[PATCH 101/171] Correct SPL uses of I8259_PIC
This converts 4 usages of this option to the non-SPL form, since there is no SPL_I8259_PIC defined in Kconfig
arch/x86/lib/interrupts.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/x86/lib/interrupts.c b/arch/x86/lib/interrupts.c index ff52959ed28..33d6eb49d75 100644 --- a/arch/x86/lib/interrupts.c +++ b/arch/x86/lib/interrupts.c @@ -66,7 +66,7 @@ void irq_install_handler(int irq, interrupt_handler_t *handler, void *arg) irq_handlers[irq].arg = arg; irq_handlers[irq].count = 0;
- if (CONFIG_IS_ENABLED(I8259_PIC)) + if (IS_ENABLED(CONFIG_I8259_PIC)) unmask_irq(irq);
if (status) @@ -86,7 +86,7 @@ void irq_free_handler(int irq)
status = disable_interrupts();
- if (CONFIG_IS_ENABLED(I8259_PIC)) + if (IS_ENABLED(CONFIG_I8259_PIC)) mask_irq(irq);
irq_handlers[irq].handler = NULL; @@ -108,13 +108,13 @@ void do_irq(int hw_irq) }
if (irq_handlers[irq].handler) { - if (CONFIG_IS_ENABLED(I8259_PIC)) + if (IS_ENABLED(CONFIG_I8259_PIC)) mask_irq(irq);
irq_handlers[irq].handler(irq_handlers[irq].arg); irq_handlers[irq].count++;
- if (CONFIG_IS_ENABLED(I8259_PIC)) { + if (IS_ENABLED(CONFIG_I8259_PIC)) { unmask_irq(irq); specific_eoi(irq); }
This converts 3 usages of this option to the non-SPL form, since there is no SPL_IMX8M defined in Kconfig
arch/arm/mach-imx/imx_bootaux.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-imx/imx_bootaux.c b/arch/arm/mach-imx/imx_bootaux.c index 1a3e538c4fa..433c1f80cee 100644 --- a/arch/arm/mach-imx/imx_bootaux.c +++ b/arch/arm/mach-imx/imx_bootaux.c @@ -15,7 +15,7 @@ #include <cpu_func.h>
/* Just to avoid build error */ -#if CONFIG_IS_ENABLED(IMX8M) +#if IS_ENABLED(CONFIG_IMX8M) #define SRC_M4C_NON_SCLR_RST_MASK BIT(0) #define SRC_M4_ENABLE_MASK BIT(0) #define SRC_M4_REG_OFFSET 0 @@ -128,7 +128,7 @@ int arch_auxiliary_core_up(u32 core_id, ulong addr) flush_dcache_all();
/* Enable M4 */ - if (CONFIG_IS_ENABLED(IMX8M)) { + if (IS_ENABLED(CONFIG_IMX8M)) { arm_smccc_smc(IMX_SIP_SRC, IMX_SIP_SRC_M4_START, 0, 0, 0, 0, 0, 0, NULL); } else { clrsetbits_le32(SRC_BASE_ADDR + SRC_M4_REG_OFFSET, @@ -143,7 +143,7 @@ int arch_auxiliary_core_check_up(u32 core_id) struct arm_smccc_res res; unsigned int val;
- if (CONFIG_IS_ENABLED(IMX8M)) { + if (IS_ENABLED(CONFIG_IMX8M)) { arm_smccc_smc(IMX_SIP_SRC, IMX_SIP_SRC_M4_STARTED, 0, 0, 0, 0, 0, 0, &res); return res.a0; }
This converts 1 usage of this option to the non-SPL form, since there is no SPL_IMX8MN_BEACON_2GB_LPDDR defined in Kconfig
include/configs/imx8mn_beacon.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/imx8mn_beacon.h b/include/configs/imx8mn_beacon.h index bb3dfe3fa0d..1880d0311e4 100644 --- a/include/configs/imx8mn_beacon.h +++ b/include/configs/imx8mn_beacon.h @@ -80,7 +80,7 @@
#define CFG_SYS_SDRAM_BASE 0x40000000 #define PHYS_SDRAM 0x40000000 -#if CONFIG_IS_ENABLED(IMX8MN_BEACON_2GB_LPDDR) +#if IS_ENABLED(CONFIG_IMX8MN_BEACON_2GB_LPDDR) #define PHYS_SDRAM_SIZE 0x80000000 /* 2GB DDR */ #else #define PHYS_SDRAM_SIZE 0x40000000 /* 1GB DDR */
Reviewed-by: Adam Ford aford173@gmail.com
2.39.1.456.gfc5497dd1b-goog
This converts 6 usages of this option to the non-SPL form, since there is no SPL_IMX_MODULE_FUSE defined in Kconfig
arch/arm/include/asm/mach-imx/module_fuse.h | 2 +- drivers/i2c/mxc_i2c.c | 4 ++-- drivers/net/fec_mxc.c | 2 +- drivers/usb/host/ehci-mx6.c | 4 ++-- 4 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/arch/arm/include/asm/mach-imx/module_fuse.h b/arch/arm/include/asm/mach-imx/module_fuse.h index a46fc3f1f8e..6c92cb40d6d 100644 --- a/arch/arm/include/asm/mach-imx/module_fuse.h +++ b/arch/arm/include/asm/mach-imx/module_fuse.h @@ -74,7 +74,7 @@ struct fuse_entry_desc { u32 status; };
-#if !CONFIG_IS_ENABLED(IMX_MODULE_FUSE) +#if !IS_ENABLED(CONFIG_IMX_MODULE_FUSE) static inline u32 check_module_fused(enum fuse_module_type module) { return 0; diff --git a/drivers/i2c/mxc_i2c.c b/drivers/i2c/mxc_i2c.c index 9a1599dcd91..86b9fb57c83 100644 --- a/drivers/i2c/mxc_i2c.c +++ b/drivers/i2c/mxc_i2c.c @@ -744,7 +744,7 @@ void bus_i2c_init(int index, int speed, int unused, return; }
- if (CONFIG_IS_ENABLED(IMX_MODULE_FUSE)) { + if (IS_ENABLED(CONFIG_IMX_MODULE_FUSE)) { if (i2c_fused((ulong)mxc_i2c_buses[index].base)) { printf("SoC fuse indicates I2C@0x%lx is unavailable.\n", (ulong)mxc_i2c_buses[index].base); @@ -878,7 +878,7 @@ static int mxc_i2c_probe(struct udevice *bus) if (addr == FDT_ADDR_T_NONE) return -EINVAL;
- if (CONFIG_IS_ENABLED(IMX_MODULE_FUSE)) { + if (IS_ENABLED(CONFIG_IMX_MODULE_FUSE)) { if (i2c_fused((ulong)addr)) { printf("SoC fuse indicates I2C@0x%lx is unavailable.\n", (ulong)addr); diff --git a/drivers/net/fec_mxc.c b/drivers/net/fec_mxc.c index 006d27051eb..5cc35958c49 100644 --- a/drivers/net/fec_mxc.c +++ b/drivers/net/fec_mxc.c @@ -1125,7 +1125,7 @@ static int fecmxc_probe(struct udevice *dev) uint32_t start; int ret;
- if (CONFIG_IS_ENABLED(IMX_MODULE_FUSE)) { + if (IS_ENABLED(CONFIG_IMX_MODULE_FUSE)) { if (enet_fused((ulong)priv->eth)) { printf("SoC fuse indicates Ethernet@0x%lx is unavailable.\n", (ulong)priv->eth); return -ENODEV; diff --git a/drivers/usb/host/ehci-mx6.c b/drivers/usb/host/ehci-mx6.c index 0a12db614ff..91633f013a5 100644 --- a/drivers/usb/host/ehci-mx6.c +++ b/drivers/usb/host/ehci-mx6.c @@ -360,7 +360,7 @@ int ehci_hcd_init(int index, enum usb_init_type init, if (index > 3) return -EINVAL;
- if (CONFIG_IS_ENABLED(IMX_MODULE_FUSE)) { + if (IS_ENABLED(CONFIG_IMX_MODULE_FUSE)) { if (usb_fused((ulong)ehci)) { printf("SoC fuse indicates USB@0x%lx is unavailable.\n", (ulong)ehci); @@ -641,7 +641,7 @@ static int ehci_usb_probe(struct udevice *dev) struct ehci_hcor *hcor; int ret;
This converts 2 usages of this option to the non-SPL form, since there is no SPL_IMX_RDC defined in Kconfig
arch/arm/mach-imx/mx7/soc.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-imx/mx7/soc.c b/arch/arm/mach-imx/mx7/soc.c index 02af0d568f2..550e392550e 100644 --- a/arch/arm/mach-imx/mx7/soc.c +++ b/arch/arm/mach-imx/mx7/soc.c @@ -68,7 +68,7 @@ U_BOOT_DRVINFO(imx7_thermal) = { }; #endif
-#if CONFIG_IS_ENABLED(IMX_RDC) +#if IS_ENABLED(CONFIG_IMX_RDC) /* * In current design, if any peripheral was assigned to both A7 and M4, * it will receive ipg_stop or ipg_wait when any of the 2 platforms enter @@ -316,7 +316,7 @@ int arch_cpu_init(void)
init_cpu_basic();
-#if CONFIG_IS_ENABLED(IMX_RDC) +#if IS_ENABLED(CONFIG_IMX_RDC) isolate_resource(); #endif
This converts 9 usages of this option to the non-SPL form, since there is no SPL_LMB defined in Kconfig
arch/arc/lib/bootm.c | 2 +- arch/arm/lib/bootm.c | 2 +- arch/m68k/lib/bootm.c | 2 +- arch/microblaze/lib/bootm.c | 2 +- arch/powerpc/lib/bootm.c | 2 +- arch/riscv/lib/bootm.c | 2 +- arch/sandbox/lib/bootm.c | 2 +- arch/x86/lib/bootm.c | 2 +- boot/image-board.c | 2 +- 9 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/arch/arc/lib/bootm.c b/arch/arc/lib/bootm.c index 07b2c1540d0..2dd003445f8 100644 --- a/arch/arc/lib/bootm.c +++ b/arch/arc/lib/bootm.c @@ -29,7 +29,7 @@ static int boot_prep_linux(struct bootm_headers *images) { int ret;
- if (CONFIG_IS_ENABLED(LMB)) { + if (IS_ENABLED(CONFIG_LMB)) { ret = image_setup_linux(images); if (ret) return ret; diff --git a/arch/arm/lib/bootm.c b/arch/arm/lib/bootm.c index e414ef82673..c56285738a2 100644 --- a/arch/arm/lib/bootm.c +++ b/arch/arm/lib/bootm.c @@ -199,7 +199,7 @@ static void boot_prep_linux(struct bootm_headers *images) { char *commandline = env_get("bootargs");
- if (CONFIG_IS_ENABLED(OF_LIBFDT) && CONFIG_IS_ENABLED(LMB) && images->ft_len) { + if (CONFIG_IS_ENABLED(OF_LIBFDT) && IS_ENABLED(CONFIG_LMB) && images->ft_len) { debug("using: FDT\n"); if (image_setup_linux(images)) { panic("FDT creation failed!"); diff --git a/arch/m68k/lib/bootm.c b/arch/m68k/lib/bootm.c index c1c9bdceb50..f18bed235d4 100644 --- a/arch/m68k/lib/bootm.c +++ b/arch/m68k/lib/bootm.c @@ -60,7 +60,7 @@ int do_bootm_linux(int flag, int argc, char *const argv[], } set_clocks_in_mhz(kbd);
