[PATCH 00/12] omap configuration cleanups
Here is a bunch of configuration cleanups for OMAP boards, mostly unifying and moving common configuration from board-specific defconfigs to Kconfig definitions.
There's also a cleanup of the sniper (LG Optimus Black) defconfig, prior to migrating it to DM/DT in a future follow-up series.
Paul Kocialkowski (12): omap3: Define common SPL text base in Kconfig instead of defconfigs omap3: Define common init stack pointer address in Kconfig am33xx: Unify init stack pointer address across boards am33xx: Define common init stack pointer address in Kconfig am43xx: Define common init stack pointer address in Kconfig dra7xx: Unify init stack pointer address across boards dra7xx: Define common init stack pointer address in Kconfig omap3: Define maximum U-Boot size in Kconfig instead of defconfigs omap3: Define maximum SPL size in Kconfig instead of defconfigs omap3: Define DRAM banks number in Kconfig instead of defconfigs dra7xx: Remove explicit DRAM banks number from defconfigs omap3: sniper: Streamline defconfig
Kconfig | 7 +++++++ common/spl/Kconfig | 2 ++ configs/am335x_baltos_defconfig | 2 -- configs/am335x_evm_defconfig | 2 -- configs/am335x_evm_spiboot_defconfig | 2 -- configs/am335x_guardian_defconfig | 2 -- configs/am335x_hs_evm_defconfig | 2 -- configs/am335x_hs_evm_uart_defconfig | 2 -- configs/am335x_igep003x_defconfig | 2 -- configs/am335x_pdu001_defconfig | 2 -- configs/am335x_shc_defconfig | 2 -- configs/am335x_shc_ict_defconfig | 2 -- configs/am335x_shc_netboot_defconfig | 2 -- configs/am335x_shc_sdboot_defconfig | 2 -- configs/am335x_sl50_defconfig | 2 -- configs/am3517_evm_defconfig | 6 ------ configs/am43xx_evm_defconfig | 2 -- configs/am43xx_evm_qspiboot_defconfig | 2 -- configs/am43xx_evm_rtconly_defconfig | 2 -- configs/am43xx_evm_usbhost_boot_defconfig | 2 -- configs/am43xx_hs_evm_defconfig | 2 -- configs/am43xx_hs_evm_qspi_defconfig | 2 -- configs/am57xx_evm_defconfig | 3 --- configs/am57xx_hs_evm_defconfig | 3 --- configs/am57xx_hs_evm_usb_defconfig | 3 --- configs/brppt1_mmc_defconfig | 2 -- configs/brsmarc1_defconfig | 2 -- configs/brxre1_defconfig | 2 -- configs/chiliboard_defconfig | 2 -- configs/cm_t43_defconfig | 2 -- configs/devkit8000_defconfig | 6 ------ configs/dra7xx_evm_defconfig | 3 --- configs/dra7xx_hs_evm_defconfig | 3 --- configs/dra7xx_hs_evm_usb_defconfig | 3 --- configs/draco-etamin_defconfig | 2 -- configs/draco-rastaban_defconfig | 2 -- configs/draco-thuban_defconfig | 2 -- configs/igep00x0_defconfig | 6 ------ configs/omap35_logic_defconfig | 6 ------ configs/omap35_logic_somlv_defconfig | 6 ------ configs/omap3_evm_defconfig | 6 ------ configs/omap3_logic_defconfig | 6 ------ configs/omap3_logic_somlv_defconfig | 6 ------ configs/pcm051_rev3_defconfig | 2 -- configs/phycore-am335x-r2-regor_defconfig | 2 -- configs/phycore-am335x-r2-wega_defconfig | 2 -- configs/pxm2_defconfig | 2 -- configs/rut_defconfig | 2 -- configs/sniper_defconfig | 21 ++++----------------- 49 files changed, 13 insertions(+), 147 deletions(-)
The SPL text base was defined to the same value in each OMAP3 board defconfig. Move the common definition to the Kconfig option declaration instead.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- common/spl/Kconfig | 1 + configs/am3517_evm_defconfig | 1 - configs/devkit8000_defconfig | 1 - configs/igep00x0_defconfig | 1 - configs/omap35_logic_defconfig | 1 - configs/omap35_logic_somlv_defconfig | 1 - configs/omap3_evm_defconfig | 1 - configs/omap3_logic_defconfig | 1 - configs/omap3_logic_somlv_defconfig | 1 - configs/sniper_defconfig | 1 - 10 files changed, 1 insertion(+), 9 deletions(-)
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 6f56ca911c1e..6fc97f4ccbd8 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -261,6 +261,7 @@ config SPL_LDSCRIPT
config SPL_TEXT_BASE hex "SPL Text Base" + default 0x40200000 if OMAP34XX default 0x402F4000 if AM43XX default 0x402F0400 if AM33XX default 0x40301350 if OMAP54XX diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index 3236f1dd672f..129ffa28d272 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -10,7 +10,6 @@ CONFIG_ENV_SOURCE_FILE="am3517evm" CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 CONFIG_DEFAULT_DEVICE_TREE="ti/omap/am3517-evm" -CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_TARGET_AM3517_EVM=y CONFIG_EMIF4=y CONFIG_SYS_MONITOR_LEN=262144 diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index 7653fbbe7e5a..db6e9386cf5f 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -7,7 +7,6 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 CONFIG_DEFAULT_DEVICE_TREE="omap3-devkit8000" -CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_TARGET_DEVKIT8000=y CONFIG_SYS_MONITOR_LEN=262144 CONFIG_SPL_SYS_MALLOC_F_LEN=0x400 diff --git a/configs/igep00x0_defconfig b/configs/igep00x0_defconfig index 473891607b0f..90ef2635c899 100644 --- a/configs/igep00x0_defconfig +++ b/configs/igep00x0_defconfig @@ -9,7 +9,6 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 CONFIG_ENV_SIZE=0x8000 CONFIG_DEFAULT_DEVICE_TREE="ti/omap/omap3-igep0020" -CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_TARGET_OMAP3_IGEP00X0=y CONFIG_SYS_MONITOR_LEN=262144 CONFIG_SPL_SYS_MALLOC_F_LEN=0x400 diff --git a/configs/omap35_logic_defconfig b/configs/omap35_logic_defconfig index 23b2e503385d..3b66af079c59 100644 --- a/configs/omap35_logic_defconfig +++ b/configs/omap35_logic_defconfig @@ -10,7 +10,6 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 CONFIG_DEFAULT_DEVICE_TREE="ti/omap/logicpd-torpedo-35xx-devkit" -CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set CONFIG_SYS_MONITOR_LEN=262144 diff --git a/configs/omap35_logic_somlv_defconfig b/configs/omap35_logic_somlv_defconfig index a5f242ff40cf..1b1d3dcfb203 100644 --- a/configs/omap35_logic_somlv_defconfig +++ b/configs/omap35_logic_somlv_defconfig @@ -10,7 +10,6 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 CONFIG_DEFAULT_DEVICE_TREE="ti/omap/logicpd-som-lv-35xx-devkit" -CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set CONFIG_SYS_MONITOR_LEN=262144 diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 3c8d974fbd09..4ccb9b65c8bb 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -7,7 +7,6 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 CONFIG_DEFAULT_DEVICE_TREE="omap3-evm" -CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_TARGET_OMAP3_EVM=y CONFIG_SYS_MONITOR_LEN=262144 CONFIG_SPL_SYS_MALLOC_F_LEN=0x400 diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index d081d4e0fb46..1fa5873a42d5 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -10,7 +10,6 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 CONFIG_DEFAULT_DEVICE_TREE="ti/omap/logicpd-torpedo-37xx-devkit" -CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set CONFIG_SYS_MONITOR_LEN=262144 diff --git a/configs/omap3_logic_somlv_defconfig b/configs/omap3_logic_somlv_defconfig index 68e89d245eee..642d2121ceda 100644 --- a/configs/omap3_logic_somlv_defconfig +++ b/configs/omap3_logic_somlv_defconfig @@ -10,7 +10,6 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 CONFIG_DEFAULT_DEVICE_TREE="ti/omap/logicpd-som-lv-37xx-devkit" -CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set CONFIG_SYS_MONITOR_LEN=262144 diff --git a/configs/sniper_defconfig b/configs/sniper_defconfig index 0243b15f31ce..72634db607bf 100644 --- a/configs/sniper_defconfig +++ b/configs/sniper_defconfig @@ -7,7 +7,6 @@ CONFIG_SYS_MALLOC_F_LEN=0x400 CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 -CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_TARGET_SNIPER=y CONFIG_SPL_STACK=0x4020fffc CONFIG_SPL_BSS_START_ADDR=0x80000000
Thanks for doing this.
