132,26 @@ #define CONFIG_SYS_DDR_SIZE 256 /* MB */ #if defined(CONFIG_DDR_II) #define CONFIG_SYS_DDRCDR 0x80080001 -#define CONFIG_SYS_DDR_CS0_BNDS 0x0000000f +#define CONFIG_SYS_DDR_CS0_BNDS 0x0000000f #define CONFIG_SYS_DDR_CS0_CONFIG 0x80330102 -#define CONFIG_SYS_DDR_TIMING_0 0x00220802 -#define CONFIG_SYS_DDR_TIMING_1 0x38357322 -#define CONFIG_SYS_DDR_TIMING_2 0x2f9048c8 -#define CONFIG_SYS_DDR_TIMING_3 0x00000000 -#define CONFIG_SYS_DDR_CLK_CNTL 0x02000000 +#define CONFIG_SYS_DDR_TIMING_0 0x00220802 +#define CONFIG_SYS_DDR_TIMING_1 0x38357322 +#define CONFIG_SYS_DDR_TIMING_2 0x2f9048c8 +#define CONFIG_SYS_DDR_TIMING_3 0x00000000 +#define CONFIG_SYS_DDR_CLK_CNTL 0x02000000 #define CONFIG_SYS_DDR_MODE 0x47d00432 #define CONFIG_SYS_DDR_MODE2 0x8000c000 -#define CONFIG_SYS_DDR_INTERVAL 0x03cf0080 +#define CONFIG_SYS_DDR_INTERVAL 0x03cf0080 #define CONFIG_SYS_DDR_SDRAM_CFG 0x43000000 #define CONFIG_SYS_DDR_SDRAM_CFG2 0x00401000 #else -#define CONFIG_SYS_DDR_CONFIG (CSCONFIG_EN | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_9) +#define CONFIG_SYS_DDR_CONFIG (CSCONFIG_EN \ + | CSCONFIG_ROW_BIT_13 \ + | CSCONFIG_COL_BIT_9) #define CONFIG_SYS_DDR_TIMING_1 0x37344321 /* tCL-tRCD-tRP-tRAS=2.5-3-3-7 */ #define CONFIG_SYS_DDR_TIMING_2 0x00000800 /* may need tuning */ -#define CONFIG_SYS_DDR_CONTROL 0x42008000 /* Self refresh,2T timing */ -#define CONFIG_SYS_DDR_MODE 0x20000162 /* DLL,normal,seq,4/2.5 */ +#define CONFIG_SYS_DDR_CONTROL 0x42008000 /* Self refresh,2T timing */ +#define CONFIG_SYS_DDR_MODE 0x20000162 /* DLL,normal,seq,4/2.5 */ #define CONFIG_SYS_DDR_INTERVAL 0x045b0100 /* page mode */ #endif #endif @@ -173,8 +176,8 @@ #endif
/* CONFIG_SYS_MONITOR_LEN must be a multiple of CONFIG_ENV_SECT_SIZE */ -#define CONFIG_SYS_MONITOR_LEN (384 * 1024) /* Reserve 384 kB for Mon */ -#define CONFIG_SYS_MALLOC_LEN (128 * 1024) /* Reserved for malloc */ +#define CONFIG_SYS_MONITOR_LEN (384 * 1024) /* Reserve 384 kB for Mon */ +#define CONFIG_SYS_MALLOC_LEN (128 * 1024) /* Reserved for malloc */
/* * Initial RAM Base Address Setup @@ -182,34 +185,42 @@ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
/* * Local Bus Configuration & Clock Setup */ #define CONFIG_SYS_LCRR_DBYP LCRR_DBYP #define CONFIG_SYS_LCRR_CLKDIV LCRR_CLKDIV_4 -#define CONFIG_SYS_LBC_LBCR 0x00000000 +#define CONFIG_SYS_LBC_LBCR 0x00000000
/* * FLASH on the Local Bus */ #define CONFIG_SYS_FLASH_CFI /* use the Common Flash Interface */ -#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ +#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ #define CONFIG_SYS_FLASH_BASE 0xFE000000 /* FLASH base address */ #define CONFIG_SYS_FLASH_SIZE 32 /* max FLASH size is 32M */ -#define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */ -#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ +#define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */ +#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
-#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE /* Window base at flash base */ + /* Window base at flash base */ +#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000018 /* 32MB window size */
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | /* Flash Base address */ \ - (2 << BR_PS_SHIFT) | /* 16 bit port size */ \ - BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) | OR_UPM_XAM | \ - OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | OR_GPCM_XACS | OR_GPCM_SCY_15 | \ - OR_GPCM_TRLX | OR_GPCM_EHTR | OR_GPCM_EAD) +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE \ + | (2 << BR_PS_SHIFT) /* 16 bit port */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) \ + | OR_UPM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX \ + | OR_GPCM_EHTR \ + | OR_GPCM_EAD)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 256 /* max sectors per device */ @@ -219,11 +230,13 @@ /* * BCSR on the Local Bus */ -#define CONFIG_SYS_BCSR 0xF8000000 -#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_BCSR /* Access window base at BCSR base */ +#define CONFIG_SYS_BCSR 0xF8000000 + /* Access window base at BCSR base */ +#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_BCSR #define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000F /* Access window size 64K */
/* @@ -271,8 +284,10 @@
#define CONFIG_SYS_OR2 0xfc006901
-#define CONFIG_SYS_LBC_LSRT 0x32000000 /* LB sdram refresh timer, about 6us */ -#define CONFIG_SYS_LBC_MRTPR 0x20000000 /* LB refresh timer prescal, 266MHz/32 */ + /* LB sdram refresh timer, about 6us */ +#define CONFIG_SYS_LBC_LSRT 0x32000000 + /* LB refresh timer prescal, 266MHz/32 */ +#define CONFIG_SYS_LBC_MRTPR 0x20000000
#define CONFIG_SYS_LBC_LSDMR_COMMON 0x0063b723
@@ -315,7 +330,7 @@ #define CONFIG_SYS_NS16550_CLK get_bus_freq(0)
#define CONFIG_SYS_BAUDRATE_TABLE \ - {300, 600, 1200, 2400, 4800, 9600, 19200, 38400,115200} + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 115200}
#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR+0x4600) @@ -424,11 +439,12 @@
#ifndef CONFIG_SYS_RAMBOOT #define CONFIG_ENV_IS_IN_FLASH 1 - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) + #define CONFIG_ENV_ADDR \ + (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x20000 #define CONFIG_ENV_SIZE 0x2000 #else - #define CONFIG_SYS_NO_FLASH 1 /* Flash is not usable now */ + #define CONFIG_SYS_NO_FLASH 1 /* Flash is not usable now */ #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 @@ -481,17 +497,19 @@ #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #endif
-#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ -#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */ + /* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ + /* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */
/* * For booting Linux, the board info and command line data * have to be in the first 256 MB of memory, since this is * the maximum mapped by the Linux kernel during initialization. */ -#define CONFIG_SYS_BOOTMAPSZ (256 << 20) /* Initial Memory map for Linux */ +#define CONFIG_SYS_BOOTMAPSZ (256 << 20) /* Initial Memory map for Linux */
/* * Core HID Setup @@ -508,54 +526,94 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR/LBC SDRAM: cacheable */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT0L CONFIG_SYS_IBAT0L #define CONFIG_SYS_DBAT0U CONFIG_SYS_IBAT0U
/* IMMRBAR & PCI IO: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_10 | \ - BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT1U (CONFIG_SYS_IMMR | BATU_BL_4M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT1U (CONFIG_SYS_IMMR \ + | BATU_BL_4M \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT1L CONFIG_SYS_IBAT1L #define CONFIG_SYS_DBAT1U CONFIG_SYS_IBAT1U
/* DDR/LBC SDRAM next 256M: cacheable */ -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_SDRAM_BASE2 | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT4U (CONFIG_SYS_SDRAM_BASE2 | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_SDRAM_BASE2 \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT4U (CONFIG_SYS_SDRAM_BASE2 \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT4L CONFIG_SYS_IBAT4L #define CONFIG_SYS_DBAT4U CONFIG_SYS_IBAT4U
#ifdef CONFIG_PCI /* PCI MEM space: cacheable */ -#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI1_MEM_PHYS | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI1_MEM_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI1_MEM_PHYS \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI1_MEM_PHYS \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT6L CONFIG_SYS_IBAT6L #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U /* PCI MMIO space: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI1_MMIO_PHYS | BATL_PP_10 | \ - BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT7U (CONFIG_SYS_PCI1_MMIO_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI1_MMIO_PHYS \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT7U (CONFIG_SYS_PCI1_MMIO_PHYS \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT7L CONFIG_SYS_IBAT7L #define CONFIG_SYS_DBAT7U CONFIG_SYS_IBAT7U #else @@ -593,30 +651,31 @@ #undef CONFIG_BOOTARGS /* the boot command will set bootargs */
#define CONFIG_EXTRA_ENV_SETTINGS \ - "netdev=eth0\0" \ - "consoledev=ttyS0\0" \ - "ramdiskaddr=1000000\0" \ - "ramdiskfile=ramfs.83xx\0" \ - "fdtaddr=780000\0" \ - "fdtfile=mpc836x_mds.dtb\0" \ - "" + "netdev=eth0\0" \ + "consoledev=ttyS0\0" \ + "ramdiskaddr=1000000\0" \ + "ramdiskfile=ramfs.83xx\0" \ + "fdtaddr=780000\0" \ + "fdtfile=mpc836x_mds.dtb\0" \ + ""
#define CONFIG_NFSBOOTCOMMAND \ - "setenv bootargs root=/dev/nfs rw " \ - "nfsroot=$serverip:$rootpath " \ - "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "tftp $loadaddr $bootfile;" \ - "tftp $fdtaddr $fdtfile;" \ - "bootm $loadaddr - $fdtaddr" + "setenv bootargs root=/dev/nfs rw " \ + "nfsroot=$serverip:$rootpath " \ + "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:" \ + "$netdev:off " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr - $fdtaddr"
#define CONFIG_RAMBOOTCOMMAND \ - "setenv bootargs root=/dev/ram rw " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "tftp $ramdiskaddr $ramdiskfile;" \ - "tftp $loadaddr $bootfile;" \ - "tftp $fdtaddr $fdtfile;" \ - "bootm $loadaddr $ramdiskaddr $fdtaddr" + "setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $ramdiskaddr $ramdiskfile;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr"
#define CONFIG_BOOTCOMMAND CONFIG_NFSBOOTCOMMAND
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- include/configs/MPC8360ERDK.h | 282 ++++++++++++++++++++++++---------------- 1 files changed, 169 insertions(+), 113 deletions(-)
diff --git a/include/configs/MPC8360ERDK.h b/include/configs/MPC8360ERDK.h index 851872a..33fb937 100644 --- a/include/configs/MPC8360ERDK.h +++ b/include/configs/MPC8360ERDK.h @@ -85,8 +85,8 @@ #define CONFIG_SYS_DDR_BASE 0x00000000 /* DDR is system memory */ #define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_BASE #define CONFIG_SYS_DDR_SDRAM_BASE CONFIG_SYS_DDR_BASE -#define CONFIG_SYS_DDR_SDRAM_CLK_CNTL (DDR_SDRAM_CLK_CNTL_SS_EN | \ - DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05) +#define CONFIG_SYS_DDR_SDRAM_CLK_CNTL (DDR_SDRAM_CLK_CNTL_SS_EN \ + | DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05)
@@ -106,13 +106,16 @@ #define CONFIG_DDR_II #define CONFIG_SYS_DDR_SIZE 256 /* MB */ #define CONFIG_SYS_DDR_CS0_BNDS 0x0000000f -#define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN | CSCONFIG_ROW_BIT_13 | \ - CSCONFIG_COL_BIT_10 | CSCONFIG_ODT_WR_ACS) -#define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SDRAM_TYPE_DDR2 | SDRAM_CFG_ECC_EN) +#define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN \ + | CSCONFIG_ROW_BIT_13 \ + | CSCONFIG_COL_BIT_10 \ + | CSCONFIG_ODT_WR_ACS) +#define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SDRAM_TYPE_DDR2 \ + | SDRAM_CFG_ECC_EN) #define CONFIG_SYS_DDR_SDRAM_CFG2 0x00001000 -#define CONFIG_SYS_DDR_CLK_CNTL (DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05) -#define CONFIG_SYS_DDR_INTERVAL ((256 << SDRAM_INTERVAL_BSTOPRE_SHIFT) | \ - (1115 << SDRAM_INTERVAL_REFINT_SHIFT)) +#define CONFIG_SYS_DDR_CLK_CNTL (DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05) +#define CONFIG_SYS_DDR_INTERVAL ((256 << SDRAM_INTERVAL_BSTOPRE_SHIFT) \ + | (1115 << SDRAM_INTERVAL_REFINT_SHIFT)) #define CONFIG_SYS_DDR_MODE 0x47800432 #define CONFIG_SYS_DDR_MODE2 0x8000c000
@@ -125,14 +128,14 @@ (0 << TIMING_CFG0_WRT_SHIFT) | \ (0 << TIMING_CFG0_RWT_SHIFT))
-#define CONFIG_SYS_DDR_TIMING_1 (( TIMING_CFG1_CASLAT_30) | \ - ( 2 << TIMING_CFG1_WRTORD_SHIFT) | \ - ( 2 << TIMING_CFG1_ACTTOACT_SHIFT) | \ - ( 3 << TIMING_CFG1_WRREC_SHIFT) | \ +#define CONFIG_SYS_DDR_TIMING_1 ((TIMING_CFG1_CASLAT_30) | \ + (2 << TIMING_CFG1_WRTORD_SHIFT) | \ + (2 << TIMING_CFG1_ACTTOACT_SHIFT) | \ + (3 << TIMING_CFG1_WRREC_SHIFT) | \ (10 << TIMING_CFG1_REFREC_SHIFT) | \ - ( 3 << TIMING_CFG1_ACTTORW_SHIFT) | \ - ( 8 << TIMING_CFG1_ACTTOPRE_SHIFT) | \ - ( 3 << TIMING_CFG1_PRETOACT_SHIFT)) + (3 << TIMING_CFG1_ACTTORW_SHIFT) | \ + (8 << TIMING_CFG1_ACTTOPRE_SHIFT) | \ + (3 << TIMING_CFG1_PRETOACT_SHIFT))
#define CONFIG_SYS_DDR_TIMING_2 ((9 << TIMING_CFG2_FOUR_ACT_SHIFT) | \ (4 << TIMING_CFG2_CKE_PLS_SHIFT) | \ @@ -163,8 +166,8 @@ #undef CONFIG_SYS_RAMBOOT #endif
/* * Initial RAM Base Address Setup @@ -172,33 +175,40 @@ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
/* * FLASH on the Local Bus */ #define CONFIG_SYS_FLASH_CFI /* use the Common Flash Interface */ -#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ +#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ #define CONFIG_SYS_FLASH_SIZE 8 /* max FLASH size is 32M */ #define CONFIG_SYS_FLASH_PROTECTION 1 /* Use intel Flash protection. */
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | /* Flash Base address */ \ - (2 << BR_PS_SHIFT) | /* 16 bit port size */ \ - BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) | OR_UPM_XAM | \ - OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | \ - OR_GPCM_XACS | OR_GPCM_SCY_15 | \ - OR_GPCM_TRLX | OR_GPCM_EHTR | OR_GPCM_EAD) +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE \ + | (2 << BR_PS_SHIFT) /* 16 bit port */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) \ + | OR_UPM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX \ + | OR_GPCM_EHTR \ + | OR_GPCM_EAD)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 256 /* max sectors per device */ @@ -230,8 +240,9 @@ #define CONFIG_SYS_LBLAWAR2_PRELIM 0x80000019 /* Access window size 64MB */
/* Port size 32 bit, UPMB */ -#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_VIDEO_BASE | 0x000018a1) /* PS=11, UPMB */ -#define CONFIG_SYS_OR2_PRELIM 0xfc000001 /* (64MB, EAD=1) */ + /* PS=11, UPMB */ +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_VIDEO_BASE | 0x000018a1) +#define CONFIG_SYS_OR2_PRELIM 0xfc000001 /* (64MB, EAD=1) */
/* * Serial Port @@ -243,13 +254,13 @@ #define CONFIG_SYS_NS16550_CLK get_bus_freq(0)
#define CONFIG_SYS_BAUDRATE_TABLE \ - {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 115200,} + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 115200}
#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ -#define CONFIG_AUTO_COMPLETE /* add autocompletion support */ +#define CONFIG_AUTO_COMPLETE /* add autocompletion support */ /* Use the HUSH parser */ #define CONFIG_SYS_HUSH_PARSER #ifdef CONFIG_SYS_HUSH_PARSER @@ -268,9 +279,9 @@ #define CONFIG_I2C_MULTI_BUS #define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ #define CONFIG_SYS_I2C_SLAVE 0x7F -#define CONFIG_SYS_I2C_NOPROBES {{0x52}} /* Don't probe these addrs */ +#define CONFIG_SYS_I2C_NOPROBES { {0, 0x52} } /* Don't probe these addrs */ #define CONFIG_SYS_I2C_OFFSET 0x3000 -#define CONFIG_SYS_I2C2_OFFSET 0x3100 +#define CONFIG_SYS_I2C2_OFFSET 0x3100
/* * General PCI @@ -284,9 +295,9 @@ #define CONFIG_SYS_PCI1_MMIO_BASE 0x90000000 #define CONFIG_SYS_PCI1_MMIO_PHYS CONFIG_SYS_PCI1_MMIO_BASE #define CONFIG_SYS_PCI1_MMIO_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCI1_IO_BASE 0xE0300000 -#define CONFIG_SYS_PCI1_IO_PHYS 0xE0300000 -#define CONFIG_SYS_PCI1_IO_SIZE 0x100000 /* 1M */ +#define CONFIG_SYS_PCI1_IO_BASE 0xE0300000 +#define CONFIG_SYS_PCI1_IO_PHYS 0xE0300000 +#define CONFIG_SYS_PCI1_IO_SIZE 0x100000 /* 1M */
#ifdef CONFIG_PCI
@@ -318,8 +329,8 @@ #define CONFIG_SYS_UEC1_TX_CLK QE_CLK9 #define CONFIG_SYS_UEC1_ETH_TYPE GIGA_ETH #define CONFIG_SYS_UEC1_PHY_ADDR 2 -#define CONFIG_SYS_UEC1_INTERFACE_TYPE PHY_INTERFACE_MODE_RGMII_RXID -#define CONFIG_SYS_UEC1_INTERFACE_SPEED 1000 +#define CONFIG_SYS_UEC1_INTERFACE_TYPE PHY_INTERFACE_MODE_RGMII_RXID +#define CONFIG_SYS_UEC1_INTERFACE_SPEED 1000 #endif
#define CONFIG_UEC_ETH2 /* GETH2 */ @@ -330,8 +341,8 @@ #define CONFIG_SYS_UEC2_TX_CLK QE_CLK4 #define CONFIG_SYS_UEC2_ETH_TYPE GIGA_ETH #define CONFIG_SYS_UEC2_PHY_ADDR 4 -#define CONFIG_SYS_UEC2_INTERFACE_TYPE PHY_INTERFACE_MODE_RGMII_RXID -#define CONFIG_SYS_UEC2_INTERFACE_SPEED 1000 +#define CONFIG_SYS_UEC2_INTERFACE_TYPE PHY_INTERFACE_MODE_RGMII_RXID +#define CONFIG_SYS_UEC2_INTERFACE_SPEED 1000 #endif
/* @@ -340,11 +351,11 @@
#ifndef CONFIG_SYS_RAMBOOT #define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) +#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K(one sector) for env */ #define CONFIG_ENV_SIZE 0x20000 #else /* CONFIG_SYS_RAMBOOT */ -#define CONFIG_SYS_NO_FLASH 1 /* Flash is not usable now */ +#define CONFIG_SYS_NO_FLASH 1 /* Flash is not usable now */ #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 @@ -396,17 +407,19 @@ #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #endif
/* * Core HID Setup @@ -423,54 +436,95 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR: cache cacheable */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT0L CONFIG_SYS_IBAT0L #define CONFIG_SYS_DBAT0U CONFIG_SYS_IBAT0U
/* NAND: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_NAND_BASE | BATL_PP_10 | BATL_CACHEINHIBIT |\ - BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT2U (CONFIG_SYS_NAND_BASE | BATU_BL_64M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_NAND_BASE \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT2U (CONFIG_SYS_NAND_BASE \ + | BATU_BL_64M \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT2L CONFIG_SYS_IBAT2L #define CONFIG_SYS_DBAT2U CONFIG_SYS_IBAT2U
/* FLASH: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT3U (CONFIG_SYS_FLASH_BASE | BATU_BL_32M | BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT3L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ - BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_FLASH_BASE \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT3U (CONFIG_SYS_FLASH_BASE \ + | BATU_BL_32M \ + | BATU_VS \ + | BATU_VP) +#define CONFIG_SYS_DBAT3L (CONFIG_SYS_FLASH_BASE \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT3U CONFIG_SYS_IBAT3U
/* Stack in dcache: cacheable, no memory coherence */ -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10) -#define CONFIG_SYS_IBAT4U (CONFIG_SYS_INIT_RAM_ADDR | BATU_BL_128K | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_INIT_RAM_ADDR \ + | BATL_PP_10) +#define CONFIG_SYS_IBAT4U (CONFIG_SYS_INIT_RAM_ADDR \ + | BATU_BL_128K \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT4L CONFIG_SYS_IBAT4L #define CONFIG_SYS_DBAT4U CONFIG_SYS_IBAT4U
-#define CONFIG_SYS_IBAT5L (CONFIG_SYS_VIDEO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | \ - BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT5U (CONFIG_SYS_VIDEO_BASE | BATU_BL_64M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_VIDEO_BASE \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT5U (CONFIG_SYS_VIDEO_BASE \ + | BATU_BL_64M \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT5L CONFIG_SYS_IBAT5L #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U
#ifdef CONFIG_PCI /* PCI MEM space: cacheable */ -#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI1_MEM_PHYS | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI1_MEM_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI1_MEM_PHYS \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI1_MEM_PHYS \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT6L CONFIG_SYS_IBAT6L #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U /* PCI MMIO space: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI1_MMIO_PHYS | BATL_PP_10 | \ - BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT7U (CONFIG_SYS_PCI1_MMIO_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI1_MMIO_PHYS \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT7U (CONFIG_SYS_PCI1_MMIO_PHYS \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT7L CONFIG_SYS_IBAT7L #define CONFIG_SYS_DBAT7U CONFIG_SYS_IBAT7U #else /* CONFIG_PCI */ @@ -513,49 +567,51 @@ #undef CONFIG_BOOTARGS /* the boot command will set bootargs */
#define CONFIG_EXTRA_ENV_SETTINGS \ - "netdev=eth0\0"\ - "consoledev=ttyS0\0"\ - "loadaddr=a00000\0"\ - "fdtaddr=900000\0"\ - "fdtfile=mpc836x_rdk.dtb\0"\ - "fsfile=fs\0"\ - "ubootfile=u-boot.bin\0"\ - "mtdparts=mtdparts=60000000.nand-flash:4096k(kernel),128k(dtb),-(rootfs)\0"\ - "setbootargs=setenv bootargs console=$consoledev,$baudrate "\ - "$mtdparts panic=1\0"\ - "adddhcpargs=setenv bootargs $bootargs ip=on\0"\ - "addnfsargs=setenv bootargs $bootargs ip=$ipaddr:$serverip:"\ - "$gatewayip:$netmask:$hostname:$netdev:off "\ - "root=/dev/nfs rw nfsroot=$serverip:$rootpath\0"\ - "addnandargs=setenv bootargs $bootargs root=/dev/mtdblock3 "\ - "rootfstype=jffs2 rw\0"\ - "tftp_get_uboot=tftp 100000 $ubootfile\0"\ - "tftp_get_kernel=tftp $loadaddr $bootfile\0"\ - "tftp_get_dtb=tftp $fdtaddr $fdtfile\0"\ - "tftp_get_fs=tftp c00000 $fsfile\0"\ - "nand_erase_kernel=nand erase 0 400000\0"\ - "nand_erase_dtb=nand erase 400000 20000\0"\ - "nand_erase_fs=nand erase 420000 3be0000\0"\ - "nand_write_kernel=nand write.jffs2 $loadaddr 0 400000\0"\ - "nand_write_dtb=nand write.jffs2 $fdtaddr 400000 20000\0"\ - "nand_write_fs=nand write.jffs2 c00000 420000 $filesize\0"\ - "nand_read_kernel=nand read.jffs2 $loadaddr 0 400000\0"\ - "nand_read_dtb=nand read.jffs2 $fdtaddr 400000 20000\0"\ - "nor_reflash=protect off ff800000 ff87ffff ; erase ff800000 ff87ffff ; "\ - "cp.b 100000 ff800000 $filesize\0"\ - "nand_reflash_kernel=run tftp_get_kernel nand_erase_kernel "\ - "nand_write_kernel\0"\ - "nand_reflash_dtb=run tftp_get_dtb nand_erase_dtb nand_write_dtb\0"\ - "nand_reflash_fs=run tftp_get_fs nand_erase_fs nand_write_fs\0"\ - "nand_reflash=run nand_reflash_kernel nand_reflash_dtb "\ - "nand_reflash_fs\0"\ - "boot_m=bootm $loadaddr - $fdtaddr\0"\ - "dhcpboot=dhcp ; run setbootargs adddhcpargs tftp_get_dtb boot_m\0"\ - "nfsboot=run setbootargs addnfsargs tftp_get_kernel tftp_get_dtb "\ - "boot_m\0"\ - "nandboot=run setbootargs addnandargs nand_read_kernel nand_read_dtb "\ - "boot_m\0"\ - "" + "netdev=eth0\0" \ + "consoledev=ttyS0\0" \ + "loadaddr=a00000\0" \ + "fdtaddr=900000\0" \ + "fdtfile=mpc836x_rdk.dtb\0" \ + "fsfile=fs\0" \ + "ubootfile=u-boot.bin\0" \ + "mtdparts=mtdparts=60000000.nand-flash:4096k(kernel),128k(dtb),"\ + "-(rootfs)\0" \ + "setbootargs=setenv bootargs console=$consoledev,$baudrate " \ + "$mtdparts panic=1\0" \ + "adddhcpargs=setenv bootargs $bootargs ip=on\0" \ + "addnfsargs=setenv bootargs $bootargs ip=$ipaddr:$serverip:" \ + "$gatewayip:$netmask:$hostname:$netdev:off " \ + "root=/dev/nfs rw nfsroot=$serverip:$rootpath\0" \ + "addnandargs=setenv bootargs $bootargs root=/dev/mtdblock3 " \ + "rootfstype=jffs2 rw\0" \ + "tftp_get_uboot=tftp 100000 $ubootfile\0" \ + "tftp_get_kernel=tftp $loadaddr $bootfile\0" \ + "tftp_get_dtb=tftp $fdtaddr $fdtfile\0" \ + "tftp_get_fs=tftp c00000 $fsfile\0" \ + "nand_erase_kernel=nand erase 0 400000\0" \ + "nand_erase_dtb=nand erase 400000 20000\0" \ + "nand_erase_fs=nand erase 420000 3be0000\0" \ + "nand_write_kernel=nand write.jffs2 $loadaddr 0 400000\0" \ + "nand_write_dtb=nand write.jffs2 $fdtaddr 400000 20000\0" \ + "nand_write_fs=nand write.jffs2 c00000 420000 $filesize\0" \ + "nand_read_kernel=nand read.jffs2 $loadaddr 0 400000\0" \ + "nand_read_dtb=nand read.jffs2 $fdtaddr 400000 20000\0" \ + "nor_reflash=protect off ff800000 ff87ffff ; " \ + "erase ff800000 ff87ffff ; " \ + "cp.b 100000 ff800000 $filesize\0" \ + "nand_reflash_kernel=run tftp_get_kernel nand_erase_kernel " \ + "nand_write_kernel\0" \ + "nand_reflash_dtb=run tftp_get_dtb nand_erase_dtb nand_write_dtb\0"\ + "nand_reflash_fs=run tftp_get_fs nand_erase_fs nand_write_fs\0" \ + "nand_reflash=run nand_reflash_kernel nand_reflash_dtb " \ + "nand_reflash_fs\0" \ + "boot_m=bootm $loadaddr - $fdtaddr\0" \ + "dhcpboot=dhcp ; run setbootargs adddhcpargs tftp_get_dtb boot_m\0"\ + "nfsboot=run setbootargs addnfsargs tftp_get_kernel tftp_get_dtb "\ + "boot_m\0" \ + "nandboot=run setbootargs addnandargs nand_read_kernel nand_read_dtb "\ + "boot_m\0" \ + ""
#define CONFIG_BOOTCOMMAND "run dhcpboot"
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- include/configs/MPC837XEMDS.h | 283 ++++++++++++++++++++++++----------------- 1 files changed, 166 insertions(+), 117 deletions(-)
diff --git a/include/configs/MPC837XEMDS.h b/include/configs/MPC837XEMDS.h index abccfd6..6a6621f 100644 --- a/include/configs/MPC837XEMDS.h +++ b/include/configs/MPC837XEMDS.h @@ -88,17 +88,17 @@
/* Arbiter Configuration Register */ #define CONFIG_SYS_ACR_PIPE_DEP 3 /* Arbiter pipeline depth is 4 */ -#define CONFIG_SYS_ACR_RPTCNT 3 /* Arbiter repeat count is 4 */ +#define CONFIG_SYS_ACR_RPTCNT 3 /* Arbiter repeat count is 4 */
/* System Priority Control Register */ -#define CONFIG_SYS_SPCR_TSECEP 3 /* eTSEC1/2 emergency has highest priority */ +#define CONFIG_SYS_SPCR_TSECEP 3 /* eTSEC1/2 emergency has highest priority */
/* * IP blocks clock configuration */ #define CONFIG_SYS_SCCR_TSEC1CM 1 /* CSB:eTSEC1 = 1:1 */ #define CONFIG_SYS_SCCR_TSEC2CM 1 /* CSB:eTSEC2 = 1:1 */ -#define CONFIG_SYS_SCCR_SATACM SCCR_SATACM_2 /* CSB:SATA[0:3] = 2:1 */ +#define CONFIG_SYS_SCCR_SATACM SCCR_SATACM_2 /* CSB:SATA[0:3] = 2:1 */
/* * System IO Config @@ -146,46 +146,47 @@ */ #define CONFIG_SYS_DDR_SIZE 512 /* MB */ #define CONFIG_SYS_DDR_CS0_BNDS 0x0000001f -#define CONFIG_SYS_DDR_CS0_CONFIG ( CSCONFIG_EN \ +#define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN \ | 0x00010000 /* ODT_WR to CSn */ \ - | CSCONFIG_ROW_BIT_14 | CSCONFIG_COL_BIT_10 ) + | CSCONFIG_ROW_BIT_14 \ + | CSCONFIG_COL_BIT_10) /* 0x80010202 */ #define CONFIG_SYS_DDR_TIMING_3 0x00000000 -#define CONFIG_SYS_DDR_TIMING_0 ( ( 0 << TIMING_CFG0_RWT_SHIFT ) \ - | ( 0 << TIMING_CFG0_WRT_SHIFT ) \ - | ( 0 << TIMING_CFG0_RRT_SHIFT ) \ - | ( 0 << TIMING_CFG0_WWT_SHIFT ) \ - | ( 6 << TIMING_CFG0_ACT_PD_EXIT_SHIFT ) \ - | ( 2 << TIMING_CFG0_PRE_PD_EXIT_SHIFT ) \ - | ( 8 << TIMING_CFG0_ODT_PD_EXIT_SHIFT ) \ - | ( 2 << TIMING_CFG0_MRS_CYC_SHIFT ) ) +#define CONFIG_SYS_DDR_TIMING_0 ((0 << TIMING_CFG0_RWT_SHIFT) \ + | (0 << TIMING_CFG0_WRT_SHIFT) \ + | (0 << TIMING_CFG0_RRT_SHIFT) \ + | (0 << TIMING_CFG0_WWT_SHIFT) \ + | (6 << TIMING_CFG0_ACT_PD_EXIT_SHIFT) \ + | (2 << TIMING_CFG0_PRE_PD_EXIT_SHIFT) \ + | (8 << TIMING_CFG0_ODT_PD_EXIT_SHIFT) \ + | (2 << TIMING_CFG0_MRS_CYC_SHIFT)) /* 0x00620802 */ -#define CONFIG_SYS_DDR_TIMING_1 ( ( 3 << TIMING_CFG1_PRETOACT_SHIFT ) \ - | ( 9 << TIMING_CFG1_ACTTOPRE_SHIFT ) \ - | ( 3 << TIMING_CFG1_ACTTORW_SHIFT ) \ - | ( 5 << TIMING_CFG1_CASLAT_SHIFT ) \ - | (13 << TIMING_CFG1_REFREC_SHIFT ) \ - | ( 3 << TIMING_CFG1_WRREC_SHIFT ) \ - | ( 2 << TIMING_CFG1_ACTTOACT_SHIFT ) \ - | ( 2 << TIMING_CFG1_WRTORD_SHIFT ) ) +#define CONFIG_SYS_DDR_TIMING_1 ((3 << TIMING_CFG1_PRETOACT_SHIFT) \ + | (9 << TIMING_CFG1_ACTTOPRE_SHIFT) \ + | (3 << TIMING_CFG1_ACTTORW_SHIFT) \ + | (5 << TIMING_CFG1_CASLAT_SHIFT) \ + | (13 << TIMING_CFG1_REFREC_SHIFT) \ + | (3 << TIMING_CFG1_WRREC_SHIFT) \ + | (2 << TIMING_CFG1_ACTTOACT_SHIFT) \ + | (2 << TIMING_CFG1_WRTORD_SHIFT)) /* 0x3935d322 */ -#define CONFIG_SYS_DDR_TIMING_2 ( ( 1 << TIMING_CFG2_ADD_LAT_SHIFT ) \ - | ( 6 << TIMING_CFG2_CPO_SHIFT ) \ - | ( 2 << TIMING_CFG2_WR_LAT_DELAY_SHIFT ) \ - | ( 4 << TIMING_CFG2_RD_TO_PRE_SHIFT ) \ - | ( 2 << TIMING_CFG2_WR_DATA_DELAY_SHIFT ) \ - | ( 3 << TIMING_CFG2_CKE_PLS_SHIFT ) \ - | ( 8 << TIMING_CFG2_FOUR_ACT_SHIFT) ) +#define CONFIG_SYS_DDR_TIMING_2 ((1 << TIMING_CFG2_ADD_LAT_SHIFT) \ + | (6 << TIMING_CFG2_CPO_SHIFT) \ + | (2 << TIMING_CFG2_WR_LAT_DELAY_SHIFT) \ + | (4 << TIMING_CFG2_RD_TO_PRE_SHIFT) \ + | (2 << TIMING_CFG2_WR_DATA_DELAY_SHIFT) \ + | (3 << TIMING_CFG2_CKE_PLS_SHIFT) \ + | (8 << TIMING_CFG2_FOUR_ACT_SHIFT)) /* 0x131088c8 */ -#define CONFIG_SYS_DDR_INTERVAL ( ( 0x03E0 << SDRAM_INTERVAL_REFINT_SHIFT ) \ - | ( 0x0100 << SDRAM_INTERVAL_BSTOPRE_SHIFT ) ) +#define CONFIG_SYS_DDR_INTERVAL ((0x03E0 << SDRAM_INTERVAL_REFINT_SHIFT) \ + | (0x0100 << SDRAM_INTERVAL_BSTOPRE_SHIFT)) /* 0x03E00100 */ #define CONFIG_SYS_DDR_SDRAM_CFG 0x43000000 #define CONFIG_SYS_DDR_SDRAM_CFG2 0x00001000 /* 1 posted refresh */ -#define CONFIG_SYS_DDR_MODE ( ( 0x0448 << SDRAM_MODE_ESD_SHIFT ) \ - | ( 0x1432 << SDRAM_MODE_SD_SHIFT ) ) +#define CONFIG_SYS_DDR_MODE ((0x0448 << SDRAM_MODE_ESD_SHIFT) \ + | (0x1432 << SDRAM_MODE_SD_SHIFT)) /* ODT 150ohm CL=3, AL=1 on SDRAM */ -#define CONFIG_SYS_DDR_MODE2 0x00000000 +#define CONFIG_SYS_DDR_MODE2 0x00000000 #endif
/* @@ -207,8 +208,8 @@ #endif
/* CONFIG_SYS_MONITOR_LEN must be a multiple of CONFIG_ENV_SECT_SIZE */ -#define CONFIG_SYS_MONITOR_LEN (384 * 1024) /* Reserve 384 kB for Mon */ -#define CONFIG_SYS_MALLOC_LEN (512 * 1024) /* Reserved for malloc */ +#define CONFIG_SYS_MONITOR_LEN (384 * 1024) /* Reserve 384 kB for Mon */ +#define CONFIG_SYS_MALLOC_LEN (512 * 1024) /* Reserved for malloc */
/* * Initial RAM Base Address Setup @@ -216,7 +217,8 @@ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
/* * Local Bus Configuration & Clock Setup @@ -229,19 +231,20 @@ /* * FLASH on the Local Bus */ -#define CONFIG_SYS_FLASH_CFI /* use the Common Flash Interface */ +#define CONFIG_SYS_FLASH_CFI /* use the Common Flash Interface */ #define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ -#define CONFIG_SYS_FLASH_BASE 0xFE000000 /* FLASH base address */ -#define CONFIG_SYS_FLASH_SIZE 32 /* max FLASH size is 32M */ -#define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */ +#define CONFIG_SYS_FLASH_BASE 0xFE000000 /* FLASH base address */ +#define CONFIG_SYS_FLASH_SIZE 32 /* max FLASH size is 32M */ +#define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */
-#define CONFIG_SYS_BR0_PRELIM ( CONFIG_SYS_FLASH_BASE /* Flash Base address */ \ - | (2 << BR_PS_SHIFT) /* 16 bit port size */ \ - | BR_V ) /* valid */ -#define CONFIG_SYS_OR0_PRELIM ( (~(CONFIG_SYS_FLASH_SIZE - 1) << 20) \ +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE \ + | (2 << BR_PS_SHIFT) /* 16 bit port */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) \ | OR_UPM_XAM \ | OR_GPCM_CSNT \ | OR_GPCM_ACS_DIV2 \ @@ -249,7 +252,7 @@ | OR_GPCM_SCY_15 \ | OR_GPCM_TRLX \ | OR_GPCM_EHTR \ - | OR_GPCM_EAD ) + | OR_GPCM_EAD) /* 0xFE000FF7 */
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ @@ -263,11 +266,13 @@ * BCSR on the Local Bus */ #define CONFIG_SYS_BCSR 0xF8000000 -#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_BCSR /* Access window base at BCSR base */ + /* Access window base at BCSR base */ +#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_BCSR #define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000E /* Access window size 32K */
-#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR | 0x00000801) /* Port size=8bit, MSEL=GPCM */ -#define CONFIG_SYS_OR1_PRELIM 0xFFFFE9f7 /* length 32K */ + /* Port size=8bit, MSEL=GPCM */ +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR | 0x00000801) +#define CONFIG_SYS_OR1_PRELIM 0xFFFFE9f7 /* length 32K */
/* * NAND Flash on the Local Bus @@ -275,22 +280,22 @@ #define CONFIG_CMD_NAND 1 #define CONFIG_MTD_NAND_VERIFY_WRITE 1 #define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_NAND_FSL_ELBC 1 +#define CONFIG_NAND_FSL_ELBC 1
-#define CONFIG_SYS_NAND_BASE 0xE0600000 /* 0xE0600000 */ -#define CONFIG_SYS_BR3_PRELIM ( CONFIG_SYS_NAND_BASE \ +#define CONFIG_SYS_NAND_BASE 0xE0600000 /* 0xE0600000 */ +#define CONFIG_SYS_BR3_PRELIM (CONFIG_SYS_NAND_BASE \ | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ - | BR_PS_8 /* Port Size = 8 bit */ \ + | BR_PS_8 /* 8 bit port */ \ | BR_MS_FCM /* MSEL = FCM */ \ - | BR_V ) /* valid */ -#define CONFIG_SYS_OR3_PRELIM ( 0xFFFF8000 /* length 32K */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR3_PRELIM (0xFFFF8000 /* length 32K */ \ | OR_FCM_BCTLD \ | OR_FCM_CST \ | OR_FCM_CHT \ | OR_FCM_SCY_1 \ | OR_FCM_RST \ | OR_FCM_TRLX \ - | OR_FCM_EHTR ) + | OR_FCM_EHTR) /* 0xFFFF919E */
#define CONFIG_SYS_LBLAWBAR3_PRELIM CONFIG_SYS_NAND_BASE @@ -306,7 +311,7 @@ #define CONFIG_SYS_NS16550_CLK get_bus_freq(0)
#define CONFIG_SYS_BAUDRATE_TABLE \ - {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200} + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 57600, 115200}
#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR+0x4600) @@ -326,11 +331,11 @@ #define CONFIG_HARD_I2C /* I2C with hardware support */ #undef CONFIG_SOFT_I2C /* I2C bit-banged */ #define CONFIG_FSL_I2C -#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ -#define CONFIG_SYS_I2C_SLAVE 0x7F +#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_I2C_SLAVE 0x7F #define CONFIG_SYS_I2C_NOPROBES {0x51} /* Don't probe these addrs */ -#define CONFIG_SYS_I2C_OFFSET 0x3000 -#define CONFIG_SYS_I2C2_OFFSET 0x3100 +#define CONFIG_SYS_I2C_OFFSET 0x3000 +#define CONFIG_SYS_I2C2_OFFSET 0x3100
/* * Config on-board RTC @@ -342,9 +347,9 @@ * General PCI * Addresses are mapped 1-1. */ -#define CONFIG_SYS_PCI_MEM_BASE 0x80000000 -#define CONFIG_SYS_PCI_MEM_PHYS CONFIG_SYS_PCI_MEM_BASE -#define CONFIG_SYS_PCI_MEM_SIZE 0x10000000 /* 256M */ +#define CONFIG_SYS_PCI_MEM_BASE 0x80000000 +#define CONFIG_SYS_PCI_MEM_PHYS CONFIG_SYS_PCI_MEM_BASE +#define CONFIG_SYS_PCI_MEM_SIZE 0x10000000 /* 256M */ #define CONFIG_SYS_PCI_MMIO_BASE 0x90000000 #define CONFIG_SYS_PCI_MMIO_PHYS CONFIG_SYS_PCI_MMIO_BASE #define CONFIG_SYS_PCI_MMIO_SIZE 0x10000000 /* 256M */ @@ -402,9 +407,9 @@ extern int board_pci_host_broken(void); */ #define CONFIG_TSEC_ENET /* TSEC ethernet support */ #define CONFIG_SYS_TSEC1_OFFSET 0x24000 -#define CONFIG_SYS_TSEC1 (CONFIG_SYS_IMMR+CONFIG_SYS_TSEC1_OFFSET) +#define CONFIG_SYS_TSEC1 (CONFIG_SYS_IMMR+CONFIG_SYS_TSEC1_OFFSET) #define CONFIG_SYS_TSEC2_OFFSET 0x25000 -#define CONFIG_SYS_TSEC2 (CONFIG_SYS_IMMR+CONFIG_SYS_TSEC2_OFFSET) +#define CONFIG_SYS_TSEC2 (CONFIG_SYS_IMMR+CONFIG_SYS_TSEC2_OFFSET)
/* * TSEC ethernet configuration @@ -440,12 +445,12 @@ extern int board_pci_host_broken(void); #define CONFIG_SYS_SATA_MAX_DEVICE 2 #define CONFIG_SATA1 #define CONFIG_SYS_SATA1_OFFSET 0x18000 -#define CONFIG_SYS_SATA1 (CONFIG_SYS_IMMR + CONFIG_SYS_SATA1_OFFSET) -#define CONFIG_SYS_SATA1_FLAGS FLAGS_DMA +#define CONFIG_SYS_SATA1 (CONFIG_SYS_IMMR + CONFIG_SYS_SATA1_OFFSET) +#define CONFIG_SYS_SATA1_FLAGS FLAGS_DMA #define CONFIG_SATA2 #define CONFIG_SYS_SATA2_OFFSET 0x19000 -#define CONFIG_SYS_SATA2 (CONFIG_SYS_IMMR + CONFIG_SYS_SATA2_OFFSET) -#define CONFIG_SYS_SATA2_FLAGS FLAGS_DMA +#define CONFIG_SYS_SATA2 (CONFIG_SYS_IMMR + CONFIG_SYS_SATA2_OFFSET) +#define CONFIG_SYS_SATA2_FLAGS FLAGS_DMA
#ifdef CONFIG_FSL_SATA #define CONFIG_LBA48 @@ -459,11 +464,12 @@ extern int board_pci_host_broken(void); */ #ifndef CONFIG_SYS_RAMBOOT #define CONFIG_ENV_IS_IN_FLASH 1 - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) + #define CONFIG_ENV_ADDR \ + (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K(one sector) for env */ #define CONFIG_ENV_SIZE 0x2000 #else - #define CONFIG_SYS_NO_FLASH 1 /* Flash is not usable now */ + #define CONFIG_SYS_NO_FLASH 1 /* Flash is not usable now */ #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 @@ -531,17 +537,19 @@ extern int board_pci_host_broken(void); #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #endif
/* * Core HID Setup @@ -560,53 +568,93 @@ extern int board_pci_host_broken(void); #define CONFIG_SYS_SDRAM_LOWER CONFIG_SYS_SDRAM_BASE #define CONFIG_SYS_SDRAM_UPPER (CONFIG_SYS_SDRAM_BASE + 0x10000000)
-#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_LOWER | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_LOWER | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_LOWER \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_LOWER \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT0L CONFIG_SYS_IBAT0L #define CONFIG_SYS_DBAT0U CONFIG_SYS_IBAT0U
-#define CONFIG_SYS_IBAT1L (CONFIG_SYS_SDRAM_UPPER | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT1U (CONFIG_SYS_SDRAM_UPPER | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_SDRAM_UPPER \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT1U (CONFIG_SYS_SDRAM_UPPER \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT1L CONFIG_SYS_IBAT1L #define CONFIG_SYS_DBAT1U CONFIG_SYS_IBAT1U
/* IMMRBAR, PCI IO and NAND: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_IMMR | BATL_PP_10 | \ - BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT2U (CONFIG_SYS_IMMR | BATU_BL_8M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_IMMR \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT2U (CONFIG_SYS_IMMR \ + | BATU_BL_8M \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT2L CONFIG_SYS_IBAT2L #define CONFIG_SYS_DBAT2U CONFIG_SYS_IBAT2U
/* BCSR: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_BCSR | BATL_PP_10 | \ - BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT3U (CONFIG_SYS_BCSR | BATU_BL_128K | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_BCSR \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT3U (CONFIG_SYS_BCSR \ + | BATU_BL_128K \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT3L CONFIG_SYS_IBAT3L #define CONFIG_SYS_DBAT3U CONFIG_SYS_IBAT3U
/* FLASH: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT4U (CONFIG_SYS_FLASH_BASE | BATU_BL_32M | BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT4L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ - BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_FLASH_BASE \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT4U (CONFIG_SYS_FLASH_BASE \ + | BATU_BL_32M \ + | BATU_VS \ + | BATU_VP) +#define CONFIG_SYS_DBAT4L (CONFIG_SYS_FLASH_BASE \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT4U CONFIG_SYS_IBAT4U
/* Stack in dcache: cacheable, no memory coherence */ #define CONFIG_SYS_IBAT5L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10) -#define CONFIG_SYS_IBAT5U (CONFIG_SYS_INIT_RAM_ADDR | BATU_BL_128K | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT5U (CONFIG_SYS_INIT_RAM_ADDR \ + | BATU_BL_128K \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT5L CONFIG_SYS_IBAT5L #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U
#ifdef CONFIG_PCI /* PCI MEM space: cacheable */ -#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI_MEM_PHYS | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI_MEM_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI_MEM_PHYS \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI_MEM_PHYS \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT6L CONFIG_SYS_IBAT6L #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U /* PCI MMIO space: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI_MMIO_PHYS | BATL_PP_10 | \ - BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT7U (CONFIG_SYS_PCI_MMIO_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI_MMIO_PHYS \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT7U (CONFIG_SYS_PCI_MMIO_PHYS \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT7L CONFIG_SYS_IBAT7L #define CONFIG_SYS_DBAT7U CONFIG_SYS_IBAT7U #else @@ -644,30 +692,31 @@ extern int board_pci_host_broken(void); #undef CONFIG_BOOTARGS /* the boot command will set bootargs */
#define CONFIG_EXTRA_ENV_SETTINGS \ - "netdev=eth0\0" \ - "consoledev=ttyS0\0" \ - "ramdiskaddr=1000000\0" \ - "ramdiskfile=ramfs.83xx\0" \ - "fdtaddr=780000\0" \ - "fdtfile=mpc8379_mds.dtb\0" \ - "" + "netdev=eth0\0" \ + "consoledev=ttyS0\0" \ + "ramdiskaddr=1000000\0" \ + "ramdiskfile=ramfs.83xx\0" \ + "fdtaddr=780000\0" \ + "fdtfile=mpc8379_mds.dtb\0" \ + ""
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- include/configs/MPC837XERDB.h | 249 ++++++++++++++++++++++++---------------- 1 files changed, 149 insertions(+), 100 deletions(-)
diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index ea3056b..405589d 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -103,15 +103,15 @@
/* Arbiter Configuration Register */ #define CONFIG_SYS_ACR_PIPE_DEP 3 /* Arbiter pipeline depth (0-3) */ -#define CONFIG_SYS_ACR_RPTCNT 3 /* Arbiter repeat count (0-7) */ +#define CONFIG_SYS_ACR_RPTCNT 3 /* Arbiter repeat count (0-7) */
/* System Priority Control Regsiter */ -#define CONFIG_SYS_SPCR_TSECEP 3 /* eTSEC1&2 emergency priority (0-3) */ +#define CONFIG_SYS_SPCR_TSECEP 3 /* eTSEC1&2 emergency priority (0-3) */
/* System Clock Configuration Register */ #define CONFIG_SYS_SCCR_TSEC1CM 1 /* eTSEC1 clock mode (0-3) */ #define CONFIG_SYS_SCCR_TSEC2CM 1 /* eTSEC2 clock mode (0-3) */ -#define CONFIG_SYS_SCCR_SATACM SCCR_SATACM_2 /* SATA1-4 clock mode (0-3) */ +#define CONFIG_SYS_SCCR_SATACM SCCR_SATACM_2 /* SATA1-4 clock mode (0-3) */
/* * System IO Config @@ -197,19 +197,19 @@ /* 0x06090100 */
#if defined(CONFIG_DDR_2T_TIMING) -#define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SREN \ - | 3 << SDRAM_CFG_SDRAM_TYPE_SHIFT \ - | SDRAM_CFG_2T_EN \ - | SDRAM_CFG_DBW_32) +#define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SREN \ + | 3 << SDRAM_CFG_SDRAM_TYPE_SHIFT \ + | SDRAM_CFG_2T_EN \ + | SDRAM_CFG_DBW_32) #else -#define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SREN \ - | 3 << SDRAM_CFG_SDRAM_TYPE_SHIFT) - /* 0x43000000 */ +#define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SREN \ + | 3 << SDRAM_CFG_SDRAM_TYPE_SHIFT) + /* 0x43000000 */ #endif #define CONFIG_SYS_DDR_SDRAM_CFG2 0x00001000 /* 1 posted refresh */ #define CONFIG_SYS_DDR_MODE ((0x0406 << SDRAM_MODE_ESD_SHIFT) \ - | (0x0442 << SDRAM_MODE_SD_SHIFT)) - /* 0x04400442 */ /* DDR400 */ + | (0x0442 << SDRAM_MODE_SD_SHIFT)) + /* 0x04400442 */ /* DDR400 */ #define CONFIG_SYS_DDR_MODE2 0x00000000
/* @@ -230,8 +230,8 @@ #undef CONFIG_SYS_RAMBOOT #endif
/* * Initial RAM Base Address Setup @@ -239,7 +239,8 @@ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ #define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
/* * Local Bus Configuration & Clock Setup @@ -257,17 +258,18 @@ #define CONFIG_SYS_FLASH_BASE 0xFE000000 /* FLASH base address */ #define CONFIG_SYS_FLASH_SIZE 8 /* max FLASH size is 32M */
-#define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */ -#define CONFIG_SYS_FLASH_EMPTY_INFO /* display empty sectors */ -#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE /* buffer up multiple bytes */ +#define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */ +#define CONFIG_SYS_FLASH_EMPTY_INFO /* display empty sectors */ +#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE /* buffer up multiple bytes */
-#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE /* Window base at flash base */ + /* Window base at flash base */ +#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000016 /* 8 MB window size */
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | /* Flash Base address */ \ - (2 << BR_PS_SHIFT) | /* 16 bit port size */ \ - BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM (0xFF800000 /* 8 MByte */ \ +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE \ + | (2 << BR_PS_SHIFT) /* 16 bit port */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR0_PRELIM (0xFF800000 /* 8 MByte */ \ | OR_GPCM_XACS \ | OR_GPCM_SCY_9 \ | OR_GPCM_EHTR \ @@ -284,19 +286,19 @@ /* * NAND Flash on the Local Bus */ -#define CONFIG_SYS_NAND_BASE 0xE0600000 /* 0xE0600000 */ -#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_NAND_BASE | \ - (2 << BR_DECC_SHIFT) | /* Use HW ECC */ \ - BR_PS_8 | /* Port Size = 8 bit */ \ - BR_MS_FCM | /* MSEL = FCM */ \ - BR_V) /* valid */ -#define CONFIG_SYS_OR1_PRELIM (0xFFFF8000 | /* length 32K */ \ - OR_FCM_CSCT | \ - OR_FCM_CST | \ - OR_FCM_CHT | \ - OR_FCM_SCY_1 | \ - OR_FCM_TRLX | \ - OR_FCM_EHTR) +#define CONFIG_SYS_NAND_BASE 0xE0600000 /* 0xE0600000 */ +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_NAND_BASE \ + | (2 << BR_DECC_SHIFT) /* Use HW ECC */ \ + | BR_PS_8 | /* 8 bit Port */ \ + | BR_MS_FCM | /* MSEL = FCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR1_PRELIM (0xFFFF8000 /* length 32K */ \ + | OR_FCM_CSCT \ + | OR_FCM_CST \ + | OR_FCM_CHT \ + | OR_FCM_SCY_1 \ + | OR_FCM_TRLX \ + | OR_FCM_EHTR) #define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_NAND_BASE #define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000E /* 32KB */
@@ -306,10 +308,11 @@
#ifdef CONFIG_VSC7385_ENET
-#define CONFIG_SYS_BR2_PRELIM 0xf0000801 /* Base address */ -#define CONFIG_SYS_OR2_PRELIM 0xfffe09ff /* 128K bytes*/ -#define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_VSC7385_BASE /* Access Base */ -#define CONFIG_SYS_LBLAWAR2_PRELIM 0x80000010 /* Access Size 128K */ +#define CONFIG_SYS_BR2_PRELIM 0xf0000801 /* Base address */ +#define CONFIG_SYS_OR2_PRELIM 0xfffe09ff /* 128K bytes*/ + /* Access Base */ +#define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_VSC7385_BASE +#define CONFIG_SYS_LBLAWAR2_PRELIM 0x80000010 /* Access Size 128K */
#endif
@@ -323,7 +326,7 @@ #define CONFIG_SYS_NS16550_CLK get_bus_freq(0)
#define CONFIG_SYS_BAUDRATE_TABLE \ - {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 115200} + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 115200}
#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR+0x4600) @@ -348,11 +351,11 @@ #define CONFIG_HARD_I2C /* I2C with hardware support */ #undef CONFIG_SOFT_I2C /* I2C bit-banged */ #define CONFIG_FSL_I2C -#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ -#define CONFIG_SYS_I2C_SLAVE 0x7F +#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_I2C_SLAVE 0x7F #define CONFIG_SYS_I2C_NOPROBES {0x51} /* Don't probe these addrs */ -#define CONFIG_SYS_I2C_OFFSET 0x3000 -#define CONFIG_SYS_I2C2_OFFSET 0x3100 +#define CONFIG_SYS_I2C_OFFSET 0x3000 +#define CONFIG_SYS_I2C2_OFFSET 0x3100
/* * Config on-board RTC @@ -364,9 +367,9 @@ * General PCI * Addresses are mapped 1-1. */ -#define CONFIG_SYS_PCI_MEM_BASE 0x80000000 -#define CONFIG_SYS_PCI_MEM_PHYS CONFIG_SYS_PCI_MEM_BASE -#define CONFIG_SYS_PCI_MEM_SIZE 0x10000000 /* 256M */ +#define CONFIG_SYS_PCI_MEM_BASE 0x80000000 +#define CONFIG_SYS_PCI_MEM_PHYS CONFIG_SYS_PCI_MEM_BASE +#define CONFIG_SYS_PCI_MEM_SIZE 0x10000000 /* 256M */ #define CONFIG_SYS_PCI_MMIO_BASE 0x90000000 #define CONFIG_SYS_PCI_MMIO_PHYS CONFIG_SYS_PCI_MMIO_BASE #define CONFIG_SYS_PCI_MMIO_SIZE 0x10000000 /* 256M */ @@ -448,12 +451,12 @@ #define CONFIG_SYS_SATA_MAX_DEVICE 2 #define CONFIG_SATA1 #define CONFIG_SYS_SATA1_OFFSET 0x18000 -#define CONFIG_SYS_SATA1 (CONFIG_SYS_IMMR + CONFIG_SYS_SATA1_OFFSET) -#define CONFIG_SYS_SATA1_FLAGS FLAGS_DMA +#define CONFIG_SYS_SATA1 (CONFIG_SYS_IMMR + CONFIG_SYS_SATA1_OFFSET) +#define CONFIG_SYS_SATA1_FLAGS FLAGS_DMA #define CONFIG_SATA2 #define CONFIG_SYS_SATA2_OFFSET 0x19000 -#define CONFIG_SYS_SATA2 (CONFIG_SYS_IMMR + CONFIG_SYS_SATA2_OFFSET) -#define CONFIG_SYS_SATA2_FLAGS FLAGS_DMA +#define CONFIG_SYS_SATA2 (CONFIG_SYS_IMMR + CONFIG_SYS_SATA2_OFFSET) +#define CONFIG_SYS_SATA2_FLAGS FLAGS_DMA