- if (CONFIG_IS_ENABLED(LMB)) { + if (IS_ENABLED(CONFIG_LMB)) { ret = image_setup_linux(images); if (ret) goto error; diff --git a/arch/microblaze/lib/bootm.c b/arch/microblaze/lib/bootm.c index 4a5421497e5..930384f4015 100644 --- a/arch/microblaze/lib/bootm.c +++ b/arch/microblaze/lib/bootm.c @@ -73,7 +73,7 @@ static void boot_jump_linux(struct bootm_headers *images, int flag)
static void boot_prep_linux(struct bootm_headers *images) { - if (CONFIG_IS_ENABLED(OF_LIBFDT) && CONFIG_IS_ENABLED(LMB) && images->ft_len) { + if (CONFIG_IS_ENABLED(OF_LIBFDT) && IS_ENABLED(CONFIG_LMB) && images->ft_len) { debug("using: FDT\n"); if (image_setup_linux(images)) { printf("FDT creation failed! hanging..."); diff --git a/arch/powerpc/lib/bootm.c b/arch/powerpc/lib/bootm.c index ef1d5af8908..7a305456346 100644 --- a/arch/powerpc/lib/bootm.c +++ b/arch/powerpc/lib/bootm.c @@ -214,7 +214,7 @@ static int boot_body_linux(struct bootm_headers *images) if (ret) return ret;
- if (CONFIG_IS_ENABLED(LMB)) { + if (IS_ENABLED(CONFIG_LMB)) { ret = image_setup_linux(images); if (ret) return ret; diff --git a/arch/riscv/lib/bootm.c b/arch/riscv/lib/bootm.c index f5f8b4c7333..276677a5e2f 100644 --- a/arch/riscv/lib/bootm.c +++ b/arch/riscv/lib/bootm.c @@ -64,7 +64,7 @@ static void announce_and_cleanup(int fake)
static void boot_prep_linux(struct bootm_headers *images) { - if (CONFIG_IS_ENABLED(OF_LIBFDT) && CONFIG_IS_ENABLED(LMB) && images->ft_len) { + if (CONFIG_IS_ENABLED(OF_LIBFDT) && IS_ENABLED(CONFIG_LMB) && images->ft_len) { debug("using: FDT\n"); if (image_setup_linux(images)) { printf("FDT creation failed! hanging..."); diff --git a/arch/sandbox/lib/bootm.c b/arch/sandbox/lib/bootm.c index 28f4a746fb6..dc8b8e46cb4 100644 --- a/arch/sandbox/lib/bootm.c +++ b/arch/sandbox/lib/bootm.c @@ -55,7 +55,7 @@ static int boot_prep_linux(struct bootm_headers *images) { int ret;
- if (CONFIG_IS_ENABLED(LMB)) { + if (IS_ENABLED(CONFIG_LMB)) { ret = image_setup_linux(images); if (ret) return ret; diff --git a/arch/x86/lib/bootm.c b/arch/x86/lib/bootm.c index 04e475bdc24..873e2bc176f 100644 --- a/arch/x86/lib/bootm.c +++ b/arch/x86/lib/bootm.c @@ -78,7 +78,7 @@ static int boot_prep_linux(struct bootm_headers *images) size_t len; int ret;
- if (CONFIG_IS_ENABLED(OF_LIBFDT) && CONFIG_IS_ENABLED(LMB) && images->ft_len) { + if (CONFIG_IS_ENABLED(OF_LIBFDT) && IS_ENABLED(CONFIG_LMB) && images->ft_len) { debug("using: FDT\n"); if (image_setup_linux(images)) { puts("FDT creation failed! hanging..."); diff --git a/boot/image-board.c b/boot/image-board.c index e5d71a3d541..25b60ec30b3 100644 --- a/boot/image-board.c +++ b/boot/image-board.c @@ -927,7 +927,7 @@ int image_setup_linux(struct bootm_headers *images) int ret;
/* This function cannot be called without lmb support */ - if (!CONFIG_IS_ENABLED(LMB)) + if (!IS_ENABLED(CONFIG_LMB)) return -EFAULT; if (CONFIG_IS_ENABLED(OF_LIBFDT)) boot_fdt_add_mem_rsv_regions(lmb, *of_flat_tree);
This converts 2 usages of this option to the non-SPL form, since there is no SPL_MICROBLAZE defined in Kconfig
board/xilinx/common/board.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/xilinx/common/board.c b/board/xilinx/common/board.c index aa9f3ef071c..bed15319934 100644 --- a/board/xilinx/common/board.c +++ b/board/xilinx/common/board.c @@ -412,14 +412,14 @@ int board_late_init_xilinx(void) struct xilinx_board_description *desc; phys_size_t bootm_size = gd->ram_top - gd->ram_base;
- if (!CONFIG_IS_ENABLED(MICROBLAZE)) { + if (!IS_ENABLED(CONFIG_MICROBLAZE)) { ulong scriptaddr;
scriptaddr = env_get_hex("scriptaddr", 0); ret |= env_set_hex("scriptaddr", gd->ram_base + scriptaddr); }
- if (IS_ENABLED(CONFIG_ARCH_ZYNQ) || CONFIG_IS_ENABLED(MICROBLAZE)) + if (IS_ENABLED(CONFIG_ARCH_ZYNQ) || IS_ENABLED(CONFIG_MICROBLAZE)) bootm_size = min(bootm_size, (phys_size_t)(SZ_512M + SZ_256M));
ret |= env_set_hex("script_offset_f", CONFIG_BOOT_SCRIPT_OFFSET);
This converts 1 usage of this option to the non-SPL form, since there is no SPL_MIPS_CM defined in Kconfig
arch/mips/include/asm/cm.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/mips/include/asm/cm.h b/arch/mips/include/asm/cm.h index 5cc8c09621d..c695ffc71f5 100644 --- a/arch/mips/include/asm/cm.h +++ b/arch/mips/include/asm/cm.h @@ -108,7 +108,7 @@ #include <asm/io.h> #include <linux/bitops.h>
-#if CONFIG_IS_ENABLED(MIPS_CM) +#if IS_ENABLED(CONFIG_MIPS_CM) static inline void *mips_cm_base(void) { return (void *)CKSEG1ADDR(CONFIG_MIPS_CM_BASE);
This converts 1 usage of this option to the non-SPL form, since there is no SPL_MMC_QUIRKS defined in Kconfig
drivers/mmc/mmc.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 210703ea46b..fd4aa946e2a 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -247,7 +247,7 @@ static int mmc_send_cmd_retry(struct mmc *mmc, struct mmc_cmd *cmd, static int mmc_send_cmd_quirks(struct mmc *mmc, struct mmc_cmd *cmd, struct mmc_data *data, u32 quirk, uint retries) { - if (CONFIG_IS_ENABLED(MMC_QUIRKS) && mmc->quirks & quirk) + if (IS_ENABLED(CONFIG_MMC_QUIRKS) && mmc->quirks & quirk) return mmc_send_cmd_retry(mmc, cmd, data, retries); else return mmc_send_cmd(mmc, cmd, data);
This converts 2 usages of this option to the non-SPL form, since there is no SPL_MTD defined in Kconfig
arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c | 2 +- board/st/common/stm32mp_dfu.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c index 4b75397b1cc..9c4ba407ba0 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c @@ -1748,7 +1748,7 @@ static void stm32prog_end_phase(struct stm32prog_data *data, u64 offset) } }
- if (CONFIG_IS_ENABLED(MTD) && + if (IS_ENABLED(CONFIG_MTD) && data->cur_part->bin_nb > 1) { if (stm32prog_copy_fsbl(data->cur_part)) { stm32prog_err("%s (0x%x): copy of fsbl failed", diff --git a/board/st/common/stm32mp_dfu.c b/board/st/common/stm32mp_dfu.c index 19e9c3b2402..079ba15ddb1 100644 --- a/board/st/common/stm32mp_dfu.c +++ b/board/st/common/stm32mp_dfu.c @@ -123,7 +123,7 @@ void set_dfu_alt_info(char *interface, char *devstr) board_get_alt_info_mmc(dev, buf); }
- if (CONFIG_IS_ENABLED(MTD)) { + if (IS_ENABLED(CONFIG_MTD)) { /* probe all MTD devices */ mtd_probe_devices();
This converts 3 usages of this option to the non-SPL form, since there is no SPL_MULTIPLEXER defined in Kconfig
drivers/Makefile | 2 +- drivers/mux/Makefile | 2 +- include/mux.h | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/Makefile b/drivers/Makefile index 15d19d0c8a3..20497aa2ac9 100644 --- a/drivers/Makefile +++ b/drivers/Makefile @@ -18,7 +18,7 @@ obj-$(CONFIG_$(SPL_TPL_)INPUT) += input/ obj-$(CONFIG_$(SPL_TPL_)LED) += led/ obj-$(CONFIG_$(SPL_TPL_)MMC) += mmc/ obj-y += mtd/ -obj-$(CONFIG_$(SPL_)MULTIPLEXER) += mux/ +obj-$(CONFIG_MULTIPLEXER) += mux/ obj-$(CONFIG_$(SPL_TPL_)ETH) += net/ obj-$(CONFIG_$(SPL_TPL_)PCH) += pch/ obj-$(CONFIG_$(SPL_TPL_)PCI) += pci/ diff --git a/drivers/mux/Makefile b/drivers/mux/Makefile index 78ebf04c7a9..d4e24789d33 100644 --- a/drivers/mux/Makefile +++ b/drivers/mux/Makefile @@ -3,5 +3,5 @@ # (C) Copyright 2019 # Jean-Jacques Hiblot jjhiblot@ti.com
-obj-$(CONFIG_$(SPL_)MULTIPLEXER) += mux-uclass.o +obj-$(CONFIG_MULTIPLEXER) += mux-uclass.o obj-$(CONFIG_$(SPL_)MUX_MMIO) += mmio.o diff --git a/include/mux.h b/include/mux.h index 9f809912742..c92d887591e 100644 --- a/include/mux.h +++ b/include/mux.h @@ -23,7 +23,7 @@ struct udevice; struct mux_control;
-#if CONFIG_IS_ENABLED(MULTIPLEXER) +#if IS_ENABLED(CONFIG_MULTIPLEXER) /** * mux_control_states() - Query the number of multiplexer states. * @mux: The mux-control to query.
