[U-Boot] [PATCH 0/2] SMDKV310 Board support
Hi, This patchset adds support for a new board SMDKV310, based on S5PV310 SOC. This SOC is very similar to S5PC210 SOC, hence we are re-using this SOC code.
Chander Kashyap (2): ARMV7: Adding support for Samsung SMDKV310 Board ARMV7: MMC SPL Boot support for SMDKV310 board
Makefile | 11 +- board/samsung/smdkv310/Makefile | 46 ++ board/samsung/smdkv310/config.mk | 1 + board/samsung/smdkv310/lowlevel_init.S | 549 ++++++++++++++++++++ board/samsung/smdkv310/mem_setup.S | 632 +++++++++++++++++++++++ board/samsung/smdkv310/smdkv310.c | 138 +++++ boards.cfg | 1 + include/configs/smdkv310.h | 199 +++++++ spl/board/samsung/smdkv310/Makefile | 104 ++++ spl/board/samsung/smdkv310/mmc_boot.c | 82 +++ spl/board/samsung/smdkv310/tools/mkv310_image.c | 103 ++++ spl/board/samsung/smdkv310/u-boot.lds | 86 +++ 12 files changed, 1951 insertions(+), 1 deletions(-) create mode 100644 board/samsung/smdkv310/Makefile create mode 100644 board/samsung/smdkv310/config.mk create mode 100644 board/samsung/smdkv310/lowlevel_init.S create mode 100644 board/samsung/smdkv310/mem_setup.S create mode 100644 board/samsung/smdkv310/smdkv310.c create mode 100644 include/configs/smdkv310.h create mode 100644 spl/board/samsung/smdkv310/Makefile create mode 100644 spl/board/samsung/smdkv310/mmc_boot.c create mode 100644 spl/board/samsung/smdkv310/tools/mkv310_image.c create mode 100644 spl/board/samsung/smdkv310/u-boot.lds
SMDKV310 board is based on Samsung S5PV310 SOC. This SOC is very much similar to S5PC210.
Signed-off-by: Chander Kashyap chander.kashyap@linaro.org Signed-off-by: Tushar Behera tushar.behera@linaro.org --- board/samsung/smdkv310/Makefile | 46 +++ board/samsung/smdkv310/config.mk | 1 + board/samsung/smdkv310/lowlevel_init.S | 549 +++++++++++++++++++++++++++ board/samsung/smdkv310/mem_setup.S | 632 ++++++++++++++++++++++++++++++++ board/samsung/smdkv310/smdkv310.c | 138 +++++++ boards.cfg | 1 + include/configs/smdkv310.h | 199 ++++++++++ 7 files changed, 1566 insertions(+), 0 deletions(-) create mode 100644 board/samsung/smdkv310/Makefile create mode 100644 board/samsung/smdkv310/config.mk create mode 100644 board/samsung/smdkv310/lowlevel_init.S create mode 100644 board/samsung/smdkv310/mem_setup.S create mode 100644 board/samsung/smdkv310/smdkv310.c create mode 100644 include/configs/smdkv310.h
diff --git a/board/samsung/smdkv310/Makefile b/board/samsung/smdkv310/Makefile new file mode 100644 index 0000000..8e9b703 --- /dev/null +++ b/board/samsung/smdkv310/Makefile @@ -0,0 +1,46 @@ +# +# Copyright (C) 2011 Samsung Electronics +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).o + +SOBJS := mem_setup.o +SOBJS += lowlevel_init.o +COBJS += smdkv310.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS) $(SOBJS)) + +all: $(obj).depend $(LIB) + +$(LIB): $(OBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) + +######################################################################### + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/board/samsung/smdkv310/config.mk b/board/samsung/smdkv310/config.mk new file mode 100644 index 0000000..19b9e2f --- /dev/null +++ b/board/samsung/smdkv310/config.mk @@ -0,0 +1 @@ +CONFIG_SYS_TEXT_BASE = 0x43e00000 diff --git a/board/samsung/smdkv310/lowlevel_init.S b/board/samsung/smdkv310/lowlevel_init.S new file mode 100644 index 0000000..ead12b2 --- /dev/null +++ b/board/samsung/smdkv310/lowlevel_init.S @@ -0,0 +1,549 @@ +/* + * Lowlevel setup for SMDKV310 board based on S5PC210 + * + * Copyright (C) 2011 Samsung Electronics + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> +#include <version.h> +#include <asm/arch/cpu.h> + +/* + * Register usages: + * + * r5 has zero always + * r7 has GPIO part1 base 0x11400000 + * r6 has GPIO part2 base 0x11000000 + */ + +#define MEM_DLLl_ON + + +_TEXT_BASE: + .word CONFIG_SYS_TEXT_BASE + + .globl lowlevel_init +lowlevel_init: + push {lr} + + + /* r5 has always zero */ + mov r5, #0 + + ldr r7, =S5PC210_GPIO_PART1_BASE + ldr r6, =S5PC210_GPIO_PART2_BASE + + /* check reset status */ + ldr r0, =(S5PC210_POWER_BASE + 0x81C) @ INFORM7 + ldr r1, [r0] + + /* AFTR wakeup reset */ + ldr r2, =S5P_CHECK_DIDLE + cmp r1, r2 + beq exit_wakeup + + /* Sleep wakeup reset */ + ldr r2, =S5P_CHECK_SLEEP + cmp r1, r2 + beq wakeup_reset + + /* when we already run in ram, we don't need to relocate U-Boot. + * and actually, memory controller must be configured before U-Boot + * is running in ram. + */ + ldr r0, =0x00ffffff /* r0 <- Mask Bits*/ + bic r1, pc, r0 /* pc <- current addr of code */ + /* r1 <- unmasked bits of pc */ + + ldr r2, _TEXT_BASE /* r2 <- original base addr in ram */ + bic r2, r2, r0 /* r2 <- unmasked bits of r2*/ + cmp r1, r2 /* compare r1, r2 */ + beq 1f /* r0 == r1 then skip sdram init */ + + /* init system clock */ + bl system_clock_init + + /* Memory initialize */ + bl mem_ctrl_asm_init + +1: + /* for UART */ + bl uart_asm_init + bl tzpc_init + pop {pc} + +wakeup_reset: + bl system_clock_init + bl mem_ctrl_asm_init + bl tzpc_init + +exit_wakeup: + /*Load return address and jump to kernel*/ + ldr r0, =(S5PC210_POWER_BASE + 0x800) @ INFORM0 + + /* r1 = physical address of s5pc210_cpu_resume function */ + ldr r1, [r0] + + /* Jump to kernel*/ + mov pc, r1 + nop + nop + +/* + * system_clock_init: Initialize core clock and bus clock. + * void system_clock_init(void) + */ +system_clock_init: + push {lr} + ldr r0, =S5PC210_CLOCK_BASE + + /* APLL(1), MPLL(1), CORE(0), HPM(0) */ + ldr r1, =0x0101 + ldr r2, =0x14200 @CLK_SRC_CPU + str r1, [r0, r2] + + /* wait ?us */ + mov r1, #0x10000 +1: subs r1, r1, #1 + bne 1b + + ldr r1, =0x0110 + ldr r2, =0x0C210 @CLK_SRC_TOP0 + str r1, [r0, r2] + + ldr r1, =0x00 + ldr r2, =0x0C214 @CLK_SRC_TOP1_OFFSET + str r1, [r0, r2] + + /* DMC */ + ldr r1, =0x00 + ldr r2, =0x10200 @CLK_SRC_DMC_OFFSET + str r1, [r0, r2] + + /* SATA: SCLKMPLL(0), MMC[0:4]: SCLKMPLL(6) */ + + ldr r1, =0x066666 + ldr r2, =0x0C240 @ CLK_SRC_FSYS + str r1, [r0, r2] + + /*CLK_SRC_LEFTBUS */ + ldr r1, =0x00 + ldr r2, =0x04200 @CLK_SRC_LEFTBUS_OFFSET + str r1, [r0, r2] + + /*CLK_SRC_RIGHTBUS */ + ldr r1, =0x00 + ldr r2, =0x08200 @CLK_SRC_RIGHTBUS_OFFSET + str r1, [r0, r2] + + /* UART[0:4], PWM: SCLKMPLL(6) */ + ldr r1, =0x06666666 + ldr r2, =0x0C250 @CLK_SRC_PERIL0_OFFSET + str r1, [r0, r2] + + /* wait ?us */ + mov r1, #0x10000 +4: subs r1, r1, #1 + bne 4b + + /* CLK_DIV_CPU0: + PCLK_DBG_RATIO[20] 0x1 + ATB_RATIO[16] 0x3 + PERIPH_RATIO[12] 0x3 + COREM1_RATIO[8] 0x7 + COREM0_RATIO[4] 0x3 + */ + ldr r1, =0x0133730 + ldr r2, =0x14500 @CLK_DIV_CPU0_OFFSET + str r1, [r0, r2] + + /* CLK_DIV_CPU1 + COPY_RATIO [0] 0x3 + */ + ldr r1, =0x03 + ldr r2, =0x14504 @CLK_DIV_CPU1_OFFSET + str r1, [r0, r2] + + /* wait ?us */ + mov r1, #0x10000 +2: subs r1, r1, #1 + bne 2b + + /* MMC[0:1] */ + ldr r1, =0x000f000f /* 800(MPLL) / (15 + 1) */ + ldr r2, =0x0C544 @ CLK_DIV_FSYS1 + str r1, [r0, r2] + /* MMC[2:3] */ + ldr r1, =0x000f070f /* 800(MPLL) / (15 + 1) */ + ldr r2, =0x0C548 @ CLK_DIV_FSYS2 + str r1, [r0, r2] + /* MMC4 */ + ldr