#ifdef CONFIG_FSL_SATA #define CONFIG_LBA48 @@ -467,11 +470,12 @@ */ #ifndef CONFIG_SYS_RAMBOOT #define CONFIG_ENV_IS_IN_FLASH 1 - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE+CONFIG_SYS_MONITOR_LEN) + #define CONFIG_ENV_ADDR \ + (CONFIG_SYS_MONITOR_BASE+CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K (one sector) for env */ #define CONFIG_ENV_SIZE 0x4000 #else - #define CONFIG_SYS_NO_FLASH 1 /* Flash is not usable now */ + #define CONFIG_SYS_NO_FLASH 1 /* Flash is not usable now */ #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE-0x1000) #define CONFIG_ENV_SIZE 0x2000 @@ -509,7 +513,7 @@ #endif
#undef CONFIG_WATCHDOG /* watchdog disabled */
@@ -529,9 +533,9 @@ /* * Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ -#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ +#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */
#if defined(CONFIG_CMD_KGDB) #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ @@ -539,24 +543,26 @@ #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #endif
/* * Core HID Setup */ #define CONFIG_SYS_HID0_INIT 0x000000000 -#define CONFIG_SYS_HID0_FINAL (HID0_ENABLE_MACHINE_CHECK | \ - HID0_ENABLE_INSTRUCTION_CACHE) +#define CONFIG_SYS_HID0_FINAL (HID0_ENABLE_MACHINE_CHECK \ + | HID0_ENABLE_INSTRUCTION_CACHE) #define CONFIG_SYS_HID2 HID2_HBE
/* @@ -569,53 +575,93 @@ #define CONFIG_SYS_SDRAM_LOWER CONFIG_SYS_SDRAM_BASE #define CONFIG_SYS_SDRAM_UPPER (CONFIG_SYS_SDRAM_BASE + 0x10000000)
/* L2 Switch: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_VSC7385_BASE | BATL_PP_10 | \ - BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT3U (CONFIG_SYS_VSC7385_BASE | BATU_BL_128K | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_VSC7385_BASE \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT3U (CONFIG_SYS_VSC7385_BASE \ + | BATU_BL_128K \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT3L CONFIG_SYS_IBAT3L #define CONFIG_SYS_DBAT3U CONFIG_SYS_IBAT3U
#ifdef CONFIG_PCI /* PCI MEM space: cacheable */ -#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI_MEM_PHYS | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI_MEM_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI_MEM_PHYS \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI_MEM_PHYS \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT6L CONFIG_SYS_IBAT6L #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U /* PCI MMIO space: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI_MMIO_PHYS | BATL_PP_10 | \ - BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT7U (CONFIG_SYS_PCI_MMIO_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI_MMIO_PHYS \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT7U (CONFIG_SYS_PCI_MMIO_PHYS \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_DBAT7L CONFIG_SYS_IBAT7L #define CONFIG_SYS_DBAT7U CONFIG_SYS_IBAT7U #else @@ -641,16 +687,18 @@
#define CONFIG_HAS_FSL_DR_USB
-#define CONFIG_NETDEV eth1 +#define CONFIG_NETDEV "eth1"
#define CONFIG_HOSTNAME mpc837x_rdb #define CONFIG_ROOTPATH /nfsroot -#define CONFIG_RAMDISKFILE rootfs.ext2.gz.uboot +#define CONFIG_RAMDISKFILE "rootfs.ext2.gz.uboot" #define CONFIG_BOOTFILE uImage -#define CONFIG_UBOOTPATH u-boot.bin /* U-Boot image on TFTP server */ -#define CONFIG_FDTFILE mpc8379_rdb.dtb + /* U-Boot image on TFTP server */ +#define CONFIG_UBOOTPATH "u-boot.bin" +#define CONFIG_FDTFILE "mpc8379_rdb.dtb"
-#define CONFIG_LOADADDR 800000 /* default location for tftp and bootm */ + /* default location for tftp and bootm */ +#define CONFIG_LOADADDR 800000 #define CONFIG_BOOTDELAY 6 /* -1 disables auto-boot */ #define CONFIG_BAUDRATE 115200
@@ -658,23 +706,24 @@ #define MK_STR(x) XMK_STR(x)
#define CONFIG_EXTRA_ENV_SETTINGS \ - "netdev=" MK_STR(CONFIG_NETDEV) "\0" \ - "uboot=" MK_STR(CONFIG_UBOOTPATH) "\0" \ + "netdev=" CONFIG_NETDEV "\0" \ + "uboot=" CONFIG_UBOOTPATH "\0" \ "tftpflash=tftp $loadaddr $uboot;" \ - "protect off " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; " \ - "erase " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; " \ - "cp.b $loadaddr " MK_STR(CONFIG_SYS_TEXT_BASE) " $filesize; " \ - "protect on " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; " \ - "cmp.b $loadaddr " MK_STR(CONFIG_SYS_TEXT_BASE) " $filesize\0" \ + "protect off " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; " \ + "erase " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; " \ + "cp.b $loadaddr " MK_STR(CONFIG_SYS_TEXT_BASE) " $filesize; " \ + "protect on " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; " \ + "cmp.b $loadaddr " MK_STR(CONFIG_SYS_TEXT_BASE) " $filesize\0" \ "fdtaddr=780000\0" \ - "fdtfile=" MK_STR(CONFIG_FDTFILE) "\0" \ + "fdtfile=" CONFIG_FDTFILE "\0" \ "ramdiskaddr=1000000\0" \ - "ramdiskfile=" MK_STR(CONFIG_RAMDISKFILE) "\0" \ + "ramdiskfile=" CONFIG_RAMDISKFILE "\0" \ "console=ttyS0\0" \ "setbootargs=setenv bootargs " \ "root=$rootdev rw console=$console,$baudrate $othbootargs\0" \ "setipargs=setenv bootargs nfsroot=$serverip:$rootpath " \ - "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ + "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:" \ + "$netdev:off " \ "root=$rootdev rw console=$console,$baudrate $othbootargs\0"
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- include/configs/MVBLM7.h | 116 ++++++++++++++++++++++++++++++---------------- 1 files changed, 76 insertions(+), 40 deletions(-)
diff --git a/include/configs/MVBLM7.h b/include/configs/MVBLM7.h index c201310..4b3917e 100644 --- a/include/configs/MVBLM7.h +++ b/include/configs/MVBLM7.h @@ -107,13 +107,19 @@ #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 256
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | BR_PS_16 | BR_V) -#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) | OR_UPM_XAM | \ - OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | OR_GPCM_XACS|\ - OR_GPCM_SCY_15 | OR_GPCM_TRLX | OR_GPCM_EHTR | \ - OR_GPCM_EAD) +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | BR_PS_16 | BR_V) +#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) \ + | OR_UPM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX \ + | OR_GPCM_EHTR \ + | OR_GPCM_EAD) #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | (0x13 + CONFIG_SYS_FLASH_SIZE_SHIFT)) +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN \ + | (0x13 + CONFIG_SYS_FLASH_SIZE_SHIFT))
/* * U-Boot memory configuration @@ -122,10 +128,11 @@ #undef CONFIG_SYS_RAMBOOT
#define CONFIG_SYS_INIT_RAM_LOCK -#define CONFIG_SYS_INIT_RAM_ADDR 0xFD000000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM*/ +#define CONFIG_SYS_INIT_RAM_ADDR 0xFD000000 /* Initial RAM address */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM*/
-#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* CONFIG_SYS_MONITOR_LEN must be a multiple of CONFIG_ENV_SECT_SIZE */ @@ -157,7 +164,7 @@ #define CONFIG_SYS_NS16550_CLK get_bus_freq(0)
#define CONFIG_CONSOLE ttyS0 #define CONFIG_BAUDRATE 115200 @@ -177,7 +184,8 @@ #define CONFIG_SYS_PCI1_MEM_BASE 0x80000000 #define CONFIG_SYS_PCI1_MEM_PHYS CONFIG_SYS_PCI1_MEM_BASE #define CONFIG_SYS_PCI1_MEM_SIZE 0x10000000 -#define CONFIG_SYS_PCI1_MMIO_BASE (CONFIG_SYS_PCI1_MEM_BASE + CONFIG_SYS_PCI1_MEM_SIZE) +#define CONFIG_SYS_PCI1_MMIO_BASE \ + (CONFIG_SYS_PCI1_MEM_BASE + CONFIG_SYS_PCI1_MEM_SIZE) #define CONFIG_SYS_PCI1_MMIO_PHYS CONFIG_SYS_PCI1_MMIO_BASE #define CONFIG_SYS_PCI1_MMIO_SIZE 0x10000000 #define CONFIG_SYS_PCI1_IO_BASE 0x00000000 @@ -205,16 +213,16 @@ #define CONFIG_TSEC1_NAME "TSEC0" #define CONFIG_FEC1_PHY_NORXERR #define CONFIG_SYS_TSEC1_OFFSET 0x24000 -#define CONFIG_SYS_TSEC1 (CONFIG_SYS_IMMR+CONFIG_SYS_TSEC1_OFFSET) +#define CONFIG_SYS_TSEC1 (CONFIG_SYS_IMMR+CONFIG_SYS_TSEC1_OFFSET) #define TSEC1_PHY_ADDR 0x10 #define TSEC1_PHYIDX 0 #define TSEC1_FLAGS (TSEC_GIGABIT|TSEC_REDUCED)
#define CONFIG_HAS_ETH1 -#define CONFIG_TSEC2_NAME "TSEC1" +#define CONFIG_TSEC2_NAME "TSEC1" #define CONFIG_FEC2_PHY_NORXERR #define CONFIG_SYS_TSEC2_OFFSET 0x25000 -#define CONFIG_SYS_TSEC2 (CONFIG_SYS_IMMR+CONFIG_SYS_TSEC2_OFFSET) +#define CONFIG_SYS_TSEC2 (CONFIG_SYS_IMMR+CONFIG_SYS_TSEC2_OFFSET) #define TSEC2_PHY_ADDR 0x11 #define TSEC2_PHYIDX 0 #define TSEC2_FLAGS (TSEC_GIGABIT|TSEC_REDUCED) @@ -251,7 +259,7 @@ #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_ENV_SECT_SIZE 0x2000 #define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR+CONFIG_ENV_SIZE) -#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE +#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE
#define CONFIG_LOADS_ECHO #define CONFIG_SYS_LOADS_BAUD_CHANGE @@ -281,7 +289,7 @@ */ #define CONFIG_SYS_LONGHELP #define CONFIG_CMDLINE_EDITING -#define CONFIG_AUTO_COMPLETE /* add autocompletion support */ +#define CONFIG_AUTO_COMPLETE /* add autocompletion support */ #define CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_PROMPT_HUSH_PS2 "> "
@@ -293,7 +301,8 @@ #define CONFIG_SYS_PROMPT "mvBL-M7> " #define CONFIG_SYS_CBSIZE 256
-#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) +#define CONFIG_SYS_PBSIZE \ + (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) #define CONFIG_SYS_MAXARGS 16 #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE #define CONFIG_SYS_HZ 1000 @@ -303,7 +312,8 @@ * have to be in the first 256 MB of memory, since this is * the maximum mapped by the Linux kernel during initialization. */ -#define CONFIG_SYS_BOOTMAPSZ (256 << 20) /* Initial Memory map for Linux*/ + /* Initial Memory map for Linux*/ +#define CONFIG_SYS_BOOTMAPSZ (256 << 20)
#define CONFIG_SYS_HRCW_LOW 0x0 #define CONFIG_SYS_HRCW_HIGH 0x0 @@ -312,7 +322,7 @@ * System performance */ #define CONFIG_SYS_ACR_PIPE_DEP 3 /* Arbiter pipeline depth (0-3) */ -#define CONFIG_SYS_ACR_RPTCNT 3 /* Arbiter repeat count (0-7) */ +#define CONFIG_SYS_ACR_RPTCNT 3 /* Arbiter repeat count (0-7) */ #define CONFIG_SYS_SPCR_TSEC1EP 3 /* TSEC1 emergency priority (0-3) */ #define CONFIG_SYS_SPCR_TSEC2EP 3 /* TSEC2 emergency priority (0-3) */
@@ -334,15 +344,30 @@ #define CONFIG_HIGH_BATS 1
/* DDR */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP)
/* PCI */ -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT |\ - BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP)
/* no PCI2 */ #define CONFIG_SYS_IBAT3L 0 @@ -351,14 +376,25 @@ #define CONFIG_SYS_IBAT4U 0
/* IMMRBAR @ 0xE0000000, PCI IO @ 0xE2000000 & BCSR @ 0xE2400000 */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR | BATL_PP_10 | BATL_CACHEINHIBIT | \ - BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT5U (CONFIG_SYS_IMMR | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT5U (CONFIG_SYS_IMMR \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP)
/* stack in DCACHE 0xFDF00000 & FLASH @ 0xFF800000 */ -#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_10 | BATL_MEMCOHERENCE | \ +#define CONFIG_SYS_IBAT6L (0xF0000000 \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE \ + | \ BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT6U (0xF0000000 | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT6U (0xF0000000 \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) #define CONFIG_SYS_IBAT7L 0 #define CONFIG_SYS_IBAT7U 0
@@ -393,8 +429,8 @@ #define CONFIG_ZERO_BOOTDELAY_CHECK #define CONFIG_RESET_TO_RETRY 1000
-#define MV_CI mvBL-M7 -#define MV_VCI mvBL-M7 +#define MV_CI "mvBL-M7" +#define MV_VCI "mvBL-M7" #define MV_FPGA_DATA 0xfff40000 #define MV_FPGA_SIZE 0 #define MV_KERNEL_ADDR 0xff810000 @@ -410,15 +446,15 @@ #define MV_DTB_ADDR_RAM 0x00600000 #define MV_INITRD_ADDR_RAM 0x01000000
-#define CONFIG_BOOTCOMMAND "if imi ${script_addr}; \ - then source ${script_addr}; \ - else source ${script_addr2}; \ - fi;" +#define CONFIG_BOOTCOMMAND "if imi ${script_addr}; " \ + "then source ${script_addr}; " \ + "else source ${script_addr2}; " \ + "fi;" #define CONFIG_BOOTARGS "root=/dev/ram ro rootfstype=squashfs"
#define CONFIG_EXTRA_ENV_SETTINGS \ "console_nr=0\0" \ - "baudrate=" MK_STR(CONFIG_BAUDRATE) "\0" \ + "baudrate=" MK_STR(CONFIG_BAUDRATE) "\0" \ "stdin=serial\0" \ "stdout=serial\0" \ "stderr=serial\0" \ @@ -436,8 +472,8 @@ "mv_dtb_addr_ram=" MK_STR(MV_DTB_ADDR_RAM) "\0" \ "dtb_name=" MK_STR(MV_DTB_NAME) "\0" \ "mv_version=" U_BOOT_VERSION "\0" \ - "dhcp_client_id=" MK_STR(MV_CI) "\0" \ - "dhcp_vendor-class-identifier=" MK_STR(MV_VCI) "\0" \ + "dhcp_client_id=" MV_CI "\0" \ + "dhcp_vendor-class-identifier=" MV_VCI "\0" \ "netretry=no\0" \ "use_static_ipaddr=no\0" \ "static_ipaddr=192.168.90.10\0" \
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- include/configs/SIMPC8313.h | 288 ++++++++++++++++++++++++------------------- 1 files changed, 164 insertions(+), 124 deletions(-)
diff --git a/include/configs/SIMPC8313.h b/include/configs/SIMPC8313.h index 339e02b..3c8f221 100644 --- a/include/configs/SIMPC8313.h +++ b/include/configs/SIMPC8313.h @@ -77,8 +77,8 @@ #define CONFIG_SYS_MEMTEST_START 0x00001000 #define CONFIG_SYS_MEMTEST_END 0x07f00000
-#define CONFIG_SYS_ACR_PIPE_DEP 3 /* Arbiter pipeline depth (0-3) */ -#define CONFIG_SYS_ACR_RPTCNT 3 /* Arbiter repeat count (0-7) */ +#define CONFIG_SYS_ACR_PIPE_DEP 3 /* Arbiter pipeline depth (0-3) */ +#define CONFIG_SYS_ACR_RPTCNT 3 /* Arbiter repeat count (0-7) */
/* * Device configurations @@ -88,17 +88,18 @@ /* * DDR Setup */ -#define CONFIG_SYS_DDR_BASE 0x00000000 /* DDR is system memory*/ + /* DDR is system memory*/ +#define CONFIG_SYS_DDR_BASE 0x00000000 #define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_BASE #define CONFIG_SYS_DDR_SDRAM_BASE CONFIG_SYS_DDR_BASE
#define CONFIG_VERY_BIG_RAM #define CONFIG_MAX_MEM_MAPPED (512 << 20)
-#define CONFIG_SYS_DDRCDR ( DDRCDR_EN \ +#define CONFIG_SYS_DDRCDR (DDRCDR_EN \ | DDRCDR_PZ_NOMZ \ | DDRCDR_NZ_NOMZ \ - | DDRCDR_M_ODR ) + | DDRCDR_M_ODR) /* 0x73000002 TODO ODR & DRN ? */
/* @@ -111,15 +112,16 @@ #endif
#define CONFIG_SYS_INIT_RAM_LOCK 1 -#define CONFIG_SYS_INIT_RAM_ADDR 0xFD000000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM*/ +#define CONFIG_SYS_INIT_RAM_ADDR 0xFD000000 /* Initial RAM address */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM*/
/* CONFIG_SYS_MONITOR_LEN must be a multiple of CONFIG_ENV_SECT_SIZE */ -#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ -#define CONFIG_SYS_MALLOC_LEN (512 * 1024) /* Reserved for malloc */ +#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ +#define CONFIG_SYS_MALLOC_LEN (512 * 1024) /* Reserved for malloc */
/* * Local Bus LCRR and LBCR regs @@ -129,9 +131,10 @@ #define CONFIG_SYS_LCRR_CLKDIV LCRR_CLKDIV_2 #define CONFIG_SYS_LBC_LBCR (0x00040000 /* TODO */ \ | (0xFF << LBCR_BMT_SHIFT) \ - | 0xF ) /* 0x0004ff0f */ + | 0xF) /* 0x0004ff0f */
-#define CONFIG_SYS_LBC_MRTPR 0x20000000 /* LB refresh timer prescal, 266MHz/32 */ + /* LB refresh timer prescal, 266MHz/32 */ +#define CONFIG_SYS_LBC_MRTPR 0x20000000
/* drivers/mtd/nand/nand.c */ #ifdef CONFIG_NAND_SPL @@ -144,39 +147,41 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define NAND_MAX_CHIPS 1 #define CONFIG_MTD_NAND_VERIFY_WRITE -#define CONFIG_CMD_NAND 1 +#define CONFIG_CMD_NAND 1 #define CONFIG_NAND_FSL_ELBC 1
-#define CONFIG_SYS_NAND_BR_PRELIM ( CONFIG_SYS_NAND_BASE \ - | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ - | BR_PS_8 /* Port Size = 8 bit */ \ - | BR_MS_FCM /* MSEL = FCM */ \ - | BR_V ) /* valid */ +#define CONFIG_SYS_NAND_BR_PRELIM (CONFIG_SYS_NAND_BASE \ + | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ + | BR_PS_8 /* 8 bit Port */ \ + | BR_MS_FCM /* MSEL = FCM */ \ + | BR_V) /* valid */
#ifdef CONFIG_NAND_SP -#define CONFIG_SYS_NAND_OR_PRELIM ( 0xFFFF8000 /* length 32K */ \ +#define CONFIG_SYS_NAND_OR_PRELIM (0xFFFF8000 /* length 32K */ \ | OR_FCM_CSCT \ | OR_FCM_CST \ | OR_FCM_CHT \ | OR_FCM_SCY_1 \ | OR_FCM_TRLX \ - | OR_FCM_EHTR ) + | OR_FCM_EHTR) #define CONFIG_SYS_LBLAWAR0_PRELIM 0x8000000E /* 32KB */ -#define CONFIG_SYS_NAND_PAGE_SIZE (512) /* NAND chip page size */ -#define CONFIG_SYS_NAND_BLOCK_SIZE (16 << 10) /* NAND chip block size */ +#define CONFIG_SYS_NAND_PAGE_SIZE (512) /* NAND chip page size */ + /* NAND chip block size */ +#define CONFIG_SYS_NAND_BLOCK_SIZE (16 << 10) #define NAND_CACHE_PAGES 32 #elif defined(CONFIG_NAND_LP) -#define CONFIG_SYS_NAND_OR_PRELIM ( 0xFFFC0000 /* length 256K */ \ +#define CONFIG_SYS_NAND_OR_PRELIM (0xFFFC0000 /* length 256K */ \ | OR_FCM_PGS \ | OR_FCM_CSCT \ | OR_FCM_CST \ | OR_FCM_CHT \ | OR_FCM_SCY_1 \ | OR_FCM_TRLX \ - | OR_FCM_EHTR ) + | OR_FCM_EHTR) #define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000011 /* 256KB */ -#define CONFIG_SYS_NAND_PAGE_SIZE (2048) /* NAND chip page size */ -#define CONFIG_SYS_NAND_BLOCK_SIZE (128 << 10) /* NAND chip block size */ +#define CONFIG_SYS_NAND_PAGE_SIZE (2048) /* NAND chip page size */ + /* NAND chip block size */ +#define CONFIG_SYS_NAND_BLOCK_SIZE (128 << 10) #define NAND_CACHE_PAGES 64 #else #error Page size of NAND not defined. @@ -192,11 +197,11 @@ #define CONFIG_SYS_NAND_LBLAWBAR_PRELIM CONFIG_SYS_LBLAWBAR0_PRELIM #define CONFIG_SYS_NAND_LBLAWAR_PRELIM CONFIG_SYS_LBLAWAR0_PRELIM
-#define CONFIG_SYS_BR1_PRELIM ( CONFIG_SYS_FPGA_BASE \ +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_FPGA_BASE \ | BR_PS_16 \ | BR_MS_UPMA \ - | BR_V ) -#define CONFIG_SYS_OR1_PRELIM ( OR_AM_2MB \ + | BR_V) +#define CONFIG_SYS_OR1_PRELIM (OR_AM_2MB \ | OR_UPM_BCTLD)
#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_FPGA_BASE @@ -210,7 +215,7 @@
/* mtdparts command line support */ #define CONFIG_CMD_MTDPARTS -#define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ +#define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ #define MTDIDS_DEFAULT "nand0=nand0" #define MTDPARTS_DEFAULT "mtdparts=nand0:2M(u-boot),6M(kernel),-(jffs2)"
@@ -231,7 +236,7 @@ #endif
#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR+0x4600) @@ -241,14 +246,14 @@ #define CONFIG_SYS_PROMPT_HUSH_PS2 "> "
/* I2C */ -#define CONFIG_HARD_I2C /* I2C with hardware support*/ +#define CONFIG_HARD_I2C /* I2C with hardware support*/ #define CONFIG_FSL_I2C #define CONFIG_I2C_MULTI_BUS -#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ -#define CONFIG_SYS_I2C_SLAVE 0x7F -#define CONFIG_SYS_I2C_NOPROBES {{0,0x69}} /* Don't probe these addrs */ -#define CONFIG_SYS_I2C_OFFSET 0x3000 -#define CONFIG_SYS_I2C2_OFFSET 0x3100 +#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_I2C_SLAVE 0x7F +#define CONFIG_SYS_I2C_NOPROBES { {0, 0x69} } /* Don't probe these addrs */ +#define CONFIG_SYS_I2C_OFFSET 0x3000 +#define CONFIG_SYS_I2C2_OFFSET 0x3100
/* * General PCI @@ -307,28 +312,30 @@ * Environment */ #if defined(CONFIG_NAND_U_BOOT) - #define CONFIG_ENV_IS_IN_NAND 1 - #define CONFIG_ENV_OFFSET (768 * 1024) - #define CONFIG_ENV_SECT_SIZE CONFIG_SYS_NAND_BLOCK_SIZE - #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE - #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE - #define CONFIG_ENV_RANGE (CONFIG_ENV_SECT_SIZE * 4) - #define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + CONFIG_ENV_RANGE) + #define CONFIG_ENV_IS_IN_NAND 1 + #define CONFIG_ENV_OFFSET (768 * 1024) + #define CONFIG_ENV_SECT_SIZE CONFIG_SYS_NAND_BLOCK_SIZE + #define CONFIG_ENV_SIZE CONFIG_ENV_SECT_SIZE + #define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE + #define CONFIG_ENV_RANGE (CONFIG_ENV_SECT_SIZE * 4) + #define CONFIG_ENV_OFFSET_REDUND \ + (CONFIG_ENV_OFFSET + CONFIG_ENV_RANGE) #elif !defined(CONFIG_SYS_RAMBOOT) - #define CONFIG_ENV_IS_IN_FLASH 1 - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) - #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K(one sector) for env */ - #define CONFIG_ENV_SIZE 0x2000 + #define CONFIG_ENV_IS_IN_FLASH 1 + #define CONFIG_ENV_ADDR \ + (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) + #define CONFIG_ENV_SECT_SIZE 0x10000 /* 64K(one sector) for env */ + #define CONFIG_ENV_SIZE 0x2000
/* Address and size of Redundant Environment Sector */ #else - #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ - #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) - #define CONFIG_ENV_SIZE 0x2000 + #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ + #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) + #define CONFIG_ENV_SIZE 0x2000 #endif
-#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */ +#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ +#define CONFIG_SYS_LOADS_BAUD_CHANGE 1 /* allow baudrate change */
/* * BOOTP options @@ -359,80 +366,82 @@ #undef CONFIG_CMD_LOADS #endif
-#define CONFIG_CMDLINE_EDITING 1 -#define CONFIG_AUTO_COMPLETE /* add autocompletion support */ +#define CONFIG_CMDLINE_EDITING 1 +#define CONFIG_AUTO_COMPLETE /* add autocompletion support */
/* * Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ -#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ - -#define CONFIG_SYS_PBSIZE ( CONFIG_SYS_CBSIZE \ - + sizeof(CONFIG_SYS_PROMPT) \ - + 16 ) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ -#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ +#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ +#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ + +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE \ + + sizeof(CONFIG_SYS_PROMPT) \ + + 16) /* Print Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ + /* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */
/* * For booting Linux, the board info and command line data * have to be in the first 256 MB of memory, since this is * the maximum mapped by the Linux kernel during initialization. */ -#define CONFIG_SYS_BOOTMAPSZ (256 << 20) /* Initial Memory map for Linux*/ + /* Initial Memory map for Linux*/ +#define CONFIG_SYS_BOOTMAPSZ (256 << 20)
-#define CONFIG_SYS_RCWH_PCIHOST 0x80000000 /* PCIHOST */ +#define CONFIG_SYS_RCWH_PCIHOST 0x80000000 /* PCIHOST */
-#define CONFIG_SYS_HRCW_LOW ( HRCWL_LCL_BUS_TO_SCB_CLK_1X1 \ - | 0x20000000 /* reserved */ \ - | HRCWL_DDR_TO_SCB_CLK_2X1 \ - | HRCWL_CSB_TO_CLKIN_4X1 \ - | HRCWL_CORE_TO_CSB_2_5X1 ) +#define CONFIG_SYS_HRCW_LOW (HRCWL_LCL_BUS_TO_SCB_CLK_1X1 \ + | 0x20000000 /* reserved */ \ + | HRCWL_DDR_TO_SCB_CLK_2X1 \ + | HRCWL_CSB_TO_CLKIN_4X1 \ + | HRCWL_CORE_TO_CSB_2_5X1)
-#define CONFIG_SYS_NS16550_CLK (CONFIG_83XX_CLKIN * 4) +#define CONFIG_SYS_NS16550_CLK (CONFIG_83XX_CLKIN * 4)
-#define CONFIG_SYS_HRCW_HIGH_BASE ( HRCWH_PCI_HOST \ - | HRCWH_PCI1_ARBITER_ENABLE \ - | HRCWH_CORE_ENABLE \ - | HRCWH_BOOTSEQ_DISABLE \ - | HRCWH_SW_WATCHDOG_DISABLE \ - | HRCWH_TSEC1M_IN_RGMII \ - | HRCWH_TSEC2M_IN_RGMII \ - | HRCWH_BIG_ENDIAN \ - | HRCWH_LALE_NORMAL ) +#define CONFIG_SYS_HRCW_HIGH_BASE (HRCWH_PCI_HOST \ + | HRCWH_PCI1_ARBITER_ENABLE \ + | HRCWH_CORE_ENABLE \ + | HRCWH_BOOTSEQ_DISABLE \ + | HRCWH_SW_WATCHDOG_DISABLE \ + | HRCWH_TSEC1M_IN_RGMII \ + | HRCWH_TSEC2M_IN_RGMII \ + | HRCWH_BIG_ENDIAN \ + | HRCWH_LALE_NORMAL)
#ifdef CONFIG_NAND_LP -#define CONFIG_SYS_HRCW_HIGH ( CONFIG_SYS_HRCW_HIGH_BASE \ - | HRCWH_FROM_0XFFF00100 \ - | HRCWH_ROM_LOC_NAND_LP_8BIT \ +#define CONFIG_SYS_HRCW_HIGH (CONFIG_SYS_HRCW_HIGH_BASE \ + | HRCWH_FROM_0XFFF00100 \ + | HRCWH_ROM_LOC_NAND_LP_8BIT \ | HRCWH_RL_EXT_NAND) #else -#define CONFIG_SYS_HRCW_HIGH ( CONFIG_SYS_HRCW_HIGH_BASE \ - | HRCWH_FROM_0XFFF00100 \ - | HRCWH_ROM_LOC_NAND_SP_8BIT \ - | HRCWH_RL_EXT_NAND ) +#define CONFIG_SYS_HRCW_HIGH (CONFIG_SYS_HRCW_HIGH_BASE \ + | HRCWH_FROM_0XFFF00100 \ + | HRCWH_ROM_LOC_NAND_SP_8BIT \ + | HRCWH_RL_EXT_NAND) #endif
/* System IO Config */ -#define CONFIG_SYS_SICRH ( SICRH_ETSEC2_B \ +#define CONFIG_SYS_SICRH (SICRH_ETSEC2_B \ | SICRH_ETSEC2_C \ | SICRH_ETSEC2_D \ | SICRH_ETSEC2_E \ | SICRH_ETSEC2_F \ | SICRH_ETSEC2_G \ | SICRH_TSOBI1 \ - | SICRH_TSOBI2 ) -#define CONFIG_SYS_SICRL ( SICRL_LBC \ + | SICRH_TSOBI2) +#define CONFIG_SYS_SICRL (SICRL_LBC \ | SICRL_USBDR_10 \ - | SICRL_ETSEC2_A ) + | SICRL_ETSEC2_A)
#define CONFIG_SYS_HID0_INIT 0x000000000 -#define CONFIG_SYS_HID0_FINAL (HID0_ENABLE_MACHINE_CHECK | \ - HID0_ENABLE_INSTRUCTION_CACHE | \ - HID0_ENABLE_DYNAMIC_POWER_MANAGMENT ) +#define CONFIG_SYS_HID0_FINAL (HID0_ENABLE_MACHINE_CHECK \ + | HID0_ENABLE_INSTRUCTION_CACHE \ + | HID0_ENABLE_DYNAMIC_POWER_MANAGMENT)
@@ -440,27 +449,54 @@
/* DDR @ 0x00000000 */ #define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10) -#define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT1L ((CONFIG_SYS_SDRAM_BASE + 0x10000000) | BATL_PP_10) -#define CONFIG_SYS_IBAT1U ((CONFIG_SYS_SDRAM_BASE + 0x10000000) | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) +#define CONFIG_SYS_IBAT1L ((CONFIG_SYS_SDRAM_BASE + 0x10000000) \ + | BATL_PP_10) +#define CONFIG_SYS_IBAT1U ((CONFIG_SYS_SDRAM_BASE + 0x10000000) \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP)
/* PCI @ 0x80000000 */ #define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10) -#define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT3U (CONFIG_SYS_PCI1_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MEM_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI1_MMIO_BASE \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT3U (CONFIG_SYS_PCI1_MMIO_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP)
/* PCI2 not supported on 8313 */ #define CONFIG_SYS_IBAT4L (0) #define CONFIG_SYS_IBAT4U (0)
/* IMMRBAR @ 0xE0000000, PCI IO @ 0xE2000000 */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT5U (CONFIG_SYS_IMMR | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT5U (CONFIG_SYS_IMMR \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP)
/* SDRAM @ 0xF0000000, stack in DCACHE 0xFDF00000 & FLASH @ 0xFE000000 */ -#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_10 | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT6U (0xF0000000 | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT6L (0xF0000000 \ + | BATL_PP_10 \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT6U (0xF0000000 \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP)
#define CONFIG_SYS_IBAT7L (0) #define CONFIG_SYS_IBAT7U (0) @@ -487,41 +523,45 @@ */ #define CONFIG_ENV_OVERWRITE
#define CONFIG_HOSTNAME simpc8313 #define CONFIG_ROOTPATH /tftpboot/ #define CONFIG_BOOTFILE /tftpboot/uImage -#define CONFIG_UBOOTPATH u-boot-nand.bin /* U-Boot image on TFTP server */ -#define CONFIG_FDTFILE simpc8313.dtb + /* U-Boot image on TFTP server */ +#define CONFIG_UBOOTPATH "u-boot-nand.bin" +#define CONFIG_FDTFILE "simpc8313.dtb"
-#define CONFIG_LOADADDR 500000 /* default location for tftp and bootm */ + /* default location for tftp and bootm */ +#define CONFIG_LOADADDR 500000 #define CONFIG_BOOTDELAY 5 /* 5 second delay */ #define CONFIG_BAUDRATE 115200
-#define CONFIG_BOOTCOMMAND "nand read $loadaddr kernel 600000;bootm $loadaddr - $fdtaddr" +#define CONFIG_BOOTCOMMAND "nand read $loadaddr kernel 600000;" \ + "bootm $loadaddr - $fdtaddr"
#define XMK_STR(x) #x #define MK_STR(x) XMK_STR(x)
#define CONFIG_EXTRA_ENV_SETTINGS \ - "netdev=" MK_STR(CONFIG_NETDEV) "\0" \ + "netdev=" CONFIG_NETDEV "\0" \ "ethprime=TSEC1\0" \ - "uboot=" MK_STR(CONFIG_UBOOTPATH) "\0" \ + "uboot=" CONFIG_UBOOTPATH "\0" \ "tftpflash=tftpboot $loadaddr $uboot; " \ - "protect off " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; " \ - "erase " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; " \ - "cp.b $loadaddr " MK_STR(CONFIG_SYS_TEXT_BASE) " $filesize; " \ - "protect on " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; " \ - "cmp.b $loadaddr " MK_STR(CONFIG_SYS_TEXT_BASE) " $filesize\0" \ + "protect off " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; " \ + "erase " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; " \ + "cp.b $loadaddr " MK_STR(CONFIG_SYS_TEXT_BASE) " $filesize; " \ + "protect on " MK_STR(CONFIG_SYS_TEXT_BASE) " +$filesize; " \ + "cmp.b $loadaddr " MK_STR(CONFIG_SYS_TEXT_BASE) " $filesize\0" \ "fdtaddr=ae0000\0" \ - "fdtfile=" MK_STR(CONFIG_FDTFILE) "\0" \ + "fdtfile=" CONFIG_FDTFILE "\0" \ "console=ttyS0\0" \ "setbootargs=setenv bootargs " \ "root=$rootdev rw console=$console,$baudrate $othbootargs\0" \ - "setipargs=setenv bootargs nfsroot=$serverip:$rootpath " \ - "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ - "root=$rootdev rw console=$console,$baudrate $othbootargs\0" \ + "setipargs=setenv bootargs nfsroot=$serverip:$rootpath " \ + "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:" \ + "$netdev:off " \ + "root=$rootdev rw console=$console,$baudrate $othbootargs\0" \ "load_uboot=tftp 100000 u-boot-nand.bin\0" \ "burn_uboot=nand erase u-boot 80000; " \ "nand write 100000 u-boot $filesize\0" \ @@ -534,7 +574,7 @@ "addip=setenv bootargs ${bootargs} " \ "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ ":${hostname}:${netdev}:off panic=1\0" \ - "addtty=setenv bootargs ${bootargs} console=ttyS0,${baudrate}\0" \ + "addtty=setenv bootargs ${bootargs} console=ttyS0,${baudrate}\0" \ "bootargs=root=/dev/mtdblock2 rootfstype=jffs2 rw " \ "console=ttyS0,115200\0" \ ""
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- include/configs/TQM834x.h | 277 +++++++++++++++++++++++++++------------------ 1 files changed, 169 insertions(+), 108 deletions(-)
diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index 5cd517d..8b8c604 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -66,26 +66,27 @@ /* * DDR Setup */ -#define CONFIG_SYS_DDR_BASE 0x00000000 /* DDR is system memory*/ -#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_BASE + /* DDR is system memory*/ +#define CONFIG_SYS_DDR_BASE 0x00000000 +#define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_BASE #define CONFIG_SYS_DDR_SDRAM_BASE CONFIG_SYS_DDR_BASE -#define DDR_CASLAT_25 /* CASLAT set to 2.5 */ -#undef CONFIG_DDR_ECC /* only for ECC DDR module */ -#undef CONFIG_SPD_EEPROM /* do not use SPD EEPROM for DDR setup */ +#define DDR_CASLAT_25 /* CASLAT set to 2.5 */ +#undef CONFIG_DDR_ECC /* only for ECC DDR module */ +#undef CONFIG_SPD_EEPROM /* do not use SPD EEPROM for DDR setup */
-#undef CONFIG_SYS_DRAM_TEST /* memory test, takes time */ +#undef CONFIG_SYS_DRAM_TEST /* memory test, takes time */ #define CONFIG_SYS_MEMTEST_START 0x00000000 /* memtest region */ #define CONFIG_SYS_MEMTEST_END 0x00100000
/* * FLASH on the Local Bus */ -#define CONFIG_SYS_FLASH_CFI /* use the Common Flash Interface */ -#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ +#define CONFIG_SYS_FLASH_CFI /* use the Common Flash Interface */ +#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ #undef CONFIG_SYS_FLASH_CHECKSUM #define CONFIG_SYS_FLASH_BASE 0x80000000 /* start of FLASH */ #define CONFIG_SYS_FLASH_SIZE 8 /* FLASH size in MB */ -#define CONFIG_SYS_FLASH_EMPTY_INFO /* print 'E' for empty sectors */ +#define CONFIG_SYS_FLASH_EMPTY_INFO /* print 'E' for empty sectors */ #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE
/* @@ -93,34 +94,41 @@ */
/* - * When CONFIG_SYS_MAX_FLASH_BANKS_DETECT is defined, the actual number of Flash - * banks has to be determined at runtime and stored in a gloabl variable - * tqm834x_num_flash_banks. The value of CONFIG_SYS_MAX_FLASH_BANKS_DETECT is only - * used instead of CONFIG_SYS_MAX_FLASH_BANKS to allocate the array flash_info, and - * should be made sufficiently large to accomodate the number of banks that - * might actually be detected. Since most (all?) Flash related functions use - * CONFIG_SYS_MAX_FLASH_BANKS as the number of actual banks on the board, it is - * defined as tqm834x_num_flash_banks. + * When CONFIG_SYS_MAX_FLASH_BANKS_DETECT is defined, the actual number of + * Flash banks has to be determined at runtime and stored in a gloabl variable + * tqm834x_num_flash_banks. The value of CONFIG_SYS_MAX_FLASH_BANKS_DETECT is + * only used instead of CONFIG_SYS_MAX_FLASH_BANKS to allocate the array + * flash_info, and should be made sufficiently large to accomodate the number + * of banks that might actually be detected. Since most (all?) Flash related + * functions use CONFIG_SYS_MAX_FLASH_BANKS as the number of actual banks on + * the board, it is defined as tqm834x_num_flash_banks. */ #define CONFIG_SYS_MAX_FLASH_BANKS_DETECT 2
-#define CONFIG_SYS_MAX_FLASH_SECT 512 /* max sectors per device */ +#define CONFIG_SYS_MAX_FLASH_SECT 512 /* max sectors per device */
/* 32 bit device at 0x80000000 via GPCM (0x8000_1801) */ -#define CONFIG_SYS_BR0_PRELIM ((CONFIG_SYS_FLASH_BASE & BR_BA) | \ - BR_MS_GPCM | BR_PS_32 | BR_V) +#define CONFIG_SYS_BR0_PRELIM ((CONFIG_SYS_FLASH_BASE & BR_BA) \ + | BR_MS_GPCM \ + | BR_PS_32 \ + | BR_V)
/* FLASH timing (0x0000_0c54) */ -#define CONFIG_SYS_OR_TIMING_FLASH (OR_GPCM_CSNT | OR_GPCM_ACS_DIV4 | \ - OR_GPCM_SCY_5 | OR_GPCM_TRLX) +#define CONFIG_SYS_OR_TIMING_FLASH (OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV4 \ + | OR_GPCM_SCY_5 \ + | OR_GPCM_TRLX)
#define CONFIG_SYS_PRELIM_OR_AM 0xc0000000 /* OR addr mask: 1 GiB */
-#define CONFIG_SYS_OR0_PRELIM (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) +#define CONFIG_SYS_OR0_PRELIM (CONFIG_SYS_PRELIM_OR_AM \ + | CONFIG_SYS_OR_TIMING_FLASH)
-#define CONFIG_SYS_LBLAWAR0_PRELIM 0x8000001D /* 1 GiB window size (2^(size + 1)) */ + /* 1 GiB window size (2^(size + 1)) */ +#define CONFIG_SYS_LBLAWAR0_PRELIM 0x8000001D
/* disable remaining mappings */ #define CONFIG_SYS_BR1_PRELIM 0x00000000 @@ -150,14 +158,17 @@ #endif
#define CONFIG_SYS_INIT_RAM_LOCK 1 -#define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM*/ +#define CONFIG_SYS_INIT_RAM_ADDR 0x20000000 /* Initial RAM address */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM*/
-#define CONFIG_SYS_MONITOR_LEN (384 * 1024) /* Reserve 384 kB = 3 sect. for Mon */ -#define CONFIG_SYS_MALLOC_LEN (512 * 1024) /* Reserve 512 kB for malloc */ + /* Reserve 384 kB = 3 sect. for Mon */ +#define CONFIG_SYS_MONITOR_LEN (384 * 1024) + /* Reserve 512 kB for malloc */ +#define CONFIG_SYS_MALLOC_LEN (512 * 1024)
/* * Serial Port @@ -169,7 +180,7 @@ #define CONFIG_SYS_NS16550_CLK get_bus_freq(0)
#define CONFIG_SYS_BAUDRATE_TABLE \ - {300, 600, 1200, 2400, 4800, 9600, 19200, 38400,115200} + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 115200}
#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR + 0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR + 0x4600) @@ -177,30 +188,30 @@ /* * I2C */ -#define CONFIG_HARD_I2C /* I2C with hardware support */ -#undef CONFIG_SOFT_I2C /* I2C bit-banged */ +#define CONFIG_HARD_I2C /* I2C with hardware support */ +#undef CONFIG_SOFT_I2C /* I2C bit-banged */ #define CONFIG_FSL_I2C -#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed: 400KHz */ -#define CONFIG_SYS_I2C_SLAVE 0x7F /* slave address */ -#define CONFIG_SYS_I2C_OFFSET 0x3000 +#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed: 400KHz */ +#define CONFIG_SYS_I2C_SLAVE 0x7F /* slave address */ +#define CONFIG_SYS_I2C_OFFSET 0x3000
/* I2C EEPROM, configuration for onboard EEPROMs 24C256 and 24C32 */ -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* 1010000x */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 /* 16 bit */ -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 5 /* 32 bytes per write */ -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 12 /* 10ms +/- 20% */ -#define CONFIG_SYS_I2C_MULTI_EEPROMS 1 /* more than one eeprom */ +#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* 1010000x */ +#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 /* 16 bit */ +#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 5 /* 32 bytes/write */ +#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 12 /* 10ms +/- 20% */ +#define CONFIG_SYS_I2C_MULTI_EEPROMS /* more than one eeprom */
/* I2C RTC */ -#define CONFIG_RTC_DS1337 /* use ds1337 rtc via i2c */ -#define CONFIG_SYS_I2C_RTC_ADDR 0x68 /* at address 0x68 */ +#define CONFIG_RTC_DS1337 /* use ds1337 rtc via i2c */ +#define CONFIG_SYS_I2C_RTC_ADDR 0x68 /* at address 0x68 */
/* I2C SYSMON (LM75) */ -#define CONFIG_DTT_LM75 1 /* ON Semi's LM75 */ -#define CONFIG_DTT_SENSORS {0} /* Sensor addresses */ +#define CONFIG_DTT_LM75 1 /* ON Semi's LM75 */ +#define CONFIG_DTT_SENSORS {0} /* Sensor addresses */ #define CONFIG_SYS_DTT_MAX_TEMP 70 #define CONFIG_SYS_DTT_LOW_TEMP -30 -#define CONFIG_SYS_DTT_HYSTERESIS 3 +#define CONFIG_SYS_DTT_HYSTERESIS 3
/* * TSEC @@ -209,9 +220,9 @@ #define CONFIG_MII
#define CONFIG_SYS_TSEC1_OFFSET 0x24000 -#define CONFIG_SYS_TSEC1 (CONFIG_SYS_IMMR + CONFIG_SYS_TSEC1_OFFSET) +#define CONFIG_SYS_TSEC1 (CONFIG_SYS_IMMR + CONFIG_SYS_TSEC1_OFFSET) #define CONFIG_SYS_TSEC2_OFFSET 0x25000 -#define CONFIG_SYS_TSEC2 (CONFIG_SYS_IMMR + CONFIG_SYS_TSEC2_OFFSET) +#define CONFIG_SYS_TSEC2 (CONFIG_SYS_IMMR + CONFIG_SYS_TSEC2_OFFSET)
#if defined(CONFIG_TSEC_ENET)
@@ -223,15 +234,15 @@ #define CONFIG_TSEC1_NAME "TSEC0" #define CONFIG_TSEC2 1 #define CONFIG_TSEC2_NAME "TSEC1" -#define TSEC1_PHY_ADDR 2 -#define TSEC2_PHY_ADDR 1 -#define TSEC1_PHYIDX 0 -#define TSEC2_PHYIDX 0 +#define TSEC1_PHY_ADDR 2 +#define TSEC2_PHY_ADDR 1 +#define TSEC1_PHYIDX 0 +#define TSEC2_PHYIDX 0 #define TSEC1_FLAGS TSEC_GIGABIT #define TSEC2_FLAGS TSEC_GIGABIT
/* Options are: TSEC[0-1] */ -#define CONFIG_ETHPRIME "TSEC0" +#define CONFIG_ETHPRIME "TSEC0"
#endif /* CONFIG_TSEC_ENET */
@@ -243,19 +254,20 @@
#if defined(CONFIG_PCI)
-#define CONFIG_PCI_PNP /* do pci plug-and-play */ -#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */ +#define CONFIG_PCI_PNP /* do pci plug-and-play */ +#define CONFIG_PCI_SCAN_SHOW /* show pci devices on startup */
/* PCI1 host bridge */ -#define CONFIG_SYS_PCI1_MEM_BASE 0x90000000 -#define CONFIG_SYS_PCI1_MEM_PHYS CONFIG_SYS_PCI1_MEM_BASE -#define CONFIG_SYS_PCI1_MEM_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCI1_MMIO_BASE (CONFIG_SYS_PCI1_MEM_BASE + CONFIG_SYS_PCI1_MEM_SIZE) -#define CONFIG_SYS_PCI1_MMIO_PHYS CONFIG_SYS_PCI1_MMIO_BASE -#define CONFIG_SYS_PCI1_MMIO_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCI1_IO_BASE 0xe2000000 -#define CONFIG_SYS_PCI1_IO_PHYS CONFIG_SYS_PCI1_IO_BASE -#define CONFIG_SYS_PCI1_IO_SIZE 0x1000000 /* 16M */ +#define CONFIG_SYS_PCI1_MEM_BASE 0x90000000 +#define CONFIG_SYS_PCI1_MEM_PHYS CONFIG_SYS_PCI1_MEM_BASE +#define CONFIG_SYS_PCI1_MEM_SIZE 0x10000000 /* 256M */ +#define CONFIG_SYS_PCI1_MMIO_BASE \ + (CONFIG_SYS_PCI1_MEM_BASE + CONFIG_SYS_PCI1_MEM_SIZE) +#define CONFIG_SYS_PCI1_MMIO_PHYS CONFIG_SYS_PCI1_MMIO_BASE +#define CONFIG_SYS_PCI1_MMIO_SIZE 0x10000000 /* 256M */ +#define CONFIG_SYS_PCI1_IO_BASE 0xe2000000 +#define CONFIG_SYS_PCI1_IO_PHYS CONFIG_SYS_PCI1_IO_BASE +#define CONFIG_SYS_PCI1_IO_SIZE 0x1000000 /* 16M */
#undef CONFIG_EEPRO100 #define CONFIG_EEPRO100 @@ -274,15 +286,16 @@ /* * Environment */ -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) -#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) for env */ -#define CONFIG_ENV_SIZE 0x8000 /* 32K max size */ +#define CONFIG_ENV_IS_IN_FLASH 1 +#define CONFIG_ENV_ADDR \ + (CONFIG_SYS_MONITOR_BASE + CONFIG_SYS_MONITOR_LEN) +#define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K (one sector) for env */ +#define CONFIG_ENV_SIZE 0x8000 /* 32K max size */ #define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE)
/* * BOOTP options @@ -323,30 +336,32 @@ /* * Miscellaneous configurable options */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ -#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_LOAD_ADDR 0x2000000 /* default load address */ +#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */
-#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ -#define CONFIG_AUTO_COMPLETE /* add autocompletion support */ +#define CONFIG_CMDLINE_EDITING 1 /* add command line history */ +#define CONFIG_AUTO_COMPLETE /* add autocompletion support */
-#define CONFIG_SYS_HUSH_PARSER 1 /* Use the HUSH parser */ +#define CONFIG_SYS_HUSH_PARSER 1 /* Use the HUSH parser */ #ifdef CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #endif
#if defined(CONFIG_CMD_KGDB) - #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ + #define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ #else - #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ + #define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ #endif
-#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ -#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */ + /* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ + /* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1ms ticks */
-#undef CONFIG_WATCHDOG /* watchdog disabled */ +#undef CONFIG_WATCHDOG /* watchdog disabled */
/* pass open firmware flat tree */ #define CONFIG_OF_LIBFDT 1 @@ -358,7 +373,8 @@ * have to be in the first 256 MB of memory, since this is * the maximum mapped by the Linux kernel during initialization. */ -#define CONFIG_SYS_BOOTMAPSZ (256 << 20) /* Initial Memory map for Linux*/ + /* Initial Memory map for Linux */ +#define CONFIG_SYS_BOOTMAPSZ (256 << 20)
#define CONFIG_SYS_HRCW_LOW (\ HRCWL_LCL_BUS_TO_SCB_CLK_1X1 |\ @@ -379,7 +395,7 @@ HRCWH_SW_WATCHDOG_DISABLE |\ HRCWH_ROM_LOC_LOCAL_16BIT |\ HRCWH_TSEC1M_IN_GMII |\ - HRCWH_TSEC2M_IN_GMII ) + HRCWH_TSEC2M_IN_GMII) #else #define CONFIG_SYS_HRCW_HIGH (\ HRCWH_PCI_HOST |\ @@ -392,7 +408,7 @@ HRCWH_SW_WATCHDOG_DISABLE |\ HRCWH_ROM_LOC_LOCAL_16BIT |\ HRCWH_TSEC1M_IN_GMII |\ - HRCWH_TSEC2M_IN_GMII ) + HRCWH_TSEC2M_IN_GMII) #endif
/* System IO Config */ @@ -408,23 +424,55 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR 0 - 512M */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_SDRAM_BASE + 0x10000000 | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT1U (CONFIG_SYS_SDRAM_BASE + 0x10000000 | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_SDRAM_BASE + 0x10000000 \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT1U (CONFIG_SYS_SDRAM_BASE + 0x10000000 \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP)
/* stack in DCACHE @ 512M (no backing mem) */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT2U (CONFIG_SYS_INIT_RAM_ADDR | BATU_BL_128K | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_INIT_RAM_ADDR \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT2U (CONFIG_SYS_INIT_RAM_ADDR \ + | BATU_BL_128K \ + | BATU_VS \ + | BATU_VP)
/* PCI */ #ifdef CONFIG_PCI -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT3U (CONFIG_SYS_PCI1_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_10 | BATL_MEMCOHERENCE | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT4U (CONFIG_SYS_PCI1_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_PCI1_IO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT5U (CONFIG_SYS_PCI1_IO_BASE | BATU_BL_16M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI1_MEM_BASE \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT3U (CONFIG_SYS_PCI1_MEM_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI1_MMIO_BASE \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT4U (CONFIG_SYS_PCI1_MMIO_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_PCI1_IO_BASE \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT5U (CONFIG_SYS_PCI1_IO_BASE \ + | BATU_BL_16M \ + | BATU_VS \ + | BATU_VP) #else #define CONFIG_SYS_IBAT3L (0) #define CONFIG_SYS_IBAT3U (0) @@ -435,12 +483,24 @@ #endif
/* IMMRBAR */ -#define CONFIG_SYS_IBAT6L (CONFIG_SYS_IMMR | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT6U (CONFIG_SYS_IMMR | BATU_BL_1M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_IMMR \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT6U (CONFIG_SYS_IMMR \ + | BATU_BL_1M \ + | BATU_VS \ + | BATU_VP)
/* FLASH */ -#define CONFIG_SYS_IBAT7L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT7U (CONFIG_SYS_FLASH_BASE | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT7L (CONFIG_SYS_FLASH_BASE \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT7U (CONFIG_SYS_FLASH_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP)
#define CONFIG_SYS_DBAT0L CONFIG_SYS_IBAT0L #define CONFIG_SYS_DBAT0U CONFIG_SYS_IBAT0U @@ -468,10 +528,11 @@ * Environment Configuration */
-#define CONFIG_LOADADDR 400000 /* default location for tftp and bootm */ + /* default location for tftp and bootm */ +#define CONFIG_LOADADDR 400000
#define CONFIG_BOOTDELAY 6 /* -1 disables auto-boot */ -#undef CONFIG_BOOTARGS /* the boot command will set bootargs */ +#undef CONFIG_BOOTARGS /* the boot command will set bootargs */
@@ -490,7 +551,7 @@ "addip=setenv bootargs ${bootargs} " \ "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ ":${hostname}:${netdev}:off panic=1\0" \ - "addcons=setenv bootargs ${bootargs} console=ttyS0,${baudrate}\0"\ + "addcons=setenv bootargs ${bootargs} console=ttyS0,${baudrate}\0" \ "flash_nfs_old=run nfsargs addip addcons;" \ "bootm ${kernel_addr}\0" \ "flash_nfs=run nfsargs addip addcons;" \ @@ -534,8 +595,8 @@ #define MTDIDS_DEFAULT "nor0=TQM834x-0"
/* default mtd partition table */ -#define MTDPARTS_DEFAULT "mtdparts=TQM834x-0:256k(u-boot),256k(env),"\ - "1m(kernel),2m(initrd),"\ - "-(user);"\ +#define MTDPARTS_DEFAULT "mtdparts=TQM834x-0:256k(u-boot),256k(env)," \ + "1m(kernel),2m(initrd)," \ + "-(user);" \
#endif /* __CONFIG_H */
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- include/configs/kmeter1.h | 4 ++-- 1 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/kmeter1.h b/include/configs/kmeter1.h index 8639ddd..3ae171b 100644 --- a/include/configs/kmeter1.h +++ b/include/configs/kmeter1.h @@ -49,7 +49,7 @@ HRCWL_CSB_TO_CLKIN_4X1 | \ HRCWL_CORE_TO_CSB_2X1 | \ HRCWL_CE_PLL_VCO_DIV_2 | \ - HRCWL_CE_TO_PLL_1X6 ) + HRCWL_CE_TO_PLL_1X6)
#define CONFIG_SYS_HRCW_HIGH (\ HRCWH_CORE_ENABLE | \ @@ -59,7 +59,7 @@ HRCWH_ROM_LOC_LOCAL_16BIT | \ HRCWH_BIG_ENDIAN | \ HRCWH_LALE_EARLY | \ - HRCWH_LDP_CLEAR ) + HRCWH_LDP_CLEAR)
#define CONFIG_SYS_DDR_CS0_BNDS 0x0000007f #define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SDRAM_TYPE_DDR2 | \
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- include/configs/mpc8308_p1m.h | 29 ++++++++++++++--------------- 1 files changed, 14 insertions(+), 15 deletions(-)