This converts 3 usages of this option to the non-SPL form, since there is no SPL_NEEDS_MANUAL_RELOC defined in Kconfig
common/board_r.c | 4 ++-- common/event.c | 2 +- 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/common/board_r.c b/common/board_r.c index 552b9899323..cbc140e6d8b 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -155,7 +155,7 @@ static int initr_reloc_global_data(void) * The fdt_blob needs to be moved to new relocation address * incase of FDT blob is embedded with in image */ - if (CONFIG_IS_ENABLED(OF_EMBED) && CONFIG_IS_ENABLED(NEEDS_MANUAL_RELOC)) + if (CONFIG_IS_ENABLED(OF_EMBED) && IS_ENABLED(CONFIG_NEEDS_MANUAL_RELOC)) gd->fdt_blob += gd->reloc_off;
#ifdef CONFIG_EFI_LOADER @@ -609,7 +609,7 @@ static init_fnc_t init_sequence_r[] = { */ #endif initr_reloc_global_data, -#if CONFIG_IS_ENABLED(NEEDS_MANUAL_RELOC) && CONFIG_IS_ENABLED(EVENT) +#if IS_ENABLED(CONFIG_NEEDS_MANUAL_RELOC) && CONFIG_IS_ENABLED(EVENT) event_manual_reloc, #endif #if defined(CONFIG_SYS_INIT_RAM_LOCK) && defined(CONFIG_E500) diff --git a/common/event.c b/common/event.c index c312556490e..164c95f8f52 100644 --- a/common/event.c +++ b/common/event.c @@ -155,7 +155,7 @@ void event_show_spy_list(void) } }
-#if CONFIG_IS_ENABLED(NEEDS_MANUAL_RELOC) +#if IS_ENABLED(CONFIG_NEEDS_MANUAL_RELOC) int event_manual_reloc(void) { struct evspy_info *spy, *end;
This converts 1 usage of this option to the non-SPL form, since there is no SPL_NETDEVICES defined in Kconfig
net/bootp.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/net/bootp.c b/net/bootp.c index cae041988db..8b1a4ae2ef8 100644 --- a/net/bootp.c +++ b/net/bootp.c @@ -1078,7 +1078,7 @@ static void dhcp_handler(uchar *pkt, unsigned dest, struct in_addr sip, #endif /* CONFIG_SYS_BOOTFILE_PREFIX */ dhcp_packet_process_options(bp); if (CONFIG_IS_ENABLED(EFI_LOADER) && - CONFIG_IS_ENABLED(NETDEVICES)) + IS_ENABLED(CONFIG_NETDEVICES)) efi_net_set_dhcp_ack(pkt, len);
#if defined(CONFIG_SERVERIP_FROM_PROXYDHCP)
This converts 2 usages of this option to the non-SPL form, since there is no SPL_NXP_FSPI defined in Kconfig
drivers/clk/imx/clk-imx8mm.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/clk/imx/clk-imx8mm.c b/drivers/clk/imx/clk-imx8mm.c index b5c253e4966..663b9a1bc7e 100644 --- a/drivers/clk/imx/clk-imx8mm.c +++ b/drivers/clk/imx/clk-imx8mm.c @@ -86,7 +86,7 @@ static const char *imx8mm_wdog_sels[] = {"clock-osc-24m", "sys_pll1_133m", "sys_ static const char *imx8mm_usdhc3_sels[] = {"clock-osc-24m", "sys_pll1_400m", "sys_pll1_800m", "sys_pll2_500m", "sys_pll3_out", "sys_pll1_266m", "audio_pll2_clk", "sys_pll1_100m", };
-#if CONFIG_IS_ENABLED(NXP_FSPI) +#if IS_ENABLED(CONFIG_NXP_FSPI) static const char *imx8mm_qspi_sels[] = {"clock-osc-24m", "sys_pll1_400m", "sys_pll2_333m", "sys_pll2_500m", "audio_pll2_out", "sys_pll1_266m", "sys_pll3_out", "sys_pll1_100m", }; #endif @@ -355,7 +355,7 @@ static int imx8mm_clk_probe(struct udevice *dev) imx_clk_gate4("ecspi3_root_clk", "ecspi3", base + 0x4090, 0)); #endif
-#if CONFIG_IS_ENABLED(NXP_FSPI) +#if IS_ENABLED(CONFIG_NXP_FSPI) clk_dm(IMX8MM_CLK_QSPI, imx8m_clk_composite("qspi", imx8mm_qspi_sels, base + 0xab80)); clk_dm(IMX8MM_CLK_QSPI_ROOT,
This converts 1 usage of this option to the non-SPL form, since there is no SPL_OCTEON_SERIAL_BOOTCMD defined in Kconfig
arch/mips/mach-octeon/cpu.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/mips/mach-octeon/cpu.c b/arch/mips/mach-octeon/cpu.c index 1bdc6cd7290..5adf4ba32c8 100644 --- a/arch/mips/mach-octeon/cpu.c +++ b/arch/mips/mach-octeon/cpu.c @@ -451,7 +451,7 @@ int arch_misc_init(void) if (CONFIG_IS_ENABLED(OCTEON_SERIAL_PCIE_CONSOLE)) init_pcie_console();
- if (CONFIG_IS_ENABLED(OCTEON_SERIAL_BOOTCMD)) + if (IS_ENABLED(CONFIG_OCTEON_SERIAL_BOOTCMD)) init_bootcmd_console();
This converts 1 usage of this option to the non-SPL form, since there is no SPL_OCTEON_SERIAL_PCIE_CONSOLE defined in Kconfig
diff --git a/arch/mips/mach-octeon/cpu.c b/arch/mips/mach-octeon/cpu.c index 5adf4ba32c8..c7744e84706 100644 --- a/arch/mips/mach-octeon/cpu.c +++ b/arch/mips/mach-octeon/cpu.c @@ -448,7 +448,7 @@ int arch_misc_init(void) if (ret) return ret;
- if (CONFIG_IS_ENABLED(OCTEON_SERIAL_PCIE_CONSOLE)) + if (IS_ENABLED(CONFIG_OCTEON_SERIAL_PCIE_CONSOLE)) init_pcie_console();
This converts 3 usages of this option to the non-SPL form, since there is no SPL_OF_BOARD defined in Kconfig
drivers/pinctrl/broadcom/pinctrl-bcm283x.c | 2 +- drivers/serial/serial_bcm283x_mu.c | 2 +- drivers/serial/serial_bcm283x_pl011.c | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/pinctrl/broadcom/pinctrl-bcm283x.c b/drivers/pinctrl/broadcom/pinctrl-bcm283x.c index 44a310f83de..e949cb70900 100644 --- a/drivers/pinctrl/broadcom/pinctrl-bcm283x.c +++ b/drivers/pinctrl/broadcom/pinctrl-bcm283x.c @@ -153,7 +153,7 @@ U_BOOT_DRIVER(pinctrl_bcm283x) = { .priv_auto = sizeof(struct bcm283x_pinctrl_priv), .ops = &bcm283x_pinctrl_ops, .probe = bcm283x_pinctl_probe, -#if CONFIG_IS_ENABLED(OF_BOARD) +#if IS_ENABLED(CONFIG_OF_BOARD) .flags = DM_FLAG_PRE_RELOC, #endif }; diff --git a/drivers/serial/serial_bcm283x_mu.c b/drivers/serial/serial_bcm283x_mu.c index 12cbcb9858c..7585f790d22 100644 --- a/drivers/serial/serial_bcm283x_mu.c +++ b/drivers/serial/serial_bcm283x_mu.c @@ -197,7 +197,7 @@ U_BOOT_DRIVER(serial_bcm283x_mu) = { .plat_auto = sizeof(struct bcm283x_mu_serial_plat), .probe = bcm283x_mu_serial_probe, .ops = &bcm283x_mu_serial_ops, -#if !CONFIG_IS_ENABLED(OF_CONTROL) || CONFIG_IS_ENABLED(OF_BOARD) +#if !CONFIG_IS_ENABLED(OF_CONTROL) || IS_ENABLED(CONFIG_OF_BOARD) .flags = DM_FLAG_PRE_RELOC, #endif .priv_auto = sizeof(struct bcm283x_mu_priv), diff --git a/drivers/serial/serial_bcm283x_pl011.c b/drivers/serial/serial_bcm283x_pl011.c index 7d172cdac0a..09a9868a38f 100644 --- a/drivers/serial/serial_bcm283x_pl011.c +++ b/drivers/serial/serial_bcm283x_pl011.c @@ -94,7 +94,7 @@ U_BOOT_DRIVER(bcm283x_pl011_uart) = { .probe = bcm283x_pl011_serial_probe, .plat_auto = sizeof(struct pl01x_serial_plat), .ops = &bcm283x_pl011_serial_ops, -#if !CONFIG_IS_ENABLED(OF_CONTROL) || CONFIG_IS_ENABLED(OF_BOARD) +#if !CONFIG_IS_ENABLED(OF_CONTROL) || IS_ENABLED(CONFIG_OF_BOARD) .flags = DM_FLAG_PRE_RELOC, #endif .priv_auto = sizeof(struct pl01x_priv),
For bcm283x: Reviewed-by: Matthias Brugger mbrugger@suse.com
This converts 1 usage of this option to the non-SPL form, since there is no SPL_OF_EMBED defined in Kconfig
common/board_r.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/board_r.c b/common/board_r.c index cbc140e6d8b..2cd66eac803 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -155,7 +155,7 @@ static int initr_reloc_global_data(void) * The fdt_blob needs to be moved to new relocation address * incase of FDT blob is embedded with in image */ - if (CONFIG_IS_ENABLED(OF_EMBED) && IS_ENABLED(CONFIG_NEEDS_MANUAL_RELOC)) + if (IS_ENABLED(CONFIG_OF_EMBED) && IS_ENABLED(CONFIG_NEEDS_MANUAL_RELOC)) gd->fdt_blob += gd->reloc_off;
This converts 1 usage of this option to the non-SPL form, since there is no SPL_PANEL defined in Kconfig
drivers/video/imx/mxc_ipuv3_fb.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/video/imx/mxc_ipuv3_fb.c b/drivers/video/imx/mxc_ipuv3_fb.c index 8b01a1be112..7e60385bcfa 100644 --- a/drivers/video/imx/mxc_ipuv3_fb.c +++ b/drivers/video/imx/mxc_ipuv3_fb.c @@ -615,7 +615,7 @@ static int ipuv3_video_probe(struct udevice *dev) if (ret < 0) return ret; #endif - if (CONFIG_IS_ENABLED(PANEL)) { + if (IS_ENABLED(CONFIG_PANEL)) { struct udevice *panel_dev;
ret = uclass_get_device(UCLASS_PANEL, 0, &panel_dev);
This converts 1 usage of this option to the non-SPL form, since there is no SPL_PARTITION_TYPE_GUID defined in Kconfig
disk/part_efi.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/disk/part_efi.c b/disk/part_efi.c index 18f7e584050..80a44dc9f07 100644 --- a/disk/part_efi.c +++ b/disk/part_efi.c @@ -242,7 +242,7 @@ void part_print_efi(struct blk_desc *dev_desc) print_efiname(&gpt_pte[i])); printf("\tattrs:\t0x%016llx\n", gpt_pte[i].attributes.raw); uuid = (unsigned char *)gpt_pte[i].partition_type_guid.b; - if (CONFIG_IS_ENABLED(PARTITION_TYPE_GUID)) + if (IS_ENABLED(CONFIG_PARTITION_TYPE_GUID)) printf("\ttype:\t%pUl\n\t\t(%pUs)\n", uuid, uuid); else printf("\ttype:\t%pUl\n", uuid);
This converts 1 usage of this option to the non-SPL form, since there is no SPL_PCI_PNP defined in Kconfig
drivers/pci/pci-uclass.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index 9343cfc62a9..a0c19987ab1 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -1140,7 +1140,7 @@ static int pci_uclass_post_probe(struct udevice *bus) if (ret) return log_msg_ret("bind", ret);
- if (CONFIG_IS_ENABLED(PCI_PNP) && ll_boot_init() && + if (IS_ENABLED(CONFIG_PCI_PNP) && ll_boot_init() && (!hose->skip_auto_config_until_reloc || (gd->flags & GD_FLG_RELOC))) { ret = pci_auto_config_devices(bus);
This converts 2 usages of this option to the non-SPL form, since there is no SPL_PG_WCOM_UBOOT_BOOTPACKAGE defined in Kconfig
board/keymile/common/common.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/keymile/common/common.c b/board/keymile/common/common.c index 0252ada93ff..9cf5b71655c 100644 --- a/board/keymile/common/common.c +++ b/board/keymile/common/common.c @@ -79,9 +79,9 @@ int set_km_env(void) }