r1, =0x000f /* 800(MPLL) / (15 + 1) */ + ldr r2, =0x0C54C @ CLK_DIV_FSYS3 + str r1, [r0, r2] + + /* CLK_DIV_DMC0: + CORE_TIMERS_RATIO[28] 0x1 + COPY2_RATIO[24] 0x3 + DMCP_RATIO[20] 0x1 + DMCD_RATIO[16] 0x1 + DMC_RATIO[12] 0x1 + DPHY_RATIO[8] 0x1 + ACP_PCLK_RATIO[4] 0x1 + ACP_RATIO[0] 0x3 + */ + ldr r1, =0x13111113 + ldr r2, =0x010500 @CLK_DIV_DMC0_OFFSET + str r1, [r0, r2] + + /* CLK_DIV_DMC1: + DPM_RATIO[24] 0x1 + DVSEM_RATIO[16] 0x1 + PWI_RATIO[8] 0x1 + */ + ldr r1, =0x01010100 + ldr r2, =0x010504 @CLK_DIV_DMC1_OFFSET + str r1, [r0, r2] + + /* CLK_DIV_PERIL0: + UART5_RATIO[20] 8 + UART4_RATIO[16] 8 + UART3_RATIO[12] 8 + UART2_RATIO[8] 8 + UART1_RATIO[4] 8 + UART0_RATIO[0] 8 + */ + ldr r1, =0x774777 + ldr r2, =0x0C550 @CLK_DIV_PERIL0_OFFSET + str r1, [r0, r2] + + /* SLIMBUS: ???, PWM */ + ldr r1, =0x8 + ldr r2, =0x0C55C @ CLK_DIV_PERIL3 + str r1, [r0, r2] + + /* CLK_DIV_TOP: + ONENAND_RATIO[16] 0x0 + ACLK_133_RATIO[12] 0x5 + ACLK_160_RATIO[8] 0x4 + ACLK_100_RATIO[4] 0x7 + ACLK_200_RATIO[0] 0x3 + */ + ldr r1, =0x05473 + ldr r2, =0x0C510 @CLK_DIV_TOP_OFFSET + str r1, [r0, r2] + + /* CLK_DIV_LEFRBUS: + GPL_RATIO[4] 0x1 + GDL_RATIO[0] 0x3 + */ + ldr r1, =0x013 + ldr r2, =0x04500 @CLK_DIV_LEFTBUS_OFFSET + str r1, [r0, r2] + + /* CLK_DIV_RIGHTBUS: + GPR_RATIO[4] 0x1 + GDR_RATIO[0] 0x3 + */ + ldr r1, =0x013 + ldr r2, =0x08500 @CLK_DIV_RIGHTBUS_OFFSET + str r1, [r0, r2] + + /* Set PLL locktime */ + ldr r1, =0x01C20 + ldr r2, =0x014000 @APLL_LOCK_OFFSET + str r1, [r0, r2] + ldr r1, =0x01C20 + ldr r2, =0x014008 @MPLL_LOCK_OFFSET + str r1, [r0, r2] + ldr r1, =0x01C20 + ldr r2, =0x0C010 @EPLL_LOCK_OFFSET + str r1, [r0, r2] + ldr r1, =0x01C20 + ldr r2, =0x0C020 @VPLL_LOCK_OFFSET + str r1, [r0, r2] + + /* APLL_CON1: + APLL_AFC_ENB[31] 0x1 + APLL_AFC[0] 0xC + */ + ldr r1, =0x8000000C + ldr r2, =0x014104 @APLL_CON1_OFFSET + str r1, [r0, r2] + + /*APLL_CON0: + APLL_MDIV[16] 0xFA + APLL_PDIV[8] 0x6 + APLL_SDIV[0] 0x1 + */ + ldr r1, =0x80FA0601 + ldr r2, =0x014100 @APLL_CON0_OFFSET + str r1, [r0, r2] + + /* MPLL_CON1: + MPLL_AFC_ENB[31] 0x0 + MPLL_AFC[0] 0x1C + */ + ldr r1, =0x01C + ldr r2, =0x01410C @MPLL_CON1_OFFSET + str r1, [r0, r2] + + /*MPLL_CON0: + MPLL_MDIV[16] 0xC8 + MPLL_PDIV[8] 0x6 + MPLL_SDIV[0] 0x1 + */ + ldr r1, =0x80C80601 + ldr r2, =0x014108 @MPLL_CON0_OFFSET + str r1, [r0, r2] + + /* EPLL */ + ldr r1, =0x0 + ldr r2, =0x0C114 @EPLL_CON1_OFFSET + str r1, [r0, r2] + /* EPLL_CON0: + EPLL_MDIV[16] 0x30 + EPLL_PDIV[8] 0x3 + EPLL_SDIV[0] 0x2 + */ + ldr r1, =80300302 + ldr r2, =0x0C110 @EPLL_CON0_OFFSET + str r1, [r0, r2] + + /* VPLL_CON1: + VPLL_MRR[24] 0x11 + VPLL_MFR[16] 0x0 + VPLL_K[0] 0x400 + */ + ldr r1, =0x11000400 + ldr r2, =0x0C124 @VPLL_CON1_OFFSET + str r1, [r0, r2] + /* VPLL_CON0: + VPLL_MDIV[16] 0x35 + VPLL_PDIV[8] 0x3 + VPLL_SDIV[0] 0x2 + */ + ldr r1, =0x80350302 + ldr r2, =0x0C120 @VPLL_CON0_OFFSET + str r1, [r0, r2] + + /* wait ?us */ + mov r1, #0x30000 +3: subs r1, r1, #1 + bne 3b + + ldr r0, =S5PC2XX_ADDR_BASE @CHIP_ID_BASE + ldr r1, [r0] + lsr r1, r1, #8 + and r1, r1, #3 + cmp r1, #2 + bne v310_2 + +@ ConControl +#ifdef MEM_DLLl_ON + ldr r0, =S5PC210_DMC0_BASE @0x10400000 + + ldr r1, =0x7110100A + ldr r2, =0x18 @DMC_PHYCONTROL0 + str r1, [r0, r2] + ldr r1, =0x00000084 + ldr r2, =0x1C @DMC_PHYCONTROL1 + str r1, [r0, r2] + ldr r1, =0x7110100B + ldr r2, =0x18 @DMC_PHYCONTROL0 + str r1, [r0, r2] + + /* wait ?us */ + mov r1, #0x20000 +8: subs r1, r1, #1 + bne 8b + + ldr r1, =0x0000008C + ldr r2, =0x1C @DMC_PHYCONTROL1 + str r1, [r0, r2] + ldr r1, =0x00000084 + ldr r2, =0x1C @DMC_PHYCONTROL1 + str r1, [r0, r2] + + /* wait ?us */ + mov r1, #0x20000 +9: subs r1, r1, #1 + bne 9b + + ldr r0, =S5PC210_DMC1_BASE @0x10410000 + + ldr r1, =0x7110100A + ldr r2, =0x18 @DMC_PHYCONTROL0 + str r1, [r0, r2] + ldr r1, =0x00000084 + ldr r2, =0x1C @DMC_PHYCONTROL1 + str r1, [r0, r2] + ldr r1, =0x7110100B + ldr r2, =0x18 @DMC_PHYCONTROL0 + str r1, [r0, r2] + + /* wait ?us */ + mov r1, #0x20000 +10: subs r1, r1, #1 + bne 10b + + ldr r1, =0x0000008C + ldr r2, =0x1C @DMC_PHYCONTROL1 + str r1, [r0, r2] + ldr r1, =0x00000084 + ldr r2, =0x1C @DMC_PHYCONTROL1 + str r1, [r0, r2] +#endif + + ldr r0, =S5PC210_DMC0_BASE @0x10400000 +#ifdef CONFIG_CLK_1000_200_200 + ldr r1, =0x0FFF30f0 +#else + ldr r1, =0x0FFF30fa +#endif + ldr r2, =0x00 @DMC_CONCONTROL + str r1, [r0, r2] + ldr r0, =S5PC210_DMC1_BASE @0x10410000 +#ifdef CONFIG_CLK_1000_200_200 + ldr r1, =0x0FFF30f0 +#else + ldr r1, =0x0FFF30fa +#endif + ldr r2, =0x00 @DMC_CONCONTROL + str r1, [r0, r2] + +v310_2: + pop {pc} + +/* + * Check clock until stable. + */ + + /* Check devider change state */ +wait_div_state1: + ldr r1, =(S5PC210_CLOCK_BASE + 0x1004) @CLK_DIV_STAT1_OFFSET + ldr r2, [r1] + tst r2, #(0x1<<15) + bne wait_div_state1 + mov pc, lr + + /* Check source change state */ +wait_mux_state1: + ldr r1, =(S5PC210_CLOCK_BASE + 0x1104) @CLK_MUX_STAT1_OFFSET + ldr r2, [r1] + tst r2, #(0x1<<31) + bne wait_mux_state1 + mov pc, lr + + /* Check source change state */ +wait_mux_state0: + ldr r1, =(S5PC210_CLOCK_BASE + 0x1100) @CLK_MUX_STAT0_OFFSET + ldr r2, [r1] + tst r2, #(0x4) + bne wait_mux_state0 + mov pc, lr + +/* + * uart_asm_init: Initialize UART in asm mode, 115200bps fixed. + * void uart_asm_init(void) + */ + .globl uart_asm_init +uart_asm_init: + + /* + * setup UART0-UART3 GPIOs (part1) + */ + mov r0, r7 + ldr r1, =0x22222222 + str r1, [r0, #0x00] @ S5PC210_GPIO_A0_OFFSET + ldr r1, =0x00222222 + str r1, [r0, #0x20] @ S5PC210_GPIO_A1_OFFSET + + ldr r0, =S5PC210_UART_BASE + add r0, r0, #S5PC210_UART1_OFFSET + + ldr r1, =0x3C5 + str r1, [r0, #0x4] + ldr r1, =0x111 + str r1, [r0, #0x8] + ldr r1, =0x3 + str r1, [r0, #0x0] + ldr r1, =0x35 + str r1, [r0, #0x28] + ldr r1, =0x4 + str r1, [r0, #0x2c] + + mov pc, lr + nop + nop + nop + +/* + * Setting TZPC[TrustZone Protection Controller] + */ + +tzpc_init: + ldr r0, =0x10110000 + mov r1, #0x0 + str r1, [r0] + mov r1, #0xff + str r1, [r0, #0x0804] + str r1, [r0, #0x0810] + str r1, [r0, #0x081C] + str r1, [r0, #0x0828] + + ldr r0, =0x10120000 + mov r1, #0x0 + str r1, [r0] + mov r1, #0xff + str r1, [r0, #0x0804] + str r1, [r0, #0x0810] + str r1, [r0, #0x081C] + str r1, [r0, #0x0828] + + ldr r0, =0x10130000 + mov r1, #0x0 + str r1, [r0] + mov r1, #0xff + str r1, [r0, #0x0804] + str r1, [r0, #0x0810] + str r1, [r0, #0x081C] + str r1, [r0, #0x0828] + + ldr r0, =0x10140000 + mov r1, #0x0 + str r1, [r0] + mov r1, #0xff + str r1, [r0, #0x0804] + str r1, [r0, #0x0810] + str r1, [r0, #0x081C] + str r1, [r0, #0x0828] + + ldr r0, =0x10150000 + mov r1, #0x0 + str r1, [r0] + mov r1, #0xff + str r1, [r0, #0x0804] + str r1, [r0, #0x0810] + str r1, [r0, #0x081C] + str r1, [r0, #0x0828] + + mov pc, lr diff --git a/board/samsung/smdkv310/mem_setup.S b/board/samsung/smdkv310/mem_setup.S new file mode 100644 index 0000000..3ff486c --- /dev/null +++ b/board/samsung/smdkv310/mem_setup.S @@ -0,0 +1,632 @@ +/* + * Memory setup for SMDKV310 board based on S5PC210 + * + * Copyright (C) 2011 Samsung Electronics + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> + +#define