diff --git a/include/configs/mpc8308_p1m.h b/include/configs/mpc8308_p1m.h index d7a3a96..635afec 100644 --- a/include/configs/mpc8308_p1m.h +++ b/include/configs/mpc8308_p1m.h @@ -220,7 +220,7 @@ */ #define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xE6000000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM */ #define CONFIG_SYS_GBL_DATA_OFFSET \ (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
@@ -246,10 +246,9 @@ #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_64MB)
-#define CONFIG_SYS_BR0_PRELIM (\ - CONFIG_SYS_FLASH_BASE /* Flash Base address */ |\ - (2 << BR_PS_SHIFT) /* 16 bit port size */ |\ - BR_V) /* valid */ +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE /* Flash Base addr */ \ + | (2 << BR_PS_SHIFT) /* 16 bit port */ \ + | BR_V) /* valid */ #define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) \ | OR_UPM_XAM \ | OR_GPCM_CSNT \ @@ -271,11 +270,11 @@ /* * SJA1000 CAN controller on Local Bus */ -#define CONFIG_SYS_SJA1000_BASE 0xFBFF0000 -#define CONFIG_SYS_BR1_PRELIM ( CONFIG_SYS_SJA1000_BASE \ - | (1 << BR_PS_SHIFT) /* 8 bit port size */ \ - | BR_V ) /* valid */ -#define CONFIG_SYS_OR1_PRELIM ( 0xFFFF8000 /* length 32K */ \ +#define CONFIG_SYS_SJA1000_BASE 0xFBFF0000 +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_SJA1000_BASE \ + | (1 << BR_PS_SHIFT) /* 8 bit port */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR1_PRELIM (0xFFFF8000 /* length 32K */ \ | OR_GPCM_SCY_5 \ | OR_GPCM_EHTR) /* 0xFFFF8052 */ @@ -286,11 +285,11 @@ /* * CPLD on Local Bus */ -#define CONFIG_SYS_CPLD_BASE 0xFBFF8000 -#define CONFIG_SYS_BR2_PRELIM ( CONFIG_SYS_CPLD_BASE \ - | (1 << BR_PS_SHIFT) /* 8 bit port size */ \ - | BR_V ) /* valid */ -#define CONFIG_SYS_OR2_PRELIM ( 0xFFFF8000 /* length 32K */ \ +#define CONFIG_SYS_CPLD_BASE 0xFBFF8000 +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_CPLD_BASE \ + | (1 << BR_PS_SHIFT) /* 8 bit port */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR2_PRELIM (0xFFFF8000 /* length 32K */ \ | OR_GPCM_SCY_4 \ | OR_GPCM_EHTR) /* 0xFFFF8042 */
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- include/configs/sbc8349.h | 236 +++++++++++++++++++++++++++------------------ 1 files changed, 143 insertions(+), 93 deletions(-)
diff --git a/include/configs/sbc8349.h b/include/configs/sbc8349.h index b418cf2..d6207dd 100644 --- a/include/configs/sbc8349.h +++ b/include/configs/sbc8349.h @@ -71,7 +71,7 @@
#define CONFIG_SYS_IMMR 0xE0000000
@@ -81,7 +81,7 @@ #undef CONFIG_DDR_ECC /* only for ECC DDR module */ #undef CONFIG_DDR_ECC_CMD /* use DDR ECC user commands */ #define CONFIG_SPD_EEPROM /* use SPD EEPROM for DDR setup*/ -#define CONFIG_SYS_83XX_DDR_USES_CS0 /* WRS; Fsl board uses CS2/CS3 */ +#define CONFIG_SYS_83XX_DDR_USES_CS0 /* WRS; Fsl board uses CS2/CS3 */
/* * 32-bit data path mode. @@ -95,7 +95,7 @@ */ #undef CONFIG_DDR_32BIT
-#define CONFIG_SYS_DDR_BASE 0x00000000 /* DDR is system memory*/ +#define CONFIG_SYS_DDR_BASE 0x00000000 /* DDR is system memory*/ #define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_BASE #define CONFIG_SYS_DDR_SDRAM_BASE CONFIG_SYS_DDR_BASE #define CONFIG_SYS_DDR_SDRAM_CLK_CNTL (DDR_SDRAM_CLK_CNTL_SS_EN | \ @@ -114,18 +114,22 @@ * NB: manual DDR setup untested on sbc834x */ #define CONFIG_SYS_DDR_SIZE 256 /* MB */ -#define CONFIG_SYS_DDR_CONFIG (CSCONFIG_EN | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10) +#define CONFIG_SYS_DDR_CONFIG (CSCONFIG_EN \ + | CSCONFIG_ROW_BIT_13 \ + | CSCONFIG_COL_BIT_10) #define CONFIG_SYS_DDR_TIMING_1 0x36332321 #define CONFIG_SYS_DDR_TIMING_2 0x00000800 /* P9-45,may need tuning */ -#define CONFIG_SYS_DDR_CONTROL 0xc2000000 /* unbuffered,no DYN_PWR */ +#define CONFIG_SYS_DDR_CONTROL 0xc2000000 /* unbuffered,no DYN_PWR */ #define CONFIG_SYS_DDR_INTERVAL 0x04060100 /* autocharge,no open page */
#if defined(CONFIG_DDR_32BIT) /* set burst length to 8 for 32-bit data path */ -#define CONFIG_SYS_DDR_MODE 0x00000023 /* DLL,normal,seq,4/2.5, 8 burst len */ + /* DLL,normal,seq,4/2.5, 8 burst len */ +#define CONFIG_SYS_DDR_MODE 0x00000023 #else /* the default burst length is 4 - for 64-bit data path */ -#define CONFIG_SYS_DDR_MODE 0x00000022 /* DLL,normal,seq,4/2.5, 4 burst len */ + /* DLL,normal,seq,4/2.5, 4 burst len */ +#define CONFIG_SYS_DDR_MODE 0x00000022 #endif #endif
@@ -133,27 +137,28 @@ * SDRAM on the Local Bus */ #define CONFIG_SYS_LBC_SDRAM_BASE 0x10000000 /* Localbus SDRAM */ -#define CONFIG_SYS_LBC_SDRAM_SIZE 128 /* LBC SDRAM is 128MB */ +#define CONFIG_SYS_LBC_SDRAM_SIZE 128 /* LBC SDRAM is 128MB */
/* * FLASH on the Local Bus */ -#define CONFIG_SYS_FLASH_CFI /* use the Common Flash Interface */ -#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ +#define CONFIG_SYS_FLASH_CFI /* use the Common Flash Interface */ +#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ #define CONFIG_SYS_FLASH_BASE 0xFF800000 /* start of FLASH */ #define CONFIG_SYS_FLASH_SIZE 8 /* flash size in MB */ /* #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE */
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | /* flash Base address */ \ - (2 << BR_PS_SHIFT) | /* 16 bit port size */ \ - BR_V) /* valid */ +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE \ + | (2 << BR_PS_SHIFT) /* 16 bit port */ \ + | BR_V) /* valid */
#define CONFIG_SYS_OR0_PRELIM 0xFF806FF7 /* 8 MB flash size */ -#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE /* window base at flash base */ + /* window base at flash base */ +#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000016 /* 8 MB window size */
-#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 64 /* sectors per device */ +#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ +#define CONFIG_SYS_MAX_FLASH_SECT 64 /* sectors per device */
#undef CONFIG_SYS_FLASH_CHECKSUM #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase Timeout (ms) */ @@ -168,14 +173,17 @@ #endif
#define CONFIG_SYS_INIT_RAM_LOCK 1 -#define CONFIG_SYS_INIT_RAM_ADDR 0xFD000000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM*/ + /* Initial RAM address */ +#define CONFIG_SYS_INIT_RAM_ADDR 0xFD000000 + /* Size of used area in RAM*/ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000
-#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ -#define CONFIG_SYS_MALLOC_LEN (128 * 1024) /* Reserved for malloc */ +#define CONFIG_SYS_MONITOR_LEN (256 * 1024) /* Reserve 256 kB for Mon */ +#define CONFIG_SYS_MALLOC_LEN (128 * 1024) /* Reserved for malloc */
/* * Local Bus LCRR and LBCR regs @@ -209,7 +217,8 @@ * FIXME: the top 17 bits of BR2. */
-#define CONFIG_SYS_BR2_PRELIM 0xF0001861 /* Port-size=32bit, MSEL=SDRAM */ + /* Port-size=32bit, MSEL=SDRAM */ +#define CONFIG_SYS_BR2_PRELIM 0xF0001861 #define CONFIG_SYS_LBLAWBAR2_PRELIM 0xF0000000 #define CONFIG_SYS_LBLAWAR2_PRELIM 0x80000019 /* 64M */
@@ -229,18 +238,19 @@
#define CONFIG_SYS_OR2_PRELIM 0xFC006901
-#define CONFIG_SYS_LBC_LSRT 0x32000000 /* LB sdram refresh timer, about 6us */ -#define CONFIG_SYS_LBC_MRTPR 0x20000000 /* LB refresh timer prescal, 266MHz/32 */ + /* LB sdram refresh timer, about 6us */ +#define CONFIG_SYS_LBC_LSRT 0x32000000 + /* LB refresh timer prescal, 266MHz/32 */ +#define CONFIG_SYS_LBC_MRTPR 0x20000000
-#define CONFIG_SYS_LBC_LSDMR_COMMON ( LSDMR_RFEN \ - | LSDMR_BSMA1516 \ - | LSDMR_RFCR8 \ - | LSDMR_PRETOACT6 \ - | LSDMR_ACTTORW3 \ - | LSDMR_BL8 \ - | LSDMR_WRC3 \ - | LSDMR_CL3 \ - ) +#define CONFIG_SYS_LBC_LSDMR_COMMON (LSDMR_RFEN \ + | LSDMR_BSMA1516 \ + | LSDMR_RFCR8 \ + | LSDMR_PRETOACT6 \ + | LSDMR_ACTTORW3 \ + | LSDMR_BL8 \ + | LSDMR_WRC3 \ + | LSDMR_CL3)
/* * SDRAM Controller configuration sequence. @@ -262,7 +272,7 @@ #define CONFIG_SYS_NS16550_CLK get_bus_freq(0)
#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR+0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR+0x4600) @@ -271,7 +281,7 @@ #define CONFIG_AUTO_COMPLETE /* add autocompletion support */ /* Use the HUSH parser */ #define CONFIG_SYS_HUSH_PARSER -#ifdef CONFIG_SYS_HUSH_PARSER +#ifdef CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_PROMPT_HUSH_PS2 "> " #endif
@@ -284,19 +294,19 @@ #define CONFIG_HARD_I2C /* I2C with hardware support*/ #undef CONFIG_SOFT_I2C /* I2C bit-banged */ #define CONFIG_FSL_I2C -#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ -#define CONFIG_SYS_I2C_SLAVE 0x7F +#define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ +#define CONFIG_SYS_I2C_SLAVE 0x7F #define CONFIG_SYS_I2C_NOPROBES {0x69} /* Don't probe these addrs */ -#define CONFIG_SYS_I2C1_OFFSET 0x3000 -#define CONFIG_SYS_I2C2_OFFSET 0x3100 -#define CONFIG_SYS_I2C_OFFSET CONFIG_SYS_I2C2_OFFSET +#define CONFIG_SYS_I2C1_OFFSET 0x3000 +#define CONFIG_SYS_I2C2_OFFSET 0x3100 +#define CONFIG_SYS_I2C_OFFSET CONFIG_SYS_I2C2_OFFSET /* could also use CONFIG_I2C_MULTI_BUS and CONFIG_SYS_SPD_BUS_NUM... */
/* TSEC */ #define CONFIG_SYS_TSEC1_OFFSET 0x24000 -#define CONFIG_SYS_TSEC1 (CONFIG_SYS_IMMR+CONFIG_SYS_TSEC1_OFFSET) +#define CONFIG_SYS_TSEC1 (CONFIG_SYS_IMMR+CONFIG_SYS_TSEC1_OFFSET) #define CONFIG_SYS_TSEC2_OFFSET 0x25000 -#define CONFIG_SYS_TSEC2 (CONFIG_SYS_IMMR+CONFIG_SYS_TSEC2_OFFSET) +#define CONFIG_SYS_TSEC2 (CONFIG_SYS_IMMR+CONFIG_SYS_TSEC2_OFFSET)
/* * General PCI @@ -308,9 +318,9 @@ #define CONFIG_SYS_PCI1_MMIO_BASE 0x90000000 #define CONFIG_SYS_PCI1_MMIO_PHYS CONFIG_SYS_PCI1_MMIO_BASE #define CONFIG_SYS_PCI1_MMIO_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCI1_IO_BASE 0x00000000 -#define CONFIG_SYS_PCI1_IO_PHYS 0xE2000000 -#define CONFIG_SYS_PCI1_IO_SIZE 0x00100000 /* 1M */ +#define CONFIG_SYS_PCI1_IO_BASE 0x00000000 +#define CONFIG_SYS_PCI1_IO_PHYS 0xE2000000 +#define CONFIG_SYS_PCI1_IO_SIZE 0x00100000 /* 1M */
#define CONFIG_SYS_PCI2_MEM_BASE 0xA0000000 #define CONFIG_SYS_PCI2_MEM_PHYS CONFIG_SYS_PCI2_MEM_BASE @@ -318,9 +328,9 @@ #define CONFIG_SYS_PCI2_MMIO_BASE 0xB0000000 #define CONFIG_SYS_PCI2_MMIO_PHYS CONFIG_SYS_PCI2_MMIO_BASE #define CONFIG_SYS_PCI2_MMIO_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCI2_IO_BASE 0x00000000 -#define CONFIG_SYS_PCI2_IO_PHYS 0xE2100000 -#define CONFIG_SYS_PCI2_IO_SIZE 0x00100000 /* 1M */ +#define CONFIG_SYS_PCI2_IO_BASE 0x00000000 +#define CONFIG_SYS_PCI2_IO_PHYS 0xE2100000 +#define CONFIG_SYS_PCI2_IO_SIZE 0x00100000 /* 1M */
@@ -390,7 +400,7 @@ #define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE)
#else - #define CONFIG_SYS_NO_FLASH 1 /* Flash is not usable now */ + #define CONFIG_SYS_NO_FLASH 1 /* Flash is not usable now */ #define CONFIG_ENV_IS_NOWHERE 1 /* Store ENV in memory only */ #define CONFIG_ENV_ADDR (CONFIG_SYS_MONITOR_BASE - 0x1000) #define CONFIG_ENV_SIZE 0x2000 @@ -438,22 +448,25 @@ #define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */
@@ -506,7 +519,7 @@ HRCWH_SW_WATCHDOG_DISABLE |\ HRCWH_ROM_LOC_LOCAL_16BIT |\ HRCWH_TSEC1M_IN_GMII |\ - HRCWH_TSEC2M_IN_GMII ) + HRCWH_TSEC2M_IN_GMII) #else #define CONFIG_SYS_HRCW_HIGH (\ HRCWH_PCI_HOST |\ @@ -519,7 +532,7 @@ HRCWH_SW_WATCHDOG_DISABLE |\ HRCWH_ROM_LOC_LOCAL_16BIT |\ HRCWH_TSEC1M_IN_GMII |\ - HRCWH_TSEC2M_IN_GMII ) + HRCWH_TSEC2M_IN_GMII) #endif
/* System IO Config */ @@ -527,13 +540,13 @@ #define CONFIG_SYS_SICRL SICRL_LDP_A
#define CONFIG_SYS_HID0_INIT 0x000000000 -#define CONFIG_SYS_HID0_FINAL (HID0_ENABLE_MACHINE_CHECK | \ - HID0_ENABLE_INSTRUCTION_CACHE) +#define CONFIG_SYS_HID0_FINAL (HID0_ENABLE_MACHINE_CHECK \ + | HID0_ENABLE_INSTRUCTION_CACHE)
-/* #define CONFIG_SYS_HID0_FINAL (\ +/* #define CONFIG_SYS_HID0_FINAL (\ HID0_ENABLE_INSTRUCTION_CACHE |\ HID0_ENABLE_M_BIT |\ - HID0_ENABLE_ADDRESS_BROADCAST ) */ + HID0_ENABLE_ADDRESS_BROADCAST) */
#define CONFIG_SYS_HID2 HID2_HBE @@ -541,15 +554,31 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR @ 0x00000000 */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP)
/* PCI @ 0x80000000 */ #ifdef CONFIG_PCI -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) #else #define CONFIG_SYS_IBAT1L (0) #define CONFIG_SYS_IBAT1U (0) @@ -558,10 +587,21 @@ #endif
#ifdef CONFIG_MPC83XX_PCI2 -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI2_MEM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) -#define CONFIG_SYS_IBAT3U (CONFIG_SYS_PCI2_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI2_MMIO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT4U (CONFIG_SYS_PCI2_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI2_MEM_BASE \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT3U (CONFIG_SYS_PCI2_MEM_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI2_MMIO_BASE \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT4U (CONFIG_SYS_PCI2_MMIO_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) #else #define CONFIG_SYS_IBAT3L (0) #define CONFIG_SYS_IBAT3U (0) @@ -570,12 +610,20 @@ #endif
/* SDRAM @ 0xF0000000, stack in DCACHE 0xFDF00000 & FLASH @ 0xFE000000 */ -#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_10 | BATL_MEMCOHERENCE | \ - BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT6L (0xF0000000 \ + | BATL_PP_10 \ + | BATL_MEMCOHERENCE \ + | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT6U (0xF0000000 | BATU_BL_256M | BATU_VS | BATU_VP)
#define CONFIG_SYS_IBAT7L (0) @@ -617,10 +665,11 @@ #define CONFIG_ROOTPATH /tftpboot/rootfs #define CONFIG_BOOTFILE uImage
-#define CONFIG_LOADADDR 800000 /* default location for tftp and bootm */ + /* default location for tftp and bootm */ +#define CONFIG_LOADADDR 800000
@@ -642,28 +691,29 @@ "bootm\0" \ "load=tftp 100000 /tftpboot/sbc8349/u-boot.bin\0" \ "update=protect off ff800000 ff83ffff; " \ - "era ff800000 ff83ffff; cp.b 100000 ff800000 ${filesize}\0" \ + "era ff800000 ff83ffff; cp.b 100000 ff800000 ${filesize}\0" \ "upd=run load update\0" \ "fdtaddr=780000\0" \ "fdtfile=sbc8349.dtb\0" \ ""
-#define CONFIG_NFSBOOTCOMMAND \ - "setenv bootargs root=/dev/nfs rw " \ - "nfsroot=$serverip:$rootpath " \ - "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:off " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "tftp $loadaddr $bootfile;" \ - "tftp $fdtaddr $fdtfile;" \ - "bootm $loadaddr - $fdtaddr" +#define CONFIG_NFSBOOTCOMMAND \ + "setenv bootargs root=/dev/nfs rw " \ + "nfsroot=$serverip:$rootpath " \ + "ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:" \ + "$netdev:off " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr - $fdtaddr"
#define CONFIG_RAMBOOTCOMMAND \ - "setenv bootargs root=/dev/ram rw " \ - "console=$consoledev,$baudrate $othbootargs;" \ - "tftp $ramdiskaddr $ramdiskfile;" \ - "tftp $loadaddr $bootfile;" \ - "tftp $fdtaddr $fdtfile;" \ - "bootm $loadaddr $ramdiskaddr $fdtaddr" + "setenv bootargs root=/dev/ram rw " \ + "console=$consoledev,$baudrate $othbootargs;" \ + "tftp $ramdiskaddr $ramdiskfile;" \ + "tftp $loadaddr $bootfile;" \ + "tftp $fdtaddr $fdtfile;" \ + "bootm $loadaddr $ramdiskaddr $fdtaddr"
#define CONFIG_BOOTCOMMAND "run flash_self"
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- include/configs/ve8313.h | 204 ++++++++++++++++++++++++--------------------- 1 files changed, 109 insertions(+), 95 deletions(-)
diff --git a/include/configs/ve8313.h b/include/configs/ve8313.h index abb57fe..9035383 100644 --- a/include/configs/ve8313.h +++ b/include/configs/ve8313.h @@ -70,7 +70,7 @@ /* * DDR Setup */ -#define CONFIG_SYS_DDR_BASE 0x00000000 /* DDR is system memory*/ +#define CONFIG_SYS_DDR_BASE 0x00000000 /* DDR is system memory*/ #define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_BASE #define CONFIG_SYS_DDR_SDRAM_BASE CONFIG_SYS_DDR_BASE
@@ -78,59 +78,60 @@ * Manually set up DDR parameters, as this board does not * have the SPD connected to I2C. */ -#define CONFIG_SYS_DDR_SIZE 128 /* MB */ -#define CONFIG_SYS_DDR_CONFIG ( CSCONFIG_EN \ +#define CONFIG_SYS_DDR_SIZE 128 /* MB */ +#define CONFIG_SYS_DDR_CONFIG (CSCONFIG_EN \ | CSCONFIG_AP \ | 0x00040000 /* TODO */ \ - | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10 ) + | CSCONFIG_ROW_BIT_13 \ + | CSCONFIG_COL_BIT_10) /* 0x80840102 */
#define CONFIG_SYS_DDR_TIMING_3 0x00000000 -#define CONFIG_SYS_DDR_TIMING_0 ( ( 0 << TIMING_CFG0_RWT_SHIFT ) \ - | ( 0 << TIMING_CFG0_WRT_SHIFT ) \ - | ( 3 << TIMING_CFG0_RRT_SHIFT ) \ - | ( 2 << TIMING_CFG0_WWT_SHIFT ) \ - | ( 7 << TIMING_CFG0_ACT_PD_EXIT_SHIFT ) \ - | ( 2 << TIMING_CFG0_PRE_PD_EXIT_SHIFT ) \ - | ( 8 << TIMING_CFG0_ODT_PD_EXIT_SHIFT ) \ - | ( 2 << TIMING_CFG0_MRS_CYC_SHIFT ) ) +#define CONFIG_SYS_DDR_TIMING_0 ((0 << TIMING_CFG0_RWT_SHIFT) \ + | (0 << TIMING_CFG0_WRT_SHIFT) \ + | (3 << TIMING_CFG0_RRT_SHIFT) \ + | (2 << TIMING_CFG0_WWT_SHIFT) \ + | (7 << TIMING_CFG0_ACT_PD_EXIT_SHIFT) \ + | (2 << TIMING_CFG0_PRE_PD_EXIT_SHIFT) \ + | (8 << TIMING_CFG0_ODT_PD_EXIT_SHIFT) \ + | (2 << TIMING_CFG0_MRS_CYC_SHIFT)) /* 0x0e720802 */ -#define CONFIG_SYS_DDR_TIMING_1 ( ( 2 << TIMING_CFG1_PRETOACT_SHIFT ) \ - | ( 6 << TIMING_CFG1_ACTTOPRE_SHIFT ) \ - | ( 2 << TIMING_CFG1_ACTTORW_SHIFT ) \ - | ( 5 << TIMING_CFG1_CASLAT_SHIFT ) \ - | ( 6 << TIMING_CFG1_REFREC_SHIFT ) \ - | ( 2 << TIMING_CFG1_WRREC_SHIFT ) \ - | ( 2 << TIMING_CFG1_ACTTOACT_SHIFT ) \ - | ( 2 << TIMING_CFG1_WRTORD_SHIFT ) ) +#define CONFIG_SYS_DDR_TIMING_1 ((2 << TIMING_CFG1_PRETOACT_SHIFT) \ + | (6 << TIMING_CFG1_ACTTOPRE_SHIFT) \ + | (2 << TIMING_CFG1_ACTTORW_SHIFT) \ + | (5 << TIMING_CFG1_CASLAT_SHIFT) \ + | (6 << TIMING_CFG1_REFREC_SHIFT) \ + | (2 << TIMING_CFG1_WRREC_SHIFT) \ + | (2 << TIMING_CFG1_ACTTOACT_SHIFT) \ + | (2 << TIMING_CFG1_WRTORD_SHIFT)) /* 0x26256222 */ -#define CONFIG_SYS_DDR_TIMING_2 ( ( 0 << TIMING_CFG2_ADD_LAT_SHIFT ) \ - | ( 5 << TIMING_CFG2_CPO_SHIFT ) \ - | ( 2 << TIMING_CFG2_WR_LAT_DELAY_SHIFT ) \ - | ( 1 << TIMING_CFG2_RD_TO_PRE_SHIFT ) \ - | ( 2 << TIMING_CFG2_WR_DATA_DELAY_SHIFT ) \ - | ( 3 << TIMING_CFG2_CKE_PLS_SHIFT ) \ - | ( 7 << TIMING_CFG2_FOUR_ACT_SHIFT) ) +#define CONFIG_SYS_DDR_TIMING_2 ((0 << TIMING_CFG2_ADD_LAT_SHIFT) \ + | (5 << TIMING_CFG2_CPO_SHIFT) \ + | (2 << TIMING_CFG2_WR_LAT_DELAY_SHIFT) \ + | (1 << TIMING_CFG2_RD_TO_PRE_SHIFT) \ + | (2 << TIMING_CFG2_WR_DATA_DELAY_SHIFT) \ + | (3 << TIMING_CFG2_CKE_PLS_SHIFT) \ + | (7 << TIMING_CFG2_FOUR_ACT_SHIFT)) /* 0x029028c7 */ -#define CONFIG_SYS_DDR_INTERVAL ( ( 0x320 << SDRAM_INTERVAL_REFINT_SHIFT ) \ - | ( 0x2000 << SDRAM_INTERVAL_BSTOPRE_SHIFT ) ) +#define CONFIG_SYS_DDR_INTERVAL ((0x320 << SDRAM_INTERVAL_REFINT_SHIFT) \ + | (0x2000 << SDRAM_INTERVAL_BSTOPRE_SHIFT)) /* 0x03202000 */ -#define CONFIG_SYS_SDRAM_CFG ( SDRAM_CFG_SREN \ +#define CONFIG_SYS_SDRAM_CFG (SDRAM_CFG_SREN \ | SDRAM_CFG_SDRAM_TYPE_DDR2 \ - | SDRAM_CFG_32_BE ) + | SDRAM_CFG_32_BE) /* 0x43080000 */ -#define CONFIG_SYS_SDRAM_CFG2 0x00401000 -#define CONFIG_SYS_DDR_MODE ( ( 0x4440 << SDRAM_MODE_ESD_SHIFT ) \ - | ( 0x0232 << SDRAM_MODE_SD_SHIFT ) ) +#define CONFIG_SYS_SDRAM_CFG2 0x00401000 +#define CONFIG_SYS_DDR_MODE ((0x4440 << SDRAM_MODE_ESD_SHIFT) \ + | (0x0232 << SDRAM_MODE_SD_SHIFT)) /* 0x44400232 */ -#define CONFIG_SYS_DDR_MODE_2 0x8000C000 +#define CONFIG_SYS_DDR_MODE_2 0x8000C000
#define CONFIG_SYS_DDR_CLK_CNTL DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05 /*0x02000000*/ -#define CONFIG_SYS_DDRCDR_VALUE ( DDRCDR_EN \ +#define CONFIG_SYS_DDRCDR_VALUE (DDRCDR_EN \ | DDRCDR_PZ_NOMZ \ | DDRCDR_NZ_NOMZ \ - | DDRCDR_M_ODR ) + | DDRCDR_M_ODR) /* 0x73000002 */
/* @@ -143,16 +144,16 @@ #define CONFIG_SYS_FLASH_EMPTY_INFO /* display empty sectors */ #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE /* buffer up multiple bytes */
-#define CONFIG_SYS_NOR_BR_PRELIM (CONFIG_SYS_FLASH_BASE | \ - (2 << BR_PS_SHIFT) | /* 16 bit */ \ - BR_V) /* valid */ +#define CONFIG_SYS_NOR_BR_PRELIM (CONFIG_SYS_FLASH_BASE \ + | (2 << BR_PS_SHIFT) /* 16 bit */ \ + | BR_V) /* valid */ #define CONFIG_SYS_NOR_OR_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ - | OR_GPCM_CSNT \ - | OR_GPCM_ACS_DIV4 \ - | OR_GPCM_SCY_5 \ - | OR_GPCM_TRLX \ - | OR_GPCM_EAD) - /* 0xfe000c55 */ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV4 \ + | OR_GPCM_SCY_5 \ + | OR_GPCM_TRLX \ + | OR_GPCM_EAD) + /* 0xfe000c55 */
#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000018 /* 32 MB window size */ @@ -171,10 +172,10 @@
#define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xFD000000 /* Initial RAM address */ -#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM*/ +#define CONFIG_SYS_INIT_RAM_SIZE 0x1000 /* Size of used area in RAM*/
-#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_SIZE - \ - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_GBL_DATA_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) #define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET
/* CONFIG_SYS_MONITOR_LEN must be a multiple of CONFIG_ENV_SECT_SIZE */ @@ -201,19 +202,19 @@ #define CONFIG_NAND_FSL_ELBC 1 #define CONFIG_SYS_NAND_BLOCK_SIZE 16384
-#define CONFIG_SYS_NAND_BR_PRELIM ( CONFIG_SYS_NAND_BASE \ - | BR_PS_8 \ - | BR_DECC_CHK_GEN \ - | BR_MS_FCM \ - | BR_V ) /* valid */ - /* 0x61000c21 */ +#define CONFIG_SYS_NAND_BR_PRELIM (CONFIG_SYS_NAND_BASE \ + | BR_PS_8 \ + | BR_DECC_CHK_GEN \ + | BR_MS_FCM \ + | BR_V) /* valid */ + /* 0x61000c21 */ #define CONFIG_SYS_NAND_OR_PRELIM (0xffff8000 \ - | OR_FCM_BCTLD \ - | OR_FCM_CHT \ - | OR_FCM_SCY_2 \ - | OR_FCM_RST \ - | OR_FCM_TRLX) - /* 0xffff90ac */ + | OR_FCM_BCTLD \ + | OR_FCM_CHT \ + | OR_FCM_SCY_2 \ + | OR_FCM_RST \ + | OR_FCM_TRLX) + /* 0xffff90ac */
#define CONFIG_SYS_BR0_PRELIM CONFIG_SYS_NOR_BR_PRELIM #define CONFIG_SYS_OR0_PRELIM CONFIG_SYS_NOR_OR_PRELIM @@ -227,27 +228,27 @@ #define CONFIG_SYS_NAND_LBLAWAR_PRELIM CONFIG_SYS_LBLAWAR1_PRELIM
/* CS2 NvRAM */ -#define CONFIG_SYS_BR2_PRELIM (0x60000000 \ - | BR_PS_8 \ +#define CONFIG_SYS_BR2_PRELIM (0x60000000 \ + | BR_PS_8 \ | BR_V) /* 0x60000801 */ -#define CONFIG_SYS_OR2_PRELIM (0xfffe0000 \ - | OR_GPCM_CSNT \ - | OR_GPCM_XACS \ +#define CONFIG_SYS_OR2_PRELIM (0xfffe0000 \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ | OR_GPCM_SCY_3 \ | OR_GPCM_TRLX \ | OR_GPCM_EHTR \ | OR_GPCM_EAD) /* 0xfffe0937 */ /* local bus read write buffer mapping SRAM@0x64000000 */ -#define CONFIG_SYS_BR3_PRELIM (0x62000000 \ - | BR_PS_16 \ +#define CONFIG_SYS_BR3_PRELIM (0x62000000 \ + | BR_PS_16 \ | BR_V) /* 0x62001001 */
-#define CONFIG_SYS_OR3_PRELIM (0xfe000000 \ - | OR_GPCM_CSNT \ - | OR_GPCM_XACS \ +#define CONFIG_SYS_OR3_PRELIM (0xfe000000 \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ | OR_GPCM_SCY_15 \ | OR_GPCM_TRLX \ | OR_GPCM_EHTR \ @@ -289,9 +290,9 @@ #define CONFIG_SYS_PCI1_MMIO_BASE 0x90000000 #define CONFIG_SYS_PCI1_MMIO_PHYS CONFIG_SYS_PCI1_MMIO_BASE #define CONFIG_SYS_PCI1_MMIO_SIZE 0x10000000 /* 256M */ -#define CONFIG_SYS_PCI1_IO_BASE 0x00000000 -#define CONFIG_SYS_PCI1_IO_PHYS 0xE2000000 -#define CONFIG_SYS_PCI1_IO_SIZE 0x00100000 /* 1M */ +#define CONFIG_SYS_PCI1_IO_BASE 0x00000000 +#define CONFIG_SYS_PCI1_IO_PHYS 0xE2000000 +#define CONFIG_SYS_PCI1_IO_SIZE 0x00100000 /* 1M */
#define CONFIG_PCI_PNP /* do pci plug-and-play */ #define CONFIG_SYS_PCI_SUBSYS_VENDORID 0x1957 /* Freescale */ @@ -321,13 +322,13 @@ * Environment */ #define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + \ - CONFIG_SYS_MONITOR_LEN) +#define CONFIG_ENV_ADDR \ + (CONFIG_SYS_FLASH_BASE + CONFIG_SYS_MONITOR_LEN) #define CONFIG_ENV_SECT_SIZE 0x20000 /* 128K(one sector) for env */ #define CONFIG_ENV_SIZE 0x4000 /* Address and size of Redundant Environment Sector */ -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET + \ - CONFIG_ENV_SECT_SIZE) +#define CONFIG_ENV_OFFSET_REDUND \ + (CONFIG_ENV_OFFSET + CONFIG_ENV_SECT_SIZE) #define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE)
#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ @@ -372,7 +373,8 @@ * have to be in the first 256 MB of memory, since this is * the maximum mapped by the Linux kernel during initialization. */ -#define CONFIG_SYS_BOOTMAPSZ (256 << 20) /* Initial Memory map for Linux*/ + /* Initial Memory map for Linux*/ +#define CONFIG_SYS_BOOTMAPSZ (256 << 20)
/* 0x64050000 */ #define CONFIG_SYS_HRCW_LOW (\ @@ -422,18 +424,26 @@
/* DDR @ 0x00000000 */ #define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10) -#define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | \ - BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP)
#if defined(CONFIG_PCI) /* PCI @ 0x80000000 */ #define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10) -#define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE | BATU_BL_256M | \ - BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_10 | \ - BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE | BATU_BL_256M | \ - BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP) #else #define CONFIG_SYS_IBAT1L (0) #define CONFIG_SYS_IBAT1U (0) @@ -448,10 +458,14 @@ #define CONFIG_SYS_IBAT4U (0)
/* IMMRBAR @ 0xE0000000, PCI IO @ 0xE2000000 & BCSR @ 0xE2400000 */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR | BATL_PP_10 | \ - BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT5U (CONFIG_SYS_IMMR | BATU_BL_256M | BATU_VS | \ - BATU_VP) +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR \ + | BATL_PP_10 \ + | BATL_CACHEINHIBIT \ + | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT5U (CONFIG_SYS_IMMR \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP)
/* stack in DCACHE 0xFDF00000 & FLASH @ 0xFE000000 */ #define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_10 | BATL_GUARDEDSTORAGE) @@ -496,10 +510,10 @@ "u-boot_addr_r=100000\0" \ "load=tftp ${u-boot_addr_r} ${u-boot}\0" \ "update=protect off " MK_STR(CONFIG_SYS_FLASH_BASE) " +${filesize};" \ - "erase " MK_STR(CONFIG_SYS_FLASH_BASE) " +${filesize};" \ - "cp.b ${u-boot_addr_r} " MK_STR(CONFIG_SYS_FLASH_BASE) \ - " ${filesize};" \ - "protect on " MK_STR(CONFIG_SYS_FLASH_BASE) " +${filesize}\0" \ + "erase " MK_STR(CONFIG_SYS_FLASH_BASE) " +${filesize};" \ + "cp.b ${u-boot_addr_r} " MK_STR(CONFIG_SYS_FLASH_BASE) \ + " ${filesize};" \ + "protect on " MK_STR(CONFIG_SYS_FLASH_BASE) " +${filesize}\0" \
#undef MK_STR #undef XMK_STR
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- include/configs/vme8349.h | 35 ++++++++++++++++++----------------- 1 files changed, 18 insertions(+), 17 deletions(-)
diff --git a/include/configs/vme8349.h b/include/configs/vme8349.h index d153762..6a34537 100644 --- a/include/configs/vme8349.h +++ b/include/configs/vme8349.h @@ -151,7 +151,7 @@ #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 /* Flash Erase TO (ms) */ #define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write TO (ms) */
-#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */
#if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) #define CONFIG_SYS_RAMBOOT @@ -191,7 +191,7 @@ #define CONFIG_SYS_NS16550_CLK get_bus_freq(0)
#define CONFIG_SYS_BAUDRATE_TABLE \ - {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 115200} + {300, 600, 1200, 2400, 4800, 9600, 19200, 38400, 115200}
#define CONFIG_SYS_NS16550_COM1 (CONFIG_SYS_IMMR + 0x4500) #define CONFIG_SYS_NS16550_COM2 (CONFIG_SYS_IMMR + 0x4600) @@ -217,7 +217,7 @@ #define CONFIG_I2C_CMD_TREE #define CONFIG_SYS_I2C_SPEED 400000 /* I2C speed and slave address */ #define CONFIG_SYS_I2C_SLAVE 0x7F -#define CONFIG_SYS_I2C_NOPROBES {{0, 0x69}} /* Don't probe these addrs */ +#define CONFIG_SYS_I2C_NOPROBES { {0, 0x69} } /* Don't probe these addrs */ #define CONFIG_SYS_I2C1_OFFSET 0x3000 #define CONFIG_SYS_I2C2_OFFSET 0x3100 #define CONFIG_SYS_I2C_OFFSET CONFIG_SYS_I2C1_OFFSET @@ -589,22 +589,23 @@ "fdtfile=vme8349.dtb\0" \ ""
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- include/configs/MERGERBOX.h | 14 +++++++------- include/configs/MPC8308RDB.h | 10 +++++----- include/configs/MPC8313ERDB.h | 10 +++++----- include/configs/MPC8315ERDB.h | 14 +++++++------- include/configs/MPC8323ERDB.h | 14 +++++++------- include/configs/MPC832XEMDS.h | 16 ++++++++-------- include/configs/MPC8349EMDS.h | 19 +++++++++---------- include/configs/MPC8349ITX.h | 14 +++++++------- include/configs/MPC8360EMDS.h | 18 +++++++++--------- include/configs/MPC8360ERDK.h | 18 +++++++++--------- include/configs/MPC837XEMDS.h | 18 +++++++++--------- include/configs/MPC837XERDB.h | 18 +++++++++--------- include/configs/MVBLM7.h | 13 ++++++------- include/configs/SIMPC8313.h | 12 ++++++------ include/configs/TQM834x.h | 16 ++++++++-------- include/configs/km/km83xx-common.h | 14 +++++++------- include/configs/kmeter1.h | 8 ++++---- include/configs/kmsupx5.h | 4 ++-- include/configs/mpc8308_p1m.h | 10 +++++----- include/configs/sbc8349.h | 14 +++++++------- include/configs/suvd3.h | 8 ++++---- include/configs/tuda1.h | 8 ++++---- include/configs/tuxa1.h | 8 ++++---- include/configs/ve8313.h | 12 ++++++------ include/configs/vme8349.h | 16 ++++++++-------- 25 files changed, 162 insertions(+), 164 deletions(-)
diff --git a/include/configs/MERGERBOX.h b/include/configs/MERGERBOX.h index 105a45a..15cd646 100644 --- a/include/configs/MERGERBOX.h +++ b/include/configs/MERGERBOX.h @@ -409,7 +409,7 @@ /* DDR: cache cacheable */ #define CONFIG_SYS_SDRAM CONFIG_SYS_SDRAM_BASE
-#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM | BATL_PP_10 |\ +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM | BATL_PP_RW |\ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM | BATU_BL_256M | BATU_VS |\ BATU_VP) @@ -423,7 +423,7 @@ #define CONFIG_SYS_DBAT1U CONFIG_SYS_IBAT1U
/* IMMRBAR, PCI IO and NAND: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_IMMR | BATL_PP_10 |\ +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_IMMR | BATL_PP_RW |\ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_IMMR | BATU_BL_8M | BATU_VS |\ BATU_VP) @@ -437,23 +437,23 @@ #define CONFIG_SYS_DBAT3U CONFIG_SYS_IBAT3U
/* FLASH: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 |\ +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW |\ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_FLASH_BASE | BATU_BL_64M |\ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT4L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT4L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT4U CONFIG_SYS_IBAT4U
/* Stack in dcache: cacheable, no memory coherence */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10) +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_RW) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_INIT_RAM_ADDR | BATU_BL_128K |\ BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT5L CONFIG_SYS_IBAT5L #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U
/* PCI MEM space: cacheable */ -#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI_MEM_PHYS | BATL_PP_10 |\ +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI_MEM_PHYS | BATL_PP_RW |\ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI_MEM_PHYS | BATU_BL_256M |\ BATU_VS | BATU_VP) @@ -461,7 +461,7 @@ #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U
/* PCI MMIO space: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI_MMIO_PHYS | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI_MMIO_PHYS | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT7U (CONFIG_SYS_PCI_MMIO_PHYS | BATU_BL_256M |\ BATU_VS | BATU_VP) diff --git a/include/configs/MPC8308RDB.h b/include/configs/MPC8308RDB.h index e6b83c8..6a39cee 100644 --- a/include/configs/MPC8308RDB.h +++ b/include/configs/MPC8308RDB.h @@ -464,7 +464,7 @@ */
/* DDR: cache cacheable */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_128M | \ BATU_VS | BATU_VP) @@ -472,7 +472,7 @@ #define CONFIG_SYS_DBAT0U CONFIG_SYS_IBAT0U
/* IMMRBAR, PCI IO and NAND: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_IMMR | BATU_BL_8M | BATU_VS | \ BATU_VP) @@ -480,17 +480,17 @@ #define CONFIG_SYS_DBAT1U CONFIG_SYS_IBAT1U
/* FLASH: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_FLASH_BASE | BATU_BL_8M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | \ BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT2U CONFIG_SYS_IBAT2U
/* Stack in dcache: cacheable, no memory coherence */ -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_RW) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_INIT_RAM_ADDR | BATU_BL_128K | \ BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT3L CONFIG_SYS_IBAT3L diff --git a/include/configs/MPC8313ERDB.h b/include/configs/MPC8313ERDB.h index edcd085..dde03ee 100644 --- a/include/configs/MPC8313ERDB.h +++ b/include/configs/MPC8313ERDB.h @@ -562,20 +562,20 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR @ 0x00000000 */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE \ | BATU_BL_256M \ | BATU_VS \ | BATU_VP)
/* PCI @ 0x80000000 */ -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10) +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_RW) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE \ | BATU_BL_256M \ | BATU_VS \ | BATU_VP) #define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE \ @@ -591,7 +591,7 @@
/* IMMRBAR @ 0xE0000000, PCI IO @ 0xE2000000 & BCSR @ 0xE2400000 */ #define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_IMMR \ @@ -600,7 +600,7 @@ | BATU_VP)
/* SDRAM @ 0xF0000000, stack in DCACHE 0xFDF00000 & FLASH @ 0xFE000000 */ -#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_10 | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_RW | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT6U (0xF0000000 | BATU_BL_256M | BATU_VS | BATU_VP)
#define CONFIG_SYS_IBAT7L (0) diff --git a/include/configs/MPC8315ERDB.h b/include/configs/MPC8315ERDB.h index 62ecfdc..81a3491 100644 --- a/include/configs/MPC8315ERDB.h +++ b/include/configs/MPC8315ERDB.h @@ -577,7 +577,7 @@
/* DDR: cache cacheable */ #define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE \ | BATU_BL_128M \ @@ -588,7 +588,7 @@
/* IMMRBAR, PCI IO and NAND: cache-inhibit and guarded */ #define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_IMMR \ @@ -600,20 +600,20 @@
/* FLASH: icache cacheable, but dcache-inhibit and guarded */ #define CONFIG_SYS_IBAT2L (CONFIG_SYS_FLASH_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_FLASH_BASE \ | BATU_BL_32M \ | BATU_VS \ | BATU_VP) #define CONFIG_SYS_DBAT2L (CONFIG_SYS_FLASH_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT2U CONFIG_SYS_IBAT2U
/* Stack in dcache: cacheable, no memory coherence */ -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_RW) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_INIT_RAM_ADDR \ | BATU_BL_128K \ | BATU_VS \ @@ -623,7 +623,7 @@
/* PCI MEM space: cacheable */ #define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI_MEM_PHYS \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_PCI_MEM_PHYS \ | BATU_BL_256M \ @@ -634,7 +634,7 @@
/* PCI MMIO space: cache-inhibit and guarded */ #define CONFIG_SYS_IBAT5L (CONFIG_SYS_PCI_MMIO_PHYS \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_PCI_MMIO_PHYS \ diff --git a/include/configs/MPC8323ERDB.h b/include/configs/MPC8323ERDB.h index 957090d..a27d33c 100644 --- a/include/configs/MPC8323ERDB.h +++ b/include/configs/MPC8323ERDB.h @@ -460,7 +460,7 @@
/* DDR: cache cacheable */ #define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE \ | BATU_BL_256M \ @@ -471,7 +471,7 @@
/* IMMRBAR & PCI IO: cache-inhibit and guarded */ #define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_IMMR \ @@ -483,14 +483,14 @@
/* FLASH: icache cacheable, but dcache-inhibit and guarded */ #define CONFIG_SYS_IBAT2L (CONFIG_SYS_FLASH_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_FLASH_BASE \ | BATU_BL_32M \ | BATU_VS \ | BATU_VP) #define CONFIG_SYS_DBAT2L (CONFIG_SYS_FLASH_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT2U CONFIG_SYS_IBAT2U @@ -501,7 +501,7 @@ #define CONFIG_SYS_DBAT3U CONFIG_SYS_IBAT3U
/* Stack in dcache: cacheable, no memory coherence */ -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10) +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_RW) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_INIT_RAM_ADDR \ | BATU_BL_128K \ | BATU_VS \ @@ -512,7 +512,7 @@ #ifdef CONFIG_PCI /* PCI MEM space: cacheable */ #define CONFIG_SYS_IBAT5L (CONFIG_SYS_PCI1_MEM_PHYS \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_PCI1_MEM_PHYS \ | BATU_BL_256M \ @@ -522,7 +522,7 @@ #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U /* PCI MMIO space: cache-inhibit and guarded */ #define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI1_MMIO_PHYS \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI1_MMIO_PHYS \ diff --git a/include/configs/MPC832XEMDS.h b/include/configs/MPC832XEMDS.h index 9e65b00..d276be4 100644 --- a/include/configs/MPC832XEMDS.h +++ b/include/configs/MPC832XEMDS.h @@ -483,7 +483,7 @@
/* DDR: cache cacheable */ #define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE \ | BATU_BL_256M \ @@ -494,7 +494,7 @@
/* IMMRBAR & PCI IO: cache-inhibit and guarded */ #define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_IMMR \ @@ -506,7 +506,7 @@
/* BCSR: cache-inhibit and guarded */ #define CONFIG_SYS_IBAT2L (CONFIG_SYS_BCSR \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_BCSR \ @@ -518,14 +518,14 @@
/* FLASH: icache cacheable, but dcache-inhibit and guarded */ #define CONFIG_SYS_IBAT3L (CONFIG_SYS_FLASH_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_FLASH_BASE \ | BATU_BL_32M \ | BATU_VS \ | BATU_VP) #define CONFIG_SYS_DBAT3L (CONFIG_SYS_FLASH_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT3U CONFIG_SYS_IBAT3U @@ -536,7 +536,7 @@ #define CONFIG_SYS_DBAT4U CONFIG_SYS_IBAT4U
/* Stack in dcache: cacheable, no memory coherence */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10) +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_RW) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_INIT_RAM_ADDR \ | BATU_BL_128K \ | BATU_VS \ @@ -547,7 +547,7 @@ #ifdef CONFIG_PCI /* PCI MEM space: cacheable */ #define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI1_MEM_PHYS \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI1_MEM_PHYS \ | BATU_BL_256M \ @@ -557,7 +557,7 @@ #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U /* PCI MMIO space: cache-inhibit and guarded */ #define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI1_MMIO_PHYS \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT7U (CONFIG_SYS_PCI1_MMIO_PHYS \ diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index b377650..f720797 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -633,7 +633,7 @@
/* DDR @ 0x00000000 */ #define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE \ | BATU_BL_256M \ @@ -643,14 +643,14 @@ /* PCI @ 0x80000000 */ #ifdef CONFIG_PCI #define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE \ | BATU_BL_256M \ | BATU_VS \ | BATU_VP) #define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE \ @@ -666,14 +666,14 @@
#ifdef CONFIG_MPC83XX_PCI2 #define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI2_MEM_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_PCI2_MEM_BASE \ | BATU_BL_256M \ | BATU_VS \ | BATU_VP) #define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI2_MMIO_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_PCI2_MMIO_BASE \ @@ -689,7 +689,7 @@
/* IMMRBAR @ 0xE0000000, PCI IO @ 0xE2000000 & BCSR @ 0xE2400000 */ #define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_IMMR \ @@ -699,10 +699,9 @@
/* SDRAM @ 0xF0000000, stack in DCACHE 0xFDF00000 & FLASH @ 0xFE000000 */ #define CONFIG_SYS_IBAT6L (0xF0000000 \ - | BATL_PP_10 \ - | BATL_MEMCOHERENCE |\ - \ - BATL_GUARDEDSTORAGE) + | BATL_PP_RW \ + | BATL_MEMCOHERENCE \ + | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT6U (0xF0000000 \ | BATU_BL_256M \ | BATU_VS \ diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index c98c675..8ad494f 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -648,7 +648,7 @@ boards, we say we have two, but don't display a message if we find only one. */
/* DDR */ #define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE \ | BATU_BL_256M \ @@ -658,14 +658,14 @@ boards, we say we have two, but don't display a message if we find only one. */ /* PCI */ #ifdef CONFIG_PCI #define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE \ | BATU_BL_256M \ | BATU_VS \ | BATU_VP) #define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE \ @@ -681,14 +681,14 @@ boards, we say we have two, but don't display a message if we find only one. */
#ifdef CONFIG_MPC83XX_PCI2 #define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI2_MEM_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_PCI2_MEM_BASE \ | BATU_BL_256M \ | BATU_VS \ | BATU_VP) #define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI2_MMIO_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_PCI2_MMIO_BASE \ @@ -704,7 +704,7 @@ boards, we say we have two, but don't display a message if we find only one. */
/* IMMRBAR @ 0xE0000000, PCI IO @ 0xE2000000 & BCSR @ 0xE2400000 */ #define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_IMMR \ @@ -714,7 +714,7 @@ boards, we say we have two, but don't display a message if we find only one. */
/* SDRAM @ 0xF0000000, stack in DCACHE 0xFDF00000 & FLASH @ 0xFE000000 */ #define CONFIG_SYS_IBAT6L (0xF0000000 \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT6U (0xF0000000 \ diff --git a/include/configs/MPC8360EMDS.h b/include/configs/MPC8360EMDS.h index 5c6b1ac..3af4b9a 100644 --- a/include/configs/MPC8360EMDS.h +++ b/include/configs/MPC8360EMDS.h @@ -527,7 +527,7 @@
/* DDR/LBC SDRAM: cacheable */ #define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE \ | BATU_BL_256M \ @@ -538,7 +538,7 @@
/* IMMRBAR & PCI IO: cache-inhibit and guarded */ #define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_IMMR \ @@ -550,7 +550,7 @@
/* BCSR: cache-inhibit and guarded */ #define CONFIG_SYS_IBAT2L (CONFIG_SYS_BCSR \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_BCSR \ @@ -562,21 +562,21 @@
/* DDR/LBC SDRAM next 256M: cacheable */ #define CONFIG_SYS_IBAT4L (CONFIG_SYS_SDRAM_BASE2 \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_SDRAM_BASE2 \ | BATU_BL_256M \ @@ -586,7 +586,7 @@ #define CONFIG_SYS_DBAT4U CONFIG_SYS_IBAT4U
/* Stack in dcache: cacheable, no memory coherence */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10) +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_RW) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_INIT_RAM_ADDR \ | BATU_BL_128K \ | BATU_VS \ @@ -597,7 +597,7 @@ #ifdef CONFIG_PCI /* PCI MEM space: cacheable */ #define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI1_MEM_PHYS \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI1_MEM_PHYS \ | BATU_BL_256M \ @@ -607,7 +607,7 @@ #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U /* PCI MMIO space: cache-inhibit and guarded */ #define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI1_MMIO_PHYS \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT7U (CONFIG_SYS_PCI1_MMIO_PHYS \ diff --git a/include/configs/MPC8360ERDK.h b/include/configs/MPC8360ERDK.h index 33fb937..a5cba19 100644 --- a/include/configs/MPC8360ERDK.h +++ b/include/configs/MPC8360ERDK.h @@ -437,7 +437,7 @@
/* DDR: cache cacheable */ #define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE \ | BATU_BL_256M \ @@ -448,7 +448,7 @@
/* IMMRBAR & PCI IO: cache-inhibit and guarded */ #define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_IMMR \ @@ -460,7 +460,7 @@
/* NAND: cache-inhibit and guarded */ #define CONFIG_SYS_IBAT2L (CONFIG_SYS_NAND_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_NAND_BASE \ @@ -472,21 +472,21 @@
/* Stack in dcache: cacheable, no memory coherence */ #define CONFIG_SYS_IBAT4L (CONFIG_SYS_INIT_RAM_ADDR \ - | BATL_PP_10) + | BATL_PP_RW) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_INIT_RAM_ADDR \ | BATU_BL_128K \ | BATU_VS \ @@ -495,7 +495,7 @@ #define CONFIG_SYS_DBAT4U CONFIG_SYS_IBAT4U
#define CONFIG_SYS_IBAT5L (CONFIG_SYS_VIDEO_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_VIDEO_BASE \ @@ -508,7 +508,7 @@ #ifdef CONFIG_PCI /* PCI MEM space: cacheable */ #define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI1_MEM_PHYS \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI1_MEM_PHYS \ | BATU_BL_256M \ @@ -518,7 +518,7 @@ #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U /* PCI MMIO space: cache-inhibit and guarded */ #define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI1_MMIO_PHYS \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT7U (CONFIG_SYS_PCI1_MMIO_PHYS \ diff --git a/include/configs/MPC837XEMDS.h b/include/configs/MPC837XEMDS.h index 6a6621f..c17cec9 100644 --- a/include/configs/MPC837XEMDS.h +++ b/include/configs/MPC837XEMDS.h @@ -569,7 +569,7 @@ extern int board_pci_host_broken(void); #define CONFIG_SYS_SDRAM_UPPER (CONFIG_SYS_SDRAM_BASE + 0x10000000)
#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_LOWER \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_LOWER \ | BATU_BL_256M \ @@ -579,7 +579,7 @@ extern int board_pci_host_broken(void); #define CONFIG_SYS_DBAT0U CONFIG_SYS_IBAT0U
#define CONFIG_SYS_IBAT1L (CONFIG_SYS_SDRAM_UPPER \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_SDRAM_UPPER \ | BATU_BL_256M \ @@ -590,7 +590,7 @@ extern int board_pci_host_broken(void);
/* IMMRBAR, PCI IO and NAND: cache-inhibit and guarded */ #define CONFIG_SYS_IBAT2L (CONFIG_SYS_IMMR \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_IMMR \ @@ -602,7 +602,7 @@ extern int board_pci_host_broken(void);
/* BCSR: cache-inhibit and guarded */ #define CONFIG_SYS_IBAT3L (CONFIG_SYS_BCSR \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_BCSR \ @@ -614,20 +614,20 @@ extern int board_pci_host_broken(void);
/* FLASH: icache cacheable, but dcache-inhibit and guarded */ #define CONFIG_SYS_IBAT4L (CONFIG_SYS_FLASH_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_FLASH_BASE \ | BATU_BL_32M \ | BATU_VS \ | BATU_VP) #define CONFIG_SYS_DBAT4L (CONFIG_SYS_FLASH_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT4U CONFIG_SYS_IBAT4U
/* Stack in dcache: cacheable, no memory coherence */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10) +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_RW) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_INIT_RAM_ADDR \ | BATU_BL_128K \ | BATU_VS \ @@ -638,7 +638,7 @@ extern int board_pci_host_broken(void); #ifdef CONFIG_PCI /* PCI MEM space: cacheable */ #define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI_MEM_PHYS \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI_MEM_PHYS \ | BATU_BL_256M \ @@ -648,7 +648,7 @@ extern int board_pci_host_broken(void); #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U /* PCI MMIO space: cache-inhibit and guarded */ #define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI_MMIO_PHYS \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT7U (CONFIG_SYS_PCI_MMIO_PHYS \ diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index 405589d..a0f8085 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -576,7 +576,7 @@ #define CONFIG_SYS_SDRAM_UPPER (CONFIG_SYS_SDRAM_BASE + 0x10000000)