#if CONFIG_IS_ENABLED(PG_WCOM_UBOOT_UPDATE_SUPPORTED) -#if ((!CONFIG_IS_ENABLED(PG_WCOM_UBOOT_BOOTPACKAGE) && \ +#if ((!IS_ENABLED(CONFIG_PG_WCOM_UBOOT_BOOTPACKAGE) && \ !CONFIG_IS_ENABLED(PG_WCOM_UBOOT_UPDATE)) || \ - (CONFIG_IS_ENABLED(PG_WCOM_UBOOT_BOOTPACKAGE) && \ + (IS_ENABLED(CONFIG_PG_WCOM_UBOOT_BOOTPACKAGE) && \ CONFIG_IS_ENABLED(PG_WCOM_UBOOT_UPDATE))) #error "It has to be either bootpackage or update u-boot image!" #endif
Reviewed-by: Aleksandar Gerasimovski Aleksandar.gerasimovski@hitachienergy.com
Regards, Aleksandar
#if CONFIG_IS_ENABLED(PG_WCOM_UBOOT_UPDATE_SUPPORTED) -#if ((!CONFIG_IS_ENABLED(PG_WCOM_UBOOT_BOOTPACKAGE) && \ +#if ((!IS_ENABLED(CONFIG_PG_WCOM_UBOOT_BOOTPACKAGE) && \ !CONFIG_IS_ENABLED(PG_WCOM_UBOOT_UPDATE)) || \ - (CONFIG_IS_ENABLED(PG_WCOM_UBOOT_BOOTPACKAGE) && \ + (IS_ENABLED(CONFIG_PG_WCOM_UBOOT_BOOTPACKAGE) && \ CONFIG_IS_ENABLED(PG_WCOM_UBOOT_UPDATE))) #error "It has to be either bootpackage or update u-boot image!" #endif -- 2.39.1.456.gfc5497dd1b-goog
This converts 2 usages of this option to the non-SPL form, since there is no SPL_PG_WCOM_UBOOT_UPDATE defined in Kconfig
diff --git a/board/keymile/common/common.c b/board/keymile/common/common.c index 9cf5b71655c..8c282f9952a 100644 --- a/board/keymile/common/common.c +++ b/board/keymile/common/common.c @@ -80,9 +80,9 @@ int set_km_env(void)
#if CONFIG_IS_ENABLED(PG_WCOM_UBOOT_UPDATE_SUPPORTED) #if ((!IS_ENABLED(CONFIG_PG_WCOM_UBOOT_BOOTPACKAGE) && \ - !CONFIG_IS_ENABLED(PG_WCOM_UBOOT_UPDATE)) || \ + !IS_ENABLED(CONFIG_PG_WCOM_UBOOT_UPDATE)) || \ (IS_ENABLED(CONFIG_PG_WCOM_UBOOT_BOOTPACKAGE) && \ - CONFIG_IS_ENABLED(PG_WCOM_UBOOT_UPDATE))) + IS_ENABLED(CONFIG_PG_WCOM_UBOOT_UPDATE))) #error "It has to be either bootpackage or update u-boot image!" #endif void check_for_uboot_update(void)
Signed-off-by: Simon Glass sjg@chromium.org --- Reviewed-by: Aleksandar Gerasimovski Aleksandar.gerasimovski@hitachienergy.com
Regards, Aleksandar
#if CONFIG_IS_ENABLED(PG_WCOM_UBOOT_UPDATE_SUPPORTED) #if ((!IS_ENABLED(CONFIG_PG_WCOM_UBOOT_BOOTPACKAGE) && \ - !CONFIG_IS_ENABLED(PG_WCOM_UBOOT_UPDATE)) || \ + !IS_ENABLED(CONFIG_PG_WCOM_UBOOT_UPDATE)) || \ (IS_ENABLED(CONFIG_PG_WCOM_UBOOT_BOOTPACKAGE) && \ - CONFIG_IS_ENABLED(PG_WCOM_UBOOT_UPDATE))) + IS_ENABLED(CONFIG_PG_WCOM_UBOOT_UPDATE))) #error "It has to be either bootpackage or update u-boot image!" #endif void check_for_uboot_update(void) -- 2.39.1.456.gfc5497dd1b-goog
This converts 1 usage of this option to the non-SPL form, since there is no SPL_PG_WCOM_UBOOT_UPDATE_SUPPORTED defined in Kconfig
board/keymile/common/common.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/keymile/common/common.c b/board/keymile/common/common.c index 8c282f9952a..991022ac833 100644 --- a/board/keymile/common/common.c +++ b/board/keymile/common/common.c @@ -78,7 +78,7 @@ int set_km_env(void) return 0; }
-#if CONFIG_IS_ENABLED(PG_WCOM_UBOOT_UPDATE_SUPPORTED) +#if IS_ENABLED(CONFIG_PG_WCOM_UBOOT_UPDATE_SUPPORTED) #if ((!IS_ENABLED(CONFIG_PG_WCOM_UBOOT_BOOTPACKAGE) && \ !IS_ENABLED(CONFIG_PG_WCOM_UBOOT_UPDATE)) || \ (IS_ENABLED(CONFIG_PG_WCOM_UBOOT_BOOTPACKAGE) && \
Regards, Aleksandar
-#if CONFIG_IS_ENABLED(PG_WCOM_UBOOT_UPDATE_SUPPORTED) +#if IS_ENABLED(CONFIG_PG_WCOM_UBOOT_UPDATE_SUPPORTED) #if ((!IS_ENABLED(CONFIG_PG_WCOM_UBOOT_BOOTPACKAGE) && \ !IS_ENABLED(CONFIG_PG_WCOM_UBOOT_UPDATE)) || \ (IS_ENABLED(CONFIG_PG_WCOM_UBOOT_BOOTPACKAGE) && \ -- 2.39.1.456.gfc5497dd1b-goog
This converts 1 usage of this option to the non-SPL form, since there is no SPL_PHY_CADENCE_SIERRA defined in Kconfig
drivers/phy/cadence/Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/phy/cadence/Makefile b/drivers/phy/cadence/Makefile index af63b32d9f5..c247feb8262 100644 --- a/drivers/phy/cadence/Makefile +++ b/drivers/phy/cadence/Makefile @@ -1,2 +1,2 @@ -obj-$(CONFIG_$(SPL_)PHY_CADENCE_SIERRA) += phy-cadence-sierra.o +obj-$(CONFIG_PHY_CADENCE_SIERRA) += phy-cadence-sierra.o obj-$(CONFIG_$(SPL_)PHY_CADENCE_TORRENT) += phy-cadence-torrent.o
This converts 1 usage of this option to the non-SPL form, since there is no SPL_PHY_CADENCE_TORRENT defined in Kconfig
diff --git a/drivers/phy/cadence/Makefile b/drivers/phy/cadence/Makefile index c247feb8262..a1cb6868c9e 100644 --- a/drivers/phy/cadence/Makefile +++ b/drivers/phy/cadence/Makefile @@ -1,2 +1,2 @@ obj-$(CONFIG_PHY_CADENCE_SIERRA) += phy-cadence-sierra.o -obj-$(CONFIG_$(SPL_)PHY_CADENCE_TORRENT) += phy-cadence-torrent.o +obj-$(CONFIG_PHY_CADENCE_TORRENT) += phy-cadence-torrent.o
This converts 3 usages of this option to the non-SPL form, since there is no SPL_PHY_FIXED defined in Kconfig
drivers/net/mvneta.c | 4 ++-- net/mdio-uclass.c | 2 +- 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/net/mvneta.c b/drivers/net/mvneta.c index 0fbfad11d45..24933473fa0 100644 --- a/drivers/net/mvneta.c +++ b/drivers/net/mvneta.c @@ -815,7 +815,7 @@ static void mvneta_defaults_set(struct mvneta_port *pp) mvreg_write(pp, MVNETA_SDMA_CONFIG, val);
/* Enable PHY polling in hardware if not in fixed-link mode */ - if (!CONFIG_IS_ENABLED(PHY_FIXED) || + if (!IS_ENABLED(CONFIG_PHY_FIXED) || pp->phydev->phy_id != PHY_FIXED_ID) { mvreg_write(pp, MVNETA_PHY_ADDR, pp->phydev->addr);
@@ -1176,7 +1176,7 @@ static void mvneta_adjust_link(struct udevice *dev) * be added). Also, why is ADVERT_FC enabled if we don't enable * inband AN at all? */ - if (CONFIG_IS_ENABLED(PHY_FIXED) && + if (IS_ENABLED(CONFIG_PHY_FIXED) && pp->phydev->phy_id == PHY_FIXED_ID) val = MVNETA_GMAC_IB_BYPASS_AN_EN | MVNETA_GMAC_SET_FC_EN | diff --git a/net/mdio-uclass.c b/net/mdio-uclass.c index 4401492ca01..989ab3e4c96 100644 --- a/net/mdio-uclass.c +++ b/net/mdio-uclass.c @@ -171,7 +171,7 @@ static struct phy_device *dm_eth_connect_phy_handle(struct udevice *ethdev, struct phy_device *phy; ofnode phynode;
- if (CONFIG_IS_ENABLED(PHY_FIXED) && + if (IS_ENABLED(CONFIG_PHY_FIXED) && ofnode_phy_is_fixed_link(dev_ofnode(ethdev), &phynode)) { phy = phy_connect(NULL, 0, ethdev, interface); goto out;
This converts 2 usages of this option to the non-SPL form, since there is no SPL_PMIC_STPMIC1 defined in Kconfig
arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c index 9c4ba407ba0..baa156acf9e 100644 --- a/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c +++ b/arch/arm/mach-stm32mp/cmd_stm32prog/stm32prog.c @@ -1583,7 +1583,7 @@ int stm32prog_pmic_read(struct stm32prog_data *data, u32 offset, u8 *buffer, int result = 0, ret; struct udevice *dev;
- if (!CONFIG_IS_ENABLED(PMIC_STPMIC1)) { + if (!IS_ENABLED(CONFIG_PMIC_STPMIC1)) { stm32prog_err("PMIC update not supported");
return -EOPNOTSUPP; @@ -1633,7 +1633,7 @@ int stm32prog_pmic_start(struct stm32prog_data *data) int ret; struct udevice *dev;
return -EOPNOTSUPP;
This converts 1 usage of this option to the non-SPL form, since there is no SPL_QFW_PIO defined in Kconfig
arch/x86/cpu/qemu/qemu.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/x86/cpu/qemu/qemu.c b/arch/x86/cpu/qemu/qemu.c index e54082df7f9..4f28dc75b70 100644 --- a/arch/x86/cpu/qemu/qemu.c +++ b/arch/x86/cpu/qemu/qemu.c @@ -17,7 +17,7 @@
static bool i440fx;
-#if CONFIG_IS_ENABLED(QFW_PIO) +#if IS_ENABLED(CONFIG_QFW_PIO) U_BOOT_DRVINFO(x86_qfw_pio) = { .name = "qfw_pio", };
This converts 1 usage of this option to the non-SPL form, since there is no SPL_REGEX defined in Kconfig
board/xilinx/common/board.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/xilinx/common/board.c b/board/xilinx/common/board.c index bed15319934..d071ebfb9cc 100644 --- a/board/xilinx/common/board.c +++ b/board/xilinx/common/board.c @@ -481,7 +481,7 @@ int __maybe_unused board_fit_config_name_match(const char *name) debug("%s: Check %s, default %s\n", __func__, name, board_name);
#if !defined(CONFIG_SPL_BUILD) - if (CONFIG_IS_ENABLED(REGEX)) { + if (IS_ENABLED(CONFIG_REGEX)) { struct slre slre; int ret;
This converts 1 usage of this option to the non-SPL form, since there is no SPL_RENESAS_SDHI defined in Kconfig
drivers/mmc/tmio-common.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mmc/tmio-common.h b/drivers/mmc/tmio-common.h index 59d5a0e22e9..b1556bba5d9 100644 --- a/drivers/mmc/tmio-common.h +++ b/drivers/mmc/tmio-common.h @@ -139,7 +139,7 @@ struct tmio_sd_priv { #if CONFIG_IS_ENABLED(CLK) struct clk clk; #endif -#if CONFIG_IS_ENABLED(RENESAS_SDHI) +#if IS_ENABLED(CONFIG_RENESAS_SDHI) unsigned int smpcmp; u8 tap_set; u8 tap_num;
This converts 1 usage of this option to the non-SPL form, since there is no SPL_RESV_RAM defined in Kconfig
board/traverse/ten64/ten64.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/traverse/ten64/ten64.c b/board/traverse/ten64/ten64.c index 13aafb5de76..9e4c84ad2f4 100644 --- a/board/traverse/ten64/ten64.c +++ b/board/traverse/ten64/ten64.c @@ -211,7 +211,7 @@ int ft_board_setup(void *blob, struct bd_info *bd) base[i] = gd->bd->bi_dram[i].start; size[i] = gd->bd->bi_dram[i].size; /* reduce size if reserved memory is within this bank */ - if (CONFIG_IS_ENABLED(RESV_RAM) && RESV_MEM_IN_BANK(i)) + if (IS_ENABLED(CONFIG_RESV_RAM) && RESV_MEM_IN_BANK(i)) size[i] = gd->arch.resv_ram - base[i]; }
This converts 2 usages of this option to the non-SPL form, since there is no SPL_ROCKCHIP_EFUSE defined in Kconfig