For the series,
Tested-by: Adam Ford aford173@gmail.com #am3517-evm
diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index 3236f1dd672f..129ffa28d272 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -10,7 +10,6 @@ CONFIG_ENV_SOURCE_FILE="am3517evm" CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 CONFIG_DEFAULT_DEVICE_TREE="ti/omap/am3517-evm" -CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_TARGET_AM3517_EVM=y CONFIG_EMIF4=y CONFIG_SYS_MONITOR_LEN=262144 diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index 7653fbbe7e5a..db6e9386cf5f 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -7,7 +7,6 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 CONFIG_DEFAULT_DEVICE_TREE="omap3-devkit8000" -CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_TARGET_DEVKIT8000=y CONFIG_SYS_MONITOR_LEN=262144 CONFIG_SPL_SYS_MALLOC_F_LEN=0x400 diff --git a/configs/igep00x0_defconfig b/configs/igep00x0_defconfig index 473891607b0f..90ef2635c899 100644 --- a/configs/igep00x0_defconfig +++ b/configs/igep00x0_defconfig @@ -9,7 +9,6 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 CONFIG_ENV_SIZE=0x8000 CONFIG_DEFAULT_DEVICE_TREE="ti/omap/omap3-igep0020" -CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_TARGET_OMAP3_IGEP00X0=y CONFIG_SYS_MONITOR_LEN=262144 CONFIG_SPL_SYS_MALLOC_F_LEN=0x400 diff --git a/configs/omap35_logic_defconfig b/configs/omap35_logic_defconfig index 23b2e503385d..3b66af079c59 100644 --- a/configs/omap35_logic_defconfig +++ b/configs/omap35_logic_defconfig @@ -10,7 +10,6 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 CONFIG_DEFAULT_DEVICE_TREE="ti/omap/logicpd-torpedo-35xx-devkit" -CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set CONFIG_SYS_MONITOR_LEN=262144 diff --git a/configs/omap35_logic_somlv_defconfig b/configs/omap35_logic_somlv_defconfig index a5f242ff40cf..1b1d3dcfb203 100644 --- a/configs/omap35_logic_somlv_defconfig +++ b/configs/omap35_logic_somlv_defconfig @@ -10,7 +10,6 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 CONFIG_DEFAULT_DEVICE_TREE="ti/omap/logicpd-som-lv-35xx-devkit" -CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set CONFIG_SYS_MONITOR_LEN=262144 diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 3c8d974fbd09..4ccb9b65c8bb 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -7,7 +7,6 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 CONFIG_DEFAULT_DEVICE_TREE="omap3-evm" -CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_TARGET_OMAP3_EVM=y CONFIG_SYS_MONITOR_LEN=262144 CONFIG_SPL_SYS_MALLOC_F_LEN=0x400 diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index d081d4e0fb46..1fa5873a42d5 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -10,7 +10,6 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 CONFIG_DEFAULT_DEVICE_TREE="ti/omap/logicpd-torpedo-37xx-devkit" -CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set CONFIG_SYS_MONITOR_LEN=262144 diff --git a/configs/omap3_logic_somlv_defconfig b/configs/omap3_logic_somlv_defconfig index 68e89d245eee..642d2121ceda 100644 --- a/configs/omap3_logic_somlv_defconfig +++ b/configs/omap3_logic_somlv_defconfig @@ -10,7 +10,6 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 CONFIG_DEFAULT_DEVICE_TREE="ti/omap/logicpd-som-lv-37xx-devkit" -CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set CONFIG_SYS_MONITOR_LEN=262144 diff --git a/configs/sniper_defconfig b/configs/sniper_defconfig index 0243b15f31ce..72634db607bf 100644 --- a/configs/sniper_defconfig +++ b/configs/sniper_defconfig @@ -7,7 +7,6 @@ CONFIG_SYS_MALLOC_F_LEN=0x400 CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 -CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_TARGET_SNIPER=y CONFIG_SPL_STACK=0x4020fffc CONFIG_SPL_BSS_START_ADDR=0x80000000 -- 2.45.2
The init stack pointer was defined to the same value in each OMAP3 board defconfig. Move the common definition to the Kconfig option declaration instead.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- Kconfig | 2 ++ configs/am3517_evm_defconfig | 2 -- configs/devkit8000_defconfig | 2 -- configs/igep00x0_defconfig | 2 -- configs/omap35_logic_defconfig | 2 -- configs/omap35_logic_somlv_defconfig | 2 -- configs/omap3_evm_defconfig | 2 -- configs/omap3_logic_defconfig | 2 -- configs/omap3_logic_somlv_defconfig | 2 -- configs/sniper_defconfig | 2 -- 10 files changed, 2 insertions(+), 18 deletions(-)
diff --git a/Kconfig b/Kconfig index 82df59f176ec..98175a8f3362 100644 --- a/Kconfig +++ b/Kconfig @@ -236,6 +236,7 @@ config SYS_BOOT_GET_KBD config HAS_CUSTOM_SYS_INIT_SP_ADDR bool "Use a custom location for the initial stack pointer address" depends on ARC || (ARM && !INIT_SP_RELATIVE) || MIPS || PPC || RISCV + default y if OMAP34XX default y if TFABOOT help Typically, we use an initial stack pointer address that is calculated @@ -249,6 +250,7 @@ config HAS_CUSTOM_SYS_INIT_SP_ADDR config CUSTOM_SYS_INIT_SP_ADDR hex "Static location for the initial stack pointer" depends on HAS_CUSTOM_SYS_INIT_SP_ADDR + default 0x4020ff00 if OMAP34XX default TEXT_BASE if TFABOOT
config SYS_MALLOC_F diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index 129ffa28d272..114d1a22f4a3 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -7,8 +7,6 @@ CONFIG_SYS_MALLOC_F_LEN=0x4000 CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_NR_DRAM_BANKS=2 CONFIG_ENV_SOURCE_FILE="am3517evm" -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 CONFIG_DEFAULT_DEVICE_TREE="ti/omap/am3517-evm" CONFIG_TARGET_AM3517_EVM=y CONFIG_EMIF4=y diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index db6e9386cf5f..d68bb8bfd37b 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -4,8 +4,6 @@ CONFIG_TEXT_BASE=0x80100000 CONFIG_SYS_MALLOC_LEN=0x40000 CONFIG_SYS_MALLOC_F_LEN=0x4000 CONFIG_NR_DRAM_BANKS=2 -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 CONFIG_DEFAULT_DEVICE_TREE="omap3-devkit8000" CONFIG_TARGET_DEVKIT8000=y CONFIG_SYS_MONITOR_LEN=262144 diff --git a/configs/igep00x0_defconfig b/configs/igep00x0_defconfig index 90ef2635c899..493395847255 100644 --- a/configs/igep00x0_defconfig +++ b/configs/igep00x0_defconfig @@ -5,8 +5,6 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_SYS_MALLOC_F_LEN=0x4000 CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_NR_DRAM_BANKS=2 -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 CONFIG_ENV_SIZE=0x8000 CONFIG_DEFAULT_DEVICE_TREE="ti/omap/omap3-igep0020" CONFIG_TARGET_OMAP3_IGEP00X0=y diff --git a/configs/omap35_logic_defconfig b/configs/omap35_logic_defconfig index 3b66af079c59..ca1b97a26d9e 100644 --- a/configs/omap35_logic_defconfig +++ b/configs/omap35_logic_defconfig @@ -7,8 +7,6 @@ CONFIG_SYS_MALLOC_F_LEN=0x3000 CONFIG_TI_COMMON_CMD_OPTIONS=y # CONFIG_SPL_GPIO is not set CONFIG_NR_DRAM_BANKS=2 -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 CONFIG_DEFAULT_DEVICE_TREE="ti/omap/logicpd-torpedo-35xx-devkit" CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set diff --git a/configs/omap35_logic_somlv_defconfig b/configs/omap35_logic_somlv_defconfig index 1b1d3dcfb203..3b0bc6d1eaf9 100644 --- a/configs/omap35_logic_somlv_defconfig +++ b/configs/omap35_logic_somlv_defconfig @@ -7,8 +7,6 @@ CONFIG_SYS_MALLOC_F_LEN=0x3000 CONFIG_TI_COMMON_CMD_OPTIONS=y # CONFIG_SPL_GPIO is not set CONFIG_NR_DRAM_BANKS=2 -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 CONFIG_DEFAULT_DEVICE_TREE="ti/omap/logicpd-som-lv-35xx-devkit" CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 4ccb9b65c8bb..d7a3fc4b25b9 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -4,8 +4,6 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_SYS_MALLOC_F_LEN=0x4000 CONFIG_NR_DRAM_BANKS=2 -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 CONFIG_DEFAULT_DEVICE_TREE="omap3-evm" CONFIG_TARGET_OMAP3_EVM=y CONFIG_SYS_MONITOR_LEN=262144 diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index 1fa5873a42d5..52e2e459dbb0 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -7,8 +7,6 @@ CONFIG_SYS_MALLOC_F_LEN=0x3000 CONFIG_TI_COMMON_CMD_OPTIONS=y # CONFIG_SPL_GPIO is not set CONFIG_NR_DRAM_BANKS=2 -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 CONFIG_DEFAULT_DEVICE_TREE="ti/omap/logicpd-torpedo-37xx-devkit" CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set diff --git a/configs/omap3_logic_somlv_defconfig b/configs/omap3_logic_somlv_defconfig index 642d2121ceda..64bb401f7ac9 100644 --- a/configs/omap3_logic_somlv_defconfig +++ b/configs/omap3_logic_somlv_defconfig @@ -7,8 +7,6 @@ CONFIG_SYS_MALLOC_F_LEN=0x3000 CONFIG_TI_COMMON_CMD_OPTIONS=y # CONFIG_SPL_GPIO is not set CONFIG_NR_DRAM_BANKS=2 -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 CONFIG_DEFAULT_DEVICE_TREE="ti/omap/logicpd-som-lv-37xx-devkit" CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set diff --git a/configs/sniper_defconfig b/configs/sniper_defconfig index 72634db607bf..35cfc28006c1 100644 --- a/configs/sniper_defconfig +++ b/configs/sniper_defconfig @@ -5,8 +5,6 @@ CONFIG_TEXT_BASE=0x80100000 CONFIG_SYS_MALLOC_LEN=0x120000 CONFIG_SYS_MALLOC_F_LEN=0x400 CONFIG_NR_DRAM_BANKS=2 -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 CONFIG_TARGET_SNIPER=y CONFIG_SPL_STACK=0x4020fffc CONFIG_SPL_BSS_START_ADDR=0x80000000
The AM33xx chiliboard and guardian boards use a slightly different init stack pointer address compared to other AM33xx boards, for no particular reason.