SET_MIU + +#define MEM_DLL + +#ifdef CONFIG_CLK_800_330_165 +#define DRAM_CLK_330 +#endif +#ifdef CONFIG_CLK_1000_200_200 +#define DRAM_CLK_200 +#endif +#ifdef CONFIG_CLK_1000_330_165 +#define DRAM_CLK_330 +#endif +#ifdef CONFIG_CLK_1000_400_200 +#define DRAM_CLK_400 +#endif + + .globl mem_ctrl_asm_init +mem_ctrl_asm_init: + + /* Async bridge configuration at CPU_core */ + /* 1: half_sync */ + /* 0: full_sync */ + ldr r0, =0x10010350 + mov r1, #1 + str r1, [r0] + + ldr r0, =0x10000000 @CHIP_ID_BASE + ldr r1, [r0] + lsr r1, r1, #8 + and r1, r1, #3 + cmp r1, #2 + bne v310 + + /* CLK_DIV_DMC0 on iROM DMC=50MHz for Init DMC */ + ldr r0, =0x10030000 @CMU_BASE + ldr r1, =0x13113113 + ldr r2, =0x10500 @CLK_DIV_DMC0_OFFSET + str r1, [r0, r2] + +#ifdef SET_MIU + ldr r0, =0x10600000 @MIU_BASE +#ifdef CONFIG_MIU_1BIT_INTERLEAVED + ldr r1, =0x0000000c + str r1, [r0, #0x400] @MIU_INTLV_CONFIG + ldr r1, =0x40000000 + str r1, [r0, #0x808] @MIU_INTLV_START_ADDR + ldr r1, =0x5fffffff + str r1, [r0, #0x810] @MIU_INTLV_END_ADDR + ldr r1, =0x00000001 + str r1, [r0, #0x800] @MIU_MAPPING_UPDATE +#endif +#ifdef CONFIG_MIU_2BIT_INTERLEAVED + ldr r1, =0x2000150c + str r1, [r0, #0x400] @MIU_INTLV_CONFIG + ldr r1, =0x40000000 + str r1, [r0, #0x808] @MIU_INTLV_START_ADDR + ldr r1, =0x5fffffff + str r1, [r0, #0x810] @MIU_INTLV_END_ADDR + ldr r1, =0x00000001 + str r1, [r0, #0x800] @MIU_MAPPING_UPDATE +#endif +#ifdef CONFIG_MIU_LINEAR + ldr r1, =0x40000000 + str r1, [r0, #0x818] @MIU_SINGLE_MAPPING0_START_ADDR + ldr r1, =0x4fffffff + str r1, [r0, #0x820] @MIU_SINGLE_MAPPING0_END_ADDR + ldr r1, =0x50000000 + str r1, [r0, #0x828] @MIU_SINGLE_MAPPING1_START_ADDR + ldr r1, =0x5fffffff + str r1, [r0, #0x830] @MIU_SINGLE_MAPPING1_END_ADDR] + ldr r1, =0x00000006 + str r1, [r0, #0x800] @MIU_MAPPING_UPDATE +#endif +#endif + +/*****************************************************************/ +/*DREX0***********************************************************/ +/*****************************************************************/ + ldr r0, =0x10400000 @APB_DMC_0_BASE + + ldr r1, =0xE3855503 + str r1, [r0, #0x44] @DMC_PHYZQCONTROL + + ldr r1, =0x71101008 + str r1, [r0, #0x18] @DMC_PHYCONTROL0 + + ldr r1, =0x7110100A + str r1, [r0, #0x18] @DMC_PHYCONTROL0 + + ldr r1, =0x00000084 + str r1, [r0, #0x1C] @DMC_PHYCONTROL1 + + ldr r1, =0x71101008 + str r1, [r0, #0x18] @DMC_PHYCONTROL0 + + ldr r1, =0x0000008C + str r1, [r0, #0x1C] @DMC_PHYCONTROL1 + + ldr r1, =0x00000084 + str r1, [r0, #0x1C] @DMC_PHYCONTROL1 + + ldr r1, =0x0000008C + str r1, [r0, #0x1C] @DMC_PHYCONTROL1 + + ldr r1, =0x00000084 + str r1, [r0, #0x1C] @DMC_PHYCONTROL1 + + ldr r1, =0x00000000 + str r1, [r0, #0x20] @DMC_PHYCONTROL2 + + ldr r1, =0x0FFF30da + str r1, [r0, #0x00] @DMC_CONCONTROL + ldr r1, =0x00202500 + str r1, [r0, #0x04] @DMC_MEMCONTROL] +#ifdef MIU_LINEAR + ldr r1, =0x40f01223 + str r1, [r0, #0x08] @DMC_MEMCONFIG0 +#else /* @MIU_1BIT_INTERLEAVED | MIU_2BIT_INTERLEAVED */ + ldr r1, =0x20f01223 + str r1, [r0, #0x08] @DMC_MEMCONFIG0 +#endif + ldr r1, =0xff000000 + str r1, [r0, #0x14] @DMC_PRECHCONFIG + + ldr r1, =0x0000005D + str r1, [r0, #0x30] @DMC_TIMINGAREF + +#ifdef DRAM_CLK_200 + ldr r1, =0x1A254349 + str r1, [r0, #0x34] @DMC_TIMINGROW + ldr r1, =0x23230306 + str r1, [r0, #0x38] @DMC_TIMINGDATA + ldr r1, =0x281c0235 + str r1, [r0, #0x3C] @DMC_TIMINGPOWER +#endif +#ifdef DRAM_CLK_330 + ldr r1, =0x2b47654e + str r1, [r0, #0x34] @DMC_TIMINGROW + ldr r1, =0x35330306 + str r1, [r0, #0x38] @DMC_TIMINGDATA + ldr r1, =0x442f0365 + str r1, [r0, #0x3C] @DMC_TIMINGPOWER +#endif +#ifdef DRAM_CLK_400 + ldr r1, =0x34498691 + str r1, [r0, #0x34] @DMC_TIMINGROW + ldr r1, =0x36330306 + str r1, [r0, #0x38] @DMC_TIMINGDATA + ldr r1, =0x50380365 + str r1, [r0, #0x3C] @DMC_TIMINGPOWER +#endif + + mov r2, #0x100000 +2: subs r2, r2, #1 + bne 2b + ldr r1, =0x07000000 + str r1, [r0, #0x10] @DMC_DIRECTCMD + mov r2, #0x100000 +3: subs r2, r2, #1 + bne 3b + ldr r1, =0x00071C00 + str r1, [r0, #0x10] @DMC_DIRECTCMD + mov r2, #0x100000 +4: subs r2, r2, #1 + bne 4b + + ldr r1, =0x00010BFC + str r1, [r0, #0x10] @DMC_DIRECTCMD + mov r2, #0x100000 +5: subs r2, r2, #1 + bne 5b + ldr r1, =0x00000488 + str r1, [r0, #0x10] @DMC_DIRECTCMD + ldr r1, =0x00000810 + str r1, [r0, #0x10] @DMC_DIRECTCMD + ldr r1, =0x00000C08 + str r1, [r0, #0x10] @DMC_DIRECTCMD + +/*****************************************************************/ +/*DREX1***********************************************************/ +/*****************************************************************/ + ldr r0, =0x10410000 @APB_DMC_1_BASE + ldr r1, =0xE3855503 + str r1, [r0, #0x44] @DMC_PHYZQCONTROL + + ldr r1, =0x71101008 + str r1, [r0, #0x18] @DMC_PHYCONTROL0 + + ldr r1, =0x7110100A + str r1, [r0, #0x18] @DMC_PHYCONTROL0 + + ldr r1, =0x00000084 + str r1, [r0, #0x1C] @DMC_PHYCONTROL1 + + ldr r1, =0x71101008 + str r1, [r0, #0x18] @DMC_PHYCONTROL0 + + ldr r1, =0x0000008C + str r1, [r0, #0x1C] @DMC_PHYCONTROL1 + + ldr r1, =0x00000084 + str r1, [r0, #0x1C] @DMC_PHYCONTROL1 + + ldr r1, =0x0000008C + str r1, [r0, #0x1C] @DMC_PHYCONTROL1 + + ldr r1, =0x00000084 + str r1, [r0, #0x1C] @DMC_PHYCONTROL1 + + ldr r1, =0x00000000 + str r1, [r0, #0x20] @DMC_PHYCONTROL2 + + ldr r1, =0x0FFF30da + str r1, [r0, #0x00] @DMC_CONCONTROL + ldr r1, =0x00202500 + str r1, [r0, #0x04] @DMC_MEMCONTROL] +#ifdef MIU_LINEAR + ldr r1, =0x40f01223 + str r1, [r0, #0x08] @DMC_MEMCONFIG0 +#else /* @MIU_1BIT_INTERLEAVED | MIU_2BIT_INTERLEAVED */ + ldr r1, =0x20f01223 + str r1, [r0, #0x08] @DMC_MEMCONFIG0 +#endif + ldr r1, =0xff000000 + str r1, [r0, #0x14] @DMC_PRECHCONFIG + + ldr r1, =0x0000005D + str r1, [r0, #0x30] @DMC_TIMINGAREF + +#ifdef DRAM_CLK_200 + ldr r1, =0x1A254349 + str r1, [r0, #0x34] @DMC_TIMINGROW + ldr r1, =0x23230306 + str r1, [r0, #0x38] @DMC_TIMINGDATA + ldr r1, =0x281c0235 + str r1, [r0, #0x3C] @DMC_TIMINGPOWER +#endif +#ifdef DRAM_CLK_330 + ldr r1, =0x2b47654e + str r1, [r0, #0x34] @DMC_TIMINGROW + ldr r1, =0x35330306 + str r1, [r0, #0x38] @DMC_TIMINGDATA + ldr r1, =0x442f0365 + str r1, [r0, #0x3C] @DMC_TIMINGPOWER +#endif +#ifdef DRAM_CLK_400 + ldr r1, =0x34498691 + str r1, [r0, #0x34] @DMC_TIMINGROW + ldr r1, =0x36330306 + str r1, [r0, #0x38] @DMC_TIMINGDATA + ldr r1, =0x50380365 + str r1, [r0, #0x3C] @DMC_TIMINGPOWER +#endif + + mov r2, #0x100000 +2: subs r2, r2, #1 + bne 2b + ldr r1, =0x07000000 + str r1, [r0, #0x10] @DMC_DIRECTCMD + mov r2, #0x100000 +3: subs r2, r2, #1 + bne 3b + ldr r1, =0x00071C00 + str r1, [r0, #0x10] @DMC_DIRECTCMD + mov r2, #0x100000 +4: subs r2, r2, #1 + bne 4b + + ldr r1, =0x00010BFC + str r1, [r0, #0x10] @DMC_DIRECTCMD + mov r2, #0x100000 +5: subs r2, r2, #1 + bne 5b + ldr r1, =0x00000488 + str r1, [r0, #0x10] @DMC_DIRECTCMD + ldr r1, =0x00000810 + str r1, [r0, #0x10] @DMC_DIRECTCMD + ldr r1, =0x00000C08 + str r1, [r0, #0x10] @DMC_DIRECTCMD + + mov pc, lr + +v310: + +#ifdef SET_MIU + ldr r0, =0x10600000 @MIU_BASE +#ifdef CONFIG_MIU_1BIT_INTERLEAVED + ldr r1, =0x0000000c + str r1, [r0, #0x400] @MIU_INTLV_CONFIG + ldr r1, =0x40000000 + str