arch/arm/mach-rockchip/misc.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-rockchip/misc.c b/arch/arm/mach-rockchip/misc.c index 01aedadf2c6..437c7cf896a 100644 --- a/arch/arm/mach-rockchip/misc.c +++ b/arch/arm/mach-rockchip/misc.c @@ -60,12 +60,12 @@ int rockchip_cpuid_from_efuse(const u32 cpuid_offset, const u32 cpuid_length, u8 *cpuid) { -#if CONFIG_IS_ENABLED(ROCKCHIP_EFUSE) || CONFIG_IS_ENABLED(ROCKCHIP_OTP) +#if IS_ENABLED(CONFIG_ROCKCHIP_EFUSE) || CONFIG_IS_ENABLED(ROCKCHIP_OTP) struct udevice *dev; int ret;
/* retrieve the device */ -#if CONFIG_IS_ENABLED(ROCKCHIP_EFUSE) +#if IS_ENABLED(CONFIG_ROCKCHIP_EFUSE) ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(rockchip_efuse), &dev); #elif CONFIG_IS_ENABLED(ROCKCHIP_OTP)
This converts 2 usages of this option to the non-SPL form, since there is no SPL_ROCKCHIP_OTP defined in Kconfig
diff --git a/arch/arm/mach-rockchip/misc.c b/arch/arm/mach-rockchip/misc.c index 437c7cf896a..b350f18f114 100644 --- a/arch/arm/mach-rockchip/misc.c +++ b/arch/arm/mach-rockchip/misc.c @@ -60,7 +60,7 @@ int rockchip_cpuid_from_efuse(const u32 cpuid_offset, const u32 cpuid_length, u8 *cpuid) { -#if IS_ENABLED(CONFIG_ROCKCHIP_EFUSE) || CONFIG_IS_ENABLED(ROCKCHIP_OTP) +#if IS_ENABLED(CONFIG_ROCKCHIP_EFUSE) || IS_ENABLED(CONFIG_ROCKCHIP_OTP) struct udevice *dev; int ret;
@@ -68,7 +68,7 @@ int rockchip_cpuid_from_efuse(const u32 cpuid_offset, #if IS_ENABLED(CONFIG_ROCKCHIP_EFUSE) ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(rockchip_efuse), &dev); -#elif CONFIG_IS_ENABLED(ROCKCHIP_OTP) +#elif IS_ENABLED(CONFIG_ROCKCHIP_OTP) ret = uclass_get_device_by_driver(UCLASS_MISC, DM_DRIVER_GET(rockchip_otp), &dev); #endif
This converts 1 usage of this option to the non-SPL form, since there is no SPL_SANDBOX defined in Kconfig
drivers/pinctrl/pinctrl-single.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/pinctrl/pinctrl-single.c b/drivers/pinctrl/pinctrl-single.c index bc9c17bce84..d80281fd3dd 100644 --- a/drivers/pinctrl/pinctrl-single.c +++ b/drivers/pinctrl/pinctrl-single.c @@ -541,7 +541,7 @@ static int single_probe(struct udevice *dev) INIT_LIST_HEAD(&priv->gpiofuncs);
size = pdata->offset + pdata->width / BITS_PER_BYTE; - #if (CONFIG_IS_ENABLED(SANDBOX)) + #if (IS_ENABLED(CONFIG_SANDBOX)) priv->sandbox_regs = devm_kzalloc(dev, size * sizeof(*priv->sandbox_regs), GFP_KERNEL);
This converts 12 usages of this option to the non-SPL form, since there is no SPL_SANDBOX_CLK_CCF defined in Kconfig
drivers/clk/clk-divider.c | 4 ++-- drivers/clk/clk-gate.c | 6 +++--- drivers/clk/clk-mux.c | 8 ++++---- include/linux/clk-provider.h | 6 +++--- 4 files changed, 12 insertions(+), 12 deletions(-)
diff --git a/drivers/clk/clk-divider.c b/drivers/clk/clk-divider.c index 7e8e62feeee..6ab137a72be 100644 --- a/drivers/clk/clk-divider.c +++ b/drivers/clk/clk-divider.c @@ -81,7 +81,7 @@ static ulong clk_divider_recalc_rate(struct clk *clk) unsigned long parent_rate = clk_get_parent_rate(clk); unsigned int val;
-#if CONFIG_IS_ENABLED(SANDBOX_CLK_CCF) +#if IS_ENABLED(CONFIG_SANDBOX_CLK_CCF) val = divider->io_divider_val; #else val = readl(divider->reg); @@ -210,7 +210,7 @@ static struct clk *_register_divider(struct device *dev, const char *name, div->width = width; div->flags = clk_divider_flags; div->table = table; -#if CONFIG_IS_ENABLED(SANDBOX_CLK_CCF) +#if IS_ENABLED(CONFIG_SANDBOX_CLK_CCF) div->io_divider_val = *(u32 *)reg; #endif
diff --git a/drivers/clk/clk-gate.c b/drivers/clk/clk-gate.c index aa40daf3d79..a8775c77dc2 100644 --- a/drivers/clk/clk-gate.c +++ b/drivers/clk/clk-gate.c @@ -62,7 +62,7 @@ static void clk_gate_endisable(struct clk *clk, int enable) if (set) reg |= BIT(gate->bit_idx); } else { -#if CONFIG_IS_ENABLED(SANDBOX_CLK_CCF) +#if IS_ENABLED(CONFIG_SANDBOX_CLK_CCF) reg = gate->io_gate_val; #else reg = readl(gate->reg); @@ -96,7 +96,7 @@ int clk_gate_is_enabled(struct clk *clk) struct clk_gate *gate = to_clk_gate(clk); u32 reg;
-#if CONFIG_IS_ENABLED(SANDBOX_CLK_CCF) +#if IS_ENABLED(CONFIG_SANDBOX_CLK_CCF) reg = gate->io_gate_val; #else reg = readl(gate->reg); @@ -142,7 +142,7 @@ struct clk *clk_register_gate(struct device *dev, const char *name, gate->reg = reg; gate->bit_idx = bit_idx; gate->flags = clk_gate_flags; -#if CONFIG_IS_ENABLED(SANDBOX_CLK_CCF) +#if IS_ENABLED(CONFIG_SANDBOX_CLK_CCF) gate->io_gate_val = *(u32 *)reg; #endif
diff --git a/drivers/clk/clk-mux.c b/drivers/clk/clk-mux.c index b49946fbcd5..184d426d0b3 100644 --- a/drivers/clk/clk-mux.c +++ b/drivers/clk/clk-mux.c @@ -90,7 +90,7 @@ u8 clk_mux_get_parent(struct clk *clk) struct clk_mux *mux = to_clk_mux(clk); u32 val;
-#if CONFIG_IS_ENABLED(SANDBOX_CLK_CCF) +#if IS_ENABLED(CONFIG_SANDBOX_CLK_CCF) val = mux->io_mux_val; #else val = readl(mux->reg); @@ -137,7 +137,7 @@ static int clk_mux_set_parent(struct clk *clk, struct clk *parent) if (mux->flags & CLK_MUX_HIWORD_MASK) { reg = mux->mask << (mux->shift + 16); } else { -#if CONFIG_IS_ENABLED(SANDBOX_CLK_CCF) +#if IS_ENABLED(CONFIG_SANDBOX_CLK_CCF) reg = mux->io_mux_val; #else reg = readl(mux->reg); @@ -146,7 +146,7 @@ static int clk_mux_set_parent(struct clk *clk, struct clk *parent) } val = val << mux->shift; reg |= val; -#if CONFIG_IS_ENABLED(SANDBOX_CLK_CCF) +#if IS_ENABLED(CONFIG_SANDBOX_CLK_CCF) mux->io_mux_val = reg; #else writel(reg, mux->reg); @@ -194,7 +194,7 @@ struct clk *clk_hw_register_mux_table(struct device *dev, const char *name, mux->mask = mask; mux->flags = clk_mux_flags; mux->table = table; -#if CONFIG_IS_ENABLED(SANDBOX_CLK_CCF) +#if IS_ENABLED(CONFIG_SANDBOX_CLK_CCF) mux->io_mux_val = *(u32 *)reg; #endif
diff --git a/include/linux/clk-provider.h b/include/linux/clk-provider.h index 2d04882d053..b8acacd49ee 100644 --- a/include/linux/clk-provider.h +++ b/include/linux/clk-provider.h @@ -65,7 +65,7 @@ struct clk_mux { */ const char * const *parent_names; u8 num_parents; -#if CONFIG_IS_ENABLED(SANDBOX_CLK_CCF) +#if IS_ENABLED(CONFIG_SANDBOX_CLK_CCF) u32 io_mux_val; #endif
@@ -93,7 +93,7 @@ struct clk_gate { void __iomem *reg; u8 bit_idx; u8 flags; -#if CONFIG_IS_ENABLED(SANDBOX_CLK_CCF) +#if IS_ENABLED(CONFIG_SANDBOX_CLK_CCF) u32 io_gate_val; #endif }; @@ -121,7 +121,7 @@ struct clk_divider { u8 width; u8 flags; const struct clk_div_table *table; -#if CONFIG_IS_ENABLED(SANDBOX_CLK_CCF) +#if IS_ENABLED(CONFIG_SANDBOX_CLK_CCF) u32 io_divider_val; #endif };
This converts 2 usages of this option to the non-SPL form, since there is no SPL_SAVE_PREV_BL_FDT_ADDR defined in Kconfig
arch/arm/lib/save_prev_bl_data.c | 2 +- common/board_r.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/lib/save_prev_bl_data.c b/arch/arm/lib/save_prev_bl_data.c index f4ee86a89c6..cd943eefe10 100644 --- a/arch/arm/lib/save_prev_bl_data.c +++ b/arch/arm/lib/save_prev_bl_data.c @@ -60,7 +60,7 @@ int save_prev_bl_data(void) return -ENODATA; }
- if (CONFIG_IS_ENABLED(SAVE_PREV_BL_FDT_ADDR)) + if (IS_ENABLED(CONFIG_SAVE_PREV_BL_FDT_ADDR)) env_set_addr("prevbl_fdt_addr", (void *)reg0); if (!CONFIG_IS_ENABLED(SAVE_PREV_BL_INITRAMFS_START_ADDR)) return 0; diff --git a/common/board_r.c b/common/board_r.c index 2cd66eac803..56c50f43baf 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -453,7 +453,7 @@ static int initr_env(void) (unsigned long)map_to_sysmem(gd->fdt_blob));
#if (CONFIG_IS_ENABLED(SAVE_PREV_BL_INITRAMFS_START_ADDR) || \ - CONFIG_IS_ENABLED(SAVE_PREV_BL_FDT_ADDR)) + IS_ENABLED(CONFIG_SAVE_PREV_BL_FDT_ADDR)) save_prev_bl_data(); #endif
This converts 2 usages of this option to the non-SPL form, since there is no SPL_SAVE_PREV_BL_INITRAMFS_START_ADDR defined in Kconfig
diff --git a/arch/arm/lib/save_prev_bl_data.c b/arch/arm/lib/save_prev_bl_data.c index cd943eefe10..f7b23faf0d6 100644 --- a/arch/arm/lib/save_prev_bl_data.c +++ b/arch/arm/lib/save_prev_bl_data.c @@ -62,7 +62,7 @@ int save_prev_bl_data(void)
if (IS_ENABLED(CONFIG_SAVE_PREV_BL_FDT_ADDR)) env_set_addr("prevbl_fdt_addr", (void *)reg0); - if (!CONFIG_IS_ENABLED(SAVE_PREV_BL_INITRAMFS_START_ADDR)) + if (!IS_ENABLED(CONFIG_SAVE_PREV_BL_INITRAMFS_START_ADDR)) return 0;
node = fdt_path_offset(fdt_blob, "/chosen"); diff --git a/common/board_r.c b/common/board_r.c index 56c50f43baf..df88a9dd63b 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -452,7 +452,7 @@ static int initr_env(void) env_set_hex("fdtcontroladdr", (unsigned long)map_to_sysmem(gd->fdt_blob));
- #if (CONFIG_IS_ENABLED(SAVE_PREV_BL_INITRAMFS_START_ADDR) || \ + #if (IS_ENABLED(CONFIG_SAVE_PREV_BL_INITRAMFS_START_ADDR) || \ IS_ENABLED(CONFIG_SAVE_PREV_BL_FDT_ADDR)) save_prev_bl_data(); #endif
This converts 2 usages of this option to the non-SPL form, since there is no SPL_SEC_FIRMWARE_ARMV8_PSCI defined in Kconfig
arch/arm/cpu/armv8/cpu-dt.c | 2 +- arch/arm/lib/bootm-fdt.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv8/cpu-dt.c b/arch/arm/cpu/armv8/cpu-dt.c index 9bfe3815e51..afb2dd6c5b6 100644 --- a/arch/arm/cpu/armv8/cpu-dt.c +++ b/arch/arm/cpu/armv8/cpu-dt.c @@ -18,7 +18,7 @@ __weak int psci_update_dt(void *fdt) * number to support detecting PSCI dynamically and then switching * the SMP boot method between PSCI and spin-table. */ - if (CONFIG_IS_ENABLED(SEC_FIRMWARE_ARMV8_PSCI) && + if (IS_ENABLED(CONFIG_SEC_FIRMWARE_ARMV8_PSCI) && sec_firmware_support_psci_version() == PSCI_INVALID_VER) return 0;