Align the address with other AM33xx boards prior to removing it as a per-board option in a later commit.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- configs/am335x_guardian_defconfig | 2 +- configs/chiliboard_defconfig | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/configs/am335x_guardian_defconfig b/configs/am335x_guardian_defconfig index 751385424312..e68bada6c13c 100644 --- a/configs/am335x_guardian_defconfig +++ b/configs/am335x_guardian_defconfig @@ -4,7 +4,7 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030fef0 +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0x500000 CONFIG_DEFAULT_DEVICE_TREE="am335x-guardian" diff --git a/configs/chiliboard_defconfig b/configs/chiliboard_defconfig index c574d93806a6..da61c86e3961 100644 --- a/configs/chiliboard_defconfig +++ b/configs/chiliboard_defconfig @@ -4,7 +4,7 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030fef0 +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x20000 CONFIG_DM_GPIO=y
The init stack pointer was defined to the same value in each AM33xx board defconfig. Move the common definition to the Kconfig option declaration instead.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- Kconfig | 3 ++- configs/am335x_baltos_defconfig | 2 -- configs/am335x_evm_defconfig | 2 -- configs/am335x_evm_spiboot_defconfig | 2 -- configs/am335x_guardian_defconfig | 2 -- configs/am335x_hs_evm_defconfig | 2 -- configs/am335x_hs_evm_uart_defconfig | 2 -- configs/am335x_igep003x_defconfig | 2 -- configs/am335x_pdu001_defconfig | 2 -- configs/am335x_shc_defconfig | 2 -- configs/am335x_shc_ict_defconfig | 2 -- configs/am335x_shc_netboot_defconfig | 2 -- configs/am335x_shc_sdboot_defconfig | 2 -- configs/am335x_sl50_defconfig | 2 -- configs/brppt1_mmc_defconfig | 2 -- configs/brsmarc1_defconfig | 2 -- configs/brxre1_defconfig | 2 -- configs/chiliboard_defconfig | 2 -- configs/draco-etamin_defconfig | 2 -- configs/draco-rastaban_defconfig | 2 -- configs/draco-thuban_defconfig | 2 -- configs/pcm051_rev3_defconfig | 2 -- configs/phycore-am335x-r2-regor_defconfig | 2 -- configs/phycore-am335x-r2-wega_defconfig | 2 -- configs/pxm2_defconfig | 2 -- configs/rut_defconfig | 2 -- 26 files changed, 2 insertions(+), 51 deletions(-)
diff --git a/Kconfig b/Kconfig index 98175a8f3362..45656e90b917 100644 --- a/Kconfig +++ b/Kconfig @@ -236,7 +236,7 @@ config SYS_BOOT_GET_KBD config HAS_CUSTOM_SYS_INIT_SP_ADDR bool "Use a custom location for the initial stack pointer address" depends on ARC || (ARM && !INIT_SP_RELATIVE) || MIPS || PPC || RISCV - default y if OMAP34XX + default y if OMAP34XX || AM33XX default y if TFABOOT help Typically, we use an initial stack pointer address that is calculated @@ -251,6 +251,7 @@ config CUSTOM_SYS_INIT_SP_ADDR hex "Static location for the initial stack pointer" depends on HAS_CUSTOM_SYS_INIT_SP_ADDR default 0x4020ff00 if OMAP34XX + default 0x4030ff00 if AM33XX default TEXT_BASE if TFABOOT
config SYS_MALLOC_F diff --git a/configs/am335x_baltos_defconfig b/configs/am335x_baltos_defconfig index f8dfd1d20602..14d8d96a8656 100644 --- a/configs/am335x_baltos_defconfig +++ b/configs/am335x_baltos_defconfig @@ -3,8 +3,6 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_DEFAULT_DEVICE_TREE="am335x-baltos" CONFIG_AM33XX=y CONFIG_TARGET_AM335X_BALTOS=y diff --git a/configs/am335x_evm_defconfig b/configs/am335x_evm_defconfig index cabc181460ab..5dd0b3288353 100644 --- a/configs/am335x_evm_defconfig +++ b/configs/am335x_evm_defconfig @@ -2,8 +2,6 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_TI_COMMON_CMD_OPTIONS=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_DEFAULT_DEVICE_TREE="am335x-evm" CONFIG_AM33XX=y diff --git a/configs/am335x_evm_spiboot_defconfig b/configs/am335x_evm_spiboot_defconfig index 8239f5f84dae..a55aace02460 100644 --- a/configs/am335x_evm_spiboot_defconfig +++ b/configs/am335x_evm_spiboot_defconfig @@ -2,8 +2,6 @@ CONFIG_ARM=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_TI_COMMON_CMD_OPTIONS=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_ENV_OFFSET=0x100000 CONFIG_SPL_DM_SPI=y diff --git a/configs/am335x_guardian_defconfig b/configs/am335x_guardian_defconfig index e68bada6c13c..6b40d398392c 100644 --- a/configs/am335x_guardian_defconfig +++ b/configs/am335x_guardian_defconfig @@ -3,8 +3,6 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_ENV_SIZE=0x40000 CONFIG_ENV_OFFSET=0x500000 CONFIG_DEFAULT_DEVICE_TREE="am335x-guardian" diff --git a/configs/am335x_hs_evm_defconfig b/configs/am335x_hs_evm_defconfig index 3694cc32db95..d780239715f5 100644 --- a/configs/am335x_hs_evm_defconfig +++ b/configs/am335x_hs_evm_defconfig @@ -3,8 +3,6 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_TI_SECURE_DEVICE=y CONFIG_TI_COMMON_CMD_OPTIONS=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_DEFAULT_DEVICE_TREE="am335x-evm" CONFIG_SPL_TEXT_BASE=0x40300350 diff --git a/configs/am335x_hs_evm_uart_defconfig b/configs/am335x_hs_evm_uart_defconfig index a99b7b46cfba..bd979941b7a2 100644 --- a/configs/am335x_hs_evm_uart_defconfig +++ b/configs/am335x_hs_evm_uart_defconfig @@ -3,8 +3,6 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_TI_SECURE_DEVICE=y CONFIG_TI_COMMON_CMD_OPTIONS=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_DEFAULT_DEVICE_TREE="am335x-evm" CONFIG_SPL_TEXT_BASE=0x40301950 diff --git a/configs/am335x_igep003x_defconfig b/configs/am335x_igep003x_defconfig index ddffd4f46f0f..ef4d8661a131 100644 --- a/configs/am335x_igep003x_defconfig +++ b/configs/am335x_igep003x_defconfig @@ -4,8 +4,6 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_ENV_SIZE=0x18000 CONFIG_DEFAULT_DEVICE_TREE="am335x-base0033" CONFIG_AM33XX=y diff --git a/configs/am335x_pdu001_defconfig b/configs/am335x_pdu001_defconfig index febe5ebaabb2..f6b7d9c88ebd 100644 --- a/configs/am335x_pdu001_defconfig +++ b/configs/am335x_pdu001_defconfig @@ -4,8 +4,6 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_SYS_MALLOC_F_LEN=0x1200 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_ENV_SIZE=0x4000 CONFIG_DM_GPIO=y CONFIG_DEFAULT_DEVICE_TREE="am335x-pdu001" diff --git a/configs/am335x_shc_defconfig b/configs/am335x_shc_defconfig index 47c08e5054b3..f2cf35c4c331 100644 --- a/configs/am335x_shc_defconfig +++ b/configs/am335x_shc_defconfig @@ -4,8 +4,6 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x7000 CONFIG_DEFAULT_DEVICE_TREE="am335x-shc" diff --git a/configs/am335x_shc_ict_defconfig b/configs/am335x_shc_ict_defconfig index c7618c5c799c..f30c2661100d 100644 --- a/configs/am335x_shc_ict_defconfig +++ b/configs/am335x_shc_ict_defconfig @@ -4,8 +4,6 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x7000 CONFIG_DEFAULT_DEVICE_TREE="am335x-shc" diff --git a/configs/am335x_shc_netboot_defconfig b/configs/am335x_shc_netboot_defconfig index 934265815beb..e9262fdf3713 100644 --- a/configs/am335x_shc_netboot_defconfig +++ b/configs/am335x_shc_netboot_defconfig @@ -4,8 +4,6 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x7000 CONFIG_DEFAULT_DEVICE_TREE="am335x-shc" diff --git a/configs/am335x_shc_sdboot_defconfig