#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_LOWER \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_LOWER \ | BATU_BL_256M \ @@ -586,7 +586,7 @@ #define CONFIG_SYS_DBAT0U CONFIG_SYS_IBAT0U
#define CONFIG_SYS_IBAT1L (CONFIG_SYS_SDRAM_UPPER \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_SDRAM_UPPER \ | BATU_BL_256M \ @@ -597,7 +597,7 @@
/* IMMRBAR, PCI IO and NAND: cache-inhibit and guarded */ #define CONFIG_SYS_IBAT2L (CONFIG_SYS_IMMR \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_IMMR \ @@ -609,7 +609,7 @@
/* L2 Switch: cache-inhibit and guarded */ #define CONFIG_SYS_IBAT3L (CONFIG_SYS_VSC7385_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_VSC7385_BASE \ @@ -621,20 +621,20 @@
/* Stack in dcache: cacheable, no memory coherence */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10) +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_RW) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_INIT_RAM_ADDR \ | BATU_BL_128K \ | BATU_VS \ @@ -645,7 +645,7 @@ #ifdef CONFIG_PCI /* PCI MEM space: cacheable */ #define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI_MEM_PHYS \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI_MEM_PHYS \ | BATU_BL_256M \ @@ -655,7 +655,7 @@ #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U /* PCI MMIO space: cache-inhibit and guarded */ #define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI_MMIO_PHYS \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT7U (CONFIG_SYS_PCI_MMIO_PHYS \ diff --git a/include/configs/MVBLM7.h b/include/configs/MVBLM7.h index 4b3917e..7e9c5f3 100644 --- a/include/configs/MVBLM7.h +++ b/include/configs/MVBLM7.h @@ -345,7 +345,7 @@
/* DDR */ #define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE \ | BATU_BL_256M \ @@ -354,14 +354,14 @@
/* PCI */ #define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE \ | BATU_BL_256M \ | BATU_VS \ | BATU_VP) #define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE \ @@ -377,7 +377,7 @@
/* IMMRBAR @ 0xE0000000, PCI IO @ 0xE2000000 & BCSR @ 0xE2400000 */ #define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_IMMR \ @@ -387,10 +387,9 @@
/* stack in DCACHE 0xFDF00000 & FLASH @ 0xFF800000 */ #define CONFIG_SYS_IBAT6L (0xF0000000 \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE \ - | \ - BATL_GUARDEDSTORAGE) + | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT6U (0xF0000000 \ | BATU_BL_256M \ | BATU_VS \ diff --git a/include/configs/SIMPC8313.h b/include/configs/SIMPC8313.h index 3c8f221..3eb6f65 100644 --- a/include/configs/SIMPC8313.h +++ b/include/configs/SIMPC8313.h @@ -448,26 +448,26 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR @ 0x00000000 */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE \ | BATU_BL_256M \ | BATU_VS \ | BATU_VP) #define CONFIG_SYS_IBAT1L ((CONFIG_SYS_SDRAM_BASE + 0x10000000) \ - | BATL_PP_10) + | BATL_PP_RW) #define CONFIG_SYS_IBAT1U ((CONFIG_SYS_SDRAM_BASE + 0x10000000) \ | BATU_BL_256M \ | BATU_VS \ | BATU_VP)
/* PCI @ 0x80000000 */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10) +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_RW) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MEM_BASE \ | BATU_BL_256M \ | BATU_VS \ | BATU_VP) #define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI1_MMIO_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_PCI1_MMIO_BASE \ @@ -481,7 +481,7 @@
/* IMMRBAR @ 0xE0000000, PCI IO @ 0xE2000000 */ #define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_IMMR \ @@ -491,7 +491,7 @@
/* SDRAM @ 0xF0000000, stack in DCACHE 0xFDF00000 & FLASH @ 0xFE000000 */ #define CONFIG_SYS_IBAT6L (0xF0000000 \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT6U (0xF0000000 \ | BATU_BL_256M \ diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index 8b8c604..1abfbb2 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -425,14 +425,14 @@
/* DDR 0 - 512M */ #define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE \ | BATU_BL_256M \ | BATU_VS \ | BATU_VP) #define CONFIG_SYS_IBAT1L (CONFIG_SYS_SDRAM_BASE + 0x10000000 \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_SDRAM_BASE + 0x10000000 \ | BATU_BL_256M \ @@ -441,7 +441,7 @@
/* stack in DCACHE @ 512M (no backing mem) */ #define CONFIG_SYS_IBAT2L (CONFIG_SYS_INIT_RAM_ADDR \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_INIT_RAM_ADDR \ | BATU_BL_128K \ @@ -451,14 +451,14 @@ /* PCI */ #ifdef CONFIG_PCI #define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI1_MEM_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_PCI1_MEM_BASE \ | BATU_BL_256M \ | BATU_VS \ | BATU_VP) #define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI1_MMIO_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_PCI1_MMIO_BASE \ @@ -466,7 +466,7 @@ | BATU_VS \ | BATU_VP) #define CONFIG_SYS_IBAT5L (CONFIG_SYS_PCI1_IO_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_PCI1_IO_BASE \ @@ -484,7 +484,7 @@
/* IMMRBAR */ #define CONFIG_SYS_IBAT6L (CONFIG_SYS_IMMR \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_IMMR \ @@ -494,7 +494,7 @@
/* FLASH */ #define CONFIG_SYS_IBAT7L (CONFIG_SYS_FLASH_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT7U (CONFIG_SYS_FLASH_BASE \ diff --git a/include/configs/km/km83xx-common.h b/include/configs/km/km83xx-common.h index 2b1a84a..9d28d8e 100644 --- a/include/configs/km/km83xx-common.h +++ b/include/configs/km/km83xx-common.h @@ -242,7 +242,7 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR: cache cacheable */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) @@ -250,7 +250,7 @@ #define CONFIG_SYS_DBAT0U CONFIG_SYS_IBAT0U
/* IMMRBAR & PCI IO: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_IMMR | BATU_BL_4M | BATU_VS \ | BATU_VP) @@ -258,25 +258,25 @@ #define CONFIG_SYS_DBAT1U CONFIG_SYS_IBAT1U
/* PRIO1, PIGGY: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_KMBEC_FPGA_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_KMBEC_FPGA_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_KMBEC_FPGA_BASE | BATU_BL_128M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT2L (CONFIG_SYS_KMBEC_FPGA_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT2L (CONFIG_SYS_KMBEC_FPGA_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT2U CONFIG_SYS_IBAT2U
/* FLASH: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_FLASH_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT3L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT3L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT3U CONFIG_SYS_IBAT3U
/* Stack in dcache: cacheable, no memory coherence */ -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10) +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_RW) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_INIT_RAM_ADDR | BATU_BL_128K | \ BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT4L CONFIG_SYS_IBAT4L diff --git a/include/configs/kmeter1.h b/include/configs/kmeter1.h index 3ae171b..5f68dc9 100644 --- a/include/configs/kmeter1.h +++ b/include/configs/kmeter1.h @@ -151,22 +151,22 @@ */
/* PAXE: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_PAXE_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_PAXE_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_PAXE_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT5L (CONFIG_SYS_PAXE_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT5L (CONFIG_SYS_PAXE_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U
#ifdef CONFIG_PCI /* PCI MEM space: cacheable */ -#define CFG_IBAT6L (CFG_PCI1_MEM_PHYS | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CFG_IBAT6L (CFG_PCI1_MEM_PHYS | BATL_PP_RW | BATL_MEMCOHERENCE) #define CFG_IBAT6U (CFG_PCI1_MEM_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CFG_DBAT6L CFG_IBAT6L #define CFG_DBAT6U CFG_IBAT6U /* PCI MMIO space: cache-inhibit and guarded */ -#define CFG_IBAT7L (CFG_PCI1_MMIO_PHYS | BATL_PP_10 | \ +#define CFG_IBAT7L (CFG_PCI1_MMIO_PHYS | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CFG_IBAT7U (CFG_PCI1_MMIO_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CFG_DBAT7L CFG_IBAT7L diff --git a/include/configs/kmsupx5.h b/include/configs/kmsupx5.h index f8cd8e0..ccc1561 100644 --- a/include/configs/kmsupx5.h +++ b/include/configs/kmsupx5.h @@ -74,11 +74,11 @@ OR_GPCM_EAD)
/* LPXF: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_LPXF_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_LPXF_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_LPXF_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT5L (CONFIG_SYS_LPXF_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT5L (CONFIG_SYS_LPXF_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U
diff --git a/include/configs/mpc8308_p1m.h b/include/configs/mpc8308_p1m.h index 635afec..ba71d9f 100644 --- a/include/configs/mpc8308_p1m.h +++ b/include/configs/mpc8308_p1m.h @@ -455,7 +455,7 @@ */
/* DDR: cache cacheable */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_128M | \ BATU_VS | BATU_VP) @@ -463,7 +463,7 @@ #define CONFIG_SYS_DBAT0U CONFIG_SYS_IBAT0U
/* IMMRBAR, PCI IO and NAND: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_IMMR | BATU_BL_8M | BATU_VS | \ BATU_VP) @@ -471,17 +471,17 @@ #define CONFIG_SYS_DBAT1U CONFIG_SYS_IBAT1U
/* Stack in dcache: cacheable, no memory coherence */ -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_RW) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_INIT_RAM_ADDR | BATU_BL_128K | \ BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT3L CONFIG_SYS_IBAT3L diff --git a/include/configs/sbc8349.h b/include/configs/sbc8349.h index d6207dd..9a16e74 100644 --- a/include/configs/sbc8349.h +++ b/include/configs/sbc8349.h @@ -555,7 +555,7 @@
/* DDR @ 0x00000000 */ #define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE \ | BATU_BL_256M \ @@ -565,14 +565,14 @@ /* PCI @ 0x80000000 */ #ifdef CONFIG_PCI #define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE \ | BATU_BL_256M \ | BATU_VS \ | BATU_VP) #define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE \ @@ -588,14 +588,14 @@
#ifdef CONFIG_MPC83XX_PCI2 #define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI2_MEM_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_PCI2_MEM_BASE \ | BATU_BL_256M \ | BATU_VS \ | BATU_VP) #define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI2_MMIO_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_PCI2_MMIO_BASE \ @@ -611,7 +611,7 @@
/* IMMRBAR @ 0xE0000000, PCI IO @ 0xE2000000 */ #define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_IMMR \ @@ -621,7 +621,7 @@
/* SDRAM @ 0xF0000000, stack in DCACHE 0xFDF00000 & FLASH @ 0xFE000000 */ #define CONFIG_SYS_IBAT6L (0xF0000000 \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_MEMCOHERENCE \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT6U (0xF0000000 | BATU_BL_256M | BATU_VS | BATU_VP) diff --git a/include/configs/suvd3.h b/include/configs/suvd3.h index 0b59d51..5f2e1e3 100644 --- a/include/configs/suvd3.h +++ b/include/configs/suvd3.h @@ -85,19 +85,19 @@
/* APP1: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_APP1_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_APP1_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_APP1_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT5L (CONFIG_SYS_APP1_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT5L (CONFIG_SYS_APP1_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U
-#define CONFIG_SYS_IBAT6L (CONFIG_SYS_APP2_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_APP2_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_APP2_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT6L (CONFIG_SYS_APP2_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT6L (CONFIG_SYS_APP2_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U
diff --git a/include/configs/tuda1.h b/include/configs/tuda1.h index 853c00a..7ae7d58 100644 --- a/include/configs/tuda1.h +++ b/include/configs/tuda1.h @@ -106,7 +106,7 @@ */ /* PAXG: icache cacheable, but dcache-inhibit and guarded */ #define CONFIG_SYS_IBAT5L (CONFIG_SYS_APP1_BASE | \ - BATL_PP_10 | \ + BATL_PP_RW | \ BATL_MEMCOHERENCE) /* 512M should also include APP2... */ #define CONFIG_SYS_IBAT5U (CONFIG_SYS_APP1_BASE | \ @@ -114,21 +114,21 @@ BATU_VS | \ BATU_VP) #define CONFIG_SYS_DBAT5L (CONFIG_SYS_APP1_BASE | \ - BATL_PP_10 | \ + BATL_PP_RW | \ BATL_CACHEINHIBIT | \ BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U
/* PINC3: icache cacheable, but dcache-inhibit and guarded */ #define CONFIG_SYS_IBAT6L (CONFIG_SYS_APP2_BASE | \ - BATL_PP_10 | \ + BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_APP2_BASE | \ BATU_BL_256M | \ BATU_VS | \ BATU_VP) #define CONFIG_SYS_DBAT6L (CONFIG_SYS_APP2_BASE | \ - BATL_PP_10 | \ + BATL_PP_RW | \ BATL_CACHEINHIBIT | \ BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U diff --git a/include/configs/tuxa1.h b/include/configs/tuxa1.h index ceeb5a3..815c260 100644 --- a/include/configs/tuxa1.h +++ b/include/configs/tuxa1.h @@ -99,20 +99,20 @@ * MMU Setup */ /* LPXF: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_LPXF_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_LPXF_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_LPXF_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT5L (CONFIG_SYS_LPXF_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT5L (CONFIG_SYS_LPXF_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U
/* PINC2: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PINC2_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PINC2_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_PINC2_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT6L (CONFIG_SYS_PINC2_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT6L (CONFIG_SYS_PINC2_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U
diff --git a/include/configs/ve8313.h b/include/configs/ve8313.h index 9035383..8d3836d 100644 --- a/include/configs/ve8313.h +++ b/include/configs/ve8313.h @@ -423,7 +423,7 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR @ 0x00000000 */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE \ | BATU_BL_256M \ | BATU_VS \ @@ -431,13 +431,13 @@
#if defined(CONFIG_PCI) /* PCI @ 0x80000000 */ -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10) +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_RW) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE \ | BATU_BL_256M \ | BATU_VS \ | BATU_VP) #define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE \ @@ -459,7 +459,7 @@
/* IMMRBAR @ 0xE0000000, PCI IO @ 0xE2000000 & BCSR @ 0xE2400000 */ #define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR \ - | BATL_PP_10 \ + | BATL_PP_RW \ | BATL_CACHEINHIBIT \ | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_IMMR \ @@ -468,11 +468,11 @@ | BATU_VP)
/* stack in DCACHE 0xFDF00000 & FLASH @ 0xFE000000 */ -#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_10 | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_RW | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT6U (0xF0000000 | BATU_BL_256M | BATU_VS | BATU_VP)
/* FPGA, SRAM, NAND @ 0x60000000 */ -#define CONFIG_SYS_IBAT7L (0x60000000 | BATL_PP_10 | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT7L (0x60000000 | BATL_PP_RW | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT7U (0x60000000 | BATU_BL_256M | BATU_VS | BATU_VP)
#define CONFIG_SYS_DBAT0L CONFIG_SYS_IBAT0L diff --git a/include/configs/vme8349.h b/include/configs/vme8349.h index 6a34537..e043e04 100644 --- a/include/configs/vme8349.h +++ b/include/configs/vme8349.h @@ -465,18 +465,18 @@ #define CONFIG_HIGH_BATS /* High BATs supported */
/* DDR @ 0x00000000 */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP)
/* PCI @ 0x80000000 */ #ifdef CONFIG_PCI -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) @@ -488,11 +488,11 @@ #endif
#ifdef CONFIG_MPC83XX_PCI2 -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI2_MEM_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI2_MEM_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_PCI2_MEM_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI2_MMIO_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI2_MMIO_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_PCI2_MMIO_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) @@ -504,17 +504,17 @@ #endif
/* IMMRBAR @ 0xE0000000, PCI IO @ 0xE2000000 */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_IMMR | BATU_BL_256M | \ BATU_VS | BATU_VP)
-#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (0xF0000000 | BATU_BL_256M | BATU_VS | BATU_VP)
#if (CONFIG_SYS_DDR_SIZE == 512) #define CONFIG_SYS_IBAT7L (CONFIG_SYS_SDRAM_BASE+0x10000000 | \ - BATL_PP_10 | BATL_MEMCOHERENCE) + BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT7U (CONFIG_SYS_SDRAM_BASE+0x10000000 | \ BATU_BL_256M | BATU_VS | BATU_VP) #else
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- arch/powerpc/cpu/mpc83xx/spd_sdram.c | 9 ++++++ include/configs/MPC8308RDB.h | 5 ++- include/configs/MPC8313ERDB.h | 10 ++++-- include/configs/MPC8315ERDB.h | 5 ++- include/configs/MPC8323ERDB.h | 2 - include/configs/MPC832XEMDS.h | 52 ++++++++++++++++++++++++++++----- include/configs/MPC8360ERDK.h | 9 ++++-- include/configs/MPC837XEMDS.h | 14 ++++++--- include/configs/MPC837XERDB.h | 28 ++++++++++++------ include/configs/MVBLM7.h | 5 ++- include/configs/kmeter1.h | 5 ++- include/configs/mpc8308_p1m.h | 10 ++++-- include/configs/ve8313.h | 5 ++- include/configs/vme8349.h | 9 ++++-- include/mpc83xx.h | 32 +++++++++++++++++++- 15 files changed, 150 insertions(+), 50 deletions(-)
diff --git a/arch/powerpc/cpu/mpc83xx/spd_sdram.c b/arch/powerpc/cpu/mpc83xx/spd_sdram.c index 9b01f0d..3855bfd 100644 --- a/arch/powerpc/cpu/mpc83xx/spd_sdram.c +++ b/arch/powerpc/cpu/mpc83xx/spd_sdram.c @@ -46,10 +46,19 @@ void board_add_ram_info(int use_default) printf(" (DDR%d", ((ddr->sdram_cfg & SDRAM_CFG_SDRAM_TYPE_MASK) >> SDRAM_CFG_SDRAM_TYPE_SHIFT) - 1);
+#if defined(CONFIG_MPC8308) || defined(CONFIG_MPC831x) + if ((ddr->sdram_cfg & SDRAM_CFG_DBW_MASK) == SDRAM_CFG_DBW_16) + puts(", 16-bit"); + else if ((ddr->sdram_cfg & SDRAM_CFG_DBW_MASK) == SDRAM_CFG_DBW_32) + puts(", 32-bit"); + else + puts(", unknown width"); +#else if (ddr->sdram_cfg & SDRAM_CFG_32_BE) puts(", 32-bit"); else puts(", 64-bit"); +#endif
if (ddr->sdram_cfg & SDRAM_CFG_ECC_EN) puts(", ECC on"); diff --git a/include/configs/MPC8308RDB.h b/include/configs/MPC8308RDB.h index 6a39cee..088b6a4 100644 --- a/include/configs/MPC8308RDB.h +++ b/include/configs/MPC8308RDB.h @@ -149,7 +149,8 @@
#define CONFIG_SYS_DDR_CS0_BNDS 0x00000007 #define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN \ - | 0x00010000 /* ODT_WR to CSn */ \ + | CSCONFIG_ODT_RD_NEVER \ + | CSCONFIG_ODT_WR_ONLY_CURRENT \ | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10) /* 0x80010102 */ #define CONFIG_SYS_DDR_TIMING_3 0x00000000 @@ -184,7 +185,7 @@ /* 0x03600100 */ #define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SREN \ | SDRAM_CFG_SDRAM_TYPE_DDR2 \ - | SDRAM_CFG_32_BE) + | SDRAM_CFG_DBW_32) /* 0x43080000 */
#define CONFIG_SYS_DDR_SDRAM_CFG2 0x00401000 /* 1 posted refresh */ diff --git a/include/configs/MPC8313ERDB.h b/include/configs/MPC8313ERDB.h index dde03ee..186ee2f 100644 --- a/include/configs/MPC8313ERDB.h +++ b/include/configs/MPC8313ERDB.h @@ -131,7 +131,8 @@ */ #define CONFIG_SYS_DDR_SIZE 128 /* MB */ #define CONFIG_SYS_DDR_CONFIG (CSCONFIG_EN \ - | 0x00010000 /* TODO */ \ + | CSCONFIG_ODT_RD_NEVER \ + | CSCONFIG_ODT_WR_ONLY_CURRENT \ | CSCONFIG_ROW_BIT_13 \ | CSCONFIG_COL_BIT_10) /* 0x80010102 */ @@ -169,12 +170,13 @@ #if defined(CONFIG_DDR_2T_TIMING) #define CONFIG_SYS_SDRAM_CFG (SDRAM_CFG_SREN \ | SDRAM_CFG_SDRAM_TYPE_DDR2 \ - | SDRAM_CFG_2T_EN \ - | SDRAM_CFG_DBW_32) + | SDRAM_CFG_DBW_32 \ + | SDRAM_CFG_2T_EN) + /* 0x43088000 */ #else #define CONFIG_SYS_SDRAM_CFG (SDRAM_CFG_SREN \ | SDRAM_CFG_SDRAM_TYPE_DDR2 \ - | SDRAM_CFG_32_BE) + | SDRAM_CFG_DBW_32) /* 0x43080000 */ #endif #define CONFIG_SYS_SDRAM_CFG2 0x00401000 diff --git a/include/configs/MPC8315ERDB.h b/include/configs/MPC8315ERDB.h index 81a3491..9c07243 100644 --- a/include/configs/MPC8315ERDB.h +++ b/include/configs/MPC8315ERDB.h @@ -141,7 +141,8 @@ #define CONFIG_SYS_DDR_SIZE 128 /* MB */ #define CONFIG_SYS_DDR_CS0_BNDS 0x00000007 #define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN \ - | 0x00010000 /* ODT_WR to CSn */ \ + | CSCONFIG_ODT_RD_NEVER \ + | CSCONFIG_ODT_WR_ONLY_CURRENT \ | CSCONFIG_ROW_BIT_13 \ | CSCONFIG_COL_BIT_10) /* 0x80010102 */ @@ -177,7 +178,7 @@ /* 0x03600100 */ #define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SREN \ | SDRAM_CFG_SDRAM_TYPE_DDR2 \ - | SDRAM_CFG_32_BE) + | SDRAM_CFG_DBW_32) /* 0x43080000 */ #define CONFIG_SYS_DDR_SDRAM_CFG2 0x00401000 /* 1 posted refresh */ #define CONFIG_SYS_DDR_MODE ((0x0448 << SDRAM_MODE_ESD_SHIFT) \ diff --git a/include/configs/MPC8323ERDB.h b/include/configs/MPC8323ERDB.h index a27d33c..9827425 100644 --- a/include/configs/MPC8323ERDB.h +++ b/include/configs/MPC8323ERDB.h @@ -78,7 +78,6 @@ #define CONFIG_SYS_DDR_BASE 0x00000000 /* DDR is system memory */ #define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_BASE #define CONFIG_SYS_DDR_SDRAM_BASE CONFIG_SYS_DDR_BASE -#define CONFIG_SYS_DDRCDR 0x73000002 /* DDR II voltage is 1.8V */
#undef CONFIG_SPD_EEPROM #if defined(CONFIG_SPD_EEPROM) @@ -90,7 +89,6 @@ */ #define CONFIG_SYS_DDR_SIZE 64 /* MB */ #define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN \ - | CSCONFIG_ODT_WR_ACS \ | CSCONFIG_ROW_BIT_13 \ | CSCONFIG_COL_BIT_9) /* 0x80010101 */ diff --git a/include/configs/MPC832XEMDS.h b/include/configs/MPC832XEMDS.h index d276be4..42ec3c3 100644 --- a/include/configs/MPC832XEMDS.h +++ b/include/configs/MPC832XEMDS.h @@ -111,17 +111,53 @@ /* Manually set up DDR parameters */ #define CONFIG_SYS_DDR_SIZE 128 /* MB */ -#define CONFIG_SYS_DDR_CS0_CONFIG 0x80840102 -#define CONFIG_SYS_DDR_TIMING_0 0x00220802 -#define CONFIG_SYS_DDR_TIMING_1 0x3935d322 -#define CONFIG_SYS_DDR_TIMING_2 0x0f9048ca +#define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN \ + | CSCONFIG_AP \ + | CSCONFIG_ODT_WR_CFG \ + | CSCONFIG_ROW_BIT_13 \ + | CSCONFIG_COL_BIT_10) + /* 0x80840102 */ +#define CONFIG_SYS_DDR_TIMING_0 ((0 << TIMING_CFG0_RWT_SHIFT) \ + | (0 << TIMING_CFG0_WRT_SHIFT) \ + | (0 << TIMING_CFG0_RRT_SHIFT) \ + | (0 << TIMING_CFG0_WWT_SHIFT) \ + | (2 << TIMING_CFG0_ACT_PD_EXIT_SHIFT) \ + | (2 << TIMING_CFG0_PRE_PD_EXIT_SHIFT) \ + | (8 << TIMING_CFG0_ODT_PD_EXIT_SHIFT) \ + | (2 << TIMING_CFG0_MRS_CYC_SHIFT)) + /* 0x00220802 */ +#define CONFIG_SYS_DDR_TIMING_1 ((3 << TIMING_CFG1_PRETOACT_SHIFT) \ + | (9 << TIMING_CFG1_ACTTOPRE_SHIFT) \ + | (3 << TIMING_CFG1_ACTTORW_SHIFT) \ + | (5 << TIMING_CFG1_CASLAT_SHIFT) \ + | (13 << TIMING_CFG1_REFREC_SHIFT) \ + | (3 << TIMING_CFG1_WRREC_SHIFT) \ + | (2 << TIMING_CFG1_ACTTOACT_SHIFT) \ + | (2 << TIMING_CFG1_WRTORD_SHIFT)) + /* 0x3935D322 */ +#define CONFIG_SYS_DDR_TIMING_2 ((0 << TIMING_CFG2_ADD_LAT_SHIFT) \ + | (31 << TIMING_CFG2_CPO_SHIFT) \ + | (2 << TIMING_CFG2_WR_LAT_DELAY_SHIFT) \ + | (2 << TIMING_CFG2_RD_TO_PRE_SHIFT) \ + | (2 << TIMING_CFG2_WR_DATA_DELAY_SHIFT) \ + | (3 << TIMING_CFG2_CKE_PLS_SHIFT) \ + | (10 << TIMING_CFG2_FOUR_ACT_SHIFT)) + /* 0x0F9048CA */ #define CONFIG_SYS_DDR_TIMING_3 0x00000000 -#define CONFIG_SYS_DDR_CLK_CNTL 0x02000000 -#define CONFIG_SYS_DDR_MODE 0x44400232 +#define CONFIG_SYS_DDR_CLK_CNTL DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05 + /* 0x02000000 */ +#define CONFIG_SYS_DDR_MODE ((0x4440 << SDRAM_MODE_ESD_SHIFT) \ + | (0x0232 << SDRAM_MODE_SD_SHIFT)) + /* 0x44400232 */ #define CONFIG_SYS_DDR_MODE2 0x8000c000 -#define CONFIG_SYS_DDR_INTERVAL 0x03200064 +#define CONFIG_SYS_DDR_INTERVAL ((800 << SDRAM_INTERVAL_REFINT_SHIFT) \ + | (100 << SDRAM_INTERVAL_BSTOPRE_SHIFT)) + /* 0x03200064 */ #define CONFIG_SYS_DDR_CS0_BNDS 0x00000007 -#define CONFIG_SYS_DDR_SDRAM_CFG 0x43080000 +#define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SREN \ + | SDRAM_CFG_SDRAM_TYPE_DDR2 \ + | SDRAM_CFG_32_BE) + /* 0x43080000 */ #define CONFIG_SYS_DDR_SDRAM_CFG2 0x00401000 #endif
diff --git a/include/configs/MPC8360ERDK.h b/include/configs/MPC8360ERDK.h index a5cba19..68603df 100644 --- a/include/configs/MPC8360ERDK.h +++ b/include/configs/MPC8360ERDK.h @@ -96,7 +96,10 @@ /* * DDRCDR - DDR Control Driver Register */ -#define CONFIG_SYS_DDRCDR_VALUE 0x80080001 +#define CONFIG_SYS_DDRCDR_VALUE (DDRCDR_DHC_EN \ + | DDRCDR_ODT \ + | DDRCDR_Q_DRN) + /* 0x80080001 */
#undef CONFIG_SPD_EEPROM /* Do not use SPD EEPROM for DDR setup */
@@ -105,11 +108,11 @@ */ #define CONFIG_DDR_II #define CONFIG_SYS_DDR_SIZE 256 /* MB */ -#define CONFIG_SYS_DDR_CS0_BNDS 0x0000000f +#define CONFIG_SYS_DDR_CS0_BNDS 0x0000000f #define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN \ | CSCONFIG_ROW_BIT_13 \ | CSCONFIG_COL_BIT_10 \ - | CSCONFIG_ODT_WR_ACS) + | CSCONFIG_ODT_WR_ONLY_CURRENT) #define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SDRAM_TYPE_DDR2 \ | SDRAM_CFG_ECC_EN) #define CONFIG_SYS_DDR_SDRAM_CFG2 0x00001000 diff --git a/include/configs/MPC837XEMDS.h b/include/configs/MPC837XEMDS.h index c17cec9..008f0ef 100644 --- a/include/configs/MPC837XEMDS.h +++ b/include/configs/MPC837XEMDS.h @@ -128,7 +128,10 @@ #define CONFIG_SYS_DDR_SDRAM_BASE CONFIG_SYS_DDR_BASE #define CONFIG_SYS_DDR_SDRAM_CLK_CNTL DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05 #define CONFIG_SYS_83XX_DDR_USES_CS0 -#define CONFIG_SYS_DDRCDR_VALUE 0x80080001 /* ODT 150ohm on SoC */ +#define CONFIG_SYS_DDRCDR_VALUE (DDRCDR_DHC_EN \ + | DDRCDR_ODT \ + | DDRCDR_Q_DRN) + /* 0x80080001 */ /* ODT 150ohm on SoC */
#undef CONFIG_DDR_ECC /* support DDR ECC function */ #undef CONFIG_DDR_ECC_CMD /* Use DDR ECC user commands */ @@ -147,10 +150,11 @@ #define CONFIG_SYS_DDR_SIZE 512 /* MB */ #define CONFIG_SYS_DDR_CS0_BNDS 0x0000001f #define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN \ - | 0x00010000 /* ODT_WR to CSn */ \ - | CSCONFIG_ROW_BIT_14 \ - | CSCONFIG_COL_BIT_10) - /* 0x80010202 */ + | CSCONFIG_ODT_RD_NEVER /* ODT_RD to none */ \ + | CSCONFIG_ODT_WR_ONLY_CURRENT /* ODT_WR to CSn */ \ + | CSCONFIG_ROW_BIT_14 \ + | CSCONFIG_COL_BIT_10) + /* 0x80010202 */ #define CONFIG_SYS_DDR_TIMING_3 0x00000000 #define CONFIG_SYS_DDR_TIMING_0 ((0 << TIMING_CFG0_RWT_SHIFT) \ | (0 << TIMING_CFG0_WRT_SHIFT) \ diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index a0f8085..2355964 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -165,9 +165,11 @@ * Manually set up DDR parameters */ #define CONFIG_SYS_DDR_SIZE 256 /* MB */ -#define CONFIG_SYS_DDR_CS0_BNDS 0x0000000f -#define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN | CSCONFIG_ODT_WR_ACS \ - | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10) +#define CONFIG_SYS_DDR_CS0_BNDS 0x0000000f +#define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN \ + | CSCONFIG_ODT_WR_ONLY_CURRENT \ + | CSCONFIG_ROW_BIT_13 \ + | CSCONFIG_COL_BIT_10)
#define CONFIG_SYS_DDR_TIMING_3 0x00000000 #define CONFIG_SYS_DDR_TIMING_0 ((0 << TIMING_CFG0_RWT_SHIFT) \ @@ -178,7 +180,6 @@ | (6 << TIMING_CFG0_PRE_PD_EXIT_SHIFT) \ | (8 << TIMING_CFG0_ODT_PD_EXIT_SHIFT) \ | (2 << TIMING_CFG0_MRS_CYC_SHIFT)) - /* 0x00220802 */ /* 0x00260802 */ /* DDR400 */ #define CONFIG_SYS_DDR_TIMING_1 ((3 << TIMING_CFG1_PRETOACT_SHIFT) \ | (9 << TIMING_CFG1_ACTTOPRE_SHIFT) \ @@ -188,9 +189,15 @@ | (3 << TIMING_CFG1_WRREC_SHIFT) \ | (2 << TIMING_CFG1_ACTTOACT_SHIFT) \ | (2 << TIMING_CFG1_WRTORD_SHIFT)) - /* 0x3935d322 */ /* 0x3937d322 */ -#define CONFIG_SYS_DDR_TIMING_2 0x02984cc8 +#define CONFIG_SYS_DDR_TIMING_2 ((0 << TIMING_CFG2_ADD_LAT_SHIFT) \ + | (5 << TIMING_CFG2_CPO_SHIFT) \ + | (3 << TIMING_CFG2_WR_LAT_DELAY_SHIFT) \ + | (2 << TIMING_CFG2_RD_TO_PRE_SHIFT) \ + | (3 << TIMING_CFG2_WR_DATA_DELAY_SHIFT) \ + | (3 << TIMING_CFG2_CKE_PLS_SHIFT) \ + | (8 << TIMING_CFG2_FOUR_ACT_SHIFT)) + /* 0x02984cc8 */
#define CONFIG_SYS_DDR_INTERVAL ((1024 << SDRAM_INTERVAL_REFINT_SHIFT) \ | (0 << SDRAM_INTERVAL_BSTOPRE_SHIFT)) @@ -198,12 +205,13 @@
#if defined(CONFIG_DDR_2T_TIMING) #define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SREN \ - | 3 << SDRAM_CFG_SDRAM_TYPE_SHIFT \ - | SDRAM_CFG_2T_EN \ - | SDRAM_CFG_DBW_32) + | SDRAM_CFG_SDRAM_TYPE_DDR2 \ + | SDRAM_CFG_32_BE \ + | SDRAM_CFG_2T_EN) + /* 0x43088000 */ #else #define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SREN \ - | 3 << SDRAM_CFG_SDRAM_TYPE_SHIFT) + | SDRAM_CFG_SDRAM_TYPE_DDR2) /* 0x43000000 */ #endif #define CONFIG_SYS_DDR_SDRAM_CFG2 0x00001000 /* 1 posted refresh */ diff --git a/include/configs/MVBLM7.h b/include/configs/MVBLM7.h index 7e9c5f3..5e6b8c2 100644 --- a/include/configs/MVBLM7.h +++ b/include/configs/MVBLM7.h @@ -72,7 +72,10 @@ #define CONFIG_SYS_MEMTEST_END (70<<20) #define CONFIG_VERY_BIG_RAM
-#define CONFIG_SYS_DDRCDR 0x22000001 +#define CONFIG_SYS_DDRCDR (DDRCDR_PZ_HIZ \ + | DDRCDR_NZ_HIZ \ + | DDRCDR_Q_DRN) + /* 0x22000001 */ #define CONFIG_SYS_DDR_SDRAM_CLK_CNTL DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05
#define CONFIG_SYS_DDR_SIZE 512 diff --git a/include/configs/kmeter1.h b/include/configs/kmeter1.h index 5f68dc9..c04bde9 100644 --- a/include/configs/kmeter1.h +++ b/include/configs/kmeter1.h @@ -72,9 +72,10 @@ #define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN | CSCONFIG_AP | \ CSCONFIG_ROW_BIT_13 | \ CSCONFIG_COL_BIT_10 | \ - CSCONFIG_ODT_WR_ACS) + CSCONFIG_ODT_WR_ONLY_CURRENT)
-#define CONFIG_SYS_DDRCDR 0x40000001 +#define CONFIG_SYS_DDRCDR (DDRCDR_EN | DDRCDR_Q_DRN) + /* 0x40000001 */ #define CONFIG_SYS_DDR_MODE 0x47860452 #define CONFIG_SYS_DDR_MODE2 0x8080c000
diff --git a/include/configs/mpc8308_p1m.h b/include/configs/mpc8308_p1m.h index ba71d9f..ff773ec 100644 --- a/include/configs/mpc8308_p1m.h +++ b/include/configs/mpc8308_p1m.h @@ -157,9 +157,11 @@
#define CONFIG_SYS_DDR_CS0_BNDS 0x00000007 #define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN \ - | 0x00010000 /* ODT_WR to CSn */ \ - | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10) - /* 0x80010102 */ + | CSCONFIG_ODT_RD_NEVER \ + | CSCONFIG_ODT_WR_ONLY_CURRENT \ + | CSCONFIG_ROW_BIT_13 \ + | CSCONFIG_COL_BIT_10) + /* 0x80010102 */ #define CONFIG_SYS_DDR_TIMING_3 0x00000000 #define CONFIG_SYS_DDR_TIMING_0 ((0 << TIMING_CFG0_RWT_SHIFT) \ | (0 << TIMING_CFG0_WRT_SHIFT) \ @@ -192,7 +194,7 @@ /* 0x03600100 */ #define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SREN \ | SDRAM_CFG_SDRAM_TYPE_DDR2 \ - | SDRAM_CFG_32_BE) + | SDRAM_CFG_DBW_32) /* 0x43080000 */
#define CONFIG_SYS_DDR_SDRAM_CFG2 0x00401000 /* 1 posted refresh */ diff --git a/include/configs/ve8313.h b/include/configs/ve8313.h index 8d3836d..ca64022 100644 --- a/include/configs/ve8313.h +++ b/include/configs/ve8313.h @@ -81,7 +81,8 @@ #define CONFIG_SYS_DDR_SIZE 128 /* MB */ #define CONFIG_SYS_DDR_CONFIG (CSCONFIG_EN \ | CSCONFIG_AP \ - | 0x00040000 /* TODO */ \ + | CSCONFIG_ODT_RD_NEVER \ + | CSCONFIG_ODT_WR_ALL \ | CSCONFIG_ROW_BIT_13 \ | CSCONFIG_COL_BIT_10) /* 0x80840102 */ @@ -118,7 +119,7 @@ /* 0x03202000 */ #define CONFIG_SYS_SDRAM_CFG (SDRAM_CFG_SREN \ | SDRAM_CFG_SDRAM_TYPE_DDR2 \ - | SDRAM_CFG_32_BE) + | SDRAM_CFG_DBW_32) /* 0x43080000 */ #define CONFIG_SYS_SDRAM_CFG2 0x00401000 #define CONFIG_SYS_DDR_MODE ((0x4440 << SDRAM_MODE_ESD_SHIFT) \ diff --git a/include/configs/vme8349.h b/include/configs/vme8349.h index e043e04..a0f25be 100644 --- a/include/configs/vme8349.h +++ b/include/configs/vme8349.h @@ -106,10 +106,13 @@ #define CONFIG_SYS_DDR_BASE 0x00000000 /* DDR is sys memory*/ #define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_BASE #define CONFIG_SYS_DDR_SDRAM_BASE CONFIG_SYS_DDR_BASE -#define CONFIG_SYS_DDR_SDRAM_CLK_CNTL (DDR_SDRAM_CLK_CNTL_SS_EN | \ - DDR_SDRAM_CLK_CNTL_CLK_ADJUST_075) +#define CONFIG_SYS_DDR_SDRAM_CLK_CNTL (DDR_SDRAM_CLK_CNTL_SS_EN \ + | DDR_SDRAM_CLK_CNTL_CLK_ADJUST_075) #define CONFIG_DDR_2T_TIMING -#define CONFIG_SYS_DDRCDR 0x80080001 +#define CONFIG_SYS_DDRCDR (DDRCDR_DHC_EN \ + | DDRCDR_ODT \ + | DDRCDR_Q_DRN) + /* 0x80080001 */
/* * FLASH on the Local Bus diff --git a/include/mpc83xx.h b/include/mpc83xx.h index 8292018..15ef487 100644 --- a/include/mpc83xx.h +++ b/include/mpc83xx.h @@ -905,9 +905,29 @@ */ #define CSCONFIG_EN 0x80000000 #define CSCONFIG_AP 0x00800000 -#define CSCONFIG_ODT_WR_ACS 0x00010000 -#if defined(CONFIG_MPC832x) +#if defined(CONFIG_MPC8308) || defined(CONFIG_MPC831x) +#define CSCONFIG_ODT_RD_NEVER 0x00000000 +#define CSCONFIG_ODT_RD_ONLY_CURRENT 0x00100000 +#define CSCONFIG_ODT_RD_ONLY_OTHER_CS 0x00200000 +#define CSCONFIG_ODT_RD_ALL 0x00400000 +#define CSCONFIG_ODT_WR_NEVER 0x00000000 +#define CSCONFIG_ODT_WR_ONLY_CURRENT 0x00010000 +#define CSCONFIG_ODT_WR_ONLY_OTHER_CS 0x00020000 +#define CSCONFIG_ODT_WR_ALL 0x00040000 +#elif defined(CONFIG_MPC832x) +#define CSCONFIG_ODT_RD_CFG 0x00400000 #define CSCONFIG_ODT_WR_CFG 0x00040000 +#elif defined(CONFIG_MPC8360) || defined(CONFIG_MPC837x) +#define CSCONFIG_ODT_RD_NEVER 0x00000000 +#define CSCONFIG_ODT_RD_ONLY_CURRENT 0x00100000 +#define CSCONFIG_ODT_RD_ONLY_OTHER_CS 0x00200000 +#define CSCONFIG_ODT_RD_ONLY_OTHER_DIMM 0x00300000 +#define CSCONFIG_ODT_RD_ALL 0x00400000 +#define CSCONFIG_ODT_WR_NEVER 0x00000000 +#define CSCONFIG_ODT_WR_ONLY_CURRENT 0x00010000 +#define CSCONFIG_ODT_WR_ONLY_OTHER_CS 0x00020000 +#define CSCONFIG_ODT_WR_ONLY_OTHER_DIMM 0x00030000 +#define CSCONFIG_ODT_WR_ALL 0x00040000 #endif #define CSCONFIG_BANK_BIT_3 0x00004000 #define CSCONFIG_ROW_BIT 0x00000700 @@ -996,8 +1016,16 @@ #define SDRAM_CFG_SDRAM_TYPE_MASK 0x07000000 #define SDRAM_CFG_SDRAM_TYPE_SHIFT 24 #define SDRAM_CFG_DYN_PWR 0x00200000 +#if defined(CONFIG_MPC8308) || defined(CONFIG_MPC831x) +#define SDRAM_CFG_DBW_MASK 0x00180000 +#define SDRAM_CFG_DBW_16 0x00100000 +#define SDRAM_CFG_DBW_32 0x00080000 +#else #define SDRAM_CFG_32_BE 0x00080000 +#endif +#if !defined(CONFIG_MPC8308) #define SDRAM_CFG_8_BE 0x00040000 +#endif #define SDRAM_CFG_NCAP 0x00020000 #define SDRAM_CFG_2T_EN 0x00008000 #define SDRAM_CFG_HSE 0x00000008
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- arch/powerpc/include/asm/fsl_lbc.h | 8 ++- include/configs/MERGERBOX.h | 14 ++-- include/configs/MPC8308RDB.h | 39 +++++++--- include/configs/MPC8313ERDB.h | 70 +++++++++++++----- include/configs/MPC8315ERDB.h | 35 +++++---- include/configs/MPC8323ERDB.h | 84 ++++------------------ include/configs/MPC832XEMDS.h | 143 ++++++++++++++++-------------------- include/configs/MPC8349EMDS.h | 55 +++++++++----- include/configs/MPC8349ITX.h | 33 +++++--- include/configs/MPC8360EMDS.h | 93 ++++++++++++++++++------ include/configs/MPC8360ERDK.h | 40 +++++++--- include/configs/MPC837XEMDS.h | 44 +++++++---- include/configs/MPC837XERDB.h | 42 +++++++---- include/configs/MVBLM7.h | 15 ++-- include/configs/SIMPC8313.h | 14 ++-- include/configs/TQM834x.h | 5 +- include/configs/km/km83xx-common.h | 14 ++-- include/configs/kmeter1.h | 7 +- include/configs/kmsupx5.h | 4 +- include/configs/mpc8308_p1m.h | 32 ++++---- include/configs/sbc8349.h | 55 +++++++++----- include/configs/suvd3.h | 2 +- include/configs/tuda1.h | 13 ++-- include/configs/tuxa1.h | 13 ++-- include/configs/ve8313.h | 25 +++--- include/configs/vme8349.h | 55 ++++++++++---- 26 files changed, 548 insertions(+), 406 deletions(-)
diff --git a/arch/powerpc/include/asm/fsl_lbc.h b/arch/powerpc/include/asm/fsl_lbc.h index 8695a62..bf572b7 100644 --- a/arch/powerpc/include/asm/fsl_lbc.h +++ b/arch/powerpc/include/asm/fsl_lbc.h @@ -50,8 +50,10 @@ void lbc_sdram_init(void); #define BR_MSEL 0x000000E0 #define BR_MSEL_SHIFT 5 #define BR_MS_GPCM 0x00000000 /* GPCM */ +#if !defined(CONFIG_MPC834x) && !defined(CONFIG_MPC8360) #define BR_MS_FCM 0x00000020 /* FCM */ -#ifdef CONFIG_MPC83xx +#endif +#if defined(CONFIG_MPC834x) || defined(CONFIG_MPC8360) #define BR_MS_SDRAM 0x00000060 /* SDRAM */ #elif defined(CONFIG_MPC85xx) #define BR_MS_SDRAM 0x00000000 /* SDRAM */ @@ -138,8 +140,10 @@ void lbc_sdram_init(void); #define OR_GPCM_EHTR_SHIFT 1 #define OR_GPCM_EHTR_CLEAR 0x00000000 #define OR_GPCM_EHTR_SET 0x00000002 +#if !defined(CONFIG_MPC8308) #define OR_GPCM_EAD 0x00000001 #define OR_GPCM_EAD_SHIFT 0 +#endif
/* helpers to convert values into an OR address mask (GPCM mode) */ #define P2SZ_TO_AM(s) ((~((s) - 1)) & 0xffff8000) /* must be pow of 2 */ @@ -196,8 +200,10 @@ void lbc_sdram_init(void); #define OR_SDRAM_XAM_SHIFT 13 #define OR_SDRAM_COLS 0x00001C00 #define OR_SDRAM_COLS_SHIFT 10 +#define OR_SDRAM_MIN_COLS 7 #define OR_SDRAM_ROWS 0x000001C0 #define OR_SDRAM_ROWS_SHIFT 6 +#define OR_SDRAM_MIN_ROWS 9 #define OR_SDRAM_PMSEL 0x00000020 #define OR_SDRAM_PMSEL_SHIFT 5 #define OR_SDRAM_EAD 0x00000001 diff --git a/include/configs/MERGERBOX.h b/include/configs/MERGERBOX.h index 15cd646..17ee5b6 100644 --- a/include/configs/MERGERBOX.h +++ b/include/configs/MERGERBOX.h @@ -159,11 +159,13 @@ #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_64MB)
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | BR_PS_16 | BR_V) +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | BR_PS_16 |\ + BR_MS_GPCM | BR_V) #define CONFIG_SYS_OR0_PRELIM (CONFIG_SYS_FLASH_BASE | OR_UPM_XAM |\ OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 |\ - OR_GPCM_XACS | OR_GPCM_SCY_15 | OR_GPCM_TRLX |\ - OR_GPCM_EHTR | OR_GPCM_EAD) + OR_GPCM_XACS | OR_GPCM_SCY_15 |\ + OR_GPCM_TRLX_SET | OR_GPCM_EHTR_SET |\ + OR_GPCM_EAD)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 512 @@ -180,14 +182,14 @@ #define CONFIG_NAND_FSL_ELBC 1
#define CONFIG_SYS_NAND_BASE 0xE0600000 -#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_NAND_BASE | (2<<BR_DECC_SHIFT) |\ +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_NAND_BASE | BR_DECC_CHK_GEN |\ BR_PS_8 | BR_MS_FCM | BR_V) -#define CONFIG_SYS_OR1_PRELIM (0xFFFF8000 | OR_FCM_BCTLD | OR_FCM_CST |\ +#define CONFIG_SYS_OR1_PRELIM (OR_AM_32KB | OR_FCM_BCTLD | OR_FCM_CST |\ OR_FCM_CHT | OR_FCM_SCY_1 | OR_FCM_RST |\ OR_FCM_TRLX | OR_FCM_EHTR)
#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_NAND_BASE -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000E +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_32KB)
/* * Serial Port diff --git a/include/configs/MPC8308RDB.h b/include/configs/MPC8308RDB.h index 088b6a4..6a42f27 100644 --- a/include/configs/MPC8308RDB.h +++ b/include/configs/MPC8308RDB.h @@ -239,19 +239,18 @@ #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_8MB)
-#define CONFIG_SYS_BR0_PRELIM (\ - CONFIG_SYS_FLASH_BASE /* Flash Base address */ |\ - (2 << BR_PS_SHIFT) /* 16 bit port size */ |\ - BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) \ +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE \ + | BR_PS_16 /* 16 bit port */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ | OR_UPM_XAM \ | OR_GPCM_CSNT \ | OR_GPCM_ACS_DIV2 \ | OR_GPCM_XACS \ | OR_GPCM_SCY_15 \ - | OR_GPCM_TRLX \ - | OR_GPCM_EHTR \ - | OR_GPCM_EAD) + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ /* 127 64KB sectors and 8 8KB top sectors per device */ @@ -264,12 +263,13 @@ * NAND Flash on the Local Bus */ #define CONFIG_SYS_NAND_BASE 0xE0600000 /* 0xE0600000 */ +#define CONFIG_SYS_NAND_WINDOW_SIZE (32 * 1024) /* 0x00008000 */ #define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_NAND_BASE \ - | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ - | BR_PS_8 /* 8 bit port */ \ + | BR_DECC_CHK_GEN /* Use HW ECC */ \ + | BR_PS_8 /* 8 bit Port */ \ | BR_MS_FCM /* MSEL = FCM */ \ | BR_V) /* valid */ -#define CONFIG_SYS_OR1_PRELIM (0xFFFF8000 /* length 32K */ \ +#define CONFIG_SYS_OR1_PRELIM (P2SZ_TO_AM(CONFIG_SYS_NAND_WINDOW_SIZE) \ | OR_FCM_CSCT \ | OR_FCM_CST \ | OR_FCM_CHT \ @@ -283,9 +283,22 @@
#ifdef CONFIG_VSC7385_ENET #define CONFIG_TSEC2 + /* VSC7385 Base address on CS2 */ #define CONFIG_SYS_VSC7385_BASE 0xF0000000 -#define CONFIG_SYS_BR2_PRELIM 0xf0000801 /* VSC7385 Base address */ -#define CONFIG_SYS_OR2_PRELIM 0xfffe09ff /* VSC7385, 128K bytes*/ +#define CONFIG_SYS_VSC7385_SIZE (128 * 1024) /* 0x00020000 */ +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_VSC7385_BASE \ + | BR_PS_8 /* 8-bit port */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ + /* 0xF0000801 */ +#define CONFIG_SYS_OR2_PRELIM (P2SZ_TO_AM(CONFIG_SYS_VSC7385_SIZE) \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_SETA \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET) + /* 0xFFFE09FF */ /* Access window base at VSC7385 base */ #define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_VSC7385_BASE /* Access window size 128K */ diff --git a/include/configs/MPC8313ERDB.h b/include/configs/MPC8313ERDB.h index 186ee2f..a0ad225 100644 --- a/include/configs/MPC8313ERDB.h +++ b/include/configs/MPC8313ERDB.h @@ -205,9 +205,10 @@ #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE /* buffer up multiple bytes */
#define CONFIG_SYS_NOR_BR_PRELIM (CONFIG_SYS_FLASH_BASE \ - | (2 << BR_PS_SHIFT) /* 16 bit port */ \ - | BR_V) /* valid */ -#define CONFIG_SYS_NOR_OR_PRELIM (0xFF800000 /* 8 MByte */ \ + | BR_PS_16 /* 16 bit port */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_NOR_OR_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ | OR_GPCM_XACS \ | OR_GPCM_SCY_9 \ | OR_GPCM_EHTR \ @@ -215,7 +216,8 @@ /* 0xFF006FF7 TODO SLOW 16 MB flash size */ /* window base at flash base */ #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000017 /* 16 MB window size */ + /* 16 MB window size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_16MB)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 135 /* sectors per device */ @@ -271,14 +273,16 @@ #define CONFIG_CMD_NAND 1 #define CONFIG_NAND_FSL_ELBC 1 #define CONFIG_SYS_NAND_BLOCK_SIZE 16384 +#define CONFIG_SYS_NAND_WINDOW_SIZE (32 * 1024)
#define CONFIG_SYS_NAND_BR_PRELIM (CONFIG_SYS_NAND_BASE \ - | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ + | BR_DECC_CHK_GEN /* Use HW ECC */ \ | BR_PS_8 /* 8 bit port */ \ | BR_MS_FCM /* MSEL = FCM */ \ | BR_V) /* valid */ -#define CONFIG_SYS_NAND_OR_PRELIM (0xFFFF8000 /* length 32K */ \ +#define CONFIG_SYS_NAND_OR_PRELIM \ + (P2SZ_TO_AM(CONFIG_SYS_NAND_WINDOW_SIZE) \ | OR_FCM_CSCT \ | OR_FCM_CST \ | OR_FCM_CHT \ @@ -300,31 +304,57 @@ #endif
#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_NAND_BASE -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000E /* 32KB */ +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_32KB)
#define CONFIG_SYS_NAND_LBLAWBAR_PRELIM CONFIG_SYS_LBLAWBAR1_PRELIM #define CONFIG_SYS_NAND_LBLAWAR_PRELIM CONFIG_SYS_LBLAWAR1_PRELIM
-/* local bus read write buffer mapping */ -#define CONFIG_SYS_BR3_PRELIM 0xFA000801 /* map at 0xFA000000 */ -#define CONFIG_SYS_OR3_PRELIM 0xFFFF8FF7 /* 32kB */ -#define CONFIG_SYS_LBLAWBAR3_PRELIM 0xFA000000 -#define CONFIG_SYS_LBLAWAR3_PRELIM 0x8000000E /* 32KB */ +/* local bus write LED / read status buffer (BCSR) mapping */ +#define CONFIG_SYS_BCSR_ADDR 0xFA000000 +#define CONFIG_SYS_BCSR_SIZE (32 * 1024) /* 0x00008000 */ + /* map at 0xFA000000 on LCS3 */ +#define CONFIG_SYS_BR3_PRELIM (CONFIG_SYS_BCSR_ADDR \ + | BR_PS_8 /* 8 bit port */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ + /* 0xFA000801 */ +#define CONFIG_SYS_OR3_PRELIM (P2SZ_TO_AM(CONFIG_SYS_BCSR_SIZE) \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xFFFF8FF7 */ +#define CONFIG_SYS_LBLAWBAR3_PRELIM CONFIG_SYS_BCSR_ADDR +#define CONFIG_SYS_LBLAWAR3_PRELIM (LBLAWAR_EN | LBLAWAR_32KB)
/* Vitesse 7385 */
-#define CONFIG_SYS_VSC7385_BASE 0xF0000000 - #ifdef CONFIG_VSC7385_ENET
- /* VSC7385 Base address */ -#define CONFIG_SYS_BR2_PRELIM 0xf0000801 - /* VSC7385, 128K bytes*/ -#define CONFIG_SYS_OR2_PRELIM 0xfffe09ff + /* VSC7385 Base address on LCS2 */ +#define CONFIG_SYS_VSC7385_BASE 0xF0000000 +#define CONFIG_SYS_VSC7385_SIZE (128 * 1024) /* 0x00020000 */ + +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_VSC7385_BASE \ + | BR_PS_8 /* 8 bit port */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR2_PRELIM (P2SZ_TO_AM(CONFIG_SYS_VSC7385_SIZE) \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_SETA \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xFFFE09FF */ + /* Access window base at VSC7385 base */ #define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_VSC7385_BASE - /* Access window size 128K */ -#define CONFIG_SYS_LBLAWAR2_PRELIM 0x80000010 +#define CONFIG_SYS_LBLAWAR2_PRELIM (LBLAWAR_EN | LBLAWAR_128KB)
#endif
diff --git a/include/configs/MPC8315ERDB.h b/include/configs/MPC8315ERDB.h index 9c07243..35c194a 100644 --- a/include/configs/MPC8315ERDB.h +++ b/include/configs/MPC8315ERDB.h @@ -229,20 +229,21 @@
/* Window base at flash base */ #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000016 /* 8MB window size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_8MB)
#define CONFIG_SYS_NOR_BR_PRELIM (CONFIG_SYS_FLASH_BASE \ - | (2 << BR_PS_SHIFT) /* 16 bit port */ \ - | BR_V) /* valid */ -#define CONFIG_SYS_NOR_OR_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) \ - | OR_UPM_XAM \ - | OR_GPCM_CSNT \ - | OR_GPCM_ACS_DIV2 \ - | OR_GPCM_XACS \ - | OR_GPCM_SCY_15 \ - | OR_GPCM_TRLX \ - | OR_GPCM_EHTR \ - | OR_GPCM_EAD) + | BR_PS_16 /* 16 bit port */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_NOR_OR_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ + | OR_UPM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ /* 127 64KB sectors and 8 8KB top sectors per device */ @@ -273,7 +274,8 @@ #define CONFIG_MTD_NAND_VERIFY_WRITE 1 #define CONFIG_CMD_NAND 1 #define CONFIG_NAND_FSL_ELBC 1 -#define CONFIG_SYS_NAND_BLOCK_SIZE 16384 +#define CONFIG_SYS_NAND_BLOCK_SIZE 16384 +#define CONFIG_SYS_NAND_WINDOW_SIZE (32 * 1024) /* 0x00008000 */
#define CONFIG_SYS_NAND_U_BOOT_SIZE (512 << 10) #define CONFIG_SYS_NAND_U_BOOT_DST 0x00100000 @@ -282,11 +284,12 @@ #define CONFIG_SYS_NAND_U_BOOT_RELOC 0x00010000