diff --git a/arch/arm/lib/bootm-fdt.c b/arch/arm/lib/bootm-fdt.c index 29020bd1c6b..69e688f677f 100644 --- a/arch/arm/lib/bootm-fdt.c +++ b/arch/arm/lib/bootm-fdt.c @@ -64,7 +64,7 @@ int arch_fixup_fdt(void *blob) #endif
#if defined(CONFIG_ARMV7_NONSEC) || defined(CONFIG_ARMV8_PSCI) || \ - CONFIG_IS_ENABLED(SEC_FIRMWARE_ARMV8_PSCI) + IS_ENABLED(CONFIG_SEC_FIRMWARE_ARMV8_PSCI) ret = psci_update_dt(blob); if (ret) return ret;
This converts 2 usages of this option to the non-SPL form, since there is no SPL_SIFIVE_OTP defined in Kconfig
board/sifive/unleashed/unleashed.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/sifive/unleashed/unleashed.c b/board/sifive/unleashed/unleashed.c index f8aad862c6d..b6ab06a08fb 100644 --- a/board/sifive/unleashed/unleashed.c +++ b/board/sifive/unleashed/unleashed.c @@ -27,7 +27,7 @@
#ifdef CONFIG_MISC_INIT_R
-#if CONFIG_IS_ENABLED(SIFIVE_OTP) +#if IS_ENABLED(CONFIG_SIFIVE_OTP) static u32 otp_read_serialnum(struct udevice *dev) { int ret; @@ -53,7 +53,7 @@ static u32 fu540_read_serialnum(void) { u32 serial = ERROR_READING_SERIAL_NUMBER;
-#if CONFIG_IS_ENABLED(SIFIVE_OTP) +#if IS_ENABLED(CONFIG_SIFIVE_OTP) struct udevice *dev; int ret;
This converts 1 usage of this option to the non-SPL form, since there is no SPL_SL28CPLD defined in Kconfig
board/kontron/sl28/sl28.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/kontron/sl28/sl28.c b/board/kontron/sl28/sl28.c index 4ad6b323476..257923685a5 100644 --- a/board/kontron/sl28/sl28.c +++ b/board/kontron/sl28/sl28.c @@ -109,7 +109,7 @@ static void print_cpld_version(void) int checkboard(void) { printf("EL: %d\n", current_el()); - if (CONFIG_IS_ENABLED(SL28CPLD)) + if (IS_ENABLED(CONFIG_SL28CPLD)) print_cpld_version();
This converts 1 usage of this option to the non-SPL form, since there is no SPL_SL28_SPL_LOADS_OPTEE_BL32 defined in Kconfig
diff --git a/board/kontron/sl28/sl28.c b/board/kontron/sl28/sl28.c index 257923685a5..e78a0d5dd3c 100644 --- a/board/kontron/sl28/sl28.c +++ b/board/kontron/sl28/sl28.c @@ -188,7 +188,7 @@ int ft_board_setup(void *blob, struct bd_info *bd)
fdt_fixup_icid(blob);
- if (CONFIG_IS_ENABLED(SL28_SPL_LOADS_OPTEE_BL32)) { + if (IS_ENABLED(CONFIG_SL28_SPL_LOADS_OPTEE_BL32)) { node = fdt_node_offset_by_compatible(blob, -1, "linaro,optee-tz"); if (node) fdt_set_node_status(blob, node, FDT_STATUS_OKAY);
This converts 1 usage of this option to the non-SPL form, since there is no SPL_SPI_FLASH_BAR defined in Kconfig
drivers/mtd/spi/spi-nor-core.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mtd/spi/spi-nor-core.c b/drivers/mtd/spi/spi-nor-core.c index 2c3116ee530..d410ae58953 100644 --- a/drivers/mtd/spi/spi-nor-core.c +++ b/drivers/mtd/spi/spi-nor-core.c @@ -3894,7 +3894,7 @@ void spi_nor_set_fixups(struct spi_nor *nor) } }
- if (CONFIG_IS_ENABLED(SPI_FLASH_BAR) && + if (IS_ENABLED(CONFIG_SPI_FLASH_BAR) && !strcmp(nor->info->name, "s25fl256l")) nor->fixups = &s25fl256l_fixups; #endif
This converts 2 usages of this option to the non-SPL form, since there is no SPL_SPI_FLASH_MACRONIX defined in Kconfig
drivers/mtd/spi/spi-nor-core.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/spi/spi-nor-core.c b/drivers/mtd/spi/spi-nor-core.c index d410ae58953..3f97acdb18c 100644 --- a/drivers/mtd/spi/spi-nor-core.c +++ b/drivers/mtd/spi/spi-nor-core.c @@ -3645,7 +3645,7 @@ static struct spi_nor_fixups mt35xu512aba_fixups = { }; #endif /* CONFIG_SPI_FLASH_MT35XU */
-#if CONFIG_IS_ENABLED(SPI_FLASH_MACRONIX) +#if IS_ENABLED(CONFIG_SPI_FLASH_MACRONIX) /** * spi_nor_macronix_octal_dtr_enable() - Enable octal DTR on Macronix flashes. * @nor: pointer to a 'struct spi_nor' @@ -3904,7 +3904,7 @@ void spi_nor_set_fixups(struct spi_nor *nor) nor->fixups = &mt35xu512aba_fixups; #endif
-#if CONFIG_IS_ENABLED(SPI_FLASH_MACRONIX) +#if IS_ENABLED(CONFIG_SPI_FLASH_MACRONIX) nor->fixups = ¯onix_octal_fixups; #endif /* SPI_FLASH_MACRONIX */ }
This converts 1 usage of this option to the non-SPL form, since there is no SPL_SPLASH_SOURCE defined in Kconfig
common/splash.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/splash.c b/common/splash.c index 2e466a8a0f5..245ff680ebd 100644 --- a/common/splash.c +++ b/common/splash.c @@ -89,7 +89,7 @@ static inline int splash_video_logo_load(void) { return -ENOSYS; }
__weak int splash_screen_prepare(void) { - if (CONFIG_IS_ENABLED(SPLASH_SOURCE)) + if (IS_ENABLED(CONFIG_SPLASH_SOURCE)) return splash_source_load(default_splash_locations, ARRAY_SIZE(default_splash_locations));
This converts 1 usage of this option to the non-SPL form, since there is no SPL_STM32MP15X_STM32IMAGE defined in Kconfig
arch/arm/mach-stm32mp/fdt.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-stm32mp/fdt.c b/arch/arm/mach-stm32mp/fdt.c index 218d9ef282a..c21c5c42fe1 100644 --- a/arch/arm/mach-stm32mp/fdt.c +++ b/arch/arm/mach-stm32mp/fdt.c @@ -505,7 +505,7 @@ int ft_system_setup(void *blob, struct bd_info *bd) * under CONFIG_STM32MP15X_STM32IMAGE only for compatibility * when FIP is not used by TF-A */ - if (CONFIG_IS_ENABLED(STM32MP15X_STM32IMAGE) && + if (IS_ENABLED(CONFIG_STM32MP15X_STM32IMAGE) && !tee_find_device(NULL, NULL, NULL, NULL)) stm32_fdt_disable_optee(blob); }
This converts 1 usage of this option to the non-SPL form, since there is no SPL_SUPPORT_EMMC_RPMB defined in Kconfig
drivers/mmc/Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/mmc/Makefile b/drivers/mmc/Makefile index 3a664c2ebbb..3dc757108d5 100644 --- a/drivers/mmc/Makefile +++ b/drivers/mmc/Makefile @@ -46,7 +46,7 @@ obj-$(CONFIG_MMC_MXS) += mxsmmc.o obj-$(CONFIG_MMC_OCTEONTX) += octeontx_hsmmc.o obj-$(CONFIG_MMC_OWL) += owl_mmc.o obj-$(CONFIG_MMC_PCI) += pci_mmc.o -obj-$(CONFIG_$(SPL_TPL_)SUPPORT_EMMC_RPMB) += rpmb.o +obj-$(CONFIG_SUPPORT_EMMC_RPMB) += rpmb.o obj-$(CONFIG_MMC_SANDBOX) += sandbox_mmc.o obj-$(CONFIG_SH_MMCIF) += sh_mmcif.o obj-$(CONFIG_SH_SDHI) += sh_sdhi.o
This converts 1 usage of this option to the non-SPL form, since there is no SPL_SYS_FSL_ERRATUM_A010539 defined in Kconfig
arch/arm/cpu/armv8/fsl-layerscape/cpu.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c index b0e86785337..12d31184ad9 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/cpu.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/cpu.c @@ -760,7 +760,7 @@ enum boot_src __get_boot_src(u32 porsr1) } #endif
- if (CONFIG_IS_ENABLED(SYS_FSL_ERRATUM_A010539) && !rcw_src) + if (IS_ENABLED(CONFIG_SYS_FSL_ERRATUM_A010539) && !rcw_src) src = BOOT_SOURCE_QSPI_NOR;
debug("%s: src 0x%x\n", __func__, src);
This converts 5 usages of this option to the non-SPL form, since there is no SPL_SYS_LONGHELP defined in Kconfig
cmd/bootcount.c | 4 ++-- cmd/cpu.c | 2 +- cmd/dm.c | 2 +- cmd/ti/pd.c | 2 +- 4 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/cmd/bootcount.c b/cmd/bootcount.c index 654bbb805c1..3898d2543d2 100644 --- a/cmd/bootcount.c +++ b/cmd/bootcount.c @@ -46,7 +46,7 @@ static int do_bootcount(struct cmd_tbl *cmdtp, int flag, int argc, return CMD_RET_USAGE; }
-#if CONFIG_IS_ENABLED(SYS_LONGHELP) +#if IS_ENABLED(CONFIG_SYS_LONGHELP) static char bootcount_help_text[] = "print - print current bootcounter\n" "reset - reset the bootcounter" @@ -55,7 +55,7 @@ static char bootcount_help_text[] =
U_BOOT_CMD(bootcount, 2, 1, do_bootcount, "bootcount", -#if CONFIG_IS_ENABLED(SYS_LONGHELP) +#if IS_ENABLED(CONFIG_SYS_LONGHELP) bootcount_help_text #endif ); diff --git a/cmd/cpu.c b/cmd/cpu.c index a09736e1bb9..314852440f1 100644 --- a/cmd/cpu.c +++ b/cmd/cpu.c @@ -83,7 +83,7 @@ static int do_cpu_detail(struct cmd_tbl *cmdtp, int flag, int argc, return 0; }
-#if CONFIG_IS_ENABLED(SYS_LONGHELP) +#if IS_ENABLED(CONFIG_SYS_LONGHELP) static char cpu_help_text[] = "list - list available CPUs\n" "cpu detail - show CPU detail" diff --git a/cmd/dm.c b/cmd/dm.c index 979cd36061e..3263547cbec 100644 --- a/cmd/dm.c +++ b/cmd/dm.c @@ -84,7 +84,7 @@ static int do_dm_dump_uclass(struct cmd_tbl *cmdtp, int flag, int argc, #define DM_MEM #endif
-#if CONFIG_IS_ENABLED(SYS_LONGHELP) +#if IS_ENABLED(CONFIG_SYS_LONGHELP) static char dm_help_text[] = "compat Dump list of drivers with compatibility strings\n" "dm devres Dump list of device resources for each device\n" diff --git a/cmd/ti/pd.c b/cmd/ti/pd.c index 008668fd903..a9a182fc386 100644 --- a/cmd/ti/pd.c +++ b/cmd/ti/pd.c @@ -177,7 +177,7 @@ static int ti_do_pd(struct cmd_tbl *cmdtp, int flag, int argc, char * const argv
U_BOOT_CMD(pd, 4, 1, ti_do_pd, "TI power domain control", -#if CONFIG_IS_ENABLED(SYS_LONGHELP) +#if IS_ENABLED(CONFIG_SYS_LONGHELP) "dump - show power domain status\n" "enable [psc] [lpsc] - enable power domain\n" "disable [psc] [lpsc] - disable power domain\n"
This converts 1 usage of this option to the non-SPL form, since there is no SPL_SYS_MEM_RSVD_FOR_MMU defined in Kconfig
board/xilinx/versal-net/board.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/xilinx/versal-net/board.c b/board/xilinx/versal-net/board.c index 7ff2c620110..6724c7290f8 100644 --- a/board/xilinx/versal-net/board.c +++ b/board/xilinx/versal-net/board.c @@ -195,7 +195,7 @@ int dram_init(void) { int ret;
- if (CONFIG_IS_ENABLED(SYS_MEM_RSVD_FOR_MMU)) + if (IS_ENABLED(CONFIG_SYS_MEM_RSVD_FOR_MMU)) ret = fdtdec_setup_mem_size_base(); else ret = fdtdec_setup_mem_size_base_lowest();