b/configs/am335x_shc_sdboot_defconfig index 439f9b8188ad..887b6aa6feb9 100644 --- a/configs/am335x_shc_sdboot_defconfig +++ b/configs/am335x_shc_sdboot_defconfig @@ -4,8 +4,6 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_ENV_SIZE=0x1000 CONFIG_ENV_OFFSET=0x7000 CONFIG_DEFAULT_DEVICE_TREE="am335x-shc" diff --git a/configs/am335x_sl50_defconfig b/configs/am335x_sl50_defconfig index 88122bd052c8..3e539c8d54e4 100644 --- a/configs/am335x_sl50_defconfig +++ b/configs/am335x_sl50_defconfig @@ -4,8 +4,6 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_ENV_OFFSET=0x0 CONFIG_DEFAULT_DEVICE_TREE="am335x-sl50" CONFIG_AM33XX=y diff --git a/configs/brppt1_mmc_defconfig b/configs/brppt1_mmc_defconfig index 0b2ee74b003f..09e061350bc8 100644 --- a/configs/brppt1_mmc_defconfig +++ b/configs/brppt1_mmc_defconfig @@ -6,8 +6,6 @@ CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0x40000 CONFIG_DM_GPIO=y diff --git a/configs/brsmarc1_defconfig b/configs/brsmarc1_defconfig index f584b8d30b1f..5ec55f34f697 100644 --- a/configs/brsmarc1_defconfig +++ b/configs/brsmarc1_defconfig @@ -4,8 +4,6 @@ CONFIG_SYS_MALLOC_LEN=0x500000 CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0x20000 diff --git a/configs/brxre1_defconfig b/configs/brxre1_defconfig index 6c27f07fc794..0663a597847a 100644 --- a/configs/brxre1_defconfig +++ b/configs/brxre1_defconfig @@ -4,8 +4,6 @@ CONFIG_SYS_MALLOC_LEN=0x500000 CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0x40000 CONFIG_DM_GPIO=y diff --git a/configs/chiliboard_defconfig b/configs/chiliboard_defconfig index da61c86e3961..25e162e938e3 100644 --- a/configs/chiliboard_defconfig +++ b/configs/chiliboard_defconfig @@ -3,8 +3,6 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x20000 CONFIG_DM_GPIO=y diff --git a/configs/draco-etamin_defconfig b/configs/draco-etamin_defconfig index ba3f381f69f3..78ee5c1eb66f 100644 --- a/configs/draco-etamin_defconfig +++ b/configs/draco-etamin_defconfig @@ -5,8 +5,6 @@ CONFIG_SYS_MALLOC_LEN=0x1000000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_ENV_SIZE=0x2000 CONFIG_ENV_OFFSET=0x980000 CONFIG_DEFAULT_DEVICE_TREE="am335x-draco" diff --git a/configs/draco-rastaban_defconfig b/configs/draco-rastaban_defconfig index 43d29f5b11ab..81a349b730c6 100644 --- a/configs/draco-rastaban_defconfig +++ b/configs/draco-rastaban_defconfig @@ -5,8 +5,6 @@ CONFIG_SYS_MALLOC_LEN=0x1000000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_ENV_SIZE=0x2000 CONFIG_DEFAULT_DEVICE_TREE="am335x-draco" CONFIG_AM33XX=y diff --git a/configs/draco-thuban_defconfig b/configs/draco-thuban_defconfig index b457b22fc64d..265c1138dfe7 100644 --- a/configs/draco-thuban_defconfig +++ b/configs/draco-thuban_defconfig @@ -5,8 +5,6 @@ CONFIG_SYS_MALLOC_LEN=0x1000000 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_ENV_SIZE=0x2000 CONFIG_DEFAULT_DEVICE_TREE="am335x-draco" CONFIG_AM33XX=y diff --git a/configs/pcm051_rev3_defconfig b/configs/pcm051_rev3_defconfig index 78469814af39..a4e467fa05ed 100644 --- a/configs/pcm051_rev3_defconfig +++ b/configs/pcm051_rev3_defconfig @@ -3,8 +3,6 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_DEFAULT_DEVICE_TREE="am335x-wega-rdk" CONFIG_AM33XX=y diff --git a/configs/phycore-am335x-r2-regor_defconfig b/configs/phycore-am335x-r2-regor_defconfig index ac638c4e321f..d5056ccd98ea 100644 --- a/configs/phycore-am335x-r2-regor_defconfig +++ b/configs/phycore-am335x-r2-regor_defconfig @@ -4,8 +4,6 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_ENV_OFFSET=0xA0000 CONFIG_DEFAULT_DEVICE_TREE="am335x-regor-rdk" CONFIG_AM33XX=y diff --git a/configs/phycore-am335x-r2-wega_defconfig b/configs/phycore-am335x-r2-wega_defconfig index 98c621718654..5813d102475b 100644 --- a/configs/phycore-am335x-r2-wega_defconfig +++ b/configs/phycore-am335x-r2-wega_defconfig @@ -4,8 +4,6 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_ENV_OFFSET=0xA0000 CONFIG_DEFAULT_DEVICE_TREE="am335x-wega-rdk" CONFIG_AM33XX=y diff --git a/configs/pxm2_defconfig b/configs/pxm2_defconfig index c2f869391d73..30946b8f6b42 100644 --- a/configs/pxm2_defconfig +++ b/configs/pxm2_defconfig @@ -6,8 +6,6 @@ CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_ENV_SIZE=0x2000 CONFIG_SPL_DM_SPI=y CONFIG_DEFAULT_DEVICE_TREE="am335x-pxm50" diff --git a/configs/rut_defconfig b/configs/rut_defconfig index 7e78f1d64917..93d182a710c5 100644 --- a/configs/rut_defconfig +++ b/configs/rut_defconfig @@ -6,8 +6,6 @@ CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4030ff00 CONFIG_ENV_SIZE=0x2000 CONFIG_SPL_DM_SPI=y CONFIG_DEFAULT_DEVICE_TREE="am335x-rut"
The init stack pointer was defined to the same value in each AM43xx board defconfig. Move the common definition to the Kconfig option declaration instead.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- Kconfig | 3 ++- configs/am43xx_evm_defconfig | 2 -- configs/am43xx_evm_qspiboot_defconfig | 2 -- configs/am43xx_evm_rtconly_defconfig | 2 -- configs/am43xx_evm_usbhost_boot_defconfig | 2 -- configs/am43xx_hs_evm_defconfig | 2 -- configs/am43xx_hs_evm_qspi_defconfig | 2 -- configs/cm_t43_defconfig | 2 -- 8 files changed, 2 insertions(+), 15 deletions(-)
diff --git a/Kconfig b/Kconfig index 45656e90b917..19ce371a9cc2 100644 --- a/Kconfig +++ b/Kconfig @@ -236,7 +236,7 @@ config SYS_BOOT_GET_KBD config HAS_CUSTOM_SYS_INIT_SP_ADDR bool "Use a custom location for the initial stack pointer address" depends on ARC || (ARM && !INIT_SP_RELATIVE) || MIPS || PPC || RISCV - default y if OMAP34XX || AM33XX + default y if OMAP34XX || AM33XX || AM43XX default y if TFABOOT help Typically, we use an initial stack pointer address that is calculated @@ -252,6 +252,7 @@ config CUSTOM_SYS_INIT_SP_ADDR depends on HAS_CUSTOM_SYS_INIT_SP_ADDR default 0x4020ff00 if OMAP34XX default 0x4030ff00 if AM33XX + default 0x4033ff00 if AM43XX default TEXT_BASE if TFABOOT
config SYS_MALLOC_F diff --git a/configs/am43xx_evm_defconfig b/configs/am43xx_evm_defconfig index d73b1cb804b0..0fc4c0f269a8 100644 --- a/configs/am43xx_evm_defconfig +++ b/configs/am43xx_evm_defconfig @@ -3,8 +3,6 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_TI_COMMON_CMD_OPTIONS=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4033ff00 CONFIG_SF_DEFAULT_SPEED=48000000 CONFIG_ENV_SIZE=0x10000 CONFIG_DM_GPIO=y diff --git a/configs/am43xx_evm_qspiboot_defconfig b/configs/am43xx_evm_qspiboot_defconfig index 89e212595af9..c538c1ae352f 100644 --- a/configs/am43xx_evm_qspiboot_defconfig +++ b/configs/am43xx_evm_qspiboot_defconfig @@ -4,8 +4,6 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_TEXT_BASE=0x30000000 CONFIG_SYS_MALLOC_F_LEN=0x400 -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4033ff00 CONFIG_SF_DEFAULT_SPEED=48000000 CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0x110000 diff --git a/configs/am43xx_evm_rtconly_defconfig b/configs/am43xx_evm_rtconly_defconfig index 2ff011932853..0fe5479757bf 100644 --- a/configs/am43xx_evm_rtconly_defconfig +++ b/configs/am43xx_evm_rtconly_defconfig @@ -3,8 +3,6 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_TI_COMMON_CMD_OPTIONS=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4033ff00 