#define CONFIG_SYS_NAND_BR_PRELIM (CONFIG_SYS_NAND_BASE \ - | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ + | BR_DECC_CHK_GEN /* Use HW ECC */ \ | BR_PS_8 /* 8 bit port */ \ | BR_MS_FCM /* MSEL = FCM */ \ | BR_V) /* valid */ -#define CONFIG_SYS_NAND_OR_PRELIM (0xFFFF8000 /* length 32K */ \ +#define CONFIG_SYS_NAND_OR_PRELIM \ + (P2SZ_TO_AM(CONFIG_SYS_NAND_WINDOW_SIZE) \ | OR_FCM_CSCT \ | OR_FCM_CST \ | OR_FCM_CHT \ @@ -308,7 +311,7 @@ #endif
#define CONFIG_SYS_NAND_LBLAWBAR_PRELIM CONFIG_SYS_LBLAWBAR1_PRELIM #define CONFIG_SYS_NAND_LBLAWAR_PRELIM CONFIG_SYS_LBLAWAR1_PRELIM diff --git a/include/configs/MPC8323ERDB.h b/include/configs/MPC8323ERDB.h index 9827425..0d43a48 100644 --- a/include/configs/MPC8323ERDB.h +++ b/include/configs/MPC8323ERDB.h @@ -185,12 +185,22 @@
/* Window base at flash base */ #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000018 /* 32MB window size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_32MB)
#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE \ - | (2 << BR_PS_SHIFT) /* 16 bit port */ \ - | BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM 0xfe006ff7 /* 16MB Flash size */ + | BR_PS_16 /* 16 bit port */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xFE006FF7 */
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 128 /* sectors per device */ @@ -198,72 +208,6 @@ #undef CONFIG_SYS_FLASH_CHECKSUM
/* - * SDRAM on the Local Bus - */ -#undef CONFIG_SYS_LB_SDRAM /* The board has not SRDAM on local bus */ - -#ifdef CONFIG_SYS_LB_SDRAM -#define CONFIG_SYS_LBC_SDRAM_BASE 0xF0000000 /* SDRAM base addr */ -#define CONFIG_SYS_LBC_SDRAM_SIZE 64 /* LBC SDRAM is 64MB */ - -#define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_LBC_SDRAM_BASE -#define CONFIG_SYS_LBLAWAR2_PRELIM 0x80000019 /* 64MB */ - -/*local bus BR2, OR2 definition for SDRAM if soldered on the EPB board */ -/* - * Base Register 2 and Option Register 2 configure SDRAM. - * The SDRAM base address, CONFIG_SYS_LBC_SDRAM_BASE, is 0xf0000000. - * - * For BR2, need: - * Base address of 0xf0000000 = BR[0:16] = 1111 0000 0000 0000 0 - * port size = 32-bits = BR2[19:20] = 11 - * no parity checking = BR2[21:22] = 00 - * SDRAM for MSEL = BR2[24:26] = 011 - * Valid = BR[31] = 1 - * - * 0 4 8 12 16 20 24 28 - * 1111 0000 0000 0000 0001 1000 0110 0001 = f0001861 - * - * CONFIG_SYS_LBC_SDRAM_BASE should be masked and OR'ed into - * the top 17 bits of BR2. - */ - - /*Port size=32bit, MSEL=SDRAM */ -#define CONFIG_SYS_BR2_PRELIM 0xf0001861 - -/* - * The SDRAM size in MB, CONFIG_SYS_LBC_SDRAM_SIZE, is 64. - * - * For OR2, need: - * 64MB mask for AM, OR2[0:7] = 1111 1100 - * XAM, OR2[17:18] = 11 - * 9 columns OR2[19-21] = 010 - * 13 rows OR2[23-25] = 100 - * EAD set for extra time OR[31] = 1 - * - * 0 4 8 12 16 20 24 28 - * 1111 1100 0000 0000 0110 1001 0000 0001 = fc006901 - */ - -#define CONFIG_SYS_OR2_PRELIM 0xfc006901 - - /* LB sdram refresh timer, about 6us */ -#define CONFIG_SYS_LBC_LSRT 0x32000000 - /* LB refresh timer prescal, 266MHz/32 */ -#define CONFIG_SYS_LBC_MRTPR 0x20000000 - -#define CONFIG_SYS_LBC_LSDMR_COMMON 0x0063b723 - -#endif - -/* - * Windows to access PIB via local bus - */ - /* windows base 0xf8008000 */ -#define CONFIG_SYS_LBLAWBAR3_PRELIM 0xf8008000 -#define CONFIG_SYS_LBLAWAR3_PRELIM 0x8000000f /* windows size 64KB */ - -/* * Serial Port */ #define CONFIG_CONS_INDEX 1 diff --git a/include/configs/MPC832XEMDS.h b/include/configs/MPC832XEMDS.h index 42ec3c3..2377972 100644 --- a/include/configs/MPC832XEMDS.h +++ b/include/configs/MPC832XEMDS.h @@ -210,12 +210,22 @@
#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE \ - | (2 << BR_PS_SHIFT) /* 16 bit port */ \ - | BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM 0xfe006ff7 /* 16MB Flash size */ + | BR_PS_16 /* 16 bit port */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xfe006ff7 */
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 128 /* sectors per device */ @@ -228,94 +238,67 @@ #define CONFIG_SYS_BCSR 0xF8000000 /* Access window base at BCSR base */ #define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_BCSR - /* Access window size 32K */ -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000E - - /* Port size=8bit, MSEL=GPCM */ -#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR|0x00000801) -#define CONFIG_SYS_OR1_PRELIM 0xFFFFE9f7 /* length 32K */ - -/* - * SDRAM on the Local Bus - */ -#undef CONFIG_SYS_LB_SDRAM /* The board has not SRDAM on local bus */ - -#ifdef CONFIG_SYS_LB_SDRAM -#define CONFIG_SYS_LBC_SDRAM_BASE 0xF0000000 /* SDRAM base address */ -#define CONFIG_SYS_LBC_SDRAM_SIZE 64 /* LBC SDRAM is 64MB */ - -#define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_LBC_SDRAM_BASE -#define CONFIG_SYS_LBLAWAR2_PRELIM 0x80000019 /* 64MB */ - -/*local bus BR2, OR2 definition for SDRAM if soldered on the EPB board */ -/* - * Base Register 2 and Option Register 2 configure SDRAM. - * The SDRAM base address, CONFIG_SYS_LBC_SDRAM_BASE, is 0xf0000000. - * - * For BR2, need: - * Base address of 0xf0000000 = BR[0:16] = 1111 0000 0000 0000 0 - * port size = 32-bits = BR2[19:20] = 11 - * no parity checking = BR2[21:22] = 00 - * SDRAM for MSEL = BR2[24:26] = 011 - * Valid = BR[31] = 1 - * - * 0 4 8 12 16 20 24 28 - * 1111 0000 0000 0000 0001 1000 0110 0001 = f0001861 - * - * CONFIG_SYS_LBC_SDRAM_BASE should be masked and OR'ed into - * the top 17 bits of BR2. - */ - -#define CONFIG_SYS_BR2_PRELIM 0xf0001861 /*Port size=32bit, MSEL=SDRAM */ - -/* - * The SDRAM size in MB, CONFIG_SYS_LBC_SDRAM_SIZE, is 64. - * - * For OR2, need: - * 64MB mask for AM, OR2[0:7] = 1111 1100 - * XAM, OR2[17:18] = 11 - * 9 columns OR2[19-21] = 010 - * 13 rows OR2[23-25] = 100 - * EAD set for extra time OR[31] = 1 - * - * 0 4 8 12 16 20 24 28 - * 1111 1100 0000 0000 0110 1001 0000 0001 = fc006901 - */ - -#define CONFIG_SYS_OR2_PRELIM 0xfc006901 - - /* LB sdram refresh timer, about 6us */ -#define CONFIG_SYS_LBC_LSRT 0x32000000 - /* LB refresh timer prescal, 266MHz/32 */ -#define CONFIG_SYS_LBC_MRTPR 0x20000000 - -#define CONFIG_SYS_LBC_LSDMR_COMMON 0x0063b723 - -#endif +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_32KB) + +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR \ + | BR_PS_8 \ + | BR_MS_GPCM \ + | BR_V) +#define CONFIG_SYS_OR1_PRELIM (OR_AM_32KB \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xFFFFE9F7 */
/* * Windows to access PIB via local bus */ - /* windows base 0xf8008000 */ -#define CONFIG_SYS_LBLAWBAR3_PRELIM 0xf8008000 - /* windows size 64KB */ -#define CONFIG_SYS_LBLAWAR3_PRELIM 0x8000000f + /* PIB window base 0xF8008000 */ +#define CONFIG_SYS_PIB_BASE 0xF8008000 +#define CONFIG_SYS_PIB_WINDOW_SIZE (32 * 1024) +#define CONFIG_SYS_LBLAWBAR3_PRELIM CONFIG_SYS_PIB_BASE +#define CONFIG_SYS_LBLAWAR3_PRELIM (LBLAWAR_EN | LBLAWAR_64KB)
/* * CS2 on Local Bus, to PIB */ - /* CS2 base address at 0xf8008000 */ -#define CONFIG_SYS_BR2_PRELIM 0xf8008801 - /* size 32KB, port size 8bit, GPCM */ -#define CONFIG_SYS_OR2_PRELIM 0xffffe9f7 +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_PIB_BASE \ + | BR_PS_8 \ + | BR_MS_GPCM \ + | BR_V) + /* 0xF8008801 */ +#define CONFIG_SYS_OR2_PRELIM (P2SZ_TO_AM(CONFIG_SYS_PIB_WINDOW_SIZE) \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xffffe9f7 */
/* * CS3 on Local Bus, to PIB */ - /* CS3 base address at 0xf8010000 */ -#define CONFIG_SYS_BR3_PRELIM 0xf8010801 - /* size 32KB, port size 8bit, GPCM */ -#define CONFIG_SYS_OR3_PRELIM 0xffffe9f7 +#define CONFIG_SYS_BR3_PRELIM ((CONFIG_SYS_PIB_BASE + \ + CONFIG_SYS_PIB_WINDOW_SIZE) \ + | BR_PS_8 \ + | BR_MS_GPCM \ + | BR_V) + /* 0xF8010801 */ +#define CONFIG_SYS_OR3_PRELIM (P2SZ_TO_AM(CONFIG_SYS_PIB_WINDOW_SIZE) \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xffffe9f7 */
/* * Serial Port diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index f720797..c41ef31 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -162,21 +162,23 @@ #define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */ /* #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE */
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | \ - (2 << BR_PS_SHIFT) | /* 16 bit port */ \ - BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) \ +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE \ + | BR_PS_16 /* 16 bit port */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ | OR_UPM_XAM \ | OR_GPCM_CSNT \ | OR_GPCM_ACS_DIV2 \ | OR_GPCM_XACS \ | OR_GPCM_SCY_15 \ - | OR_GPCM_TRLX \ - | OR_GPCM_EHTR \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ | OR_GPCM_EAD) + /* window base at flash base */ #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000018 /* 32 MB window size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_32MB)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 256 /* max sectors per device */ @@ -199,11 +201,19 @@ #define CONFIG_SYS_BCSR 0xE2400000 /* Access window base at BCSR base */ #define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_BCSR - /* Access window size 32K */ -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000E - /* Port-size=8bit, MSEL=GPCM */ -#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR|0x00000801) -#define CONFIG_SYS_OR1_PRELIM 0xFFFFE8F0 /* length 32K */ +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_32KB) +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR \ + | BR_PS_8 \ + | BR_MS_GPCM \ + | BR_V) + /* 0x00000801 */ +#define CONFIG_SYS_OR1_PRELIM (OR_AM_32KB \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_CLEAR \ + | OR_GPCM_EHTR_CLEAR) + /* 0xFFFFE8F0 */
#define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xFD000000 /* Initial RAM addr */ @@ -247,15 +257,15 @@ * * 0 4 8 12 16 20 24 28 * 1111 0000 0000 0000 0001 1000 0110 0001 = F0001861 - * - * FIXME: CONFIG_SYS_LBC_SDRAM_BASE should be masked and OR'ed into - * FIXME: the top 17 bits of BR2. */
- /* Port-size=32bit, MSEL=SDRAM */ -#define CONFIG_SYS_BR2_PRELIM 0xF0001861 -#define CONFIG_SYS_LBLAWBAR2_PRELIM 0xF0000000 -#define CONFIG_SYS_LBLAWAR2_PRELIM 0x80000019 /* 64M */ +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_LBC_SDRAM_BASE \ + | BR_PS_32 /* 32-bit port */ \ + | BR_MS_SDRAM /* MSEL = SDRAM */ \ + | BR_V) /* Valid */ + /* 0xF0001861 */ +#define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_LBC_SDRAM_BASE +#define CONFIG_SYS_LBLAWAR2_PRELIM (LBLAWAR_EN | LBLAWAR_64MB)
/* * The SDRAM size in MB, CONFIG_SYS_LBC_SDRAM_SIZE, is 64. @@ -271,7 +281,12 @@ * 1111 1100 0000 0000 0110 1001 0000 0001 = FC006901 */
-#define CONFIG_SYS_OR2_PRELIM 0xFC006901 +#define CONFIG_SYS_OR2_PRELIM (OR_AM_64MB \ + | OR_SDRAM_XAM \ + | ((9 - OR_SDRAM_MIN_COLS) << OR_SDRAM_COLS_SHIFT) \ + | ((13 - OR_SDRAM_MIN_ROWS) << OR_SDRAM_ROWS_SHIFT) \ + | OR_SDRAM_EAD) + /* 0xFC006901 */
/* LB sdram refresh timer, about 6us */ #define CONFIG_SYS_LBC_LSRT 0x32000000 diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index 8ad494f..d0586af 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -235,7 +235,6 @@ boards, we say we have two, but don't display a message if we find only one. */ #define CONFIG_SYS_FLASH_BANKS_LIST \ {CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE + 0x800000} #define CONFIG_SYS_FLASH_SIZE 16 /* FLASH size in MB */ -#define CONFIG_SYS_FLASH_SIZE_SHIFT 4 /* log2 of the above value */ #define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */
/* Vitesse 7385 */ @@ -256,19 +255,21 @@ boards, we say we have two, but don't display a message if we find only one. */
/* Flash */
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | BR_PS_16 | BR_V) -#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) \ +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE \ + | BR_PS_16 \ + | BR_MS_GPCM \ + | BR_V) +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ | OR_UPM_XAM \ | OR_GPCM_CSNT \ | OR_GPCM_ACS_DIV2 \ | OR_GPCM_XACS \ | OR_GPCM_SCY_15 \ - | OR_GPCM_TRLX \ - | OR_GPCM_EHTR \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ | OR_GPCM_EAD) #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN \ - | (0x13 + CONFIG_SYS_FLASH_SIZE_SHIFT)) +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_16MB)
/* Vitesse 7385 */
@@ -276,14 +277,17 @@ boards, we say we have two, but don't display a message if we find only one. */
-#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_VSC7385_BASE | BR_PS_8 | BR_V) +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_VSC7385_BASE \ + | BR_PS_8 \ + | BR_MS_GPCM \ + | BR_V) #define CONFIG_SYS_OR1_PRELIM (OR_AM_128KB \ | OR_GPCM_CSNT \ | OR_GPCM_XACS \ | OR_GPCM_SCY_15 \ | OR_GPCM_SETA \ - | OR_GPCM_TRLX \ - | OR_GPCM_EHTR \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ | OR_GPCM_EAD)
#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_VSC7385_BASE @@ -294,14 +298,17 @@ boards, we say we have two, but don't display a message if we find only one. */ /* LED */
#define CONFIG_SYS_LED_BASE 0xF9000000 -#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_LED_BASE | BR_PS_8 | BR_V) +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_LED_BASE \ + | BR_PS_8 \ + | BR_MS_GPCM \ + | BR_V) #define CONFIG_SYS_OR2_PRELIM (OR_AM_2MB \ | OR_GPCM_CSNT \ | OR_GPCM_ACS_DIV2 \ | OR_GPCM_XACS \ | OR_GPCM_SCY_9 \ - | OR_GPCM_TRLX \ - | OR_GPCM_EHTR \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ | OR_GPCM_EAD)
/* Compact Flash */ diff --git a/include/configs/MPC8360EMDS.h b/include/configs/MPC8360EMDS.h index 3af4b9a..3a636ec 100644 --- a/include/configs/MPC8360EMDS.h +++ b/include/configs/MPC8360EMDS.h @@ -207,19 +207,20 @@
#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE \ - | (2 << BR_PS_SHIFT) /* 16 bit port */ \ - | BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) \ - | OR_UPM_XAM \ + | BR_PS_16 /* 16 bit port */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ + | OR_GPCM_XAM \ | OR_GPCM_CSNT \ | OR_GPCM_ACS_DIV2 \ | OR_GPCM_XACS \ | OR_GPCM_SCY_15 \ - | OR_GPCM_TRLX \ - | OR_GPCM_EHTR \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ | OR_GPCM_EAD)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ @@ -233,11 +234,21 @@ #define CONFIG_SYS_BCSR 0xF8000000 /* Access window base at BCSR base */ #define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_BCSR -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000F /* Access window size 64K */ - - /* Port size=8bit, MSEL=GPCM */ -#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR|0x00000801) -#define CONFIG_SYS_OR1_PRELIM 0xFFFFE9f7 /* length 32K */ +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_64KB) + +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR \ + | BR_PS_8 \ + | BR_MS_GPCM \ + | BR_V) +#define CONFIG_SYS_OR1_PRELIM (OR_AM_32KB \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xFFFFE9F7 */
/* * SDRAM on the Local Bus @@ -249,7 +260,7 @@
#ifdef CONFIG_SYS_LB_SDRAM #define CONFIG_SYS_LBLAWBAR2 0 -#define CONFIG_SYS_LBLAWAR2 0x80000019 /* 64MB */ +#define CONFIG_SYS_LBLAWAR2 (LBLAWAR_EN | LBLAWAR_64MB)
/*local bus BR2, OR2 definition for SDRAM if soldered on the EPB board */ /* @@ -266,7 +277,8 @@ * xxxx xxxx xxxx xxxx x001 1000 0110 0001 = 00001861 */
-#define CONFIG_SYS_BR2 0x00001861 /*Port size=32bit, MSEL=SDRAM */ +/* Port size=32bit, MSEL=DRAM */ +#define CONFIG_SYS_BR2 (BR_PS_32 | BR_MS_SDRAM | BR_V) /* 0xF0001861 */
/* * The SDRAM size in MB, CONFIG_SYS_LBC_SDRAM_SIZE, is 64. @@ -282,7 +294,12 @@ * 1111 1100 0000 0000 0110 1001 0000 0001 = fc006901 */
-#define CONFIG_SYS_OR2 0xfc006901 +#define CONFIG_SYS_OR2 (MEG_TO_AM(CONFIG_SYS_LBC_SDRAM_SIZE) \ + | OR_SDRAM_XAM \ + | ((9 - OR_SDRAM_MIN_COLS) << OR_SDRAM_COLS_SHIFT) \ + | ((13 - OR_SDRAM_MIN_ROWS) << OR_SDRAM_ROWS_SHIFT) \ + | OR_SDRAM_EAD) + /* 0xFC006901 */
/* LB sdram refresh timer, about 6us */ #define CONFIG_SYS_LBC_LSRT 0x32000000 @@ -303,22 +320,54 @@ #endif
/* - * Windows to access PIB via local bus + * Windows to access Platform I/O Boards (PIB) via local bus */ -#define CONFIG_SYS_LBLAWBAR3_PRELIM 0xf8010000 /* windows base 0xf8010000 */ -#define CONFIG_SYS_LBLAWAR3_PRELIM 0x8000000e /* windows size 32KB */ +#define CONFIG_SYS_PIB_BASE 0xF8008000 +#define CONFIG_SYS_PIB_WINDOW_SIZE (32 * 1024) + +/* [RFC] This LBLAW only covers the 2nd window (CS5) */ +#define CONFIG_SYS_LBLAWBAR3_PRELIM \ + CONFIG_SYS_PIB_BASE + CONFIG_SYS_PIB_WINDOW_SIZE +#define CONFIG_SYS_LBLAWAR3_PRELIM (LBLAWAR_EN | LBLAWAR_32KB)
/* * CS4 on Local Bus, to PIB */ -#define CONFIG_SYS_BR4_PRELIM 0xf8008801 /* CS4 base address at 0xf8008000 */ -#define CONFIG_SYS_OR4_PRELIM 0xffffe9f7 /* size 32KB, port size 8bit, GPCM */ + /* CS4 base address at 0xf8008000 */ +#define CONFIG_SYS_BR4_PRELIM (CONFIG_SYS_PIB_BASE \ + | BR_PS_8 \ + | BR_MS_GPCM \ + | BR_V) + /* 0xF8008801 */ +#define CONFIG_SYS_OR4_PRELIM (OR_AM_32KB \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xffffe9f7 */
/* * CS5 on Local Bus, to PIB */ -#define CONFIG_SYS_BR5_PRELIM 0xf8010801 /* CS5 base address at 0xf8010000 */ -#define CONFIG_SYS_OR5_PRELIM 0xffffe9f7 /* size 32KB, port size 8bit, GPCM */ + /* CS5 base address at 0xf8010000 */ +#define CONFIG_SYS_BR5_PRELIM ((CONFIG_SYS_PIB_BASE + \ + CONFIG_SYS_PIB_WINDOW_SIZE) \ + | BR_PS_8 \ + | BR_MS_GPCM \ + | BR_V) + /* 0xF8010801 */ +#define CONFIG_SYS_OR5_PRELIM (CONFIG_SYS_PIB_BASE \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xffffe9f7 */
/* * Serial Port diff --git a/include/configs/MPC8360ERDK.h b/include/configs/MPC8360ERDK.h index 68603df..b187030 100644 --- a/include/configs/MPC8360ERDK.h +++ b/include/configs/MPC8360ERDK.h @@ -198,19 +198,20 @@
#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE \ - | (2 << BR_PS_SHIFT) /* 16 bit port */ \ - | BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) \ + | BR_PS_16 /* 16 bit port */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ | OR_UPM_XAM \ | OR_GPCM_CSNT \ | OR_GPCM_ACS_DIV2 \ | OR_GPCM_XACS \ | OR_GPCM_SCY_15 \ - | OR_GPCM_TRLX \ - | OR_GPCM_EHTR \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ | OR_GPCM_EAD)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ @@ -228,11 +229,20 @@ #define CONFIG_MTD_NAND_VERIFY_WRITE
#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_NAND_BASE -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000001b /* Access window size 4K */ +/* + * [RFC] Comment said 4KB window; code said 256MB window; OR1 says 64MB + * ... What's correct? + */ +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_256MB)
/* Port size 8 bit, UPMA */ -#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_NAND_BASE | 0x00000881) -#define CONFIG_SYS_OR1_PRELIM 0xfc000001 +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_NAND_BASE \ + | BR_PS_8 \ + | BR_MS_UPMA \ + | BR_V) + /* 0x60000881 */ +#define CONFIG_SYS_OR1_PRELIM (OR_AM_64MB | OR_UPM_EAD) + /* 0xFC000001 */
/* * Fujitsu MB86277 (MINT) graphics controller @@ -240,12 +250,16 @@ #define CONFIG_SYS_VIDEO_BASE 0x70000000
#define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_VIDEO_BASE -#define CONFIG_SYS_LBLAWAR2_PRELIM 0x80000019 /* Access window size 64MB */ +#define CONFIG_SYS_LBLAWAR2_PRELIM (LBLAWAR_EN | LBLAWAR_64MB)
/* Port size 32 bit, UPMB */ - /* PS=11, UPMB */ -#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_VIDEO_BASE | 0x000018a1) -#define CONFIG_SYS_OR2_PRELIM 0xfc000001 /* (64MB, EAD=1) */ +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_VIDEO_BASE \ + | BR_PS_32 \ + | BR_MS_UPMB \ + | BR_V) + /* 0x000018a1 */ +#define CONFIG_SYS_OR2_PRELIM (OR_AM_64MB | OR_UPM_EAD) + /* 0xFC000001 */
/* * Serial Port diff --git a/include/configs/MPC837XEMDS.h b/include/configs/MPC837XEMDS.h index 008f0ef..4bee2c5 100644 --- a/include/configs/MPC837XEMDS.h +++ b/include/configs/MPC837XEMDS.h @@ -243,19 +243,20 @@
#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE \ - | (2 << BR_PS_SHIFT) /* 16 bit port */ \ - | BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) \ + | BR_PS_16 /* 16 bit port */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ | OR_UPM_XAM \ | OR_GPCM_CSNT \ | OR_GPCM_ACS_DIV2 \ | OR_GPCM_XACS \ | OR_GPCM_SCY_15 \ - | OR_GPCM_TRLX \ - | OR_GPCM_EHTR \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ | OR_GPCM_EAD) /* 0xFE000FF7 */
@@ -272,11 +273,22 @@ #define CONFIG_SYS_BCSR 0xF8000000 /* Access window base at BCSR base */ #define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_BCSR -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000E /* Access window size 32K */ - - /* Port size=8bit, MSEL=GPCM */ -#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR | 0x00000801) -#define CONFIG_SYS_OR1_PRELIM 0xFFFFE9f7 /* length 32K */ +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_32KB) + +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR \ + | BR_PS_8 \ + | BR_MS_GPCM \ + | BR_V) + /* 0xF8000801 */ +#define CONFIG_SYS_OR1_PRELIM (OR_AM_32KB \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xFFFFE9F7 */
/* * NAND Flash on the Local Bus @@ -286,13 +298,13 @@ #define CONFIG_SYS_MAX_NAND_DEVICE 1 #define CONFIG_NAND_FSL_ELBC 1
-#define CONFIG_SYS_NAND_BASE 0xE0600000 /* 0xE0600000 */ +#define CONFIG_SYS_NAND_BASE 0xE0600000 #define CONFIG_SYS_BR3_PRELIM (CONFIG_SYS_NAND_BASE \ - | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ + | BR_DECC_CHK_GEN /* Use HW ECC */ \ | BR_PS_8 /* 8 bit port */ \ | BR_MS_FCM /* MSEL = FCM */ \ - | BR_V) /* valid */ -#define CONFIG_SYS_OR3_PRELIM (0xFFFF8000 /* length 32K */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR3_PRELIM (OR_AM_32KB \ | OR_FCM_BCTLD \ | OR_FCM_CST \ | OR_FCM_CHT \ @@ -303,7 +315,7 @@ /* 0xFFFF919E */
#define CONFIG_SYS_LBLAWBAR3_PRELIM CONFIG_SYS_NAND_BASE -#define CONFIG_SYS_LBLAWAR3_PRELIM 0x8000000E /* 32KB */ +#define CONFIG_SYS_LBLAWAR3_PRELIM (LBLAWAR_EN | LBLAWAR_32KB)
/* * Serial Port diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index 2355964..ef89e91 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -275,14 +275,15 @@ #define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000016 /* 8 MB window size */
#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE \ - | (2 << BR_PS_SHIFT) /* 16 bit port */ \ - | BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM (0xFF800000 /* 8 MByte */ \ + | BR_PS_16 /* 16 bit port */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ | OR_GPCM_XACS \ | OR_GPCM_SCY_9 \ - | OR_GPCM_EHTR \ + | OR_GPCM_EHTR_SET \ | OR_GPCM_EAD) - /* 0xFF806FF7 TODO SLOW 8 MB flash size */ + /* 0xFF800191 */
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 256 /* max sectors per device */ @@ -294,13 +295,13 @@ /* * NAND Flash on the Local Bus */ -#define CONFIG_SYS_NAND_BASE 0xE0600000 /* 0xE0600000 */ +#define CONFIG_SYS_NAND_BASE 0xE0600000 #define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_NAND_BASE \ - | (2 << BR_DECC_SHIFT) /* Use HW ECC */ \ - | BR_PS_8 | /* 8 bit Port */ \ - | BR_MS_FCM | /* MSEL = FCM */ \ + | BR_DECC_CHK_GEN /* Use HW ECC */ \ + | BR_PS_8 /* 8 bit port */ \ + | BR_MS_FCM /* MSEL = FCM */ \ | BR_V) /* valid */ -#define CONFIG_SYS_OR1_PRELIM (0xFFFF8000 /* length 32K */ \ +#define CONFIG_SYS_OR1_PRELIM (OR_AM_32KB \ | OR_FCM_CSCT \ | OR_FCM_CST \ | OR_FCM_CHT \ @@ -308,7 +309,7 @@ | OR_FCM_TRLX \ | OR_FCM_EHTR) #define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_NAND_BASE -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000E /* 32KB */ +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_32KB)
/* Vitesse 7385 */
@@ -316,11 +317,24 @@
-#define CONFIG_SYS_BR2_PRELIM 0xf0000801 /* Base address */ -#define CONFIG_SYS_OR2_PRELIM 0xfffe09ff /* 128K bytes*/ +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_VSC7385_BASE \ + | BR_PS_8 \ + | BR_MS_GPCM \ + | BR_V) + /* 0xF0000801 */ +#define CONFIG_SYS_OR2_PRELIM (OR_AM_128KB \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_SETA \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xfffe09ff */ + /* Access Base */ #define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_VSC7385_BASE -#define CONFIG_SYS_LBLAWAR2_PRELIM 0x80000010 /* Access Size 128K */ +#define CONFIG_SYS_LBLAWAR2_PRELIM (LBLAWAR_EN | LBLAWAR_128KB)
#endif
diff --git a/include/configs/MVBLM7.h b/include/configs/MVBLM7.h index 5e6b8c2..bfa0ab6 100644 --- a/include/configs/MVBLM7.h +++ b/include/configs/MVBLM7.h @@ -103,26 +103,27 @@
#define CONFIG_SYS_FLASH_BASE 0xFF800000 #define CONFIG_SYS_FLASH_SIZE 8 -#define CONFIG_SYS_FLASH_SIZE_SHIFT 3 #define CONFIG_SYS_FLASH_EMPTY_INFO #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 #define CONFIG_SYS_FLASH_WRITE_TOUT 500 #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 256
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | BR_PS_16 | BR_V) -#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) \ +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE \ + | BR_PS_16 \ + | BR_MS_GPCM \ + | BR_V) +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ | OR_UPM_XAM \ | OR_GPCM_CSNT \ | OR_GPCM_ACS_DIV2 \ | OR_GPCM_XACS \ | OR_GPCM_SCY_15 \ - | OR_GPCM_TRLX \ - | OR_GPCM_EHTR \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ | OR_GPCM_EAD) #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN \ - | (0x13 + CONFIG_SYS_FLASH_SIZE_SHIFT)) +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_8MB)
/* * U-Boot memory configuration diff --git a/include/configs/SIMPC8313.h b/include/configs/SIMPC8313.h index 3eb6f65..7b1af7b 100644 --- a/include/configs/SIMPC8313.h +++ b/include/configs/SIMPC8313.h @@ -151,26 +151,26 @@ #define CONFIG_NAND_FSL_ELBC 1
#define CONFIG_SYS_NAND_BR_PRELIM (CONFIG_SYS_NAND_BASE \ - | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ + | BR_DECC_CHK_GEN /* Use HW ECC */ \ | BR_PS_8 /* 8 bit Port */ \ | BR_MS_FCM /* MSEL = FCM */ \ | BR_V) /* valid */
#ifdef CONFIG_NAND_SP -#define CONFIG_SYS_NAND_OR_PRELIM (0xFFFF8000 /* length 32K */ \ +#define CONFIG_SYS_NAND_OR_PRELIM (OR_AM_32KB \ | OR_FCM_CSCT \ | OR_FCM_CST \ | OR_FCM_CHT \ | OR_FCM_SCY_1 \ | OR_FCM_TRLX \ | OR_FCM_EHTR) -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x8000000E /* 32KB */ -#define CONFIG_SYS_NAND_PAGE_SIZE (512) /* NAND chip page size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_32KB) +#define CONFIG_SYS_NAND_PAGE_SIZE 512 /* NAND chip page size */ /* NAND chip block size */ #define CONFIG_SYS_NAND_BLOCK_SIZE (16 << 10) #define NAND_CACHE_PAGES 32 #elif defined(CONFIG_NAND_LP) -#define CONFIG_SYS_NAND_OR_PRELIM (0xFFFC0000 /* length 256K */ \ +#define CONFIG_SYS_NAND_OR_PRELIM (OR_AM_256KB \ | OR_FCM_PGS \ | OR_FCM_CSCT \ | OR_FCM_CST \ @@ -178,8 +178,8 @@ | OR_FCM_SCY_1 \ | OR_FCM_TRLX \ | OR_FCM_EHTR) -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000011 /* 256KB */ -#define CONFIG_SYS_NAND_PAGE_SIZE (2048) /* NAND chip page size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_256KB) +#define CONFIG_SYS_NAND_PAGE_SIZE 2048 /* NAND chip page size */ /* NAND chip block size */ #define CONFIG_SYS_NAND_BLOCK_SIZE (128 << 10) #define NAND_CACHE_PAGES 64 diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index 1abfbb2..458b2d8 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -119,13 +119,12 @@ | OR_GPCM_SCY_5 \ | OR_GPCM_TRLX)
-#define CONFIG_SYS_PRELIM_OR_AM 0xc0000000 /* OR addr mask: 1 GiB */ +#define CONFIG_SYS_PRELIM_OR_AM OR_AM_1GB /* OR addr mask: 1 GiB */
#define CONFIG_SYS_OR0_PRELIM (CONFIG_SYS_PRELIM_OR_AM \ | CONFIG_SYS_OR_TIMING_FLASH)
- /* 1 GiB window size (2^(size + 1)) */ -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x8000001D +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_1GB)
/* Window base at flash base */ #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE diff --git a/include/configs/km/km83xx-common.h b/include/configs/km/km83xx-common.h index 9d28d8e..0a4e4a4 100644 --- a/include/configs/km/km83xx-common.h +++ b/include/configs/km/km83xx-common.h @@ -103,16 +103,17 @@ #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE
#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x8000001b /* 256MB window size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_256MB)
#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | \ - (2 << BR_PS_SHIFT) | /* 16 bit port size */ \ + BR_PS_16 | /* 16 bit port size */ \ + BR_MS_GPCM | /* MSEL = GPCM */ \ BR_V)
#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) | \ OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | \ OR_GPCM_SCY_5 | \ - OR_GPCM_TRLX | OR_GPCM_EAD) + OR_GPCM_TRLX_SET | OR_GPCM_EAD)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max num of flash banks */ #define CONFIG_SYS_MAX_FLASH_SECT 512 /* max num of sects on one chip */ @@ -123,15 +124,16 @@ */ /* Window base at flash base */ #define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_KMBEC_FPGA_BASE -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000001A /* 128MB window size */ +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_128MB)
#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_KMBEC_FPGA_BASE | \ - (1 << BR_PS_SHIFT) | /* 8 bit port size */ \ + BR_PS_8 | /* 8 bit port size */ \ + BR_MS_GPCM | /* MSEL = GPCM */ \ BR_V) #define CONFIG_SYS_OR1_PRELIM (MEG_TO_AM(CONFIG_SYS_KMBEC_FPGA_SIZE) | \ OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | \ OR_GPCM_SCY_2 | \ - OR_GPCM_TRLX | OR_GPCM_EAD) + OR_GPCM_TRLX_SET | OR_GPCM_EAD)
/* * Serial Port diff --git a/include/configs/kmeter1.h b/include/configs/kmeter1.h index c04bde9..6b5a6fe 100644 --- a/include/configs/kmeter1.h +++ b/include/configs/kmeter1.h @@ -137,15 +137,16 @@ * PAXE on the local bus CS3 */ #define CONFIG_SYS_LBLAWBAR3_PRELIM CONFIG_SYS_PAXE_BASE -#define CONFIG_SYS_LBLAWAR3_PRELIM 0x8000001C /* 512MB window size */ +#define CONFIG_SYS_LBLAWAR3_PRELIM (LBLAWAR_EN | LBLAWAR_512MB)
#define CONFIG_SYS_BR3_PRELIM (CONFIG_SYS_PAXE_BASE | \ - (1 << BR_PS_SHIFT) | /* 8 bit port size */ \ + BR_PS_8 | /* 8 bit port size */ \ + BR_MS_GPCM | /* MSEL = GPCM */ \ BR_V) #define CONFIG_SYS_OR3_PRELIM (MEG_TO_AM(CONFIG_SYS_PAXE_SIZE) | \ OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | \ OR_GPCM_SCY_2 | \ - OR_GPCM_TRLX | OR_GPCM_EAD) + OR_GPCM_TRLX_SET | OR_GPCM_EAD)
/* * MMU Setup diff --git a/include/configs/kmsupx5.h b/include/configs/kmsupx5.h index ccc1561..b0dd88c 100644 --- a/include/configs/kmsupx5.h +++ b/include/configs/kmsupx5.h @@ -69,8 +69,8 @@ OR_GPCM_CSNT | \ OR_GPCM_ACS_DIV4 | \ OR_GPCM_SCY_2 | \ - (OR_GPCM_TRLX & \ - (~OR_GPCM_EHTR)) | /* EHTR = 0 */ \ + OR_GPCM_TRLX_SET | \ + OR_GPCM_EHTR_CLEAR | \ OR_GPCM_EAD)
/* LPXF: icache cacheable, but dcache-inhibit and guarded */ diff --git a/include/configs/mpc8308_p1m.h b/include/configs/mpc8308_p1m.h index ff773ec..46bef57 100644 --- a/include/configs/mpc8308_p1m.h +++ b/include/configs/mpc8308_p1m.h @@ -248,18 +248,18 @@ #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_64MB)
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE /* Flash Base addr */ \ - | (2 << BR_PS_SHIFT) /* 16 bit port */ \ - | BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) \ +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE \ + | BR_PS_16 /* 16 bit port */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ | OR_UPM_XAM \ | OR_GPCM_CSNT \ | OR_GPCM_ACS_DIV2 \ | OR_GPCM_XACS \ | OR_GPCM_SCY_4 \ - | OR_GPCM_TRLX \ - | OR_GPCM_EHTR \ - | OR_GPCM_EAD) + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 512 @@ -274,11 +274,12 @@ */ #define CONFIG_SYS_SJA1000_BASE 0xFBFF0000 #define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_SJA1000_BASE \ - | (1 << BR_PS_SHIFT) /* 8 bit port */ \ - | BR_V) /* valid */ -#define CONFIG_SYS_OR1_PRELIM (0xFFFF8000 /* length 32K */ \ + | BR_PS_8 /* 8 bit port size */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR1_PRELIM (OR_AM_32KB \ | OR_GPCM_SCY_5 \ - | OR_GPCM_EHTR) + | OR_GPCM_EHTR_SET) /* 0xFFFF8052 */
#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_SJA1000_BASE @@ -289,11 +290,12 @@ */ #define CONFIG_SYS_CPLD_BASE 0xFBFF8000 #define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_CPLD_BASE \ - | (1 << BR_PS_SHIFT) /* 8 bit port */ \ - | BR_V) /* valid */ -#define CONFIG_SYS_OR2_PRELIM (0xFFFF8000 /* length 32K */ \ + | BR_PS_8 /* 8 bit port */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR2_PRELIM (OR_AM_32KB \ | OR_GPCM_SCY_4 \ - | OR_GPCM_EHTR) + | OR_GPCM_EHTR_SET) /* 0xFFFF8042 */
#define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_CPLD_BASE diff --git a/include/configs/sbc8349.h b/include/configs/sbc8349.h index 9a16e74..e9eb632 100644 --- a/include/configs/sbc8349.h +++ b/include/configs/sbc8349.h @@ -136,8 +136,8 @@ /* * SDRAM on the Local Bus */ -#define CONFIG_SYS_LBC_SDRAM_BASE 0x10000000 /* Localbus SDRAM */ -#define CONFIG_SYS_LBC_SDRAM_SIZE 128 /* LBC SDRAM is 128MB */ +#define CONFIG_SYS_LBC_SDRAM_BASE 0xF0000000 /* Localbus SDRAM */ +#define CONFIG_SYS_LBC_SDRAM_SIZE 64 /* LBC SDRAM is 64MB */
/* * FLASH on the Local Bus @@ -148,14 +148,25 @@ #define CONFIG_SYS_FLASH_SIZE 8 /* flash size in MB */ /* #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE */
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE \ - | (2 << BR_PS_SHIFT) /* 16 bit port */ \ - | BR_V) /* valid */ +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE \ + | BR_PS_16 /* 16 bit port */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ + +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xFF806FF7 */
-#define CONFIG_SYS_OR0_PRELIM 0xFF806FF7 /* 8 MB flash size */ /* window base at flash base */ #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000016 /* 8 MB window size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_8MB)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 64 /* sectors per device */ @@ -212,15 +223,15 @@ * * 0 4 8 12 16 20 24 28 * 1111 0000 0000 0000 0001 1000 0110 0001 = F0001861 - * - * FIXME: CONFIG_SYS_LBC_SDRAM_BASE should be masked and OR'ed into - * FIXME: the top 17 bits of BR2. */
- /* Port-size=32bit, MSEL=SDRAM */ -#define CONFIG_SYS_BR2_PRELIM 0xF0001861 -#define CONFIG_SYS_LBLAWBAR2_PRELIM 0xF0000000 -#define CONFIG_SYS_LBLAWAR2_PRELIM 0x80000019 /* 64M */ +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_LBC_SDRAM_BASE \ + | BR_PS_32 \ + | BR_MS_SDRAM \ + | BR_V) + /* 0xF0001861 */ +#define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_LBC_SDRAM_BASE +#define CONFIG_SYS_LBLAWAR2_PRELIM (LBLAWAR_EN | LBLAWAR_64MB)
/* * The SDRAM size in MB, CONFIG_SYS_LBC_SDRAM_SIZE, is 64. @@ -236,7 +247,12 @@ * 1111 1100 0000 0000 0110 1001 0000 0001 = FC006901 */
-#define CONFIG_SYS_OR2_PRELIM 0xFC006901 +#define CONFIG_SYS_OR2_PRELIM (MEG_TO_AM(CONFIG_SYS_LBC_SDRAM_SIZE) \ + | OR_SDRAM_XAM \ + | ((9 - OR_SDRAM_MIN_COLS) << OR_SDRAM_COLS_SHIFT) \ + | ((13 - OR_SDRAM_MIN_ROWS) << OR_SDRAM_ROWS_SHIFT) \ + | OR_SDRAM_EAD) + /* 0xFC006901 */
/* LB sdram refresh timer, about 6us */ #define CONFIG_SYS_LBC_LSRT 0x32000000 @@ -619,12 +635,15 @@ | BATU_VS \ | BATU_VP)
-/* SDRAM @ 0xF0000000, stack in DCACHE 0xFDF00000 & FLASH @ 0xFE000000 */ -#define CONFIG_SYS_IBAT6L (0xF0000000 \ +/* LBC SDRAM @ 0xF0000000, stack in DCACHE 0xFDF00000 & FLASH @ 0xFE000000 */ +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_LBC_SDRAM_BASE \ | BATL_PP_RW \ | BATL_MEMCOHERENCE \ | BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT6U (0xF0000000 | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT6U (CONFIG_SYS_LBC_SDRAM_BASE \ + | BATU_BL_256M \ + | BATU_VS \ + | BATU_VP)
#define CONFIG_SYS_IBAT7L (0) #define CONFIG_SYS_IBAT7U (0) diff --git a/include/configs/suvd3.h b/include/configs/suvd3.h index 5f2e1e3..ae19701 100644 --- a/include/configs/suvd3.h +++ b/include/configs/suvd3.h @@ -70,7 +70,7 @@ OR_GPCM_CSNT | \ OR_GPCM_ACS_DIV4 | \ OR_GPCM_SCY_3 | \ - OR_GPCM_TRLX) + OR_GPCM_TRLX_SET)
#define CONFIG_SYS_MAMR (MxMR_GPL_x4DIS | \ 0x0000c000 | \ diff --git a/include/configs/tuda1.h b/include/configs/tuda1.h index 7ae7d58..577bbd0 100644 --- a/include/configs/tuda1.h +++ b/include/configs/tuda1.h @@ -73,8 +73,8 @@ OR_GPCM_CSNT | \ OR_GPCM_ACS_DIV4 | \ OR_GPCM_SCY_2 | \ - (OR_GPCM_TRLX & \ - (~OR_GPCM_EHTR)) | /* EHTR = 0 */ \ + OR_GPCM_TRLX_SET | \ + OR_GPCM_EHTR_CLEAR | \ OR_GPCM_EAD) /* * PINC3 on the local bus CS3 @@ -91,11 +91,10 @@
#define CONFIG_SYS_OR3_PRELIM (MEG_TO_AM(CONFIG_SYS_APP2_SIZE) | \ OR_GPCM_CSNT | \ - (OR_GPCM_ACS_DIV2 & /* ACS = 11 */\ - (~OR_GPCM_XACS)) | /* XACS = 0 */\ - (OR_GPCM_SCY_2 & \ - (~OR_GPCM_EHTR)) | /* EHTR = 0 */ \ - OR_GPCM_TRLX) + OR_GPCM_ACS_DIV2 | \ + OR_GPCM_SCY_2 | \ + OR_GPCM_TRLX_SET | \ + OR_GPCM_EHTR_CLEAR)
#define CONFIG_SYS_MAMR (MxMR_GPL_x4DIS | \ 0x0000c000 | \ diff --git a/include/configs/tuxa1.h b/include/configs/tuxa1.h index 815c260..2d9af3f 100644 --- a/include/configs/tuxa1.h +++ b/include/configs/tuxa1.h @@ -67,8 +67,8 @@ OR_GPCM_CSNT | \ OR_GPCM_ACS_DIV4 | \ OR_GPCM_SCY_2 | \ - (OR_GPCM_TRLX & \ - (~OR_GPCM_EHTR)) | /* EHTR = 0 */ \ + OR_GPCM_TRLX_SET | \ + OR_GPCM_EHTR_CLEAR | \ OR_GPCM_EAD) /* * PINC2 on the local bus CS3 @@ -85,11 +85,10 @@
#define CONFIG_SYS_OR3_PRELIM (MEG_TO_AM(CONFIG_SYS_PINC2_SIZE) | \ OR_GPCM_CSNT | \ - (OR_GPCM_ACS_DIV2 & /* ACS = 11 */ \ - (~OR_GPCM_XACS)) | /* XACS = 0 */ \ - (OR_GPCM_SCY_2 & \ - (~OR_GPCM_EHTR)) | /* EHTR = 0 */ \ - OR_GPCM_TRLX) + OR_GPCM_ACS_DIV2 | \ + OR_GPCM_SCY_2 | \ + OR_GPCM_TRLX_SET | \ + OR_GPCM_EHTR_CLEAR)
#define CONFIG_SYS_MAMR (MxMR_GPL_x4DIS | \ 0x0000c000 | \ diff --git a/include/configs/ve8313.h b/include/configs/ve8313.h index ca64022..0cddca3 100644 --- a/include/configs/ve8313.h +++ b/include/configs/ve8313.h @@ -146,18 +146,19 @@ #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE /* buffer up multiple bytes */
#define CONFIG_SYS_NOR_BR_PRELIM (CONFIG_SYS_FLASH_BASE \ - | (2 << BR_PS_SHIFT) /* 16 bit */ \ - | BR_V) /* valid */ + | BR_PS_16 /* 16 bit */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ #define CONFIG_SYS_NOR_OR_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ | OR_GPCM_CSNT \ | OR_GPCM_ACS_DIV4 \ | OR_GPCM_SCY_5 \ - | OR_GPCM_TRLX \ + | OR_GPCM_TRLX_SET \ | OR_GPCM_EAD) /* 0xfe000c55 */
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 256 /* sectors per dev */ @@ -209,7 +210,7 @@ | BR_MS_FCM \ | BR_V) /* valid */ /* 0x61000c21 */ -#define CONFIG_SYS_NAND_OR_PRELIM (0xffff8000 \ +#define CONFIG_SYS_NAND_OR_PRELIM (OR_AM_32KB \ | OR_FCM_BCTLD \ | OR_FCM_CHT \ | OR_FCM_SCY_2 \ @@ -223,7 +224,7 @@ #define CONFIG_SYS_OR1_PRELIM CONFIG_SYS_NAND_OR_PRELIM
#define CONFIG_SYS_NAND_LBLAWBAR_PRELIM CONFIG_SYS_LBLAWBAR1_PRELIM #define CONFIG_SYS_NAND_LBLAWAR_PRELIM CONFIG_SYS_LBLAWAR1_PRELIM @@ -233,12 +234,12 @@ | BR_PS_8 \ | BR_V) /* 0x60000801 */ -#define CONFIG_SYS_OR2_PRELIM (0xfffe0000 \ +#define CONFIG_SYS_OR2_PRELIM (OR_AM_128KB \ | OR_GPCM_CSNT \ | OR_GPCM_XACS \ | OR_GPCM_SCY_3 \ - | OR_GPCM_TRLX \ - | OR_GPCM_EHTR \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ | OR_GPCM_EAD) /* 0xfffe0937 */ /* local bus read write buffer mapping SRAM@0x64000000 */ @@ -247,12 +248,12 @@ | BR_V) /* 0x62001001 */
-#define CONFIG_SYS_OR3_PRELIM (0xfe000000 \ +#define CONFIG_SYS_OR3_PRELIM (OR_AM_32MB \ | OR_GPCM_CSNT \ | OR_GPCM_XACS \ | OR_GPCM_SCY_15 \ - | OR_GPCM_TRLX \ - | OR_GPCM_EHTR \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ | OR_GPCM_EAD) /* 0xfe0009f7 */
diff --git a/include/configs/vme8349.h b/include/configs/vme8349.h index a0f25be..6677804 100644 --- a/include/configs/vme8349.h +++ b/include/configs/vme8349.h @@ -123,29 +123,56 @@ #define CONFIG_SYS_FLASH_BASE 0xffc00000 /* start of FLASH */ #define CONFIG_SYS_FLASH_SIZE 4 /* flash size in MB */ #define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | \ - (2 << BR_PS_SHIFT) | /* 16bit */ \ - BR_V) /* valid */ - -#define CONFIG_SYS_OR0_PRELIM 0xffc06ff7 /* 4 MB flash size */ + BR_PS_16 | /* 16bit */ \ + BR_MS_GPCM | /* MSEL = GPCM */ \ + BR_V) /* valid */ + +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xffc06ff7 */ #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000015 /* 4 MB window size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_4MB) #else #define CONFIG_SYS_FLASH_BASE 0xf8000000 /* start of FLASH */ #define CONFIG_SYS_FLASH_SIZE 128 /* flash size in MB */ #define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | \ - (2 << BR_PS_SHIFT) | /* 16bit */ \ - BR_V) /* valid */ - -#define CONFIG_SYS_OR0_PRELIM 0xf8006ff7 /* 128 MB flash size */ + BR_PS_16 | /* 16bit */ \ + BR_MS_GPCM | /* MSEL = GPCM */ \ + BR_V) /* valid */ + +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xf8006ff7 */ #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x8000001a /* 128 MB window size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_128MB) #endif /* #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE */
-#define CONFIG_SYS_BR1_PRELIM (0xf0000000 | 0x00001801) -#define CONFIG_SYS_OR1_PRELIM (0xfffc0008 | 0x00000200) -#define CONFIG_SYS_LBLAWBAR1_PRELIM 0xf0000000 -#define CONFIG_SYS_LBLAWAR1_PRELIM (0x80000000 | 0x00000011) +#define CONFIG_SYS_WINDOW1_BASE 0xf0000000 +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_WINDOW1_BASE \ + | BR_PS_32 \ + | BR_MS_GPCM \ + | BR_V) + /* 0xF0001801 */ +#define CONFIG_SYS_OR1_PRELIM (OR_AM_256KB \ + | OR_GPCM_SETA) + /* 0xfffc0208 */ +#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_WINDOW1_BASE +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_256KB)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device*/
Rename CONFIG_SYS_DDR_CONFIG to include which CS it is configuring Cleanup the setting of the csnbds to respect the setting of CONFIG_SYS_DDR_SDRAM_BASE Use __ilog2 instead of writing the code to compute it Disable unused CS configs Ensure ddrlaw.bar is configured
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- board/freescale/mpc8313erdb/sdram.c | 10 +++++- board/freescale/mpc8349emds/mpc8349emds.c | 27 +++++++++--------- board/freescale/mpc8349itx/mpc8349itx.c | 28 +++++++++++-------- board/freescale/mpc8360emds/mpc8360emds.c | 42 ++++++++++++++++++----------- board/sbc8349/sbc8349.c | 27 +++++++++--------- board/ve8313/ve8313.c | 10 +++++- include/configs/MPC8313ERDB.h | 2 +- include/configs/MPC8349EMDS.h | 2 +- include/configs/MPC8349ITX.h | 2 +- include/configs/MPC8360EMDS.h | 7 +++-- include/configs/sbc8349.h | 2 +- include/configs/ve8313.h | 2 +- 12 files changed, 93 insertions(+), 68 deletions(-)
diff --git a/board/freescale/mpc8313erdb/sdram.c b/board/freescale/mpc8313erdb/sdram.c index 7aede13..a9a2ba4 100644 --- a/board/freescale/mpc8313erdb/sdram.c +++ b/board/freescale/mpc8313erdb/sdram.c @@ -74,8 +74,14 @@ static long fixed_sdram(void) */ __udelay(50000);
- im->ddr.csbnds[0].csbnds = (msize - 1) >> 24; - im->ddr.cs_config[0] = CONFIG_SYS_DDR_CONFIG; +#if ((CONFIG_SYS_DDR_SDRAM_BASE & 0x00FFFFFF) != 0) +#warning Chip select bounds is only configurable in 16MB increments +#endif + im->ddr.csbnds[0].csbnds = + ((CONFIG_SYS_DDR_SDRAM_BASE >> CSBNDS_SA_SHIFT) & CSBNDS_SA) | + (((CONFIG_SYS_DDR_SDRAM_BASE + msize - 1) >> CSBNDS_EA_SHIFT) & + CSBNDS_EA); + im->ddr.cs_config[0] = CONFIG_SYS_DDR_CS0_CONFIG;
/* Currently we use only one CS, so disable the other bank. */ im->ddr.cs_config[1] = 0; diff --git a/board/freescale/mpc8349emds/mpc8349emds.c b/board/freescale/mpc8349emds/mpc8349emds.c index 365ac37..edce4c3 100644 --- a/board/freescale/mpc8349emds/mpc8349emds.c +++ b/board/freescale/mpc8349emds/mpc8349emds.c @@ -97,18 +97,10 @@ phys_size_t initdram (int board_type) int fixed_sdram(void) { volatile immap_t *im = (immap_t *)CONFIG_SYS_IMMR; - u32 msize = 0; - u32 ddr_size; - u32 ddr_size_log2; - - msize = CONFIG_SYS_DDR_SIZE; - for (ddr_size = msize << 20, ddr_size_log2 = 0; - (ddr_size > 1); - ddr_size = ddr_size>>1, ddr_size_log2++) { - if (ddr_size & 1) { - return -1; - } - } + u32 msize = CONFIG_SYS_DDR_SIZE; + u32 ddr_size = msize << 20; /* DDR size in bytes */ + u32 ddr_size_log2 = __ilog2(ddr_size); + im->sysconf.ddrlaw[0].bar = CONFIG_SYS_DDR_SDRAM_BASE & 0xfffff000; im->sysconf.ddrlaw[0].ar = LAWAR_EN | ((ddr_size_log2 - 1) & LAWAR_SIZE);
@@ -129,8 +121,15 @@ int fixed_sdram(void) im->ddr.sdram_interval = CONFIG_SYS_DDR_INTERVAL; im->ddr.sdram_clk_cntl = CONFIG_SYS_DDR_CLK_CNTL; #else - im->ddr.csbnds[2].csbnds = 0x0000000f; - im->ddr.cs_config[2] = CONFIG_SYS_DDR_CONFIG; + +#if ((CONFIG_SYS_DDR_SDRAM_BASE & 0x00FFFFFF) != 0) +#warning Chip select bounds is only configurable in 16MB increments +#endif + im->ddr.csbnds[2].csbnds = + ((CONFIG_SYS_DDR_SDRAM_BASE >> CSBNDS_SA_SHIFT) & CSBNDS_SA) | + (((CONFIG_SYS_DDR_SDRAM_BASE + ddr_size - 1) >> + CSBNDS_EA_SHIFT) & CSBNDS_EA); + im->ddr.cs_config[2] = CONFIG_SYS_DDR_CS2_CONFIG;
/* currently we use only one CS, so disable the other banks */ im->ddr.cs_config[0] = 0; diff --git a/board/freescale/mpc8349itx/mpc8349itx.c b/board/freescale/mpc8349itx/mpc8349itx.c index 5647579..9cc808e 100644 --- a/board/freescale/mpc8349itx/mpc8349itx.c +++ b/board/freescale/mpc8349itx/mpc8349itx.c @@ -43,23 +43,27 @@ int fixed_sdram(void) { volatile immap_t *im = (immap_t *) CONFIG_SYS_IMMR; - u32 ddr_size; /* The size of RAM, in bytes */ - u32 ddr_size_log2 = 0; - - for (ddr_size = CONFIG_SYS_DDR_SIZE * 0x100000; ddr_size > 1; ddr_size >>= 1) { - if (ddr_size & 1) { - return -1; - } - ddr_size_log2++; - } + /* The size of RAM, in bytes */ + u32 ddr_size = CONFIG_SYS_DDR_SIZE << 20; + u32 ddr_size_log2 = __ilog2(ddr_size);
im->sysconf.ddrlaw[0].ar = LAWAR_EN | ((ddr_size_log2 - 1) & LAWAR_SIZE); im->sysconf.ddrlaw[0].bar = CONFIG_SYS_DDR_SDRAM_BASE & 0xfffff000;
- /* Only one CS0 for DDR */ - im->ddr.csbnds[0].csbnds = 0x0000000f; - im->ddr.cs_config[0] = CONFIG_SYS_DDR_CONFIG; +#if ((CONFIG_SYS_DDR_SDRAM_BASE & 0x00FFFFFF) != 0) +#warning Chip select bounds is only configurable in 16MB increments +#endif + im->ddr.csbnds[0].csbnds = + ((CONFIG_SYS_DDR_SDRAM_BASE >> CSBNDS_SA_SHIFT) & CSBNDS_SA) | + (((CONFIG_SYS_DDR_SDRAM_BASE + ddr_size - 1) >> + CSBNDS_EA_SHIFT) & CSBNDS_EA); + im->ddr.cs_config[0] = CONFIG_SYS_DDR_CS0_CONFIG; + + /* Only one CS for DDR */ + im->ddr.cs_config[1] = 0; + im->ddr.cs_config[2] = 0; + im->ddr.cs_config[3] = 0;