r1, [r0, #0x808] @MIU_INTLV_START_ADDR + ldr r1, =0xbfffffff + str r1, [r0, #0x810] @MIU_INTLV_END_ADDR + ldr r1, =0x00000001 + str r1, [r0, #0x800] @MIU_MAPPING_UPDATE +#endif +#ifdef CONFIG_MIU_2BIT_INTERLEAVED + ldr r1, =0x2000150c + str r1, [r0, #0x400] @MIU_INTLV_CONFIG + ldr r1, =0x40000000 + str r1, [r0, #0x808] @MIU_INTLV_START_ADDR + ldr r1, =0xbfffffff + str r1, [r0, #0x810] @MIU_INTLV_END_ADDR + ldr r1, =0x00000001 + str r1, [r0, #0x800] @MIU_MAPPING_UPDATE +#endif +#ifdef CONFIG_MIU_LINEAR + ldr r1, =0x40000000 + str r1, [r0, #0x818] @MIU_SINGLE_MAPPING0_START_ADDR + ldr r1, =0x7fffffff + str r1, [r0, #0x820] @MIU_SINGLE_MAPPING0_END_ADDR + ldr r1, =0x80000000 + str r1, [r0, #0x828] @MIU_SINGLE_MAPPING1_START_ADDR + ldr r1, =0xbfffffff + str r1, [r0, #0x830] @MIU_SINGLE_MAPPING1_END_ADDR] + ldr r1, =0x00000006 + str r1, [r0, #0x800] @MIU_MAPPING_UPDATE +#endif +#endif + +/*****************************************************************/ +/*DREX0***********************************************************/ +/*****************************************************************/ + + ldr r0, =0x10400000 @APB_DMC_0_BASE + + ldr r1, =0xe0000086 + str r1, [r0, #0x1C] @DMC_PHYCONTROL1 + + ldr r1, =0xE3855703 + str r1, [r0, #0x44] @DMC_PHYZQCONTROL + + mov r2, #0x100000 +1: subs r2, r2, #1 + bne 1b + + ldr r1, =0xe000008e + str r1, [r0, #0x1C] @DMC_PHYCONTROL1 + ldr r1, =0xe0000086 + str r1, [r0, #0x1C] @DMC_PHYCONTROL1 + + ldr r1, =0x71101008 + str r1, [r0, #0x18] @DMC_PHYCONTROL0 + ldr r1, =0x7110100A + str r1, [r0, #0x18] @DMC_PHYCONTROL0 + ldr r1, =0xe0000086 + str r1, [r0, #0x1C] @DMC_PHYCONTROL1 + ldr r1, =0x7110100B + str r1, [r0, #0x18] @DMC_PHYCONTROL0 + + ldr r1, =0x00000000 + str r1, [r0, #0x20] @DMC_PHYCONTROL2 + + ldr r1, =0x0FFF301a + str r1, [r0, #0x00] @DMC_CONCONTROL + ldr r1, =0x00312640 + str r1, [r0, #0x04] @DMC_MEMCONTROL] + +#ifdef MIU_LINEAR + ldr r1, =0x40e01323 + str r1, [r0, #0x08] @DMC_MEMCONFIG0 + ldr r1, =0x60e01323 + str r1, [r0, #0x0C] @DMC_MEMCONFIG1 +#else /* @MIU_1BIT_INTERLEAVED | MIU_2BIT_INTERLEAVED */ + ldr r1, =0x20e01323 + str r1, [r0, #0x08] @DMC_MEMCONFIG0 + ldr r1, =0x40e01323 + str r1, [r0, #0x0C] @DMC_MEMCONFIG1 +#endif + + ldr r1, =0xff000000 + str r1, [r0, #0x14] @DMC_PRECHCONFIG + + ldr r1, =0x000000BC + str r1, [r0, #0x30] @DMC_TIMINGAREF + +#ifdef DRAM_CLK_330 + ldr r1, =0x3545548d + str r1, [r0, #0x34] @DMC_TIMINGROW + ldr r1, =0x45430506 + str r1, [r0, #0x38] @DMC_TIMINGDATA + ldr r1, =0x4439033c + str r1, [r0, #0x3C] @DMC_TIMINGPOWER +#endif +#ifdef DRAM_CLK_400 + ldr r1, =0x4046654f + str r1, [r0, #0x34] @DMC_TIMINGROW + ldr r1, =0x56500506 + str r1, [r0, #0x38] @DMC_TIMINGDATA + ldr r1, =0x5444033d + str r1, [r0, #0x3C] @DMC_TIMINGPOWER +#endif + + ldr r1, =0x07000000 + str r1, [r0, #0x10] @DMC_DIRECTCMD + + mov r2, #0x100000 +2: subs r2, r2, #1 + bne 2b + + ldr r1, =0x00020000 + str r1, [r0, #0x10] @DMC_DIRECTCMD + ldr r1, =0x00030000 + str r1, [r0, #0x10] @DMC_DIRECTCMD + ldr r1, =0x00010002 + str r1, [r0, #0x10] @DMC_DIRECTCMD + ldr r1, =0x00000328 + str r1, [r0, #0x10] @DMC_DIRECTCMD + + mov r2, #0x100000 +3: subs r2, r2, #1 + bne 3b + + ldr r1, =0x0a000000 + str r1, [r0, #0x10] @DMC_DIRECTCMD + + mov r2, #0x100000 +4: subs r2, r2, #1 + bne 4b + + ldr r1, =0x07100000 + str r1, [r0, #0x10] @DMC_DIRECTCMD + + mov r2, #0x100000 +5: subs r2, r2, #1 + bne 5b + + ldr r1, =0x00120000 + str r1, [r0, #0x10] @DMC_DIRECTCMD + ldr r1, =0x00130000 + str r1, [r0, #0x10] @DMC_DIRECTCMD + ldr r1, =0x00110002 + str r1, [r0, #0x10] @DMC_DIRECTCMD + ldr r1, =0x00100328 + str r1, [r0, #0x10] @DMC_DIRECTCMD + + mov r2, #0x100000 +6: subs r2, r2, #1 + bne 6b + + ldr r1, =0x0a100000 + str r1, [r0, #0x10] @DMC_DIRECTCMD + + mov r2, #0x100000 +7: subs r2, r2, #1 + bne 7b + + ldr r1, =0xe000008e + str r1, [r0, #0x1C] @DMC_PHYCONTROL1 + ldr r1, =0xe0000086 + str r1, [r0, #0x1C] @DMC_PHYCONTROL1 + + mov r2, #0x100000 +8: subs r2, r2, #1 + bne 8b + +/*****************************************************************/ +/*DREX1***********************************************************/ +/*****************************************************************/ + + ldr r0, =0x10410000 @APB_DMC_1_BASE + + ldr r1, =0xe0000086 + str r1, [r0, #0x1C] @DMC_PHYCONTROL1 + + ldr r1, =0xE3855703 + str r1, [r0, #0x44] @DMC_PHYZQCONTROL + + mov r2, #0x100000 +1: subs r2, r2, #1 + bne 1b + + ldr r1, =0xe000008e + str r1, [r0, #0x1C] @DMC_PHYCONTROL1 + ldr r1, =0xe0000086 + str r1, [r0, #0x1C] @DMC_PHYCONTROL1 + + ldr r1, =0x71101008 + str r1, [r0, #0x18] @DMC_PHYCONTROL0 + ldr r1, =0x7110100A + str r1, [r0, #0x18] @DMC_PHYCONTROL0 + ldr r1, =0xe0000086 + str r1, [r0, #0x1C] @DMC_PHYCONTROL1 + ldr r1, =0x7110100B + str r1, [r0, #0x18] @DMC_PHYCONTROL0 + + ldr r1, =0x00000000 + str r1, [r0, #0x20] @DMC_PHYCONTROL2 + + ldr r1, =0x0FFF301a + str r1, [r0, #0x00] @DMC_CONCONTROL + ldr r1, =0x00312640 + str r1, [r0, #0x04] @DMC_MEMCONTROL] + +#ifdef MIU_LINEAR + ldr r1, =0x40e01323 + str r1, [r0, #0x08] @DMC_MEMCONFIG0 + ldr r1, =0x60e01323 + str r1, [r0, #0x0C] @DMC_MEMCONFIG1 +#else /* @MIU_1BIT_INTERLEAVED | MIU_2BIT_INTERLEAVED */ + ldr r1, =0x20e01323 + str r1, [r0, #0x08] @DMC_MEMCONFIG0 + ldr r1, =0x40e01323 + str r1, [r0, #0x0C] @DMC_MEMCONFIG1 +#endif + + ldr r1, =0xff000000 + str r1, [r0, #0x14] @DMC_PRECHCONFIG + + ldr r1, =0x000000BC + str r1, [r0, #0x30] @DMC_TIMINGAREF + +#ifdef DRAM_CLK_330 + ldr r1, =0x3545548d + str r1, [r0, #0x34] @DMC_TIMINGROW + ldr r1, =0x45430506 + str r1, [r0, #0x38] @DMC_TIMINGDATA + ldr r1, =0x4439033c + str r1, [r0, #0x3C] @DMC_TIMINGPOWER +#endif +#ifdef DRAM_CLK_400 + ldr r1, =0x4046654f + str r1, [r0, #0x34] @DMC_TIMINGROW + ldr r1, =0x56500506 + str r1, [r0, #0x38] @DMC_TIMINGDATA + ldr r1, =0x5444033d + str r1, [r0, #0x3C] @DMC_TIMINGPOWER +#endif + + ldr r1, =0x07000000 + str r1, [r0, #0x10] @DMC_DIRECTCMD + + mov r2, #0x100000 +2: subs r2, r2, #1 + bne 2b + + ldr r1, =0x00020000 + str r1, [r0, #0x10] @DMC_DIRECTCMD + ldr r1, =0x00030000 + str r1, [r0, #0x10] @DMC_DIRECTCMD + ldr r1, =0x00010002 + str r1, [r0, #0x10] @DMC_DIRECTCMD + ldr r1, =0x00000328 + str r1, [r0, #0x10] @DMC_DIRECTCMD + + mov r2, #0x100000 +3: subs r2, r2, #1 + bne 3b + + ldr r1, =0x0a000000 + str r1, [r0, #0x10] @DMC_DIRECTCMD + + mov r2, #0x100000 +4: subs r2, r2, #1 + bne 4b + + ldr r1, =0x07100000 + str r1, [r0, #0x10] @DMC_DIRECTCMD + + mov r2, #0x100000 +5: subs r2, r2, #1 + bne 5b + + ldr r1, =0x00120000 + str r1, [r0, #0x10] @DMC_DIRECTCMD + ldr r1, =0x00130000 + str r1, [r0, #0x10] @DMC_DIRECTCMD + ldr r1, =0x00110002 + str r1, [r0, #0x10] @DMC_DIRECTCMD + ldr r1, =0x00100328 + str r1, [r0, #0x10] @DMC_DIRECTCMD + + mov r2, #0x100000 +6: subs r2, r2, #1 + bne 6b + + ldr r1, =0x0a100000 + str r1, [r0, #0x10] @DMC_DIRECTCMD + + mov r2, #0x100000 +7: subs r2, r2, #1 + bne 7b + + ldr r1, =0xe000008e + str r1, [r0, #0x1C] @DMC_PHYCONTROL1 + ldr r1, =0xe0000086 + str r1, [r0, #0x1C] @DMC_PHYCONTROL1 + + mov r2, #0x100000 +8: subs r2, r2, #1 + bne 8b + +/*****************************************************************/ +/* turn on DREX0, DREX1 ******************************************/ +/*****************************************************************/ + + ldr r0, =0x10400000 @APB_DMC_0_BASE + ldr r1, =0x0FFF303a + str r1, [r0, #0x00] @DMC_CONCONTROL + + ldr r0, =0x10410000 @APB_DMC_1_BASE + ldr r1, =0x0FFF303a + str r1, [r0, #0x00] @DMC_CONCONTROL + + mov pc, lr diff --git a/board/samsung/smdkv310/smdkv310.c b/board/samsung/smdkv310/smdkv310.c new file mode 100644 index 0000000..255ae88 --- /dev/null +++ b/board/samsung/smdkv310/smdkv310.c @@ -0,0 +1,138 @@ +/* + * Copyright (C) 2011 Samsung Electronics + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <asm/io.h> +#include <netdev.h> +#include <asm/arch/cpu.h> +#include <asm/arch/gpio.h> +#include <asm/arch/mmc.h> + +DECLARE_GLOBAL_DATA_PTR; +struct s5pc210_gpio_part1 *gpio1; +struct s5pc210_gpio_part2 *gpio2; + +static void smc9115_pre_init(void) +{ + unsigned int *ptr; + /* gpio configuration */ + + writel(0x22222222, 0x11000000 + 0x120); + + /* Ethernet needs bus width of 16 bits */ + ptr = (unsigned int *) (S5PC210_SROMC_BASE + 0); + *ptr = 0x9999; + + /* Select and configure the SROMC bank (Bank = 1)*/ + ptr = (unsigned int *) (S5PC210_SROMC_BASE + 0x08); + *ptr = 0xffffffff; +} + +int board_init(void) +{ + smc9115_pre_init(); + + gpio1 = (struct s5pc210_gpio_part1 *) S5PC210_GPIO_PART1_BASE; + gpio2 = (struct s5pc210_gpio_part2 *) S5PC210_GPIO_PART2_BASE; + + gd->bd->bi_arch_number = MACH_TYPE; + gd->bd->bi_boot_params = (PHYS_SDRAM_1 + 0x100UL); + return 0; +} + +int dram_init(void) +{ + gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE) + + get_ram_size((long *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE) + + get_ram_size((long *)PHYS_SDRAM_3, PHYS_SDRAM_3_SIZE) + + get_ram_size((long *)PHYS_SDRAM_4, PHYS_SDRAM_4_SIZE); + + return 0; +} + +void dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + gd->bd->bi_dram[1].start = PHYS_SDRAM_2; + gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE; + gd->bd->bi_dram[2].start = PHYS_SDRAM_3; + gd->bd->bi_dram[2].size = PHYS_SDRAM_3_SIZE; + gd->bd->bi_dram[3].start = PHYS_SDRAM_4; + gd->bd->bi_dram[3].size = PHYS_SDRAM_4_SIZE; +} + +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_SMC911X + rc = smc911x_initialize(0, CONFIG_SMC911X_BASE); +#endif + return rc; +} + +#ifdef BOARD_LATE_INIT +int board_late_init(void) +{ + return 0; +} +#endif + +#ifdef CONFIG_DISPLAY_BOARDINFO +int checkboard(void) +{ + unsigned int *ptr = (unsigned int *) S5PC210_PRO_ID; + if (((*ptr & 0x300) >> 8) == 2) + printf("\nBoard: SMDKC210\n"); + else + printf("\nBoard: SMDKV310\n"); + + return 0; +} +#endif + +#ifdef CONFIG_GENERIC_MMC +int board_mmc_init(bd_t *bis) +{ + int i, err; + + /* + * MMC2 SD card GPIO: + * GPK2[0] SD_2_CLK(2) + * GPK2[1] SD_2_CMD(2) + * GPK2[2] SD_2_CDn -> Not used + * GPK2[3:6] SD_2_DATA[0:3](2) + */ + for (i = 0; i < 7; i++) { + if (i == 2) + continue; + /* GPK2[0:6] special function 2 */ + gpio_cfg_pin(&gpio2->k2, i, 0x2); + /* GPK2[0:6] pull disable */ + gpio_set_pull(&gpio2->k2, i, GPIO_PULL_NONE); + /* GPK2[0:6] drv 4x */ + gpio_set_drv(&gpio2->k2, i, GPIO_DRV_4X); + } + err = s5p_mmc_init(2, 4); + return err; +} +#endif diff --git a/boards.cfg b/boards.cfg index 45c3102..8bb245d 100644 --- a/boards.cfg +++ b/boards.cfg @@ -128,6 +128,7 @@ omap4_sdp4430 arm armv7 sdp4430 ti s5p_goni arm armv7 goni samsung s5pc1xx smdkc100 arm armv7 smdkc100 samsung s5pc1xx s5pc210_universal arm armv7 universal_c210 samsung s5pc2xx +smdkv310 arm armv7 smdkv310 samsung s5pc2xx harmony arm armv7 harmony nvidia tegra2 seaboard arm armv7 seaboard nvidia tegra2 actux1 arm ixp diff --git a/include/configs/smdkv310.h b/include/configs/smdkv310.h new file mode 100644 index 0000000..a80f902 --- /dev/null +++ b/include/configs/smdkv310.h @@ -0,0 +1,199 @@ +/* + * Copyright (C) 2011 Samsung Electronics + * + * Configuration settings for the SAMSUNG SMDKV310 (S5PC210) board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* High Level Configuration Options */ +#define CONFIG_ARMV7 1 /*This is an ARM V7 CPU core */ +#define CONFIG_SAMSUNG 1 /* in a SAMSUNG core */ +#define CONFIG_S5P 1 /* S5P Family */ +#define CONFIG_S5PC210 1 /* which is in a S5PC210 SoC */ +#define CONFIG_SMDKV310 1 /* working within SMDKV310*/ +#define CONFIG_EVT1 1 /* EVT1 */ + +#include <asm/arch/cpu.h> /* get chip and board defs */ + +#define CONFIG_ARCH_CPU_INIT +#define CONFIG_DISPLAY_CPUINFO +#define CONFIG_DISPLAY_BOARDINFO + +/* Keep L2 Cache Disabled */ +#define CONFIG_L2_OFF 1 + +#define CONFIG_SYS_SDRAM_BASE 0x40000000 + +/* input clock of PLL: SMDKV310 has 24MHz input clock */ +#define CONFIG_SYS_CLK_FREQ 24000000 + +#define CONFIG_SETUP_MEMORY_TAGS +#define CONFIG_CMDLINE_TAG +#define CONFIG_INITRD_TAG +#define CONFIG_CMDLINE_EDITING + +/* Handling Sleep Mode*/ +#define S5P_CHECK_SLEEP 0x00000BAD +#define S5P_CHECK_DIDLE 0xBAD00000 + +/* Architecture magic and machine type */ +#define MACH_TYPE 2925UL /* SMDKV310 machine ID */ +#define UBOOT_MAGIC (0x43090000 | MACH_TYPE) + +/* Size of malloc() pool */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (1 << 20)) + +/* size in bytes reserved for initial data */ +#define CONFIG_SYS_GBL_DATA_SIZE 128 + +/* select serial console configuration */ +#define CONFIG_SERIAL_MULTI 1 +#define CONFIG_SERIAL1 1 /* use SERIAL 1 */ +#define CONFIG_BAUDRATE 115200 +#define S5PC210_UART1_OFFSET 0x010000 + +/* SD/MMC configuration */ +#define CONFIG_GENERIC_MMC 1 +#define CONFIG_MMC 1 +#define CONFIG_S5P_MMC 1 + +/* PWM */ +#define CONFIG_PWM 1 + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE + +/* Command definition*/ +#include <config_cmd_default.h> + +#define CONFIG_CMD_PING +#define CONFIG_CMD_ELF +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_MMC +#define CONFIG_CMD_NET +#define CONFIG_CMD_FAT + +#define CONFIG_BOOTDELAY 3 +#define CONFIG_ZERO_BOOTDELAY_CHECK +#define CONFIG_MMC_U_BOOT + +#define CONFIG_MTDPARTITION "80000 400000 3000000" +#define CONFIG_BOOTCOMMAND "mmc read 0 40007000 441 2000;\ + bootm 40007000" + +/* Miscellaneous configurable options */ +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_HUSH_PARSER /* use "hush" command parser */ +#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_SYS_PROMPT "SMDKV310 # " +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size*/ +#define CONFIG_SYS_PBSIZE 384 /* Print Buffer Size */ +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_DEFAULT_CONSOLE "console=ttySAC2,115200n8\0" +/* Boot Argument Buffer Size */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE +/* memtest works on */ +#define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE +#define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x6000000) +#define CONFIG_SYS_LOAD_ADDR (CONFIG_SYS_SDRAM_BASE + 0x3E00000) + +#define CONFIG_SYS_HZ 1000 + +/* valid baudrates */ +#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } + +/* Stack sizes */ +#define CONFIG_STACKSIZE (256 << 10) /* 256KB */ + +/* SMDKV310 has 4 