CONFIG_SF_DEFAULT_SPEED=48000000 CONFIG_ENV_SIZE=0x10000 CONFIG_DM_GPIO=y diff --git a/configs/am43xx_evm_usbhost_boot_defconfig b/configs/am43xx_evm_usbhost_boot_defconfig index 845b686ac93f..c4693bc98249 100644 --- a/configs/am43xx_evm_usbhost_boot_defconfig +++ b/configs/am43xx_evm_usbhost_boot_defconfig @@ -2,8 +2,6 @@ CONFIG_ARM=y CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_OMAP2PLUS=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4033ff00 CONFIG_SF_DEFAULT_SPEED=48000000 CONFIG_ENV_SIZE=0x10000 CONFIG_DM_GPIO=y diff --git a/configs/am43xx_hs_evm_defconfig b/configs/am43xx_hs_evm_defconfig index ff5073cbb2ba..980ef13f1045 100644 --- a/configs/am43xx_hs_evm_defconfig +++ b/configs/am43xx_hs_evm_defconfig @@ -4,8 +4,6 @@ CONFIG_ARCH_CPU_INIT=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_TI_SECURE_DEVICE=y CONFIG_TI_COMMON_CMD_OPTIONS=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4033ff00 CONFIG_SF_DEFAULT_SPEED=48000000 CONFIG_ENV_SIZE=0x10000 CONFIG_DM_GPIO=y diff --git a/configs/am43xx_hs_evm_qspi_defconfig b/configs/am43xx_hs_evm_qspi_defconfig index 5ef59d830e5e..75725e179d79 100644 --- a/configs/am43xx_hs_evm_qspi_defconfig +++ b/configs/am43xx_hs_evm_qspi_defconfig @@ -3,8 +3,6 @@ CONFIG_ARCH_CPU_INIT=y # CONFIG_SYS_THUMB_BUILD is not set CONFIG_ARCH_OMAP2PLUS=y CONFIG_TI_SECURE_DEVICE=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4033ff00 CONFIG_SF_DEFAULT_SPEED=48000000 CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0x110000 diff --git a/configs/cm_t43_defconfig b/configs/cm_t43_defconfig index 32f126a51744..e8603886d6a6 100644 --- a/configs/cm_t43_defconfig +++ b/configs/cm_t43_defconfig @@ -5,8 +5,6 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_SYS_MALLOC_F_LEN=0x400 CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4033ff00 CONFIG_SF_DEFAULT_SPEED=48000000 CONFIG_ENV_SIZE=0x4000 CONFIG_ENV_OFFSET=0xC0000
The DRA7xx EVM board use a slightly different init stack pointer address compared to the AM57xx EVM board, for no particular reason.
Align the address with the AM57xx EVM board (which matches the usual offset to the end of SRAM used by other OMAP devices) prior to removing it as a per-board option in a later commit.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- configs/dra7xx_evm_defconfig | 2 +- configs/dra7xx_hs_evm_defconfig | 2 +- configs/dra7xx_hs_evm_usb_defconfig | 2 +- 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 0cea5504364b..dd2378801249 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -4,7 +4,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x18000 CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4037fef0 +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4037ff00 CONFIG_SF_DEFAULT_SPEED=76800000 CONFIG_DM_GPIO=y CONFIG_SPL_DM_SPI=y diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index 5f56b1875037..b698a36eb838 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -5,7 +5,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x18000 CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4037fef0 +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4037ff00 CONFIG_SF_DEFAULT_SPEED=76800000 CONFIG_DM_GPIO=y CONFIG_SPL_DM_SPI=y diff --git a/configs/dra7xx_hs_evm_usb_defconfig b/configs/dra7xx_hs_evm_usb_defconfig index 5b67a0e8392f..40f47a3adb1e 100644 --- a/configs/dra7xx_hs_evm_usb_defconfig +++ b/configs/dra7xx_hs_evm_usb_defconfig @@ -5,7 +5,7 @@ CONFIG_SYS_MALLOC_F_LEN=0x18000 CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4037fef0 +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4037ff00 CONFIG_SF_DEFAULT_SPEED=76800000 CONFIG_DM_GPIO=y CONFIG_SPL_DM_SPI=y
The init stack pointer was defined to the same value in each DRA7xx board defconfig. Move the common definition to the Kconfig option declaration instead.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- Kconfig | 3 ++- configs/am57xx_evm_defconfig | 2 -- configs/am57xx_hs_evm_defconfig | 2 -- configs/am57xx_hs_evm_usb_defconfig | 2 -- configs/dra7xx_evm_defconfig | 2 -- configs/dra7xx_hs_evm_defconfig | 2 -- configs/dra7xx_hs_evm_usb_defconfig | 2 -- 7 files changed, 2 insertions(+), 13 deletions(-)
diff --git a/Kconfig b/Kconfig index 19ce371a9cc2..70c26b4ce76d 100644 --- a/Kconfig +++ b/Kconfig @@ -236,7 +236,7 @@ config SYS_BOOT_GET_KBD config HAS_CUSTOM_SYS_INIT_SP_ADDR bool "Use a custom location for the initial stack pointer address" depends on ARC || (ARM && !INIT_SP_RELATIVE) || MIPS || PPC || RISCV - default y if OMAP34XX || AM33XX || AM43XX + default y if OMAP34XX || AM33XX || AM43XX || DRA7XX default y if TFABOOT help Typically, we use an initial stack pointer address that is calculated @@ -253,6 +253,7 @@ config CUSTOM_SYS_INIT_SP_ADDR default 0x4020ff00 if OMAP34XX default 0x4030ff00 if AM33XX default 0x4033ff00 if AM43XX + default 0x4037ff00 if DRA7XX default TEXT_BASE if TFABOOT
config SYS_MALLOC_F diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index 7c3ceeb07db0..145c6d8e5855 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -2,8 +2,6 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_NR_DRAM_BANKS=2 -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4037ff00 CONFIG_SF_DEFAULT_SPEED=76800000 CONFIG_DM_GPIO=y CONFIG_SPL_DM_SPI=y diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index 1f7eca4691ee..850fce024f1d 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -3,8 +3,6 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_TI_SECURE_DEVICE=y CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_NR_DRAM_BANKS=2 -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4037ff00 CONFIG_SF_DEFAULT_SPEED=76800000 CONFIG_DM_GPIO=y CONFIG_SPL_DM_SPI=y diff --git a/configs/am57xx_hs_evm_usb_defconfig b/configs/am57xx_hs_evm_usb_defconfig index 807e1d66a6d7..d1ef82b7bcb2 100644 --- a/configs/am57xx_hs_evm_usb_defconfig +++ b/configs/am57xx_hs_evm_usb_defconfig @@ -3,8 +3,6 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_TI_SECURE_DEVICE=y CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_NR_DRAM_BANKS=2 -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4037ff00 CONFIG_SF_DEFAULT_SPEED=76800000 CONFIG_DM_GPIO=y CONFIG_SPL_DM_SPI=y diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index dd2378801249..244d5351bd83 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -3,8 +3,6 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_SYS_MALLOC_F_LEN=0x18000 CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_NR_DRAM_BANKS=2 -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4037ff00 CONFIG_SF_DEFAULT_SPEED=76800000 CONFIG_DM_GPIO=y CONFIG_SPL_DM_SPI=y diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index b698a36eb838..225f279572d5 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -4,8 +4,6 @@ CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_F_LEN=0x18000 CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_NR_DRAM_BANKS=2 -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4037ff00 CONFIG_SF_DEFAULT_SPEED=76800000 CONFIG_DM_GPIO=y CONFIG_SPL_DM_SPI=y diff --git a/configs/dra7xx_hs_evm_usb_defconfig b/configs/dra7xx_hs_evm_usb_defconfig index 40f47a3adb1e..3b37355654ce 100644 --- a/configs/dra7xx_hs_evm_usb_defconfig +++ b/configs/dra7xx_hs_evm_usb_defconfig @@ -4,8 +4,6 @@ CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_F_LEN=0x18000 CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_NR_DRAM_BANKS=2 -CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y -CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4037ff00 CONFIG_SF_DEFAULT_SPEED=76800000 CONFIG_DM_GPIO=y CONFIG_SPL_DM_SPI=y