debug("cs0_bnds = 0x%08x\n", im->ddr.csbnds[0].csbnds); debug("cs0_config = 0x%08x\n", im->ddr.cs_config[0]); diff --git a/board/freescale/mpc8360emds/mpc8360emds.c b/board/freescale/mpc8360emds/mpc8360emds.c index 51d8035..a0114f6 100644 --- a/board/freescale/mpc8360emds/mpc8360emds.c +++ b/board/freescale/mpc8360emds/mpc8360emds.c @@ -216,19 +216,15 @@ phys_size_t initdram(int board_type) int fixed_sdram(void) { volatile immap_t *im = (immap_t *) CONFIG_SYS_IMMR; - u32 msize = 0; - u32 ddr_size; - u32 ddr_size_log2; - - msize = CONFIG_SYS_DDR_SIZE; - for (ddr_size = msize << 20, ddr_size_log2 = 0; - (ddr_size > 1); ddr_size = ddr_size >> 1, ddr_size_log2++) { - if (ddr_size & 1) { - return -1; - } - } + u32 msize = CONFIG_SYS_DDR_SIZE; + u32 ddr_size = msize << 20; + u32 ddr_size_log2 = __ilog2(ddr_size); + u32 half_ddr_size = ddr_size >> 1; + + im->sysconf.ddrlaw[0].bar = + CONFIG_SYS_DDR_SDRAM_BASE & 0xfffff000; im->sysconf.ddrlaw[0].ar = - LAWAR_EN | ((ddr_size_log2 - 1) & LAWAR_SIZE); + LAWAR_EN | ((ddr_size_log2 - 1) & LAWAR_SIZE); #if (CONFIG_SYS_DDR_SIZE != 256) #warning Currenly any ddr size other than 256 is not supported #endif @@ -246,11 +242,25 @@ int fixed_sdram(void) im->ddr.sdram_interval = CONFIG_SYS_DDR_INTERVAL; im->ddr.sdram_clk_cntl = CONFIG_SYS_DDR_CLK_CNTL; #else - im->ddr.csbnds[0].csbnds = 0x00000007; - im->ddr.csbnds[1].csbnds = 0x0008000f;
- im->ddr.cs_config[0] = CONFIG_SYS_DDR_CONFIG; - im->ddr.cs_config[1] = CONFIG_SYS_DDR_CONFIG; +#if ((CONFIG_SYS_DDR_SDRAM_BASE & 0x00FFFFFF) != 0) +#warning Chip select bounds is only configurable in 16MB increments +#endif + im->ddr.csbnds[0].csbnds = + ((CONFIG_SYS_DDR_SDRAM_BASE >> CSBNDS_SA_SHIFT) & CSBNDS_SA) | + (((CONFIG_SYS_DDR_SDRAM_BASE + half_ddr_size - 1) >> + CSBNDS_EA_SHIFT) & CSBNDS_EA); + im->ddr.csbnds[1].csbnds = + (((CONFIG_SYS_DDR_SDRAM_BASE + half_ddr_size) >> + CSBNDS_SA_SHIFT) & CSBNDS_SA) | + (((CONFIG_SYS_DDR_SDRAM_BASE + ddr_size - 1) >> + CSBNDS_EA_SHIFT) & CSBNDS_EA); + + im->ddr.cs_config[0] = CONFIG_SYS_DDR_CS0_CONFIG; + im->ddr.cs_config[1] = CONFIG_SYS_DDR_CS1_CONFIG; + + im->ddr.cs_config[2] = 0; + im->ddr.cs_config[3] = 0;
im->ddr.timing_cfg_1 = CONFIG_SYS_DDR_TIMING_1; im->ddr.timing_cfg_2 = CONFIG_SYS_DDR_TIMING_2; diff --git a/board/sbc8349/sbc8349.c b/board/sbc8349/sbc8349.c index 50fae7c..42f4c1e 100644 --- a/board/sbc8349/sbc8349.c +++ b/board/sbc8349/sbc8349.c @@ -89,26 +89,25 @@ phys_size_t initdram (int board_type) int fixed_sdram(void) { volatile immap_t *im = (immap_t *)CONFIG_SYS_IMMR; - u32 msize = 0; - u32 ddr_size; - u32 ddr_size_log2; - - msize = CONFIG_SYS_DDR_SIZE; - for (ddr_size = msize << 20, ddr_size_log2 = 0; - (ddr_size > 1); - ddr_size = ddr_size>>1, ddr_size_log2++) { - if (ddr_size & 1) { - return -1; - } - } + u32 msize = CONFIG_SYS_DDR_SIZE; + u32 ddr_size = msize << 20; /* DDR size in bytes */ + u32 ddr_size_log2 = __ilog2(msize); + im->sysconf.ddrlaw[0].bar = CONFIG_SYS_DDR_SDRAM_BASE & 0xfffff000; im->sysconf.ddrlaw[0].ar = LAWAR_EN | ((ddr_size_log2 - 1) & LAWAR_SIZE);
#if (CONFIG_SYS_DDR_SIZE != 256) #warning Currently any ddr size other than 256 is not supported #endif - im->ddr.csbnds[2].csbnds = 0x0000000f; - im->ddr.cs_config[2] = CONFIG_SYS_DDR_CONFIG; + +#if ((CONFIG_SYS_DDR_SDRAM_BASE & 0x00FFFFFF) != 0) +#warning Chip select bounds is only configurable in 16MB increments +#endif + im->ddr.csbnds[2].csbnds = + ((CONFIG_SYS_DDR_SDRAM_BASE >> CSBNDS_SA_SHIFT) & CSBNDS_SA) | + (((CONFIG_SYS_DDR_SDRAM_BASE + ddr_size - 1) >> + CSBNDS_EA_SHIFT) & CSBNDS_EA); + im->ddr.cs_config[2] = CONFIG_SYS_DDR_CS2_CONFIG;
/* currently we use only one CS, so disable the other banks */ im->ddr.cs_config[0] = 0; diff --git a/board/ve8313/ve8313.c b/board/ve8313/ve8313.c index 166e459..924d871 100644 --- a/board/ve8313/ve8313.c +++ b/board/ve8313/ve8313.c @@ -65,8 +65,14 @@ static long fixed_sdram(void) */ __udelay(50000);
- out_be32(&im->ddr.csbnds[0].csbnds, (msize - 1) >> 24); - out_be32(&im->ddr.cs_config[0], CONFIG_SYS_DDR_CONFIG); +#if ((CONFIG_SYS_DDR_SDRAM_BASE & 0x00FFFFFF) != 0) +#warning Chip select bounds is only configurable in 16MB increments +#endif + out_be32(&im->ddr.csbnds[0].csbnds, + ((CONFIG_SYS_DDR_SDRAM_BASE >> CSBNDS_SA_SHIFT) & CSBNDS_SA) | + (((CONFIG_SYS_DDR_SDRAM_BASE + msize - 1) >> CSBNDS_EA_SHIFT) & + CSBNDS_EA)); + out_be32(&im->ddr.cs_config[0], CONFIG_SYS_DDR_CS0_CONFIG);
/* Currently we use only one CS, so disable the other bank. */ out_be32(&im->ddr.cs_config[1], 0); diff --git a/include/configs/MPC8313ERDB.h b/include/configs/MPC8313ERDB.h index a0ad225..624156a 100644 --- a/include/configs/MPC8313ERDB.h +++ b/include/configs/MPC8313ERDB.h @@ -130,7 +130,7 @@ * seem to have the SPD connected to I2C. */ #define CONFIG_SYS_DDR_SIZE 128 /* MB */ -#define CONFIG_SYS_DDR_CONFIG (CSCONFIG_EN \ +#define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN \ | CSCONFIG_ODT_RD_NEVER \ | CSCONFIG_ODT_WR_ONLY_CURRENT \ | CSCONFIG_ROW_BIT_13 \ diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index c41ef31..c458060 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -126,7 +126,7 @@ #define CONFIG_SYS_DDR_SDRAM_CFG 0x43000000 #define CONFIG_SYS_DDR_SDRAM_CFG2 0x00401000 #else -#define CONFIG_SYS_DDR_CONFIG (CSCONFIG_EN \ +#define CONFIG_SYS_DDR_CS2_CONFIG (CSCONFIG_EN \ | CSCONFIG_ROW_BIT_13 \ | CSCONFIG_COL_BIT_10) #define CONFIG_SYS_DDR_TIMING_1 0x36332321 diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index d0586af..6506937 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -206,7 +206,7 @@ /* No SPD? Then manually set up DDR parameters */ #ifndef CONFIG_SPD_EEPROM #define CONFIG_SYS_DDR_SIZE 256 /* Mb */ - #define CONFIG_SYS_DDR_CONFIG (CSCONFIG_EN \ + #define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN \ | CSCONFIG_ROW_BIT_13 \ | CSCONFIG_COL_BIT_10)
diff --git a/include/configs/MPC8360EMDS.h b/include/configs/MPC8360EMDS.h index 3a636ec..cce7515 100644 --- a/include/configs/MPC8360EMDS.h +++ b/include/configs/MPC8360EMDS.h @@ -145,9 +145,10 @@ #define CONFIG_SYS_DDR_SDRAM_CFG 0x43000000 #define CONFIG_SYS_DDR_SDRAM_CFG2 0x00401000 #else -#define CONFIG_SYS_DDR_CONFIG (CSCONFIG_EN \ - | CSCONFIG_ROW_BIT_13 \ - | CSCONFIG_COL_BIT_9) +#define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN \ + | CSCONFIG_ROW_BIT_13 \ + | CSCONFIG_COL_BIT_9) +#define CONFIG_SYS_DDR_CS1_CONFIG CONFIG_SYS_DDR_CS0_CONFIG #define CONFIG_SYS_DDR_TIMING_1 0x37344321 /* tCL-tRCD-tRP-tRAS=2.5-3-3-7 */ #define CONFIG_SYS_DDR_TIMING_2 0x00000800 /* may need tuning */ #define CONFIG_SYS_DDR_CONTROL 0x42008000 /* Self refresh,2T timing */ diff --git a/include/configs/sbc8349.h b/include/configs/sbc8349.h index e9eb632..a1377a4 100644 --- a/include/configs/sbc8349.h +++ b/include/configs/sbc8349.h @@ -114,7 +114,7 @@ * NB: manual DDR setup untested on sbc834x */ #define CONFIG_SYS_DDR_SIZE 256 /* MB */ -#define CONFIG_SYS_DDR_CONFIG (CSCONFIG_EN \ +#define CONFIG_SYS_DDR_CS2_CONFIG (CSCONFIG_EN \ | CSCONFIG_ROW_BIT_13 \ | CSCONFIG_COL_BIT_10) #define CONFIG_SYS_DDR_TIMING_1 0x36332321 diff --git a/include/configs/ve8313.h b/include/configs/ve8313.h index 0cddca3..0c6c3a7 100644 --- a/include/configs/ve8313.h +++ b/include/configs/ve8313.h @@ -79,7 +79,7 @@ * have the SPD connected to I2C. */ #define CONFIG_SYS_DDR_SIZE 128 /* MB */ -#define CONFIG_SYS_DDR_CONFIG (CSCONFIG_EN \ +#define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN \ | CSCONFIG_AP \ | CSCONFIG_ODT_RD_NEVER \ | CSCONFIG_ODT_WR_ALL \
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- Changes for v2: - Split
include/configs/MPC8315ERDB.h | 13 +++++++------ include/configs/MPC8323ERDB.h | 6 +++--- include/configs/MPC832XEMDS.h | 6 +++--- include/configs/MPC8349EMDS.h | 36 ++++++++++++++++++------------------ include/configs/MPC8360EMDS.h | 32 ++++++++++++++++---------------- include/configs/MPC8360ERDK.h | 8 ++++---- include/configs/MPC837XEMDS.h | 12 ++++++------ include/configs/MPC837XERDB.h | 8 ++++---- include/configs/mpc8308_p1m.h | 2 +- include/configs/tuxa1.h | 2 +- include/configs/ve8313.h | 36 ++++++++++++++++++------------------ 11 files changed, 81 insertions(+), 80 deletions(-)
diff --git a/include/configs/MPC8315ERDB.h b/include/configs/MPC8315ERDB.h index a0cfd00..cffb9ff 100644 --- a/include/configs/MPC8315ERDB.h +++ b/include/configs/MPC8315ERDB.h @@ -268,13 +268,14 @@ #define CONFIG_MTD_NAND_VERIFY_WRITE 1 #define CONFIG_CMD_NAND 1 #define CONFIG_NAND_FSL_ELBC 1 -#define CONFIG_SYS_NAND_BLOCK_SIZE 16384 - -#define CONFIG_SYS_NAND_U_BOOT_SIZE (512 << 10) -#define CONFIG_SYS_NAND_U_BOOT_DST 0x00100000 -#define CONFIG_SYS_NAND_U_BOOT_START 0x00100100 -#define CONFIG_SYS_NAND_U_BOOT_OFFS 16384 -#define CONFIG_SYS_NAND_U_BOOT_RELOC 0x00010000 +#define CONFIG_SYS_NAND_BLOCK_SIZE 16384 +#define CONFIG_SYS_NAND_WINDOW_SIZE (32 * 1024) + +#define CONFIG_SYS_NAND_U_BOOT_SIZE (512 << 10) +#define CONFIG_SYS_NAND_U_BOOT_DST 0x00100000 +#define CONFIG_SYS_NAND_U_BOOT_START 0x00100100 +#define CONFIG_SYS_NAND_U_BOOT_OFFS 16384 +#define CONFIG_SYS_NAND_U_BOOT_RELOC 0x00010000
#define CONFIG_SYS_NAND_BR_PRELIM (CONFIG_SYS_NAND_BASE \ | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ diff --git a/include/configs/MPC8323ERDB.h b/include/configs/MPC8323ERDB.h index 4d4c758..6766b76 100644 --- a/include/configs/MPC8323ERDB.h +++ b/include/configs/MPC8323ERDB.h @@ -62,7 +62,7 @@ /* * IMMR new address */ -#define CONFIG_SYS_IMMR 0xE0000000 +#define CONFIG_SYS_IMMR 0xE0000000
/* * System performance @@ -177,9 +177,9 @@ * FLASH on the Local Bus */ #define CONFIG_SYS_FLASH_CFI /* use the Common Flash Interface */ -#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ +#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ #define CONFIG_SYS_FLASH_BASE 0xFE000000 /* FLASH base address */ -#define CONFIG_SYS_FLASH_SIZE 16 /* FLASH size is 16M */ +#define CONFIG_SYS_FLASH_SIZE 16 /* FLASH size is 16M */ #define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */
#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE /* Window base at flash base */ diff --git a/include/configs/MPC832XEMDS.h b/include/configs/MPC832XEMDS.h index f136a8e..0342194 100644 --- a/include/configs/MPC832XEMDS.h +++ b/include/configs/MPC832XEMDS.h @@ -185,9 +185,9 @@ #undef CONFIG_SYS_FLASH_CHECKSUM
/* - * BCSR on the Local Bus + * Status buffer (BCSR) on the Local Bus */ -#define CONFIG_SYS_BCSR 0xF8000000 +#define CONFIG_SYS_BCSR 0xF8000000 #define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_BCSR /* Access window base at BCSR base */ #define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000E /* Access window size 32K */
@@ -251,7 +251,7 @@ #endif
/* - * Windows to access PIB via local bus + * Windows to access Platform I/O Boards (PIB) via local bus */ #define CONFIG_SYS_LBLAWBAR3_PRELIM 0xf8008000 /* windows base 0xf8008000 */ #define CONFIG_SYS_LBLAWAR3_PRELIM 0x8000000f /* windows size 64KB */ diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index 45b6b5f..b238880 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -113,24 +113,24 @@ #define CONFIG_SYS_DDR_SIZE 256 /* MB */ #if defined(CONFIG_DDR_II) #define CONFIG_SYS_DDRCDR 0x80080001 -#define CONFIG_SYS_DDR_CS2_BNDS 0x0000000f +#define CONFIG_SYS_DDR_CS2_BNDS 0x0000000f #define CONFIG_SYS_DDR_CS2_CONFIG 0x80330102 -#define CONFIG_SYS_DDR_TIMING_0 0x00220802 -#define CONFIG_SYS_DDR_TIMING_1 0x38357322 -#define CONFIG_SYS_DDR_TIMING_2 0x2f9048c8 -#define CONFIG_SYS_DDR_TIMING_3 0x00000000 -#define CONFIG_SYS_DDR_CLK_CNTL 0x02000000 +#define CONFIG_SYS_DDR_TIMING_0 0x00220802 +#define CONFIG_SYS_DDR_TIMING_1 0x38357322 +#define CONFIG_SYS_DDR_TIMING_2 0x2f9048c8 +#define CONFIG_SYS_DDR_TIMING_3 0x00000000 +#define CONFIG_SYS_DDR_CLK_CNTL 0x02000000 #define CONFIG_SYS_DDR_MODE 0x47d00432 #define CONFIG_SYS_DDR_MODE2 0x8000c000 -#define CONFIG_SYS_DDR_INTERVAL 0x03cf0080 +#define CONFIG_SYS_DDR_INTERVAL 0x03cf0080 #define CONFIG_SYS_DDR_SDRAM_CFG 0x43000000 #define CONFIG_SYS_DDR_SDRAM_CFG2 0x00401000 #else #define CONFIG_SYS_DDR_CONFIG (CSCONFIG_EN | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10) -#define CONFIG_SYS_DDR_TIMING_1 0x36332321 -#define CONFIG_SYS_DDR_TIMING_2 0x00000800 /* P9-45,may need tuning */ +#define CONFIG_SYS_DDR_TIMING_1 0x36332321 +#define CONFIG_SYS_DDR_TIMING_2 0x00000800 /* P9-45,may need tuning */ #define CONFIG_SYS_DDR_CONTROL 0xc2000000 /* unbuffered,no DYN_PWR */ -#define CONFIG_SYS_DDR_INTERVAL 0x04060100 /* autocharge,no open page */ +#define CONFIG_SYS_DDR_INTERVAL 0x04060100 /* autocharge,no open page */
#if defined(CONFIG_DDR_32BIT) /* set burst length to 8 for 32-bit data path */ @@ -143,12 +143,6 @@ #endif
/* - * SDRAM on the Local Bus - */ -#define CONFIG_SYS_LBC_SDRAM_BASE 0xF0000000 /* Localbus SDRAM */ -#define CONFIG_SYS_LBC_SDRAM_SIZE 64 /* LBC SDRAM is 64MB */ - -/* * FLASH on the Local Bus */ #define CONFIG_SYS_FLASH_CFI /* use the Common Flash Interface */ @@ -185,7 +179,7 @@ /* * BCSR register on local bus 32KB, 8-bit wide for MDS config reg */ -#define CONFIG_SYS_BCSR 0xE2400000 +#define CONFIG_SYS_BCSR 0xE2400000 #define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_BCSR /* Access window base at BCSR base */ #define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000E /* Access window size 32K */ #define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR|0x00000801) /* Port-size=8bit, MSEL=GPCM */ @@ -209,7 +203,7 @@ */ #define CONFIG_SYS_LCRR_DBYP LCRR_DBYP #define CONFIG_SYS_LCRR_CLKDIV LCRR_CLKDIV_4 -#define CONFIG_SYS_LBC_LBCR 0x00000000 +#define CONFIG_SYS_LBC_LBCR 0x00000000
/* * The MPC834xEA MDS for 834xE rev3.1 may not be assembled SDRAM memory. @@ -217,6 +211,12 @@ */ #undef CONFIG_SYS_LB_SDRAM
+/* + * SDRAM on the Local Bus + */ +#define CONFIG_SYS_LBC_SDRAM_BASE 0xF0000000 /* Localbus SDRAM */ +#define CONFIG_SYS_LBC_SDRAM_SIZE 64 /* LBC SDRAM is 64MB */ + #ifdef CONFIG_SYS_LB_SDRAM /* Local bus BR2, OR2 definition for SDRAM if soldered on the MDS board */ /* diff --git a/include/configs/MPC8360EMDS.h b/include/configs/MPC8360EMDS.h index 49d64a5..8927e2f 100644 --- a/include/configs/MPC8360EMDS.h +++ b/include/configs/MPC8360EMDS.h @@ -106,7 +106,7 @@ #define CONFIG_SYS_SDRAM_BASE2 (CONFIG_SYS_SDRAM_BASE + 0x10000000) /* + 256M */ #define CONFIG_SYS_DDR_SDRAM_BASE CONFIG_SYS_DDR_BASE #define CONFIG_SYS_DDR_SDRAM_CLK_CNTL (DDR_SDRAM_CLK_CNTL_SS_EN | \ - DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05) + DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05)
#define CONFIG_SYS_83XX_DDR_USES_CS0
@@ -131,25 +131,25 @@ #define CONFIG_SYS_DDR_SIZE 256 /* MB */ #if defined(CONFIG_DDR_II) #define CONFIG_SYS_DDRCDR 0x80080001 -#define CONFIG_SYS_DDR_CS0_BNDS 0x0000000f +#define CONFIG_SYS_DDR_CS0_BNDS 0x0000000f #define CONFIG_SYS_DDR_CS0_CONFIG 0x80330102 -#define CONFIG_SYS_DDR_TIMING_0 0x00220802 -#define CONFIG_SYS_DDR_TIMING_1 0x38357322 -#define CONFIG_SYS_DDR_TIMING_2 0x2f9048c8 -#define CONFIG_SYS_DDR_TIMING_3 0x00000000 -#define CONFIG_SYS_DDR_CLK_CNTL 0x02000000 +#define CONFIG_SYS_DDR_TIMING_0 0x00220802 +#define CONFIG_SYS_DDR_TIMING_1 0x38357322 +#define CONFIG_SYS_DDR_TIMING_2 0x2f9048c8 +#define CONFIG_SYS_DDR_TIMING_3 0x00000000 +#define CONFIG_SYS_DDR_CLK_CNTL 0x02000000 #define CONFIG_SYS_DDR_MODE 0x47d00432 #define CONFIG_SYS_DDR_MODE2 0x8000c000 -#define CONFIG_SYS_DDR_INTERVAL 0x03cf0080 +#define CONFIG_SYS_DDR_INTERVAL 0x03cf0080 #define CONFIG_SYS_DDR_SDRAM_CFG 0x43000000 #define CONFIG_SYS_DDR_SDRAM_CFG2 0x00401000 #else -#define CONFIG_SYS_DDR_CONFIG (CSCONFIG_EN | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_9) -#define CONFIG_SYS_DDR_TIMING_1 0x37344321 /* tCL-tRCD-tRP-tRAS=2.5-3-3-7 */ -#define CONFIG_SYS_DDR_TIMING_2 0x00000800 /* may need tuning */ +#define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_9) +#define CONFIG_SYS_DDR_TIMING_1 0x37344321 /* tCL-tRCD-tRP-tRAS=2.5-3-3-7 */ +#define CONFIG_SYS_DDR_TIMING_2 0x00000800 /* may need tuning */ #define CONFIG_SYS_DDR_CONTROL 0x42008000 /* Self refresh,2T timing */ #define CONFIG_SYS_DDR_MODE 0x20000162 /* DLL,normal,seq,4/2.5 */ -#define CONFIG_SYS_DDR_INTERVAL 0x045b0100 /* page mode */ +#define CONFIG_SYS_DDR_INTERVAL 0x045b0100 /* page mode */ #endif #endif
@@ -195,11 +195,11 @@ * FLASH on the Local Bus */ #define CONFIG_SYS_FLASH_CFI /* use the Common Flash Interface */ -#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ +#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ #define CONFIG_SYS_FLASH_BASE 0xFE000000 /* FLASH base address */ #define CONFIG_SYS_FLASH_SIZE 32 /* max FLASH size is 32M */ -#define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */ -#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */ +#define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */ +#define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE /* Window base at flash base */ #define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000018 /* 32MB window size */ @@ -219,7 +219,7 @@ /* * BCSR on the Local Bus */ -#define CONFIG_SYS_BCSR 0xF8000000 +#define CONFIG_SYS_BCSR 0xF8000000 #define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_BCSR /* Access window base at BCSR base */ #define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000F /* Access window size 64K */
diff --git a/include/configs/MPC8360ERDK.h b/include/configs/MPC8360ERDK.h index 851872a..0ad10d4 100644 --- a/include/configs/MPC8360ERDK.h +++ b/include/configs/MPC8360ERDK.h @@ -105,14 +105,14 @@ */ #define CONFIG_DDR_II #define CONFIG_SYS_DDR_SIZE 256 /* MB */ -#define CONFIG_SYS_DDR_CS0_BNDS 0x0000000f +#define CONFIG_SYS_DDR_CS0_BNDS 0x0000000f #define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN | CSCONFIG_ROW_BIT_13 | \ CSCONFIG_COL_BIT_10 | CSCONFIG_ODT_WR_ACS) #define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SDRAM_TYPE_DDR2 | SDRAM_CFG_ECC_EN) #define CONFIG_SYS_DDR_SDRAM_CFG2 0x00001000 -#define CONFIG_SYS_DDR_CLK_CNTL (DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05) -#define CONFIG_SYS_DDR_INTERVAL ((256 << SDRAM_INTERVAL_BSTOPRE_SHIFT) | \ - (1115 << SDRAM_INTERVAL_REFINT_SHIFT)) +#define CONFIG_SYS_DDR_CLK_CNTL (DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05) +#define CONFIG_SYS_DDR_INTERVAL ((256 << SDRAM_INTERVAL_BSTOPRE_SHIFT) | \ + (1115 << SDRAM_INTERVAL_REFINT_SHIFT)) #define CONFIG_SYS_DDR_MODE 0x47800432 #define CONFIG_SYS_DDR_MODE2 0x8000c000
diff --git a/include/configs/MPC837XEMDS.h b/include/configs/MPC837XEMDS.h index abccfd6..325be32 100644 --- a/include/configs/MPC837XEMDS.h +++ b/include/configs/MPC837XEMDS.h @@ -223,17 +223,17 @@ */ #define CONFIG_SYS_LCRR_DBYP LCRR_DBYP #define CONFIG_SYS_LCRR_CLKDIV LCRR_CLKDIV_8 -#define CONFIG_SYS_LBC_LBCR 0x00000000 +#define CONFIG_SYS_LBC_LBCR 0x00000000 #define CONFIG_FSL_ELBC 1
/* * FLASH on the Local Bus */ #define CONFIG_SYS_FLASH_CFI /* use the Common Flash Interface */ -#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ +#define CONFIG_FLASH_CFI_DRIVER /* use the CFI driver */ #define CONFIG_SYS_FLASH_BASE 0xFE000000 /* FLASH base address */ #define CONFIG_SYS_FLASH_SIZE 32 /* max FLASH size is 32M */ -#define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */ +#define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */
#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE /* Window base at flash base */ #define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000018 /* 32MB window size */ @@ -262,7 +262,7 @@ /* * BCSR on the Local Bus */ -#define CONFIG_SYS_BCSR 0xF8000000 +#define CONFIG_SYS_BCSR 0xF8000000 #define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_BCSR /* Access window base at BCSR base */ #define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000E /* Access window size 32K */
@@ -272,10 +272,10 @@ /* * NAND Flash on the Local Bus */ -#define CONFIG_CMD_NAND 1 +#define CONFIG_CMD_NAND 1 #define CONFIG_MTD_NAND_VERIFY_WRITE 1 #define CONFIG_SYS_MAX_NAND_DEVICE 1 -#define CONFIG_NAND_FSL_ELBC 1 +#define CONFIG_NAND_FSL_ELBC 1
#define CONFIG_SYS_NAND_BASE 0xE0600000 /* 0xE0600000 */ #define CONFIG_SYS_BR3_PRELIM ( CONFIG_SYS_NAND_BASE \ diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index ea3056b..270ad41 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -165,9 +165,9 @@ * Manually set up DDR parameters */ #define CONFIG_SYS_DDR_SIZE 256 /* MB */ -#define CONFIG_SYS_DDR_CS0_BNDS 0x0000000f +#define CONFIG_SYS_DDR_CS0_BNDS 0x0000000f #define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN | CSCONFIG_ODT_WR_ACS \ - | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10) + | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10)
#define CONFIG_SYS_DDR_TIMING_3 0x00000000 #define CONFIG_SYS_DDR_TIMING_0 ((0 << TIMING_CFG0_RWT_SHIFT) \ @@ -208,8 +208,8 @@ #endif #define CONFIG_SYS_DDR_SDRAM_CFG2 0x00001000 /* 1 posted refresh */ #define CONFIG_SYS_DDR_MODE ((0x0406 << SDRAM_MODE_ESD_SHIFT) \ - | (0x0442 << SDRAM_MODE_SD_SHIFT)) - /* 0x04400442 */ /* DDR400 */ + | (0x0442 << SDRAM_MODE_SD_SHIFT)) + /* 0x04400442 */ /* DDR400 */ #define CONFIG_SYS_DDR_MODE2 0x00000000
/* diff --git a/include/configs/mpc8308_p1m.h b/include/configs/mpc8308_p1m.h index d7a3a96..4c9a766 100644 --- a/include/configs/mpc8308_p1m.h +++ b/include/configs/mpc8308_p1m.h @@ -155,7 +155,7 @@
-#define CONFIG_SYS_DDR_CS0_BNDS 0x00000007 +#define CONFIG_SYS_DDR_CS0_BNDS 0x00000007 #define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN \ | 0x00010000 /* ODT_WR to CSn */ \ | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10) diff --git a/include/configs/tuxa1.h b/include/configs/tuxa1.h index ceeb5a3..5ce8ad5 100644 --- a/include/configs/tuxa1.h +++ b/include/configs/tuxa1.h @@ -58,7 +58,7 @@ #define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_LPXF_BASE #define CONFIG_SYS_LBLAWAR2_PRELIM (LBLAWAR_EN | LBLAWAR_256MB)
-#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_LPXF_BASE | \ +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_LPXF_BASE | \ BR_PS_8 | \ BR_MS_GPCM | \ BR_V) diff --git a/include/configs/ve8313.h b/include/configs/ve8313.h index abb57fe..8beac34 100644 --- a/include/configs/ve8313.h +++ b/include/configs/ve8313.h @@ -147,12 +147,12 @@ (2 << BR_PS_SHIFT) | /* 16 bit */ \ BR_V) /* valid */ #define CONFIG_SYS_NOR_OR_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ - | OR_GPCM_CSNT \ - | OR_GPCM_ACS_DIV4 \ - | OR_GPCM_SCY_5 \ - | OR_GPCM_TRLX \ - | OR_GPCM_EAD) - /* 0xfe000c55 */ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV4 \ + | OR_GPCM_SCY_5 \ + | OR_GPCM_TRLX \ + | OR_GPCM_EAD) + /* 0xfe000c55 */
#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000018 /* 32 MB window size */ @@ -202,18 +202,18 @@ #define CONFIG_SYS_NAND_BLOCK_SIZE 16384
#define CONFIG_SYS_NAND_BR_PRELIM ( CONFIG_SYS_NAND_BASE \ - | BR_PS_8 \ - | BR_DECC_CHK_GEN \ - | BR_MS_FCM \ - | BR_V ) /* valid */ - /* 0x61000c21 */ -#define CONFIG_SYS_NAND_OR_PRELIM (0xffff8000 \ - | OR_FCM_BCTLD \ - | OR_FCM_CHT \ - | OR_FCM_SCY_2 \ - | OR_FCM_RST \ - | OR_FCM_TRLX) - /* 0xffff90ac */ + | BR_PS_8 \ + | BR_DECC_CHK_GEN \ + | BR_MS_FCM \ + | BR_V ) /* valid */ + /* 0x61000c21 */ +#define CONFIG_SYS_NAND_OR_PRELIM ( 0xffff8000 \ + | OR_FCM_BCTLD \ + | OR_FCM_CHT \ + | OR_FCM_SCY_2 \ + | OR_FCM_RST \ + | OR_FCM_TRLX) + /* 0xffff90ac */
#define CONFIG_SYS_BR0_PRELIM CONFIG_SYS_NOR_BR_PRELIM #define CONFIG_SYS_OR0_PRELIM CONFIG_SYS_NOR_OR_PRELIM
Dear Joe Hershberger,
In message 1313185980-6208-2-git-send-email-joe.hershberger@ni.com you wrote:
Changes for v2:
- Split
Checkpatch says:
total: 2 errors, 8 warnings, 342 lines checked
Please clean up and resubmit. Thanks.
include/configs/MERGERBOX.h | 14 +++++++------- include/configs/MPC8308RDB.h | 10 +++++----- include/configs/MPC8313ERDB.h | 10 +++++----- include/configs/MPC8315ERDB.h | 14 +++++++------- include/configs/MPC8323ERDB.h | 14 +++++++------- include/configs/MPC832XEMDS.h | 16 ++++++++-------- include/configs/MPC8349EMDS.h | 14 +++++++------- include/configs/MPC8349ITX.h | 14 +++++++------- include/configs/MPC8360EMDS.h | 18 +++++++++--------- include/configs/MPC8360ERDK.h | 18 +++++++++--------- include/configs/MPC837XEMDS.h | 18 +++++++++--------- include/configs/MPC837XERDB.h | 18 +++++++++--------- include/configs/MVBLM7.h | 10 +++++----- include/configs/SIMPC8313.h | 12 ++++++------ include/configs/TQM834x.h | 16 ++++++++-------- include/configs/km/km83xx-common.h | 14 +++++++------- include/configs/kmeter1.h | 8 ++++---- include/configs/kmsupx5.h | 4 ++-- include/configs/mpc8308_p1m.h | 10 +++++----- include/configs/sbc8349.h | 14 +++++++------- include/configs/suvd3.h | 8 ++++---- include/configs/tuda1.h | 8 ++++---- include/configs/tuxa1.h | 8 ++++---- include/configs/ve8313.h | 12 ++++++------ include/configs/vme8349.h | 16 ++++++++-------- 25 files changed, 159 insertions(+), 159 deletions(-)
diff --git a/include/configs/MERGERBOX.h b/include/configs/MERGERBOX.h index f9681cd..ca7ecdd 100644 --- a/include/configs/MERGERBOX.h +++ b/include/configs/MERGERBOX.h @@ -409,7 +409,7 @@ /* DDR: cache cacheable */ #define CONFIG_SYS_SDRAM CONFIG_SYS_SDRAM_BASE
-#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM | BATL_PP_10 |\ +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM | BATL_PP_RW |\ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM | BATU_BL_256M | BATU_VS |\ BATU_VP) @@ -423,7 +423,7 @@ #define CONFIG_SYS_DBAT1U CONFIG_SYS_IBAT1U
/* IMMRBAR, PCI IO and NAND: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_IMMR | BATL_PP_10 |\ +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_IMMR | BATL_PP_RW |\ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_IMMR | BATU_BL_8M | BATU_VS |\ BATU_VP) @@ -437,23 +437,23 @@ #define CONFIG_SYS_DBAT3U CONFIG_SYS_IBAT3U
/* FLASH: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 |\ +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW |\ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_FLASH_BASE | BATU_BL_64M |\ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT4L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT4L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT4U CONFIG_SYS_IBAT4U
/* Stack in dcache: cacheable, no memory coherence */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10) +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_RW) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_INIT_RAM_ADDR | BATU_BL_128K |\ BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT5L CONFIG_SYS_IBAT5L #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U
/* PCI MEM space: cacheable */ -#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI_MEM_PHYS | BATL_PP_10 |\ +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI_MEM_PHYS | BATL_PP_RW |\ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI_MEM_PHYS | BATU_BL_256M |\ BATU_VS | BATU_VP) @@ -461,7 +461,7 @@ #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U
/* PCI MMIO space: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI_MMIO_PHYS | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI_MMIO_PHYS | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT7U (CONFIG_SYS_PCI_MMIO_PHYS | BATU_BL_256M |\ BATU_VS | BATU_VP) diff --git a/include/configs/MPC8308RDB.h b/include/configs/MPC8308RDB.h index 3ff175c..cbdaada 100644 --- a/include/configs/MPC8308RDB.h +++ b/include/configs/MPC8308RDB.h @@ -464,7 +464,7 @@ */
/* DDR: cache cacheable */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_128M | \ BATU_VS | BATU_VP) @@ -472,7 +472,7 @@ #define CONFIG_SYS_DBAT0U CONFIG_SYS_IBAT0U
/* IMMRBAR, PCI IO and NAND: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_IMMR | BATU_BL_8M | BATU_VS | \ BATU_VP) @@ -480,17 +480,17 @@ #define CONFIG_SYS_DBAT1U CONFIG_SYS_IBAT1U
/* FLASH: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_FLASH_BASE | BATU_BL_8M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | \ BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT2U CONFIG_SYS_IBAT2U
/* Stack in dcache: cacheable, no memory coherence */ -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_RW) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_INIT_RAM_ADDR | BATU_BL_128K | \ BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT3L CONFIG_SYS_IBAT3L diff --git a/include/configs/MPC8313ERDB.h b/include/configs/MPC8313ERDB.h index 92c54d0..7405538 100644 --- a/include/configs/MPC8313ERDB.h +++ b/include/configs/MPC8313ERDB.h @@ -547,13 +547,13 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR @ 0x00000000 */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | BATU_VS | BATU_VP)
/* PCI @ 0x80000000 */ -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10) +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_RW) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_RW | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP)
/* PCI2 not supported on 8313 */ @@ -563,11 +563,11 @@ #define CONFIG_SYS_IBAT4U (0)
/* IMMRBAR @ 0xE0000000, PCI IO @ 0xE2000000 & BCSR @ 0xE2400000 */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR | BATL_PP_RW | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_IMMR | BATU_BL_256M | BATU_VS | BATU_VP)
/* SDRAM @ 0xF0000000, stack in DCACHE 0xFDF00000 & FLASH @ 0xFE000000 */ -#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_10 | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_RW | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT6U (0xF0000000 | BATU_BL_256M | BATU_VS | BATU_VP)
#define CONFIG_SYS_IBAT7L (0) diff --git a/include/configs/MPC8315ERDB.h b/include/configs/MPC8315ERDB.h index cffb9ff..20d82a1 100644 --- a/include/configs/MPC8315ERDB.h +++ b/include/configs/MPC8315ERDB.h @@ -570,40 +570,40 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR: cache cacheable */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_128M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT0L CONFIG_SYS_IBAT0L #define CONFIG_SYS_DBAT0U CONFIG_SYS_IBAT0U
/* IMMRBAR, PCI IO and NAND: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_IMMR | BATU_BL_8M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT1L CONFIG_SYS_IBAT1L #define CONFIG_SYS_DBAT1U CONFIG_SYS_IBAT1U
/* FLASH: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_FLASH_BASE | BATU_BL_32M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT2U CONFIG_SYS_IBAT2U
/* Stack in dcache: cacheable, no memory coherence */ -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_RW) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_INIT_RAM_ADDR | BATU_BL_128K | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT3L CONFIG_SYS_IBAT3L #define CONFIG_SYS_DBAT3U CONFIG_SYS_IBAT3U
/* PCI MEM space: cacheable */ -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI_MEM_PHYS | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI_MEM_PHYS | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_PCI_MEM_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT4L CONFIG_SYS_IBAT4L #define CONFIG_SYS_DBAT4U CONFIG_SYS_IBAT4U
/* PCI MMIO space: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_PCI_MMIO_PHYS | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_PCI_MMIO_PHYS | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_PCI_MMIO_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT5L CONFIG_SYS_IBAT5L diff --git a/include/configs/MPC8323ERDB.h b/include/configs/MPC8323ERDB.h index 6766b76..37f6a47 100644 --- a/include/configs/MPC8323ERDB.h +++ b/include/configs/MPC8323ERDB.h @@ -447,22 +447,22 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR: cache cacheable */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT0L CONFIG_SYS_IBAT0L #define CONFIG_SYS_DBAT0U CONFIG_SYS_IBAT0U
/* IMMRBAR & PCI IO: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_IMMR | BATU_BL_4M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT1L CONFIG_SYS_IBAT1L #define CONFIG_SYS_DBAT1U CONFIG_SYS_IBAT1U
/* FLASH: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_FLASH_BASE | BATU_BL_32M | BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT2L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT2U CONFIG_SYS_IBAT2U
@@ -472,19 +472,19 @@ #define CONFIG_SYS_DBAT3U CONFIG_SYS_IBAT3U
/* Stack in dcache: cacheable, no memory coherence */ -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10) +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_RW) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_INIT_RAM_ADDR | BATU_BL_128K | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT4L CONFIG_SYS_IBAT4L #define CONFIG_SYS_DBAT4U CONFIG_SYS_IBAT4U
#ifdef CONFIG_PCI /* PCI MEM space: cacheable */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_PCI1_MEM_PHYS | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_PCI1_MEM_PHYS | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_PCI1_MEM_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT5L CONFIG_SYS_IBAT5L #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U /* PCI MMIO space: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI1_MMIO_PHYS | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI1_MMIO_PHYS | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI1_MMIO_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT6L CONFIG_SYS_IBAT6L diff --git a/include/configs/MPC832XEMDS.h b/include/configs/MPC832XEMDS.h index 0342194..38ca314 100644 --- a/include/configs/MPC832XEMDS.h +++ b/include/configs/MPC832XEMDS.h @@ -465,29 +465,29 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* BCSR: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_BCSR | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_BCSR | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_BCSR | BATU_BL_128K | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT2L CONFIG_SYS_IBAT2L #define CONFIG_SYS_DBAT2U CONFIG_SYS_IBAT2U
/* FLASH: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_FLASH_BASE | BATU_BL_32M | BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT3L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT3L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT3U CONFIG_SYS_IBAT3U
@@ -497,19 +497,19 @@ #define CONFIG_SYS_DBAT4U CONFIG_SYS_IBAT4U
/* Stack in dcache: cacheable, no memory coherence */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10) +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_RW) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_INIT_RAM_ADDR | BATU_BL_128K | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT5L CONFIG_SYS_IBAT5L #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U
#ifdef CONFIG_PCI /* PCI MEM space: cacheable */ -#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI1_MEM_PHYS | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI1_MEM_PHYS | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI1_MEM_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT6L CONFIG_SYS_IBAT6L #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U /* PCI MMIO space: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI1_MMIO_PHYS | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI1_MMIO_PHYS | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT7U (CONFIG_SYS_PCI1_MMIO_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT7L CONFIG_SYS_IBAT7L diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index b238880..88fdb2e 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -611,14 +611,14 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR @ 0x00000000 */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | BATU_VS | BATU_VP)
/* PCI @ 0x80000000 */ #ifdef CONFIG_PCI -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_RW | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP) #else #define CONFIG_SYS_IBAT1L (0) @@ -628,9 +628,9 @@ #endif
#ifdef CONFIG_MPC83XX_PCI2 -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI2_MEM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI2_MEM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_PCI2_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI2_MMIO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI2_MMIO_BASE | BATL_PP_RW | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_PCI2_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP) #else #define CONFIG_SYS_IBAT3L (0) @@ -640,11 +640,11 @@ #endif
/* SDRAM @ 0xF0000000, stack in DCACHE 0xFDF00000 & FLASH @ 0xFE000000 */ -#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_10 | BATL_MEMCOHERENCE | \ +#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_RW | BATL_MEMCOHERENCE | \ BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT6U (0xF0000000 | BATU_BL_256M | BATU_VS | BATU_VP)
diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index de233ff..e671a64 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -606,14 +606,14 @@ boards, we say we have two, but don't display a message if we find only one. */ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | BATU_VS | BATU_VP)
/* PCI */ #ifdef CONFIG_PCI -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_RW | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP) #else #define CONFIG_SYS_IBAT1L 0 @@ -623,9 +623,9 @@ boards, we say we have two, but don't display a message if we find only one. */ #endif
#ifdef CONFIG_MPC83XX_PCI2 -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI2_MEM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI2_MEM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_PCI2_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI2_MMIO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI2_MMIO_BASE | BATL_PP_RW | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_PCI2_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP) #else #define CONFIG_SYS_IBAT3L 0 @@ -635,11 +635,11 @@ boards, we say we have two, but don't display a message if we find only one. */ #endif
diff --git a/include/configs/MPC8360EMDS.h b/include/configs/MPC8360EMDS.h index 8927e2f..c054e34 100644 --- a/include/configs/MPC8360EMDS.h +++ b/include/configs/MPC8360EMDS.h @@ -508,52 +508,52 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR/LBC SDRAM: cacheable */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT0L CONFIG_SYS_IBAT0L #define CONFIG_SYS_DBAT0U CONFIG_SYS_IBAT0U
/* DDR/LBC SDRAM next 256M: cacheable */ -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_SDRAM_BASE2 | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_SDRAM_BASE2 | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_SDRAM_BASE2 | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT4L CONFIG_SYS_IBAT4L #define CONFIG_SYS_DBAT4U CONFIG_SYS_IBAT4U
#ifdef CONFIG_PCI /* PCI MEM space: cacheable */ -#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI1_MEM_PHYS | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI1_MEM_PHYS | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI1_MEM_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT6L CONFIG_SYS_IBAT6L #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U /* PCI MMIO space: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI1_MMIO_PHYS | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI1_MMIO_PHYS | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT7U (CONFIG_SYS_PCI1_MMIO_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT7L CONFIG_SYS_IBAT7L diff --git a/include/configs/MPC8360ERDK.h b/include/configs/MPC8360ERDK.h index 0ad10d4..9242ff5 100644 --- a/include/configs/MPC8360ERDK.h +++ b/include/configs/MPC8360ERDK.h @@ -423,39 +423,39 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* NAND: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_NAND_BASE | BATL_PP_10 | BATL_CACHEINHIBIT |\ +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_NAND_BASE | BATL_PP_RW | BATL_CACHEINHIBIT |\ BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_NAND_BASE | BATU_BL_64M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT2L CONFIG_SYS_IBAT2L #define CONFIG_SYS_DBAT2U CONFIG_SYS_IBAT2U
-#define CONFIG_SYS_IBAT5L (CONFIG_SYS_VIDEO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | \ +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_VIDEO_BASE | BATL_PP_RW | BATL_CACHEINHIBIT | \ BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_VIDEO_BASE | BATU_BL_64M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT5L CONFIG_SYS_IBAT5L @@ -463,12 +463,12 @@
#ifdef CONFIG_PCI /* PCI MEM space: cacheable */ -#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI1_MEM_PHYS | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI1_MEM_PHYS | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI1_MEM_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT6L CONFIG_SYS_IBAT6L #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U /* PCI MMIO space: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI1_MMIO_PHYS | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI1_MMIO_PHYS | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT7U (CONFIG_SYS_PCI1_MMIO_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT7L CONFIG_SYS_IBAT7L diff --git a/include/configs/MPC837XEMDS.h b/include/configs/MPC837XEMDS.h index 325be32..a6f2fde 100644 --- a/include/configs/MPC837XEMDS.h +++ b/include/configs/MPC837XEMDS.h @@ -560,51 +560,51 @@ extern int board_pci_host_broken(void); #define CONFIG_SYS_SDRAM_LOWER CONFIG_SYS_SDRAM_BASE #define CONFIG_SYS_SDRAM_UPPER (CONFIG_SYS_SDRAM_BASE + 0x10000000)
-#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_LOWER | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_LOWER | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_LOWER | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT0L CONFIG_SYS_IBAT0L #define CONFIG_SYS_DBAT0U CONFIG_SYS_IBAT0U
-#define CONFIG_SYS_IBAT1L (CONFIG_SYS_SDRAM_UPPER | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_SDRAM_UPPER | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_SDRAM_UPPER | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT1L CONFIG_SYS_IBAT1L #define CONFIG_SYS_DBAT1U CONFIG_SYS_IBAT1U
/* IMMRBAR, PCI IO and NAND: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_IMMR | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_IMMR | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_IMMR | BATU_BL_8M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT2L CONFIG_SYS_IBAT2L #define CONFIG_SYS_DBAT2U CONFIG_SYS_IBAT2U
/* BCSR: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_BCSR | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_BCSR | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_BCSR | BATU_BL_128K | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT3L CONFIG_SYS_IBAT3L #define CONFIG_SYS_DBAT3U CONFIG_SYS_IBAT3U
/* FLASH: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_FLASH_BASE | BATU_BL_32M | BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT4L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT4L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT4U CONFIG_SYS_IBAT4U
#ifdef CONFIG_PCI /* PCI MEM space: cacheable */ -#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI_MEM_PHYS | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI_MEM_PHYS | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI_MEM_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT6L CONFIG_SYS_IBAT6L #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U /* PCI MMIO space: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI_MMIO_PHYS | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI_MMIO_PHYS | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT7U (CONFIG_SYS_PCI_MMIO_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT7L CONFIG_SYS_IBAT7L diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index 270ad41..9807d31 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -569,51 +569,51 @@ #define CONFIG_SYS_SDRAM_LOWER CONFIG_SYS_SDRAM_BASE #define CONFIG_SYS_SDRAM_UPPER (CONFIG_SYS_SDRAM_BASE + 0x10000000)
/* L2 Switch: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_VSC7385_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_VSC7385_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_VSC7385_BASE | BATU_BL_128K | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT3L CONFIG_SYS_IBAT3L #define CONFIG_SYS_DBAT3U CONFIG_SYS_IBAT3U
#ifdef CONFIG_PCI /* PCI MEM space: cacheable */ -#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI_MEM_PHYS | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PCI_MEM_PHYS | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_PCI_MEM_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT6L CONFIG_SYS_IBAT6L #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U /* PCI MMIO space: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI_MMIO_PHYS | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT7L (CONFIG_SYS_PCI_MMIO_PHYS | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT7U (CONFIG_SYS_PCI_MMIO_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT7L CONFIG_SYS_IBAT7L diff --git a/include/configs/MVBLM7.h b/include/configs/MVBLM7.h index c201310..6fe9684 100644 --- a/include/configs/MVBLM7.h +++ b/include/configs/MVBLM7.h @@ -334,13 +334,13 @@ #define CONFIG_HIGH_BATS 1
/* PCI */ -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT |\ +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_RW | BATL_CACHEINHIBIT |\ BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP)
@@ -351,12 +351,12 @@ #define CONFIG_SYS_IBAT4U 0
/* IMMRBAR @ 0xE0000000, PCI IO @ 0xE2000000 & BCSR @ 0xE2400000 */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR | BATL_PP_10 | BATL_CACHEINHIBIT | \ +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR | BATL_PP_RW | BATL_CACHEINHIBIT | \ BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_IMMR | BATU_BL_256M | BATU_VS | BATU_VP)
/* stack in DCACHE 0xFDF00000 & FLASH @ 0xFF800000 */ -#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_10 | BATL_MEMCOHERENCE | \ +#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_RW | BATL_MEMCOHERENCE | \ BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT6U (0xF0000000 | BATU_BL_256M | BATU_VS | BATU_VP) #define CONFIG_SYS_IBAT7L 0 diff --git a/include/configs/SIMPC8313.h b/include/configs/SIMPC8313.h index 339e02b..2ec2637 100644 --- a/include/configs/SIMPC8313.h +++ b/include/configs/SIMPC8313.h @@ -439,15 +439,15 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR @ 0x00000000 */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT1L ((CONFIG_SYS_SDRAM_BASE + 0x10000000) | BATL_PP_10) +#define CONFIG_SYS_IBAT1L ((CONFIG_SYS_SDRAM_BASE + 0x10000000) | BATL_PP_RW) #define CONFIG_SYS_IBAT1U ((CONFIG_SYS_SDRAM_BASE + 0x10000000) | BATU_BL_256M | BATU_VS | BATU_VP)