bank of DRAM */ +#define CONFIG_NR_DRAM_BANKS 4 +#define SDRAM_BANK_SIZE (512 << 20) /* 512 MB */ +#define PHYS_SDRAM_1 CONFIG_SYS_SDRAM_BASE +#define PHYS_SDRAM_1_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_2 (CONFIG_SYS_SDRAM_BASE + SDRAM_BANK_SIZE) +#define PHYS_SDRAM_2_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_3 (CONFIG_SYS_SDRAM_BASE + 2 * SDRAM_BANK_SIZE) +#define PHYS_SDRAM_3_SIZE SDRAM_BANK_SIZE +#define PHYS_SDRAM_4 (CONFIG_SYS_SDRAM_BASE + 3 * SDRAM_BANK_SIZE) +#define PHYS_SDRAM_4_SIZE SDRAM_BANK_SIZE + + +/* FLASH and environment organization */ +#define CONFIG_SYS_NO_FLASH 1 +#undef CONFIG_CMD_IMLS +#define CONFIG_IDENT_STRING " for SMDKC210/V310" + +/* base address for uboot */ +#define CONFIG_SYS_PHY_UBOOT_BASE (CONFIG_SYS_SDRAM_BASE + 0x3e00000) +#define CONFIG_SYS_MMC_UBOOT_START CONFIG_SYS_PHY_UBOOT_BASE + +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ (4*1024) /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ (4*1024) /* FIQ stack */ +#endif + +#define CONFIG_CLK_1000_400_200 +#define CONFIG_BOOTM_LINUX 1 +#define CONFIG_INCLUDE_TEST +#define CONFIG_IMAGE_BOOT +#define BOARD_LATE_INIT + +/* MIU (Memory Interleaving Unit) */ +#define CONFIG_MIU_2BIT_INTERLEAVED + +/* The macro for MMC channel 0 is defined by default and can't be undefined */ +#define USE_MMC2 +#define MMC_MAX_CHANNEL 4 + +#define CONFIG_ENV_IS_IN_MMC 1 +#define CONFIG_SYS_MMC_ENV_DEV 0 +#define CONFIG_ENV_SIZE (16 << 10) /* 16 KB */ +#define RESERVE_BLOCK_SIZE (512) +#define BL1_SIZE (16 << 10) /*16 K reserved for BL1*/ +#define CONFIG_ENV_OFFSET (RESERVE_BLOCK_SIZE + BL1_SIZE) +#define CONFIG_DOS_PARTITION 1 + +#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - 0x1000000) + +/* U-boot copy size from boot Media to DRAM.*/ +#define COPY_BL2_SIZE 0x80000 +#define BL2_SIZE_BLOC_COUNT (COPY_BL2_SIZE/512) +/* Ethernet Controllor Driver */ +#ifdef CONFIG_CMD_NET +#define CONFIG_NET_MULTI +#define CONFIG_SMC911X +#define CONFIG_SMC911X_BASE 0x5000000 +#define CONFIG_SMC911X_16_BIT +#endif /*CONFIG_CMD_NET*/ + +#undef CONFIG_SKIP_RELOCATE_UBOOT +#undef CONFIG_USE_NOR_BOOT +#undef CONFIG_USE_IRQ + +/* + * SD/MMC detection takes a little long time + * So, you can ignore detection process for SD/MMC card + */ +#undef CONFIG_NO_SDMMC_DETECTION +#undef CONFIG_USB_STORAGE +#endif /* __CONFIG_H */ -- 1.7.1
Dear Chander Kashyap,
You missing MAINTAINER entry.
Please remove this file. And move this define to config file.
diff --git a/board/samsung/smdkv310/lowlevel_init.S b/board/samsung/smdkv310/lowlevel_init.S new file mode 100644 index 0000000..ead12b2 --- /dev/null +++ b/board/samsung/smdkv310/lowlevel_init.S +#define MEM_DLLl_ON
please remove this space.
+_TEXT_BASE:
- .word CONFIG_SYS_TEXT_BASE
- .globl lowlevel_init
+lowlevel_init:
- push {lr}
ditto.
- /* r5 has always zero */
- mov r5, #0
- ldr r7, =S5PC210_GPIO_PART1_BASE
- ldr r6, =S5PC210_GPIO_PART2_BASE
- /* check reset status */
- ldr r0, =(S5PC210_POWER_BASE + 0x81C) @ INFORM7
- ldr r1, [r0]
- /* AFTR wakeup reset */
- ldr r2, =S5P_CHECK_DIDLE
- cmp r1, r2
- beq exit_wakeup
- /* Sleep wakeup reset */
- ldr r2, =S5P_CHECK_SLEEP
- cmp r1, r2
- beq wakeup_reset
- /* when we already run in ram, we don't need to relocate U-Boot.
- * and actually, memory controller must be configured before U-Boot
- * is running in ram.
We don't allow this comment style. Please check it. http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=blob;f=Do...
- ldr r0, =0x00ffffff /* r0 <- Mask Bits*/
- bic r1, pc, r0 /* pc <- current addr of code */
- /* r1 <- unmasked bits of pc */
- ldr r2, _TEXT_BASE /* r2 <- original base addr in ram */
- bic r2, r2, r0 /* r2 <- unmasked bits of r2*/
- cmp r1, r2 /* compare r1, r2 */
- beq 1f /* r0 == r1 then skip sdram init */
- /* init system clock */
- bl system_clock_init
- /* Memory initialize */
- bl mem_ctrl_asm_init
Is it OK that memory initialize on u-boot? Maybe only do on mmc spl?
+1:
- /* for UART */
- bl uart_asm_init
- bl tzpc_init
- pop {pc}
+wakeup_reset:
- bl tzpc_init
+exit_wakeup:
- /*Load return address and jump to kernel*/
- ldr r0, =(S5PC210_POWER_BASE + 0x800) @ INFORM0
- /* r1 = physical address of s5pc210_cpu_resume function */
- ldr r1, [r0]
- /* Jump to kernel*/
- mov pc, r1
- nop
- nop
- system_clock_init: Initialize core clock and bus clock.
- void system_clock_init(void)
+system_clock_init:
- push {lr}
- ldr r0, =S5PC210_CLOCK_BASE
- /* APLL(1), MPLL(1), CORE(0), HPM(0) */
- ldr r1, =0x0101
- ldr r2, =0x14200 @CLK_SRC_CPU
- str r1, [r0, r2]
- /* wait ?us */
- mov r1, #0x10000
+1: subs r1, r1, #1
- bne 1b
- ldr r1, =0x0110
- ldr r2, =0x0C210 @CLK_SRC_TOP0
- str r1, [r0, r2]
- ldr r1, =0x00
- ldr r2, =0x0C214 @CLK_SRC_TOP1_OFFSET
- str r1, [r0, r2]
- /* DMC */
- ldr r1, =0x00
- ldr r2, =0x10200 @CLK_SRC_DMC_OFFSET
- str r1, [r0, r2]
- /* SATA: SCLKMPLL(0), MMC[0:4]: SCLKMPLL(6) */
- ldr r1, =0x066666
- ldr r2, =0x0C240 @ CLK_SRC_FSYS
- str r1, [r0, r2]
- /*CLK_SRC_LEFTBUS */
- ldr r1, =0x00
- ldr r2, =0x04200 @CLK_SRC_LEFTBUS_OFFSET
- str r1, [r0, r2]
- /*CLK_SRC_RIGHTBUS */
- ldr r1, =0x00
- ldr r2, =0x08200 @CLK_SRC_RIGHTBUS_OFFSET
- str r1, [r0, r2]
- /* UART[0:4], PWM: SCLKMPLL(6) */
- ldr r1, =0x06666666
- ldr r2, =0x0C250 @CLK_SRC_PERIL0_OFFSET
- str r1, [r0, r2]
- /* wait ?us */
- mov r1, #0x10000
+4: subs r1, r1, #1
- bne 4b
- /* CLK_DIV_CPU0:
- PCLK_DBG_RATIO[20] 0x1
- ATB_RATIO[16] 0x3
- PERIPH_RATIO[12] 0x3
- COREM1_RATIO[8] 0x7
- COREM0_RATIO[4] 0x3
Check the style.
- ldr r1, =0x0133730
- ldr r2, =0x14500 @CLK_DIV_CPU0_OFFSET
- str r1, [r0, r2]
- /* CLK_DIV_CPU1
- COPY_RATIO [0] 0x3
ditto.
- Memory setup for SMDKV310 board based on S5PC210
- Copyright (C) 2011 Samsung Electronics
- project.
- MA 02111-1307 USA
+#define SET_MIU
+#define MEM_DLL
- .globl mem_ctrl_asm_init
+mem_ctrl_asm_init:
- /* Async bridge configuration at CPU_core */
- /* 1: half_sync */
- /* 0: full_sync */
- ldr r0, =0x10010350
- mov r1, #1
- str r1, [r0]
- ldr r0, =0x10000000 @CHIP_ID_BASE
- ldr r1, [r0]
- lsr r1, r1, #8
- and r1, r1, #3
- cmp r1, #2
- bne v310
- /* CLK_DIV_DMC0 on iROM DMC=50MHz for Init DMC */
- ldr r0, =0x10030000 @CMU_BASE
- ldr r1, =0x13113113
- ldr r2, =0x10500 @CLK_DIV_DMC0_OFFSET
- str r1, [r0, r2]
+#ifdef SET_MIU
- ldr r0, =0x10600000 @MIU_BASE
- ldr r1, =0x0000000c
- str r1, [r0, #0x400] @MIU_INTLV_CONFIG
- ldr r1, =0x40000000
- str r1, [r0, #0x808] @MIU_INTLV_START_ADDR
- ldr r1, =0x5fffffff
- str r1, [r0, #0x810] @MIU_INTLV_END_ADDR
- ldr r1, =0x00000001
- str r1, [r0, #0x800] @MIU_MAPPING_UPDATE
- ldr r1, =0x2000150c
- str r1, [r0, #0x818] @MIU_SINGLE_MAPPING0_START_ADDR
- ldr r1, =0x4fffffff
- str r1, [r0, #0x820] @MIU_SINGLE_MAPPING0_END_ADDR
- ldr r1, =0x50000000
- str r1, [r0, #0x828] @MIU_SINGLE_MAPPING1_START_ADDR
- str r1, [r0, #0x830] @MIU_SINGLE_MAPPING1_END_ADDR]
- ldr r1, =0x00000006
+#endif +#endif
Check the style globally..
- project.
- MA 02111-1307 USA
- unsigned int *ptr;
- /* gpio configuration */
- writel(0x22222222, 0x11000000 + 0x120);
NAK. What is 0x11000000 + 0x120?