The maximum U-Boot size was defined to the same value in each OMAP3 board defconfig. Move the common definition to the Kconfig option declaration instead.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- Kconfig | 1 + configs/am3517_evm_defconfig | 1 - configs/devkit8000_defconfig | 1 - configs/igep00x0_defconfig | 1 - configs/omap35_logic_defconfig | 1 - configs/omap35_logic_somlv_defconfig | 1 - configs/omap3_evm_defconfig | 1 - configs/omap3_logic_defconfig | 1 - configs/omap3_logic_somlv_defconfig | 1 - 9 files changed, 1 insertion(+), 8 deletions(-)
diff --git a/Kconfig b/Kconfig index 70c26b4ce76d..69e8b17b7933 100644 --- a/Kconfig +++ b/Kconfig @@ -620,6 +620,7 @@ config SYS_SRAM_SIZE config SYS_MONITOR_LEN int "Maximum size in bytes reserved for U-Boot in memory" default 1048576 if X86 + default 262144 if OMAP34XX default 786432 if ARCH_SUNXI default 0 help diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index 114d1a22f4a3..a6e3a03ec143 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -10,7 +10,6 @@ CONFIG_ENV_SOURCE_FILE="am3517evm" CONFIG_DEFAULT_DEVICE_TREE="ti/omap/am3517-evm" CONFIG_TARGET_AM3517_EVM=y CONFIG_EMIF4=y -CONFIG_SYS_MONITOR_LEN=262144 CONFIG_SPL_SYS_MALLOC_F_LEN=0x2500 CONFIG_SPL=y CONFIG_LTO=y diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index d68bb8bfd37b..b78a567aef75 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -6,7 +6,6 @@ CONFIG_SYS_MALLOC_F_LEN=0x4000 CONFIG_NR_DRAM_BANKS=2 CONFIG_DEFAULT_DEVICE_TREE="omap3-devkit8000" CONFIG_TARGET_DEVKIT8000=y -CONFIG_SYS_MONITOR_LEN=262144 CONFIG_SPL_SYS_MALLOC_F_LEN=0x400 CONFIG_SPL_BSS_START_ADDR=0x80000500 CONFIG_SPL=y diff --git a/configs/igep00x0_defconfig b/configs/igep00x0_defconfig index 493395847255..761f5c31e832 100644 --- a/configs/igep00x0_defconfig +++ b/configs/igep00x0_defconfig @@ -8,7 +8,6 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_ENV_SIZE=0x8000 CONFIG_DEFAULT_DEVICE_TREE="ti/omap/omap3-igep0020" CONFIG_TARGET_OMAP3_IGEP00X0=y -CONFIG_SYS_MONITOR_LEN=262144 CONFIG_SPL_SYS_MALLOC_F_LEN=0x400 CONFIG_SPL=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/omap35_logic_defconfig b/configs/omap35_logic_defconfig index ca1b97a26d9e..539cb15157e3 100644 --- a/configs/omap35_logic_defconfig +++ b/configs/omap35_logic_defconfig @@ -10,7 +10,6 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_DEFAULT_DEVICE_TREE="ti/omap/logicpd-torpedo-35xx-devkit" CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set -CONFIG_SYS_MONITOR_LEN=262144 CONFIG_SPL=y CONFIG_LTO=y CONFIG_ANDROID_BOOT_IMAGE=y diff --git a/configs/omap35_logic_somlv_defconfig b/configs/omap35_logic_somlv_defconfig index 3b0bc6d1eaf9..3039e2960488 100644 --- a/configs/omap35_logic_somlv_defconfig +++ b/configs/omap35_logic_somlv_defconfig @@ -10,7 +10,6 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_DEFAULT_DEVICE_TREE="ti/omap/logicpd-som-lv-35xx-devkit" CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set -CONFIG_SYS_MONITOR_LEN=262144 CONFIG_SPL=y CONFIG_LTO=y CONFIG_SYS_MONITOR_BASE=0x10000000 diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index d7a3fc4b25b9..c502542a79d0 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -6,7 +6,6 @@ CONFIG_SYS_MALLOC_F_LEN=0x4000 CONFIG_NR_DRAM_BANKS=2 CONFIG_DEFAULT_DEVICE_TREE="omap3-evm" CONFIG_TARGET_OMAP3_EVM=y -CONFIG_SYS_MONITOR_LEN=262144 CONFIG_SPL_SYS_MALLOC_F_LEN=0x400 CONFIG_SPL=y CONFIG_DISTRO_DEFAULTS=y diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index 52e2e459dbb0..522052d7eb40 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -10,7 +10,6 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_DEFAULT_DEVICE_TREE="ti/omap/logicpd-torpedo-37xx-devkit" CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set -CONFIG_SYS_MONITOR_LEN=262144 CONFIG_SPL=y CONFIG_LTO=y CONFIG_ANDROID_BOOT_IMAGE=y diff --git a/configs/omap3_logic_somlv_defconfig b/configs/omap3_logic_somlv_defconfig index 64bb401f7ac9..5c15e87a4584 100644 --- a/configs/omap3_logic_somlv_defconfig +++ b/configs/omap3_logic_somlv_defconfig @@ -10,7 +10,6 @@ CONFIG_NR_DRAM_BANKS=2 CONFIG_DEFAULT_DEVICE_TREE="ti/omap/logicpd-som-lv-37xx-devkit" CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set -CONFIG_SYS_MONITOR_LEN=262144 CONFIG_SPL=y CONFIG_LTO=y CONFIG_SYS_MONITOR_BASE=0x10000000
The maximum SPL size was defined to the same value in each OMAP3 board defconfig. Move the common definition to the Kconfig option declaration instead.
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index 6fc97f4ccbd8..3fd113d776b7 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -78,6 +78,7 @@ config SPL_MAX_SIZE hex "Maximum size of the SPL image, excluding BSS" default 0x30000 if ARCH_MX6 && MX6_OCRAM_256KB default 0x1b000 if AM33XX && !TI_SECURE_DEVICE + default 0xec00 if OMAP34XX default 0x10000 if ARCH_MX6 && !MX6_OCRAM_256KB default 0x7fa0 if SUNXI_SRAM_ADDRESS = 0x10000 default 0x7fa0 if SUNXI_SRAM_ADDRESS = 0x20000 && !MACH_SUN50I_H616 diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index a6e3a03ec143..f492053aa0f4 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -17,7 +17,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTDELAY=10 CONFIG_BOOTCOMMAND="mmc dev ${mmcdev}; if mmc rescan; then echo SD/MMC found on device $mmcdev; if run loadbootenv; then run importbootenv; fi; echo Checking if uenvcmd is set ...; if test -n $uenvcmd; then echo Running uenvcmd ...; run uenvcmd; fi; echo Running default loadimage ...; setenv bootfile zImage; if run loadimage; then run loadfdt; run mmcboot; fi; else run nandboot; fi" CONFIG_SYS_PBSIZE=1054 -CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index b78a567aef75..6c54dba5b4d3 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -13,7 +13,6 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="run autoboot" CONFIG_USE_PREBOOT=y CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y diff --git a/configs/igep00x0_defconfig b/configs/igep00x0_defconfig index 761f5c31e832..04bd464780e5 100644 --- a/configs/igep00x0_defconfig +++ b/configs/igep00x0_defconfig @@ -18,7 +18,6 @@ CONFIG_BOOTCOMMAND="run findfdt; run distro_bootcmd" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 diff --git a/configs/omap35_logic_defconfig b/configs/omap35_logic_defconfig index 539cb15157e3..dca2bc32decc 100644 --- a/configs/omap35_logic_defconfig +++ b/configs/omap35_logic_defconfig @@ -20,7 +20,6 @@ CONFIG_PREBOOT="setenv preboot;saveenv;" CONFIG_DEFAULT_FDT_FILE="logicpd-torpedo-35xx-devkit.dtb" CONFIG_SYS_PBSIZE=1054 CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 