This converts 3 usages of this option to the non-SPL form, since there is no SPL_TARGET_LX2160ARDB defined in Kconfig
board/freescale/lx2160a/lx2160a.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/board/freescale/lx2160a/lx2160a.c b/board/freescale/lx2160a/lx2160a.c index cf5b1ee46e0..d8a86cdf618 100644 --- a/board/freescale/lx2160a/lx2160a.c +++ b/board/freescale/lx2160a/lx2160a.c @@ -676,7 +676,7 @@ void board_quiesce_devices(void) } #endif
-#if CONFIG_IS_ENABLED(TARGET_LX2160ARDB) +#if IS_ENABLED(CONFIG_TARGET_LX2160ARDB) int fdt_fixup_add_thermal(void *blob, int mux_node, int channel, int reg) { int err; @@ -798,7 +798,7 @@ int ft_board_setup(void *blob, struct bd_info *bd) u64 mc_memory_size = 0; u16 total_memory_banks; int err; -#if CONFIG_IS_ENABLED(TARGET_LX2160ARDB) +#if IS_ENABLED(CONFIG_TARGET_LX2160ARDB) u8 board_rev; #endif
@@ -862,7 +862,7 @@ int ft_board_setup(void *blob, struct bd_info *bd) #endif fdt_fixup_icid(blob);
-#if CONFIG_IS_ENABLED(TARGET_LX2160ARDB) +#if IS_ENABLED(CONFIG_TARGET_LX2160ARDB) board_rev = (QIXIS_READ(arch) & 0xf) - 1 + 'A'; if (board_rev == 'C') fdt_fixup_i2c_thermal_node(blob);
This converts 1 usage of this option to the non-SPL form, since there is no SPL_TARGET_MX6UL_9X9_EVK defined in Kconfig
include/configs/mx6ul_14x14_evk.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/mx6ul_14x14_evk.h b/include/configs/mx6ul_14x14_evk.h index 635ae78abcb..98b743b9364 100644 --- a/include/configs/mx6ul_14x14_evk.h +++ b/include/configs/mx6ul_14x14_evk.h @@ -13,7 +13,7 @@ #include "mx6_common.h" #include <asm/mach-imx/gpio.h>
-#define is_mx6ul_9x9_evk() CONFIG_IS_ENABLED(TARGET_MX6UL_9X9_EVK) +#define is_mx6ul_9x9_evk() IS_ENABLED(CONFIG_TARGET_MX6UL_9X9_EVK)
#define CFG_MXC_UART_BASE UART1_BASE
This converts 1 usage of this option to the non-SPL form, since there is no SPL_TARGET_PG_WCOM_EXPU1 defined in Kconfig
board/keymile/pg-wcom-ls102xa/pg-wcom-ls102xa.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/board/keymile/pg-wcom-ls102xa/pg-wcom-ls102xa.c b/board/keymile/pg-wcom-ls102xa/pg-wcom-ls102xa.c index e005ece469b..c65cd9cdc9b 100644 --- a/board/keymile/pg-wcom-ls102xa/pg-wcom-ls102xa.c +++ b/board/keymile/pg-wcom-ls102xa/pg-wcom-ls102xa.c @@ -79,7 +79,7 @@ int board_early_init_f(void) qrio_wdmask(KM_PAXK_RST, true); #endif
-#if CONFIG_IS_ENABLED(TARGET_PG_WCOM_EXPU1) +#if IS_ENABLED(CONFIG_TARGET_PG_WCOM_EXPU1) qrio_prstcfg(WCOM_TMG_RST, PRSTCFG_POWUP_UNIT_RST); qrio_wdmask(WCOM_TMG_RST, true);
Regards, Aleksandar
This converts 1 usage of this option to the non-SPL form, since there is no SPL_TARGET_PG_WCOM_SELI8 defined in Kconfig
diff --git a/board/keymile/pg-wcom-ls102xa/pg-wcom-ls102xa.c b/board/keymile/pg-wcom-ls102xa/pg-wcom-ls102xa.c index c65cd9cdc9b..2f1731eea6a 100644 --- a/board/keymile/pg-wcom-ls102xa/pg-wcom-ls102xa.c +++ b/board/keymile/pg-wcom-ls102xa/pg-wcom-ls102xa.c @@ -71,7 +71,7 @@ int board_early_init_f(void) /* QRIO Configuration */ qrio_uprstreq(UPREQ_CORE_RST);
-#if CONFIG_IS_ENABLED(TARGET_PG_WCOM_SELI8) +#if IS_ENABLED(CONFIG_TARGET_PG_WCOM_SELI8) qrio_prstcfg(KM_LIU_RST, PRSTCFG_POWUP_UNIT_RST); qrio_wdmask(KM_LIU_RST, true);
Regards, Aleksandar
This converts 1 usage of this option to the non-SPL form, since there is no SPL_TEE defined in Kconfig
include/tee.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/tee.h b/include/tee.h index 13f6096b9a6..ab0c5832613 100644 --- a/include/tee.h +++ b/include/tee.h @@ -328,7 +328,7 @@ bool tee_shm_is_registered(struct tee_shm *shm, struct udevice *dev); * Returns a probed TEE device of the first TEE device matched by the * match() callback or NULL. */ -#if CONFIG_IS_ENABLED(TEE) +#if IS_ENABLED(CONFIG_TEE) struct udevice *tee_find_device(struct udevice *start, int (*match)(struct tee_version_data *vers, const void *data),
This converts 2 usages of this option to the non-SPL form, since there is no SPL_TEN64_CONTROLLER defined in Kconfig
board/traverse/ten64/ten64.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/board/traverse/ten64/ten64.c b/board/traverse/ten64/ten64.c index 9e4c84ad2f4..5dfb7165c0e 100644 --- a/board/traverse/ten64/ten64.c +++ b/board/traverse/ten64/ten64.c @@ -97,7 +97,7 @@ int checkboard(void) printf("Unknown boot source %d\n", src);
puts("Controller: "); - if (CONFIG_IS_ENABLED(TEN64_CONTROLLER)) { + if (IS_ENABLED(CONFIG_TEN64_CONTROLLER)) { /* Driver not compatible with alpha/beta board MCU firmware */ if (board_rev <= TEN64_BOARD_REV_C) { if (ten64_read_board_info(&boardinfo)) { @@ -375,7 +375,7 @@ static void ten64_board_retimer_ds110df410_init(void) /* Retimer power cycle not implemented on early board * revisions/controller firmwares */ - if (CONFIG_IS_ENABLED(TEN64_CONTROLLER) && + if (IS_ENABLED(CONFIG_TEN64_CONTROLLER) && board_rev >= TEN64_BOARD_REV_C) { ret = board_cycle_retimer(&retim_dev); if (ret) {
This converts 1 usage of this option to the non-SPL form, since there is no SPL_TPM_RNG defined in Kconfig
drivers/tpm/tpm-uclass.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/tpm/tpm-uclass.c b/drivers/tpm/tpm-uclass.c index 5ff0cd3958c..b2286f7e7ed 100644 --- a/drivers/tpm/tpm-uclass.c +++ b/drivers/tpm/tpm-uclass.c @@ -156,7 +156,7 @@ static int tpm_uclass_post_probe(struct udevice *dev) const char *drv = TPM_RNG_DRV_NAME; struct udevice *child;
- if (CONFIG_IS_ENABLED(TPM_RNG)) { + if (IS_ENABLED(CONFIG_TPM_RNG)) { ret = device_find_first_child_by_uclass(dev, UCLASS_RNG, &child);
This converts 1 usage of this option to the non-SPL form, since there is no SPL_UDP_FUNCTION_FASTBOOT defined in Kconfig
cmd/fastboot.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cmd/fastboot.c b/cmd/fastboot.c index b94dbd54884..17c53bbe277 100644 --- a/cmd/fastboot.c +++ b/cmd/fastboot.c @@ -21,7 +21,7 @@ static int do_fastboot_udp(int argc, char *const argv[], { int err;
- if (!CONFIG_IS_ENABLED(UDP_FUNCTION_FASTBOOT)) { + if (!IS_ENABLED(CONFIG_UDP_FUNCTION_FASTBOOT)) { pr_err("Fastboot UDP not enabled\n"); return CMD_RET_FAILURE; }
Reviewed-by: Mattijs Korpershoek mkorpershoek@baylibre.com
- if (!IS_ENABLED(CONFIG_UDP_FUNCTION_FASTBOOT)) { pr_err("Fastboot UDP not enabled\n"); return CMD_RET_FAILURE; }
This converts 1 usage of this option to the non-SPL form, since there is no SPL_USB_DWC3_MESON_G12A defined in Kconfig
arch/arm/mach-meson/board-g12a.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-meson/board-g12a.c b/arch/arm/mach-meson/board-g12a.c index 2e59eee8f79..d9f1acdef74 100644 --- a/arch/arm/mach-meson/board-g12a.c +++ b/arch/arm/mach-meson/board-g12a.c @@ -97,7 +97,7 @@ static struct mm_region g12a_mem_map[] = {
struct mm_region *mem_map = g12a_mem_map;
-#if CONFIG_IS_ENABLED(USB_DWC3_MESON_G12A) && \ +#if IS_ENABLED(CONFIG_USB_DWC3_MESON_G12A) && \ CONFIG_IS_ENABLED(USB_GADGET_DWC2_OTG) static struct dwc2_plat_otg_data meson_g12a_dwc2_data;
This converts 2 usages of this option to the non-SPL form, since there is no SPL_USB_DWC3_MESON_GXL defined in Kconfig
arch/arm/mach-meson/board-axg.c | 2 +- arch/arm/mach-meson/board-gx.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-meson/board-axg.c b/arch/arm/mach-meson/board-axg.c index 236ec815799..8bcb0b3a212 100644 --- a/arch/arm/mach-meson/board-axg.c +++ b/arch/arm/mach-meson/board-axg.c @@ -91,7 +91,7 @@ static struct mm_region axg_mem_map[] = {
struct mm_region *mem_map = axg_mem_map;
-#if CONFIG_IS_ENABLED(USB_DWC3_MESON_GXL) && \ +#if IS_ENABLED(CONFIG_USB_DWC3_MESON_GXL) && \ CONFIG_IS_ENABLED(USB_GADGET_DWC2_OTG) static struct dwc2_plat_otg_data meson_gx_dwc2_data;
diff --git a/arch/arm/mach-meson/board-gx.c b/arch/arm/mach-meson/board-gx.c index 01fafd81c48..41f767302ec 100644 --- a/arch/arm/mach-meson/board-gx.c +++ b/arch/arm/mach-meson/board-gx.c @@ -109,7 +109,7 @@ static struct mm_region gx_mem_map[] = {
struct mm_region *mem_map = gx_mem_map;
This code is getting removed in the last PR I sent at https://lore.kernel.org/all/ec3802ba-6e79-5370-e41e-cd2487cd618f@linaro.org/
This converts 1 usage of this option to the non-SPL form, since there is no SPL_USB_FUNCTION_FASTBOOT defined in Kconfig
diff --git a/cmd/fastboot.c b/cmd/fastboot.c index 17c53bbe277..97dc02ce748 100644 --- a/cmd/fastboot.c +++ b/cmd/fastboot.c @@ -44,7 +44,7 @@ static int do_fastboot_usb(int argc, char *const argv[], char *endp; int ret;
- if (!CONFIG_IS_ENABLED(USB_FUNCTION_FASTBOOT)) { + if (!IS_ENABLED(CONFIG_USB_FUNCTION_FASTBOOT)) { pr_err("Fastboot USB not enabled\n"); return CMD_RET_FAILURE; }
- if (!IS_ENABLED(CONFIG_USB_FUNCTION_FASTBOOT)) { pr_err("Fastboot USB not enabled\n"); return CMD_RET_FAILURE; }
This converts 3 usages of this option to the non-SPL form, since there is no SPL_USB_GADGET_DWC2_OTG defined in Kconfig
arch/arm/mach-meson/board-axg.c | 2 +- arch/arm/mach-meson/board-g12a.c | 2 +- arch/arm/mach-meson/board-gx.c | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-meson/board-axg.c b/arch/arm/mach-meson/board-axg.c index 8bcb0b3a212..4baf045d416 100644 --- a/arch/arm/mach-meson/board-axg.c +++ b/arch/arm/mach-meson/board-axg.c @@ -92,7 +92,7 @@ static struct mm_region axg_mem_map[] = { struct mm_region *mem_map = axg_mem_map;
#if IS_ENABLED(CONFIG_USB_DWC3_MESON_GXL) && \ - CONFIG_IS_ENABLED(USB_GADGET_DWC2_OTG) + IS_ENABLED(CONFIG_USB_GADGET_DWC2_OTG) static struct dwc2_plat_otg_data meson_gx_dwc2_data;