- /* Ethernet needs bus width of 16 bits */
- ptr = (unsigned int *) (S5PC210_SROMC_BASE + 0);
- *ptr = 0x9999;
- /* Select and configure the SROMC bank (Bank = 1)*/
- ptr = (unsigned int *) (S5PC210_SROMC_BASE + 0x08);
- *ptr = 0xffffffff;
NAK. Please use read/write function with structure.
- smc9115_pre_init();
- gpio1 = (struct s5pc210_gpio_part1 *) S5PC210_GPIO_PART1_BASE;
- gpio2 = (struct s5pc210_gpio_part2 *) S5PC210_GPIO_PART2_BASE;
- gd->bd->bi_arch_number = MACH_TYPE;
Please use MACH_TYPE_SMDKV310 directly.
- gd->bd->bi_boot_params = (PHYS_SDRAM_1 + 0x100UL);
- gd->ram_size = get_ram_size((long *)PHYS_SDRAM_1, PHYS_SDRAM_1_SIZE)
- + get_ram_size((long *)PHYS_SDRAM_2, PHYS_SDRAM_2_SIZE)
- + get_ram_size((long *)PHYS_SDRAM_3, PHYS_SDRAM_3_SIZE)
- + get_ram_size((long *)PHYS_SDRAM_4, PHYS_SDRAM_4_SIZE);
- gd->bd->bi_dram[0].start = PHYS_SDRAM_1;
- gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE;
- gd->bd->bi_dram[1].start = PHYS_SDRAM_2;
- gd->bd->bi_dram[1].size = PHYS_SDRAM_2_SIZE;
- gd->bd->bi_dram[2].start = PHYS_SDRAM_3;
- gd->bd->bi_dram[2].size = PHYS_SDRAM_3_SIZE;
- gd->bd->bi_dram[3].start = PHYS_SDRAM_4;
- gd->bd->bi_dram[3].size = PHYS_SDRAM_4_SIZE;
- int rc = 0;
- rc = smc911x_initialize(0, CONFIG_SMC911X_BASE);
- return rc;
+} +#endif
Just return 0? then, please remove it. Please don't make dead function.
- unsigned int *ptr = (unsigned int *) S5PC210_PRO_ID;
Please use readl function.
- if (((*ptr & 0x300) >> 8) == 2)
Please add some descriptions.
- printf("\nBoard: SMDKC210\n");
- else
- printf("\nBoard: SMDKV310\n");
+} +#endif
+#endif diff --git a/boards.cfg b/boards.cfg index 45c3102..8bb245d 100644 --- a/boards.cfg +++ b/boards.cfg @@ -128,6 +128,7 @@ omap4_sdp4430 arm armv7 sdp4430 ti s5p_goni arm armv7 goni samsung s5pc1xx smdkc100 arm armv7 smdkc100 samsung s5pc1xx s5pc210_universal arm armv7 universal_c210 samsung s5pc2xx +smdkv310 arm armv7 smdkv310 samsung s5pc2xx harmony arm armv7 harmony nvidia tegra2 seaboard arm armv7 seaboard nvidia tegra2 actux1 arm ixp diff --git a/include/configs/smdkv310.h b/include/configs/smdkv310.h new file mode 100644 index 0000000..a80f902 --- /dev/null +++ b/include/configs/smdkv310.h +/* High Level Configuration Options */ +#define CONFIG_ARMV7 1 /*This is an ARM V7 CPU core */ +#define CONFIG_SAMSUNG 1 /* in a SAMSUNG core */ +#define CONFIG_S5P 1 /* S5P Family */ +#define CONFIG_S5PC210 1 /* which is in a S5PC210 SoC */ +#define CONFIG_SMDKV310 1 /* working within SMDKV310*/ +#define CONFIG_EVT1 1 /* EVT1 */
Is it need?
Please remove it. Use MACH_TYPE_SMDKV310 define.
What is it?
This define doesn't use anywhere. Please remove it.
remove space.
Already defined at config_cmd_default.h Please remove it.
+#define CONFIG_INCLUDE_TEST +#define CONFIG_IMAGE_BOOT +#define USE_MMC2 +#define MMC_MAX_CHANNEL 4
What is these defines?
#define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_LOAD_ADDR - GENERATED_GBL_DATA_SIZE) is better.
+#undef CONFIG_SKIP_RELOCATE_UBOOT +#undef CONFIG_USE_NOR_BOOT +#undef CONFIG_USE_IRQ +#undef CONFIG_NO_SDMMC_DETECTION +#undef CONFIG_USB_STORAGE
remove these defines. Please don't make private defines if you don't have special reason.
Thanks Minkyu Kang.
Dear Minkyu,
I did not got this. Where to put maintainer entry.
config.mk
Done
+_TEXT_BASE:
+lowlevel_init:
push {lr}
ditto.
Done
mov r5, #0
ldr r1, [r0]
cmp r1, r2
beq exit_wakeup
cmp r1, r2
beq wakeup_reset
U-Boot
ram */
This is generic initialisation Code. We need this in case of NOR boot. This initialisation is excluded in case of SPL boot.
+1:
/* for UART */
bl uart_asm_init
bl tzpc_init
pop {pc}
+wakeup_reset:
bl tzpc_init
+exit_wakeup:
ldr r1, [r0]
/* Jump to kernel*/
mov pc, r1
nop
nop
+system_clock_init:
push {lr}
ldr r1, =0x0101
str r1, [r0, r2]
/* wait ?us */
mov r1, #0x10000
+1: subs r1, r1, #1
bne 1b
ldr r1, =0x0110
str r1, [r0, r2]
ldr r1, =0x00
str r1, [r0, r2]
/* DMC */
ldr r1, =0x00
str r1, [r0, r2]
ldr r1, =0x066666
str r1, [r0, r2]
ldr r1, =0x00
str r1, [r0, r2]
ldr r1, =0x00
str r1, [r0, r2]
ldr r1, =0x06666666
str r1, [r0, r2]
/* wait ?us */
mov r1, #0x10000
+4: subs r1, r1, #1
bne 4b
/* CLK_DIV_CPU0:
ATB_RATIO[16] 0x3
COREM1_RATIO[8] 0x7
COREM0_RATIO[4] 0x3
Check the style.
ldr r1, =0x0133730
str r1, [r0, r2]
/* CLK_DIV_CPU1
COPY_RATIO [0] 0x3
ditto.
- project.
- MA 02111-1307 USA
+#define SET_MIU
+#define MEM_DLL
+mem_ctrl_asm_init:
/* 1: half_sync */
/* 0: full_sync */
ldr r0, =0x10010350
mov r1, #1
str r1, [r0]
ldr r1, [r0]
lsr r1, r1, #8
and r1, r1, #3
cmp r1, #2
bne v310
ldr r1, =0x13113113
str r1, [r0, r2]
+#ifdef SET_MIU
ldr r1, =0x0000000c
ldr r1, =0x40000000
ldr r1, =0x5fffffff
ldr r1, =0x00000001
ldr r1, =0x2000150c
ldr r1, =0x40000000
ldr r1, =0x5fffffff
ldr r1, =0x00000001
ldr r1, =0x40000000
ldr r1, =0x4fffffff
ldr r1, =0x50000000
ldr r1, =0x5fffffff
ldr r1, =0x00000006
+#endif +#endif
- project.
- MA 02111-1307 USA
unsigned int *ptr;
Done
*ptr = 0x9999;
*ptr = 0xffffffff;
Done
smc9115_pre_init();
PHYS_SDRAM_1_SIZE)
PHYS_SDRAM_2_SIZE)
PHYS_SDRAM_3_SIZE)
PHYS_SDRAM_4_SIZE);
int rc = 0;
return rc;
+} +#endif
else
+} +#endif
sdp4430 ti
samsung s5pc1xx
samsung s5pc1xx
samsung s5pc2xx
samsung s5pc2xx
nvidia tegra2
nvidia tegra2
core */
SoC */
SMDKV310*/
Is it need?
Not required
What is it?
Not required
Ok
SDRAM_BANK_SIZE)
SDRAM_BANK_SIZE)
remove space.
0x3e00000)
BL1*/
0x1000000)
Thanks Minkyu Kang. -- from. prom. www.promsoft.net
Please see MAINTAINERS.
How about eMMC boot or OneNAND boot? Maybe DRAM will be initialized twice, and then system will be hang. I think need to add ifdef condition.
Thanks Minkyu Kang
Added MMC SPL boot support for SMDKV310. This framework design is based on nand_spl support.