diff --git a/configs/omap35_logic_somlv_defconfig b/configs/omap35_logic_somlv_defconfig index 3039e2960488..3cbc1f0bff11 100644 --- a/configs/omap35_logic_somlv_defconfig +++ b/configs/omap35_logic_somlv_defconfig @@ -21,7 +21,6 @@ CONFIG_PREBOOT="setenv preboot;saveenv;" CONFIG_DEFAULT_FDT_FILE="logicpd-som-lv-35xx-devkit.dtb" CONFIG_SYS_PBSIZE=1054 CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index c502542a79d0..032a9bebfc9c 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -14,7 +14,6 @@ CONFIG_USE_PREBOOT=y CONFIG_DEFAULT_FDT_FILE="omap3-evm.dtb" CONFIG_SYS_PBSIZE=1053 CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index 522052d7eb40..4e94170afb1e 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -19,7 +19,6 @@ CONFIG_USE_PREBOOT=y CONFIG_PREBOOT="setenv preboot;saveenv;" CONFIG_SYS_PBSIZE=1054 CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 diff --git a/configs/omap3_logic_somlv_defconfig b/configs/omap3_logic_somlv_defconfig index 5c15e87a4584..97a936f31d75 100644 --- a/configs/omap3_logic_somlv_defconfig +++ b/configs/omap3_logic_somlv_defconfig @@ -21,7 +21,6 @@ CONFIG_PREBOOT="setenv preboot;saveenv;" CONFIG_DEFAULT_FDT_FILE="logicpd-som-lv-37xx-devkit.dtb" CONFIG_SYS_PBSIZE=1054 CONFIG_SYS_CONSOLE_INFO_QUIET=y -CONFIG_SPL_MAX_SIZE=0xec00 CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 diff --git a/configs/sniper_defconfig b/configs/sniper_defconfig index 35cfc28006c1..cd0f48528f42 100644 --- a/configs/sniper_defconfig +++ b/configs/sniper_defconfig @@ -14,7 +14,6 @@ CONFIG_BOOTCOMMAND="setenv boot_mmc_part ${kernel_mmc_part}; if test reboot-${re CONFIG_SYS_CBSIZE=512 CONFIG_SYS_PBSIZE=538 CONFIG_SYS_CONSOLE_IS_IN_ENV=y -CONFIG_SPL_MAX_SIZE=0xec00 # CONFIG_SPL_SHARES_INIT_SP_ADDR is not set CONFIG_SPL_SYS_MALLOC=y CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y
The number of DRAM banks was defined to the same value in each OMAP3 board defconfig, which is expected and hardcoded in the code. Move the common definition to the Kconfig option declaration instead.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- Kconfig | 1 + configs/am3517_evm_defconfig | 1 - configs/devkit8000_defconfig | 1 - configs/igep00x0_defconfig | 1 - configs/omap35_logic_defconfig | 1 - configs/omap35_logic_somlv_defconfig | 1 - configs/omap3_evm_defconfig | 1 - configs/omap3_logic_defconfig | 1 - configs/omap3_logic_somlv_defconfig | 1 - configs/sniper_defconfig | 1 - 10 files changed, 1 insertion(+), 9 deletions(-)
diff --git a/Kconfig b/Kconfig index 69e8b17b7933..8b7b213ffec0 100644 --- a/Kconfig +++ b/Kconfig @@ -209,6 +209,7 @@ config ENV_VARS_UBOOT_CONFIG config NR_DRAM_BANKS int "Number of DRAM banks" default 1 if ARCH_SUNXI || ARCH_OWL + default 2 if OMAP34XX default 4 help This defines the number of DRAM banks. diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index f492053aa0f4..4eb406673ff5 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -5,7 +5,6 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_TEXT_BASE=0x80100000 CONFIG_SYS_MALLOC_F_LEN=0x4000 CONFIG_TI_COMMON_CMD_OPTIONS=y -CONFIG_NR_DRAM_BANKS=2 CONFIG_ENV_SOURCE_FILE="am3517evm" CONFIG_DEFAULT_DEVICE_TREE="ti/omap/am3517-evm" CONFIG_TARGET_AM3517_EVM=y diff --git a/configs/devkit8000_defconfig b/configs/devkit8000_defconfig index 6c54dba5b4d3..33201cec7726 100644 --- a/configs/devkit8000_defconfig +++ b/configs/devkit8000_defconfig @@ -3,7 +3,6 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_TEXT_BASE=0x80100000 CONFIG_SYS_MALLOC_LEN=0x40000 CONFIG_SYS_MALLOC_F_LEN=0x4000 -CONFIG_NR_DRAM_BANKS=2 CONFIG_DEFAULT_DEVICE_TREE="omap3-devkit8000" CONFIG_TARGET_DEVKIT8000=y CONFIG_SPL_SYS_MALLOC_F_LEN=0x400 diff --git a/configs/igep00x0_defconfig b/configs/igep00x0_defconfig index 04bd464780e5..f1d9bb34abae 100644 --- a/configs/igep00x0_defconfig +++ b/configs/igep00x0_defconfig @@ -4,7 +4,6 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_SYS_MALLOC_F_LEN=0x4000 CONFIG_TI_COMMON_CMD_OPTIONS=y -CONFIG_NR_DRAM_BANKS=2 CONFIG_ENV_SIZE=0x8000 CONFIG_DEFAULT_DEVICE_TREE="ti/omap/omap3-igep0020" CONFIG_TARGET_OMAP3_IGEP00X0=y diff --git a/configs/omap35_logic_defconfig b/configs/omap35_logic_defconfig index dca2bc32decc..843b61dec4a6 100644 --- a/configs/omap35_logic_defconfig +++ b/configs/omap35_logic_defconfig @@ -6,7 +6,6 @@ CONFIG_TEXT_BASE=0x80100000 CONFIG_SYS_MALLOC_F_LEN=0x3000 CONFIG_TI_COMMON_CMD_OPTIONS=y # CONFIG_SPL_GPIO is not set -CONFIG_NR_DRAM_BANKS=2 CONFIG_DEFAULT_DEVICE_TREE="ti/omap/logicpd-torpedo-35xx-devkit" CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set diff --git a/configs/omap35_logic_somlv_defconfig b/configs/omap35_logic_somlv_defconfig index 3cbc1f0bff11..bbd1b746cf90 100644 --- a/configs/omap35_logic_somlv_defconfig +++ b/configs/omap35_logic_somlv_defconfig @@ -6,7 +6,6 @@ CONFIG_TEXT_BASE=0x80100000 CONFIG_SYS_MALLOC_F_LEN=0x3000 CONFIG_TI_COMMON_CMD_OPTIONS=y # CONFIG_SPL_GPIO is not set -CONFIG_NR_DRAM_BANKS=2 CONFIG_DEFAULT_DEVICE_TREE="ti/omap/logicpd-som-lv-35xx-devkit" CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set diff --git a/configs/omap3_evm_defconfig b/configs/omap3_evm_defconfig index 032a9bebfc9c..cc0b61af509e 100644 --- a/configs/omap3_evm_defconfig +++ b/configs/omap3_evm_defconfig @@ -3,7 +3,6 @@ CONFIG_ARM=y # CONFIG_SPL_USE_ARCH_MEMSET is not set CONFIG_ARCH_OMAP2PLUS=y CONFIG_SYS_MALLOC_F_LEN=0x4000 -CONFIG_NR_DRAM_BANKS=2 CONFIG_DEFAULT_DEVICE_TREE="omap3-evm" CONFIG_TARGET_OMAP3_EVM=y CONFIG_SPL_SYS_MALLOC_F_LEN=0x400 diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index 4e94170afb1e..ed04386cf95f 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -6,7 +6,6 @@ CONFIG_TEXT_BASE=0x80100000 CONFIG_SYS_MALLOC_F_LEN=0x3000 CONFIG_TI_COMMON_CMD_OPTIONS=y # CONFIG_SPL_GPIO is not set -CONFIG_NR_DRAM_BANKS=2 CONFIG_DEFAULT_DEVICE_TREE="ti/omap/logicpd-torpedo-37xx-devkit" CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set diff --git a/configs/omap3_logic_somlv_defconfig b/configs/omap3_logic_somlv_defconfig index 97a936f31d75..c5d76d0d0860 100644 --- a/configs/omap3_logic_somlv_defconfig +++ b/configs/omap3_logic_somlv_defconfig @@ -6,7 +6,6 @@ CONFIG_TEXT_BASE=0x80100000 CONFIG_SYS_MALLOC_F_LEN=0x3000 CONFIG_TI_COMMON_CMD_OPTIONS=y # CONFIG_SPL_GPIO is not set -CONFIG_NR_DRAM_BANKS=2 CONFIG_DEFAULT_DEVICE_TREE="ti/omap/logicpd-som-lv-37xx-devkit" CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set diff --git a/configs/sniper_defconfig b/configs/sniper_defconfig index cd0f48528f42..08ab3a66c51a 100644 --- a/configs/sniper_defconfig +++ b/configs/sniper_defconfig @@ -4,7 +4,6 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_TEXT_BASE=0x80100000 CONFIG_SYS_MALLOC_LEN=0x120000 CONFIG_SYS_MALLOC_F_LEN=0x400 -CONFIG_NR_DRAM_BANKS=2 CONFIG_TARGET_SNIPER=y CONFIG_SPL_STACK=0x4020fffc CONFIG_SPL_BSS_START_ADDR=0x80000000
The common EMIF init code used for DRA7xx does not explicitly fill the gd->bd->bi_dram entries (like OMAP3 does), so there is no reason to set an explicit number of DRAM banks which doesn't correspond to anything in particular.