int board_usb_init(int index, enum usb_init_type init) diff --git a/arch/arm/mach-meson/board-g12a.c b/arch/arm/mach-meson/board-g12a.c index d9f1acdef74..46507c6a0f9 100644 --- a/arch/arm/mach-meson/board-g12a.c +++ b/arch/arm/mach-meson/board-g12a.c @@ -98,7 +98,7 @@ static struct mm_region g12a_mem_map[] = { struct mm_region *mem_map = g12a_mem_map;
#if IS_ENABLED(CONFIG_USB_DWC3_MESON_G12A) && \ - CONFIG_IS_ENABLED(USB_GADGET_DWC2_OTG) + IS_ENABLED(CONFIG_USB_GADGET_DWC2_OTG) static struct dwc2_plat_otg_data meson_g12a_dwc2_data;
int board_usb_init(int index, enum usb_init_type init) diff --git a/arch/arm/mach-meson/board-gx.c b/arch/arm/mach-meson/board-gx.c index 41f767302ec..b850460c26c 100644 --- a/arch/arm/mach-meson/board-gx.c +++ b/arch/arm/mach-meson/board-gx.c @@ -110,7 +110,7 @@ static struct mm_region gx_mem_map[] = { struct mm_region *mem_map = gx_mem_map;
Same as 160, this code is getting removed in This code is getting removed in the last PR I sent at https://lore.kernel.org/all/ec3802ba-6e79-5370-e41e-cd2487cd618f@linaro.org/
This converts 2 usages of this option to the non-SPL form, since there is no SPL_USB_KEYBOARD defined in Kconfig
arch/x86/cpu/coreboot/coreboot.c | 2 +- arch/x86/cpu/efi/payload.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/x86/cpu/coreboot/coreboot.c b/arch/x86/cpu/coreboot/coreboot.c index aaa5ae112e4..d7eedbd7436 100644 --- a/arch/x86/cpu/coreboot/coreboot.c +++ b/arch/x86/cpu/coreboot/coreboot.c @@ -77,7 +77,7 @@ static void board_final_init(void) int last_stage_init(void) { /* start usb so that usb keyboard can be used as input device */ - if (CONFIG_IS_ENABLED(USB_KEYBOARD)) + if (IS_ENABLED(CONFIG_USB_KEYBOARD)) usb_init();
board_final_init(); diff --git a/arch/x86/cpu/efi/payload.c b/arch/x86/cpu/efi/payload.c index 1c28a43778e..19a25dd6408 100644 --- a/arch/x86/cpu/efi/payload.c +++ b/arch/x86/cpu/efi/payload.c @@ -171,7 +171,7 @@ int reserve_arch(void) int last_stage_init(void) { /* start usb so that usb keyboard can be used as input device */ - if (CONFIG_IS_ENABLED(USB_KEYBOARD)) + if (IS_ENABLED(CONFIG_USB_KEYBOARD)) usb_init();
This converts 2 usages of this option to the non-SPL form, since there is no SPL_USB_MUSB_HOST defined in Kconfig
drivers/phy/phy-ab8500-usb.c | 2 +- drivers/usb/musb-new/omap2430.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/phy/phy-ab8500-usb.c b/drivers/phy/phy-ab8500-usb.c index 0e04595717b..3d3d48c9733 100644 --- a/drivers/phy/phy-ab8500-usb.c +++ b/drivers/phy/phy-ab8500-usb.c @@ -19,7 +19,7 @@ static int ab8500_usb_phy_power_on(struct phy *phy) struct udevice *dev = phy->dev; uint set = AB8500_BIT_PHY_CTRL_DEVICE_EN;
- if (CONFIG_IS_ENABLED(USB_MUSB_HOST)) + if (IS_ENABLED(CONFIG_USB_MUSB_HOST)) set = AB8500_BIT_PHY_CTRL_HOST_EN;
return pmic_clrsetbits(dev->parent, AB8500_USB_PHY_CTRL_REG, diff --git a/drivers/usb/musb-new/omap2430.c b/drivers/usb/musb-new/omap2430.c index 42e7abddbc2..482dfdc6be6 100644 --- a/drivers/usb/musb-new/omap2430.c +++ b/drivers/usb/musb-new/omap2430.c @@ -231,7 +231,7 @@ static int omap2430_musb_probe(struct udevice *dev)
otg_board_data = &plat->otg_board_data;
- if (CONFIG_IS_ENABLED(USB_MUSB_HOST)) { + if (IS_ENABLED(CONFIG_USB_MUSB_HOST)) { struct musb_host_data *host = dev_get_priv(dev); struct usb_bus_priv *priv = dev_get_uclass_priv(dev);
This converts 2 usages of this option to the non-SPL form, since there is no SPL_VIDEO defined in Kconfig
cmd/cls.c | 2 +- common/fdt_simplefb.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/cmd/cls.c b/cmd/cls.c index 18643ec0243..787c7edbee3 100644 --- a/cmd/cls.c +++ b/cmd/cls.c @@ -19,7 +19,7 @@ static int do_video_clear(struct cmd_tbl *cmdtp, int flag, int argc,
/* Send clear screen and home */ printf(CSI "2J" CSI "1;1H"); - if (CONFIG_IS_ENABLED(VIDEO) && !CONFIG_IS_ENABLED(VIDEO_ANSI)) { + if (IS_ENABLED(CONFIG_VIDEO) && !CONFIG_IS_ENABLED(VIDEO_ANSI)) { if (uclass_first_device_err(UCLASS_VIDEO, &dev)) return CMD_RET_FAILURE; if (video_clear(dev)) diff --git a/common/fdt_simplefb.c b/common/fdt_simplefb.c index 71d4c8fde90..282c34fe0b9 100644 --- a/common/fdt_simplefb.c +++ b/common/fdt_simplefb.c @@ -82,7 +82,7 @@ int fdt_simplefb_enable_existing_node(void *blob) return fdt_simplefb_configure_node(blob, off); }
-#if CONFIG_IS_ENABLED(VIDEO) +#if IS_ENABLED(CONFIG_VIDEO) int fdt_simplefb_enable_and_mem_rsv(void *blob) { struct fdt_memory mem;
This converts 1 usage of this option to the non-SPL form, since there is no SPL_VIDEO_ANSI defined in Kconfig
cmd/cls.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cmd/cls.c b/cmd/cls.c index 787c7edbee3..40a32eeab63 100644 --- a/cmd/cls.c +++ b/cmd/cls.c @@ -19,7 +19,7 @@ static int do_video_clear(struct cmd_tbl *cmdtp, int flag, int argc,
/* Send clear screen and home */ printf(CSI "2J" CSI "1;1H"); - if (IS_ENABLED(CONFIG_VIDEO) && !CONFIG_IS_ENABLED(VIDEO_ANSI)) { + if (IS_ENABLED(CONFIG_VIDEO) && !IS_ENABLED(CONFIG_VIDEO_ANSI)) { if (uclass_first_device_err(UCLASS_VIDEO, &dev)) return CMD_RET_FAILURE; if (video_clear(dev))
This converts 1 usage of this option to the non-SPL form, since there is no SPL_VIDEO_BPP16 defined in Kconfig
drivers/video/video-uclass.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/video/video-uclass.c b/drivers/video/video-uclass.c index 0ce376ca3f1..f36970e0420 100644 --- a/drivers/video/video-uclass.c +++ b/drivers/video/video-uclass.c @@ -196,7 +196,7 @@ u32 video_index_to_colour(struct video_priv *priv, unsigned int idx) { switch (priv->bpix) { case VIDEO_BPP16: - if (CONFIG_IS_ENABLED(VIDEO_BPP16)) { + if (IS_ENABLED(CONFIG_VIDEO_BPP16)) { return ((colours[idx].r >> 3) << 11) | ((colours[idx].g >> 2) << 5) | ((colours[idx].b >> 3) << 0);
This converts 1 usage of this option to the non-SPL form, since there is no SPL_VIDEO_BPP32 defined in Kconfig
diff --git a/drivers/video/video-uclass.c b/drivers/video/video-uclass.c index f36970e0420..6aaacff10df 100644 --- a/drivers/video/video-uclass.c +++ b/drivers/video/video-uclass.c @@ -203,7 +203,7 @@ u32 video_index_to_colour(struct video_priv *priv, unsigned int idx) } break; case VIDEO_BPP32: - if (CONFIG_IS_ENABLED(VIDEO_BPP32)) { + if (IS_ENABLED(CONFIG_VIDEO_BPP32)) { if (priv->format == VIDEO_X2R10G10B10) return (colours[idx].r << 22) | (colours[idx].g << 12) |
This converts 1 usage of this option to the non-SPL form, since there is no SPL_WATCHDOG_AUTOSTART defined in Kconfig
diff --git a/board/kontron/sl28/sl28.c b/board/kontron/sl28/sl28.c index e78a0d5dd3c..89948e087f1 100644 --- a/board/kontron/sl28/sl28.c +++ b/board/kontron/sl28/sl28.c @@ -157,7 +157,7 @@ int fsl_board_late_init(void) * If the watchdog isn't enabled at reset (which is a configuration * option) disabling it doesn't hurt either. */ - if (!CONFIG_IS_ENABLED(WATCHDOG_AUTOSTART)) + if (!IS_ENABLED(CONFIG_WATCHDOG_AUTOSTART)) stop_recovery_watchdog();
This converts 4 usages of this option to the non-SPL form, since there is no SPL_XEN_SERIAL defined in Kconfig
drivers/xen/events.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/drivers/xen/events.c b/drivers/xen/events.c index 532216fece3..2ebe20dbf26 100644 --- a/drivers/xen/events.c +++ b/drivers/xen/events.c @@ -23,9 +23,9 @@ #include <xen/events.h> #include <xen/hvm.h>
-#if CONFIG_IS_ENABLED(XEN_SERIAL) +#if IS_ENABLED(CONFIG_XEN_SERIAL) extern u32 console_evtchn; -#endif /* CONFIG_IS_ENABLED(XEN_SERIAL) */ +#endif /* IS_ENABLED(CONFIG_XEN_SERIAL) */
#define NR_EVS 1024
@@ -53,10 +53,10 @@ void unbind_all_ports(void) struct vcpu_info *vcpu_info = &s->vcpu_info[cpu];
for (i = 0; i < NR_EVS; i++) { -#if CONFIG_IS_ENABLED(XEN_SERIAL) +#if IS_ENABLED(CONFIG_XEN_SERIAL) if (i == console_evtchn) continue; -#endif /* CONFIG_IS_ENABLED(XEN_SERIAL) */ +#endif /* IS_ENABLED(CONFIG_XEN_SERIAL) */
if (test_and_clear_bit(i, bound_ports)) { printf("port %d still bound!\n", i);
This converts 2 usages of this option to the non-SPL form, since there is no SPL_ZYNQMP_FIRMWARE defined in Kconfig
drivers/spi/cadence_ospi_versal.c | 2 +- drivers/spi/cadence_qspi.c | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/spi/cadence_ospi_versal.c b/drivers/spi/cadence_ospi_versal.c index e0d5e6b9e69..434c6038f3b 100644 --- a/drivers/spi/cadence_ospi_versal.c +++ b/drivers/spi/cadence_ospi_versal.c @@ -216,7 +216,7 @@ int cadence_qspi_versal_flash_reset(struct udevice *dev)
void cadence_qspi_apb_enable_linear_mode(bool enable) { - if (CONFIG_IS_ENABLED(ZYNQMP_FIRMWARE)) { + if (IS_ENABLED(CONFIG_ZYNQMP_FIRMWARE)) { if (enable) /* ahb read mode */ xilinx_pm_request(PM_IOCTL, PM_DEV_OSPI, diff --git a/drivers/spi/cadence_qspi.c b/drivers/spi/cadence_qspi.c index 3ce5f8fb8d8..c7f10c50132 100644 --- a/drivers/spi/cadence_qspi.c +++ b/drivers/spi/cadence_qspi.c @@ -215,7 +215,7 @@ static int cadence_spi_probe(struct udevice *bus) priv->tchsh_ns = plat->tchsh_ns; priv->tslch_ns = plat->tslch_ns;
- if (CONFIG_IS_ENABLED(ZYNQMP_FIRMWARE)) + if (IS_ENABLED(CONFIG_ZYNQMP_FIRMWARE)) xilinx_pm_request(PM_REQUEST_NODE, PM_DEV_OSPI, ZYNQMP_PM_CAPABILITY_ACCESS, ZYNQMP_PM_MAX_QOS, ZYNQMP_PM_REQUEST_ACK_NO, NULL);
participants (6)
Adam Ford
Matthias Brugger
Mattijs Korpershoek
Neil Armstrong