Signed-off-by: Chander Kashyap chander.kashyap@linaro.org --- Makefile | 11 ++- spl/board/samsung/smdkv310/Makefile | 104 +++++++++++++++++++++++ spl/board/samsung/smdkv310/mmc_boot.c | 82 ++++++++++++++++++ spl/board/samsung/smdkv310/tools/mkv310_image.c | 103 ++++++++++++++++++++++ spl/board/samsung/smdkv310/u-boot.lds | 86 +++++++++++++++++++ 5 files changed, 385 insertions(+), 1 deletions(-) create mode 100644 spl/board/samsung/smdkv310/Makefile create mode 100644 spl/board/samsung/smdkv310/mmc_boot.c create mode 100644 spl/board/samsung/smdkv310/tools/mkv310_image.c create mode 100644 spl/board/samsung/smdkv310/u-boot.lds
diff --git a/Makefile b/Makefile index c42432b..0fe8286 100644 --- a/Makefile +++ b/Makefile @@ -299,6 +299,10 @@ U_BOOT_ONENAND = $(obj)u-boot-onenand.bin ONENAND_BIN ?= $(obj)onenand_ipl/onenand-ipl-2k.bin endif
+ifeq ($(CONFIG_MMC_U_BOOT),y) +MMC_SPL = spl +V310_MMC_SPL_BIN = $(obj)spl/v310_mmc_spl.bin +endif __OBJS := $(subst $(obj),,$(OBJS)) __LIBS := $(subst $(obj),,$(LIBS)) $(subst $(obj),,$(LIBBOARD))
@@ -321,7 +325,7 @@ BOARD_SIZE_CHECK = endif
# Always append ALL so that arch config.mk's can add custom ones -ALL += $(obj)u-boot.srec $(obj)u-boot.bin $(obj)System.map $(U_BOOT_NAND) $(U_BOOT_ONENAND) +ALL += $(obj)u-boot.srec $(obj)u-boot.bin $(obj)System.map $(U_BOOT_NAND) $(U_BOOT_ONENAND) $(V310_MMC_SPL_BIN)
all: $(ALL)
@@ -414,6 +418,11 @@ $(ONENAND_IPL): $(TIMESTAMP_FILE) $(VERSION_FILE) $(obj)include/autoconf.mk $(U_BOOT_ONENAND): $(ONENAND_IPL) $(obj)u-boot.bin cat $(ONENAND_BIN) $(obj)u-boot.bin > $(obj)u-boot-onenand.bin
+$(MMC_SPL): $(TIMESTAMP_FILE) $(VERSION_FILE) depend + $(MAKE) -C $(MMC_SPL)/board/$(BOARDDIR) all + +$(V310_MMC_SPL_BIN): $(MMC_SPL) + $(VERSION_FILE): @( printf '#define U_BOOT_VERSION "U-Boot %s%s"\n' "$(U_BOOT_VERSION)" \ '$(shell $(TOPDIR)/tools/setlocalversion $(TOPDIR))' ) > $@.tmp diff --git a/spl/board/samsung/smdkv310/Makefile b/spl/board/samsung/smdkv310/Makefile new file mode 100644 index 0000000..42ef926 --- /dev/null +++ b/spl/board/samsung/smdkv310/Makefile @@ -0,0 +1,104 @@ +# +# (C) Copyright 2006-2007 +# Stefan Roese, DENX Software Engineering, sr@denx.de. +# +# (C) Copyright 2008 +# Guennadi Liakhovetki, DENX Software Engineering, lg@denx.de +# +# (C) Copyright 2011 +# Chander Kashyap, Samsung Electronics, k.chander@samsung.com +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +CONFIG_MMC_SPL = y + +include $(TOPDIR)/config.mk +include $(TOPDIR)/board/$(BOARDDIR)/config.mk + +LDSCRIPT= $(TOPDIR)/spl/board/$(BOARDDIR)/u-boot.lds +LDFLAGS = -Bstatic -T $(mmcobj)u-boot.lds -Ttext $(CONFIG_SYS_TEXT_BASE) $(PLATFORM_LDFLAGS) +AFLAGS += -DCONFIG_MMC_SPL +CFLAGS += -DCONFIG_MMC_SPL + +SOBJS = start.o mem_setup.o lowlevel_init.o +COBJS = mmc_boot.o + +SRCS := $(addprefix $(obj),$(SOBJS:.o=.S) $(COBJS:.o=.c)) +OBJS := $(addprefix $(obj),$(SOBJS) $(COBJS)) +__OBJS := $(SOBJS) $(COBJS) +LNDIR := $(OBJTREE)/spl/board/$(BOARDDIR) + +mmcobj := $(OBJTREE)/spl/ + + +MKBIN_V310_MMC_SPL_BIN = mkv310_mmc_spl_bin +MMC_SPL_BIN = v310_mmc_spl.bin + +ALL = $(mmcobj)u-boot-spl $(mmcobj)u-boot-spl.bin $(mmcobj)$(MMC_SPL_BIN) + +all: $(obj).depend $(ALL) + +$(mmcobj)$(MMC_SPL_BIN): $(mmcobj)u-boot-spl.bin tools/$(MKBIN_V310_MMC_SPL_BIN) + ./tools/$(MKBIN_V310_MMC_SPL_BIN) $(mmcobj)u-boot-spl.bin $(mmcobj)$(MMC_SPL_BIN) + +tools/$(MKBIN_V310_MMC_SPL_BIN): tools/mkv310_image.c + $(HOSTCC) tools/mkv310_image.c -o tools/$(MKBIN_V310_MMC_SPL_BIN) + +$(mmcobj)u-boot-spl.bin: $(mmcobj)u-boot-spl + $(OBJCOPY) ${OBJCFLAGS} -O binary $< $@ + +$(mmcobj)u-boot-spl: $(OBJS) $(mmcobj)u-boot.lds + cd $(LNDIR) && $(LD) $(LDFLAGS) $(__OBJS) \ + -Map $(mmcobj)u-boot-spl.map \ + -o $(mmcobj)u-boot-spl + +$(mmcobj)u-boot.lds: $(LDSCRIPT) + $(CPP) $(CPPFLAGS) $(LDPPFLAGS) -ansi -D__ASSEMBLY__ -P - <$^ >$@ + +# create symbolic links for common files + +# from cpu directory +$(obj)start.S: + @rm -f $@ + @ln -s $(TOPDIR)/arch/arm/cpu/armv7/start.S $@ + +# from board directory +$(obj)mem_setup.S: + @rm -f $@ + @ln -s $(TOPDIR)/board/samsung/smdkv310/mem_setup.S $@ + +$(obj)lowlevel_init.S: + @rm -f $@ + @ln -s $(TOPDIR)/board/samsung/smdkv310/lowlevel_init.S $@ + +######################################################################### + +$(obj)%.o: $(obj)%.S + $(CC) $(AFLAGS) -c -o $@ $< + +$(obj)%.o: $(obj)%.c + $(CC) $(CFLAGS) -c -o $@ $< + +# defines $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### diff --git a/spl/board/samsung/smdkv310/mmc_boot.c b/spl/board/samsung/smdkv310/mmc_boot.c new file mode 100644 index 0000000..6eabfac --- /dev/null +++ b/spl/board/samsung/smdkv310/mmc_boot.c @@ -0,0 +1,82 @@ +/* + * Copyright (C) 2011 Samsung Electronics + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include<common.h> +#include <configs/smdkv310.h> + +typedef u32(*copy_sd_mmc_to_mem) \ + (u32 start_block, u32 block_count, u32 *dest_addr); + + +void copy_uboot_to_ram(void) +{ + copy_sd_mmc_to_mem copy_bl2 = (copy_sd_mmc_to_mem)(0x00002488); + copy_bl2(65, BL2_SIZE_BLOC_COUNT, (u32 *)CONFIG_SYS_PHY_UBOOT_BASE); +} + +void board_init_f(unsigned long bootflag) +{ + __attribute__((noreturn)) void (*uboot)(void); + copy_uboot_to_ram(); + + /* + * Jump to U-Boot image + */ + uboot = (void *)CONFIG_SYS_MMC_UBOOT_START; + (*uboot)(); + /* Never returns Here */ +} + +/* Place Holders */ +void board_init_r(gd_t *id, ulong dest_addr) +{ +} + +void do_undefined_instruction(struct pt_regs *pt_regs) +{ +} + +void do_software_interrupt(struct pt_regs *pt_regs) +{ +} + +void do_prefetch_abort(struct pt_regs *pt_regs) +{ +} + +void do_data_abort(struct pt_regs *pt_regs) +{ +} + +void do_not_used(struct pt_regs *pt_regs) +{ +} + +void do_fiq(struct pt_regs *pt_regs) +{ +} + +#ifndef CONFIG_USE_IRQ +void do_irq(struct pt_regs *pt_regs) +{ +} +#endif diff --git a/spl/board/samsung/smdkv310/tools/mkv310_image.c b/spl/board/samsung/smdkv310/tools/mkv310_image.c new file mode 100644 index 0000000..fdef3fe --- /dev/null +++ b/spl/board/samsung/smdkv310/tools/mkv310_image.c @@ -0,0 +1,103 @@ +/* + * Copyright (C) 2011 Samsung Electronics + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <stdio.h> +#include <stdlib.h> +#include <unistd.h> +#include <fcntl.h> +#include <errno.h> +#include <string.h> + +#define CHECKSUM_OFFSET (14*1024-4) +#define BUFSIZE (16*1024) +#define FILE_PERM (S_IRUSR | S_IWUSR | S_IRGRP \ + | S_IWGRP | S_IROTH | S_IWOTH) + +int main(int argc, char **argv) +{ + int i, len; + unsigned char buffer[BUFSIZE] = {0}; + int ifd, ofd; + unsigned int checksum = 0, count; + + if (argc != 3) { + printf(" %d Wrong number of arguments\n", argc); + exit(EXIT_FAILURE); + } + + ifd = open(argv[1], O_RDONLY); + if (ifd < 0) { + fprintf(stderr, "%s: Can't open %s: %s\n", + argv[0], argv[1], strerror(errno)); + exit(EXIT_FAILURE); + } + + ofd = open(argv[2], O_WRONLY | O_CREAT | O_TRUNC, FILE_PERM); + if (ifd < 0) { + fprintf(stderr, "%s: Can't open %s: %s\n", + argv[0], argv[2], strerror(errno)); + if (ifd) + close(ifd); + exit(EXIT_FAILURE); + } + + len = lseek(ifd, 0, SEEK_END); + lseek(ifd, 0, SEEK_SET); + + count = (len < CHECKSUM_OFFSET) ? len : CHECKSUM_OFFSET; + + if (read(ifd, buffer, count) != count) { + fprintf(stderr, "%s: Can't read %s: %s\n", + argv[0], argv[1], strerror(errno)); + + if (ifd) + close(ifd); + if (ofd) + close(ofd); + + exit(EXIT_FAILURE); + } + + for (i = 0, checksum = 0; i < CHECKSUM_OFFSET; i++) + checksum += buffer[i]; + + memcpy(&buffer[CHECKSUM_OFFSET], &checksum, sizeof(checksum)); + + if (write(ofd, buffer, BUFSIZE) != BUFSIZE) { + fprintf(stderr, "%s: Can't write %s: %s\n", + argv[0], argv[2], strerror(errno)); + + if (ifd) + close(ifd); + if (ofd) + close(ofd); + + exit(EXIT_FAILURE); + } + + if (ifd) + close(ifd); + if (ofd) + close(ofd); + + return EXIT_SUCCESS; +} diff --git a/spl/board/samsung/smdkv310/u-boot.lds b/spl/board/samsung/smdkv310/u-boot.lds new file mode 100644 index 0000000..93cfab5 --- /dev/null +++ b/spl/board/samsung/smdkv310/u-boot.lds @@ -0,0 +1,86 @@ +/* + * January 2004 - Changed to support H4 device + * Copyright (c) 2004-2008 Texas Instruments + * + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, garyj@denx.de + * + * (C) Copyright 2011 + * Chander Kashyap, Samsung Electronics, k.chander@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + + . = ALIGN(4); + .text : + { + start.o (.text) + *(.text) + } + + . = ALIGN(4); + .rodata : { *(SORT_BY_ALIGNMENT(SORT_BY_NAME(.rodata*))) } + + . = ALIGN(4); + .data : { + *(.data) + } + + . = ALIGN(4); + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + + .rel.dyn : { + __rel_dyn_start = .; + *(.rel*) + __rel_dyn_end = .; + } + + .dynsym : { + __dynsym_start = .; + *(.dynsym) + } + + _end = .; + + .bss __rel_dyn_start (OVERLAY) : { + __bss_start = .; + *(.bss) + . = ALIGN(4); + __bss_end__ = .; + } + + /DISCARD/ : { *(.dynstr*) } + /DISCARD/ : { *(.dynamic*) } + /DISCARD/ : { *(.plt*) } + /DISCARD/ : { *(.interp*) } + /DISCARD/ : { *(.gnu*) } +} -- 1.7.1
Chander Kashyap
Minkyu Kang