Remove the CONFIG_NR_DRAM_BANKS option from the concerned defconfigs. The dram_init_banksize default implementation will be fine with the default value for the config option.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- configs/am57xx_evm_defconfig | 1 - configs/am57xx_hs_evm_defconfig | 1 - configs/am57xx_hs_evm_usb_defconfig | 1 - configs/dra7xx_evm_defconfig | 1 - configs/dra7xx_hs_evm_defconfig | 1 - configs/dra7xx_hs_evm_usb_defconfig | 1 - 6 files changed, 6 deletions(-)
diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index 145c6d8e5855..587af53acb61 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -1,7 +1,6 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_TI_COMMON_CMD_OPTIONS=y -CONFIG_NR_DRAM_BANKS=2 CONFIG_SF_DEFAULT_SPEED=76800000 CONFIG_DM_GPIO=y CONFIG_SPL_DM_SPI=y diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index 850fce024f1d..b790897645fb 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_TI_SECURE_DEVICE=y CONFIG_TI_COMMON_CMD_OPTIONS=y -CONFIG_NR_DRAM_BANKS=2 CONFIG_SF_DEFAULT_SPEED=76800000 CONFIG_DM_GPIO=y CONFIG_SPL_DM_SPI=y diff --git a/configs/am57xx_hs_evm_usb_defconfig b/configs/am57xx_hs_evm_usb_defconfig index d1ef82b7bcb2..450751b354fd 100644 --- a/configs/am57xx_hs_evm_usb_defconfig +++ b/configs/am57xx_hs_evm_usb_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_TI_SECURE_DEVICE=y CONFIG_TI_COMMON_CMD_OPTIONS=y -CONFIG_NR_DRAM_BANKS=2 CONFIG_SF_DEFAULT_SPEED=76800000 CONFIG_DM_GPIO=y CONFIG_SPL_DM_SPI=y diff --git a/configs/dra7xx_evm_defconfig b/configs/dra7xx_evm_defconfig index 244d5351bd83..6264d9fa7ada 100644 --- a/configs/dra7xx_evm_defconfig +++ b/configs/dra7xx_evm_defconfig @@ -2,7 +2,6 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_SYS_MALLOC_F_LEN=0x18000 CONFIG_TI_COMMON_CMD_OPTIONS=y -CONFIG_NR_DRAM_BANKS=2 CONFIG_SF_DEFAULT_SPEED=76800000 CONFIG_DM_GPIO=y CONFIG_SPL_DM_SPI=y diff --git a/configs/dra7xx_hs_evm_defconfig b/configs/dra7xx_hs_evm_defconfig index 225f279572d5..4e7929718fd8 100644 --- a/configs/dra7xx_hs_evm_defconfig +++ b/configs/dra7xx_hs_evm_defconfig @@ -3,7 +3,6 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_F_LEN=0x18000 CONFIG_TI_COMMON_CMD_OPTIONS=y -CONFIG_NR_DRAM_BANKS=2 CONFIG_SF_DEFAULT_SPEED=76800000 CONFIG_DM_GPIO=y CONFIG_SPL_DM_SPI=y diff --git a/configs/dra7xx_hs_evm_usb_defconfig b/configs/dra7xx_hs_evm_usb_defconfig index 3b37355654ce..68d342b277cd 100644 --- a/configs/dra7xx_hs_evm_usb_defconfig +++ b/configs/dra7xx_hs_evm_usb_defconfig @@ -3,7 +3,6 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_TI_SECURE_DEVICE=y CONFIG_SYS_MALLOC_F_LEN=0x18000 CONFIG_TI_COMMON_CMD_OPTIONS=y -CONFIG_NR_DRAM_BANKS=2 CONFIG_SF_DEFAULT_SPEED=76800000 CONFIG_DM_GPIO=y CONFIG_SPL_DM_SPI=y
Remove custom config options that are not particularly necessary. Align them with OMAP3 defaults used on other boards (especially for memory locations).
Also enable Thumb build to reduce the SPL size and remove the custom prompt text.
This makes the config a lot more minimalistic, maintainable and easier to read.
Signed-off-by: Paul Kocialkowski contact@paulk.fr --- configs/sniper_defconfig | 16 ++++------------ 1 file changed, 4 insertions(+), 12 deletions(-)
diff --git a/configs/sniper_defconfig b/configs/sniper_defconfig index 08ab3a66c51a..5c6f9328bf8b 100644 --- a/configs/sniper_defconfig +++ b/configs/sniper_defconfig @@ -1,28 +1,20 @@ CONFIG_ARM=y -# CONFIG_SYS_THUMB_BUILD is not set CONFIG_ARCH_OMAP2PLUS=y -CONFIG_TEXT_BASE=0x80100000 -CONFIG_SYS_MALLOC_LEN=0x120000 -CONFIG_SYS_MALLOC_F_LEN=0x400 +CONFIG_SYS_MALLOC_F_LEN=0x4000 CONFIG_TARGET_SNIPER=y -CONFIG_SPL_STACK=0x4020fffc -CONFIG_SPL_BSS_START_ADDR=0x80000000 +CONFIG_SPL_SYS_MALLOC_F_LEN=0x400 CONFIG_SPL=y CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="setenv boot_mmc_part ${kernel_mmc_part}; if test reboot-${reboot-mode} = reboot-r; then echo recovery; setenv boot_mmc_part ${recovery_mmc_part}; fi; if test reboot-${reboot-mode} = reboot-b; then echo fastboot; fastboot 0; fi; part start mmc ${boot_mmc_dev} ${boot_mmc_part} boot_mmc_start; part size mmc ${boot_mmc_dev} ${boot_mmc_part} boot_mmc_size; mmc dev ${boot_mmc_dev}; mmc read ${kernel_addr_r} ${boot_mmc_start} ${boot_mmc_size} && bootm ${kernel_addr_r};" -CONFIG_SYS_CBSIZE=512 -CONFIG_SYS_PBSIZE=538 CONFIG_SYS_CONSOLE_IS_IN_ENV=y -# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_SYS_MALLOC=y -CONFIG_SPL_HAS_CUSTOM_MALLOC_START=y -CONFIG_SPL_CUSTOM_SYS_MALLOC_ADDR=0x80208000 +CONFIG_SPL_SYS_MALLOC_SIZE=0x800000 # CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR is not set CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION=2 # CONFIG_SPL_FS_EXT4 is not set # CONFIG_SPL_NAND_SUPPORT is not set -CONFIG_SYS_PROMPT="sniper # " CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y
On Sun, Jul 28, 2024 at 10:24:49PM +0200, Paul Kocialkowski wrote:
Here is a bunch of configuration cleanups for OMAP boards, mostly unifying and moving common configuration from board-specific defconfigs to Kconfig definitions.
There's also a cleanup of the sniper (LG Optimus Black) defconfig, prior to migrating it to DM/DT in a future follow-up series.
Paul Kocialkowski (12): omap3: Define common SPL text base in Kconfig instead of defconfigs omap3: Define common init stack pointer address in Kconfig am33xx: Unify init stack pointer address across boards am33xx: Define common init stack pointer address in Kconfig am43xx: Define common init stack pointer address in Kconfig dra7xx: Unify init stack pointer address across boards dra7xx: Define common init stack pointer address in Kconfig omap3: Define maximum U-Boot size in Kconfig instead of defconfigs omap3: Define maximum SPL size in Kconfig instead of defconfigs omap3: Define DRAM banks number in Kconfig instead of defconfigs dra7xx: Remove explicit DRAM banks number from defconfigs omap3: sniper: Streamline defconfig
Kconfig | 7 +++++++ common/spl/Kconfig | 2 ++ configs/am335x_baltos_defconfig | 2 -- configs/am335x_evm_defconfig | 2 -- configs/am335x_evm_spiboot_defconfig | 2 -- configs/am335x_guardian_defconfig | 2 -- configs/am335x_hs_evm_defconfig | 2 -- configs/am335x_hs_evm_uart_defconfig | 2 -- configs/am335x_igep003x_defconfig | 2 -- configs/am335x_pdu001_defconfig | 2 -- configs/am335x_shc_defconfig | 2 -- configs/am335x_shc_ict_defconfig | 2 -- configs/am335x_shc_netboot_defconfig | 2 -- configs/am335x_shc_sdboot_defconfig | 2 -- configs/am335x_sl50_defconfig | 2 -- configs/am3517_evm_defconfig | 6 ------ configs/am43xx_evm_defconfig | 2 -- configs/am43xx_evm_qspiboot_defconfig | 2 -- configs/am43xx_evm_rtconly_defconfig | 2 -- configs/am43xx_evm_usbhost_boot_defconfig | 2 -- configs/am43xx_hs_evm_defconfig | 2 -- configs/am43xx_hs_evm_qspi_defconfig | 2 -- configs/am57xx_evm_defconfig | 3 --- configs/am57xx_hs_evm_defconfig | 3 --- configs/am57xx_hs_evm_usb_defconfig | 3 --- configs/brppt1_mmc_defconfig | 2 -- configs/brsmarc1_defconfig | 2 -- configs/brxre1_defconfig | 2 -- configs/chiliboard_defconfig | 2 -- configs/cm_t43_defconfig | 2 -- configs/devkit8000_defconfig | 6 ------ configs/dra7xx_evm_defconfig | 3 --- configs/dra7xx_hs_evm_defconfig | 3 --- configs/dra7xx_hs_evm_usb_defconfig | 3 --- configs/draco-etamin_defconfig | 2 -- configs/draco-rastaban_defconfig | 2 -- configs/draco-thuban_defconfig | 2 -- configs/igep00x0_defconfig | 6 ------ configs/omap35_logic_defconfig | 6 ------ configs/omap35_logic_somlv_defconfig | 6 ------ configs/omap3_evm_defconfig | 6 ------ configs/omap3_logic_defconfig | 6 ------ configs/omap3_logic_somlv_defconfig | 6 ------ configs/pcm051_rev3_defconfig | 2 -- configs/phycore-am335x-r2-regor_defconfig | 2 -- configs/phycore-am335x-r2-wega_defconfig | 2 -- configs/pxm2_defconfig | 2 -- configs/rut_defconfig | 2 -- configs/sniper_defconfig | 21 ++++----------------- 49 files changed, 13 insertions(+), 147 deletions(-)
-- 2.45.2
For "configs/omap3_evm_defconfig":
Tested-by: Derald D. Woods woods.technical@gmail.com
Thanks! For the series:
Adam Ford
Derald D. Woods
Paul Kocialkowski