/* PCI @ 0x80000000 */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10) +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_RW) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_RW | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_PCI1_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP)
/* PCI2 not supported on 8313 */ @@ -455,11 +455,11 @@ #define CONFIG_SYS_IBAT4U (0)
/* IMMRBAR @ 0xE0000000, PCI IO @ 0xE2000000 */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR | BATL_PP_RW | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_IMMR | BATU_BL_256M | BATU_VS | BATU_VP)
#define CONFIG_SYS_IBAT7L (0) diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index 5cd517d..e0bba46 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -408,22 +408,22 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR 0 - 512M */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_SDRAM_BASE + 0x10000000 | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_SDRAM_BASE + 0x10000000 | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_SDRAM_BASE + 0x10000000 | BATU_BL_256M | BATU_VS | BATU_VP)
/* stack in DCACHE @ 512M (no backing mem) */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_INIT_RAM_ADDR | BATU_BL_128K | BATU_VS | BATU_VP)
/* PCI */ #ifdef CONFIG_PCI -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_PCI1_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_10 | BATL_MEMCOHERENCE | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_RW | BATL_MEMCOHERENCE | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_PCI1_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_PCI1_IO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_PCI1_IO_BASE | BATL_PP_RW | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_PCI1_IO_BASE | BATU_BL_16M | BATU_VS | BATU_VP) #else #define CONFIG_SYS_IBAT3L (0) @@ -435,11 +435,11 @@ #endif
/* IMMRBAR */ -#define CONFIG_SYS_IBAT6L (CONFIG_SYS_IMMR | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_IMMR | BATL_PP_RW | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_IMMR | BATU_BL_1M | BATU_VS | BATU_VP)
/* FLASH */ -#define CONFIG_SYS_IBAT7L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT7L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT7U (CONFIG_SYS_FLASH_BASE | BATU_BL_256M | BATU_VS | BATU_VP)
#define CONFIG_SYS_DBAT0L CONFIG_SYS_IBAT0L diff --git a/include/configs/km/km83xx-common.h b/include/configs/km/km83xx-common.h index 2b1a84a..9d28d8e 100644 --- a/include/configs/km/km83xx-common.h +++ b/include/configs/km/km83xx-common.h @@ -242,7 +242,7 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR: cache cacheable */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) @@ -250,7 +250,7 @@ #define CONFIG_SYS_DBAT0U CONFIG_SYS_IBAT0U
/* IMMRBAR & PCI IO: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_IMMR | BATU_BL_4M | BATU_VS \ | BATU_VP) @@ -258,25 +258,25 @@ #define CONFIG_SYS_DBAT1U CONFIG_SYS_IBAT1U
/* PRIO1, PIGGY: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_KMBEC_FPGA_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_KMBEC_FPGA_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_KMBEC_FPGA_BASE | BATU_BL_128M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT2L (CONFIG_SYS_KMBEC_FPGA_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT2L (CONFIG_SYS_KMBEC_FPGA_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT2U CONFIG_SYS_IBAT2U
/* FLASH: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_FLASH_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT3L (CONFIG_SYS_FLASH_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT3L (CONFIG_SYS_FLASH_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT3U CONFIG_SYS_IBAT3U
/* Stack in dcache: cacheable, no memory coherence */ -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10) +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_RW) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_INIT_RAM_ADDR | BATU_BL_128K | \ BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT4L CONFIG_SYS_IBAT4L diff --git a/include/configs/kmeter1.h b/include/configs/kmeter1.h index 8639ddd..de336f0 100644 --- a/include/configs/kmeter1.h +++ b/include/configs/kmeter1.h @@ -151,22 +151,22 @@ */
/* PAXE: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_PAXE_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_PAXE_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_PAXE_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT5L (CONFIG_SYS_PAXE_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT5L (CONFIG_SYS_PAXE_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U
#ifdef CONFIG_PCI /* PCI MEM space: cacheable */ -#define CFG_IBAT6L (CFG_PCI1_MEM_PHYS | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CFG_IBAT6L (CFG_PCI1_MEM_PHYS | BATL_PP_RW | BATL_MEMCOHERENCE) #define CFG_IBAT6U (CFG_PCI1_MEM_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CFG_DBAT6L CFG_IBAT6L #define CFG_DBAT6U CFG_IBAT6U /* PCI MMIO space: cache-inhibit and guarded */ -#define CFG_IBAT7L (CFG_PCI1_MMIO_PHYS | BATL_PP_10 | \ +#define CFG_IBAT7L (CFG_PCI1_MMIO_PHYS | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CFG_IBAT7U (CFG_PCI1_MMIO_PHYS | BATU_BL_256M | BATU_VS | BATU_VP) #define CFG_DBAT7L CFG_IBAT7L diff --git a/include/configs/kmsupx5.h b/include/configs/kmsupx5.h index f8cd8e0..ccc1561 100644 --- a/include/configs/kmsupx5.h +++ b/include/configs/kmsupx5.h @@ -74,11 +74,11 @@ OR_GPCM_EAD)
/* LPXF: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_LPXF_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_LPXF_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_LPXF_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT5L (CONFIG_SYS_LPXF_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT5L (CONFIG_SYS_LPXF_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U
diff --git a/include/configs/mpc8308_p1m.h b/include/configs/mpc8308_p1m.h index 4c9a766..048843c 100644 --- a/include/configs/mpc8308_p1m.h +++ b/include/configs/mpc8308_p1m.h @@ -456,7 +456,7 @@ */
/* DDR: cache cacheable */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_128M | \ BATU_VS | BATU_VP) @@ -464,7 +464,7 @@ #define CONFIG_SYS_DBAT0U CONFIG_SYS_IBAT0U
/* IMMRBAR, PCI IO and NAND: cache-inhibit and guarded */ -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_IMMR | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_IMMR | BATU_BL_8M | BATU_VS | \ BATU_VP) @@ -472,17 +472,17 @@ #define CONFIG_SYS_DBAT1U CONFIG_SYS_IBAT1U
/* Stack in dcache: cacheable, no memory coherence */ -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_10) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_INIT_RAM_ADDR | BATL_PP_RW) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_INIT_RAM_ADDR | BATU_BL_128K | \ BATU_VS | BATU_VP) #define CONFIG_SYS_DBAT3L CONFIG_SYS_IBAT3L diff --git a/include/configs/sbc8349.h b/include/configs/sbc8349.h index b418cf2..06ca500 100644 --- a/include/configs/sbc8349.h +++ b/include/configs/sbc8349.h @@ -541,14 +541,14 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* PCI @ 0x80000000 */ #ifdef CONFIG_PCI -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_RW | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP) #else #define CONFIG_SYS_IBAT1L (0) @@ -558,9 +558,9 @@ #endif
#ifdef CONFIG_MPC83XX_PCI2 -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI2_MEM_BASE | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI2_MEM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_PCI2_MEM_BASE | BATU_BL_256M | BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI2_MMIO_BASE | BATL_PP_10 | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI2_MMIO_BASE | BATL_PP_RW | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_PCI2_MMIO_BASE | BATU_BL_256M | BATU_VS | BATU_VP) #else #define CONFIG_SYS_IBAT3L (0) @@ -570,11 +570,11 @@ #endif
diff --git a/include/configs/suvd3.h b/include/configs/suvd3.h index 0b59d51..5f2e1e3 100644 --- a/include/configs/suvd3.h +++ b/include/configs/suvd3.h @@ -85,19 +85,19 @@
/* APP1: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_APP1_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_APP1_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_APP1_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT5L (CONFIG_SYS_APP1_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT5L (CONFIG_SYS_APP1_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U
-#define CONFIG_SYS_IBAT6L (CONFIG_SYS_APP2_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_APP2_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_APP2_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT6L (CONFIG_SYS_APP2_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT6L (CONFIG_SYS_APP2_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U
diff --git a/include/configs/tuda1.h b/include/configs/tuda1.h index 853c00a..7ae7d58 100644 --- a/include/configs/tuda1.h +++ b/include/configs/tuda1.h @@ -106,7 +106,7 @@ */ /* PAXG: icache cacheable, but dcache-inhibit and guarded */ #define CONFIG_SYS_IBAT5L (CONFIG_SYS_APP1_BASE | \ - BATL_PP_10 | \ + BATL_PP_RW | \ BATL_MEMCOHERENCE) /* 512M should also include APP2... */ #define CONFIG_SYS_IBAT5U (CONFIG_SYS_APP1_BASE | \ @@ -114,21 +114,21 @@ BATU_VS | \ BATU_VP) #define CONFIG_SYS_DBAT5L (CONFIG_SYS_APP1_BASE | \ - BATL_PP_10 | \ + BATL_PP_RW | \ BATL_CACHEINHIBIT | \ BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U
/* PINC3: icache cacheable, but dcache-inhibit and guarded */ #define CONFIG_SYS_IBAT6L (CONFIG_SYS_APP2_BASE | \ - BATL_PP_10 | \ + BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_APP2_BASE | \ BATU_BL_256M | \ BATU_VS | \ BATU_VP) #define CONFIG_SYS_DBAT6L (CONFIG_SYS_APP2_BASE | \ - BATL_PP_10 | \ + BATL_PP_RW | \ BATL_CACHEINHIBIT | \ BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U diff --git a/include/configs/tuxa1.h b/include/configs/tuxa1.h index 5ce8ad5..d3a82eb 100644 --- a/include/configs/tuxa1.h +++ b/include/configs/tuxa1.h @@ -99,20 +99,20 @@ * MMU Setup */ /* LPXF: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_LPXF_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_LPXF_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_LPXF_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT5L (CONFIG_SYS_LPXF_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT5L (CONFIG_SYS_LPXF_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT5U CONFIG_SYS_IBAT5U
/* PINC2: icache cacheable, but dcache-inhibit and guarded */ -#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PINC2_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_PINC2_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (CONFIG_SYS_PINC2_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_DBAT6L (CONFIG_SYS_PINC2_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_DBAT6L (CONFIG_SYS_PINC2_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_DBAT6U CONFIG_SYS_IBAT6U
diff --git a/include/configs/ve8313.h b/include/configs/ve8313.h index 8beac34..526a731 100644 --- a/include/configs/ve8313.h +++ b/include/configs/ve8313.h @@ -421,16 +421,16 @@ #define CONFIG_HIGH_BATS 1 /* High BATs supported */
/* DDR @ 0x00000000 */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10) +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP)
#if defined(CONFIG_PCI) /* PCI @ 0x80000000 */ -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10) +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_RW) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) @@ -448,17 +448,17 @@ #define CONFIG_SYS_IBAT4U (0)
/* IMMRBAR @ 0xE0000000, PCI IO @ 0xE2000000 & BCSR @ 0xE2400000 */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_IMMR | BATU_BL_256M | BATU_VS | \ BATU_VP)
/* stack in DCACHE 0xFDF00000 & FLASH @ 0xFE000000 */ -#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_10 | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_RW | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT6U (0xF0000000 | BATU_BL_256M | BATU_VS | BATU_VP)
/* FPGA, SRAM, NAND @ 0x60000000 */ -#define CONFIG_SYS_IBAT7L (0x60000000 | BATL_PP_10 | BATL_GUARDEDSTORAGE) +#define CONFIG_SYS_IBAT7L (0x60000000 | BATL_PP_RW | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT7U (0x60000000 | BATU_BL_256M | BATU_VS | BATU_VP)
#define CONFIG_SYS_DBAT0L CONFIG_SYS_IBAT0L diff --git a/include/configs/vme8349.h b/include/configs/vme8349.h index d153762..95de633 100644 --- a/include/configs/vme8349.h +++ b/include/configs/vme8349.h @@ -465,18 +465,18 @@ #define CONFIG_HIGH_BATS /* High BATs supported */
/* DDR @ 0x00000000 */ -#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT0L (CONFIG_SYS_SDRAM_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT0U (CONFIG_SYS_SDRAM_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP)
/* PCI @ 0x80000000 */ #ifdef CONFIG_PCI -#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT1L (CONFIG_SYS_PCI1_MEM_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT1U (CONFIG_SYS_PCI1_MEM_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT2L (CONFIG_SYS_PCI1_MMIO_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT2U (CONFIG_SYS_PCI1_MMIO_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) @@ -488,11 +488,11 @@ #endif
#ifdef CONFIG_MPC83XX_PCI2 -#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI2_MEM_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT3L (CONFIG_SYS_PCI2_MEM_BASE | BATL_PP_RW | \ BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT3U (CONFIG_SYS_PCI2_MEM_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) -#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI2_MMIO_BASE | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT4L (CONFIG_SYS_PCI2_MMIO_BASE | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT4U (CONFIG_SYS_PCI2_MMIO_BASE | BATU_BL_256M | \ BATU_VS | BATU_VP) @@ -504,17 +504,17 @@ #endif
/* IMMRBAR @ 0xE0000000, PCI IO @ 0xE2000000 */ -#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR | BATL_PP_10 | \ +#define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR | BATL_PP_RW | \ BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_IMMR | BATU_BL_256M | \ BATU_VS | BATU_VP)
-#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_10 | BATL_MEMCOHERENCE) +#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT6U (0xF0000000 | BATU_BL_256M | BATU_VS | BATU_VP)
#if (CONFIG_SYS_DDR_SIZE == 512) #define CONFIG_SYS_IBAT7L (CONFIG_SYS_SDRAM_BASE+0x10000000 | \ - BATL_PP_10 | BATL_MEMCOHERENCE) + BATL_PP_RW | BATL_MEMCOHERENCE) #define CONFIG_SYS_IBAT7U (CONFIG_SYS_SDRAM_BASE+0x10000000 | \ BATU_BL_256M | BATU_VS | BATU_VP) #else
In message 1313185980-6208-3-git-send-email-joe.hershberger@ni.com you wrote:
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com
Changes for v2:
- Split
Checkpatch says:
total: 0 errors, 61 warnings, 1027 lines checked
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com --- Changes for v2: - Split
arch/powerpc/cpu/mpc83xx/spd_sdram.c | 9 +++++ include/configs/MPC8308RDB.h | 5 ++- include/configs/MPC8313ERDB.h | 10 ++++-- include/configs/MPC8315ERDB.h | 5 ++- include/configs/MPC8323ERDB.h | 10 +++++- include/configs/MPC832XEMDS.h | 56 ++++++++++++++++++++++++++++------ include/configs/MPC8360ERDK.h | 8 ++++- include/configs/MPC837XEMDS.h | 6 ++- include/configs/MPC837XERDB.h | 30 +++++++++++------- include/configs/MVBLM7.h | 5 ++- include/configs/kmeter1.h | 5 ++- include/configs/mpc8308_p1m.h | 10 ++++-- include/configs/ve8313.h | 11 ++++--- include/configs/vme8349.h | 3 +- include/mpc83xx.h | 32 ++++++++++++++++++- 15 files changed, 154 insertions(+), 51 deletions(-)
diff --git a/arch/powerpc/cpu/mpc83xx/spd_sdram.c b/arch/powerpc/cpu/mpc83xx/spd_sdram.c index 9b01f0d..3855bfd 100644 --- a/arch/powerpc/cpu/mpc83xx/spd_sdram.c +++ b/arch/powerpc/cpu/mpc83xx/spd_sdram.c @@ -46,10 +46,19 @@ void board_add_ram_info(int use_default) printf(" (DDR%d", ((ddr->sdram_cfg & SDRAM_CFG_SDRAM_TYPE_MASK) >> SDRAM_CFG_SDRAM_TYPE_SHIFT) - 1);
+#if defined(CONFIG_MPC8308) || defined(CONFIG_MPC831x) + if ((ddr->sdram_cfg & SDRAM_CFG_DBW_MASK) == SDRAM_CFG_DBW_16) + puts(", 16-bit"); + else if ((ddr->sdram_cfg & SDRAM_CFG_DBW_MASK) == SDRAM_CFG_DBW_32) + puts(", 32-bit"); + else + puts(", unknown width"); +#else if (ddr->sdram_cfg & SDRAM_CFG_32_BE) puts(", 32-bit"); else puts(", 64-bit"); +#endif
if (ddr->sdram_cfg & SDRAM_CFG_ECC_EN) puts(", ECC on"); diff --git a/include/configs/MPC8308RDB.h b/include/configs/MPC8308RDB.h index cbdaada..d73894c 100644 --- a/include/configs/MPC8308RDB.h +++ b/include/configs/MPC8308RDB.h @@ -149,7 +149,8 @@
#define CONFIG_SYS_DDR_CS0_BNDS 0x00000007 #define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN \ - | 0x00010000 /* ODT_WR to CSn */ \ + | CSCONFIG_ODT_RD_NEVER \ + | CSCONFIG_ODT_WR_ONLY_CURRENT \ | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10) /* 0x80010102 */ #define CONFIG_SYS_DDR_TIMING_3 0x00000000 @@ -184,7 +185,7 @@ /* 0x03600100 */ #define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SREN \ | SDRAM_CFG_SDRAM_TYPE_DDR2 \ - | SDRAM_CFG_32_BE) + | SDRAM_CFG_DBW_32) /* 0x43080000 */
#define CONFIG_SYS_DDR_SDRAM_CFG2 0x00401000 /* 1 posted refresh */ diff --git a/include/configs/MPC8313ERDB.h b/include/configs/MPC8313ERDB.h index 7405538..d39444b 100644 --- a/include/configs/MPC8313ERDB.h +++ b/include/configs/MPC8313ERDB.h @@ -131,7 +131,8 @@ */ #define CONFIG_SYS_DDR_SIZE 128 /* MB */ #define CONFIG_SYS_DDR_CONFIG ( CSCONFIG_EN \ - | 0x00010000 /* TODO */ \ + | CSCONFIG_ODT_RD_NEVER \ + | CSCONFIG_ODT_WR_ONLY_CURRENT \ | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10 ) /* 0x80010102 */
@@ -168,12 +169,13 @@ #if defined(CONFIG_DDR_2T_TIMING) #define CONFIG_SYS_SDRAM_CFG ( SDRAM_CFG_SREN \ | SDRAM_CFG_SDRAM_TYPE_DDR2 \ - | SDRAM_CFG_2T_EN \ - | SDRAM_CFG_DBW_32 ) + | SDRAM_CFG_DBW_32 \ + | SDRAM_CFG_2T_EN ) + /* 0x43088000 */ #else #define CONFIG_SYS_SDRAM_CFG ( SDRAM_CFG_SREN \ | SDRAM_CFG_SDRAM_TYPE_DDR2 \ - | SDRAM_CFG_32_BE ) + | SDRAM_CFG_DBW_32 ) /* 0x43080000 */ #endif #define CONFIG_SYS_SDRAM_CFG2 0x00401000 diff --git a/include/configs/MPC8315ERDB.h b/include/configs/MPC8315ERDB.h index 20d82a1..85d07e0 100644 --- a/include/configs/MPC8315ERDB.h +++ b/include/configs/MPC8315ERDB.h @@ -141,7 +141,8 @@ #define CONFIG_SYS_DDR_SIZE 128 /* MB */ #define CONFIG_SYS_DDR_CS0_BNDS 0x00000007 #define CONFIG_SYS_DDR_CS0_CONFIG ( CSCONFIG_EN \ - | 0x00010000 /* ODT_WR to CSn */ \ + | CSCONFIG_ODT_RD_NEVER \ + | CSCONFIG_ODT_WR_ONLY_CURRENT \ | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10 ) /* 0x80010102 */ #define CONFIG_SYS_DDR_TIMING_3 0x00000000 @@ -176,7 +177,7 @@ /* 0x03600100 */ #define CONFIG_SYS_DDR_SDRAM_CFG ( SDRAM_CFG_SREN \ | SDRAM_CFG_SDRAM_TYPE_DDR2 \ - | SDRAM_CFG_32_BE ) + | SDRAM_CFG_DBW_32 ) /* 0x43080000 */ #define CONFIG_SYS_DDR_SDRAM_CFG2 0x00401000 /* 1 posted refresh */ #define CONFIG_SYS_DDR_MODE ( ( 0x0448 << SDRAM_MODE_ESD_SHIFT ) \ diff --git a/include/configs/MPC8323ERDB.h b/include/configs/MPC8323ERDB.h index 37f6a47..704684d 100644 --- a/include/configs/MPC8323ERDB.h +++ b/include/configs/MPC8323ERDB.h @@ -77,7 +77,13 @@ #define CONFIG_SYS_DDR_BASE 0x00000000 /* DDR is system memory */ #define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_BASE #define CONFIG_SYS_DDR_SDRAM_BASE CONFIG_SYS_DDR_BASE -#define CONFIG_SYS_DDRCDR 0x73000002 /* DDR II voltage is 1.8V */ +/* [RFC]This is not defined on the MPC8323: +#define CONFIG_SYS_DDRCDR ( DDRCDR_EN \ + | DDRCDR_PZ_NOMZ \ + | DDRCDR_NZ_NOMZ \ + | DDRCDR_M_ODR ) +*/ + /* 0x73000002 */ /* DDR II voltage is 1.8V */
#undef CONFIG_SPD_EEPROM #if defined(CONFIG_SPD_EEPROM) @@ -89,7 +95,7 @@ */ #define CONFIG_SYS_DDR_SIZE 64 /* MB */ #define CONFIG_SYS_DDR_CS0_CONFIG ( CSCONFIG_EN \ - | CSCONFIG_ODT_WR_ACS \ + /* [RFC]Reserved on MPC832x: | 0x00010000 */ \ | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_9 ) /* 0x80010101 */ #define CONFIG_SYS_DDR_TIMING_0 ( ( 0 << TIMING_CFG0_RWT_SHIFT ) \ diff --git a/include/configs/MPC832XEMDS.h b/include/configs/MPC832XEMDS.h index 38ca314..6f892d0 100644 --- a/include/configs/MPC832XEMDS.h +++ b/include/configs/MPC832XEMDS.h @@ -111,17 +111,53 @@ /* Manually set up DDR parameters */ #define CONFIG_SYS_DDR_SIZE 128 /* MB */ -#define CONFIG_SYS_DDR_CS0_CONFIG 0x80840102 -#define CONFIG_SYS_DDR_TIMING_0 0x00220802 -#define CONFIG_SYS_DDR_TIMING_1 0x3935d322 -#define CONFIG_SYS_DDR_TIMING_2 0x0f9048ca -#define CONFIG_SYS_DDR_TIMING_3 0x00000000 -#define CONFIG_SYS_DDR_CLK_CNTL 0x02000000 -#define CONFIG_SYS_DDR_MODE 0x44400232 +#define CONFIG_SYS_DDR_CS0_CONFIG ( CSCONFIG_EN \ + | CSCONFIG_AP \ + | CSCONFIG_ODT_WR_CFG \ + | CSCONFIG_ROW_BIT_13 \ + | CSCONFIG_COL_BIT_10) + /* 0x80840102 */ +#define CONFIG_SYS_DDR_TIMING_0 ( (0 << TIMING_CFG0_RWT_SHIFT) \ + | (0 << TIMING_CFG0_WRT_SHIFT) \ + | (0 << TIMING_CFG0_RRT_SHIFT) \ + | (0 << TIMING_CFG0_WWT_SHIFT) \ + | (2 << TIMING_CFG0_ACT_PD_EXIT_SHIFT) \ + | (2 << TIMING_CFG0_PRE_PD_EXIT_SHIFT) \ + | (8 << TIMING_CFG0_ODT_PD_EXIT_SHIFT) \ + | (2 << TIMING_CFG0_MRS_CYC_SHIFT) ) + /* 0x00220802 */ +#define CONFIG_SYS_DDR_TIMING_1 ( (3 << TIMING_CFG1_PRETOACT_SHIFT) \ + | (9 << TIMING_CFG1_ACTTOPRE_SHIFT) \ + | (3 << TIMING_CFG1_ACTTORW_SHIFT) \ + | (5 << TIMING_CFG1_CASLAT_SHIFT) \ + | (13 << TIMING_CFG1_REFREC_SHIFT) \ + | (3 << TIMING_CFG1_WRREC_SHIFT) \ + | (2 << TIMING_CFG1_ACTTOACT_SHIFT) \ + | (2 << TIMING_CFG1_WRTORD_SHIFT)) + /* 0x3935D322 */ +#define CONFIG_SYS_DDR_TIMING_2 ( (0 << TIMING_CFG2_ADD_LAT_SHIFT) \ + | (31 << TIMING_CFG2_CPO_SHIFT) \ + | (2 << TIMING_CFG2_WR_LAT_DELAY_SHIFT) \ + | (2 << TIMING_CFG2_RD_TO_PRE_SHIFT) \ + | (2 << TIMING_CFG2_WR_DATA_DELAY_SHIFT) \ + | (3 << TIMING_CFG2_CKE_PLS_SHIFT) \ + | (10 << TIMING_CFG2_FOUR_ACT_SHIFT)) + /* 0x0F9048CA */ +#define CONFIG_SYS_DDR_TIMING_3 0x00000000 +#define CONFIG_SYS_DDR_CLK_CNTL DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05 + /* 0x02000000 */ +#define CONFIG_SYS_DDR_MODE ((0x4440 << SDRAM_MODE_ESD_SHIFT) \ + | (0x0232 << SDRAM_MODE_SD_SHIFT)) + /* 0x44400232 */ #define CONFIG_SYS_DDR_MODE2 0x8000c000 -#define CONFIG_SYS_DDR_INTERVAL 0x03200064 -#define CONFIG_SYS_DDR_CS0_BNDS 0x00000007 -#define CONFIG_SYS_DDR_SDRAM_CFG 0x43080000 +#define CONFIG_SYS_DDR_INTERVAL ((800 << SDRAM_INTERVAL_REFINT_SHIFT) \ + | (100 << SDRAM_INTERVAL_BSTOPRE_SHIFT)) + /* 0x03200064 */ +#define CONFIG_SYS_DDR_CS0_BNDS 0x00000007 +#define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SREN \ + | SDRAM_CFG_SDRAM_TYPE_DDR2 \ + | SDRAM_CFG_32_BE) + /* 0x43080000 */ #define CONFIG_SYS_DDR_SDRAM_CFG2 0x00401000 #endif
diff --git a/include/configs/MPC8360ERDK.h b/include/configs/MPC8360ERDK.h index 9242ff5..672eeba 100644 --- a/include/configs/MPC8360ERDK.h +++ b/include/configs/MPC8360ERDK.h @@ -96,7 +96,10 @@ /* * DDRCDR - DDR Control Driver Register */ -#define CONFIG_SYS_DDRCDR_VALUE 0x80080001 +#define CONFIG_SYS_DDRCDR_VALUE (DDRCDR_DHC_EN \ + | DDRCDR_ODT \ + | DDRCDR_Q_DRN) + /* 0x80080001 */
#undef CONFIG_SPD_EEPROM /* Do not use SPD EEPROM for DDR setup */
@@ -107,7 +110,8 @@ #define CONFIG_SYS_DDR_SIZE 256 /* MB */ #define CONFIG_SYS_DDR_CS0_BNDS 0x0000000f #define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN | CSCONFIG_ROW_BIT_13 | \ - CSCONFIG_COL_BIT_10 | CSCONFIG_ODT_WR_ACS) + CSCONFIG_COL_BIT_10 | \ + CSCONFIG_ODT_WR_ONLY_CURRENT) #define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SDRAM_TYPE_DDR2 | SDRAM_CFG_ECC_EN) #define CONFIG_SYS_DDR_SDRAM_CFG2 0x00001000 #define CONFIG_SYS_DDR_CLK_CNTL (DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05) diff --git a/include/configs/MPC837XEMDS.h b/include/configs/MPC837XEMDS.h index a6f2fde..eaca6cb 100644 --- a/include/configs/MPC837XEMDS.h +++ b/include/configs/MPC837XEMDS.h @@ -128,7 +128,8 @@ #define CONFIG_SYS_DDR_SDRAM_BASE CONFIG_SYS_DDR_BASE #define CONFIG_SYS_DDR_SDRAM_CLK_CNTL DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05 #define CONFIG_SYS_83XX_DDR_USES_CS0 -#define CONFIG_SYS_DDRCDR_VALUE 0x80080001 /* ODT 150ohm on SoC */ +#define CONFIG_SYS_DDRCDR_VALUE (DDRCDR_DHC_EN | DDRCDR_ODT | DDRCDR_Q_DRN) + /* 0x80080001 */ /* ODT 150ohm on SoC */
#undef CONFIG_DDR_ECC /* support DDR ECC function */ #undef CONFIG_DDR_ECC_CMD /* Use DDR ECC user commands */ @@ -147,7 +148,8 @@ #define CONFIG_SYS_DDR_SIZE 512 /* MB */ #define CONFIG_SYS_DDR_CS0_BNDS 0x0000001f #define CONFIG_SYS_DDR_CS0_CONFIG ( CSCONFIG_EN \ - | 0x00010000 /* ODT_WR to CSn */ \ + | CSCONFIG_ODT_RD_NEVER /* ODT_RD to none */ \ + | CSCONFIG_ODT_WR_ONLY_CURRENT /* ODT_WR to CSn */ \ | CSCONFIG_ROW_BIT_14 | CSCONFIG_COL_BIT_10 ) /* 0x80010202 */ #define CONFIG_SYS_DDR_TIMING_3 0x00000000 diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index 9807d31..6b9096d 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -165,8 +165,8 @@ * Manually set up DDR parameters */ #define CONFIG_SYS_DDR_SIZE 256 /* MB */ -#define CONFIG_SYS_DDR_CS0_BNDS 0x0000000f -#define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN | CSCONFIG_ODT_WR_ACS \ +#define CONFIG_SYS_DDR_CS0_BNDS 0x0000000f +#define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN | CSCONFIG_ODT_WR_ONLY_CURRENT \ | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10)
#define CONFIG_SYS_DDR_TIMING_3 0x00000000 @@ -178,7 +178,6 @@ | (6 << TIMING_CFG0_PRE_PD_EXIT_SHIFT) \ | (8 << TIMING_CFG0_ODT_PD_EXIT_SHIFT) \ | (2 << TIMING_CFG0_MRS_CYC_SHIFT)) - /* 0x00220802 */ /* 0x00260802 */ /* DDR400 */ #define CONFIG_SYS_DDR_TIMING_1 ((3 << TIMING_CFG1_PRETOACT_SHIFT) \ | (9 << TIMING_CFG1_ACTTOPRE_SHIFT) \ @@ -188,23 +187,30 @@ | (3 << TIMING_CFG1_WRREC_SHIFT) \ | (2 << TIMING_CFG1_ACTTOACT_SHIFT) \ | (2 << TIMING_CFG1_WRTORD_SHIFT)) - /* 0x3935d322 */ /* 0x3937d322 */ -#define CONFIG_SYS_DDR_TIMING_2 0x02984cc8 +#define CONFIG_SYS_DDR_TIMING_2 ((0 << TIMING_CFG2_ADD_LAT_SHIFT) \ + | (5 << TIMING_CFG2_CPO_SHIFT) \ + | (3 << TIMING_CFG2_WR_LAT_DELAY_SHIFT) \ + | (2 << TIMING_CFG2_RD_TO_PRE_SHIFT) \ + | (3 << TIMING_CFG2_WR_DATA_DELAY_SHIFT) \ + | (3 << TIMING_CFG2_CKE_PLS_SHIFT) \ + | (8 << TIMING_CFG2_FOUR_ACT_SHIFT)) + /* 0x02984cc8 */
#define CONFIG_SYS_DDR_INTERVAL ((1024 << SDRAM_INTERVAL_REFINT_SHIFT) \ | (0 << SDRAM_INTERVAL_BSTOPRE_SHIFT)) /* 0x06090100 */
#if defined(CONFIG_DDR_2T_TIMING) -#define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SREN \ - | 3 << SDRAM_CFG_SDRAM_TYPE_SHIFT \ - | SDRAM_CFG_2T_EN \ - | SDRAM_CFG_DBW_32) +#define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SREN \ + | SDRAM_CFG_SDRAM_TYPE_DDR2 \ + | SDRAM_CFG_32_BE \ + | SDRAM_CFG_2T_EN) + /* 0x43088000 */ #else -#define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SREN \ - | 3 << SDRAM_CFG_SDRAM_TYPE_SHIFT) - /* 0x43000000 */ +#define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SREN \ + | SDRAM_CFG_SDRAM_TYPE_DDR2) + /* 0x43000000 */ #endif #define CONFIG_SYS_DDR_SDRAM_CFG2 0x00001000 /* 1 posted refresh */ #define CONFIG_SYS_DDR_MODE ((0x0406 << SDRAM_MODE_ESD_SHIFT) \ diff --git a/include/configs/MVBLM7.h b/include/configs/MVBLM7.h index 6fe9684..f295871 100644 --- a/include/configs/MVBLM7.h +++ b/include/configs/MVBLM7.h @@ -72,7 +72,10 @@ #define CONFIG_SYS_MEMTEST_END (70<<20) #define CONFIG_VERY_BIG_RAM
-#define CONFIG_SYS_DDRCDR 0x22000001 +#define CONFIG_SYS_DDRCDR (DDRCDR_PZ_HIZ \ + | DDRCDR_NZ_HIZ \ + | DDRCDR_Q_DRN) + /* 0x22000001 */ #define CONFIG_SYS_DDR_SDRAM_CLK_CNTL DDR_SDRAM_CLK_CNTL_CLK_ADJUST_05
#define CONFIG_SYS_DDR_SIZE 512 diff --git a/include/configs/kmeter1.h b/include/configs/kmeter1.h index de336f0..37175d6 100644 --- a/include/configs/kmeter1.h +++ b/include/configs/kmeter1.h @@ -72,9 +72,10 @@ #define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN | CSCONFIG_AP | \ CSCONFIG_ROW_BIT_13 | \ CSCONFIG_COL_BIT_10 | \ - CSCONFIG_ODT_WR_ACS) + CSCONFIG_ODT_WR_ONLY_CURRENT)
-#define CONFIG_SYS_DDRCDR 0x40000001 +#define CONFIG_SYS_DDRCDR (DDRCDR_EN | DDRCDR_Q_DRN) + /* 0x40000001 */ #define CONFIG_SYS_DDR_MODE 0x47860452 #define CONFIG_SYS_DDR_MODE2 0x8080c000
diff --git a/include/configs/mpc8308_p1m.h b/include/configs/mpc8308_p1m.h index 048843c..a633dca 100644 --- a/include/configs/mpc8308_p1m.h +++ b/include/configs/mpc8308_p1m.h @@ -157,9 +157,11 @@
#define CONFIG_SYS_DDR_CS0_BNDS 0x00000007 #define CONFIG_SYS_DDR_CS0_CONFIG (CSCONFIG_EN \ - | 0x00010000 /* ODT_WR to CSn */ \ - | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10) - /* 0x80010102 */ + | CSCONFIG_ODT_RD_NEVER \ + | CSCONFIG_ODT_WR_ONLY_CURRENT \ + | CSCONFIG_ROW_BIT_13 \ + | CSCONFIG_COL_BIT_10) + /* 0x80010102 */ #define CONFIG_SYS_DDR_TIMING_3 0x00000000 #define CONFIG_SYS_DDR_TIMING_0 ((0 << TIMING_CFG0_RWT_SHIFT) \ | (0 << TIMING_CFG0_WRT_SHIFT) \ @@ -192,7 +194,7 @@ /* 0x03600100 */ #define CONFIG_SYS_DDR_SDRAM_CFG (SDRAM_CFG_SREN \ | SDRAM_CFG_SDRAM_TYPE_DDR2 \ - | SDRAM_CFG_32_BE) + | SDRAM_CFG_DBW_32) /* 0x43080000 */
#define CONFIG_SYS_DDR_SDRAM_CFG2 0x00401000 /* 1 posted refresh */ diff --git a/include/configs/ve8313.h b/include/configs/ve8313.h index 526a731..d256def 100644 --- a/include/configs/ve8313.h +++ b/include/configs/ve8313.h @@ -80,10 +80,11 @@ */ #define CONFIG_SYS_DDR_SIZE 128 /* MB */ #define CONFIG_SYS_DDR_CONFIG ( CSCONFIG_EN \ - | CSCONFIG_AP \ - | 0x00040000 /* TODO */ \ - | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10 ) - /* 0x80840102 */ + | CSCONFIG_AP \ + | CSCONFIG_ODT_RD_NEVER \ + | CSCONFIG_ODT_WR_ALL \ + | CSCONFIG_ROW_BIT_13 | CSCONFIG_COL_BIT_10 ) + /* 0x80840102 */
#define CONFIG_SYS_DDR_TIMING_3 0x00000000 #define CONFIG_SYS_DDR_TIMING_0 ( ( 0 << TIMING_CFG0_RWT_SHIFT ) \ @@ -117,7 +118,7 @@ /* 0x03202000 */ #define CONFIG_SYS_SDRAM_CFG ( SDRAM_CFG_SREN \ | SDRAM_CFG_SDRAM_TYPE_DDR2 \ - | SDRAM_CFG_32_BE ) + | SDRAM_CFG_DBW_32 ) /* 0x43080000 */ #define CONFIG_SYS_SDRAM_CFG2 0x00401000 #define CONFIG_SYS_DDR_MODE ( ( 0x4440 << SDRAM_MODE_ESD_SHIFT ) \ diff --git a/include/configs/vme8349.h b/include/configs/vme8349.h index 95de633..dbdb9da 100644 --- a/include/configs/vme8349.h +++ b/include/configs/vme8349.h @@ -109,7 +109,8 @@ #define CONFIG_SYS_DDR_SDRAM_CLK_CNTL (DDR_SDRAM_CLK_CNTL_SS_EN | \ DDR_SDRAM_CLK_CNTL_CLK_ADJUST_075) #define CONFIG_DDR_2T_TIMING -#define CONFIG_SYS_DDRCDR 0x80080001 +#define CONFIG_SYS_DDRCDR (DDRCDR_DHC_EN | DDRCDR_ODT | DDRCDR_Q_DRN) + /* 0x80080001 */
/* * FLASH on the Local Bus diff --git a/include/mpc83xx.h b/include/mpc83xx.h index 8292018..15ef487 100644 --- a/include/mpc83xx.h +++ b/include/mpc83xx.h @@ -905,9 +905,29 @@ */ #define CSCONFIG_EN 0x80000000 #define CSCONFIG_AP 0x00800000 -#define CSCONFIG_ODT_WR_ACS 0x00010000 -#if defined(CONFIG_MPC832x) +#if defined(CONFIG_MPC8308) || defined(CONFIG_MPC831x) +#define CSCONFIG_ODT_RD_NEVER 0x00000000 +#define CSCONFIG_ODT_RD_ONLY_CURRENT 0x00100000 +#define CSCONFIG_ODT_RD_ONLY_OTHER_CS 0x00200000 +#define CSCONFIG_ODT_RD_ALL 0x00400000 +#define CSCONFIG_ODT_WR_NEVER 0x00000000 +#define CSCONFIG_ODT_WR_ONLY_CURRENT 0x00010000 +#define CSCONFIG_ODT_WR_ONLY_OTHER_CS 0x00020000 +#define CSCONFIG_ODT_WR_ALL 0x00040000 +#elif defined(CONFIG_MPC832x) +#define CSCONFIG_ODT_RD_CFG 0x00400000 #define CSCONFIG_ODT_WR_CFG 0x00040000 +#elif defined(CONFIG_MPC8360) || defined(CONFIG_MPC837x) +#define CSCONFIG_ODT_RD_NEVER 0x00000000 +#define CSCONFIG_ODT_RD_ONLY_CURRENT 0x00100000 +#define CSCONFIG_ODT_RD_ONLY_OTHER_CS 0x00200000 +#define CSCONFIG_ODT_RD_ONLY_OTHER_DIMM 0x00300000 +#define CSCONFIG_ODT_RD_ALL 0x00400000 +#define CSCONFIG_ODT_WR_NEVER 0x00000000 +#define CSCONFIG_ODT_WR_ONLY_CURRENT 0x00010000 +#define CSCONFIG_ODT_WR_ONLY_OTHER_CS 0x00020000 +#define CSCONFIG_ODT_WR_ONLY_OTHER_DIMM 0x00030000 +#define CSCONFIG_ODT_WR_ALL 0x00040000 #endif #define CSCONFIG_BANK_BIT_3 0x00004000 #define CSCONFIG_ROW_BIT 0x00000700 @@ -996,8 +1016,16 @@ #define SDRAM_CFG_SDRAM_TYPE_MASK 0x07000000 #define SDRAM_CFG_SDRAM_TYPE_SHIFT 24 #define SDRAM_CFG_DYN_PWR 0x00200000 +#if defined(CONFIG_MPC8308) || defined(CONFIG_MPC831x) +#define SDRAM_CFG_DBW_MASK 0x00180000 +#define SDRAM_CFG_DBW_16 0x00100000 +#define SDRAM_CFG_DBW_32 0x00080000 +#else #define SDRAM_CFG_32_BE 0x00080000 +#endif +#if !defined(CONFIG_MPC8308) #define SDRAM_CFG_8_BE 0x00040000 +#endif #define SDRAM_CFG_NCAP 0x00020000 #define SDRAM_CFG_2T_EN 0x00008000 #define SDRAM_CFG_HSE 0x00000008
Dear Joe Hershberger,
In message 1313185980-6208-4-git-send-email-joe.hershberger@ni.com you wrote:
Changes for v2:
- Split
Checkpatch says:
total: 10 errors, 8 warnings, 381 lines checked
Please clean up and resubmit. Thanks.
arch/powerpc/include/asm/fsl_lbc.h | 8 ++- include/configs/MERGERBOX.h | 14 ++-- include/configs/MPC8308RDB.h | 35 +++++++--- include/configs/MPC8313ERDB.h | 60 ++++++++++++---- include/configs/MPC8315ERDB.h | 17 +++-- include/configs/MPC8323ERDB.h | 84 ++++------------------ include/configs/MPC832XEMDS.h | 135 +++++++++++++++++------------------- include/configs/MPC8349EMDS.h | 57 +++++++++++----- include/configs/MPC8349ITX.h | 21 +++--- include/configs/MPC8360EMDS.h | 96 ++++++++++++++++++++------ include/configs/MPC8360ERDK.h | 40 +++++++---- include/configs/MPC837XEMDS.h | 75 ++++++++++++-------- include/configs/MPC837XERDB.h | 64 ++++++++++------- include/configs/MVBLM7.h | 13 ++-- include/configs/SIMPC8313.h | 14 ++-- include/configs/TQM834x.h | 4 +- include/configs/km/km83xx-common.h | 14 ++-- include/configs/kmeter1.h | 7 +- include/configs/kmsupx5.h | 4 +- include/configs/mpc8308_p1m.h | 25 ++++--- include/configs/sbc8349.h | 53 +++++++++----- include/configs/suvd3.h | 2 +- include/configs/tuda1.h | 13 ++-- include/configs/tuxa1.h | 13 ++-- include/configs/ve8313.h | 25 ++++--- include/configs/vme8349.h | 56 +++++++++++---- 26 files changed, 552 insertions(+), 397 deletions(-)
diff --git a/arch/powerpc/include/asm/fsl_lbc.h b/arch/powerpc/include/asm/fsl_lbc.h index 8695a62..bf572b7 100644 --- a/arch/powerpc/include/asm/fsl_lbc.h +++ b/arch/powerpc/include/asm/fsl_lbc.h @@ -50,8 +50,10 @@ void lbc_sdram_init(void); #define BR_MSEL 0x000000E0 #define BR_MSEL_SHIFT 5 #define BR_MS_GPCM 0x00000000 /* GPCM */ +#if !defined(CONFIG_MPC834x) && !defined(CONFIG_MPC8360) #define BR_MS_FCM 0x00000020 /* FCM */ -#ifdef CONFIG_MPC83xx +#endif +#if defined(CONFIG_MPC834x) || defined(CONFIG_MPC8360) #define BR_MS_SDRAM 0x00000060 /* SDRAM */ #elif defined(CONFIG_MPC85xx) #define BR_MS_SDRAM 0x00000000 /* SDRAM */ @@ -138,8 +140,10 @@ void lbc_sdram_init(void); #define OR_GPCM_EHTR_SHIFT 1 #define OR_GPCM_EHTR_CLEAR 0x00000000 #define OR_GPCM_EHTR_SET 0x00000002 +#if !defined(CONFIG_MPC8308) #define OR_GPCM_EAD 0x00000001 #define OR_GPCM_EAD_SHIFT 0 +#endif
/* helpers to convert values into an OR address mask (GPCM mode) */ #define P2SZ_TO_AM(s) ((~((s) - 1)) & 0xffff8000) /* must be pow of 2 */ @@ -196,8 +200,10 @@ void lbc_sdram_init(void); #define OR_SDRAM_XAM_SHIFT 13 #define OR_SDRAM_COLS 0x00001C00 #define OR_SDRAM_COLS_SHIFT 10 +#define OR_SDRAM_MIN_COLS 7 #define OR_SDRAM_ROWS 0x000001C0 #define OR_SDRAM_ROWS_SHIFT 6 +#define OR_SDRAM_MIN_ROWS 9 #define OR_SDRAM_PMSEL 0x00000020 #define OR_SDRAM_PMSEL_SHIFT 5 #define OR_SDRAM_EAD 0x00000001 diff --git a/include/configs/MERGERBOX.h b/include/configs/MERGERBOX.h index ca7ecdd..8a1c4f0 100644 --- a/include/configs/MERGERBOX.h +++ b/include/configs/MERGERBOX.h @@ -159,11 +159,13 @@ #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE #define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_64MB)
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | BR_PS_16 | BR_V) +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | BR_PS_16 |\ + BR_MS_GPCM | BR_V) #define CONFIG_SYS_OR0_PRELIM (CONFIG_SYS_FLASH_BASE | OR_UPM_XAM |\ OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 |\ - OR_GPCM_XACS | OR_GPCM_SCY_15 | OR_GPCM_TRLX |\ - OR_GPCM_EHTR | OR_GPCM_EAD) + OR_GPCM_XACS | OR_GPCM_SCY_15 |\ + OR_GPCM_TRLX_SET | OR_GPCM_EHTR_SET |\ + OR_GPCM_EAD)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 512 @@ -180,14 +182,14 @@ #define CONFIG_NAND_FSL_ELBC 1
#define CONFIG_SYS_NAND_BASE 0xE0600000 -#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_NAND_BASE | (2<<BR_DECC_SHIFT) |\ +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_NAND_BASE | BR_DECC_CHK_GEN |\ BR_PS_8 | BR_MS_FCM | BR_V) -#define CONFIG_SYS_OR1_PRELIM (0xFFFF8000 | OR_FCM_BCTLD | OR_FCM_CST |\ +#define CONFIG_SYS_OR1_PRELIM (OR_AM_32KB | OR_FCM_BCTLD | OR_FCM_CST |\ OR_FCM_CHT | OR_FCM_SCY_1 | OR_FCM_RST |\ OR_FCM_TRLX | OR_FCM_EHTR)
#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_NAND_BASE -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000E +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_32KB)
/* * Serial Port diff --git a/include/configs/MPC8308RDB.h b/include/configs/MPC8308RDB.h index d73894c..1e50194 100644 --- a/include/configs/MPC8308RDB.h +++ b/include/configs/MPC8308RDB.h @@ -241,17 +241,18 @@
#define CONFIG_SYS_BR0_PRELIM (\ CONFIG_SYS_FLASH_BASE /* Flash Base address */ |\ - (2 << BR_PS_SHIFT) /* 16 bit port size */ |\ + BR_PS_16 /* 16 bit port size */ |\ + BR_MS_GPCM /* MSEL = GPCM */ |\ BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) \ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ | OR_UPM_XAM \ | OR_GPCM_CSNT \ | OR_GPCM_ACS_DIV2 \ | OR_GPCM_XACS \ | OR_GPCM_SCY_15 \ - | OR_GPCM_TRLX \ - | OR_GPCM_EHTR \ - | OR_GPCM_EAD) + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + /* [RFC]EAD is reserved on MPC8308: | OR_GPCM_EAD */)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ /* 127 64KB sectors and 8 8KB top sectors per device */ @@ -264,12 +265,13 @@ * NAND Flash on the Local Bus */ #define CONFIG_SYS_NAND_BASE 0xE0600000 /* 0xE0600000 */ +#define CONFIG_SYS_NAND_WINDOW_SIZE (32 * 1024) /* 0x00008000 */ #define CONFIG_SYS_BR1_PRELIM ( CONFIG_SYS_NAND_BASE \ - | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ + | BR_DECC_CHK_GEN /* Use HW ECC */ \ | BR_PS_8 /* Port Size = 8 bit */ \ | BR_MS_FCM /* MSEL = FCM */ \ | BR_V ) /* valid */ -#define CONFIG_SYS_OR1_PRELIM ( 0xFFFF8000 /* length 32K */ \ +#define CONFIG_SYS_OR1_PRELIM ( P2SZ_TO_AM(CONFIG_SYS_NAND_WINDOW_SIZE) \ | OR_FCM_CSCT \ | OR_FCM_CST \ | OR_FCM_CHT \ @@ -283,9 +285,22 @@
#ifdef CONFIG_VSC7385_ENET #define CONFIG_TSEC2 -#define CONFIG_SYS_VSC7385_BASE 0xF0000000 -#define CONFIG_SYS_BR2_PRELIM 0xf0000801 /* VSC7385 Base address */ -#define CONFIG_SYS_OR2_PRELIM 0xfffe09ff /* VSC7385, 128K bytes*/ +#define CONFIG_SYS_VSC7385_BASE 0xF0000000 /* VSC7385 Base address */ +#define CONFIG_SYS_VSC7385_SIZE (128 * 1024) /* 0x00020000 */ +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_VSC7385_BASE /* VSC7385 Base address on CS2 */ \ + | BR_PS_8 /* Port Size = 8 bit */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ + /* 0xF0000801 */ +#define CONFIG_SYS_OR2_PRELIM (P2SZ_TO_AM(CONFIG_SYS_VSC7385_SIZE) \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_SETA \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + /* [RFC]EAD is reserved on MPC8308: | OR_GPCM_EAD */) + /* 0xFFFE09FF */ /* Access window base at VSC7385 base */ #define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_VSC7385_BASE /* Access window size 128K */ diff --git a/include/configs/MPC8313ERDB.h b/include/configs/MPC8313ERDB.h index d39444b..046fe0a 100644 --- a/include/configs/MPC8313ERDB.h +++ b/include/configs/MPC8313ERDB.h @@ -204,16 +204,17 @@ #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE /* buffer up multiple bytes */
#define CONFIG_SYS_NOR_BR_PRELIM (CONFIG_SYS_FLASH_BASE | /* flash Base address */ \ - (2 << BR_PS_SHIFT) | /* 16 bit port size */ \ + BR_PS_16 | /* 16 bit port size */ \ + BR_MS_GPCM | /* MSEL = GPCM */ \ BR_V) /* valid */ -#define CONFIG_SYS_NOR_OR_PRELIM ( 0xFF800000 /* 8 MByte */ \ +#define CONFIG_SYS_NOR_OR_PRELIM ( MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) /* 8 MByte */ \ | OR_GPCM_XACS \ | OR_GPCM_SCY_9 \ | OR_GPCM_EHTR \ | OR_GPCM_EAD ) /* 0xFF006FF7 TODO SLOW 16 MB flash size */ #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE /* window base at flash base */ -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000017 /* 16 MB window size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_16MB) /* 16 MB window size */
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 135 /* sectors per device */ @@ -266,14 +267,15 @@ #define CONFIG_CMD_NAND 1 #define CONFIG_NAND_FSL_ELBC 1 #define CONFIG_SYS_NAND_BLOCK_SIZE 16384 +#define CONFIG_SYS_NAND_WINDOW_SIZE (32 * 1024)
#define CONFIG_SYS_NAND_BR_PRELIM ( CONFIG_SYS_NAND_BASE \ - | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ + | BR_DECC_CHK_GEN /* Use HW ECC */ \ | BR_PS_8 /* Port Size = 8 bit */ \ | BR_MS_FCM /* MSEL = FCM */ \ | BR_V ) /* valid */ -#define CONFIG_SYS_NAND_OR_PRELIM ( 0xFFFF8000 /* length 32K */ \ +#define CONFIG_SYS_NAND_OR_PRELIM ( P2SZ_TO_AM(CONFIG_SYS_NAND_WINDOW_SIZE) \ | OR_FCM_CSCT \ | OR_FCM_CST \ | OR_FCM_CHT \ @@ -295,27 +297,53 @@ #endif
#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_NAND_BASE -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000E /* 32KB */ +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_32KB)
#define CONFIG_SYS_NAND_LBLAWBAR_PRELIM CONFIG_SYS_LBLAWBAR1_PRELIM #define CONFIG_SYS_NAND_LBLAWAR_PRELIM CONFIG_SYS_LBLAWAR1_PRELIM
-/* local bus read write buffer mapping */ -#define CONFIG_SYS_BR3_PRELIM 0xFA000801 /* map at 0xFA000000 */ -#define CONFIG_SYS_OR3_PRELIM 0xFFFF8FF7 /* 32kB */ -#define CONFIG_SYS_LBLAWBAR3_PRELIM 0xFA000000 -#define CONFIG_SYS_LBLAWAR3_PRELIM 0x8000000E /* 32KB */ +/* local bus write LED / read status buffer (BCSR) mapping */ +#define CONFIG_SYS_BCSR_ADDR 0xFA000000 +#define CONFIG_SYS_BCSR_SIZE (32 * 1024) /* 0x00008000 */ +#define CONFIG_SYS_BR3_PRELIM (CONFIG_SYS_BCSR_ADDR /* map at 0xFA000000 on LCS3 */ \ + | BR_PS_8 /* Port Size = 8 bit */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ + /* 0xFA000801 */ +#define CONFIG_SYS_OR3_PRELIM (P2SZ_TO_AM(CONFIG_SYS_BCSR_SIZE) \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xFFFF8FF7 */ +#define CONFIG_SYS_LBLAWBAR3_PRELIM CONFIG_SYS_BCSR_ADDR +#define CONFIG_SYS_LBLAWAR3_PRELIM (LBLAWAR_EN | LBLAWAR_32KB)
/* Vitesse 7385 */
-#define CONFIG_SYS_VSC7385_BASE 0xF0000000 - #ifdef CONFIG_VSC7385_ENET
-#define CONFIG_SYS_BR2_PRELIM 0xf0000801 /* VSC7385 Base address */ -#define CONFIG_SYS_OR2_PRELIM 0xfffe09ff /* VSC7385, 128K bytes*/ +#define CONFIG_SYS_VSC7385_BASE 0xF0000000 /* VSC7385 Base address */ +#define CONFIG_SYS_VSC7385_SIZE (128 * 1024) /* 0x00020000 */ + +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_VSC7385_BASE/* VSC7385 Base address on LCS2 */ \ + | BR_PS_8 /* Port Size = 8 bit */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR2_PRELIM (P2SZ_TO_AM(CONFIG_SYS_VSC7385_SIZE) \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_SETA \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xFFFE09FF */ #define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_VSC7385_BASE/* Access window base at VSC7385 base */ -#define CONFIG_SYS_LBLAWAR2_PRELIM 0x80000010 /* Access window size 128K */ +#define CONFIG_SYS_LBLAWAR2_PRELIM (LBLAWAR_EN | LBLAWAR_128KB)
#endif
diff --git a/include/configs/MPC8315ERDB.h b/include/configs/MPC8315ERDB.h index 85d07e0..c2a38d0 100644 --- a/include/configs/MPC8315ERDB.h +++ b/include/configs/MPC8315ERDB.h @@ -226,19 +226,20 @@ #define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */
#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE /* Window base at flash base */ -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000016 /* 8MB window size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_8MB)
#define CONFIG_SYS_NOR_BR_PRELIM (CONFIG_SYS_FLASH_BASE \ - | (2 << BR_PS_SHIFT) /* 16 bit port size */ \ + | BR_PS_16 /* 16 bit port size */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ | BR_V ) /* valid */ -#define CONFIG_SYS_NOR_OR_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) \ +#define CONFIG_SYS_NOR_OR_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ | OR_UPM_XAM \ | OR_GPCM_CSNT \ | OR_GPCM_ACS_DIV2 \ | OR_GPCM_XACS \ | OR_GPCM_SCY_15 \ - | OR_GPCM_TRLX \ - | OR_GPCM_EHTR \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ | OR_GPCM_EAD )
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ @@ -279,11 +280,11 @@ #define CONFIG_SYS_NAND_U_BOOT_RELOC 0x00010000
#define CONFIG_SYS_NAND_BR_PRELIM (CONFIG_SYS_NAND_BASE \ - | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ + | BR_DECC_CHK_GEN /* Use HW ECC */ \ | BR_PS_8 /* Port Size = 8 bit */ \ | BR_MS_FCM /* MSEL = FCM */ \ | BR_V ) /* valid */ -#define CONFIG_SYS_NAND_OR_PRELIM (0xFFFF8000 /* length 32K */ \ +#define CONFIG_SYS_NAND_OR_PRELIM (P2SZ_TO_AM(CONFIG_SYS_NAND_WINDOW_SIZE) \ | OR_FCM_CSCT \ | OR_FCM_CST \ | OR_FCM_CHT \ @@ -305,7 +306,7 @@ #endif
#define CONFIG_SYS_NAND_LBLAWBAR_PRELIM CONFIG_SYS_LBLAWBAR1_PRELIM #define CONFIG_SYS_NAND_LBLAWAR_PRELIM CONFIG_SYS_LBLAWAR1_PRELIM diff --git a/include/configs/MPC8323ERDB.h b/include/configs/MPC8323ERDB.h index 704684d..c77ed61 100644 --- a/include/configs/MPC8323ERDB.h +++ b/include/configs/MPC8323ERDB.h @@ -189,12 +189,22 @@ #define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */
#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE /* Window base at flash base */ -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000018 /* 32MB window size */ - -#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | /* Flash Base address */ \ - (2 << BR_PS_SHIFT) | /* 16 bit port size */ \ - BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM 0xfe006ff7 /* 16MB Flash size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_32MB) + +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE /* Flash Base address */ \ + | BR_PS_16 /* 16 bit port size */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xFE006FF7 */
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 128 /* sectors per device */ @@ -202,68 +212,6 @@ #undef CONFIG_SYS_FLASH_CHECKSUM
/* - * SDRAM on the Local Bus - */ -#undef CONFIG_SYS_LB_SDRAM /* The board has not SRDAM on local bus */ - -#ifdef CONFIG_SYS_LB_SDRAM -#define CONFIG_SYS_LBC_SDRAM_BASE 0xF0000000 /* SDRAM base address */ -#define CONFIG_SYS_LBC_SDRAM_SIZE 64 /* LBC SDRAM is 64MB */ - -#define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_LBC_SDRAM_BASE -#define CONFIG_SYS_LBLAWAR2_PRELIM 0x80000019 /* 64MB */ - -/*local bus BR2, OR2 definition for SDRAM if soldered on the EPB board */ -/* - * Base Register 2 and Option Register 2 configure SDRAM. - * The SDRAM base address, CONFIG_SYS_LBC_SDRAM_BASE, is 0xf0000000. - * - * For BR2, need: - * Base address of 0xf0000000 = BR[0:16] = 1111 0000 0000 0000 0 - * port size = 32-bits = BR2[19:20] = 11 - * no parity checking = BR2[21:22] = 00 - * SDRAM for MSEL = BR2[24:26] = 011 - * Valid = BR[31] = 1 - * - * 0 4 8 12 16 20 24 28 - * 1111 0000 0000 0000 0001 1000 0110 0001 = f0001861 - * - * CONFIG_SYS_LBC_SDRAM_BASE should be masked and OR'ed into - * the top 17 bits of BR2. - */ - -#define CONFIG_SYS_BR2_PRELIM 0xf0001861 /*Port size=32bit, MSEL=SDRAM */ - -/* - * The SDRAM size in MB, CONFIG_SYS_LBC_SDRAM_SIZE, is 64. - * - * For OR2, need: - * 64MB mask for AM, OR2[0:7] = 1111 1100 - * XAM, OR2[17:18] = 11 - * 9 columns OR2[19-21] = 010 - * 13 rows OR2[23-25] = 100 - * EAD set for extra time OR[31] = 1 - * - * 0 4 8 12 16 20 24 28 - * 1111 1100 0000 0000 0110 1001 0000 0001 = fc006901 - */ - -#define CONFIG_SYS_OR2_PRELIM 0xfc006901 - -#define CONFIG_SYS_LBC_LSRT 0x32000000 /* LB sdram refresh timer, about 6us */ -#define CONFIG_SYS_LBC_MRTPR 0x20000000 /* LB refresh timer prescal, 266MHz/32 */ - -#define CONFIG_SYS_LBC_LSDMR_COMMON 0x0063b723 - -#endif - -/* - * Windows to access PIB via local bus - */ -#define CONFIG_SYS_LBLAWBAR3_PRELIM 0xf8008000 /* windows base 0xf8008000 */ -#define CONFIG_SYS_LBLAWAR3_PRELIM 0x8000000f /* windows size 64KB */ - -/* * Serial Port */ #define CONFIG_CONS_INDEX 1 diff --git a/include/configs/MPC832XEMDS.h b/include/configs/MPC832XEMDS.h index 6f892d0..785d51e 100644 --- a/include/configs/MPC832XEMDS.h +++ b/include/configs/MPC832XEMDS.h @@ -208,12 +208,22 @@ #define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */
#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE /* Window base at flash base */ -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000018 /* 32MB window size */ - -#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | /* Flash Base address */ \ - (2 << BR_PS_SHIFT) | /* 16 bit port size */ \ - BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM 0xfe006ff7 /* 16MB Flash size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_32MB) + +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE /* Flash Base address */ \ + | BR_PS_16 /* 16 bit port size */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xfe006ff7 */
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 128 /* sectors per device */ @@ -225,84 +235,65 @@ */ #define CONFIG_SYS_BCSR 0xF8000000 #define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_BCSR /* Access window base at BCSR base */ -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000E /* Access window size 32K */ - -#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR|0x00000801) /* Port size=8bit, MSEL=GPCM */ -#define CONFIG_SYS_OR1_PRELIM 0xFFFFE9f7 /* length 32K */ - -/* - * SDRAM on the Local Bus - */ -#undef CONFIG_SYS_LB_SDRAM /* The board has not SRDAM on local bus */ - -#ifdef CONFIG_SYS_LB_SDRAM -#define CONFIG_SYS_LBC_SDRAM_BASE 0xF0000000 /* SDRAM base address */ -#define CONFIG_SYS_LBC_SDRAM_SIZE 64 /* LBC SDRAM is 64MB */ - -#define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_LBC_SDRAM_BASE -#define CONFIG_SYS_LBLAWAR2_PRELIM 0x80000019 /* 64MB */ - -/*local bus BR2, OR2 definition for SDRAM if soldered on the EPB board */ -/* - * Base Register 2 and Option Register 2 configure SDRAM. - * The SDRAM base address, CONFIG_SYS_LBC_SDRAM_BASE, is 0xf0000000. - * - * For BR2, need: - * Base address of 0xf0000000 = BR[0:16] = 1111 0000 0000 0000 0 - * port size = 32-bits = BR2[19:20] = 11 - * no parity checking = BR2[21:22] = 00 - * SDRAM for MSEL = BR2[24:26] = 011 - * Valid = BR[31] = 1 - * - * 0 4 8 12 16 20 24 28 - * 1111 0000 0000 0000 0001 1000 0110 0001 = f0001861 - * - * CONFIG_SYS_LBC_SDRAM_BASE should be masked and OR'ed into - * the top 17 bits of BR2. - */ - -#define CONFIG_SYS_BR2_PRELIM 0xf0001861 /*Port size=32bit, MSEL=SDRAM */ - -/* - * The SDRAM size in MB, CONFIG_SYS_LBC_SDRAM_SIZE, is 64. - * - * For OR2, need: - * 64MB mask for AM, OR2[0:7] = 1111 1100 - * XAM, OR2[17:18] = 11 - * 9 columns OR2[19-21] = 010 - * 13 rows OR2[23-25] = 100 - * EAD set for extra time OR[31] = 1 - * - * 0 4 8 12 16 20 24 28 - * 1111 1100 0000 0000 0110 1001 0000 0001 = fc006901 - */ - -#define CONFIG_SYS_OR2_PRELIM 0xfc006901 - -#define CONFIG_SYS_LBC_LSRT 0x32000000 /* LB sdram refresh timer, about 6us */ -#define CONFIG_SYS_LBC_MRTPR 0x20000000 /* LB refresh timer prescal, 266MHz/32 */ - -#define CONFIG_SYS_LBC_LSDMR_COMMON 0x0063b723 - -#endif +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_32KB) + +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR \ + | BR_PS_8 \ + | BR_MS_GPCM \ + | BR_V) +#define CONFIG_SYS_OR1_PRELIM (OR_AM_32KB \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xFFFFE9F7 */
/* * Windows to access Platform I/O Boards (PIB) via local bus */ -#define CONFIG_SYS_LBLAWBAR3_PRELIM 0xf8008000 /* windows base 0xf8008000 */ -#define CONFIG_SYS_LBLAWAR3_PRELIM 0x8000000f /* windows size 64KB */ +#define CONFIG_SYS_PIB_BASE 0xF8008000 /* PIB window base 0xF8008000 */ +#define CONFIG_SYS_PIB_WINDOW_SIZE (32 * 1024) +#define CONFIG_SYS_LBLAWBAR3_PRELIM CONFIG_SYS_PIB_BASE +#define CONFIG_SYS_LBLAWAR3_PRELIM (LBLAWAR_EN | LBLAWAR_64KB)
/* * CS2 on Local Bus, to PIB */ -#define CONFIG_SYS_BR2_PRELIM 0xf8008801 /* CS2 base address at 0xf8008000 */ -#define CONFIG_SYS_OR2_PRELIM 0xffffe9f7 /* size 32KB, port size 8bit, GPCM */ +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_PIB_BASE \ + | BR_PS_8 \ + | BR_MS_GPCM \ + | BR_V) + /* 0xF8008801 */ +#define CONFIG_SYS_OR2_PRELIM (P2SZ_TO_AM(CONFIG_SYS_PIB_WINDOW_SIZE) \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xffffe9f7 */
/* * CS3 on Local Bus, to PIB */ -#define CONFIG_SYS_BR3_PRELIM 0xf8010801 /* CS3 base address at 0xf8010000 */ -#define CONFIG_SYS_OR3_PRELIM 0xffffe9f7 /* size 32KB, port size 8bit, GPCM */ +#define CONFIG_SYS_BR3_PRELIM ((CONFIG_SYS_PIB_BASE + CONFIG_SYS_PIB_WINDOW_SIZE) \ + | BR_PS_8 \ + | BR_MS_GPCM \ + | BR_V) + /* 0xF8010801 */ +#define CONFIG_SYS_OR3_PRELIM (P2SZ_TO_AM(CONFIG_SYS_PIB_WINDOW_SIZE) \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xffffe9f7 */
/* * Serial Port diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index 88fdb2e..7dcb55a 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -152,14 +152,21 @@ #define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */ /* #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE */
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | /* flash Base address */ \ - (2 << BR_PS_SHIFT) | /* 16 bit port size */ \ - BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) | OR_UPM_XAM | \ - OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | OR_GPCM_XACS | OR_GPCM_SCY_15 | \ - OR_GPCM_TRLX | OR_GPCM_EHTR | OR_GPCM_EAD) +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE /* flash base address */\ + | BR_PS_16 /* 16 bit port size */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ + | OR_UPM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE /* window base at flash base */ -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000018 /* 32 MB window size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_32MB)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 256 /* max sectors per device */ @@ -181,9 +188,19 @@ */ #define CONFIG_SYS_BCSR 0xE2400000 #define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_BCSR /* Access window base at BCSR base */ -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000E /* Access window size 32K */ -#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR|0x00000801) /* Port-size=8bit, MSEL=GPCM */ -#define CONFIG_SYS_OR1_PRELIM 0xFFFFE8F0 /* length 32K */ +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_32KB)/* Access window size 32K */ +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR \ + | BR_PS_8 \ + | BR_MS_GPCM \ + | BR_V) + /* 0x00000801 */ +#define CONFIG_SYS_OR1_PRELIM (OR_AM_32KB \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_CLEAR \ + | OR_GPCM_EHTR_CLEAR) + /* 0xFFFFE8F0 */
#define CONFIG_SYS_INIT_RAM_LOCK 1 #define CONFIG_SYS_INIT_RAM_ADDR 0xFD000000 /* Initial RAM address */ @@ -232,14 +249,15 @@ * * 0 4 8 12 16 20 24 28 * 1111 0000 0000 0000 0001 1000 0110 0001 = F0001861 - * - * FIXME: CONFIG_SYS_LBC_SDRAM_BASE should be masked and OR'ed into - * FIXME: the top 17 bits of BR2. */
-#define CONFIG_SYS_BR2_PRELIM 0xF0001861 /* Port-size=32bit, MSEL=SDRAM */ -#define CONFIG_SYS_LBLAWBAR2_PRELIM 0xF0000000 -#define CONFIG_SYS_LBLAWAR2_PRELIM 0x80000019 /* 64M */ +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_LBC_SDRAM_BASE \ + | BR_PS_32 /* Port-size = 32bit */ \ + | BR_MS_SDRAM /* MSEL = SDRAM */ \ + | BR_V) /* Valid */ + /* 0xF0001861 */ +#define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_LBC_SDRAM_BASE +#define CONFIG_SYS_LBLAWAR2_PRELIM (LBLAWAR_EN | LBLAWAR_64MB)
/* * The SDRAM size in MB, CONFIG_SYS_LBC_SDRAM_SIZE, is 64. @@ -255,7 +273,12 @@ * 1111 1100 0000 0000 0110 1001 0000 0001 = FC006901 */
-#define CONFIG_SYS_OR2_PRELIM 0xFC006901 +#define CONFIG_SYS_OR2_PRELIM (OR_AM_64MB \ + | OR_SDRAM_XAM \ + | ((9 - OR_SDRAM_MIN_COLS) << OR_SDRAM_COLS_SHIFT) \ + | ((13 - OR_SDRAM_MIN_ROWS) << OR_SDRAM_ROWS_SHIFT) \ + | OR_SDRAM_EAD) + /* 0xFC006901 */
#define CONFIG_SYS_LBC_LSRT 0x32000000 /* LB sdram refresh timer, about 6us */ #define CONFIG_SYS_LBC_MRTPR 0x20000000 /* LB refresh timer prescal, 266MHz/32 */ diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index e671a64..e32ab1c 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -227,7 +227,6 @@ boards, we say we have two, but don't display a message if we find only one. */ #define CONFIG_SYS_MAX_FLASH_BANKS 2 /* number of banks */ #define CONFIG_SYS_FLASH_BANKS_LIST {CONFIG_SYS_FLASH_BASE, CONFIG_SYS_FLASH_BASE + 0x800000} #define CONFIG_SYS_FLASH_SIZE 16 /* FLASH size in MB */ -#define CONFIG_SYS_FLASH_SIZE_SHIFT 4 /* log2 of the above value */ #define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */
/* Vitesse 7385 */ @@ -248,12 +247,12 @@ boards, we say we have two, but don't display a message if we find only one. */
/* Flash */
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | BR_PS_16 | BR_V) -#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) | OR_UPM_XAM | \ +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | BR_PS_16 | BR_MS_GPCM | BR_V) +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) | OR_UPM_XAM | \ OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | OR_GPCM_XACS | OR_GPCM_SCY_15 | \ - OR_GPCM_TRLX | OR_GPCM_EHTR | OR_GPCM_EAD) + OR_GPCM_TRLX_SET | OR_GPCM_EHTR_SET | OR_GPCM_EAD) #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | (0x13 + CONFIG_SYS_FLASH_SIZE_SHIFT)) +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_16MB)
/* Vitesse 7385 */
@@ -261,10 +260,10 @@ boards, we say we have two, but don't display a message if we find only one. */
-#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_VSC7385_BASE | BR_PS_8 | BR_V) +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_VSC7385_BASE | BR_PS_8 | BR_MS_GPCM | BR_V) #define CONFIG_SYS_OR1_PRELIM (OR_AM_128KB | OR_GPCM_CSNT | OR_GPCM_XACS | \ - OR_GPCM_SCY_15 | OR_GPCM_SETA | OR_GPCM_TRLX | \ - OR_GPCM_EHTR | OR_GPCM_EAD) + OR_GPCM_SCY_15 | OR_GPCM_SETA | OR_GPCM_TRLX_SET | \ + OR_GPCM_EHTR_SET | OR_GPCM_EAD)
#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_VSC7385_BASE #define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_128KB) @@ -274,10 +273,10 @@ boards, we say we have two, but don't display a message if we find only one. */ /* LED */
#define CONFIG_SYS_LED_BASE 0xF9000000 -#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_LED_BASE | BR_PS_8 | BR_V) +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_LED_BASE | BR_PS_8 | BR_MS_GPCM | BR_V) #define CONFIG_SYS_OR2_PRELIM (OR_AM_2MB | OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | \ - OR_GPCM_XACS | OR_GPCM_SCY_9 | OR_GPCM_TRLX | \ - OR_GPCM_EHTR | OR_GPCM_EAD) + OR_GPCM_XACS | OR_GPCM_SCY_9 | OR_GPCM_TRLX_SET | \ + OR_GPCM_EHTR_SET | OR_GPCM_EAD)
/* Compact Flash */
diff --git a/include/configs/MPC8360EMDS.h b/include/configs/MPC8360EMDS.h index c054e34..b275486 100644 --- a/include/configs/MPC8360EMDS.h +++ b/include/configs/MPC8360EMDS.h @@ -202,14 +202,15 @@ #define CONFIG_FLASH_SHOW_PROGRESS 45 /* count down from 45/5: 9..1 */
#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE /* Window base at flash base */ -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000018 /* 32MB window size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_32MB)
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | /* Flash Base address */ \ - (2 << BR_PS_SHIFT) | /* 16 bit port size */ \ - BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) | OR_UPM_XAM | \ +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE /* Flash Base address */ \ + | BR_PS_16 /* 16 bit port size */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) | OR_GPCM_XAM | \ OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | OR_GPCM_XACS | OR_GPCM_SCY_15 | \ - OR_GPCM_TRLX | OR_GPCM_EHTR | OR_GPCM_EAD) + OR_GPCM_TRLX_SET | OR_GPCM_EHTR_SET | OR_GPCM_EAD)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 256 /* max sectors per device */ @@ -221,22 +222,36 @@ */ #define CONFIG_SYS_BCSR 0xF8000000 #define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_BCSR /* Access window base at BCSR base */ -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000F /* Access window size 64K */ - -#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR|0x00000801) /* Port size=8bit, MSEL=GPCM */ -#define CONFIG_SYS_OR1_PRELIM 0xFFFFE9f7 /* length 32K */ +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_64KB) + +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR \ + | BR_PS_8 \ + | BR_MS_GPCM \ + | BR_V) +#define CONFIG_SYS_OR1_PRELIM (OR_AM_32KB \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xFFFFE9F7 */
/* * SDRAM on the Local Bus */ +/* [RFC]Given this base address, there is no BAT covering LBC_SDRAM */ #define CONFIG_SYS_LBC_SDRAM_BASE 0xF0000000 /* SDRAM base address */ #define CONFIG_SYS_LBC_SDRAM_SIZE 64 /* LBC SDRAM is 64MB */
#define CONFIG_SYS_LB_SDRAM /* if board has SRDAM on local bus */
#ifdef CONFIG_SYS_LB_SDRAM -#define CONFIG_SYS_LBLAWBAR2 0 -#define CONFIG_SYS_LBLAWAR2 0x80000019 /* 64MB */ +/* [RFC]This used to be CONFIG_SYS_LBLAWBAR2 */ +#define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_LBC_SDRAM_BASE /* [RFC]This was 0 before, overlapping DDR */ +/* [RFC]This used to be CONFIG_SYS_LBLAWAR2 */ +#define CONFIG_SYS_LBLAWAR2_PRELIM (LBLAWAR_EN | LBLAWAR_64MB)
/*local bus BR2, OR2 definition for SDRAM if soldered on the EPB board */ /* @@ -253,7 +268,12 @@ * xxxx xxxx xxxx xxxx x001 1000 0110 0001 = 00001861 */
-#define CONFIG_SYS_BR2 0x00001861 /*Port size=32bit, MSEL=SDRAM */ +/* [RFC]This used to be CONFIG_SYS_BR2 */ +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_LBC_SDRAM_BASE /* [RFC]This was 0 before, overlapping DDR */ \ + | BR_PS_32 \ + | BR_MS_SDRAM \ + | BR_V) + /* 0xF0001861 */
/* * The SDRAM size in MB, CONFIG_SYS_LBC_SDRAM_SIZE, is 64. @@ -269,7 +289,13 @@ * 1111 1100 0000 0000 0110 1001 0000 0001 = fc006901 */
-#define CONFIG_SYS_OR2 0xfc006901 +/* [RFC]This used to be CONFIG_SYS_OR2 */ +#define CONFIG_SYS_OR2_PRELIM (MEG_TO_AM(CONFIG_SYS_LBC_SDRAM_SIZE) \ + | OR_SDRAM_XAM \ + | ((9 - OR_SDRAM_MIN_COLS) << OR_SDRAM_COLS_SHIFT) \ + | ((13 - OR_SDRAM_MIN_ROWS) << OR_SDRAM_ROWS_SHIFT) \ + | OR_SDRAM_EAD) + /* 0xFC006901 */
#define CONFIG_SYS_LBC_LSRT 0x32000000 /* LB sdram refresh timer, about 6us */ #define CONFIG_SYS_LBC_MRTPR 0x20000000 /* LB refresh timer prescal, 266MHz/32 */ @@ -288,22 +314,50 @@ #endif
/* - * Windows to access PIB via local bus + * Windows to access Platform I/O Boards (PIB) via local bus */ -#define CONFIG_SYS_LBLAWBAR3_PRELIM 0xf8010000 /* windows base 0xf8010000 */ -#define CONFIG_SYS_LBLAWAR3_PRELIM 0x8000000e /* windows size 32KB */ +#define CONFIG_SYS_PIB_BASE 0xF8008000 +#define CONFIG_SYS_PIB_WINDOW_SIZE (32 * 1024) + +/* [RFC]Previously, this LBLAW only covered the 2nd window (CS5) */ +#define CONFIG_SYS_LBLAWBAR3_PRELIM CONFIG_SYS_PIB_BASE /* windows base */ +#define CONFIG_SYS_LBLAWAR3_PRELIM (LBLAWAR_EN | LBLAWAR_64KB)
/* * CS4 on Local Bus, to PIB */ -#define CONFIG_SYS_BR4_PRELIM 0xf8008801 /* CS4 base address at 0xf8008000 */ -#define CONFIG_SYS_OR4_PRELIM 0xffffe9f7 /* size 32KB, port size 8bit, GPCM */ +#define CONFIG_SYS_BR4_PRELIM (CONFIG_SYS_PIB_BASE \ + | BR_PS_8 \ + | BR_MS_GPCM \ + | BR_V) + /* 0xF8008801 */ /* CS4 base address at 0xf8008000 */ +#define CONFIG_SYS_OR4_PRELIM (OR_AM_32KB \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xffffe9f7 */
/* * CS5 on Local Bus, to PIB */ -#define CONFIG_SYS_BR5_PRELIM 0xf8010801 /* CS5 base address at 0xf8010000 */ -#define CONFIG_SYS_OR5_PRELIM 0xffffe9f7 /* size 32KB, port size 8bit, GPCM */ +#define CONFIG_SYS_BR5_PRELIM ((CONFIG_SYS_PIB_BASE + CONFIG_SYS_PIB_WINDOW_SIZE) \ + | BR_PS_8 \ + | BR_MS_GPCM \ + | BR_V) + /* 0xF8010801 */ /* CS5 base address at 0xf8010000 */ +#define CONFIG_SYS_OR5_PRELIM (CONFIG_SYS_PIB_BASE \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xffffe9f7 */
/* * Serial Port diff --git a/include/configs/MPC8360ERDK.h b/include/configs/MPC8360ERDK.h index 672eeba..9eea9c0 100644 --- a/include/configs/MPC8360ERDK.h +++ b/include/configs/MPC8360ERDK.h @@ -194,15 +194,16 @@ #define CONFIG_SYS_FLASH_PROTECTION 1 /* Use intel Flash protection. */
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | /* Flash Base address */ \ - (2 << BR_PS_SHIFT) | /* 16 bit port size */ \ - BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) | OR_UPM_XAM | \ - OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | \ - OR_GPCM_XACS | OR_GPCM_SCY_15 | \ - OR_GPCM_TRLX | OR_GPCM_EHTR | OR_GPCM_EAD) +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE /* Flash Base address */ \ + | BR_PS_16 /* 16 bit port size */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) | OR_UPM_XAM | \ + OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | \ + OR_GPCM_XACS | OR_GPCM_SCY_15 | \ + OR_GPCM_TRLX_SET | OR_GPCM_EHTR_SET | OR_GPCM_EAD)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 256 /* max sectors per device */ @@ -219,11 +220,17 @@ #define CONFIG_MTD_NAND_VERIFY_WRITE
#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_NAND_BASE -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000001b /* Access window size 4K */ +/* [RFC]Comment said 4KB window; code said 256MB window; OR1 says 64MB... what's correct? */ +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_256MB)
/* Port size 8 bit, UPMA */ -#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_NAND_BASE | 0x00000881) -#define CONFIG_SYS_OR1_PRELIM 0xfc000001 +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_NAND_BASE \ + | BR_PS_8 \ + | BR_MS_UPMA \ + | BR_V) + /* 0x60000881 */ +#define CONFIG_SYS_OR1_PRELIM (OR_AM_64MB | OR_UPM_EAD) + /* 0xFC000001 */
/* * Fujitsu MB86277 (MINT) graphics controller @@ -231,11 +238,16 @@ #define CONFIG_SYS_VIDEO_BASE 0x70000000
#define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_VIDEO_BASE -#define CONFIG_SYS_LBLAWAR2_PRELIM 0x80000019 /* Access window size 64MB */ +#define CONFIG_SYS_LBLAWAR2_PRELIM (LBLAWAR_EN | LBLAWAR_64MB)
/* Port size 32 bit, UPMB */ -#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_VIDEO_BASE | 0x000018a1) /* PS=11, UPMB */ -#define CONFIG_SYS_OR2_PRELIM 0xfc000001 /* (64MB, EAD=1) */ +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_VIDEO_BASE \ + | BR_PS_32 \ + | BR_MS_UPMB \ + | BR_V) + /* 0x000018a1 */ +#define CONFIG_SYS_OR2_PRELIM (OR_AM_64MB | OR_UPM_EAD) + /* 0xFC000001 */
/* * Serial Port diff --git a/include/configs/MPC837XEMDS.h b/include/configs/MPC837XEMDS.h index eaca6cb..9529ccd 100644 --- a/include/configs/MPC837XEMDS.h +++ b/include/configs/MPC837XEMDS.h @@ -238,21 +238,22 @@ #define CONFIG_SYS_FLASH_PROTECTION 1 /* Use h/w Flash protection. */
#define CONFIG_SYS_BR0_PRELIM ( CONFIG_SYS_FLASH_BASE /* Flash Base address */ \ - | (2 << BR_PS_SHIFT) /* 16 bit port size */ \ - | BR_V ) /* valid */ -#define CONFIG_SYS_OR0_PRELIM ( (~(CONFIG_SYS_FLASH_SIZE - 1) << 20) \ - | OR_UPM_XAM \ - | OR_GPCM_CSNT \ - | OR_GPCM_ACS_DIV2 \ - | OR_GPCM_XACS \ - | OR_GPCM_SCY_15 \ - | OR_GPCM_TRLX \ - | OR_GPCM_EHTR \ - | OR_GPCM_EAD ) - /* 0xFE000FF7 */ + | BR_PS_16 /* 16 bit port size */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V ) /* valid */ +#define CONFIG_SYS_OR0_PRELIM ( MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ + | OR_UPM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD ) + /* 0xFE000FF7 */
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 256 /* max sectors per device */ @@ -266,10 +267,22 @@ */ #define CONFIG_SYS_BCSR 0xF8000000 #define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_BCSR /* Access window base at BCSR base */ -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000E /* Access window size 32K */ - -#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_BCSR | 0x00000801) /* Port size=8bit, MSEL=GPCM */ -#define CONFIG_SYS_OR1_PRELIM 0xFFFFE9f7 /* length 32K */ +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_32KB) + +#define CONFIG_SYS_BR1_PRELIM ( CONFIG_SYS_BCSR \ + | BR_PS_8 \ + | BR_MS_GPCM \ + | BR_V ) + /* 0xF8000801 */ +#define CONFIG_SYS_OR1_PRELIM ( OR_AM_32KB \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD ) + /* 0xFFFFE9F7 */
/* * NAND Flash on the Local Bus @@ -281,22 +294,22 @@
#define CONFIG_SYS_NAND_BASE 0xE0600000 /* 0xE0600000 */ #define CONFIG_SYS_BR3_PRELIM ( CONFIG_SYS_NAND_BASE \ - | (2<<BR_DECC_SHIFT) /* Use HW ECC */ \ - | BR_PS_8 /* Port Size = 8 bit */ \ - | BR_MS_FCM /* MSEL = FCM */ \ - | BR_V ) /* valid */ -#define CONFIG_SYS_OR3_PRELIM ( 0xFFFF8000 /* length 32K */ \ - | OR_FCM_BCTLD \ - | OR_FCM_CST \ - | OR_FCM_CHT \ - | OR_FCM_SCY_1 \ - | OR_FCM_RST \ - | OR_FCM_TRLX \ - | OR_FCM_EHTR ) - /* 0xFFFF919E */ + | BR_DECC_CHK_GEN /* Use HW ECC */ \ + | BR_PS_8 /* Port Size = 8 bit */ \ + | BR_MS_FCM /* MSEL = FCM */ \ + | BR_V ) /* valid */ +#define CONFIG_SYS_OR3_PRELIM ( OR_AM_32KB \ + | OR_FCM_BCTLD \ + | OR_FCM_CST \ + | OR_FCM_CHT \ + | OR_FCM_SCY_1 \ + | OR_FCM_RST \ + | OR_FCM_TRLX \ + | OR_FCM_EHTR ) + /* 0xFFFF919E */
#define CONFIG_SYS_LBLAWBAR3_PRELIM CONFIG_SYS_NAND_BASE -#define CONFIG_SYS_LBLAWAR3_PRELIM 0x8000000E /* 32KB */ +#define CONFIG_SYS_LBLAWAR3_PRELIM (LBLAWAR_EN | LBLAWAR_32KB)
/* * Serial Port diff --git a/include/configs/MPC837XERDB.h b/include/configs/MPC837XERDB.h index 6b9096d..3da60e7 100644 --- a/include/configs/MPC837XERDB.h +++ b/include/configs/MPC837XERDB.h @@ -270,15 +270,17 @@ #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE /* Window base at flash base */ #define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000016 /* 8 MB window size */
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | /* Flash Base address */ \ - (2 << BR_PS_SHIFT) | /* 16 bit port size */ \ - BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM (0xFF800000 /* 8 MByte */ \ - | OR_GPCM_XACS \ - | OR_GPCM_SCY_9 \ - | OR_GPCM_EHTR \ - | OR_GPCM_EAD) - /* 0xFF806FF7 TODO SLOW 8 MB flash size */ +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE /* Flash Base address */ \ + | BR_PS_16 /* 16 bit port size */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_9 \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xFF800191 */ +/* [RFC]Old comment: 0xFF806FF7 TODO SLOW 8 MB flash size */
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 256 /* max sectors per device */ @@ -291,20 +293,20 @@ * NAND Flash on the Local Bus */ #define CONFIG_SYS_NAND_BASE 0xE0600000 /* 0xE0600000 */ -#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_NAND_BASE | \ - (2 << BR_DECC_SHIFT) | /* Use HW ECC */ \ - BR_PS_8 | /* Port Size = 8 bit */ \ - BR_MS_FCM | /* MSEL = FCM */ \ - BR_V) /* valid */ -#define CONFIG_SYS_OR1_PRELIM (0xFFFF8000 | /* length 32K */ \ - OR_FCM_CSCT | \ - OR_FCM_CST | \ - OR_FCM_CHT | \ - OR_FCM_SCY_1 | \ - OR_FCM_TRLX | \ - OR_FCM_EHTR) +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_NAND_BASE \ + | BR_DECC_CHK_GEN /* Use HW ECC */ \ + | BR_PS_8 /* Port Size = 8 bit */ \ + | BR_MS_FCM /* MSEL = FCM */ \ + | BR_V) /* valid */ +#define CONFIG_SYS_OR1_PRELIM (OR_AM_32KB \ + | OR_FCM_CSCT \ + | OR_FCM_CST \ + | OR_FCM_CHT \ + | OR_FCM_SCY_1 \ + | OR_FCM_TRLX \ + | OR_FCM_EHTR) #define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_NAND_BASE -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000000E /* 32KB */ +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_32KB)
/* Vitesse 7385 */
@@ -312,10 +314,22 @@
-#define CONFIG_SYS_BR2_PRELIM 0xf0000801 /* Base address */ -#define CONFIG_SYS_OR2_PRELIM 0xfffe09ff /* 128K bytes*/ +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_VSC7385_BASE \ + | BR_PS_8 \ + | BR_MS_GPCM \ + | BR_V) + /* 0xF0000801 */ +#define CONFIG_SYS_OR2_PRELIM (OR_AM_128KB \ + | OR_GPCM_CSNT \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_SETA \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xfffe09ff */ /* 128K bytes*/ #define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_VSC7385_BASE /* Access Base */ -#define CONFIG_SYS_LBLAWAR2_PRELIM 0x80000010 /* Access Size 128K */ +#define CONFIG_SYS_LBLAWAR2_PRELIM (LBLAWAR_EN | LBLAWAR_128KB)
#endif
diff --git a/include/configs/MVBLM7.h b/include/configs/MVBLM7.h index f295871..6c1d6e3 100644 --- a/include/configs/MVBLM7.h +++ b/include/configs/MVBLM7.h @@ -103,20 +103,19 @@
#define CONFIG_SYS_FLASH_BASE 0xFF800000 #define CONFIG_SYS_FLASH_SIZE 8 -#define CONFIG_SYS_FLASH_SIZE_SHIFT 3 #define CONFIG_SYS_FLASH_EMPTY_INFO #define CONFIG_SYS_FLASH_ERASE_TOUT 60000 #define CONFIG_SYS_FLASH_WRITE_TOUT 500 #define CONFIG_SYS_MAX_FLASH_BANKS 1 #define CONFIG_SYS_MAX_FLASH_SECT 256
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | BR_PS_16 | BR_V) -#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) | OR_UPM_XAM | \ - OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | OR_GPCM_XACS|\ - OR_GPCM_SCY_15 | OR_GPCM_TRLX | OR_GPCM_EHTR | \ - OR_GPCM_EAD) +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | BR_PS_16 | BR_MS_GPCM | BR_V) +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) | OR_UPM_XAM | \ + OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | OR_GPCM_XACS | \ + OR_GPCM_SCY_15 | OR_GPCM_TRLX_SET | OR_GPCM_EHTR_SET | \ + OR_GPCM_EAD) #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | (0x13 + CONFIG_SYS_FLASH_SIZE_SHIFT)) +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_8MB)
/* * U-Boot memory configuration diff --git a/include/configs/SIMPC8313.h b/include/configs/SIMPC8313.h index 2ec2637..e731574 100644 --- a/include/configs/SIMPC8313.h +++ b/include/configs/SIMPC8313.h @@ -148,25 +148,25 @@ #define CONFIG_NAND_FSL_ELBC 1
#ifdef CONFIG_NAND_SP -#define CONFIG_SYS_NAND_OR_PRELIM ( 0xFFFF8000 /* length 32K */ \ +#define CONFIG_SYS_NAND_OR_PRELIM ( OR_AM_32KB \ | OR_FCM_CSCT \ | OR_FCM_CST \ | OR_FCM_CHT \ | OR_FCM_SCY_1 \ | OR_FCM_TRLX \ | OR_FCM_EHTR ) -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x8000000E /* 32KB */ -#define CONFIG_SYS_NAND_PAGE_SIZE (512) /* NAND chip page size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_32KB) +#define CONFIG_SYS_NAND_PAGE_SIZE 512 /* NAND chip page size */ #define CONFIG_SYS_NAND_BLOCK_SIZE (16 << 10) /* NAND chip block size */ #define NAND_CACHE_PAGES 32 #elif defined(CONFIG_NAND_LP) -#define CONFIG_SYS_NAND_OR_PRELIM ( 0xFFFC0000 /* length 256K */ \ +#define CONFIG_SYS_NAND_OR_PRELIM ( OR_AM_256KB \ | OR_FCM_PGS \ | OR_FCM_CSCT \ | OR_FCM_CST \ @@ -174,8 +174,8 @@ | OR_FCM_SCY_1 \ | OR_FCM_TRLX \ | OR_FCM_EHTR ) -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000011 /* 256KB */ -#define CONFIG_SYS_NAND_PAGE_SIZE (2048) /* NAND chip page size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_256KB) +#define CONFIG_SYS_NAND_PAGE_SIZE 2048 /* NAND chip page size */ #define CONFIG_SYS_NAND_BLOCK_SIZE (128 << 10) /* NAND chip block size */ #define NAND_CACHE_PAGES 64 #else diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index e0bba46..dd2b50e 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -114,11 +114,11 @@ #define CONFIG_SYS_OR_TIMING_FLASH (OR_GPCM_CSNT | OR_GPCM_ACS_DIV4 | \ OR_GPCM_SCY_5 | OR_GPCM_TRLX)
-#define CONFIG_SYS_PRELIM_OR_AM 0xc0000000 /* OR addr mask: 1 GiB */ +#define CONFIG_SYS_PRELIM_OR_AM OR_AM_1GB /* OR addr mask: 1 GiB */
#define CONFIG_SYS_OR0_PRELIM (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_FLASH)
-#define CONFIG_SYS_LBLAWAR0_PRELIM 0x8000001D /* 1 GiB window size (2^(size + 1)) */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_1GB )
diff --git a/include/configs/km/km83xx-common.h b/include/configs/km/km83xx-common.h index 9d28d8e..0a4e4a4 100644 --- a/include/configs/km/km83xx-common.h +++ b/include/configs/km/km83xx-common.h @@ -103,16 +103,17 @@ #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE
#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x8000001b /* 256MB window size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_256MB)
#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | \ - (2 << BR_PS_SHIFT) | /* 16 bit port size */ \ + BR_PS_16 | /* 16 bit port size */ \ + BR_MS_GPCM | /* MSEL = GPCM */ \ BR_V)
#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) | \ OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | \ OR_GPCM_SCY_5 | \ - OR_GPCM_TRLX | OR_GPCM_EAD) + OR_GPCM_TRLX_SET | OR_GPCM_EAD)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max num of flash banks */ #define CONFIG_SYS_MAX_FLASH_SECT 512 /* max num of sects on one chip */ @@ -123,15 +124,16 @@ */ /* Window base at flash base */ #define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_KMBEC_FPGA_BASE -#define CONFIG_SYS_LBLAWAR1_PRELIM 0x8000001A /* 128MB window size */ +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_128MB)
#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_KMBEC_FPGA_BASE | \ - (1 << BR_PS_SHIFT) | /* 8 bit port size */ \ + BR_PS_8 | /* 8 bit port size */ \ + BR_MS_GPCM | /* MSEL = GPCM */ \ BR_V) #define CONFIG_SYS_OR1_PRELIM (MEG_TO_AM(CONFIG_SYS_KMBEC_FPGA_SIZE) | \ OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | \ OR_GPCM_SCY_2 | \ - OR_GPCM_TRLX | OR_GPCM_EAD) + OR_GPCM_TRLX_SET | OR_GPCM_EAD)
/* * Serial Port diff --git a/include/configs/kmeter1.h b/include/configs/kmeter1.h index 37175d6..c44258e 100644 --- a/include/configs/kmeter1.h +++ b/include/configs/kmeter1.h @@ -137,15 +137,16 @@ * PAXE on the local bus CS3 */ #define CONFIG_SYS_LBLAWBAR3_PRELIM CONFIG_SYS_PAXE_BASE -#define CONFIG_SYS_LBLAWAR3_PRELIM 0x8000001C /* 512MB window size */ +#define CONFIG_SYS_LBLAWAR3_PRELIM (LBLAWAR_EN | LBLAWAR_512MB)
#define CONFIG_SYS_BR3_PRELIM (CONFIG_SYS_PAXE_BASE | \ - (1 << BR_PS_SHIFT) | /* 8 bit port size */ \ + BR_PS_8 | /* 8 bit port size */ \ + BR_MS_GPCM | /* MSEL = GPCM */ \ BR_V) #define CONFIG_SYS_OR3_PRELIM (MEG_TO_AM(CONFIG_SYS_PAXE_SIZE) | \ OR_GPCM_CSNT | OR_GPCM_ACS_DIV2 | \ OR_GPCM_SCY_2 | \ - OR_GPCM_TRLX | OR_GPCM_EAD) + OR_GPCM_TRLX_SET | OR_GPCM_EAD)
/* * MMU Setup diff --git a/include/configs/kmsupx5.h b/include/configs/kmsupx5.h index ccc1561..b0dd88c 100644 --- a/include/configs/kmsupx5.h +++ b/include/configs/kmsupx5.h @@ -69,8 +69,8 @@ OR_GPCM_CSNT | \ OR_GPCM_ACS_DIV4 | \ OR_GPCM_SCY_2 | \ - (OR_GPCM_TRLX & \ - (~OR_GPCM_EHTR)) | /* EHTR = 0 */ \ + OR_GPCM_TRLX_SET | \ + OR_GPCM_EHTR_CLEAR | \ OR_GPCM_EAD)
/* LPXF: icache cacheable, but dcache-inhibit and guarded */ diff --git a/include/configs/mpc8308_p1m.h b/include/configs/mpc8308_p1m.h index a633dca..c3d49fa 100644 --- a/include/configs/mpc8308_p1m.h +++ b/include/configs/mpc8308_p1m.h @@ -250,17 +250,18 @@
#define CONFIG_SYS_BR0_PRELIM (\ CONFIG_SYS_FLASH_BASE /* Flash Base address */ |\ - (2 << BR_PS_SHIFT) /* 16 bit port size */ |\ + BR_PS_16 /* 16 bit port size */ |\ + BR_MS_GPCM /* MSEL = GPCM */ |\ BR_V) /* valid */ -#define CONFIG_SYS_OR0_PRELIM ((~(CONFIG_SYS_FLASH_SIZE - 1) << 20) \ +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ | OR_UPM_XAM \ | OR_GPCM_CSNT \ | OR_GPCM_ACS_DIV2 \ | OR_GPCM_XACS \ | OR_GPCM_SCY_4 \ - | OR_GPCM_TRLX \ - | OR_GPCM_EHTR \ - | OR_GPCM_EAD) + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + /* [RFC]Reserved on mpc8308: | OR_GPCM_EAD */)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 512 @@ -275,11 +276,12 @@ */ #define CONFIG_SYS_SJA1000_BASE 0xFBFF0000 #define CONFIG_SYS_BR1_PRELIM ( CONFIG_SYS_SJA1000_BASE \ - | (1 << BR_PS_SHIFT) /* 8 bit port size */ \ + | BR_PS_8 /* 8 bit port size */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ | BR_V ) /* valid */ -#define CONFIG_SYS_OR1_PRELIM ( 0xFFFF8000 /* length 32K */ \ +#define CONFIG_SYS_OR1_PRELIM ( OR_AM_32KB \ | OR_GPCM_SCY_5 \ - | OR_GPCM_EHTR) + | OR_GPCM_EHTR_SET) /* 0xFFFF8052 */
#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_SJA1000_BASE @@ -290,11 +292,12 @@ */ #define CONFIG_SYS_CPLD_BASE 0xFBFF8000 #define CONFIG_SYS_BR2_PRELIM ( CONFIG_SYS_CPLD_BASE \ - | (1 << BR_PS_SHIFT) /* 8 bit port size */ \ + | BR_PS_8 /* 8 bit port size */ \ + | BR_MS_GPCM /* MSEL = GPCM */ \ | BR_V ) /* valid */ -#define CONFIG_SYS_OR2_PRELIM ( 0xFFFF8000 /* length 32K */ \ +#define CONFIG_SYS_OR2_PRELIM ( OR_AM_32KB \ | OR_GPCM_SCY_4 \ - | OR_GPCM_EHTR) + | OR_GPCM_EHTR_SET) /* 0xFFFF8042 */
#define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_CPLD_BASE diff --git a/include/configs/sbc8349.h b/include/configs/sbc8349.h index 06ca500..db9340f 100644 --- a/include/configs/sbc8349.h +++ b/include/configs/sbc8349.h @@ -132,8 +132,9 @@ /* * SDRAM on the Local Bus */ -#define CONFIG_SYS_LBC_SDRAM_BASE 0x10000000 /* Localbus SDRAM */ -#define CONFIG_SYS_LBC_SDRAM_SIZE 128 /* LBC SDRAM is 128MB */ +/* [RFC]Changed to match code */ +#define CONFIG_SYS_LBC_SDRAM_BASE 0xF0000000 /* Localbus SDRAM */ +#define CONFIG_SYS_LBC_SDRAM_SIZE 64 /* LBC SDRAM is 64MB */
/* * FLASH on the Local Bus @@ -144,13 +145,23 @@ #define CONFIG_SYS_FLASH_SIZE 8 /* flash size in MB */ /* #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE */
-#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | /* flash Base address */ \ - (2 << BR_PS_SHIFT) | /* 16 bit port size */ \ - BR_V) /* valid */ - -#define CONFIG_SYS_OR0_PRELIM 0xFF806FF7 /* 8 MB flash size */ +#define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | \ + BR_PS_16 | /* 16 bit port size */ \ + BR_MS_GPCM | /* MSEL = GPCM */ \ + BR_V) /* valid */ + +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xFF806FF7 */ #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE /* window base at flash base */ -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000016 /* 8 MB window size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_8MB)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 64 /* sectors per device */ @@ -204,14 +215,15 @@ * * 0 4 8 12 16 20 24 28 * 1111 0000 0000 0000 0001 1000 0110 0001 = F0001861 - * - * FIXME: CONFIG_SYS_LBC_SDRAM_BASE should be masked and OR'ed into - * FIXME: the top 17 bits of BR2. */
-#define CONFIG_SYS_BR2_PRELIM 0xF0001861 /* Port-size=32bit, MSEL=SDRAM */ -#define CONFIG_SYS_LBLAWBAR2_PRELIM 0xF0000000 -#define CONFIG_SYS_LBLAWAR2_PRELIM 0x80000019 /* 64M */ +#define CONFIG_SYS_BR2_PRELIM (CONFIG_SYS_LBC_SDRAM_BASE \ + | BR_PS_32 \ + | BR_MS_SDRAM \ + | BR_V) + /* 0xF0001861 */ +#define CONFIG_SYS_LBLAWBAR2_PRELIM CONFIG_SYS_LBC_SDRAM_BASE +#define CONFIG_SYS_LBLAWAR2_PRELIM (LBLAWAR_EN | LBLAWAR_64MB)
/* * The SDRAM size in MB, CONFIG_SYS_LBC_SDRAM_SIZE, is 64. @@ -227,7 +239,12 @@ * 1111 1100 0000 0000 0110 1001 0000 0001 = FC006901 */
-#define CONFIG_SYS_OR2_PRELIM 0xFC006901 +#define CONFIG_SYS_OR2_PRELIM (MEG_TO_AM(CONFIG_SYS_LBC_SDRAM_SIZE) \ + | OR_SDRAM_XAM \ + | ((9 - OR_SDRAM_MIN_COLS) << OR_SDRAM_COLS_SHIFT) \ + | ((13 - OR_SDRAM_MIN_ROWS) << OR_SDRAM_ROWS_SHIFT) \ + | OR_SDRAM_EAD) + /* 0xFC006901 */
#define CONFIG_SYS_LBC_LSRT 0x32000000 /* LB sdram refresh timer, about 6us */ #define CONFIG_SYS_LBC_MRTPR 0x20000000 /* LB refresh timer prescal, 266MHz/32 */ @@ -573,10 +590,10 @@ #define CONFIG_SYS_IBAT5L (CONFIG_SYS_IMMR | BATL_PP_RW | BATL_CACHEINHIBIT | BATL_GUARDEDSTORAGE) #define CONFIG_SYS_IBAT5U (CONFIG_SYS_IMMR | BATU_BL_256M | BATU_VS | BATU_VP)
-/* SDRAM @ 0xF0000000, stack in DCACHE 0xFDF00000 & FLASH @ 0xFE000000 */ -#define CONFIG_SYS_IBAT6L (0xF0000000 | BATL_PP_RW | BATL_MEMCOHERENCE | \ +/* LBC SDRAM @ 0xF0000000, stack in DCACHE 0xFDF00000 & FLASH @ 0xFE000000 */ +#define CONFIG_SYS_IBAT6L (CONFIG_SYS_LBC_SDRAM_BASE | BATL_PP_RW | BATL_MEMCOHERENCE | \ BATL_GUARDEDSTORAGE) -#define CONFIG_SYS_IBAT6U (0xF0000000 | BATU_BL_256M | BATU_VS | BATU_VP) +#define CONFIG_SYS_IBAT6U (CONFIG_SYS_LBC_SDRAM_BASE | BATU_BL_256M | BATU_VS | BATU_VP)
#define CONFIG_SYS_IBAT7L (0) #define CONFIG_SYS_IBAT7U (0) diff --git a/include/configs/suvd3.h b/include/configs/suvd3.h index 5f2e1e3..ae19701 100644 --- a/include/configs/suvd3.h +++ b/include/configs/suvd3.h @@ -70,7 +70,7 @@ OR_GPCM_CSNT | \ OR_GPCM_ACS_DIV4 | \ OR_GPCM_SCY_3 | \ - OR_GPCM_TRLX) + OR_GPCM_TRLX_SET)
#define CONFIG_SYS_MAMR (MxMR_GPL_x4DIS | \ 0x0000c000 | \ diff --git a/include/configs/tuda1.h b/include/configs/tuda1.h index 7ae7d58..577bbd0 100644 --- a/include/configs/tuda1.h +++ b/include/configs/tuda1.h @@ -73,8 +73,8 @@ OR_GPCM_CSNT | \ OR_GPCM_ACS_DIV4 | \ OR_GPCM_SCY_2 | \ - (OR_GPCM_TRLX & \ - (~OR_GPCM_EHTR)) | /* EHTR = 0 */ \ + OR_GPCM_TRLX_SET | \ + OR_GPCM_EHTR_CLEAR | \ OR_GPCM_EAD) /* * PINC3 on the local bus CS3 @@ -91,11 +91,10 @@
#define CONFIG_SYS_OR3_PRELIM (MEG_TO_AM(CONFIG_SYS_APP2_SIZE) | \ OR_GPCM_CSNT | \ - (OR_GPCM_ACS_DIV2 & /* ACS = 11 */\ - (~OR_GPCM_XACS)) | /* XACS = 0 */\ - (OR_GPCM_SCY_2 & \ - (~OR_GPCM_EHTR)) | /* EHTR = 0 */ \ - OR_GPCM_TRLX) + OR_GPCM_ACS_DIV2 | \ + OR_GPCM_SCY_2 | \ + OR_GPCM_TRLX_SET | \ + OR_GPCM_EHTR_CLEAR)
#define CONFIG_SYS_MAMR (MxMR_GPL_x4DIS | \ 0x0000c000 | \ diff --git a/include/configs/tuxa1.h b/include/configs/tuxa1.h index d3a82eb..36eaf4e 100644 --- a/include/configs/tuxa1.h +++ b/include/configs/tuxa1.h @@ -67,8 +67,8 @@ OR_GPCM_CSNT | \ OR_GPCM_ACS_DIV4 | \ OR_GPCM_SCY_2 | \ - (OR_GPCM_TRLX & \ - (~OR_GPCM_EHTR)) | /* EHTR = 0 */ \ + OR_GPCM_TRLX_SET | \ + OR_GPCM_EHTR_CLEAR | \ OR_GPCM_EAD) /* * PINC2 on the local bus CS3 @@ -85,11 +85,10 @@
#define CONFIG_SYS_OR3_PRELIM (MEG_TO_AM(CONFIG_SYS_PINC2_SIZE) | \ OR_GPCM_CSNT | \ - (OR_GPCM_ACS_DIV2 & /* ACS = 11 */ \ - (~OR_GPCM_XACS)) | /* XACS = 0 */ \ - (OR_GPCM_SCY_2 & \ - (~OR_GPCM_EHTR)) | /* EHTR = 0 */ \ - OR_GPCM_TRLX) + OR_GPCM_ACS_DIV2 | \ + OR_GPCM_SCY_2 | \ + OR_GPCM_TRLX_SET | \ + OR_GPCM_EHTR_CLEAR)
#define CONFIG_SYS_MAMR (MxMR_GPL_x4DIS | \ 0x0000c000 | \ diff --git a/include/configs/ve8313.h b/include/configs/ve8313.h index d256def..23e811a 100644 --- a/include/configs/ve8313.h +++ b/include/configs/ve8313.h @@ -145,18 +145,19 @@ #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE /* buffer up multiple bytes */
#define CONFIG_SYS_NOR_BR_PRELIM (CONFIG_SYS_FLASH_BASE | \ - (2 << BR_PS_SHIFT) | /* 16 bit */ \ - BR_V) /* valid */ + BR_PS_16 | /* 16 bit */ \ + BR_MS_GPCM | /* MSEL = GPCM */ \ + BR_V) /* valid */ #define CONFIG_SYS_NOR_OR_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ | OR_GPCM_CSNT \ | OR_GPCM_ACS_DIV4 \ | OR_GPCM_SCY_5 \ - | OR_GPCM_TRLX \ + | OR_GPCM_TRLX_SET \ | OR_GPCM_EAD) /* 0xfe000c55 */
#define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000018 /* 32 MB window size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_32MB)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 256 /* sectors per dev */ @@ -208,7 +209,7 @@ | BR_MS_FCM \ | BR_V ) /* valid */ /* 0x61000c21 */ -#define CONFIG_SYS_NAND_OR_PRELIM ( 0xffff8000 \ +#define CONFIG_SYS_NAND_OR_PRELIM ( OR_AM_32KB \ | OR_FCM_BCTLD \ | OR_FCM_CHT \ | OR_FCM_SCY_2 \ @@ -222,7 +223,7 @@ #define CONFIG_SYS_OR1_PRELIM CONFIG_SYS_NAND_OR_PRELIM
#define CONFIG_SYS_NAND_LBLAWBAR_PRELIM CONFIG_SYS_LBLAWBAR1_PRELIM #define CONFIG_SYS_NAND_LBLAWAR_PRELIM CONFIG_SYS_LBLAWAR1_PRELIM @@ -232,12 +233,12 @@ | BR_PS_8 \ | BR_V) /* 0x60000801 */ -#define CONFIG_SYS_OR2_PRELIM (0xfffe0000 \ +#define CONFIG_SYS_OR2_PRELIM ( OR_AM_128KB \ | OR_GPCM_CSNT \ | OR_GPCM_XACS \ | OR_GPCM_SCY_3 \ - | OR_GPCM_TRLX \ - | OR_GPCM_EHTR \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ | OR_GPCM_EAD) /* 0xfffe0937 */ /* local bus read write buffer mapping SRAM@0x64000000 */ @@ -246,12 +247,12 @@ | BR_V) /* 0x62001001 */
-#define CONFIG_SYS_OR3_PRELIM (0xfe000000 \ +#define CONFIG_SYS_OR3_PRELIM ( OR_AM_32MB \ | OR_GPCM_CSNT \ | OR_GPCM_XACS \ | OR_GPCM_SCY_15 \ - | OR_GPCM_TRLX \ - | OR_GPCM_EHTR \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ | OR_GPCM_EAD) /* 0xfe0009f7 */
diff --git a/include/configs/vme8349.h b/include/configs/vme8349.h index dbdb9da..f6a47f3 100644 --- a/include/configs/vme8349.h +++ b/include/configs/vme8349.h @@ -121,29 +121,57 @@ #define CONFIG_SYS_FLASH_BASE 0xffc00000 /* start of FLASH */ #define CONFIG_SYS_FLASH_SIZE 4 /* flash size in MB */ #define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | \ - (2 << BR_PS_SHIFT) | /* 16bit */ \ - BR_V) /* valid */ - -#define CONFIG_SYS_OR0_PRELIM 0xffc06ff7 /* 4 MB flash size */ + BR_PS_16 | /* 16bit */ \ + BR_MS_GPCM | /* MSEL = GPCM */ \ + BR_V) /* valid */ + +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xffc06ff7 */ #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x80000015 /* 4 MB window size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_4MB) #else #define CONFIG_SYS_FLASH_BASE 0xf8000000 /* start of FLASH */ #define CONFIG_SYS_FLASH_SIZE 128 /* flash size in MB */ #define CONFIG_SYS_BR0_PRELIM (CONFIG_SYS_FLASH_BASE | \ - (2 << BR_PS_SHIFT) | /* 16bit */ \ - BR_V) /* valid */ - -#define CONFIG_SYS_OR0_PRELIM 0xf8006ff7 /* 128 MB flash size */ + BR_PS_16 | /* 16bit */ \ + BR_MS_GPCM | /* MSEL = GPCM */ \ + BR_V) /* valid */ + +#define CONFIG_SYS_OR0_PRELIM (MEG_TO_AM(CONFIG_SYS_FLASH_SIZE) \ + | OR_GPCM_XAM \ + | OR_GPCM_CSNT \ + | OR_GPCM_ACS_DIV2 \ + | OR_GPCM_XACS \ + | OR_GPCM_SCY_15 \ + | OR_GPCM_TRLX_SET \ + | OR_GPCM_EHTR_SET \ + | OR_GPCM_EAD) + /* 0xf8006ff7 */ #define CONFIG_SYS_LBLAWBAR0_PRELIM CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_LBLAWAR0_PRELIM 0x8000001a /* 128 MB window size */ +#define CONFIG_SYS_LBLAWAR0_PRELIM (LBLAWAR_EN | LBLAWAR_128MB) #endif /* #define CONFIG_SYS_FLASH_USE_BUFFER_WRITE */
-#define CONFIG_SYS_BR1_PRELIM (0xf0000000 | 0x00001801) -#define CONFIG_SYS_OR1_PRELIM (0xfffc0008 | 0x00000200) -#define CONFIG_SYS_LBLAWBAR1_PRELIM 0xf0000000 -#define CONFIG_SYS_LBLAWAR1_PRELIM (0x80000000 | 0x00000011) +#define CONFIG_SYS_WINDOW1_BASE 0xf0000000 +#define CONFIG_SYS_BR1_PRELIM (CONFIG_SYS_WINDOW1_BASE \ + | BR_PS_32 \ + | BR_MS_GPCM \ + | BR_V) + /* 0xF0001801 */ +#define CONFIG_SYS_OR1_PRELIM (OR_AM_256KB \ + | 0x00000200 /* [RFC]Reserved ACS value on MPC8349 */ \ + | OR_GPCM_SETA) + /* 0xfffc0208 */ +#define CONFIG_SYS_LBLAWBAR1_PRELIM CONFIG_SYS_WINDOW1_BASE +#define CONFIG_SYS_LBLAWAR1_PRELIM (LBLAWAR_EN | LBLAWAR_256KB)
#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* number of banks */ #define CONFIG_SYS_MAX_FLASH_SECT 1024 /* sectors per device*/
On Fri, 12 Aug 2011 16:53:00 -0500 Joe Hershberger joe.hershberger@ni.com wrote:
Signed-off-by: Joe Hershberger joe.hershberger@ni.com Cc: Joe Hershberger joe.hershberger@gmail.com Cc: Kim Phillips kim.phillips@freescale.com
Changes for v2:
- Split
4 out of 4 patches applied to mpc83xx master, except changes with embedded '[RFC]' tags were reverted back to their original versions; changes such as this:
see commit 5c2ff32 on how the 8360MDS does things a bit differently.
Kim
Dear Kim Phillips,
Changes for v2:
- Split
Please undo. I will not accept a pull request for these.
Dear Joe Hershberger,
In message 1313185980-6208-5-git-send-email-joe.hershberger@ni.com you wrote:
Changes for v2:
- Split
arch/powerpc/include/asm/fsl_lbc.h | 8 ++- include/configs/MERGERBOX.h | 14 ++-- include/configs/MPC8308RDB.h | 35 +++++++--- include/configs/MPC8313ERDB.h | 60 ++++++++++++---- include/configs/MPC8315ERDB.h | 17 +++-- include/configs/MPC8323ERDB.h | 84 ++++------------------ include/configs/MPC832XEMDS.h | 135 +++++++++++++++++------------------- include/configs/MPC8349EMDS.h | 57 +++++++++++----- include/configs/MPC8349ITX.h | 21 +++--- include/configs/MPC8360EMDS.h | 96 ++++++++++++++++++++------ include/configs/MPC8360ERDK.h | 40 +++++++---- include/configs/MPC837XEMDS.h | 75 ++++++++++++-------- include/configs/MPC837XERDB.h | 64 ++++++++++------- include/configs/MVBLM7.h | 13 ++-- include/configs/SIMPC8313.h | 14 ++-- include/configs/TQM834x.h | 4 +- include/configs/km/km83xx-common.h | 14 ++-- include/configs/kmeter1.h | 7 +- include/configs/kmsupx5.h | 4 +- include/configs/mpc8308_p1m.h | 25 ++++--- include/configs/sbc8349.h | 53 +++++++++----- include/configs/suvd3.h | 2 +- include/configs/tuda1.h | 13 ++-- include/configs/tuxa1.h | 13 ++-- include/configs/ve8313.h | 25 ++++--- include/configs/vme8349.h | 56 +++++++++++---- 26 files changed, 552 insertions(+), 397 deletions(-)
Checkpatch says:
total: 26 errors, 84 warnings, 1538 lines checked
Please clean up and resubmit. Thanks.
Joe Hershberger
Joe Hershberger
Kim Phillips
